# # Automatically generated file; DO NOT EDIT. # Linux/arm 5.1.1 Kernel Configuration # # # Compiler: arm-suse-linux-gnueabi-gcc (SUSE Linux) 7.4.1 20190424 [gcc-7-branch revision 270538] # CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=70401 CONFIG_CLANG_VERSION=0 CONFIG_CC_HAS_ASM_GOTO=y CONFIG_CC_HAS_WARN_MAYBE_UNINITIALIZED=y CONFIG_CC_DISABLE_WARN_MAYBE_UNINITIALIZED=y CONFIG_IRQ_WORK=y # # General setup # CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set CONFIG_LOCALVERSION="-mw" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_BUILD_SALT="" CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y # CONFIG_KERNEL_GZIP is not set CONFIG_KERNEL_LZMA=y # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_HOSTNAME="BPiR2" # CONFIG_SYSVIPC is not set # CONFIG_POSIX_MQUEUE is not set # CONFIG_USELIB is not set # CONFIG_AUDIT is not set CONFIG_HAVE_ARCH_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_CHIP=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_HANDLE_DOMAIN_IRQ=y CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y CONFIG_ARCH_CLOCKSOURCE_DATA=y CONFIG_GENERIC_CLOCKEVENTS=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_HZ_PERIODIC=y # CONFIG_NO_HZ_IDLE is not set # CONFIG_NO_HZ is not set CONFIG_HIGH_RES_TIMERS=y # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_IRQ_TIME_ACCOUNTING is not set # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_TASKSTATS is not set # CONFIG_PSI is not set # # RCU Subsystem # CONFIG_PREEMPT_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y CONFIG_TASKS_RCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y CONFIG_BUILD_BIN2C=y CONFIG_IKCONFIG=y CONFIG_LOG_BUF_SHIFT=17 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 CONFIG_GENERIC_SCHED_CLOCK=y CONFIG_CGROUPS=y # CONFIG_MEMCG is not set # CONFIG_BLK_CGROUP is not set CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y # CONFIG_CFS_BANDWIDTH is not set # CONFIG_RT_GROUP_SCHED is not set # CONFIG_CGROUP_PIDS is not set # CONFIG_CGROUP_RDMA is not set # CONFIG_CGROUP_FREEZER is not set # CONFIG_CGROUP_DEVICE is not set # CONFIG_CGROUP_CPUACCT is not set # CONFIG_CGROUP_BPF is not set # CONFIG_CGROUP_DEBUG is not set # CONFIG_NAMESPACES is not set # CONFIG_CHECKPOINT_RESTORE is not set # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y # CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE is not set CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_ANON_INODES=y CONFIG_HAVE_UID16=y CONFIG_BPF=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y CONFIG_SGETMASK_SYSCALL=y # CONFIG_SYSFS_SYSCALL is not set # CONFIG_FHANDLE is not set # CONFIG_POSIX_TIMERS is not set CONFIG_PRINTK=y CONFIG_PRINTK_NMI=y CONFIG_BUG=y # CONFIG_BASE_FULL is not set # CONFIG_FUTEX is not set # CONFIG_EPOLL is not set # CONFIG_SIGNALFD is not set # CONFIG_TIMERFD is not set # CONFIG_EVENTFD is not set # CONFIG_AIO is not set # CONFIG_IO_URING is not set # CONFIG_ADVISE_SYSCALLS is not set # CONFIG_MEMBARRIER is not set # CONFIG_KALLSYMS is not set CONFIG_BPF_SYSCALL=y CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y # CONFIG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # # CONFIG_PERF_EVENTS is not set # CONFIG_VM_EVENT_COUNTERS is not set # CONFIG_COMPAT_BRK is not set # CONFIG_SLAB is not set # CONFIG_SLUB is not set CONFIG_SLOB=y # CONFIG_SLAB_MERGE_DEFAULT is not set # CONFIG_MMAP_ALLOW_UNINITIALIZED is not set CONFIG_SYSTEM_DATA_VERIFICATION=y # CONFIG_PROFILING is not set CONFIG_ARM=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_NO_IOPORT_MAP=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_RWSEM_XCHGADD_ALGORITHM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_PHYS_OFFSET=0x00800000 CONFIG_GENERIC_BUG=y CONFIG_PGTABLE_LEVELS=2 # # System Type # # CONFIG_MMU is not set CONFIG_ARCH_MMAP_RND_BITS_MIN=8 CONFIG_ARCH_MMAP_RND_BITS_MAX=16 CONFIG_ARM_SINGLE_ARMV7M=y # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C24XX is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_STM32 is not set # CONFIG_ARCH_EFM32 is not set # CONFIG_ARCH_LPC18XX is not set # CONFIG_ARCH_MPS2 is not set # # Processor Type # CONFIG_CPU_V7M=y CONFIG_CPU_THUMBONLY=y CONFIG_CPU_THUMB_CAPABLE=y CONFIG_CPU_32v7M=y CONFIG_CPU_ABRT_NOMMU=y CONFIG_CPU_PABRT_LEGACY=y CONFIG_CPU_CACHE_NOP=y