Information for device USBStreamer (VID=0x2752 PID=0x0016): Connection Information: ------------------------------ Device current bus speed: HighSpeed Device supports USB 1.1 specification Device supports USB 2.0 specification Device address: 0x000F Current configuration value: 0x01 Number of open pipes: 0 Device Descriptor: ------------------------------ 0x12 bLength 0x01 bDescriptorType 0x0200 bcdUSB 0xEF bDeviceClass (Miscellaneous device) 0x02 bDeviceSubClass 0x01 bDeviceProtocol 0x40 bMaxPacketSize0 (64 bytes) 0x2752 idVendor 0x0016 idProduct 0x06B3 bcdDevice 0x01 iManufacturer "miniDSP" 0x03 iProduct "USBStreamer" 0x02 iSerialNumber "00001" 0x02 bNumConfigurations Device Qualifier Descriptor: ------------------------------ 0x0A bLength 0x06 bDescriptorType 0x0200 bcdUSB 0xEF bDeviceClass (Miscellaneous device) 0x02 bDeviceSubClass 0x01 bDeviceProtocol 0x40 bMaxPacketSize0 (64 bytes) 0x02 bNumConfigurations 0x00 bReserved Configuration Descriptor: ------------------------------ 0x09 bLength 0x02 bDescriptorType 0x017D wTotalLength (381 bytes) 0x04 bNumInterfaces 0x01 bConfigurationValue 0x00 iConfiguration 0x80 bmAttributes (Bus-powered Device) 0xFA bMaxPower (500 mA) Interface Association Descriptor: ------------------------------ 0x08 bLength 0x0B bDescriptorType 0x00 bFirstInterface 0x03 bInterfaceCount 0x01 bFunctionClass (Audio Device Class) 0x00 bFunctionSubClass 0x20 bFunctionProtocol (Audio Protocol IP version 2.00) 0x00 iFunction Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x00 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x01 bInterfaceSubClass (Audio Control Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x03 iInterface "USBStreamer" AC Interface Header Descriptor: ------------------------------ 0x09 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x0200 bcdADC 0x08 bCategory (IO_BOX) 0x00A7 wTotalLength (167 bytes) 0x00 bmControls AC Clock Source Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0A bDescriptorSubtype 0x29 bClockID 0x03 bmAttributes 0x07 bmControls 0x00 bAssocTerminal 0x09 iClockSource "miniDSP Internal Clock" AC Clock Selector Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0B bDescriptorSubtype 0x28 bClockID 0x01 bNrInPins 0x29 baCSourceID(1) 0x03 bmControls 0x08 iClockSelector "miniDSP Clock Selector" AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x02 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames 0x00 bmControls 0x06 iTerminal "USBStreamer " AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0A bUnitID 0x02 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x14 bTerminalID 0x0301 wTerminalType (Speaker) 0x00 bAssocTerminal 0x0A bSourceID 0x28 bCSourceID 0x0000 bmControls 0x00 iTerminal AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bTerminalID 0x0201 wTerminalType (Microphone) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames 0x00 bmControls 0x00 iTerminal AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0B bUnitID 0x01 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x16 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x0B bSourceID 0x28 bCSourceID 0x0000 bmControls 0x07 iTerminal "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x01 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 microframes) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 microframes) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x02 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x02 bSubslotSize 0x10 bBitResolution (16 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x00D0 wMaxPacketSize (1 x 208 bytes) 0x01 bInterval (1 microframes) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 microframes) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x01 bAlternateSetting 0x01 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x16 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x82 bEndpointAddress (IN endpoint 2) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 microframes) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x03 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0xFE bInterfaceClass (Application Specific) 0x01 bInterfaceSubClass 0x01 bInterfaceProtocol 0x0A iInterface "miniDSP DFU" DFU Functional Descriptor: ------------------------------ 0x09 bLength 0x21 bDescriptorType 0x07 bmAttributes 0x00FA wDetachTimeOut (250 milliseconds) 0x0040 wTransferSize (64 bytes) 0x0110 bcdDFUVersion Configuration Descriptor: ------------------------------ 0x09 bLength 0x02 bDescriptorType 