------ Rebuild All started: Project: Example_TCA0_CCL, Configuration: Release AVR ------ Build started. Project "Example_TCA0_CCL.cproj" (Clean target(s)): Target "Clean" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\Worker\Documents\Atmel Studio\7.0\Workspace_ATmega4809\Example_TCA0_CCL\Example_TCA0_CCL\Example_TCA0_CCL.cproj" (entry point): Task "RunCompilerTask" Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe clean rm -rf atmel_start.o driver_isr.o main.o src/bod.o src/clkctrl.o src/cpuint.o src/driver_init.o src/protected_io.o src/slpctrl.o rm -rf atmel_start.d driver_isr.d main.d src/bod.d src/clkctrl.d src/cpuint.d src/driver_init.d src/protected_io.d src/slpctrl.d rm -rf "Example_TCA0_CCL.elf" "Example_TCA0_CCL.a" "Example_TCA0_CCL.hex" "Example_TCA0_CCL.lss" "Example_TCA0_CCL.eep" "Example_TCA0_CCL.map" "Example_TCA0_CCL.srec" "Example_TCA0_CCL.usersignatures" Done executing task "RunCompilerTask". Done building target "Clean" in project "Example_TCA0_CCL.cproj". Done building project "Example_TCA0_CCL.cproj". Build succeeded. ------ Rebuild All started: Project: Example_TCA0_CCL, Configuration: Release AVR ------ Build started. Project "Example_TCA0_CCL.cproj" (default targets): Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!=''). Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\Worker\Documents\Atmel Studio\7.0\Workspace_ATmega4809\Example_TCA0_CCL\Example_TCA0_CCL\Example_TCA0_CCL.cproj" (target "Build" depends on it): Task "RunCompilerTask" Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 8 --output-sync Building file: .././atmel_start.c Invoking: AVR/GNU C Compiler : 9.1.0 Using built-in specs. Reading specs from c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/device-specs/specs-atmega4809 rename spec link to old_link COLLECT_GCC=C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe Target: avr Configured with: ../configure --prefix=/omgwtfbbq/win32 --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libada --with-dwarf2 --disable-shared --enable-static --enable-mingw-wildcard --host=i686-w64-mingw32 --build=x86_64-pc-linux-gnu Thread model: single gcc version 9.1.0 (GCC) "C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DNDEBUG -I"../Config" -I"../include" -I"../utils" -I"../utils/assembler" -I".." -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include" -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega4809 -c -std=gnu99 -v -MD -MP -MF "atmel_start.d" -MT"atmel_start.d" -MT"atmel_start.o" -o "atmel_start.o" ".././atmel_start.c" Finished building: .././atmel_start.c COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'atmel_start.d' '-MT' 'atmel_start.d' '-MT' 'atmel_start.o' '-o' 'atmel_start.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/cc1.exe -quiet -v -I ../Config -I ../include -I ../utils -I ../utils/assembler -I .. -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include -imultilib avrxmega3 -iprefix c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/ -MD atmel_start.d -MF atmel_start.d -MP -MT atmel_start.d -MT atmel_start.o -D__AVR_ATmega4809__ -D__AVR_DEVICE_NAME__=atmega4809 -D__AVR_DEV_LIB_NAME__=m4809 -D NDEBUG .././atmel_start.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase atmel_start.c -mmcu=avrxmega3 -auxbase-strip atmel_start.o -Os -Wall -std=gnu99 -version -funsigned-char -funsigned-bitfields -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -o C:\Users\Worker\AppData\Local\Temp\ccssNFIA.s GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include-fixed" ignoring nonexistent directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: ../Config ../include ../utils ../utils/assembler .. C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include-fixed c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/include End of search list. GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: b0785c7356923997471c565d91463c89 COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'atmel_start.d' '-MT' 'atmel_start.d' '-MT' 'atmel_start.o' '-o' 'atmel_start.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/as.exe -mmcu=avrxmega3 -mno-skip-bug -o atmel_start.o C:\Users\Worker\AppData\Local\Temp\ccssNFIA.s COMPILER_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/ LIBRARY_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'atmel_start.d' '-MT' 'atmel_start.d' '-MT' 'atmel_start.o' '-o' 'atmel_start.