CONFIG_CPU_CACHE_V7M=y CONFIG_CPU_V7M_NUM_IRQ=240 # # Processor Features # CONFIG_ARM_THUMB=y # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_ARM_L1_CACHE_SHIFT=5 # CONFIG_ARM_DMA_MEM_BUFFERABLE is not set # CONFIG_SET_MEM_PARAM is not set CONFIG_DRAM_BASE=0x00800000 CONFIG_DRAM_SIZE=0x00800000 # CONFIG_REMAP_VECTORS_TO_RAM is not set # CONFIG_ARM_MPU is not set # # Bus support # # # Kernel Features # CONFIG_PAGE_OFFSET=0x00800000 CONFIG_ARCH_NR_GPIO=0 CONFIG_HZ_FIXED=0 CONFIG_HZ_100=y # CONFIG_HZ_200 is not set # CONFIG_HZ_250 is not set # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=100 CONFIG_SCHED_HRTICK=y CONFIG_THUMB2_KERNEL=y CONFIG_THUMB2_AVOID_R_ARM_THM_JUMP11=y CONFIG_AEABI=y CONFIG_HAVE_ARCH_PFN_VALID=y CONFIG_ARCH_WANT_GENERAL_HUGETLB=y CONFIG_ARM_MODULE_PLTS=y CONFIG_FORCE_MAX_ZONEORDER=11 # CONFIG_SECCOMP is not set # CONFIG_PARAVIRT is not set # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set # # Boot options # CONFIG_USE_OF=y # CONFIG_ATAGS is not set CONFIG_ZBOOT_ROM_TEXT=0x0 CONFIG_ZBOOT_ROM_BSS=0x0 CONFIG_ARM_APPENDED_DTB=y # CONFIG_ARM_ATAG_DTB_COMPAT is not set CONFIG_CMDLINE="" # CONFIG_XIP_KERNEL is not set # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y # # CPU Power Management # # # CPU Frequency scaling # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_GOV_ATTR_SET=y CONFIG_CPU_FREQ_GOV_COMMON=y # CONFIG_CPU_FREQ_STAT is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE=y CONFIG_CPU_FREQ_GOV_PERFORMANCE=y # CONFIG_CPU_FREQ_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_GOV_ONDEMAND is not set CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y # # CPU frequency scaling drivers # # CONFIG_CPUFREQ_DT is not set # CONFIG_QORIQ_CPUFREQ is not set # # CPU Idle # # CONFIG_CPU_IDLE is not set # # Floating point emulation # # # At least one emulation must be selected # # # Power management options # # CONFIG_SUSPEND is not set # CONFIG_PM is not set # CONFIG_APM_EMULATION is not set CONFIG_ARCH_SUSPEND_POSSIBLE=y # # Firmware Drivers # # CONFIG_FIRMWARE_MEMMAP is not set # CONFIG_GOOGLE_FIRMWARE is not set # # Tegra firmware driver # # CONFIG_ARM_CRYPTO is not set # CONFIG_VIRTUALIZATION is not set # # General architecture-dependent options # CONFIG_HAVE_OPROFILE=y CONFIG_ARCH_USE_BUILTIN_BSWAP=y CONFIG_HAVE_NMI=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_FORTIFY_SOURCE=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y CONFIG_ARCH_32BIT_OFF_T=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_RSEQ=y CONFIG_HAVE_CLK=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_HAVE_STACKPROTECTOR=y CONFIG_CC_HAS_STACKPROTECTOR_NONE=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_HAVE_CONTEXT_TRACKING=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_EXIT_THREAD=y CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y CONFIG_COMPAT_32BIT_TIME=y CONFIG_ARCH_HAS_PHYS_TO_DMA=y CONFIG_REFCOUNT_FULL=y # # GCOV-based kernel profiling # CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y CONFIG_PLUGIN_HOSTCC="" CONFIG_HAVE_GCC_PLUGINS=y CONFIG_BASE_SMALL=1 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set # CONFIG_MODULE_SIG is not set # CONFIG_MODULE_COMPRESS is not set # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_BLOCK=y CONFIG_LBDAF=y CONFIG_BLK_SCSI_REQUEST=y CONFIG_BLK_DEV_BSG=y # CONFIG_BLK_DEV_BSGLIB is not set # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_ZONED is not set # CONFIG_BLK_CMDLINE_PARSER is not set # CONFIG_BLK_WBT is not set # CONFIG_BLK_SED_OPAL is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_EFI_PARTITION=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set CONFIG_ASN1=y CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y # # Executable file formats # # CONFIG_BINFMT_ELF_FDPIC is not set CONFIG_BINFMT_SCRIPT=m # CONFIG_BINFMT_FLAT is not set # CONFIG_BINFMT_MISC is not set # CONFIG_COREDUMP is not set # # Memory Management options # CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_SPLIT_PTLOCK_CPUS=999999 CONFIG_NOMMU_INITIAL_TRIM_EXCESS=1 CONFIG_NEED_PER_CPU_KM=y # CONFIG_CLEANCACHE is not set # CONFIG_ZPOOL is not set # CONFIG_ZBUD is not set CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_BENCHMARK is not set CONFIG_NET=y CONFIG_NET_INGRESS=y CONFIG_SKB_EXTENSIONS=y # # Networking