(kicad_pcb (version 20171130) (host pcbnew "(5.0.2)-1")
  (general
    (thickness 1.6)
    (drawings 36)
    (tracks 1045)
    (zones 0)
    (modules 66)
    (nets 46)
  (page A4)
  (layers
    (0 F.Cu signal)
    (31 B.Cu signal)
    (32 B.Adhes user)
    (33 F.Adhes user)
    (34 B.Paste user)
    (35 F.Paste user)
    (36 B.SilkS user)
    (37 F.SilkS user)
    (38 B.Mask user)
    (39 F.Mask user)
    (40 Dwgs.User user hide)
    (41 Cmts.User user)
    (42 Eco1.User user)
    (43 Eco2.User user)
    (44 Edge.Cuts user)
    (45 Margin user)
    (46 B.CrtYd user)
    (47 F.CrtYd user)
    (48 B.Fab user)
    (49 F.Fab user hide)
  (setup
    (last_trace_width 0.2)
    (user_trace_width 0.1)
    (user_trace_width 0.152)
    (user_trace_width 0.2)
    (user_trace_width 0.3)
    (user_trace_width 0.5)
    (user_trace_width 1)
    (user_trace_width 1.5)
    (user_trace_width 2)
    (trace_clearance 0.2)
    (zone_clearance 0.2)
    (zone_45_only no)
    (trace_min 0.01)
    (segment_width 1)
    (edge_width 0.1)
    (via_size 0.6)
    (via_drill 0.4)
    (via_min_size 0.4)
    (via_min_drill 0.3)
    (uvia_size 0.3)
    (uvia_drill 0.1)
    (uvias_allowed no)
    (uvia_min_size 0.2)
    (uvia_min_drill 0.1)
    (pcb_text_width 0.3)
    (pcb_text_size 1.5 1.5)
    (mod_edge_width 0.15)
    (mod_text_size 1 1)
    (mod_text_width 0.15)
    (pad_size 2.75 2.75)
    (pad_drill 2.75)
    (pad_to_mask_clearance 0)
    (solder_mask_min_width 0.25)
    (aux_axis_origin 0 0)
    (visible_elements 7FFCFF7F)
    (pcbplotparams
      (layerselection 0x00030_80000001)
      (usegerberextensions false)
      (usegerberattributes false)
      (usegerberadvancedattributes false)
      (creategerberjobfile false)
      (excludeedgelayer true)
      (linewidth 0.100000)
      (plotframeref false)
      (viasonmask false)
      (mode 1)
      (useauxorigin false)
      (hpglpennumber 1)
      (hpglpenspeed 20)
      (hpglpendiameter 15.000000)
      (psnegative false)
      (psa4output false)
      (plotreference true)
      (plotvalue true)
      (plotinvisibletext false)
      (padsonsilk false)
      (subtractmaskfromsilk false)
      (outputformat 1)
      (mirror false)
      (drillshape 0)
      (scaleselection 1)
      (outputdirectory "meta/"))
  (net 0 "")
  (net 1 +3V3)
  (net 2 /GND_PI)
  (net 3 /VCC3)
  (net 4 GND)
  (net 5 /VDP)
  (net 6 "Net-(CFG1001-Pad1)")
  (net 7 /BUS+)
  (net 8 /VB+)
  (net 9 /TXD_TPUART)
  (net 10 /TXD_PI)
  (net 11 /RXD_PI)
  (net 12 "Net-(IC10-Pad13)")
  (net 13 /STXO)
  (net 14 +5V)
  (net 15 "Net-(K1-Pad27)")
  (net 16 "Net-(K1-Pad28)")
  (net 17 "Net-(LED_PI1-Pad2)")
  (net 18 "Net-(LED_STXO1-Pad2)")
  (net 19 "Net-(LED_TPUART1-Pad2)")
  (net 20 /RXD_TPUART)
  (net 21 "Net-(LED_STXO1-Pad1)")
  (net 22 "Net-(C40-Pad1)")
  (net 23 "Net-(IC40-Pad1)")
  (net 24 "Net-(DIS1-Pad1)")
  (net 25 "Net-(LED_SUP1-Pad2)")
  (net 26 /VCC5_BOOST)
  (net 27 /SOFTSTART)
  (net 28 /BOOST_30V)
  (net 29 /GYRA_C)
  (net 30 /GYRA_E)
  (net 31 /SW)
  (net 32 /DROSSEL_IN)
  (net 33 /FB)
  (net 34 /FREQ)
  (net 35 /GYRA_B)
  (net 36 /COMP)
  (net 37 /COMP1)
  (net 38 /VDDH)
  (net 39 /VSSH)
  (net 40 /BYP)
  (net 41 /RXIN)
  (net 42 /IND)
  (net 43 /X1)
  (net 44 /X2)
  (net 45 "Net-(IC40-Pad7)")
  (net_class Default "This is the default net class."
    (clearance 0.2)
    (trace_width 0.25)
    (via_dia 0.6)
    (via_drill 0.4)
    (uvia_dia 0.3)
    (uvia_drill 0.1)
    (add_net +3V3)
    (add_net +5V)
    (add_net /BOOST_30V)
    (add_net /BUS+)
    (add_net /BYP)
    (add_net /COMP)
    (add_net /COMP1)
    (add_net /DROSSEL_IN)
    (add_net /FB)
    (add_net /FREQ)
    (add_net /GND_PI)
    (add_net /GYRA_B)
    (add_net /GYRA_C)
    (add_net /GYRA_E)
    (add_net /IND)
    (add_net /RXD_PI)
    (add_net /RXD_TPUART)
    (add_net /RXIN)
    (add_net /SOFTSTART)
    (add_net /STXO)
    (add_net /SW)
    (add_net /TXD_PI)
    (add_net /TXD_TPUART)
    (add_net /VB+)
    (add_net /VCC3)
    (add_net /VCC5_BOOST)
    (add_net /VDDH)
    (add_net /VDP)
    (add_net /VSSH)
    (add_net /X1)
    (add_net /X2)
    (add_net GND)
    (add_net "Net-(C40-Pad1)")
    (add_net "Net-(CFG1001-Pad1)")
    (add_net "Net-(DIS1-Pad1)")
    (add_net "Net-(IC10-Pad13)")
    (add_net "Net-(IC40-Pad1)")
    (add_net "Net-(IC40-Pad7)")
    (add_net "Net-(K1-Pad27)")
    (add_net "Net-(K1-Pad28)")
    (add_net "Net-(LED_PI1-Pad2)")
    (add_net "Net-(LED_STXO1-Pad1)")
    (add_net "Net-(LED_STXO1-Pad2)")
    (add_net "Net-(LED_SUP1-Pad2)")
    (add_net "Net-(LED_TPUART1-Pad2)")
  (module Kalassi:Recom_R1SE_5-pin (layer F.Cu) (tedit 5C93F145) (tstamp 5CB915ED)
    (at 88.2 53.4 270)
    (path /5CB4AA5B)
    (fp_text reference IC45 (at 0.8 -6.3 270) (layer F.SilkS)
      (effects (font (size 1 1) (thickness 0.15)))
    (fp_text value R1SE-Kalassi (at -0.1 -0.1 270) (layer F.Fab)
    (fp_line (start -6.4 -5.4) (end -6.4 5.4) (layer F.SilkS) (width 0.3))
    (fp_line (start 6.4 -5.4) (end -6.4 -5.4) (layer F.SilkS) (width 0.3))
    (fp_line (start 6.4 5.4) (end 6.4 -5.4) (layer F.SilkS) (width 0.3))
    (fp_line (start -6.4 5.4) (end 6.4 5.4) (layer F.SilkS) (width 0.3))
    (pad 8 smd rect (at -3.81 -5.1 270) (size 1.2 1.8) (layers F.Cu F.Paste F.Mask))
    (pad 5 smd rect (at 3.81 -5.1 270) (size 1.2 1.8) (layers F.Cu F.Paste F.Mask)
      (net 26 /VCC5_BOOST))
    (pad 4 smd rect (at 3.81 5.1 270) (size 1.2 1.8) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 2 smd rect (at -1.27 5.1 270) (size 1.2 1.8) (layers F.Cu F.Paste F.Mask)
      (net 23 "Net-(IC40-Pad1)"))
    (pad 1 smd rect (at -3.81 5.1 270) (size 1.2 1.8) (layers F.Cu F.Paste F.Mask)
      (net 2 /GND_PI))
    (model ${KISYS3DMOD}/Converter_DCDC.3dshapes/Converter_DCDC_RECOM_R1S_SMD.STEP
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 90))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CBB5132)
    (at 108.6 40.8)
    (descr CAPACITOR)
    (tags "CAPACITOR IPC")
    (path /09ADF4B9)
    (attr smd)
    (fp_text reference C1 (at -2.3 0) (layer F.SilkS)
      (effects (font (size 0.79756 0.79756) (thickness 0.0762)))
    (fp_text value 100nF (at 0.75 1.75) (layer F.SilkS) hide
    (fp_line (start 1.5 -1) (end 1.5 1) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.5 -1) (end -1.5 1) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.5 1) (end 1.5 1) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.5 -1) (end 1.5 -1) (layer F.CrtYd) (width 0.05))
    (fp_line (start 0.875 -0.475) (end 0.875 0.475) (layer Dwgs.User) (width 0.05))
    (fp_line (start -0.875 -0.475) (end -0.875 0.475) (layer Dwgs.User) (width 0.05))
    (fp_line (start -0.875 0.475) (end 0.875 0.475) (layer Dwgs.User) (width 0.05))
    (fp_line (start -0.875 -0.475) (end 0.875 -0.475) (layer Dwgs.User) (width 0.05))
    (pad 1 smd rect (at -0.85 0) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 1 +3V3) (solder_paste_margin_ratio -0.05))
    (pad 2 smd rect (at 0.85 0) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 2 /GND_PI) (solder_paste_margin_ratio -0.05))
    (model ${KISYS3DMOD}/Capacitors_SMD.3dshapes/C_0603.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (module Capacitor_SMD:CP_Elec_6.3x5.4 (layer F.Cu) (tedit 5BCA39D0) (tstamp 5CB2C01F)
    (at 125.6 57 90)
    (descr "SMD capacitor, aluminum electrolytic, Panasonic C55, 6.3x5.4mm")
    (tags "capacitor electrolytic")
    (path /5CAFB74A)
    (attr smd)
    (fp_text reference C19 (at 4.4 2.6 180) (layer F.SilkS)
    (fp_text value CP (at 0 4.35 90) (layer F.Fab)
    (fp_circle (center 0 0) (end 3.15 0) (layer F.Fab) (width 0.1))
    (fp_line (start 3.3 -3.3) (end 3.3 3.3) (layer F.Fab) (width 0.1))
    (fp_line (start -2.3 -3.3) (end 3.3 -3.3) (layer F.Fab) (width 0.1))
    (fp_line (start -2.3 3.3) (end 3.3 3.3) (layer F.Fab) (width 0.1))
    (fp_line (start -3.3 -2.3) (end -3.3 2.3) (layer F.Fab) (width 0.1))
    (fp_line (start -3.3 -2.3) (end -2.3 -3.3) (layer F.Fab) (width 0.1))
    (fp_line (start -3.3 2.3) (end -2.3 3.3) (layer F.Fab) (width 0.1))
    (fp_line (start -2.704838 -1.33) (end -2.074838 -1.33) (layer F.Fab) (width 0.1))
    (fp_line (start -2.389838 -1.645) (end -2.389838 -1.015) (layer F.Fab) (width 0.1))
    (fp_line (start 3.41 3.41) (end 3.41 1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start 3.41 -3.41) (end 3.41 -1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.345563 -3.41) (end 3.41 -3.41) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.345563 3.41) (end 3.41 3.41) (layer F.SilkS) (width 0.12))
    (fp_line (start -3.41 2.345563) (end -3.41 1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start -3.41 -2.345563) (end -3.41 -1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start -3.41 -2.345563) (end -2.345563 -3.41) (layer F.SilkS) (width 0.12))
    (fp_line (start -3.41 2.345563) (end -2.345563 3.41) (layer F.SilkS) (width 0.12))
    (fp_line (start -4.4375 -1.8475) (end -3.65 -1.8475) (layer F.SilkS) (width 0.12))
    (fp_line (start -4.04375 -2.24125) (end -4.04375 -1.45375) (layer F.SilkS) (width 0.12))
    (fp_line (start 3.55 -3.55) (end 3.55 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.55 -1.05) (end 4.8 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 4.8 -1.05) (end 4.8 1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 4.8 1.05) (end 3.55 1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.55 1.05) (end 3.55 3.55) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.4 3.55) (end 3.55 3.55) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.4 -3.55) (end 3.55 -3.55) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.55 2.4) (end -2.4 3.55) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.55 -2.4) (end -2.4 -3.55) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.55 -2.4) (end -3.55 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.55 1.05) (end -3.55 2.4) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.55 -1.05) (end -4.8 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start -4.8 -1.05) (end -4.8 1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start -4.8 1.05) (end -3.55 1.05) (layer F.CrtYd) (width 0.05))
    (fp_text user %R (at 0 0 90) (layer F.Fab)
    (pad 1 smd roundrect (at -2.8 0 90) (size 3.5 1.6) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.15625)
      (net 38 /VDDH))
    (pad 2 smd roundrect (at 2.8 0 90) (size 3.5 1.6) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.15625)
      (net 4 GND))
    (model ${KISYS3DMOD}/Capacitor_SMD.3dshapes/CP_Elec_6.3x5.4.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module RPi_Hat:RPi_Hat_Mounting_Hole locked (layer F.Cu) (tedit 55217C7B) (tstamp 5515DEA9)
    (at 136.6 36.875)
    (descr "Mounting hole, Befestigungsbohrung, 2,7mm, No Annular, Kein Restring,")
    (tags "Mounting hole, Befestigungsbohrung, 2,7mm, No Annular, Kein Restring,")
    (fp_text reference "" (at 0 -4.0005) (layer F.SilkS) hide
    (fp_text value "" (at 0.09906 3.59918) (layer F.Fab) hide
    (fp_circle (center 0 0) (end 1.375 0) (layer F.Fab) (width 0.15))
    (fp_circle (center 0 0) (end 3.1 0) (layer F.Fab) (width 0.15))
    (fp_circle (center 0 0) (end 3.1 0) (layer B.Fab) (width 0.15))
    (fp_circle (center 0 0) (end 1.375 0) (layer B.Fab) (width 0.15))
    (fp_circle (center 0 0) (end 3.1 0) (layer F.CrtYd) (width 0.15))
    (fp_circle (center 0 0) (end 3.1 0) (layer B.CrtYd) (width 0.15))
    (pad "" np_thru_hole circle (at 0 0) (size 2.75 2.75) (drill 2.75) (layers *.Cu *.Mask)
      (solder_mask_margin 1.725) (clearance 1.725))
  (module RPi_Hat:RPi_Hat_Mounting_Hole locked (layer F.Cu) (tedit 55217CCB) (tstamp 55169DC9)
    (at 136.6 85.875)
  (module RPi_Hat:RPi_Hat_Mounting_Hole locked (layer F.Cu) (tedit 55217CB9) (tstamp 5515DECC)
    (at 78.6 85.875)
  (module RPi_Hat:RPi_Hat_Mounting_Hole locked (layer F.Cu) (tedit 55217CA2) (tstamp 5515DEBF)
    (at 78.6 36.875)
  (module Kalassi:KNX (layer F.Cu) (tedit 5CAC53A3) (tstamp 5CB6818E)
    (at 133.4 57.6 90)
    (path /5CAE11C1)
    (attr virtual)
    (fp_text reference BUS1 (at -0.6 4.9 270) (layer F.SilkS)
    (fp_text value Conn_01x02_Male (at 0 3.81 90) (layer F.Fab)
    (fp_line (start 5.8 -3.4) (end 5.8 6.7) (layer F.SilkS) (width 0.15))
    (fp_line (start -5.8 -3.4) (end -5.8 6.7) (layer F.SilkS) (width 0.15))
    (fp_line (start 5.8 6.7) (end -5.8 6.7) (layer F.SilkS) (width 0.15))
    (fp_line (start -5.8 -3.4) (end 5.8 -3.4) (layer F.SilkS) (width 0.15))
    (fp_text user VB- (at -2.81 2 90) (layer F.SilkS)
    (fp_text user VB+ (at 2.78 2 90) (layer F.SilkS)
    (pad 2 thru_hole circle (at 2.6 0 90) (size 1.50622 1.50622) (drill 0.99822) (layers *.Cu *.Mask)
      (net 7 /BUS+))
    (pad 1 thru_hole circle (at -3.4 0 90) (size 1.50622 1.50622) (drill 0.99822) (layers *.Cu *.Mask)
      (net 4 GND))
    (model ${KISYS3DMOD}/Connector.3dshapes/243-211-1.stp
      (offset (xyz -5.8 3.4 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB2C1B2)
    (at 93.2 44.2 270)
    (descr CAPACITOR)
    (path /F0F11B5E)
    (attr smd)
    (fp_text reference C4 (at 0.25 -1.75 270) (layer F.SilkS)
    (fp_text value 47nF/50V (at 0.75 1.75 270) (layer F.SilkS) hide
    (pad 2 smd rect (at 0.85 0 270) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
    (pad 1 smd rect (at -0.85 0 270) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB2C18B)
    (at 104.4 43.8 270)
    (descr CAPACITOR)
    (path /D8F795B8)
    (attr smd)
    (fp_text reference C5 (at -2.5 0.1 270) (layer F.SilkS)
      (net 3 /VCC3) (solder_paste_margin_ratio -0.05))
      (net 4 GND) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB2C164)
    (at 110 57.4 90)
    (descr CAPACITOR)
    (path /A00C79DB)
    (attr smd)
    (fp_text reference C10 (at 0.1 1.5 90) (layer F.SilkS)
    (fp_text value 220n (at 0.75 1.75 90) (layer F.SilkS) hide
    (pad 1 smd rect (at -0.85 0 90) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
    (pad 2 smd rect (at 0.85 0 90) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 5 /VDP) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB89F00)
    (at 110 64.4 270)
    (descr CAPACITOR)
    (path /9A60ACF9)
    (attr smd)
    (fp_text reference C11 (at 0.25 -1.75 270) (layer F.SilkS)
    (fp_text value 220n (at 0.75 1.75 270) (layer F.SilkS) hide
      (net 38 /VDDH) (solder_paste_margin_ratio -0.05))
      (net 39 /VSSH) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Capacitor_SMD:CP_Elec_5x5.9 (layer F.Cu) (tedit 5BCA39CF) (tstamp 5CB654AA)
    (at 123.6 65.2)
    (descr "SMD capacitor, aluminum electrolytic, Panasonic B6, 5.0x5.9mm")
    (path /5CAFB488)
    (attr smd)
    (fp_text reference C13 (at 0 -3.7) (layer F.SilkS)
    (fp_text value CP (at 0 3.7) (layer F.Fab)
    (fp_circle (center 0 0) (end 2.5 0) (layer F.Fab) (width 0.1))
    (fp_line (start 2.65 -2.65) (end 2.65 2.65) (layer F.Fab) (width 0.1))
    (fp_line (start -1.65 -2.65) (end 2.65 -2.65) (layer F.Fab) (width 0.1))
    (fp_line (start -1.65 2.65) (end 2.65 2.65) (layer F.Fab) (width 0.1))
    (fp_line (start -2.65 -1.65) (end -2.65 1.65) (layer F.Fab) (width 0.1))
    (fp_line (start -2.65 -1.65) (end -1.65 -2.65) (layer F.Fab) (width 0.1))
    (fp_line (start -2.65 1.65) (end -1.65 2.65) (layer F.Fab) (width 0.1))
    (fp_line (start -2.033956 -1.2) (end -1.533956 -1.2) (layer F.Fab) (width 0.1))
    (fp_line (start -1.783956 -1.45) (end -1.783956 -0.95) (layer F.Fab) (width 0.1))
    (fp_line (start 2.76 2.76) (end 2.76 1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.76 -2.76) (end 2.76 -1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.695563 -2.76) (end 2.76 -2.76) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.695563 2.76) (end 2.76 2.76) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.76 1.695563) (end -2.76 1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.76 -1.695563) (end -2.76 -1.06) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.76 -1.695563) (end -1.695563 -2.76) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.76 1.695563) (end -1.695563 2.76) (layer F.SilkS) (width 0.12))
    (fp_line (start -3.625 -1.685) (end -3 -1.685) (layer F.SilkS) (width 0.12))
    (fp_line (start -3.3125 -1.9975) (end -3.3125 -1.3725) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.9 -2.9) (end 2.9 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.9 -1.05) (end 3.95 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.95 -1.05) (end 3.95 1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.95 1.05) (end 2.9 1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.9 1.05) (end 2.9 2.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.75 2.9) (end 2.9 2.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.75 -2.9) (end 2.9 -2.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.9 1.75) (end -1.75 2.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.9 -1.75) (end -1.75 -2.9) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.9 -1.75) (end -2.9 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.9 1.05) (end -2.9 1.75) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.9 -1.05) (end -3.95 -1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.95 -1.05) (end -3.95 1.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.95 1.05) (end -2.9 1.05) (layer F.CrtYd) (width 0.05))
    (fp_text user %R (at 0 0) (layer F.Fab)
    (pad 1 smd roundrect (at -2.2 0) (size 3 1.6) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.15625)
      (net 3 /VCC3))
    (pad 2 smd roundrect (at 2.2 0) (size 3 1.6) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.15625)
      (net 4 GND))
    (model ${KISYS3DMOD}/Capacitor_SMD.3dshapes/CP_Elec_5x5.9.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CBB5E64)
    (at 128.2 62 270)
    (descr CAPACITOR)
    (path /355CF2CD)
    (attr smd)
    (fp_text reference C15 (at 0.1 -1.2 270) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C1206 (layer F.Cu) (tedit 5C609920) (tstamp 5CBB5AA8)
    (at 106 55 90)
    (descr CAPACITOR)
    (path /944E5673)
    (attr smd)
    (fp_text reference C16 (at 0 1.7 270) (layer F.SilkS)
    (fp_text value 47n/50V (at 0.75 1.75 90) (layer F.SilkS) hide
    (fp_line (start -1.7 -0.9) (end 1.7 -0.9) (layer Dwgs.User) (width 0.05))
    (fp_line (start -1.7 0.9) (end 1.7 0.9) (layer Dwgs.User) (width 0.05))
    (fp_line (start -1.7 -0.9) (end -1.7 0.9) (layer Dwgs.User) (width 0.05))
    (fp_line (start 1.7 -0.9) (end 1.7 0.9) (layer Dwgs.User) (width 0.05))
    (fp_line (start -2.5 -1) (end 2.5 -1) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.5 1) (end 2.5 1) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.5 -1) (end -2.5 1) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.5 -1) (end 2.5 1) (layer F.CrtYd) (width 0.05))
    (pad 2 smd rect (at 1.4 0 90) (size 1.6 1.8) (layers F.Cu F.Paste F.Mask)
      (net 8 /VB+) (solder_paste_margin_ratio -0.05))
    (pad 1 smd rect (at -1.4 0 90) (size 1.6 1.8) (layers F.Cu F.Paste F.Mask)
      (net 40 /BYP) (solder_paste_margin_ratio -0.05))
    (model ${KISYS3DMOD}/Capacitors_SMD.3dshapes/C_1206.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C1206 (layer F.Cu) (tedit 5C609920) (tstamp 5CB2C0A1)
    (at 103.6 55 90)
    (descr CAPACITOR)
    (path /8F4D0EC0)
    (attr smd)
    (fp_text reference C17 (at -3.1 0.1 180) (layer F.SilkS)
      (net 41 /RXIN) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB2C07A)
    (at 121.2 55.6 270)
    (descr CAPACITOR)
    (path /EA680916)
    (attr smd)
    (fp_text reference C18 (at -0.9 1 270) (layer F.SilkS)
    (fp_text value 10n (at 0.75 1.75 270) (layer F.SilkS) hide
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Pin_Headers:Pin_Header_Straight_1x02_Pitch2.54mm (layer F.Cu) (tedit 59650532) (tstamp 5CB65E1D)
    (at 137 44.2)
    (descr "Through hole straight pin header, 1x02, 2.54mm pitch, single row")
    (tags "Through hole pin header THT 1x02 2.54mm single row")
    (path /53A7A761)
    (fp_text reference CFG1001 (at 0 -2.33) (layer F.SilkS)
    (fp_text value PIN2_100 (at 0 4.87) (layer F.Fab)
    (fp_line (start -0.635 -1.27) (end 1.27 -1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 1.27 -1.27) (end 1.27 3.81) (layer F.Fab) (width 0.1))
    (fp_line (start 1.27 3.81) (end -1.27 3.81) (layer F.Fab) (width 0.1))
    (fp_line (start -1.27 3.81) (end -1.27 -0.635) (layer F.Fab) (width 0.1))
    (fp_line (start -1.27 -0.635) (end -0.635 -1.27) (layer F.Fab) (width 0.1))
    (fp_line (start -1.33 3.87) (end 1.33 3.87) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 1.27) (end -1.33 3.87) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.33 1.27) (end 1.33 3.87) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 1.27) (end 1.33 1.27) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 0) (end -1.33 -1.33) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 -1.33) (end 0 -1.33) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.8 -1.8) (end -1.8 4.35) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.8 4.35) (end 1.8 4.35) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.8 4.35) (end 1.8 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.8 -1.8) (end -1.8 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_text user %R (at 0 1.27 90) (layer F.Fab)
    (pad 1 thru_hole rect (at 0 0) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 6 "Net-(CFG1001-Pad1)"))
