Arduino: 1.8.8 (Windows 10), Board: "ESPino (ESP-12 Module), 80 MHz, Flash, Enabled, ck, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200" C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Heiko\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Heiko\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Heiko\Documents\Arduino\libraries -fqbn=esp8266:esp8266:espino:xtal=80,vt=flash,exception=enabled,ResetMethod=ck,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10808 -build-path C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708 -warnings=none -build-cache C:\Users\Heiko\AppData\Local\Temp\arduino_cache_455189 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose D:\WordUhr\WORD Clock De Luxe\wordclock24h\wordclock24h\ESP8266\ESP-WordClock\ESP-WordClock.ino C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Heiko\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Heiko\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Heiko\Documents\Arduino\libraries -fqbn=esp8266:esp8266:espino:xtal=80,vt=flash,exception=enabled,ResetMethod=ck,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10808 -build-path C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708 -warnings=none -build-cache C:\Users\Heiko\AppData\Local\Temp\arduino_cache_455189 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose D:\WordUhr\WORD Clock De Luxe\wordclock24h\wordclock24h\ESP8266\ESP-WordClock\ESP-WordClock.ino Using board 'espino' from platform in folder: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2 Using core 'esp8266' from platform in folder: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2 Detecting libraries used... "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\ESP-WordClock.ino.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\ESP-WordClock.ino.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\ESP-WordClock.ino.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\ESP-WordClock.ino.cpp" -o nul Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\base.cpp Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\http.cpp Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\httpclient.cpp Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\ntp.cpp "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\stm32flash.cpp" -o nul Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\tables.cpp Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\udpsrv.cpp Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\vars.cpp Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\weather.cpp Using cached library dependencies for file: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\wifi.cpp "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\BearSSLHelpers.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\CertStoreBearSSL.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFi.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiAP.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGeneric.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiMulti.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA-WPS.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiScan.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\WiFiClient.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\WiFiClientSecureAxTLS.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\WiFiClientSecureBearSSL.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\WiFiServer.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\WiFiServerSecureAxTLS.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\WiFiServerSecureBearSSL.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src\\WiFiUdp.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src\\ESP8266HTTPClient.cpp" -o nul "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src\\ESP8266httpUpdate.cpp" -o nul Generating function prototypes... "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fexceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\ESP-WordClock.ino.cpp" -o "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\preproc\\ctags_target_for_gcc_minus_e.cpp" "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\preproc\\ctags_target_for_gcc_minus_e.cpp" Sketch wird kompiliert... "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fexceptions -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\stm32flash.cpp" -o "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\stm32flash.cpp.o" "C:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/lwip2/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fexceptions -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_ESP12\"" -DESP8266 "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\cores\\esp8266" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\variants\\espino" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266HTTPClient\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\ESP8266httpUpdate\\src" "-IC:\\Users\\Heiko\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0-beta2\\libraries\\esp8266\\src" "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\ESP-WordClock.ino.cpp" -o "C:\\Users\\Heiko\\AppData\\Local\\Temp\\arduino_build_123708\\sketch\\ESP-WordClock.ino.cpp.o" Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\base.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\httpclient.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\udpsrv.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\tables.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\http.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\vars.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\weather.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\wifi.cpp.o Zuvor kompilierte Datei wird verwendet: C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\ntp.cpp.o C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\stm32flash.cpp: In function 'int stm32_bootloader(int)': stm32flash.cpp:1104:32: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive] Serial.write (buffer, 1); ^ In file included from C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\cores\esp8266/Arduino.h:263:0, from C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\ESP8266WiFi\src/WiFiClient.h:25, from C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39, from C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\stm32flash.cpp:14: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\cores\esp8266/HardwareSerial.h:168:12: error: initializing argument 1 of 'virtual size_t HardwareSerial::write(const uint8_t*, size_t)' [-fpermissive] size_t write(const uint8_t *buffer, size_t size) ^ stm32flash.cpp:1161:40: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive] Serial.write (buffer, 1); ^ In file included from C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\cores\esp8266/Arduino.h:263:0, from C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\ESP8266WiFi\src/WiFiClient.h:25, from C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39, from C:\Users\Heiko\AppData\Local\Temp\arduino_build_123708\sketch\stm32flash.cpp:14: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\cores\esp8266/HardwareSerial.h:168:12: error: initializing argument 1 of 'virtual size_t HardwareSerial::write(const uint8_t*, size_t)' [-fpermissive] size_t write(const uint8_t *buffer, size_t size) ^ Bibliothek ESP8266WiFi in Version 1.0 im Ordner: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\ESP8266WiFi wird verwendet Bibliothek ESP8266HTTPClient in Version 1.2 im Ordner: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\ESP8266HTTPClient wird verwendet Bibliothek ESP8266httpUpdate in Version 1.3 im Ordner: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\ESP8266httpUpdate wird verwendet Bibliothek esp8266 in Version 1.0 im Ordner: C:\Users\Heiko\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\libraries\esp8266 wird verwendet exit status 1 invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
