seg000:CA86 aCouldNotFindPa db '+Could not find partition magic',0Ah,0 seg000:CAA7 a06dkb db '%06dKB',0Dh,0 seg000:CAAF a06dkb_0 db '%06dKB',0Ah,0 seg000:CAB7 aOkSDBytes db 'OK %s, %d bytes',0Ah,0 seg000:CAC8 a08xErasing db '%08x: erasing',0 seg000:CAD6 aLoading db ',loading',0 seg000:CADF aTesting db ',testing',0 seg000:CAE8 a_ db '.',0Ah,0 seg000:CAEB aErrorWhileFlas db 'Error while flashing',0Ah,0 seg000:CB01 aOkSDKb db 'OK %s, %d kB',0Ah,0 seg000:CB0F aCs8900aFoundAt db 'CS8900A found at 300h',0Ah,0 seg000:CB26 aDebug db 'debug',0 seg000:CB2C a_Netbox3_5Dram db '.',0Ah seg000:CB2C db 'NetBox 3.5 [DRAM: %02dM] (Oct 25 1999 11:41:53)',0Ah,0 seg000:CB5F aNftlDocFoundAt db 'NFTL: DOC found at %p',0Ah,0 seg000:CB76 aInitializingFt db 'initializing ftl device',0Ah,0 seg000:CB8F aCouldNotInitia db 'Could not initialize block device',0Ah,0 seg000:CBB2 aDevFla_0 db '/dev/fla',0 seg000:CBBB aScan_partition db 'scan_partitions -> %d',0Ah,0 seg000:CBD2 aCouldNotFindAV db 'Could not find a valid system partition',0Ah,0 seg000:CBFB aRootSCRootdevS db 'root=%s%c ROOTDEV=%s%c ',0 seg000:CC13 aDevFtla db '/dev/ftla',0 seg000:CC1D aFlash0x2400000 db 'flash=0x2400000,0x400000,0,0x3F0000,0x3F0000,0x10000 ',0 seg000:CC53 db ' ',0 seg000:CC55 aUsingMinix db 'using minix',0Ah,0 seg000:CC62 aBootimg_rle db 'bootimg.rle',0 seg000:CC6E aLoadedBootimg_ db 'loaded bootimg.rle -> %d, img=%p',0Ah,0 seg000:CC90 aLoadedSD db 'loaded %s -> %d',0Ah,0 seg000:CCA1 aCouldNotLoadKe db 'Could not load kernel',0Ah,0 seg000:CCB8 aBootingLinux db 'booting linux',0Ah,0 seg000:CCC7 db 8,' ',8,0 seg000:CCCB aDocwritesys db 'docwritesys',0 seg000:CCD7 aBlockCount db 'block [count]',0 seg000:CCE5 aDocerase db 'docerase',0 seg000:CCEE aDocwrite db 'docwrite',0 seg000:CCF7 aDocread db 'docread',0 seg000:CCFF aFromCount db '[from [count]]',0 seg000:CD0E aDocformat db 'docformat',0 seg000:CD18 aSectorCount db '[sector [count]]',0 seg000:CD29 aDocdump db 'docdump',0 seg000:CD31 aSectorCountVal db 'sector count val',0 seg000:CD42 aBf db 'bf',0 seg000:CD45 aSectorCountChe db 'sector count checksum',0 seg000:CD5B aBp db 'bp',0 seg000:CD5E aSectorCountFro db 'sector [count [from]]',0 seg000:CD74 aBw db 'bw',0 seg000:CD77 aSectorCount_0 db 'sector [count]',0 seg000:CD86 aBd db 'bd',0 seg000:CD89 aSectorCountDes db 'sector [count [dest]]',0 seg000:CD9F aBr db 'br',0 seg000:CDA2 aPortVal db 'port val',0 seg000:CDAB aO db 'o',0 seg000:CDAD aPort db 'port',0 seg000:CDB2 aI db 'i',0 seg000:CDB4 aSourceDestBloc db 'source dest [blocks]',0 seg000:CDC9 aWf db 'wf',0 seg000:CDCC aSource db '[source]',0 seg000:CDD5 aWw db 'ww',0 seg000:CDD8 aAddress db 'address',0 seg000:CDE0 aG db 'g',0 seg000:CDE2 aAddressLengthC db 'address length checksum',0 seg000:CDFA aP db 'p',0 seg000:CDFC aFileAddress