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' Building file: .././main.c Invoking: AVR/GNU C Compiler : 9.1.0 Using built-in specs. Reading specs from c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/device-specs/specs-atmega4809 rename spec link to old_link COLLECT_GCC=C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe Target: avr Configured with: ../configure --prefix=/omgwtfbbq/win32 --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libada --with-dwarf2 --disable-shared --enable-static --enable-mingw-wildcard --host=i686-w64-mingw32 --build=x86_64-pc-linux-gnu Thread model: single gcc version 9.1.0 (GCC) "C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DNDEBUG -I"../Config" -I"../include" -I"../utils" -I"../utils/assembler" -I".." -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include" -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega4809 -c -std=gnu99 -v -MD -MP -MF "main.d" -MT"main.d" -MT"main.o" -o "main.o" ".././main.c" C:\Users\Worker\Documents\Atmel Studio\7.0\Workspace_ATmega4809\Example_TCA0_CCL\Example_TCA0_CCL\Release\Makefile(146,1): error: recipe for target 'main.o' failed COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'main.d' '-MT' 'main.d' '-MT' 'main.o' '-o' 'main.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/cc1.exe -quiet -v -I ../Config -I ../include -I ../utils -I ../utils/assembler -I .. -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include -imultilib avrxmega3 -iprefix c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/ -MD main.d -MF main.d -MP -MT main.d -MT main.o -D__AVR_ATmega4809__ -D__AVR_DEVICE_NAME__=atmega4809 -D__AVR_DEV_LIB_NAME__=m4809 -D NDEBUG .././main.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase main.c -mmcu=avrxmega3 -auxbase-strip main.o -Os -Wall -std=gnu99 -version -funsigned-char -funsigned-bitfields -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -o C:\Users\Worker\AppData\Local\Temp\ccWbBUcF.s GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include-fixed" ignoring nonexistent directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: ../Config ../include ../utils ../utils/assembler .. C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include-fixed c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/include End of search list. GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: b0785c7356923997471c565d91463c89 COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'main.d' '-MT' 'main.d' '-MT' 'main.o' '-o' 'main.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/as.exe -mmcu=avrxmega3 -mno-skip-bug -o main.o C:\Users\Worker\AppData\Local\Temp\ccWbBUcF.s C:\Users\Worker\AppData\Local\Temp\ccWbBUcF.s: Assembler messages: C:\Users\Worker\AppData\Local\Temp\ccWbBUcF.s(60,1): error: pseudo instruction `__gcc_isr' not supported C:\Users\Worker\AppData\Local\Temp\ccWbBUcF.s(77,1): error: pseudo instruction `__gcc_isr' not supported C:\Users\Worker\AppData\Local\Temp\ccWbBUcF.s(79,1): error: pseudo instruction `__gcc_isr' not supported make: *** [main.o] Error 1 make: *** Waiting for unfinished jobs.... Building file: .././driver_isr.c Invoking: AVR/GNU C Compiler : 9.1.0 "C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DNDEBUG -I"../Config" -I"../include" -I"../utils" -I"../utils/assembler" -I".." -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include" -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega4809 -c -std=gnu99 -v -MD -MP -MF "driver_isr.d" -MT"driver_isr.d" -MT"driver_isr.o" -o "driver_isr.o" ".././driver_isr.c" Finished building: .././driver_isr.c Using built-in specs. Reading specs from c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/device-specs/specs-atmega4809 rename spec link to old_link COLLECT_GCC=C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe Target: avr Configured with: ../configure --prefix=/omgwtfbbq/win32 --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libada --with-dwarf2 --disable-shared --enable-static --enable-mingw-wildcard --host=i686-w64-mingw32 --build=x86_64-pc-linux-gnu Thread model: single gcc version 9.1.0 (GCC) COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'driver_isr.d' '-MT' 'driver_isr.d' '-MT' 'driver_isr.o' '-o' 'driver_isr.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/cc1.exe -quiet -v -I ../Config -I ../include -I ../utils -I ../utils/assembler -I .. -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include -imultilib avrxmega3 -iprefix c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/ -MD driver_isr.d -MF driver_isr.d -MP -MT driver_isr.d -MT driver_isr.o -D__AVR_ATmega4809__ -D__AVR_DEVICE_NAME__=atmega4809 -D__AVR_DEV_LIB_NAME__=m4809 -D NDEBUG .././driver_isr.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase driver_isr.c -mmcu=avrxmega3 -auxbase-strip driver_isr.o -Os -Wall -std=gnu99 -version -funsigned-char -funsigned-bitfields -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -o C:\Users\Worker\AppData\Local\Temp\cc8dHjlD.s GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include-fixed" ignoring nonexistent directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: ../Config ../include ../utils ../utils/assembler .. C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include-fixed c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/include End of search list. GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: b0785c7356923997471c565d91463c89 COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'driver_isr.d' '-MT' 'driver_isr.d' '-MT' 'driver_isr.o' '-o' 'driver_isr.