# # Automatically generated file; DO NOT EDIT. # Linux/arm 5.1.1 Kernel Configuration # # # Compiler: arm-suse-linux-gnueabi-gcc (SUSE Linux) 7.4.1 20190424 [gcc-7-branch revision 270538] # CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=70401 CONFIG_CLANG_VERSION=0 CONFIG_CC_HAS_ASM_GOTO=y CONFIG_CC_HAS_WARN_MAYBE_UNINITIALIZED=y CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_EXTABLE_SORT=y # # General setup # CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set CONFIG_LOCALVERSION="" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_BUILD_SALT="" CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y CONFIG_CROSS_MEMORY_ATTACH=y # CONFIG_USELIB is not set # CONFIG_AUDIT is not set CONFIG_HAVE_ARCH_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y CONFIG_GENERIC_IRQ_MIGRATION=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_GENERIC_MSI_IRQ=y CONFIG_GENERIC_MSI_IRQ_DOMAIN=y CONFIG_HANDLE_DOMAIN_IRQ=y CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set CONFIG_GENERIC_IRQ_MULTI_HANDLER=y CONFIG_ARCH_CLOCKSOURCE_DATA=y CONFIG_GENERIC_TIME_VSYSCALL=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_ARCH_HAS_TICK_BROADCAST=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ_FULL is not set CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y CONFIG_PREEMPT_NONE=y # CONFIG_PREEMPT_VOLUNTARY is not set # CONFIG_PREEMPT is not set # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_IRQ_TIME_ACCOUNTING is not set # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_TASKSTATS is not set # CONFIG_PSI is not set CONFIG_CPU_ISOLATION=y # # RCU Subsystem # CONFIG_TREE_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y CONFIG_BUILD_BIN2C=y CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y CONFIG_LOG_BUF_SHIFT=17 CONFIG_LOG_CPU_MAX_BUF_SHIFT=12 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 CONFIG_GENERIC_SCHED_CLOCK=y CONFIG_CGROUPS=y CONFIG_PAGE_COUNTER=y CONFIG_MEMCG=y CONFIG_MEMCG_SWAP=y CONFIG_MEMCG_SWAP_ENABLED=y CONFIG_MEMCG_KMEM=y CONFIG_BLK_CGROUP=y # CONFIG_DEBUG_BLK_CGROUP is not set CONFIG_CGROUP_WRITEBACK=y CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y CONFIG_CFS_BANDWIDTH=y CONFIG_RT_GROUP_SCHED=y CONFIG_CGROUP_PIDS=y CONFIG_CGROUP_RDMA=y CONFIG_CGROUP_FREEZER=y CONFIG_CPUSETS=y CONFIG_PROC_PID_CPUSET=y CONFIG_CGROUP_DEVICE=y CONFIG_CGROUP_CPUACCT=y CONFIG_CGROUP_PERF=y CONFIG_CGROUP_BPF=y # CONFIG_CGROUP_DEBUG is not set CONFIG_SOCK_CGROUP_DATA=y CONFIG_NAMESPACES=y CONFIG_UTS_NS=y CONFIG_IPC_NS=y CONFIG_USER_NS=y CONFIG_PID_NS=y CONFIG_NET_NS=y # CONFIG_CHECKPOINT_RESTORE is not set # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_HAVE_UID16=y CONFIG_BPF=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set CONFIG_SYSFS_SYSCALL=y # CONFIG_SYSCTL_SYSCALL is not set CONFIG_FHANDLE=y CONFIG_POSIX_TIMERS=y CONFIG_PRINTK=y CONFIG_PRINTK_NMI=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_FUTEX_PI=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_IO_URING=y CONFIG_ADVISE_SYSCALLS=y CONFIG_MEMBARRIER=y CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_BPF_SYSCALL=y # CONFIG_BPF_JIT_ALWAYS_ON is not set # CONFIG_USERFAULTFD is not set CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y CONFIG_RSEQ=y # CONFIG_DEBUG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set CONFIG_VM_EVENT_COUNTERS=y CONFIG_SLUB_DEBUG=y # CONFIG_SLUB_MEMCG_SYSFS_ON is not set CONFIG_COMPAT_BRK=y # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SLAB_FREELIST_HARDENED is not set CONFIG_SLUB_CPU_PARTIAL=y CONFIG_SYSTEM_DATA_VERIFICATION=y # CONFIG_PROFILING is not set CONFIG_TRACEPOINTS=y CONFIG_ARM=y CONFIG_ARM_HAS_SG_CHAIN=y CONFIG_ARM_DMA_USE_IOMMU=y CONFIG_ARM_DMA_IOMMU_ALIGNMENT=8 CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_RWSEM_XCHGADD_ALGORITHM=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_GENERIC_BUG=y CONFIG_PGTABLE_LEVELS=2 # # System Type # CONFIG_MMU=y CONFIG_ARCH_MMAP_RND_BITS_MIN=8 CONFIG_ARCH_MMAP_RND_BITS_MAX=16 CONFIG_ARCH_MULTIPLATFORM=y # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C24XX is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_OMAP1 is not set # # Multiple platform selection # # # CPU Core family selection # # CONFIG_ARCH_MULTI_V6 is not set CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=y # CONFIG_ARCH_VIRT is not set # CONFIG_ARCH_ACTIONS is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_ARTPEC is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_DIGICOLOR is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_KEYSTONE is not set CONFIG_ARCH_MEDIATEK=y CONFIG_MACH_MT2701=y CONFIG_MACH_MT6589=y CONFIG_MACH_MT6592=y CONFIG_MACH_MT7623=y CONFIG_MACH_MT7629=y CONFIG_MACH_MT8127=y CONFIG_MACH_MT8135=y # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MILBEAUT is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_NPCM is not set # # TI OMAP/AM/DM/DRA Family # # CONFIG_ARCH_OMAP3 is not set # CONFIG_ARCH_OMAP4 is not set # CONFIG_SOC_OMAP5 is not set # CONFIG_SOC_AM33XX is not set # CONFIG_SOC_AM43XX is not set # CONFIG_SOC_DRA7XX is not set # CONFIG_ARCH_SIRF is not set # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_RDA is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_RENESAS is not set # CONFIG_ARCH_SOCFPGA is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_STM32 is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_TANGO is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_WM8850 is not set # CONFIG_ARCH_ZX is not set # CONFIG_ARCH_ZYNQ is not set # # Processor Type # CONFIG_CPU_V7=y CONFIG_CPU_THUMB_CAPABLE=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # # CONFIG_ARM_LPAE is not set CONFIG_ARM_THUMB=y CONFIG_ARM_THUMBEE=y CONFIG_ARM_VIRT_EXT=y CONFIG_SWP_EMULATE=y # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_CPU_SPECTRE=y CONFIG_HARDEN_BRANCH_PREDICTOR=y CONFIG_KUSER_HELPERS=y CONFIG_VDSO=y CONFIG_OUTER_CACHE=y CONFIG_OUTER_CACHE_SYNC=y CONFIG_MIGHT_HAVE_CACHE_L2X0=y CONFIG_CACHE_L2X0=y # CONFIG_CACHE_L2X0_PMU is not set CONFIG_PL310_ERRATA_588369=y CONFIG_PL310_ERRATA_727915=y CONFIG_PL310_ERRATA_753970=y CONFIG_PL310_ERRATA_769419=y CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARM_HEAVY_MB=y CONFIG_DEBUG_ALIGN_RODATA=y CONFIG_ARM_ERRATA_430973=y CONFIG_ARM_ERRATA_643719=y CONFIG_ARM_ERRATA_720789=y CONFIG_ARM_ERRATA_754322=y CONFIG_ARM_ERRATA_754327=y CONFIG_ARM_ERRATA_764369=y CONFIG_ARM_ERRATA_775420=y CONFIG_ARM_ERRATA_798181=y # CONFIG_ARM_ERRATA_773022 is not set # CONFIG_ARM_ERRATA_818325_852422 is not set # CONFIG_ARM_ERRATA_821420 is not set # CONFIG_ARM_ERRATA_825619 is not set # CONFIG_ARM_ERRATA_852421 is not set # CONFIG_ARM_ERRATA_852423 is not set # # Bus support # # # Kernel Features # CONFIG_HAVE_SMP=y CONFIG_SMP=y CONFIG_SMP_ON_UP=y CONFIG_ARM_CPU_TOPOLOGY=y # CONFIG_SCHED_MC is not set # CONFIG_SCHED_SMT is not set CONFIG_HAVE_ARM_ARCH_TIMER=y CONFIG_MCPM=y # CONFIG_BIG_LITTLE is not set CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_3G_OPT is not set # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_NR_CPUS=16 CONFIG_HOTPLUG_CPU=y CONFIG_ARM_PSCI=y CONFIG_ARCH_NR_GPIO=0 CONFIG_HZ_FIXED=0 # CONFIG_HZ_100 is not set # CONFIG_HZ_200 is not set CONFIG_HZ_250=y # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=250 CONFIG_SCHED_HRTICK=y # CONFIG_THUMB2_KERNEL is not set CONFIG_ARM_PATCH_IDIV=y CONFIG_AEABI=y # CONFIG_OABI_COMPAT is not set CONFIG_HAVE_ARCH_PFN_VALID=y CONFIG_HIGHMEM=y CONFIG_HIGHPTE=y CONFIG_CPU_SW_DOMAIN_PAN=y CONFIG_HW_PERF_EVENTS=y CONFIG_ARCH_WANT_GENERAL_HUGETLB=y # CONFIG_ARM_MODULE_PLTS is not set CONFIG_FORCE_MAX_ZONEORDER=12 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set CONFIG_SECCOMP=y # CONFIG_PARAVIRT is not set # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set # CONFIG_XEN is not set # # Boot options # CONFIG_USE_OF=y CONFIG_ATAGS=y # CONFIG_DEPRECATED_PARAM_STRUCT is not set CONFIG_ZBOOT_ROM_TEXT=0 CONFIG_ZBOOT_ROM_BSS=0 # CONFIG_ARM_APPENDED_DTB is not set CONFIG_CMDLINE="" CONFIG_KEXEC=y CONFIG_ATAGS_PROC=y # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y CONFIG_EFI_STUB=y CONFIG_EFI=y CONFIG_DMI=y # # CPU Power Management # # # CPU Frequency scaling # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_GOV_ATTR_SET=y CONFIG_CPU_FREQ_GOV_COMMON=y CONFIG_CPU_FREQ_STAT=y # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set CONFIG_CPU_FREQ_GOV_PERFORMANCE=y CONFIG_CPU_FREQ_GOV_POWERSAVE=y CONFIG_CPU_FREQ_GOV_USERSPACE=y CONFIG_CPU_FREQ_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y # # CPU frequency scaling drivers # CONFIG_CPUFREQ_DT=y CONFIG_CPUFREQ_DT_PLATDEV=y # CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set CONFIG_ARM_MEDIATEK_CPUFREQ=y # CONFIG_QORIQ_CPUFREQ is not set # # CPU Idle # CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y CONFIG_CPU_IDLE_GOV_LADDER=y CONFIG_CPU_IDLE_GOV_MENU=y # CONFIG_CPU_IDLE_GOV_TEO is not set CONFIG_DT_IDLE_STATES=y # # ARM CPU Idle Drivers # CONFIG_ARM_CPUIDLE=y # CONFIG_ARM_HIGHBANK_CPUIDLE is not set # # Floating point emulation # # # At least one emulation must be selected # CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y CONFIG_KERNEL_MODE_NEON=y # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_SUSPEND_SKIP_SYNC is not set # CONFIG_HIBERNATION is not set CONFIG_PM_SLEEP=y CONFIG_PM_SLEEP_SMP=y CONFIG_PM_AUTOSLEEP=y # CONFIG_PM_WAKELOCKS is not set CONFIG_PM=y # CONFIG_PM_DEBUG is not set # CONFIG_APM_EMULATION is not set CONFIG_PM_CLK=y CONFIG_PM_GENERIC_DOMAINS=y # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set CONFIG_PM_GENERIC_DOMAINS_SLEEP=y CONFIG_PM_GENERIC_DOMAINS_OF=y CONFIG_CPU_PM=y # CONFIG_ENERGY_MODEL is not set CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y # # Firmware Drivers # CONFIG_ARM_PSCI_FW=y # CONFIG_ARM_PSCI_CHECKER is not set # CONFIG_ARM_SCMI_PROTOCOL is not set # CONFIG_ARM_SCPI_PROTOCOL is not set # CONFIG_FIRMWARE_MEMMAP is not set CONFIG_DMIID=y # CONFIG_DMI_SYSFS is not set CONFIG_FW_CFG_SYSFS=m # CONFIG_FW_CFG_SYSFS_CMDLINE is not set CONFIG_HAVE_ARM_SMCCC=y # CONFIG_GOOGLE_FIRMWARE is not set # # EFI (Extensible Firmware Interface) Support # CONFIG_EFI_VARS=m CONFIG_EFI_ESRT=y CONFIG_EFI_VARS_PSTORE=m # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set CONFIG_EFI_PARAMS_FROM_FDT=y CONFIG_EFI_RUNTIME_WRAPPERS=y CONFIG_EFI_ARMSTUB=y # CONFIG_EFI_ARMSTUB_DTB_LOADER is not set # CONFIG_EFI_BOOTLOADER_CONTROL is not set CONFIG_EFI_CAPSULE_LOADER=m # CONFIG_EFI_TEST is not set # CONFIG_RESET_ATTACK_MITIGATION is not set # # Tegra firmware driver # CONFIG_ARM_CRYPTO=y CONFIG_CRYPTO_SHA1_ARM=m CONFIG_CRYPTO_SHA1_ARM_NEON=m CONFIG_CRYPTO_SHA1_ARM_CE=m CONFIG_CRYPTO_SHA2_ARM_CE=m CONFIG_CRYPTO_SHA256_ARM=m CONFIG_CRYPTO_SHA512_ARM=m CONFIG_CRYPTO_AES_ARM=m CONFIG_CRYPTO_AES_ARM_BS=m CONFIG_CRYPTO_AES_ARM_CE=m CONFIG_CRYPTO_GHASH_ARM_CE=m CONFIG_CRYPTO_CRCT10DIF_ARM_CE=m CONFIG_CRYPTO_CRC32_ARM_CE=m CONFIG_CRYPTO_CHACHA20_NEON=m # CONFIG_CRYPTO_NHPOLY1305_NEON is not set # CONFIG_VIRTUALIZATION is not set # # General architecture-dependent options # CONFIG_CRASH_CORE=y CONFIG_KEXEC_CORE=y CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set # CONFIG_JUMP_LABEL is not set CONFIG_UPROBES=y CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_ARCH_USE_BUILTIN_BSWAP=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_OPTPROBES=y CONFIG_HAVE_NMI=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_FORTIFY_SOURCE=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y CONFIG_ARCH_32BIT_OFF_T=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_RSEQ=y CONFIG_HAVE_CLK=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_SECCOMP_FILTER=y CONFIG_HAVE_STACKPROTECTOR=y CONFIG_CC_HAS_STACKPROTECTOR_NONE=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_HAVE_CONTEXT_TRACKING=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_HAVE_EXIT_THREAD=y CONFIG_ARCH_MMAP_RND_BITS=8 CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y CONFIG_COMPAT_32BIT_TIME=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y CONFIG_STRICT_MODULE_RWX=y CONFIG_ARCH_HAS_PHYS_TO_DMA=y CONFIG_REFCOUNT_FULL=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y CONFIG_PLUGIN_HOSTCC="" CONFIG_HAVE_GCC_PLUGINS=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set # CONFIG_MODULE_SIG is not set # CONFIG_MODULE_COMPRESS is not set # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_LBDAF=y CONFIG_BLK_SCSI_REQUEST=y CONFIG_BLK_DEV_BSG=y CONFIG_BLK_DEV_BSGLIB=y # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_ZONED is not set CONFIG_BLK_DEV_THROTTLING=y # CONFIG_BLK_DEV_THROTTLING_LOW is not set CONFIG_BLK_CMDLINE_PARSER=y # CONFIG_BLK_WBT is not set # CONFIG_BLK_CGROUP_IOLATENCY is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # # Partition Types # CONFIG_PARTITION_ADVANCED=y # CONFIG_ACORN_PARTITION is not set # CONFIG_AIX_PARTITION is not set # CONFIG_OSF_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_ATARI_PARTITION is not set # CONFIG_MAC_PARTITION is not set CONFIG_MSDOS_PARTITION=y # CONFIG_BSD_DISKLABEL is not set # CONFIG_MINIX_SUBPARTITION is not set # CONFIG_SOLARIS_X86_PARTITION is not set # CONFIG_UNIXWARE_DISKLABEL is not set # CONFIG_LDM_PARTITION is not set # CONFIG_SGI_PARTITION is not set # CONFIG_ULTRIX_PARTITION is not set # CONFIG_SUN_PARTITION is not set # CONFIG_KARMA_PARTITION is not set CONFIG_EFI_PARTITION=y # CONFIG_SYSV68_PARTITION is not set CONFIG_CMDLINE_PARTITION=y CONFIG_BLK_MQ_PCI=y CONFIG_BLK_MQ_VIRTIO=y CONFIG_BLK_PM=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y CONFIG_IOSCHED_BFQ=y CONFIG_BFQ_GROUP_IOSCHED=y CONFIG_ASN1=y CONFIG_INLINE_SPIN_UNLOCK_IRQ=y CONFIG_INLINE_READ_UNLOCK=y CONFIG_INLINE_READ_UNLOCK_IRQ=y CONFIG_INLINE_WRITE_UNLOCK=y CONFIG_INLINE_WRITE_UNLOCK_IRQ=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_MUTEX_SPIN_ON_OWNER=y CONFIG_RWSEM_SPIN_ON_OWNER=y CONFIG_LOCK_SPIN_ON_OWNER=y CONFIG_FREEZER=y # # Executable file formats # CONFIG_BINFMT_ELF=y # CONFIG_BINFMT_ELF_FDPIC is not set CONFIG_ELFCORE=y CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y CONFIG_BINFMT_SCRIPT=y # CONFIG_BINFMT_FLAT is not set # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # # Memory Management options # CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_MEMORY_ISOLATION=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_MIGRATION=y CONFIG_BOUNCE=y CONFIG_KSM=y CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_CLEANCACHE=y CONFIG_FRONTSWAP=y CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_CMA_DEBUGFS is not set CONFIG_CMA_AREAS=7 CONFIG_ZSWAP=y CONFIG_ZPOOL=y CONFIG_ZBUD=y CONFIG_Z3FOLD=y CONFIG_ZSMALLOC=y # CONFIG_PGTABLE_MAPPING is not set # CONFIG_ZSMALLOC_STAT is not set CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_FRAME_VECTOR=y # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_BENCHMARK is not set CONFIG_NET=y CONFIG_NET_INGRESS=y CONFIG_NET_EGRESS=y CONFIG_SKB_EXTENSIONS=y # # Networking options # CONFIG_PACKET=y CONFIG_PACKET_DIAG=m CONFIG_UNIX=y CONFIG_UNIX_SCM=y CONFIG_UNIX_DIAG=m # CONFIG_TLS is not set CONFIG_XFRM=y CONFIG_XFRM_OFFLOAD=y CONFIG_XFRM_ALGO=y CONFIG_XFRM_USER=y CONFIG_XFRM_INTERFACE=m # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set CONFIG_XFRM_IPCOMP=m CONFIG_NET_KEY=y # CONFIG_NET_KEY_MIGRATE is not set # CONFIG_XDP_SOCKETS is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y CONFIG_IP_ADVANCED_ROUTER=y CONFIG_IP_FIB_TRIE_STATS=y CONFIG_IP_MULTIPLE_TABLES=y CONFIG_IP_ROUTE_MULTIPATH=y CONFIG_IP_ROUTE_VERBOSE=y CONFIG_IP_ROUTE_CLASSID=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y CONFIG_NET_IPIP=m CONFIG_NET_IPGRE_DEMUX=m CONFIG_NET_IP_TUNNEL=m CONFIG_NET_IPGRE=m CONFIG_NET_IPGRE_BROADCAST=y CONFIG_IP_MROUTE_COMMON=y CONFIG_IP_MROUTE=y CONFIG_IP_MROUTE_MULTIPLE_TABLES=y CONFIG_IP_PIMSM_V1=y CONFIG_IP_PIMSM_V2=y CONFIG_SYN_COOKIES=y # CONFIG_NET_IPVTI is not set CONFIG_NET_UDP_TUNNEL=m # CONFIG_NET_FOU is not set # CONFIG_NET_FOU_IP_TUNNELS is not set CONFIG_INET_AH=m CONFIG_INET_ESP=m CONFIG_INET_ESP_OFFLOAD=m CONFIG_INET_IPCOMP=m CONFIG_INET_XFRM_TUNNEL=m CONFIG_INET_TUNNEL=m CONFIG_INET_XFRM_MODE_TRANSPORT=m CONFIG_INET_XFRM_MODE_TUNNEL=m CONFIG_INET_XFRM_MODE_BEET=m CONFIG_INET_DIAG=m CONFIG_INET_TCP_DIAG=m CONFIG_INET_UDP_DIAG=m # CONFIG_INET_RAW_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set CONFIG_TCP_CONG_ADVANCED=y CONFIG_TCP_CONG_BIC=y CONFIG_TCP_CONG_CUBIC=y CONFIG_TCP_CONG_WESTWOOD=y CONFIG_TCP_CONG_HTCP=y CONFIG_TCP_CONG_HSTCP=y CONFIG_TCP_CONG_HYBLA=y CONFIG_TCP_CONG_VEGAS=y CONFIG_TCP_CONG_NV=y CONFIG_TCP_CONG_SCALABLE=y CONFIG_TCP_CONG_LP=y CONFIG_TCP_CONG_VENO=y CONFIG_TCP_CONG_YEAH=y CONFIG_TCP_CONG_ILLINOIS=y # CONFIG_TCP_CONG_DCTCP is not set # CONFIG_TCP_CONG_CDG is not set # CONFIG_TCP_CONG_BBR is not set # CONFIG_DEFAULT_BIC is not set CONFIG_DEFAULT_CUBIC=y # CONFIG_DEFAULT_HTCP is not set # CONFIG_DEFAULT_HYBLA is not set # CONFIG_DEFAULT_VEGAS is not set # CONFIG_DEFAULT_VENO is not set # CONFIG_DEFAULT_WESTWOOD is not set # CONFIG_DEFAULT_RENO is not set CONFIG_DEFAULT_TCP_CONG="cubic" CONFIG_TCP_MD5SIG=y CONFIG_IPV6=y CONFIG_IPV6_ROUTER_PREF=y CONFIG_IPV6_ROUTE_INFO=y CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_AH=m CONFIG_INET6_ESP=m CONFIG_INET6_ESP_OFFLOAD=m CONFIG_INET6_IPCOMP=m CONFIG_IPV6_MIP6=m CONFIG_IPV6_ILA=m CONFIG_INET6_XFRM_TUNNEL=m CONFIG_INET6_TUNNEL=m CONFIG_INET6_XFRM_MODE_TRANSPORT=m CONFIG_INET6_XFRM_MODE_TUNNEL=m CONFIG_INET6_XFRM_MODE_BEET=m CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION=m CONFIG_IPV6_VTI=m CONFIG_IPV6_SIT=m CONFIG_IPV6_SIT_6RD=y CONFIG_IPV6_NDISC_NODETYPE=y CONFIG_IPV6_TUNNEL=m CONFIG_IPV6_GRE=m CONFIG_IPV6_MULTIPLE_TABLES=y CONFIG_IPV6_SUBTREES=y CONFIG_IPV6_MROUTE=y CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y CONFIG_IPV6_PIMSM_V2=y CONFIG_IPV6_SEG6_LWTUNNEL=y CONFIG_IPV6_SEG6_HMAC=y