0x017D wTotalLength (381 bytes) 0x04 bNumInterfaces 0x01 bConfigurationValue 0x00 iConfiguration 0x80 bmAttributes (Bus-powered Device) 0xFA bMaxPower (500 mA) Interface Association Descriptor: ------------------------------ 0x08 bLength 0x0B bDescriptorType 0x00 bFirstInterface 0x03 bInterfaceCount 0x01 bFunctionClass (Audio Device Class) 0x00 bFunctionSubClass 0x20 bFunctionProtocol (Audio Protocol IP version 2.00) 0x00 iFunction Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x00 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x01 bInterfaceSubClass (Audio Control Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x03 iInterface "USBStreamer" AC Interface Header Descriptor: ------------------------------ 0x09 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x0200 bcdADC 0x08 bCategory (IO_BOX) 0x00A7 wTotalLength (167 bytes) 0x00 bmControls AC Clock Source Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0A bDescriptorSubtype 0x29 bClockID 0x03 bmAttributes 0x07 bmControls 0x00 bAssocTerminal 0x09 iClockSource "miniDSP Internal Clock" AC Clock Selector Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0B bDescriptorSubtype 0x28 bClockID 0x01 bNrInPins 0x29 baCSourceID(1) 0x03 bmControls 0x08 iClockSelector "miniDSP Clock Selector" AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x02 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames 0x00 bmControls 0x06 iTerminal "USBStreamer " AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0A bUnitID 0x02 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x14 bTerminalID 0x0301 wTerminalType (Speaker) 0x00 bAssocTerminal 0x0A bSourceID 0x28 bCSourceID 0x0000 bmControls 0x00 iTerminal AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bTerminalID 0x0201 wTerminalType (Microphone) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames 0x00 bmControls 0x00 iTerminal AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0B bUnitID 0x01 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x16 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x0B bSourceID 0x28 bCSourceID 0x0000 bmControls 0x07 iTerminal "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x01 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 microframes) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 microframes) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x02 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x02 bSubslotSize 0x10 bBitResolution (16 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x00D0 wMaxPacketSize (1 x 208 bytes) 0x01 bInterval (1 microframes) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 microframes) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x01 bAlternateSetting 0x01 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x16 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x82 bEndpointAddress (IN endpoint 2) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 microframes) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x03 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0xFE bInterfaceClass (Application Specific) 0x01 bInterfaceSubClass 0x01 bInterfaceProtocol 0x0A iInterface "miniDSP DFU" DFU Functional Descriptor: ------------------------------ 0x09 bLength 0x21 bDescriptorType 0x07 bmAttributes 0x00FA wDetachTimeOut (250 milliseconds) 0x0040 wTransferSize (64 bytes) 0x0110 bcdDFUVersion ------------------------------ Other Speed Configuration Descriptor: ------------------------------ 0x09 bLength 0x07 bDescriptorType 0x017D wTotalLength (381 bytes) 0x04 bNumInterfaces 0x01 bConfigurationValue 0x00 iConfiguration 0x80 bmAttributes (Bus-powered Device) 0xFA bMaxPower (500 mA) Interface Association Descriptor: ------------------------------ 0x08 bLength 0x0B bDescriptorType 0x00 bFirstInterface 0x03 bInterfaceCount 0x01 bFunctionClass (Audio Device Class) 0x00 bFunctionSubClass 0x20 bFunctionProtocol (Audio Protocol IP version 2.00) 0x00 iFunction Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x00 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x01 bInterfaceSubClass (Audio Control Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x03 iInterface "USBStreamer" AC Interface Header Descriptor: ------------------------------ 0x09 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x0200 bcdADC 0x08 bCategory (IO_BOX) 0x00A7 wTotalLength (167 bytes) 0x00 bmControls AC Clock Source Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0A bDescriptorSubtype 0x29 bClockID 