    (pad 2 thru_hole oval (at 0 2.54) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (model ${KISYS3DMOD}/Pin_Headers.3dshapes/Pin_Header_Straight_1x02_Pitch2.54mm.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:SOT23 (layer F.Cu) (tedit 5C603EDA) (tstamp 5CB2BFDC)
    (at 107.8 44 90)
    (descr SOT-23)
    (tags "SOT23 IPC")
    (path /C78C3FBD)
    (fp_text reference D1 (at 2.3 0.8 180) (layer F.SilkS)
    (fp_text value BAS70-06 (at -2.2 -0.4 180) (layer F.Fab) hide
    (fp_line (start -2 -2) (end 2 -2) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2 -2) (end 2 2) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2 2) (end -2 2) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2 2) (end -2 -2) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.4 0.65) (end -1.4 -0.65) (layer F.SilkS) (width 0.15))
    (fp_line (start 1.4 0.65) (end -1.4 0.65) (layer F.SilkS) (width 0.15))
    (fp_line (start 1.4 -0.65) (end 1.4 0.65) (layer F.SilkS) (width 0.15))
    (fp_line (start -1.4 -0.65) (end 1.4 -0.65) (layer F.SilkS) (width 0.15))
    (pad 1 smd rect (at 0.95 -1.1 90) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 8 /VB+))
    (pad 3 smd rect (at 0 1.1 90) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 7 /BUS+))
    (pad 2 smd rect (at -0.95 -1.1 90) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 8 /VB+))
    (model ${KISYS3DMOD}/Diodes_SMD.3dshapes/D_SOT-23.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Diodes_SMD:D_SMA (layer F.Cu) (tedit 586432E5) (tstamp 5CB2BFA0)
    (at 134.2 65.8)
    (descr "Diode SMA (DO-214AC)")
    (tags "Diode SMA (DO-214AC)")
    (path /5CAFBE4E)
    (attr smd)
    (fp_text reference D10 (at 4.3 0.1 90) (layer F.SilkS)
    (fp_text value D_TVS (at 0 2.6) (layer F.Fab)
    (fp_text user %R (at 0 -2.5) (layer F.Fab)
    (fp_line (start -3.4 -1.65) (end -3.4 1.65) (layer F.SilkS) (width 0.12))
    (fp_line (start 2.3 1.5) (end -2.3 1.5) (layer F.Fab) (width 0.1))
    (fp_line (start -2.3 1.5) (end -2.3 -1.5) (layer F.Fab) (width 0.1))
    (fp_line (start 2.3 -1.5) (end 2.3 1.5) (layer F.Fab) (width 0.1))
    (fp_line (start 2.3 -1.5) (end -2.3 -1.5) (layer F.Fab) (width 0.1))
    (fp_line (start -3.5 -1.75) (end 3.5 -1.75) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.5 -1.75) (end 3.5 1.75) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.5 1.75) (end -3.5 1.75) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.5 1.75) (end -3.5 -1.75) (layer F.CrtYd) (width 0.05))
    (fp_line (start -0.64944 0.00102) (end -1.55114 0.00102) (layer F.Fab) (width 0.1))
    (fp_line (start 0.50118 0.00102) (end 1.4994 0.00102) (layer F.Fab) (width 0.1))
    (fp_line (start -0.64944 -0.79908) (end -0.64944 0.80112) (layer F.Fab) (width 0.1))
    (fp_line (start 0.50118 0.75032) (end 0.50118 -0.79908) (layer F.Fab) (width 0.1))
    (fp_line (start -0.64944 0.00102) (end 0.50118 0.75032) (layer F.Fab) (width 0.1))
    (fp_line (start -0.64944 0.00102) (end 0.50118 -0.79908) (layer F.Fab) (width 0.1))
    (fp_line (start -3.4 1.65) (end 2 1.65) (layer F.SilkS) (width 0.12))
    (fp_line (start -3.4 -1.65) (end 2 -1.65) (layer F.SilkS) (width 0.12))
    (pad 1 smd rect (at -2 0) (size 2.5 1.8) (layers F.Cu F.Paste F.Mask)
      (net 7 /BUS+))
    (pad 2 smd rect (at 2 0) (size 2.5 1.8) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (model ${KISYS3DMOD}/Diodes_SMD.3dshapes/D_SMA.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:SO8 (layer F.Cu) (tedit 0) (tstamp 5CB65A6A)
    (at 99.6 44.2 270)
    (descr "SO-8 Surface Mount Small Outline 150mil 8pin Package")
    (tags "Power Integrations D Package")
    (path /BC34DC86)
    (fp_text reference IC2 (at 3.4 0.1) (layer F.SilkS)
    (fp_text value ADUM1201SOIC8 (at 0 0 270) (layer F.Fab)
    (fp_line (start 2.54 1.905) (end 2.54 -1.905) (layer F.SilkS) (width 0.15))
    (fp_line (start -2.54 1.905) (end -2.54 -1.905) (layer F.SilkS) (width 0.15))
    (fp_line (start -2.54 1.905) (end 2.54 1.905) (layer F.SilkS) (width 0.15))
    (fp_line (start -2.54 -1.905) (end 2.54 -1.905) (layer F.SilkS) (width 0.15))
    (fp_line (start -2.54 1.397) (end 2.54 1.397) (layer F.SilkS) (width 0.15))
    (fp_circle (center -1.905 0.762) (end -1.778 0.762) (layer F.SilkS) (width 0.15))
    (pad 8 smd oval (at -1.905 -2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 3 /VCC3))
    (pad 7 smd oval (at -0.635 -2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 9 /TXD_TPUART))
    (pad 6 smd oval (at 0.635 -2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 20 /RXD_TPUART))
    (pad 5 smd oval (at 1.905 -2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 4 smd oval (at 1.905 2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 2 /GND_PI))
    (pad 3 smd oval (at 0.635 2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 10 /TXD_PI))
    (pad 2 smd oval (at -0.635 2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 11 /RXD_PI))
    (pad 1 smd oval (at -1.905 2.794 270) (size 0.6096 1.4732) (layers F.Cu F.Paste F.Mask)
      (net 1 +3V3))
  (module Kalassi:QFN36ePad (layer F.Cu) (tedit 5C603F63) (tstamp 5CB2BF29)
    (at 116.6 58.6)
    (path /5CAFC468)
    (fp_text reference IC10 (at 0 -1.5) (layer F.SilkS)
    (fp_text value TPUART2QFN (at 0 1.5 90) (layer F.Fab)
      (effects (font (size 1 0.8) (thickness 0.15)))
    (fp_line (start 0.5 0) (end 1 0) (layer F.Paste) (width 0.5))
    (fp_line (start -1 0) (end -0.5 0) (layer F.Paste) (width 0.5))
    (fp_line (start 0 -0.5) (end 0 -1) (layer F.Paste) (width 0.5))
    (fp_line (start 0 1) (end 0 0.5) (layer F.Paste) (width 0.5))
    (pad 1 smd oval (at -2 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (solder_paste_margin -0.01))
    (pad 2 smd oval (at -1.5 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 3 smd oval (at -1 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 4 smd oval (at -0.5 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 38 /VDDH) (solder_paste_margin -0.01))
    (pad 5 smd oval (at 0 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 39 /VSSH) (solder_paste_margin -0.01))
    (pad 6 smd oval (at 0.5 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 7 smd oval (at 1 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 4 GND) (solder_paste_margin -0.01))
    (pad 8 smd oval (at 1.5 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 3 /VCC3) (solder_paste_margin -0.01))
    (pad 9 smd oval (at 2 3) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 42 /IND) (solder_paste_margin -0.01))
    (pad 10 smd oval (at 3 2 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 11 smd oval (at 3 1.5 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 8 /VB+) (solder_paste_margin -0.01))
    (pad 12 smd oval (at 3 1 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 40 /BYP) (solder_paste_margin -0.01))
    (pad 13 smd oval (at 3 0.5 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 12 "Net-(IC10-Pad13)") (solder_paste_margin -0.01))
    (pad 14 smd oval (at 3 0 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 13 /STXO) (solder_paste_margin -0.01))
    (pad 15 smd oval (at 3 -0.5 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 41 /RXIN) (solder_paste_margin -0.01))
    (pad 16 smd oval (at 3 -1 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 17 smd oval (at 3 -1.5 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 18 smd oval (at 3 -2 90) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 22 smd oval (at 0.5 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 19 smd oval (at 2 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 21 smd oval (at 1 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 9 /TXD_TPUART) (solder_paste_margin -0.01))
    (pad 20 smd oval (at 1.5 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 20 /RXD_TPUART) (solder_paste_margin -0.01))
    (pad 23 smd oval (at 0 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 43 /X1) (solder_paste_margin -0.01))
    (pad 26 smd oval (at -1.5 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 24 smd oval (at -0.5 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 44 /X2) (solder_paste_margin -0.01))
    (pad 25 smd oval (at -1 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
      (net 5 /VDP) (solder_paste_margin -0.01))
    (pad 27 smd oval (at -2 -3 180) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 31 smd oval (at -3 -0.5 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 28 smd oval (at -3 -2 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 29 smd oval (at -3 -1.5 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 30 smd oval (at -3 -1 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 32 smd oval (at -3 0 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 35 smd oval (at -3 1.5 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 33 smd oval (at -3 0.5 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 34 smd oval (at -3 1 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 36 smd oval (at -3 2 270) (size 0.28 0.94) (layers F.Cu F.Paste F.Mask)
    (pad 37 smd rect (at 0 0) (size 4 4) (layers F.Cu F.Mask)
      (net 4 GND))
    (pad 37 thru_hole circle (at 0.7 0.7) (size 1 1) (drill 0.5) (layers *.Cu *.Mask F.SilkS)
      (net 4 GND))
    (pad 37 thru_hole circle (at -0.7 0.7) (size 1 1) (drill 0.5) (layers *.Cu *.Mask F.SilkS)
      (net 4 GND))
    (pad 37 thru_hole circle (at -0.7 -0.7) (size 1 1) (drill 0.5) (layers *.Cu *.Mask F.SilkS)
      (net 4 GND))
    (pad 37 thru_hole circle (at 0.7 -0.7) (size 1 1) (drill 0.5) (layers *.Cu *.Mask F.SilkS)
      (net 4 GND))
    (model ${KISYS3DMOD}/Package_DFN_QFN.3dshapes/QFN-36-1EP_6x6mm_P0.5mm_EP3.7x3.7mm.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Pin_Headers:Pin_Header_Straight_2x20_Pitch2.54mm locked (layer F.Cu) (tedit 59650533) (tstamp 5CB2B49C)
    (at 83.425 38.225 90)
    (descr "Through hole straight pin header, 2x20, 2.54mm pitch, double rows")
    (tags "Through hole pin header THT 2x20 2.54mm double row")
    (path /FD237801)
    (fp_text reference K1 (at 1.27 -2.33 90) (layer F.SilkS)
    (fp_text value PIN20X2 (at 1.27 50.59 90) (layer F.Fab)
    (fp_line (start 0 -1.27) (end 3.81 -1.27) (layer F.Fab) (width 0.1))
    (fp_line (start 3.81 -1.27) (end 3.81 49.53) (layer F.Fab) (width 0.1))
    (fp_line (start 3.81 49.53) (end -1.27 49.53) (layer F.Fab) (width 0.1))
    (fp_line (start -1.27 49.53) (end -1.27 0) (layer F.Fab) (width 0.1))
    (fp_line (start -1.27 0) (end 0 -1.27) (layer F.Fab) (width 0.1))
    (fp_line (start -1.33 49.59) (end 3.87 49.59) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 1.27) (end -1.33 49.59) (layer F.SilkS) (width 0.12))
    (fp_line (start 3.87 -1.33) (end 3.87 49.59) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.33 1.27) (end 1.27 1.27) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.27 1.27) (end 1.27 -1.33) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.27 -1.33) (end 3.87 -1.33) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.8 -1.8) (end -1.8 50.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.8 50.05) (end 4.35 50.05) (layer F.CrtYd) (width 0.05))
    (fp_line (start 4.35 50.05) (end 4.35 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_line (start 4.35 -1.8) (end -1.8 -1.8) (layer F.CrtYd) (width 0.05))
    (fp_text user %R (at 1.27 24.13 180) (layer F.Fab)
    (pad 1 thru_hole rect (at 0 0 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 +3V3))
    (pad 2 thru_hole oval (at 2.54 0 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 14 +5V))
    (pad 3 thru_hole oval (at 0 2.54 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 4 thru_hole oval (at 2.54 2.54 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 14 +5V))
    (pad 5 thru_hole oval (at 0 5.08 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 6 thru_hole oval (at 2.54 5.08 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 7 thru_hole oval (at 0 7.62 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 8 thru_hole oval (at 2.54 7.62 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 10 /TXD_PI))
    (pad 9 thru_hole oval (at 0 10.16 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 10 thru_hole oval (at 2.54 10.16 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 11 /RXD_PI))
    (pad 11 thru_hole oval (at 0 12.7 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 12 thru_hole oval (at 2.54 12.7 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 13 thru_hole oval (at 0 15.24 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 14 thru_hole oval (at 2.54 15.24 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 15 thru_hole oval (at 0 17.78 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 16 thru_hole oval (at 2.54 17.78 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 17 thru_hole oval (at 0 20.32 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 +3V3))
    (pad 18 thru_hole oval (at 2.54 20.32 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 19 thru_hole oval (at 0 22.86 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 20 thru_hole oval (at 2.54 22.86 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 21 thru_hole oval (at 0 25.4 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 22 thru_hole oval (at 2.54 25.4 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 23 thru_hole oval (at 0 27.94 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 24 thru_hole oval (at 2.54 27.94 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 25 thru_hole oval (at 0 30.48 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 26 thru_hole oval (at 2.54 30.48 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 27 thru_hole oval (at 0 33.02 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 15 "Net-(K1-Pad27)"))
    (pad 28 thru_hole oval (at 2.54 33.02 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 16 "Net-(K1-Pad28)"))
    (pad 29 thru_hole oval (at 0 35.56 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 30 thru_hole oval (at 2.54 35.56 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 31 thru_hole oval (at 0 38.1 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 32 thru_hole oval (at 2.54 38.1 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 33 thru_hole oval (at 0 40.64 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 34 thru_hole oval (at 2.54 40.64 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 35 thru_hole oval (at 0 43.18 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 36 thru_hole oval (at 2.54 43.18 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 37 thru_hole oval (at 0 45.72 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 38 thru_hole oval (at 2.54 45.72 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (pad 39 thru_hole oval (at 0 48.26 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
    (pad 40 thru_hole oval (at 2.54 48.26 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
    (model ${KISYS3DMOD}/Pin_Headers.3dshapes/Pin_Header_Straight_2x20_Pitch2.54mm.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:L4532M (layer F.Cu) (tedit 5C609A38) (tstamp 5CB2BEDF)
    (at 115.8 65.6)
    (descr INDUCTOR)
    (tags "INDUCTOR IPC")
    (path /5C49978A)
    (attr smd)
    (fp_text reference L10 (at -2 -2.6) (layer F.SilkS)
    (fp_text value 220uH (at -1.2 2.8) (layer F.SilkS) hide
    (fp_line (start 3.5 -2) (end 3.5 2) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.5 -2) (end -3.5 2) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.5 2) (end 3.5 2) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.5 -2) (end 3.5 -2) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.4 -1.7) (end 2.4 1.7) (layer Dwgs.User) (width 0.05))
    (fp_line (start -2.4 -1.7) (end -2.4 1.7) (layer Dwgs.User) (width 0.05))
    (fp_line (start -2.4 1.7) (end 2.4 1.7) (layer Dwgs.User) (width 0.05))
    (fp_line (start -2.4 -1.7) (end 2.4 -1.7) (layer Dwgs.User) (width 0.05))
    (pad 1 smd rect (at -1.9 0) (size 2 2.4) (layers F.Cu F.Paste F.Mask)
    (pad 2 smd rect (at 1.9 0) (size 2 2.4) (layers F.Cu F.Paste F.Mask)
      (net 42 /IND) (solder_paste_margin_ratio -0.05))
    (model ${KISYS3DMOD}/Inductors_SMD.3dshapes/L_1812.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2BCCF)
    (at 124.8 43.2 90)
    (descr RESISTOR)
    (tags "RESISTOR IPC")
    (path /8424204E)
    (attr smd)
    (fp_text reference R1 (at 2.3 0 90) (layer F.SilkS)
    (fp_text value 3k9 (at 0.75 1.75 90) (layer F.SilkS) hide
    (fp_line (start -0.85 0.495) (end -0.85 -0.495) (layer Dwgs.User) (width 0.0508))
    (fp_line (start 0.85 0.495) (end -0.85 0.495) (layer Dwgs.User) (width 0.0508))
    (fp_line (start 0.85 -0.495) (end 0.85 0.495) (layer Dwgs.User) (width 0.0508))
    (fp_line (start -0.85 -0.495) (end 0.85 -0.495) (layer Dwgs.User) (width 0.0508))
    (pad 2 smd rect (at 0.8 0 90) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
    (pad 1 smd rect (at -0.8 0 90) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 16 "Net-(K1-Pad28)") (solder_paste_margin_ratio -0.05))
    (model ${KISYS3DMOD}/Resistor_SMD.3dshapes/R_0603_1608Metric.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2BCA8)
    (at 127.2 43.2 90)
    (descr RESISTOR)
    (path /551CC7F3)
    (attr smd)
    (fp_text reference R2 (at 2.3 0 90) (layer F.SilkS)
      (net 15 "Net-(K1-Pad27)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2BC5A)
    (at 129.6 43.2 90)
    (descr RESISTOR)
    (path /299CF91A)
    (attr smd)
    (fp_text reference R3 (at 2.3 0 90) (layer F.SilkS)
    (fp_text value 1k (at 0.75 1.75 90) (layer F.SilkS) hide
      (net 6 "Net-(CFG1001-Pad1)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CBBB093)
    (at 122.5 43.2 90)
    (descr RESISTOR)
    (path /6ADC41DC)
    (attr smd)
    (fp_text reference R4 (at 2.3 0 90) (layer F.SilkS)
      (net 18 "Net-(LED_STXO1-Pad2)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2BD9B)
    (at 105.6 50.6 90)
    (descr RESISTOR)
    (path /1AA79311)
    (attr smd)
    (fp_text reference R5 (at 0.25 -1.75 90) (layer F.SilkS)
      (net 19 "Net-(LED_TPUART1-Pad2)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2BCF6)
    (at 132 43.2 90)
    (descr RESISTOR)
    (path /CBA4FB2B)
    (attr smd)
    (fp_text reference R6 (at 2.2 0 90) (layer F.SilkS)
      (net 17 "Net-(LED_PI1-Pad2)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistors_SMD:R_2010 (layer F.Cu) (tedit 5415D342) (tstamp 5CB2BD78)
    (at 100.4 54.2 270)
    (descr "Resistor SMD 2010, reflow soldering, Vishay (see dcrcw.pdf)")
    (tags "resistor 2010")
    (path /F667A0B9)
    (attr smd)
    (fp_text reference R11 (at -0.1 2.4 270) (layer F.SilkS)
    (fp_text value 68Ohm/1W (at 0 2.7 270) (layer F.Fab)
    (fp_line (start -3.25 -1.6) (end 3.25 -1.6) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.25 1.6) (end 3.25 1.6) (layer F.CrtYd) (width 0.05))
    (fp_line (start -3.25 -1.6) (end -3.25 1.6) (layer F.CrtYd) (width 0.05))
    (fp_line (start 3.25 -1.6) (end 3.25 1.6) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.95 1.475) (end -1.95 1.475) (layer F.SilkS) (width 0.15))
    (fp_line (start -1.95 -1.475) (end 1.95 -1.475) (layer F.SilkS) (width 0.15))
    (pad 1 smd rect (at -2.45 0 270) (size 1 2.5) (layers F.Cu F.Paste F.Mask)
      (net 8 /VB+))
    (pad 2 smd rect (at 2.45 0 270) (size 1 2.5) (layers F.Cu F.Paste F.Mask)
      (net 12 "Net-(IC10-Pad13)"))
    (model Resistors_SMD.3dshapes/R_2010.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:SOT23 (layer F.Cu) (tedit 5C603EDA) (tstamp 5CB2BD51)
    (at 109.8 71)
    (descr SOT-23)
    (tags "SOT23 IPC")
    (path /B8952976)
    (fp_text reference T1 (at 2.2 -0.4 90) (layer F.SilkS)
    (fp_text value 2N7002 (at -2.2 -0.4 90) (layer F.Fab) hide
    (pad 2 smd rect (at -0.95 -1.1) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 3 smd rect (at 0 1.1) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 21 "Net-(LED_STXO1-Pad1)"))
    (pad 1 smd rect (at 0.95 -1.1) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 13 /STXO))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:SO8 (layer F.Cu) (tedit 0) (tstamp 5CB2BD21)
    (at 114.2 42.6 270)
    (path /94FABF20)
    (fp_text reference U1 (at 0 0 270) (layer F.SilkS)
    (fp_text value EEPROM24 (at 0 0 270) (layer F.Fab)
      (net 2 /GND_PI))
      (net 2 /GND_PI))
      (net 2 /GND_PI))
      (net 2 /GND_PI))
      (net 1 +3V3))
  (module Kalassi:Crystal_SMD_HC49-SD (layer F.Cu) (tedit 5C93EFC8) (tstamp 5CB70867)
    (at 113.8 51 180)
    (descr "SMD Crystal HC-49-SD http://cdn-reichelt.de/documents/datenblatt/B400/xxx-HC49-SMD.pdf, 11.4x4.7mm^2 package")
    (tags "SMD SMT crystal")
    (path /8F6FA7B9)
    (attr smd)
    (fp_text reference XT10 (at 1.8 -3.4 180) (layer F.SilkS)
    (fp_text value CSM-7X-DU (at 0 3.55 180) (layer F.Fab)
    (fp_line (start -5.7 -2.35) (end -5.7 2.35) (layer F.Fab) (width 0.1))
    (fp_line (start -5.7 2.35) (end 5.7 2.35) (layer F.Fab) (width 0.1))
    (fp_line (start 5.7 2.35) (end 5.7 -2.35) (layer F.Fab) (width 0.1))
    (fp_line (start 5.7 -2.35) (end -5.7 -2.35) (layer F.Fab) (width 0.1))
    (fp_line (start -3.015 -2.115) (end 3.015 -2.115) (layer F.Fab) (width 0.1))
    (fp_line (start -3.015 2.115) (end 3.015 2.115) (layer F.Fab) (width 0.1))
    (fp_line (start 5.9 -2.55) (end -6.7 -2.55) (layer F.SilkS) (width 0.12))
