(kicad_pcb (version 20171130) (host pcbnew 5.0.2)
  (general
    (thickness 1.6)
    (drawings 10139)
    (tracks 274)
    (zones 0)
    (modules 36)
    (nets 28)
  (page A4)
  (layers
    (0 F.Cu signal)
    (31 B.Cu signal)
    (32 B.Adhes user)
    (33 F.Adhes user)
    (34 B.Paste user)
    (35 F.Paste user)
    (36 B.SilkS user)
    (37 F.SilkS user)
    (38 B.Mask user)
    (39 F.Mask user hide)
    (40 Dwgs.User user)
    (41 Cmts.User user)
    (42 Eco1.User user hide)
    (43 Eco2.User user hide)
    (44 Edge.Cuts user)
    (45 Margin user hide)
    (46 B.CrtYd user hide)
    (47 F.CrtYd user hide)
    (48 B.Fab user hide)
    (49 F.Fab user hide)
  (setup
    (last_trace_width 0.25)
    (trace_clearance 0.2)
    (zone_clearance 0.508)
    (zone_45_only no)
    (trace_min 0.2)
    (segment_width 0.2)
    (edge_width 0.05)
    (via_size 0.8)
    (via_drill 0.4)
    (via_min_size 0.4)
    (via_min_drill 0.3)
    (uvia_size 0.3)
    (uvia_drill 0.1)
    (uvias_allowed no)
    (uvia_min_size 0.2)
    (uvia_min_drill 0.1)
    (pcb_text_width 0.3)
    (pcb_text_size 1.5 1.5)
    (mod_edge_width 0.12)
    (mod_text_size 1 1)
    (mod_text_width 0.15)
    (pad_size 1.5 1.5)
    (pad_drill 1)
    (pad_to_mask_clearance 0.051)
    (solder_mask_min_width 0.25)
    (aux_axis_origin 0 0)
    (visible_elements FFFFFF7F)
    (pcbplotparams
      (layerselection 0x010fc_ffffffff)
      (usegerberextensions false)
      (usegerberattributes false)
      (usegerberadvancedattributes false)
      (creategerberjobfile false)
      (excludeedgelayer true)
      (linewidth 0.100000)
      (plotframeref false)
      (viasonmask false)
      (mode 1)
      (useauxorigin false)
      (hpglpennumber 1)
      (hpglpenspeed 20)
      (hpglpendiameter 15.000000)
      (psnegative false)
      (psa4output false)
      (plotreference true)
      (plotvalue true)
      (plotinvisibletext false)
      (padsonsilk false)
      (subtractmaskfromsilk false)
      (outputformat 1)
      (mirror false)
      (drillshape 1)
      (scaleselection 1)
      (outputdirectory ""))
  (net 0 "")
  (net 1 "Net-(D1-Pad4)")
  (net 2 "Net-(D1-Pad3)")
  (net 3 "Net-(D1-Pad2)")
  (net 4 "Net-(D1-Pad1)")
  (net 5 "Net-(D2-Pad2)")
  (net 6 "Net-(D2-Pad4)")
  (net 7 "Net-(D3-Pad3)")
  (net 8 "Net-(D3-Pad1)")
  (net 9 "Net-(D4-Pad2)")
  (net 10 "Net-(D4-Pad4)")
  (net 11 "Net-(D6-Pad4)")
  (net 12 "Net-(D6-Pad2)")
  (net 13 "Net-(D7-Pad4)")
  (net 14 "Net-(D7-Pad3)")
  (net 15 "Net-(D7-Pad2)")
  (net 16 "Net-(D7-Pad1)")
  (net 17 "Net-(D10-Pad1)")
  (net 18 "Net-(D10-Pad3)")
  (net 19 "Net-(D11-Pad2)")
  (net 20 "Net-(D11-Pad4)")
  (net 21 "Net-(D10-Pad4)")
  (net 22 "Net-(D10-Pad2)")
  (net 23 "Net-(D12-Pad2)")
  (net 24 "Net-(D12-Pad4)")
  (net 25 GND)
  (net 26 "Net-(J1-Pad2)")
  (net 27 "Net-(J1-Pad3)")
  (net_class Default "Dies ist die voreingestellte Netzklasse."