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/as.exe -mmcu=avrxmega3 -mno-skip-bug -o driver_isr.o C:\Users\Worker\AppData\Local\Temp\cc8dHjlD.s COMPILER_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/ LIBRARY_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'driver_isr.d' '-MT' 'driver_isr.d' '-MT' 'driver_isr.o' '-o' 'driver_isr.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' Building file: ../src/bod.c Invoking: AVR/GNU C Compiler : 9.1.0 Using built-in specs. Reading specs from c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/device-specs/specs-atmega4809 rename spec link to old_link COLLECT_GCC=C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe Target: avr Configured with: ../configure --prefix=/omgwtfbbq/win32 --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libada --with-dwarf2 --disable-shared --enable-static --enable-mingw-wildcard --host=i686-w64-mingw32 --build=x86_64-pc-linux-gnu Thread model: single gcc version 9.1.0 (GCC) "C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DNDEBUG -I"../Config" -I"../include" -I"../utils" -I"../utils/assembler" -I".." -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include" -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega4809 -c -std=gnu99 -v -MD -MP -MF "src/bod.d" -MT"src/bod.d" -MT"src/bod.o" -o "src/bod.o" "../src/bod.c" Finished building: ../src/bod.c COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/bod.d' '-MT' 'src/bod.d' '-MT' 'src/bod.o' '-o' 'src/bod.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/cc1.exe -quiet -v -I ../Config -I ../include -I ../utils -I ../utils/assembler -I .. -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include -imultilib avrxmega3 -iprefix c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/ -MD src/bod.d -MF src/bod.d -MP -MT src/bod.d -MT src/bod.o -D__AVR_ATmega4809__ -D__AVR_DEVICE_NAME__=atmega4809 -D__AVR_DEV_LIB_NAME__=m4809 -D NDEBUG ../src/bod.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase bod.c -mmcu=avrxmega3 -auxbase-strip src/bod.o -Os -Wall -std=gnu99 -version -funsigned-char -funsigned-bitfields -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -o C:\Users\Worker\AppData\Local\Temp\cca9b2XJ.s GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include-fixed" ignoring nonexistent directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: ../Config ../include ../utils ../utils/assembler .. C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include-fixed c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/include End of search list. GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: b0785c7356923997471c565d91463c89 COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/bod.d' '-MT' 'src/bod.d' '-MT' 'src/bod.o' '-o' 'src/bod.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/as.exe -mmcu=avrxmega3 -mno-skip-bug -o src/bod.o C:\Users\Worker\AppData\Local\Temp\cca9b2XJ.s COMPILER_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/ LIBRARY_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/bod.d' '-MT' 'src/bod.d' '-MT' 'src/bod.o' '-o' 'src/bod.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' Building file: ../src/clkctrl.c Invoking: AVR/GNU C Compiler : 9.1.0 Using built-in specs. Reading specs from c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/device-specs/specs-atmega4809 rename spec link to old_link COLLECT_GCC=C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe Target: avr Configured with: ../configure --prefix=/omgwtfbbq/win32 --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libada --with-dwarf2 --disable-shared --enable-static --enable-mingw-wildcard --host=i686-w64-mingw32 --build=x86_64-pc-linux-gnu Thread model: single gcc version 9.1.0 (GCC) "C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DNDEBUG -I"../Config" -I"../include" -I"../utils" -I"../utils/assembler" -I".." -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include" -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega4809 -c -std=gnu99 -v -MD -MP -MF "src/clkctrl.d" -MT"src/clkctrl.d" -MT"src/clkctrl.o" -o "src/clkctrl.o" "../src/clkctrl.c" Finished building: ../src/clkctrl.c COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/clkctrl.d' '-MT' 'src/clkctrl.d' '-MT' 'src/clkctrl.o' '-o' 'src/clkctrl.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/cc1.exe -quiet -v -I ../Config -I ../include -I ../utils -I ../utils/assembler -I .. -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include -imultilib avrxmega3 -iprefix c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/ -MD src/clkctrl.d -MF src/clkctrl.d -MP -MT src/clkctrl.d -MT src/clkctrl.o -D__AVR_ATmega4809__ -D__AVR_DEVICE_NAME__=atmega4809 -D__AVR_DEV_LIB_NAME__=m4809 -D NDEBUG ../src/clkctrl.