Version 4 SHEET 1 1100 1932 WIRE -816 864 -752 800 WIRE -816 864 -848 864 WIRE -720 864 -816 864 WIRE -576 864 -640 864 WIRE -496 864 -432 800 WIRE -496 864 -576 864 WIRE -400 864 -496 864 WIRE -352 864 -400 864 WIRE -224 864 -160 800 WIRE -224 864 -272 864 WIRE 0 864 -224 864 WIRE 144 864 0 864 WIRE 272 864 336 800 WIRE 272 864 240 864 WIRE 320 864 272 864 WIRE 464 864 400 864 WIRE 592 864 656 800 WIRE 592 864 464 864 WIRE 720 864 592 864 WIRE -224 912 -224 864 WIRE 0 912 0 864 WIRE 528 960 592 864 WIRE 528 960 384 960 WIRE -960 976 -992 976 WIRE -848 976 -848 864 WIRE -848 976 -896 976 WIRE -800 976 -848 976 WIRE -704 976 -736 976 WIRE 0 1040 0 992 WIRE 192 1040 192 928 WIRE 192 1040 0 1040 WIRE 384 1040 384 960 WIRE 384 1040 288 1040 WIRE -1136 1088 -1200 1088 WIRE -992 1088 -992 976 WIRE -992 1088 -1056 1088 WIRE -704 1088 -704 976 WIRE -640 1088 -704 1088 WIRE -224 1152 -224 992 WIRE -176 1152 -224 1152 WIRE -48 1152 -96 1152 WIRE 240 1152 240 1104 WIRE 240 1152 -48 1152 WIRE 464 1152 464 864 WIRE 592 1152 592 864 WIRE 720 1152 720 864 WIRE -1200 1168 -1200 1088 WIRE -576 1184 -576 864 WIRE -400 1184 -400 864 WIRE -992 1200 -992 1088 WIRE -960 1200 -992 1200 WIRE -848 1200 -896 1200 WIRE -800 1200 -848 1200 WIRE -704 1200 -704 1088 WIRE -704 1200 -736 1200 WIRE 240 1248 240 1152 WIRE -48 1264 -48 1152 WIRE -224 1280 -224 1152 WIRE -1200 1312 -1200 1248 WIRE -640 1312 -640 1088 WIRE -640 1312 -1200 1312 WIRE 128 1312 16 1312 WIRE 240 1360 240 1312 WIRE -1200 1440 -1200 1312 WIRE -848 1440 -848 1200 WIRE -576 1440 -576 1248 WIRE -576 1440 -848 1440 WIRE -400 1440 -400 1248 WIRE -400 1440 -576 1440 WIRE -224 1440 -224 1344 WIRE -224 1440 -400 1440 WIRE -48 1440 -48 1360 WIRE -48 1440 -224 1440 WIRE 0 1440 -48 1440 WIRE 128 1440 128 1312 WIRE 128 1440 80 1440 WIRE 240 1456 240 1424 WIRE 128 1488 128 1440 WIRE 240 1488 240 1456 WIRE 320 1488 240 1456 WIRE 464 1488 464 1232 WIRE 592 1488 592 1232 WIRE 720 1488 720 1232 WIRE -1200 1584 -1200 1520 WIRE 240 1632 240 1568 FLAG 656 800 OUT_B FLAG 464 1488 0 FLAG 240 1632 0 FLAG 128 1488 0 FLAG 720 1488 0 FLAG 592 1488 0 FLAG -752 800 DC_Bridge FLAG -1200 1584 0 FLAG -432 800 DC_Elko FLAG -160 800 DC_IN FLAG 336 800 DC_Out FLAG 320 1488 Test SYMBOL npn 192 1104 R270 SYMATTR InstName Q4 SYMATTR Value 2N3904 SYMBOL res 96 1424 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R8 SYMATTR Value .27_2W SYMBOL pnp 240 928 M270 SYMATTR InstName Q5 SYMATTR Value D45H11 SYMBOL res 448 1136 R0 SYMATTR InstName R9 SYMATTR Value 2.2k SYMBOL res -16 896 R0 SYMATTR InstName R10 SYMATTR Value 47 SYMBOL zener 256 1312 R180 WINDOW 0 -30 73 Left 2 WINDOW 3 -147 2 Left 2 