root@STSTW1:~# lshw ststw1 description: Desktop Computer product: SurfTab duo W1 10.1 (VT4) (ST10432-10) vendor: TrekStor version: To be filled by O.E.M. serial: 39340ZOFC0006LW width: 32 bits capabilities: smbios-2.8 dmi-2.8 configuration: boot=normal chassis=desktop family=CherryTrail CR sku=ST10432-10 uuid=00020003-0004-0005-0006-000700080009 *-core description: Motherboard product: Cherry Trail CR vendor: Hampoo physical id: 0 version: V200 slot: To be filled by O.E.M. *-firmware description: BIOS vendor: American Megatrends Inc. physical id: 0 version: BW3_VT4.105 date: 12/18/2015 size: 64KiB capacity: 4032KiB capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer acpi usb biosbootspecification uefi *-memory description: System Memory physical id: 28 slot: System board or motherboard size: 2GiB capabilities: ecc configuration: errordetection=multi-bit-ecc *-bank:0 description: DIMM DDR3 1600 MHz (0,6 ns) product: 00000000 vendor: Hynix Semiconductor physical id: 0 serial: 00000000 slot: A1_DIMM0 size: 2GiB width: 8 bits clock: 1600MHz (0.6ns) *-bank:1 description: DIMM [empty] product: 00000000 vendor: Hynix Semiconductor physical id: 1 serial: 00000000 slot: A1_DIMM1 *-cache:0 description: L1 cache physical id: 32 slot: CPU Internal L1 size: 224KiB capacity: 224KiB capabilities: internal write-back configuration: level=1 *-cache:1 description: L2 cache physical id: 33 slot: CPU Internal L2 size: 2MiB capacity: 2MiB capabilities: internal write-back unified configuration: level=2 *-cpu description: CPU product: Intel(R) Atom(TM) x5-Z8300 CPU @ 1.44GHz vendor: Intel Corp. physical id: 34 bus info: cpu@0 version: 6.12.3 serial: 0004-06C3-0000-0000-0000-0000 slot: SOCKET 0 size: 479MHz capacity: 2400MHz width: 64 bits clock: 80MHz capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx rdtscp constant_tsc arch_perfmon pebs bts xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes rdrand lahf_lm 3dnowprefetch epb tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms dtherm ida arat cpufreq configuration: cores=4 enabledcores=4 id=0 threads=4 *-logicalcpu:0 description: Logical CPU physical id: 0.1 width: 64 bits capabilities: logical *-logicalcpu:1 description: Logical CPU physical id: 0.2 width: 64 bits capabilities: logical *-logicalcpu:2 description: Logical CPU physical id: 0.3 width: 64 bits capabilities: logical *-logicalcpu:3 description: Logical CPU physical id: 0.4 width: 64 bits capabilities: logical *-logicalcpu:4 description: Logical CPU physical id: 0.5 width: 64 bits capabilities: logical *-logicalcpu:5 description: Logical CPU physical id: 0.6 width: 64 bits capabilities: logical *-logicalcpu:6 description: Logical CPU physical id: 0.7 width: 64 bits capabilities: logical *-logicalcpu:7 description: Logical CPU physical id: 0.8 width: 64 bits capabilities: logical *-logicalcpu:8 description: Logical CPU physical id: 0.9 width: 64 bits capabilities: logical *-logicalcpu:9 description: Logical CPU physical id: 0.a width: 64 bits capabilities: logical *-logicalcpu:10 description: Logical CPU physical id: 0.b width: 64 bits capabilities: logical *-logicalcpu:11 description: Logical CPU physical id: 0.c width: 64 bits capabilities: logical *-logicalcpu:12 description: Logical CPU physical id: 0.d width: 64 bits capabilities: logical *-logicalcpu:13 description: Logical CPU physical id: 0.e width: 64 bits capabilities: logical *-logicalcpu:14 description: Logical CPU physical id: 0.f width: 64 bits capabilities: logical *-logicalcpu:15 description: Logical CPU physical id: 0.10 width: 64 bits capabilities: logical *-pci description: Host bridge product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register vendor: Intel Corporation physical id: 100 bus info: pci@0000:00:00.0 version: 22 width: 32 bits clock: 33MHz configuration: driver=iosf_mbi_pci resources: irq:0 *-display description: VGA compatible controller product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 