options # CONFIG_PACKET=m CONFIG_PACKET_DIAG=m CONFIG_UNIX=m CONFIG_UNIX_SCM=y CONFIG_UNIX_DIAG=m # CONFIG_TLS is not set CONFIG_XFRM=y CONFIG_XFRM_OFFLOAD=y CONFIG_XFRM_ALGO=y # CONFIG_XFRM_USER is not set # CONFIG_XFRM_INTERFACE is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set CONFIG_XFRM_IPCOMP=m CONFIG_NET_KEY=m # CONFIG_NET_KEY_MIGRATE is not set # CONFIG_XDP_SOCKETS is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y CONFIG_IP_ADVANCED_ROUTER=y # CONFIG_IP_FIB_TRIE_STATS is not set # CONFIG_IP_MULTIPLE_TABLES is not set # CONFIG_IP_ROUTE_MULTIPATH is not set # CONFIG_IP_ROUTE_VERBOSE is not set # CONFIG_IP_PNP is not set CONFIG_NET_IPIP=m # CONFIG_NET_IPGRE_DEMUX is not set CONFIG_NET_IP_TUNNEL=m # CONFIG_IP_MROUTE is not set CONFIG_SYN_COOKIES=y CONFIG_NET_IPVTI=m CONFIG_NET_UDP_TUNNEL=m CONFIG_NET_FOU=m # CONFIG_NET_FOU_IP_TUNNELS is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set CONFIG_INET_TUNNEL=m CONFIG_INET_XFRM_MODE_TRANSPORT=y CONFIG_INET_XFRM_MODE_TUNNEL=y CONFIG_INET_XFRM_MODE_BEET=y CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_INET_UDP_DIAG is not set # CONFIG_INET_RAW_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" CONFIG_TCP_MD5SIG=y CONFIG_IPV6=y CONFIG_IPV6_ROUTER_PREF=y CONFIG_IPV6_ROUTE_INFO=y CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_AH=y CONFIG_INET6_ESP=m CONFIG_INET6_ESP_OFFLOAD=m CONFIG_INET6_IPCOMP=m CONFIG_IPV6_MIP6=m # CONFIG_IPV6_ILA is not set CONFIG_INET6_XFRM_TUNNEL=m CONFIG_INET6_TUNNEL=m CONFIG_INET6_XFRM_MODE_TRANSPORT=m CONFIG_INET6_XFRM_MODE_TUNNEL=m CONFIG_INET6_XFRM_MODE_BEET=m CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION=m CONFIG_IPV6_VTI=m CONFIG_IPV6_SIT=m # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y CONFIG_IPV6_TUNNEL=m CONFIG_IPV6_FOU=m # CONFIG_IPV6_MULTIPLE_TABLES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_IPV6_SEG6_LWTUNNEL is not set # CONFIG_IPV6_SEG6_HMAC is not set # CONFIG_NETWORK_SECMARK is not set # CONFIG_NETWORK_PHY_TIMESTAMPING is not set CONFIG_NETFILTER=y CONFIG_NETFILTER_ADVANCED=y # # Core Netfilter Configuration # CONFIG_NETFILTER_INGRESS=y CONFIG_NETFILTER_NETLINK=m CONFIG_NETFILTER_NETLINK_ACCT=m CONFIG_NETFILTER_NETLINK_QUEUE=m CONFIG_NETFILTER_NETLINK_LOG=m CONFIG_NETFILTER_NETLINK_OSF=m CONFIG_NF_CONNTRACK=m CONFIG_NF_LOG_COMMON=m CONFIG_NF_LOG_NETDEV=m CONFIG_NETFILTER_CONNCOUNT=m # CONFIG_NF_CONNTRACK_MARK is not set # CONFIG_NF_CONNTRACK_ZONES is not set # CONFIG_NF_CONNTRACK_EVENTS is not set # CONFIG_NF_CONNTRACK_TIMEOUT is not set # CONFIG_NF_CONNTRACK_TIMESTAMP is not set # CONFIG_NF_CONNTRACK_LABELS is not set CONFIG_NF_CT_PROTO_DCCP=y CONFIG_NF_CT_PROTO_SCTP=y CONFIG_NF_CT_PROTO_UDPLITE=y # CONFIG_NF_CONNTRACK_AMANDA is not set CONFIG_NF_CONNTRACK_FTP=m # CONFIG_NF_CONNTRACK_H323 is not set # CONFIG_NF_CONNTRACK_IRC is not set # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set # CONFIG_NF_CONNTRACK_SNMP is not set # CONFIG_NF_CONNTRACK_PPTP is not set # CONFIG_NF_CONNTRACK_SANE is not set CONFIG_NF_CONNTRACK_SIP=m CONFIG_NF_CONNTRACK_TFTP=m # CONFIG_NF_CT_NETLINK is not set CONFIG_NF_NAT=m CONFIG_NF_NAT_NEEDED=y CONFIG_NF_NAT_FTP=m CONFIG_NF_NAT_SIP=m CONFIG_NF_NAT_TFTP=m CONFIG_NF_NAT_REDIRECT=y CONFIG_NF_NAT_MASQUERADE=y CONFIG_NF_TABLES=m CONFIG_NF_TABLES_SET=m CONFIG_NF_TABLES_INET=y CONFIG_NF_TABLES_NETDEV=y CONFIG_NFT_NUMGEN=m CONFIG_NFT_CT=m CONFIG_NFT_COUNTER=m CONFIG_NFT_CONNLIMIT=m CONFIG_NFT_LOG=m CONFIG_NFT_LIMIT=m CONFIG_NFT_MASQ=m CONFIG_NFT_REDIR=m CONFIG_NFT_NAT=m CONFIG_NFT_TUNNEL=m CONFIG_NFT_OBJREF=m CONFIG_NFT_QUEUE=m CONFIG_NFT_QUOTA=m CONFIG_NFT_REJECT=m CONFIG_NFT_REJECT_INET=m CONFIG_NFT_HASH=m CONFIG_NFT_XFRM=m CONFIG_NFT_SOCKET=m # CONFIG_NFT_OSF is not set # CONFIG_NFT_TPROXY is not set # CONFIG_NF_DUP_NETDEV is not set # CONFIG_NFT_DUP_NETDEV is not set # CONFIG_NFT_FWD_NETDEV is not set # CONFIG_NF_FLOW_TABLE is not set # CONFIG_NETFILTER_XTABLES is not set CONFIG_IP_SET=m CONFIG_IP_SET_MAX=256 # CONFIG_IP_SET_BITMAP_IP is not set # CONFIG_IP_SET_BITMAP_IPMAC is not set # CONFIG_IP_SET_BITMAP_PORT is not set # CONFIG_IP_SET_HASH_IP is not set # CONFIG_IP_SET_HASH_IPMARK is not set # CONFIG_IP_SET_HASH_IPPORT is not set # CONFIG_IP_SET_HASH_IPPORTIP is not set # CONFIG_IP_SET_HASH_IPPORTNET is not set # CONFIG_IP_SET_HASH_IPMAC is not