# # # # # # # # # # # # # # # # # # # # # # # # # # # -==**> EEPROM ASCII file Rohde & Schwarz <**==- # # generated by # # EEP # # # # # # # # # # # # # # # # # # # # # # # # # # # ID: IDENT_2 ALIGNMENT: 16 EEPROMSIZE: 32768 PARTNUMBER: 1135.6925.02 HWCODE: 255 PRODUCTINDEX: 13.24 SN: 103388/002 PRODUCTDATE: 2004-09-17 READCODE: 0 TESTINSTRUCTION: 13.18 NAME: RXTX ID: MODIFICATION_100 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 SERVICECODE: 0 ID: STATISTICS_300 OPHOURS: 0 # gain temperature characteristic (TX) ID: USER_14000 UPDATE_INDEX: 01.03 ROWS: 2 COLUMNS: 7 ROW_ID_TYPE: INT8 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #========================================================================== # temp TX... # COL 1 2 3 4 5 6 7 #========================================================================== 1: 10 1.07 1.18 1.34 1.66 1.65 1.67 1.57 2: 40 0.00 0.00 0.00 0.00 0.00 0.00 0.00 ROWS: 2 COLUMNS: 1 ROW_ID_TYPE: INT8 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #==================== # temp TX... #==================== 1: 10 1.37 2: 40 0.00 # attenuator settings (TX) ID: USER_14010 UPDATE_INDEX: 04.00 ROWS: 67 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: RXTX_TX_GAIN_DESCRIPTOR AUX1: 0.00 AUX2: -2.56 AUX3: 0.00 #========================================================== # ID NomGain RefGain LCU Step Att5 Att6 Ampl Path #========================================================== 1: 1 -15 -15 0 0 0 0 0 1 2: 51 -24 -24 0 0 1 0 0 0 3: 52 -24 -24 0 0 0 1 0 0 4: 53 24 24 0 0 0 0 1 0 5: 101 -1 -1 0 1 0 0 0 0 6: 102 -2 -2 0 2 0 0 0 0 7: 103 -3 -3 0 3 0 0 0 0 8: 104 -4 -4 0 4 0 0 0 0 9: 105 -5 -5 0 5 0 0 0 0 10: 106 -6 -6 0 6 0 0 0 0 11: 107 -7 -7 0 7 0 0 0 0 12: 108 -8 -8 0 8 0 0 0 0 13: 109 -9 -9 0 9 0 0 0 0 14: 110 -10 -10 0 10 0 0 0 0 15: 111 -11 -11 0 11 0 0 0 0 16: 112 -12 -12 0 12 0 0 0 0 17: 113 -13 -13 0 13 0 0 0 0 18: 114 -14 -14 0 14 0 0 0 0 19: 115 -15 -15 0 15 0 0 0 0 20: 116 -16 -16 0 16 0 0 0 0 21: 117 -17 -17 0 17 0 0 0 0 22: 118 -18 -18 0 18 0 0 0 0 23: 119 -19 -19 0 19 0 0 0 0 24: 120 -20 -20 0 20 0 0 0 0 25: 121 -21 -21 0 21 0 0 0 0 26: 122 -22 -22 0 22 0 0 0 0 27: 123 -23 -23 0 23 0 0 0 0 28: 151 -20 -20 -500 0 0 0 0 0 29: 152 -19 -19 -475 0 0 0 0 0 30: 153 -18 -18 -450 0 0 0 0 0 31: 154 -17 -17 -425 0 0 0 0 0 32: 155 -16 -16 -400 0 0 0 0 0 33: 156 -15 -15 -375 0 0 0 0 0 34: 157 -14 -14 -350 0 0 0 0 0 35: 158 -13 -13 -325 0 0 0 0 0 36: 159 -12 -12 -300 0 0 0 0 0 37: 160 -11 -11 -275 0 0 0 0 0 38: 161 -10 -10 -250 0 0 0 0 0 39: 162 -9 -9 -225 0 0 0 0 0 40: 163 -8 -8 -200 0 0 0 0 0 41: 164 -7 -7 -175 0 0 0 0 0 42: 165 -6 -6 -150 0 0 0 0 0 43: 166 -5 -5 -125 0 0 0 0 0 44: 167 -4 -4 -100 0 0 0 0 0 45: 168 -3 -3 -75 0 0 0 0 0 46: 169 -2 -2 -50 0 0 0 0 0 47: 170 -1 -1 -25 0 0 0 0 0 48: 171 1 1 25 0 0 0 0 0 49: 172 2 2 50 0 0 0 0 0 50: 173 3 3 75 0 0 0 0 0 51: 174 4 4 100 0 0 0 0 0 52: 175 5 5 125 0 0 0 0 0 53: 176 6 6 150 0 0 0 0 0 54: 177 7 7 175 0 0 0 0 0 55: 178 8 8 200 0 0 0 0 0 56: 179 9 9 225 0 0 0 0 0 57: 180 10 10 250 0 0 0 0 0 58: 181 11 11 275 0 0 0 0 0 59: 182 12 12 300 0 0 0 0 0 60: 183 12 13 325 0 0 0 0 0 61: 184 14 14 350 0 0 0 0 0 62: 185 15 15 375 0 0 0 0 0 63: 186 16 16 400 0 0 0 0 0 64: 187 17 17 425 0 0 0 0 0 65: 188 18 18 450 0 0 0 0 0 66: 189 19 19 475 0 0 0 0 0 67: 190 20 20 500 0 0 0 0 0 ID: USER_14015 UPDATE_INDEX: 01.01 ROWS: 2 COLUMNS: 41 ROW_ID_TYPE: UINT16 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 30.88 AUX2: 35.35 AUX3: 0.00 #============================================================================================================================================================================================================================================================================================================================================================================================= # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 #============================================================================================================================================================================================================================================================================================================================================================================================= 0: 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 1 #--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 320 0.33 0.49 0.56 0.57 0.51 0.48 0.51 0.57 0.61 0.58 0.51 0.47 0.50 0.58 0.62 0.58 0.51 0.47 0.51 0.59 0.57 0.49 0.47 0.52 0.59 0.60 0.54 0.47 0.46 0.51 0.59 0.59 0.53 0.47 0.47 0.52 0.56 0.53 0.43 0.30 0.61 2: 682 0.61 0.97 1.18 1.23 1.14 1.04 1.06 1.18 1.28 1.27 1.14 1.02 1.04 1.18 1.30 1.27 1.13 1.01 1.05 1.21 1.25 1.10 1.01 1.08 1.23 1.30 1.21 1.05 0.98 1.05 1.23 1.27 1.19 1.05 1.00 1.07 1.18 1.16 0.99 0.73 1.31 # Frequency characteristics of IF path (TX) ID: USER_14020 UPDATE_INDEX: 01.00 ROWS: 1 COLUMNS: 40 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 31.13 AUX2: 35.35 AUX3: 0.00 #========================================================================================================================================================================================================================================================================================================================================================================================= # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 #========================================================================================================================================================================================================================================================================================================================================================================================= 0: 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 #----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 500.000 -0.56 -0.68 -0.63 -0.52 -0.51 -0.57 -0.62 -0.57 -0.43 -0.30 -0.31 -0.39 -0.47 -0.40 -0.24 -0.11 -0.10 -0.20 -0.26 -0.16 0.13 0.10 0.00 -0.03 0.07 0.23 0.30 0.22 0.10 0.04 0.14 0.28 0.31 0.25 0.14 0.10 0.15 0.18 0.07 -0.30 ID: USER_14025 UPDATE_INDEX: 01.01 ROWS: 2 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #========================== #========================== 0: 1 #-------------------------- 1: 1.000 -3.31 2: 13.850 -3.31 ID: USER_14026 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #========================== #========================== 0: 1 #-------------------------- 1: 1.000 -6.00 2: 13.850 -6.00 # Frequency characteristics of common LF path 30 kHz ... 10 MHz (TX) ID: USER_14030 UPDATE_INDEX: 01.02 ROWS: 18 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 30.88 AUX2: 35.48 AUX3: 0.00 #=================================== # MHz IDs... # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 0.030 0.56 -4.67 2: 0.040 0.55 -2.75 3: 0.050 0.51 -2.05 4: 0.060 0.52 -1.74 5: 0.080 0.52 -1.55 6: 0.100 0.50 -1.52 7: 0.150 0.53 -1.56 8: 0.200 0.52 -1.60 9: 0.300 0.51 -1.65 10: 0.500 0.45 -1.71 11: 1.000 0.37 -1.83 12: 2.000 0.29 -2.06 13: 5.000 0.29 -1.88 14: 8.000 0.24 -1.58 15: 10.000 0.18 -1.49 16: 12.000 0.04 -1.43 17: 13.850 -0.09 -1.40 18: 15.360 -0.19 -1.37 ROWS: 9 COLUMNS: 42 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 29.54 AUX2: 34.14 AUX3: 0.00 #=========================================================================================================================================================================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 #=========================================================================================================================================================================================================================================================================================================================================================================================================== 0: 51 52 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 #----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 0.030 0.09 -0.38 -0.28 -0.45 -0.44 -0.35 -0.37 -0.44 -0.53 -0.51 -0.37 -0.24 -0.27 -0.37 -0.45 -0.40 -0.23 -0.11 -0.11 -0.22 -0.28 -0.19 0.10 0.05 -0.06 -0.11 -0.02 0.12 0.16 0.06 -0.11 -0.22 0.18 0.31 0.34 0.27 0.13 0.07 0.12 0.12 -0.02 -0.42 2: 0.100 0.09 -0.38 -0.29 -0.47 -0.46 -0.36 -0.38 -0.45 -0.53 -0.51 -0.37 -0.26 -0.27 -0.37 -0.46 -0.40 -0.23 -0.12 -0.12 -0.23 -0.28 -0.20 0.09 0.05 -0.07 -0.11 -0.03 0.12 0.17 0.06 -0.10 -0.21 0.18 0.31 0.33 0.26 0.14 0.08 0.12 0.13 -0.02 -0.41 3: 0.200 0.08 -0.39 -0.29 -0.47 -0.44 -0.36 -0.37 -0.45 -0.52 -0.49 -0.37 -0.26 -0.27 -0.36 -0.45 -0.40 -0.23 -0.11 -0.11 -0.23 -0.28 -0.20 0.09 0.05 -0.06 -0.10 -0.02 0.12 0.17 0.07 -0.09 -0.21 0.18 0.32 0.33 0.26 0.14 0.09 0.13 0.13 -0.02 -0.41 4: 0.500 0.09 -0.38 -0.28 -0.47 -0.45 -0.35 -0.36 -0.46 -0.52 -0.49 -0.36 -0.25 -0.26 -0.36 -0.45 -0.40 -0.23 -0.11 -0.11 -0.22 -0.28 -0.20 0.10 0.06 -0.05 -0.09 -0.01 0.13 0.19 0.09 -0.06 -0.16 0.19 0.32 0.34 0.27 0.14 0.11 0.14 0.16 0.02 -0.36 5: 2.000 0.11 -0.35 -0.16 -0.35 -0.36 -0.29 -0.30 -0.40 -0.48 -0.46 -0.34 -0.22 -0.25 -0.35 -0.43 -0.38 -0.22 -0.10 -0.11 -0.22 -0.28 -0.19 0.11 0.08 -0.04 -0.07 0.03 0.19 0.27 0.20 0.08 0.04 0.19 0.33 0.36 0.30 0.19 0.15 0.22 0.27 0.16 -0.19 6: 8.000 0.13 -0.34 -0.05 -0.27 -0.28 -0.23 -0.26 -0.36 -0.46 -0.42 -0.33 -0.21 -0.23 -0.34 -0.43 -0.38 -0.21 -0.09 -0.10 -0.21 -0.27 -0.17 0.11 0.09 -0.02 -0.06 0.05 0.22 0.31 0.23 0.12 0.10 0.21 0.35 0.39 0.33 0.22 0.19 0.27 0.32 0.23 -0.10 7: 12.000 0.13 -0.36 -0.14 -0.33 -0.36 -0.30 -0.34 -0.43 -0.51 -0.49 -0.37 -0.26 -0.28 -0.38 -0.46 -0.39 -0.23 -0.12 -0.12 -0.23 -0.28 -0.19 0.11 0.09 -0.02 -0.06 0.06 0.21 0.30 0.24 0.13 0.10 0.20 0.34 0.37 0.31 0.20 0.17 0.25 0.29 0.19 -0.16 8: 13.850 0.14 -0.34 -0.17 -0.39 -0.40 -0.33 -0.36 -0.46 -0.54 -0.51 -0.39 -0.27 -0.28 -0.38 -0.46 -0.40 -0.23 -0.11 -0.11 -0.21 -0.27 -0.18 0.13 0.10 -0.01 -0.04 0.07 0.23 0.32 0.26 0.15 0.11 0.22 0.36 0.40 0.33 0.22 0.19 0.25 0.31 0.21 -0.13 9: 15.360 0.13 -0.34 -0.24 -0.44 -0.44 -0.39 -0.42 -0.51 -0.59 -0.54 -0.41 -0.30 -0.31 -0.40 -0.48 -0.42 -0.25 -0.12 -0.11 -0.23 -0.28 -0.18 0.12 0.09 -0.01 -0.04 0.07 0.23 0.32 0.26 0.16 0.13 0.22 0.37 0.40 0.34 0.23 0.19 0.26 0.30 0.21 -0.13 ID: USER_14035 UPDATE_INDEX: 01.00 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1.000 -3.56 0.00 2: 13.850 -3.56 0.00 # Frequency characteristics 10 ... 