CONFIG_IPV6_SEG6_BPF=y CONFIG_NETWORK_SECMARK=y CONFIG_NET_PTP_CLASSIFY=y CONFIG_NETWORK_PHY_TIMESTAMPING=y CONFIG_NETFILTER=y CONFIG_NETFILTER_ADVANCED=y CONFIG_BRIDGE_NETFILTER=m # # Core Netfilter Configuration # CONFIG_NETFILTER_INGRESS=y CONFIG_NETFILTER_NETLINK=m CONFIG_NETFILTER_FAMILY_BRIDGE=y CONFIG_NETFILTER_FAMILY_ARP=y CONFIG_NETFILTER_NETLINK_ACCT=m CONFIG_NETFILTER_NETLINK_QUEUE=m CONFIG_NETFILTER_NETLINK_LOG=m CONFIG_NETFILTER_NETLINK_OSF=m CONFIG_NF_CONNTRACK=m CONFIG_NF_LOG_COMMON=m CONFIG_NF_LOG_NETDEV=m CONFIG_NETFILTER_CONNCOUNT=m CONFIG_NF_CONNTRACK_MARK=y CONFIG_NF_CONNTRACK_SECMARK=y CONFIG_NF_CONNTRACK_ZONES=y CONFIG_NF_CONNTRACK_PROCFS=y CONFIG_NF_CONNTRACK_EVENTS=y CONFIG_NF_CONNTRACK_TIMEOUT=y CONFIG_NF_CONNTRACK_TIMESTAMP=y CONFIG_NF_CONNTRACK_LABELS=y CONFIG_NF_CT_PROTO_DCCP=y CONFIG_NF_CT_PROTO_GRE=y CONFIG_NF_CT_PROTO_SCTP=y CONFIG_NF_CT_PROTO_UDPLITE=y CONFIG_NF_CONNTRACK_AMANDA=m CONFIG_NF_CONNTRACK_FTP=m CONFIG_NF_CONNTRACK_H323=m CONFIG_NF_CONNTRACK_IRC=m CONFIG_NF_CONNTRACK_BROADCAST=m CONFIG_NF_CONNTRACK_NETBIOS_NS=m CONFIG_NF_CONNTRACK_SNMP=m CONFIG_NF_CONNTRACK_PPTP=m CONFIG_NF_CONNTRACK_SANE=m CONFIG_NF_CONNTRACK_SIP=m CONFIG_NF_CONNTRACK_TFTP=m CONFIG_NF_CT_NETLINK=m CONFIG_NF_CT_NETLINK_TIMEOUT=m CONFIG_NF_CT_NETLINK_HELPER=m CONFIG_NETFILTER_NETLINK_GLUE_CT=y CONFIG_NF_NAT=m CONFIG_NF_NAT_NEEDED=y CONFIG_NF_NAT_AMANDA=m CONFIG_NF_NAT_FTP=m CONFIG_NF_NAT_IRC=m CONFIG_NF_NAT_SIP=m CONFIG_NF_NAT_TFTP=m CONFIG_NF_NAT_REDIRECT=y CONFIG_NF_NAT_MASQUERADE=y CONFIG_NETFILTER_SYNPROXY=m CONFIG_NF_TABLES=m CONFIG_NF_TABLES_SET=m # CONFIG_NF_TABLES_INET is not set # CONFIG_NF_TABLES_NETDEV is not set # CONFIG_NFT_NUMGEN is not set CONFIG_NFT_CT=m CONFIG_NFT_FLOW_OFFLOAD=m CONFIG_NFT_COUNTER=m CONFIG_NFT_CONNLIMIT=m CONFIG_NFT_LOG=m CONFIG_NFT_LIMIT=m CONFIG_NFT_MASQ=m CONFIG_NFT_REDIR=m CONFIG_NFT_TUNNEL=m CONFIG_NFT_OBJREF=m CONFIG_NFT_QUEUE=m CONFIG_NFT_QUOTA=m CONFIG_NFT_REJECT=m CONFIG_NFT_COMPAT=m CONFIG_NFT_HASH=m # CONFIG_NFT_XFRM is not set CONFIG_NFT_SOCKET=m CONFIG_NFT_OSF=m CONFIG_NFT_TPROXY=m CONFIG_NF_FLOW_TABLE_INET=m CONFIG_NF_FLOW_TABLE=m CONFIG_NETFILTER_XTABLES=m # # Xtables combined modules # CONFIG_NETFILTER_XT_MARK=m CONFIG_NETFILTER_XT_CONNMARK=m CONFIG_NETFILTER_XT_SET=m # # Xtables targets # CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m CONFIG_NETFILTER_XT_TARGET_CONNMARK=m CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=m CONFIG_NETFILTER_XT_TARGET_CT=m CONFIG_NETFILTER_XT_TARGET_DSCP=m CONFIG_NETFILTER_XT_TARGET_HL=m CONFIG_NETFILTER_XT_TARGET_HMARK=m CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m CONFIG_NETFILTER_XT_TARGET_LED=m CONFIG_NETFILTER_XT_TARGET_LOG=m CONFIG_NETFILTER_XT_TARGET_MARK=m CONFIG_NETFILTER_XT_NAT=m CONFIG_NETFILTER_XT_TARGET_NETMAP=m CONFIG_NETFILTER_XT_TARGET_NFLOG=m CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m CONFIG_NETFILTER_XT_TARGET_NOTRACK=m CONFIG_NETFILTER_XT_TARGET_RATEEST=m CONFIG_NETFILTER_XT_TARGET_REDIRECT=m CONFIG_NETFILTER_XT_TARGET_TEE=m CONFIG_NETFILTER_XT_TARGET_TPROXY=m CONFIG_NETFILTER_XT_TARGET_TRACE=m CONFIG_NETFILTER_XT_TARGET_SECMARK=m CONFIG_NETFILTER_XT_TARGET_TCPMSS=m CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m # # Xtables matches # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m CONFIG_NETFILTER_XT_MATCH_BPF=m CONFIG_NETFILTER_XT_MATCH_CGROUP=m CONFIG_NETFILTER_XT_MATCH_CLUSTER=m CONFIG_NETFILTER_XT_MATCH_COMMENT=m CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m CONFIG_NETFILTER_XT_MATCH_CONNMARK=m CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m CONFIG_NETFILTER_XT_MATCH_CPU=m CONFIG_NETFILTER_XT_MATCH_DCCP=m CONFIG_NETFILTER_XT_MATCH_DEVGROUP=m CONFIG_NETFILTER_XT_MATCH_DSCP=m CONFIG_NETFILTER_XT_MATCH_ECN=m CONFIG_NETFILTER_XT_MATCH_ESP=m CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m CONFIG_NETFILTER_XT_MATCH_HELPER=m CONFIG_NETFILTER_XT_MATCH_HL=m CONFIG_NETFILTER_XT_MATCH_IPCOMP=m CONFIG_NETFILTER_XT_MATCH_IPRANGE=m CONFIG_NETFILTER_XT_MATCH_IPVS=m CONFIG_NETFILTER_XT_MATCH_L2TP=m CONFIG_NETFILTER_XT_MATCH_LENGTH=m CONFIG_NETFILTER_XT_MATCH_LIMIT=m CONFIG_NETFILTER_XT_MATCH_MAC=m CONFIG_NETFILTER_XT_MATCH_MARK=m CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m CONFIG_NETFILTER_XT_MATCH_NFACCT=m CONFIG_NETFILTER_XT_MATCH_OSF=m CONFIG_NETFILTER_XT_MATCH_OWNER=m CONFIG_NETFILTER_XT_MATCH_POLICY=m CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m CONFIG_NETFILTER_XT_MATCH_QUOTA=m CONFIG_NETFILTER_XT_MATCH_RATEEST=m CONFIG_NETFILTER_XT_MATCH_REALM=m CONFIG_NETFILTER_XT_MATCH_RECENT=m CONFIG_NETFILTER_XT_MATCH_SCTP=m CONFIG_NETFILTER_XT_MATCH_SOCKET=m CONFIG_NETFILTER_XT_MATCH_STATE=m CONFIG_NETFILTER_XT_MATCH_STATISTIC=m CONFIG_NETFILTER_XT_MATCH_STRING=m CONFIG_NETFILTER_XT_MATCH_TCPMSS=m CONFIG_NETFILTER_XT_MATCH_TIME=m CONFIG_NETFILTER_XT_MATCH_U32=m CONFIG_IP_SET=m CONFIG_IP_SET_MAX=256 CONFIG_IP_SET_BITMAP_IP=m CONFIG_IP_SET_BITMAP_IPMAC=m CONFIG_IP_SET_BITMAP_PORT=m CONFIG_IP_SET_HASH_IP=m CONFIG_IP_SET_HASH_IPMARK=m CONFIG_IP_SET_HASH_IPPORT=m CONFIG_IP_SET_HASH_IPPORTIP=m CONFIG_IP_SET_HASH_IPPORTNET=m CONFIG_IP_SET_HASH_IPMAC=m CONFIG_IP_SET_HASH_MAC=m CONFIG_IP_SET_HASH_NETPORTNET=m CONFIG_IP_SET_HASH_NET=m CONFIG_IP_SET_HASH_NETNET=m CONFIG_IP_SET_HASH_NETPORT=m CONFIG_IP_SET_HASH_NETIFACE=m CONFIG_IP_SET_LIST_SET=m CONFIG_IP_VS=m CONFIG_IP_VS_IPV6=y # CONFIG_IP_VS_DEBUG is not set CONFIG_IP_VS_TAB_BITS=12 # # IPVS transport protocol load balancing support # CONFIG_IP_VS_PROTO_TCP=y CONFIG_IP_VS_PROTO_UDP=y CONFIG_IP_VS_PROTO_AH_ESP=y CONFIG_IP_VS_PROTO_ESP=y CONFIG_IP_VS_PROTO_AH=y CONFIG_IP_VS_PROTO_SCTP=y # # IPVS scheduler # CONFIG_IP_VS_RR=m CONFIG_IP_VS_WRR=m CONFIG_IP_VS_LC=m CONFIG_IP_VS_WLC=m # CONFIG_IP_VS_FO is not set CONFIG_IP_VS_OVF=m CONFIG_IP_VS_LBLC=m CONFIG_IP_VS_LBLCR=m CONFIG_IP_VS_DH=m CONFIG_IP_VS_SH=m CONFIG_IP_VS_MH=m CONFIG_IP_VS_SED=m CONFIG_IP_VS_NQ=m # # IPVS SH scheduler # CONFIG_IP_VS_SH_TAB_BITS=8 # # IPVS MH scheduler # CONFIG_IP_VS_MH_TAB_INDEX=12 # # IPVS application helper # CONFIG_IP_VS_FTP=m CONFIG_IP_VS_NFCT=y CONFIG_IP_VS_PE_SIP=m # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=m CONFIG_NF_SOCKET_IPV4=m CONFIG_NF_TPROXY_IPV4=m # CONFIG_NF_TABLES_IPV4 is not set # CONFIG_NF_TABLES_ARP is not set CONFIG_NF_FLOW_TABLE_IPV4=m CONFIG_NF_DUP_IPV4=m CONFIG_NF_LOG_ARP=m CONFIG_NF_LOG_IPV4=m CONFIG_NF_REJECT_IPV4=m CONFIG_NF_NAT_SNMP_BASIC=m CONFIG_NF_NAT_PPTP=m CONFIG_NF_NAT_H323=m CONFIG_IP_NF_IPTABLES=m CONFIG_IP_NF_MATCH_AH=m CONFIG_IP_NF_MATCH_ECN=m CONFIG_IP_NF_MATCH_RPFILTER=m CONFIG_IP_NF_MATCH_TTL=m CONFIG_IP_NF_FILTER=m CONFIG_IP_NF_TARGET_REJECT=m CONFIG_IP_NF_TARGET_SYNPROXY=m CONFIG_IP_NF_NAT=m CONFIG_IP_NF_TARGET_MASQUERADE=m CONFIG_IP_NF_TARGET_NETMAP=m CONFIG_IP_NF_TARGET_REDIRECT=m CONFIG_IP_NF_MANGLE=m CONFIG_IP_NF_TARGET_CLUSTERIP=m CONFIG_IP_NF_TARGET_ECN=m CONFIG_IP_NF_TARGET_TTL=m CONFIG_IP_NF_RAW=m CONFIG_IP_NF_ARPTABLES=m CONFIG_IP_NF_ARPFILTER=m CONFIG_IP_NF_ARP_MANGLE=m # # IPv6: Netfilter Configuration # CONFIG_NF_SOCKET_IPV6=m CONFIG_NF_TPROXY_IPV6=m # CONFIG_NF_TABLES_IPV6 is not set CONFIG_NF_FLOW_TABLE_IPV6=m CONFIG_NF_DUP_IPV6=m CONFIG_NF_REJECT_IPV6=m CONFIG_NF_LOG_IPV6=m CONFIG_IP6_NF_IPTABLES=m CONFIG_IP6_NF_MATCH_AH=m CONFIG_IP6_NF_MATCH_EUI64=m CONFIG_IP6_NF_MATCH_FRAG=m CONFIG_IP6_NF_MATCH_OPTS=m CONFIG_IP6_NF_MATCH_HL=m CONFIG_IP6_NF_MATCH_IPV6HEADER=m CONFIG_IP6_NF_MATCH_MH=m CONFIG_IP6_NF_MATCH_RPFILTER=m CONFIG_IP6_NF_MATCH_RT=m CONFIG_IP6_NF_MATCH_SRH=m CONFIG_IP6_NF_TARGET_HL=m CONFIG_IP6_NF_FILTER=m CONFIG_IP6_NF_TARGET_REJECT=m CONFIG_IP6_NF_TARGET_SYNPROXY=m CONFIG_IP6_NF_MANGLE=m CONFIG_IP6_NF_RAW=m CONFIG_IP6_NF_NAT=m CONFIG_IP6_NF_TARGET_MASQUERADE=m CONFIG_IP6_NF_TARGET_NPT=m CONFIG_NF_DEFRAG_IPV6=m # CONFIG_NF_TABLES_BRIDGE is not set CONFIG_BRIDGE_NF_EBTABLES=m CONFIG_BRIDGE_EBT_BROUTE=m CONFIG_BRIDGE_EBT_T_FILTER=m CONFIG_BRIDGE_EBT_T_NAT=m CONFIG_BRIDGE_EBT_802_3=m CONFIG_BRIDGE_EBT_AMONG=m CONFIG_BRIDGE_EBT_ARP=m CONFIG_BRIDGE_EBT_IP=m CONFIG_BRIDGE_EBT_IP6=m CONFIG_BRIDGE_EBT_LIMIT=m CONFIG_BRIDGE_EBT_MARK=m CONFIG_BRIDGE_EBT_PKTTYPE=m CONFIG_BRIDGE_EBT_STP=m CONFIG_BRIDGE_EBT_VLAN=m CONFIG_BRIDGE_EBT_ARPREPLY=m CONFIG_BRIDGE_EBT_DNAT=m CONFIG_BRIDGE_EBT_MARK_T=m CONFIG_BRIDGE_EBT_REDIRECT=m CONFIG_BRIDGE_EBT_SNAT=m CONFIG_BRIDGE_EBT_LOG=m CONFIG_BRIDGE_EBT_NFLOG=m # CONFIG_BPFILTER is not set CONFIG_IP_DCCP=m CONFIG_INET_DCCP_DIAG=m # # DCCP CCIDs Configuration # # CONFIG_IP_DCCP_CCID2_DEBUG is not set CONFIG_IP_DCCP_CCID3=y # CONFIG_IP_DCCP_CCID3_DEBUG is not set CONFIG_IP_DCCP_TFRC_LIB=y # # DCCP Kernel Hacking # # CONFIG_IP_DCCP_DEBUG is not set CONFIG_IP_SCTP=m CONFIG_SCTP_DBG_OBJCNT=y CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set CONFIG_SCTP_COOKIE_HMAC_MD5=y CONFIG_SCTP_COOKIE_HMAC_SHA1=y CONFIG_INET_SCTP_DIAG=m CONFIG_RDS=m CONFIG_RDS_TCP=m # CONFIG_RDS_DEBUG is not set CONFIG_TIPC=m CONFIG_TIPC_MEDIA_UDP=y CONFIG_TIPC_DIAG=m CONFIG_ATM=m CONFIG_ATM_CLIP=m CONFIG_ATM_CLIP_NO_ICMP=y # CONFIG_ATM_LANE is not set CONFIG_ATM_BR2684=m CONFIG_ATM_BR2684_IPFILTER=y CONFIG_L2TP=m # CONFIG_L2TP_DEBUGFS is not set CONFIG_L2TP_V3=y CONFIG_L2TP_IP=m CONFIG_L2TP_ETH=m CONFIG_STP=y CONFIG_GARP=y CONFIG_MRP=y CONFIG_BRIDGE=y CONFIG_BRIDGE_IGMP_SNOOPING=y CONFIG_BRIDGE_VLAN_FILTERING=y CONFIG_HAVE_NET_DSA=y CONFIG_NET_DSA=m CONFIG_NET_DSA_LEGACY=y CONFIG_NET_DSA_TAG_MTK=y CONFIG_VLAN_8021Q=y CONFIG_VLAN_8021Q_GVRP=y CONFIG_VLAN_8021Q_MVRP=y # CONFIG_DECNET is not set CONFIG_LLC=y # CONFIG_LLC2 is not set CONFIG_ATALK=m CONFIG_DEV_APPLETALK=m CONFIG_IPDDP=m CONFIG_IPDDP_ENCAP=y # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set CONFIG_6LOWPAN=m # CONFIG_6LOWPAN_DEBUGFS is not set CONFIG_6LOWPAN_NHC=m CONFIG_6LOWPAN_NHC_DEST=m CONFIG_6LOWPAN_NHC_FRAGMENT=m CONFIG_6LOWPAN_NHC_HOP=m CONFIG_6LOWPAN_NHC_IPV6=m CONFIG_6LOWPAN_NHC_MOBILITY=m CONFIG_6LOWPAN_NHC_ROUTING=m CONFIG_6LOWPAN_NHC_UDP=m # CONFIG_6LOWPAN_GHC_EXT_HDR_HOP is not set # CONFIG_6LOWPAN_GHC_UDP is not set # CONFIG_6LOWPAN_GHC_ICMPV6 is not set # CONFIG_6LOWPAN_GHC_EXT_HDR_DEST is not set # CONFIG_6LOWPAN_GHC_EXT_HDR_FRAG is not set # CONFIG_6LOWPAN_GHC_EXT_HDR_ROUTE is not set CONFIG_IEEE802154=m CONFIG_IEEE802154_NL802154_EXPERIMENTAL=y CONFIG_IEEE802154_SOCKET=m CONFIG_IEEE802154_6LOWPAN=m CONFIG_MAC802154=m CONFIG_NET_SCHED=y # # Queueing/Scheduling # CONFIG_NET_SCH_CBQ=m CONFIG_NET_SCH_HTB=m CONFIG_NET_SCH_HFSC=m CONFIG_NET_SCH_ATM=m CONFIG_NET_SCH_PRIO=m CONFIG_NET_SCH_MULTIQ=m CONFIG_NET_SCH_RED=m CONFIG_NET_SCH_SFB=m CONFIG_NET_SCH_SFQ=m CONFIG_NET_SCH_TEQL=m CONFIG_NET_SCH_TBF=m CONFIG_NET_SCH_CBS=m CONFIG_NET_SCH_ETF=m # CONFIG_NET_SCH_TAPRIO is not set CONFIG_NET_SCH_GRED=m CONFIG_NET_SCH_DSMARK=m CONFIG_NET_SCH_NETEM=m CONFIG_NET_SCH_DRR=m CONFIG_NET_SCH_MQPRIO=m CONFIG_NET_SCH_SKBPRIO=m CONFIG_NET_SCH_CHOKE=m CONFIG_NET_SCH_QFQ=m CONFIG_NET_SCH_CODEL=m CONFIG_NET_SCH_FQ_CODEL=m CONFIG_NET_SCH_CAKE=m CONFIG_NET_SCH_FQ=m CONFIG_NET_SCH_HHF=m CONFIG_NET_SCH_PIE=m CONFIG_NET_SCH_INGRESS=m CONFIG_NET_SCH_PLUG=m # CONFIG_NET_SCH_DEFAULT is not set # # Classification # CONFIG_NET_CLS=y CONFIG_NET_CLS_BASIC=m CONFIG_NET_CLS_TCINDEX=m CONFIG_NET_CLS_ROUTE4=m CONFIG_NET_CLS_FW=m CONFIG_NET_CLS_U32=m CONFIG_CLS_U32_PERF=y CONFIG_CLS_U32_MARK=y CONFIG_NET_CLS_RSVP=m CONFIG_NET_CLS_RSVP6=m CONFIG_NET_CLS_FLOW=m CONFIG_NET_CLS_CGROUP=m CONFIG_NET_CLS_BPF=m CONFIG_NET_CLS_FLOWER=m # CONFIG_NET_CLS_MATCHALL is not set CONFIG_NET_EMATCH=y CONFIG_NET_EMATCH_STACK=32 CONFIG_NET_EMATCH_CMP=m CONFIG_NET_EMATCH_NBYTE=m CONFIG_NET_EMATCH_U32=m CONFIG_NET_EMATCH_META=m CONFIG_NET_EMATCH_TEXT=m CONFIG_NET_EMATCH_CANID=m # CONFIG_NET_EMATCH_IPSET is not set CONFIG_NET_EMATCH_IPT=m CONFIG_NET_CLS_ACT=y CONFIG_NET_ACT_POLICE=m CONFIG_NET_ACT_GACT=m CONFIG_GACT_PROB=y CONFIG_NET_ACT_MIRRED=m # CONFIG_NET_ACT_SAMPLE is not set CONFIG_NET_ACT_IPT=m CONFIG_NET_ACT_NAT=m CONFIG_NET_ACT_PEDIT=m CONFIG_NET_ACT_SIMP=m CONFIG_NET_ACT_SKBEDIT=m CONFIG_NET_ACT_CSUM=m CONFIG_NET_ACT_VLAN=m CONFIG_NET_ACT_BPF=m CONFIG_NET_ACT_CONNMARK=m # CONFIG_NET_ACT_SKBMOD is not set # CONFIG_NET_ACT_IFE is not set # CONFIG_NET_ACT_TUNNEL_KEY is not set CONFIG_NET_CLS_IND=y CONFIG_NET_SCH_FIFO=y CONFIG_DCB=y CONFIG_DNS_RESOLVER=y CONFIG_BATMAN_ADV=m CONFIG_BATMAN_ADV_BATMAN_V=y CONFIG_BATMAN_ADV_BLA=y CONFIG_BATMAN_ADV_DAT=y CONFIG_BATMAN_ADV_NC=y CONFIG_BATMAN_ADV_MCAST=y # CONFIG_BATMAN_ADV_DEBUGFS is not set # CONFIG_BATMAN_ADV_DEBUG is not set # CONFIG_BATMAN_ADV_TRACING is not set CONFIG_OPENVSWITCH=m CONFIG_OPENVSWITCH_GRE=m CONFIG_OPENVSWITCH_VXLAN=m CONFIG_VSOCKETS=m CONFIG_VSOCKETS_DIAG=m # CONFIG_VIRTIO_VSOCKETS is not set CONFIG_NETLINK_DIAG=m CONFIG_MPLS=y CONFIG_NET_MPLS_GSO=m CONFIG_MPLS_ROUTING=m CONFIG_MPLS_IPTUNNEL=m CONFIG_NET_NSH=m CONFIG_HSR=m CONFIG_NET_SWITCHDEV=y CONFIG_NET_L3_MASTER_DEV=y # CONFIG_NET_NCSI is not set CONFIG_RPS=y CONFIG_RFS_ACCEL=y CONFIG_XPS=y CONFIG_CGROUP_NET_PRIO=y CONFIG_CGROUP_NET_CLASSID=y CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y CONFIG_BPF_JIT=y # CONFIG_BPF_STREAM_PARSER is not set CONFIG_NET_FLOW_LIMIT=y # # Network testing # CONFIG_NET_PKTGEN=m # CONFIG_NET_DROP_MONITOR is not set CONFIG_HAMRADIO=y # # Packet Radio protocols # CONFIG_AX25=m CONFIG_AX25_DAMA_SLAVE=y CONFIG_NETROM=m CONFIG_ROSE=m # # AX.25 network device drivers # CONFIG_MKISS=m CONFIG_6PACK=m CONFIG_BPQETHER=m CONFIG_BAYCOM_SER_FDX=m CONFIG_BAYCOM_SER_HDX=m # CONFIG_BAYCOM_PAR is not set # CONFIG_BAYCOM_EPP is not set CONFIG_YAM=m CONFIG_CAN=m CONFIG_CAN_RAW=m CONFIG_CAN_BCM=m CONFIG_CAN_GW=m # # CAN Device Drivers # CONFIG_CAN_VCAN=m CONFIG_CAN_VXCAN=m CONFIG_CAN_SLCAN=m CONFIG_CAN_DEV=m CONFIG_CAN_CALC_BITTIMING=y CONFIG_CAN_FLEXCAN=m CONFIG_CAN_GRCAN=m CONFIG_CAN_TI_HECC=m CONFIG_CAN_C_CAN=m CONFIG_CAN_C_CAN_PLATFORM=m CONFIG_CAN_C_CAN_PCI=m CONFIG_CAN_CC770=m CONFIG_CAN_CC770_ISA=m CONFIG_CAN_CC770_PLATFORM=m # CONFIG_CAN_IFI_CANFD is not set CONFIG_CAN_M_CAN=m CONFIG_CAN_PEAK_PCIEFD=m CONFIG_CAN_RCAR=m CONFIG_CAN_RCAR_CANFD=m CONFIG_CAN_SJA1000=m CONFIG_CAN_SJA1000_ISA=m CONFIG_CAN_SJA1000_PLATFORM=m CONFIG_CAN_EMS_PCI=m CONFIG_CAN_PEAK_PCI=m CONFIG_CAN_PEAK_PCIEC=y CONFIG_CAN_KVASER_PCI=m CONFIG_CAN_PLX_PCI=m CONFIG_CAN_SOFTING=m # # CAN SPI interfaces # CONFIG_CAN_HI311X=m CONFIG_CAN_MCP251X=m # # CAN USB interfaces # CONFIG_CAN_8DEV_USB=m CONFIG_CAN_EMS_USB=m CONFIG_CAN_ESD_USB2=m CONFIG_CAN_GS_USB=m CONFIG_CAN_KVASER_USB=m # CONFIG_CAN_MCBA_USB is not set CONFIG_CAN_PEAK_USB=m CONFIG_CAN_UCAN=m # CONFIG_CAN_DEBUG_DEVICES is not set CONFIG_BT=y CONFIG_BT_BREDR=y CONFIG_BT_RFCOMM=m CONFIG_BT_RFCOMM_TTY=y CONFIG_BT_BNEP=m CONFIG_BT_BNEP_MC_FILTER=y CONFIG_BT_BNEP_PROTO_FILTER=y CONFIG_BT_HIDP=m CONFIG_BT_HS=y CONFIG_BT_LE=y CONFIG_BT_6LOWPAN=m CONFIG_BT_LEDS=y # CONFIG_BT_SELFTEST is not set CONFIG_BT_DEBUGFS=y # # Bluetooth device drivers # CONFIG_BT_INTEL=m CONFIG_BT_BCM=m CONFIG_BT_RTL=m CONFIG_BT_HCIBTUSB=m # CONFIG_BT_HCIBTUSB_AUTOSUSPEND is not set CONFIG_BT_HCIBTUSB_BCM=y CONFIG_BT_HCIBTUSB_RTL=y CONFIG_BT_HCIBTSDIO=m CONFIG_BT_HCIUART=m CONFIG_BT_HCIUART_H4=y CONFIG_BT_HCIUART_BCSP=y CONFIG_BT_HCIUART_ATH3K=y CONFIG_BT_HCIUART_INTEL=y # CONFIG_BT_HCIUART_AG6XX is not set # CONFIG_BT_HCIUART_MRVL is not set CONFIG_BT_HCIBCM203X=m CONFIG_BT_HCIBPA10X=m CONFIG_BT_HCIBFUSB=m CONFIG_BT_HCIVHCI=m CONFIG_BT_MRVL=m CONFIG_BT_MRVL_SDIO=m CONFIG_BT_ATH3K=m CONFIG_BT_HCIRSI=m CONFIG_AF_RXRPC=m # CONFIG_AF_RXRPC_IPV6 is not set # CONFIG_AF_RXRPC_INJECT_LOSS is not set # CONFIG_AF_RXRPC_DEBUG is not set # CONFIG_RXKAD is not set CONFIG_AF_KCM=m CONFIG_STREAM_PARSER=y CONFIG_FIB_RULES=y CONFIG_WIRELESS=y CONFIG_WIRELESS_EXT=y CONFIG_WEXT_CORE=y CONFIG_WEXT_PROC=y CONFIG_WEXT_SPY=y CONFIG_WEXT_PRIV=y CONFIG_CFG80211=y CONFIG_NL80211_TESTMODE=y # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set CONFIG_CFG80211_CERTIFICATION_ONUS=y CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y CONFIG_CFG80211_EXTRA_REGDB_KEYDIR="" CONFIG_CFG80211_REG_CELLULAR_HINTS=y CONFIG_CFG80211_REG_RELAX_NO_IR=y CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set CONFIG_CFG80211_CRDA_SUPPORT=y CONFIG_CFG80211_WEXT=y CONFIG_CFG80211_WEXT_EXPORT=y CONFIG_LIB80211=m CONFIG_LIB80211_CRYPT_WEP=m CONFIG_LIB80211_CRYPT_CCMP=m CONFIG_LIB80211_CRYPT_TKIP=m # CONFIG_LIB80211_DEBUG is not set CONFIG_MAC80211=y CONFIG_MAC80211_HAS_RC=y CONFIG_MAC80211_RC_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel_ht" CONFIG_MAC80211_MESH=y CONFIG_MAC80211_LEDS=y # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_MESSAGE_TRACING is not set # CONFIG_MAC80211_DEBUG_MENU is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 CONFIG_WIMAX=y CONFIG_WIMAX_DEBUG_LEVEL=8 CONFIG_RFKILL=y CONFIG_RFKILL_LEDS=y CONFIG_RFKILL_INPUT=y CONFIG_RFKILL_GPIO=y CONFIG_NET_9P=m CONFIG_NET_9P_VIRTIO=m # CONFIG_NET_9P_DEBUG is not set # CONFIG_CAIF is not set CONFIG_CEPH_LIB=m # CONFIG_CEPH_LIB_PRETTYDEBUG is not set CONFIG_CEPH_LIB_USE_DNS_RESOLVER=y CONFIG_NFC=m CONFIG_NFC_DIGITAL=m CONFIG_NFC_NCI=m CONFIG_NFC_NCI_SPI=m CONFIG_NFC_NCI_UART=m CONFIG_NFC_HCI=m CONFIG_NFC_SHDLC=y # # Near Field Communication (NFC) devices # CONFIG_NFC_TRF7970A=m CONFIG_NFC_SIM=m CONFIG_NFC_PORT100=m CONFIG_NFC_FDP=m CONFIG_NFC_FDP_I2C=m CONFIG_NFC_PN544=m CONFIG_NFC_PN544_I2C=m # CONFIG_NFC_PN533_USB is not set # CONFIG_NFC_PN533_I2C is not set CONFIG_NFC_MICROREAD=m CONFIG_NFC_MICROREAD_I2C=m CONFIG_NFC_MRVL=m CONFIG_NFC_MRVL_USB=m CONFIG_NFC_MRVL_UART=m CONFIG_NFC_MRVL_I2C=m CONFIG_NFC_MRVL_SPI=m CONFIG_NFC_ST21NFCA=m CONFIG_NFC_ST21NFCA_I2C=m CONFIG_NFC_ST_NCI=m CONFIG_NFC_ST_NCI_I2C=m CONFIG_NFC_ST_NCI_SPI=m CONFIG_NFC_NXP_NCI=m CONFIG_NFC_NXP_NCI_I2C=m CONFIG_NFC_S3FWRN5=m CONFIG_NFC_S3FWRN5_I2C=m # CONFIG_NFC_ST95HF is not set # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set CONFIG_LWTUNNEL=y CONFIG_LWTUNNEL_BPF=y CONFIG_DST_CACHE=y CONFIG_GRO_CELLS=y # CONFIG_NET_DEVLINK is not set CONFIG_FAILOVER=y CONFIG_HAVE_EBPF_JIT=y # # Device Drivers # CONFIG_HAVE_PCI=y CONFIG_PCI=y CONFIG_PCI_DOMAINS=y CONFIG_PCI_DOMAINS_GENERIC=y CONFIG_PCI_SYSCALL=y CONFIG_PCIEPORTBUS=y CONFIG_PCIEAER=y # CONFIG_PCIEAER_INJECT is not set # CONFIG_PCIE_ECRC is not set CONFIG_PCIEASPM=y # CONFIG_PCIEASPM_DEBUG is not set CONFIG_PCIEASPM_DEFAULT=y # CONFIG_PCIEASPM_POWERSAVE is not set # CONFIG_PCIEASPM_POWER_SUPERSAVE is not set # CONFIG_PCIEASPM_PERFORMANCE is not set CONFIG_PCIE_PME=y # CONFIG_PCIE_DPC is not set # CONFIG_PCIE_PTM is not set # CONFIG_PCIE_BW is not set CONFIG_PCI_MSI=y CONFIG_PCI_MSI_IRQ_DOMAIN=y CONFIG_PCI_QUIRKS=y # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_STUB is not set CONFIG_PCI_ECAM=y # CONFIG_PCI_IOV is not set # CONFIG_PCI_PRI is not set # CONFIG_PCI_PASID is not set CONFIG_PCI_LABEL=y # CONFIG_HOTPLUG_PCI is not set # # PCI controller drivers # # # Cadence PCIe controllers support # # CONFIG_PCIE_CADENCE_HOST is not set # CONFIG_PCIE_CADENCE_EP is not set # CONFIG_PCI_FTPCI100 is not set CONFIG_PCI_HOST_COMMON=y CONFIG_PCI_HOST_GENERIC=y # CONFIG_PCIE_XILINX is not set # CONFIG_PCI_V3_SEMI is not set # CONFIG_PCIE_ALTERA is not set CONFIG_PCIE_MEDIATEK=y # # DesignWare PCI Core Support # # CONFIG_PCIE_DW_PLAT_HOST is not set # CONFIG_PCIE_DW_PLAT_EP is not set # CONFIG_PCI_LAYERSCAPE is not set # CONFIG_PCI_MESON is not set # # PCI Endpoint # CONFIG_PCI_ENDPOINT=y CONFIG_PCI_ENDPOINT_CONFIGFS=y CONFIG_PCI_EPF_TEST=m # # PCI switch controller drivers # # CONFIG_PCI_SW_SWITCHTEC is not set # CONFIG_PCCARD is not set # CONFIG_RAPIDIO is not set # # Generic Driver Options # CONFIG_UEVENT_HELPER=y CONFIG_UEVENT_HELPER_PATH="" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y # # Firmware loader # CONFIG_FW_LOADER=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER is not set CONFIG_WANT_DEV_COREDUMP=y CONFIG_ALLOW_DEV_COREDUMP=y CONFIG_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_GENERIC_CPU_AUTOPROBE=y CONFIG_SOC_BUS=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set CONFIG_GENERIC_ARCH_TOPOLOGY=y # # Bus devices # # CONFIG_BRCMSTB_GISB_ARB is not set # CONFIG_SIMPLE_PM_BUS is not set CONFIG_VEXPRESS_CONFIG=y # CONFIG_CONNECTOR is not set CONFIG_GNSS=m CONFIG_MTD=y # CONFIG_MTD_TESTS is not set CONFIG_MTD_CMDLINE_PARTS=y # CONFIG_MTD_AFS_PARTS is not set CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AR7_PARTS is not set # # Partition parsers # # CONFIG_MTD_REDBOOT_PARTS is not set # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_SWAP is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # # CONFIG_MTD_CFI is not set # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set # CONFIG_MTD_DATAFLASH is not set CONFIG_MTD_M25P80=y # CONFIG_MTD_MCHP23K256 is not set # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set # CONFIG_MTD_ONENAND is not set CONFIG_MTD_NAND_ECC=y # CONFIG_MTD_NAND_ECC_SMC is not set CONFIG_MTD_NAND=y # CONFIG_MTD_NAND_ECC_BCH is not set CONFIG_MTD_NAND_DENALI=y # CONFIG_MTD_NAND_DENALI_PCI is not set CONFIG_MTD_NAND_DENALI_DT=y # CONFIG_MTD_NAND_GPIO is not set # CONFIG_MTD_NAND_RICOH is not set # CONFIG_MTD_NAND_DISKONCHIP is not set # CONFIG_MTD_NAND_CAFE is not set # CONFIG_MTD_NAND_NANDSIM is not set CONFIG_MTD_NAND_BRCMNAND=y # CONFIG_MTD_NAND_PLATFORM is not set # CONFIG_MTD_NAND_MTK is not set # CONFIG_MTD_SPI_NAND is not set # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # CONFIG_MTD_LPDDR2_NVM is not set CONFIG_MTD_SPI_NOR=y CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y # CONFIG_SPI_CADENCE_QUADSPI is not set # CONFIG_SPI_MTK_QUADSPI is not set CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=20 # CONFIG_MTD_UBI_FASTMAP is not set # CONFIG_MTD_UBI_GLUEBI is not set # CONFIG_MTD_UBI_BLOCK is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_KOBJ=y CONFIG_OF_DYNAMIC=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_NET=y CONFIG_OF_MDIO=y CONFIG_OF_RESERVED_MEM=y CONFIG_OF_RESOLVE=y CONFIG_OF_OVERLAY=y CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y CONFIG_PARPORT=m # CONFIG_PARPORT_PC is not set CONFIG_PARPORT_AX88796=m # CONFIG_PARPORT_1284 is not set CONFIG_PARPORT_NOT_PC=y CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set CONFIG_CDROM=y # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set CONFIG_ZRAM=m # CONFIG_ZRAM_WRITEBACK is not set # CONFIG_ZRAM_MEMORY_TRACKING is not set # CONFIG_BLK_DEV_UMEM is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 CONFIG_BLK_DEV_CRYPTOLOOP=m # CONFIG_BLK_DEV_DRBD is not set CONFIG_BLK_DEV_NBD=m # CONFIG_BLK_DEV_SX8 is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=4 CONFIG_BLK_DEV_RAM_SIZE=4096 # CONFIG_CDROM_PKTCDVD is not set CONFIG_ATA_OVER_ETH=m CONFIG_VIRTIO_BLK=m # CONFIG_VIRTIO_BLK_SCSI is not set CONFIG_BLK_DEV_RBD=m # CONFIG_BLK_DEV_RSXX is not set # # NVME Support # CONFIG_NVME_CORE=y CONFIG_BLK_DEV_NVME=y # CONFIG_NVME_MULTIPATH is not set # CONFIG_NVME_FC is not set # CONFIG_NVME_TCP is not set # CONFIG_NVME_TARGET is not set # # Misc devices # CONFIG_AD525X_DPOT=y CONFIG_AD525X_DPOT_I2C=y # CONFIG_AD525X_DPOT_SPI is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_PHANTOM is not set # CONFIG_SGI_IOC4 is not set # CONFIG_TIFM_CORE is not set CONFIG_ICS932S401=y # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HP_ILO is not set CONFIG_APDS9802ALS=y CONFIG_ISL29003=y # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_USB_SWITCH_FSA9480 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set CONFIG_SRAM=y CONFIG_SRAM_EXEC=y CONFIG_VEXPRESS_SYSCFG=y CONFIG_PCI_ENDPOINT_TEST=m # CONFIG_PVPANIC is not set # CONFIG_C2PORT is not set # # EEPROM support # CONFIG_EEPROM_AT24=y # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set CONFIG_EEPROM_93CX6=y # CONFIG_EEPROM_93XX46 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # CONFIG_EEPROM_EE1004 is not set # CONFIG_CB710_CORE is not set # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # CONFIG_ALTERA_STAPL is not set # # Intel MIC & related support # # # Intel MIC Bus Driver # # # SCIF Bus Driver # # # VOP Bus Driver # # CONFIG_VOP_BUS is not set # # Intel MIC Host Driver # # # Intel MIC Card Driver # # # SCIF Driver # # # Intel MIC Coprocessor State Management (COSM) Drivers # # # VOP Driver # # CONFIG_ECHO is not set # CONFIG_MISC_ALCOR_PCI is not set # CONFIG_MISC_RTSX_PCI is not set # CONFIG_MISC_RTSX_USB is not set # CONFIG_HABANA_AI is not set CONFIG_HAVE_IDE=y CONFIG_IDE=y # # Please see Documentation/ide/ide.txt for help/info on IDE drives # # CONFIG_BLK_DEV_IDE_SATA is not set CONFIG_IDE_GD=y CONFIG_IDE_GD_ATA=y # CONFIG_IDE_GD_ATAPI is not set # CONFIG_BLK_DEV_IDECD is not set # CONFIG_BLK_DEV_IDETAPE is not set # CONFIG_IDE_TASK_IOCTL is not set CONFIG_IDE_PROC_FS=y # # IDE chipset support/bugfixes # # CONFIG_BLK_DEV_PLATFORM is not set # # PCI IDE chipsets support # # CONFIG_BLK_DEV_GENERIC is not set # CONFIG_BLK_DEV_OPTI621 is not set # CONFIG_BLK_DEV_AEC62XX is not set # CONFIG_BLK_DEV_ALI15X3 is not set # CONFIG_BLK_DEV_CMD64X is not set # CONFIG_BLK_DEV_TRIFLEX is not set # CONFIG_BLK_DEV_HPT366 is not set # CONFIG_BLK_DEV_JMICRON is not set # CONFIG_BLK_DEV_PIIX is not set # CONFIG_BLK_DEV_IT8172 is not set # CONFIG_BLK_DEV_IT8213 is not set # CONFIG_BLK_DEV_IT821X is not set # CONFIG_BLK_DEV_NS87415 is not set # CONFIG_BLK_DEV_PDC202XX_OLD is not set # CONFIG_BLK_DEV_PDC202XX_NEW is not set # CONFIG_BLK_DEV_SVWKS is not set # CONFIG_BLK_DEV_SIIMAGE is not set # CONFIG_BLK_DEV_SL82C105 is not set # CONFIG_BLK_DEV_SLC90E66 is not set # CONFIG_BLK_DEV_TRM290 is not set # CONFIG_BLK_DEV_VIA82CXXX is not set # CONFIG_BLK_DEV_TC86C001 is not set # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_DMA=y CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set CONFIG_BLK_DEV_SR=y # CONFIG_BLK_DEV_SR_VENDOR is not set # CONFIG_CHR_DEV_SG is not set # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # CONFIG_SCSI_SPI_ATTRS=m # CONFIG_SCSI_FC_ATTRS is not set CONFIG_SCSI_ISCSI_ATTRS=m CONFIG_SCSI_SAS_ATTRS=m CONFIG_SCSI_SAS_LIBSAS=m CONFIG_SCSI_SAS_ATA=y CONFIG_SCSI_SAS_HOST_SMP=y # CONFIG_SCSI_SRP_ATTRS is not set CONFIG_SCSI_LOWLEVEL=y CONFIG_ISCSI_TCP=m CONFIG_ISCSI_BOOT_SYSFS=m # CONFIG_SCSI_CXGB3_ISCSI is not set # CONFIG_SCSI_CXGB4_ISCSI is not set # CONFIG_SCSI_BNX2_ISCSI is not set # CONFIG_BE2ISCSI is not set # CONFIG_BLK_DEV_3W_XXXX_RAID is not set # CONFIG_SCSI_HPSA is not set # CONFIG_SCSI_3W_9XXX is not set # CONFIG_SCSI_3W_SAS is not set # CONFIG_SCSI_ACARD is not set # CONFIG_SCSI_AACRAID is not set # CONFIG_SCSI_AIC7XXX is not set # CONFIG_SCSI_AIC79XX is not set # CONFIG_SCSI_AIC94XX is not set CONFIG_SCSI_MVSAS=m # CONFIG_SCSI_MVSAS_DEBUG is not set CONFIG_SCSI_MVSAS_TASKLET=y CONFIG_SCSI_MVUMI=m # CONFIG_SCSI_ADVANSYS is not set # CONFIG_SCSI_ARCMSR is not set # CONFIG_SCSI_ESAS2R is not set # CONFIG_MEGARAID_NEWGEN is not set # CONFIG_MEGARAID_LEGACY is not set # CONFIG_MEGARAID_SAS is not set # CONFIG_SCSI_MPT3SAS is not set # CONFIG_SCSI_MPT2SAS is not set # CONFIG_SCSI_SMARTPQI is not set # CONFIG_SCSI_UFSHCD is not set # CONFIG_SCSI_HPTIOP is not set # CONFIG_SCSI_MYRB is not set # CONFIG_SCSI_MYRS is not set # CONFIG_SCSI_SNIC is not set # CONFIG_SCSI_DMX3191D is not set # CONFIG_SCSI_GDTH is not set # CONFIG_SCSI_IPS is not set # CONFIG_SCSI_INITIO is not set # CONFIG_SCSI_INIA100 is not set # CONFIG_SCSI_STEX is not set # CONFIG_SCSI_SYM53C8XX_2 is not set # CONFIG_SCSI_IPR is not set # CONFIG_SCSI_QLOGIC_1280 is not set # CONFIG_SCSI_QLA_ISCSI is not set # CONFIG_SCSI_DC395x is not set # CONFIG_SCSI_AM53C974 is not set # CONFIG_SCSI_NSP32 is not set # CONFIG_SCSI_WD719X is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_PMCRAID is not set # CONFIG_SCSI_PM8001 is not set CONFIG_SCSI_VIRTIO=m # CONFIG_SCSI_DH is not set CONFIG_ATA=y # CONFIG_ATA_VERBOSE_ERROR is not set CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # CONFIG_SATA_AHCI=y CONFIG_SATA_MOBILE_LPM_POLICY=0 CONFIG_SATA_AHCI_PLATFORM=y # CONFIG_AHCI_CEVA is not set CONFIG_AHCI_MTK=m # CONFIG_AHCI_QORIQ is not set # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_ACARD_AHCI is not set # CONFIG_SATA_SIL24 is not set CONFIG_ATA_SFF=y # # SFF controllers with custom DMA interface # # CONFIG_PDC_ADMA is not set # CONFIG_SATA_QSTOR is not set # CONFIG_SATA_SX4 is not set CONFIG_ATA_BMDMA=y # # SATA SFF controllers with BMDMA # # CONFIG_ATA_PIIX is not set # CONFIG_SATA_DWC is not set # CONFIG_SATA_MV is not set # CONFIG_SATA_NV is not set # CONFIG_SATA_PROMISE is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIS is not set # CONFIG_SATA_SVW is not set # CONFIG_SATA_ULI is not set # CONFIG_SATA_VIA is not set # CONFIG_SATA_VITESSE is not set # # PATA SFF controllers with BMDMA # # CONFIG_PATA_ALI is not set # CONFIG_PATA_AMD is not set # CONFIG_PATA_ARTOP is not set # CONFIG_PATA_ATIIXP is not set # CONFIG_PATA_ATP867X is not set # CONFIG_PATA_CMD64X is not set # CONFIG_PATA_CYPRESS is not set # CONFIG_PATA_EFAR is not set # CONFIG_PATA_HPT366 is not set # CONFIG_PATA_HPT37X is not set # CONFIG_PATA_HPT3X2N is not set # CONFIG_PATA_HPT3X3 is not set # CONFIG_PATA_IT8213 is not set # CONFIG_PATA_IT821X is not set # CONFIG_PATA_JMICRON is not set # CONFIG_PATA_MARVELL is not set # CONFIG_PATA_NETCELL is not set # CONFIG_PATA_NINJA32 is not set # CONFIG_PATA_NS87415 is not set # CONFIG_PATA_OLDPIIX is not set # CONFIG_PATA_OPTIDMA is not set # CONFIG_PATA_PDC2027X is not set # CONFIG_PATA_PDC_OLD is not set # CONFIG_PATA_RADISYS is not set # CONFIG_PATA_RDC is not set # CONFIG_PATA_SCH is not set # CONFIG_PATA_SERVERWORKS is not set # CONFIG_PATA_SIL680 is not set # CONFIG_PATA_SIS is not set # CONFIG_PATA_TOSHIBA is not set # CONFIG_PATA_TRIFLEX is not set # CONFIG_PATA_VIA is not set # CONFIG_PATA_WINBOND is not set # # PIO-only SFF controllers # # CONFIG_PATA_CMD640_PCI is not set # CONFIG_PATA_MPIIX is not set # CONFIG_PATA_NS87410 is not set # CONFIG_PATA_OPTI is not set # CONFIG_PATA_PLATFORM is not set # CONFIG_PATA_RZ1000 is not set # # Generic fallback / legacy drivers # # CONFIG_ATA_GENERIC is not set # CONFIG_PATA_LEGACY is not set CONFIG_MD=y CONFIG_BLK_DEV_MD=y CONFIG_MD_AUTODETECT=y # CONFIG_MD_LINEAR is not set CONFIG_MD_RAID0=y CONFIG_MD_RAID1=y CONFIG_MD_RAID10=y CONFIG_MD_RAID456=y # CONFIG_MD_MULTIPATH is not set # CONFIG_MD_FAULTY is not set # CONFIG_BCACHE is not set CONFIG_BLK_DEV_DM_BUILTIN=y CONFIG_BLK_DEV_DM=y # CONFIG_DM_DEBUG is not set CONFIG_DM_BUFIO=y # CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set CONFIG_DM_BIO_PRISON=m CONFIG_DM_PERSISTENT_DATA=m # CONFIG_DM_UNSTRIPED is not set CONFIG_DM_CRYPT=y CONFIG_DM_SNAPSHOT=y CONFIG_DM_THIN_PROVISIONING=m # CONFIG_DM_CACHE is not set # CONFIG_DM_WRITECACHE is not set # CONFIG_DM_ERA is not set CONFIG_DM_MIRROR=y # CONFIG_DM_LOG_USERSPACE is not set CONFIG_DM_RAID=y # CONFIG_DM_ZERO is not set CONFIG_DM_MULTIPATH=y CONFIG_DM_MULTIPATH_QL=y CONFIG_DM_MULTIPATH_ST=y # CONFIG_DM_DELAY is not set # CONFIG_DM_INIT is not set # CONFIG_DM_UEVENT is not set # CONFIG_DM_FLAKEY is not set # CONFIG_DM_VERITY is not set # CONFIG_DM_SWITCH is not set # CONFIG_DM_LOG_WRITES is not set # CONFIG_DM_INTEGRITY is not set # CONFIG_TARGET_CORE is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set CONFIG_NETDEVICES=y CONFIG_MII=m CONFIG_NET_CORE=y CONFIG_BONDING=m CONFIG_DUMMY=m # CONFIG_EQUALIZER is not set # CONFIG_NET_FC is not set CONFIG_IFB=m CONFIG_NET_TEAM=m # CONFIG_NET_TEAM_MODE_BROADCAST is not set # CONFIG_NET_TEAM_MODE_ROUNDROBIN is not set # CONFIG_NET_TEAM_MODE_RANDOM is not set # CONFIG_NET_TEAM_MODE_ACTIVEBACKUP is not set # CONFIG_NET_TEAM_MODE_LOADBALANCE is not set CONFIG_MACVLAN=m CONFIG_MACVTAP=m CONFIG_IPVLAN_L3S=y CONFIG_IPVLAN=m CONFIG_IPVTAP=m CONFIG_VXLAN=m # CONFIG_GENEVE is not set # CONFIG_GTP is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set CONFIG_TUN=m CONFIG_TAP=m # CONFIG_TUN_VNET_CROSS_LE is not set CONFIG_VETH=y CONFIG_VIRTIO_NET=y # CONFIG_NLMON is not set CONFIG_NET_VRF=m # CONFIG_ARCNET is not set CONFIG_ATM_DRIVERS=y # CONFIG_ATM_DUMMY is not set # CONFIG_ATM_TCP is not set # CONFIG_ATM_LANAI is not set # CONFIG_ATM_ENI is not set # CONFIG_ATM_NICSTAR is not set # CONFIG_ATM_IDT77252 is not set # CONFIG_ATM_IA is not set # CONFIG_ATM_FORE200E is not set # CONFIG_ATM_HE is not set # CONFIG_ATM_SOLOS is not set # # CAIF transport drivers # # # Distributed Switch Architecture drivers # # CONFIG_B53 is not set # CONFIG_NET_DSA_BCM_SF2 is not set # CONFIG_NET_DSA_LOOP is not set # CONFIG_NET_DSA_LANTIQ_GSWIP is not set CONFIG_NET_DSA_MT7530=m # CONFIG_NET_DSA_MV88E6060 is not set # CONFIG_NET_DSA_MICROCHIP_KSZ9477 is not set # CONFIG_NET_DSA_MV88E6XXX is not set # CONFIG_NET_DSA_QCA8K is not set # CONFIG_NET_DSA_REALTEK_SMI is not set # CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set # CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set # CONFIG_NET_DSA_VITESSE_VSC73XX is not set CONFIG_ETHERNET=y # CONFIG_NET_VENDOR_3COM is not set # CONFIG_NET_VENDOR_ADAPTEC is not set # CONFIG_NET_VENDOR_AGERE is not set # CONFIG_NET_VENDOR_ALACRITECH is not set # CONFIG_NET_VENDOR_ALTEON is not set # CONFIG_ALTERA_TSE is not set # CONFIG_NET_VENDOR_AMAZON is not set # CONFIG_NET_VENDOR_AMD is not set # CONFIG_NET_VENDOR_AQUANTIA is not set # CONFIG_NET_VENDOR_ARC is not set # CONFIG_NET_VENDOR_ATHEROS is not set # CONFIG_NET_VENDOR_AURORA is not set # CONFIG_NET_VENDOR_BROADCOM is not set # CONFIG_NET_VENDOR_BROCADE is not set CONFIG_NET_VENDOR_CADENCE=y # CONFIG_MACB is not set # CONFIG_NET_VENDOR_CAVIUM is not set # CONFIG_NET_VENDOR_CHELSIO is not set # CONFIG_NET_VENDOR_CIRRUS is not set # CONFIG_NET_VENDOR_CISCO is not set CONFIG_NET_VENDOR_CORTINA=y CONFIG_GEMINI_ETHERNET=m # CONFIG_DM9000 is not set # CONFIG_DNET is not set # CONFIG_NET_VENDOR_DEC is not set # CONFIG_NET_VENDOR_DLINK is not set # CONFIG_NET_VENDOR_EMULEX is not set # CONFIG_NET_VENDOR_EZCHIP is not set # CONFIG_NET_VENDOR_FARADAY is not set # CONFIG_NET_VENDOR_HISILICON is not set # CONFIG_NET_VENDOR_HP is not set # CONFIG_NET_VENDOR_HUAWEI is not set # CONFIG_NET_VENDOR_INTEL is not set # CONFIG_JME is not set # CONFIG_NET_VENDOR_MARVELL is not set CONFIG_NET_VENDOR_MEDIATEK=y CONFIG_NET_MEDIATEK_SOC=y # CONFIG_NET_VENDOR_MELLANOX is not set # CONFIG_NET_VENDOR_MICREL is not set # CONFIG_NET_VENDOR_MICROCHIP is not set CONFIG_NET_VENDOR_MICROSEMI=y CONFIG_MSCC_OCELOT_SWITCH=m # CONFIG_MSCC_OCELOT_SWITCH_OCELOT is not set # CONFIG_NET_VENDOR_MYRI is not set # CONFIG_FEALNX is not set # CONFIG_NET_VENDOR_NATSEMI is not set CONFIG_NET_VENDOR_NETERION=y # CONFIG_S2IO is not set # CONFIG_VXGE is not set # CONFIG_NET_VENDOR_NETRONOME is not set CONFIG_NET_VENDOR_NI=y # CONFIG_NI_XGE_MANAGEMENT_ENET is not set # CONFIG_NET_VENDOR_NVIDIA is not set # CONFIG_NET_VENDOR_OKI is not set # CONFIG_ETHOC is not set CONFIG_NET_VENDOR_PACKET_ENGINES=y # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set # CONFIG_NET_VENDOR_QLOGIC is not set # CONFIG_NET_VENDOR_QUALCOMM is not set # CONFIG_NET_VENDOR_RDC is not set # CONFIG_NET_VENDOR_REALTEK is not set # CONFIG_NET_VENDOR_RENESAS is not set # CONFIG_NET_VENDOR_ROCKER is not set # CONFIG_NET_VENDOR_SAMSUNG is not set # CONFIG_NET_VENDOR_SEEQ is not set # CONFIG_NET_VENDOR_SOLARFLARE is not set # CONFIG_NET_VENDOR_SILAN is not set # CONFIG_NET_VENDOR_SIS is not set # CONFIG_NET_VENDOR_SMSC is not set CONFIG_NET_VENDOR_SOCIONEXT=y # CONFIG_NET_VENDOR_STMICRO is not set # CONFIG_NET_VENDOR_SUN is not set # CONFIG_NET_VENDOR_SYNOPSYS is not set # CONFIG_NET_VENDOR_TEHUTI is not set # CONFIG_NET_VENDOR_TI is not set # CONFIG_NET_VENDOR_VIA is not set # CONFIG_NET_VENDOR_WIZNET is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set CONFIG_MDIO_DEVICE=y CONFIG_MDIO_BUS=y CONFIG_MDIO_BCM_UNIMAC=m # CONFIG_MDIO_BITBANG is not set # CONFIG_MDIO_BUS_MUX_GPIO is not set # CONFIG_MDIO_BUS_MUX_MMIOREG is not set # CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set # CONFIG_MDIO_HISI_FEMAC is not set # CONFIG_MDIO_MSCC_MIIM is not set CONFIG_PHYLINK=m CONFIG_PHYLIB=y CONFIG_SWPHY=y # CONFIG_LED_TRIGGER_PHY is not set # # MII PHY device drivers # # CONFIG_SFP is not set # CONFIG_AMD_PHY is not set # CONFIG_AQUANTIA_PHY is not set # CONFIG_ASIX_PHY is not set # CONFIG_AT803X_PHY is not set # CONFIG_BCM7XXX_PHY is not set # CONFIG_BCM87XX_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_CORTINA_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_DP83822_PHY is not set # CONFIG_DP83TC811_PHY is not set # CONFIG_DP83848_PHY is not set # CONFIG_DP83867_PHY is not set CONFIG_FIXED_PHY=y CONFIG_ICPLUS_PHY=y # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_MARVELL_PHY is not set # CONFIG_MARVELL_10G_PHY is not set # CONFIG_MICREL_PHY is not set CONFIG_MICROCHIP_PHY=m # CONFIG_MICROCHIP_T1_PHY is not set # CONFIG_MICROSEMI_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_QSEMI_PHY is not set # CONFIG_REALTEK_PHY is not set # CONFIG_RENESAS_PHY is not set # CONFIG_ROCKCHIP_PHY is not set # CONFIG_SMSC_PHY is not set # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_XILINX_GMII2RGMII is not set CONFIG_MICREL_KS8995MA=m CONFIG_PLIP=m CONFIG_PPP=m CONFIG_PPP_BSDCOMP=m CONFIG_PPP_DEFLATE=m CONFIG_PPP_FILTER=y CONFIG_PPP_MPPE=m CONFIG_PPP_MULTILINK=y CONFIG_PPPOATM=m CONFIG_PPPOE=m CONFIG_PPTP=m CONFIG_PPPOL2TP=m CONFIG_PPP_ASYNC=m CONFIG_PPP_SYNC_TTY=m CONFIG_SLIP=m CONFIG_SLHC=m CONFIG_SLIP_COMPRESSED=y CONFIG_SLIP_SMART=y CONFIG_SLIP_MODE_SLIP6=y CONFIG_USB_NET_DRIVERS=y CONFIG_USB_CATC=m CONFIG_USB_KAWETH=m CONFIG_USB_PEGASUS=m CONFIG_USB_RTL8150=m CONFIG_USB_RTL8152=m CONFIG_USB_LAN78XX=m CONFIG_USB_USBNET=m CONFIG_USB_NET_AX8817X=m CONFIG_USB_NET_AX88179_178A=m CONFIG_USB_NET_CDCETHER=m CONFIG_USB_NET_CDC_EEM=m CONFIG_USB_NET_CDC_NCM=m CONFIG_USB_NET_HUAWEI_CDC_NCM=m CONFIG_USB_NET_CDC_MBIM=m CONFIG_USB_NET_DM9601=m CONFIG_USB_NET_SR9700=m CONFIG_USB_NET_SR9800=m CONFIG_USB_NET_SMSC75XX=m CONFIG_USB_NET_SMSC95XX=m CONFIG_USB_NET_GL620A=m CONFIG_USB_NET_NET1080=m CONFIG_USB_NET_PLUSB=m CONFIG_USB_NET_MCS7830=m CONFIG_USB_NET_RNDIS_HOST=m CONFIG_USB_NET_CDC_SUBSET_ENABLE=m CONFIG_USB_NET_CDC_SUBSET=m CONFIG_USB_ALI_M5632=y CONFIG_USB_AN2720=y CONFIG_USB_BELKIN=y CONFIG_USB_ARMLINUX=y CONFIG_USB_EPSON2888=y CONFIG_USB_KC2190=y CONFIG_USB_NET_ZAURUS=m CONFIG_USB_NET_CX82310_ETH=m CONFIG_USB_NET_KALMIA=m CONFIG_USB_NET_QMI_WWAN=m CONFIG_USB_HSO=m CONFIG_USB_NET_INT51X1=m CONFIG_USB_IPHETH=m CONFIG_USB_SIERRA_NET=m CONFIG_USB_VL600=m CONFIG_USB_NET_CH9200=m # CONFIG_USB_NET_AQC111 is not set CONFIG_WLAN=y # CONFIG_WIRELESS_WDS is not set CONFIG_WLAN_VENDOR_ADMTEK=y CONFIG_ADM8211=m CONFIG_ATH_COMMON=m CONFIG_WLAN_VENDOR_ATH=y # CONFIG_ATH_DEBUG is not set CONFIG_ATH_REG_DYNAMIC_USER_REG_HINTS=y # CONFIG_ATH_REG_DYNAMIC_USER_CERT_TESTING is not set CONFIG_ATH5K=m # CONFIG_ATH5K_DEBUG is not set # CONFIG_ATH5K_TRACER is not set CONFIG_ATH5K_PCI=y # CONFIG_ATH5K_TEST_CHANNELS is not set CONFIG_ATH9K_HW=m CONFIG_ATH9K_COMMON=m CONFIG_ATH9K_BTCOEX_SUPPORT=y CONFIG_ATH9K=m CONFIG_ATH9K_PCI=y CONFIG_ATH9K_AHB=y # CONFIG_ATH9K_DEBUGFS is not set CONFIG_ATH9K_DFS_CERTIFIED=y CONFIG_ATH9K_DYNACK=y CONFIG_ATH9K_WOW=y CONFIG_ATH9K_RFKILL=y CONFIG_ATH9K_CHANNEL_CONTEXT=y CONFIG_ATH9K_PCOEM=y CONFIG_ATH9K_HTC=m # CONFIG_ATH9K_HTC_DEBUGFS is not set # CONFIG_ATH9K_HWRNG is not set CONFIG_CARL9170=m CONFIG_CARL9170_LEDS=y CONFIG_CARL9170_WPC=y CONFIG_CARL9170_HWRNG=y CONFIG_ATH6KL=m CONFIG_ATH6KL_SDIO=m CONFIG_ATH6KL_USB=m # CONFIG_ATH6KL_DEBUG is not set # CONFIG_ATH6KL_TRACING is not set CONFIG_ATH6KL_REGDOMAIN=y CONFIG_AR5523=m CONFIG_WIL6210=m CONFIG_WIL6210_ISR_COR=y # CONFIG_WIL6210_TRACING is not set CONFIG_WIL6210_DEBUGFS=y CONFIG_ATH10K=m CONFIG_ATH10K_CE=y CONFIG_ATH10K_PCI=m # CONFIG_ATH10K_AHB is not set CONFIG_ATH10K_SDIO=m # CONFIG_ATH10K_USB is not set # CONFIG_ATH10K_DEBUG is not set # CONFIG_ATH10K_DEBUGFS is not set # CONFIG_ATH10K_TRACING is not set CONFIG_ATH10K_DFS_CERTIFIED=y CONFIG_WCN36XX=m # CONFIG_WCN36XX_DEBUGFS is not set CONFIG_WLAN_VENDOR_ATMEL=y CONFIG_ATMEL=m CONFIG_PCI_ATMEL=m CONFIG_AT76C50X_USB=m CONFIG_WLAN_VENDOR_BROADCOM=y CONFIG_B43=m CONFIG_B43_BCMA=y CONFIG_B43_SSB=y CONFIG_B43_BUSES_BCMA_AND_SSB=y # CONFIG_B43_BUSES_BCMA is not set # CONFIG_B43_BUSES_SSB is not set CONFIG_B43_PCI_AUTOSELECT=y CONFIG_B43_PCICORE_AUTOSELECT=y CONFIG_B43_SDIO=y CONFIG_B43_BCMA_PIO=y CONFIG_B43_PIO=y CONFIG_B43_PHY_G=y CONFIG_B43_PHY_N=y CONFIG_B43_PHY_LP=y CONFIG_B43_PHY_HT=y CONFIG_B43_LEDS=y CONFIG_B43_HWRNG=y # CONFIG_B43_DEBUG is not set CONFIG_B43LEGACY=m CONFIG_B43LEGACY_PCI_AUTOSELECT=y CONFIG_B43LEGACY_PCICORE_AUTOSELECT=y CONFIG_B43LEGACY_LEDS=y CONFIG_B43LEGACY_HWRNG=y # CONFIG_B43LEGACY_DEBUG is not set CONFIG_B43LEGACY_DMA=y CONFIG_B43LEGACY_PIO=y CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y # CONFIG_B43LEGACY_DMA_MODE is not set # CONFIG_B43LEGACY_PIO_MODE is not set CONFIG_BRCMUTIL=m # CONFIG_BRCMSMAC is not set CONFIG_BRCMFMAC=m CONFIG_BRCMFMAC_PROTO_BCDC=y CONFIG_BRCMFMAC_PROTO_MSGBUF=y CONFIG_BRCMFMAC_SDIO=y CONFIG_BRCMFMAC_USB=y CONFIG_BRCMFMAC_PCIE=y CONFIG_BRCM_TRACING=y # CONFIG_BRCMDBG is not set CONFIG_WLAN_VENDOR_CISCO=y CONFIG_WLAN_VENDOR_INTEL=y CONFIG_IPW2100=m CONFIG_IPW2100_MONITOR=y # CONFIG_IPW2100_DEBUG is not set CONFIG_IPW2200=m CONFIG_IPW2200_MONITOR=y CONFIG_IPW2200_RADIOTAP=y CONFIG_IPW2200_PROMISCUOUS=y CONFIG_IPW2200_QOS=y # CONFIG_IPW2200_DEBUG is not set CONFIG_LIBIPW=m # CONFIG_LIBIPW_DEBUG is not set CONFIG_IWLEGACY=m CONFIG_IWL4965=m CONFIG_IWL3945=m # # iwl3945 / iwl4965 Debugging Options # # CONFIG_IWLEGACY_DEBUG is not set CONFIG_IWLWIFI=m CONFIG_IWLWIFI_LEDS=y CONFIG_IWLDVM=m CONFIG_IWLMVM=m CONFIG_IWLWIFI_OPMODE_MODULAR=y CONFIG_IWLWIFI_BCAST_FILTERING=y # CONFIG_IWLWIFI_PCIE_RTPM is not set # # Debugging Options # # CONFIG_IWLWIFI_DEBUG is not set CONFIG_IWLWIFI_DEVICE_TRACING=y CONFIG_WLAN_VENDOR_INTERSIL=y # CONFIG_HOSTAP is not set # CONFIG_HERMES is not set # CONFIG_P54_COMMON is not set # CONFIG_PRISM54 is not set CONFIG_WLAN_VENDOR_MARVELL=y CONFIG_LIBERTAS=m CONFIG_LIBERTAS_USB=m CONFIG_LIBERTAS_SDIO=m CONFIG_LIBERTAS_SPI=m # CONFIG_LIBERTAS_DEBUG is not set CONFIG_LIBERTAS_MESH=y CONFIG_LIBERTAS_THINFIRM=m # CONFIG_LIBERTAS_THINFIRM_DEBUG is not set CONFIG_LIBERTAS_THINFIRM_USB=m CONFIG_MWIFIEX=m CONFIG_MWIFIEX_SDIO=m CONFIG_MWIFIEX_PCIE=m CONFIG_MWIFIEX_USB=m CONFIG_MWL8K=m CONFIG_WLAN_VENDOR_MEDIATEK=y CONFIG_MT7601U=m CONFIG_MT76_CORE=m CONFIG_MT76_LEDS=y CONFIG_MT76_USB=m CONFIG_MT76x02_LIB=m CONFIG_MT76x02_USB=m CONFIG_MT76x0_COMMON=m CONFIG_MT76x0U=m # CONFIG_MT76x0E is not set CONFIG_MT76x2_COMMON=m CONFIG_MT76x2E=m CONFIG_MT76x2U=m # CONFIG_MT7603E is not set CONFIG_WLAN_VENDOR_RALINK=y CONFIG_RT2X00=m CONFIG_RT2400PCI=m CONFIG_RT2500PCI=m CONFIG_RT61PCI=m CONFIG_RT2800PCI=m CONFIG_RT2800PCI_RT33XX=y CONFIG_RT2800PCI_RT35XX=y CONFIG_RT2800PCI_RT53XX=y CONFIG_RT2800PCI_RT3290=y CONFIG_RT2500USB=m CONFIG_RT73USB=m CONFIG_RT2800USB=m CONFIG_RT2800USB_RT33XX=y CONFIG_RT2800USB_RT35XX=y CONFIG_RT2800USB_RT3573=y CONFIG_RT2800USB_RT53XX=y CONFIG_RT2800USB_RT55XX=y CONFIG_RT2800USB_UNKNOWN=y CONFIG_RT2800_LIB=m CONFIG_RT2800_LIB_MMIO=m CONFIG_RT2X00_LIB_MMIO=m CONFIG_RT2X00_LIB_PCI=m CONFIG_RT2X00_LIB_USB=m CONFIG_RT2X00_LIB=m CONFIG_RT2X00_LIB_FIRMWARE=y CONFIG_RT2X00_LIB_CRYPTO=y CONFIG_RT2X00_LIB_LEDS=y # CONFIG_RT2X00_DEBUG is not set CONFIG_WLAN_VENDOR_REALTEK=y CONFIG_RTL8180=m CONFIG_RTL8187=m CONFIG_RTL8187_LEDS=y CONFIG_RTL_CARDS=m CONFIG_RTL8192CE=m CONFIG_RTL8192SE=m CONFIG_RTL8192DE=m CONFIG_RTL8723AE=m CONFIG_RTL8723BE=m CONFIG_RTL8188EE=m CONFIG_RTL8192EE=m CONFIG_RTL8821AE=m CONFIG_RTL8192CU=m CONFIG_RTLWIFI=m CONFIG_RTLWIFI_PCI=m CONFIG_RTLWIFI_USB=m # CONFIG_RTLWIFI_DEBUG is not set CONFIG_RTL8192C_COMMON=m CONFIG_RTL8723_COMMON=m CONFIG_RTLBTCOEXIST=m CONFIG_RTL8XXXU=m # CONFIG_RTL8XXXU_UNTESTED is not set CONFIG_WLAN_VENDOR_RSI=y CONFIG_RSI_91X=m # CONFIG_RSI_DEBUGFS is not set CONFIG_RSI_SDIO=m CONFIG_RSI_USB=m CONFIG_RSI_COEX=y CONFIG_WLAN_VENDOR_ST=y CONFIG_CW1200=m CONFIG_CW1200_WLAN_SDIO=m CONFIG_CW1200_WLAN_SPI=m CONFIG_WLAN_VENDOR_TI=y CONFIG_WL1251=m CONFIG_WL1251_SPI=m CONFIG_WL1251_SDIO=m CONFIG_WL12XX=m CONFIG_WL18XX=m CONFIG_WLCORE=m CONFIG_WLCORE_SPI=m CONFIG_WLCORE_SDIO=m CONFIG_WILINK_PLATFORM_DATA=y CONFIG_WLAN_VENDOR_ZYDAS=y CONFIG_USB_ZD1201=m CONFIG_ZD1211RW=m # CONFIG_ZD1211RW_DEBUG is not set CONFIG_WLAN_VENDOR_QUANTENNA=y # CONFIG_QTNFMAC_PCIE is not set CONFIG_MAC80211_HWSIM=m CONFIG_USB_NET_RNDIS_WLAN=m # CONFIG_VIRT_WIFI is not set # # WiMAX Wireless Broadband devices # CONFIG_WIMAX_I2400M=m CONFIG_WIMAX_I2400M_USB=m CONFIG_WIMAX_I2400M_DEBUG_LEVEL=8 # CONFIG_WAN is not set # CONFIG_IEEE802154_DRIVERS is not set # CONFIG_VMXNET3 is not set CONFIG_NETDEVSIM=m CONFIG_NET_FAILOVER=y # CONFIG_ISDN is not set CONFIG_NVM=y CONFIG_NVM_PBLK=m # CONFIG_NVM_PBLK_DEBUG is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_LEDS=y CONFIG_INPUT_FF_MEMLESS=m CONFIG_INPUT_POLLDEV=m # CONFIG_INPUT_SPARSEKMAP is not set CONFIG_INPUT_MATRIXKMAP=y # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=m # CONFIG_INPUT_MOUSEDEV_PSAUX is not set CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=m # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADC is not set # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=m # CONFIG_KEYBOARD_QT1070 is not set # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_DLINK_DIR685 is not set # CONFIG_KEYBOARD_LKKBD is not set CONFIG_KEYBOARD_GPIO=m # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set # CONFIG_KEYBOARD_MATRIX is not set # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set CONFIG_KEYBOARD_SAMSUNG=m # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set # CONFIG_KEYBOARD_TWL4030 is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set # CONFIG_KEYBOARD_MTK_PMIC is not set CONFIG_INPUT_MOUSE=y # CONFIG_MOUSE_PS2 is not set # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_APPLETOUCH is not set # CONFIG_MOUSE_BCM5974 is not set # CONFIG_MOUSE_CYAPA is not set # CONFIG_MOUSE_ELAN_I2C is not set # CONFIG_MOUSE_VSXXXAA is not set CONFIG_MOUSE_GPIO=m # CONFIG_MOUSE_SYNAPTICS_I2C is not set CONFIG_MOUSE_SYNAPTICS_USB=m # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set # CONFIG_INPUT_TOUCHSCREEN is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATMEL_CAPTOUCH is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_E3X0_BUTTON is not set # CONFIG_INPUT_MSM_VIBRATOR is not set # CONFIG_INPUT_MMA8450 is not set # CONFIG_INPUT_GP2A is not set # CONFIG_INPUT_GPIO_BEEPER is not set # CONFIG_INPUT_GPIO_DECODER is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set # CONFIG_INPUT_REGULATOR_HAPTIC is not set # CONFIG_INPUT_TWL4030_PWRBUTTON is not set # CONFIG_INPUT_TWL4030_VIBRA is not set # CONFIG_INPUT_UINPUT is not set # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_PWM_BEEPER is not set # CONFIG_INPUT_PWM_VIBRA is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set CONFIG_INPUT_ADXL34X=m CONFIG_INPUT_ADXL34X_I2C=m CONFIG_INPUT_ADXL34X_SPI=m # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_CMA3000 is not set # CONFIG_INPUT_SOC_BUTTON_ARRAY is not set # CONFIG_INPUT_DRV260X_HAPTICS is not set # CONFIG_INPUT_DRV2665_HAPTICS is not set # CONFIG_INPUT_DRV2667_HAPTICS is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=m CONFIG_SERIO_SERPORT=m CONFIG_SERIO_PARKBD=m # CONFIG_SERIO_PCIPS2 is not set CONFIG_SERIO_LIBPS2=m # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_OLPC_APSP is not set # CONFIG_SERIO_GPIO_PS2 is not set # CONFIG_USERIO is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=256 # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_NOZOMI is not set # CONFIG_N_GSM is not set # CONFIG_TRACE_SINK is not set CONFIG_LDISC_AUTOLOAD=y CONFIG_DEVMEM=y # CONFIG_DEVKMEM is not set # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_EXAR=y CONFIG_SERIAL_8250_NR_UARTS=4 CONFIG_SERIAL_8250_RUNTIME_UARTS=4 CONFIG_SERIAL_8250_EXTENDED=y # CONFIG_SERIAL_8250_MANY_PORTS is not set # CONFIG_SERIAL_8250_ASPEED_VUART is not set CONFIG_SERIAL_8250_SHARE_IRQ=y # CONFIG_SERIAL_8250_DETECT_IRQ is not set # CONFIG_SERIAL_8250_RSA is not set CONFIG_SERIAL_8250_FSL=y CONFIG_SERIAL_8250_DW=y CONFIG_SERIAL_8250_EM=y # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_8250_MT6577=y # CONFIG_SERIAL_8250_MOXA is not set CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set CONFIG_SERIAL_BCM63XX=y CONFIG_SERIAL_BCM63XX_CONSOLE=y # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_IFX6X60 is not set CONFIG_SERIAL_XILINX_PS_UART=y CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_RP2 is not set CONFIG_SERIAL_FSL_LPUART=y CONFIG_SERIAL_FSL_LPUART_CONSOLE=y CONFIG_SERIAL_CONEXANT_DIGICOLOR=y CONFIG_SERIAL_CONEXANT_DIGICOLOR_CONSOLE=y CONFIG_SERIAL_ST_ASC=y CONFIG_SERIAL_ST_ASC_CONSOLE=y # CONFIG_SERIAL_DEV_BUS is not set # CONFIG_TTY_PRINTK is not set CONFIG_PRINTER=m # CONFIG_LP_CONSOLE is not set CONFIG_PPDEV=m CONFIG_HVC_DRIVER=y # CONFIG_HVC_DCC is not set CONFIG_VIRTIO_CONSOLE=y # CONFIG_IPMI_HANDLER is not set CONFIG_HW_RANDOM=y # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_HW_RANDOM_VIRTIO is not set CONFIG_HW_RANDOM_MTK=y # CONFIG_APPLICOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set CONFIG_DEVPORT=y # CONFIG_XILLYBUS is not set # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_MUX=y # # Multiplexer I2C Chip support # CONFIG_I2C_ARB_GPIO_CHALLENGE=m CONFIG_I2C_MUX_GPIO=m CONFIG_I2C_MUX_GPMUX=m CONFIG_I2C_MUX_LTC4306=m CONFIG_I2C_MUX_PCA9541=m CONFIG_I2C_MUX_PCA954x=m CONFIG_I2C_MUX_PINCTRL=m CONFIG_I2C_MUX_REG=m CONFIG_I2C_DEMUX_PINCTRL=m # CONFIG_I2C_MUX_MLXCPLD is not set CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_SMBUS=m CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # CONFIG_I2C_ALI1535=m CONFIG_I2C_ALI1563=m CONFIG_I2C_ALI15X3=m CONFIG_I2C_AMD756=m CONFIG_I2C_AMD8111=m CONFIG_I2C_I801=m CONFIG_I2C_ISCH=m CONFIG_I2C_PIIX4=m CONFIG_I2C_NFORCE2=m # CONFIG_I2C_NVIDIA_GPU is not set CONFIG_I2C_SIS5595=m CONFIG_I2C_SIS630=m CONFIG_I2C_SIS96X=m CONFIG_I2C_VIA=m CONFIG_I2C_VIAPRO=m # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_DESIGNWARE_PCI is not set # CONFIG_I2C_EMEV2 is not set CONFIG_I2C_GPIO=m # CONFIG_I2C_GPIO_FAULT_INJECTOR is not set CONFIG_I2C_MT65XX=m # CONFIG_I2C_OCORES is not set # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set CONFIG_I2C_PARPORT=m # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_STUB is not set CONFIG_I2C_SLAVE=y CONFIG_I2C_SLAVE_EEPROM=y # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # CONFIG_I3C is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y CONFIG_SPI_MEM=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set CONFIG_SPI_BITBANG=y # CONFIG_SPI_BUTTERFLY is not set # CONFIG_SPI_CADENCE is not set # CONFIG_SPI_DESIGNWARE is not set # CONFIG_SPI_NXP_FLEXSPI is not set CONFIG_SPI_GPIO=m # CONFIG_SPI_LM70_LLP is not set # CONFIG_SPI_FSL_SPI is not set CONFIG_SPI_MT65XX=m # CONFIG_SPI_OC_TINY is not set # CONFIG_SPI_PXA2XX is not set # CONFIG_SPI_ROCKCHIP is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_SIFIVE is not set # CONFIG_SPI_MXIC is not set # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # # SPI Protocol Masters # CONFIG_SPI_SPIDEV=m # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set # CONFIG_SPI_SLAVE is not set CONFIG_SPMI=y # CONFIG_HSI is not set CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set CONFIG_PPS_CLIENT_PARPORT=m # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y CONFIG_DP83640_PHY=m CONFIG_PINCTRL=y CONFIG_GENERIC_PINCTRL_GROUPS=y CONFIG_PINMUX=y CONFIG_GENERIC_PINMUX_FUNCTIONS=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_AMD is not set # CONFIG_PINCTRL_MCP23S08 is not set CONFIG_PINCTRL_SINGLE=y # CONFIG_PINCTRL_SX150X is not set # CONFIG_PINCTRL_OCELOT is not set # # MediaTek pinctrl drivers # CONFIG_EINT_MTK=y CONFIG_PINCTRL_MTK=y CONFIG_PINCTRL_MTK_MOORE=y CONFIG_PINCTRL_MT2701=y CONFIG_PINCTRL_MT7623=y CONFIG_PINCTRL_MT7629=y CONFIG_PINCTRL_MT8135=y CONFIG_PINCTRL_MT8127=y CONFIG_PINCTRL_MT6397=y CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y CONFIG_GPIOLIB_IRQCHIP=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y CONFIG_GPIO_GENERIC=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_CADENCE is not set # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_EXAR is not set # CONFIG_GPIO_FTGPIO010 is not set CONFIG_GPIO_GENERIC_PLATFORM=y # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_MB86S7X is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_GPIO_MPC8XXX is not set # CONFIG_GPIO_SAMA5D2_PIOBU is not set # CONFIG_GPIO_SYSCON is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_ZEVIO is not set # CONFIG_GPIO_AMD_FCH is not set # # I2C GPIO expanders # # CONFIG_GPIO_ADP5588 is not set # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_GW_PLD is not set # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_TPIC2810 is not set # # MFD GPIO expanders # # CONFIG_HTC_EGPIO is not set # CONFIG_GPIO_TWL4030 is not set # # PCI GPIO expanders # # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_PCI_IDIO_16 is not set # CONFIG_GPIO_PCIE_IDIO_24 is not set # CONFIG_GPIO_RDC321X is not set # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX3191X is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_PISOSR is not set # CONFIG_GPIO_XRA1403 is not set # # USB GPIO expanders # CONFIG_W1=m # # 1-wire Bus Masters # # CONFIG_W1_MASTER_MATROX is not set CONFIG_W1_MASTER_DS2490=m CONFIG_W1_MASTER_DS2482=m # CONFIG_W1_MASTER_DS1WM is not set CONFIG_W1_MASTER_GPIO=m # # 1-wire Slaves # CONFIG_W1_SLAVE_THERM=m # CONFIG_W1_SLAVE_SMEM is not set # CONFIG_W1_SLAVE_DS2405 is not set # CONFIG_W1_SLAVE_DS2408 