(kicad_pcb (version 20171130) (host pcbnew 5.0.2+dfsg1-1~bpo9+1)
  (general
    (thickness 1.6)
    (drawings 6)
    (tracks 186)
    (zones 0)
    (modules 11)
    (nets 17)
  (page A4)
  (layers
    (0 F.Cu signal)
    (31 B.Cu signal hide)
    (32 B.Adhes user hide)
    (33 F.Adhes user hide)
    (34 B.Paste user hide)
    (35 F.Paste user hide)
    (36 B.SilkS user hide)
    (37 F.SilkS user)
    (38 B.Mask user hide)
    (39 F.Mask user hide)
    (40 Dwgs.User user hide)
    (41 Cmts.User user hide)
    (42 Eco1.User user)
    (43 Eco2.User user hide)
    (44 Edge.Cuts user hide)
    (45 Margin user hide)
    (46 B.CrtYd user hide)
    (47 F.CrtYd user hide)
    (48 B.Fab user hide)
    (49 F.Fab user hide)
  (setup
    (last_trace_width 0.25)
    (trace_clearance 0.2)
    (zone_clearance 0.508)
    (zone_45_only no)
    (trace_min 0.2)
    (segment_width 0.2)
    (edge_width 0.15)
    (via_size 0.8)
    (via_drill 0.4)
    (via_min_size 0.4)
    (via_min_drill 0.3)
    (uvia_size 0.3)
    (uvia_drill 0.1)
    (uvias_allowed no)
    (uvia_min_size 0.2)
    (uvia_min_drill 0.1)
    (pcb_text_width 0.3)
    (pcb_text_size 1.5 1.5)
    (mod_edge_width 0.15)
    (mod_text_size 1 1)
    (mod_text_width 0.15)
    (pad_size 1.524 1.524)
    (pad_drill 0.762)
    (pad_to_mask_clearance 0.051)
    (solder_mask_min_width 0.25)
    (aux_axis_origin 123.19 112.395)
    (grid_origin 120.65 114.3)
    (visible_elements FFFFFF7F)
    (pcbplotparams
      (layerselection 0x010fc_ffffffff)
      (usegerberextensions false)
      (usegerberattributes false)
      (usegerberadvancedattributes false)
      (creategerberjobfile false)
      (excludeedgelayer true)
      (linewidth 0.100000)
      (plotframeref false)
      (viasonmask false)
      (mode 1)
      (useauxorigin false)
      (hpglpennumber 1)
      (hpglpenspeed 20)
      (hpglpendiameter 15.000000)
      (psnegative false)
      (psa4output false)
      (plotreference true)
      (plotvalue true)
      (plotinvisibletext false)
      (padsonsilk false)
      (subtractmaskfromsilk false)
      (outputformat 1)
      (mirror false)
      (drillshape 1)
      (scaleselection 1)
      (outputdirectory ""))
  (net 0 "")
  (net 1 +3V3)
  (net 2 "Net-(D1-Pad2)")
  (net 3 "Net-(C1-Pad1)")
  (net 4 "Net-(JP2..5jtag1-Pad1)")
  (net 5 "Net-(JP2..5la1-Pad1)")
  (net 6 "Net-(JP2..5u1-Pad1)")
  (net 7 "Net-(JP2..5jtag1-Pad2)")
  (net 8 "Net-(JP2..5la1-Pad2)")
  (net 9 "Net-(JP2..5u1-Pad2)")
  (net 10 GND)
  (net 11 "Net-(JP2..5u1-Pad3)")
  (net 12 "Net-(JP2..5la1-Pad3)")
  (net 13 "Net-(JP2..5jtag1-Pad3)")
  (net 14 "Net-(JP2..5u1-Pad4)")
  (net 15 "Net-(JP2..5la1-Pad4)")
  (net 16 "Net-(JP2..5jtag1-Pad4)")
  (net_class Default "This is the default net class."
    (clearance 0.2)
    (trace_width 0.25)
    (via_dia 0.8)
    (via_drill 0.4)
    (uvia_dia 0.3)
    (uvia_drill 0.1)
    (add_net +3V3)
    (add_net GND)
    (add_net "Net-(C1-Pad1)")
    (add_net "Net-(D1-Pad2)")
    (add_net "Net-(JP2..5jtag1-Pad1)")
    (add_net "Net-(JP2..5jtag1-Pad2)")
    (add_net "Net-(JP2..5jtag1-Pad3)")
    (add_net "Net-(JP2..5jtag1-Pad4)")
    (add_net "Net-(JP2..5la1-Pad1)")
    (add_net "Net-(JP2..5la1-Pad2)")
    (add_net "Net-(JP2..5la1-Pad3)")
    (add_net "Net-(JP2..5la1-Pad4)")
    (add_net "Net-(JP2..5u1-Pad1)")
    (add_net "Net-(JP2..5u1-Pad2)")
    (add_net "Net-(JP2..5u1-Pad3)")
    (add_net "Net-(JP2..5u1-Pad4)")
  (module Capacitor_SMD:C_0603_1608Metric_Pad1.05x0.95mm_HandSolder (layer F.Cu) (tedit 5B301BBE) (tstamp 5C6C3637)
    (at 148.59 104.775 270)
    (descr "Capacitor SMD 0603 (1608 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: http://www.tortai-tech.com/upload/download/2011102023233369053.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path /5C603407)
    (attr smd)
    (fp_text reference C2 (at 0 -1.43 270) (layer F.SilkS)
      (effects (font (size 1 1) (thickness 0.15)))
    (fp_text value 100n (at 0 1.43 270) (layer F.Fab)
    (fp_line (start -0.8 0.4) (end -0.8 -0.4) (layer F.Fab) (width 0.1))
    (fp_line (start -0.8 -0.4) (end 0.8 -0.4) (layer F.Fab) (width 0.1))
    (fp_line (start 0.8 -0.4) (end 0.8 0.4) (layer F.Fab) (width 0.1))
    (fp_line (start 0.8 0.4) (end -0.8 0.4) (layer F.Fab) (width 0.1))
    (fp_line (start -0.171267 -0.51) (end 0.171267 -0.51) (layer F.SilkS) (width 0.12))
    (fp_line (start -0.171267 0.51) (end 0.171267 0.51) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.65 0.73) (end -1.65 -0.73) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.65 -0.73) (end 1.65 -0.73) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.65 -0.73) (end 1.65 0.73) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.65 0.73) (end -1.65 0.73) (layer F.CrtYd) (width 0.05))
    (fp_text user %R (at 0 0 270) (layer F.Fab)
      (effects (font (size 0.4 0.4) (thickness 0.06)))
    (pad 1 smd roundrect (at -0.875 0 270) (size 1.05 0.95) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
      (net 1 +3V3))
    (pad 2 smd roundrect (at 0.875 0 270) (size 1.05 0.95) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
      (net 10 GND))
    (model ${KISYS3DMOD}/Capacitor_SMD.3dshapes/C_0603_1608Metric.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (module Connector_PinHeader_2.54mm:PinHeader_1x04_P2.54mm_Vertical (layer F.Cu) (tedit 5C66F4A0) (tstamp 5C6C35DE)
    (at 128.27 104.14 90)
    (descr "Through hole straight pin header, 1x04, 2.54mm pitch, single row")
    (tags "Through hole pin header THT 1x04 2.54mm single row")
    (path /5C66AB31)
    (fp_text reference JP2..5la1 (at 0 -2.33 90) (layer F.SilkS) hide
    (fp_text value LA (at 0 9.95 180) (layer F.SilkS)
    (fp_text user %R (at 0 3.81 180) (layer F.Fab)
    (fp_line (start 1.8 -1.8) (end -1.8 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.8 9.4) (end 1.8 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.8 9.4) (end 1.8 9.4) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.8 -1.8) (end -1.8 9.4) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.33 -1.33) (end 0 -1.33) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 0) (end -1.33 -1.33) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 1.27) (end 1.33 1.27) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.33 1.27) (end 1.33 8.95) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 1.27) (end -1.33 8.95) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 8.95) (end 1.33 8.95) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.27 -0.635) (end -0.635 -1.27) (layer F.Fab) (width 0.1))
    (fp_line (start -1.27 8.89) (end -1.27 -0.635) (layer F.Fab) (width 0.1))
    (fp_line (start 1.27 8.89) (end -1.27 8.89) (layer F.Fab) (width 0.1))
    (fp_line (start 1.27 -1.27) (end 1.27 8.89) (layer F.Fab) (width 0.1))
    (fp_line (start -0.635 -1.27) (end 1.27 -1.27) (layer F.Fab) (width 0.1))
    (pad 4 thru_hole oval (at 0 7.62 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 15 "Net-(JP2..5la1-Pad4)"))
    (pad 3 thru_hole oval (at 0 5.08 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 12 "Net-(JP2..5la1-Pad3)"))
    (pad 2 thru_hole oval (at 0 2.54 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 8 "Net-(JP2..5la1-Pad2)"))
    (pad 1 thru_hole rect (at 0 0 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 5 "Net-(JP2..5la1-Pad1)"))