    (fp_line (start -6.7 -2.55) (end -6.7 2.55) (layer F.SilkS) (width 0.12))
    (fp_line (start -6.7 2.55) (end 5.9 2.55) (layer F.SilkS) (width 0.12))
    (fp_line (start -6.8 -2.6) (end -6.8 2.6) (layer F.CrtYd) (width 0.05))
    (fp_line (start -6.8 2.6) (end 6.8 2.6) (layer F.CrtYd) (width 0.05))
    (fp_line (start 6.8 2.6) (end 6.8 -2.6) (layer F.CrtYd) (width 0.05))
    (fp_line (start 6.8 -2.6) (end -6.8 -2.6) (layer F.CrtYd) (width 0.05))
    (fp_arc (start -3.015 0) (end -3.015 -2.115) (angle -180) (layer F.Fab) (width 0.1))
    (fp_arc (start 3.015 0) (end 3.015 -2.115) (angle 180) (layer F.Fab) (width 0.1))
    (pad 1 smd rect (at -4.25 0 180) (size 4.5 2) (layers F.Cu F.Paste F.Mask)
      (net 43 /X1))
    (pad 2 smd rect (at 4.25 0 180) (size 4.5 2) (layers F.Cu F.Paste F.Mask)
      (net 44 /X2))
    (model ${KISYS3DMOD}/Crystal.3dshapes/HC49-SMD.STEP
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB2E07C)
    (at 88 44.45 270)
    (descr CAPACITOR)
    (path /5CD68901)
    (attr smd)
    (fp_text reference C40 (at -2.75 0.1 270) (layer F.SilkS)
    (fp_text value C (at 0.75 1.75 270) (layer F.SilkS) hide
      (net 22 "Net-(C40-Pad1)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB66190)
    (at 78 79.6 270)
    (descr CAPACITOR)
    (path /5CD1980F)
    (attr smd)
    (fp_text reference C52 (at 0 1.5 270) (layer F.SilkS)
    (fp_text value 33nF (at 0.75 1.75 270) (layer F.SilkS) hide
      (net 27 /SOFTSTART) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB66407)
    (at 79.4 72.6 90)
    (descr CAPACITOR)
    (path /5CC2F899)
    (attr smd)
    (fp_text reference C55 (at -2.8 0.2 90) (layer F.SilkS)
    (fp_text value 3.3n (at 0.75 1.75 90) (layer F.SilkS) hide
      (net 36 /COMP) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CBADA8A)
    (at 77.2 72.6 270)
    (descr CAPACITOR)
    (path /5CC2F91F)
    (attr smd)
    (fp_text reference C56 (at 2.8 0 270) (layer F.SilkS)
    (fp_text value 150nF (at 0.75 1.75 270) (layer F.SilkS) hide
      (net 37 /COMP1) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Inductors_THT:L_Axial_L23.4mm_D12.7mm_P25.40mm_Horizontal_Vishay_IHA-203 (layer F.Cu) (tedit 587E3FCE) (tstamp 5CB2E0C9)
    (at 111 75)
    (descr "L, Axial series, Axial, Horizontal, pin pitch=25.4mm, , length*diameter=23.37*12.7mm^2, Vishay, IHA-203, http://www.vishay.com/docs/34014/iha.pdf")
    (tags "L Axial series Axial Horizontal pin pitch 25.4mm  length 23.37mm diameter 12.7mm Vishay IHA-203")
    (path /5CE615C6)
    (fp_text reference L60 (at 12.7 5) (layer F.SilkS)
    (fp_text value AIAP-03-272K (at 12.7 7.41) (layer F.Fab)
    (fp_line (start 1.015 -6.35) (end 1.015 6.35) (layer F.Fab) (width 0.1))
    (fp_line (start 1.015 6.35) (end 24.385 6.35) (layer F.Fab) (width 0.1))
    (fp_line (start 24.385 6.35) (end 24.385 -6.35) (layer F.Fab) (width 0.1))
    (fp_line (start 24.385 -6.35) (end 1.015 -6.35) (layer F.Fab) (width 0.1))
    (fp_line (start 0 0) (end 1.015 0) (layer F.Fab) (width 0.1))
    (fp_line (start 25.4 0) (end 24.385 0) (layer F.Fab) (width 0.1))
    (fp_line (start 0.955 -1.38) (end 0.955 -6.41) (layer F.SilkS) (width 0.12))
    (fp_line (start 0.955 -6.41) (end 24.445 -6.41) (layer F.SilkS) (width 0.12))
    (fp_line (start 24.445 -6.41) (end 24.445 -1.38) (layer F.SilkS) (width 0.12))
    (fp_line (start 0.955 1.38) (end 0.955 6.41) (layer F.SilkS) (width 0.12))
    (fp_line (start 0.955 6.41) (end 24.445 6.41) (layer F.SilkS) (width 0.12))
    (fp_line (start 24.445 6.41) (end 24.445 1.38) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.45 -6.7) (end -1.45 6.7) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.45 6.7) (end 26.85 6.7) (layer F.CrtYd) (width 0.05))
    (fp_line (start 26.85 6.7) (end 26.85 -6.7) (layer F.CrtYd) (width 0.05))
    (fp_line (start 26.85 -6.7) (end -1.45 -6.7) (layer F.CrtYd) (width 0.05))
    (pad 1 thru_hole circle (at 0 0) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 32 /DROSSEL_IN))
    (pad 2 thru_hole oval (at 25.4 0) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 7 /BUS+))
    (model Inductors_THT.3dshapes/L_Axial_L23.4mm_D12.7mm_P25.40mm_Horizontal_Vishay_IHA-203.wrl
      (at (xyz 0 0 0))
      (scale (xyz 0.393701 0.393701 0.393701))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB6595C)
    (at 85.8 44.4 270)
    (descr RESISTOR)
    (path /5CD98135)
    (attr smd)
    (fp_text reference R40 (at -2.7 -0.5 270) (layer F.SilkS)
    (fp_text value 100k (at 0.75 1.75 270) (layer F.SilkS) hide
    (pad 1 smd rect (at -0.8 0 270) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 45 "Net-(IC40-Pad7)") (solder_paste_margin_ratio -0.05))
    (pad 2 smd rect (at 0.8 0 270) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 23 "Net-(IC40-Pad1)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB66696)
    (at 80.2 79.6 270)
    (descr RESISTOR)
    (path /5CBCF865)
    (attr smd)
    (fp_text reference R52 (at 2.5 0 270) (layer F.SilkS)
      (net 34 /FREQ) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB6642E)
    (at 81.6 72.6 90)
    (descr RESISTOR)
    (path /5CC2F9A9)
    (attr smd)
    (fp_text reference R55 (at -2.8 0 90) (layer F.SilkS)
    (fp_text value 1.65k (at 0.75 1.75 90) (layer F.SilkS) hide
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2E113)
    (at 83 79 180)
    (descr RESISTOR)
    (path /5CC56634)
    (attr smd)
    (fp_text reference R58 (at 0 1.1 180) (layer F.SilkS)
    (fp_text value 220k (at 0.75 1.75 180) (layer F.SilkS) hide
    (pad 1 smd rect (at -0.8 0 180) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 28 /BOOST_30V) (solder_paste_margin_ratio -0.05))
    (pad 2 smd rect (at 0.8 0 180) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (net 33 /FB) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2E121)
    (at 83 81.4)
    (descr RESISTOR)
    (path /5CC566D8)
    (attr smd)
    (fp_text reference R59 (at -0.1 1.3) (layer F.SilkS)
    (fp_text value 10k (at 0.75 1.75) (layer F.SilkS) hide
    (pad 2 smd rect (at 0.8 0) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
    (pad 1 smd rect (at -0.8 0) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R1210 (layer F.Cu) (tedit 5B87C6CB) (tstamp 5CBCB2C1)
    (at 112.2 84.4 180)
    (descr RESISTOR)
    (path /5CE61806)
    (attr smd)
    (fp_text reference R60 (at 0.9 -2 180) (layer F.SilkS)
    (fp_text value 100R (at 0 2.2 180) (layer F.SilkS) hide
    (fp_line (start 2.5 -1.5) (end 2.5 1.5) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.5 -1.5) (end -2.5 1.5) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.5 1.5) (end 2.5 1.5) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.5 -1.5) (end 2.5 -1.5) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.675 -1.32) (end 1.675 1.32) (layer Dwgs.User) (width 0.05))
    (fp_line (start -1.675 -1.32) (end -1.675 1.32) (layer Dwgs.User) (width 0.05))
    (fp_line (start -1.675 1.32) (end 1.675 1.32) (layer Dwgs.User) (width 0.05))
    (fp_line (start -1.675 -1.32) (end 1.675 -1.32) (layer Dwgs.User) (width 0.05))
    (pad 1 smd rect (at -1.4 0 180) (size 1.6 2.7) (layers F.Cu F.Paste F.Mask)
      (net 7 /BUS+) (solder_paste_margin_ratio -0.05))
    (pad 2 smd rect (at 1.4 0 180) (size 1.6 2.7) (layers F.Cu F.Paste F.Mask)
      (net 32 /DROSSEL_IN) (solder_paste_margin_ratio -0.05))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB2E13D)
    (at 120.2 84.4 90)
    (descr RESISTOR)
    (path /5CE88CEC)
    (attr smd)
    (fp_text reference R61 (at 0 1.2 90) (layer F.SilkS)
    (fp_text value 10k (at 0.75 1.75 90) (layer F.SilkS) hide
      (net 35 /GYRA_B) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R1210 (layer F.Cu) (tedit 5B87C6CB) (tstamp 5CB2E14B)
    (at 129.6 84.6 90)
    (descr RESISTOR)
    (path /5CE9C9E5)
    (attr smd)
    (fp_text reference R62 (at -0.5 -2 90) (layer F.SilkS)
    (fp_text value 100R (at 0 2.2 90) (layer F.SilkS) hide
    (pad 2 smd rect (at 1.4 0 90) (size 1.6 2.7) (layers F.Cu F.Paste F.Mask)
      (net 29 /GYRA_C) (solder_paste_margin_ratio -0.05))
    (pad 1 smd rect (at -1.4 0 90) (size 1.6 2.7) (layers F.Cu F.Paste F.Mask)
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB34388)
    (at 89.4 79 180)
    (descr CAPACITOR)
    (path /5CCC2DB9)
    (attr smd)
    (fp_text reference C58 (at 0.25 -1.75 180) (layer F.SilkS)
    (fp_text value C (at 0.75 1.75 180) (layer F.SilkS) hide
    (pad 1 smd rect (at -0.85 0 180) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
    (pad 2 smd rect (at 0.85 0 180) (size 1.1 1) (layers F.Cu F.Paste F.Mask)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Capacitor_SMD:CP_Elec_6.3x5.4 (layer F.Cu) (tedit 5BCA39D0) (tstamp 5CB64E87)
    (at 88.6 85 180)
    (path /5CCC2E91)
    (attr smd)
    (fp_text reference C59 (at 0 2.2 180) (layer F.SilkS)
    (fp_text value CP (at 0 4.35 180) (layer F.Fab)
    (fp_text user %R (at 0 0 180) (layer F.Fab)
    (pad 1 smd roundrect (at -2.8 0 180) (size 3.5 1.6) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.15625)
      (net 28 /BOOST_30V))
    (pad 2 smd roundrect (at 2.8 0 180) (size 3.5 1.6) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.15625)
      (net 4 GND))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB343BE)
    (at 124.6 83.2 180)
    (descr CAPACITOR)
    (path /5CE9CB58)
    (attr smd)
    (fp_text reference C61 (at -0.2 1.2 180) (layer F.SilkS)
    (fp_text value 220nF (at 0.75 1.75 180) (layer F.SilkS) hide
      (net 30 /GYRA_E) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Diodes_SMD:D_SMA (layer F.Cu) (tedit 586432E5) (tstamp 5CB343D6)
    (at 101.4 79.2 90)
    (path /5CBFE5C0)
    (attr smd)
    (fp_text reference D50 (at 0 -2.5 90) (layer F.SilkS)
    (fp_text value D (at 0 2.6 90) (layer F.Fab)
    (fp_text user %R (at 0 -2.5 90) (layer F.Fab)
    (pad 2 smd rect (at 2 0 90) (size 2.5 1.8) (layers F.Cu F.Paste F.Mask)
      (net 31 /SW))
    (pad 1 smd rect (at -2 0 90) (size 2.5 1.8) (layers F.Cu F.Paste F.Mask)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Diodes_SMD:D_SMA (layer F.Cu) (tedit 586432E5) (tstamp 5CB343EE)
    (at 106.4 83.2 270)
    (path /5CE61459)
    (attr smd)
    (fp_text reference D60 (at 0 -2.5 270) (layer F.SilkS)
    (fp_text value D (at 0 2.6 270) (layer F.Fab)
    (fp_text user %R (at 0 -2.5 270) (layer F.Fab)
    (pad 1 smd rect (at -2 0 270) (size 2.5 1.8) (layers F.Cu F.Paste F.Mask)
    (pad 2 smd rect (at 2 0 270) (size 2.5 1.8) (layers F.Cu F.Paste F.Mask)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Housings_DFN_QFN:QFN-16-1EP_3x3mm_Pitch0.5mm (layer F.Cu) (tedit 54130A77) (tstamp 5CB661D1)
    (at 89.4 73.8 270)
    (descr "16-Lead Plastic Quad Flat, No Lead Package (NG) - 3x3x0.9 mm Body [QFN]; (see Microchip Packaging Specification 00000049BS.pdf)")
    (tags "QFN 0.5")
    (path /5CB6274E)
    (attr smd)
    (fp_text reference IC50 (at 0 -2.85 270) (layer F.SilkS)
    (fp_text value TPS55340 (at 0 2.85 270) (layer F.Fab)
    (fp_line (start -0.5 -1.5) (end 1.5 -1.5) (layer F.Fab) (width 0.15))
    (fp_line (start 1.5 -1.5) (end 1.5 1.5) (layer F.Fab) (width 0.15))
    (fp_line (start 1.5 1.5) (end -1.5 1.5) (layer F.Fab) (width 0.15))
    (fp_line (start -1.5 1.5) (end -1.5 -0.5) (layer F.Fab) (width 0.15))
    (fp_line (start -1.5 -0.5) (end -0.5 -1.5) (layer F.Fab) (width 0.15))
    (fp_line (start -2.1 -2.1) (end -2.1 2.1) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.1 -2.1) (end 2.1 2.1) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.1 -2.1) (end 2.1 -2.1) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.1 2.1) (end 2.1 2.1) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.625 -1.625) (end 1.625 -1.125) (layer F.SilkS) (width 0.15))
    (fp_line (start -1.625 1.625) (end -1.625 1.125) (layer F.SilkS) (width 0.15))
    (fp_line (start 1.625 1.625) (end 1.625 1.125) (layer F.SilkS) (width 0.15))
    (fp_line (start -1.625 -1.625) (end -1.125 -1.625) (layer F.SilkS) (width 0.15))
    (fp_line (start -1.625 1.625) (end -1.125 1.625) (layer F.SilkS) (width 0.15))
    (fp_line (start 1.625 1.625) (end 1.125 1.625) (layer F.SilkS) (width 0.15))
    (fp_line (start 1.625 -1.625) (end 1.125 -1.625) (layer F.SilkS) (width 0.15))
    (pad 1 smd oval (at -1.475 -0.75 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 31 /SW))
    (pad 2 smd oval (at -1.475 -0.25 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 3 smd oval (at -1.475 0.25 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 4 smd oval (at -1.475 0.75 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 27 /SOFTSTART))
    (pad 5 smd oval (at -0.75 1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask))
    (pad 6 smd oval (at -0.25 1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 7 smd oval (at 0.25 1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 36 /COMP))
    (pad 8 smd oval (at 0.75 1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 33 /FB))
    (pad 9 smd oval (at 1.475 0.75 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 34 /FREQ))
    (pad 10 smd oval (at 1.475 0.25 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 11 smd oval (at 1.475 -0.25 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 12 smd oval (at 1.475 -0.75 270) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 13 smd oval (at 0.75 -1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 14 smd oval (at 0.25 -1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
    (pad 15 smd oval (at -0.25 -1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 31 /SW))
    (pad 16 smd oval (at -0.75 -1.475) (size 0.75 0.3) (layers F.Cu F.Paste F.Mask)
      (net 31 /SW))
    (pad 17 smd rect (at 0.45 0.45 270) (size 0.9 0.9) (layers F.Cu F.Paste F.Mask)
      (net 4 GND) (solder_paste_margin_ratio -0.2))
    (pad 17 smd rect (at 0.45 -0.45 270) (size 0.9 0.9) (layers F.Cu F.Paste F.Mask)
    (pad 17 smd rect (at -0.45 0.45 270) (size 0.9 0.9) (layers F.Cu F.Paste F.Mask)
    (pad 17 smd rect (at -0.45 -0.45 270) (size 0.9 0.9) (layers F.Cu F.Paste F.Mask)
    (model ${KISYS3DMOD}/Housings_DFN_QFN.3dshapes/QFN-16-1EP_3x3mm_Pitch0.5mm.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:Eaton_HC1 (layer F.Cu) (tedit 5CAC92DB) (tstamp 5CBB54E6)
    (at 101.4 66.2 270)
    (path /5CB90F70)
    (fp_text reference L50 (at 8.4 0.3) (layer F.SilkS)
    (fp_text value "Eaton HC1-100-R" (at 0 8 270) (layer F.Fab) hide
    (fp_line (start -6.5 -6.5) (end 6.5 -6.5) (layer F.SilkS) (width 0.4))
    (fp_line (start 6.5 -6.5) (end 6.5 6.5) (layer F.SilkS) (width 0.4))
    (fp_line (start 6.5 6.5) (end -6.5 6.5) (layer F.SilkS) (width 0.4))
    (fp_line (start -6.5 6.5) (end -6.5 -6.5) (layer F.SilkS) (width 0.4))
    (pad 1 smd roundrect (at -5 0 270) (size 4.5 10) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
    (pad 2 smd roundrect (at 5 0 270) (size 4.5 10) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
      (net 31 /SW))
  (module Kalassi:SOT23 (layer F.Cu) (tedit 5C603EDA) (tstamp 5CB34421)
    (at 124.6 86.6 90)
    (descr SOT-23)
    (tags "SOT23 IPC")
    (path /5CE88C2C)
    (fp_text reference Q61 (at -1.6 2.3 180) (layer F.SilkS)
    (fp_text value BC807 (at -2.2 -0.4 180) (layer F.Fab) hide
      (net 29 /GYRA_C))
      (net 30 /GYRA_E))
      (net 35 /GYRA_B))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:C0603 (layer F.Cu) (tedit 5C60989B) (tstamp 5CB66169)
    (at 85.6 72.6 270)
    (descr CAPACITOR)
    (path /5CCC2CA4)
    (attr smd)
    (fp_text reference C50 (at -0.1 1.3 270) (layer F.SilkS)
      (net 26 /VCC5_BOOST) (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Capacitor_SMD:CP_Elec_6.3x5.4 (layer F.Cu) (tedit 5BCA39D0) (tstamp 5CB63161)
    (at 88.4 64.8 180)
    (path /5CB62866)
    (attr smd)
    (fp_text reference C51 (at 4.5 2.5 270) (layer F.SilkS)
      (net 4 GND))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Pin_Headers:Pin_Header_Straight_1x02_Pitch2.54mm (layer F.Cu) (tedit 59650532) (tstamp 5CB65063)
    (at 77.8 47.8 180)
    (path /5CE3A2BC)
    (fp_text reference DIS1 (at 0 -3.1 180) (layer F.SilkS)
    (fp_text value Conn_01x02_Male (at 0 4.87 180) (layer F.Fab)
    (fp_text user %R (at 0 1.27 270) (layer F.Fab)
    (pad 1 thru_hole rect (at 0 0 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 24 "Net-(DIS1-Pad1)"))
    (pad 2 thru_hole oval (at 0 2.54 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 2 /GND_PI))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Housings_DFN_QFN:DFN-10-1EP_3x3mm_Pitch0.5mm (layer F.Cu) (tedit 54130A77) (tstamp 5CB6459E)
    (at 82.7 44.2 90)
    (descr "10-Lead Plastic Dual Flat, No Lead Package (MF) - 3x3x0.9 mm Body [DFN] (see Microchip Packaging Specification 00000049BS.pdf)")
    (tags "DFN 0.5")
    (path /5CD28AC4)
    (attr smd)
    (fp_text reference IC40 (at 0 -2.575 90) (layer F.SilkS)
    (fp_text value STEF05 (at 0 2.575 90) (layer F.Fab)
    (fp_line (start -2.15 -1.85) (end -2.15 1.85) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.15 -1.85) (end 2.15 1.85) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.15 -1.85) (end 2.15 -1.85) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.15 1.85) (end 2.15 1.85) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.225 1.65) (end 1.225 1.65) (layer F.SilkS) (width 0.15))
    (fp_line (start -1.95 -1.65) (end 1.225 -1.65) (layer F.SilkS) (width 0.15))
    (pad 1 smd rect (at -1.55 -1 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 2 smd rect (at -1.55 -0.5 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 3 smd rect (at -1.55 0 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 4 smd rect (at -1.55 0.5 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 5 smd rect (at -1.55 1 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 6 smd rect (at 1.55 1 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask))
    (pad 7 smd rect (at 1.55 0.5 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
      (net 45 "Net-(IC40-Pad7)"))
    (pad 8 smd rect (at 1.55 0 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
    (pad 9 smd rect (at 1.55 -0.5 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
      (net 22 "Net-(C40-Pad1)"))
    (pad 10 smd rect (at 1.55 -1 90) (size 0.65 0.3) (layers F.Cu F.Paste F.Mask)
      (net 2 /GND_PI))
    (pad 11 smd rect (at 0.3875 0.62 90) (size 0.775 1.24) (layers F.Cu F.Paste F.Mask)
      (net 14 +5V) (solder_paste_margin_ratio -0.2))
    (pad 11 smd rect (at 0.3875 -0.62 90) (size 0.775 1.24) (layers F.Cu F.Paste F.Mask)
    (pad 11 smd rect (at -0.3875 0.62 90) (size 0.775 1.24) (layers F.Cu F.Paste F.Mask)
    (pad 11 smd rect (at -0.3875 -0.62 90) (size 0.775 1.24) (layers F.Cu F.Paste F.Mask)
    (model ${KISYS3DMOD}/Housings_DFN_QFN.3dshapes/DFN-10-1EP_3x3mm_Pitch0.5mm.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CB65830)
    (at 103.5 84 270)
    (descr RESISTOR)
    (path /5CF5CC0D)
    (attr smd)
    (fp_text reference R68 (at -0.1 1.7 270) (layer F.SilkS)
    (fp_text value 3k9 (at 0.75 1.75 270) (layer F.SilkS) hide
      (net 25 "Net-(LED_SUP1-Pad2)") (solder_paste_margin_ratio -0.05))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:R0603 (layer F.Cu) (tedit 5C609595) (tstamp 5CBBD5AF)
    (at 103.5 80.7 270)
    (descr RESISTOR)
    (path /5CF8DE04)
    (attr smd)
    (fp_text reference R69 (at -2.7 0 270) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Kalassi:SOT23 (layer F.Cu) (tedit 5C603EDA) (tstamp 5CBBF201)
    (at 117 84.4 270)
    (descr SOT-23)
    (tags "SOT23 IPC")
    (path /5CFA446C)
    (fp_text reference D61 (at -2.2 0.8) (layer F.SilkS)
    (fp_text value BAS70-06 (at -2.2 -0.4) (layer F.Fab) hide
    (pad 1 smd rect (at 0.95 -1.1 270) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 30 /GYRA_E))
    (pad 3 smd rect (at 0 1.1 270) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 7 /BUS+))
    (pad 2 smd rect (at -0.95 -1.1 270) (size 1 1.4) (layers F.Cu F.Paste F.Mask)
      (net 30 /GYRA_E))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LEDs:LED_0603 (layer F.Cu) (tedit 5CACDB24) (tstamp 5CBC1F69)
    (at 118.2 87.6)
    (descr "LED 0603 smd package")
    (tags "LED led 0603 SMD smd SMT smt smdled SMDLED smtled SMTLED")
    (path /5CB21A14)
    (attr smd)
    (fp_text reference LED_PI1 (at 0 -1.25) (layer F.SilkS) hide
    (fp_text value LED (at 0 1.35) (layer F.Fab)
    (fp_line (start -1.45 -0.65) (end 1.45 -0.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.45 0.65) (end -1.45 -0.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.45 0.65) (end -1.45 0.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.45 -0.65) (end 1.45 0.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.3 -0.5) (end 0.8 -0.5) (layer F.SilkS) (width 0.12))
    (fp_line (start -1.3 0.5) (end 0.8 0.5) (layer F.SilkS) (width 0.12))
    (fp_line (start -0.8 0.4) (end -0.8 -0.4) (layer F.Fab) (width 0.1))
    (fp_line (start -0.8 -0.4) (end 0.8 -0.4) (layer F.Fab) (width 0.1))
    (fp_line (start 0.8 -0.4) (end 0.8 0.4) (layer F.Fab) (width 0.1))
    (fp_line (start 0.8 0.4) (end -0.8 0.4) (layer F.Fab) (width 0.1))
    (fp_line (start 0.15 -0.2) (end 0.15 0.2) (layer F.Fab) (width 0.1))
    (fp_line (start 0.15 0.2) (end -0.15 0) (layer F.Fab) (width 0.1))
    (fp_line (start -0.15 0) (end 0.15 -0.2) (layer F.Fab) (width 0.1))
    (fp_line (start -0.2 -0.2) (end -0.2 0.2) (layer F.Fab) (width 0.1))
