.include "m8515def.inc" ;definitions .def temp = r20 .def tempH = r21 .def dmx_byte = r22 .def dmx_status = r23 .def DMXcountL = r5 .def DMXcountH = r6 .def adresseL = r3 .def adresseH = r4 .def null = r1 .equ BIT9= PE2 ;interrupt vectors rjmp init ;reset vector address reti ;External Interrupt0 Vector Address reti ;External Interrupt1 Vector Address reti ;Input Capture1 Interrupt Vector Address reti ;Output Compare1A Interrupt Vector Address reti ;Output Compare1B Interrupt Vector Address reti ;Overflow1 Interrupt Vector Address reti ;Overflow0 Interrupt Vector Address reti ;SPI Interrupt Vector Address rjmp get_byte ;UART Receive Complete Interrupt Vector Address reti ;UART Data Register Empty Interrupt Vector Address reti ;UART Transmit Complete Interrupt Vector Address reti ;Analog Comparator Interrupt Vector Address reti ;External Interrupt2 Vector Address reti ;Output Compare0 Interrupt Vector Address reti ; EEPROM Interrupt Vector Address reti ; SPM complete Interrupt Vector Address reti ; SPM complete Interrupt Vector Address ; INIT init: ; PWM sbi DDRB,PB0 ldi r16,0b01100001 out TCCR0,r16 ; Stack ldi tempH,high(RAMEND) ldi temp,low(RAMEND) out SPH,tempH out SPL,temp ; PortC clr temp out DDRC, temp ser temp out PortC, temp ;DIP eingänge mit pullup ; PortD ldi temp, 0b10000100 out DDRD, temp ldi temp, 0b00001000 out PortD, temp ; DMX, LED1 on ; PortE clr temp out DDRE, temp ser temp out PortE, temp ; BIT9 DIP-pullup ;USART ldi temp, 0x01 ;setze Uart to 250 kbaud @ 8Mhz out UBRRL, temp ldi temp, 0x00 out UBRRH, temp ldi temp, (1< wait for reset rjmp overrun sbrc temp,FE ; check for frame error -> got reset rjmp frame_error inc DMXcountL ; count incoming frames brne gb_1 inc DMXcountH gb_1: cpi dmx_status, 1 ; check for startbyte (else frame error -> reset) breq startbyte cpi dmx_status, 2 ; check for start adress breq startadr back: cpi dmx_status, 3 ; brsh handle_byte reti ;return interrupt startbyte: cp dmx_byte, null ; compare Startbyte brne overrun inc dmx_status ; next -> Startadresse clr DMXcountH ; reset frame counter clr DMXcountL in adresseL, PinC ; Einlesen der Startadresse com adresseL clr adresseH sbis PinE, BIT9 ; 9. bit inc adresseH reti startadr: clc cp DMXcountL, adresseL cpc DMXcountH, adresseH brne gb_exit inc dmx_status ; next -> Byte-Verarbeitung rjmp back ; springe zurück zur Verarbeitung... gb_exit: reti handle_byte: clr dmx_status ; all bytes received -> wait for BREAK out OCR0,dmx_byte reti frame_error: inc dmx_status ; frame-error detected as break cbi UCSRA,FE reti overrun: clr dmx_status ; warte auf frame-error reti