    (clearance 0.2)
    (trace_width 0.25)
    (via_dia 0.8)
    (via_drill 0.4)
    (uvia_dia 0.3)
    (uvia_drill 0.1)
    (add_net GND)
    (add_net "Net-(D1-Pad1)")
    (add_net "Net-(D1-Pad2)")
    (add_net "Net-(D1-Pad3)")
    (add_net "Net-(D1-Pad4)")
    (add_net "Net-(D10-Pad1)")
    (add_net "Net-(D10-Pad2)")
    (add_net "Net-(D10-Pad3)")
    (add_net "Net-(D10-Pad4)")
    (add_net "Net-(D11-Pad2)")
    (add_net "Net-(D11-Pad4)")
    (add_net "Net-(D12-Pad2)")
    (add_net "Net-(D12-Pad4)")
    (add_net "Net-(D2-Pad2)")
    (add_net "Net-(D2-Pad4)")
    (add_net "Net-(D3-Pad1)")
    (add_net "Net-(D3-Pad3)")
    (add_net "Net-(D4-Pad2)")
    (add_net "Net-(D4-Pad4)")
    (add_net "Net-(D6-Pad2)")
    (add_net "Net-(D6-Pad4)")
    (add_net "Net-(D7-Pad1)")
    (add_net "Net-(D7-Pad2)")
    (add_net "Net-(D7-Pad3)")
    (add_net "Net-(D7-Pad4)")
    (add_net "Net-(J1-Pad2)")
    (add_net "Net-(J1-Pad3)")
  (module MountingHole:MountingHole_2.1mm (layer F.Cu) (tedit 5B924765) (tstamp 5EAAFEA8)
    (at 107.696 71.12)
    (descr "Mounting Hole 2.1mm, no annular")
    (tags "mounting hole 2.1mm no annular")
    (path /5ECE300E)
    (attr virtual)
    (fp_text reference . (at 0 -3.2) (layer F.SilkS) hide
      (effects (font (size 1 1) (thickness 0.15)))
    (fp_text value MountingHole (at 0 3.2) (layer F.Fab)
    (fp_text user %R (at 0.3 0) (layer F.Fab)
    (fp_circle (center 0 0) (end 2.1 0) (layer Cmts.User) (width 0.15))
    (fp_circle (center 0 0) (end 2.35 0) (layer F.CrtYd) (width 0.05))
    (pad "" np_thru_hole circle (at 0 0) (size 2.1 2.1) (drill 2.1) (layers *.Cu *.Mask))
    (at 46.228 71.12)
    (path /5ECE300E)
    (attr virtual)
    (fp_text reference H5 (at 0 -3.2) (layer F.SilkS) hide
  (module MountingHole:MountingHole_2.1mm (layer F.Cu) (tedit 5B924765) (tstamp 5EAAFE6C)
    (at 107.696 92.456)
    (path /5ECE300E)
    (attr virtual)
  (module MountingHole:MountingHole_2.1mm (layer F.Cu) (tedit 5B924765) (tstamp 5EAAFE53)
    (at 46.228 92.456)
    (path /5ECE300E)
    (attr virtual)
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD969) (tstamp 5EAAF0ED)
    (at 106.68 59.944)
    (descr "Mounting Hole 2.2mm, no annular, M2, DIN965")
    (tags "mounting hole 2.2mm no annular m2 din965")
    (attr virtual)
    (fp_text reference - (at 0 2.032) (layer F.SilkS)
    (fp_text value MountingHole_2.2mm_M2_DIN965 (at 0 2.9) (layer F.Fab)
    (fp_circle (center 0 0) (end 1.9 0) (layer Cmts.User) (width 0.15))
    (fp_circle (center 0 0) (end 2.15 0) (layer F.CrtYd) (width 0.05))
    (pad "" np_thru_hole circle (at 0 0) (size 1.5 1.5) (drill 1) (layers *.Cu *.Mask))
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD957) (tstamp 5EAAF0ED)
    (at 110.236 66.548)
    (attr virtual)
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD948) (tstamp 5EAAF0ED)
    (at 114.3 92.964)
    (attr virtual)
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD940) (tstamp 5EAAF0ED)
    (at 117.348 100.584)
    (attr virtual)
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD920) (tstamp 5EAAF0ED)
    (at 42.672 59.436)
    (attr virtual)
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD927) (tstamp 5EAAF0ED)
    (at 46.228 67.056)
    (attr virtual)
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD931) (tstamp 5EAAF0ED)
    (at 36.068 92.964)
    (attr virtual)
  (module MountingHole:MountingHole_2.2mm_M2_DIN965 (layer F.Cu) (tedit 5EAAD938) (tstamp 5EAAEFF9)
    (at 39.624 100.584)
    (attr virtual)
  (module MountingHole:MountingHole_2.1mm (layer F.Cu) (tedit 5B924765) (tstamp 5EAAB6E2)
    (at 29.464 91.44)
    (path /5ECDD932)
    (attr virtual)
    (fp_text reference H1 (at 0 -3.2) (layer F.SilkS) hide
  (module MountingHole:MountingHole_2.1mm (layer F.Cu) (tedit 5B924765) (tstamp 5EAAA640)
    (at 120.904 103.124)
    (path /5ECE300E)
    (attr virtual)
  (module MountingHole:MountingHole_2.1mm (layer F.Cu) (tedit 5B924765) (tstamp 5EAAA638)
    (at 119.38 67.056)
    (path /5ECDDEC5)
    (attr virtual)
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A241)
    (at 39.092 73.152 180)
    (descr https://docs.broadcom.com/docs/AV02-4186EN)
    (tags "LED Avago PLCC-4 ASMB-MTB0-0A3A2")
    (path /5EAABA84)
    (attr smd)
    (fp_text reference D1 (at 1.5 -2.65) (layer F.SilkS)
    (fp_text value LED_Dual_CACA (at 0 2.65) (layer F.Fab)
    (fp_circle (center 0 0) (end 1.12 0) (layer F.Fab) (width 0.1))
    (fp_line (start 2.5 1.65) (end -2.5 1.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start 2.5 1.65) (end 2.5 -1.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.5 -1.65) (end -2.5 1.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start -2.5 -1.65) (end 2.5 -1.65) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.95 1.5) (end 1.95 1.5) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.500044 -1.5) (end 1.95 -1.5) (layer F.SilkS) (width 0.12))
    (fp_line (start -2.5 -0.7) (end -2.5 -1.5) (layer F.SilkS) (width 0.12))
    (fp_line (start 1.6 -1.4) (end -1.6 -1.4) (layer F.Fab) (width 0.1))
    (fp_line (start 1.6 1.4) (end 1.6 -1.4) (layer F.Fab) (width 0.1))
    (fp_line (start -1.6 1.4) (end 1.6 1.4) (layer F.Fab) (width 0.1))
    (fp_line (start -1.6 -1.4) (end -1.6 1.4) (layer F.Fab) (width 0.1))
    (fp_line (start -0.6 -1.4) (end -1.6 -0.4) (layer F.Fab) (width 0.1))
    (fp_text user %R (at 0 0) (layer F.Fab)
      (effects (font (size 0.5 0.5) (thickness 0.075)))
    (pad 4 smd rect (at -1.5 0.75 180) (size 1.5 1.1) (layers F.Cu F.Paste F.Mask)
      (net 1 "Net-(D1-Pad4)"))
    (pad 3 smd rect (at 1.5 0.75 180) (size 1.5 1.1) (layers F.Cu F.Paste F.Mask)
      (net 2 "Net-(D1-Pad3)"))
    (pad 2 smd rect (at 1.5 -0.75 180) (size 1.5 1.1) (layers F.Cu F.Paste F.Mask)
      (net 3 "Net-(D1-Pad2)"))
    (pad 1 smd rect (at -1.5 -0.75 180) (size 1.5 1.1) (layers F.Cu F.Paste F.Mask)
      (net 4 "Net-(D1-Pad1)"))
    (model ${KISYS3DMOD}/LED_SMD.3dshapes/LED_Avago_PLCC4_3.2x2.8mm_CW.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A257)
    (at 44.172 63.258 180)
    (path /5EAAB126)
    (attr smd)
    (fp_text reference D2 (at 0.992 -2.65) (layer F.SilkS)
      (net 25 GND))
      (net 5 "Net-(D2-Pad2)"))
      (net 25 GND))
      (net 6 "Net-(D2-Pad4)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A26D)
    (at 37.06 84.062 180)
    (path /5EAACB89)
    (attr smd)
    (fp_text reference D3 (at 1.5 -2.65) (layer F.SilkS)
      (net 7 "Net-(D3-Pad3)"))
      (net 8 "Net-(D3-Pad1)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A283)
    (at 53.34 53.34 180)
    (path /5EAA3440)
    (attr smd)
    (fp_text reference D4 (at 1.016 -2.54) (layer F.SilkS)
      (net 9 "Net-(D4-Pad2)"))
      (net 10 "Net-(D4-Pad4)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A299)
    (at 38.076 96.762 180)