SYMATTR InstName D7 SYMATTR Value BZX384B5V6 SYMATTR Description Diode SYMATTR Type diode SYMBOL npn 16 1264 M0 SYMATTR InstName Q6 SYMATTR Value BC547B SYMBOL res -240 896 R0 SYMATTR InstName R11 SYMATTR Value 180 SYMBOL res -192 1168 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R12 SYMATTR Value 180 SYMBOL res 704 1136 R0 SYMATTR InstName R_DC1 SYMATTR Value 200k_Ausgang SYMBOL polcap -592 1184 R0 SYMATTR InstName C4 SYMATTR Value 3300u_25V SYMATTR SpiceLine Rser=0.03 SYMBOL schottky 224 1360 R0 SYMATTR InstName D8 SYMATTR Value 1N5817 SYMATTR Description Diode SYMATTR Type diode SYMBOL voltage -1200 1152 R0 WINDOW 3 -15 -422 Left 2 WINDOW 123 0 0 Left 2 WINDOW 39 -14 -375 Left 2 SYMATTR Value SINE(0 {10.9*sqrt(2)} 50 0 0 0 30) SYMATTR SpiceLine Rser=.6 SYMATTR InstName V_AC SYMBOL polcap -416 1184 R0 SYMATTR InstName C5 SYMATTR Value 3300u_25V SYMATTR SpiceLine Rser=0.03 SYMBOL res 576 1136 R0 SYMATTR InstName R_Last SYMATTR Value 2.5 SYMBOL schottky -736 960 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName D9 SYMATTR Value MBR735 SYMATTR Description Diode SYMATTR Type diode SYMBOL schottky -800 1216 R270 WINDOW 0 32 32 VTop 2 WINDOW 3 0 32 VBottom 2 SYMATTR InstName D10 SYMATTR Value MBR735 SYMATTR Description Diode SYMATTR Type diode SYMBOL schottky -960 992 R270 WINDOW 0 32 32 VTop 2 WINDOW 3 0 32 VBottom 2 SYMATTR InstName D11 SYMATTR Value MBR735 SYMATTR Description Diode SYMATTR Type diode SYMBOL schottky -896 1184 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName D12 SYMATTR Value MBR735 SYMATTR Description Diode SYMATTR Type diode SYMBOL res -1216 1424 R0 SYMATTR InstName R14 SYMATTR Value 10Meg SYMBOL polcap -208 1280 M0 SYMATTR InstName C6 SYMATTR Value 100u_25V SYMATTR SpiceLine Rser=0.03 SYMBOL res -1152 1104 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R1 SYMATTR Value .03_Cu SYMBOL res -736 880 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R2 SYMATTR Value .03_Cu SYMBOL res -368 880 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R3 SYMATTR Value .03_Cu SYMBOL res 304 880 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R4 SYMATTR Value .1_Cu SYMBOL res 224 1472 R0 SYMATTR InstName R5 SYMATTR Value .03_Cu TEXT -992 1568 Left 4 !.Temp=27 TEXT -672 1568 Left 4 !.tran 1 TEXT -1000 1696 Left 2 !.model BZX384B5V6 D(Is=1.033E-15 N=1.001 BV=5.6 IBV=0.005 Rs=0.387 \n+ Cjo=1.961E-10 Vj=0.9187 M=0.423 Fc=0.5 Iave=250M Vpk=5.6 Mfg=NXP Type=ZENER) TEXT -824 1472 Left 3 ;Die Masse Cu-Verluse sind hier nicht enthalten. TEXT -1000 1656 Left 3 ;BZX384B5V6 ( SMD ) dient hier nur als Rechenmodel. TEXT -568 1152 Left 2 ;Rser .03 TEXT -384 1152 Left 2 ;Rser .03