    (model ${KISYS3DMOD}/Connector_PinHeader_2.54mm.3dshapes/PinHeader_1x04_P2.54mm_Vertical.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Connector_PinHeader_2.54mm:PinHeader_1x04_P2.54mm_Vertical (layer F.Cu) (tedit 5C66F485) (tstamp 5C6C35C6)
    (at 128.27 109.22 90)
    (path /5C66AA76)
    (fp_text reference JP2..5jtag1 (at 0 -2.33 90) (layer F.SilkS) hide
    (fp_text value JTAG (at 0 10.795 180) (layer F.SilkS)
      (net 4 "Net-(JP2..5jtag1-Pad1)"))
      (net 7 "Net-(JP2..5jtag1-Pad2)"))
      (net 13 "Net-(JP2..5jtag1-Pad3)"))
      (net 16 "Net-(JP2..5jtag1-Pad4)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_THT:LED_D3.0mm_Horizontal_O1.27mm_Z2.0mm (layer F.Cu) (tedit 5880A862) (tstamp 5C6C3584)
    (at 150.495 112.395 90)
    (descr "LED, diameter 3.0mm z-position of LED center 2.0mm, 2 pins")
    (tags "LED diameter 3.0mm z-position of LED center 2.0mm 2 pins")
    (path /5C6035E1)
    (fp_text reference D1 (at 1.27 -1.96 90) (layer F.SilkS)
    (fp_text value red (at 1.27 7.63 90) (layer F.Fab)
    (fp_arc (start 1.27 5.07) (end -0.23 5.07) (angle -180) (layer F.Fab) (width 0.1))
    (fp_arc (start 1.27 5.07) (end -0.29 5.07) (angle -180) (layer F.SilkS) (width 0.12))
    (fp_line (start -0.23 1.27) (end -0.23 5.07) (layer F.Fab) (width 0.1))
    (fp_line (start 2.77 1.27) (end 2.77 5.07) (layer F.Fab) (width 0.1))
    (fp_line (start -0.23 1.27) (end 2.77 1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 3.17 1.27) (end 3.17 2.27) (layer F.Fab) (width 0.1))
    (fp_line (start 3.17 2.27) (end 2.77 2.27) (layer F.Fab) (width 0.1))
    (fp_line (start 2.77 2.27) (end 2.77 1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 2.77 1.27) (end 3.17 1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 0 0) (end 0 1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 0 1.27) (end 0 1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 0 1.27) (end 0 0) (layer F.Fab) (width 0.1))
    (fp_line (start 0 0) (end 0 0) (layer F.Fab) (width 0.1))
    (fp_line (start 2.54 0) (end 2.54 1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 2.54 1.27) (end 2.54 1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 2.54 1.27) (end 2.54 0) (layer F.Fab) (width 0.1))
    (fp_line (start 2.54 0) (end 2.54 0) (layer F.Fab) (width 0.1))
    (fp_line (start -0.29 1.21) (end -0.29 5.07) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.83 1.21) (end 2.83 5.07) (layer F.SilkS) (width 0.12))
    (fp_line (start -0.29 1.21) (end 2.83 1.21) (layer F.SilkS) (width 0.12))
    (fp_line (start 3.23 1.21) (end 3.23 2.33) (layer F.SilkS) (width 0.12))
    (fp_line (start 3.23 2.33) (end 2.83 2.33) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.83 2.33) (end 2.83 1.21) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.83 1.21) (end 3.23 1.21) (layer F.SilkS) (width 0.12))
    (fp_line (start 0 1.08) (end 0 1.21) (layer F.SilkS) (width 0.12))
    (fp_line (start 0 1.21) (end 0 1.21) (layer F.SilkS) (width 0.12))
    (fp_line (start 0 1.21) (end 0 1.08) (layer F.SilkS) (width 0.12))
    (fp_line (start 0 1.08) (end 0 1.08) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.54 1.08) (end 2.54 1.21) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.54 1.21) (end 2.54 1.21) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.54 1.21) (end 2.54 1.08) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.54 1.08) (end 2.54 1.08) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.25 -1.25) (end -1.25 6.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.25 6.9) (end 3.75 6.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.75 6.9) (end 3.75 -1.25) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.75 -1.25) (end -1.25 -1.25) (layer F.CrtYd) (width 0.05))
    (pad 1 thru_hole rect (at 0 0 90) (size 1.8 1.8) (drill 0.9) (layers *.Cu *.Mask)
      (net 3 "Net-(C1-Pad1)"))
    (pad 2 thru_hole circle (at 2.54 0 90) (size 1.8 1.8) (drill 0.9) (layers *.Cu *.Mask)
      (net 2 "Net-(D1-Pad2)"))
    (model ${KISYS3DMOD}/LED_THT.3dshapes/LED_D3.0mm_Horizontal_O1.27mm_Z2.0mm.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric_Pad1.05x0.95mm_HandSolder (layer F.Cu) (tedit 5B301BBD) (tstamp 5C6C350D)
    (at 146.685 112.395 180)
    (descr "Resistor SMD 0603 (1608 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: http://www.tortai-tech.com/upload/download/2011102023233369053.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path /5C60346B)
    (attr smd)
    (fp_text reference C1 (at 0 -1.43 180) (layer F.SilkS)
    (fp_text value 100n (at 0 1.43 180) (layer F.Fab)
    (fp_text user %R (at 0 0 180) (layer F.Fab)
    (pad 1 smd roundrect (at -0.875 0 180) (size 1.05 0.95) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
    (pad 2 smd roundrect (at 0.875 0 180) (size 1.05 0.95) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
      (net 10 GND))
    (model ${KISYS3DMOD}/Resistor_SMD.3dshapes/R_0603_1608Metric.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_1206_3216Metric_Pad1.42x1.75mm_HandSolder (layer F.Cu) (tedit 5B301BBD) (tstamp 5C6BF881)
    (at 128.27 112.395)
    (descr "Resistor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: http://www.tortai-tech.com/upload/download/2011102023233369053.pdf), generated with kicad-footprint-generator")
    (path /5C6034C1)
    (attr smd)
    (fp_text reference R2 (at -3.81 0.635) (layer F.SilkS)
    (fp_text value 10k (at 0 1.82) (layer F.Fab)
    (fp_text user %R (at 0 0) (layer F.Fab)
      (effects (font (size 0.8 0.8) (thickness 0.12)))
    (fp_line (start 2.45 1.12) (end -2.45 1.12) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.45 -1.12) (end 2.45 1.12) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.45 -1.12) (end 2.45 -1.12) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.45 1.12) (end -2.45 -1.12) (layer F.CrtYd) (width 0.05))
    (fp_line (start -0.602064 0.91) (end 0.602064 0.91) (layer F.SilkS) (width 0.12))
    (fp_line (start -0.602064 -0.91) (end 0.602064 -0.91) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer F.Fab) (width 0.1))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer F.Fab) (width 0.1))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer F.Fab) (width 0.1))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer F.Fab) (width 0.1))
    (pad 2 smd roundrect (at 1.4875 0) (size 1.425 1.75) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.175439)
    (pad 1 smd roundrect (at -1.4875 0) (size 1.425 1.75) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.175439)
      (net 1 +3V3))
    (model ${KISYS3DMOD}/Resistor_SMD.3dshapes/R_1206_3216Metric.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Connector_PinSocket_2.54mm:PinSocket_1x02_P2.54mm_Vertical (layer F.Cu) (tedit 5C66D1BA) (tstamp 5C6B14CF)
    (at 154.94 106.68 180)
    (descr "Through hole straight socket strip, 1x02, 2.54mm pitch, single row (from Kicad 4.0.7), script generated")
    (tags "Through hole socket strip THT 1x02 2.54mm single row")
    (path /5C669C2A)
    (fp_text reference Trigger1 (at 0 -2.77 180) (layer F.SilkS) hide
    (fp_text value "Pin 7+8" (at 0 5.31 180) (layer F.Fab)
    (fp_line (start -1.27 -1.27) (end 0.635 -1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 0.635 -1.27) (end 1.27 -0.635) (layer F.Fab) (width 0.1))