    (path /5EAAC439)
    (attr smd)
    (fp_text reference D5 (at 1.5 -2.65) (layer F.SilkS)
      (net 25 GND))
      (net 25 GND))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A2AF)
    (at 66.548 49.784 180)
    (path /5EAA89F6)
    (attr smd)
    (fp_text reference D6 (at 1.524 -2.65) (layer F.SilkS)
      (net 11 "Net-(D6-Pad4)"))
      (net 12 "Net-(D6-Pad2)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A2C5)
    (at 89.94 49.784 180)
    (path /5EAACE8A)
    (attr smd)
    (fp_text reference D7 (at 1.04 -2.65) (layer F.SilkS)
      (net 13 "Net-(D7-Pad4)"))
      (net 14 "Net-(D7-Pad3)"))
      (net 15 "Net-(D7-Pad2)"))
      (net 16 "Net-(D7-Pad1)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A2DB)
    (at 115.824 97.028 180)
    (path /5EAAF388)
    (attr smd)
    (fp_text reference D8 (at 1.524 -2.65) (layer F.SilkS)
      (net 25 GND))
      (net 17 "Net-(D10-Pad1)"))
      (net 25 GND))
      (net 18 "Net-(D10-Pad3)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A2F1)
    (at 101.068 54.864 180)
    (path /5EAAD52A)
    (attr smd)
    (fp_text reference D9 (at 0.484 -2.65) (layer F.SilkS)
      (net 19 "Net-(D11-Pad2)"))
      (net 20 "Net-(D11-Pad4)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A307)
    (at 117.88 84.57 180)
    (path /5EAAEB69)
    (attr smd)
    (fp_text reference D10 (at 2.056 -2.65) (layer F.SilkS)
      (net 21 "Net-(D10-Pad4)"))
      (net 22 "Net-(D10-Pad2)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A31D)
    (at 108.712 62.992 180)
    (path /5EAADB09)
    (attr smd)
    (fp_text reference D11 (at 1.524 -2.54) (layer F.SilkS)
      (net 25 GND))
      (net 25 GND))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module LED_SMD:LED_Avago_PLCC4_3.2x2.8mm_CW (layer F.Cu) (tedit 5A643BA3) (tstamp 5EA9A333)
    (at 115.316 71.12 180)
    (path /5EAAE2C5)
    (attr smd)
    (fp_text reference D12 (at 2.032 -2.65) (layer F.SilkS)
      (net 23 "Net-(D12-Pad2)"))
      (net 24 "Net-(D12-Pad4)"))
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Connector_JST:JST_EH_S3B-EH_1x03_P2.50mm_Horizontal (layer B.Cu) (tedit 5C281425) (tstamp 5EA9A36E)
    (at 80.772 51.308 180)
    (descr "JST EH series connector, S3B-EH (http://www.jst-mfg.com/product/pdf/eng/eEH.pdf), generated with kicad-footprint-generator")
    (tags "connector JST EH horizontal")
    (path /5EACB945)
    (fp_text reference J1 (at 2.5 7.9) (layer B.SilkS)
      (effects (font (size 1 1) (thickness 0.15)) (justify mirror))
    (fp_text value Conn_01x03_Male (at 2.5 -2.7) (layer B.Fab)
    (fp_line (start -1.5 0.7) (end -1.5 -1.5) (layer B.Fab) (width 0.1))
    (fp_line (start -1.5 -1.5) (end -2.5 -1.5) (layer B.Fab) (width 0.1))
    (fp_line (start -2.5 -1.5) (end -2.5 6.7) (layer B.Fab) (width 0.1))
    (fp_line (start -2.5 6.7) (end 7.5 6.7) (layer B.Fab) (width 0.1))
    (fp_line (start 7.5 6.7) (end 7.5 -1.5) (layer B.Fab) (width 0.1))
    (fp_line (start 7.5 -1.5) (end 6.5 -1.5) (layer B.Fab) (width 0.1))
    (fp_line (start 6.5 -1.5) (end 6.5 0.7) (layer B.Fab) (width 0.1))
    (fp_line (start 6.5 0.7) (end -1.5 0.7) (layer B.Fab) (width 0.1))
    (fp_line (start -3 7.2) (end -3 -2) (layer B.CrtYd) (width 0.05))
    (fp_line (start -3 -2) (end 8 -2) (layer B.CrtYd) (width 0.05))
    (fp_line (start 8 -2) (end 8 7.2) (layer B.CrtYd) (width 0.05))
    (fp_line (start 8 7.2) (end -3 7.2) (layer B.CrtYd) (width 0.05))
    (fp_line (start -1.39 0.59) (end -1.39 -1.61) (layer B.SilkS) (width 0.12))
    (fp_line (start -1.39 -1.61) (end -2.61 -1.61) (layer B.SilkS) (width 0.12))
    (fp_line (start -2.61 -1.61) (end -2.61 6.81) (layer B.SilkS) (width 0.12))
    (fp_line (start -2.61 6.81) (end 7.61 6.81) (layer B.SilkS) (width 0.12))
    (fp_line (start 7.61 6.81) (end 7.61 -1.61) (layer B.SilkS) (width 0.12))
    (fp_line (start 7.61 -1.61) (end 6.39 -1.61) (layer B.SilkS) (width 0.12))
    (fp_line (start 6.39 -1.61) (end 6.39 0.59) (layer B.SilkS) (width 0.12))
    (fp_line (start -2.61 5.59) (end -1.39 5.59) (layer B.SilkS) (width 0.12))
    (fp_line (start -1.39 5.59) (end -1.39 0.59) (layer B.SilkS) (width 0.12))
    (fp_line (start -1.39 0.59) (end -2.61 0.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 7.61 5.59) (end 6.39 5.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 6.39 5.59) (end 6.39 0.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 6.39 0.59) (end 7.61 0.59) (layer B.SilkS) (width 0.12))
    (fp_line (start -1.39 1.59) (end 6.39 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 0 1.59) (end -0.32 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start -0.32 1.59) (end -0.32 5.01) (layer B.SilkS) (width 0.12))
    (fp_line (start -0.32 5.01) (end 0 5.09) (layer B.SilkS) (width 0.12))
    (fp_line (start 0 5.09) (end 0.32 5.01) (layer B.SilkS) (width 0.12))
    (fp_line (start 0.32 5.01) (end 0.32 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 0.32 1.59) (end 0 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 1.17 0.59) (end 1.33 0.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 2.5 1.59) (end 2.18 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 2.18 1.59) (end 2.18 5.01) (layer B.SilkS) (width 0.12))
    (fp_line (start 2.18 5.01) (end 2.5 5.09) (layer B.SilkS) (width 0.12))
    (fp_line (start 2.5 5.09) (end 2.82 5.01) (layer B.SilkS) (width 0.12))
    (fp_line (start 2.82 5.01) (end 2.82 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 2.82 1.59) (end 2.5 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 3.67 0.59) (end 3.83 0.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 5 1.59) (end 4.68 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 4.68 1.59) (end 4.68 5.01) (layer B.SilkS) (width 0.12))
    (fp_line (start 4.68 5.01) (end 5 5.09) (layer B.SilkS) (width 0.12))
    (fp_line (start 5 5.09) (end 5.32 5.01) (layer B.SilkS) (width 0.12))
    (fp_line (start 5.32 5.01) (end 5.32 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 5.32 1.59) (end 5 1.59) (layer B.SilkS) (width 0.12))
    (fp_line (start 0 -1.5) (end -0.3 -2.1) (layer B.SilkS) (width 0.12))
    (fp_line (start -0.3 -2.1) (end 0.3 -2.1) (layer B.SilkS) (width 0.12))
    (fp_line (start 0.3 -2.1) (end 0 -1.5) (layer B.SilkS) (width 0.12))
    (fp_line (start -0.5 0.7) (end 0 1.407107) (layer B.Fab) (width 0.1))
    (fp_line (start 0 1.407107) (end 0.5 0.7) (layer B.Fab) (width 0.1))
    (fp_text user %R (at 2.5 2.6) (layer B.Fab)
    (pad 1 thru_hole roundrect (at 0 0 180) (size 1.7 1.95) (drill 0.95) (layers *.Cu *.Mask) (roundrect_rratio 0.147059)
      (net 25 GND))
    (pad 2 thru_hole oval (at 2.5 0 180) (size 1.7 1.95) (drill 0.95) (layers *.Cu *.Mask)
      (net 26 "Net-(J1-Pad2)"))
    (pad 3 thru_hole oval (at 5 0 180) (size 1.7 1.95) (drill 0.95) (layers *.Cu *.Mask)