600 MHz (TX) ID: USER_14040 UPDATE_INDEX: 02.02 ROWS: 32 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.20 AUX2: 32.26 AUX3: 0.00 #=================================== # MHz IDs... # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1.000 -0.36 -1.85 2: 3.000 -0.56 -2.16 3: 5.000 -0.60 -1.89 4: 7.000 -0.66 -1.66 5: 10.000 -0.70 -1.47 6: 15.000 -0.71 -1.35 7: 20.000 -0.67 -1.32 8: 25.000 -0.61 -1.30 9: 30.000 -0.55 -1.30 10: 40.000 -0.44 -1.30 11: 50.000 -0.39 -1.31 12: 75.000 -0.31 -1.39 13: 100.000 -0.18 -1.47 14: 125.000 -0.08 -1.57 15: 150.000 0.10 -1.68 16: 175.000 0.25 -1.80 17: 200.000 0.43 -1.92 18: 250.000 0.66 -2.04 19: 275.000 0.73 -2.03 20: 300.000 0.80 -1.90 21: 325.000 0.85 -1.70 22: 350.000 0.88 -1.45 23: 375.000 0.92 -1.19 24: 400.000 0.96 -0.93 25: 435.000 1.02 -0.62 26: 470.000 1.05 -0.41 27: 500.000 1.08 -0.26 28: 525.000 1.12 -0.17 29: 550.000 1.15 -0.11 30: 575.000 1.19 -0.07 31: 600.000 1.18 -0.03 32: 632.000 1.17 -0.01 ROWS: 11 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.44 AUX2: 33.20 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 51 52 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 1.000 0.10 -0.39 0.03 0.10 0.15 0.09 0.13 0.17 0.22 0.00 0.04 -0.07 -0.04 -0.14 -0.10 -0.14 -0.09 0.04 0.10 0.15 0.20 0.13 0.18 0.24 0.26 2: 5.000 0.10 -0.37 0.01 0.10 0.15 0.09 0.13 0.18 0.23 -0.11 -0.05 -0.17 -0.10 -0.22 -0.16 -0.20 -0.14 0.07 0.12 0.17 0.23 0.17 0.21 0.23 0.28 3: 10.000 0.12 -0.34 0.03 0.12 0.16 0.10 0.15 0.21 0.25 -0.13 -0.06 -0.18 -0.12 -0.24 -0.17 -0.20 -0.15 0.10 0.14 0.20 0.25 0.19 0.21 0.26 0.30 4: 50.000 0.13 -0.35 0.01 0.11 0.14 0.07 0.11 0.17 0.20 -0.27 -0.21 -0.30 -0.24 -0.34 -0.27 -0.29 -0.24 0.05 0.09 0.15 0.21 0.14 0.15 0.21 0.25 5: 100.000 0.14 -0.33 0.02 0.10 0.13 0.06 0.10 0.15 0.19 -0.24 -0.19 -0.26 -0.21 -0.32 -0.26 -0.27 -0.22 0.03 0.08 0.14 0.17 0.10 0.14 0.19 0.23 6: 200.000 0.18 -0.31 0.03 0.08 0.13 0.03 0.08 0.12 0.17 -0.16 -0.12 -0.17 -0.14 -0.21 -0.17 -0.15 -0.12 0.00 0.04 0.08 0.15 0.06 0.11 0.14 0.20 7: 300.000 0.20 -0.32 0.04 0.07 0.13 0.04 0.09 0.13 0.18 -0.06 -0.06 -0.07 -0.05 -0.11 -0.09 -0.05 -0.03 0.01 0.06 0.11 0.17 0.06 0.13 0.18 0.21 8: 400.000 0.24 -0.31 0.03 0.07 0.12 0.04 0.09 0.12 0.17 0.01 0.03 -0.04 -0.03 -0.11 -0.08 -0.07 -0.06 -0.01 0.05 0.08 0.14 0.09 0.11 0.14 0.19 9: 500.000 0.24 -0.30 0.01 0.07 0.11 0.03 0.07 0.10 0.15 -0.14 -0.11 -0.17 -0.14 -0.22 -0.19 -0.20 -0.14 0.01 0.06 0.09 0.14 0.08 0.12 0.13 0.18 10: 600.000 0.27 -0.29 0.02 0.08 0.12 0.03 0.07 0.12 0.15 -0.34 -0.30 -0.33 -0.28 -0.36 -0.32 -0.30 -0.25 0.02 0.05 0.10 0.15 0.06 0.11 0.15 0.17 11: 632.000 0.27 -0.29 0.02 0.09 0.13 0.04 0.08 0.13 0.17 -0.34 -0.28 -0.32 -0.26 -0.35 -0.30 -0.29 -0.24 0.03 0.06 0.12 0.16 0.09 0.13 0.17 0.20 ID: USER_14045 UPDATE_INDEX: 04.03 ROWS: 3 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 10.000 -4.70 0.00 2: 200.000 -4.10 0.00 3: 632.900 -4.10 0.00 # Frequency characteristics 600.. 1200 MHz (TX) ID: USER_14050 UPDATE_INDEX: 01.01 ROWS: 21 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.69 AUX2: 33.34 AUX3: 0.00 #=================================== # MHz IDs... # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 633.000 1.12 -0.02 2: 650.000 1.10 0.01 3: 670.000 0.97 0.01 4: 700.000 1.09 0.02 5: 730.000 1.12 0.02 6: 770.000 1.15 -0.01 7: 800.000 1.16 -0.04 8: 830.000 1.19 -0.07 9: 870.000 1.20 -0.12 10: 900.000 1.20 -0.14 11: 930.000 1.14 -0.16 12: 950.000 1.08 -0.17 13: 970.000 0.98 -0.17 14: 985.000 0.81 -0.17 15: 1000.000 0.70 -0.17 16: 1025.000 0.80 -0.17 17: 1050.000 0.69 -0.17 18: 1075.000 0.50 -0.17 19: 1100.000 0.25 -0.18 20: 1150.000 -0.05 -0.14 21: 1200.000 -0.16 -0.10 ROWS: 8 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.56 AUX2: 33.34 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 51 52 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 633.000 0.28 -0.30 0.02 0.07 0.11 0.02 0.07 0.12 0.15 -0.35 -0.31 -0.33 -0.29 -0.37 -0.33 -0.31 -0.27 0.01 0.05 0.11 0.15 0.05 0.09 0.14 0.17 2: 700.000 0.29 -0.28 0.01 0.09 0.13 0.05 0.10 0.15 0.19 -0.24 -0.19 -0.26 -0.21 -0.32 -0.26 -0.27 -0.21 0.03 0.07 0.13 0.17 0.09 0.15 0.17 0.19 3: 750.000 0.31 -0.27 0.03 0.09 0.14 0.06 0.10 0.14 0.19 -0.18 -0.13 -0.22 -0.17 -0.28 -0.23 -0.26 -0.21 0.03 0.08 0.11 0.17 0.09 0.13 0.16 0.18 4: 800.000 0.31 -0.26 0.02 0.05 0.10 0.01 0.07 0.08 0.13 -0.22 -0.17 -0.27 -0.22 -0.33 -0.27 -0.31 -0.26 -0.01 0.04 0.06 0.11 0.04 0.07 0.10 0.13 5: 900.000 0.30 -0.28 0.02 0.01 0.06 -0.06 -0.01 -0.01 0.05 -0.35 -0.31 -0.37 -0.32 -0.41 -0.36 -0.37 -0.33 -0.09 -0.03 -0.04 0.01 -0.08 -0.03 -0.02 0.01 6: 1000.000 0.34 -0.30 0.05 0.01 0.08 -0.07 0.00 -0.01 0.07 -0.45 -0.40 -0.39 -0.35 -0.40 -0.35 -0.34 -0.30 -0.06 -0.01 -0.01 0.04 -0.09 -0.03 -0.05 0.03 7: 1100.000 0.34 -0.32 0.09 0.11 0.20 0.07 0.16 0.18 0.27 -0.23 -0.19 -0.11 -0.09 -0.12 -0.09 -0.01 0.00 0.09 0.17 0.19 0.26 0.13 0.19 0.19 0.28 8: 1200.000 0.45 -0.30 0.07 0.03 0.11 -0.01 0.07 0.04 0.13 0.03 0.04 0.00 0.01 -0.04 -0.04 -0.01 -0.01 -0.05 0.02 0.00 0.09 -0.03 0.03 0.00 0.08 ID: USER_14055 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 632.900 -4.30 0.00 2: 1200.100 -4.60 0.00 # Frequency characteristics 1200.. 1700 MHz (TX) ID: USER_14060 UPDATE_INDEX: 01.01 ROWS: 23 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.56 AUX2: 33.47 AUX3: 0.00 #=================================== # MHz IDs... # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1200.000 2.71 -0.09 2: 1215.000 2.69 -0.09 3: 1235.000 2.67 -0.08 4: 1250.000 2.66 -0.09 5: 1260.000 2.66 -0.09 6: 1270.000 2.65 -0.09 7: 1280.000 2.68 -0.10 8: 1290.000 2.75 -0.11 9: 1300.000 2.81 -0.11 10: 1330.000 2.86 -0.14 11: 1350.000 2.87 -0.17 12: 1370.000 2.89 -0.19 13: 1400.000 2.92 -0.23 14: 1415.000 2.91 -0.26 15: 1430.000 2.88 -0.28 16: 1450.000 2.84 -0.31 17: 1470.000 2.81 -0.35 18: 1500.000 2.72 -0.41 19: 1530.000 2.72 -0.46 20: 1570.000 2.65 -0.51 21: 1585.000 2.62 -0.53 22: 1595.000 2.58 -0.53 23: 1607.000 2.54 -0.53 ROWS: 9 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.56 AUX2: 33.34 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 51 52 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 1200.000 0.44 -0.34 0.00 -0.17 -0.12 -0.27 -0.21 -0.30 -0.23 -0.18 -0.16 -0.30 -0.29 -0.37 -0.36 -0.42 -0.42 -0.36 -0.29 -0.39 -0.31 -0.43 -0.37 -0.44 -0.38 2: 1250.000 0.52 -0.32 -0.02 -0.22 -0.18 -0.34 -0.28 -0.40 -0.33 -0.15 -0.15 -0.32 -0.32 -0.40 -0.40 -0.47 -0.47 -0.44 -0.37 -0.49 -0.41 -0.53 -0.45 -0.55 -0.50 3: 1300.000 0.59 -0.29 0.00 -0.24 -0.19 -0.36 -0.30 -0.43 -0.36 -0.20 -0.21 -0.35 -0.36 -0.41 -0.42 -0.48 -0.49 -0.45 -0.37 -0.51 -0.43 -0.58 -0.49 -0.59 -0.54 4: 1350.000 0.65 -0.28 0.01 -0.21 -0.15 -0.32 -0.25 -0.39 -0.31 -0.21 -0.23 -0.32 -0.33 -0.35 -0.37 -0.39 -0.41 -0.37 -0.30 -0.46 -0.36 -0.50 -0.44 -0.55 -0.48 5: 1400.000 0.71 -0.26 0.05 -0.14 -0.06 -0.23 -0.15 -0.27 -0.18 -0.14 -0.17 -0.19 -0.22 -0.21 -0.24 -0.23 -0.26 -0.25 -0.17 -0.31 -0.23 -0.38 -0.31 -0.41 -0.33 6: 1450.000 0.76 -0.25 0.08 -0.06 0.05 -0.11 -0.02 -0.11 0.00 0.01 -0.03 0.00 -0.03 -0.01 -0.04 0.01 -0.03 -0.11 -0.02 -0.13 -0.05 -0.21 -0.14 -0.22 -0.16 7: 1500.000 0.82 -0.27 0.10 0.00 0.12 -0.03 0.07 0.01 0.12 0.19 0.14 0.20 0.16 0.18 0.13 0.20 0.16 -0.04 0.05 -0.03 0.05 -0.10 -0.03 -0.09 -0.01 8: 1550.000 0.85 -0.29 0.09 0.03 0.14 0.00 0.10 0.06 0.16 0.36 0.31 0.36 0.30 0.31 0.24 0.33 0.27 -0.07 0.01 -0.03 0.04 -0.09 -0.02 -0.05 0.01 9: 1607.000 0.89 -0.33 0.04 -0.04 0.04 -0.10 -0.02 -0.07 0.01 0.47 0.40 0.37 0.30 0.27 0.19 0.25 0.17 -0.28 -0.21 -0.24 -0.17 -0.27 -0.21 -0.25 -0.20 ID: USER_14065 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1200.100 -7.60 0.00 2: 1607.900 -7.50 0.00 # Frequency characteristics 1700.. 2200 MHz (TX) ID: USER_14070 UPDATE_INDEX: 01.01 ROWS: 39 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.44 AUX2: 33.34 AUX3: 0.00 #=================================== # MHz IDs... # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1608.000 2.53 -0.55 2: 1620.000 2.49 -0.53 3: 1630.000 2.49 -0.52 4: 1640.000 2.48 -0.51 5: 1650.000 2.47 -0.50 6: 1660.000 2.42 -0.49 7: 1670.000 2.38 -0.47 8: 1700.000 2.32 -0.42 9: 1720.000 2.28 -0.38 10: 1740.000 2.28 -0.34 11: 1760.000 2.27 -0.34 12: 1780.000 2.17 -0.30 13: 1800.000 2.10 -0.27 14: 1830.000 1.99 -0.26 15: 1850.000 1.92 -0.25 16: 1870.000 1.91 -0.24 17: 1885.000 1.89 -0.23 18: 1900.000 1.82 -0.22 19: 1915.000 1.77 -0.20 20: 1930.000 1.74 -0.20 21: 1970.000 1.63 -0.17 22: 2000.000 1.57 -0.18 23: 2010.000 1.57 -0.18 24: 2020.000 1.54 -0.18 25: 2030.000 1.52 -0.17 26: 2040.000 1.50 -0.18 27: 2050.000 1.47 -0.18 28: 2080.000 1.37 -0.21 29: 2100.000 1.31 -0.22 30: 2110.000 1.24 -0.23 31: 2120.000 1.17 -0.23 32: 2130.000 1.11 -0.24 33: 2140.000 1.05 -0.23 34: 2150.000 1.00 -0.23 35: 2160.000 1.00 -0.22 36: 2170.000 0.96 -0.21 37: 2180.000 0.93 -0.22 38: 2190.000 0.88 -0.24 39: 2200.000 0.80 -0.25 ROWS: 12 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.44 AUX2: 33.34 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 51 52 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 1608.000 0.85 -0.38 0.03 -0.07 0.01 -0.13 -0.05 -0.11 -0.02 0.44 0.37 0.34 0.27 0.24 0.16 0.21 0.14 -0.32 -0.24 -0.27 -0.20 -0.31 -0.24 -0.30 -0.25 2: 1700.000 0.89 -0.40 -0.05 -0.26 -0.23 -0.38 -0.33 -0.45 -0.39 0.42 0.32 0.16 0.05 0.01 -0.09 -0.10 -0.21 -0.63 -0.57 -0.66 -0.60 -0.69 -0.63 -0.73 -0.71 3: 1750.000 0.91 -0.40 -0.05 -0.28 -0.26 -0.41 -0.37 -0.51 -0.46 0.40 0.27 0.10 -0.01 -0.03 -0.15 -0.17 -0.29 -0.63 -0.57 -0.70 -0.67 -0.74 -0.70 -0.83 -0.80 4: 1800.000 0.92 -0.39 -0.04 -0.30 -0.28 -0.41 -0.38 -0.53 -0.48 0.38 0.25 0.08 -0.05 -0.04 -0.17 -0.18 -0.32 -0.58 -0.54 -0.70 -0.66 -0.75 -0.72 -0.84 -0.83 5: 1850.000 0.95 -0.38 -0.02 -0.28 -0.25 -0.37 -0.33 -0.49 -0.44 0.38 0.24 0.09 -0.04 -0.01 -0.14 -0.16 -0.30 -0.48 -0.44 -0.62 -0.59 -0.68 -0.67 -0.80 -0.79 6: 1900.000 0.97 -0.38 0.01 -0.24 -0.21 -0.30 -0.27 -0.42 -0.38 0.38 0.23 0.12 -0.02 0.04 -0.10 -0.10 -0.26 -0.33 -0.31 -0.51 -0.50 -0.58 -0.57 -0.72 -0.72 7: 1950.000 0.98 -0.39 0.04 -0.18 -0.14 -0.21 -0.18 -0.31 -0.27 0.39 0.24 0.17 0.03 0.12 -0.03 -0.01 -0.17 -0.16 -0.16 -0.35 -0.35 -0.44 -0.45 -0.58 -0.60 8: 2000.000 0.95 -0.45 0.04 -0.13 -0.08 -0.15 -0.11 -0.22 -0.18 0.38 0.22 0.20 0.05 0.15 0.00 0.04 -0.13 -0.07 -0.07 -0.26 -0.26 -0.34 -0.36 -0.50 -0.50 9: 2050.000 0.87 -0.53 0.06 -0.09 -0.04 -0.10 -0.07 -0.16 -0.13 0.34 0.20 0.18 0.03 0.15 0.00 0.04 -0.13 0.03 0.02 -0.18 -0.19 -0.26 -0.29 -0.43 -0.46 10: 2100.000 0.77 -0.63 0.06 -0.07 -0.02 -0.06 -0.03 -0.11 -0.09 0.28 0.14 0.14 -0.01 0.11 -0.04 0.00 -0.16 0.10 0.06 -0.12 -0.15 -0.19 -0.26 -0.37 -0.41 11: 2150.000 0.69 -0.73 0.07 -0.03 0.01 -0.02 0.00 -0.05 -0.04 0.20 0.05 0.09 -0.06 0.08 -0.08 -0.03 -0.19 0.17 0.12 -0.04 -0.11 -0.14 -0.21 -0.32 -0.39 12: 2200.000 0.61 -0.79 0.08 -0.01 0.03 0.01 0.02 -0.03 -0.02 0.09 -0.04 0.01 -0.14 0.01 -0.14 -0.09 -0.25 0.23 0.18 0.00 -0.07 -0.10 -0.19 -0.27 -0.37 ID: USER_14075 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1607.000 -7.40 0.00 2: 2200.100 -6.80 0.00 # Frequency characteristics 2200.. 