Bug# Report Importance =============================================================================================================== #1823973 "Segmentation fault after a failed assertion when "Cleanup Tracks and Vias" in Pcbnew Critical #1826794 KiCad Crashes on reloading deleted footprint Critical #1828214 Eeschema generates corrupted schematic file Critical #1828289 Segfault in CVPCB Critical #1828726 Pcbnew delete DRC marker crash Critical #1829243 Footprint editor crash to desktop when loading Eagle library Critical #1829337 Crash in Footprint Properties/3D Settings Critical #1829647 Kicad 5.1.2: Gerview segfaults almost immediately after start on Ubuntu Critical #1832107 Segfault when importing a footprint to modedit and then undoing Critical #1832930 pcbnew crashes when you try to draw a line more than a few segments Critical #1833059 airwire missing when trace is almost connected Critical #1833819 Strange footprint (with polyline) results in footprint editor non responsive (hangs withou Critical #1834111 PCBNew crash on move hotkey while clicking Critical #1834718 Pcbnew: fill then move zone in modern canvases causes segfault Critical #1826014 Circles and arcs on Edge.Cuts cause routing failure High #1826270 pcbnew modern toolset: unable to place track on board with circular edge cut High #1826278 Strange track behaviour (constrain) High #1828285 Pcbnew doesn't save board settings High #1828442 Via changes net when pad moved over it does not undo High #1830078 Datasheet is vanished from symbol libraries High #1830564 eeschema crashes on importing Eagle from TI's Webench. High #1831643 Race condition in CMAKE High #1831941 Invalid Gerber export of Paste layer for custom shape pad with negative expansion High #1832635 footprint wizard crashed on start High #1834629 FP Editor: Cant set FP pad connection High #1810914 Simulations PNG export has black font for legend on black background Medium #1813328 PNS router does not obey netclass clearance Medium #1818667 Bad move / grid interaction Medium #1819419 Delete button doesn't remove items on Mac OS X Medium #1820841 Flipped Edge.Cuts in STEP export Medium #1821319 Eagle import: symbol w. multiple pads mapped to single "not connected" pin creates stack... Medium #1821606 Removing a symbol library throws off all other symbols Medium #1822772 Arcs aren't mirrored when printing mirrored Medium #1823147 Printing mirrored layout in pcbnew shrink nonrectangular pads Medium #1825588 DRC: Wrong track clearance error type Medium #1825808 Issue with legacy segment filling in 5.1 Medium #1825913 Project rescue helper: hi dpi leads to quarter sized viewport Medium #1826723 Highlight collisions/allow violations doesn't let draw tracks to all grid points Medium #1827642 I can't select the last 4 or 5 smaller grid options Medium #1828747 3d viewer: orthographic view does not render board body at some angles Medium #1829048 hierarchical sheet drawing issue Medium #1829509 pcbnew: export to svg/pdf does not show curves in board Medium #1829664 Converting text to a label can create a label with illegal characters Medium #1829707 Eagle import: schematic page descriptions with new line character break import Medium #1830083 Escheema is not importing a Datasheet field value Medium #1830245 pcbnew: plot to svg: sometime generate a empty circular pads/vias Medium #1831311 Custom pad jumps when mirrored Medium #1831481 Ctrl+Click on filled zones deletes it. Medium #1832289 "Delete Block" operation deletes unselected components Medium #1833214 PNS doesn't respect "Minimum hole to hole" Medium #1833295 Nightly MODEDIT : not export from menu File/export Medium #1833478 Assertion when moving full board Medium #1833748 Pcbnew does not ask for saving your changes if there are only zones in the file Medium #1833822 Can't generate BOM with python scripts - regular expression error in python BOM generation Medium #1833831 Cannot remove corners from self-intersecting zones and polygons in some cases. Medium #1833870 Gerbview does not restrict selections to current layer in high contrast mode as in Pcbnew Medium #1835051 Current nightly build sometimes does not respect symbol-library pin line-width Medium #1835999 Modedit: Upper/lower case in new footprint name can cause overwriting existing file withou Medium #1836183 Update footprint does not reset text visibilities Medium #1836923 pcbnew: plot gerber invalid first init of Use aux axis flag Medium
