This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by avr-libc configure 2.0.0svn, which was generated by GNU Autoconf 2.69. Invocation command line was $ ../../downloads/avr-libc/configure --prefix=/home/ubuntixer/local/avrLinux64/ --host=avr --build= ## --------- ## ## Platform. ## ## --------- ## hostname = ubuntu uname -m = x86_64 uname -r = 5.3.0-42-generic uname -s = Linux uname -v = #34~18.04.1-Ubuntu SMP Fri Feb 28 13:42:26 UTC 2020 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /usr/local/sbin PATH: /usr/local/bin PATH: /usr/sbin PATH: /usr/bin PATH: /sbin PATH: /bin PATH: /usr/games PATH: /usr/local/games PATH: /snap/bin PATH: /home/ubuntixer/local/avrLinux64//bin/ ## ----------- ## ## Core tests. ## ## ----------- ## configure:2516: checking build system type configure:2530: result: x86_64-pc-linux-gnu configure:2550: checking host system type configure:2563: result: avr-unknown-none configure:2587: checking if configuring for cross compile configure:2607: result: yes configure:2611: checking if target host is avr configure:2615: result: yes configure:2655: checking for a BSD-compatible install configure:2723: result: /usr/bin/install -c configure:2734: checking whether build environment is sane configure:2789: result: yes configure:2848: checking for avr-strip configure:2878: result: no configure:2888: checking for strip configure:2904: found /usr/bin/strip configure:2915: result: strip configure:2940: checking for a thread-safe mkdir -p configure:2979: result: /bin/mkdir -p configure:2986: checking for gawk configure:3016: result: no configure:2986: checking for mawk configure:3002: found /usr/bin/mawk configure:3013: result: mawk configure:3024: checking whether make sets $(MAKE) configure:3046: result: yes configure:3075: checking whether make supports nested variables configure:3092: result: yes configure:3237: checking for avr-gcc configure:3253: found /home/ubuntixer/local/avrLinux64//bin//avr-gcc configure:3264: result: avr-gcc configure:3533: checking for C compiler version configure:3542: avr-gcc --version >&5 avr-gcc (GCC) 10.0.1 20200315 (experimental) Copyright (C) 2020 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:3553: $? = 0 configure:3542: avr-gcc -v >&5 Using built-in specs. Reading specs from /home/ubuntixer/local/avrLinux64/lib/gcc/avr/10.0.1/device-specs/specs-avr2 COLLECT_GCC=avr-gcc COLLECT_LTO_WRAPPER=/home/ubuntixer/local/avrLinux64/libexec/gcc/avr/10.0.1/lto-wrapper Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrLinux64/ --target=avr --enable-languages=c,c++,lto --disable-nls --disable-libssp --with-dwarf2 --build=x86_64-linux-gnu --host=x86_64-linux-gnu --disable-shared --enable-checking=release Thread model: single Supported LTO compression algorithms: zlib gcc version 10.0.1 20200315 (experimental) (GCC) configure:3553: $? = 0 configure:3542: avr-gcc -V >&5 avr-gcc: error: unrecognized command-line option '-V' avr-gcc: fatal error: no input files compilation terminated. configure:3553: $? = 1 configure:3542: avr-gcc -qversion >&5 avr-gcc: error: unrecognized command-line option '-qversion'; did you mean '--version'? avr-gcc: fatal error: no input files compilation terminated. configure:3553: $? = 1 configure:3573: avr-gcc -o conftest conftest.c >&5 as: unrecognized option '-mmcu=avr2' configure:3577: $? = 1 configure:3790: checking whether we are cross compiling configure:3828: result: yes configure:3832: checking for suffix of object files configure:3854: avr-gcc -c conftest.c >&5 as: unrecognized option '-mmcu=avr2' configure:3858: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "avr-libc" | #define PACKAGE_TARNAME "avr-libc" | #define PACKAGE_VERSION "2.0.0svn" | #define PACKAGE_STRING "avr-libc 2.0.0svn" | #define PACKAGE_BUGREPORT "avr-libc-dev@nongnu.org" | #define PACKAGE_URL "" | #define PACKAGE "avr-libc" | #define VERSION "2.0.0svn" | /* end confdefs.h. */ | | int | main () | { | | ; | return 0; | } configure:3872: error: in `/home/ubuntixer/toolchain/buildLinux/avr-libc': configure:3874: error: cannot compute suffix of object files: cannot compile See `config.log' for more details ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_build=x86_64-pc-linux-gnu ac_cv_env_CCASFLAGS_set= ac_cv_env_CCASFLAGS_value= ac_cv_env_CCAS_set= ac_cv_env_CCAS_value= ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_LIBS_set= ac_cv_env_LIBS_value= ac_cv_env_build_alias_set=set ac_cv_env_build_alias_value= ac_cv_env_host_alias_set=set ac_cv_env_host_alias_value=avr ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_host=avr-unknown-none ac_cv_path_install='/usr/bin/install -c' ac_cv_path_mkdir=/bin/mkdir ac_cv_prog_AWK=mawk ac_cv_prog_CC=avr-gcc ac_cv_prog_ac_ct_STRIP=strip ac_cv_prog_make_make_set=yes am_cv_make_support_nested_variables=yes ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /home/ubuntixer/toolchain/downloads/avr-libc/missing aclocal-1.15' AMDEPBACKSLASH='' AMDEP_FALSE='' AMDEP_TRUE='' AMTAR='$${TAR-tar}' AM_BACKSLASH='\' AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)' AM_DEFAULT_VERBOSITY='1' AM_V='$(V)' AR='' AS='' ASDEBUG='' AUTOCONF='${SHELL} /home/ubuntixer/toolchain/downloads/avr-libc/missing