[EMI] DRAMC calibration passed [MEM] complex R/W mem test pass 0:dram_rank_size:80000000 [Dram_Buffer] dram size:-2147483648 [Dram_Buffer] structure size: 1725560 [Dram_Buffer] MAX_TEE_DRAM_SIZE: 0 Load u-boot from eMMC... [PLFM] Init Boot Device: OK(0) [PART] blksz: 512B [PART] [0x0000000000000000-0x000000000003FFFF] "PRELOADER" (512 blocks) [PART] [0x0000000000000000-0x000000000003FFFF] "MBR" (512 blocks) [PART] [0x0000000000040000-0x00000000000BFFFF] "UBOOT" (1024 blocks) [PART] [0x00000000000C0000-0x00000000000FFFFF] "CONFIG" (512 blocks) [PART] [0x0000000000100000-0x000000000013FFFF] "FACTORY" (512 blocks) [PART] [0x0000000000140000-0x000000000213FFFF] "BOOTIMG" (65536 blocks) [PART] [0x0000000002140000-0x000000000413FFFF] "RECOVERY" (65536 blocks) [PART] [0x0000000004140000-0x000000004413FFFF] "ROOTFS" (2097152 blocks) [PART] [0x0000000044140000-0x000001FFC413FFFF] "USER" (-4194304 blocks) [platform_vusb_on] PASS [TOOL] PMIC not dectect usb cable! [TOOL] listen ended, receive size:0! [TOOL] wait sync time 150ms->5ms [TOOL] receieved data: () Device APC domain init setup: bootloader load uboot ,the address of uboot is 81E00000 [PART]partition name UBOOT [PART]partition start block 0x200 [PART]partition size 0x80000 [PART]partition blks 0x400 [PART]partition flags 0x0 [PART]partition name 0x8 [bean] part->startblk(0x200) bdev->blksz(0x200) part->part_id(8) hdr(0xFFB50000) [BlkDev.c 101 ]partition block size 0x200 ,blks:0xE90000 [BlkDev.c 101 ]partition block erase size 0x200 [PART] load "UBOOT" from 0x0000000000050000 (dev) to 0x81E00000 (mem) [SUCCESS] [PART] load speed: 10462KB/s, 300000 bytes, 28ms [BT_SD_PG] device info 0x8590 0x8A00 0xCB01 0x102 0:dram_rank_size:80000000 [PLFM] md_type[0] = 255 [PLFM] md_type[1] = 255 [PLFM] boot reason: 0 [PLFM] boot mode: 0 [PLFM] META COM0: 0 [PLFM] <0xFFB7CC10>: 0x0 [PLFM] boot time: 3045ms [PLFM] DDR reserve mode: enable = 0, success = 0 [BLDR] jump to 0x81E00000 [BLDR] <0x81E00000>=0xEA0000B8 [BLDR] <0x81E00004>=0xE59FF014 ================================================================================ Boot from SD Card!! [PLFM] Init Boot Device: OK(0) [PART] blksz: 512B [PART] [0x0000000000000000-0x000000000003FFFF] "PRELOADER" (512 blocks) [PART] [0x0000000000000000-0x000000000003FFFF] "MBR" (512 blocks) [PART] [0x0000000000040000-0x00000000000BFFFF] "UBOOT" (1024 blocks) [PART] [0x00000000000C0000-0x00000000000FFFFF] "CONFIG" (512 blocks) [PART] [0x0000000000100000-0x000000000013FFFF] "FACTORY" (512 blocks) [PART] [0x0000000000140000-0x000000000213FFFF] "BOOTIMG" (65536 blocks) [PART] [0x0000000002140000-0x000000000413FFFF] "RECOVERY" (65536 blocks) [PART] [0x0000000004140000-0x000000004413FFFF] "ROOTFS" (2097152 blocks) [PART] [0x0000000044140000-0x000001FFC413FFFF] "USER" (-4194304 blocks) [platform_vusb_on] PASS [TOOL] PMIC not dectect usb cable! [TOOL] listen ended, receive size:0! [TOOL] wait sync time 150ms->5ms [TOOL] receieved data: () Device APC domain init setup: bootloader load uboot ,the address of uboot is 81E00000 [PART]partition name UBOOT [PART]partition start block 0x200 [PART]partition size 0x80000 [PART]partition blks 0x400 [PART]partition flags 0x0 [PART]partition name 0x8 [bean] part->startblk(0x200) bdev->blksz(0x200) part->part_id(8) hdr(0xFFB50000) [BlkDev.c 101 ]partition block size 0x200 ,blks:0x1DACC00 [BlkDev.c 101 ]partition block erase size 0x200 [PART] load "UBOOT" from 0x0000000000050000 (dev) to 0x81E00000 (mem) [SUCCESS] [PART] load speed: 5744KB/s, 300000 bytes, 51ms [BT_SD_PG] device info 0x8590 0x8A00 0xCB01 0x102 0:dram_rank_size:80000000 [PLFM] md_type[0] = 255 [PLFM] md_type[1] = 255 [PLFM] boot reason: 0 [PLFM] boot mode: 0 [PLFM] META COM0: 0 [PLFM] <0xFFB7CC10>: 0x0 [PLFM] boot time: 2933ms [PLFM] DDR reserve mode: enable = 0, success = 0 [BLDR] jump to 0x81E00000 [BLDR] <0x81E00000>=0xEA0000B8 [BLDR] <0x81E00004>=0xE59FF014 U-Boot 2019.01-armbian (Feb 11 2019 - 08:04:39 +0100) CPU: MediaTek MT7623 E3 DRAM: 2 GiB MMC: mmc@11230000: 0, mmc@11240000: 1 In: serial Out: serial Err: serial Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device 1092 bytes read in 11 ms (96.7 KiB/s) Running boot/boot.scr from: mmc 1:1 using boot/boot.scr ## Executing script at 85f80000