2700 MHz (TX) ID: USER_14080 UPDATE_INDEX: 01.02 ROWS: 34 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.56 AUX2: 33.34 AUX3: 0.00 #=================================== # MHz IDs... # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 2200.000 1.91 -0.26 2: 2220.000 2.04 -0.28 3: 2240.000 2.16 -0.33 4: 2260.000 2.27 -0.36 5: 2280.000 2.27 -0.35 6: 2300.000 2.25 -0.33 7: 2320.000 2.21 -0.30 8: 2340.000 2.06 -0.26 9: 2360.000 1.94 -0.21 10: 2380.000 1.76 -0.15 11: 2400.000 1.53 -0.11 12: 2420.000 1.37 -0.10 13: 2440.000 1.15 -0.11 14: 2460.000 0.90 -0.10 15: 2480.000 0.79 -0.14 16: 2500.000 0.68 -0.17 17: 2520.000 0.61 -0.20 18: 2540.000 0.57 -0.21 19: 2550.000 0.55 -0.21 20: 2560.000 0.54 -0.22 21: 2570.000 0.56 -0.23 22: 2580.000 0.59 -0.23 23: 2590.000 0.63 -0.23 24: 2600.000 0.65 -0.23 25: 2610.000 0.66 -0.24 26: 2620.000 0.71 -0.26 27: 2630.000 0.77 -0.26 28: 2640.000 0.84 -0.27 29: 2650.000 0.90 -0.28 30: 2660.000 0.93 -0.29 31: 2670.000 0.96 -0.30 32: 2680.000 1.01 -0.31 33: 2690.000 1.06 -0.32 34: 2700.000 1.13 -0.33 ROWS: 16 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.93 AUX2: 33.47 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 51 52 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 2200.000 0.56 -0.82 -0.02 -0.03 -0.03 -0.07 -0.07 -0.06 -0.07 0.00 -0.14 -0.06 -0.20 -0.11 -0.26 -0.15 -0.32 -0.06 -0.12 -0.18 -0.24 -0.28 -0.36 -0.39 -0.48 2: 2230.000 0.53 -0.84 -0.03 -0.06 -0.06 -0.10 -0.11 -0.10 -0.12 -0.01 -0.15 -0.10 -0.25 -0.17 -0.32 -0.24 -0.40 -0.09 -0.17 -0.22 -0.31 -0.33 -0.41 -0.44 -0.55 3: 2270.000 0.52 -0.85 -0.02 -0.06 -0.08 -0.10 -0.12 -0.13 -0.15 0.00 -0.13 -0.15 -0.29 -0.21 -0.36 -0.32 -0.47 -0.07 -0.15 -0.24 -0.33 -0.32 -0.43 -0.48 -0.61 4: 2300.000 0.54 -0.82 -0.01 -0.08 -0.08 -0.10 -0.12 -0.14 -0.16 -0.01 -0.13 -0.18 -0.31 -0.23 -0.38 -0.36 -0.51 -0.01 -0.09 -0.22 -0.31 -0.32 -0.41 -0.49 -0.61 5: 2330.000 0.59 -0.79 0.01 -0.07 -0.07 -0.09 -0.10 -0.13 -0.16 -0.04 -0.16 -0.20 -0.34 -0.25 -0.39 -0.40 -0.54 0.06 -0.02 -0.19 -0.28 -0.27 -0.39 -0.49 -0.61 6: 2370.000 0.66 -0.70 0.02 -0.08 -0.07 -0.07 -0.08 -0.13 -0.15 -0.11 -0.23 -0.27 -0.39 -0.28 -0.42 -0.43 -0.58 0.17 0.08 -0.13 -0.23 -0.23 -0.36 -0.47 -0.59 7: 2400.000 0.74 -0.64 0.04 -0.06 -0.04 -0.05 -0.06 -0.10 -0.13 -0.20 -0.30 -0.32 -0.43 -0.30 -0.44 -0.44 -0.59 0.24 0.14 -0.07 -0.18 -0.18 -0.31 -0.43 -0.57 8: 2430.000 0.80 -0.61 0.06 -0.05 -0.02 -0.03 -0.04 -0.09 -0.11 -0.30 -0.41 -0.38 -0.50 -0.36 -0.49 -0.48 -0.62 0.30 0.20 -0.03 -0.15 -0.16 -0.29 -0.41 -0.56 9: 2470.000 0.86 -0.58 0.05 -0.04 -0.02 -0.04 -0.04 -0.08 -0.11 -0.49 -0.59 -0.52 -0.63 -0.46 -0.58 -0.56 -0.70 0.29 0.19 -0.02 -0.15 -0.16 -0.29 -0.41 -0.56 10: 2500.000 0.90 -0.56 0.04 -0.04 -0.02 -0.04 -0.05 -0.07 -0.10 -0.64 -0.73 -0.61 -0.71 -0.54 -0.66 -0.61 -0.75 0.27 0.16 -0.04 -0.17 -0.17 -0.33 -0.40 -0.57 11: 2530.000 0.93 -0.56 0.04 -0.02 -0.01 -0.04 -0.06 -0.05 -0.10 -0.77 -0.86 -0.69 -0.79 -0.62 -0.74 -0.66 -0.79 0.21 0.10 -0.05 -0.20 -0.19 -0.35 -0.41 -0.58 12: 2570.000 1.01 -0.57 0.01 -0.01 -0.02 -0.07 -0.09 -0.06 -0.11 -0.93 -1.02 -0.81 -0.91 -0.74 -0.86 -0.74 -0.88 0.08 -0.04 -0.13 -0.28 -0.27 -0.43 -0.45 -0.63 13: 2600.000 1.04 -0.58 -0.03 -0.02 -0.04 -0.10 -0.14 -0.07 -0.13 -1.05 -1.14 -0.90 -1.00 -0.83 -0.95 -0.82 -0.95 -0.04 -0.16 -0.21 -0.35 -0.34 -0.51 -0.50 -0.69 14: 2630.000 1.07 -0.59 -0.06 -0.01 -0.06 -0.12 -0.17 -0.08 -0.14 -1.12 -1.22 -0.96 -1.06 -0.91 -1.03 -0.88 -1.01 -0.16 -0.27 -0.27 -0.42 -0.41 -0.57 -0.54 -0.73 15: 2670.000 1.06 -0.67 -0.09 -0.01 -0.08 -0.14 -0.20 -0.09 -0.17 -1.20 -1.29 -1.03 -1.12 -1.00 -1.12 -0.95 -1.07 -0.28 -0.42 -0.37 -0.52 -0.49 -0.67 -0.60 -0.79 16: 2700.000 1.07 -0.73 -0.11 -0.01 -0.09 -0.15 -0.22 -0.09 -0.18 -1.22 -1.31 -1.05 -1.14 -1.04 -1.15 -0.98 -1.11 -0.35 -0.48 -0.41 -0.57 -0.53 -0.71 -0.63 -0.82 ID: USER_14085 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 2200.100 -5.40 0.00 2: 2697.700 -6.30 0.00 # Frequency characteristics 2700.. 2800 MHz (TX) ID: USER_14090 UPDATE_INDEX: 02.01 ROWS: 6 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 29.17 AUX2: 33.87 AUX3: 0.00 #=================================== # MHz IDs... # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 2650.000 0.86 -0.30 2: 2660.000 0.89 -0.31 3: 2670.000 0.92 -0.32 4: 2680.000 0.97 -0.33 5: 2690.000 1.02 -0.35 6: 2700.000 1.08 -0.36 ROWS: 3 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 29.17 AUX2: 34.01 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 51 52 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 2650.000 1.02 -0.63 -0.07 0.00 -0.05 -0.12 -0.18 -0.08 -0.15 -1.16 -1.26 -0.99 -1.09 -0.95 -1.07 -0.91 -1.04 -0.23 -0.35 -0.32 -0.47 -0.44 -0.61 -0.56 -0.75 2: 2670.000 1.04 -0.69 -0.07 0.01 -0.05 -0.11 -0.19 -0.08 -0.15 -1.18 -1.27 -1.01 -1.11 -0.98 -1.09 -0.94 -1.06 -0.27 -0.40 -0.34 -0.52 -0.48 -0.66 -0.59 -0.78 3: 2700.000 1.04 -0.76 -0.10 0.00 -0.07 -0.13 -0.21 -0.09 -0.17 -1.21 -1.29 -1.04 -1.13 -1.02 -1.13 -0.97 -1.09 -0.34 -0.47 -0.40 -0.54 -0.51 -0.69 -0.61 -0.81 ID: USER_14095 UPDATE_INDEX: 04.03 ROWS: 1 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 2700.000 -6.30 0.00 # optimal absolute level at 1. mixer (X14 & X17) (TX) ID: USER_14200 UPDATE_INDEX: 02.00 ROWS: 3 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #============== # level #============== 1: -15.00 2: -25.00 3: -5.00 # measured relative level at 1. mixer (X14 & X17) (TX) ID: USER_14210 UPDATE_INDEX: 03.00 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 49.19 AUX2: 55.89 AUX3: 0.00 #======================= # db # COL 1 2 #======================= 1: -23.00 -33.44 2: -36.00 -46.27 # Gain to external IF2-input (TX) ID: USER_14220 UPDATE_INDEX: 01.00 ROWS: 1 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 29.30 AUX2: 34.01 AUX3: 0.00 #========================== # db #========================== 0: 1 #-------------------------- 1: 500.000 -19.22 ID: USER_14221 UPDATE_INDEX: 01.00 ROWS: 16 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 28.93 AUX2: 34.14 AUX3: 0.00 #=============================== # Magnit Delay #=============================== 1: -10000 -0.20 0.00 2: -8000 -0.08 0.00 3: -6000 -0.02 0.00 4: -4000 0.05 0.00 5: -2000 0.03 0.00 6: 0 0.00 0.00 7: 2000 -0.06 0.00 8: 4000 -0.10 0.00 9: 6000 -0.17 0.00 10: 8000 -0.23 0.00 11: 10000 -0.33 0.00 12: 12000 -0.40 0.00 13: 15000 -0.44 0.00 14: 20000 -0.51 0.00 15: 25000 -0.52 0.00 16: 30000 -0.48 0.00 ID: USER_14222 UPDATE_INDEX: 01.01 ROWS: 15 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 28.93 AUX2: 34.14 AUX3: 0.00 #=============================== # Magnit Delay #=============================== 1: -12000 -2.45 0.00 2: -10000 -1.19 0.00 3: -8000 -0.55 0.00 4: -6000 -0.34 0.00 5: -4000 -0.20 0.00 6: -3000 -0.16 0.00 7: -2000 -0.12 0.00 8: -1000 -0.05 0.00 9: 0 0.00 0.00 10: 1000 0.08 0.00 11: 2000 0.11 0.00 12: 3000 0.12 0.00 13: 4000 0.14 0.00 14: 5000 0.10 0.00 15: 6000 0.09 0.00 # Passband characteristic of subharmonics filter (TX) ID: USER_14230 UPDATE_INDEX: 03.00 ROWS: 45 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 29.17 AUX2: 34.01 AUX3: 0.00 #============================== # Level Magnit Delay # Magnit Delay #============================== 1: -3047 0.15 -1.30 2: -2908 0.14 -1.30 3: -2770 0.12 -1.30 4: -2631 0.13 -1.30 5: -2493 0.13 -1.30 6: -2354 0.08 -1.10 7: -2216 0.07 -1.00 8: -2077 0.07 -0.80 9: -1939 0.07 -0.80 10: -1800 0.07 -0.70 11: -1662 0.07 -0.90 12: -1523 0.04 -0.90 13: -1385 0.06 -0.60 14: -1246 0.02 -0.60 15: -1108 0.02 -0.50 16: -969 0.01 -0.30 17: -831 0.02 -0.40 18: -692 0.02 -0.20 19: -554 0.01 -0.10 20: -415 0.03 -0.10 21: -277 0.00 -0.20 22: -138 0.01 -0.10 23: 0 0.00 0.00 24: 138 -0.03 0.00 25: 277 -0.04 0.10 26: 415 -0.05 0.40 27: 554 -0.06 0.30 28: 692 -0.07 0.30 29: 831 -0.09 0.40 30: 969 -0.09 0.30 31: 1108 -0.10 0.40 32: 1246 -0.11 0.50 33: 1385 -0.11 0.50 34: 1523 -0.12 0.60 35: 1662 -0.12 0.90 36: 1800 -0.13 0.70 37: 1939 -0.15 0.60 38: 2077 -0.14 0.80 39: 2216 -0.14 0.80 40: 2354 -0.13 1.20 41: 2493 -0.14 1.30 42: 2631 -0.13 0.80 43: 2770 -0.13 0.90 44: 2908 -0.12 1.00 45: 3047 -0.12 1.10 # Bounds of frequency bands (TX) ID: USER_14250 UPDATE_INDEX: 02.02 ROWS: 7 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: RXTX_FREQUENCY_BAND_BOUND AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #================================================ # LowerBound UpperBound #================================================ 1: 20 15100 2: 30 632900 3: 632900 1282900 4: 957900 1607900 5: 1607900 2257900 6: 2046700 2700000 7: 2600000 3400000 # SAW-filter characteristic (TX) ID: USER_14260 UPDATE_INDEX: 02.02 ROWS: 59 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 28.93 AUX2: 34.01 AUX3: -43.18 #============================== # Magnit Delay #============================== 1: -4016 -1.16 4.70 2: -3878 -1.22 3.60 3: -3739 -1.31 2.00 4: -3601 -1.33 -3.50 5: -3462 -1.29 -4.90 6: -3324 -1.17 -0.10 7: -3185 -1.04 2.40 8: -3047 -1.03 4.70 9: -2908 -1.08 3.50 10: -2770 -1.13 2.30 11: -2631 -1.14 -1.10 12: -2493 -1.05 -2.30 13: -2354 -0.94 4.00 14: -2216 -0.85 9.30 15: -2077 -0.76 9.00 16: -1939 -0.74 8.00 17: -1800 -0.74 5.80 18: -1662 -0.70 1.10 19: -1523 -0.59 2.00 20: -1385 -0.51 7.10 21: -1246 -0.45 11.50 22: -1108 -0.33 9.90 23: -969 -0.28 7.90 24: -831 -0.27 6.40 25: -692 -0.26 3.10 26: -554 -0.21 4.50 27: -415 -0.15 10.60 28: -277 -0.08 9.00 29: -138 -0.04 7.60 30: 0 0.00 0.00 31: 138 0.04 5.20 32: 277 0.13 2.70 33: 415 0.17 3.80 34: 554 0.20 4.60 35: 692 0.24 1.80 36: 831 0.29 0.00 37: 969 0.36 0.50 38: 1108 0.39 0.10 39: 1246 0.39 1.70 40: 1385 0.38 0.60 41: 1523 0.36 -0.50 42: 1662 0.33 -7.20 43: 1800 0.37 -9.80 44: 1939 0.39 -9.40 45: 2077 0.39 -9.00 46: 2216 0.30 -7.20 47: 2354 0.17 -6.80 48: 2493 0.00 -12.10 49: 2631 -0.12 -19.50 50: 2770 -0.15 -25.10 51: 2908 -0.21 -23.80 52: 3047 -0.41 -23.20 53: 3185 -0.60 -19.50 54: 3324 -0.91 -15.80 55: 3462 -1.29 -24.00 56: 3601 -1.57 -35.30 57: 3739 -1.78 -43.70 58: 3878 -2.06 -44.30 59: 4016 -2.44 -38.90 # gain temperature characteristic (RX) ID: USER_14500 UPDATE_INDEX: 01.03 ROWS: 2 COLUMNS: 7 ROW_ID_TYPE: INT8 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #========================================================================== # temp