    (fp_line (start -1.3 -0.5) (end -1.3 0.5) (layer F.SilkS) (width 0.12))
    (pad 1 smd rect (at -0.8 0 180) (size 0.8 0.8) (layers F.Cu F.Paste F.Mask)
      (net 2 /GND_PI))
    (pad 2 smd rect (at 0.8 0 180) (size 0.8 0.8) (layers F.Cu F.Paste F.Mask)
      (net 17 "Net-(LED_PI1-Pad2)"))
    (model ${KISYS3DMOD}/LEDs.3dshapes/LED_0603.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 180))
  (module LEDs:LED_0603 (layer F.Cu) (tedit 5CACDB2A) (tstamp 5CBC1F7D)
    (at 108.7 87.6)
    (path /5CB21D18)
    (attr smd)
    (fp_text reference LED_STXO1 (at 0 -1.25) (layer F.SilkS) hide
      (net 18 "Net-(LED_STXO1-Pad2)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LEDs:LED_0603 (layer F.Cu) (tedit 5CACDB1D) (tstamp 5CBC1F91)
    (at 111.9 87.6 180)
    (path /5CF5CC13)
    (attr smd)
    (fp_text reference LED_SUP1 (at 0 -1.25 180) (layer F.SilkS) hide
    (fp_text value LED (at 0 1.35 180) (layer F.Fab)
    (pad 2 smd rect (at 0.8 0) (size 0.8 0.8) (layers F.Cu F.Paste F.Mask)
      (net 25 "Net-(LED_SUP1-Pad2)"))
    (pad 1 smd rect (at -0.8 0) (size 0.8 0.8) (layers F.Cu F.Paste F.Mask)
      (net 4 GND))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LEDs:LED_0603 (layer F.Cu) (tedit 5CACDB35) (tstamp 5CBCA9DC)
    (at 115.2 87.6 180)
    (path /5CB21E08)
    (attr smd)
    (fp_text reference LED_TPUART1 (at 0 -1.25 180) (layer F.SilkS) hide
      (net 4 GND))
      (net 19 "Net-(LED_TPUART1-Pad2)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (gr_text 3V3 (at 115.2 88.8) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.1)))
  (gr_text TX (at 108.4 88.8) (layer F.SilkS) (tstamp 5CBBAB33)
  (gr_text INT (at 112 88.8) (layer F.SilkS) (tstamp 5CBBC5F6)
  (gr_text PI (at 118.2 88.8) (layer F.SilkS)
  (gr_line (start 83.45 36.925) (end 83.5 39.425) (layer F.SilkS) (width 0.2))
  (gr_line (start 82.25 38.15) (end 84.75 38.15) (layer F.SilkS) (width 0.2))
  (dimension 56 (width 0.15) (layer Dwgs.User)
    (gr_text "56 mm (Thru-hole socket J2)" (at 75.35 28.5 270) (layer Dwgs.User)
      (effects (font (size 1.5 1.5) (thickness 0.15)))
    (feature1 (pts (xy 66 56.5) (xy 76.7 56.5)))
    (feature2 (pts (xy 66 0.5) (xy 76.7 0.5)))
    (crossbar (pts (xy 74 0.5) (xy 74 56.5)))
    (arrow1a (pts (xy 74 56.5) (xy 73.413579 55.373496)))
    (arrow1b (pts (xy 74 56.5) (xy 74.586421 55.373496)))
    (arrow2a (pts (xy 74 0.5) (xy 73.413579 1.626504)))
    (arrow2b (pts (xy 74 0.5) (xy 74.586421 1.626504)))
  (dimension 11.5 (width 0.15) (layer Dwgs.User)
    (gr_text "11.5 mm" (at 39.150001 50.75 270) (layer Dwgs.User)
    (feature1 (pts (xy 43 56.5) (xy 37.800001 56.5)))
    (feature2 (pts (xy 43 45) (xy 37.800001 45)))
    (crossbar (pts (xy 40.500001 45) (xy 40.500001 56.5)))
    (arrow1a (pts (xy 40.500001 56.5) (xy 39.91358 55.373496)))
    (arrow1b (pts (xy 40.500001 56.5) (xy 41.086422 55.373496)))
    (arrow2a (pts (xy 40.500001 45) (xy 39.91358 46.126504)))
    (arrow2b (pts (xy 40.500001 45) (xy 41.086422 46.126504)))
  (dimension 2 (width 0.15) (layer Dwgs.User) (tstamp 5516A8F7)
    (gr_text "2 mm" (at 49.75 33) (layer Dwgs.User) (tstamp 5516A8F7)
    (feature1 (pts (xy 46 35.5) (xy 46 30.300001)))
    (feature2 (pts (xy 44 35.5) (xy 44 30.300001)))
    (crossbar (pts (xy 44 33.000001) (xy 46 33.000001)))
    (arrow1a (pts (xy 46 33.000001) (xy 44.873496 33.586422)))
    (arrow1b (pts (xy 46 33.000001) (xy 44.873496 32.41358)))
    (arrow2a (pts (xy 44 33.000001) (xy 45.126504 33.586422)))
    (arrow2b (pts (xy 44 33.000001) (xy 45.126504 32.41358)))
  (dimension 17 (width 0.15) (layer Dwgs.User)
    (gr_text "17 mm" (at 51.35 45 270) (layer Dwgs.User)
    (feature1 (pts (xy 47 53.5) (xy 52.7 53.5)))
    (feature2 (pts (xy 47 36.5) (xy 52.7 36.5)))
    (crossbar (pts (xy 50 36.5) (xy 50 53.5)))
    (arrow1a (pts (xy 50 53.5) (xy 49.413579 52.373496)))
    (arrow1b (pts (xy 50 53.5) (xy 50.586421 52.373496)))
    (arrow2a (pts (xy 50 36.5) (xy 49.413579 37.626504)))
    (arrow2b (pts (xy 50 36.5) (xy 50.586421 37.626504)))
  (dimension 3.5 (width 0.15) (layer Dwgs.User)
    (gr_text "3.5 mm" (at 8.5 60) (layer Dwgs.User)
    (feature1 (pts (xy 3.5 57.5) (xy 3.5 62.7)))
    (feature2 (pts (xy 0 57.5) (xy 0 62.7)))
    (crossbar (pts (xy 0 60) (xy 3.5 60)))
    (arrow1a (pts (xy 3.5 60) (xy 2.373496 60.586421)))
    (arrow1b (pts (xy 3.5 60) (xy 2.373496 59.413579)))
    (arrow2a (pts (xy 0 60) (xy 1.126504 60.586421)))
    (arrow2b (pts (xy 0 60) (xy 1.126504 59.413579)))
  (dimension 3.5 (width 0.15) (layer Dwgs.User) (tstamp 55169E80)
    (gr_text "3.5 mm" (at 10.25 48.25 270) (layer Dwgs.User) (tstamp 55169E80)
    (feature1 (pts (xy 7 56.5) (xy 12.7 56.5)))
    (feature2 (pts (xy 7 53) (xy 12.7 53)))
    (crossbar (pts (xy 10 53) (xy 10 56.5)))
    (arrow1a (pts (xy 10 56.5) (xy 9.413579 55.373496)))
    (arrow1b (pts (xy 10 56.5) (xy 10.586421 55.373496)))
    (arrow2a (pts (xy 10 53) (xy 9.413579 54.126504)))
    (arrow2b (pts (xy 10 53) (xy 10.586421 54.126504)))
  (dimension 49 (width 0.15) (layer Dwgs.User)
    (gr_text "49 mm" (at 70.349999 28.5 270) (layer Dwgs.User)
    (feature1 (pts (xy 66 53) (xy 71.699999 53)))
    (feature2 (pts (xy 66 4) (xy 71.699999 4)))
    (crossbar (pts (xy 68.999999 4) (xy 68.999999 53)))
    (arrow1a (pts (xy 68.999999 53) (xy 68.413578 51.873496)))
    (arrow1b (pts (xy 68.999999 53) (xy 69.58642 51.873496)))
    (arrow2a (pts (xy 68.999999 4) (xy 68.413578 5.126504)))
    (arrow2b (pts (xy 68.999999 4) (xy 69.58642 5.126504)))
  (dimension 19.5 (width 0.15) (layer Dwgs.User) (tstamp 55169DA3)
    (gr_text "19.5 mm" (at -5.35 46.75 270) (layer Dwgs.User) (tstamp 55169DA3)
    (feature1 (pts (xy -1 56.5) (xy -6.7 56.5)))
    (feature2 (pts (xy -1 37) (xy -6.7 37)))
    (crossbar (pts (xy -4 37) (xy -4 56.5)))
    (arrow1a (pts (xy -4 56.5) (xy -4.586421 55.373496)))
    (arrow1b (pts (xy -4 56.5) (xy -3.413579 55.373496)))
    (arrow2a (pts (xy -4 37) (xy -4.586421 38.126504)))
    (arrow2b (pts (xy -4 37) (xy -3.413579 38.126504)))
    (gr_text "17 mm" (at 9.35 28.5 270) (layer Dwgs.User)
    (feature1 (pts (xy 6 37) (xy 10.7 37)))
    (feature2 (pts (xy 6 20) (xy 10.7 20)))
    (crossbar (pts (xy 8 20) (xy 8 37)))
    (arrow1a (pts (xy 8 37) (xy 7.413579 35.873496)))
    (arrow1b (pts (xy 8 37) (xy 8.586421 35.873496)))
    (arrow2a (pts (xy 8 20) (xy 7.413579 21.126504)))
    (arrow2b (pts (xy 8 20) (xy 8.586421 21.126504)))
  (dimension 5 (width 0.15) (layer Dwgs.User)
    (gr_text "5 mm" (at 8.75 18) (layer Dwgs.User)
    (feature1 (pts (xy 5 20) (xy 5 15.3)))
    (feature2 (pts (xy 0 20) (xy 0 15.3)))
    (crossbar (pts (xy 0 18) (xy 5 18)))
    (arrow1a (pts (xy 5 18) (xy 3.873496 18.586421)))
    (arrow1b (pts (xy 5 18) (xy 3.873496 17.413579)))
    (arrow2a (pts (xy 0 18) (xy 1.126504 18.586421)))
    (arrow2b (pts (xy 0 18) (xy 1.126504 17.413579)))
  (dimension 29 (width 0.15) (layer Dwgs.User)
    (gr_text "29 mm" (at 18 11.849999) (layer Dwgs.User)
    (feature1 (pts (xy 32.5 8) (xy 32.5 13.199999)))
    (feature2 (pts (xy 3.5 8) (xy 3.5 13.199999)))
    (crossbar (pts (xy 3.5 10.499999) (xy 32.5 10.499999)))
    (arrow1a (pts (xy 32.5 10.499999) (xy 31.373496 11.08642)))
    (arrow1b (pts (xy 32.5 10.499999) (xy 31.373496 9.913578)))
    (arrow2a (pts (xy 3.5 10.499999) (xy 4.626504 11.08642)))
    (arrow2b (pts (xy 3.5 10.499999) (xy 4.626504 9.913578)))
  (dimension 58 (width 0.15) (layer Dwgs.User)
    (gr_text "58 mm" (at 32.5 -4.85) (layer Dwgs.User)
    (feature1 (pts (xy 61.5 -1) (xy 61.5 -6.2)))
    (feature2 (pts (xy 3.5 -1) (xy 3.5 -6.2)))
    (crossbar (pts (xy 3.5 -3.5) (xy 61.5 -3.5)))
    (arrow1a (pts (xy 61.5 -3.5) (xy 60.373496 -2.913579)))
    (arrow1b (pts (xy 61.5 -3.5) (xy 60.373496 -4.086421)))
    (arrow2a (pts (xy 3.5 -3.5) (xy 4.626504 -2.913579)))
    (arrow2b (pts (xy 3.5 -3.5) (xy 4.626504 -4.086421)))
  (dimension 65 (width 0.15) (layer Dwgs.User)
    (gr_text "65 mm" (at 32.5 -9.35) (layer Dwgs.User)
    (feature1 (pts (xy 65 -1) (xy 65 -10.7)))
    (feature2 (pts (xy 0 -1) (xy 0 -10.7)))
    (crossbar (pts (xy 0 -8) (xy 65 -8)))
    (arrow1a (pts (xy 65 -8) (xy 63.873496 -7.413579)))
    (arrow1b (pts (xy 65 -8) (xy 63.873496 -8.586421)))
    (arrow2a (pts (xy 0 -8) (xy 1.126504 -7.413579)))
    (arrow2b (pts (xy 0 -8) (xy 1.126504 -8.586421)))
  (dimension 56.5 (width 0.15) (layer Dwgs.User)
    (gr_text "56.5 mm (SMT socket J1)" (at 79.35 28.25 270) (layer Dwgs.User)
    (feature1 (pts (xy 66 56.5) (xy 80.7 56.5)))
    (feature2 (pts (xy 66 0) (xy 80.7 0)))
    (crossbar (pts (xy 78 0) (xy 78 56.5)))
    (arrow1a (pts (xy 78 56.5) (xy 77.413579 55.373496)))
    (arrow1b (pts (xy 78 56.5) (xy 78.586421 55.373496)))
    (arrow2a (pts (xy 78 0) (xy 77.413579 1.126504)))
    (arrow2b (pts (xy 78 0) (xy 78.586421 1.126504)))
  (gr_arc (start 76.1 70.875) (end 75.1 70.875) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 5515814F))
  (gr_arc (start 79.1 68.875) (end 80.1 68.875) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 5515812E))
  (gr_arc (start 79.1 53.875) (end 79.1 52.875) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 5515810E))
  (gr_arc (start 76.1 51.875) (end 76.1 52.875) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 55158090))
  (gr_arc (start 137.1 86.375) (end 140.1 86.375) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 55157FFB))
  (gr_arc (start 78.1 86.375) (end 78.1 89.375) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 55157FCE))
  (gr_arc (start 78.1 35.875) (end 75.1 35.875) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 55157F8A))
  (gr_arc (start 137.1 35.875) (end 137.1 32.875) (angle 90) (layer Edge.Cuts) (width 0.1) (tstamp 55157F2C))
  (gr_line (start 75.1 70.875) (end 75.1 86.375) (layer Edge.Cuts) (width 0.1) (tstamp 5CB66449))
  (gr_line (start 75.1 35.875) (end 75.1 51.875) (layer Edge.Cuts) (width 0.1))
  (gr_line (start 76.1 69.875) (end 79.1 69.875) (layer Edge.Cuts) (width 0.1))
  (gr_line (start 76.1 52.875) (end 79.1 52.875) (layer Edge.Cuts) (width 0.1))
  (gr_line (start 80.1 53.875) (end 80.1 68.875) (layer Edge.Cuts) (width 0.1))
  (gr_line (start 78.1 89.375) (end 137.1 89.375) (angle 90) (layer Edge.Cuts) (width 0.1))
  (gr_line (start 140.1 35.875) (end 140.1 86.375) (angle 90) (layer Edge.Cuts) (width 0.1))
  (gr_line (start 78.1 32.875) (end 137.1 32.875) (angle 90) (layer Edge.Cuts) (width 0.1))
  (segment (start 83.425 38.225) (end 83.425 37.223) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 83.425 37.223) (end 83.549001 37.098999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 93.2 42.648) (end 93.2 43.35) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 92.458999 41.906999) (end 93.2 42.648) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 91.698999 37.098999) (end 92.458999 37.858999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 96.3742 42.295) (end 96.806 42.295) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 95.9174 42.7518) (end 96.3742 42.295) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 95.9174 43.1836) (end 95.9174 42.7518) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 95.751 43.35) (end 95.9174 43.1836) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 93.2 43.35) (end 95.751 43.35) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 103.745 38.225) (end 102.618999 37.098999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 92.458999 37.858999) (end 92.458999 38.1) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 92.458999 38.1) (end 92.458999 41.906999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 101.745481 34.558999) (end 89.941001 34.558999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 102.618999 37.098999) (end 102.618999 35.432517) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 102.618999 35.432517) (end 101.745481 34.558999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 89.918999 34.581001) (end 89.918999 36.918999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 89.941001 34.558999) (end 89.918999 34.581001) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 90 37) (end 90 37.098999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 89.918999 36.918999) (end 90 37) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 83.549001 37.098999) (end 90 37.098999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 90 37.098999) (end 91.698999 37.098999) (width 0.152) (layer F.Cu) (net 1))
  (segment (start 124.75 42.35) (end 124.8 42.4) (width 0.3) (layer F.Cu) (net 1))
  (segment (start 124.8 42.4) (end 127.2 42.4) (width 0.3) (layer F.Cu) (net 1))
  (segment (start 127.2 42.4) (end 129.6 42.4) (width 0.3) (layer F.Cu) (net 1))
  (segment (start 129.6 42.4) (end 132 42.4) (width 0.3) (layer F.Cu) (net 1))
  (segment (start 124.8 40.9) (end 124.8 42.4) (width 0.3) (layer F.Cu) (net 1))
  (segment (start 123.6 39.7) (end 124.8 40.9) (width 0.3) (layer F.Cu) (net 1))
  (segment (start 120.374999 38.974999) (end 120.374999 37.674999) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 121.1 39.7) (end 120.374999 38.974999) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 121.1 39.7) (end 123.6 39.7) (width 0.3) (layer F.Cu) (net 1))
  (segment (start 104.594999 37.375001) (end 103.745 38.225) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 105.134999 36.835001) (end 104.594999 37.375001) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 119.535001 36.835001) (end 105.134999 36.835001) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 120.374999 37.674999) (end 119.535001 36.835001) (width 0.2) (layer F.Cu) (net 1))
  (via (at 118.7 41.3) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 1))
  (segment (start 116.994 40.695) (end 118.095 40.695) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 118.095 40.695) (end 118.7 41.3) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 118.7 41.3) (end 118.275736 41.3) (width 0.2) (layer B.Cu) (net 1))
  (segment (start 118.275736 41.3) (end 117.975736 41) (width 0.2) (layer B.Cu) (net 1))
  (segment (start 117.975736 41) (end 109.4 41) (width 0.2) (layer B.Cu) (net 1))
  (via (at 107.7 41.9) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 1))
  (segment (start 109.4 41) (end 108.5 41.9) (width 0.2) (layer B.Cu) (net 1))
  (segment (start 108.5 41.9) (end 107.7 41.9) (width 0.2) (layer B.Cu) (net 1))
  (segment (start 107.7 40.85) (end 107.75 40.8) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 107.7 41.9) (end 107.7 40.85) (width 0.2) (layer F.Cu) (net 1))
  (segment (start 88.01 49.59) (end 90.2 47.4) (width 1) (layer F.Cu) (net 2))
  (via (at 90.2 40.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 2))
  (segment (start 89.354999 36.534999) (end 88.505 35.685) (width 0.3) (layer B.Cu) (net 2))
  (segment (start 89.844999 37.024999) (end 89.354999 36.534999) (width 0.3) (layer B.Cu) (net 2))
  (segment (start 89.844999 39.844999) (end 89.844999 37.024999) (width 0.3) (layer B.Cu) (net 2))
  (segment (start 90.2 40.2) (end 89.844999 39.844999) (width 0.3) (layer B.Cu) (net 2))
  (segment (start 89 45) (end 90.2 45) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 88.7 45.3) (end 89 45) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 88 45.3) (end 88.7 45.3) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 90.2 47.4) (end 90.2 45) (width 1) (layer F.Cu) (net 2))
  (segment (start 90.2 45) (end 90.2 40.2) (width 1) (layer F.Cu) (net 2))
  (segment (start 81.7 42.102541) (end 83.602541 40.2) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 81.7 42.65) (end 81.7 42.102541) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 89.775736 40.2) (end 90.2 40.2) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 83.602541 40.2) (end 89.775736 40.2) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 76.673999 48.870801) (end 81.303198 53.5) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 77.8 45.26) (end 76.673999 46.386001) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 76.673999 46.386001) (end 76.673999 48.870801) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 81.303198 53.5) (end 84.6 53.5) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 86 52.1) (end 86 49.59) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 84.6 53.5) (end 86 52.1) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 83.1 49.59) (end 86 49.59) (width 1) (layer F.Cu) (net 2))
  (segment (start 86 49.59) (end 88.01 49.59) (width 1) (layer F.Cu) (net 2))
  (segment (start 93.2 45.1) (end 93.2 45.05) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 94.205 46.105) (end 93.2 45.1) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 96.806 46.105) (end 94.205 46.105) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 92.498 45) (end 90.2 45) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 92.548 45.05) (end 92.498 45) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 93.2 45.05) (end 92.548 45.05) (width 0.152) (layer F.Cu) (net 2))
  (segment (start 93.585 38.225) (end 92.384999 37.024999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 92.274 37.098999) (end 92.2 37.024999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 98.665 35.685) (end 97.251001 37.098999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 92.384999 37.024999) (end 92.2 37.024999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 92.2 37.024999) (end 89.844999 37.024999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 104.871001 37.098999) (end 96.8 37.098999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 106.285 35.685) (end 104.871001 37.098999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 97.251001 37.098999) (end 96.8 37.098999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 96.8 37.098999) (end 92.274 37.098999) (width 0.152) (layer B.Cu) (net 2))
  (segment (start 111.406 40.695) (end 111.406 41.965) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 111.406 41.965) (end 111.406 43.235) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 111.406 43.235) (end 111.406 44.505) (width 0.2) (layer F.Cu) (net 2))
  (via (at 121.3 41.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 2))
  (segment (start 120.374999 40.050735) (end 120.374999 36.625001) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 121.3 41.4) (end 121.3 40.975736) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 121.3 40.975736) (end 120.374999 40.050735) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 119.925001 36.625001) (end 118.985 35.685) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 120.374999 36.625001) (end 119.925001 36.625001) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 107.134999 34.835001) (end 106.285 35.685) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 107.435001 34.534999) (end 107.134999 34.835001) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 118.985 35.685) (end 117.834999 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 112.6 36.92) (end 112.6 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 113.905 38.225) (end 112.6 36.92) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 117.834999 34.534999) (end 112.6 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 112.6 34.534999) (end 107.435001 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 122.914999 34.534999) (end 124.065 35.685) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 129.697001 34.534999) (end 122 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 130.295001 35.132999) (end 129.697001 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 130.295001 36.835001) (end 130.295001 35.132999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 131.685 38.225) (end 130.295001 36.835001) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 117.834999 34.534999) (end 122 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 122 34.534999) (end 122.914999 34.534999) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 112.3426 44.505) (end 111.406 44.505) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 115.605 44.505) (end 112.3426 44.505) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 116.20981 45.10981) (end 115.605 44.505) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 123.749999 44.850001) (end 123.7 44.800002) (width 0.2) (layer F.Cu) (net 2))
  (via (at 123.2 40.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 2))
  (segment (start 123.7 44.800002) (end 123.7 41.3) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 123.7 41.3) (end 123.2 40.8) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 121.9 40.8) (end 121.3 41.4) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 123.2 40.8) (end 121.9 40.8) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 136.150001 47.589999) (end 137 46.74) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 135.3 48.44) (end 136.150001 47.589999) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 135.3 49.9) (end 135.3 48.44) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 109.555 40.695) (end 109.45 40.8) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 111.406 40.695) (end 109.555 40.695) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 109.45 40.1) (end 109.85 39.7) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 109.45 40.8) (end 109.45 40.1) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 112.43 39.7) (end 113.905 38.225) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 109.85 39.7) (end 112.43 39.7) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 120.1 44) (end 121.3 42.8) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 120.1 44.05) (end 120.1 44) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 119.349998 43.999998) (end 118.811998 43.999998) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 118.811998 43.999998) (end 117.702186 45.10981) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 120.1 44.05) (end 119.4 44.05) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 119.4 44.05) (end 119.349998 43.999998) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 117.702186 45.10981) (end 116.20981 45.10981) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 121.3 42.8) (end 121.3 41.4) (width 0.2) (layer F.Cu) (net 2))