    (fp_line (start 1.27 -0.635) (end 1.27 3.81) (layer F.Fab) (width 0.1))
    (fp_line (start 1.27 3.81) (end -1.27 3.81) (layer F.Fab) (width 0.1))
    (fp_line (start -1.27 3.81) (end -1.27 -1.27) (layer F.Fab) (width 0.1))
    (fp_line (start -1.33 1.27) (end -1.33 3.87) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 3.87) (end 1.33 3.87) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.33 1.27) (end 1.33 3.87) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.33 -1.33) (end 1.33 0) (layer F.SilkS) (width 0.12))
    (fp_line (start 0 -1.33) (end 1.33 -1.33) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.8 -1.8) (end 1.75 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.75 -1.8) (end 1.75 4.3) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.75 4.3) (end -1.8 4.3) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.8 4.3) (end -1.8 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_text user %R (at 0 1.27 270) (layer F.Fab)
    (pad 1 thru_hole rect (at 0 0 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
    (pad 2 thru_hole oval (at 0 2.54 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 10 GND))
    (model ${KISYS3DMOD}/Connector_PinSocket_2.54mm.3dshapes/PinSocket_1x02_P2.54mm_Vertical.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_1206_3216Metric_Pad1.42x1.75mm_HandSolder (layer F.Cu) (tedit 5B301BBD) (tstamp 5C6BF871)
    (at 151.765 104.775 270)
    (path /5C603521)
    (attr smd)
    (fp_text reference R1 (at 3.175 -0.635 270) (layer F.SilkS)
    (fp_text value 390R (at 0 1.82 270) (layer F.Fab)
    (pad 1 smd roundrect (at -1.4875 0 270) (size 1.425 1.75) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.175439)
      (net 1 +3V3))
    (pad 2 smd roundrect (at 1.4875 0 270) (size 1.425 1.75) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.175439)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Package_SO:TSSOP-16_4.4x5mm_P0.65mm (layer F.Cu) (tedit 5A02F25C) (tstamp 5C6B148F)
    (at 143.51 106.68 90)
    (descr "16-Lead Plastic Thin Shrink Small Outline (ST)-4.4 mm Body [TSSOP] (see Microchip Packaging Specification 00000049BS.pdf)")
    (tags "SSOP 0.65")
    (path /5C6054CA)
    (attr smd)
    (fp_text reference U1 (at 0 -3.55 90) (layer F.SilkS)
    (fp_text value 74CBTLV3257 (at 0 3.55 90) (layer F.Fab)
    (fp_line (start -1.2 -2.5) (end 2.2 -2.5) (layer F.Fab) (width 0.15))
    (fp_line (start 2.2 -2.5) (end 2.2 2.5) (layer F.Fab) (width 0.15))
    (fp_line (start 2.2 2.5) (end -2.2 2.5) (layer F.Fab) (width 0.15))
    (fp_line (start -2.2 2.5) (end -2.2 -1.5) (layer F.Fab) (width 0.15))
    (fp_line (start -2.2 -1.5) (end -1.2 -2.5) (layer F.Fab) (width 0.15))
    (fp_line (start -3.95 -2.9) (end -3.95 2.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.95 -2.9) (end 3.95 2.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.95 -2.9) (end 3.95 -2.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.95 2.8) (end 3.95 2.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.2 2.725) (end 2.2 2.725) (layer F.SilkS) (width 0.15))
    (fp_line (start -3.775 -2.8) (end 2.2 -2.8) (layer F.SilkS) (width 0.15))
    (fp_text user %R (at 0 0 90) (layer F.Fab)
      (effects (font (size 0.8 0.8) (thickness 0.15)))
    (pad 1 smd rect (at -2.95 -2.275 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 2 smd rect (at -2.95 -1.625 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 3 smd rect (at -2.95 -0.975 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 4 smd rect (at -2.95 -0.325 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
      (net 6 "Net-(JP2..5u1-Pad1)"))
    (pad 5 smd rect (at -2.95 0.325 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 6 smd rect (at -2.95 0.975 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 7 smd rect (at -2.95 1.625 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
      (net 9 "Net-(JP2..5u1-Pad2)"))
    (pad 8 smd rect (at -2.95 2.275 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
      (net 10 GND))
    (pad 9 smd rect (at 2.95 2.275 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
      (net 11 "Net-(JP2..5u1-Pad3)"))
    (pad 10 smd rect (at 2.95 1.625 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 11 smd rect (at 2.95 0.975 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 12 smd rect (at 2.95 0.325 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
      (net 14 "Net-(JP2..5u1-Pad4)"))
    (pad 13 smd rect (at 2.95 -0.325 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 14 smd rect (at 2.95 -0.975 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
    (pad 15 smd rect (at 2.95 -1.625 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
      (net 10 GND))
    (pad 16 smd rect (at 2.95 -2.275 90) (size 1.5 0.45) (layers F.Cu F.Paste F.Mask)
      (net 1 +3V3))
    (model ${KISYS3DMOD}/Package_SO.3dshapes/TSSOP-16_4.4x5mm_P0.65mm.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Connector_PinHeader_2.54mm:PinHeader_1x02_P2.54mm_Vertical (layer F.Cu) (tedit 59FED5CC) (tstamp 5C6B152D)
    (at 123.19 109.22 90)
    (descr "Through hole straight pin header, 1x02, 2.54mm pitch, single row")
    (tags "Through hole pin header THT 1x02 2.54mm single row")
    (path /5C66C041)
    (fp_text reference JP1 (at 2.54 1.27) (layer F.SilkS)
    (fp_text value Power (at 0 4.87 90) (layer F.Fab)
    (fp_line (start 1.27 -1.27) (end 1.27 3.81) (layer F.Fab) (width 0.1))
    (fp_line (start -1.27 3.81) (end -1.27 -0.635) (layer F.Fab) (width 0.1))
    (fp_line (start -1.8 -1.8) (end -1.8 4.35) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.8 4.35) (end 1.8 4.35) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.8 4.35) (end 1.8 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_text user %R (at -2.54 2.164999 270) (layer F.Fab)
      (net 1 +3V3))
      (net 10 GND))
    (model ${KISYS3DMOD}/Connector_PinHeader_2.54mm.3dshapes/PinHeader_1x02_P2.54mm_Vertical.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Connector_PinHeader_2.54mm:PinHeader_1x04_P2.54mm_Vertical (layer F.Cu) (tedit 5C66F418) (tstamp 5C6B1517)
    (at 128.27 106.68 90)
    (path /5C66AB9B)
    (fp_text reference JP2..5u1 (at 3.81 -5.715 90) (layer F.SilkS) hide
    (fp_text value Center (at 0 9.95 90) (layer F.Fab)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (gr_text Bottom (at 123.19 104.775) (layer B.Cu)
    (effects (font (size 1 0.7) (thickness 0.175)) (justify mirror))
  (gr_text Top (at 122.555 104.775) (layer F.Cu)
    (effects (font (size 1 0.7) (thickness 0.175)))
  (gr_line (start 121.285 101.6) (end 157.48 101.6) (layer Edge.Cuts) (width 0.15))
  (gr_line (start 121.285 114.3) (end 121.285 101.6) (layer Edge.Cuts) (width 0.15))
  (gr_line (start 157.48 114.3) (end 121.285 114.3) (layer Edge.Cuts) (width 0.15))
  (gr_line (start 157.48 101.6) (end 157.48 114.3) (layer Edge.Cuts) (width 0.15))