RX... # COL 1 2 3 4 5 6 7 #========================================================================== 1: 10 0.75 0.63 0.89 0.81 0.83 1.10 1.20 2: 40 0.00 0.00 0.00 0.00 0.00 0.00 0.00 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: INT8 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #============================= # temp RX... # COL 1 2 #============================= 1: 10 1.62 1.62 2: 40 0.00 0.00 # attenuator settings (RX) ID: USER_14510 UPDATE_INDEX: 05.01 ROWS: 76 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: RXTX_RX_GAIN_DESCRIPTOR_2 AUX1: 0.00 AUX2: 2.56 AUX3: 0.00 #========================================================================= # ID NomGain RefGain LCU Step Att5 Att6 Ampl If1A IfG Filt Path #========================================================================= 1: 1 15 15 0 0 0 0 0 0 0 0 1 2: 52 -24 -24 0 0 1 0 0 0 0 0 0 3: 53 -12 -12 0 0 0 1 0 0 0 0 0 4: 54 -10 -10 0 0 0 0 0 1 0 0 0 5: 55 20 20 0 0 0 0 0 0 1 0 0 6: 56 0 0 0 0 0 0 0 0 2 0 0 7: 58 0 0 0 0 0 0 0 0 0 1 0 8: 59 -12 -12 0 0 0 0 0 0 0 2 0 9: 60 0 0 0 0 0 0 0 0 0 3 0 10: 61 0 0 0 0 0 0 0 0 0 4 0 11: 62 0 0 0 0 0 0 0 0 0 5 0 12: 63 0 0 0 0 0 0 0 0 0 6 0 13: 64 0 0 0 0 0 0 0 0 0 7 0 14: 101 -13 -13 0 13 0 0 0 0 0 0 0 15: 102 -12 -12 0 12 0 0 0 0 0 0 0 16: 103 -11 -11 0 11 0 0 0 0 0 0 0 17: 104 -10 -10 0 10 0 0 0 0 0 0 0 18: 105 -9 -9 0 9 0 0 0 0 0 0 0 19: 106 -8 -8 0 8 0 0 0 0 0 0 0 20: 107 -7 -7 0 7 0 0 0 0 0 0 0 21: 108 -6 -6 0 6 0 0 0 0 0 0 0 22: 109 -5 -5 0 5 0 0 0 0 0 0 0 23: 110 -4 -4 0 4 0 0 0 0 0 0 0 24: 111 -3 -3 0 3 0 0 0 0 0 0 0 25: 112 -2 -2 0 2 0 0 0 0 0 0 0 26: 113 -1 -1 0 1 0 0 0 0 0 0 0 27: 114 1 1 0 -1 0 0 0 0 0 0 0 28: 115 2 2 0 -2 0 0 0 0 0 0 0 29: 116 3 3 0 -3 0 0 0 0 0 0 0 30: 117 4 4 0 -4 0 0 0 0 0 0 0 31: 118 5 5 0 -5 0 0 0 0 0 0 0 32: 119 6 6 0 -6 0 0 0 0 0 0 0 33: 120 7 7 0 -7 0 0 0 0 0 0 0 34: 121 8 8 0 -8 0 0 0 0 0 0 0 35: 122 9 9 0 -9 0 0 0 0 0 0 0 36: 123 10 10 0 -10 0 0 0 0 0 0 0 37: 151 -20 -20 -500 0 0 0 0 0 0 0 0 38: 152 -19 -19 -475 0 0 0 0 0 0 0 0 39: 153 -18 -18 -450 0 0 0 0 0 0 0 0 40: 154 -17 -17 -425 0 0 0 0 0 0 0 0 41: 155 -16 -16 -400 0 0 0 0 0 0 0 0 42: 156 -15 -15 -375 0 0 0 0 0 0 0 0 43: 157 -14 -14 -350 0 0 0 0 0 0 0 0 44: 158 -13 -13 -325 0 0 0 0 0 0 0 0 45: 159 -12 -12 -300 0 0 0 0 0 0 0 0 46: 160 -11 -11 -275 0 0 0 0 0 0 0 0 47: 161 -10 -10 -250 0 0 0 0 0 0 0 0 48: 162 -9 -9 -225 0 0 0 0 0 0 0 0 49: 163 -8 -8 -200 0 0 0 0 0 0 0 0 50: 164 -7 -7 -175 0 0 0 0 0 0 0 0 51: 165 -6 -6 -150 0 0 0 0 0 0 0 0 52: 166 -5 -5 -125 0 0 0 0 0 0 0 0 53: 167 -4 -4 -100 0 0 0 0 0 0 0 0 54: 168 -3 -3 -75 0 0 0 0 0 0 0 0 55: 169 -2 -2 -50 0 0 0 0 0 0 0 0 56: 170 -1 -1 -25 0 0 0 0 0 0 0 0 57: 171 1 1 25 0 0 0 0 0 0 0 0 58: 172 2 2 50 0 0 0 0 0 0 0 0 59: 173 3 3 75 0 0 0 0 0 0 0 0 60: 174 4 4 100 0 0 0 0 0 0 0 0 61: 175 5 5 125 0 0 0 0 0 0 0 0 62: 176 6 6 150 0 0 0 0 0 0 0 0 63: 177 7 7 175 0 0 0 0 0 0 0 0 64: 178 8 8 200 0 0 0 0 0 0 0 0 65: 179 9 9 225 0 0 0 0 0 0 0 0 66: 180 10 10 250 0 0 0 0 0 0 0 0 67: 181 11 11 275 0 0 0 0 0 0 0 0 68: 182 12 12 300 0 0 0 0 0 0 0 0 69: 183 13 13 325 0 0 0 0 0 0 0 0 70: 184 14 14 350 0 0 0 0 0 0 0 0 71: 185 15 15 375 0 0 0 0 0 0 0 0 72: 186 16 16 400 0 0 0 0 0 0 0 0 73: 187 17 17 425 0 0 0 0 0 0 0 0 74: 188 18 18 450 0 0 0 0 0 0 0 0 75: 189 19 19 475 0 0 0 0 0 0 0 0 76: 190 20 20 500 0 0 0 0 0 0 0 0 ID: USER_14515 UPDATE_INDEX: 01.01 ROWS: 2 COLUMNS: 41 ROW_ID_TYPE: UINT16 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 33.20 AUX2: 32.96 AUX3: 0.00 #============================================================================================================================================================================================================================================================================================================================================================================================= # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 #============================================================================================================================================================================================================================================================================================================================================================================================= 0: 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 1 #--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 320 0.39 0.50 0.54 0.51 0.47 0.47 0.52 0.58 0.58 0.53 0.48 0.47 0.53 0.59 0.59 0.54 0.48 0.48 0.55 0.60 0.53 0.48 0.49 0.56 0.60 0.58 0.51 0.47 0.49 0.56 0.59 0.56 0.50 0.47 0.49 0.54 0.55 0.50 0.39 0.26 0.59 2: 682 0.74 1.00 1.13 1.11 1.03 1.00 1.08 1.20 1.25 1.17 1.05 1.00 1.09 1.23 1.27 1.19 1.06 1.02 1.12 1.26 1.17 1.04 1.03 1.15 1.27 1.26 1.14 1.02 1.03 1.15 1.25 1.23 1.11 1.02 1.03 1.13 1.18 1.10 0.90 0.64 1.28 # Frequency characteristics of IF path (RX) ID: USER_14520 UPDATE_INDEX: 02.00 ROWS: 1 COLUMNS: 50 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.93 AUX2: 32.47 AUX3: 0.00 #=================================================================================================================================================================================================================================================================================================================================================================================================================================================================================== # MHz IDs # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 #=================================================================================================================================================================================================================================================================================================================================================================================================================================================================================== 0: 54 56 58 59 60 61 62 63 64 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 55 #----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 500.000 0.69 -0.01 -0.93 -0.55 1.13 0.96 1.07 0.10 0.04 -0.24 -0.33 -0.32 -0.31 -0.40 -0.49 -0.52 -0.44 -0.33 -0.28 -0.37 -0.48 -0.49 -0.39 -0.25 -0.19 -0.25 -0.34 -0.32 -0.18 0.01 -0.06 -0.13 -0.09 0.06 0.17 0.25 0.14 0.07 0.11 0.21 0.32 0.30 0.20 0.13 0.15 0.21 0.20 -0.01 -0.45 1.00 ID: USER_14525 UPDATE_INDEX: 04.03 ROWS: 1 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #========================== #========================== 0: 1 #-------------------------- 1: 10.700 -7.10 # Frequency characteristics of common LF path 30 kHz ... 10 MHz (RX) ID: USER_14530 UPDATE_INDEX: 03.00 ROWS: 20 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 29.91 AUX2: 32.96 AUX3: -2.58 #========================== # MHz IDs... #========================== 0: 1 #-------------------------- 1: 0.030 -1.50 2: 0.040 -1.32 3: 0.050 -1.16 4: 0.060 -1.02 5: 0.080 -0.89 6: 0.100 -0.78 7: 0.150 -0.66 8: 0.200 -0.89 9: 0.300 -0.60 10: 0.500 -0.02 11: 1.000 0.86 12: 2.000 1.35 13: 4.000 1.41 14: 6.000 1.34 15: 7.680 1.20 16: 10.000 0.90 17: 10.700 0.81 18: 12.000 0.52 19: 14.000 -0.04 20: 15.000 -0.53 ROWS: 10 COLUMNS: 44 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 29.05 AUX2: 32.71 AUX3: 0.00 #============================================================================================================================================================================================================================================================================================================================================================================================================================= # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 #============================================================================================================================================================================================================================================================================================================================================================================================================================= 0: 52 53 55 56 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 #----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 0.030 -0.34 0.24 1.45 0.00 -0.44 -0.50 -0.45 -0.41 -0.47 -0.55 -0.56 -0.47 -0.34 -0.28 -0.37 -0.47 -0.49 -0.38 -0.23 -0.17 -0.23 -0.32 -0.31 -0.17 0.03 -0.05 -0.12 -0.07 0.07 0.18 0.31 0.20 0.12 0.16 0.26 0.36 0.34 0.24 0.16 0.17 0.23 0.22 0.02 -0.43 2: 0.100 -0.36 0.24 1.24 0.00 -0.40 -0.46 -0.42 -0.39 -0.45 -0.53 -0.55 -0.46 -0.34 -0.28 -0.37 -0.47 -0.48 -0.38 -0.23 -0.17 -0.23 -0.32 -0.30 -0.15 0.04 -0.02 -0.09 -0.04 0.10 0.22 0.33 0.23 0.16 0.21 0.32 0.43 0.42 0.34 0.28 0.31 0.39 0.40 0.21 -0.22 3: 0.200 -0.36 0.24 1.05 0.00 -0.40 -0.46 -0.42 -0.39 -0.45 -0.53 -0.55 -0.45 -0.33 -0.27 -0.37 -0.47 -0.48 -0.38 -0.23 -0.17 -0.23 -0.31 -0.30 -0.16 0.04 -0.03 -0.10 -0.06 0.09 0.20 0.32 0.21 0.14 0.18 0.29 0.39 0.37 0.28 0.22 0.23 0.31 0.30 0.10 -0.34 4: 0.500 -0.37 0.24 1.04 0.00 -0.40 -0.46 -0.42 -0.39 -0.44 -0.53 -0.55 -0.45 -0.33 -0.27 -0.37 -0.47 -0.48 -0.38 -0.23 -0.16 -0.23 -0.31 -0.29 -0.15 0.04 -0.03 -0.10 -0.05 0.10 0.21 0.31 0.20 0.14 0.18 0.28 0.39 0.37 0.28 0.21 0.24 0.31 0.30 0.10 -0.33 5: 2.000 -0.36 0.24 1.02 0.00 -0.28 -0.36 -0.33 -0.30 -0.38 -0.47 -0.50 -0.41 -0.29 -0.24 -0.34 -0.44 -0.46 -0.36 -0.21 -0.15 -0.22 -0.30 -0.29 -0.15 0.04 -0.02 -0.10 -0.05 0.10 0.21 0.30 0.19 0.13 0.16 0.27 0.38 0.36 0.27 0.20 0.22 0.29 0.29 0.09 -0.35 6: 7.680 -0.36 0.23 0.96 0.00 -0.18 -0.27 -0.26 -0.25 -0.34 -0.44 -0.47 -0.39 -0.28 -0.23 -0.33 -0.43 -0.46 -0.36 -0.21 -0.15 -0.22 -0.30 -0.29 -0.15 0.04 -0.03 -0.10 -0.06 0.09 0.20 0.29 0.18 0.11 0.15 0.26 0.36 0.35 0.25 0.19 0.20 0.28 0.27 0.07 -0.37 7: 10.000 -0.36 0.24 0.92 0.00 -0.23 -0.32 -0.30 -0.30 -0.38 -0.48 -0.50 -0.42 -0.30 -0.26 -0.35 -0.45 -0.47 -0.37 -0.22 -0.17 -0.23 -0.31 -0.30 -0.15 0.04 -0.03 -0.10 -0.06 0.09 0.20 0.29 0.18 0.12 0.15 0.26 0.36 0.35 0.26 0.18 0.20 0.27 0.27 0.06 -0.38 8: 10.700 -0.37 0.24 0.91 0.00 -0.25 -0.34 -0.32 -0.32 -0.39 -0.49 -0.52 -0.43 -0.31 -0.27 -0.36 -0.46 -0.48 -0.38 -0.23 -0.17 -0.23 -0.31 -0.30 -0.15 0.04 -0.03 -0.10 -0.05 0.09 0.20 0.30 0.19 0.12 0.16 0.26 0.37 0.35 0.26 0.19 0.21 0.28 0.27 0.07 -0.37 9: 12.000 -0.37 0.24 0.89 0.00 -0.28 -0.37 -0.35 -0.34 -0.41 -0.51 -0.54 -0.45 -0.33 -0.28 -0.37 -0.47 -0.48 -0.38 -0.23 -0.17 -0.23 -0.31 -0.30 -0.15 0.04 -0.03 -0.10 -0.05 0.10 0.21 0.30 0.19 0.13 0.16 0.27 0.37 0.36 0.27 0.20 0.21 0.28 0.27 0.07 -0.37 10: 15.000 -0.37 0.24 0.85 0.00 -0.37 -0.45 -0.43 -0.41 -0.49 -0.58 -0.59 -0.50 -0.37 -0.31 -0.40 -0.50 -0.51 -0.40 -0.25 -0.18 -0.24 -0.32 -0.30 -0.16 0.04 -0.02 -0.09 -0.04 0.10 0.21 0.31 0.20 0.14 0.18 0.28 0.38 0.37 0.28 0.21 0.22 0.29 0.28 0.08 -0.36 ID: USER_14535 UPDATE_INDEX: 04.03 ROWS: 1 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 10.000 -1.20 0.00 # Frequency characteristics 10 ... 