  (via (at 115.7 85.7) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 2))
  (segment (start 116.1 85.7) (end 115.7 85.7) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 117.4 87) (end 116.1 85.7) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 117.4 87.6) (end 117.4 87) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 135.1 49.9) (end 135.3 49.9) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 132.3343 83.4) (end 134.799991 80.934309) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 137.89999 63.83431) (end 137.89999 53.199992) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 134.799991 80.934309) (end 134.799991 66.934309) (width 0.2) (layer B.Cu) (net 2))
  (via (at 137.89999 52.775728) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 2))
  (segment (start 118 83.4) (end 132.3343 83.4) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 135.1 49.975738) (end 137.599991 52.475729) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 137.599991 52.475729) (end 137.89999 52.775728) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 134.799991 66.934309) (end 137.89999 63.83431) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 137.89999 53.199992) (end 137.89999 52.775728) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 115.7 85.7) (end 118 83.4) (width 0.2) (layer B.Cu) (net 2))
  (segment (start 135.1 49.9) (end 135.1 49.975738) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 128.799998 49.9) (end 132 49.9) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 123.7 44.800002) (end 128.799998 49.9) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 131.45 49.9) (end 132 49.9) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 132 49.9) (end 135.1 49.9) (width 0.2) (layer F.Cu) (net 2))
  (segment (start 120.5 54.75) (end 121.2 54.75) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 120.399999 54.850001) (end 120.5 54.75) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 120.399999 56.752269) (end 120.399999 54.850001) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 120.112258 57.04001) (end 120.399999 56.752269) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 119.65999 57.04001) (end 120.112258 57.04001) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 119.6 57.1) (end 119.65999 57.04001) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 113.9 67.1) (end 114 67.2) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 113.9 65.6) (end 113.9 67.1) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 119.4 67.2) (end 120 66.6) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 114 67.2) (end 119.4 67.2) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 120 66.6) (end 121.4 65.2) (width 0.3) (layer F.Cu) (net 3))
  (via (at 120.8 63.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 121.4 65.2) (end 121.4 63.8) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 121.4 63.8) (end 120.8 63.2) (width 0.3) (layer F.Cu) (net 3))
  (via (at 118 63.54999) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 118.1 61.6) (end 118.1 63.074262) (width 0.3) (layer F.Cu) (net 3))
  (via (at 123.4 55) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 121.45 55) (end 121.2 54.75) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 123.4 55) (end 121.45 55) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 103.745 42.295) (end 104.4 42.95) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 102.394 42.295) (end 103.745 42.295) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 120.950021 62.057101) (end 123.699999 59.307123) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 123.699999 59.307123) (end 123.699999 55.299999) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 120.950021 62.625715) (end 120.950021 62.057101) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 120.8 62.775736) (end 120.950021 62.625715) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 123.699999 55.299999) (end 123.4 55) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 120.8 63.2) (end 120.8 62.775736) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 120.8 63.2) (end 120.45001 63.54999) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 120.45001 63.54999) (end 118.048536 63.54999) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 118 63.125726) (end 118 63.54999) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 118.051464 63.074262) (end 118 63.125726) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 118.1 63.074262) (end 118.051464 63.074262) (width 0.3) (layer F.Cu) (net 3))
  (via (at 120.07972 40.604) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 122.5 42.4) (end 122.5 41.55) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 120.503984 40.604) (end 120.07972 40.604) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 121.554 40.604) (end 120.503984 40.604) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 122.5 41.55) (end 121.554 40.604) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 105.6 49.8) (end 105.6 49) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 105.6 49) (end 104.9 48.3) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 104.9 48.3) (end 104.9 47.7) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 104.9 47.7) (end 105.3 47.3) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 104.4 42.95) (end 104.4 43) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 104.4 43) (end 105.295993 43.895993) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 105.295993 43.895993) (end 105.295993 45.272604) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 105.295993 45.272604) (end 105.295993 45.696868) (width 0.3) (layer F.Cu) (net 3))
  (segment (start 106.760458 45.396869) (end 105.595992 45.396869) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 123.4 48.836411) (end 120.913612 46.350023) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 105.595992 45.396869) (end 105.295993 45.696868) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 123.4 55) (end 123.4 48.836411) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 110.086399 46.350011) (end 109.5864 46.850011) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 118.325777 46.350023) (end 118.325765 46.350011) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 108.2136 46.850011) (end 106.760458 45.396869) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 120.913612 46.350023) (end 118.325777 46.350023) (width 0.3) (layer B.Cu) (net 3))
  (via (at 105.295993 45.696868) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 118.325765 46.350011) (end 110.086399 46.350011) (width 0.3) (layer B.Cu) (net 3))
  (via (at 108.5 47.1) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 108.3 47.3) (end 108.5 47.1) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 105.3 47.3) (end 108.3 47.3) (width 0.2) (layer F.Cu) (net 3))
  (segment (start 108.5 47.1) (end 108.5 46.850011) (width 0.2) (layer B.Cu) (net 3))
  (segment (start 109.5864 46.850011) (end 108.5 46.850011) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 108.5 46.850011) (end 108.2136 46.850011) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 105.295993 41.404007) (end 105.295993 45.272604) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 105.295993 45.272604) (end 105.295993 45.696868) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 106.150011 40.549989) (end 105.295993 41.404007) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 119.601445 40.549989) (end 106.150011 40.549989) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 120.07972 40.604) (end 119.655456 40.604) (width 0.3) (layer B.Cu) (net 3))
  (segment (start 119.655456 40.604) (end 119.601445 40.549989) (width 0.3) (layer B.Cu) (net 3))
  (via (at 83.6 73.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 85.6 75.4) (end 83.6 73.4) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 83.1 62.3) (end 85.6 64.8) (width 2) (layer F.Cu) (net 4))
  (segment (start 83.1 57.21) (end 83.1 62.3) (width 2) (layer F.Cu) (net 4))
  (segment (start 80.15 80.45) (end 80.2 80.4) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 78 80.45) (end 80.15 80.45) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 80.2 81.25) (end 81.95 83) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 80.2 80.4) (end 80.2 81.25) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 81.95 83) (end 83.8 83) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 77.75 73.45) (end 77.2 73.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 79.4 71.8) (end 77.75 73.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 79.4 71.75) (end 79.4 71.8) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 76.399999 70.959999) (end 76.959998 70.4) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 76.399999 73.349999) (end 76.399999 70.959999) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 77.2 73.45) (end 76.5 73.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 76.5 73.45) (end 76.399999 73.349999) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 76.959998 70.4) (end 82.8 70.4) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 82.8 70.4) (end 84.15 71.75) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 84.9 73.45) (end 84.2 72.75) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 85.6 73.45) (end 84.9 73.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 84.2 72.75) (end 84.2 71.8) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 85.7 73.55) (end 85.6 73.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 87.925 73.55) (end 85.7 73.55) (width 0.2) (layer F.Cu) (net 4))
  (via (at 89.4 76.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 85.6 75.4) (end 88.4 75.4) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 88.4 75.4) (end 89.4 76.4) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 83.65 73.45) (end 83.6 73.4) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 85.6 73.45) (end 83.65 73.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 88.95 73.35) (end 89.8 73.35) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 89.85 73.35) (end 89.85 74.25) (width 0.2) (layer F.Cu) (net 4))
  (via (at 88.95 73.35) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 88.95 73.35) (end 88.95 71.4) (width 1.5) (layer B.Cu) (net 4))
  (segment (start 88.95 71.4) (end 85.6 67) (width 1.5) (layer B.Cu) (net 4))
  (segment (start 85.6 67) (end 84.4 67) (width 1.5) (layer B.Cu) (net 4))
  (segment (start 85.6 67) (end 87 67) (width 1.5) (layer B.Cu) (net 4))
  (segment (start 84.4 67) (end 84.4 67) (width 1.5) (layer B.Cu) (net 4) (tstamp 5CB668AB))
  (via (at 84.4 67) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 85.6 67) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 87 67) (end 87 67) (width 1.5) (layer B.Cu) (net 4) (tstamp 5CB668B1))
  (via (at 86.8 67) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 85 67) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4) (tstamp 5CB668B3))
  (via (at 86.2 67) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4) (tstamp 5CB668B9))
  (via (at 83.8 67) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4) (tstamp 5CB668BD))
  (via (at 87.4 67) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4) (tstamp 5CB668C2))
  (segment (start 89.8 73.35) (end 89.85 73.35) (width 0.2) (layer F.Cu) (net 4) (tstamp 5CB668DC))
  (via (at 89.8 73.35) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 89 74.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4) (tstamp 5CB6697B))
  (via (at 89.8 74.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4) (tstamp 5CB6697D))
  (via (at 89.4 77.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 90 76.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 90 77.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 88.8 77.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4) (tstamp 5CB6698D))
  (segment (start 138.050001 78.099999) (end 138.050001 74.207999) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 129.6 86) (end 130.15 86) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 130.15 86) (end 138.050001 78.099999) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 110.15 58.1) (end 110 58.25) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 111 58.1) (end 110.15 58.1) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 111 57.4) (end 111 58.1) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 111.3 57.1) (end 111 57.4) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 113.6 57.1) (end 111.3 57.1) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 110 58.25) (end 110 59.4) (width 0.2) (layer F.Cu) (net 4))
  (via (at 110 59.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 112.2 58.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 113.6 58.1) (end 112.9 58.1) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 112.9 58.1) (end 112.2 58.8) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 112.4 58.6) (end 112.2 58.8) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 113.6 58.6) (end 112.4 58.6) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 112.5 59.1) (end 112.2 58.8) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 113.6 59.1) (end 112.5 59.1) (width 0.2) (layer F.Cu) (net 4))
  (via (at 111.8 60.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 113.6 60.6) (end 112 60.6) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 112 60.6) (end 111.8 60.8) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 133.4 61) (end 135.6 61) (width 1.5) (layer F.Cu) (net 4))
  (segment (start 136.2 61.6) (end 136.2 65.8) (width 1.5) (layer F.Cu) (net 4))
  (segment (start 135.6 61) (end 136.2 61.6) (width 1.5) (layer F.Cu) (net 4))
  (segment (start 136.2 72.357998) (end 136.2 65.8) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 138.050001 74.207999) (end 136.2 72.357998) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 120.117968 57.6) (end 121.2 56.517968) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 121.2 56.517968) (end 121.2 56.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 119.6 57.6) (end 120.117968 57.6) (width 0.2) (layer F.Cu) (net 4))
  (via (at 122.6 56.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 121.2 56.45) (end 122.45 56.45) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 122.45 56.45) (end 122.6 56.6) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 137.95 65.8) (end 138.4 65.35) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 136.2 65.8) (end 137.95 65.8) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 138.4 65.35) (end 138.4 55.2) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 138.4 55.2) (end 135.6 52.4) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 135.6 52.4) (end 130.4 52.4) (width 0.5) (layer F.Cu) (net 4))
  (via (at 120.4 53) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 130.4 52.4) (end 130.2 52.6) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 102.945 46.105) (end 104.4 44.65) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 102.394 46.105) (end 102.945 46.105) (width 0.3) (layer F.Cu) (net 4))
  (via (at 109.4 54.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 104.60673 49.168194) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 119.930134 53) (end 119.902963 53.027171) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 120.4 53) (end 119.930134 53) (width 0.5) (layer F.Cu) (net 4))
  (via (at 119.902963 53.027171) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 125.6 54.2) (end 124.085415 52.685415) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 124.085415 52.685415) (end 121.287844 52.685415) (width 0.5) (layer F.Cu) (net 4))
  (via (at 120.987845 52.985414) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 120.973259 53) (end 120.987845 52.985414) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 120.4 53) (end 120.973259 53) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 121.287844 52.685415) (end 120.987845 52.985414) (width 0.5) (layer F.Cu) (net 4))
  (via (at 125.1 63.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 125.8 65.2) (end 125.8 63.9) (width 1) (layer F.Cu) (net 4))
  (segment (start 125.8 63.9) (end 125.1 63.2) (width 1) (layer F.Cu) (net 4))
  (segment (start 125.1 63.2) (end 124.6 63.2) (width 1) (layer B.Cu) (net 4))
  (via (at 124.6 63.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 124.6 63.2) (end 122.6 63.2) (width 1) (layer B.Cu) (net 4))
  (via (at 121.9 62.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 122.6 63.2) (end 121.9 62.5) (width 1) (layer B.Cu) (net 4))
  (via (at 122.3 62.9) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 121.9 62.5) (end 122.3 62.9) (width 1) (layer F.Cu) (net 4))
  (segment (start 121.585139 58.414861) (end 120.985139 58.414861) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 122.6 57.4) (end 121.585139 58.414861) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 122.6 56.6) (end 122.6 57.4) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 120.985139 58.414861) (end 120.8 58.6) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 121.9 62.5) (end 120.461586 61.061586) (width 1) (layer F.Cu) (net 4))
  (segment (start 120.461586 61.061586) (end 120.461586 60.919161) (width 1) (layer F.Cu) (net 4))
  (segment (start 120.461586 60.791586) (end 120.461586 60.919161) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 120.27 60.6) (end 120.461586 60.791586) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 119.6 60.6) (end 120.27 60.6) (width 0.2) (layer F.Cu) (net 4))
  (via (at 120.461586 60.919161) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 120 62) (end 118.263589 62) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 116.769123 63.653903) (end 116.635785 63.787241) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 116.935784 63.487242) (end 116.635785 63.787241) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 117.6 62.823026) (end 116.935784 63.487242) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 117.6 61.6) (end 117.6 62.823026) (width 0.2) (layer F.Cu) (net 4))
  (via (at 116.635785 63.787241) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 88.821271 76.427251) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 89.4 76.4) (end 89.699999 76.699999) (width 1) (layer B.Cu) (net 4))
  (segment (start 113.1 82.5) (end 113.1 67.1) (width 1) (layer B.Cu) (net 4))
  (segment (start 113.1 67.1) (end 113 67.2) (width 1) (layer B.Cu) (net 4))
  (via (at 109.5 67.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (via (at 110 67.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 109.5 67.2) (end 110 67.2) (width 1) (layer F.Cu) (net 4))
  (via (at 110.6 67.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 113 67.2) (end 110.6 67.2) (width 1) (layer B.Cu) (net 4))
  (segment (start 110.6 67.2) (end 109.5 67.2) (width 1) (layer B.Cu) (net 4))
  (segment (start 110 67.2) (end 110.6 67.2) (width 1) (layer F.Cu) (net 4))
  (segment (start 109.5 67.2) (end 108.8 67.2) (width 1) (layer F.Cu) (net 4))
  (segment (start 108.8 67.2) (end 108.3 66.7) (width 1) (layer F.Cu) (net 4))
  (segment (start 108.3 66.7) (end 108.3 63.1) (width 1) (layer F.Cu) (net 4))
  (via (at 110.6 61.2) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 108.3 63.1) (end 110.2 61.2) (width 1) (layer F.Cu) (net 4))
  (segment (start 110.2 61.2) (end 110.6 61.2) (width 1) (layer F.Cu) (net 4))
  (segment (start 111 60.8) (end 110.6 61.2) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 111.8 60.8) (end 111 60.8) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 108.85 67.25) (end 108.85 69.9) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 108.8 67.2) (end 108.85 67.25) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 127.85 63.2) (end 128.2 62.85) (width 1) (layer F.Cu) (net 4))
  (segment (start 125.1 63.2) (end 127.85 63.2) (width 1) (layer F.Cu) (net 4))
  (segment (start 104.60673 48.630026) (end 103.899978 47.923274) (width 0.3) (layer B.Cu) (net 4))
  (segment (start 104.60673 49.168194) (end 104.60673 48.630026) (width 0.3) (layer B.Cu) (net 4))
  (segment (start 104.4 44.65) (end 104.4 45.5) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 104.4 45.5) (end 103.599979 46.300021) (width 0.3) (layer F.Cu) (net 4))
  (via (at 103.599979 47.623275) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 103.599979 47.199011) (end 103.599979 47.623275) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 103.899978 47.923274) (end 103.599979 47.623275) (width 0.3) (layer B.Cu) (net 4))