is not set # CONFIG_W1_SLAVE_DS2413 is not set # CONFIG_W1_SLAVE_DS2406 is not set # CONFIG_W1_SLAVE_DS2423 is not set # CONFIG_W1_SLAVE_DS2805 is not set # CONFIG_W1_SLAVE_DS2431 is not set # CONFIG_W1_SLAVE_DS2433 is not set # CONFIG_W1_SLAVE_DS2438 is not set # CONFIG_W1_SLAVE_DS2780 is not set # CONFIG_W1_SLAVE_DS2781 is not set # CONFIG_W1_SLAVE_DS28E04 is not set # CONFIG_W1_SLAVE_DS28E17 is not set CONFIG_POWER_AVS=y CONFIG_POWER_RESET=y CONFIG_POWER_RESET_BRCMKONA=y CONFIG_POWER_RESET_BRCMSTB=y CONFIG_POWER_RESET_GPIO=y CONFIG_POWER_RESET_GPIO_RESTART=y # CONFIG_POWER_RESET_LTC2952 is not set # CONFIG_POWER_RESET_RESTART is not set # CONFIG_POWER_RESET_VERSATILE is not set CONFIG_POWER_RESET_VEXPRESS=y CONFIG_POWER_RESET_SYSCON=y CONFIG_POWER_RESET_SYSCON_POWEROFF=y # CONFIG_SYSCON_REBOOT_MODE is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set # CONFIG_PDA_POWER is not set # CONFIG_GENERIC_ADC_BATTERY is not set # CONFIG_TEST_POWER is not set CONFIG_CHARGER_ADP5061=m CONFIG_BATTERY_DS2760=m # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_LEGO_EV3 is not set CONFIG_BATTERY_SBS=y # CONFIG_CHARGER_SBS is not set # CONFIG_MANAGER_SBS is not set # CONFIG_BATTERY_BQ27XXX is not set CONFIG_BATTERY_MAX17040=m CONFIG_BATTERY_MAX17042=m # CONFIG_BATTERY_MAX1721X is not set # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_TWL4030 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_LTC3651 is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ25890 is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_CHARGER_RT9455 is not set CONFIG_HWMON=y CONFIG_HWMON_VID=m # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # CONFIG_SENSORS_AD7314=m CONFIG_SENSORS_AD7414=m CONFIG_SENSORS_AD7418=m CONFIG_SENSORS_ADM1021=m CONFIG_SENSORS_ADM1025=m CONFIG_SENSORS_ADM1026=m CONFIG_SENSORS_ADM1029=m CONFIG_SENSORS_ADM1031=m CONFIG_SENSORS_ADM9240=m CONFIG_SENSORS_ADT7X10=m CONFIG_SENSORS_ADT7310=m CONFIG_SENSORS_ADT7410=m CONFIG_SENSORS_ADT7411=m CONFIG_SENSORS_ADT7462=m CONFIG_SENSORS_ADT7470=m CONFIG_SENSORS_ADT7475=m CONFIG_SENSORS_ASC7621=m # CONFIG_SENSORS_ASPEED is not set CONFIG_SENSORS_ATXP1=m CONFIG_SENSORS_DS620=m CONFIG_SENSORS_DS1621=m CONFIG_SENSORS_I5K_AMB=m CONFIG_SENSORS_F71805F=m CONFIG_SENSORS_F71882FG=m CONFIG_SENSORS_F75375S=m CONFIG_SENSORS_FTSTEUTATES=m CONFIG_SENSORS_GL518SM=m CONFIG_SENSORS_GL520SM=m CONFIG_SENSORS_G760A=m CONFIG_SENSORS_G762=m CONFIG_SENSORS_GPIO_FAN=m CONFIG_SENSORS_HIH6130=m # CONFIG_SENSORS_IIO_HWMON is not set CONFIG_SENSORS_IT87=m CONFIG_SENSORS_JC42=m CONFIG_SENSORS_POWR1220=m CONFIG_SENSORS_LINEAGE=m CONFIG_SENSORS_LTC2945=m CONFIG_SENSORS_LTC2990=m CONFIG_SENSORS_LTC4151=m CONFIG_SENSORS_LTC4215=m CONFIG_SENSORS_LTC4222=m CONFIG_SENSORS_LTC4245=m CONFIG_SENSORS_LTC4260=m CONFIG_SENSORS_LTC4261=m CONFIG_SENSORS_MAX1111=m CONFIG_SENSORS_MAX16065=m CONFIG_SENSORS_MAX1619=m CONFIG_SENSORS_MAX1668=m CONFIG_SENSORS_MAX197=m CONFIG_SENSORS_MAX31722=m # CONFIG_SENSORS_MAX6621 is not set CONFIG_SENSORS_MAX6639=m CONFIG_SENSORS_MAX6642=m CONFIG_SENSORS_MAX6650=m CONFIG_SENSORS_MAX6697=m CONFIG_SENSORS_MAX31790=m CONFIG_SENSORS_MCP3021=m # CONFIG_SENSORS_TC654 is not set CONFIG_SENSORS_ADCXX=m CONFIG_SENSORS_LM63=m CONFIG_SENSORS_LM70=m CONFIG_SENSORS_LM73=m CONFIG_SENSORS_LM75=m CONFIG_SENSORS_LM77=m CONFIG_SENSORS_LM78=m CONFIG_SENSORS_LM80=m CONFIG_SENSORS_LM83=m CONFIG_SENSORS_LM85=m CONFIG_SENSORS_LM87=m CONFIG_SENSORS_LM90=m CONFIG_SENSORS_LM92=m CONFIG_SENSORS_LM93=m CONFIG_SENSORS_LM95234=m CONFIG_SENSORS_LM95241=m CONFIG_SENSORS_LM95245=m CONFIG_SENSORS_PC87360=m CONFIG_SENSORS_PC87427=m CONFIG_SENSORS_NTC_THERMISTOR=m CONFIG_SENSORS_NCT6683=m CONFIG_SENSORS_NCT6775=m CONFIG_SENSORS_NCT7802=m CONFIG_SENSORS_NCT7904=m CONFIG_SENSORS_NPCM7XX=m # CONFIG_SENSORS_OCC_P8_I2C is not set CONFIG_SENSORS_PCF8591=m # CONFIG_PMBUS is not set CONFIG_SENSORS_PWM_FAN=m CONFIG_SENSORS_SHT15=m CONFIG_SENSORS_SHT21=m CONFIG_SENSORS_SHT3x=m CONFIG_SENSORS_SHTC1=m CONFIG_SENSORS_SIS5595=m CONFIG_SENSORS_DME1737=m CONFIG_SENSORS_EMC1403=m CONFIG_SENSORS_EMC2103=m CONFIG_SENSORS_EMC6W201=m CONFIG_SENSORS_SMSC47M1=m CONFIG_SENSORS_SMSC47M192=m CONFIG_SENSORS_SMSC47B397=m CONFIG_SENSORS_SCH56XX_COMMON=m CONFIG_SENSORS_SCH5627=m CONFIG_SENSORS_SCH5636=m CONFIG_SENSORS_STTS751=m CONFIG_SENSORS_SMM665=m CONFIG_SENSORS_ADC128D818=m CONFIG_SENSORS_ADS1015=m CONFIG_SENSORS_ADS7828=m CONFIG_SENSORS_ADS7871=m CONFIG_SENSORS_AMC6821=m CONFIG_SENSORS_INA209=m CONFIG_SENSORS_INA2XX=m CONFIG_SENSORS_INA3221=m CONFIG_SENSORS_TC74=m CONFIG_SENSORS_THMC50=m CONFIG_SENSORS_TMP102=m CONFIG_SENSORS_TMP103=m # CONFIG_SENSORS_TMP108 is not set CONFIG_SENSORS_TMP401=m CONFIG_SENSORS_TMP421=m CONFIG_SENSORS_VEXPRESS=m # CONFIG_SENSORS_VIA686A is not set CONFIG_SENSORS_VT1211=m CONFIG_SENSORS_VT8231=m CONFIG_SENSORS_W83773G=m CONFIG_SENSORS_W83781D=m CONFIG_SENSORS_W83791D=m CONFIG_SENSORS_W83792D=m CONFIG_SENSORS_W83793=m CONFIG_SENSORS_W83795=m # CONFIG_SENSORS_W83795_FANCTRL is not set CONFIG_SENSORS_W83L785TS=m CONFIG_SENSORS_W83L786NG=m CONFIG_SENSORS_W83627HF=m CONFIG_SENSORS_W83627EHF=m CONFIG_THERMAL=y # CONFIG_THERMAL_STATISTICS is not set CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 CONFIG_THERMAL_HWMON=y CONFIG_THERMAL_OF=y CONFIG_THERMAL_WRITABLE_TRIPS=y # CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE is not set # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE=y # CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set CONFIG_THERMAL_GOV_FAIR_SHARE=y CONFIG_THERMAL_GOV_STEP_WISE=y CONFIG_THERMAL_GOV_BANG_BANG=y CONFIG_THERMAL_GOV_USER_SPACE=y CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y CONFIG_CPU_THERMAL=y # CONFIG_CLOCK_THERMAL is not set # CONFIG_DEVFREQ_THERMAL is not set # CONFIG_THERMAL_EMULATION is not set # CONFIG_QORIQ_THERMAL is not set CONFIG_MTK_THERMAL=y # CONFIG_GENERIC_ADC_THERMAL is not set CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y # CONFIG_WATCHDOG_SYSFS is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set # CONFIG_CADENCE_WATCHDOG is not set # CONFIG_FTWDT010_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set # CONFIG_TWL4030_WATCHDOG is not set # CONFIG_MAX63XX_WATCHDOG is not set CONFIG_MEDIATEK_WATCHDOG=y # CONFIG_ALIM7101_WDT is not set # CONFIG_I6300ESB_WDT is not set # CONFIG_MEN_A21_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set CONFIG_SSB_POSSIBLE=y CONFIG_SSB=m CONFIG_SSB_SPROM=y CONFIG_SSB_BLOCKIO=y CONFIG_SSB_PCIHOST_POSSIBLE=y CONFIG_SSB_PCIHOST=y CONFIG_SSB_B43_PCI_BRIDGE=y CONFIG_SSB_SDIOHOST_POSSIBLE=y CONFIG_SSB_SDIOHOST=y CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y CONFIG_SSB_DRIVER_PCICORE=y # CONFIG_SSB_DRIVER_GPIO is not set CONFIG_BCMA_POSSIBLE=y CONFIG_BCMA=m CONFIG_BCMA_BLOCKIO=y CONFIG_BCMA_HOST_PCI_POSSIBLE=y CONFIG_BCMA_HOST_PCI=y # CONFIG_BCMA_HOST_SOC is not set CONFIG_BCMA_DRIVER_PCI=y # CONFIG_BCMA_DRIVER_GMAC_CMN is not set # CONFIG_BCMA_DRIVER_GPIO is not set # CONFIG_BCMA_DEBUG is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y # CONFIG_MFD_ACT8945A is not set # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set # CONFIG_MFD_BD9571MWV is not set # CONFIG_MFD_AXP20X_I2C is not set # CONFIG_MFD_CROS_EC is not set # CONFIG_MFD_MADERA is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_LPC_ICH is not set CONFIG_LPC_SCH=m # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set # CONFIG_MFD_MAX77620 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set CONFIG_MFD_MT6397=y # CONFIG_MFD_MENF21BMC is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_CPCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_PM8XXX is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_RK808 is not set # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_SMSC is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y # CONFIG_MFD_TI_AM335X_TSCADC is not set # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set # CONFIG_MFD_PALMAS is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TI_LP873X is not set # CONFIG_MFD_TI_LP87565 is not set # CONFIG_MFD_TPS65218 is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_MFD_TPS80031 is not set CONFIG_TWL4030_CORE=y CONFIG_TWL4030_POWER=y # CONFIG_MFD_TWL4030_AUDIO is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_MFD_VX855 is not set # CONFIG_MFD_LOCHNAGAR is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set CONFIG_MFD_ROHM_BD718XX=m # CONFIG_MFD_STPMIC1 is not set CONFIG_MFD_VEXPRESS_SYSREG=y CONFIG_REGULATOR=y CONFIG_REGULATOR_DEBUG=y CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_88PG86X is not set # CONFIG_REGULATOR_ACT8865 is not set # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ANATOP is not set CONFIG_REGULATOR_BD718XX=m # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set # CONFIG_REGULATOR_FAN53555 is not set # CONFIG_REGULATOR_GPIO is not set # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set # CONFIG_REGULATOR_LP8755 is not set # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_MAX8973 is not set # CONFIG_REGULATOR_MCP16502 is not set # CONFIG_REGULATOR_MT6311 is not set CONFIG_REGULATOR_MT6323=y # CONFIG_REGULATOR_MT6380 is not set # CONFIG_REGULATOR_MT6397 is not set # CONFIG_REGULATOR_PFUZE100 is not set # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set # CONFIG_REGULATOR_PWM is not set # CONFIG_REGULATOR_QCOM_SPMI is not set # CONFIG_REGULATOR_SY8106A is not set # CONFIG_REGULATOR_TPS51632 is not set # CONFIG_REGULATOR_TPS62360 is not set # CONFIG_REGULATOR_TPS65023 is not set # CONFIG_REGULATOR_TPS6507X is not set # CONFIG_REGULATOR_TPS65132 is not set # CONFIG_REGULATOR_TPS6524X is not set # CONFIG_REGULATOR_TWL4030 is not set # CONFIG_REGULATOR_VCTRL is not set # CONFIG_REGULATOR_VEXPRESS is not set CONFIG_CEC_CORE=m CONFIG_RC_CORE=m CONFIG_RC_MAP=m CONFIG_LIRC=y CONFIG_RC_DECODERS=y CONFIG_IR_NEC_DECODER=m CONFIG_IR_RC5_DECODER=m CONFIG_IR_RC6_DECODER=m CONFIG_IR_JVC_DECODER=m CONFIG_IR_SONY_DECODER=m CONFIG_IR_SANYO_DECODER=m CONFIG_IR_SHARP_DECODER=m CONFIG_IR_MCE_KBD_DECODER=m CONFIG_IR_XMP_DECODER=m CONFIG_IR_IMON_DECODER=m # CONFIG_IR_RCMM_DECODER is not set CONFIG_RC_DEVICES=y # CONFIG_RC_ATI_REMOTE is not set # CONFIG_IR_HIX5HD2 is not set # CONFIG_IR_IMON is not set # CONFIG_IR_IMON_RAW is not set # CONFIG_IR_MCEUSB is not set CONFIG_IR_MTK=m # CONFIG_IR_REDRAT3 is not set # CONFIG_IR_SPI is not set # CONFIG_IR_STREAMZAP is not set # CONFIG_IR_IGORPLUGUSB is not set # CONFIG_IR_IGUANA is not set # CONFIG_IR_TTUSBIR is not set # CONFIG_RC_LOOPBACK is not set # CONFIG_IR_GPIO_CIR is not set # CONFIG_IR_GPIO_TX is not set # CONFIG_IR_PWM_TX is not set # CONFIG_IR_SERIAL is not set # CONFIG_IR_SIR is not set # CONFIG_RC_XBOX_DVD is not set CONFIG_MEDIA_SUPPORT=m # # Multimedia core support # CONFIG_MEDIA_CAMERA_SUPPORT=y # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set # CONFIG_MEDIA_RADIO_SUPPORT is not set # CONFIG_MEDIA_SDR_SUPPORT is not set CONFIG_MEDIA_CEC_SUPPORT=y # CONFIG_MEDIA_CEC_RC is not set CONFIG_MEDIA_CONTROLLER=y CONFIG_VIDEO_DEV=m CONFIG_VIDEO_V4L2_SUBDEV_API=y CONFIG_VIDEO_V4L2=m # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set CONFIG_V4L2_MEM2MEM_DEV=m # CONFIG_V4L2_FLASH_LED_CLASS is not set CONFIG_V4L2_FWNODE=m # # Media drivers # CONFIG_MEDIA_USB_SUPPORT=y # # Webcam devices # CONFIG_USB_VIDEO_CLASS=m CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y CONFIG_USB_GSPCA=m # CONFIG_USB_M5602 is not set # CONFIG_USB_STV06XX is not set # CONFIG_USB_GL860 is not set # CONFIG_USB_GSPCA_BENQ is not set # CONFIG_USB_GSPCA_CONEX is not set # CONFIG_USB_GSPCA_CPIA1 is not set # CONFIG_USB_GSPCA_DTCS033 is not set # CONFIG_USB_GSPCA_ETOMS is not set # CONFIG_USB_GSPCA_FINEPIX is not set # CONFIG_USB_GSPCA_JEILINJ is not set # CONFIG_USB_GSPCA_JL2005BCD is not set # CONFIG_USB_GSPCA_KINECT is not set # CONFIG_USB_GSPCA_KONICA is not set # CONFIG_USB_GSPCA_MARS is not set # CONFIG_USB_GSPCA_MR97310A is not set # CONFIG_USB_GSPCA_NW80X is not set # CONFIG_USB_GSPCA_OV519 is not set # CONFIG_USB_GSPCA_OV534 is not set # CONFIG_USB_GSPCA_OV534_9 is not set # CONFIG_USB_GSPCA_PAC207 is not set # CONFIG_USB_GSPCA_PAC7302 is not set # CONFIG_USB_GSPCA_PAC7311 is not set # CONFIG_USB_GSPCA_SE401 is not set # CONFIG_USB_GSPCA_SN9C2028 is not set # CONFIG_USB_GSPCA_SN9C20X is not set # CONFIG_USB_GSPCA_SONIXB is not set # CONFIG_USB_GSPCA_SONIXJ is not set # CONFIG_USB_GSPCA_SPCA500 is not set # CONFIG_USB_GSPCA_SPCA501 is not set # CONFIG_USB_GSPCA_SPCA505 is not set # CONFIG_USB_GSPCA_SPCA506 is not set # CONFIG_USB_GSPCA_SPCA508 is not set # CONFIG_USB_GSPCA_SPCA561 is not set # CONFIG_USB_GSPCA_SPCA1528 is not set # CONFIG_USB_GSPCA_SQ905 is not set # CONFIG_USB_GSPCA_SQ905C is not set # CONFIG_USB_GSPCA_SQ930X is not set # CONFIG_USB_GSPCA_STK014 is not set # CONFIG_USB_GSPCA_STK1135 is not set # CONFIG_USB_GSPCA_STV0680 is not set # CONFIG_USB_GSPCA_SUNPLUS is not set # CONFIG_USB_GSPCA_T613 is not set # CONFIG_USB_GSPCA_TOPRO is not set # CONFIG_USB_GSPCA_TOUPTEK is not set # CONFIG_USB_GSPCA_TV8532 is not set # CONFIG_USB_GSPCA_VC032X is not set # CONFIG_USB_GSPCA_VICAM is not set # CONFIG_USB_GSPCA_XIRLINK_CIT is not set # CONFIG_USB_GSPCA_ZC3XX is not set # CONFIG_USB_PWC is not set # CONFIG_VIDEO_CPIA2 is not set # CONFIG_USB_ZR364XX is not set # CONFIG_USB_STKWEBCAM is not set # CONFIG_USB_S2255 is not set # CONFIG_VIDEO_USBTV is not set # # Webcam, TV (analog/digital) USB devices # # CONFIG_VIDEO_EM28XX is not set # # USB HDMI CEC adapters # CONFIG_USB_PULSE8_CEC=m # CONFIG_USB_RAINSHADOW_CEC is not set # CONFIG_MEDIA_PCI_SUPPORT is not set CONFIG_V4L_PLATFORM_DRIVERS=y # CONFIG_VIDEO_CAFE_CCIC is not set # CONFIG_VIDEO_CADENCE is not set # CONFIG_VIDEO_ASPEED is not set # CONFIG_VIDEO_MUX is not set # CONFIG_VIDEO_XILINX is not set CONFIG_V4L_MEM2MEM_DRIVERS=y # CONFIG_VIDEO_MEDIATEK_VPU is not set # CONFIG_VIDEO_MEDIATEK_MDP is not set # CONFIG_VIDEO_MEDIATEK_VCODEC is not set # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set # CONFIG_VIDEO_SH_VEU is not set CONFIG_V4L_TEST_DRIVERS=y # CONFIG_VIDEO_VIMC is not set CONFIG_VIDEO_VIVID=m # CONFIG_VIDEO_VIVID_CEC is not set CONFIG_VIDEO_VIVID_MAX_DEVS=64 # CONFIG_VIDEO_VIM2M is not set CONFIG_VIDEO_VICODEC=m CONFIG_CEC_PLATFORM_DRIVERS=y # # Supported MMC/SDIO adapters # # CONFIG_CYPRESS_FIRMWARE is not set CONFIG_VIDEOBUF2_CORE=m CONFIG_VIDEOBUF2_V4L2=m CONFIG_VIDEOBUF2_MEMOPS=m CONFIG_VIDEOBUF2_DMA_CONTIG=m CONFIG_VIDEOBUF2_VMALLOC=m CONFIG_VIDEO_V4L2_TPG=m # # Media ancillary drivers (tuners, sensors, i2c, spi, frontends) # # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set CONFIG_VIDEO_IR_I2C=m # # I2C Encoders, decoders, sensors and other helper chips # # # Audio decoders, processors and mixers # # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TDA1997X is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_CS3308 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_WM8775 is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # # Video decoders # CONFIG_VIDEO_ADV7180=m # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_ADV748X is not set # CONFIG_VIDEO_ADV7604 is not set # CONFIG_VIDEO_ADV7842 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_KS0127 is not set CONFIG_VIDEO_ML86V7667=m # CONFIG_VIDEO_AD5820 is not set CONFIG_VIDEO_AK7375=m # CONFIG_VIDEO_DW9714 is not set # CONFIG_VIDEO_DW9807_VCM is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_TC358743 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_TW9910 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # # Video encoders # # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_ADV7511 is not set # CONFIG_VIDEO_AD9389B is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_THS8200 is not set # # Camera sensor devices # # CONFIG_VIDEO_IMX214 is not set # CONFIG_VIDEO_IMX258 is not set # CONFIG_VIDEO_IMX274 is not set # CONFIG_VIDEO_IMX319 is not set # CONFIG_VIDEO_IMX355 is not set # CONFIG_VIDEO_OV2640 is not set # CONFIG_VIDEO_OV2659 is not set CONFIG_VIDEO_OV2680=m # CONFIG_VIDEO_OV2685 is not set # CONFIG_VIDEO_OV5640 is not set # CONFIG_VIDEO_OV5645 is not set # CONFIG_VIDEO_OV5647 is not set # CONFIG_VIDEO_OV6650 is not set # CONFIG_VIDEO_OV5670 is not set # CONFIG_VIDEO_OV5695 is not set # CONFIG_VIDEO_OV7251 is not set # CONFIG_VIDEO_OV772X is not set # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_OV7740 is not set # CONFIG_VIDEO_OV8856 is not set # CONFIG_VIDEO_OV9640 is not set # CONFIG_VIDEO_OV9650 is not set # CONFIG_VIDEO_OV13858 is not set # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_MT9M001 is not set # CONFIG_VIDEO_MT9M032 is not set # CONFIG_VIDEO_MT9M111 is not set # CONFIG_VIDEO_MT9P031 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9T112 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V032 is not set CONFIG_VIDEO_MT9V111=m # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_VIDEO_NOON010PC30 is not set # CONFIG_VIDEO_M5MOLS is not set # CONFIG_VIDEO_RJ54N1 is not set # CONFIG_VIDEO_S5K6AA is not set # CONFIG_VIDEO_S5K6A3 is not set # CONFIG_VIDEO_S5K4ECGX is not set # CONFIG_VIDEO_S5K5BAF is not set # CONFIG_VIDEO_SMIAPP is not set # CONFIG_VIDEO_ET8EK8 is not set # CONFIG_VIDEO_S5C73M3 is not set # # Flash devices # # CONFIG_VIDEO_ADP1653 is not set # CONFIG_VIDEO_LM3560 is not set # CONFIG_VIDEO_LM3646 is not set # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # # Audio/Video compression chips # # CONFIG_VIDEO_SAA6752HS is not set # # SDR tuner chips # # # Miscellaneous helper chips # # CONFIG_VIDEO_THS7303 is not set # CONFIG_VIDEO_M52790 is not set # CONFIG_VIDEO_I2C is not set # # SPI helper chips # # CONFIG_VIDEO_GS1662 is not set # # Media SPI Adapters # # # Customise DVB Frontends # # # Tools to develop new frontends # # # Graphics support # CONFIG_VGA_ARB=y CONFIG_VGA_ARB_MAX_GPUS=16 # CONFIG_IMX_IPUV3_CORE is not