autoconf' AUTOHEADER='${SHELL} /home/ubuntixer/toolchain/downloads/avr-libc/missing autoheader' AUTOMAKE='${SHELL} /home/ubuntixer/toolchain/downloads/avr-libc/missing automake-1.15' AVR_LIBC_MAJOR='2' AVR_LIBC_MINOR='0' AVR_LIBC_RELDATE='20150209' AVR_LIBC_REVISION='0' AVR_LIBC_USER_MANUAL='' AVR_LIBC_VERSION='2.0.0svn' AVR_LIBC_VERSION_NUMERIC='20000' AWK='mawk' CC='avr-gcc' CCAS='' CCASDEPMODE='' CCASFLAGS='' CCDEPMODE='' CDEBUG='' CFLAGS='' CPPFLAGS='' CYGPATH_W='echo' DEFS='' DEPDIR='' DOCSDIR='' DOC_INST_DIR='' ECHO_C='' ECHO_N='-n' ECHO_T='' EXEEXT='' FNO_JUMP_TABLES='' HAS_DELAY_CYCLES='' HAS_DEV_LIB_FALSE='' HAS_DEV_LIB_TRUE='' HAS_GCC_5_1_FALSE='' HAS_GCC_5_1_TRUE='' HAS_at43usb320_FALSE='' HAS_at43usb320_TRUE='' HAS_at43usb355_FALSE='' HAS_at43usb355_TRUE='' HAS_at76c711_FALSE='' HAS_at76c711_TRUE='' HAS_at86rf401_FALSE='' HAS_at86rf401_TRUE='' HAS_at90c8534_FALSE='' HAS_at90c8534_TRUE='' HAS_at90can128_FALSE='' HAS_at90can128_TRUE='' HAS_at90can32_FALSE='' HAS_at90can32_TRUE='' HAS_at90can64_FALSE='' HAS_at90can64_TRUE='' HAS_at90pwm161_FALSE='' HAS_at90pwm161_TRUE='' HAS_at90pwm1_FALSE='' HAS_at90pwm1_TRUE='' HAS_at90pwm216_FALSE='' HAS_at90pwm216_TRUE='' HAS_at90pwm2_FALSE='' HAS_at90pwm2_TRUE='' HAS_at90pwm2b_FALSE='' HAS_at90pwm2b_TRUE='' HAS_at90pwm316_FALSE='' HAS_at90pwm316_TRUE='' HAS_at90pwm3_FALSE='' HAS_at90pwm3_TRUE='' HAS_at90pwm3b_FALSE='' HAS_at90pwm3b_TRUE='' HAS_at90pwm81_FALSE='' HAS_at90pwm81_TRUE='' HAS_at90s1200_FALSE='' HAS_at90s1200_TRUE='' HAS_at90s2313_FALSE='' HAS_at90s2313_TRUE='' HAS_at90s2323_FALSE='' HAS_at90s2323_TRUE='' HAS_at90s2333_FALSE='' HAS_at90s2333_TRUE='' HAS_at90s2343_FALSE='' HAS_at90s2343_TRUE='' HAS_at90s4414_FALSE='' HAS_at90s4414_TRUE='' HAS_at90s4433_FALSE='' HAS_at90s4433_TRUE='' HAS_at90s4434_FALSE='' HAS_at90s4434_TRUE='' HAS_at90s8515_FALSE='' HAS_at90s8515_TRUE='' HAS_at90s8535_FALSE='' HAS_at90s8535_TRUE='' HAS_at90scr100_FALSE='' HAS_at90scr100_TRUE='' HAS_at90usb1286_FALSE='' HAS_at90usb1286_TRUE='' HAS_at90usb1287_FALSE='' HAS_at90usb1287_TRUE='' HAS_at90usb162_FALSE='' HAS_at90usb162_TRUE='' HAS_at90usb646_FALSE='' HAS_at90usb646_TRUE='' HAS_at90usb647_FALSE='' HAS_at90usb647_TRUE='' HAS_at90usb82_FALSE='' HAS_at90usb82_TRUE='' HAS_at94k_FALSE='' HAS_at94k_TRUE='' HAS_ata5272_FALSE='' HAS_ata5272_TRUE='' HAS_ata5505_FALSE='' HAS_ata5505_TRUE='' HAS_ata5702m322_FALSE='' HAS_ata5702m322_TRUE='' HAS_ata5782_FALSE='' HAS_ata5782_TRUE='' HAS_ata5790_FALSE='' HAS_ata5790_TRUE='' HAS_ata5790n_FALSE='' HAS_ata5790n_TRUE='' HAS_ata5795_