  (segment (start 125.97 112.395) (end 126.7825 112.395) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 125.265 112.395) (end 125.97 112.395) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 123.19 110.32) (end 125.265 112.395) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 123.19 109.22) (end 123.19 110.32) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 148.59 103.2875) (end 151.765 103.2875) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 147.818653 102.516153) (end 148.59 103.2875) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 147.507489 102.204989) (end 147.818653 102.516153) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 141.760011 102.204989) (end 147.507489 102.204989) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 141.235 102.73) (end 141.235 103.73) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 140.74 102.235) (end 141.235 102.73) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 123.19 109.22) (end 123.19 108.12) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 125.73 102.235) (end 140.74 102.235) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 123.19 108.12) (end 125.73 105.58) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 125.73 105.58) (end 125.73 102.235) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 141.235 102.73) (end 141.760011 102.204989) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 151.3475 110.2725) (end 151.13 110.49) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 151.13 106.8975) (end 151.765 106.2625) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 151.765 108.585) (end 151.765 106.2625) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 150.495 109.855) (end 151.765 108.585) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 141.235 109.63) (end 141.195 109.63) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 141.195 109.63) (end 140.56 109.63) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 141.235 109.63) (end 140.56 109.63) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 140.56 109.63) (end 141.060001 109.764999) (width 0.25) (layer F.Cu) (net 3) (tstamp 5C6C00D6))
  (via (at 140.56 109.63) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (via (at 147.955 109.855) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 147.955 112.1775) (end 148.1725 112.395) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 147.955 109.855) (end 147.955 112.1775) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 131.445 112.395) (end 131.445 112.395) (width 0.25) (layer B.Cu) (net 3) (tstamp 5C6C0888))
  (via (at 131.445 112.395) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 131.445 112.395) (end 129.7575 112.395) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 147.555001 110.254999) (end 147.955 109.855) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 145.324999 112.485001) (end 147.555001 110.254999) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 141.891999 112.485001) (end 145.324999 112.485001) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 148.1725 112.395) (end 150.495 112.395) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 154.94 107.78) (end 154.94 106.68) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 154.94 109.1) (end 154.94 107.78) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 151.645 112.395) (end 154.94 109.1) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 150.495 112.395) (end 151.645 112.395) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 131.445 112.395) (end 139.318002 112.395) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 139.318002 110.871998) (end 140.56 109.63) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 139.318002 112.395) (end 139.318002 110.871998) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 140.56 111.153002) (end 141.891999 112.485001) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 140.56 109.63) (end 140.56 111.153002) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 141.720001 110.705001) (end 141.785001 110.640001) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 128.27 110.020998) (end 130.245999 108.044999) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 128.27 109.22) (end 128.27 110.020998) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 131.374001 108.044999) (end 130.245999 108.044999) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 131.985001 108.655999) (end 131.374001 108.044999) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 130.245999 108.044999) (end 129.634999 108.655999) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 131.985001 109.758591) (end 131.985001 108.655999) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 132.931411 110.705001) (end 131.985001 109.758591) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 141.885 110.63) (end 141.885 109.63) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 141.809999 110.705001) (end 141.885 110.63) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 141.720001 110.705001) (end 141.809999 110.705001) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 132.931411 110.705001) (end 141.720001 110.705001) (width 0.25) (layer F.Cu) (net 4))
  (via (at 142.24 111.76) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 5))
  (segment (start 142.535 111.465) (end 142.24 111.76) (width 0.25) (layer F.Cu) (net 5))
  (segment (start 142.535 109.63) (end 142.535 111.465) (width 0.25) (layer F.Cu) (net 5))
  (segment (start 128.27 103.04) (end 128.27 104.14) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 128.89001 102.41999) (end 128.27 103.04) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 148.40501 102.6836) (end 148.1414 102.41999) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 148.40501 105.59499) (end 148.40501 102.6836) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 142.24 111.76) (end 148.40501 105.59499) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 148.1414 102.41999) (end 128.89001 102.41999) (width 0.25) (layer B.Cu) (net 5))
  (via (at 135.345001 111.669999) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 6) (tstamp 5C6C00B0))
  (via (at 135.345001 111.669999) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 6))
  (segment (start 128.345001 107.855001) (end 128.27 107.78) (width 0.25) (layer B.Cu) (net 6))
  (segment (start 131.348591 107.855001) (end 128.345001 107.855001) (width 0.25) (layer B.Cu) (net 6))
  (segment (start 131.985001 108.491411) (end 131.348591 107.855001) (width 0.25) (layer B.Cu) (net 6))
  (segment (start 131.985001 109.760001) (end 131.985001 108.491411) (width 0.25) (layer B.Cu) (net 6))
  (segment (start 128.27 107.78) (end 128.27 106.68) (width 0.25) (layer B.Cu) (net 6))
  (segment (start 133.894999 111.669999) (end 131.985001 109.760001) (width 0.25) (layer B.Cu) (net 6))
  (segment (start 135.345001 111.669999) (end 133.894999 111.669999) (width 0.25) (layer B.Cu) (net 6))
  (segment (start 143.185 111.888002) (end 143.185 110.63) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 142.588001 112.485001) (end 143.185 111.888002) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 143.185 110.63) (end 143.185 109.63) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 135.345001 111.669999) (end 136.160003 112.485001) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 136.160003 112.485001) (end 142.588001 112.485001) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 143.835 110.63) (end 143.835 109.63) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 143.835 111.874412) (end 143.835 110.63) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 142.774402 112.93501) (end 143.835 111.874412) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 130.81 109.22) (end 134.52501 112.93501) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 134.52501 112.93501) (end 142.774402 112.93501) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 144.485 109.63) (end 144.485 108.29) (width 0.25) (layer F.Cu) (net 8))
