Version 4 SHEET 1 1316 680 WIRE 16 96 -48 96 WIRE 128 96 96 96 WIRE 176 96 128 96 WIRE 240 96 176 96 WIRE 240 128 240 96 WIRE 128 192 128 96 WIRE -48 208 -48 96 WIRE 240 240 240 208 WIRE 288 240 240 240 WIRE 352 240 288 240 WIRE 384 240 352 240 WIRE 560 240 464 240 WIRE 608 240 560 240 WIRE 240 272 240 240 WIRE 608 272 608 240 WIRE 832 320 816 320 WIRE 848 320 832 320 WIRE 1024 320 992 320 WIRE 1040 320 1024 320 WIRE -48 384 -48 288 WIRE 128 384 128 272 WIRE 128 384 -48 384 WIRE 240 384 240 352 WIRE 240 384 128 384 WIRE 608 384 608 352 WIRE 608 384 240 384 WIRE 240 400 240 384 FLAG 240 400 0 FLAG 240 96 1 FLAG 608 240 2 FLAG 288 240 3 DATAFLAG 176 96 "round($*100)/100" DATAFLAG 352 240 "round($*100)/100" DATAFLAG 560 240 "" DATAFLAG -48 96 "" DATAFLAG 1024 320 "round(V(2)*100)/100" DATAFLAG 832 320 "round(V(3)*10000)/10000" DATAFLAG 416 192 "round(I(R5)*10000)/10000" SYMBOL res 0 112 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R1 SYMATTR Value 10 SYMBOL res 112 176 R0 SYMATTR InstName R2 SYMATTR Value 12.35 SYMBOL res 224 112 R0 SYMATTR InstName R3 SYMATTR Value 15 SYMBOL res 224 256 R0 SYMATTR InstName R4 SYMATTR Value 12 SYMBOL res 368 256 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R5 SYMATTR Value 30 SYMBOL voltage 608 256 R0 SYMATTR InstName V1 SYMATTR Value 9 SYMBOL voltage -48 192 R0 SYMATTR InstName V2 SYMATTR Value 12 TEXT -72 24 Left 2 !.op TEXT -112 -216 Left 2 ;Run the simulation.\n \nRight mouse-click into an empty area.\nChoose View -> Place .op Data Label\n \nIf you have only a .op analysis,\njust clicking on a net is sufficient\nto place a Data Label. TEXT 432 -240 Left 2 ;Change the number of digits\n \nRight-mouse-click on the Plot Label \nChange the $ to this expression.\n \n$ -> round($*100)/100 TEXT 712 80 Left 2 ;Plot labels can be copied and moved \nto any place on the schematic. TEXT -72 488 Left 2 ;The plot labels are available when a DC operating point \nhas been calculated from LTspice. This will be not the case\nif a pure linear circuit is simulated in an AC-analysis. Something\nnonlinear can be added to force a DC-op analysis in this case. TEXT 416 -8 Left 2 ;Plot labels can be currents or any other expression. TEXT 776 232 Left 2 ;Voltmeter TEXT 968 232 Left 2 ;Voltmeter TEXT 800 264 Left 2 ;net 1 TEXT 992 264 Left 2 ;net 2 TEXT 0 24 Left 2 !.tran 1m LINE Normal 224 64 400 -96 LINE Normal 240 64 224 64 LINE Normal 224 64 240 64 LINE Normal 224 48 224 64 LINE Normal 416 144 544 16 LINE Normal 432 144 416 144 LINE Normal 416 144 432 144 LINE Normal 416 128 416 144 LINE Normal 936 184 925 171 LINE Normal 948 169 936 184 LINE Normal 936 184 948 169 LINE Normal 936 136 936 184 RECTANGLE Normal 928 320 736 288 RECTANGLE Normal 928 288 736 208 RECTANGLE Normal 1104 320 944 288 RECTANGLE Normal 1104 320 944 208
