Version 4 SHEET 1 944 1236 WIRE -48 96 -144 96 WIRE -16 96 -48 96 WIRE 128 96 64 96 WIRE 368 96 272 96 WIRE 512 96 448 96 WIRE -144 128 -144 96 WIRE 128 128 128 96 WIRE 272 128 272 96 WIRE 512 128 512 96 WIRE -144 240 -144 208 WIRE 128 240 128 208 WIRE 128 240 -144 240 WIRE 272 240 272 208 WIRE 272 240 128 240 WIRE 512 240 512 208 WIRE 512 240 272 240 WIRE -144 272 -144 240 WIRE -64 432 -144 432 WIRE -32 432 -64 432 WIRE 80 432 48 432 WIRE 208 432 160 432 WIRE 272 432 208 432 WIRE 384 432 352 432 WIRE 528 432 464 432 WIRE -144 464 -144 432 WIRE 208 464 208 432 WIRE 528 464 528 432 WIRE -144 576 -144 544 WIRE 208 576 208 544 WIRE 208 576 -144 576 WIRE 528 576 528 544 WIRE 528 576 208 576 WIRE -144 608 -144 576 FLAG -144 272 0 FLAG -48 96 1 FLAG -144 608 0 FLAG -64 432 1A FLAG 512 96 2 FLAG 528 432 2A SYMBOL ind2 112 112 R0 SYMATTR InstName L1 SYMATTR Value {L1} SYMATTR Type ind SYMATTR SpiceLine Rser=0 SYMBOL Misc\\EuropeanResistor -32 112 R270 WINDOW 0 27 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName R1 SYMATTR Value 1 SYMBOL Misc\\EuropeanResistor 352 112 R270 WINDOW 0 27 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName R2 SYMATTR Value 0.2 SYMBOL ind2 256 112 R0 SYMATTR InstName L2 SYMATTR Value {L2} SYMATTR Type ind SYMATTR SpiceLine Rser=0 SYMBOL voltage -144 112 R0 WINDOW 3 36 81 Left 2 WINDOW 123 27 107 Left 2 WINDOW 39 0 0 Left 2 SYMATTR Value SINE(0 1 1k) SYMATTR Value2 AC 10 SYMATTR InstName V1 SYMBOL Misc\\EuropeanResistor -48 448 R270 WINDOW 0 27 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName R1A SYMATTR Value 1 SYMBOL Misc\\EuropeanResistor 368 448 R270 WINDOW 0 27 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName R2A SYMATTR Value 0.2 SYMBOL voltage -144 448 R0 WINDOW 3 36 81 Left 2 WINDOW 123 27 107 Left 2 WINDOW 39 0 0 Left 2 SYMATTR Value SINE(0 1 1k) SYMATTR Value2 AC 10 SYMATTR InstName V4 SYMBOL ind 64 448 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName L1M SYMATTR Value {L1M} SYMATTR SpiceLine Rser=0 SYMBOL ind 256 448 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName L2M SYMATTR Value {L2M} SYMATTR SpiceLine Rser=0 SYMBOL ind 192 448 R0 SYMATTR InstName LM SYMATTR Value {M} SYMATTR SpiceLine Rser=0 SYMBOL Misc\\EuropeanResistor 496 112 R0 SYMATTR InstName RL SYMATTR Value 10 SYMBOL Misc\\EuropeanResistor 512 448 R0 SYMATTR InstName RLA SYMATTR Value 10 TEXT 120 72 Left 2 !K1 L1 L2 {k} TEXT -152 -112 Left 2 ;.step param x list 1 2\n.ac list 1k\n.meas ac Ze find V(1)/I(R1) at 1k\n.meas ac Zea find V(1a)/I(R1) at 1k\n.options meascplxfmt=polar TEXT 288 528 Left 2 ;M=k*sqrt(L1*L2) TEXT 96 376 Left 2 ;L1-M TEXT 288 376 Left 2 ;L2-M TEXT -160 352 Left 2 ;Ersatzschaltung TEXT 296 -240 Left 2 !.param L1=1m L2=0.04m k=0.8\n.param M=k*sqrt(L1*L2)\n.param L1M=L1-M\n.param L2M=L2-M\n.param u=sqrt(L1/L2) ; ü TEXT -152 -176 Left 2 !.tran 0 10m 0 1u TEXT 296 -80 Left 2 !.options measdgt=10\n.meas M_ param M\n.meas L1M_ param L1M\n.meas L2M_ param L2M TEXT -152 -208 Left 2 !.options tseed=10n TEXT -160 -472 Left 3 ;Problem with negative inductance values in the TRAN-Analysis\nWhen L2M is negative, then either omit the first results\n.tran 0 10m 5u 1u\nor use the option below to control the first time step.\n.options tseed=10n\n.tran 0 10m 0 1u
