<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?fileVersion 4.0.0?>
<cproject>
<storageModule moduleId="org.eclipse.cdt.core.settings">
<cconfiguration id="de.innot.avreclipse.configuration.app.release.909921314">
<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="de.innot.avreclipse.configuration.app.release.909921314" moduleId="org.eclipse.cdt.core.settings" name="Release">
<externalSettings/>
<extensions>
<extension id="org.eclipse.cdt.core.ELF" point="org.eclipse.cdt.core.BinaryParser"/>
<extension id="org.eclipse.cdt.core.MakeErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GCCErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GASErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GLDErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
</extensions>
</storageModule>
<storageModule moduleId="cdtBuildSystem" version="4.0.0">
<configuration artifactName="USB-USART_target" buildArtefactType="de.innot.avreclipse.buildArtefactType.app" buildProperties="org.eclipse.cdt.build.core.buildType=org.eclipse.cdt.build.core.buildType.release,org.eclipse.cdt.build.core.buildArtefactType=de.innot.avreclipse.buildArtefactType.app" description="" id="de.innot.avreclipse.configuration.app.release.909921314" name="Release" parent="de.innot.avreclipse.configuration.app.release">
<folderInfo id="de.innot.avreclipse.configuration.app.release.909921314." name="/" resourcePath="">
<toolChain id="de.innot.avreclipse.toolchain.winavr.app.release.1889903267" name="AVR-GCC Toolchain" superClass="de.innot.avreclipse.toolchain.winavr.app.release">
<option id="de.innot.avreclipse.toolchain.options.toolchain.objcopy.flash.app.release.1379250152" name="Generate HEX file for Flash memory" superClass="de.innot.avreclipse.toolchain.options.toolchain.objcopy.flash.app.release"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objcopy.eeprom.app.release.149872150" name="Generate HEX file for EEPROM" superClass="de.innot.avreclipse.toolchain.options.toolchain.objcopy.eeprom.app.release"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objdump.app.release.1629526702" name="Generate Extended Listing (Source + generated Assembler)" superClass="de.innot.avreclipse.toolchain.options.toolchain.objdump.app.release"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.size.app.release.1571693403" name="Print Size" superClass="de.innot.avreclipse.toolchain.options.toolchain.size.app.release"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.avrdude.app.release.69155208" name="AVRDude" superClass="de.innot.avreclipse.toolchain.options.toolchain.avrdude.app.release"/>
<targetPlatform id="de.innot.avreclipse.targetplatform.winavr.app.release.1391689067" name="AVR Cross-Target" superClass="de.innot.avreclipse.targetplatform.winavr.app.release"/>
<builder buildPath="${workspace_loc:/USB-USART_target/Release}" id="de.innot.avreclipse.target.builder.winavr.app.release.509436634" keepEnvironmentInBuildfile="false" managedBuildOn="true" name="AVR GNU Make Builder" superClass="de.innot.avreclipse.target.builder.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.assembler.winavr.app.release.1379024121" name="AVR Assembler" superClass="de.innot.avreclipse.tool.assembler.winavr.app.release">
<option id="de.innot.avreclipse.assembler.option.debug.level.934765445" name="Generate Debugging Info" superClass="de.innot.avreclipse.assembler.option.debug.level" value="de.innot.avreclipse.assembler.option.debug.level.none" valueType="enumerated"/>
<inputType id="de.innot.avreclipse.tool.assembler.input.973873547" superClass="de.innot.avreclipse.tool.assembler.input"/>
</tool>
<tool id="de.innot.avreclipse.tool.compiler.winavr.app.release.262847072" name="AVR Compiler" superClass="de.innot.avreclipse.tool.compiler.winavr.app.release">
<option id="de.innot.avreclipse.compiler.option.debug.level.1678424184" name="Generate Debugging Info" superClass="de.innot.avreclipse.compiler.option.debug.level" value="de.innot.avreclipse.compiler.option.debug.level.none" valueType="enumerated"/>
<option id="de.innot.avreclipse.compiler.option.optimize.1197910061" name="Optimization Level" superClass="de.innot.avreclipse.compiler.option.optimize" value="de.innot.avreclipse.compiler.optimize.size" valueType="enumerated"/>
<option id="de.innot.avreclipse.compiler.option.incpath.1198754881" name="Include Paths (-I)" superClass="de.innot.avreclipse.compiler.option.incpath" valueType="includePath">
<listOptionValue builtIn="false" value="&quot;${workspace_loc:/ETVlib}&quot;"/>
</option>
<option id="de.innot.avreclipse.compiler.option.std.1644422200" name="Language Standard" superClass="de.innot.avreclipse.compiler.option.std" value="de.innot.avreclipse.compiler.option.std.gnu99" valueType="enumerated"/>
<inputType id="de.innot.avreclipse.compiler.winavr.input.281521950" name="C Source Files" superClass="de.innot.avreclipse.compiler.winavr.input"/>
</tool>