  (segment (start 103.599979 46.300021) (end 103.599979 47.199011) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 116.635785 63.362977) (end 116.6 63.327192) (width 0.5) (layer B.Cu) (net 4))
  (segment (start 116.635785 63.787241) (end 116.635785 63.362977) (width 0.5) (layer B.Cu) (net 4))
  (segment (start 116.6 63.327192) (end 116.6 61.5) (width 0.5) (layer B.Cu) (net 4))
  (segment (start 100.5 87.5) (end 87.4 87.5) (width 1) (layer B.Cu) (net 4))
  (via (at 84.4 87.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 85 87.5) (end 84.4 87.5) (width 1) (layer B.Cu) (net 4) (tstamp 5CBB68F4))
  (via (at 85 87.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 85.6 87.5) (end 85 87.5) (width 1) (layer B.Cu) (net 4) (tstamp 5CBB6AAC))
  (via (at 85.6 87.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 86.2 87.5) (end 85.6 87.5) (width 1) (layer B.Cu) (net 4) (tstamp 5CBB6C64))
  (via (at 86.2 87.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 86.8 87.5) (end 86.2 87.5) (width 1) (layer B.Cu) (net 4) (tstamp 5CBB6E1C))
  (via (at 86.8 87.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 87.4 87.5) (end 86.8 87.5) (width 1) (layer B.Cu) (net 4) (tstamp 5CBB6FD4))
  (via (at 87.4 87.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 128.6 54.2) (end 130.4 52.4) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 125.6 54.2) (end 128.6 54.2) (width 0.5) (layer F.Cu) (net 4))
  (segment (start 100.5 87.5) (end 103.5 87.5) (width 1) (layer B.Cu) (net 4))
  (segment (start 103.5 87.5) (end 108.1 87.5) (width 1) (layer B.Cu) (net 4))
  (segment (start 108.1 87.5) (end 108.9 86.7) (width 1) (layer B.Cu) (net 4))
  (segment (start 108.9 86.7) (end 113.1 82.5) (width 1) (layer B.Cu) (net 4))
  (segment (start 107.4 52.4) (end 104.737996 52.4) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 104.737996 52.4) (end 104.049998 51.712002) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 104.306731 49.468193) (end 104.60673 49.168194) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 104.049998 49.724926) (end 104.306731 49.468193) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 104.049998 51.712002) (end 104.049998 49.724926) (width 0.3) (layer F.Cu) (net 4))
  (segment (start 109.4 54.4) (end 107.4 52.4) (width 0.3) (layer F.Cu) (net 4))
  (via (at 104.525728 77.225728) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 103.5 78.251456) (end 104.225729 77.525727) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 104.225729 77.525727) (end 104.525728 77.225728) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 103.5 79.9) (end 103.5 78.251456) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 103.5 80.9657) (end 103.399989 80.865689) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 104.225729 77.525727) (end 104.525728 77.225728) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 103.399989 78.351467) (end 104.225729 77.525727) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 103.5 87.5) (end 103.5 80.9657) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 103.399989 80.865689) (end 103.399989 78.351467) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 108.9 86.7) (end 108.90001 86.70001) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 108.90001 86.70001) (end 112.275736 86.70001) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 112.275736 86.70001) (end 112.7 86.70001) (width 0.2) (layer B.Cu) (net 4))
  (via (at 112.7 86.70001) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 112.7 87.6) (end 112.7 86.70001) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 116 86.848544) (end 115.875728 86.724272) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 115.851466 86.70001) (end 115.875728 86.724272) (width 0.2) (layer B.Cu) (net 4))
  (segment (start 116 87.6) (end 116 86.848544) (width 0.2) (layer F.Cu) (net 4))
  (segment (start 112.7 86.70001) (end 115.851466 86.70001) (width 0.2) (layer B.Cu) (net 4))
  (via (at 115.875728 86.724272) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 110.05 56.6) (end 110 56.55) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 115.6 55.147732) (end 115.052268 54.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 115.6 55.6) (end 115.6 55.147732) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 115.052268 54.6) (end 112.8 54.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 111.8 55.6) (end 111.8 56.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 112.8 54.6) (end 111.8 55.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 111.8 56.6) (end 110.05 56.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 113.6 56.6) (end 111.8 56.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 112.511996 57.6) (end 111.599998 58.511998) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 111.599998 58.688006) (end 110.288002 60.000002) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 113.6 57.6) (end 112.511996 57.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 109 57.6) (end 110 56.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 110 56.6) (end 110 56.55) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 109 59.288004) (end 109 57.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 109.711998 60.000002) (end 109 59.288004) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 111.599998 58.511998) (end 111.599998 58.688006) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 110.400002 60.000002) (end 110.2 60.000002) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 110.5 60.1) (end 110.400002 60.000002) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 110.288002 60.000002) (end 110.2 60.000002) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 110.2 60.000002) (end 109.711998 60.000002) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 112.43 60.1) (end 112.2 60.1) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 112.93 59.6) (end 112.43 60.1) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 113.6 59.6) (end 112.93 59.6) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 113.6 60.1) (end 112.2 60.1) (width 0.2) (layer F.Cu) (net 5))
  (segment (start 112.2 60.1) (end 110.5 60.1) (width 0.2) (layer F.Cu) (net 5))
  (via (at 127.97427 45.125727) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 6))
  (segment (start 129.6 44.05) (end 128.524273 45.125727) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 128.524273 45.125727) (end 127.97427 45.125727) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 129.6 44) (end 129.6 44.05) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 130.3 44) (end 130.9 44.6) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 129.6 44) (end 130.3 44) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 131.109999 48.600001) (end 133.499999 48.600001) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 130.9 44.6) (end 130.9 48.390002) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 130.9 48.390002) (end 131.109999 48.600001) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 133.499999 48.600001) (end 135.7 46.4) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 135.95 44.2) (end 137 44.2) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 135.7 44.45) (end 135.95 44.2) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 135.7 46.4) (end 135.7 44.45) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 115.735021 41.965) (end 115.6 42.100021) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 115.899999 42.40002) (end 115.6 42.100021) (width 0.2) (layer B.Cu) (net 6))
  (segment (start 127.97427 45.125727) (end 127.448543 44.6) (width 0.2) (layer B.Cu) (net 6))
  (segment (start 127.448543 44.6) (end 118.099979 44.6) (width 0.2) (layer B.Cu) (net 6))
  (via (at 115.6 42.100021) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 6))
  (segment (start 116.994 41.965) (end 115.735021 41.965) (width 0.2) (layer F.Cu) (net 6))
  (segment (start 118.099979 44.6) (end 115.899999 42.40002) (width 0.2) (layer B.Cu) (net 6))
  (segment (start 120.2 83.6) (end 120.05 83.45) (width 0.5) (layer F.Cu) (net 7))
  (segment (start 120.2 83.6) (end 120.2 82.55) (width 0.5) (layer F.Cu) (net 7))
  (segment (start 132.646891 55.753109) (end 133.4 55) (width 1.5) (layer F.Cu) (net 7))
  (segment (start 131.696889 56.703111) (end 132.646891 55.753109) (width 1.5) (layer F.Cu) (net 7))
  (segment (start 131.696889 62.896889) (end 131.696889 56.703111) (width 1.5) (layer F.Cu) (net 7))
  (segment (start 132.2 63.4) (end 131.696889 62.896889) (width 1.5) (layer F.Cu) (net 7))
  (segment (start 132.2 65.8) (end 132.2 63.4) (width 1.5) (layer F.Cu) (net 7))
  (segment (start 132.2 70.8) (end 132.2 65.8) (width 0.5) (layer F.Cu) (net 7))
  (segment (start 136.4 75) (end 132.2 70.8) (width 0.5) (layer F.Cu) (net 7))
  (segment (start 130.45 65.8) (end 129.8 65.15) (width 0.5) (layer F.Cu) (net 7))
  (segment (start 132.2 65.8) (end 130.45 65.8) (width 0.5) (layer F.Cu) (net 7))
  (via (at 129.8 65.15) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 7))
  (segment (start 108.9 45.315297) (end 109.184693 45.59999) (width 0.5) (layer F.Cu) (net 7))
  (via (at 109.184693 45.59999) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 7))
  (segment (start 108.9 44) (end 108.9 45.315297) (width 0.5) (layer F.Cu) (net 7))
  (segment (start 129.8 53.722167) (end 121.427834 45.350001) (width 0.5) (layer B.Cu) (net 7))
  (segment (start 118.739999 45.350001) (end 118.689989 45.299991) (width 0.5) (layer B.Cu) (net 7))
  (segment (start 121.427834 45.350001) (end 118.739999 45.350001) (width 0.5) (layer B.Cu) (net 7))
  (segment (start 109.484692 45.299991) (end 109.184693 45.59999) (width 0.5) (layer B.Cu) (net 7))
  (segment (start 118.689989 45.299991) (end 109.484692 45.299991) (width 0.5) (layer B.Cu) (net 7))
  (segment (start 129.8 65.15) (end 129.8 53.722167) (width 0.5) (layer B.Cu) (net 7))
  (segment (start 115.9 84.4) (end 113.6 84.4) (width 1) (layer F.Cu) (net 7))
  (segment (start 115.9 84.4) (end 115.9 82.9) (width 1) (layer F.Cu) (net 7))
  (segment (start 116.8 82) (end 120.75 82) (width 1) (layer F.Cu) (net 7))
  (segment (start 115.9 82.9) (end 116.8 82) (width 1) (layer F.Cu) (net 7))
  (segment (start 120.2 82.55) (end 120.75 82) (width 0.5) (layer F.Cu) (net 7))
  (segment (start 127.75 75) (end 120.75 82) (width 1) (layer F.Cu) (net 7))
  (segment (start 136.4 75) (end 127.75 75) (width 1) (layer F.Cu) (net 7))
  (segment (start 106.7 43.05) (end 106.7 44.95) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 100.4 50.75) (end 100.4 51.75) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 101.55 49.6) (end 100.4 50.75) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 103.05 49.6) (end 101.55 49.6) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 106 53.6) (end 103.6 53.6) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 103.65 49) (end 103.05 49.6) (width 0.5) (layer F.Cu) (net 8))
  (via (at 106.7 41.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 8))
  (segment (start 106.7 41.8) (end 106.7 43.05) (width 0.2) (layer F.Cu) (net 8))
  (segment (start 120.931386 60.1) (end 121.936089 61.104703) (width 0.2) (layer F.Cu) (net 8))
  (segment (start 121.936089 61.104703) (end 122.315234 61.104703) (width 0.2) (layer F.Cu) (net 8))
  (via (at 122.615233 61.404702) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 8))
  (segment (start 119.6 60.1) (end 120.931386 60.1) (width 0.2) (layer F.Cu) (net 8))
  (segment (start 122.315234 61.104703) (end 122.615233 61.404702) (width 0.2) (layer F.Cu) (net 8))
  (segment (start 118.512177 45.900012) (end 121.200012 45.900012) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 122.915232 61.104703) (end 122.615233 61.404702) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 118.512165 45.9) (end 118.512177 45.900012) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 109.9 45.9) (end 118.512165 45.9) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 121.200012 45.900012) (end 124.4 49.1) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 124.4 49.1) (end 124.4 59.619935) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 106.7 44.4) (end 108.7 46.4) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 106.7 41.8) (end 106.7 44.4) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 124.4 59.619935) (end 122.915232 61.104703) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 109.4 46.4) (end 109.9 45.9) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 108.7 46.4) (end 109.4 46.4) (width 0.2) (layer B.Cu) (net 8))
  (segment (start 106.7 44.95) (end 106.7 45.353537) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 104.872177 46.74999) (end 104.349989 47.272178) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 104.349989 48.300011) (end 103.65 49) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 105.303547 46.74999) (end 104.872177 46.74999) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 104.349989 47.272178) (end 104.349989 48.300011) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 106.7 45.353537) (end 105.303547 46.74999) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 103.5 53.6) (end 102.2 52.3) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 103.6 53.6) (end 103.5 53.6) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 102.2 52.3) (end 102.2 50.45) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 102.2 50.45) (end 103.449987 49.200013) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 103.449987 49.200013) (end 103.65 49) (width 0.5) (layer F.Cu) (net 8))
  (segment (start 101.78233 47.41767) (end 101.78233 47.48836) (width 0.2) (layer F.Cu) (net 9))
  (via (at 101.994417 47.84362) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 9))
  (segment (start 101.994417 47.700447) (end 101.994417 47.84362) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 101.9622 43.565) (end 100.957379 44.569821) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 100.957379 44.569821) (end 100.957379 46.663409) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 100.957379 46.663409) (end 101.78233 47.48836) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 101.78233 47.48836) (end 101.994417 47.700447) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 102.394 43.565) (end 101.9622 43.565) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 101.8 47.4) (end 101.78233 47.41767) (width 0.2) (layer F.Cu) (net 9))
  (via (at 106.548559 48.400015) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 9))
  (segment (start 106.799988 46.099988) (end 107.1 46.4) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 103.113794 46.299979) (end 105.975556 46.299979) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 105.975556 46.299979) (end 106.175547 46.099988) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 107.1 46.4) (end 107.1 47.848574) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 106.848558 48.100016) (end 106.548559 48.400015) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 107.1 47.848574) (end 106.848558 48.100016) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 101.994417 47.84362) (end 101.994417 47.419356) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 106.175547 46.099988) (end 106.799988 46.099988) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 101.994417 47.419356) (end 103.113794 46.299979) (width 0.2) (layer B.Cu) (net 9))
  (segment (start 106.972823 48.400015) (end 106.548559 48.400015) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 119.400015 48.400015) (end 106.972823 48.400015) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 117.6 55.6) (end 117.6 53.9343) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 117.6 53.9343) (end 119.2343 52.3) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 119.2343 52.3) (end 120.5 52.3) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 120.5 52.3) (end 120.7 52.1) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 120.7 52.1) (end 120.7 49.7) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 120.7 49.7) (end 119.400015 48.400015) (width 0.2) (layer F.Cu) (net 9))
  (segment (start 93.837483 36.811001) (end 94.8 37.773518) (width 0.152) (layer F.Cu) (net 10))
  (segment (start 91.045 35.685) (end 92.171001 36.811001) (width 0.152) (layer F.Cu) (net 10))
  (segment (start 92.171001 36.811001) (end 93.837483 36.811001) (width 0.152) (layer F.Cu) (net 10))
  (segment (start 94.8 38.566482) (end 98.6 42.366482) (width 0.152) (layer F.Cu) (net 10))
  (segment (start 94.8 37.773518) (end 94.8 38.566482) (width 0.152) (layer F.Cu) (net 10))
  (segment (start 97.2378 44.835) (end 96.806 44.835) (width 0.152) (layer F.Cu) (net 10))
  (segment (start 98.6 43.4728) (end 97.2378 44.835) (width 0.152) (layer F.Cu) (net 10))
  (segment (start 98.6 42.366482) (end 98.6 43.4728) (width 0.152) (layer F.Cu) (net 10))
  (via (at 95.2 44.7) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 11))
  (segment (start 95.2392 44.7) (end 95.2 44.7) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 96.806 43.565) (end 96.3742 43.565) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 96.3742 43.565) (end 95.2392 44.7) (width 0.152) (layer F.Cu) (net 11))
  (via (at 97.2 39.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 11))
  (segment (start 95.2 44.7) (end 95.2 41.8) (width 0.152) (layer B.Cu) (net 11))
  (segment (start 95.2 41.8) (end 97.2 39.8) (width 0.152) (layer B.Cu) (net 11))
  (segment (start 94.434999 36.534999) (end 93.585 35.685) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 94.998999 37.098999) (end 94.434999 36.534999) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 96.665481 37.098999) (end 94.998999 37.098999) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 97.251001 37.684519) (end 96.665481 37.098999) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 97.251001 39.324735) (end 97.251001 37.684519) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 97.2 39.375736) (end 97.251001 39.324735) (width 0.152) (layer F.Cu) (net 11))
  (segment (start 97.2 39.8) (end 97.2 39.375736) (width 0.152) (layer F.Cu) (net 11))
  (via (at 99.6 54.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 12))
  (segment (start 100.4 56.65) (end 100.4 55.4) (width 0.2) (layer F.Cu) (net 12))
  (segment (start 100.4 55.4) (end 99.6 54.6) (width 0.2) (layer F.Cu) (net 12))
  (via (at 121.526973 59.014862) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 12))
  (segment (start 121.441835 59.1) (end 121.526973 59.014862) (width 0.2) (layer F.Cu) (net 12))
  (segment (start 119.6 59.1) (end 121.441835 59.1) (width 0.2) (layer F.Cu) (net 12))
  (segment (start 118.139365 46.800022) (end 118.139377 46.800034) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 99.6 54.6) (end 99.6 53.246296) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 110.772799 46.800022) (end 118.139365 46.800022) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 122.800022 53.107114) (end 122.600012 53.307124) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 118.139377 46.800034) (end 120.727212 46.800034) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 99.6 53.246296) (end 100.446318 52.399978) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 123.200001 57.466279) (end 121.651418 59.014862) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 122.600012 53.307124) (end 122.600012 55.71201) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 123.200001 56.311999) (end 123.200001 57.466279) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 121.651418 59.014862) (end 121.526973 59.014862) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 122.600012 55.71201) (end 123.200001 56.311999) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 122.800022 48.872844) (end 122.800022 53.107114) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 120.727212 46.800034) (end 122.800022 48.872844) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 105.172843 52.399978) (end 110.772799 46.800022) (width 0.2) (layer B.Cu) (net 12))
  (segment (start 100.446318 52.399978) (end 105.172843 52.399978) (width 0.2) (layer B.Cu) (net 12))
  (via (at 115.2 69.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 13))
  (segment (start 110.75 69.9) (end 115.1 69.9) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 115.1 69.9) (end 115.2 69.8) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 123.50001 57.69999) (end 127.70001 57.69999) (width 0.3) (layer F.Cu) (net 13))
  (segment (start 122.6 58.6) (end 123.50001 57.69999) (width 0.3) (layer F.Cu) (net 13))
  (segment (start 127.70001 57.69999) (end 131.8 53.6) (width 0.3) (layer F.Cu) (net 13))
  (segment (start 131.8 53.6) (end 135 53.6) (width 0.3) (layer F.Cu) (net 13))
  (segment (start 135 53.6) (end 137 55.6) (width 0.3) (layer F.Cu) (net 13))
  (via (at 137 59.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 13))
  (segment (start 137 55.6) (end 137 59.6) (width 0.3) (layer F.Cu) (net 13))
  (segment (start 122.6 58.6) (end 122.35985 58.84015) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 122.35985 58.860296) (end 122.35985 59.28456) (width 0.2) (layer F.Cu) (net 13))
  (via (at 122.35985 59.28456) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 13))