db 'file [address]',0 seg000:CE0B aTftpget db 'tftpget',0 seg000:CE13 aSourceDestSize db 'source dest size',0 seg000:CE24 aMMwMd db 'm,mw,md',0 seg000:CE2C aValueValue___ db 'value value [...]',0 seg000:CE3E db '+',0 seg000:CE40 aAddressLengthV db 'address length value',0 seg000:CE55 aFFwFd db 'f,fw,fd',0 seg000:CE5D aAddressValue__ db 'address value [...]',0 seg000:CE71 aEEwDd db 'e,ew,dd',0 seg000:CE79 aAddressLength db '[address] [length]',0 seg000:CE8C aDDwDd db 'd,dw,dd',0 seg000:CE94 aAddress1Addres db '[address1] [address2] [length]',0 seg000:CEB3 aCCwCd db 'c,cw,cd',0 seg000:CEBB aSerial_speed db 'serial_speed',0 seg000:CEC8 aBaudB db 'baud,b',0 seg000:CECF aArgs___ db 'args...',0 seg000:CED7 aBoot db 'boot',0 seg000:CEDC db 0 ; seg000:CEDD aRebootQ db 'reboot,Q',0 seg000:CEE6 aCommand db '[command]',0 seg000:CEF0 aHelp? db 'help,?',0 seg000:CEF7 db 0Ah ; seg000:CEF8 aNsdb3_50CCCopy db 'NSDB 3.50%c (C) Copyright NetGem 1996-1999',0Ah,0 seg000:CF24 db '>',0 seg000:CF26 aUsageSS db 'usage: %s %s',0Ah,0 seg000:CF34 aSCommandNotFou db '%s: command not found',0Ah,0 seg000:CF4B a11sS db '%-11s %s',0Ah,0 seg000:CF55 a08xDU0O0bS db '= %08X, %d, %u, 0%o, 0b%s',0Ah,0 seg000:CF70 aB db 'b',0 seg000:CF72 a08x db '%08X',0 seg000:CF77 aC02x db '%c%02X',0 seg000:CF7E a04x_0 db ' %04X',0 seg000:CF84 a08x_0 db ' %08X',0 seg000:CF8A db ' ',0 seg000:CF8D a08x02x db '%08X: %02X',0Ah,0 seg000:CF99 a08x04x db '%08X: %04X',0Ah,0 seg000:CFA5 a08x08x db '%08X: %08X',0Ah,0 seg000:CFB1 a08x02x08x02x db '%08X: %02X <=> %08X: %02X',0Ah,0 seg000:CFCC a08x04x08x04x db '%08X: %04X <=> %08X: %04X',0Ah,0 seg000:CFE7 a08x08x08x08x db '%08X: %08X <=> %08X: %08X',0Ah,0 seg000:D002 aBlock08xErasin db ' block %08X: erasing',0 seg000:D018 aLoading_0 db ',loading',0 seg000:D021 aTesting_0 db ',testing',0 seg000:D02A a__0 db '.',0Ah,0 seg000:D02D aSErrorDWhileDo db '%s: error %d while downloading.',0Ah,0 seg000:D04E a04x_1 db '%04X',0 seg000:D053 a_02x db '.%02X',0 seg000:D059 db '[%X',0 seg000:D05D db '%X',0 seg000:D060 a0X db ']: %0*x',0 seg000:D068 a02x_0 db ': %02X',0 seg000:D06F db 0Ah,0 seg000:D071 db ' ',0 seg000:D073 aEssAt0x2200x38 db 'ESS at 0x220/0x388/0x330',0Ah,0 seg000:D08D aOctet db 'octet',0 seg000:D093 aBlksize db 'blksize',0 seg000:D09B aRexmt db '',0Ah,0 seg000:D0A4 aRfc1782Error db 'RFC1782 error',0 seg000:D0B2 aFtl100 db 'FTL100',0 seg000:D0B9 aDevFtla_0 db '/dev/ftla',0 seg000:D0C3 aReadError db 'read error',0Ah,0 seg000:D0CF aWriteError db 'write error',0Ah,0 seg000:D0DC aSector0x4x db 'sector 0x%4x:',0Ah,0 seg000:D0EB aVgaFramebuffer db 'VGA: framebuffer at %p, size %dk',0Ah,0 seg000:D10D aVgaModeDxDxDLi db 'VGA: mode=%dx%dx%d, line_length=%d',0Ah,0 seg000:D131 aWritingSystem_ db 'Writing SYSTEM ...',0 seg000:D144 aVerifying___ db 'Verifying ...',0 seg000:D152 aErrorAtPage0xX db 0Ah seg000:D152 db 'Error at page 0x%x',0Ah,0 seg000:D167 aDone db 'Done',0Ah,0 seg000:D16D aFormatting___ db 'Formatting ...',0 seg000:D17C aChecking___ db 'Checking ...',0 seg000:D189 aBadBlockAt0xLx db 0Ah seg000:D189 db 'Bad Block at 0x%lx',0Ah,0 seg000:D19E aWritingTables_ db 'Writing Tables ...',0 seg000:D1B1 aAnand_0 db 'ANAND',0 seg000:D1B7 aDocError db 'DOC error',0Ah,0 seg000:D1C2 aToshiba db '(Toshiba) ',0 seg000:D1CD aSamsung db '(Samsung) ',0 seg000:D1D8 aAmd db '(AMD) ',0 seg000:D1DF aFujitsu db '(Fujitsu) ',0 seg000:D1EA aUnknownVendorI db 'Unknown Vendor ID: %x',0Ah,0 seg000:D201 aUnknownChipIdX db 'Unknown Chip ID: %x',0Ah,0 seg000:D216 aMdoc8m db 'MDOC 8M',0Ah,0 seg000:D21F aSectSignData db 'SECT SIGN DAT' seg000:D21F db 'A',0Ah,0 seg000:D25E a04x db '%04x ',0 seg000:D264 a02x db ' %02X',0 seg000:D26A db ' ',0 seg000:D26C a___ db ' ...',0Ah,0 seg000:D272 db 0Ah ; seg000:D273 db 0 ; seg000:D274 aErasing___ db 'Erasing ...',0 seg000:D280 aDebugDidNotIde db 'Debug: did not identify flash media.',0Ah,0 seg000:D2A6 aDebugFailedAll db 'Debug: failed allocating sector buffer.',0Ah,0 seg000:D2CF aDebugTimeoutEr db 'Debug: timeout error in NFDC 2148.',0Ah,0 seg000:D2F3 aDebugNfdc2148W db 'Debug: NFDC 2148 write failed.',0Ah,0 seg000:D313 aDebugEdcErrorF db 'Debug: EDC error for NFDC 2148.',0Ah,0 seg000:D334 aDebugNfdc2148E db 'Debug: NFDC 2148 erase failed.',0Ah,0 seg000:D354 aDebugEnteringN db 'debug: entering NFDC 2148 identification routine.',0Ah,0 seg000:D387 aDebugFailedToI db 'Debug: failed to identify NFDC 2148.',0Ah,0 seg000:D3AD aDebugIdentifie db 'Debug: identified NFDC 2148.',0Ah,0 seg000:D3CB aDebugMediaIsNo db 'Debug: media is not fit for NFTL format.',0Ah,0 seg000:D3F5 aDebugFailedA_0 db 'Debug: failed allocating conversion tables for NFTL.',0Ah,0 seg000:D42B aDebugStartingN db 'Debug: starting NFTL mount.',0Ah,0 seg000:D448 aAnand db 'ANAND',0 seg000:D44E aDebugNotNftlFo db 'Debug: not NFTL format.',0Ah,0 seg000:D467 aDebugFinishedN db 'Debug: finished NFTL mount.',0Ah,0 seg000:D484 aDebugNftlRunsW db 'Debug: NFTL runs without U-cache',0Ah,0 seg000:D4A6 aDebugNftlRun_0 db 'Debug: NFTL runs without S-cache',0Ah,0 seg000:D4C8 aNftl_readError db 'nftl_read: error=%d block=%d nsect=%d',0Ah,0 seg000:D4EF aNftl_writeErro db 'nftl_write: error=%d block=%d nsect=%d',0Ah,0 seg000:D517 aMSystemsDiskon db 'M-Systems DiskOnChip not found.',0Ah,0 seg000:D538 aNftlErrorDWhil db 'NFTL: Error %d while mounting device',0Ah,0 seg000:D55E aDevFla db '/dev/fla',0 seg000:D567 db 0 ; seg000:D568 aVmlinuz db 'vmlinuz',0 seg000:D570 aRoConsoleTtys1 db 'ro console=ttyS1,9600n8 parport=0x203,6 ',0 seg000:D599 aRomimage_bin db 'romimage.bin',0 seg000:D5A6 aDiskimage_bin db 'diskimage.bin',0