600 MHz (RX) ID: USER_14540 UPDATE_INDEX: 02.01 ROWS: 23 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 28.56 AUX2: 31.98 AUX3: 0.00 #========================== # MHz IDs... #========================== 0: 1 #-------------------------- 1: 8.000 0.92 2: 10.000 1.56 3: 15.000 2.33 4: 20.000 2.43 5: 25.000 2.41 6: 30.000 2.38 7: 40.000 2.33 8: 50.000 2.29 9: 100.000 2.14 10: 150.000 2.23 11: 200.000 2.45 12: 250.000 2.67 13: 300.000 2.67 14: 350.000 2.58 15: 400.000 2.53 16: 435.000 2.46 17: 470.000 2.30 18: 500.000 2.14 19: 525.000 2.00 20: 550.000 1.86 21: 575.000 1.78 22: 600.000 1.72 23: 633.000 1.71 ROWS: 8 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 32.84 AUX2: 32.47 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 52 53 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 10.000 -0.34 0.23 0.00 -0.06 -0.08 -0.15 -0.08 -0.14 -0.19 -0.25 -0.10 -0.11 -0.10 -0.11 -0.02 0.09 0.08 -0.07 -0.13 -0.15 -0.21 -0.16 -0.22 -0.27 -0.34 2: 50.000 -0.32 0.24 -0.19 -0.26 -0.27 -0.33 -0.26 -0.33 -0.37 -0.43 -0.16 -0.15 -0.15 -0.13 -0.06 0.09 0.11 -0.20 -0.25 -0.24 -0.29 -0.22 -0.25 -0.25 -0.27 3: 100.000 -0.33 0.23 -0.11 -0.17 -0.19 -0.24 -0.18 -0.24 -0.28 -0.34 -0.13 -0.12 -0.12 -0.11 -0.04 0.09 0.11 -0.12 -0.17 -0.18 -0.22 -0.16 -0.20 -0.21 -0.24 4: 200.000 -0.34 0.24 0.20 0.16 0.13 0.09 0.15 0.11 0.06 0.01 -0.05 -0.08 -0.07 -0.09 -0.01 0.05 0.03 0.17 0.13 0.09 0.04 0.10 0.04 -0.02 -0.07 5: 300.000 -0.32 0.25 0.49 0.46 0.41 0.38 0.45 0.42 0.36 0.33 0.02 -0.04 -0.03 -0.08 0.01 0.02 -0.04 0.47 0.44 0.38 0.34 0.41 0.37 0.29 0.24 6: 500.000 -0.27 0.23 0.61 0.59 0.54 0.51 0.58 0.56 0.48 0.46 0.03 -0.05 -0.01 -0.09 0.04 0.04 -0.05 0.64 0.61 0.54 0.51 0.58 0.54 0.44 0.39 7: 600.000 -0.22 0.23 0.46 0.42 0.39 0.35 0.43 0.39 0.33 0.29 0.00 -0.08 -0.02 -0.10 0.04 0.08 0.00 0.50 0.45 0.40 0.34 0.40 0.34 0.25 0.18 8: 633.000 -0.21 0.23 0.35 0.31 0.28 0.24 0.32 0.27 0.22 0.18 -0.03 -0.10 -0.04 -0.12 0.03 0.08 0.01 0.40 0.34 0.30 0.24 0.30 0.23 0.15 0.08 ID: USER_14545 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1.000 -5.20 0.00 2: 633.000 -4.90 0.00 # Frequency characteristics 600.. 1200 MHz (RX) ID: USER_14550 UPDATE_INDEX: 01.00 ROWS: 21 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 33.33 AUX2: 33.08 AUX3: 0.00 #========================== # MHz IDs... #========================== 0: 1 #-------------------------- 1: 634.000 1.66 2: 670.000 1.70 3: 700.000 1.81 4: 730.000 1.98 5: 770.000 2.16 6: 800.000 2.32 7: 830.000 2.38 8: 870.000 2.47 9: 900.000 2.52 10: 925.000 2.47 11: 950.000 2.50 12: 975.000 2.42 13: 1000.000 2.31 14: 1025.000 2.10 15: 1050.000 1.82 16: 1075.000 1.37 17: 1100.000 0.93 18: 1125.000 0.53 19: 1150.000 0.14 20: 1175.000 -0.12 21: 1200.000 -0.09 ROWS: 8 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 33.33 AUX2: 33.08 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 52 53 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 634.000 -0.21 0.23 0.38 0.34 0.32 0.28 0.35 0.31 0.26 0.21 0.01 -0.06 0.00 -0.08 0.07 0.12 0.05 0.43 0.38 0.33 0.28 0.34 0.27 0.19 0.12 2: 700.000 -0.19 0.22 0.15 0.09 0.09 0.04 0.12 0.06 0.04 -0.02 -0.04 -0.09 -0.04 -0.09 0.04 0.13 0.08 0.23 0.16 0.15 0.08 0.16 0.09 0.06 -0.01 3: 750.000 -0.19 0.20 -0.01 -0.07 -0.06 -0.12 -0.03 -0.09 -0.10 -0.17 -0.08 -0.10 -0.07 -0.09 0.02 0.12 0.10 0.10 0.03 0.04 -0.03 0.06 -0.01 -0.01 -0.07 4: 800.000 -0.19 0.19 -0.16 -0.22 -0.20 -0.26 -0.16 -0.23 -0.23 -0.30 -0.11 -0.12 -0.09 -0.10 0.00 0.11 0.11 -0.02 -0.09 -0.07 -0.13 -0.03 -0.10 -0.07 -0.12 5: 900.000 -0.19 0.14 -0.39 -0.44 -0.41 -0.47 -0.37 -0.43 -0.43 -0.49 -0.18 -0.14 -0.15 -0.11 -0.05 0.08 0.12 -0.20 -0.26 -0.22 -0.28 -0.17 -0.22 -0.17 -0.20 6: 1000.000 -0.17 0.10 -0.36 -0.39 -0.38 -0.41 -0.33 -0.37 -0.37 -0.41 -0.20 -0.16 -0.16 -0.12 -0.05 0.09 0.13 -0.13 -0.17 -0.15 -0.19 -0.10 -0.14 -0.11 -0.13 7: 1100.000 -0.14 0.10 -0.12 -0.13 -0.13 -0.13 -0.08 -0.09 -0.11 -0.12 -0.19 -0.19 -0.13 -0.13 -0.01 0.16 0.16 0.14 0.12 0.10 0.07 0.13 0.10 0.07 0.05 8: 1200.000 -0.07 0.15 -0.09 -0.10 -0.06 -0.09 -0.01 -0.04 -0.01 -0.04 -0.20 -0.24 -0.10 -0.15 0.04 0.25 0.20 0.24 0.19 0.20 0.15 0.23 0.18 0.17 0.12 ID: USER_14555 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 633.000 -5.10 0.00 2: 1200.000 -5.20 0.00 # Frequency characteristics 1200.. 1700 MHz (RX) ID: USER_14560 UPDATE_INDEX: 01.00 ROWS: 14 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 33.33 AUX2: 33.33 AUX3: 0.00 #========================== # MHz IDs... #========================== 0: 1 #-------------------------- 1: 1200.000 0.18 2: 1215.000 0.32 3: 1230.000 0.39 4: 1270.000 0.60 5: 1300.000 0.72 6: 1330.000 0.86 7: 1370.000 1.06 8: 1400.000 1.15 9: 1430.000 1.39 10: 1470.000 1.55 11: 1500.000 1.71 12: 1530.000 1.82 13: 1570.000 1.85 14: 1606.000 1.94 ROWS: 9 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 33.57 AUX2: 33.20 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 52 53 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 1200.000 -0.08 0.15 -0.43 -0.42 -0.38 -0.38 -0.32 -0.32 -0.30 -0.31 -0.28 -0.25 -0.17 -0.15 -0.02 0.20 0.22 0.00 -0.04 -0.02 -0.05 0.02 -0.01 0.00 -0.01 2: 1250.000 -0.02 0.18 -0.51 -0.49 -0.45 -0.43 -0.37 -0.37 -0.34 -0.34 -0.32 -0.28 -0.19 -0.16 -0.04 0.22 0.25 -0.05 -0.07 -0.05 -0.07 -0.01 -0.03 -0.01 -0.01 3: 1300.000 0.03 0.22 -0.50 -0.47 -0.42 -0.39 -0.34 -0.32 -0.27 -0.26 -0.33 -0.29 -0.19 -0.15 -0.03 0.24 0.27 0.00 -0.02 0.00 -0.01 0.03 0.02 0.03 0.02 4: 1350.000 0.08 0.24 -0.46 -0.42 -0.35 -0.32 -0.26 -0.23 -0.17 -0.15 -0.33 -0.30 -0.17 -0.15 -0.02 0.26 0.28 0.07 0.06 0.08 0.07 0.11 0.09 0.10 0.08 5: 1400.000 0.11 0.26 -0.43 -0.38 -0.30 -0.25 -0.19 -0.16 -0.07 -0.05 -0.33 -0.31 -0.17 -0.15 -0.02 0.27 0.27 0.15 0.14 0.17 0.15 0.19 0.17 0.19 0.17 6: 1450.000 0.12 0.27 -0.41 -0.36 -0.26 -0.21 -0.14 -0.10 0.01 0.04 -0.33 -0.30 -0.15 -0.14 -0.01 0.27 0.27 0.22 0.21 0.25 0.24 0.29 0.27 0.32 0.29 7: 1500.000 0.10 0.24 -0.42 -0.36 -0.24 -0.20 -0.11 -0.07 0.07 0.09 -0.32 -0.30 -0.14 -0.13 -0.01 0.26 0.26 0.27 0.26 0.32 0.31 0.38 0.35 0.44 0.42 8: 1550.000 0.08 0.22 -0.45 -0.39 -0.25 -0.21 -0.10 -0.07 0.10 0.13 -0.31 -0.29 -0.13 -0.12 -0.01 0.24 0.25 0.29 0.28 0.36 0.35 0.44 0.41 0.54 0.52 9: 1606.000 0.00 0.16 -0.47 -0.41 -0.26 -0.21 -0.10 -0.06 0.13 0.15 -0.30 -0.27 -0.13 -0.11 -0.03 0.20 0.22 0.32 0.30 0.40 0.38 0.48 0.46 0.61 0.58 ID: USER_14565 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1200.000 -5.70 0.00 2: 1600.000 -6.30 0.00 # Frequency characteristics 1700.. 2200 MHz (RX) ID: USER_14570 UPDATE_INDEX: 01.00 ROWS: 24 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 34.18 AUX2: 33.33 AUX3: 0.00 #========================== # MHz IDs... #========================== 0: 1 #-------------------------- 1: 1607.000 1.93 2: 1630.000 1.86 3: 1670.000 1.80 4: 1700.000 1.71 5: 1730.000 1.52 6: 1770.000 1.31 7: 1800.000 1.16 8: 1830.000 1.10 9: 1870.000 0.95 10: 1900.000 0.94 11: 1930.000 0.81 12: 1970.000 0.70 13: 2000.000 0.68 14: 2025.000 0.53 15: 2050.000 0.47 16: 2075.000 0.34 17: 2100.000 0.16 18: 2120.000 0.04 19: 2140.000 -0.07 20: 2160.000 -0.17 21: 2170.000 -0.27 22: 2180.000 -0.37 23: 2190.000 -0.47 24: 2200.000 -0.52 ROWS: 12 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 34.06 AUX2: 33.20 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 52 53 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 1608.000 -0.01 0.15 -0.47 -0.41 -0.26 -0.21 -0.09 -0.05 0.13 0.16 -0.30 -0.27 -0.13 -0.10 -0.02 0.21 0.22 0.32 0.31 0.40 0.39 0.49 0.46 0.61 0.59 2: 1700.000 -0.09 0.04 -0.48 -0.40 -0.25 -0.18 -0.05 0.01 0.20 0.24 -0.28 -0.24 -0.13 -0.09 -0.03 0.15 0.17 0.41 0.41 0.50 0.49 0.60 0.58 0.73 0.70 3: 1750.000 -0.14 -0.01 -0.48 -0.38 -0.23 -0.15 -0.02 0.05 0.24 0.29 -0.28 -0.23 -0.12 -0.09 -0.03 0.14 0.16 0.48 0.48 0.57 0.56 0.68 0.67 0.81 0.79 4: 1800.000 -0.17 -0.06 -0.47 -0.37 -0.21 -0.13 0.01 0.08 0.28 0.33 -0.28 -0.23 -0.12 -0.09 -0.03 0.12 0.14 0.56 0.56 0.64 0.64 0.76 0.76 0.90 0.88 5: 1850.000 -0.20 -0.09 -0.49 -0.38 -0.22 -0.13 0.02 0.09 0.29 0.35 -0.28 -0.24 -0.13 -0.10 -0.03 0.12 0.13 0.61 0.62 0.69 0.70 0.83 0.82 0.97 0.96 6: 1900.000 -0.19 -0.10 -0.52 -0.40 -0.24 -0.14 0.01 0.09 0.29 0.35 -0.29 -0.25 -0.13 -0.11 -0.03 0.12 0.13 0.64 0.65 0.73 0.74 0.88 0.88 1.03 1.03 7: 1950.000 -0.16 -0.10 -0.58 -0.45 -0.27 -0.17 -0.01 0.07 0.28 0.34 -0.29 -0.25 -0.13 -0.11 -0.03 0.12 0.13 0.66 0.67 0.76 0.76 0.91 0.90 1.07 1.07 8: 2000.000 -0.11 -0.07 -0.64 -0.51 -0.32 -0.22 -0.05 0.03 0.26 0.32 -0.30 -0.26 -0.13 -0.11 -0.03 0.12 0.13 0.65 0.66 0.76 0.76 0.91 0.90 1.08 1.08 9: 2050.000 -0.04 -0.03 -0.71 -0.58 -0.37 -0.26 -0.09 -0.01 0.24 0.30 -0.31 -0.26 -0.14 -0.11 -0.04 0.10 0.12 0.64 0.64 0.75 0.74 0.89 0.88 1.08 1.07 10: 2100.000 0.04 0.02 -0.78 -0.65 -0.42 -0.32 -0.13 -0.05 0.21 0.27 -0.31 -0.26 -0.14 -0.10 -0.04 0.09 0.11 0.62 0.61 0.73 0.72 0.88 0.86 1.06 1.05 11: 2150.000 0.10 0.07 -0.85 -0.71 -0.47 -0.36 -0.17 -0.08 0.19 0.25 -0.32 -0.25 -0.14 -0.10 -0.05 0.08 0.10 0.61 0.59 0.72 0.70 0.86 0.84 1.05 1.03 12: 2200.000 0.15 0.10 -0.91 -0.75 -0.51 -0.39 -0.19 -0.10 0.18 0.24 -0.31 -0.24 -0.14 -0.09 -0.05 0.06 0.08 0.61 0.60 0.72 0.70 0.86 0.83 1.04 1.01 ID: USER_14575 UPDATE_INDEX: 04.03 ROWS: 3 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 1607.000 -6.20 0.00 2: 1900.000 -6.50 0.00 3: 2200.000 -5.90 0.00 # Frequency characteristics 2200.. 