  (segment (start 122.35985 58.84015) (end 122.35985 58.860296) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 121.053831 58.6) (end 120.27 58.6) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 120.27 58.6) (end 119.6 58.6) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 122.41486 58.41486) (end 121.238971 58.41486) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 121.238971 58.41486) (end 121.053831 58.6) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 122.6 58.6) (end 122.41486 58.41486) (width 0.2) (layer F.Cu) (net 13))
  (segment (start 137 59.6) (end 126.8 69.8) (width 0.3) (layer B.Cu) (net 13))
  (segment (start 126.8 69.8) (end 115.624264 69.8) (width 0.3) (layer B.Cu) (net 13))
  (segment (start 115.624264 69.8) (end 115.2 69.8) (width 0.3) (layer B.Cu) (net 13))
  (segment (start 81.7 44.5875) (end 80.4 43.2875) (width 1) (layer F.Cu) (net 14))
  (segment (start 83.32 44.5875) (end 81.7 44.5875) (width 1) (layer F.Cu) (net 14))
  (segment (start 80.4 42.214998) (end 81.8 40.814998) (width 1) (layer F.Cu) (net 14))
  (segment (start 80.4 43.2875) (end 80.4 42.214998) (width 1) (layer F.Cu) (net 14))
  (via (at 81.8 40.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 14))
  (segment (start 81.8 40.814998) (end 81.8 40.8) (width 0.3) (layer F.Cu) (net 14))
  (segment (start 85.965 35.685) (end 83.425 35.685) (width 1) (layer F.Cu) (net 14))
  (segment (start 82.08 44.5875) (end 82.08 43.8125) (width 0.2) (layer F.Cu) (net 14))
  (segment (start 83.32 43.8125) (end 83.32 44.5875) (width 0.2) (layer F.Cu) (net 14))
  (segment (start 83.360002 40.8) (end 84.7 39.460002) (width 0.5) (layer B.Cu) (net 14))
  (segment (start 81.8 40.8) (end 83.360002 40.8) (width 0.5) (layer B.Cu) (net 14))
  (segment (start 84.7 36.96) (end 83.425 35.685) (width 0.3) (layer B.Cu) (net 14))
  (segment (start 84.7 39.460002) (end 84.7 36.96) (width 0.3) (layer B.Cu) (net 14))
  (segment (start 84.7 36.95) (end 85.965 35.685) (width 0.3) (layer B.Cu) (net 14))
  (segment (start 84.7 36.96) (end 84.7 36.95) (width 0.3) (layer B.Cu) (net 14))
  (segment (start 116.83361 43.83981) (end 116.31168 43.83981) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 116.994 44.505) (end 116.994 44.0002) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 116.994 44.0002) (end 116.83361 43.83981) (width 0.2) (layer F.Cu) (net 15))
  (via (at 128 43.9) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 15))
  (segment (start 127.2 44) (end 127.9 44) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 127.9 44) (end 128 43.9) (width 0.2) (layer F.Cu) (net 15))
  (via (at 114.5 42.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 15))
  (segment (start 114.82813 42.5) (end 114.9 42.42813) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 114.5 42.5) (end 114.82813 42.5) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 116.31168 43.83981) (end 114.9 42.42813) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 114.5 40.224243) (end 114.5 39.799979) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 116.072102 39.799979) (end 114.924264 39.799979) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 123 42.6) (end 118.3343 42.6) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 114.5 42.075736) (end 114.5 42.5) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 125.4 40.2) (end 123 42.6) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 128 40.7) (end 127.5 40.2) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 127.5 40.2) (end 125.4 40.2) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 115.075725 41.500011) (end 114.5 42.075736) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 114.924264 39.799979) (end 114.5 39.799979) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 128 43.9) (end 128 40.7) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 116.445 39.427081) (end 116.072102 39.799979) (width 0.2) (layer B.Cu) (net 15))
  (via (at 114.5 39.799979) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 15))
  (segment (start 118.3343 42.6) (end 117.234311 41.500011) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 117.234311 41.500011) (end 115.075725 41.500011) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 114.5 42.02813) (end 114.5 40.224243) (width 0.2) (layer F.Cu) (net 15))
  (segment (start 116.445 38.225) (end 116.445 39.427081) (width 0.2) (layer B.Cu) (net 15))
  (segment (start 114.9 42.42813) (end 114.5 42.02813) (width 0.2) (layer F.Cu) (net 15))
  (via (at 115.2 39.1) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 16))
  (segment (start 115.2 40.18813) (end 115.2 39.1) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 117.4258 43.235) (end 118.03061 42.63019) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 116.994 43.235) (end 117.4258 43.235) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 118.03061 42.63019) (end 118.03061 41.71448) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 118.03061 41.71448) (end 117.61594 41.29981) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 117.61594 41.29981) (end 116.31168 41.29981) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 116.31168 41.29981) (end 115.2 40.18813) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 115.2 36.93) (end 116.445 35.685) (width 0.2) (layer B.Cu) (net 16))
  (segment (start 115.2 39.1) (end 115.2 36.93) (width 0.2) (layer B.Cu) (net 16))
  (segment (start 117.595001 34.534999) (end 124.734999 34.534999) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 116.445 35.685) (end 117.595001 34.534999) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 125.454999 35.254999) (end 125.454999 40.554999) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 124.734999 34.534999) (end 125.454999 35.254999) (width 0.2) (layer F.Cu) (net 16))
  (via (at 126 41.1) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 16))
  (segment (start 125.454999 40.554999) (end 126 41.1) (width 0.2) (layer F.Cu) (net 16))
  (via (at 125.8 44) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 16))
  (segment (start 126 41.1) (end 126 43.8) (width 0.2) (layer B.Cu) (net 16))
  (segment (start 126 43.8) (end 125.8 44) (width 0.2) (layer B.Cu) (net 16))
  (segment (start 125.8 44) (end 124.8 44) (width 0.2) (layer F.Cu) (net 16))
  (segment (start 132 46.9) (end 132.1 47) (width 0.2) (layer F.Cu) (net 17))
  (segment (start 132 44) (end 132 46.9) (width 0.2) (layer F.Cu) (net 17))
  (via (at 120.8 87.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 17))
  (segment (start 119 87.6) (end 120.8 87.6) (width 0.2) (layer F.Cu) (net 17))
  (segment (start 120.8 87.6) (end 128.8 87.6) (width 0.2) (layer B.Cu) (net 17))
  (segment (start 138.300012 78.099988) (end 138.300012 64.599988) (width 0.2) (layer B.Cu) (net 17))
  (segment (start 128.8 87.6) (end 138.300012 78.099988) (width 0.2) (layer B.Cu) (net 17))
  (segment (start 138.300012 64.599988) (end 138.4 64.5) (width 0.2) (layer B.Cu) (net 17))
  (segment (start 138.4 64.5) (end 138.4 53.2) (width 0.2) (layer B.Cu) (net 17))
  (segment (start 138.4 53.2) (end 138.6 53) (width 0.2) (layer B.Cu) (net 17))
  (segment (start 138.6 53) (end 138.6 52.4) (width 0.2) (layer B.Cu) (net 17))
  (via (at 132.1 47) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 17))
  (segment (start 138.6 52.4) (end 133.2 47) (width 0.2) (layer B.Cu) (net 17))
  (segment (start 133.2 47) (end 132.1 47) (width 0.2) (layer B.Cu) (net 17))
  (via (at 109.5 88.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 18))
  (segment (start 109.5 87.6) (end 109.5 88.5) (width 0.2) (layer F.Cu) (net 18))
  (via (at 123.6 45.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 18))
  (segment (start 122.5 44.75) (end 122.5 44) (width 0.2) (layer F.Cu) (net 18))
  (segment (start 122.5 45.124264) (end 122.5 44.75) (width 0.2) (layer F.Cu) (net 18))
  (segment (start 123.175736 45.8) (end 122.5 45.124264) (width 0.2) (layer F.Cu) (net 18))
  (segment (start 123.6 45.8) (end 123.175736 45.8) (width 0.2) (layer F.Cu) (net 18))
  (segment (start 128.4657 88.5) (end 139.000009 77.965691) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 139.000009 77.965691) (end 139.000009 64.134309) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 138.9 64.0343) (end 138.9 53.2657) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 124.024264 45.8) (end 123.6 45.8) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 132.8657 45.8) (end 124.024264 45.8) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 139.000009 64.134309) (end 138.9 64.0343) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 139.000011 53.165689) (end 139.000011 51.934311) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 138.9 53.2657) (end 139.000011 53.165689) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 139.000011 51.934311) (end 132.8657 45.8) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 109.5 88.5) (end 128.4657 88.5) (width 0.2) (layer B.Cu) (net 18))
  (segment (start 105.6 51.35) (end 105.6 51.4) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 105.6 51.4) (end 104.7 51.4) (width 0.2) (layer F.Cu) (net 19))
  (via (at 104.7 51.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 19))
  (segment (start 104.7 51.4) (end 99.9 51.4) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 99.9 51.4) (end 98.9 52.4) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 98.9 52.4) (end 98.9 55.8) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 98.9 55.8) (end 103 59.9) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 103 59.9) (end 105.3 59.9) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 105.3 59.9) (end 106.6 61.2) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 106.6 61.2) (end 106.6 76) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 106.6 76) (end 104.7 77.9) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 104.7 77.9) (end 103.8 78.8) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 103.8 78.8) (end 103.8 80.7) (width 0.2) (layer B.Cu) (net 19))
  (via (at 107.9 82.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 19))
  (segment (start 103.8 80.7) (end 106 80.7) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 106 80.7) (end 107.9 82.6) (width 0.2) (layer B.Cu) (net 19))
  (segment (start 107.9 82.6) (end 107.9 83.024264) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 107.9 83.024264) (end 109.5 84.624264) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 109.5 84.624264) (end 109.5 85.7) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 109.5 85.7) (end 109.9 86.1) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 109.9 86.1) (end 113.7 86.1) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 114.4 86.8) (end 114.4 87.6) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 113.7 86.1) (end 114.4 86.8) (width 0.2) (layer F.Cu) (net 19))
  (segment (start 118.1 55.6) (end 118.1 53.999998) (width 0.2) (layer F.Cu) (net 20))
  (via (at 121.6 53.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 20))
  (segment (start 121.300001 53.899999) (end 121.6 53.6) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 118.199999 53.899999) (end 121.300001 53.899999) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 118.1 53.999998) (end 118.199999 53.899999) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 102.100001 47.100001) (end 102.360165 47.100001) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 101.35739 45.43981) (end 101.35739 46.35739) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 102.394 44.835) (end 101.9622 44.835) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 101.9622 44.835) (end 101.35739 45.43981) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 102.360165 47.100001) (end 102.660164 47.4) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 101.35739 46.35739) (end 102.100001 47.100001) (width 0.2) (layer F.Cu) (net 20))
  (via (at 100.7 53.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 20))
  (segment (start 99.659999 53.300001) (end 98.8 52.440002) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 100.7 53.6) (end 100.400001 53.300001) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 100.400001 53.300001) (end 99.659999 53.300001) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 98.8 51.059998) (end 101.259998 48.6) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 98.8 52.440002) (end 98.8 51.059998) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 101.259998 48.6) (end 102.5 48.6) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 102.660164 48.439836) (end 102.660164 47.4) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 102.5 48.6) (end 102.660164 48.439836) (width 0.2) (layer F.Cu) (net 20))
  (segment (start 122 52.775736) (end 122 49.3) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 111.104177 47.600044) (end 105.104221 53.6) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 117.807987 47.600044) (end 111.104177 47.600044) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 121.6 53.6) (end 121.6 53.175736) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 101.124264 53.6) (end 100.7 53.6) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 117.807999 47.600056) (end 117.807987 47.600044) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 121.6 53.175736) (end 122 52.775736) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 122 49.3) (end 120.300056 47.600056) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 120.300056 47.600056) (end 117.807999 47.600056) (width 0.2) (layer B.Cu) (net 20))
  (segment (start 105.104221 53.6) (end 101.124264 53.6) (width 0.2) (layer B.Cu) (net 20))
  (via (at 108 85.8) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 21))
  (segment (start 107.9 87.6) (end 107.9 85.9) (width 0.2) (layer F.Cu) (net 21))
  (segment (start 107.9 85.9) (end 108 85.8) (width 0.2) (layer F.Cu) (net 21))
  (segment (start 108 85.8) (end 108.6 85.2) (width 0.2) (layer B.Cu) (net 21))
  (via (at 108.6 73.5) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 21))
  (segment (start 108.6 85.2) (end 108.6 73.5) (width 0.2) (layer B.Cu) (net 21))
  (segment (start 108.6 73.3) (end 109.8 72.1) (width 0.2) (layer F.Cu) (net 21))
  (segment (start 108.6 73.5) (end 108.6 73.3) (width 0.2) (layer F.Cu) (net 21))
  (segment (start 86.249998 41.099998) (end 83.268244 41.099998) (width 0.2) (layer F.Cu) (net 22))
  (segment (start 82.2 42.168242) (end 82.2 42.65) (width 0.2) (layer F.Cu) (net 22))
  (segment (start 88 43.6) (end 88 42.85) (width 0.2) (layer F.Cu) (net 22))
  (segment (start 88 42.85) (end 86.249998 41.099998) (width 0.2) (layer F.Cu) (net 22))
  (segment (start 83.268244 41.099998) (end 82.2 42.168242) (width 0.2) (layer F.Cu) (net 22))
  (segment (start 81.7 45.75) (end 81.7 47.1) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 81.7 47.1) (end 81.8 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 83.7 47.1) (end 83.7 45.75) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 83.6 47.2) (end 83.7 47.1) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 83.2 45.75) (end 83.2 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 83.2 47.2) (end 83.6 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 82.7 47.1) (end 82.6 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 82.7 45.75) (end 82.7 47.1) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 82.6 47.2) (end 83.2 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 82.2 46.375) (end 82.2 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 82.2 45.75) (end 82.2 46.375) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 81.8 47.2) (end 82.2 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 82.2 47.2) (end 82.6 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 81.8 47.2) (end 80.4 48.6) (width 1) (layer F.Cu) (net 23))
  (segment (start 80.4 48.6) (end 80.4 51.4) (width 1) (layer F.Cu) (net 23))
  (segment (start 81.13 52.13) (end 83.1 52.13) (width 1) (layer F.Cu) (net 23))
  (segment (start 80.4 51.4) (end 81.13 52.13) (width 1) (layer F.Cu) (net 23))
  (segment (start 83.6 47.2) (end 85.1 47.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 85.8 46.5) (end 85.8 45.2) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 85.1 47.2) (end 85.8 46.5) (width 0.3) (layer F.Cu) (net 23))
  (segment (start 82.7 42.65) (end 82.7 42.2) (width 0.152) (layer F.Cu) (net 24))
  (segment (start 83.20301 41.696988) (end 84.796988 41.696988) (width 0.152) (layer F.Cu) (net 24))
  (segment (start 82.7 42.2) (end 83.20301 41.696988) (width 0.152) (layer F.Cu) (net 24))
  (segment (start 84.8 41.7) (end 85.5 41.7) (width 0.152) (layer F.Cu) (net 24))
  (via (at 85.5 41.7) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 24))
  (segment (start 84.796988 41.696988) (end 84.8 41.7) (width 0.152) (layer F.Cu) (net 24))
  (segment (start 83.9 41.7) (end 77.8 47.8) (width 0.152) (layer B.Cu) (net 24))
  (segment (start 85.5 41.7) (end 83.9 41.7) (width 0.152) (layer B.Cu) (net 24))
  (segment (start 93.3 57.21) (end 92.99 57.21) (width 2) (layer F.Cu) (net 26))
  (segment (start 92.99 57.21) (end 91.2 59) (width 2) (layer F.Cu) (net 26))
  (segment (start 91.2 59) (end 91.2 64.8) (width 2) (layer F.Cu) (net 26))
  (segment (start 91.2 64.8) (end 93.8 64.8) (width 2) (layer F.Cu) (net 26))
  (segment (start 93.8 64.8) (end 94.8 63.8) (width 2) (layer F.Cu) (net 26))
  (segment (start 94.8 63.8) (end 94.8 61.8) (width 2) (layer F.Cu) (net 26))
  (segment (start 95.4 61.2) (end 101.4 61.2) (width 2) (layer F.Cu) (net 26))
  (segment (start 94.8 61.8) (end 95.4 61.2) (width 2) (layer F.Cu) (net 26))
  (segment (start 89.15 71.65) (end 88.1 70.6) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 89.15 72.325) (end 89.15 71.65) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 88.1 70.6) (end 85.8 70.6) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 85.6 70.8) (end 85.6 71.75) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 85.8 70.6) (end 85.6 70.8) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 89.65 72.325) (end 89.65 71.05) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 89.2 70.6) (end 88.1 70.6) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 89.65 71.05) (end 89.2 70.6) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 91.2 66.6) (end 91.2 64.8) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 84.8 71.75) (end 84.6 71.55) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 85.6 71.75) (end 84.8 71.75) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 84.6 71.55) (end 84.6 70) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 84.6 70) (end 86.6 68) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 86.6 68) (end 89.8 68) (width 0.3) (layer F.Cu) (net 26))
  (segment (start 89.8 68) (end 91.2 66.6) (width 0.3) (layer F.Cu) (net 26))
  (via (at 78.8 75) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 27))
  (segment (start 78 75.8) (end 78 78.75) (width 0.2) (layer F.Cu) (net 27))
  (segment (start 78.8 75) (end 78 75.8) (width 0.2) (layer F.Cu) (net 27))
  (via (at 87.191109 71.408891) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 27))
  (segment (start 82.391109 71.408891) (end 86.766845 71.408891) (width 0.2) (layer B.Cu) (net 27))
  (segment (start 86.766845 71.408891) (end 87.191109 71.408891) (width 0.2) (layer B.Cu) (net 27))
  (segment (start 87.491108 71.70889) (end 87.191109 71.408891) (width 0.2) (layer F.Cu) (net 27))
  (segment (start 78.8 75) (end 82.391109 71.408891) (width 0.2) (layer B.Cu) (net 27))
  (segment (start 88.65 72.325) (end 88.107218 72.325) (width 0.2) (layer F.Cu) (net 27))
  (segment (start 88.107218 72.325) (end 87.491108 71.70889) (width 0.2) (layer F.Cu) (net 27))
  (via (at 85 78.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 28))
  (segment (start 83.8 79) (end 84.4 79) (width 0.3) (layer F.Cu) (net 28))
  (segment (start 84.4 79) (end 85 78.4) (width 0.3) (layer F.Cu) (net 28))
  (segment (start 106.4 85.6) (end 106.4 85.2) (width 1.5) (layer F.Cu) (net 28))
  (segment (start 104.6 87.4) (end 106.4 85.6) (width 1.5) (layer F.Cu) (net 28))
  (segment (start 91.4 85) (end 91.4 87.4) (width 1.5) (layer F.Cu) (net 28))
  (segment (start 103.6 87) (end 103.2 87.4) (width 0.2) (layer F.Cu) (net 28))
  (segment (start 103.6 86.2) (end 103.6 87) (width 0.2) (layer F.Cu) (net 28))
  (segment (start 91.4 87.4) (end 103.2 87.4) (width 1.5) (layer F.Cu) (net 28))
  (segment (start 103.2 87.4) (end 104.6 87.4) (width 1.5) (layer F.Cu) (net 28))
  (segment (start 103.5 83.2) (end 103.5 81.5) (width 0.2) (layer F.Cu) (net 25))
  (segment (start 103.5 81.5) (end 103.5 81.45) (width 0.2) (layer F.Cu) (net 25))
  (segment (start 111.1 86.9) (end 111.050009 86.850009) (width 0.3) (layer F.Cu) (net 25))
  (segment (start 107.180002 83.2) (end 104.3 83.2) (width 0.3) (layer F.Cu) (net 25))
  (segment (start 104.3 83.2) (end 103.5 83.2) (width 0.3) (layer F.Cu) (net 25))
  (segment (start 109.049989 85.069987) (end 107.180002 83.2) (width 0.3) (layer F.Cu) (net 25))
  (segment (start 109.049989 85.886399) (end 109.049989 85.069987) (width 0.3) (layer F.Cu) (net 25))
  (segment (start 111.050009 86.850009) (end 110.013599 86.850009) (width 0.3) (layer F.Cu) (net 25))
  (segment (start 111.1 87.6) (end 111.1 86.9) (width 0.3) (layer F.Cu) (net 25))
  (segment (start 110.013599 86.850009) (end 109.049989 85.886399) (width 0.3) (layer F.Cu) (net 25))