version: 22 width: 64 bits clock: 33MHz capabilities: pm msi vga_controller bus_master cap_list rom configuration: driver=i915 latency=0 resources: irq:217 memory:90000000-90ffffff memory:80000000-8fffffff ioport:f000(size=64) memory:c0000-dffff *-multimedia UNCLAIMED description: Multimedia controller product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit vendor: Intel Corporation physical id: 3 bus info: pci@0000:00:03.0 version: 22 width: 32 bits clock: 33MHz capabilities: pm msi cap_list configuration: latency=0 resources: memory:91000000-913fffff *-generic:0 description: Signal processing controller product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Power Management Controller vendor: Intel Corporation physical id: b bus info: pci@0000:00:0b.0 version: 22 width: 64 bits clock: 33MHz capabilities: msi pm cap_list configuration: driver=proc_thermal latency=0 resources: irq:219 memory:91a3d000-91a3dfff *-usb:0 description: USB controller product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller vendor: Intel Corporation physical id: 14 bus info: pci@0000:00:14.0 version: 22 width: 64 bits clock: 33MHz capabilities: pm msi xhci bus_master cap_list configuration: driver=xhci_hcd latency=0 resources: irq:215 memory:91a00000-91a0ffff *-usbhost:0 product: xHCI Host Controller vendor: Linux 4.9.0-8-686 xhci-hcd physical id: 0 bus info: usb@1 logical name: usb1 version: 4.09 capabilities: usb-2.00 configuration: driver=hub slots=7 speed=480Mbit/s *-usb description: USB hub product: USB2.0 Hub vendor: Genesys Logic, Inc. physical id: 3 bus info: usb@1:3 version: 85.36 capabilities: usb-2.00 configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s *-usb:0 description: USB hub product: USB2.0 Hub vendor: GenesysLogic physical id: 1 bus info: usb@1:3.1 version: 92.23 capabilities: usb-2.00 configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s *-usb description: Generic USB device product: USB 10/100/1000 LAN vendor: Realtek physical id: 1 bus info: usb@1:3.1.1 version: 30.00 serial: 00E04C680ABE capabilities: usb-2.10 configuration: driver=r8152 maxpower=100mA speed=480Mbit/s *-usb:1 description: Mouse product: USB Optical Mouse vendor: Logitech physical id: 3 bus info: usb@1:3.3 version: 67.00 capabilities: usb-2.00 configuration: driver=usbhid maxpower=98mA speed=1Mbit/s *-usb:2 description: Keyboard product: USB Keyboard vendor: LIZHICHIP physical id: 4 bus info: usb@1:3.4 version: 1.10 capabilities: usb-1.10 configuration: driver=usbhid maxpower=98mA speed=1Mbit/s *-usbhost:1 product: xHCI Host Controller vendor: Linux 4.9.0-8-686 xhci-hcd physical id: 1 bus info: usb@2 logical name: usb2 version: 4.09 capabilities: usb-3.00 configuration: driver=hub slots=6 speed=5000Mbit/s *-usb:1 UNCLAIMED description: USB controller product: Intel Corporation vendor: Intel Corporation physical id: 16 bus info: pci@0000:00:16.0 version: 22 width: 32 bits clock: 33MHz capabilities: pm usb_device bus_master cap_list configuration: latency=0 resources: memory:91400000-915fffff *-generic:1 UNCLAIMED description: Encryption controller product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine vendor: Intel Corporation physical id: 1a bus info: pci@0000:00:1a.0 version: 22 width: 32 bits clock: 33MHz capabilities: pm msi bus_master cap_list configuration: latency=0 resources: memory:91900000-919fffff memory:91800000-918fffff *-isa description: ISA bridge product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU vendor: Intel Corporation physical id: 1f bus info: pci@0000:00:1f.0 version: 22 width: 32 bits clock: 33MHz capabilities: isa bus_master cap_list configuration: driver=lpc_ich latency=0 resources: irq:0 *-network description: Ethernet interface physical id: 1 logical name: eth0 serial: 00:e0:4c:68:0a:be size: 100Mbit/s capacity: 1Gbit/s capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.08.9 duplex=full ip=192.202.0.15 link=yes multicast=yes port=MII speed=100Mbit/s