2700 MHz (RX) ID: USER_14580 UPDATE_INDEX: 01.01 ROWS: 31 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 34.42 AUX2: 33.45 AUX3: 0.00 #========================== # MHz IDs... #========================== 0: 1 #-------------------------- 1: 2200.000 1.84 2: 2220.000 2.12 3: 2240.000 2.27 4: 2260.000 2.47 5: 2280.000 2.59 6: 2300.000 2.74 7: 2320.000 2.93 8: 2340.000 2.84 9: 2360.000 2.87 10: 2380.000 2.97 11: 2400.000 2.94 12: 2420.000 3.09 13: 2440.000 3.01 14: 2460.000 3.04 15: 2480.000 3.22 16: 2500.000 3.19 17: 2520.000 3.29 18: 2540.000 3.33 19: 2560.000 3.34 20: 2580.000 3.49 21: 2600.000 3.45 22: 2610.000 3.44 23: 2620.000 3.47 24: 2630.000 3.50 25: 2640.000 3.48 26: 2650.000 3.43 27: 2660.000 3.38 28: 2670.000 3.37 29: 2680.000 3.36 30: 2690.000 3.28 31: 2700.000 3.13 ROWS: 16 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 34.42 AUX2: 33.45 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 52 53 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 2200.000 0.15 0.10 -0.87 -0.72 -0.47 -0.36 -0.15 -0.07 0.21 0.27 -0.30 -0.25 -0.13 -0.10 -0.04 0.07 0.08 0.65 0.64 0.77 0.75 0.92 0.89 1.12 1.09 2: 2230.000 0.17 0.13 -0.93 -0.78 -0.52 -0.41 -0.20 -0.12 0.17 0.22 -0.31 -0.25 -0.15 -0.10 -0.06 0.04 0.05 0.62 0.60 0.73 0.70 0.87 0.83 1.06 1.03 3: 2270.000 0.17 0.13 -1.00 -0.84 -0.58 -0.47 -0.24 -0.16 0.12 0.18 -0.30 -0.22 -0.14 -0.09 -0.06 0.02 0.04 0.59 0.57 0.69 0.66 0.82 0.77 0.99 0.94 4: 2300.000 0.18 0.13 -1.06 -0.90 -0.65 -0.53 -0.30 -0.21 0.06 0.12 -0.32 -0.23 -0.16 -0.10 -0.08 -0.02 0.02 0.55 0.52 0.64 0.60 0.76 0.71 0.91 0.85 5: 2330.000 0.16 0.13 -1.13 -0.96 -0.70 -0.57 -0.35 -0.26 0.00 0.07 -0.33 -0.24 -0.19 -0.11 -0.10 -0.05 -0.01 0.52 0.49 0.60 0.56 0.71 0.66 0.84 0.77 6: 2370.000 0.13 0.10 -1.18 -0.99 -0.75 -0.61 -0.39 -0.28 -0.04 0.04 -0.34 -0.23 -0.21 -0.12 -0.13 -0.10 -0.04 0.51 0.49 0.58 0.55 0.69 0.64 0.78 0.72 7: 2400.000 0.12 0.09 -1.20 -1.00 -0.77 -0.61 -0.40 -0.28 -0.06 0.03 -0.35 -0.22 -0.21 -0.11 -0.13 -0.10 -0.04 0.53 0.52 0.59 0.57 0.70 0.67 0.79 0.73 8: 2430.000 0.04 0.05 -1.23 -1.01 -0.80 -0.62 -0.42 -0.29 -0.09 0.01 -0.36 -0.23 -0.23 -0.13 -0.14 -0.13 -0.05 0.55 0.55 0.60 0.59 0.71 0.69 0.78 0.74 9: 2470.000 0.00 0.01 -1.24 -1.00 -0.81 -0.61 -0.42 -0.27 -0.10 0.02 -0.38 -0.25 -0.26 -0.14 -0.16 -0.16 -0.08 0.60 0.62 0.65 0.66 0.77 0.77 0.83 0.81 10: 2500.000 -0.04 -0.01 -1.25 -0.99 -0.80 -0.59 -0.42 -0.25 -0.10 0.04 -0.39 -0.26 -0.27 -0.16 -0.17 -0.16 -0.08 0.65 0.68 0.69 0.71 0.83 0.84 0.88 0.88 11: 2530.000 -0.12 -0.05 -1.23 -0.95 -0.78 -0.56 -0.39 -0.22 -0.08 0.06 -0.39 -0.26 -0.27 -0.16 -0.15 -0.15 -0.08 0.71 0.76 0.75 0.78 0.89 0.91 0.94 0.95 12: 2570.000 -0.16 -0.08 -1.21 -0.92 -0.76 -0.52 -0.36 -0.17 -0.05 0.10 -0.39 -0.27 -0.27 -0.17 -0.15 -0.14 -0.08 0.79 0.84 0.82 0.86 0.96 1.00 1.00 1.03 13: 2600.000 -0.19 -0.09 -1.22 -0.91 -0.75 -0.51 -0.34 -0.15 -0.04 0.12 -0.39 -0.28 -0.27 -0.18 -0.14 -0.14 -0.08 0.83 0.88 0.85 0.90 1.00 1.04 1.03 1.07 14: 2630.000 -0.22 -0.10 -1.23 -0.93 -0.76 -0.51 -0.34 -0.15 -0.04 0.12 -0.39 -0.29 -0.27 -0.19 -0.13 -0.12 -0.08 0.86 0.91 0.88 0.92 1.01 1.05 1.04 1.08 15: 2670.000 -0.25 -0.10 -1.29 -0.98 -0.79 -0.55 -0.36 -0.17 -0.05 0.10 -0.39 -0.30 -0.26 -0.20 -0.12 -0.10 -0.07 0.87 0.91 0.88 0.91 1.01 1.04 1.03 1.06 16: 2700.000 -0.26 -0.10 -1.37 -1.05 -0.85 -0.61 -0.41 -0.23 -0.09 0.05 -0.40 -0.32 -0.26 -0.20 -0.12 -0.09 -0.07 0.85 0.88 0.86 0.88 0.98 1.00 1.00 1.02 ID: USER_14585 UPDATE_INDEX: 04.03 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 2200.000 -6.60 0.00 2: 2695.000 -6.40 0.00 # Frequency characteristics 2700.. 2800 MHz (RX) ID: USER_14590 UPDATE_INDEX: 02.01 ROWS: 6 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 35.03 AUX2: 34.18 AUX3: 0.00 #========================== # MHz IDs... #========================== 0: 1 #-------------------------- 1: 2650.000 3.33 2: 2660.000 3.28 3: 2670.000 3.28 4: 2680.000 3.27 5: 2690.000 3.19 6: 2700.000 3.04 ROWS: 3 COLUMNS: 25 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 34.91 AUX2: 34.18 AUX3: 0.00 #================================================================================================================================================================================================================================================== # MHz IDs... # COL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 #================================================================================================================================================================================================================================================== 0: 52 53 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 #-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1: 2650.000 -0.23 -0.10 -1.18 -0.87 -0.69 -0.45 -0.27 -0.08 0.04 0.19 -0.32 -0.22 -0.19 -0.12 -0.05 -0.04 0.00 0.95 0.99 0.96 1.00 1.10 1.13 1.12 1.15 2: 2670.000 -0.25 -0.10 -1.22 -0.91 -0.72 -0.47 -0.29 -0.10 0.03 0.17 -0.32 -0.22 -0.19 -0.12 -0.04 -0.03 0.01 0.95 0.99 0.96 0.99 1.09 1.12 1.11 1.13 3: 2700.000 -0.26 -0.10 -1.29 -0.98 -0.77 -0.53 -0.34 -0.15 -0.01 0.13 -0.32 -0.24 -0.19 -0.13 -0.04 -0.01 0.01 0.93 0.96 0.94 0.96 1.07 1.08 1.08 1.09 ID: USER_14595 UPDATE_INDEX: 04.03 ROWS: 1 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 #=================================== 0: 1 53 #----------------------------------- 1: 2700.000 -6.30 0.00 # optimal absolute level at 1. mixer (X14 & X17) (RX) ID: USER_14700 UPDATE_INDEX: 01.01 ROWS: 3 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #============== # level #============== 1: -30.00 2: -42.00 3: -20.00 # if3 deviation X38 - X39 (RX) ID: USER_14705 UPDATE_INDEX: 01.00 ROWS: 3 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 53.34 AUX2: 56.27 AUX3: 0.00 #========================== # dB #========================== 1: 7.680 -6.05 2: 10.000 -5.81 3: 10.700 -5.78 # measured relative level at 1. mixer (X14 & X17) (RX) ID: USER_14710 UPDATE_INDEX: 05.00 ROWS: 2 COLUMNS: 2 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 51.51 AUX2: 54.93 AUX3: 0.00 #=================================== # db # COL 1 2 #=================================== 1: 500.000 -14.00 42.54 2: 1816.115 3.00 25.17 # Gain at extern IF2-input (RX) ID: USER_14720 UPDATE_INDEX: 01.01 ROWS: 2 COLUMNS: 1 ROW_ID_TYPE: FIX32D3 COLUMN_ID_TYPE: UINT8 DATATYPE: FIX16D2 AUX1: 34.91 AUX2: 34.30 AUX3: 0.00 #========================== # dB #========================== 0: 1 #-------------------------- 1: 500.000 -7.16 2: 500.000 -5.77 ID: USER_14721 UPDATE_INDEX: 01.01 ROWS: 16 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 33.69 AUX2: 33.69 AUX3: 0.00 #=============================== # Magnit Delay #=============================== 1: -10000 -0.24 0.00 2: -8000 -0.13 0.00 3: -6000 -0.06 0.00 4: -4000 -0.02 1.10 5: -2000 0.00 0.50 6: 0 0.00 0.00 7: 2000 -0.01 -0.40 8: 4000 0.00 -0.90 9: 6000 0.00 0.00 10: 8000 0.00 0.00 11: 10000 0.00 0.00 12: 12000 -0.01 0.00 13: 15000 0.01 0.00 14: 20000 0.01 0.00 15: 25000 0.03 0.00 16: 30000 0.03 0.00 ID: USER_14722 UPDATE_INDEX: 01.01 ROWS: 15 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 33.69 AUX2: 33.69 AUX3: 0.00 #=============================== # Magnit Delay #=============================== 1: -12000 -1.02 0.00 2: -10000 -0.76 0.00 3: -8000 -0.46 0.00 4: -6000 -0.23 0.00 5: -4000 -0.09 0.00 6: -3000 -0.07 0.00 7: -2000 -0.05 0.00 8: -1000 -0.02 0.00 9: 0 0.00 0.00 10: 1000 0.00 0.00 11: 2000 0.01 0.00 12: 3000 0.01 0.00 13: 4000 0.00 0.00 14: 5000 -0.04 0.00 15: 6000 -0.11 0.00 # Passband characteristic of 10.7 MHz subharmonics filter (RX) ID: USER_14730 UPDATE_INDEX: 02.03 ROWS: 48 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 35.03 AUX2: 34.18 AUX3: 0.00 #============================== # Magnit Delay #============================== 1: -3463 -3.40 46.00 2: -3324 -2.50 46.00 3: -3186 -1.73 46.00 4: -3047 -1.08 46.00 5: -2908 -0.56 53.00 6: -2770 -0.16 61.00 7: -2631 0.13 66.00 8: -2493 0.34 69.00 9: -2354 0.46 69.00 10: -2216 0.53 67.00 11: -2077 0.56 63.00 12: -1939 0.55 59.00 13: -1800 0.52 51.00 14: -1662 0.46 44.00 15: -1523 0.39 36.50 16: -1385 0.32 30.00 17: -1246 0.25 23.80 18: -1108 0.18 18.60 19: -969 0.13 13.50 20: -831 0.08 10.30 21: -692 0.04 6.50 22: -554 0.01 3.30 23: -415 0.01 1.20 24: -277 0.03 4.60 25: -138 -0.01 5.10 26: 0 0.00 0.00 27: 138 0.02 0.00 28: 277 0.00 4.00 29: 415 -0.03 2.00 30: 554 -0.06 0.20 31: 692 -0.07 0.80 32: 831 -0.06 3.30 33: 969 -0.05 5.90 34: 1108 -0.04 8.00 35: 1246 -0.03 10.60 36: 1385 -0.01 13.90 37: 1523 0.01 15.00 38: 1662 0.03 17.00 39: 1800 0.05 19.40 40: 1939 0.06 22.10 41: 2077 0.06 24.00 42: 2216 0.06 25.70 43: 2354 0.04 29.70 44: 2493 0.02 31.40 45: 2631 0.00 33.40 46: 2770 -0.04 35.80 47: 2908 -0.10 33.20 48: 3047 -0.15 32.40 # Passband characteristic of 300 kHz narrowband filter (RX) ID: USER_14731 UPDATE_INDEX: 02.03 ROWS: 45 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 34.06 AUX2: 34.30 AUX3: 0.00 #============================== # Magnit Delay #============================== 1: -304 -2.59 -0.10 2: -290 -1.25 0.24 3: -277 -0.29 0.58 4: -263 0.28 1.03 5: -249 0.51 1.43 6: -235 0.53 1.73 7: -221 0.45 1.79 8: -207 0.35 1.62 9: -193 0.27 1.35 10: -180 0.21 1.05 11: -166 0.19 0.78 12: -152 0.19 0.60 13: -138 0.22 0.47 14: -124 0.25 0.40 15: -110 0.29 0.33 16: -96 0.32 0.30 17: -83 0.33 0.27 18: -69 0.32 0.23 19: -55 0.29 0.20 20: -41 0.24 0.16 21: -27 0.18 0.10 22: -13 0.10 0.05 23: 0 0.00 0.00 24: 13 -0.10 -0.04 25: 27 -0.21 -0.09 26: 41 -0.31 -0.11 27: 55 -0.41 -0.11 28: 69 -0.48 -0.09 29: 83 -0.55 -0.06 30: 96 -0.61 0.01 31: 110 -0.67 0.09 32: 124 -0.74 0.19 33: 138 -0.83 0.30 34: 152 -0.97 0.44 35: 166 -1.17 0.57 36: 180 -1.45 0.68 37: 193 -1.82 0.75 38: 207 -2.30 0.76 39: 221 -2.89 0.73 40: 235 -3.61 0.69 41: 249 -4.48 0.66 42: 263 -5.57 0.67 43: 277 -6.93 0.74 44: 290 -8.62 0.87 45: 304 -10.65 1.08 # Passband characteristic of notch filter (RX) ID: USER_14732 UPDATE_INDEX: 01.01 ROWS: 31 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 33.81 AUX2: 33.94 AUX3: 0.00 #============================== # Magnit Delay #============================== 1: -2077 12.85 63.00 2: -1939 12.74 59.00 3: -1800 12.58 51.00 4: -1662 12.37 44.00 5: -1523 12.11 36.50 6: -1385 11.81 30.00 7: -1246 11.47 23.80 8: -1108 11.06 18.60 9: -969 10.58 13.50 10: -831 9.97 10.30 11: -692 9.19 6.50 12: -554 8.12 3.30 13: -415 6.61 1.20 14: -277 4.29 4.60 15: -138 1.19 5.10 16: 0 0.00 0.00 17: 138 3.38 0.00 18: 277 6.69 4.00 19: 415 8.89 2.00 20: 554 10.27 0.20 21: 692 11.15 0.80 22: 831 11.71 3.30 23: 969 12.06 5.90 24: 1108 12.28 8.00 25: 1246 12.43 10.60 26: 1385 12.52 13.90 27: 1523 12.58 15.00 28: 1662 12.62 17.00 29: 1800 12.64 19.40 30: 1939 12.64 22.10 31: 2077 12.62 24.00 # Passband characteristic of WCDMA filter (RX) ID: USER_14733 UPDATE_INDEX: 02.02 ROWS: 39 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 33.94 AUX2: 34.06 AUX3: 0.00 #============================== # Magnit Delay #============================== 1: -9418 1.18 -25.00 2: -8864 1.45 -24.00 3: -8310 1.57 -23.00 4: -7756 1.61 -23.00 5: -7202 1.62 -23.00 6: -6648 1.61 -23.00 7: -6094 1.60 -23.00 8: -5540 1.56 -23.80 9: -5263 1.53 -21.00 10: -4986 1.50 -21.50 11: -4709 1.45 -20.20 12: -4432 1.40 -19.90 13: -4155 1.33 -19.80 14: -3878 1.26 -18.20 