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase clkctrl.c -mmcu=avrxmega3 -auxbase-strip src/clkctrl.o -Os -Wall -std=gnu99 -version -funsigned-char -funsigned-bitfields -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -o C:\Users\Worker\AppData\Local\Temp\ccIkszpO.s GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include-fixed" ignoring nonexistent directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: ../Config ../include ../utils ../utils/assembler .. C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include-fixed c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/include End of search list. GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: b0785c7356923997471c565d91463c89 COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/clkctrl.d' '-MT' 'src/clkctrl.d' '-MT' 'src/clkctrl.o' '-o' 'src/clkctrl.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/as.exe -mmcu=avrxmega3 -mno-skip-bug -o src/clkctrl.o C:\Users\Worker\AppData\Local\Temp\ccIkszpO.s COMPILER_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/ LIBRARY_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/clkctrl.d' '-MT' 'src/clkctrl.d' '-MT' 'src/clkctrl.o' '-o' 'src/clkctrl.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' Building file: ../src/cpuint.c Invoking: AVR/GNU C Compiler : 9.1.0 Using built-in specs. Reading specs from c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/device-specs/specs-atmega4809 rename spec link to old_link COLLECT_GCC=C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe Target: avr Configured with: ../configure --prefix=/omgwtfbbq/win32 --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp --disable-libada --with-dwarf2 --disable-shared --enable-static --enable-mingw-wildcard --host=i686-w64-mingw32 --build=x86_64-pc-linux-gnu Thread model: single gcc version 9.1.0 (GCC) "C:\Users\Worker\Documents\Atmel Studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DNDEBUG -I"../Config" -I"../include" -I"../utils" -I"../utils/assembler" -I".." -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include" -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega4809 -c -std=gnu99 -v -MD -MP -MF "src/cpuint.d" -MT"src/cpuint.d" -MT"src/cpuint.o" -o "src/cpuint.o" "../src/cpuint.c" Finished building: ../src/cpuint.c COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/cpuint.d' '-MT' 'src/cpuint.d' '-MT' 'src/cpuint.o' '-o' 'src/cpuint.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/cc1.exe -quiet -v -I ../Config -I ../include -I ../utils -I ../utils/assembler -I .. -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include -imultilib avrxmega3 -iprefix c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/ -MD src/cpuint.d -MF src/cpuint.d -MP -MT src/cpuint.d -MT src/cpuint.o -D__AVR_ATmega4809__ -D__AVR_DEVICE_NAME__=atmega4809 -D__AVR_DEV_LIB_NAME__=m4809 -D NDEBUG ../src/cpuint.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase cpuint.c -mmcu=avrxmega3 -auxbase-strip src/cpuint.o -Os -Wall -std=gnu99 -version -funsigned-char -funsigned-bitfields -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -o C:\Users\Worker\AppData\Local\Temp\cc0tGIxW.s GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/include-fixed" ignoring nonexistent directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/sys-include" ignoring duplicate directory "c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/lib/gcc/../../lib/gcc/avr/9.1.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: ../Config ../include ../utils ../utils/assembler .. C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/include-fixed c:\users\worker\documents\atmel studio\7.0\toolchain\avr-gcc-9.1.0_mingw32\bin\../lib/gcc/avr/9.1.0/../../../../avr/include End of search list. GNU C99 (GCC) version 9.1.0 (avr) compiled by GNU C version 5.3.0, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: b0785c7356923997471c565d91463c89 COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/cpuint.d' '-MT' 'src/cpuint.d' '-MT' 'src/cpuint.o' '-o' 'src/cpuint.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/as.exe -mmcu=avrxmega3 -mno-skip-bug -o src/cpuint.o C:\Users\Worker\AppData\Local\Temp\cc0tGIxW.s COMPILER_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../libexec/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/bin/ LIBRARY_PATH=c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/avrxmega3/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/;c:/users/worker/documents/atmel studio/7.0/toolchain/avr-gcc-9.1.0_mingw32/bin/../lib/gcc/avr/9.1.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'NDEBUG' '-I' '../Config' '-I' '../include' '-I' '../utils' '-I' '../utils/assembler' '-I' '..' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-c' '-std=gnu99' '-v' '-MD' '-MP' '-MF' 'src/cpuint.d' '-MT' 'src/cpuint.d' '-MT' 'src/cpuint.o' '-o' 'src/cpuint.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' Done executing task "RunCompilerTask" -- FAILED. Done building target "CoreBuild" in project "Example_TCA0_CCL.cproj" -- FAILED. Done building project "Example_TCA0_CCL.cproj" -- FAILED. Build FAILED. ========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
