# # Specs for AVR device atmega809 (core avrxmega3, 16-bit SP, short-calls) # # Used by : avr-gcc compiler driver # Used for : building command options for sub-processes # # See # for a documentation of spec files. # If you intend to use an existing device specs file as a starting point # for a new device spec file, make sure you are copying from a specs # file for a device from the same core architecture and SP width. # See for a description # of how to use such own spec files. *avrlibc_startfile: crtatmega809.o%s *avrlibc_devicelib: %{!nodevicelib:-latmega809} *cc1_n_flash: %{!mn-flash=*:-mn-flash=1} *cc1_rmw: %{mrmw} *cc1_errata_skip: %{!mskip-bug: -mno-skip-bug} *cc1_absdata: %{mabsdata} *asm_arch: -mmcu=avrxmega3 *asm_relax: %{mrelax:--mlink-relax} *asm_rmw: %{mrmw} *asm_gccisr: %{!mno-gas-isr-prologues: -mgcc-isr} *asm_errata_skip: %{!mskip-bug: -mno-skip-bug} *link_pmem_wrap: %{!mno-pmem-wrap-around: --pmem-wrap-around=8k} *link_relax: %{mrelax:--relax} *link_arch: %{mmcu=*:-m%*} --defsym=__RODATA_PM_OFFSET__=0x4000 *link_data_start: %{!Tdata:-Tdata 0x803C00} *link_text_start: *self_spec: %{!mmcu=avr*: % # #elif ... # # If no device macro is defined, AVR-LibC uses __AVR_DEV_LIB_NAME__ # as fallback to determine the name of the device header as # # "avr/io" + __AVR_DEV_LIB_NAME__ + ".h" # # If you provide your own specs file for a device not yet known to # AVR-LibC, you can now define the hook macro __AVR_DEV_LIB_NAME__ # as needed so that # # #include # # will include the desired device header. For ATmega8A the supplement # to *cpp would read # # -D__AVR_DEV_LIB_NAME__=m8a *cpp_avrlibc: -D__AVR_ATmega809__ -D__AVR_DEVICE_NAME__=atmega809 -D__AVR_DEV_LIB_NAME__=m809 *cpp_mcu: -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 *cpp: %(cpp_avrlibc) %(cpp_mcu) # End of file