set CONFIG_DRM=y CONFIG_DRM_MIPI_DSI=y # CONFIG_DRM_DP_AUX_CHARDEV is not set # CONFIG_DRM_DEBUG_MM is not set # CONFIG_DRM_DEBUG_SELFTEST is not set CONFIG_DRM_KMS_HELPER=y CONFIG_DRM_KMS_FB_HELPER=y CONFIG_DRM_FBDEV_EMULATION=y CONFIG_DRM_FBDEV_OVERALLOC=100 # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set # CONFIG_DRM_DP_CEC is not set CONFIG_DRM_TTM=m CONFIG_DRM_GEM_CMA_HELPER=y CONFIG_DRM_KMS_CMA_HELPER=y CONFIG_DRM_VM=y # # I2C encoder or helper chips # # CONFIG_DRM_I2C_CH7006 is not set # CONFIG_DRM_I2C_SIL164 is not set # CONFIG_DRM_I2C_NXP_TDA998X is not set # CONFIG_DRM_I2C_NXP_TDA9950 is not set # # ARM devices # # CONFIG_DRM_HDLCD is not set # CONFIG_DRM_MALI_DISPLAY is not set # CONFIG_DRM_KOMEDA is not set # CONFIG_DRM_RADEON is not set # CONFIG_DRM_AMDGPU is not set # # ACP (Audio CoProcessor) Configuration # # # AMD Library routines # CONFIG_DRM_NOUVEAU=m CONFIG_NOUVEAU_DEBUG=5 CONFIG_NOUVEAU_DEBUG_DEFAULT=3 # CONFIG_NOUVEAU_DEBUG_MMU is not set CONFIG_DRM_NOUVEAU_BACKLIGHT=y # CONFIG_DRM_VGEM is not set # CONFIG_DRM_VKMS is not set CONFIG_DRM_EXYNOS=m # # CRTCs # CONFIG_DRM_EXYNOS_FIMD=y # CONFIG_DRM_EXYNOS5433_DECON is not set # CONFIG_DRM_EXYNOS7_DECON is not set CONFIG_DRM_EXYNOS_MIXER=y # CONFIG_DRM_EXYNOS_VIDI is not set # # Encoders and Bridges # CONFIG_DRM_EXYNOS_DPI=y CONFIG_DRM_EXYNOS_DSI=y CONFIG_DRM_EXYNOS_DP=y CONFIG_DRM_EXYNOS_HDMI=y # # Sub-drivers # # CONFIG_DRM_EXYNOS_G2D is not set # CONFIG_DRM_EXYNOS_FIMC is not set # CONFIG_DRM_EXYNOS_ROTATOR is not set # CONFIG_DRM_EXYNOS_SCALER is not set # CONFIG_DRM_EXYNOS_GSC is not set # CONFIG_DRM_UDL is not set # CONFIG_DRM_AST is not set # CONFIG_DRM_MGAG200 is not set # CONFIG_DRM_CIRRUS_QEMU is not set # CONFIG_DRM_ARMADA is not set # CONFIG_DRM_RCAR_DW_HDMI is not set CONFIG_DRM_RCAR_LVDS=y # CONFIG_DRM_OMAP is not set # CONFIG_DRM_TILCDC is not set # CONFIG_DRM_QXL is not set # CONFIG_DRM_BOCHS is not set # CONFIG_DRM_VIRTIO_GPU is not set CONFIG_DRM_FSL_DCU=m # CONFIG_DRM_STM is not set CONFIG_DRM_PANEL=y # # Display Panels # # CONFIG_DRM_PANEL_ARM_VERSATILE is not set # CONFIG_DRM_PANEL_LVDS is not set CONFIG_DRM_PANEL_SIMPLE=y # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set CONFIG_DRM_PANEL_ILITEK_ILI9881C=m # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set CONFIG_DRM_PANEL_SAMSUNG_LD9040=m # CONFIG_DRM_PANEL_LG_LG4573 is not set # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set # CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set # CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0=m # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set # CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set # CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set # CONFIG_DRM_PANEL_TPO_TPG110 is not set # CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set CONFIG_DRM_BRIDGE=y CONFIG_DRM_PANEL_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_ANALOGIX_ANX78XX is not set # CONFIG_DRM_CDNS_DSI is not set CONFIG_DRM_DUMB_VGA_DAC=m # CONFIG_DRM_LVDS_ENCODER is not set # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set CONFIG_DRM_NXP_PTN3460=m CONFIG_DRM_PARADE_PS8622=m # CONFIG_DRM_SIL_SII8620 is not set # CONFIG_DRM_SII902X is not set CONFIG_DRM_SII9234=m # CONFIG_DRM_THINE_THC63LVD1024 is not set # CONFIG_DRM_TOSHIBA_TC358764 is not set # CONFIG_DRM_TOSHIBA_TC358767 is not set # CONFIG_DRM_TI_TFP410 is not set # CONFIG_DRM_TI_SN65DSI86 is not set CONFIG_DRM_ANALOGIX_DP=m CONFIG_DRM_I2C_ADV7511=m CONFIG_DRM_I2C_ADV7511_AUDIO=y CONFIG_DRM_I2C_ADV7533=y CONFIG_DRM_I2C_ADV7511_CEC=y CONFIG_DRM_STI=m # CONFIG_DRM_ETNAVIV is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_HISI_HIBMC is not set # CONFIG_DRM_MEDIATEK is not set CONFIG_DRM_MXS=y CONFIG_DRM_MXSFB=m # CONFIG_DRM_TINYDRM is not set # CONFIG_DRM_PL111 is not set # CONFIG_DRM_TVE200 is not set # CONFIG_DRM_LEGACY is not set CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y # # Frame buffer Devices # CONFIG_FB_CMDLINE=y CONFIG_FB_NOTIFY=y CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y CONFIG_FB_SYS_FILLRECT=y CONFIG_FB_SYS_COPYAREA=y CONFIG_FB_SYS_IMAGEBLIT=y # CONFIG_FB_FOREIGN_ENDIAN is not set CONFIG_FB_SYS_FOPS=y CONFIG_FB_DEFERRED_IO=y CONFIG_FB_MODE_HELPERS=y # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set CONFIG_FB_EFI=y # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_I740 is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_S3 is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_VT8623 is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_ARK is not set # CONFIG_FB_PM3 is not set # CONFIG_FB_CARMINE is not set # CONFIG_FB_SMSCUFX is not set # CONFIG_FB_UDL is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set CONFIG_FB_SIMPLE=y # CONFIG_FB_SSD1307 is not set # CONFIG_FB_SM712 is not set CONFIG_BACKLIGHT_LCD_SUPPORT=y CONFIG_LCD_CLASS_DEVICE=m # CONFIG_LCD_L4F00242T03 is not set # CONFIG_LCD_LMS283GF05 is not set # CONFIG_LCD_LTV350QV is not set # CONFIG_LCD_ILI922X is not set # CONFIG_LCD_ILI9320 is not set # CONFIG_LCD_TDO24M is not set # CONFIG_LCD_VGG2432A4 is not set CONFIG_LCD_PLATFORM=m # CONFIG_LCD_AMS369FG06 is not set # CONFIG_LCD_LMS501KF03 is not set # CONFIG_LCD_HX8357 is not set # CONFIG_LCD_OTM3225A is not set CONFIG_BACKLIGHT_CLASS_DEVICE=y CONFIG_BACKLIGHT_GENERIC=y CONFIG_BACKLIGHT_PWM=y # CONFIG_BACKLIGHT_PM8941_WLED is not set # CONFIG_BACKLIGHT_ADP8860 is not set # CONFIG_BACKLIGHT_ADP8870 is not set # CONFIG_BACKLIGHT_LM3630A is not set # CONFIG_BACKLIGHT_LM3639 is not set # CONFIG_BACKLIGHT_LP855X is not set # CONFIG_BACKLIGHT_PANDORA is not set # CONFIG_BACKLIGHT_GPIO is not set # CONFIG_BACKLIGHT_LV5207LP is not set # CONFIG_BACKLIGHT_BD6107 is not set # CONFIG_BACKLIGHT_ARCXCNN is not set CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_DUMMY_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y # CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set # CONFIG_LOGO is not set CONFIG_SOUND=m CONFIG_SND=m CONFIG_SND_TIMER=m CONFIG_SND_PCM=m CONFIG_SND_PCM_ELD=y CONFIG_SND_PCM_IEC958=y CONFIG_SND_DMAENGINE_PCM=m CONFIG_SND_HWDEP=m CONFIG_SND_RAWMIDI=m CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_OSSEMUL is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set CONFIG_SND_DYNAMIC_MINORS=y CONFIG_SND_MAX_CARDS=32 CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # CONFIG_SND_SEQUENCER is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_MTS64 is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_MPU401 is not set # CONFIG_SND_PORTMAN2X4 is not set CONFIG_SND_PCI=y # CONFIG_SND_AD1889 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AW2 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_OXYGEN is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CTXFI is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_INDIGOIOX is not set # CONFIG_SND_INDIGODJX is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_ICE1724 is not set # CONFIG_SND_INTEL8X0 is not set # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_LOLA is not set CONFIG_SND_LX6464ES=m # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SE6X is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VIRTUOSO is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # # HD-Audio # # CONFIG_SND_HDA_INTEL is not set CONFIG_SND_HDA_PREALLOC_SIZE=64 CONFIG_SND_ARM=y CONFIG_SND_SPI=y CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=m # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set # CONFIG_SND_USB_HIFACE is not set # CONFIG_SND_BCD2000 is not set # CONFIG_SND_USB_POD is not set # CONFIG_SND_USB_PODHD is not set # CONFIG_SND_USB_TONEPORT is not set # CONFIG_SND_USB_VARIAX is not set CONFIG_SND_SOC=m CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set CONFIG_SND_SOC_FSL_SAI=m # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_FSL_MICFIL is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_SOC_IMG is not set CONFIG_SND_SOC_MEDIATEK=m CONFIG_SND_SOC_MT2701=m CONFIG_SND_SOC_MT2701_CS42448=m CONFIG_SND_SOC_MT2701_WM8960=m # CONFIG_SND_SOC_MT6797 is not set # CONFIG_SND_SOC_MT8173 is not set # CONFIG_SND_SOC_MT8183 is not set # CONFIG_SND_SOC_MTK_BTCVSD is not set # # STMicroelectronics STM32 SOC audio support # # CONFIG_SND_SOC_XILINX_I2S is not set # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set # CONFIG_SND_SOC_XILINX_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set # CONFIG_ZX_TDM is not set CONFIG_SND_SOC_I2C_AND_SPI=m # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU1761_SPI is not set # CONFIG_SND_SOC_ADAU7002 is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4118 is not set # CONFIG_SND_SOC_AK4458 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set CONFIG_SND_SOC_AK4642=m # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_AK5558 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_BD28623 is not set CONFIG_SND_SOC_BT_SCO=m # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS35L36 is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set CONFIG_SND_SOC_CS42XX8=m CONFIG_SND_SOC_CS42XX8_I2C=m # CONFIG_SND_SOC_CS43130 is not set # CONFIG_SND_SOC_CS4341 is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_DMIC is not set CONFIG_SND_SOC_HDMI_CODEC=m # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES7241 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_ES8328_SPI is not set # CONFIG_SND_SOC_GTM601 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98088 is not set # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9867 is not set # CONFIG_SND_SOC_MAX98927 is not set # CONFIG_SND_SOC_MAX98373 is not set # CONFIG_SND_SOC_MAX9860 is not set # CONFIG_SND_SOC_MSM8916_WCD_ANALOG is not set # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM1789_I2C is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM186X_I2C is not set # CONFIG_SND_SOC_PCM186X_SPI is not set # CONFIG_SND_SOC_PCM3060_I2C is not set # CONFIG_SND_SOC_PCM3060_SPI is not set # CONFIG_SND_SOC_PCM3168A_I2C is not set # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RK3328 is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set CONFIG_SND_SOC_SGTL5000=m # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set CONFIG_SND_SOC_SPDIF=m # CONFIG_SND_SOC_SSM2305 is not set # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set CONFIG_SND_SOC_STI_SAS=m # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TAS6424 is not set # CONFIG_SND_SOC_TDA7419 is not set # CONFIG_SND_SOC_TFA9879 is not set CONFIG_SND_SOC_TLV320AIC23=m CONFIG_SND_SOC_TLV320AIC23_I2C=m # CONFIG_SND_SOC_TLV320AIC23_SPI is not set # CONFIG_SND_SOC_TLV320AIC31XX is not set # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set # CONFIG_SND_SOC_TLV320AIC3X is not set CONFIG_SND_SOC_TS3A227E=m # CONFIG_SND_SOC_TSCS42XX is not set # CONFIG_SND_SOC_TSCS454 is not set # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set # CONFIG_SND_SOC_WM8524 is not set # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731 is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set CONFIG_SND_SOC_WM8753=m # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8782 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set CONFIG_SND_SOC_WM8903=m # CONFIG_SND_SOC_WM8904 is not set CONFIG_SND_SOC_WM8960=m # CONFIG_SND_SOC_WM8962 is not set # CONFIG_SND_SOC_WM8974 is not set CONFIG_SND_SOC_WM8978=m # CONFIG_SND_SOC_WM8985 is not set # CONFIG_SND_SOC_ZX_AUD96P22 is not set # CONFIG_SND_SOC_MAX9759 is not set # CONFIG_SND_SOC_MT6351 is not set # CONFIG_SND_SOC_MT6358 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8822 is not set # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set # CONFIG_SND_SIMPLE_CARD is not set # CONFIG_SND_AUDIO_GRAPH_CARD is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set CONFIG_HIDRAW=y # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACCUTOUCH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_APPLEIR is not set # CONFIG_HID_ASUS is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_BETOP_FF is not set # CONFIG_HID_BIGBEN_FF is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CORSAIR is not set # CONFIG_HID_COUGAR is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set CONFIG_HID_CP2112=m # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELAN is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_GT683R is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_VIEWSONIC is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_ITE is not set # CONFIG_HID_JABRA is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LED is not set # CONFIG_HID_LENOVO is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MALTRON is not set # CONFIG_HID_MAYFLASH is not set # CONFIG_HID_REDRAGON is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set # CONFIG_HID_MULTITOUCH is not set # CONFIG_HID_NTI is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PENMOUNT is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_RETRODE is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEAM is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_UDRAW_PS3 is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # # USB HID support # CONFIG_USB_HID=y # CONFIG_HID_PID is not set CONFIG_USB_HIDDEV=y # # I2C HID support # # CONFIG_I2C_HID is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y CONFIG_USB_PCI=y # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_DYNAMIC_MINORS is not set CONFIG_USB_OTG=y # CONFIG_USB_OTG_WHITELIST is not set # CONFIG_USB_OTG_BLACKLIST_HUB is not set # CONFIG_USB_OTG_FSM is not set # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set CONFIG_USB_AUTOSUSPEND_DELAY=2 # CONFIG_USB_MON is not set # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set CONFIG_USB_XHCI_HCD=y # CONFIG_USB_XHCI_DBGCAP is not set CONFIG_USB_XHCI_PCI=y # CONFIG_USB_XHCI_PLATFORM is not set CONFIG_USB_XHCI_MTK=y # CONFIG_USB_EHCI_HCD is not set # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_MAX3421_HCD is not set # CONFIG_USB_OHCI_HCD is not set # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set CONFIG_USB_HCD_BCMA=m CONFIG_USB_HCD_SSB=m # CONFIG_USB_HCD_TEST_MODE is not set # # USB Device Class drivers # CONFIG_USB_ACM=m # CONFIG_USB_PRINTER is not set CONFIG_USB_WDM=m # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set CONFIG_USB_UAS=m # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set CONFIG_USB_MTU3=m # CONFIG_USB_MTU3_HOST is not set # CONFIG_USB_MTU3_GADGET is not set CONFIG_USB_MTU3_DUAL_ROLE=y # CONFIG_USB_MTU3_DEBUG is not set # CONFIG_USB_MUSB_HDRC is not set # CONFIG_USB_DWC3 is not set # CONFIG_USB_DWC2 is not set # CONFIG_USB_CHIPIDEA is not set # CONFIG_USB_ISP1760 is not set # # USB port drivers # CONFIG_USB_USS720=m CONFIG_USB_SERIAL=y # CONFIG_USB_SERIAL_CONSOLE is not set # CONFIG_USB_SERIAL_GENERIC is not set # CONFIG_USB_SERIAL_SIMPLE is not set # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_CH341 is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set # CONFIG_USB_SERIAL_CP210X is not set # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set # CONFIG_USB_SERIAL_FTDI_SIO is not set # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_F8153X is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MXUPORT is not set # CONFIG_USB_SERIAL_NAVMAN is not set # CONFIG_USB_SERIAL_PL2303 is not set # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set # CONFIG_USB_SERIAL_QUALCOMM is not set # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set # CONFIG_USB_SERIAL_XIRCOM is not set # CONFIG_USB_SERIAL_OPTION is not set # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_XSENS_MT is not set # CONFIG_USB_SERIAL_WISHBONE is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_QT2 is not set # CONFIG_USB_SERIAL_UPD78F0730 is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HUB_USB251XB is not set # CONFIG_USB_HSIC_USB3503 is not set # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # CONFIG_USB_CHAOSKEY is not set CONFIG_USB_ATM=m # CONFIG_USB_SPEEDTOUCH is not set # CONFIG_USB_CXACRU is not set # CONFIG_USB_UEAGLEATM is not set # CONFIG_USB_XUSBATM is not set # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_NOP_USB_XCEIV=m CONFIG_AM335X_CONTROL_USB=m CONFIG_AM335X_PHY_USB=m CONFIG_USB_GPIO_VBUS=m CONFIG_USB_ISP1301=y CONFIG_USB_ULPI=y CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_GADGET=m # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2 # CONFIG_U_SERIAL_CONSOLE is not set # # USB Peripheral Controller # # CONFIG_USB_FUSB300 is not set # CONFIG_USB_FOTG210_UDC is not set # CONFIG_USB_GR_UDC is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_PXA27X is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_MV_U3D is not set CONFIG_USB_SNP_CORE=m CONFIG_USB_SNP_UDC_PLAT=m # CONFIG_USB_M66592 is not set CONFIG_USB_BDC_UDC=m # # Platform Support # CONFIG_USB_BDC_PCI=m # CONFIG_USB_AMD5536UDC is not set # CONFIG_USB_NET2272 is not set # CONFIG_USB_NET2280 is not set # CONFIG_USB_GOKU is not set # CONFIG_USB_EG20T is not set # CONFIG_USB_GADGET_XILINX is not set # CONFIG_USB_DUMMY_HCD is not set CONFIG_USB_LIBCOMPOSITE=m CONFIG_USB_F_ACM=m CONFIG_USB_F_SS_LB=m CONFIG_USB_U_SERIAL=m CONFIG_USB_U_ETHER=m CONFIG_USB_U_AUDIO=m CONFIG_USB_F_SERIAL=m CONFIG_USB_F_OBEX=m CONFIG_USB_F_NCM=m CONFIG_USB_F_ECM=m CONFIG_USB_F_EEM=m CONFIG_USB_F_SUBSET=m CONFIG_USB_F_RNDIS=m CONFIG_USB_F_MASS_STORAGE=m CONFIG_USB_F_FS=m CONFIG_USB_F_UAC1=m CONFIG_USB_F_UAC1_LEGACY=m CONFIG_USB_F_UAC2=m CONFIG_USB_F_UVC=m CONFIG_USB_F_MIDI=m CONFIG_USB_F_HID=m CONFIG_USB_F_PRINTER=m CONFIG_USB_CONFIGFS=m CONFIG_USB_CONFIGFS_SERIAL=y CONFIG_USB_CONFIGFS_ACM=y CONFIG_USB_CONFIGFS_OBEX=y CONFIG_USB_CONFIGFS_NCM=y CONFIG_USB_CONFIGFS_ECM=y CONFIG_USB_CONFIGFS_ECM_SUBSET=y CONFIG_USB_CONFIGFS_RNDIS=y CONFIG_USB_CONFIGFS_EEM=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y CONFIG_USB_CONFIGFS_F_LB_SS=y