  (segment (start 144.485 108.29) (end 144.485 108.29) (width 0.25) (layer F.Cu) (net 8) (tstamp 5C6C0070))
  (via (at 144.485 108.29) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 8))
  (segment (start 144.485 108.29) (end 147.955 104.82) (width 0.25) (layer B.Cu) (net 8))
  (segment (start 147.955 104.82) (end 147.955 102.87) (width 0.25) (layer B.Cu) (net 8))
  (segment (start 132.08 102.87) (end 130.81 104.14) (width 0.25) (layer B.Cu) (net 8))
  (segment (start 132.08 102.87) (end 147.955 102.87) (width 0.25) (layer B.Cu) (net 8))
  (via (at 138.43 107.95) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 9))
  (segment (start 132.08 107.95) (end 130.81 106.68) (width 0.25) (layer B.Cu) (net 9))
  (segment (start 145.135 108.63) (end 145.135 109.63) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 145.210001 108.554999) (end 145.135 108.63) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 144.818003 107.550001) (end 145.210001 107.941999) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 145.210001 107.941999) (end 145.210001 108.554999) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 138.43 107.95) (end 138.829999 107.550001) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 136.359002 107.95) (end 138.43 107.95) (width 0.25) (layer B.Cu) (net 9))
  (segment (start 132.08 107.95) (end 136.359002 107.95) (width 0.25) (layer B.Cu) (net 9))
  (segment (start 138.829999 107.550001) (end 144.818003 107.550001) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 145.785 111.8075) (end 145.1975 112.395) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 145.785 109.63) (end 145.785 111.8075) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 141.885 103.73) (end 141.885 102.73) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 141.960001 102.654999) (end 141.885 102.73) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 146.270001 102.654999) (end 141.960001 102.654999) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 148.59 106.3) (end 148.59 106.2625) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 145.785 109.105) (end 148.59 106.3) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 145.785 109.63) (end 145.785 109.105) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 146.335001 102.719999) (end 146.270001 102.654999) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 148.59 105.45) (end 146.335001 103.195001) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 146.335001 103.195001) (end 146.335001 102.719999) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 148.59 106.2625) (end 148.59 105.45) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 125.73 109.22) (end 127.635 111.125) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 144.426153 113.166347) (end 145.1975 112.395) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 144.207481 113.385019) (end 144.426153 113.166347) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 131.248002 111.125) (end 133.508021 113.385019) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 127.635 111.125) (end 131.248002 111.125) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 154.090001 104.989999) (end 154.94 104.14) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 153.85501 105.22499) (end 154.090001 104.989999) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 149.62751 105.22499) (end 153.85501 105.22499) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 148.59 106.2625) (end 149.62751 105.22499) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 133.508021 113.385019) (end 144.207481 113.385019) (width 0.25) (layer F.Cu) (net 10))
  (via (at 122.555 102.87) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 124.46 102.87) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 122.555 107.315) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 122.555 111.125) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 122.555 113.03) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 124.46 113.03) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 153.035 113.03) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 156.21 113.03) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 156.21 109.22) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 153.035 108.585) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 148.59 107.95) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 125.73 107.315) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (via (at 150.495 107.95) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 10))
  (segment (start 145.785 104.255) (end 145.785 103.73) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 146.26 104.73) (end 145.785 104.255) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 146.26 105.358002) (end 146.26 104.73) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 144.753011 106.864991) (end 146.26 105.358002) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 133.35 106.68) (end 134.525001 107.855001) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 134.525001 107.855001) (end 137.451997 107.855001) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 137.451997 107.855001) (end 138.442007 106.864991) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 138.442007 106.864991) (end 144.753011 106.864991) (width 0.25) (layer F.Cu) (net 11))
  (via (at 138.43 104.14) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 12))
  (via (at 145.135 105.41) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 12))
  (segment (start 133.35 104.14) (end 134.62 102.87) (width 0.25) (layer F.Cu) (net 12))
  (segment (start 145.135 103.73) (end 145.135 105.41) (width 0.25) (layer F.Cu) (net 12))
  (segment (start 137.16 102.87) (end 138.43 104.14) (width 0.25) (layer F.Cu) (net 12))
  (segment (start 134.62 102.87) (end 137.16 102.87) (width 0.25) (layer F.Cu) (net 12))
  (segment (start 144.735001 105.010001) (end 145.135 105.41) (width 0.25) (layer B.Cu) (net 12))
  (segment (start 143.465001 103.740001) (end 144.735001 105.010001) (width 0.25) (layer B.Cu) (net 12))
  (segment (start 138.43 104.14) (end 138.829999 103.740001) (width 0.25) (layer B.Cu) (net 12))
  (segment (start 138.829999 103.740001) (end 143.465001 103.740001) (width 0.25) (layer B.Cu) (net 12))
  (via (at 144.145 106.045) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 13))
  (segment (start 144.145 105.479315) (end 144.145 106.045) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 144.145 105.326998) (end 144.145 105.479315) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 144.485 104.986998) (end 144.145 105.326998) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 144.485 103.73) (end 144.485 104.986998) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 133.35 109.22) (end 134.62 110.49) (width 0.25) (layer B.Cu) (net 13))
  (segment (start 143.579315 106.045) (end 144.145 106.045) (width 0.25) (layer B.Cu) (net 13))
