LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY altera_mf; USE altera_mf.altera_mf_components.all; ENTITY rom_ip IS PORT ( address : IN STD_LOGIC_VECTOR (9 DOWNTO 0); clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (7 DOWNTO 0) ); END rom_ip; ARCHITECTURE SYN OF rom_ip IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR (7 DOWNTO 0); BEGIN q <= sub_wire0(7 DOWNTO 0); altsyncram_component : altsyncram GENERIC MAP ( address_aclr_a => "NONE", clock_enable_input_a => "BYPASS", clock_enable_output_a => "BYPASS", init_file => "lena.mif", intended_device_family => "Cyclone IV E", lpm_hint => "ENABLE_RUNTIME_MOD=NO", lpm_type => "altsyncram", maximum_depth => 1024, numwords_a => 1024, operation_mode => "ROM", outdata_aclr_a => "NONE", outdata_reg_a => "CLOCK0", ram_block_type => "M9K", widthad_a => 10, width_a => 8, width_byteena_a => 1 ) PORT MAP ( address_a => address, clock0 => clock, q_a => sub_wire0 ); END SYN;