FALSE='' HAS_ata5795_TRUE='' HAS_ata5831_FALSE='' HAS_ata5831_TRUE='' HAS_ata6285_FALSE='' HAS_ata6285_TRUE='' HAS_ata6286_FALSE='' HAS_ata6286_TRUE='' HAS_ata6289_FALSE='' HAS_ata6289_TRUE='' HAS_ata6612c_FALSE='' HAS_ata6612c_TRUE='' HAS_ata6613c_FALSE='' HAS_ata6613c_TRUE='' HAS_ata6614q_FALSE='' HAS_ata6614q_TRUE='' HAS_ata6616c_FALSE='' HAS_ata6616c_TRUE='' HAS_ata6617c_FALSE='' HAS_ata6617c_TRUE='' HAS_ata664251_FALSE='' HAS_ata664251_TRUE='' HAS_atmega103_FALSE='' HAS_atmega103_TRUE='' HAS_atmega1280_FALSE='' HAS_atmega1280_TRUE='' HAS_atmega1281_FALSE='' HAS_atmega1281_TRUE='' HAS_atmega1284_FALSE='' HAS_atmega1284_TRUE='' HAS_atmega1284p_FALSE='' HAS_atmega1284p_TRUE='' HAS_atmega1284rfr2_FALSE='' HAS_atmega1284rfr2_TRUE='' HAS_atmega128_FALSE='' HAS_atmega128_TRUE='' HAS_atmega128a_FALSE='' HAS_atmega128a_TRUE='' HAS_atmega128rfa1_FALSE='' HAS_atmega128rfa1_TRUE='' HAS_atmega128rfr2_FALSE='' HAS_atmega128rfr2_TRUE='' HAS_atmega161_FALSE='' HAS_atmega161_TRUE='' HAS_atmega162_FALSE='' HAS_atmega162_TRUE='' HAS_atmega163_FALSE='' HAS_atmega163_TRUE='' HAS_atmega164a_FALSE='' HAS_atmega164a_TRUE='' HAS_atmega164p_FALSE='' HAS_atmega164p_TRUE='' HAS_atmega164pa_FALSE='' HAS_atmega164pa_TRUE='' HAS_atmega165_FALSE='' HAS_atmega165_TRUE='' HAS_atmega165a_FALSE='' HAS_atmega165a_TRUE='' HAS_atmega165p_FALSE='' HAS_atmega165p_TRUE='' HAS_atmega165pa_FALSE='' HAS_atmega165pa_TRUE='' HAS_atmega168_FALSE='' HAS_atmega168_TRUE='' HAS_atmega168a_FALSE='' HAS_atmega168a_TRUE='' HAS_atmega168p_FALSE='' HAS_atmega168p_TRUE='' HAS_atmega168pa_FALSE='' HAS_atmega168pa_TRUE='' HAS_atmega169_FALSE='' HAS_atmega169_TRUE='' HAS_atmega169a_FALSE='' HAS_atmega169a_TRUE='' HAS_atmega169p_FALSE='' HAS_atmega169p_TRUE='' HAS_atmega169pa_FALSE='' HAS_atmega169pa_TRUE='' HAS_atmega16_FALSE='' HAS_atmega16_TRUE='' HAS_atmega16a_FALSE='' HAS_atmega16a_TRUE='' HAS_atmega16hva2_FALSE='' HAS_atmega16hva2_TRUE='' HAS_atmega16hva_FALSE='' HAS_atmega16hva_TRUE='' HAS_atmega16hvb_FALSE='' HAS_atmega16hvb_TRUE='' HAS_atmega16hvbrevb_FALSE='' HAS_atmega16hvbrevb_TRUE='' HAS_atmega16m1_FALSE='' HAS_atmega16m1_TRUE='' HAS_atmega16u2_FALSE='' HAS_atmega16u2_TRUE='' HAS_atmega16u4_FALSE='' HAS_atmega16u4_TRUE='' HAS_atmega2560_FALSE='' HAS_atmega2560_TRUE='' HAS_atmega2561_FALSE='' HAS_atmega2561_TRUE='' HAS_atmega2564rfr2_FALSE='' HAS_atmega2564rfr2_TRUE='' HAS_atmega256rfr2_FALSE='' HAS_atmega256rfr2_TRUE='' HAS_atmega323_FALSE='' HAS_atmega323_TRUE='' HAS_atmega324a_FALSE='' HAS_atmega324a_TRUE='' HAS_atmega324p_FALSE='' HAS_atmega324p_TRUE='' HAS_atmega324pa_FALSE='' HAS_atmega324pa_TRUE='' HAS_atmega3250_FALSE='' HAS_atmega3250_TRUE='' HAS_atmega3250a_FALSE='' HAS_atmega3250a_TRUE='' HAS_atmega3250p_FALSE='' HAS_atmega3250p_TRUE='' HAS_atmega3250pa_FALSE='' HAS_atmega3250pa_TRUE='' HAS_atmega325_FALSE='' HAS_atmega325_TRUE='' HAS_atmega325a_FALSE='' HAS_atmega325a_TRUE='' HAS_atmega325p_FALSE='' HAS_atmega325p_TRUE='' HAS_atmega325pa_FALSE='' HAS_atmega325pa_TRUE='' HAS_atmega328_FALSE='' HAS_atmega328_TRUE='' HAS_atmega328p_FALSE='' HAS_atmega328p_TRUE='' HAS_atmega3290_FALSE='' HAS_atmega3290_TRUE='' HAS_atmega3290a_FALSE='' HAS_atmega3290a_TRUE='' HAS_atmega3290p_FALSE='' HAS_atmega3290p_TRUE='' HAS_atmega3290pa_FALSE='' HAS_atmega3290pa_TRUE='' HAS_atmega329_FALSE='' HAS_atmega329_TRUE='' HAS_atmega329a_FALSE='' HAS_atmega329a_TRUE='' HAS_atmega329p_FALSE='' HAS_atmega329p_TRUE='' HAS_atmega329pa_FALSE='' HAS_atmega329pa_TRUE='' HAS_atmega32_FALSE='' HAS_atmega32_TRUE='' HAS_atmega32a_FALSE='' HAS_atmega32a_TRUE='' HAS_atmega32c1_FALSE='' HAS_atmega32c1_TRUE='' HAS_atmega32hvb_FALSE='' HAS_atmega32hvb_TRUE='' HAS_atmega32hvbrevb_FALSE='' HAS_atmega32hvbrevb_TRUE='' HAS_atmega32m1_FALSE='' HAS_atmega32m1_TRUE='' HAS_atmega32u2_FALSE='' HAS_atmega32u2_TRUE='' HAS_atmega32u4_FALSE='' HAS_atmega32u4_TRUE='' HAS_atmega32u6_FALSE='' HAS_atmega32u6_TRUE='' HAS_atmega406_FALSE='' HAS_atmega406_TRUE='' HAS_atmega48_FALSE='' HAS_atmega48_TRUE='' HAS_atmega48a_FALSE='' HAS_atmega48a_TRUE='' HAS_atmega48p_FALSE='' HAS_atmega48p_TRUE='' HAS_atmega48pa_FALSE='' HAS_atmega48pa_TRUE='' HAS_atmega48pb_FALSE='' HAS_atmega48pb_TRUE='' HAS_atmega640_FALSE='' HAS_atmega640_TRUE='' HAS_atmega644_FALSE='' HAS_atmega644_TRUE='' HAS_atmega644a_FALSE='' HAS_atmega644a_TRUE='' HAS_atmega644p_FALSE='' HAS_atmega644p_TRUE='' HAS_atmega644pa_FALSE='' HAS_atmega644pa_TRUE='' HAS_atmega644rfr2_FALSE='' HAS_atmega644rfr2_TRUE='' HAS_atmega6450_FALSE='' HAS_atmega6450_TRUE='' HAS_atmega6450a_FALSE='' HAS_atmega6450a_TRUE='' HAS_atmega6450p_FALSE='' HAS_atmega6450p_TRUE='' HAS_atmega645_FALSE='' HAS_atmega645_TRUE='' HAS_atmega645a_FALSE='' HAS_atmega645a_TRUE='' HAS_atmega645p_FALSE='' HAS_atmega645p_TRUE='' HAS_atmega6490_FALSE='' HAS_atmega6490_TRUE='' HAS_atmega6490a_FALSE='' HAS_atmega6490a_TRUE='' HAS_atmega6490p_FALSE='' HAS_atmega6490p_TRUE='' HAS_atmega649_FALSE='' HAS_atmega649_TRUE='' HAS_atmega649a_FALSE='' HAS_atmega649a_TRUE='' HAS_atmega649p_FALSE='' HAS_atmega649p_TRUE='' HAS_atmega64_FALSE='' HAS_atmega64_TRUE='' HAS_atmega64a_FALSE='' HAS_atmega64a_TRUE='' HAS_atmega64c1_FALSE='' HAS_atmega64c1_TRUE='