set # CONFIG_IP_SET_HASH_MAC is not set # CONFIG_IP_SET_HASH_NETPORTNET is not set # CONFIG_IP_SET_HASH_NET is not set # CONFIG_IP_SET_HASH_NETNET is not set # CONFIG_IP_SET_HASH_NETPORT is not set # CONFIG_IP_SET_HASH_NETIFACE is not set # CONFIG_IP_SET_LIST_SET is not set # CONFIG_IP_VS is not set # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=m CONFIG_NF_SOCKET_IPV4=m # CONFIG_NF_TPROXY_IPV4 is not set CONFIG_NF_TABLES_IPV4=y # CONFIG_NFT_CHAIN_ROUTE_IPV4 is not set CONFIG_NFT_REJECT_IPV4=m # CONFIG_NFT_DUP_IPV4 is not set # CONFIG_NFT_FIB_IPV4 is not set # CONFIG_NF_TABLES_ARP is not set # CONFIG_NF_DUP_IPV4 is not set # CONFIG_NF_LOG_ARP is not set # CONFIG_NF_LOG_IPV4 is not set CONFIG_NF_REJECT_IPV4=m # CONFIG_IP_NF_IPTABLES is not set # CONFIG_IP_NF_ARPTABLES is not set # # IPv6: Netfilter Configuration # CONFIG_NF_SOCKET_IPV6=m # CONFIG_NF_TPROXY_IPV6 is not set CONFIG_NF_TABLES_IPV6=y # CONFIG_NFT_CHAIN_ROUTE_IPV6 is not set CONFIG_NFT_REJECT_IPV6=m # CONFIG_NFT_DUP_IPV6 is not set # CONFIG_NFT_FIB_IPV6 is not set # CONFIG_NF_DUP_IPV6 is not set CONFIG_NF_REJECT_IPV6=m # CONFIG_NF_LOG_IPV6 is not set # CONFIG_IP6_NF_IPTABLES is not set CONFIG_NF_DEFRAG_IPV6=m # CONFIG_BPFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set # CONFIG_BRIDGE is not set CONFIG_HAVE_NET_DSA=y # CONFIG_NET_DSA is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set # CONFIG_DNS_RESOLVER is not set # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_NET_NSH is not set # CONFIG_HSR is not set # CONFIG_NET_SWITCHDEV is not set # CONFIG_NET_L3_MASTER_DEV is not set # CONFIG_NET_NCSI is not set # CONFIG_CGROUP_NET_PRIO is not set # CONFIG_CGROUP_NET_CLASSID is not set CONFIG_NET_RX_BUSY_POLL=y # CONFIG_BPF_JIT is not set # # Network testing # # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set CONFIG_WIRELESS=y CONFIG_CFG80211=m # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set # CONFIG_CFG80211_CERTIFICATION_ONUS is not set CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y CONFIG_CFG80211_DEFAULT_PS=y CONFIG_CFG80211_CRDA_SUPPORT=y # CONFIG_CFG80211_WEXT is not set # CONFIG_MAC80211 is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set CONFIG_DST_CACHE=y CONFIG_GRO_CELLS=y # CONFIG_NET_DEVLINK is not set # CONFIG_FAILOVER is not set CONFIG_HAVE_EBPF_JIT=y # # Device Drivers # # CONFIG_PCCARD is not set # # Generic Driver Options # # CONFIG_UEVENT_HELPER is not set # CONFIG_DEVTMPFS is not set # CONFIG_STANDALONE is not set # CONFIG_PREVENT_FIRMWARE_BUILD is not set # # Firmware loader # CONFIG_FW_LOADER=m CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER is not set # CONFIG_ALLOW_DEV_COREDUMP is not set # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_GENERIC_CPU_AUTOPROBE=y # # Bus devices # # CONFIG_BRCMSTB_GISB_ARB is not set # CONFIG_VEXPRESS_CONFIG is not set # CONFIG_CONNECTOR is not set # CONFIG_GNSS is not set # CONFIG_MTD is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_NET=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set # CONFIG_BLK_DEV_LOOP is not set # # DRBD disabled because PROC_FS or INET not selected # # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_RAM is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_BLK_DEV_RBD is not set # # NVME Support # # CONFIG_NVME_FC is not set # # Misc devices # # CONFIG_DUMMY_IRQ is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_SRAM is not set # CONFIG_PVPANIC is not set # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_93CX6 is not set # # Texas Instruments shared transport line discipline # # # Altera FPGA firmware download module (requires I2C) # # # Intel MIC & related support # # # Intel MIC Bus Driver # # # SCIF Bus Driver # # # VOP Bus Driver # # CONFIG_VOP_BUS is not set # # Intel MIC Host Driver # # # Intel MIC Card Driver # # # SCIF Driver # # # Intel MIC Coprocessor State Management (COSM) Drivers # # # VOP Driver # # CONFIG_ECHO is not set # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set # CONFIG_SCSI is not set # CONFIG_ATA is not set # CONFIG_MD is not set # CONFIG_TARGET_CORE is not set CONFIG_NETDEVICES=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_TEAM is not set # CONFIG_MACVLAN is not set # CONFIG_IPVLAN is not set # CONFIG_VXLAN is not set # CONFIG_GENEVE is not set # CONFIG_GTP