0x03 bmAttributes 0x07 bmControls 0x00 bAssocTerminal 0x09 iClockSource "miniDSP Internal Clock" AC Clock Selector Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0B bDescriptorSubtype 0x28 bClockID 0x01 bNrInPins 0x29 baCSourceID(1) 0x03 bmControls 0x08 iClockSelector "miniDSP Clock Selector" AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x02 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames 0x00 bmControls 0x06 iTerminal "USBStreamer " AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0A bUnitID 0x02 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x14 bTerminalID 0x0301 wTerminalType (Speaker) 0x00 bAssocTerminal 0x0A bSourceID 0x28 bCSourceID 0x0000 bmControls 0x00 iTerminal AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bTerminalID 0x0201 wTerminalType (Microphone) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames 0x00 bmControls 0x00 iTerminal AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0B bUnitID 0x01 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x16 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x0B bSourceID 0x28 bCSourceID 0x0000 bmControls 0x07 iTerminal "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x01 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 frames) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 frames) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x02 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x02 bSubslotSize 0x10 bBitResolution (16 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x00D0 wMaxPacketSize (1 x 208 bytes) 0x01 bInterval (1 frames) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 frames) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x01 bAlternateSetting 0x01 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x16 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x82 bEndpointAddress (IN endpoint 2) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 frames) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x03 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0xFE bInterfaceClass (Application Specific) 0x01 bInterfaceSubClass 0x01 bInterfaceProtocol 0x0A iInterface "miniDSP DFU" DFU Functional Descriptor: ------------------------------ 0x09 bLength 0x21 bDescriptorType 0x07 bmAttributes 0x00FA wDetachTimeOut (250 milliseconds) 0x0040 wTransferSize (64 bytes) 0x0110 bcdDFUVersion ------------------------------ Other Speed Configuration Descriptor: ------------------------------ 0x09 bLength 0x07 bDescriptorType 0x017D wTotalLength (381 bytes) 0x04 bNumInterfaces 0x01 bConfigurationValue 0x00 iConfiguration 0x80 bmAttributes (Bus-powered Device) 0xFA bMaxPower (500 mA) Interface Association Descriptor: ------------------------------ 0x08 bLength 0x0B bDescriptorType 0x00 bFirstInterface 0x03 bInterfaceCount 0x01 bFunctionClass (Audio Device Class) 0x00 bFunctionSubClass 0x20 bFunctionProtocol (Audio Protocol IP version 2.00) 0x00 iFunction Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x00 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x01 bInterfaceSubClass (Audio Control Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x03 iInterface "USBStreamer" AC Interface Header Descriptor: ------------------------------ 0x09 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x0200 bcdADC 0x08 bCategory (IO_BOX) 0x00A7 wTotalLength (167 bytes) 0x00 bmControls AC Clock Source Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0A bDescriptorSubtype 0x29 bClockID 0x03 bmAttributes 0x07 bmControls 0x00 bAssocTerminal 0x09 iClockSource "miniDSP Internal Clock" AC Clock Selector Descriptor: ------------------------------ 0x08 bLength 0x24 bDescriptorType 0x0B bDescriptorSubtype 0x28 bClockID 0x01 bNrInPins 0x29 baCSourceID(1) 0x03 bmControls 0x08 iClockSelector "miniDSP Clock Selector" AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x02 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames 0x00 bmControls 0x06 iTerminal "USBStreamer " AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0A bUnitID 0x02 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x14 bTerminalID 0x0301 wTerminalType (Speaker) 0x00 bAssocTerminal 0x0A bSourceID 0x28 bCSourceID 0x0000 bmControls 0x00 iTerminal AC Input Terminal Descriptor: ------------------------------ 0x11 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bTerminalID 0x0201 wTerminalType (Microphone) 0x00 bAssocTerminal 0x28 bCSourceID 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames 0x00 