' HAS_atmega64hve2_FALSE='' HAS_atmega64hve2_TRUE='' HAS_atmega64hve_FALSE='' HAS_atmega64hve_TRUE='' HAS_atmega64m1_FALSE='' HAS_atmega64m1_TRUE='' HAS_atmega64rfr2_FALSE='' HAS_atmega64rfr2_TRUE='' HAS_atmega8515_FALSE='' HAS_atmega8515_TRUE='' HAS_atmega8535_FALSE='' HAS_atmega8535_TRUE='' HAS_atmega88_FALSE='' HAS_atmega88_TRUE='' HAS_atmega88a_FALSE='' HAS_atmega88a_TRUE='' HAS_atmega88p_FALSE='' HAS_atmega88p_TRUE='' HAS_atmega88pa_FALSE='' HAS_atmega88pa_TRUE='' HAS_atmega88pb_FALSE='' HAS_atmega88pb_TRUE='' HAS_atmega8_FALSE='' HAS_atmega8_TRUE='' HAS_atmega8a_FALSE='' HAS_atmega8a_TRUE='' HAS_atmega8hva_FALSE='' HAS_atmega8hva_TRUE='' HAS_atmega8u2_FALSE='' HAS_atmega8u2_TRUE='' HAS_attiny10_FALSE='' HAS_attiny10_TRUE='' HAS_attiny11_FALSE='' HAS_attiny11_TRUE='' HAS_attiny12_FALSE='' HAS_attiny12_TRUE='' HAS_attiny13_FALSE='' HAS_attiny13_TRUE='' HAS_attiny13a_FALSE='' HAS_attiny13a_TRUE='' HAS_attiny15_FALSE='' HAS_attiny15_TRUE='' HAS_attiny1634_FALSE='' HAS_attiny1634_TRUE='' HAS_attiny167_FALSE='' HAS_attiny167_TRUE='' HAS_attiny20_FALSE='' HAS_attiny20_TRUE='' HAS_attiny22_FALSE='' HAS_attiny22_TRUE='' HAS_attiny2313_FALSE='' HAS_attiny2313_TRUE='' HAS_attiny2313a_FALSE='' HAS_attiny2313a_TRUE='' HAS_attiny24_FALSE='' HAS_attiny24_TRUE='' HAS_attiny24a_FALSE='' HAS_attiny24a_TRUE='' HAS_attiny25_FALSE='' HAS_attiny25_TRUE='' HAS_attiny261_FALSE='' HAS_attiny261_TRUE='' HAS_attiny261a_FALSE='' HAS_attiny261a_TRUE='' HAS_attiny26_FALSE='' HAS_attiny26_TRUE='' HAS_attiny28_FALSE='' HAS_attiny28_TRUE='' HAS_attiny40_FALSE='' HAS_attiny40_TRUE='' HAS_attiny4313_FALSE='' HAS_attiny4313_TRUE='' HAS_attiny43u_FALSE='' HAS_attiny43u_TRUE='' HAS_attiny441_FALSE='' HAS_attiny441_TRUE='' HAS_attiny44_FALSE='' HAS_attiny44_TRUE='' HAS_attiny44a_FALSE='' HAS_attiny44a_TRUE='' HAS_attiny45_FALSE='' HAS_attiny45_TRUE='' HAS_attiny461_FALSE='' HAS_attiny461_TRUE='' HAS_attiny461a_FALSE='' HAS_attiny461a_TRUE='' HAS_attiny48_FALSE='' HAS_attiny48_TRUE='' HAS_attiny4_FALSE='' HAS_attiny4_TRUE='' HAS_attiny5_FALSE='' HAS_attiny5_TRUE='' HAS_attiny828_FALSE='' HAS_attiny828_TRUE='' HAS_attiny841_FALSE='' HAS_attiny841_TRUE='' HAS_attiny84_FALSE='' HAS_attiny84_TRUE='' HAS_attiny84a_FALSE='' HAS_attiny84a_TRUE='' HAS_attiny85_FALSE='' HAS_attiny85_TRUE='' HAS_attiny861_FALSE='' HAS_attiny861_TRUE='' HAS_attiny861a_FALSE='' HAS_attiny861a_TRUE='' HAS_attiny87_FALSE='' HAS_attiny87_TRUE='' HAS_attiny88_FALSE='' HAS_attiny88_TRUE='' HAS_attiny9_FALSE='' HAS_attiny9_TRUE='' HAS_atxmega128a1_FALSE='' HAS_atxmega128a1_TRUE='' HAS_atxmega128a1u_FALSE='' HAS_atxmega128a1u_TRUE='' HAS_atxmega128a3_FALSE='' HAS_atxmega128a3_TRUE='' HAS_atxmega128a3u_FALSE='' HAS_atxmega128a3u_TRUE='' HAS_atxmega128a4u_FALSE='' HAS_atxmega128a4u_TRUE='' HAS_atxmega128b1_FALSE='' HAS_atxmega128b1_TRUE='' HAS_atxmega128b3_FALSE='' HAS_atxmega128b3_TRUE='' HAS_atxmega128c3_FALSE='' HAS_atxmega128c3_TRUE='' HAS_atxmega128d3_FALSE='' HAS_atxmega128d3_TRUE='' HAS_atxmega128d4_FALSE='' HAS_atxmega128d4_TRUE='' HAS_atxmega16a4_FALSE='' HAS_atxmega16a4_TRUE='' HAS_atxmega16a4u_FALSE='' HAS_atxmega16a4u_TRUE='' HAS_atxmega16c4_FALSE='' HAS_atxmega16c4_TRUE='' HAS_atxmega16d4_FALSE='' HAS_atxmega16d4_TRUE='' HAS_atxmega192a3_FALSE='' HAS_atxmega192a3_TRUE='' HAS_atxmega192a3u_FALSE='' HAS_atxmega192a3u_TRUE='' HAS_atxmega192c3_FALSE='' HAS_atxmega192c3_TRUE='' HAS_atxmega192d3_FALSE='' HAS_atxmega192d3_TRUE='' HAS_atxmega256a3_FALSE='' HAS_atxmega256a3_TRUE='' HAS_atxmega256a3b_FALSE='' HAS_atxmega256a3b_TRUE='' HAS_atxmega256a3bu_FALSE='' HAS_atxmega256a3bu_TRUE='' HAS_atxmega256a3u_FALSE='' HAS_atxmega256a3u_TRUE='' HAS_atxmega256c3_FALSE='' HAS_atxmega256c3_TRUE='' HAS_atxmega256d3_FALSE='' HAS_atxmega256d3_TRUE='' HAS_atxmega32a4_FALSE='' HAS_atxmega32a4_TRUE='' HAS_atxmega32a4u_FALSE='' HAS_atxmega32a4u_TRUE='' HAS_atxmega32c3_FALSE='' HAS_atxmega32c3_TRUE='' HAS_atxmega32c4_FALSE='' HAS_atxmega32c4_TRUE='' HAS_atxmega32d3_FALSE='' HAS_atxmega32d3_TRUE='' HAS_atxmega32d4_FALSE='' HAS_atxmega32d4_TRUE='' HAS_atxmega32e5_FALSE='' HAS_atxmega32e5_TRUE='' HAS_atxmega384c3_FALSE='' HAS_atxmega384c3_TRUE='' HAS_atxmega384d3_FALSE='' HAS_atxmega384d3_TRUE='' HAS_atxmega64a1_FALSE='' HAS_atxmega64a1_TRUE='' HAS_atxmega64a1u_FALSE='' HAS_atxmega64a1u_TRUE='' HAS_atxmega64a3_FALSE='' HAS_atxmega64a3_TRUE='' HAS_atxmega64a3u_FALSE='' HAS_atxmega64a3u_TRUE='' HAS_atxmega64a4u_FALSE='' HAS_atxmega64a4u_TRUE='' HAS_atxmega64b1_FALSE='' HAS_atxmega64b1_TRUE='' HAS_atxmega64b3_FALSE='' HAS_atxmega64b3_TRUE='' HAS_atxmega64c3_FALSE='' HAS_atxmega64c3_TRUE='' HAS_atxmega64d3_FALSE='' HAS_atxmega64d3_TRUE='' HAS_atxmega64d4_FALSE='' HAS_atxmega64d4_TRUE='' HAS_atxmega8e5_FALSE='' HAS_atxmega8e5_TRUE='' HAS_avr1_FALSE='' HAS_avr1_TRUE='' HAS_avr25_FALSE='' HAS_avr25_TRUE='' HAS_avr2_FALSE='' HAS_avr2_TRUE='' HAS_avr31_FALSE='' HAS_avr31_TRUE='' HAS_avr35_FALSE='' HAS_avr35_TRUE='' HAS_avr3_FALSE='' HAS_avr3_TRUE='' HAS_avr4_FALSE='' HAS_avr4_TRUE='' HAS_avr51_FALSE='' HAS_avr51_TRUE='' HAS_avr5_FALSE='' HAS_avr5_TRUE='' HAS_avr6_FALSE='' HAS_avr6_TRUE='' HAS_avrtiny_FALSE='' HAS_avrtiny_TRUE='' HAS_avrxmega2_FALSE='' HAS_avrxmega2_TRUE='' HAS_avrxmega3_FALSE='' HAS_avrxmega3_TRUE='' HAS_avrxmega4_FALSE='' HAS_avrxmega4_TRUE='' HAS_avrxmega5_FALSE='' HAS_avrxmega5_TRUE='' HAS_avrxmega6_FALSE='' HAS_avrxmega6_TRUE='' HAS_avrxmega7_FALSE='' HAS_avrxmega7_TRUE='' HAS_m3000_FALSE='' HAS_m3000_TRUE='' INSTALL_DATA='${INSTALL} -m 