      (net 27 "Net-(J1-Pad3)"))
    (model ${KISYS3DMOD}/Connector_JST.3dshapes/JST_EH_S3B-EH_1x03_P2.50mm_Horizontal.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A37F)
    (at 75.184 58.42 180)
    (descr "Resistor SMD 0603 (1608 Metric), square (rectangular) end terminal, IPC_7351 nominal, (Body size source: http://www.tortai-tech.com/upload/download/2011102023233369053.pdf), generated with kicad-footprint-generator")
    (tags resistor)
    (path /5EAC8F53)
    (attr smd)
    (fp_text reference R1 (at 0 -1.43) (layer F.SilkS)
    (fp_text value R_Small (at 0 1.43) (layer F.Fab)
      (effects (font (size 0.4 0.4) (thickness 0.06)))
    (fp_line (start 1.48 0.73) (end -1.48 0.73) (layer F.CrtYd) (width 0.05))
    (fp_line (start 1.48 -0.73) (end 1.48 0.73) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.48 -0.73) (end 1.48 -0.73) (layer F.CrtYd) (width 0.05))
    (fp_line (start -1.48 0.73) (end -1.48 -0.73) (layer F.CrtYd) (width 0.05))
    (fp_line (start -0.162779 0.51) (end 0.162779 0.51) (layer F.SilkS) (width 0.12))
    (fp_line (start -0.162779 -0.51) (end 0.162779 -0.51) (layer F.SilkS) (width 0.12))
    (fp_line (start 0.8 0.4) (end -0.8 0.4) (layer F.Fab) (width 0.1))
    (fp_line (start 0.8 -0.4) (end 0.8 0.4) (layer F.Fab) (width 0.1))
    (fp_line (start -0.8 -0.4) (end 0.8 -0.4) (layer F.Fab) (width 0.1))
    (fp_line (start -0.8 0.4) (end -0.8 -0.4) (layer F.Fab) (width 0.1))
    (pad 2 smd roundrect (at 0.7875 0 180) (size 0.875 0.95) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
    (pad 1 smd roundrect (at -0.7875 0 180) (size 0.875 0.95) (layers F.Cu F.Paste F.Mask) (roundrect_rratio 0.25)
    (model ${KISYS3DMOD}/Resistor_SMD.3dshapes/R_0603_1608Metric.wrl
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A390)
    (at 75.184 61.468 180)
    (tags resistor)
    (path /5EAC93A7)
    (attr smd)
    (fp_text reference R2 (at 0 -1.43) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A3A1)
    (at 69.596 58.42 180)
    (tags resistor)
    (path /5EAC89FC)
    (attr smd)
    (fp_text reference R3 (at 0 -1.43) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A3B2)
    (at 69.596 61.468 180)
    (tags resistor)
    (path /5EAC706B)
    (attr smd)
    (fp_text reference R4 (at 0 -1.43) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A3C3)
    (at 80.772 58.42 180)
    (tags resistor)
    (path /5EAC97E4)
    (attr smd)
    (fp_text reference R5 (at 0 -1.43) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A3D4)
    (at 86.36 58.42 180)
    (tags resistor)
    (path /5EACA276)
    (attr smd)
    (fp_text reference R6 (at 0 -1.43) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A3E5)
    (at 80.772 61.468 180)
    (tags resistor)
    (path /5EAC9CD6)
    (attr smd)
    (fp_text reference R7 (at 0 -1.43) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (module Resistor_SMD:R_0603_1608Metric (layer F.Cu) (tedit 5B301BBD) (tstamp 5EA9A3F6)
    (at 86.36 61.468 180)
    (tags resistor)
    (path /5EACA842)
    (attr smd)
    (fp_text reference R8 (at 0 -1.43) (layer F.SilkS)
      (at (xyz 0 0 0))
      (scale (xyz 1 1 1))
  (dimension 21.336 (width 0.12) (layer F.SilkS)
    (gr_text "21,336 mm" (at 143.002 81.788 270) (layer F.SilkS)
    (feature1 (pts (xy 107.696 92.456) (xy 142.318421 92.456)))
    (feature2 (pts (xy 107.696 71.12) (xy 142.318421 71.12)))
    (crossbar (pts (xy 141.732 71.12) (xy 141.732 92.456)))
    (arrow1a (pts (xy 141.732 92.456) (xy 141.145579 91.329496)))
    (arrow1b (pts (xy 141.732 92.456) (xy 142.318421 91.329496)))
    (arrow2a (pts (xy 141.732 71.12) (xy 141.145579 72.246504)))
    (arrow2b (pts (xy 141.732 71.12) (xy 142.318421 72.246504)))
  (dimension 61.468 (width 0.12) (layer F.SilkS)
    (gr_text "61,468 mm" (at 76.962 26.162) (layer F.SilkS) (tstamp 5EAB2C12)
    (feature1 (pts (xy 107.696 71.12) (xy 107.696 26.845579)))
    (feature2 (pts (xy 46.228 71.12) (xy 46.228 26.845579)))
    (crossbar (pts (xy 46.228 27.432) (xy 107.696 27.432)))
    (arrow1a (pts (xy 107.696 27.432) (xy 106.569496 28.018421)))
    (arrow1b (pts (xy 107.696 27.432) (xy 106.569496 26.845579)))
    (arrow2a (pts (xy 46.228 27.432) (xy 47.354504 28.018421)))
    (arrow2b (pts (xy 46.228 27.432) (xy 47.354504 26.845579)))
  (gr_text . (at 56.388 53.34) (layer F.Cu) (tstamp 5EAAF328)
    (effects (font (size 2 2) (thickness 0.3)))
  (gr_text . (at 47.244 63.5) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 42.164 73.152) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 40.132 83.82) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 41.148 97.028) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 118.872 97.028) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 120.904 84.328) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 118.364 71.12) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 111.76 62.992) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 104.14 54.864) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 92.964 49.784) (layer F.Cu) (tstamp 5EAAF328)
  (gr_text . (at 69.596 49.784) (layer F.Cu)
  (gr_line (start 34.036 97.028) (end 23.714392 95.895327) (layer Edge.Cuts) (width 0.05) (tstamp 5EAAB09F))
  (gr_arc (start 75.692 90.424) (end 53.340002 43.180002) (angle -70.68931957) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 49.738522 63.258543) (end 50.8 65.024) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D668))
  (gr_arc (start 57.912 64.516) (end 59.435999 56.388001) (angle -91.87349301) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 112.775999 86.867999) (end 111.76 87.376) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D667))
  (gr_line (start 109.267318 73.655834) (end 108.712 73.66) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D666))
  (gr_arc (start 107.188 81.28) (end 112.775999 86.867999) (angle -119.7448813) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 121.48709 64.44091) (end 113.791999 63.500001) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D664))
  (gr_line (start 122.428 68.072) (end 118.584666 72.904485) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D663))
  (gr_line (start 122.329745 100.628945) (end 119.379999 99.567999) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D622))
  (gr_line (start 118.364 106.172) (end 118.364001 106.172001) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D621))
  (gr_line (start 122.936 105.156) (end 118.364 106.172) (layer Edge.Cuts) (width 0.05))
  (gr_text "Corrado 16VG60" (at 51.816 87.376) (layer F.Cu)
    (effects (font (size 1.5 1.5) (thickness 0.3)))
  (gr_text "Design By Ronny Pech" (at 88.9 76.708 16) (layer F.Cu)
  (gr_line (start 111.76 87.376) (end 87.884 94.996) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D0CF))
