;Program is made for the Atmega328p for connecting with the SSD1306 OLED ;Made by int 21h .def temp1 = r16 .def temp2 = r17 .def temp3 = r18 .equ SLAVE_ADDRESS_W = 0b01111010 ;****************************** ; INIT ;****************************** clr temp2 clr temp3 ;Init Stackpointer ldi temp1, HIGH(RAMEND) out SPH, temp1 ldi temp1, LOW(RAMEND) out SPL, temp1 ldi temp1, 0xFF out DDRD, temp1 out DDRC, temp1 ;Don't know if needed or not ;****************************** ; MAIN ;****************************** ldi temp1, 0b00110011 ;8*8 Dotmatrix rcall oled_send_data rcall oled_send_data rcall oled_send_data rcall oled_send_data rcall oled_send_data rcall oled_send_data rcall oled_send_data rcall oled_send_data end: rjmp end ;****************************** ; ROUTINEN ;****************************** oled_send_command: ;Not worked on this yet ret oled_send_data: push temp1 rcall oled_start ;Send Slave Addres ldi temp1, SLAVE_ADDRESS_W sts TWDR, temp1 ldi temp1, (1 << TWINT)|(1 << TWEN) sts TWCR, temp1 oled_send_data_0: lds temp1, TWCR sbrs temp1, TWINT rjmp oled_send_data_0 ;Send Control Byte ldi temp1, 0x40 sts TWDR, temp1 ldi temp1, (1 << TWINT)|(1 << TWEN) sts TWCR, temp1 oled_send_data_1: lds temp1, TWCR sbrs temp1, TWINT rjmp oled_send_data_1 ;Send Byte pop temp1 push temp1 sts TWDR, temp1 ldi temp1, (1 << TWINT)|(1 << TWEN) sts TWCR, temp1 oled_send_data_2: lds temp1, TWCR sbrs temp1, TWINT rjmp oled_send_data_2 rcall oled_stop pop temp1 ret oled_start: push temp1 ldi temp1, (1 << TWINT)|(1 << TWSTA)|(1 << TWEN) sts TWCR, temp1 oled_start_0: lds temp1, TWCR sbrs temp1, TWINT rjmp oled_start_0 ;Check Status Code lds temp1, TWSR andi temp1, 0x08 sbrs temp1, 3 rcall oled_error pop temp1 ret oled_stop: push temp1 ldi temp1, (1 << TWINT)|(1 << TWSTO)|(1 << TWEN) sts TWCR, temp1 oled_stop_0: lds temp1, TWCR sbrs temp1, TWINT rjmp oled_start_0 pop temp1 ret ;If an error occurs, toggle the LED oled_error: push temp1 ldi temp1, 0x01 out PORTD, temp1 pop temp1 ret