bmControls 0x00 iTerminal AC Feature Unit Descriptor: ------------------------------ 0x2A bLength 0x24 bDescriptorType 0x06 bDescriptorSubtype 0x0B bUnitID 0x01 bSourceID 0x0000000F bmaControls(0) 0x0000000F bmaControls(1) 0x0000000F bmaControls(2) 0x0000000F bmaControls(3) 0x0000000F bmaControls(4) 0x0000000F bmaControls(5) 0x0000000F bmaControls(6) 0x0000000F bmaControls(7) 0x0000000F bmaControls(8) 0x00 iFeature AC Output Terminal Descriptor: ------------------------------ 0x0C bLength 0x24 bDescriptorType 0x03 bDescriptorSubtype 0x16 bTerminalID 0x0101 wTerminalType (USB Streaming) 0x00 bAssocTerminal 0x0B bSourceID 0x28 bCSourceID 0x0000 bmControls 0x07 iTerminal "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x01 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 frames) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 frames) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x01 bInterfaceNumber 0x02 bAlternateSetting 0x02 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x04 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x02 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x0B iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x02 bSubslotSize 0x10 bBitResolution (16 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x01 bEndpointAddress (OUT endpoint 1) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x00D0 wMaxPacketSize (1 x 208 bytes) 0x01 bInterval (1 frames) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x81 bEndpointAddress (IN endpoint 1) 0x11 bmAttributes (Transfer: Isochronous / Synch: None / Usage: Feedback) 0x0004 wMaxPacketSize (1 x 4 bytes) 0x04 bInterval (8 frames) Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x02 bInterfaceNumber 0x01 bAlternateSetting 0x01 bNumEndPoints 0x01 bInterfaceClass (Audio Device Class) 0x02 bInterfaceSubClass (Audio Streaming Interface) 0x20 bInterfaceProtocol (Audio Protocol IP version 2.00) 0x05 iInterface "USBStreamer " AS Interface Descriptor: ------------------------------ 0x10 bLength 0x24 bDescriptorType 0x01 bDescriptorSubtype 0x16 bTerminalLink 0x00 bmControls 0x01 bFormatType (FORMAT_TYPE_1) 0x00000001 bmFormats 0x08 bNrChannels (8 channels) 0x00000000 bmChannelConfig 0x13 iChannelNames AS Format Type 1 Descriptor: ------------------------------ 0x06 bLength 0x24 bDescriptorType 0x02 bDescriptorSubtype 0x01 bFormatType (FORMAT_TYPE_1) 0x04 bSubslotSize 0x18 bBitResolution (24 bits per sample) Endpoint Descriptor: ------------------------------ 0x07 bLength 0x05 bDescriptorType 0x82 bEndpointAddress (IN endpoint 2) 0x05 bmAttributes (Transfer: Isochronous / Synch: Asynchronous / Usage: Data) 0x01A0 wMaxPacketSize (1 x 416 bytes) 0x01 bInterval (1 frames) AS Isochronous Data Endpoint Descriptor: ------------------------------ 0x08 bLength 0x25 bDescriptorType 0x01 bDescriptorSubtype 0x00 bmAttributes 0x00 bmControls 0x02 bLockDelayUnits (decoded PCM samples) 0x0008 wLockDelay Interface Descriptor: ------------------------------ 0x09 bLength 0x04 bDescriptorType 0x03 bInterfaceNumber 0x00 bAlternateSetting 0x00 bNumEndPoints 0xFE bInterfaceClass (Application Specific) 0x01 bInterfaceSubClass 0x01 bInterfaceProtocol 0x0A iInterface "miniDSP DFU" DFU Functional Descriptor: ------------------------------ 0x09 bLength 0x21 bDescriptorType 0x07 bmAttributes 0x00FA wDetachTimeOut (250 milliseconds) 0x0040 wTransferSize (64 bytes) 0x0110 bcdDFUVersion Microsoft OS Descriptor is not available. Error code: 0x0000001F String Descriptor Table -------------------------------- Index LANGID String 0x00 0x0000 0x0409 0x01 0x0409 "miniDSP" 0x03 0x0409 "USBStreamer" 0x02 0x0409 "00001" 0x09 0x0409 "miniDSP Internal Clock" 0x08 0x0409 "miniDSP Clock Selector" 0x0B 0x0409 "I2S Ch 1" 0x0C 0x0409 "I2S Ch 2" 0x0D 0x0409 "I2S Ch 3" 0x0E 0x0409 "I2S Ch 4" 0x0F 0x0409 "I2S Ch 5" 0x10 0x0409 "I2S Ch 6" 0x11 0x0409 "I2S Ch 7" 0x12 0x0409 "I2S Ch 8" 0x06 0x0409 "USBStreamer " 0x13 0x0409 "I2S Ch 1" 0x14 0x0409 "I2S Ch 2" 0x15 0x0409 "I2S Ch 3" 0x16 0x0409 "I2S Ch 4" 0x17 0x0409 "I2S Ch 5" 0x18 0x0409 "I2S Ch 6" 0x19 0x0409 "I2S Ch 7" 0x1A 0x0409 "I2S Ch 8" 0x07 0x0409 "USBStreamer " 0x04 0x0409 "USBStreamer " 0x05 0x0409 "USBStreamer " 0x0A 0x0409 "miniDSP DFU" ------------------------------ Connection path for device: USB-xHCI-kompatibler Hostcontroller Root Hub Generischer USB-Hub USBStreamer (VID=0x2752 PID=0x0016) Port: 2 Running on: Windows 10 or greater (Build Version 18362) Brought to you by TDD v2.12.0, Aug 2 2019, 16:35:05
