#define CONFIG_CMD_FAT 1 #define CONFIG_BOOTM_NETBSD 1 #define CONFIG_CMD_FDT 1 #define CONFIG_MTK_TIMER 1 #define CONFIG_CMD_ITEST 1 #define CONFIG_BOOTM_VXWORKS 1 #define CONFIG_CMD_EDITENV 1 #define CONFIG_CMD_SETEXPR 1 #define CONFIG_CMD_PART 1 #define CONFIG_SPL_LOGLEVEL 4 #define CONFIG_SPL_USE_ARCH_MEMSET 1 #define CONFIG_HAS_VBAR 1 #define CONFIG_CMD_ENV_EXISTS 1 #define CONFIG_CMD_CRC32 1 #define CONFIG_SYS_LONGHELP 1 #define CONFIG_IS_MODULE(option) config_enabled(CONFIG_VAL(option ##_MODULE)) #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR #define CONFIG_HASH 1 #define CONFIG_USE_ARCH_MEMSET 1 #define CONFIG_OPTEE_TZDRAM_BASE 0x00000000 #define CONFIG_EXPERT 1 #define CONFIG_MTK_POWER_DOMAIN 1 #define CONFIG_CMDLINE 1 #define CONFIG_BOOTDELAY 3 #define CONFIG_SYS_HELP_CMD_WIDTH 8 #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_EFI_PARTITION 1 #define CONFIG_FS_FAT 1 #define CONFIG_SYS_ARM_CACHE_CP15 1 #define CONFIG_BOOTM_RTEMS 1 #define CONFIG_SYS_CBSIZE SZ_1K #define CONFIG_RESET_MEDIATEK 1 #define CONFIG_MD5 1 #define CONFIG_BOOTM_LINUX 1 #define CONFIG_DEFAULT_FDT_FILE "mt7623n-bananapi-bpi-r2" #define CONFIG_CREATE_ARCH_SYMLINK 1 #define CONFIG_CMD_CONSOLE 1 #define CONFIG_SUPPORT_OF_CONTROL 1 #define CONFIG_PINCTRL_FULL 1 #define CONFIG_BLK 1 #define CONFIG_SYS_CPU "armv7" #define CONFIG_BOOTP_GATEWAY 1 #define CONFIG_SYS_THUMB_BUILD 1 #define CONFIG_PINCTRL 1 #define CONFIG_SYS_CACHELINE_SIZE 64 #define CONFIG_MMC 1 #define CONFIG_DM_ETH 1 #define CONFIG_PINCTRL_MTK 1 #define CONFIG_CMD_PINMUX 1 #define CONFIG_CMD_MISC 1 #define CONFIG_FIT 1 #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_DM_DEVICE_REMOVE 1 #define CONFIG_MEDIATEK_ETH 1 #define CONFIG_MMC_WRITE 1 #define CONFIG_ENV_OVERWRITE #define CONFIG_CMD_NET 1 #define CONFIG_PINCTRL_MT7623 1 #define CONFIG_TIMER 1 #define CONFIG_SPL_SYS_THUMB_BUILD 1 #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_CMD_FS_GENERIC 1 #define CONFIG_CMD_PING 1 #define CONFIG_SYS_MALLOC_LEN SZ_4M #define CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET 0x0 #define CONFIG_PYLIBFDT 1 #define CONFIG_INITRD_TAG #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_LOCALVERSION "" #define CONFIG_SYS_BOOTM_LEN SZ_64M #define CONFIG_SYS_TEXT_BASE 0x81e00000 #define CONFIG_CC_OPTIMIZE_FOR_SIZE 1 #define CONFIG_ARCH_MEDIATEK 1 #define CONFIG_REGEX 1 #define CONFIG_EFI_PARTITION_ENTRIES_NUMBERS 128 #define CONFIG_SYS_CONFIG_NAME "mt7623" #define CONFIG_BOOTSTAGE_RECORD_COUNT 30 #define CONFIG_CMD_STRINGS 1 #define CONFIG_CMD_SAVEENV 1 #define CONFIG_SYS_ARM_MMU 1 #define CONFIG_BOOTM_PLAN9 1 #define CONFIG_IS_BUILTIN(option) config_enabled(CONFIG_VAL(option)) #define