  (gr_line (start 108.712 73.66) (end 75.184 83.522419) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9D0CE))
  (gr_line (start 50.8 65.024) (end 67.056 94.996) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9CBF3))
  (gr_line (start 59.436 56.388) (end 74.676001 83.311999) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9CBF2))
  (gr_line (start 44.196 94.996) (end 67.056 94.996) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 44.396054 116.176901) (end 44.196 94.996) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 75.692 86.868) (end 34.036 97.028) (angle -29.41516057) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 60.96 40.21916) (end 53.34 43.18) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 60.96 41.656) (end 61.975999 40.640001) (angle -45) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 66.040001 44.195999) (end 61.976 40.64) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 66.548 44.406419) (end 67.529329 44.236247) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9C9AD))
  (gr_arc (start 66.548 43.688) (end 66.040001 44.195999) (angle -45) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 76.708 87.376) (end 113.791999 63.500001) (angle -69.23660106) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 118.872 67.056) (end 122.428 68.072) (angle -60.9453959) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 80.772 87.376) (end 119.379999 99.567999) (angle -38.46821892) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 120.904 103.124) (end 122.936 105.156) (angle -105.2551311) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 116.590446 107.625968) (end 116.523376 107.77574) (layer Edge.Cuts) (width 0.05) (tstamp 5EA9C982))
  (gr_arc (start 119.38 109.22) (end 118.364001 106.172001) (angle -41.82016988) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 98.044 100.076) (end 109.727999 116.331999) (angle -31.67344365) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 109.728 94.996) (end 109.728 116.332) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 87.884 94.996) (end 109.728 94.996) (layer Edge.Cuts) (width 0.05))
  (gr_arc (start 75.184 82.804) (end 74.676001 83.311999) (angle -45) (layer Edge.Cuts) (width 0.05))
  (gr_line (start 29.0042 88.2447) (end 28.9636 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8358 89.5731) (end 27.8003 89.6239) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.6232 88.6409) (end 28.58 88.686601) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4988 88.7755) (end 28.4556 88.8213) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.834 88.419901) (end 28.7909 88.4657) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.6275 89.8754) (end 27.5945 89.9287) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2524 89.0499) (end 28.2143 89.0956) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3743 88.9127) (end 28.3337 88.9584) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1355 89.1896) (end 28.0974 89.2353) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.5615 89.9795) (end 27.531 90.0328) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4149 88.867) (end 28.3743 88.9127) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2643 90.5408) (end 27.2592 90.551) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0212 89.3318) (end 27.9831 89.3775) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2694 90.5281) (end 27.2643 90.5408) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2948 90.4723) (end 27.2694 90.5281) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0593 89.2835) (end 28.0212 89.3318) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.293 89.0041) (end 28.2524 89.0499) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.6639 88.5977) (end 28.6232 88.6409) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0906 88.1583) (end 29.0474 88.2015) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.3227 90.4138) (end 27.2948 90.4723) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.3507 90.358) (end 27.3227 90.4138) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.58 88.686601) (end 28.5394 88.7298) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1736 89.1413) (end 28.1355 89.1896) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.3786 90.3046) (end 27.3507 90.358) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.4091 90.2487) (end 27.3786 90.3046) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.437 90.1929) (end 27.4091 90.2487) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8714 89.5248) (end 27.8358 89.5731) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3337 88.9584) (end 28.293 89.0041) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.498 90.0862) (end 27.4675 90.1395) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.531 90.0328) (end 27.498 90.0862) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.9636 88.2904) (end 28.9204 88.3336) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0974 89.2353) (end 28.0593 89.2835) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7647 89.6722) (end 27.7291 89.723) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.707 88.552001) (end 28.6639 88.5977) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8003 89.6239) (end 27.7647 89.6722) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.5394 88.7298) (end 28.4988 88.7755) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.7502 88.5088) (end 28.707 88.552001) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.6606 89.8246) (end 27.6275 89.8754) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.5945 89.9287) (end 27.5615 89.9795) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9069 89.474) (end 27.8714 89.5248) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2143 89.0956) (end 28.1736 89.1413) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.8772 88.3768) (end 28.834 88.419901) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.9204 88.3336) (end 28.8772 88.3768) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7291 89.723) (end 27.6936 89.7738) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.6936 89.7738) (end 27.6606 89.8246) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.945 89.4258) (end 27.9069 89.474) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9831 89.3775) (end 27.945 89.4258) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.7909 88.4657) (end 28.7502 88.5088) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0474 88.2015) (end 29.0042 88.2447) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.4675 90.1395) (end 27.437 90.1929) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4556 88.8213) (end 28.4149 88.867) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.562 85.5955) (end 31.5214 85.6386) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.568899 