Model:DS1054Z SN:DS1ZA201002922 Manufacturer:RIGOL TECHNOLOGIES Board Ver:0.1.4 Firmware Ver:0.2.3.11 BOOT Ver:0.0.1.4 CPLD Ver:1.1 SoftWare Ver:00.04.04.SP3 DSO Vertical System CH1:On Scale:2.000000V Position:2.000000V Coupling:DC Bandwidth Limit:20M Probe Ratio:10X Unit:V CH2:On Scale:2.000000V Position:-4.000000V Coupling:DC Bandwidth Limit:20M Probe Ratio:10X Unit:V CH3:Off Scale:1.000000V Position:0.000000V Coupling:DC Bandwidth Limit:OFF Probe Ratio:10X Unit:V CH4:Off Scale:1.000000V Position:0.000000V Coupling:DC Bandwidth Limit:OFF Probe Ratio:10X Unit:V DSO Horizontal System Delay:Off Time Mode:YT Time Scale:1.000000e-01s Delay Time Scale:5.000000e-07s Time Offset:2.000000e+00s Delay Time Offset:0.000000e+00s DSO Acquire System Acquire Mode:Normal Memory Depth:600000pts Average Num:2 Sampling Rate:500000Sa/s DSO Trigger System Trigger Mode:Edge Trigger Source:CH1 Trigger Edge Slope:Rising Trigger Sweep:Single Trigger Coupling:DC Trigger Noise Reject:Off Trigger HoldOff:1.600000e-08s CH1 Level:1.920000V CH2 Level:0.000000V CH3 Level:0.000000V CH4 Level:0.000000V Pulse Condition:Positive More Pulse High Time:0.000002s Pulse Low Time:0.000001s Slope Condition:Positive More Slope High Time:0.000002s Slope Low Time:0.000001s Slope Win:Win Up Slope Level1:4.000000V Slope Level2:0.000000V Video Polarity:Positive Video Sync:All Lines Video Standard:NTSC Video Line:1 Runt Polarity:Positive Runt Condition:Do not care Runt Win:Win Up Windows Type:Rising Windows Pos:Enter Window Time:0.000001s NCycle Edge:Rise NCycle Time:0.000001s NCycle Num:2 Pattern CH1:X Pattern CH2:X Pattern CH3:X Pattern CH4:X Delay A:CH1 Delay B:CH2 Delay A Slope:Rising Delay B Slope:Rising Delay Range:More Delay High:0.000002s Delay Low:0.000001s TimeOut Slope:Rising TimeOut:1.600000e-08s Duration Type:More Dura. High:0.000002s Dura. Low:0.000001s Setup/Hold Clk:CH2 Setup/Hold Data:CH1 Setup/Hold Slope:Rising Setup/Hold Patt.:H Setup/Hold Type:Setup Setup Time:0.000001s Hold Time:0.000001s RS232 Source:CH1 RS232 Type:Frame Start RS232 Stop Bit:1 RS232 Parity:None RS232 Data Bit:8 RS232 Baudrate:9600 RS232 Data:90 IIC Clock Source:CH1 IIC Data Source:CH2 IIC Type:Start IIC Address:1 IIC Direction:Read IIC Address Length:7 IIC Byte Length:1 IIC Data:82 SPI SCLK:CH1 SPI SDIO:CH2 SPI Mode:CS SPI CS Mode:Low SPI Edge:Rise SPI Timeout:0.000001s SPI Data Length:8 SPI Data:82 LA System D0~D7 Threshold Type:TTL D0~D7 Threshold Value:1.400000V D8~D15 Threshold Type:TTL D8~D15 Threshold Value:1.400000V D0~D7 Status:0000 0000 D8~D15 Stauts:0000 0000
