Version 4 SHEET 1 1464 680 WIRE 208 -592 96 -592 WIRE 96 -560 96 -592 WIRE 208 -560 208 -592 WIRE 208 -384 96 -384 WIRE 96 -352 96 -384 WIRE 208 -352 208 -384 FLAG 96 -480 0 FLAG 96 -272 0 FLAG 208 -480 0 FLAG 208 -272 0 FLAG 208 -592 VoV_1 IOPIN 208 -592 Out FLAG 208 -384 VoI_1 IOPIN 208 -384 Out SYMBOL current 96 -272 R180 WINDOW 0 24 80 Left 2 WINDOW 3 24 0 Left 2 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName I1 SYMATTR Value 1 SYMBOL voltage 96 -576 R0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName V1 SYMATTR Value 1 SYMBOL res 192 -576 R0 WINDOW 3 36 52 Left 2 SYMATTR InstName Rout_1 SYMATTR Value 1 tc= 0.1, 0.01, SYMBOL res 192 -368 R0 WINDOW 3 36 52 Left 2 SYMATTR InstName Rout_2 SYMATTR Value 1 tc= 0.1, 0.01, TEXT 112 -424 Left 2 !.DC temp -20 150 0.1 TEXT 352 -616 Left 2 ;; Globale Temp für alle Devices \n.TEMP 40\n \n;global temp from\n.STEP temp -20 150 0.1\n \n; local temp attached to device\n1Ohm, tc=2ppm, Temp=150 °C\n \nDevise 1Ohm at 27 °C (default temp LTSPICE) \nR is a temp coef of tc=2ppm.\ntemp R is set 150 °C.\n \n \nR, C, L Q, M\nSyntax: Rxxx n1 n2 [tc=tc1, tc2, ...] [temp=] TEXT 40 -664 Left 2 ;LTspice Temperaturen simulieren\nhttps://www.mikrocontroller.net/topic/489275#new RECTANGLE Normal 304 -432 32 -624 2 RECTANGLE Normal 304 -224 32 -416 2