86.6318) (end 30.5282 86.6724) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.436 87.8103) (end 29.3928 87.8535) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.6494 87.5894) (end 29.6062 87.6351) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6788 85.471) (end 31.6382 85.5116) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.7332 87.5005) (end 29.69 87.546201) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8526 87.376) (end 29.8119 87.4166) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.2895 86.9213) (end 30.2488 86.962) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.5282 86.6724) (end 30.4876 86.7131) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.6476 86.548) (end 30.6095 86.5911) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0507 87.1677) (end 30.0101 87.2109) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.1701 87.0458) (end 30.1294 87.0864) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2445 85.9282) (end 31.2064 85.9714) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.3639 85.8037) (end 31.3232 85.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6382 85.5116) (end 31.6001 85.5548) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.69 87.546201) (end 29.6494 87.5894) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8119 87.4166) (end 29.7713 87.4598) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8907 87.3354) (end 29.8526 87.376) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.2107 87.0026) (end 30.1701 87.0458) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0913 87.1271) (end 30.0507 87.1677) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.1294 87.0864) (end 30.0913 87.1271) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.4495 86.7562) (end 30.4088 86.7969) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.6095 86.5911) (end 30.568899 86.6318) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.767 86.426) (end 30.7289 86.4667) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.927 86.2609) (end 30.8864 86.3016) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.9676 86.2178) (end 30.927 86.2609) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4833 85.6793) (end 31.4426 85.7199) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.087 86.0958) (end 31.0464 86.1365) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2851 85.8876) (end 31.2445 85.9282) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4045 85.7631) (end 31.3639 85.8037) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.5214 85.6386) (end 31.4833 85.6793) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4426 85.7199) (end 31.4045 85.7631) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2064 85.9714) (end 31.1658 86.012) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.3682 86.8375) (end 30.3301 86.8782) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.1338 88.1151) (end 29.0906 88.1583) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.1769 88.072) (end 29.1338 88.1151) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.7713 87.4598) (end 29.7332 87.5005) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.2201 88.0288) (end 29.1769 88.072) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0464 86.1365) (end 31.0057 86.1771) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.1251 86.0527) (end 31.087 86.0958) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.7289 86.4667) (end 30.6882 86.5073) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.6062 87.6351) (end 29.563 87.6783) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.6882 86.5073) (end 30.6476 86.548) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.1658 86.012) (end 31.1251 86.0527) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8483 86.3422) (end 30.8076 86.3829) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0101 87.2109) (end 29.972 87.2515) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.972 87.2515) (end 29.9313 87.2922) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.3301 86.8782) (end 30.2895 86.9213) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.2633 87.9831) (end 29.2201 88.0288) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.4792 87.7646) (end 29.436 87.8103) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.563 87.6783) (end 29.5198 87.7214) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.2488 86.962) (end 30.2107 87.0026) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.5198 87.7214) (end 29.4792 87.7646) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.4088 86.7969) (end 30.3682 86.8375) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.9313 87.2922) (end 29.8907 87.3354) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.4876 86.7131) (end 30.4495 86.7562) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8076 86.3829) (end 30.767 86.426) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8864 86.3016) (end 30.8483 86.3422) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.3232 85.8469) (end 31.2851 85.8876) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6001 85.5548) (end 31.562 85.5955) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0057 86.1771) (end 30.9676 86.2178) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3065 87.9399) (end 29.2633 87.9831) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3497 87.8967) (end 29.3065 87.9399) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3928 87.8535) (end 29.3497 87.8967) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3367 84.709) (end 32.3316 84.7192) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3494 84.676) (end 32.3469 84.6861) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.357 84.6506) (end 32.3545 84.6633) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3773 84.5769) (end 32.3748 84.5896) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3697 84.615) (end 32.3646 84.6277) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3926 84.5007) (end 32.39 84.5134) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4205 84.2391) (end 32.4205 84.2543) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3951 84.4855) (end 32.3926 84.5007) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4078 84.3915) (end 32.4053 84.4042) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4154 84.3229) (end 32.4129 84.3356) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3113 84.7623) (end 32.3062 84.7725) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4002 84.4601) (end 32.3977 84.4728) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3469 84.6861) (end 32.3418 84.6988) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4129 84.3509) (end 32.4104 84.3636) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4053 