U-Boot 1.1.3 (Feb 20 2012 - 16:20:22) Board: Ralink APSoC DRAM: 32 MB relocate_code Pointer at: 81fb0000 config usb.. ****************************** Software System Reset Occurred ****************************** flash_protect ON: from 0xBF000000 to 0xBF01E757 flash_protect ON: from 0xBF030000 to 0xBF030FFF *** Warning - bad CRC, using default environment ============================================ Ralink UBoot Version: 3.5.0.0 -------------------------------------------- ASIC 3052_MP2 (Port5<->None) DRAM component: 256 Mbits SDR DRAM bus: 16 bit Total memory: 32 MBytes Flash component: NOR Flash Date:Feb 20 2012 Time:16:20:22 ============================================ icache: sets:256, ways:4, linesz:32 ,total:32768 dcache: sets:128, ways:4, linesz:32 ,total:16384 ##### The CPU freq = 320 MHZ #### estimate memory size =32 Mbytes Please choose the operation: 1: Load system code to SDRAM via TFTP. 2: Load system code then write to Flash via TFTP. 3: Boot system code via Flash (default). 4: Entr boot command line interface. 7: Load Boot Loader code then write to Flash via Serial. 9: Load Boot Loader code then write to Flash via TFTP. 0 3: System Boot system code via Flash. ## Booting image at bf050000 ... Image Name: MIPS OpenWrt Linux-4.14.63 Created: 2018-08-16 7:51:15 UTC Image Type: MIPS Linux Kernel Image (lzma compressed) Data Size: 1369817 Bytes = 1.3 MB Load Address: 80000000 Entry Point: 80000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK No initrd ## Transferring control to Linux (at address 80000000) ... ## Giving linux memsize in MB, 32 Starting kernel ... [ 0.000000] Linux version 4.14.63 (buildbot@builds-03.infra.lede-project.org) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7102-3f3a2c9)) #0 Thu Aug 16 07:51:15 2018 [ 0.000000] SoC Type: Ralink RT3350 id:1 rev:2 [ 0.000000] bootconsole [early0] enabled [ 0.000000] CPU0 revision is: 0001964c (MIPS 24KEc) [ 0.000000] MIPS: machine is 8devices Carambola [ 0.000000] Determined physical RAM map: [ 0.000000] memory: 02000000 @ 00000000 (usable) [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. [ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000001ffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000001ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000001ffffff] [ 0.000000] random: get_random_bytes called from 0x803ee72c with crng_init=0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128 [ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2 [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes) [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Writing ErrCtl register=0006a310 [ 0.000000] Readback ErrCtl register=0006a310 [ 0.000000] Memory: 27964K/32768K available (3419K kernel code, 172K rwdata, 424K rodata, 200K init, 210K bss, 4804K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] NR_IRQS: 256 [ 0.000000] CPU Clock: 320MHz [ 0.000000] timer_probe: no matching timers found [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 11945377789 ns [ 0.000019] sched_clock: 32 bits at 160MHz, resolution 6ns, wraps every 13421772796ns [ 0.007901] Calibrating delay loop... 212.58 BogoMIPS (lpj=1062912) [ 0.094000] pid_max: default: 32768 minimum: 301 [ 0.099004] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.105609] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.122003] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.131832] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.138058] pinctrl core: initialized pinctrl subsystem [ 0.146598] NET: Registered protocol family 16 [ 0.160293] Can't analyze schedule() prologue at 80352ab0 [ 0.212848] rt2880_gpio 10000600.gpio: registering 24 gpios [ 0.218536] rt2880_gpio 10000600.gpio: registering 24 irq handlers [ 0.236019] clocksource: Switched to clocksource MIPS [ 0.243537] NET: Registered protocol family 2 [ 0.250055] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.257097] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 0.263366] TCP: Hash tables configured (established 1024 bind 1024) [ 0.270135] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.275918] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.282888] NET: Registered protocol family 1 [ 0.294919] rt-timer 10000100.timer: maximum frequency is 3255Hz [ 0.302769] Crashlog allocated RAM at address 0x1f00000 [ 0.313281] workingset: timestamp_bits=30 max_order=13 bucket_order=0 [ 0.332137] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.338005] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. [ 0.380095] io scheduler noop registered [ 0.383927] io scheduler deadline registered (default) [ 0.390428] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled [ 0.403425] console [ttyS0] disabled [ 0.407158] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20, base_baud = 6666666) is a Palmchip BK-3103 [ 0.417056] console [ttyS0] enabled [ 0.417056] console [ttyS0] enabled [ 0.424008] bootconsole [early0] disabled [ 0.424008] bootconsole [early0] disabled [ 0.433208] cacheinfo: Failed to find cpu0 device node [ 0.438550] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 0.446186] 1f000000.cfi: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x0000c2 Chip ID 0x0022c9 [ 0.456381] Amd/Fujitsu Extended Query Table at 0x0040 [ 0.461595] Amd/Fujitsu Extended Query version 1.1. [ 0.466755] 1f000000.cfi: Swapping erase regions for top-boot CFI table. [ 0.473529] number of CFI chips: 1 [ 0.494559] 4 fixed-partitions