CONFIG_USB_CONFIGFS_F_FS=y CONFIG_USB_CONFIGFS_F_UAC1=y CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y CONFIG_USB_CONFIGFS_F_UAC2=y CONFIG_USB_CONFIGFS_F_MIDI=y CONFIG_USB_CONFIGFS_F_HID=y CONFIG_USB_CONFIGFS_F_UVC=y CONFIG_USB_CONFIGFS_F_PRINTER=y # CONFIG_USB_ZERO is not set # CONFIG_USB_AUDIO is not set CONFIG_USB_ETH=m CONFIG_USB_ETH_RNDIS=y # CONFIG_USB_ETH_EEM is not set # CONFIG_USB_G_NCM is not set # CONFIG_USB_GADGETFS is not set # CONFIG_USB_FUNCTIONFS is not set # CONFIG_USB_MASS_STORAGE is not set # CONFIG_USB_G_SERIAL is not set # CONFIG_USB_MIDI_GADGET is not set # CONFIG_USB_G_PRINTER is not set # CONFIG_USB_CDC_COMPOSITE is not set # CONFIG_USB_G_ACM_MS is not set # CONFIG_USB_G_MULTI is not set # CONFIG_USB_G_HID is not set # CONFIG_USB_G_DBGP is not set # CONFIG_USB_G_WEBCAM is not set # CONFIG_TYPEC is not set CONFIG_USB_ROLE_SWITCH=m # CONFIG_USB_LED_TRIG is not set # CONFIG_USB_ULPI_BUS is not set # CONFIG_UWB is not set CONFIG_MMC=y CONFIG_PWRSEQ_EMMC=y # CONFIG_PWRSEQ_SD8787 is not set CONFIG_PWRSEQ_SIMPLE=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=16 # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_DEBUG is not set # CONFIG_MMC_SDHCI is not set # CONFIG_MMC_TIFM_SD is not set # CONFIG_MMC_SPI is not set # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set # CONFIG_MMC_CQHCI is not set # CONFIG_MMC_TOSHIBA_PCI is not set CONFIG_MMC_MTK=y # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y CONFIG_LEDS_CLASS_FLASH=m # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set # # LED drivers # # CONFIG_LEDS_AAT1290 is not set # CONFIG_LEDS_AN30259A is not set # CONFIG_LEDS_AS3645A is not set # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set # CONFIG_LEDS_CR0014114 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3642 is not set # CONFIG_LEDS_LM3692X is not set # CONFIG_LEDS_LM3601X is not set CONFIG_LEDS_MT6323=y # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP3952 is not set # CONFIG_LEDS_LP5521 is not set # CONFIG_LEDS_LP5523 is not set # CONFIG_LEDS_LP5562 is not set # CONFIG_LEDS_LP8501 is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set CONFIG_LEDS_PCA963X=y # CONFIG_LEDS_DAC124S085 is not set CONFIG_LEDS_PWM=y # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_TLC591XX is not set # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_KTD2692 is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # # CONFIG_LEDS_BLINKM is not set # CONFIG_LEDS_SYSCON is not set # CONFIG_LEDS_MLXREG is not set # CONFIG_LEDS_USER is not set # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y CONFIG_LEDS_TRIGGER_ONESHOT=y # CONFIG_LEDS_TRIGGER_DISK is not set # CONFIG_LEDS_TRIGGER_MTD is not set CONFIG_LEDS_TRIGGER_HEARTBEAT=y CONFIG_LEDS_TRIGGER_BACKLIGHT=y CONFIG_LEDS_TRIGGER_CPU=y # CONFIG_LEDS_TRIGGER_ACTIVITY is not set CONFIG_LEDS_TRIGGER_GPIO=y CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # CONFIG_LEDS_TRIGGER_TRANSIENT=y CONFIG_LEDS_TRIGGER_CAMERA=y # CONFIG_LEDS_TRIGGER_PANIC is not set # CONFIG_LEDS_TRIGGER_NETDEV is not set # CONFIG_LEDS_TRIGGER_PATTERN is not set # CONFIG_LEDS_TRIGGER_AUDIO is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_ATOMIC_SCRUB=y CONFIG_EDAC_SUPPORT=y CONFIG_EDAC=y CONFIG_EDAC_LEGACY_SYSFS=y # CONFIG_EDAC_DEBUG is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set CONFIG_RTC_NVMEM=y # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set CONFIG_RTC_DRV_DS1307=y CONFIG_RTC_DRV_DS1307_CENTURY=y # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set CONFIG_RTC_DRV_HYM8563=m # CONFIG_RTC_DRV_MAX6900 is not set CONFIG_RTC_DRV_RS5C372=m # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_ISL12026 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set # CONFIG_RTC_DRV_PCF85363 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set CONFIG_RTC_DRV_BQ32K=m CONFIG_RTC_DRV_TWL4030=y CONFIG_RTC_DRV_S35390A=m # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set CONFIG_RTC_DRV_RX8581=m # CONFIG_RTC_DRV_RX8025 is not set CONFIG_RTC_DRV_EM3027=y # CONFIG_RTC_DRV_RV3028 is not set # CONFIG_RTC_DRV_RV8803 is not set # CONFIG_RTC_DRV_SD3078 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6916 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RX4581 is not set # CONFIG_RTC_DRV_RX6110 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_MCP795 is not set CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_PCF2127 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set CONFIG_RTC_DRV_EFI=m # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # # CONFIG_RTC_DRV_CADENCE is not set # CONFIG_RTC_DRV_FTRTC010 is not set # CONFIG_RTC_DRV_SNVS is not set CONFIG_RTC_DRV_MT6397=y # CONFIG_RTC_DRV_MT7622 is not set # CONFIG_RTC_DRV_R7301 is not set # # HID Sensor RTC drivers # CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # CONFIG_ALTERA_MSGDMA is not set # CONFIG_DW_AXI_DMAC is not set # CONFIG_FSL_EDMA is not set # CONFIG_FSL_QDMA is not set # CONFIG_INTEL_IDMA64 is not set # CONFIG_NBPFAXI_DMA is not set CONFIG_MTK_HSDMA=y # CONFIG_MTK_CQDMA is not set # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set # CONFIG_DW_DMAC is not set # CONFIG_DW_DMAC_PCI is not set # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set CONFIG_DMATEST=m CONFIG_DMA_ENGINE_RAID=y # # DMABUF options # CONFIG_SYNC_FILE=y # CONFIG_SW_SYNC is not set # CONFIG_UDMABUF is not set # CONFIG_AUXDISPLAY is not set # CONFIG_PANEL is not set # CONFIG_UIO is not set # CONFIG_VFIO is not set # CONFIG_VIRT_DRIVERS is not set CONFIG_VIRTIO=y CONFIG_VIRTIO_MENU=y CONFIG_VIRTIO_PCI=y CONFIG_VIRTIO_PCI_LEGACY=y # CONFIG_VIRTIO_BALLOON is not set # CONFIG_VIRTIO_INPUT is not set CONFIG_VIRTIO_MMIO=y # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set # # Microsoft Hyper-V guest support # CONFIG_STAGING=y # CONFIG_PRISM2_USB is not set # CONFIG_COMEDI is not set # CONFIG_RTL8192U is not set # CONFIG_RTLLIB is not set # CONFIG_RTL8723BS is not set # CONFIG_R8712U is not set # CONFIG_R8188EU is not set # CONFIG_R8822BE is not set # CONFIG_RTS5208 is not set # CONFIG_VT6655 is not set # CONFIG_VT6656 is not set # # IIO staging drivers # # # Accelerometers # # CONFIG_ADIS16203 is not set # CONFIG_ADIS16240 is not set # # Analog to digital converters # # CONFIG_AD7780 is not set # CONFIG_AD7816 is not set # CONFIG_AD7192 is not set # CONFIG_AD7280 is not set # # Analog digital bi-direction converters # # CONFIG_ADT7316 is not set # # Capacitance to digital converters # # CONFIG_AD7150 is not set # CONFIG_AD7746 is not set # # Direct Digital Synthesis # # CONFIG_AD9832 is not set # CONFIG_AD9834 is not set # # Network Analyzer, Impedance Converters # # CONFIG_AD5933 is not set # # Active energy metering IC # # CONFIG_ADE7854 is not set # # Resolver to digital converters # # CONFIG_AD2S1210 is not set # CONFIG_FB_SM750 is not set # # Speakup console speech # # CONFIG_SPEAKUP is not set # CONFIG_STAGING_MEDIA is not set # # Android # CONFIG_STAGING_BOARD=y # CONFIG_LTE_GDM724X is not set # CONFIG_GS_FPGABOOT is not set # CONFIG_UNISYSSPAR is not set # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set # CONFIG_FB_TFT is not set # CONFIG_WILC1000_SDIO is not set # CONFIG_WILC1000_SPI is not set # CONFIG_MOST is not set # CONFIG_KS7010 is not set # CONFIG_GREYBUS is not set # CONFIG_PI433 is not set # # Gasket devices # CONFIG_XIL_AXIS_FIFO=m # CONFIG_EROFS_FS is not set # CONFIG_GOLDFISH is not set CONFIG_CHROME_PLATFORMS=y # CONFIG_MELLANOX_PLATFORM is not set CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Common Clock Framework # # CONFIG_CLK_HSDK is not set CONFIG_COMMON_CLK_MAX9485=m # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI544 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set # CONFIG_COMMON_CLK_CS2000_CP is not set # CONFIG_CLK_QORIQ is not set # CONFIG_COMMON_CLK_PWM is not set # CONFIG_COMMON_CLK_VC5 is not set # CONFIG_COMMON_CLK_BD718XX is not set # CONFIG_COMMON_CLK_FIXED_MMIO is not set # # Clock driver for MediaTek SoC # CONFIG_COMMON_CLK_MEDIATEK=y CONFIG_COMMON_CLK_MT2701=y CONFIG_COMMON_CLK_MT2701_MMSYS=y CONFIG_COMMON_CLK_MT2701_IMGSYS=y CONFIG_COMMON_CLK_MT2701_VDECSYS=y CONFIG_COMMON_CLK_MT2701_HIFSYS=y CONFIG_COMMON_CLK_MT2701_ETHSYS=y CONFIG_COMMON_CLK_MT2701_BDPSYS=y CONFIG_COMMON_CLK_MT2701_AUDSYS=y CONFIG_COMMON_CLK_MT2701_G3DSYS=y CONFIG_COMMON_CLK_MT7622=y # CONFIG_COMMON_CLK_MT7622_ETHSYS is not set # CONFIG_COMMON_CLK_MT7622_HIFSYS is not set # CONFIG_COMMON_CLK_MT7622_AUDSYS is not set CONFIG_COMMON_CLK_MT7629=y # CONFIG_COMMON_CLK_MT7629_ETHSYS is not set # CONFIG_COMMON_CLK_MT7629_HIFSYS is not set CONFIG_COMMON_CLK_MT8135=y CONFIG_COMMON_CLK_MT8173=y # CONFIG_HWSPINLOCK is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_CLKSRC_MMIO=y CONFIG_ARM_ARCH_TIMER=y CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y CONFIG_ARM_TIMER_SP804=y CONFIG_MTK_TIMER=y CONFIG_CLKSRC_VERSATILE=y CONFIG_MAILBOX=y # CONFIG_PLATFORM_MHU is not set # CONFIG_ALTERA_MBOX is not set # CONFIG_MAILBOX_TEST is not set CONFIG_MTK_CMDQ_MBOX=m CONFIG_IOMMU_IOVA=y CONFIG_IOMMU_API=y CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # CONFIG_IOMMU_IO_PGTABLE=y # CONFIG_IOMMU_IO_PGTABLE_LPAE is not set CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y # CONFIG_IOMMU_IO_PGTABLE_ARMV7S_SELFTEST is not set # CONFIG_IOMMU_DEBUGFS is not set # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set CONFIG_OF_IOMMU=y CONFIG_IOMMU_DMA=y # CONFIG_ARM_SMMU is not set CONFIG_MTK_IOMMU=y # CONFIG_MTK_IOMMU_V1 is not set # # Remoteproc drivers # CONFIG_REMOTEPROC=m # # Rpmsg drivers # CONFIG_RPMSG=m # CONFIG_RPMSG_CHAR is not set # CONFIG_RPMSG_QCOM_GLINK_RPM is not set CONFIG_RPMSG_VIRTIO=m # CONFIG_SOUNDWIRE is not set # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # # Broadcom SoC drivers # CONFIG_SOC_BRCMSTB=y # # NXP/Freescale QorIQ SoC drivers # # # i.MX SoC drivers # # # MediaTek SoC drivers # # CONFIG_MTK_CMDQ is not set CONFIG_MTK_INFRACFG=y CONFIG_MTK_PMIC_WRAP=y CONFIG_MTK_SCPSYS=y # # Qualcomm SoC drivers # # CONFIG_SOC_TI is not set # # Xilinx SoC drivers # # CONFIG_XILINX_VCU is not set CONFIG_PM_DEVFREQ=y # # DEVFREQ Governors # CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=m # CONFIG_DEVFREQ_GOV_PERFORMANCE is not set # CONFIG_DEVFREQ_GOV_POWERSAVE is not set # CONFIG_DEVFREQ_GOV_USERSPACE is not set # CONFIG_DEVFREQ_GOV_PASSIVE is not set # # DEVFREQ Drivers # # CONFIG_PM_DEVFREQ_EVENT is not set CONFIG_EXTCON=y # # Extcon Device Drivers # # CONFIG_EXTCON_ADC_JACK is not set # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_MAX3355 is not set # CONFIG_EXTCON_PTN5150 is not set # CONFIG_EXTCON_RT8973A is not set # CONFIG_EXTCON_SM5502 is not set # CONFIG_EXTCON_USB_GPIO is not set CONFIG_MEMORY=y CONFIG_MTK_SMI=y CONFIG_IIO=y CONFIG_IIO_BUFFER=y # CONFIG_IIO_BUFFER_CB is not set # CONFIG_IIO_BUFFER_HW_CONSUMER is not set CONFIG_IIO_KFIFO_BUF=y CONFIG_IIO_TRIGGERED_BUFFER=y CONFIG_IIO_CONFIGFS=y CONFIG_IIO_TRIGGER=y CONFIG_IIO_CONSUMERS_PER_TRIGGER=2 # CONFIG_IIO_SW_DEVICE is not set CONFIG_IIO_SW_TRIGGER=y # # Accelerometers # # CONFIG_ADIS16201 is not set # CONFIG_ADIS16209 is not set # CONFIG_ADXL372_SPI is not set # CONFIG_ADXL372_I2C is not set # CONFIG_BMA180 is not set # CONFIG_BMA220 is not set # CONFIG_BMC150_ACCEL is not set # CONFIG_DA280 is not set # CONFIG_DA311 is not set # CONFIG_DMARD06 is not set # CONFIG_DMARD09 is not set # CONFIG_DMARD10 is not set # CONFIG_IIO_CROS_EC_ACCEL_LEGACY is not set # CONFIG_IIO_ST_ACCEL_3AXIS is not set # CONFIG_KXSD9 is not set # CONFIG_KXCJK1013 is not set # CONFIG_MC3230 is not set # CONFIG_MMA7455_I2C is not set # CONFIG_MMA7455_SPI is not set # CONFIG_MMA7660 is not set # CONFIG_MMA8452 is not set # CONFIG_MMA9551 is not set # CONFIG_MMA9553 is not set # CONFIG_MXC4005 is not set # CONFIG_MXC6255 is not set # CONFIG_SCA3000 is not set # CONFIG_STK8312 is not set # CONFIG_STK8BA50 is not set # # Analog to digital converters # # CONFIG_AD7124 is not set # CONFIG_AD7266 is not set # CONFIG_AD7291 is not set # CONFIG_AD7298 is not set # CONFIG_AD7476 is not set # CONFIG_AD7606_IFACE_PARALLEL is not set # CONFIG_AD7606_IFACE_SPI is not set # CONFIG_AD7766 is not set # CONFIG_AD7768_1 is not set # CONFIG_AD7791 is not set # CONFIG_AD7793 is not set # CONFIG_AD7887 is not set # CONFIG_AD7923 is not set # CONFIG_AD7949 is not set # CONFIG_AD799X is not set # CONFIG_CC10001_ADC is not set # CONFIG_ENVELOPE_DETECTOR is not set # CONFIG_HI8435 is not set # CONFIG_HX711 is not set # CONFIG_INA2XX_ADC is not set # CONFIG_LTC2471 is not set # CONFIG_LTC2485 is not set # CONFIG_LTC2497 is not set # CONFIG_MAX1027 is not set # CONFIG_MAX11100 is not set # CONFIG_MAX1118 is not set # CONFIG_MAX1363 is not set # CONFIG_MAX9611 is not set # CONFIG_MCP320X is not set # CONFIG_MCP3422 is not set # CONFIG_MCP3911 is not set CONFIG_MEDIATEK_MT6577_AUXADC=m # CONFIG_NAU7802 is not set # CONFIG_QCOM_SPMI_IADC is not set # CONFIG_QCOM_SPMI_VADC is not set # CONFIG_QCOM_SPMI_ADC5 is not set # CONFIG_SD_ADC_MODULATOR is not set # CONFIG_TI_ADC081C is not set # CONFIG_TI_ADC0832 is not set # CONFIG_TI_ADC084S021 is not set # CONFIG_TI_ADC12138 is not set # CONFIG_TI_ADC108S102 is not set # CONFIG_TI_ADC128S052 is not set # CONFIG_TI_ADC161S626 is not set # CONFIG_TI_ADS1015 is not set # CONFIG_TI_ADS7950 is not set # CONFIG_TI_ADS8688 is not set # CONFIG_TI_ADS124S08 is not set # CONFIG_TI_TLC4541 is not set # CONFIG_TWL4030_MADC is not set # CONFIG_TWL6030_GPADC is not set CONFIG_VF610_ADC=m # # Analog Front Ends # # CONFIG_IIO_RESCALE is not set # # Amplifiers # # CONFIG_AD8366 is not set # # Chemical Sensors # # CONFIG_ATLAS_PH_SENSOR is not set CONFIG_BME680=m CONFIG_BME680_I2C=m CONFIG_BME680_SPI=m # CONFIG_CCS811 is not set # CONFIG_IAQCORE is not set # CONFIG_SENSIRION_SGP30 is not set # CONFIG_SPS30 is not set # CONFIG_VZ89X is not set # # Hid Sensor IIO Common # # # SSP Sensor Common # # CONFIG_IIO_SSP_SENSORHUB is not set # # Counters # # # Digital to analog converters # # CONFIG_AD5064 is not set # CONFIG_AD5360 is not set # CONFIG_AD5380 is not set # CONFIG_AD5421 is not set # CONFIG_AD5446 is not set # CONFIG_AD5449 is not set # CONFIG_AD5592R is not set # CONFIG_AD5593R is not set # CONFIG_AD5504 is not set # CONFIG_AD5624R_SPI is not set # CONFIG_LTC1660 is not set # CONFIG_LTC2632 is not set # CONFIG_AD5686_SPI is not set # CONFIG_AD5696_I2C is not set # CONFIG_AD5755 is not set CONFIG_AD5758=m # CONFIG_AD5761 is not set # CONFIG_AD5764 is not set # CONFIG_AD5791 is not set # CONFIG_AD7303 is not set # CONFIG_AD8801 is not set # CONFIG_DPOT_DAC is not set # CONFIG_DS4424 is not set # CONFIG_M62332 is not set # CONFIG_MAX517 is not set # CONFIG_MAX5821 is not set # CONFIG_MCP4725 is not set # CONFIG_MCP4922 is not set # CONFIG_TI_DAC082S085 is not set # CONFIG_TI_DAC5571 is not set # CONFIG_TI_DAC7311 is not set # CONFIG_TI_DAC7612 is not set # CONFIG_VF610_DAC is not set # # IIO dummy driver # # # Frequency Synthesizers DDS/PLL # # # Clock Generator/Distribution # # CONFIG_AD9523 is not set # # Phase-Locked Loop (PLL) frequency synthesizers # # CONFIG_ADF4350 is not set # # Digital gyroscope sensors # # CONFIG_ADIS16080 is not set # CONFIG_ADIS16130 is not set # CONFIG_ADIS16136 is not set # CONFIG_ADIS16260 is not set # CONFIG_ADXRS450 is not set # CONFIG_BMG160 is not set CONFIG_MPU3050=y CONFIG_MPU3050_I2C=y # CONFIG_IIO_ST_GYRO_3AXIS is not set # CONFIG_ITG3200 is not set # # Health Sensors # # # Heart Rate Monitors # # CONFIG_AFE4403 is not set # CONFIG_AFE4404 is not set # CONFIG_MAX30100 is not set # CONFIG_MAX30102 is not set # # Humidity sensors # # CONFIG_AM2315 is not set # CONFIG_DHT11 is not set # CONFIG_HDC100X is not set # CONFIG_HTS221 is not set # CONFIG_HTU21 is not set # CONFIG_SI7005 is not set # CONFIG_SI7020 is not set # # Inertial measurement units # # CONFIG_ADIS16400 is not set # CONFIG_ADIS16480 is not set # CONFIG_BMI160_I2C is not set # CONFIG_BMI160_SPI is not set # CONFIG_KMX61 is not set # CONFIG_INV_MPU6050_I2C is not set # CONFIG_INV_MPU6050_SPI is not set # CONFIG_IIO_ST_LSM6DSX is not set # # Light sensors # # CONFIG_ADJD_S311 is not set # CONFIG_AL3320A is not set # CONFIG_APDS9300 is not set # CONFIG_APDS9960 is not set # CONFIG_BH1750 is not set # CONFIG_BH1780 is not set # CONFIG_CM32181 is not set # CONFIG_CM3232 is not set # CONFIG_CM3323 is not set # CONFIG_CM3605 is not set CONFIG_CM36651=m # CONFIG_GP2AP020A00F is not set CONFIG_SENSORS_ISL29018=y CONFIG_SENSORS_ISL29028=y # CONFIG_ISL29125 is not set # CONFIG_JSA1212 is not set # CONFIG_RPR0521 is not set # CONFIG_LTR501 is not set # CONFIG_LV0104CS is not set # CONFIG_MAX44000 is not set # CONFIG_MAX44009 is not set # CONFIG_OPT3001 is not set # CONFIG_PA12203001 is not set CONFIG_SI1133=m # CONFIG_SI1145 is not set # CONFIG_STK3310 is not set # CONFIG_ST_UVIS25 is not set # CONFIG_TCS3414 is not set # CONFIG_TCS3472 is not set # CONFIG_SENSORS_TSL2563 is not set # CONFIG_TSL2583 is not set # CONFIG_TSL2772 is not set # CONFIG_TSL4531 is not set # CONFIG_US5182D is not set # CONFIG_VCNL4000 is not set # CONFIG_VCNL4035 is not set # CONFIG_VEML6070 is not set # CONFIG_VL6180 is not set # CONFIG_ZOPT2201 is not set # # Magnetometer sensors # # CONFIG_AK8974 is not set CONFIG_AK8975=y # CONFIG_AK09911 is not set # CONFIG_BMC150_MAGN_I2C is not set # CONFIG_BMC150_MAGN_SPI is not set # CONFIG_MAG3110 is not set # CONFIG_MMC35240 is not set # CONFIG_IIO_ST_MAGN_3AXIS is not set # CONFIG_SENSORS_HMC5843_I2C is not set # CONFIG_SENSORS_HMC5843_SPI is not set # CONFIG_SENSORS_RM3100_I2C is not set # CONFIG_SENSORS_RM3100_SPI is not set # # Multiplexers # # CONFIG_IIO_MUX is not set # # Inclinometer sensors # # # Triggers - standalone # CONFIG_IIO_HRTIMER_TRIGGER=y # CONFIG_IIO_INTERRUPT_TRIGGER is not set # CONFIG_IIO_TIGHTLOOP_TRIGGER is not