ESP8266 MCU Modules
<br><br>
<author>Mr.AtiX, CroNet</author>
ESP8266 Module, ESP-09<p>
>Name
>Value
ESP8266 Module, ESP-10<p>
ESP-10
>Name
>Value
ESP8266 Module, ESP-04<p>
ESP-04
>Name
>Value
ESP8266 Module, ESP-12E<p>
>NAME
>VALUE
>VALUE
>NAME
ESP8266 Module, ESP-01<p>
Antenna
>NAME
>VALUE
ESP8266 Module, ESP-12E, THT version<p>
>VALUE
>NAME
ESP8266 Module, ESP-11<p>
>Name
ESP-11
>VALUE
>NAME
ESP8266 Module, ESP-08, 14 pin version<p>
ESP-08
>Name
>Value
ESP8266 Adapter, SIP header 0.1", 32mil drill<p>
for ESP-07, ESP-12 and similar.<p>
>VALUE
RST
ADC
CH_PD
GPIO16
GPIO14
GPIO12
GPIO13
VCC
TXD
RXD
GPIO5
GPIO4
GPIO0
GPIO2
GPIO15
GND
Antenna
ESP8266 Module, ESP-12EQ<p>
>VALUE
>NAME
>NAME
>VALUE
ESP8266 Module, ESP-01S with I2C<p>
Antenna
>NAME
>VALUE
ESP8266 Module, ESP-02<p>
ESP-02
>Value
>Name
Wemos D1 mini, ESP8266 Module, ESP-12<p>
>NAME
RST
A0
D0
D5
D6
D7
D8
3V3
5V
GND
D4
D3
D2
D1
RX
TX
Antenna
keep clear
microUSB
Reset
>VALUE
ESP8266 Module, ESP-03<p>
ESP-03
>Name
>Value
ESP8266 Module, ESP-06<p>
ESP-06
>Value
>Name
ESP8266 Module, ESP-05, 5 pin version<p>
ESP-05
>Name
>Value
ESP8266 Module, ESP-01/S, ESP-07, ESP-12<p>
double Breakout aka Goofy Adapter<p>
Antenna
>NAME
>VALUE
ESP12E_DEVKIT
AD0
RSV
RSV
SD3
SD2
SD1
CMD
SD0
CLK
GND
3V3
EN
RST
GND
VIN
3V3
GND
TX
RX
~D8
~D7
~D6
~D5
GND
3V3
~D4
~D3
~D2
~D1
D0
>NAME
>VALUE
>NAME
Antenna
keep clear
>VALUE
RST
A0
D0
D5
D6
D7
D8
3V3
5V
GND
D4
D3
D2
D1
RX
TX
A0
GND
VV
S3
S2
S1
SC
S0
SK
GND
3V3
EN
RST
GND
VIN
3V3
GND
TX
RX
D8
D7
D6
D5
GND
3V3
D4
D3
D2
D1
D0
RST
FLASH
>VALUE
>NAME
ESP8266 Module, ESP-07S<br>
with Thermalpad<br><br>
>VALUE
>NAME
with Groundpad<br><br>
>VALUE
>NAME
>NAME
>VALUE
>VALUE
>NAME
ESP8266 Module ESP-03 / ESP-04
>VALUE
>NAME
ESP8266-12
>NAME
>VALUE
ESP8266, ESP-01/S<p>
>NAME
>VALUE
>NAME
>VALUE
ESP8266-12E Module
>NAME
>VALUE
ESP8266 Module ESP-07/08 - 14 pins
>NAME
>VALUE
>NAME
>VALUE
<b>ESP8266 Adapterboard</b><p>
for ESP8266-07, ESP8266-12 and other 8+8 pins.<p>
The adapter has ingegrated 10k pullup on CH_PD/EN and 10k pulldown on GPIO15. Both can be leave unconnected.<p>
On the bottom side is place for a SOT-89 voltage regulator. Default is disabled, bridged with 0R resistor (remove it).<p><br>
The author cannot warrant that this library is free from error or will meet your specific requirements.<p>
<author>Mr.AtiX, CroNet</author>.
>VALUE
>NAME
ESP8266, ESP-01S_MOD, with GPIO4+5<p>
>NAME
>VALUE
>NAME
>VALUE
>VALUE
>NAME
on double breakout aka Goofy Adapter<p>
ESP-GOOFY
>NAME
>VALUE
ESP12E_DEVKIT
>NAME
>VALUE
>VALUE
>NAME
>NAME
>VALUE
ESP8266 Module ESP-07 - 16 pins
>NAME
>VALUE
ESP8266 Wifi module ESP-09
ESP8266 Wifi module ESP-10
ESP8266 Wifi module ESP-04
ESP8266 Wifi module ESP-01 512kB/1M<p>
ESP8266 Wifi module ESP-11
ESP8266 Wifi module ESP-12 4MB (32Mb)
ESP8266 Wifi module ESP-08
<b>ESP8266 Adapterplate</b><p>
for ESP-07, ESP-12 and other 2x8 pins.<p><br>
The adapter have ingegrated 10k pullup on CH_PD/EN and 10k pulldown on GPIO15. Leave both pins non-connected on the pcb.<br>
On the bottom side is place for a SOT-89 voltage regulator. Default is disabled, while bridged with the 0R resistor (remove it!).<br>
<br><br>
ESP-12E Module 4MB (32Mb), with long SPI Pads, fixed GPIO4/5<p>
<b>ESP8266-01S *MOD*, with additional I/O</b><p>
with deepsleep (RST-GPIO16 connect)<p>
additional I2C pins (GPIO4+GPIO5)<br><p>
ESP8266 Wifi module ESP-02
ESP8266 Wifi module ESP-03
ESP8266 Wifi module ESP-06
ESP8266 Wifi module ESP-05 - 5pin
<b>ESP8266 Module</b>, ESP-01, ESP-07, ESP-12<p>
double breakout aka Goofy Adapter.<br>
Integrated is a pulldown on IO15.<br>
Optional a red SMD LED (on TX/IO1 line) and a blue (on IO2) can be soldered.<br>
IO16 for deep sleep is not out, but can simply direct on the module soldered.<br>
The external connector for the breakout is a HDR-2x07 2.54mm.
<br><br>
ESP12E DEVKIT BOARD/ Module
ESP8266 Wifi module ESP-07 1MB (8Mb)
Since Version 6.2.2 text objects can contain more than one line,
which will not be processed correctly with this version.