is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set CONFIG_TUN=m # CONFIG_TUN_VNET_CROSS_LE is not set # CONFIG_VETH is not set # CONFIG_NLMON is not set # # CAIF transport drivers # # # Distributed Switch Architecture drivers # CONFIG_ETHERNET=y CONFIG_NET_VENDOR_ALACRITECH=y # CONFIG_ALTERA_TSE is not set CONFIG_NET_VENDOR_AMAZON=y CONFIG_NET_VENDOR_AQUANTIA=y CONFIG_NET_VENDOR_ARC=y CONFIG_NET_VENDOR_AURORA=y # CONFIG_AURORA_NB8800 is not set CONFIG_NET_VENDOR_BROADCOM=y # CONFIG_B44 is not set # CONFIG_BCMGENET is not set # CONFIG_SYSTEMPORT is not set CONFIG_NET_VENDOR_CADENCE=y # CONFIG_MACB is not set CONFIG_NET_VENDOR_CAVIUM=y CONFIG_NET_VENDOR_CIRRUS=y # CONFIG_CS89x0 is not set CONFIG_NET_VENDOR_CORTINA=y # CONFIG_GEMINI_ETHERNET is not set # CONFIG_DM9000 is not set # CONFIG_DNET is not set CONFIG_NET_VENDOR_EZCHIP=y # CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set CONFIG_NET_VENDOR_FARADAY=y # CONFIG_FTMAC100 is not set # CONFIG_FTGMAC100 is not set CONFIG_NET_VENDOR_HISILICON=y # CONFIG_HIX5HD2_GMAC is not set # CONFIG_HISI_FEMAC is not set # CONFIG_HIP04_ETH is not set # CONFIG_HNS is not set # CONFIG_HNS_DSAF is not set # CONFIG_HNS_ENET is not set CONFIG_NET_VENDOR_HUAWEI=y CONFIG_NET_VENDOR_I825XX=y CONFIG_NET_VENDOR_INTEL=y CONFIG_NET_VENDOR_MARVELL=y # CONFIG_MVMDIO is not set CONFIG_NET_VENDOR_MICREL=y # CONFIG_KS8851_MLL is not set CONFIG_NET_VENDOR_MICROCHIP=y CONFIG_NET_VENDOR_MICROSEMI=y CONFIG_NET_VENDOR_NATSEMI=y CONFIG_NET_VENDOR_NETRONOME=y CONFIG_NET_VENDOR_NI=y # CONFIG_NI_XGE_MANAGEMENT_ENET is not set CONFIG_NET_VENDOR_8390=y # CONFIG_AX88796 is not set # CONFIG_ETHOC is not set CONFIG_NET_VENDOR_QUALCOMM=y # CONFIG_QCA7000_UART is not set # CONFIG_QCOM_EMAC is not set # CONFIG_RMNET is not set CONFIG_NET_VENDOR_RENESAS=y CONFIG_NET_VENDOR_ROCKER=y CONFIG_NET_VENDOR_SAMSUNG=y # CONFIG_SXGBE_ETH is not set CONFIG_NET_VENDOR_SEEQ=y CONFIG_NET_VENDOR_SOLARFLARE=y CONFIG_NET_VENDOR_SMSC=y # CONFIG_SMC91X is not set # CONFIG_SMC911X is not set # CONFIG_SMSC911X is not set CONFIG_NET_VENDOR_SOCIONEXT=y CONFIG_NET_VENDOR_STMICRO=y # CONFIG_STMMAC_ETH is not set CONFIG_NET_VENDOR_SYNOPSYS=y # CONFIG_DWC_XLGMAC is not set CONFIG_NET_VENDOR_VIA=y # CONFIG_VIA_RHINE is not set # CONFIG_VIA_VELOCITY is not set CONFIG_NET_VENDOR_WIZNET=y # CONFIG_WIZNET_W5100 is not set # CONFIG_WIZNET_W5300 is not set # CONFIG_MDIO_DEVICE is not set # CONFIG_PHYLIB is not set # CONFIG_PPP is not set # # Host-side USB support is needed for USB Network Adapter support # CONFIG_WLAN=y # CONFIG_WIRELESS_WDS is not set CONFIG_WLAN_VENDOR_ADMTEK=y CONFIG_WLAN_VENDOR_ATH=y # CONFIG_ATH_DEBUG is not set # CONFIG_ATH6KL is not set CONFIG_WLAN_VENDOR_ATMEL=y CONFIG_WLAN_VENDOR_BROADCOM=y # CONFIG_BRCMFMAC is not set CONFIG_WLAN_VENDOR_CISCO=y CONFIG_WLAN_VENDOR_INTEL=y CONFIG_WLAN_VENDOR_INTERSIL=y # CONFIG_HOSTAP is not set CONFIG_WLAN_VENDOR_MARVELL=y # CONFIG_LIBERTAS is not set # CONFIG_MWIFIEX is not set CONFIG_WLAN_VENDOR_MEDIATEK=y # CONFIG_WLAN_VENDOR_RALINK is not set # CONFIG_WLAN_VENDOR_REALTEK is not set # CONFIG_WLAN_VENDOR_RSI is not set # CONFIG_WLAN_VENDOR_ST is not set # CONFIG_WLAN_VENDOR_TI is not set # CONFIG_WLAN_VENDOR_ZYDAS is not set # CONFIG_WLAN_VENDOR_QUANTENNA is not set # CONFIG_VIRT_WIFI is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # CONFIG_WAN is not set # CONFIG_NET_FAILOVER is not set # CONFIG_ISDN is not set # CONFIG_NVM is not set # # Input device support # # CONFIG_INPUT is not set # # Hardware I/O ports # # CONFIG_SERIO is not set # CONFIG_GAMEPORT is not set # # Character devices # # CONFIG_TTY is not set # CONFIG_DEVMEM is not set # CONFIG_DEVKMEM is not set CONFIG_SERIAL_DEV_BUS=m # CONFIG_IPMI_HANDLER is not set # CONFIG_HW_RANDOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set # CONFIG_XILLYBUS is not set # # I2C support # # CONFIG_I2C is not set # CONFIG_I3C is not set # CONFIG_SPI is not set # CONFIG_SPMI is not set # CONFIG_HSI is not set # CONFIG_PPS is not set # # PTP clock support # # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # # CONFIG_PINCTRL is not set CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y # CONFIG_DEBUG_GPIO is not set # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_CADENCE is not set # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_FTGPIO010 