15: -3601 1.17 -17.80 16: -3324 1.08 -15.60 17: -3047 0.97 -15.50 18: -2770 0.85 -14.10 19: -2493 0.72 -13.30 20: -2216 0.57 -12.00 21: -1939 0.42 -10.70 22: -1662 0.30 -9.80 23: -1385 0.23 -7.90 24: -1108 0.18 -7.20 25: -831 0.13 -7.50 26: -554 0.08 -5.20 27: -277 0.05 -2.50 28: 0 0.00 0.00 29: 277 -0.04 7.50 30: 554 -0.11 2.70 31: 831 -0.12 5.90 32: 1108 -0.13 7.80 33: 1385 -0.16 10.30 34: 1662 -0.27 11.30 35: 1939 -0.40 13.80 36: 2216 -0.53 15.10 37: 2493 -0.66 19.80 38: 2770 -0.78 23.30 39: 3047 -0.94 21.50 # Passband characteristic of 10.0 MHz prefilter (RX) ID: USER_14734 UPDATE_INDEX: 01.01 ROWS: 25 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 33.69 AUX2: 33.57 AUX3: 0.00 #============================== # Magnit Delay #============================== 1: -3601 -6.98 -23.00 2: -3324 -2.64 -23.00 3: -3047 -0.33 -23.00 4: -2770 0.03 -23.00 5: -2493 -0.28 -23.00 6: -2216 -0.59 -23.80 7: -1939 -0.74 -21.00 8: -1662 -0.76 -21.50 9: -1385 -0.68 -20.20 10: -1108 -0.55 -19.90 11: -831 -0.38 -19.80 12: -554 -0.21 -18.20 13: -277 -0.02 -17.80 14: 0 0.00 0.00 15: 277 -0.01 -15.50 16: 554 -0.15 -14.10 17: 831 -0.29 -13.30 18: 1108 -0.46 -12.00 19: 1385 -0.66 -10.70 20: 1662 -0.87 -9.80 21: 1939 -1.15 -7.90 22: 2216 -1.55 -7.20 23: 2493 -2.22 -7.50 24: 2770 -3.27 -5.20 25: 3047 -4.78 -2.50 # Passband characteristic of 2 MHz narrowband filter (RX) ID: USER_14735 UPDATE_INDEX: 01.00 ROWS: 29 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 33.69 AUX2: 33.57 AUX3: 0.00 #============================== # Magnit Delay #============================== 1: -1939 -5.50 -25.00 2: -1800 -4.11 -24.00 3: -1662 -2.99 -23.00 4: -1523 -2.12 -23.00 5: -1385 -1.49 -23.00 6: -1246 -1.04 -23.00 7: -1108 -0.71 -23.00 8: -969 -0.47 -23.80 9: -831 -0.29 -21.00 10: -692 -0.17 -21.50 11: -554 -0.09 -20.20 12: -415 -0.02 -19.90 13: -277 0.00 -19.80 14: -139 -0.07 -18.20 15: 0 0.00 0.00 16: 139 0.02 -15.60 17: 277 -0.15 -15.50 18: 415 -0.21 -14.10 19: 554 -0.28 -13.30 20: 692 -0.33 -12.00 21: 831 -0.39 -10.70 22: 969 -0.48 -9.80 23: 1108 -0.64 -7.90 24: 1246 -0.92 -7.20 25: 1385 -1.40 -7.50 26: 1523 -2.11 -5.20 27: 1662 -3.08 -2.50 28: 1800 -4.28 -1.00 29: 1939 -5.67 0.00 # Bounds of frequency bands (RX) ID: USER_14750 UPDATE_INDEX: 02.02 ROWS: 7 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: RXTX_FREQUENCY_BAND_BOUND AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #================================================ # LowerBound UpperBound #================================================ 1: 20 15100 2: 30 632900 3: 632900 1282900 4: 957900 1607900 5: 1607900 2257900 6: 2046700 2700000 7: 2600000 3300000 # SAW-filter characteristic (RX) ID: USER_14760 UPDATE_INDEX: 02.02 ROWS: 59 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: PASSBAND AUX1: 34.06 AUX2: 33.69 AUX3: -43.18 #============================== # Magnit Delay #============================== 1: -4016 -0.53 4.20 2: -3878 -0.58 3.00 3: -3739 -0.68 1.80 4: -3601 -0.75 -1.60 5: -3462 -0.79 -2.80 6: -3324 -0.78 3.50 7: -3185 -0.75 8.80 8: -3047 -0.74 8.50 9: -2908 -0.75 7.50 10: -2770 -0.78 5.30 11: -2631 -0.80 0.60 12: -2493 -0.74 1.50 13: -2354 -0.68 6.60 14: -2216 -0.61 11.00 15: -2077 -0.55 9.40 16: -1939 -0.56 7.40 17: -1800 -0.57 5.90 18: -1662 -0.57 2.60 19: -1523 -0.54 4.00 20: -1385 -0.44 10.10 21: -1246 -0.38 8.50 22: -1108 -0.33 7.10 23: -969 -0.32 7.40 24: -831 -0.34 4.70 25: -692 -0.30 2.20 26: -554 -0.23 3.30 27: -415 -0.16 4.10 28: -277 -0.06 1.30 29: -138 -0.02 -0.50 30: 0 0.00 0.00 31: 138 0.00 -0.40 32: 277 -0.01 1.20 33: 415 0.04 0.10 34: 554 0.09 -1.00 35: 692 0.16 -7.70 36: 831 0.24 -10.30 37: 969 0.24 -9.90 38: 1108 0.24 -9.50 39: 1246 0.24 -7.70 40: 1385 0.23 -7.30 41: 1523 0.27 -12.60 42: 1662 0.30 -20.00 43: 1800 0.32 -25.60 44: 1939 0.33 -24.30 45: 2077 0.27 -23.70 46: 2216 0.23 -20.00 47: 2354 0.19 -16.30 48: 2493 0.15 -24.50 49: 2631 0.16 -35.80 50: 2770 0.12 -44.20 51: 2908 0.05 -44.80 52: 3047 -0.04 -39.40 53: 3185 -0.18 -36.80 54: 3324 -0.32 -29.40 55: 3462 -0.45 -24.50 56: 3601 -0.62 -35.80 57: 3739 -0.81 -44.20 58: 3878 -1.07 -44.80 59: 4016 -1.33 -39.40 ID: USER_14800 UPDATE_INDEX: 01.00 ROWS: 5 COLUMNS: 5 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: INT8 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 3 4 5 #=================================== 1: -1 0 0 1 1 2: -2 0 0 1 1 3: -4 0 1 1 1 4: 2 0 -2 1 1 5: 3 0 -2 1 1 ROWS: 7 COLUMNS: 5 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: INT8 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 3 4 5 #=================================== 1: 1 0 0 -1 1 2: 2 0 -1 -1 1 3: -2 0 2 -1 1 4: 3 0 -1 -1 1 5: -3 0 3 -1 1 6: -4 0 3 -1 1 7: 4 0 -2 -1 1 ROWS: 2 COLUMNS: 5 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: INT8 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #=================================== # COL 1 2 3 4 5 #=================================== 1: 0 1 -2 1 1 2: 2 -1 -1 1 1 # Output level with calsource (TX) ID: USER_15000 UPDATE_INDEX: 02.01 ROWS: 1 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 29.30 AUX2: 34.14 AUX3: 0.00 #============== # db #============== 1: -5.44 ID: USER_15005 UPDATE_INDEX: 04.00 ROWS: 1 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 40.00 AUX2: 40.00 AUX3: 0.00 #============== #============== 1: 0.00 # table of tuning filter temperature characteristic (TX) ID: USER_15010 UPDATE_INDEX: 01.00 ROWS: 3 COLUMNS: 1 ROW_ID_TYPE: INT8 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #==================== # temp Filter #==================== 1: 0 0.00 2: 50 0.00 3: 80 0.00 # voltage characteristic of tuning filter (TX) ID: USER_15020 UPDATE_INDEX: 02.01 ROWS: 22 COLUMNS: 4 ROW_ID_TYPE: UINT16 COLUMN_ID_TYPE: 0 DATATYPE: UINT16 AUX1: 31.01 AUX2: 35.48 AUX3: 0.00 #======================================== # COL 1 2 3 4 #======================================== 1: 1200 167 0 0 1 2: 1250 202 0 0 1 3: 1300 231 41 0 0 4: 1350 246 81 0 0 5: 1400 267 137 0 0 6: 1450 274 191 0 0 7: 1500 295 243 0 0 8: 1550 334 306 0 0 9: 1600 356 346 0 0 10: 1650 393 393 0 0 11: 1700 445 428 0 0 12: 1750 475 475 0 0 13: 1800 505 504 0 0 14: 1850 556 536 0 0 15: 1900 586 586 0 0 16: 1950 623 621 0 0 17: 2000 646 670 0 0 18: 2050 740 719 0 0 19: 2100 813 770 0 0 20: 2150 950 799 0 0 21: 2200 1023 873 2 0 22: 2250 1010 902 2 0 # FM deviation ID: USER_15030 UPDATE_INDEX: 01.01 ROWS: 3 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: DOUBLE DATATYPE: DOUBLE AUX1: 48.83 AUX2: 55.63 AUX3: 0.00 #=================== #=================== 0: 501.370000 #------------------- 1: 15894.742207 2: 68677.774407 3: 316368.738007 ID: USER_15035 UPDATE_INDEX: 02.00 ROWS: 3 COLUMNS: 7 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: DOUBLE DATATYPE: DOUBLE AUX1: 0.00 AUX2: 0.00 AUX3: 50.13 #================================================================================== # COL 1 2 3 4 5 6 7 #================================================================================== 0: 10.000000 0.080000 0.100000 10.000000 100.000000 300.000000 500.000000 #---------------------------------------------------------------------------------- 1: 63.000000 80.000000 1.200000 0.000000 0.000000 0.000000 -1.000000 2: 63.000000 80.000000 1.200000 0.100000 0.000000 -0.400000 -2.500000 3: 160.000000 80.000000 1.200000 0.200000 0.000000 -1.000000 -3.700000 ID: USER_15050 UPDATE_INDEX: 01.01 ROWS: 21 COLUMNS: 1 ROW_ID_TYPE: FIX16D2 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D3 AUX1: 28.93 AUX2: 33.87 AUX3: 0.00 #======================= #======================= 1: 0.00 0.213 2: -1.00 0.190 3: -2.00 0.164 4: -3.00 0.143 5: -4.00 0.123 6: -5.00 0.105 7: -6.00 0.090 8: -7.00 0.077 9: -8.00 0.066 10: -9.00 0.055 11: -10.00 0.047 12: -11.00 0.038 13: -12.00 0.034 14: -13.00 0.027 15: -14.00 0.023 16: -15.00 0.020 17: -16.00 0.015 18: -17.00 0.012 19: -18.00 0.011 20: -19.00 0.007 21: -20.00 0.008 # Characteristic of power detector ID: USER_15500 UPDATE_INDEX: 04.04 ROWS: 19 COLUMNS: 4 ROW_ID_TYPE: FIX16D2 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D3 AUX1: 33.69 AUX2: 33.94 AUX3: 84.17 #================================================== # dBm V V # COL 1 2 3 4 #================================================== 1: 11.14 1.705 2.272 2.208 2.432 2: 6.96 1.580 2.159 2.090 2.328 3: 1.96 1.456 2.032 1.958 2.205 4: -3.06 1.333 1.898 1.830 2.083 5: -8.08 1.205 1.777 1.708 1.953 6: -12.96 1.085 1.650 1.580 1.830 7: -17.98 0.959 1.523 1.456 1.709 8: -22.98 0.828 1.395 1.324 1.573 9: -27.98 0.708 1.266 1.196 1.449 10: -32.98 0.586 1.144 1.075 1.328 11: -37.98 0.461 1.021 0.948 1.205 12: -42.98 0.353 0.896 0.823 1.080 13: -47.98 0.275 0.769 0.699 0.961 14: -52.98 0.234 0.646 0.570 0.835 15: -57.98 0.215 0.524 0.439 0.739 16: -62.98 0.211 0.402 0.350 0.645 17: -67.98 0.209 0.342 0.249 0.607 18: -72.98 0.205 0.239 0.206 0.580 19: -77.98 0.208 0.276 0.197 0.645 ID: USER_15510 UPDATE_INDEX: 01.00 ROWS: 1 COLUMNS: 2 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: DOUBLE AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #========================= # COL 1 2 #========================= 1: 0.002252 0.038444 # Comb generator settings ID: USER_15550 UPDATE_INDEX: 01.02 ROWS: 3 COLUMNS: 1 ROW_ID_TYPE: UINT8 COLUMN_ID_TYPE: 0 DATATYPE: COMB_SETTINGS AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #===================================== # State N-Cnt R-Cnt Deviation #===================================== 1: 0 3 3 0 0.00 2: 1 768 11080 10 0.00 3: 2 768 1385 10 0.00 ID: USER_15600 UPDATE_INDEX: 01.00 ROWS: 20 COLUMNS: 1 ROW_ID_TYPE: INT16 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D2 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #===================== #===================== 1: -1800 -199.00 2: -1600 -199.00 3: -1400 -199.00 4: -1200 -199.00 5: -1000 -199.00 6: -800 -199.00 7: -600 -92.00 8: -400 -90.00 9: -250 -199.00 10: -100 -199.00 11: 100 -199.00 12: 250 -199.00 13: 400 -90.00 14: 600 -92.00 15: 800 -199.00 16: 1000 -199.00 17: 1200 -199.00 18: 1400 -199.00 19: 1600 -199.00 20: 1800 -199.00 ID: USER_15610 UPDATE_INDEX: 00.00 ROWS: 120 COLUMNS: 2 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: INT32 AUX1: 39.43 AUX2: 40.16 AUX3: 0.00 #============================= # COL 1 2 #============================= 1: 16776267 16776233 2: 16777009 16776356 3: 1481 16776967 4: 2257 451 5: 1038 863 6: 16775840 758 7: 16774395 332 8: 16775534 16777134 9: 1537 16776986 10: 4356 16777003 11: 4275 16776924 12: 954 16776566 13: 16773990 16776135 14: 16772309 16776070 15: 16774727 16776728 16: 2346 722 17: 5770 