Open On-Chip Debugger 0.10.0+dev-00021-g524e8c8 (2019-04-12-08:33) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html srst_only separate srst_nogate srst_open_drain connect_assert_srst Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 8000 kHz adapter_nsrst_delay: 100 Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : clock speed 8000 kHz Info : STLINK v2.1 JTAG v29 API v2 M18 VID 0x0483 PID 0x374B Info : using stlink api v2 Info : Target voltage: 3.257369 Info : Unable to match requested speed 8000 kHz, using 4000 kHz Info : Stlink adapter speed set to 4000 kHz Info : STM32F303RETx.cpu: hardware has 6 breakpoints, 4 watchpoints Info : Listening on port 3333 for gdb connections Info : accepting 'gdb' connection on tcp/3333 target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x08000290 msp: 0x20010000 Info : Unable to match requested speed 8000 kHz, using 4000 kHz Info : Stlink adapter speed set to 4000 kHz Info : Unable to match requested speed 8000 kHz, using 4000 kHz adapter speed: 4000 kHz Info : device id = 0x10036446 Info : flash size = 512kbytes target halted due to breakpoint, current mode: Thread xPSR: 0x61000000 pc: 0x2000003a msp: 0x20010000
