#include "Arduino.h" #include "SoftwareSerial.h" #include "DFRobotDFPlayerMini.h" SoftwareSerial mySoftwareSerial(10, 11); // RX, TX DFRobotDFPlayerMini myDFPlayer; void printDetail(uint8_t type, int value); // ===================== Variables =============================================================// // ------- Declaring Pins ----------------------------------------------// static byte disruptorPin = 9; static byte enginePin = 6; static byte pushButtonPin = 12; static byte torpPin[] = { 2, 3 }; // ------- User Inputs ------------------------------------------------// static unsigned long torpUpTime = 1750; static unsigned long torpFlashTime = 200; static unsigned long torpDownTime = 150; static long double torpIdleBrightness = 10; static long double torpMaxBrightness = 255; static unsigned long engineFadePeriod = 3000; static unsigned long disruptorFiringTime = 2600; // ------- For the Button Pushing -------------------------------------// unsigned long debounce = 30; unsigned long holdTime = 1500; // ------- Bookeeping ------------------------------------------------// unsigned long currentMillis; boolean buttonValue = false; boolean buttonLast = false; boolean ignoreUp = false; unsigned long buttonUpTime; unsigned long buttonDownTime; unsigned int torpedoPushes = 0; unsigned int disruptorPushes = 0; unsigned long torpedoTime; unsigned long disruptorTime; unsigned long torpedoMillis; unsigned long disruptorMillis; unsigned long disruptorFlashTime; boolean disruptorState = 0; // ==================== End Variables ========================================================= // // ===================== Setup ================================================================ // void setup(){ pinMode(disruptorPin,OUTPUT); pinMode(enginePin,OUTPUT); pinMode(pushButtonPin,INPUT_PULLUP); // Enables internal pull-up resistor pinMode(torpPin[0],OUTPUT); pinMode(torpPin[1],OUTPUT); mySoftwareSerial.begin(9600); Serial.begin(115200); if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3. while(true); } myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms myDFPlayer.volume(10); //Set volume value (0~30). myDFPlayer.EQ(DFPLAYER_EQ_NORMAL); myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD); } // ===================== End Setup ============================================================ // // ===================== Main Loop ============================================================ // void loop() { currentMillis = millis(); // get current time // ---------- Push Buttoon Code --------------------------------------------------------// buttonValue = digitalRead(pushButtonPin); // Record Time of Push if (buttonValue == LOW && buttonLast == HIGH && (millis() - buttonUpTime) > debounce){ buttonDownTime = millis(); } // Record Time of Release if (buttonValue == HIGH && buttonLast == LOW && (millis() - buttonDownTime) > debounce){ buttonUpTime = millis(); if (ignoreUp == false){ disruptorTime = millis(); // If released early, fire disruptors! disruptorPushes++; myDFPlayer.playMp3Folder(2); } else{ ignoreUp = false; } } // If push time is longer than threshold, fire Torpedos! if (buttonValue == LOW && (millis() - buttonDownTime) > long(holdTime)){ buttonDownTime = millis(); torpedoTime = millis(); torpedoPushes++; ignoreUp = true; myDFPlayer.playMp3Folder(1); } // Record the button state for comparison in the next cycle buttonLast = buttonValue; // -------------------------------------------------------------------------------------// // ---------- Torpedo Firing ----------------------------------------------------------// // Ramp Up Red LED, Flash White LED, then a Ramp Down of Red LED // Ramp Up if ((currentMillis-torpedoTime) < torpUpTime && torpedoPushes > 0){ analogWrite(torpPin[1],torpIdleBrightness+(torpMaxBrightness-torpIdleBrightness)/torpUpTime*(currentMillis-torpedoTime)); digitalWrite(torpPin[0], LOW); } // Flash else if (((currentMillis-torpedoTime) > torpUpTime) && ((currentMillis-torpedoTime) < (torpUpTime+torpFlashTime)) && torpedoPushes > 0){ analogWrite(torpPin[1], 0); digitalWrite(torpPin[0], HIGH); } // Ramp Down else if (((currentMillis-torpedoTime) > (torpUpTime+torpFlashTime)) && ((currentMillis-torpedoTime) < (torpUpTime+torpFlashTime+torpDownTime)) && torpedoPushes > 0){ analogWrite(torpPin[1],torpMaxBrightness+(torpIdleBrightness-torpMaxBrightness)/torpDownTime*((currentMillis-torpedoTime)-(torpUpTime+torpFlashTime))); digitalWrite(torpPin[0], LOW); } // Idle else{ analogWrite(torpPin[1], torpIdleBrightness); digitalWrite(torpPin[0], LOW); } // ---------- Engine Fading ----------------------------------------------------------- // // Slow Up and Down Fade with Shorter Pusations int fadeValue = int(127.0+127.0/2.0*(1+(0.75*sin(2*PI*currentMillis/engineFadePeriod)+0.25*cos(14*PI*currentMillis/engineFadePeriod)))); analogWrite(enginePin,fadeValue); // ---------- Disruptor Firing -------------------------------------------------------- // // Get Random On or Off Time Using getRandom() Function Below disruptorFlashTime = fmod(getRandom(), 4000UL) + 60UL; if (((currentMillis - disruptorTime) < disruptorFiringTime) && (disruptorPushes > 0)){ if(currentMillis - disruptorMillis > disruptorFlashTime) { disruptorMillis = currentMillis; digitalWrite(disruptorPin, disruptorState = !disruptorState); } } else{ analogWrite(disruptorPin,5); } // ------------------------------------------------------------------------------------ // } // ===================== End Main Loop ======================================================== // // ===================== Pseduo-Random Generator ============================================== // // Found This Online. I Take No Credit for It. unsigned long m_w = 1; unsigned long m_z = 2; unsigned long getRandom() { m_z = 36969L * (m_z & 65535L) + (m_z >> 16); m_w = 18000L * (m_w & 65535L) + (m_w >> 16); return (m_z << 16) + m_w; /* 32-bit result */ } // ===================== End Pseduo-Random Generator ========================================== //