84.4042) (end 32.4053 84.4194) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3748 84.5896) (end 32.3723 84.6023) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3621 84.6404) (end 32.357 84.6506) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9887 85.1332) (end 31.9506 85.1764) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1437 84.963) (end 32.1056 85.0062) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3723 84.6023) (end 32.3697 84.615) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3799 84.5642) (end 32.3773 84.5769) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3875 84.5261) (end 32.385 84.5388) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4027 84.4321) (end 32.4002 84.4448) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1818 84.9224) (end 32.1437 84.963) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2656 84.8284) (end 32.258 84.836) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2986 84.7827) (end 32.2935 84.7903) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3265 84.7293) (end 32.3215 84.742) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3164 84.7522) (end 32.3113 84.7623) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3824 84.5515) (end 32.3799 84.5642) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3215 84.742) (end 32.3164 84.7522) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3316 84.7192) (end 32.3265 84.7293) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.385 84.5388) (end 32.3824 84.5515) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2859 84.8004) (end 32.2808 84.8106) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.8338 85.3034) (end 31.7957 85.344) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9125 85.217) (end 31.8744 85.2602) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3545 84.6633) (end 32.3494 84.676) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9506 85.1764) (end 31.9125 85.217) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4002 84.4448) (end 32.4002 84.4601) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.258 84.836) (end 32.2199 84.8792) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2732 84.8182) (end 32.2656 84.8284) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3646 84.6277) (end 32.3621 84.6404) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0675 85.0494) (end 32.0294 85.09) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2808 84.8106) (end 32.2732 84.8182) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.418 84.267) (end 32.418 84.2823) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4053 84.4194) (end 32.4027 84.4321) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4205 84.2543) (end 32.418 84.267) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3977 84.4728) (end 32.3951 84.4855) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4154 84.3077) (end 32.4154 84.3229) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.7169 85.4278) (end 31.6788 85.471) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.7576 85.3872) (end 31.7169 85.4278) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.7957 85.344) (end 31.7576 85.3872) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0294 85.09) (end 31.9887 85.1332) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4129 84.3356) (end 32.4129 84.3509) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1056 85.0062) (end 32.0675 85.0494) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.39 84.5134) (end 32.3875 84.5261) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.418 84.2823) (end 32.4154 84.295) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2199 84.8792) (end 32.1818 84.9224) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3062 84.7725) (end 32.2986 84.7827) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3418 84.6988) (end 32.3367 84.709) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4154 84.295) (end 32.4154 84.3077) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4078 84.3788) (end 32.4078 84.3915) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4104 84.3636) (end 32.4078 84.3788) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.8744 85.2602) (end 31.8338 85.3034) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2935 84.7903) (end 32.2859 84.8004) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5424 82.7126) (end 32.5348 82.8091) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4281 84.1299) (end 32.4281 84.1451) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4764 83.566) (end 32.4688 83.66) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4307 84.0918) (end 32.4307 84.1045) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.451 83.8505) (end 32.4434 83.9445) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5145 83.0936) (end 32.5069 83.1875) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6567 81.1022) (end 32.6491 81.1962) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4332 84.0537) (end 32.4332 84.0664) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.771 79.7789) (end 32.7609 79.8728) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4358 84.0384) (end 32.4332 84.0537) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7177 80.3453) (end 32.7101 80.4393) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5805 82.1436) (end 32.5755 82.2401) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7431 80.0608) (end 32.7355 80.1548) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6009 81.8591) (end 32.5958 81.9556) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6771 80.8177) (end 32.672 80.9117) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6415 81.2902) (end 32.6364 81.3867) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.672 80.9117) (end 32.6644 81.0057) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6847 80.7237) (end 32.6771 80.8177) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7507 79.9668) (end 32.7431 80.0608) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6491 81.1962) (end 32.6415 81.2902) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7355 80.1548) (end 32.7253 80.2488) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.484 83.472) (end 32.4764 83.