Version 4 SHEET 1 1056 724 WIRE -80 208 -176 208 WIRE 32 208 0 208 WIRE 192 208 64 208 WIRE 288 208 192 208 WIRE 416 208 352 208 WIRE 432 208 416 208 WIRE 32 272 32 208 WIRE 144 272 32 272 WIRE 192 272 144 272 WIRE 432 272 432 208 WIRE -80 288 -80 272 WIRE -176 304 -176 208 WIRE 0 336 0 272 WIRE 64 336 64 208 WIRE 64 336 0 336 WIRE 96 336 64 336 WIRE 144 368 -80 368 WIRE 432 368 432 336 WIRE 432 368 144 368 WIRE 144 384 144 368 WIRE -176 400 -176 384 FLAG -176 400 0 FLAG -176 208 Vcc+ FLAG 416 208 Vsek+ FLAG 192 272 Vo1 IOPIN 192 272 Out FLAG 192 208 Vo2 IOPIN 192 208 Out FLAG 144 384 0 SYMBOL ind2 16 192 R90 WINDOW 3 -26 -5 VTop 2 WINDOW 0 4 56 VBottom 2 SYMATTR Value 50µ SYMATTR InstName L1 SYMATTR Type ind SYMATTR SpiceLine Rser=2.6 SYMBOL ind2 -96 288 R270 WINDOW 3 33 -11 VBottom 2 WINDOW 0 32 56 VTop 2 SYMATTR Value 20m SYMATTR InstName L2 SYMATTR Type ind SYMATTR SpiceLine Rser=0.6 SYMBOL res -96 272 R0 SYMATTR Value 0 SYMATTR InstName R1 SYMBOL diode 352 224 M270 WINDOW 0 32 32 VTop 2 WINDOW 3 56 90 VBottom 2 SYMATTR InstName D2 SYMATTR Value 1N4148 SYMBOL LED 448 336 R180 WINDOW 0 -37 29 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D3 SYMATTR Value NSSW008CT-P1 SYMATTR Description Diode SYMATTR Type diode SYMBOL njf 96 272 R0 SYMATTR InstName J2 SYMATTR Value 2SK170 SYMBOL voltage -176 288 R0 WINDOW 3 -77 4 Left 2 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR Value 50mV SYMATTR InstName V2 TEXT -112 152 Left 2 !K1 L1 L2 0.999 TEXT -304 120 Left 2 !.tran 0 .2m 0 startup TEXT -376 448 Left 2 !.MODEL 2SK170 NJF(Beta=59.86m Rs=4.151 Rd=4.151 \n + Betatce=-.5 Lambda=1.923m Vto=-.5024 \n + Vtotc=-2.5m Cgd=20p M=.3805 Pb=.4746 \n + Fc=.5 Cgs=25.48p Isr=84.77p Nr=2 Is=8.477p \n + N=1 Xti=3 Alpha=10u Vk=100 Kf=111.3E-18 Af=1) TEXT 232 472 Left 2 !.model bf862 njf(beta=47.800m rd=.8 rs=7.5 lambda=37.3m \n+ vto=-.57093 is=424.6p cgd=7.4p pb=.5 \n+ fc=.5 cgs=8.29p kf=87.5e-18 af=1 alpha=-1m nr=2 isr=2.995p \n+ vtotc=-2m betatce=-.5 xti=3 vk=59.97 m=.6015 MFG=PHILIPS