  (segment (start 143.071998 106.045) (end 143.579315 106.045) (width 0.25) (layer B.Cu) (net 13))
  (segment (start 138.626998 110.49) (end 143.071998 106.045) (width 0.25) (layer B.Cu) (net 13))
  (segment (start 134.62 110.49) (end 138.626998 110.49) (width 0.25) (layer B.Cu) (net 13))
  (segment (start 143.835 103.815) (end 143.835 103.73) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 135.89 106.68) (end 137.092081 106.68) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 137.092081 106.68) (end 137.542091 106.22999) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 143.735001 103.914999) (end 143.835 103.815) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 142.33501 106.22999) (end 143.835 104.73) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 143.835 104.73) (end 143.835 103.73) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 137.542091 106.22999) (end 142.33501 106.22999) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 136.739999 104.989999) (end 135.89 104.14) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 143.185 104.73) (end 142.925001 104.989999) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 143.185 104.73) (end 143.185 103.73) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 142.414999 105.500001) (end 143.185 104.73) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 137.250001 105.500001) (end 142.414999 105.500001) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 135.89 104.14) (end 137.250001 105.500001) (width 0.25) (layer F.Cu) (net 15))
  (via (at 139.7 104.775) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 16))
  (segment (start 137.092081 109.22) (end 135.89 109.22) (width 0.25) (layer B.Cu) (net 16))
  (segment (start 138.233002 109.22) (end 137.092081 109.22) (width 0.25) (layer B.Cu) (net 16))
  (segment (start 139.7 107.753002) (end 138.233002 109.22) (width 0.25) (layer B.Cu) (net 16))
  (segment (start 139.7 104.775) (end 139.7 107.753002) (width 0.25) (layer B.Cu) (net 16))
  (segment (start 140.295686 104.805001) (end 140.265685 104.775) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 140.265685 104.775) (end 139.7 104.775) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 142.370001 104.805001) (end 140.295686 104.805001) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 142.535 104.640002) (end 142.370001 104.805001) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 142.535 103.73) (end 142.535 104.640002) (width 0.25) (layer F.Cu) (net 16))
  (zone (net 10) (net_name GND) (layer F.Cu) (tstamp 5C6C1E18) (hatch edge 0.508)
    (connect_pads (clearance 0.508))
    (min_thickness 0.254)
    (fill yes (arc_segments 16) (thermal_gap 0.508) (thermal_bridge_width 0.508))
    (polygon
      (pts
        (xy 121.285 101.6) (xy 157.48 101.6) (xy 157.48 114.3) (xy 121.285 114.3)
    (filled_polygon
      (pts
        (xy 156.770001 113.59) (xy 151.961595 113.59) (xy 151.993157 113.542765) (xy 152.04244 113.295) (xy 152.04244 113.043483)
        (xy 152.192929 112.942929) (xy 152.235331 112.87947) (xy 155.424473 109.690329) (xy 155.487929 109.647929) (xy 155.562366 109.536526)
        (xy 155.655904 109.396538) (xy 155.6737 109.307071) (xy 155.7 109.174852) (xy 155.7 109.174848) (xy 155.714888 109.1)
        (xy 155.7 109.025152) (xy 155.7 108.17744) (xy 155.79 108.17744) (xy 156.037765 108.128157) (xy 156.247809 107.987809)
        (xy 156.388157 107.777765) (xy 156.43744 107.53) (xy 156.43744 105.83) (xy 156.388157 105.582235) (xy 156.247809 105.372191)
        (xy 156.037765 105.231843) (xy 155.934292 105.211261) (xy 156.211645 104.906924) (xy 156.381476 104.49689) (xy 156.260155 104.267)
        (xy 155.067 104.267) (xy 155.067 104.287) (xy 154.813 104.287) (xy 154.813 104.267) (xy 153.619845 104.267)
        (xy 153.498524 104.49689) (xy 153.668355 104.906924) (xy 153.945708 105.211261) (xy 153.842235 105.231843) (xy 153.632191 105.372191)
        (xy 153.491843 105.582235) (xy 153.44256 105.83) (xy 153.44256 107.53) (xy 153.491843 107.777765) (xy 153.632191 107.987809)
        (xy 153.842235 108.128157) (xy 154.09 108.17744) (xy 154.180001 108.17744) (xy 154.18 108.785198) (xy 151.88293 111.082269)
        (xy 151.852809 111.037191) (xy 151.735796 110.959005) (xy 151.937829 110.756973) (xy 152.063403 110.569037) (xy 152.122388 110.272501)
        (xy 152.063403 109.975964) (xy 152.03 109.925973) (xy 152.03 109.54967) (xy 151.98464 109.440162) (xy 152.249473 109.175329)
        (xy 152.312929 109.132929) (xy 152.480904 108.881537) (xy 152.525 108.659852) (xy 152.525 108.659848) (xy 152.539888 108.585001)
        (xy 152.525 108.510154) (xy 152.525 107.595587) (xy 152.733435 107.554126) (xy 153.024586 107.359586) (xy 153.219126 107.068435)
        (xy 153.28744 106.725) (xy 153.28744 105.8) (xy 153.219126 105.456565) (xy 153.024586 105.165414) (xy 152.733435 104.970874)
        (xy 152.39 104.90256) (xy 151.14 104.90256) (xy 150.796565 104.970874) (xy 150.505414 105.165414) (xy 150.310874 105.456565)
        (xy 150.24256 105.8) (xy 150.24256 106.725) (xy 150.310874 107.068435) (xy 150.505414 107.359586) (xy 150.540278 107.382881)
        (xy 150.582071 107.445429) (xy 150.833463 107.613403) (xy 151.005 107.647524) (xy 151.005 108.270198) (xy 150.909838 108.36536)
        (xy 150.80033 108.32) (xy 150.18967 108.32) (xy 149.625493 108.55369) (xy 149.19369 108.985493) (xy 148.96 109.54967)
        (xy 148.96 109.576699) (xy 148.832431 109.26872) (xy 148.54128 108.977569) (xy 148.160874 108.82) (xy 147.749126 108.82)
        (xy 147.36872 108.977569) (xy 147.077569 109.26872) (xy 146.92 109.649126) (xy 146.92 110.060874) (xy 147.077569 110.44128)
        (xy 147.195 110.558711) (xy 147.195001 111.287976) (xy 146.933848 111.339922) (xy 146.76546 111.452435) (xy 146.694698 111.381673)
        (xy 146.461309 111.285) (xy 146.09575 111.285) (xy 145.937 111.44375) (xy 145.937 112.268) (xy 145.957 112.268)
        (xy 145.957 112.522) (xy 145.937 112.522) (xy 145.937 113.34625) (xy 146.09575 113.505) (xy 146.461309 113.505)
        (xy 146.694698 113.408327) (xy 146.76546 113.337565) (xy 146.933848 113.450078) (xy 147.2725 113.51744) (xy 147.8475 113.51744)
        (xy 148.186152 113.450078) (xy 148.473247 113.258247) (xy 148.542235 113.155) (xy 148.94756 113.155) (xy 148.94756 113.295)
        (xy 148.996843 113.542765) (xy 149.028405 113.59) (xy 143.162103 113.59) (xy 143.322331 113.482939) (xy 143.364733 113.41948)
        (xy 144.103463 112.68075) (xy 144.65 112.68075) (xy 144.65 112.99631) (xy 144.746673 113.229699) (xy 144.925302 113.408327)
        (xy 145.158691 113.505) (xy 145.52425 113.505) (xy 145.683 113.34625) (xy 145.683 112.522) (xy 144.80875 112.522)
        (xy 144.65 112.68075) (xy 144.103463 112.68075) (xy 144.319473 112.464741) (xy 144.382929 112.422341) (xy 144.550904 112.170949)
        (xy 144.595 111.949264) (xy 144.595 111.94926) (xy 144.609888 111.874413) (xy 144.595 111.799566) (xy 144.595 111.79369)
        (xy 144.65 111.79369) (xy 144.65 112.10925) (xy 144.80875 112.268) (xy 145.683 112.268) (xy 145.683 111.44375)
        (xy 145.52425 111.285) (xy 145.158691 111.285) (xy 144.925302 111.381673) (xy 144.746673 111.560301) (xy 144.65 111.79369)
        (xy 144.595 111.79369) (xy 144.595 111.02744) (xy 144.71 111.02744) (xy 144.81 111.007549) (xy 144.91 111.02744)