set # CONFIG_IIO_SYSFS_TRIGGER is not set # # Digital potentiometers # # CONFIG_AD5272 is not set # CONFIG_DS1803 is not set # CONFIG_MAX5481 is not set # CONFIG_MAX5487 is not set # CONFIG_MCP4018 is not set # CONFIG_MCP4131 is not set # CONFIG_MCP4531 is not set # CONFIG_MCP41010 is not set # CONFIG_TPL0102 is not set # # Digital potentiostats # # CONFIG_LMP91000 is not set # # Pressure sensors # # CONFIG_ABP060MG is not set # CONFIG_BMP280 is not set # CONFIG_HP03 is not set # CONFIG_MPL115_I2C is not set # CONFIG_MPL115_SPI is not set # CONFIG_MPL3115 is not set # CONFIG_MS5611 is not set # CONFIG_MS5637 is not set # CONFIG_IIO_ST_PRESS is not set # CONFIG_T5403 is not set # CONFIG_HP206C is not set # CONFIG_ZPA2326 is not set # # Lightning sensors # # CONFIG_AS3935 is not set # # Proximity and distance sensors # CONFIG_ISL29501=m # CONFIG_LIDAR_LITE_V2 is not set # CONFIG_RFD77402 is not set # CONFIG_SRF04 is not set # CONFIG_SX9500 is not set # CONFIG_SRF08 is not set # CONFIG_VL53L0X_I2C is not set # # Resolver to digital converters # # CONFIG_AD2S90 is not set # CONFIG_AD2S1200 is not set # # Temperature sensors # # CONFIG_MAXIM_THERMOCOUPLE is not set # CONFIG_MLX90614 is not set # CONFIG_MLX90632 is not set # CONFIG_TMP006 is not set # CONFIG_TMP007 is not set # CONFIG_TSYS01 is not set # CONFIG_TSYS02D is not set # CONFIG_NTB is not set # CONFIG_VME_BUS is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_FSL_FTM is not set # CONFIG_PWM_MTK_DISP is not set CONFIG_PWM_MEDIATEK=m # CONFIG_PWM_PCA9685 is not set # CONFIG_PWM_TWL is not set # CONFIG_PWM_TWL_LED is not set # # IRQ chip support # CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y CONFIG_ARM_GIC_MAX_NR=1 # CONFIG_IPACK_BUS is not set CONFIG_RESET_CONTROLLER=y # CONFIG_RESET_TI_SYSCON is not set # CONFIG_FMC is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y # CONFIG_BCM_KONA_USB2_PHY is not set # CONFIG_PHY_CADENCE_DP is not set # CONFIG_PHY_CADENCE_DPHY is not set # CONFIG_PHY_CADENCE_SIERRA is not set # CONFIG_PHY_FSL_IMX8MQ_USB is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set CONFIG_PHY_MTK_TPHY=y CONFIG_PHY_MTK_XSPHY=y # CONFIG_PHY_CPCAP_USB is not set # CONFIG_PHY_MAPPHONE_MDM6600 is not set # CONFIG_PHY_OCELOT_SERDES is not set # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # # CONFIG_ARM_CCI_PMU is not set # CONFIG_ARM_CCN is not set CONFIG_ARM_PMU=y CONFIG_RAS=y # # Android # # CONFIG_ANDROID is not set # CONFIG_DAX is not set CONFIG_NVMEM=y CONFIG_MTK_EFUSE=m # # HW tracing support # # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # CONFIG_FPGA is not set # CONFIG_FSI is not set # CONFIG_TEE is not set CONFIG_MULTIPLEXER=m # # Multiplexer drivers # # CONFIG_MUX_ADG792A is not set # CONFIG_MUX_ADGS1408 is not set # CONFIG_MUX_GPIO is not set # CONFIG_MUX_MMIO is not set CONFIG_PM_OPP=y # CONFIG_SIOX is not set # CONFIG_SLIMBUS is not set # CONFIG_INTERCONNECT is not set # # File systems # CONFIG_DCACHE_WORD_ACCESS=y CONFIG_VALIDATE_FS_PARSER=y CONFIG_FS_IOMAP=y # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set CONFIG_EXT4_FS=y CONFIG_EXT4_USE_FOR_EXT2=y CONFIG_EXT4_FS_POSIX_ACL=y CONFIG_EXT4_FS_SECURITY=y # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set CONFIG_XFS_FS=m # CONFIG_XFS_QUOTA is not set # CONFIG_XFS_POSIX_ACL is not set # CONFIG_XFS_RT is not set # CONFIG_XFS_ONLINE_SCRUB is not set # CONFIG_XFS_WARN is not set # CONFIG_XFS_DEBUG is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set CONFIG_BTRFS_FS=y # CONFIG_BTRFS_FS_POSIX_ACL is not set # CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set # CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set # CONFIG_BTRFS_DEBUG is not set # CONFIG_BTRFS_ASSERT is not set # CONFIG_BTRFS_FS_REF_VERIFY is not set # CONFIG_NILFS2_FS is not set CONFIG_F2FS_FS=m CONFIG_F2FS_STAT_FS=y CONFIG_F2FS_FS_XATTR=y CONFIG_F2FS_FS_POSIX_ACL=y # CONFIG_F2FS_FS_SECURITY is not set # CONFIG_F2FS_CHECK_FS is not set # CONFIG_F2FS_FAULT_INJECTION is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y CONFIG_EXPORTFS_BLOCK_OPS=y CONFIG_FILE_LOCKING=y CONFIG_MANDATORY_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set CONFIG_AUTOFS4_FS=y CONFIG_AUTOFS_FS=y CONFIG_FUSE_FS=y # CONFIG_CUSE is not set CONFIG_OVERLAY_FS=y # CONFIG_OVERLAY_FS_REDIRECT_DIR is not set CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y # CONFIG_OVERLAY_FS_INDEX is not set # CONFIG_OVERLAY_FS_XINO_AUTO is not set # CONFIG_OVERLAY_FS_METACOPY is not set # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_FAT_DEFAULT_UTF8 is not set CONFIG_NTFS_FS=y # CONFIG_NTFS_DEBUG is not set # CONFIG_NTFS_RW is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y # CONFIG_PROC_CHILDREN is not set CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y CONFIG_MEMFD_CREATE=y CONFIG_CONFIGFS_FS=y CONFIG_EFIVAR_FS=m CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS2_FS is not set CONFIG_UBIFS_FS=y # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y # CONFIG_UBIFS_ATIME_SUPPORT is not set CONFIG_UBIFS_FS_XATTR=y CONFIG_UBIFS_FS_SECURITY=y # CONFIG_UBIFS_FS_AUTHENTICATION is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y CONFIG_SQUASHFS_FILE_CACHE=y # CONFIG_SQUASHFS_FILE_DIRECT is not set CONFIG_SQUASHFS_DECOMP_SINGLE=y # CONFIG_SQUASHFS_DECOMP_MULTI is not set # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set # CONFIG_SQUASHFS_XATTR is not set CONFIG_SQUASHFS_ZLIB=y # CONFIG_SQUASHFS_LZ4 is not set CONFIG_SQUASHFS_LZO=y CONFIG_SQUASHFS_XZ=y # CONFIG_SQUASHFS_ZSTD is not set # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set CONFIG_PSTORE=y CONFIG_PSTORE_DEFLATE_COMPRESS=y # CONFIG_PSTORE_LZO_COMPRESS is not set # CONFIG_PSTORE_LZ4_COMPRESS is not set # CONFIG_PSTORE_LZ4HC_COMPRESS is not set # CONFIG_PSTORE_842_COMPRESS is not set # CONFIG_PSTORE_ZSTD_COMPRESS is not set CONFIG_PSTORE_COMPRESS=y CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y CONFIG_PSTORE_COMPRESS_DEFAULT="deflate" CONFIG_PSTORE_CONSOLE=y CONFIG_PSTORE_PMSG=y CONFIG_PSTORE_RAM=y # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V2=y CONFIG_NFS_V3=y CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=y CONFIG_NFS_SWAP=y CONFIG_NFS_V4_1=y CONFIG_NFS_V4_2=y CONFIG_PNFS_FILE_LAYOUT=y CONFIG_PNFS_BLOCK=y CONFIG_PNFS_FLEXFILE_LAYOUT=m CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org" CONFIG_NFS_V4_1_MIGRATION=y CONFIG_ROOT_NFS=y CONFIG_NFS_USE_LEGACY_DNS=y CONFIG_NFSD=m CONFIG_NFSD_V2_ACL=y CONFIG_NFSD_V3=y CONFIG_NFSD_V3_ACL=y CONFIG_NFSD_V4=y CONFIG_NFSD_PNFS=y CONFIG_NFSD_BLOCKLAYOUT=y CONFIG_NFSD_SCSILAYOUT=y CONFIG_NFSD_FLEXFILELAYOUT=y CONFIG_NFSD_FAULT_INJECTION=y CONFIG_GRACE_PERIOD=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_ACL_SUPPORT=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y CONFIG_SUNRPC_BACKCHANNEL=y CONFIG_SUNRPC_SWAP=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set CONFIG_CIFS=m # CONFIG_CIFS_STATS2 is not set CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y # CONFIG_CIFS_WEAK_PW_HASH is not set # CONFIG_CIFS_UPCALL is not set # CONFIG_CIFS_XATTR is not set CONFIG_CIFS_DEBUG=y # CONFIG_CIFS_DEBUG2 is not set # CONFIG_CIFS_DEBUG_DUMP_KEYS is not set # CONFIG_CIFS_DFS_UPCALL is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set # CONFIG_9P_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set CONFIG_NLS_UTF8=y # CONFIG_DLM is not set # # Security options # CONFIG_KEYS=y # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_BIG_KEYS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_FORTIFY_SOURCE is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="yama,loadpin,safesetid,integrity" CONFIG_XOR_BLOCKS=y CONFIG_ASYNC_CORE=y CONFIG_ASYNC_MEMCPY=y CONFIG_ASYNC_XOR=y CONFIG_ASYNC_PQ=y CONFIG_ASYNC_RAID6_RECOV=y CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=y CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=y CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=y CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=y CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_KPP=y CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_RSA=y # CONFIG_CRYPTO_DH is not set CONFIG_CRYPTO_ECDH=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y CONFIG_CRYPTO_USER=m CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_GF128MUL=y CONFIG_CRYPTO_NULL=y CONFIG_CRYPTO_NULL2=y # CONFIG_CRYPTO_PCRYPT is not set CONFIG_CRYPTO_WORKQUEUE=y CONFIG_CRYPTO_CRYPTD=m CONFIG_CRYPTO_AUTHENC=m # CONFIG_CRYPTO_TEST is not set CONFIG_CRYPTO_SIMD=m # # Authenticated Encryption with Associated Data # CONFIG_CRYPTO_CCM=y CONFIG_CRYPTO_GCM=y # CONFIG_CRYPTO_CHACHA20POLY1305 is not set CONFIG_CRYPTO_AEGIS128=m CONFIG_CRYPTO_AEGIS128L=m CONFIG_CRYPTO_AEGIS256=m CONFIG_CRYPTO_MORUS640=m CONFIG_CRYPTO_MORUS1280=m CONFIG_CRYPTO_SEQIV=y CONFIG_CRYPTO_ECHAINIV=m # # Block modes # CONFIG_CRYPTO_CBC=y # CONFIG_CRYPTO_CFB is not set CONFIG_CRYPTO_CTR=y # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=y # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_ADIANTUM is not set # # Hash modes # CONFIG_CRYPTO_CMAC=y CONFIG_CRYPTO_HMAC=y # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=y CONFIG_CRYPTO_CRC32=m CONFIG_CRYPTO_CRCT10DIF=y CONFIG_CRYPTO_GHASH=y # CONFIG_CRYPTO_POLY1305 is not set CONFIG_CRYPTO_MD4=m CONFIG_CRYPTO_MD5=y CONFIG_CRYPTO_MICHAEL_MIC=m # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set CONFIG_CRYPTO_SHA1=y CONFIG_CRYPTO_SHA256=y CONFIG_CRYPTO_SHA512=y # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_SM3 is not set # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set CONFIG_CRYPTO_ARC4=y # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=m # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set CONFIG_CRYPTO_CHACHA20=m # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_SM4 is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # CONFIG_CRYPTO_DEFLATE=y CONFIG_CRYPTO_LZO=y # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set CONFIG_CRYPTO_ZSTD=m # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_DRBG_MENU=y CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=y CONFIG_CRYPTO_JITTERENTROPY=y CONFIG_CRYPTO_USER_API=m CONFIG_CRYPTO_USER_API_HASH=m CONFIG_CRYPTO_USER_API_SKCIPHER=m CONFIG_CRYPTO_USER_API_RNG=m CONFIG_CRYPTO_USER_API_AEAD=m # CONFIG_CRYPTO_STATS is not set CONFIG_CRYPTO_HASH_INFO=y CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_HIFN_795X is not set CONFIG_CRYPTO_DEV_MEDIATEK=y # CONFIG_CRYPTO_DEV_VIRTIO is not set # CONFIG_CRYPTO_DEV_CCREE is not set CONFIG_ASYMMETRIC_KEY_TYPE=y CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y CONFIG_X509_CERTIFICATE_PARSER=y # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set CONFIG_PKCS7_MESSAGE_PARSER=y # CONFIG_PKCS7_TEST_KEY is not set # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set # # Certificates for signature checking # CONFIG_SYSTEM_TRUSTED_KEYRING=y CONFIG_SYSTEM_TRUSTED_KEYS="" # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set # CONFIG_SECONDARY_TRUSTED_KEYRING is not set # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set CONFIG_BINARY_PRINTF=y # # Library routines # CONFIG_RAID6_PQ=y CONFIG_RAID6_PQ_BENCHMARK=y CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_RATIONAL=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y CONFIG_CRC_CCITT=m CONFIG_CRC16=y CONFIG_CRC_T10DIF=y CONFIG_CRC_ITU_T=m CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set # CONFIG_CRC64 is not set # CONFIG_CRC4 is not set CONFIG_CRC7=m CONFIG_LIBCRC32C=y CONFIG_CRC8=m CONFIG_XXHASH=y # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_ZSTD_COMPRESS=y CONFIG_ZSTD_DECOMPRESS=y CONFIG_XZ_DEC=y CONFIG_XZ_DEC_X86=y CONFIG_XZ_DEC_POWERPC=y CONFIG_XZ_DEC_IA64=y CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y CONFIG_XZ_DEC_SPARC=y CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_REED_SOLOMON=y CONFIG_REED_SOLOMON_ENC8=y CONFIG_REED_SOLOMON_DEC8=y CONFIG_TEXTSEARCH=y CONFIG_TEXTSEARCH_KMP=m CONFIG_TEXTSEARCH_BM=m CONFIG_TEXTSEARCH_FSM=m CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_NEED_SG_DMA_LENGTH=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_ARCH_HAS_SETUP_DMA_OPS=y CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y CONFIG_DMA_REMAP=y CONFIG_DMA_CMA=y # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=64 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 # CONFIG_DMA_API_DEBUG is not set CONFIG_SGL_ALLOC=y CONFIG_CPU_RMAP=y CONFIG_DQL=y CONFIG_GLOB=y # CONFIG_GLOB_SELFTEST is not set CONFIG_NLATTR=y CONFIG_CLZ_TAB=y CONFIG_CORDIC=m # CONFIG_DDR is not set # CONFIG_IRQ_POLL is not set CONFIG_MPILIB=y CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_UCS2_STRING=y CONFIG_FONT_SUPPORT=y # CONFIG_FONTS is not set CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y CONFIG_SG_POOL=y CONFIG_SBITMAP=y # CONFIG_STRING_SELFTEST is not set # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y # CONFIG_PRINTK_CALLER is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # # Compile-time checks and compiler options # # CONFIG_DEBUG_INFO is not set CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_UNUSED_SYMBOLS is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set CONFIG_MAGIC_SYSRQ=y CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1 CONFIG_MAGIC_SYSRQ_SERIAL=y CONFIG_DEBUG_KERNEL=y # # Memory Debugging # CONFIG_PAGE_EXTENSION=y # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_PAGE_REF is not set # CONFIG_DEBUG_RODATA_TEST is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_SLUB_STATS is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_VM is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_PER_CPU_MAPS is not set # CONFIG_DEBUG_HIGHMEM is not set CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_KASAN_STACK=1 CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y # CONFIG_KCOV is not set # CONFIG_DEBUG_SHIRQ is not set # # Debug Lockups and Hangs # # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 CONFIG_SCHED_DEBUG=y # CONFIG_SCHEDSTATS is not set # CONFIG_SCHED_STACK_END_CHECK is not set # CONFIG_DEBUG_TIMEKEEPING is not set # # Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_LOCK_DEBUGGING_SUPPORT=y # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set CONFIG_STACKTRACE=y # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set CONFIG_DEBUG_BUGVERBOSE=y # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PI_LIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_PERF_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 CONFIG_RCU_TRACE=y # CONFIG_RCU_EQS_DEBUG is not set # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set CONFIG_NOP_TRACER=y CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACE_CLOCK=y CONFIG_RING_BUFFER=y CONFIG_EVENT_TRACING=y CONFIG_CONTEXT_SWITCH_TRACER=y CONFIG_TRACING=y CONFIG_TRACING_SUPPORT=y CONFIG_FTRACE=y # CONFIG_FUNCTION_TRACER is not set # CONFIG_PREEMPTIRQ_EVENTS is not set # CONFIG_IRQSOFF_TRACER is not set # CONFIG_SCHED_TRACER is not set # CONFIG_HWLAT_TRACER is not set # CONFIG_ENABLE_DEFAULT_TRACERS is not set # CONFIG_FTRACE_SYSCALLS is not set # CONFIG_TRACER_SNAPSHOT is not set CONFIG_BRANCH_PROFILE_NONE=y # CONFIG_PROFILE_ANNOTATED_BRANCHES is not set # CONFIG_PROFILE_ALL_BRANCHES is not set # CONFIG_STACK_TRACER is not set # CONFIG_BLK_DEV_IO_TRACE is not set CONFIG_UPROBE_EVENTS=y CONFIG_BPF_EVENTS=y CONFIG_DYNAMIC_EVENTS=y CONFIG_PROBE_EVENTS=y # CONFIG_TRACEPOINT_BENCHMARK is not set # CONFIG_RING_BUFFER_BENCHMARK is not set # CONFIG_RING_BUFFER_STARTUP_TEST is not set # CONFIG_PREEMPTIRQ_DELAY_TEST is not set # CONFIG_TRACE_EVAL_MAP_FILE is not set CONFIG_TRACING_EVENTS_GPIO=y CONFIG_RUNTIME_TESTING_MENU=y # CONFIG_LKDTM is not set # CONFIG_TEST_LIST_SORT is not set # CONFIG_TEST_SORT is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_RBTREE_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_PERCPU_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_ASYNC_RAID6_TEST is not set # CONFIG_TEST_HEXDUMP is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_TEST_PRINTF is not set # CONFIG_TEST_BITMAP is not set # CONFIG_TEST_BITFIELD is not set # CONFIG_TEST_UUID is not set # CONFIG_TEST_XARRAY is not set # CONFIG_TEST_OVERFLOW is not set # CONFIG_TEST_RHASHTABLE is not set # CONFIG_TEST_HASH is not set # CONFIG_TEST_IDA is not set # CONFIG_TEST_LKM is not set # CONFIG_TEST_VMALLOC is not set # CONFIG_TEST_USER_COPY is not set # CONFIG_TEST_BPF is not set # CONFIG_FIND_BIT_BENCHMARK is not set # CONFIG_TEST_FIRMWARE is not set # CONFIG_TEST_SYSCTL is not set # CONFIG_TEST_UDELAY is not set # CONFIG_TEST_STATIC_KEYS is not set # CONFIG_TEST_KMOD is not set # CONFIG_TEST_MEMCAT_P is not set # CONFIG_TEST_STACKINIT is not set # CONFIG_MEMTEST is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_UBSAN is not set CONFIG_UBSAN_ALIGNMENT=y CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y # CONFIG_STRICT_DEVMEM is not set # CONFIG_ARM_PTDUMP_DEBUGFS is not set # CONFIG_DEBUG_WX is not set # CONFIG_UNWINDER_FRAME_POINTER is not set CONFIG_UNWINDER_ARM=y CONFIG_ARM_UNWIND=y # CONFIG_DEBUG_USER is not set CONFIG_DEBUG_LL=y # CONFIG_DEBUG_MT6589_UART0 is not set # CONFIG_DEBUG_MT8127_UART0 is not set # CONFIG_DEBUG_MT8135_UART3 is not set # CONFIG_DEBUG_ICEDCC is not set # CONFIG_DEBUG_SEMIHOSTING is not set CONFIG_DEBUG_LL_UART_8250=y # CONFIG_DEBUG_LL_UART_PL01X is not set CONFIG_DEBUG_LL_INCLUDE="debug/8250.S" CONFIG_DEBUG_UART_PHYS=0x11004000 CONFIG_DEBUG_UART_VIRT=0xf1004000 CONFIG_DEBUG_UART_8250_SHIFT=2 # CONFIG_DEBUG_UART_8250_WORD is not set # CONFIG_DEBUG_UART_8250_PALMCHIP is not set # CONFIG_DEBUG_UART_8250_FLOW_CONTROL is not set # CONFIG_DEBUG_UNCOMPRESS is not set CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" CONFIG_EARLY_PRINTK=y # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_CORESIGHT is not set
