Version 4 SHEET 1 1564 772 WIRE -176 -16 -208 -16 WIRE -128 -16 -176 -16 WIRE 64 -16 32 -16 WIRE 112 -16 64 -16 WIRE 304 -16 272 -16 WIRE 352 -16 304 -16 WIRE 544 -16 496 -16 WIRE 688 -16 640 -16 WIRE 832 -16 784 -16 WIRE 976 -16 928 -16 WIRE -208 16 -208 -16 WIRE -128 16 -128 -16 WIRE 32 16 32 -16 WIRE 112 16 112 -16 WIRE 272 16 272 -16 WIRE 352 16 352 -16 WIRE 496 16 496 -16 WIRE 640 16 640 -16 WIRE 784 16 784 -16 WIRE 928 16 928 -16 WIRE -208 112 -208 96 WIRE -128 112 -128 80 WIRE -128 112 -208 112 WIRE 32 112 32 96 WIRE 112 112 112 80 WIRE 112 112 32 112 WIRE 272 112 272 96 WIRE 352 112 352 80 WIRE 352 112 272 112 WIRE 496 112 496 96 WIRE 640 112 640 96 WIRE 784 112 784 96 WIRE 928 112 928 96 WIRE -208 128 -208 112 WIRE 32 128 32 112 WIRE 272 128 272 112 WIRE 896 224 784 224 WIRE 928 224 896 224 WIRE 784 256 784 224 WIRE 928 256 928 224 WIRE 784 368 784 336 WIRE 928 368 928 320 WIRE 928 368 784 368 WIRE 784 384 784 368 FLAG -208 128 0 FLAG -176 -16 VF1 FLAG 32 128 0 FLAG 64 -16 VF2 FLAG 496 112 0 FLAG 544 -16 N IOPIN 544 -16 Out FLAG 640 112 0 FLAG 688 -16 Is IOPIN 688 -16 Out FLAG 784 112 0 FLAG 832 -16 Rs IOPIN 832 -16 Out FLAG 272 128 0 FLAG 304 -16 VF3 FLAG 928 112 0 FLAG 976 -16 Eg IOPIN 976 -16 Out FLAG 784 384 0 FLAG 896 224 VF_green SYMBOL diode -144 16 R0 SYMATTR InstName D1 SYMATTR Value DMOD SYMBOL current -208 96 R180 WINDOW 0 24 88 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName I1 SYMATTR Value {I1} SYMBOL diode 96 16 R0 SYMATTR InstName D2 SYMATTR Value DMOD SYMBOL current 32 96 R180 WINDOW 0 24 88 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName I2 SYMATTR Value {I2} SYMBOL voltage 496 0 R0 SYMATTR InstName V1 SYMATTR Value {N} SYMBOL voltage 640 0 R0 SYMATTR InstName V2 SYMATTR Value {Is} SYMBOL voltage 784 0 R0 SYMATTR InstName V3 SYMATTR Value {Rs} SYMBOL diode 336 16 R0 SYMATTR InstName D3 SYMATTR Value DMOD SYMBOL current 272 96 R180 WINDOW 0 24 88 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName I3 SYMATTR Value {I3} SYMBOL voltage 928 0 R0 SYMATTR InstName V4 SYMATTR Value {Eg} SYMBOL current 784 336 M180 WINDOW 0 24 88 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName I4 SYMATTR Value 50u SYMBOL diode 912 256 R0 SYMATTR InstName D_GREEN SYMATTR Value LED_GREEN TEXT -224 -424 Left 2 !.param Vf2=1.80 TEXT -224 -496 Left 2 !.param Vf1=1.71 TEXT -224 -528 Left 2 !.param I1=0.00005 TEXT -224 -456 Left 2 !.param I2=0.00055 TEXT 256 -592 Left 2 !.param T0=273.15+Tmeas\n.param Vt = k*T0/q\n.param N = (Vf2-Vf1)/(Vt*ln(I2/I1))\n.param Is= I1/exp(Vf1/(N*Vt))\n.param Rs=(Vf3-ln(I3/Is)*(N*Vt))/I3 TEXT 256 -440 Left 2 !.param XTI=3\n.param T1=T0+1\n.param deltaT=T1-T0\n.param Vt_t0=Vt\n.param Vt_t1=Vt_t0*(1+(T1-T0)/T0)\n.param Vf_t0=Vf1\n.param Vf_t1=Vf_t0+Tempco*deltaT\n.param Is_t0=Is\n.param Is_t1=I1/exp(Vf_t1/(N*Vt_t1))\n.param Eg=N*Vt_t1*T0/(T1-T0)*ln(Is_t1/(Is_t0*(T1/T0)**(XTI/N))) TEXT 744 -568 Left 2 !.param k=boltz\n.param q=echarge TEXT 0 -112 Left 2 !.model DMOD D(Is={Is} N={N} Rs={Rs} Eg={Eg} Tnom={Tmeas}) TEXT -248 -80 Left 2 !.OP TEXT -224 -384 Left 2 !.param I3=0.01 TEXT -224 -352 Left 2 !.param VF3=1.96 TEXT -224 -296 Left 2 !* Tempco @I1 (50uA)\n.param Tempco=-0.002 TEXT 128 -480 Left 2 ;N and Is TEXT 128 -360 Left 2 ;Rs TEXT 128 -304 Left 2 ;Eg TEXT -256 360 Left 2 !.model LED_GREEN D(Is=8.2e-25 N=1.46 Rs=5.1 Eg=2.23 Tnom={Tmeas}) TEXT -248 -112 Left 2 !.TEMP {Tmeas} TEXT -224 -568 Left 2 !.param Tmeas=25 TEXT -256 -1032 Left 2 ;Calculation Of Diode(LED) SPICE Parameters For DC. V1.1\n \nN and Is: Measure Vf at low currents e.g. 50uA and 500uA\nRs: Measure Vf at high current, e.g. 10mA\nEg: Enter temperature coefficient Tempco, e.g. -0.002 V/degree for Si, green-LED\n Typical values of Eg: Si 1.11, Sbd 0.69, Ge 0.67, In 3.0 from SCAD3-help\n \nChoose Tmeas=27deg to avoid the parameter Tnom={} in the diode model!\n \nThe blue data values in .param are measured with a green LED and \nthe active values are measured with a red LED.\n \nEnable the .step command very below to make a nice Vf(Idiode) plot. TEXT 752 -608 Left 2 ;General constants TEXT -256 312 Left 2 ;.step oct I4 10u 50m 50 TEXT 32 312 Left 2 ;Enable this line for Vf(Idiode) plot TEXT 760 -352 Left 2 !.meas Vt_ param Vt\n.meas Is_ param Is\n.meas N_ param N\n.meas Rs_ param Rs TEXT -256 264 Left 2 ;.step TEMP 25 26 TEXT -208 -624 Left 2 ;Measured Values TEXT 760 -400 Left 2 ;Results to Logfile TEXT 312 -624 Left 2 ;Calculation LINE Normal 80 -592 -256 -592 1 LINE Normal 80 -224 80 -592 1 LINE Normal -256 -224 80 -224 1 LINE Normal -256 -592 -256 -224 1 LINE Normal -256 -592 -256 -592 2 LINE Normal 112 -336 112 -384 LINE Normal 96 -336 112 -336 LINE Normal 96 -384 112 -384 LINE Normal 112 -400 112 -544 LINE Normal 96 -400 112 -400 LINE Normal 96 -544 112 -544 LINE Normal 112 -272 112 -320 LINE Normal 96 -272 112 -272 LINE Normal 96 -320 112 -320