644' INSTALL_DOX_HTML='' INSTALL_DOX_MAN='' INSTALL_DOX_PDF='' INSTALL_PROGRAM='${INSTALL}' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='$(install_sh) -c -s' LDFLAGS='' LIBOBJS='' LIBS='' LN_S='' LTLIBOBJS='' MAKEINFO='${SHELL} /home/ubuntixer/toolchain/downloads/avr-libc/missing makeinfo' MKDIR_P='/bin/mkdir -p' OBJEXT='' PACKAGE='avr-libc' PACKAGE_BUGREPORT='avr-libc-dev@nongnu.org' PACKAGE_NAME='avr-libc' PACKAGE_STRING='avr-libc 2.0.0svn' PACKAGE_TARNAME='avr-libc' PACKAGE_URL='' PACKAGE_VERSION='2.0.0svn' PATH_SEPARATOR=':' PNGTOPNM='' PNMTOPNG='' RANLIB='' SET_MAKE='' SHELL='/bin/bash' STRIP='strip' TARGET_DOX_HTML='' TARGET_DOX_PDF='' VERSION='2.0.0svn' ac_ct_CC='' am__EXEEXT_FALSE='' am__EXEEXT_TRUE='' am__fastdepCCAS_FALSE='' am__fastdepCCAS_TRUE='' am__fastdepCC_FALSE='' am__fastdepCC_TRUE='' am__include='' am__isrc=' -I$(srcdir)' am__leading_dot='.' am__nodep='' am__quote='' am__tar='$${TAR-tar} chof - "$$tardir"' am__untar='$${TAR-tar} xf -' bindir='${exec_prefix}/bin' build='x86_64-pc-linux-gnu' build_alias='' build_cpu='x86_64' build_os='linux-gnu' build_vendor='pc' datadir='${datarootdir}' datarootdir='${prefix}/share' docdir='${datarootdir}/doc/${PACKAGE_TARNAME}' dvidir='${docdir}' exec_prefix='NONE' host='avr-unknown-none' host_alias='avr' host_cpu='avr' host_os='none' host_vendor='unknown' htmldir='${docdir}' includedir='${prefix}/include' infodir='${datarootdir}/info' install_sh='${SHELL} /home/ubuntixer/toolchain/downloads/avr-libc/install-sh' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localedir='${datarootdir}/locale' localstatedir='${prefix}/var' mandir='${datarootdir}/man' mkdir_p='$(MKDIR_P)' oldincludedir='/usr/include' pdfdir='${docdir}' prefix='/home/ubuntixer/local/avrLinux64' program_transform_name='s,x,x,' psdir='${docdir}' runstatedir='${localstatedir}/run' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target_alias='' ## ----------- ## ## confdefs.h. ## ## ----------- ## /* confdefs.h */ #define PACKAGE_NAME "avr-libc" #define PACKAGE_TARNAME "avr-libc" #define PACKAGE_VERSION "2.0.0svn" #define PACKAGE_STRING "avr-libc 2.0.0svn" #define PACKAGE_BUGREPORT "avr-libc-dev@nongnu.org" #define PACKAGE_URL "" #define PACKAGE "avr-libc" #define VERSION "2.0.0svn" configure: exit 1