        (xy 145.36 111.02744) (xy 145.430073 111.013502) (xy 145.43369 111.015) (xy 145.51375 111.015) (xy 145.536397 110.992353)
        (xy 145.607765 110.978157) (xy 145.817809 110.837809) (xy 145.8975 110.718544) (xy 145.8975 110.85625) (xy 146.05625 111.015)
        (xy 146.13631 111.015) (xy 146.369699 110.918327) (xy 146.548327 110.739698) (xy 146.645 110.506309) (xy 146.645 109.91575)
        (xy 146.48625 109.757) (xy 146.00744 109.757) (xy 146.00744 109.503) (xy 146.48625 109.503) (xy 146.645 109.34425)
        (xy 146.645 108.753691) (xy 146.548327 108.520302) (xy 146.369699 108.341673) (xy 146.13631 108.245) (xy 146.05625 108.245)
        (xy 145.970001 108.331249) (xy 145.970001 108.016846) (xy 145.984889 107.941999) (xy 145.970001 107.867152) (xy 145.970001 107.867147)
        (xy 145.925905 107.645462) (xy 145.75793 107.39407) (xy 145.694471 107.351668) (xy 145.517803 107.175) (xy 146.744473 105.948331)
        (xy 146.763301 105.93575) (xy 147.48 105.93575) (xy 147.48 106.301309) (xy 147.576673 106.534698) (xy 147.755301 106.713327)
        (xy 147.98869 106.81) (xy 148.30425 106.81) (xy 148.463 106.65125) (xy 148.463 105.777) (xy 148.717 105.777)
        (xy 148.717 106.65125) (xy 148.87575 106.81) (xy 149.19131 106.81) (xy 149.424699 106.713327) (xy 149.603327 106.534698)
        (xy 149.7 106.301309) (xy 149.7 105.93575) (xy 149.54125 105.777) (xy 148.717 105.777) (xy 148.463 105.777)
        (xy 147.63875 105.777) (xy 147.48 105.93575) (xy 146.763301 105.93575) (xy 146.807929 105.905931) (xy 146.975904 105.654539)
        (xy 147.02 105.432854) (xy 147.02 105.43285) (xy 147.034888 105.358003) (xy 147.02 105.283156) (xy 147.02 104.804846)
        (xy 147.034888 104.729999) (xy 147.02 104.655152) (xy 147.02 104.655148) (xy 146.975904 104.433463) (xy 146.807929 104.182071)
        (xy 146.744472 104.139671) (xy 146.65744 104.052638) (xy 146.65744 102.98) (xy 146.654454 102.964989) (xy 147.192687 102.964989)
        (xy 147.334182 103.106484) (xy 147.529385 103.301686) (xy 147.46756 103.6125) (xy 147.46756 104.1875) (xy 147.534922 104.526152)
        (xy 147.647435 104.69454) (xy 147.576673 104.765302) (xy 147.48 104.998691) (xy 147.48 105.36425) (xy 147.63875 105.523)
        (xy 148.463 105.523) (xy 148.463 105.503) (xy 148.717 105.503) (xy 148.717 105.523) (xy 149.54125 105.523)
        (xy 149.7 105.36425) (xy 149.7 104.998691) (xy 149.603327 104.765302) (xy 149.532565 104.69454) (xy 149.645078 104.526152)
        (xy 149.71244 104.1875) (xy 149.71244 104.0475) (xy 150.301737 104.0475) (xy 150.310874 104.093435) (xy 150.505414 104.384586)
        (xy 150.796565 104.579126) (xy 151.14 104.64744) (xy 152.39 104.64744) (xy 152.733435 104.579126) (xy 153.024586 104.384586)
        (xy 153.219126 104.093435) (xy 153.280853 103.78311) (xy 153.498524 103.78311) (xy 153.619845 104.013) (xy 154.813 104.013)
        (xy 154.813 102.819181) (xy 155.067 102.819181) (xy 155.067 104.013) (xy 156.260155 104.013) (xy 156.381476 103.78311)
        (xy 156.211645 103.373076) (xy 155.821358 102.944817) (xy 155.296892 102.698514) (xy 155.067 102.819181) (xy 154.813 102.819181)
        (xy 154.583108 102.698514) (xy 154.058642 102.944817) (xy 153.668355 103.373076) (xy 153.498524 103.78311) (xy 153.280853 103.78311)
        (xy 153.28744 103.75) (xy 153.28744 102.825) (xy 153.219126 102.481565) (xy 153.10449 102.31) (xy 156.77 102.31)
    (filled_polygon
      (pts
        (xy 126.821843 103.042235) (xy 126.77256 103.29) (xy 126.77256 104.99) (xy 126.821843 105.237765) (xy 126.936928 105.41)
        (xy 126.821843 105.582235) (xy 126.77256 105.83) (xy 126.77256 107.53) (xy 126.821843 107.777765) (xy 126.936928 107.95)
        (xy 126.821843 108.122235) (xy 126.801261 108.225708) (xy 126.496924 107.948355) (xy 126.08689 107.778524) (xy 125.857 107.899845)
        (xy 125.857 109.093) (xy 125.877 109.093) (xy 125.877 109.347) (xy 125.857 109.347) (xy 125.857 110.540155)
        (xy 126.08689 110.661476) (xy 126.496924 110.491645) (xy 126.801261 110.214292) (xy 126.821843 110.317765) (xy 126.962191 110.527809)
        (xy 127.172235 110.668157) (xy 127.42 110.71744) (xy 127.944337 110.71744) (xy 127.973464 110.736902) (xy 128.27 110.795887)
        (xy 128.566537 110.736902) (xy 128.595664 110.71744) (xy 129.12 110.71744) (xy 129.367765 110.668157) (xy 129.577809 110.527809)
        (xy 129.718157 110.317765) (xy 129.727184 110.272381) (xy 129.739375 110.290625) (xy 130.230582 110.618839) (xy 130.663744 110.705)
        (xy 130.956256 110.705) (xy 131.176408 110.661209) (xy 133.934681 113.419483) (xy 133.977081 113.482939) (xy 134.137309 113.59)
        (xy 130.897741 113.59) (xy 131.049126 113.363435) (xy 131.051356 113.352223) (xy 131.239126 113.43) (xy 131.650874 113.43)
        (xy 132.03128 113.272431) (xy 132.322431 112.98128) (xy 132.48 112.600874) (xy 132.48 112.189126) (xy 132.322431 111.80872)
        (xy 132.03128 111.517569) (xy 131.650874 111.36) (xy 131.239126 111.36) (xy 131.051356 111.437777) (xy 131.049126 111.426565)
        (xy 130.854586 111.135414) (xy 130.563435 110.940874) (xy 130.22 110.87256) (xy 129.295 110.87256) (xy 128.951565 110.940874)
        (xy 128.660414 111.135414) (xy 128.465874 111.426565) (xy 128.39756 111.77) (xy 128.39756 113.02) (xy 128.465874 113.363435)
        (xy 128.617259 113.59) (xy 127.922741 113.59) (xy 128.074126 113.363435) (xy 128.14244 113.02) (xy 128.14244 111.77)
        (xy 128.074126 111.426565) (xy 127.879586 111.135414) (xy 127.588435 110.940874) (xy 127.245 110.87256) (xy 126.32 110.87256)
        (xy 125.976565 110.940874) (xy 125.685414 111.135414) (xy 125.490874 111.426565) (xy 125.471046 111.526245) (xy 124.482704 110.537902)
        (xy 124.497809 110.527809) (xy 124.638157 110.317765) (xy 124.658739 110.214292) (xy 124.963076 110.491645) (xy 125.37311 110.661476)
        (xy 125.603 110.540155) (xy 125.603 109.347) (xy 125.583 109.347) (xy 125.583 109.093) (xy 125.603 109.093)
        (xy 125.603 107.899845) (xy 125.37311 107.778524) (xy 124.963076 107.948355) (xy 124.658739 108.225708) (xy 124.638157 108.122235)
        (xy 124.497809 107.912191) (xy 124.482704 107.902098) (xy 126.214476 106.170327) (xy 126.277929 106.127929) (xy 126.320327 106.064476)
        (xy 126.320329 106.064474) (xy 126.418649 105.917327) (xy 126.445904 105.876537) (xy 126.49 105.654852) (xy 126.49 105.654848)
        (xy 126.504888 105.580001) (xy 126.49 105.505154) (xy 126.49 102.995) (xy 126.853405 102.995)
    (filled_polygon
      (pts
        (xy 122.092235 110.668157) (xy 122.34 110.71744) (xy 122.541518 110.71744) (xy 122.587688 110.786537) (xy 122.642072 110.867929)
        (xy 122.705528 110.910329) (xy 124.674671 112.879473) (xy 124.717071 112.942929) (xy 124.968463 113.110904) (xy 125.190148 113.155)
        (xy 125.190152 113.155) (xy 125.264999 113.169888) (xy 125.339846 113.155) (xy 125.449413 113.155) (xy 125.490874 113.363435)
        (xy 125.642259 113.59) (xy 121.995 113.59) (xy 121.995 110.603186)
    (filled_polygon
      (pts
        (xy 122.705528 107.529671) (xy 122.642072 107.572071) (xy 122.599672 107.635527) (xy 122.599671 107.635528) (xy 122.541518 107.72256)
        (xy 122.34 107.72256) (xy 122.092235 107.771843) (xy 121.995 107.836814) (xy 121.995 106.32125) (xy 123.913948 106.32125)
