Count ReleaseSemaphore rc = 298. GUI --- Auto connect to cable... // *** BATCH CMD : setCable -port auto AutoDetecting cable. Please wait. PROGRESS_START - Starting Operation. Connecting to cable (Parallel Port - LPT1). Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811. LPT base address = 0378h. ECP base address = FFFFFFFFh. Cable connection failed. Connecting to cable (Parallel Port - LPT2). Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811. Cable connection failed. Connecting to cable (Parallel Port - LPT3). Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811. Cable connection failed. Connecting to cable (Parallel Port - LPT4). Checking cable driver. Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811. Cable connection failed. Connecting to cable (Usb Port - USB21). Checking cable driver. Source driver files not found. The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry the Cable Setup operation. Cable connection failed. Connecting to cable (Usb Port - USB22). Checking cable driver. Source driver files not found. The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry the Cable Setup operation. Cable connection failed. Connecting to cable (Usb Port - USB23). Checking cable driver. Source driver files not found. The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry the Cable Setup operation. Cable connection failed. Connecting to cable (Usb Port - USB24). Checking cable driver. Source driver files not found. The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry the Cable Setup operation. Cable connection failed. PROGRESS_END - End Operation. Elapsed time = 3 sec. Cable autodetection failed.
