Ubuntu 18.04.2 LTS bananapir2 ttyS2 bananapir2 login: root Password: Last login: Fri Jun 7 11:54:17 UTC 2019 on ttyS2 ____ ____ _ ____ ____ | __ ) __ _ _ __ __ _ _ __ __ _ | _ \(_) | _ \|___ \ | _ \ / _` | '_ \ / _` | '_ \ / _` | | |_) | | | |_) | __) | | |_) | (_| | | | | (_| | | | | (_| | | __/| | | _ < / __/ |____/ \__,_|_| |_|\__,_|_| |_|\__,_| |_| |_| |_| \_\_____| Welcome to ARMBIAN 5.75 stable Ubuntu 18.04.2 LTS 5.2.0-rc2 System load: 0.70 0.19 0.06 Up time: 0 min Memory usage: 4 % of 2010MB IP: CPU temp: 24�°C Usage of /: 3% of 32G storage/: 33% of 485M [ General system configuration (beta): armbian-config ] root@bananapir2:~# lsscsi [0:0:0:0] disk ATA INTEL SSDSC2KW24 G200 /dev/sda [1:0:0:0] disk ATA HGST HTS541010B7 1A01 /dev/sdb Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x0003bb90 Device Boot Start End Sectors Size Id Type /dev/sda1 * 2048 1044479 1042432 509M 83 Linux /dev/sda2 1044480 9431039 8386560 4G 82 Linux swap / Solaris /dev/sda3 9431040 42989567 33558528 16G 83 Linux /dev/sda4 42989568 468860927 425871360 203.1G f W95 Ext'd (LBA) /dev/sda5 42991616 76550143 33558528 16G 83 Linux /dev/sda6 76552192 143652863 67100672 32G 83 Linux /dev/sda7 143654912 468860927 325206016 155.1G 83 Linux Disk /dev/sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: dos Disk identifier: 0xb4993fa5 Device Boot Start End Sectors Size Id Type /dev/sdb1 2048 2099199 2097152 1G 83 Linux /dev/sdb2 2099200 10487807 8388608 4G 82 Linux swap / Solaris /dev/sdb3 * 10487808 77596671 67108864 32G 83 Linux /dev/sdb4 77596672 1953525167 1875928496 894.5G f W95 Ext'd (LBA) /dev/sdb5 77598720 94375935 16777216 8G 83 Linux /dev/sdb6 94377984 1953525167 1859147184 886.5G 83 Linux
