[EPS-Drillaid] @EPS Long = "Postscript with max hole size in pads/etc, ala drill-aid.ulp" Header3 = "%% redefine our /h function with a fixed diameter\n"\ "/h { %% draw a hole\n"\ " /d exch def\n %% Still need to pop diam off stack\n"\ " d 5000 gt {\n"\ " /d 5000 def\n %% But override it to 0.5mm\n"\ " } if\n"\ " /y exch def\n"\ " /x exch def\n"\ " d 0 gt {\n"\ " newpath\n"\ " x EU y EU d 2 div EU 0 360 arc\n"\ " currentgray dup\n"\ " 1 exch sub setgray\n"\ " fill\n"\ " setgray\n"\ " } if\n"\ " } def\n"\ "%% The drawing\n" [PS-Drillaid] @PS Long = "Postscript (printable) with max hold size ala Drill-aid.ulp" Header2 = "%% redefine our /h function with a fixed diameter\n"\ "/h { %% draw a hole\n"\ " /d exch def\n %% Still need to pop diam off stack\n"\ " d 5000 gt {\n"\ " /d 5000 def\n %% But override it to 0.5mm\n"\ " } if\n"\ " /y exch def\n"\ " /x exch def\n"\ " d 0 gt {\n"\ " newpath\n"\ " x EU y EU d 2 div EU 0 360 arc\n"\ " currentgray dup\n"\ " 1 exch sub setgray\n"\ " fill\n"\ " setgray\n"\ " } if\n"\ " } def\n"\ "%% Remainder of Header2 copied from define for PS device\n"\ "%% the real drawing size:\n"\ "\n"\ "/MinDrawX %6d EU def\n"\ "/MinDrawY %6d EU def\n"\ "/MaxDrawX %6d EU def\n"\ "/MaxDrawY %6d EU def\n"\ "\n"\ "%% the usable page size:\n"\ "\n"\ "/LeftMargin 0.25 inch def %% change these if drawing gets clipped!\n"\ "/BotMargin 0.25 inch def\n"\ "/PageWidth %7.4f inch def\n"\ "/PageHeight %7.4f inch def\n"\ "\n"\ "%% are we going to rotate?:\n"\ "\n"\ "/RotateDrawing %d 0 ne def\n"\ "\n" ;(x1, y1, x2, y2, Width, Height, DoRotate)