  (via (at 91.292886 79.707114) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 28))
  (segment (start 85 78.4) (end 89.985772 78.4) (width 0.3) (layer B.Cu) (net 28))
  (segment (start 90.992887 79.407115) (end 91.292886 79.707114) (width 0.3) (layer B.Cu) (net 28))
  (segment (start 89.985772 78.4) (end 90.992887 79.407115) (width 0.3) (layer B.Cu) (net 28))
  (segment (start 103.5 86.1) (end 103.6 86.2) (width 0.2) (layer F.Cu) (net 28))
  (segment (start 103.5 84.8) (end 103.5 86.1) (width 0.2) (layer F.Cu) (net 28))
  (segment (start 123.5 83.45) (end 123.75 83.2) (width 0.5) (layer F.Cu) (net 29))
  (segment (start 123.5 85.65) (end 123.5 83.45) (width 0.5) (layer F.Cu) (net 29))
  (segment (start 123.75 82.2) (end 124.15 81.8) (width 0.5) (layer F.Cu) (net 29))
  (segment (start 123.75 83.2) (end 123.75 82.2) (width 0.5) (layer F.Cu) (net 29))
  (segment (start 127.75 83.2) (end 129.6 83.2) (width 0.5) (layer F.Cu) (net 29))
  (segment (start 126.35 81.8) (end 127.75 83.2) (width 0.5) (layer F.Cu) (net 29))
  (segment (start 124.15 81.8) (end 126.35 81.8) (width 0.5) (layer F.Cu) (net 29))
  (segment (start 125.45 86.35) (end 125.7 86.6) (width 0.5) (layer F.Cu) (net 30))
  (segment (start 125.45 83.2) (end 125.45 86.35) (width 0.5) (layer F.Cu) (net 30))
  (via (at 119.8 87) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 30))
  (via (at 125.45 85) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 30))
  (segment (start 119.8 87) (end 121.8 85) (width 0.5) (layer B.Cu) (net 30))
  (segment (start 121.8 85) (end 125.45 85) (width 0.5) (layer B.Cu) (net 30))
  (segment (start 118.1 83.45) (end 118.1 85.35) (width 1) (layer F.Cu) (net 30))
  (segment (start 119.8 87) (end 119.1 86.3) (width 0.3) (layer F.Cu) (net 30))
  (segment (start 118.3 85.35) (end 118.1 85.35) (width 0.3) (layer F.Cu) (net 30))
  (segment (start 119.1 86.15) (end 118.3 85.35) (width 0.3) (layer F.Cu) (net 30))
  (segment (start 119.1 86.3) (end 119.1 86.15) (width 0.3) (layer F.Cu) (net 30))
  (segment (start 108.4 75) (end 111 75) (width 1.5) (layer F.Cu) (net 32))
  (segment (start 106.4 81.2) (end 106.4 77) (width 1.5) (layer F.Cu) (net 32))
  (segment (start 106.4 77) (end 108.4 75) (width 1.5) (layer F.Cu) (net 32))
  (segment (start 110.8 75.2) (end 111 75) (width 0.5) (layer F.Cu) (net 32))
  (segment (start 110.8 84.4) (end 110.8 75.2) (width 0.5) (layer F.Cu) (net 32))
  (segment (start 82.2 81.4) (end 82.2 79) (width 0.3) (layer F.Cu) (net 33))
  (segment (start 87.25 74.55) (end 87.925 74.55) (width 0.3) (layer F.Cu) (net 33))
  (segment (start 87.049988 74.750012) (end 87.25 74.55) (width 0.3) (layer F.Cu) (net 33))
  (segment (start 82.25 79) (end 86.499988 74.750012) (width 0.3) (layer F.Cu) (net 33))
  (segment (start 82.2 79) (end 82.25 79) (width 0.3) (layer F.Cu) (net 33))
  (segment (start 86.499988 74.750012) (end 87.049988 74.750012) (width 0.3) (layer F.Cu) (net 33))
  (via (at 87.8 76) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 34))
  (segment (start 87.375736 76) (end 86.375736 77) (width 0.2) (layer B.Cu) (net 34))
  (segment (start 87.8 76) (end 87.375736 76) (width 0.2) (layer B.Cu) (net 34))
  (via (at 81 77) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 34))
  (segment (start 86.375736 77) (end 81 77) (width 0.2) (layer B.Cu) (net 34))
  (segment (start 81 77) (end 80.4 77) (width 0.2) (layer F.Cu) (net 34))
  (segment (start 80.2 77.2) (end 80.2 78.8) (width 0.2) (layer F.Cu) (net 34))
  (segment (start 80.4 77) (end 80.2 77.2) (width 0.2) (layer F.Cu) (net 34))
  (segment (start 88.65 75.275) (end 88.65 75.75) (width 0.2) (layer F.Cu) (net 34))
  (segment (start 88.4 76) (end 87.8 76) (width 0.2) (layer F.Cu) (net 34))
  (segment (start 88.65 75.75) (end 88.4 76) (width 0.2) (layer F.Cu) (net 34))
  (segment (start 122.55 87.55) (end 120.2 85.2) (width 0.5) (layer F.Cu) (net 35))
  (segment (start 123.5 87.55) (end 122.55 87.55) (width 0.5) (layer F.Cu) (net 35))
  (segment (start 81.6 74.15) (end 81.6 73.4) (width 0.2) (layer F.Cu) (net 36))
  (segment (start 81.750001 74.300001) (end 81.6 74.15) (width 0.2) (layer F.Cu) (net 36))
  (segment (start 86.340001 74.300001) (end 81.750001 74.300001) (width 0.2) (layer F.Cu) (net 36))
  (segment (start 86.590002 74.05) (end 86.340001 74.300001) (width 0.2) (layer F.Cu) (net 36))
  (segment (start 87.925 74.05) (end 86.590002 74.05) (width 0.2) (layer F.Cu) (net 36))
  (segment (start 79.45 73.4) (end 79.4 73.45) (width 0.2) (layer F.Cu) (net 36))
  (segment (start 81.6 73.4) (end 79.45 73.4) (width 0.2) (layer F.Cu) (net 36))
  (segment (start 81.6 71.05) (end 81.6 71.8) (width 0.2) (layer F.Cu) (net 37))
  (segment (start 81.449999 70.899999) (end 81.6 71.05) (width 0.2) (layer F.Cu) (net 37))
  (segment (start 78.000001 70.899999) (end 81.449999 70.899999) (width 0.2) (layer F.Cu) (net 37))
  (segment (start 77.2 71.7) (end 78.000001 70.899999) (width 0.2) (layer F.Cu) (net 37))
  (segment (start 77.2 71.75) (end 77.2 71.7) (width 0.2) (layer F.Cu) (net 37))
  (segment (start 112.549999 67.949999) (end 112.6 68) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 112.6 68) (end 121.248546 68) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 121.248546 68) (end 123.6 65.648546) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 115.299999 63.499999) (end 115.299999 63.499999) (width 0.3) (layer F.Cu) (net 38) (tstamp 5CB892CC))
  (via (at 115.299999 63.499999) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 38))
  (segment (start 112.499999 65.25) (end 112.549999 65.2) (width 0.2) (layer F.Cu) (net 38))
  (segment (start 110 65.25) (end 112.499999 65.25) (width 0.2) (layer F.Cu) (net 38))
  (segment (start 112.549999 65.2) (end 112.549999 67.949999) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 125.6 59.8) (end 124.7 59.8) (width 0.3) (layer F.Cu) (net 38))
  (via (at 124.649196 60.219283) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 38))
  (segment (start 124.649196 59.850804) (end 124.649196 60.219283) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 124.7 59.8) (end 124.649196 59.850804) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 117.1 61.6) (end 117.1 62.3958) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 115.802968 62.42001) (end 113.17999 62.42001) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 115.724263 63.499999) (end 115.299999 63.499999) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 116.1 61.6) (end 116.1 62.122978) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 112.549999 63.050001) (end 112.549999 65.2) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 117.1 62.3958) (end 115.995801 63.499999) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 115.995801 63.499999) (end 115.724263 63.499999) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 113.17999 62.42001) (end 112.549999 63.050001) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 116.1 62.122978) (end 115.802968 62.42001) (width 0.3) (layer F.Cu) (net 38))
  (segment (start 115.299999 63.499999) (end 115.299999 64.13641) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 115.299999 64.13641) (end 116.1136 64.950011) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 125.663458 64.436542) (end 126.2 63.9) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 126.2 61.770087) (end 124.949195 60.519282) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 124.949195 60.519282) (end 124.649196 60.219283) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 126.2 63.9) (end 126.2 61.770087) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 117.599869 64.436542) (end 125.663458 64.436542) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 117.0864 64.950011) (end 117.599869 64.436542) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 116.1136 64.950011) (end 117.0864 64.950011) (width 0.3) (layer B.Cu) (net 38))
  (segment (start 127.25 62.1) (end 128.2 61.15) (width 0.5) (layer F.Cu) (net 38))
  (segment (start 124.1 62.1) (end 127.25 62.1) (width 0.5) (layer F.Cu) (net 38))
  (segment (start 123.6 65.648546) (end 123.6 62.6) (width 0.5) (layer F.Cu) (net 38))
  (segment (start 123.6 62.6) (end 124.1 62.1) (width 0.5) (layer F.Cu) (net 38))
  (segment (start 126.9 59.8) (end 125.6 59.8) (width 0.5) (layer F.Cu) (net 38))
  (segment (start 128.2 61.15) (end 128.2 61.1) (width 0.5) (layer F.Cu) (net 38))
  (segment (start 128.2 61.1) (end 126.9 59.8) (width 0.5) (layer F.Cu) (net 38))
  (via (at 113.8 63.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 39))
  (segment (start 113.8 63.4) (end 111.6 63.4) (width 0.2) (layer B.Cu) (net 39))
  (via (at 111.4 63.6) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 39))
  (segment (start 111.6 63.4) (end 111.4 63.6) (width 0.2) (layer B.Cu) (net 39))
  (segment (start 111.35 63.55) (end 111.4 63.6) (width 0.2) (layer F.Cu) (net 39))
  (segment (start 110 63.55) (end 111.35 63.55) (width 0.2) (layer F.Cu) (net 39))
  (segment (start 114.329979 62.870021) (end 114.099999 63.100001) (width 0.2) (layer F.Cu) (net 39))
  (segment (start 115.989368 62.870021) (end 114.329979 62.870021) (width 0.2) (layer F.Cu) (net 39))
  (segment (start 116.6 62.259389) (end 115.989368 62.870021) (width 0.2) (layer F.Cu) (net 39))
  (segment (start 116.6 61.6) (end 116.6 62.259389) (width 0.2) (layer F.Cu) (net 39))
  (segment (start 114.099999 63.100001) (end 113.8 63.4) (width 0.2) (layer F.Cu) (net 39))
  (via (at 106.4 58.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 40))
  (segment (start 106.4 56.8) (end 106 56.4) (width 0.2) (layer F.Cu) (net 40))
  (segment (start 106.4 58.4) (end 106.4 56.8) (width 0.2) (layer F.Cu) (net 40))
  (via (at 121.494129 59.8142) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 40))
  (segment (start 121.279929 59.6) (end 121.494129 59.8142) (width 0.2) (layer F.Cu) (net 40))
  (segment (start 119.6 59.6) (end 121.279929 59.6) (width 0.2) (layer F.Cu) (net 40))
  (segment (start 106.4 58.4) (end 110.6 62.6) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 121.494129 59.8142) (end 121.494129 60.805871) (width 0.3) (layer B.Cu) (net 40))
  (segment (start 121.494129 60.805871) (end 120.45001 61.84999) (width 0.3) (layer B.Cu) (net 40))
  (segment (start 120.1864 62.45001) (end 120.14999 62.45001) (width 0.3) (layer B.Cu) (net 40))
  (segment (start 120.45001 62.1864) (end 120.1864 62.45001) (width 0.3) (layer B.Cu) (net 40))
  (segment (start 120.45001 61.84999) (end 120.45001 62.1864) (width 0.3) (layer B.Cu) (net 40))
  (segment (start 120.14999 62.45001) (end 119.8 62.8) (width 0.3) (layer B.Cu) (net 40))
  (segment (start 117.399999 63.500001) (end 117.369124 63.530876) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 117.399999 63.261989) (end 117.399999 63.500001) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 117.711999 62.949989) (end 117.399999 63.261989) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 117.950011 62.949989) (end 117.711999 62.949989) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 119.8 62.8) (end 118.1 62.8) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 118.1 62.8) (end 117.950011 62.949989) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 117.369124 63.830876) (end 117.205715 63.994285) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 117.369124 63.530876) (end 117.369124 63.830876) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 117.205715 63.994285) (end 117.205715 64.194285) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 117.205715 64.194285) (end 116.9 64.5) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 116.9 64.5) (end 116.5 64.5) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 115.9 63.9) (end 115.9 62.6) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 116.5 64.5) (end 115.9 63.9) (width 0.2) (layer B.Cu) (net 40))
  (segment (start 110.6 62.6) (end 115.9 62.6) (width 0.2) (layer B.Cu) (net 40))
  (via (at 100.8 54.4) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 41))
  (segment (start 102.5 56.4) (end 103.6 56.4) (width 0.2) (layer F.Cu) (net 41))
  (segment (start 102.375736 56.4) (end 102.5 56.4) (width 0.2) (layer F.Cu) (net 41))
  (segment (start 100.8 54.824264) (end 102.375736 56.4) (width 0.2) (layer F.Cu) (net 41))
  (segment (start 100.8 54.4) (end 100.8 54.824264) (width 0.2) (layer F.Cu) (net 41))
  (via (at 121.375735 57.775722) (size 0.6) (drill 0.4) (layers F.Cu B.Cu) (net 41))
  (segment (start 121.312409 57.775722) (end 121.375735 57.775722) (width 0.2) (layer F.Cu) (net 41))
  (segment (start 119.6 58.1) (end 120.988131 58.1) (width 0.2) (layer F.Cu) (net 41))
  (segment (start 120.988131 58.1) (end 121.312409 57.775722) (width 0.2) (layer F.Cu) (net 41))
  (segment (start 117.973676 47.200033) (end 117.973688 47.200045) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 120.561523 47.200045) (end 122.400011 49.038533) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 100.375736 54.4) (end 100.099998 54.124262) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 117.973688 47.200045) (end 120.561523 47.200045) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 122.200001 53.141435) (end 122.200001 56.111997) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 122.400011 49.038533) (end 122.400011 52.941425) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 105.338532 52.799989) (end 110.938488 47.200033) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 110.938488 47.200033) (end 117.973676 47.200033) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 122.200001 56.111997) (end 121.375735 56.936263) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 121.375735 56.936263) (end 121.375735 57.351458) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 121.375735 57.351458) (end 121.375735 57.775722) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 122.400011 52.941425) (end 122.200001 53.141435) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 100.099998 53.311998) (end 100.612007 52.799989) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 100.612007 52.799989) (end 105.338532 52.799989) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 100.099998 54.124262) (end 100.099998 53.311998) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 100.8 54.4) (end 100.375736 54.4) (width 0.2) (layer B.Cu) (net 41))
  (segment (start 118.6 64.7) (end 117.7 65.6) (width 0.3) (layer F.Cu) (net 42))
  (segment (start 119 65.6) (end 117.7 65.6) (width 0.3) (layer F.Cu) (net 42))
  (segment (start 119.3 65.3) (end 119 65.6) (width 0.3) (layer F.Cu) (net 42))
  (segment (start 119.3 63.07) (end 119.3 65.3) (width 0.3) (layer F.Cu) (net 42))
  (segment (start 118.6 62.37) (end 119.3 63.07) (width 0.3) (layer F.Cu) (net 42))
  (segment (start 118.6 61.6) (end 118.6 62.37) (width 0.3) (layer F.Cu) (net 42))
  (segment (start 116.6 55.6) (end 116.6 53.4) (width 0.2) (layer F.Cu) (net 43))
  (segment (start 118.05 51.95) (end 118.05 50.2) (width 0.2) (layer F.Cu) (net 43))
  (segment (start 116.6 53.4) (end 118.05 51.95) (width 0.2) (layer F.Cu) (net 43))
  (segment (start 116.1 54.93) (end 114.37 53.2) (width 0.2) (layer F.Cu) (net 44))
  (segment (start 116.1 55.6) (end 116.1 54.93) (width 0.2) (layer F.Cu) (net 44))
  (segment (start 114.37 53.2) (end 111.2 53.2) (width 0.2) (layer F.Cu) (net 44))
  (segment (start 109.55 51.55) (end 109.55 50.2) (width 0.2) (layer F.Cu) (net 44))
  (segment (start 111.2 53.2) (end 109.55 51.55) (width 0.2) (layer F.Cu) (net 44))
  (segment (start 85.8 43.55) (end 85.8 43.6) (width 0.152) (layer F.Cu) (net 45))
  (segment (start 83.348819 42.048999) (end 84.298999 42.048999) (width 0.152) (layer F.Cu) (net 45))
  (segment (start 84.298999 42.048999) (end 85.8 43.55) (width 0.152) (layer F.Cu) (net 45))
  (segment (start 83.2 42.197818) (end 83.348819 42.048999) (width 0.152) (layer F.Cu) (net 45))
  (segment (start 83.2 42.65) (end 83.2 42.197818) (width 0.152) (layer F.Cu) (net 45))
  (zone (net 31) (net_name /SW) (layer F.Cu) (tstamp 5CBAD6FD) (hatch edge 0.508)
    (connect_pads yes (clearance 0.2))
    (min_thickness 0.254)
    (fill yes (arc_segments 16) (thermal_gap 0.2) (thermal_bridge_width 0.508))
    (polygon
      (pts
        (xy 102.6 78.4) (xy 99 78.4) (xy 95 73.7) (xy 90.4 73.7) (xy 90.4 72.8)
        (xy 90 72.8) (xy 90 71.4) (xy 90 69) (xy 106.6 69) (xy 106.6 72.8)
    (filled_polygon
      (pts
        (xy 106.473 72.759301) (xy 102.534644 78.273) (xy 99.058683 78.273) (xy 95.096716 73.617689) (xy 95.057854 73.586943)
        (xy 95 73.573) (xy 90.633406 73.573) (xy 90.633406 72.9) (xy 90.608027 72.772411) (xy 90.535754 72.664246)
        (xy 90.427589 72.591973) (xy 90.3 72.566594) (xy 90.127 72.566594) (xy 90.127 71.09697) (xy 90.136343 71.049999)
        (xy 90.127 71.003028) (xy 90.127 69.127) (xy 106.473 69.127)
  (zone (net 28) (net_name /BOOST_30V) (layer F.Cu) (tstamp 5CBAD6FA) (hatch edge 0.508)
    (polygon
      (pts
        (xy 102.4 79.8) (xy 102.4 85.8) (xy 89.6 85.8) (xy 89.6 78.2) (xy 97.4 78.2)
        (xy 99.4 79.8)
    (filled_polygon
      (pts
        (xy 99.320664 79.89917) (xy 99.364654 79.921982) (xy 99.4 79.927) (xy 102.273 79.927) (xy 102.273 85.673)
        (xy 89.727 85.673) (xy 89.727 78.327) (xy 97.355451 78.327)
  (zone (net 4) (net_name GND) (layer F.Cu) (tstamp 5CBAD6F7) (hatch edge 0.508)
    (polygon
      (pts
        (xy 91.4 73.9) (xy 91.4 77.8) (xy 89 77.8) (xy 89 79.6) (xy 87.6 84.2)
        (xy 87.6 88) (xy 84 88) (xy 84 84) (xy 83 82) (xy 83 80.6)
        (xy 84.4 80.6) (xy 88.8 76) (xy 89 73.9)
    (filled_polygon
      (pts
        (xy 91.273 77.673) (xy 89 77.673) (xy 88.951399 77.682667) (xy 88.910197 77.710197) (xy 88.882667 77.751399)
        (xy 88.873 77.8) (xy 88.873 79.5811) (xy 87.478502 84.163022) (xy 87.473 84.2) (xy 87.473 87.873)
        (xy 84.127 87.873) (xy 84.127 84) (xy 84.113592 83.943204) (xy 83.127 81.97002) (xy 83.127 80.727)
        (xy 84.4 80.727) (xy 84.448601 80.717333) (xy 84.491776 80.687785) (xy 88.634221 76.357047) (xy 88.70785 76.30785)
        (xy 88.731675 76.272193) (xy 88.922193 76.081675) (xy 88.95785 76.05785) (xy 89.052225 75.916607) (xy 89.077 75.792054)
        (xy 89.085365 75.750001) (xy 89.078774 75.716869) (xy 89.099323 75.686116) (xy 89.127 75.546975) (xy 89.127 75.003026)
        (xy 89.099323 74.863884) (xy 89.043704 74.780645) (xy 89.11548 74.027) (xy 91.273 74.027)
  (zone (net 4) (net_name GND) (layer F.Cu) (tstamp 5CBAD6F4) (hatch edge 0.508)
    (polygon
      (pts
        (xy 87.4 64) (xy 87.4 65.8) (xy 87.8 66.8) (xy 87.8 67.6) (xy 83.4 67.6)
        (xy 83.4 64)
    (filled_polygon
      (pts
        (xy 87.273 65.8) (xy 87.282083 65.847167) (xy 87.673 66.82446) (xy 87.673 67.473) (xy 83.527 67.473)
        (xy 83.527 64.127) (xy 87.273 64.127)
  (zone (net 4) (net_name GND) (layer B.Cu) (tstamp 5CBAD6F1) (hatch edge 0.508)
    (polygon
      (pts
        (xy 90.2 72.9) (xy 90.2 77.8) (xy 88.4 77.8) (xy 88.4 72.8)
    (filled_polygon
      (pts
        (xy 90.073 73.02014) (xy 90.073 77.673) (xy 88.527 77.673) (xy 88.527 72.934251)
  (zone (net 4) (net_name GND) (layer B.Cu) (tstamp 5CBAD6EE) (hatch edge 0.508)
    (polygon
      (pts
        (xy 121.2 49.2) (xy 121.2 48.2) (xy 106.6 48.2) (xy 103.8 50.8) (xy 103.8 57.8)
        (xy 108.6 57.8) (xy 108.6 62.2) (xy 121.2 62.2)
    (filled_polygon
      (pts
        (xy 120.77299 51.275568) (xy 120.77299 51.423417) (xy 120.868445 51.653866) (xy 121.044823 51.830244) (xy 121.073 51.841915)
        (xy 121.073 53.240288) (xy 121.068455 53.244833) (xy 120.973 53.475282) (xy 120.973 53.724718) (xy 121.068455 53.955167)
        (xy 121.073 53.959712) (xy 121.073 56.624995) (xy 121.067885 56.628413) (xy 120.97351 56.769657) (xy 120.948735 56.894209)
        (xy 120.94037 56.936263) (xy 120.948735 56.978316) (xy 120.948735 57.31601) (xy 120.84419 57.420555) (xy 120.748735 57.651004)
        (xy 120.748735 57.90044) (xy 120.84419 58.130889) (xy 121.020568 58.307267) (xy 121.073 58.328985) (xy 121.073 58.582123)
        (xy 120.995428 58.659695) (xy 120.899973 58.890144) (xy 120.899973 59.13958) (xy 120.995428 59.370029) (xy 121.023508 59.398109)
        (xy 120.962584 59.459033) (xy 120.867129 59.689482) (xy 120.867129 59.938918) (xy 120.962584 60.169367) (xy 121.017129 60.223912)
        (xy 121.01713 60.60829) (xy 120.145939 61.479482) (xy 120.106113 61.506093) (xy 120.000687 61.663875) (xy 119.97301 61.803016)
        (xy 119.97301 61.803019) (xy 119.963667 61.84999) (xy 119.97301 61.896961) (xy 119.97301 61.988821) (xy 119.955647 62.006184)
        (xy 119.879445 62.057101) (xy 119.85565 62.073) (xy 110.676869 62.073) (xy 108.727 60.123132) (xy 108.727 57.8)
        (xy 108.717333 57.751399) (xy 108.689803 57.710197) (xy 108.648601 57.682667) (xy 108.6 57.673) (xy 104.511512 57.673)
        (xy 113.357491 48.827023) (xy 114.377326 48.827023) (xy 114.419379 48.835388) (xy 114.461432 48.827023) (xy 114.461433 48.827023)
        (xy 114.585986 48.802248) (xy 114.698587 48.727011) (xy 118.224434 48.727011)
  (zone (net 31) (net_name /SW) (layer F.Cu) (tstamp 0) (hatch edge 0.508)
    (polygon
      (pts
        (xy 91.9 73.7) (xy 91.9 77.8) (xy 98.6 77.8) (xy 96 73.4) (xy 92.2 73.4)
    (filled_polygon
      (pts
        (xy 98.377438 77.673) (xy 92.027 77.673) (xy 92.027 73.752606) (xy 92.252606 73.527) (xy 95.927529 73.527)