1830 18: 4827 2040 19: 4 1056 20: 16772310 16776538 21: 16771477 16775047 22: 16775733 16774638 23: 4553 16775461 24: 7144 16776873 25: 3463 786 26: 16773035 1172 27: 16767547 1115 28: 16769365 1257 29: 885 1904 30: 10131 2506 31: 12039 2017 32: 3759 16776982 33: 16767806 16773585 34: 16759944 16770875 35: 16764676 16770875 36: 2653 16774257 37: 17214 2403 38: 19136 6880 39: 5558 8022 40: 16763848 5451 41: 16756088 1193 42: 16768906 16775306 43: 17330 16774791 44: 33556 16775600 45: 19835 16774913 46: 16753798 16771161 47: 16709266 16766610 48: 16704816 16767019 49: 16764362 689 50: 90518 21798 51: 172796 43933 52: 157941 51088 53: 12308 28494 54: 16563130 16749720 55: 16387559 16673998 56: 16421107 16606780 57: 16763748 16579511 58: 609675 16611300 59: 1343860 16697982 60: 1938981 34206 61: 2172474 134200 62: 1948641 185314 63: 1354410 174461 64: 608566 114737 65: 16741353 37279 66: 16376120 16752978 67: 16327995 16727926 68: 16502829 16739609 69: 16742021 16771500 70: 131055 24391 71: 166360 37112 72: 97981 29683 73: 16776775 10527 74: 16714940 16769369 75: 16713777 16760604 76: 16753102 16762774 77: 16249 16770960 78: 29367 1374 79: 13760 4506 80: 16766242 3388 81: 16754364 900 82: 16763357 16776948 83: 6769 448 84: 22253 1631 85: 21811 1533 86: 7800 16776956 87: 16769459 16774754 88: 16764027 16774080 89: 16771587 16775981 90: 8026 2581 91: 17349 6400 92: 16357 8361 93: 7200 7807 94: 16774652 5512 95: 16770939 2936 96: 16774264 1176 97: 2848 379 98: 5335 16777180 99: 2232 16776555 100: 16773465 16775683 101: 16769704 16775098 102: 16771383 16775370 103: 136 16776568 104: 5973 884 105: 7533 1911 106: 4061 1914 107: 16775697 1054 108: 16772124 16777199 109: 16772703 16776584 110: 16776260 16776625 111: 2396 16777035 112: 3041 95 113: 1013 16777201 114: 16775715 16776827 115: 16775006 16776567 116: 16776557 16776648 117: 1578 16777017 118: 2407 110 119: 1119 148 120: 16776140 16777067 ID: USER_15611 UPDATE_INDEX: 00.00 ROWS: 120 COLUMNS: 2 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: INT32 AUX1: 39.43 AUX2: 40.16 AUX3: 0.00 #============================= # COL 1 2 #============================= 1: 16776228 16775536 2: 58 16775865 3: 2136 16776890 4: 3180 671 5: 1972 1069 6: 16776526 906 7: 16774762 655 8: 16775704 708 9: 1692 907 10: 4529 678 11: 4299 16776815 12: 591 16775202 13: 16773185 16774084 14: 16771319 16774514 15: 16774028 16776666 16: 2323 2283 17: 6454 4107 18: 5862 3742 19: 912 1387 20: 16772837 16775747 21: 16771777 16774097 22: 16776192 16774369 23: 5440 16775841 24: 8330 16777091 25: 4514 51 26: 16773581 16776869 27: 16767680 47 28: 16769653 2064 29: 1964 4839 30: 12111 6048 31: 14244 3603 32: 5046 16774862 33: 16767357 16768364 34: 16757922 16765551 35: 16762250 16768994 36: 1252 245 37: 17544 9096 38: 20674 13263 39: 7001 10765 40: 16764185 4103 41: 16755476 16775413 42: 16768499 16773485 43: 18082 16774124 44: 34842 16772355 45: 19240 16764540 46: 16748652 16753594 47: 16699262 16749739 48: 16693783 16764544 49: 16759419 23607 50: 98186 68032 51: 193980 93150 52: 184937 70608 53: 30624 16766881 54: 16558234 16647360 55: 16353636 16537154 56: 16366811 16492487 57: 16711046 16549293 58: 585075 16701010 59: 1365878 118817 60: 2007995 281352 61: 2268749 346065 62: 2039509 288373 63: 1408861 139138 64: 610384 16742678 65: 16695239 16616250 66: 16304199 16580193 67: 16258840 16632562 68: 16458949 16733178 69: 16731779 50900 70: 148210 100000 71: 196100 93105 72: 125361 48417 73: 15765 16774243 74: 16718886 16741509 75: 16709528 16735889 76: 16745724 16749562 77: 8851 16767760 78: 22619 2057 79: 7306 4493 80: 16760342 2438 81: 16750381 1626 82: 16762883 4035 83: 10263 7168 84: 28339 7111 85: 27814 2385 86: 11118 16772661 87: 16768832 16768121 88: 16759912 16769325 89: 16765537 16775949 90: 1635 7090 91: 11506 12711 92: 11205 13194 93: 2625 9351 94: 16770785 4100 95: 16768239 215 96: 16773171 16775861 97: 3340 16775710 98: 6779 16775542 99: 3680 16774796 100: 16774166 16774162 101: 16769468 16774760 102: 16770549 16776943 103: 16776435 2543 104: 5278 4329 105: 7037 3921 106: 3580 1537 107: 16775193 16775848 108: 16771843 16774099 109: 16773057 16774295 110: 306 16775941 111: 4478 567 112: 5494 1563 113: 3271 1516 114: 146 977 115: 16775922 594 116: 16776835 541 117: 1364 455 118: 1775 16777145 119: 137 16776205 120: 16774936 16775433 # PLL settings of RX-LO3 with temp.-dyn.-IF2-sweep ID: USER_15620 UPDATE_INDEX: 03.00 ROWS: 6 COLUMNS: 1 ROW_ID_TYPE: UINT8 COLUMN_ID_TYPE: 0 DATATYPE: LO3_SETTINGS AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #================================================================= # C1 C2 C3 RCnt NCnt ACnt dyn IF3-Freq RF-Temp IF-Temp #================================================================= 1: 0 1 1 1 20 22 7 0 10700000 0.00 0.00 2: 1 1 1 1 20 22 5 0 7680000 0.00 0.00 3: 2 1 1 1 20 22 6 0 10000000 0.00 0.00 4: 3 1 1 1 400 448 12 1 10700000 40.00 40.00 5: 4 1 1 1 400 446 4 1 7680000 40.00 40.00 6: 5 1 1 1 400 447 4 1 7680000 40.00 40.00 # RXTX gain and offset values for diagnosis ID: USER_15900 UPDATE_INDEX: 03.02 ROWS: 38 COLUMNS: 1 ROW_ID_TYPE: FIX16D2 COLUMN_ID_TYPE: 0 DATATYPE: FIX16D3 AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #======================= #======================= 1: 5.70 0.000 2: 2.50 0.000 3: 3.74 3.663 4: 1.10 0.000 5: 1.47 0.000 6: 2.50 3.000 7: 3.74 3.663 8: 2.50 3.000 9: 100.00 0.000 10: 2.00 0.000 11: 6.17 0.380 12: 1.00 0.000 13: 1.00 0.000 14: 1.00 0.000 15: 1.00 0.346 16: 1.00 0.000 17: 6.60 0.455 18: 1.10 0.455 19: 6.60 0.455 20: 6.60 0.455 21: 1.10 0.455 22: 1.10 0.455 23: 110.00 0.455 24: 1.10 0.455 25: 6.60 0.455 26: 1.10 0.455 27: 6.60 0.455 28: 1.10 0.455 29: 6.60 0.455 30: 100.00 0.000 31: 1.10 0.455 32: 100.00 0.000 33: 5.70 0.200 34: 1.10 0.455 35: 1.10 0.455 36: 2.00 0.000 37: 2.00 0.000 38: 2.00 0.000 # diagnosis settings ID: USER_15910 UPDATE_INDEX: 03.00 ROWS: 59 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: RXTX_DIAG_SETTINGS AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #================================================= # ID DAdr Bits Frequency Band SReg Reg #================================================= 1: 1 1 0 0 0 8 0 2: 2 2 0 0 0 8 0 3: 3 3 0 0 0 8 0 4: 4 4 0 0 0 8 0 5: 5 5 0 0 0 8 0 6: 6 6 0 0 0 8 0 7: 7 7 0 0 0 8 0 8: 8 8 0 0 0 8 0 9: 55 36 0 0 0 8 0 10: 56 37 0 0 0 8 0 11: 57 10 0 0 0 8 0 12: 58 38 0 0 0 8 0 13: 9 9 0 0 0 8 0 14: 23 23 0 0 0 8 0 15: 30 30 0 0 0 8 0 16: 32 32 0 0 0 8 0 17: 48 22 95 650000 2 8 0 18: 29 29 1 2300000 5 8 0 19: 28 28 95 2300000 5 8 0 20: 53 28 127 2300000 5 8 0 21: 20 20 1 650000 2 8 0 22: 21 21 79 650000 2 8 0 23: 47 21 95 650000 2 8 0 24: 17 17 1 15000 1 8 0 25: 43 17 1 2200000 4 8 0 26: 44 17 1 600000 1 8 0 27: 45 17 1 650000 2 8 0 28: 24 24 1 650000 2 8 0 29: 19 19 1 650000 2 8 0 30: 18 18 87 650000 2 8 0 31: 46 18 95 650000 2 8 0 32: 14 14 0 0 0 1 512 33: 59 33 0 0 0 4 512 34: 11 11 0 0 0 3 0 35: 54 11 0 0 0 3 1 36: 33 11 0 0 0 3 2 37: 34 11 0 0 0 3 4 38: 35 11 0 0 0 3 8 39: 36 11 0 0 0 3 16 40: 37 11 0 0 0 3 32 41: 38 11 0 0 0 3 64 42: 39 11 0 0 0 3 128 43: 40 11 0 0 0 3 256 44: 41 11 0 0 0 3 512 45: 42 11 0 0 0 3 1023 46: 60 34 0 0 0 8 0 47: 61 35 0 0 0 8 0 48: 25 25 0 15000 1 8 0 49: 49 25 0 2200000 4 8 0 50: 50 25 0 600000 1 8 0 51: 51 25 0 650000 2 8 0 52: 31 31 0 650000 2 8 0 53: 27 27 0 650000 2 8 0 54: 26 26 91 650000 2 8 0 55: 52 26 95 650000 2 8 0 56: 13 13 0 0 0 0 512 57: 12 12 0 0 0 5 512 58: 15 15 0 0 0 8 0 59: 16 16 0 0 0 8 0 # limits of diagnosis voltages ID: USER_15920 UPDATE_INDEX: 06.10 ROWS: 97 COLUMNS: 1 ROW_ID_TYPE: 0 COLUMN_ID_TYPE: 0 DATATYPE: DIAG_DESCRIPTOR AUX1: 0.00 AUX2: 0.00 AUX3: 0.00 #================================================= # ID min. (V) max. (V) FMDV (V) act #================================================= 1: 1 25.024 28.840 0.000 128 2: 2 10.900 12.200 0.000 128 3: 3 -5.500 -4.500 0.000 128 4: 4 4.750 5.252 0.000 128 5: 5 3.200 3.465 0.000 128 6: 6 -5.400 -4.600 0.000 128 7: 7 -12.500 -10.800 0.000 128 8: 8 -6.500 -5.500 0.000 128 9: 55 7.000 8.000 0.000 128 10: 56 7.000 8.000 0.000 128 11: 57 4.900 5.100 0.000 128 12: 58 5.000 6.000 0.000 128 13: 9 0.000 0.700 0.000 128 14: 23 0.000 0.700 0.000 128 15: 30 0.000 0.700 0.000 128 16: 32 0.000 0.700 0.000 128 17: 48 0.100 0.300 0.000 128 18: 29 3.000 20.000 0.000 128 19: 53 -0.200 0.860 0.000 128 20: 20 0.500 24.000 0.000 128 21: 47 0.230 0.620 0.000 128 22: 17 2.000 24.000 0.000 128 23: 24 0.000 1.300 0.000 128 24: 19 7.500 10.000 0.000 128 25: 46 0.700 1.430 0.000 128 26: 14 0.000 2.428 0.000 128 27: 59 0.000 27.882 0.000 128 28: 11 -1.758 27.612 0.000 128 29: 60 -0.055 0.315 0.000 128 30: 61 -0.030 0.030 0.000 128 31: 25 2.000 24.000 0.000 128 32: 31 0.000 1.500 0.000 128 33: 27 2.800 15.200 0.000 128 34: 52 0.640 1.200 0.000 128 35: 13 0.000 2.428 0.000 128 36: 12 0.000 2.428 0.000 128 37: 15 -0.400 2.800 0.000 128 38: 16 -0.300 2.500 0.000 128 39: 1 25.024 28.840 27.428 0 40: 2 10.900 12.200 11.765 0 41: 3 -5.500 -4.500 -5.053 0 42: 4 4.750 5.252 5.042 0 43: 5 3.200 3.465 3.357 0 44: 6 -5.400 -4.600 -5.080 0 45: 7 -12.500 -10.800 -11.659 0 46: 8 -6.500 -5.500 -6.017 0 47: 55 7.000 8.000 7.512 0 48: 56 7.000 8.000 7.515 0 49: 57 4.900 5.100 5.017 0 50: 58 5.000 6.000 5.500 0 51: 9 0.000 0.700 0.309 0 52: 23 0.000 0.700 0.355 0 53: 30 0.000 0.700 0.348 0 54: 32 0.000 0.700 0.342 0 55: 48 0.100 0.300 0.202 0 56: 29 3.000 20.000 10.726 0 57: 28 -0.200 0.200 0.000 0 58: 53 0.240 0.860 0.755 0 59: 20 0.500 24.000 8.639 0 60: 21 -0.200 0.200 0.003 0 61: 47 0.230 0.620 0.486 0 62: 17 3.800 7.800 5.940 0 63: 43 15.000 24.000 19.531 0 64: 44 15.000 22.000 18.492 0 65: 45 3.600 9.600 7.301 0 66: 24 0.000 1.300 0.537 0 67: 19 7.500 10.000 8.631 0 68: 18 -0.200 0.200 -0.001 0 69: 46 0.700 1.430 1.083 0 70: 14 1.100 1.300 1.216 0 71: 59 -0.800 27.382 11.885 0 72: 11 -1.758 0.149 -1.102 0 73: 54 -1.106 -1.049 -1.079 0 74: 33 -1.085 -1.020 -1.057 0 75: 34 -1.035 -0.971 -1.004 0 76: 35 -0.951 -0.856 -0.899 0 77: 36 -0.784 -0.627 -0.695 0 78: 37 -0.450 -0.167 -0.288 0 79: 38 0.219 0.750 0.540 0 80: 39 1.558 2.588 2.197 0 81: 40 4.238 6.258 5.496 0 82: 41 9.588 13.608 12.116 0 83: 42 20.268 28.268 25.259 0 84: 60 -0.055 0.315 0.105 0 85: 61 -0.030 0.030 0.000 0 86: 25 4.000 9.000 7.164 0 87: 49 15.000 24.000 18.242 0 88: 50 17.000 22.000 19.684 0 89: 51 3.000 9.000 5.932 0 90: 31 0.000 1.500 0.384 0 91: 27 2.800 15.200 6.383 0 92: 26 -0.200 0.200 0.000 0 93: 52 0.640 1.200 0.828 0 94: 13 1.100 1.300 1.208 0 95: 12 1.100 1.300 1.210 0 96: 15 -0.400 2.800 2.164 0 97: 16 -0.300 2.500 0.187 0 ID: END