CONFIG_SERIAL_PRESENT 1 #define CONFIG_DM_MMC 1 #define CONFIG_SYSRESET_WATCHDOG 1 #define CONFIG_FIT_ENABLE_SHA256_SUPPORT 1 #define CONFIG_LZMA 1 #define CONFIG_CMD_GPT 1 #define CONFIG_TPL_SYS_MALLOC_F_LEN 0x4000 #define CONFIG_PHY_FIXED 1 #define CONFIG_DM_DEV_READ_INLINE 1 #define CONFIG_DM_WARN 1 #define CONFIG_BOOTP_DNS 1 #define CONFIG_SYS_CACHE_SHIFT_6 1 #define CONFIG_CMD_MEMORY 1 #define CONFIG_SYS_MAXARGS 8 #define CONFIG_SYSRESET 1 #define CONFIG_MMC_HW_PARTITIONING 1 #define CONFIG_SUPPORT_SPL 1 #define CONFIG_CMD_RUN 1 #define CONFIG_IPADDR 192.168.1.1 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_TARGET_MT7623 1 #define CONFIG_OPTEE_TZDRAM_SIZE 0x0000000 #define CONFIG_BOOTP_HOSTNAME 1 #define CONFIG_BOARDDIR board/mediatek/mt7623 #define CONFIG_TPL_LOGLEVEL 4 #define CONFIG_CPU_V7A 1 #define CONFIG_DM_RESET 1 #define CONFIG_SPL_BOOTSTAGE_RECORD_COUNT 5 #define CONFIG_TPL_SERIAL_PRESENT 1 #define CONFIG_NET 1 #define CONFIG_OF_LIBFDT 1 #define CONFIG_DEFAULT_ENV_FILE "uEnv.txt" #define CONFIG_MMC_HS200_SUPPORT 1 #define CONFIG_SYS_MAX_FLASH_SECT 512 #define CONFIG_CLK 1 #define CONFIG_PHYLIB 1 #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_DM_SERIAL 1 #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 #define CONFIG_ARCH_FIXUP_FDT_MEMORY 1 #define CONFIG_SYS_MALLOC_CLEAR_ON_INIT 1 #define CONFIG_SYS_EXTRA_OPTIONS "" #define CONFIG_HUSH_PARSER 1 #define CONFIG_BOOTP_VCI_STRING "U-Boot.armv7" #define CONFIG_SYS_MMC_MAX_BLK_COUNT 65535 #define CONFIG_DM 1 #define CONFIG_ZLIB 1 #define CONFIG_LOADADDR 0x84000000 #define CONFIG_LIB_UUID 1 #define CONFIG_CMD_GO 1 #define CONFIG_CMD_BOOTD 1 #define CONFIG_CMD_BOOTM 1 #define CONFIG_CMD_BOOTP 1 #define CONFIG_CMD_BOOTZ 1 #define CONFIG_SYS_MALLOC_F 1 #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_SPRINTF 1 #define CONFIG_SYS_SOC "mediatek" #define CONFIG_ENV_IS_IN_MMC 1 #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MALLOC_F_LEN 0x4000 #define CONFIG_DOS_PARTITION 1 #define CONFIG_GZIP 1 #define CONFIG_SYS_VENDOR "mediatek" #define CONFIG_CMD_BOOTMENU 1 #define CONFIG_USE_DEFAULT_ENV_FILE 1 #define CONFIG_REQUIRE_SERIAL_CONSOLE 1 #define CONFIG_IDENT_STRING "" #define CONFIG_BINMAN 1 #define CONFIG_MTK_SERIAL 1 #define CONFIG_PRINTF 1 #define CONFIG_PINCTRL_GENERIC 1 #define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } #define CONFIG_VAL(option) config_val(option) #define CONFIG_DM_STDIO 1 #define CONFIG_LOCALVERSION_AUTO 1 #define CONFIG_SUPPORT_EMMC_BOOT #define CONFIG_SYS_SDRAM_BASE 0x80000000 #define CONFIG_IMAGE_FORMAT_LEGACY 1 #define CONFIG_ARCH_MISC_INIT 1 #define CONFIG_SYS_BOOT_RAMDISK_HIGH #define CONFIG_MMC_VERBOSE 