adapter_khz 1000 reset_config srst_only adapter_nsrst_assert_width 100 interface cmsis-dap transport select jtag set _CHIPNAME riscv jtag newtap $_CHIPNAME cpu -irlen 5 -expected-id 0x1000563d set _TARGETNAME $_CHIPNAME.cpu target create $_TARGETNAME riscv -chain-position $_TARGETNAME $_TARGETNAME configure -work-area-phys 0x20000000 -work-area-size 20480 -work-area-backup 0 # Work-area is a space in RAM used for flash programming if { [info exists WORKAREASIZE] } { set _WORKAREASIZE $WORKAREASIZE } else { set _WORKAREASIZE 0x5000 } # Allow overriding the Flash bank size if { [info exists FLASH_SIZE] } { set _FLASH_SIZE $FLASH_SIZE } else { # autodetect size set _FLASH_SIZE 0 } # flash size will be probed set _FLASHNAME $_CHIPNAME.flash flash bank $_FLASHNAME gd32vf103 0x08000000 0 0 0 $_TARGETNAME riscv set_reset_timeout_sec 1 init halt