    (filled_polygon
      (pts
        (xy 124.97 105.265197) (xy 124.1775 106.057698) (xy 124.1775 103.37625) (xy 121.995 103.37625) (xy 121.995 102.31)
        (xy 124.970001 102.31)
  (zone (net 10) (net_name GND) (layer B.Cu) (tstamp 5C6C1E15) (hatch edge 0.508)
    (polygon
      (pts
    (filled_polygon
      (pts
        (xy 156.770001 113.59) (xy 151.961595 113.59) (xy 151.993157 113.542765) (xy 152.04244 113.295) (xy 152.04244 111.495)
        (xy 151.993157 111.247235) (xy 151.852809 111.037191) (xy 151.642765 110.896843) (xy 151.627092 110.893725) (xy 151.79631 110.724507)
        (xy 152.03 110.16033) (xy 152.03 109.54967) (xy 151.79631 108.985493) (xy 151.364507 108.55369) (xy 150.80033 108.32)
        (xy 150.18967 108.32) (xy 149.625493 108.55369) (xy 149.19369 108.985493) (xy 148.96 109.54967) (xy 148.96 109.576699)
        (xy 148.832431 109.26872) (xy 148.54128 108.977569) (xy 148.160874 108.82) (xy 147.749126 108.82) (xy 147.36872 108.977569)
        (xy 147.077569 109.26872) (xy 146.92 109.649126) (xy 146.92 109.815198) (xy 145.010198 111.725001) (xy 143.3498 111.725001)
        (xy 148.889483 106.185319) (xy 148.952939 106.142919) (xy 149.018366 106.045001) (xy 149.120914 105.891528) (xy 149.131337 105.839126)
        (xy 149.133152 105.83) (xy 153.44256 105.83) (xy 153.44256 107.53) (xy 153.491843 107.777765) (xy 153.632191 107.987809)
        (xy 153.842235 108.128157) (xy 154.09 108.17744) (xy 155.79 108.17744) (xy 156.037765 108.128157) (xy 156.247809 107.987809)
        (xy 153.491843 105.582235) (xy 153.44256 105.83) (xy 149.133152 105.83) (xy 149.16501 105.669842) (xy 149.16501 105.669838)
        (xy 149.179898 105.59499) (xy 149.16501 105.520142) (xy 149.16501 103.78311) (xy 153.498524 103.78311) (xy 153.619845 104.013)
        (xy 154.813 104.013) (xy 154.813 102.819181) (xy 155.067 102.819181) (xy 155.067 104.013) (xy 156.260155 104.013)
        (xy 156.381476 103.78311) (xy 156.211645 103.373076) (xy 155.821358 102.944817) (xy 155.296892 102.698514) (xy 155.067 102.819181)
        (xy 154.813 102.819181) (xy 154.583108 102.698514) (xy 154.058642 102.944817) (xy 153.668355 103.373076) (xy 153.498524 103.78311)
        (xy 149.16501 103.78311) (xy 149.16501 102.758448) (xy 149.179898 102.6836) (xy 149.16501 102.608752) (xy 149.16501 102.608748)
        (xy 149.120914 102.387063) (xy 149.069422 102.31) (xy 156.77 102.31)
    (filled_polygon
      (pts
        (xy 127.78553 102.449669) (xy 127.722071 102.492071) (xy 127.621518 102.64256) (xy 127.42 102.64256) (xy 127.172235 102.691843)
        (xy 126.962191 102.832191) (xy 126.821843 103.042235) (xy 126.77256 103.29) (xy 126.77256 104.99) (xy 126.821843 105.237765)
        (xy 126.936928 105.41) (xy 126.821843 105.582235) (xy 126.77256 105.83) (xy 126.77256 107.53) (xy 126.821843 107.777765)
        (xy 126.936928 107.95) (xy 126.821843 108.122235) (xy 126.801261 108.225708) (xy 126.496924 107.948355) (xy 126.08689 107.778524)
        (xy 125.857 107.899845) (xy 125.857 109.093) (xy 125.877 109.093) (xy 125.877 109.347) (xy 125.857 109.347)
        (xy 125.857 110.540155) (xy 126.08689 110.661476) (xy 126.496924 110.491645) (xy 126.801261 110.214292) (xy 126.821843 110.317765)
        (xy 126.962191 110.527809) (xy 127.172235 110.668157) (xy 127.42 110.71744) (xy 129.12 110.71744) (xy 129.367765 110.668157)
        (xy 129.577809 110.527809) (xy 129.718157 110.317765) (xy 129.727184 110.272381) (xy 129.739375 110.290625) (xy 130.230582 110.618839)
        (xy 130.663744 110.705) (xy 130.956256 110.705) (xy 131.389418 110.618839) (xy 131.616983 110.466785) (xy 132.785198 111.635)
        (xy 132.148711 111.635) (xy 132.03128 111.517569) (xy 131.650874 111.36) (xy 131.239126 111.36) (xy 130.85872 111.517569)
        (xy 130.567569 111.80872) (xy 130.41 112.189126) (xy 130.41 112.600874) (xy 130.567569 112.98128) (xy 130.85872 113.272431)
        (xy 131.239126 113.43) (xy 131.650874 113.43) (xy 132.03128 113.272431) (xy 132.148711 113.155) (xy 139.24315 113.155)
        (xy 139.318002 113.169889) (xy 139.392854 113.155) (xy 139.614539 113.110904) (xy 139.865931 112.942929) (xy 140.033906 112.691537)
        (xy 140.062571 112.54743) (xy 140.078002 112.469852) (xy 140.078002 112.469851) (xy 140.092891 112.395) (xy 140.078002 112.320148)
        (xy 140.078002 111.745805) (xy 141.30167 112.969474) (xy 141.34407 113.03293) (xy 141.595462 113.200905) (xy 141.817147 113.245001)
        (xy 141.817151 113.245001) (xy 141.891998 113.259889) (xy 141.966845 113.245001) (xy 145.250152 113.245001) (xy 145.324999 113.259889)
        (xy 145.399846 113.245001) (xy 145.399851 113.245001) (xy 145.621536 113.200905) (xy 145.872928 113.03293) (xy 145.91533 112.969471)
        (xy 147.994802 110.89) (xy 148.160874 110.89) (xy 148.54128 110.732431) (xy 148.832431 110.44128) (xy 148.96 110.133301)
        (xy 148.96 110.16033) (xy 149.19369 110.724507) (xy 149.362908 110.893725) (xy 149.347235 110.896843) (xy 149.137191 111.037191)
        (xy 148.996843 111.247235) (xy 148.94756 111.495) (xy 148.94756 113.295) (xy 148.996843 113.542765) (xy 149.028405 113.59)
        (xy 121.995 113.59) (xy 121.995 110.603186) (xy 122.092235 110.668157) (xy 122.34 110.71744) (xy 124.04 110.71744)
        (xy 124.287765 110.668157) (xy 124.497809 110.527809) (xy 124.638157 110.317765) (xy 124.658739 110.214292) (xy 124.963076 110.491645)
        (xy 125.37311 110.661476) (xy 125.603 110.540155) (xy 125.603 109.347) (xy 125.583 109.347) (xy 125.583 109.093)
        (xy 125.603 109.093) (xy 125.603 107.899845) (xy 125.37311 107.778524) (xy 124.963076 107.948355) (xy 124.658739 108.225708)
        (xy 124.638157 108.122235) (xy 124.497809 107.912191) (xy 124.287765 107.771843) (xy 124.04 107.72256) (xy 122.34 107.72256)
        (xy 122.092235 107.771843) (xy 121.995 107.836814) (xy 121.995 106.32125) (xy 125.7625 106.32125) (xy 125.7625 103.37625)
        (xy 121.995 103.37625) (xy 121.995 102.31) (xy 127.925199 102.31)
  (zone (net 10) (net_name GND) (layer F.Cu) (tstamp 5C6C1E12) (hatch edge 0.508)
    (polygon
      (pts
        (xy 121.285 101.6) (xy 125.73 101.6) (xy 125.73 107.95) (xy 121.285 107.95)
    (filled_polygon
      (pts
        (xy 122.34 107.72256) (xy 122.092235 107.771843) (xy 122.015674 107.823) (xy 121.995 107.823) (xy 121.995 106.32125)
    (filled_polygon
      (pts
        (xy 125.603 107.735) (xy 125.602998 107.735) (xy 125.602998 107.823) (xy 125.457387 107.823) (xy 125.37311 107.778524)
        (xy 125.265729 107.823) (xy 124.561802 107.823) (xy 125.603 106.781803)
    (filled_polygon
      (pts
  (zone (net 10) (net_name GND) (layer F.Cu) (tstamp 5C6C1E0F) (hatch edge 0.508)
    (polygon
      (pts
        (xy 121.285 110.49) (xy 125.095 110.49) (xy 125.095 114.3) (xy 121.285 114.3)
    (filled_polygon
      (pts
        (xy 122.092235 110.668157) (xy 122.34 110.71744) (xy 122.541518 110.71744) (xy 122.642072 110.867929) (xy 122.705528 110.910329)
        (xy 124.674671 112.879473) (xy 124.717071 112.942929) (xy 124.968 113.110595) (xy 124.968 113.59) (xy 121.995 113.59)
        (xy 121.995 110.617) (xy 122.015674 110.617)
    (filled_polygon
      (pts
        (xy 124.968 111.023198) (xy 124.561802 110.617) (xy 124.968 110.617)