1 #define CONFIG_NET_TFTP_VARS 1 #define CONFIG_MKIMAGE_DTC_PATH "dtc" #define CONFIG_USE_PRIVATE_LIBGCC 1 #define CONFIG_CMD_ECHO 1 #define CONFIG_STRTO 1 #define CONFIG_REGMAP 1 #define CONFIG_USE_ARCH_MEMCPY 1 #define CONFIG_OF_CONTROL 1 #define CONFIG_EXTRA_ENV_SETTINGS FDT_HIGH #define CONFIG_EFI_PARTITION_ENTRIES_OFF 0 #define CONFIG_INPUT 1 #define CONFIG_HAS_THUMB2 1 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_2M - GENERATED_GBL_DATA_SIZE) #define CONFIG_FIT_EXTERNAL_OFFSET 0x0 #define CONFIG_SYS_ARCH "arm" #define CONFIG_CMD_ASKENV 1 #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BOARD "mt7623" #define CONFIG_PARTITION_UUIDS 1 #define CONFIG_DM_GPIO 1 #define CONFIG_DTC 1 #define CONFIG_CMDLINE_TAG #define CONFIG_SYS_ARM_ARCH 7 #define CONFIG_SPL_USE_ARCH_MEMCPY 1 #define CONFIG_NET_RANDOM_ETHADDR 1 #define CONFIG_BOOTSTAGE_STASH_SIZE 0x1000 #define CONFIG_OF_LIBFDT_OVERLAY 1 #define CONFIG_CMD_IMPORTENV 1 #define CONFIG_PINMUX 1 #define CONFIG_MTK_BROM_HEADER_INFO "lk=1" #define CONFIG_HAVE_PRIVATE_LIBGCC 1 #define CONFIG_CMD_EXPORTENV 1 #define CONFIG_WDT_MTK 1 #define CONFIG_PARTITIONS 1 #define CONFIG_OF_TRANSLATE 1 #define CONFIG_FIT_VERBOSE 1 #define CONFIG_PINCONF 1 #define CONFIG_RANDOM_UUID 1 #define CONFIG_DM_SEQ_ALIAS 1 #define CONFIG_CMD_READ 1 #define CONFIG_BOOTSTAGE_STASH_ADDR 0x0 #define CONFIG_CMD_SOURCE 1 #define CONFIG_SYS_PROMPT "BPI-R2> " #define CONFIG_BOOTP_BOOTPATH 1 #define CONFIG_DISPLAY_CPUINFO 1 #define CONFIG_DTOC 1 #define CONFIG_LOGLEVEL 4 #define CONFIG_POWER_DOMAIN 1 #define CONFIG_SHA1 1 #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CRC32 #define CONFIG_MMC_HS400_SUPPORT 1 #define CONFIG_SPL_SYS_MALLOC_F_LEN 0x4000 #define CONFIG_CMD_LOADB 1 #define CONFIG_CMD_LOADS 1 #define CONFIG_WDT 1 #define CONFIG_FS_FAT_MAX_CLUSTSIZE 65536 #define CONFIG_CMD_IMI 1 #define CONFIG_SYSCON 1 #define CONFIG_LMB #define CONFIG_AUTOBOOT 1 #define CONFIG_ARM 1 #define CONFIG_HAVE_BLOCK_DEVICE 1 #define CONFIG_IS_ENABLED(option) (config_enabled(CONFIG_VAL(option)) || config_enabled(CONFIG_VAL(option ##_MODULE))) #define CONFIG_OF_SEPARATE 1 #define CONFIG_CMD_GPIO 1 #define CONFIG_CMD_BDI 1 #define CONFIG_SERVERIP 192.168.1.2 #define CONFIG_SHA256 1 #define CONFIG_BOOTP_SUBNETMASK 1 #define CONFIG_MENU 1 #define CONFIG_NETDEVICES 1 #define CONFIG_DEFAULT_DEVICE_TREE "mt7623n-bananapi-bpi-r2" #define CONFIG_LIB_RAND 1 #define CONFIG_SIMPLE_BUS 1 #define CONFIG_ARM_ASM_UNIFIED 1 #define CONFIG_SYS_NONCACHED_MEMORY SZ_1M #define CONFIG_CMD_MMC 1 #define CONFIG_MMC_MTK 1 #define CONFIG_CMD_TFTPBOOT 1 #define CONFIG_SAVED_DRAM_TIMING_BASE 0x180000 #define CONFIG_SPL_SERIAL_PRESENT 1
