Version 4 SHEET 1 1932 996 WIRE 32 112 -96 112 WIRE 80 112 32 112 WIRE 160 112 80 112 WIRE 320 112 240 112 WIRE 80 144 80 112 WIRE 320 144 320 112 WIRE -96 176 -96 112 WIRE 320 288 320 224 WIRE 352 288 320 288 WIRE 400 288 352 288 WIRE 1184 288 480 288 WIRE -96 336 -96 256 WIRE 80 432 80 224 WIRE 144 432 80 432 WIRE 560 432 144 432 WIRE 992 432 928 432 WIRE 928 464 928 432 WIRE 560 480 560 432 WIRE 720 480 560 480 WIRE 848 480 800 480 WIRE 880 480 848 480 WIRE 80 496 80 432 WIRE 992 528 992 432 WIRE 1184 528 1184 288 WIRE 1184 528 992 528 WIRE 1248 528 1184 528 WIRE 320 560 320 288 WIRE 880 560 880 528 WIRE 880 560 320 560 WIRE 928 576 928 544 WIRE 80 640 80 576 FLAG -96 336 0 FLAG 80 640 0 FLAG 928 576 0 FLAG 1248 528 OUT IOPIN 1248 528 Out FLAG 32 112 1 FLAG 144 432 4 FLAG 352 288 3 FLAG 320 112 2 FLAG 848 480 5 SYMBOL res 64 128 R0 SYMATTR InstName R2 SYMATTR Value {wc(10k,tol)} SYMBOL res 64 480 R0 SYMATTR InstName R1 SYMATTR Value {wc(100k,tol)} SYMBOL voltage -96 160 R0 SYMATTR InstName V1 SYMATTR Value 10 SYMBOL res 304 128 R0 SYMATTR InstName R3 SYMATTR Value {wc(10k,tol)} SYMBOL res 384 304 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R4 SYMATTR Value {wc(100k,tol)} SYMBOL e 928 448 R0 SYMATTR InstName E1 SYMATTR Value 1e5 SYMBOL voltage 704 480 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 -32 56 VBottom 2 SYMATTR InstName V2 SYMATTR Value {1m*(1-wc(1,1))} SYMBOL res 144 128 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R5 SYMATTR Value 1 TEXT -88 -32 Left 2 !.op TEXT -88 0 Left 2 !.step param x 0 400 1 TEXT -88 -88 Left 2 !.param tol=0.001 ; 0.1%\n.param offset=1m TEXT 680 376 Left 2 ;Ideal OPAMP with offset TEXT -80 -288 Left 4 ;Monte Carlo Worst Case Simulation Of A Differential Amplifier TEXT 512 144 Left 2 ;mc(10k,tol) varies from 10k*(1-tol) to 10k*(1+tol)\n1m*(1-mc(1,1)) varies from -1m to +1m TEXT 208 728 Left 2 ;Hint:\nYou can easily make a histogram of the output voltage with DPLOT95.\n \n1. Export the data in the Waveform Viewer of LTspice\nFile -> Export V(out)\n \n2. Start DPLOT95\nEither drag the file into the window or use File->Open (o D multiple columns)\n \n3. From the menu in DPLOT95: Generate -> Histogram 0.005 TEXT 304 -88 Left 2 !.meas max_ MAX V(out)\n.meas min_ MIN V(out)\n.meas x_max FIND x when V(out)=max_\n.meas x_min FIND x when V(out)=min_ TEXT -80 -240 Left 2 ;The results from MEASURE are in the log-file.\nView -> SPICE Error Log TEXT 848 -216 Left 2 !.meas R1_max FIND abs((V(4))/I(R1)) WHEN V(out)=max_\n.meas R2_max FIND abs((V(1)-V(4))/I(R2)) WHEN V(out)=max_\n.meas R3_max FIND abs(V(2,3)/I(R3)) WHEN V(out)=max_\n.meas R4_max FIND abs(V(3,out)/I(R4)) WHEN V(out)=max_\n.meas V2_max FIND V(4,5) WHEN V(out)=max_ TEXT 848 -64 Left 2 !.meas R1_min FIND abs((V(4))/I(R1)) WHEN V(out)=min_\n.meas R2_min FIND abs((V(1)-V(4))/I(R2)) WHEN V(out)=min_\n.meas R3_min FIND abs(V(2,3)/I(R3)) WHEN V(out)=min_\n.meas R4_minx FIND abs(V(3,out)/I(R4)) WHEN V(out)=min_\n.meas V2_min FIND V(4,5) WHEN V(out)=min_ TEXT -88 -144 Left 2 !.function wc(nom,tol) if(x==0, nom, if(flat(0.5)>0,nom*(1+tol),nom*(1-tol))) LINE Normal 640 672 640 352 LINE Normal 960 352 640 352 LINE Normal 1088 528 960 352 LINE Normal 960 672 1088 528 LINE Normal 640 672 960 672