partitions found on MTD device 1f000000.cfi [ 0.501661] Creating 4 MTD partitions on "1f000000.cfi": [ 0.507111] 0x000000000000-0x000000030000 : "u-boot" [ 0.514221] 0x000000030000-0x000000040000 : "u-boot-env" [ 0.521734] 0x000000040000-0x000000050000 : "factory" [ 0.529091] 0x000000050000-0x000000800000 : "firmware" [ 0.548528] 2 uimage-fw partitions found on MTD device firmware [ 0.554568] 0x000000050000-0x00000019e719 : "kernel" [ 0.561709] 0x00000019e719-0x000000800000 : "rootfs" [ 0.568783] mtd: device 5 (rootfs) set to be root filesystem [ 0.574573] 1 squashfs-split partitions found on MTD device rootfs [ 0.580997] 0x0000003c0000-0x000000800000 : "rootfs_data" [ 0.589865] libphy: Fixed MDIO Bus: probed [ 0.597848] rt3050-esw 10110000.esw: link changed 0x02 [ 0.616934] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5 [ 0.626584] rt2880_wdt 10000120.watchdog: Initialized [ 0.634439] NET: Registered protocol family 10 [ 0.649960] Segment Routing with IPv6 [ 0.653913] NET: Registered protocol family 17 [ 0.658712] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 0.671905] 8021q: 802.1Q VLAN Support v1.8 [ 0.689045] VFS: Mounted root (squashfs filesystem) readonly on device 31:5. [ 0.699193] Freeing unused kernel memory: 200K [ 0.703699] This architecture does not have kernel memory protection. [ 1.679071] init: Console is alive [ 1.683189] init: - watchdog - [ 2.400850] random: fast init done [ 2.829043] kmodloader: loading kernel modules from /etc/modules-boot.d/* [ 3.002424] kmodloader: done loading kernel modules from /etc/modules-boot.d/* [ 3.020970] init: - preinit - [ 4.528712] 8021q: adding VLAN 0 to HW filter on device eth0 Press the [f] key and hit [enter] to enter failsafe mode Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level [ 8.116997] jffs2: notice: (318) jffs2_build_xattr_subsystem: complete building xattr subsystem, 8 of xdatum (2 unchecked, 6 orphan) and 47 of xref (16 dead, 0 orphan) found. [ 8.135863] mount_root: switching to jffs2 overlay [ 8.190785] overlayfs: upper fs does not support tmpfile. [ 8.206878] urandom-seed: Seeding with /etc/urandom.seed [ 8.433873] procd: - early - [ 8.437284] procd: - watchdog - [ 9.245177] procd: - watchdog - [ 9.249462] procd: - ubus - [ 9.411538] random: ubusd: uninitialized urandom read (4 bytes read) [ 9.422519] random: ubusd: uninitialized urandom read (4 bytes read) [ 9.430317] random: ubusd: uninitialized urandom read (4 bytes read) [ 9.440163] procd: - init - Please press Enter to activate this console. [ 10.384465] kmodloader: loading kernel modules from /etc/modules.d/* [ 10.514152] usbcore: registered new interface driver usbfs [ 10.520182] usbcore: registered new interface driver hub [ 10.525954] usbcore: registered new device driver usb [ 10.562340] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 10.663183] SCSI subsystem initialized [ 10.699741] ehci-platform: EHCI generic platform driver [ 10.716806] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 10.767523] i2c /dev entries driver [ 10.780909] i2c-gpio i2c-gpio: using pins 1 (SDA) and 2 (SCL) [ 10.802100] Loading modules backported from Linux version wt-2017-11-01-0-gfe248fc2c180 [ 10.810341] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d [ 10.826456] ip_tables: (C) 2000-2006 Netfilter Core Team [ 10.852881] nf_conntrack version 0.5.0 (1024 buckets, 4096 max) [ 10.996559] usbcore: registered new interface driver usb-storage [ 11.047991] xt_time: kernel timezone is -0000 [ 11.183353] PPP generic driver version 2.4.2 [ 11.194336] NET: Registered protocol family 24 [ 11.253723] rt2800_wmac 10180000.wmac: loaded eeprom from mtd device "factory" [ 11.261215] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 2872, rev 0200 detected [ 11.269114] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected [ 11.446646] kmodloader: done loading kernel modules from /etc/modules.d/* [ 13.381924] urandom_read: 5 callbacks suppressed [ 13.381941] random: jshn: uninitialized urandom read (4 bytes read) [ 13.549444] random: ubusd: uninitialized urandom read (4 bytes read) [ 31.145249] 8021q: adding VLAN 0 to HW filter on device eth0 [ 31.199360] br-lan: port 1(eth0.1) entered blocking state [ 31.204849] br-lan: port 1(eth0.1) entered disabled state [ 31.211232] device eth0.1 entered promiscuous mode [ 31.216217] device eth0 entered promiscuous mode [ 31.258893] br-lan: port 1(eth0.1) entered blocking state [ 31.264384] br-lan: port 1(eth0.1) entered forwarding state [ 31.270635] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready [ 31.850445] br-wan: port 1(eth0.2) entered blocking state [ 31.855933] br-wan: port 1(eth0.2) entered disabled state [ 31.862280] device eth0.2 entered promiscuous mode [ 31.949842] br-wan: port 1(eth0.2) entered blocking state [ 31.955332] br-wan: port 1(eth0.2) entered forwarding state [ 32.186951] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready [ 37.674715] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 40.721254] wlan0: authenticate with 7c:ff:4d:af:50:1a [ 40.746486] wlan0: send auth to 7c:ff:4d:af:50:1a (try 1/3) [ 40.756862] wlan0: authenticated [ 40.766590] wlan0: associate with 7c:ff:4d:af:50:1a (try 1/3) [ 40.785652] wlan0: RX AssocResp from 7c:ff:4d:af:50:1a (capab=0x1431 status=0 aid=2) [ 40.794226] wlan0: associated [ 40.797697] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 7c:ff:4d:af:50:1a [ 41.836632] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