<tool id="de.innot.avreclipse.tool.cppcompiler.app.release.57266437" name="AVR C++ Compiler" superClass="de.innot.avreclipse.tool.cppcompiler.app.release">
<option id="de.innot.avreclipse.cppcompiler.option.debug.level.1713997169" name="Generate Debugging Info" superClass="de.innot.avreclipse.cppcompiler.option.debug.level" value="de.innot.avreclipse.cppcompiler.option.debug.level.none" valueType="enumerated"/>
<option id="de.innot.avreclipse.cppcompiler.option.optimize.1901161636" name="Optimization Level" superClass="de.innot.avreclipse.cppcompiler.option.optimize" value="de.innot.avreclipse.cppcompiler.optimize.size" valueType="enumerated"/>
</tool>
<tool id="de.innot.avreclipse.tool.linker.winavr.app.release.1303671837" name="AVR C Linker" superClass="de.innot.avreclipse.tool.linker.winavr.app.release">
<option id="de.innot.avreclipse.linker.option.libs.1825613669" name="Libraries (-l)" superClass="de.innot.avreclipse.linker.option.libs" valueType="libs">
<listOptionValue builtIn="false" value="ETVlib"/>
</option>
<option id="de.innot.avreclipse.linker.option.libpath.1732829491" name="Libraries Path (-L)" superClass="de.innot.avreclipse.linker.option.libpath" valueType="stringList">
<listOptionValue builtIn="false" value="&quot;${workspace_loc:/ETVlib/Release}&quot;"/>
</option>
</tool>
<tool id="de.innot.avreclipse.tool.cpplinker.app.release.1142844419" name="AVR C++ Linker" superClass="de.innot.avreclipse.tool.cpplinker.app.release"/>
<tool id="de.innot.avreclipse.tool.archiver.winavr.base.513372947" name="AVR Archiver" superClass="de.innot.avreclipse.tool.archiver.winavr.base"/>
<tool id="de.innot.avreclipse.tool.objdump.winavr.app.release.1632356536" name="AVR Create Extended Listing" superClass="de.innot.avreclipse.tool.objdump.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.objcopy.flash.winavr.app.release.1187536572" name="AVR Create Flash image" superClass="de.innot.avreclipse.tool.objcopy.flash.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.objcopy.eeprom.winavr.app.release.1529045150" name="AVR Create EEPROM image" superClass="de.innot.avreclipse.tool.objcopy.eeprom.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.size.winavr.app.release.489797716" name="Print Size" superClass="de.innot.avreclipse.tool.size.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.avrdude.app.release.1244472572" name="AVRDude" superClass="de.innot.avreclipse.tool.avrdude.app.release"/>
</toolChain>
</folderInfo>
</configuration>
</storageModule>
<storageModule moduleId="scannerConfiguration">
<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId="org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile"/>
<profile id="de.innot.avreclipse.core.AVRGCCManagedMakePerProjectProfileC">
<buildOutputProvider>
<openAction enabled="true" filePath=""/>
<parser enabled="true"/>
</buildOutputProvider>
<scannerInfoProvider id="specsFile">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.c" command="avr-gcc" useDefault="true"/>
</scannerInfoProvider>
</profile>
<profile id="de.innot.avreclipse.core.AVRGCCManagedMakePerProjectProfileCPP">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.cpp" command="avr-g++" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/${specs_file}" command="gcc" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile">
<scannerInfoProvider id="makefileGenerator">
<runAction arguments="-f ${project_name}_scd.mk" command="make" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile">
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.cpp" command="g++" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.c" command="gcc" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile">
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP">
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC">
</profile>
<scannerConfigBuildInfo instanceId="de.innot.avreclipse.configuration.app.release.909921314;de.innot.avreclipse.configuration.app.release.909921314.">
<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId="de.innot.avreclipse.core.AVRGCCManagedMakePerProjectProfileC"/>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</scannerConfigBuildInfo>
<scannerConfigBuildInfo instanceId="de.innot.avreclipse.configuration.app.release.909921314;de.innot.avreclipse.configuration.app.release.909921314.;de.innot.avreclipse.tool.compiler.winavr.app.release.262847072;de.innot.avreclipse.compiler.winavr.input.281521950">
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</storageModule>
<storageModule moduleId="org.eclipse.cdt.core.externalSettings"/>
<storageModule moduleId="org.eclipse.cdt.core.language.mapping"/>
<storageModule moduleId="org.eclipse.cdt.internal.ui.text.commentOwnerProjectMappings"/>
</cconfiguration>
</storageModule>
<project id="USB-USART_target.de.innot.avreclipse.project.winavr.elf_2.1.0.633796492" name="AVR Cross Target Application" projectType="de.innot.avreclipse.project.winavr.elf_2.1.0"/>
</storageModule>
</cproject>