is not set # CONFIG_GPIO_GENERIC_PLATFORM is not set # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_MB86S7X is not set # CONFIG_GPIO_MPC8XXX is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_ZEVIO is not set # CONFIG_GPIO_AMD_FCH is not set # # MFD GPIO expanders # # CONFIG_HTC_EGPIO is not set # CONFIG_W1 is not set # CONFIG_POWER_AVS is not set # CONFIG_POWER_RESET is not set # CONFIG_POWER_SUPPLY is not set # CONFIG_HWMON is not set # CONFIG_THERMAL is not set # CONFIG_WATCHDOG is not set CONFIG_SSB_POSSIBLE=y # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # CONFIG_BCMA is not set # # Multifunction device drivers # # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_CROS_EC is not set # CONFIG_MFD_MADERA is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_MT6397 is not set # CONFIG_MFD_PM8XXX is not set # CONFIG_MFD_SM501 is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_SYSCON is not set # CONFIG_MFD_TI_AM335X_TSCADC is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_RAVE_SP_CORE is not set # CONFIG_REGULATOR is not set # CONFIG_MEDIA_SUPPORT is not set # # Graphics support # # CONFIG_DRM is not set # CONFIG_DRM_DP_CEC is not set # # ARM devices # # # ACP (Audio CoProcessor) Configuration # # # AMD Library routines # # # Frame buffer Devices # # CONFIG_FB is not set # CONFIG_BACKLIGHT_LCD_SUPPORT is not set # CONFIG_SOUND is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_ARCH_HAS_HCD=y # CONFIG_USB is not set # # USB port drivers # # # USB Physical Layer drivers # # CONFIG_NOP_USB_XCEIV is not set # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ULPI is not set # CONFIG_USB_GADGET is not set # CONFIG_TYPEC is not set # CONFIG_USB_ROLE_SWITCH is not set # CONFIG_USB_ULPI_BUS is not set # CONFIG_UWB is not set # CONFIG_MMC is not set # CONFIG_MEMSTICK is not set # CONFIG_NEW_LEDS is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_ATOMIC_SCRUB=y CONFIG_EDAC_SUPPORT=y CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set CONFIG_RTC_NVMEM=y # # RTC interfaces # CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # # SPI RTC drivers # # # SPI and I2C RTC drivers # # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # # CONFIG_RTC_DRV_CADENCE is not set # CONFIG_RTC_DRV_FTRTC010 is not set # CONFIG_RTC_DRV_SNVS is not set # CONFIG_RTC_DRV_R7301 is not set # # HID Sensor RTC drivers # # CONFIG_DMADEVICES is not set # # DMABUF options # # CONFIG_SYNC_FILE is not set # CONFIG_AUXDISPLAY is not set # CONFIG_VIRT_DRIVERS is not set # CONFIG_VIRTIO_MENU is not set # # Microsoft Hyper-V guest support # # CONFIG_STAGING is not set # CONFIG_GOLDFISH is not set # CONFIG_CHROME_PLATFORMS is not set # CONFIG_MELLANOX_PLATFORM is not set CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Common Clock Framework # # CONFIG_CLK_HSDK is not set # CONFIG_CLK_QORIQ is not set # CONFIG_COMMON_CLK_FIXED_MMIO is not set # CONFIG_HWSPINLOCK is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y # CONFIG_ARM_TIMER_SP804 is not set # CONFIG_MAILBOX is not set # # Remoteproc drivers # # CONFIG_REMOTEPROC is not set # # Rpmsg drivers # # CONFIG_RPMSG_VIRTIO is not set # CONFIG_SOUNDWIRE is not set # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # # Broadcom SoC drivers # # CONFIG_SOC_BRCMSTB is not set # # NXP/Freescale QorIQ SoC drivers # # # i.MX SoC drivers # # # Qualcomm SoC drivers # # CONFIG_SOC_TI is not set # # Xilinx SoC drivers # # CONFIG_XILINX_VCU is not set # CONFIG_PM_DEVFREQ is not set # CONFIG_EXTCON is not set # CONFIG_MEMORY is not set # CONFIG_IIO is not set # CONFIG_PWM is not set # # IRQ chip support # CONFIG_IRQCHIP=y CONFIG_ARM_GIC_MAX_NR=1 CONFIG_ARM_NVIC=y # CONFIG_IPACK_BUS is not set # CONFIG_RESET_CONTROLLER is not set # CONFIG_FMC is not set # # PHY Subsystem # # CONFIG_GENERIC_PHY is not set # CONFIG_BCM_KONA_USB2_PHY is not set # CONFIG_PHY_CADENCE_DP is not set # CONFIG_PHY_CADENCE_DPHY is not set # CONFIG_PHY_FSL_IMX8MQ_USB is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_PHY_MAPPHONE_MDM6600 is not set # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # CONFIG_RAS is not set # # Android # # CONFIG_ANDROID is not set # CONFIG_DAX is not set CONFIG_NVMEM=y # # HW tracing support # # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # CONFIG_FPGA is not set # CONFIG_FSI is not set # CONFIG_SIOX is not set # CONFIG_SLIMBUS is not set # CONFIG_INTERCONNECT is not set # # File systems # # CONFIG_VALIDATE_FS_PARSER is not set # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set # CONFIG_EXT4_FS is not set # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set # CONFIG_EXPORTFS_BLOCK_OPS is not set # CONFIG_FILE_LOCKING is not set # CONFIG_FS_ENCRYPTION is not set # CONFIG_DNOTIFY is not set # CONFIG_INOTIFY_USER is not set # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set # CONFIG_AUTOFS4_FS is not set # CONFIG_AUTOFS_FS is not set # CONFIG_FUSE_FS is not set # CONFIG_OVERLAY_FS is not set # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # # CONFIG_MSDOS_FS is not set # CONFIG_VFAT_FS is not set # CONFIG_NTFS_FS is not set # # Pseudo filesystems # # CONFIG_PROC_FS is not set # CONFIG_PROC_CHILDREN is not set CONFIG_KERNFS=y # CONFIG_SYSFS is not set # CONFIG_CONFIGFS_FS is not set # CONFIG_MISC_FILESYSTEMS is not set CONFIG_NETWORK_FILESYSTEMS=y # CONFIG_CEPH_FS is not set CONFIG_CIFS=m # CONFIG_CIFS_STATS2 is not set CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y # CONFIG_CIFS_WEAK_PW_HASH is not set # CONFIG_CIFS_UPCALL is not set # CONFIG_CIFS_XATTR is not set CONFIG_CIFS_DEBUG=y # CONFIG_CIFS_DEBUG2 is not set # CONFIG_CIFS_DEBUG_DUMP_KEYS is not set # CONFIG_CIFS_DFS_UPCALL is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=m CONFIG_NLS_DEFAULT="iso8859-1" # CONFIG_NLS_CODEPAGE_437 is not set # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set # CONFIG_NLS_ISO8859_1 is not set # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set # CONFIG_NLS_UTF8 is not set # # Security options # CONFIG_KEYS=y # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_ENCRYPTED_KEYS is not set CONFIG_KEY_DH_OPERATIONS=y # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITYFS is not set # CONFIG_FORTIFY_SOURCE is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="yama,loadpin,safesetid,integrity" CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=m CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=m CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=m CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=m CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_KPP=y CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_RSA=y CONFIG_CRYPTO_DH=y # CONFIG_CRYPTO_ECDH is not set CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y # CONFIG_CRYPTO_GF128MUL is not set CONFIG_CRYPTO_NULL=m CONFIG_CRYPTO_NULL2=y CONFIG_CRYPTO_WORKQUEUE=y # CONFIG_CRYPTO_CRYPTD is not set CONFIG_CRYPTO_AUTHENC=m # CONFIG_CRYPTO_TEST is not set # # Authenticated Encryption with Associated Data # CONFIG_CRYPTO_CCM=m # CONFIG_CRYPTO_GCM is not set # CONFIG_CRYPTO_CHACHA20POLY1305 is not set # CONFIG_CRYPTO_AEGIS128 is not set # CONFIG_CRYPTO_AEGIS128L is not set # CONFIG_CRYPTO_AEGIS256 is not set # CONFIG_CRYPTO_MORUS640 is not set # CONFIG_CRYPTO_MORUS1280 is not set CONFIG_CRYPTO_SEQIV=m CONFIG_CRYPTO_ECHAINIV=m # # Block modes # CONFIG_CRYPTO_CBC=m # CONFIG_CRYPTO_CFB is not set CONFIG_CRYPTO_CTR=m # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=m # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_ADIANTUM is not set # # Hash modes # CONFIG_CRYPTO_CMAC=m CONFIG_CRYPTO_HMAC=y # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=m # CONFIG_CRYPTO_CRC32 is not set # CONFIG_CRYPTO_CRCT10DIF is not set # CONFIG_CRYPTO_GHASH is not set # CONFIG_CRYPTO_POLY1305 is not set CONFIG_CRYPTO_MD4=m CONFIG_CRYPTO_MD5=y # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set CONFIG_CRYPTO_SHA1=y CONFIG_CRYPTO_SHA256=m CONFIG_CRYPTO_SHA512=m # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_SM3 is not set # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set CONFIG_CRYPTO_ARC4=m # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=m # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_CHACHA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_SM4 is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # CONFIG_CRYPTO_DEFLATE=m # CONFIG_CRYPTO_LZO is not set # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set # CONFIG_CRYPTO_ZSTD is not set # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_DRBG_MENU=m CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=m CONFIG_CRYPTO_JITTERENTROPY=m # CONFIG_CRYPTO_USER_API_HASH is not set # CONFIG_CRYPTO_USER_API_SKCIPHER is not set # CONFIG_CRYPTO_USER_API_RNG is not set # CONFIG_CRYPTO_USER_API_AEAD is not set CONFIG_CRYPTO_HASH_INFO=y CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_CCREE is not set CONFIG_ASYMMETRIC_KEY_TYPE=y CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y CONFIG_X509_CERTIFICATE_PARSER=y # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set CONFIG_PKCS7_MESSAGE_PARSER=y # CONFIG_PKCS7_TEST_KEY is not set # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set # # Certificates for signature checking # CONFIG_SYSTEM_TRUSTED_KEYRING=y CONFIG_SYSTEM_TRUSTED_KEYS="" # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set # CONFIG_SECONDARY_TRUSTED_KEYRING is not set # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_RATIONAL=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y # CONFIG_CRC_CCITT is not set # CONFIG_CRC16 is not set # CONFIG_CRC_T10DIF is not set # CONFIG_CRC_ITU_T is not set CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set # CONFIG_CRC64 is not set # CONFIG_CRC4 is not set # CONFIG_CRC7 is not set CONFIG_LIBCRC32C=m # CONFIG_CRC8 is not set # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=m CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_XZ_DEC=y CONFIG_XZ_DEC_X86=y CONFIG_XZ_DEC_POWERPC=y CONFIG_XZ_DEC_IA64=y CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y CONFIG_XZ_DEC_SPARC=y CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_DMA=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_ARCH_HAS_SETUP_DMA_OPS=y # CONFIG_DMA_API_DEBUG is not set CONFIG_SGL_ALLOC=y CONFIG_NLATTR=y CONFIG_GENERIC_ATOMIC64=y CONFIG_CLZ_TAB=y # CONFIG_CORDIC is not set # CONFIG_DDR is not set # CONFIG_IRQ_POLL is not set CONFIG_MPILIB=y CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_ARCH_NO_SG_CHAIN=y CONFIG_SBITMAP=y # CONFIG_STRING_SELFTEST is not set # # Kernel hacking # # # printk and dmesg options # # CONFIG_PRINTK_TIME is not set # CONFIG_PRINTK_CALLER is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # # Compile-time checks and compiler options # # CONFIG_DEBUG_INFO is not set # CONFIG_ENABLE_MUST_CHECK is not set CONFIG_FRAME_WARN=1024 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_UNUSED_SYMBOLS is not set # CONFIG_DEBUG_FS is not set # CONFIG_HEADERS_CHECK is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set # CONFIG_SECTION_MISMATCH_WARN_ONLY is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # CONFIG_MAGIC_SYSRQ is not set CONFIG_DEBUG_KERNEL=y # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_OBJECTS is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_NOMMU_REGIONS is not set # CONFIG_DEBUG_MEMORY_INIT is not set CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_KASAN_STACK=1 CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y # CONFIG_KCOV is not set # CONFIG_DEBUG_SHIRQ is not set # # Debug Lockups and Hangs # # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 # CONFIG_SCHED_STACK_END_CHECK is not set # CONFIG_DEBUG_TIMEKEEPING is not set # # Lock Debugging (spinlocks, mutexes, etc...) # # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set CONFIG_STACKTRACE=y # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set CONFIG_DEBUG_BUGVERBOSE=y # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PI_LIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_PERF_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 # CONFIG_RCU_TRACE is not set # CONFIG_RCU_EQS_DEBUG is not set # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y # CONFIG_RUNTIME_TESTING_MENU is not set CONFIG_MEMTEST=y # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_SAMPLES is not set # CONFIG_UBSAN is not set CONFIG_UBSAN_ALIGNMENT=y CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y CONFIG_UNWINDER_ARM=y CONFIG_ARM_UNWIND=y # CONFIG_DEBUG_USER is not set CONFIG_DEBUG_LL=y CONFIG_DEBUG_ICEDCC=y # CONFIG_DEBUG_SEMIHOSTING is not set # CONFIG_DEBUG_LL_UART_8250 is not set # CONFIG_DEBUG_LL_UART_PL01X is not set CONFIG_DEBUG_LL_INCLUDE="debug/icedcc.S" # CONFIG_DEBUG_UNCOMPRESS is not set CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" CONFIG_EARLY_PRINTK=y # CONFIG_CORESIGHT is not set