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4332 84.0791) (end 32.4307 84.0918) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5551 82.5246) (end 32.5475 82.6186) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4256 84.1578) (end 32.4256 84.1705) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8091 79.4004) (end 32.799 79.4944) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4688 83.66) (end 32.4612 83.7565) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7253 80.2488) (end 32.7177 80.3453) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4281 84.1172) (end 32.4281 84.1299) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6085 81.7651) (end 32.6009 81.8591) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4205 84.2264) (end 32.4205 84.2391) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4231 84.2112) (end 32.4205 84.2264) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4231 84.1985) (end 32.4231 84.2112) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7888 79.5884) (end 32.7787 79.6823) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4256 84.1858) (end 32.4231 84.1985) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4332 84.0664) (end 32.4332 84.0791) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6644 81.0057) (end 32.6567 81.1022) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4281 84.1451) (end 32.4256 84.1578) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5348 82.8091) (end 32.5272 82.9031) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4307 84.1045) (end 32.4281 84.1172) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4612 83.7565) (end 32.451 83.8505) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6364 81.3867) (end 32.6288 81.4807) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4916 83.378) (end 32.484 83.472) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5678 82.3341) (end 32.5628 82.4281) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4993 83.2815) (end 32.4916 83.378) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7101 80.4393) (end 32.7025 80.5332) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7025 80.5332) (end 32.6923 80.6272) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7787 79.6823) (end 32.771 79.7789) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5755 82.2401) (end 32.5678 82.3341) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5196 82.997) (end 32.5145 83.0936) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6288 81.4807) (end 32.6212 81.5746) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7609 79.8728) (end 32.7507 79.9668) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5272 82.9031) (end 32.5196 82.997) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.799 79.4944) (end 32.7888 79.5884) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5628 82.4281) (end 32.5551 82.5246) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4256 84.1705) (end 32.4256 84.1858) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6212 81.5746) (end 32.6161 81.6712) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5069 83.1875) (end 32.4993 83.2815) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6161 81.6712) (end 32.6085 81.7651) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6923 80.6272) (end 32.6847 80.7237) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5475 82.6186) (end 32.5424 82.7126) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5882 82.0496) (end 32.5805 82.1436) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4434 83.9445) (end 32.4358 84.0384) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5958 81.9556) (end 32.5882 82.0496) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.279 76.5835) (end 33.2587 76.6648) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.865 78.9305) (end 32.8523 79.0245) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3171 76.4184) (end 33.2968 76.4997) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4568 75.8393) (end 33.4365 75.9231) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7693 74.6912) (end 33.7464 74.7725) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4162 76.0044) (end 33.3959 76.0882) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1546 77.1627) (end 33.1368 77.2465) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7921 74.61) (end 33.7693 74.6912) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6981 74.9376) (end 33.6753 75.0189) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9565 78.2752) (end 32.9412 78.3692) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8777 78.8365) (end 32.865 78.9305) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9826 73.9572) (end 33.9598 74.0385) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8904 78.7425) (end 32.8777 78.8365) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9031 78.6486) (end 32.8904 78.7425) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1038 77.4116) (end 33.0885 77.4954) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9158 78.5546) (end 32.9031 78.6486) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9717 78.1812) (end 32.9565 78.2752) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3959 76.0882) (end 33.3756 76.1695) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8632 74.3661) (end 33.8404 74.4474) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9285 78.4606) (end 32.9158 78.5546) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0276 77.8281) (end 33.0149 77.912) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9412 78.3692) (end 32.9285 78.4606) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9844 78.0872) (end 32.9717 78.1812) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2968 76.4997) (end 33.279 76.5835) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2409 76.7486) (end 33.2232 76.8299) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7464 74.7725) (end 33.721 74.8563) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6092 75.2653) (end 33.5864 75.3466) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9598 74.0385) (end 33.9344 74.1197) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0149 77.912) (end 32.9996 77.9932) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3756 76.1695) (end 33.3552 76.2533) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.815 74.5287) (end 33.7921 74.61) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5864 75.3466) (end 33.5635 75.4304) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3552 76.2533) (end 33.3349 76.3346) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5 75.6768) (end 33.4797 75.758) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6753 75.0189) (end 33.6524 75.1002) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9115 74.201) (end 33.8861 74.2823) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9996 77.9932) (end 32.9844 78.0872) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4797 75.758) (end 33.4568 75.8393) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0428 77.7443) (end 33.0276 77.8281) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0581 77.6605) (end 33.0428 77.7443) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0733 77.5767) (end 33.0581 77.6605) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1698 77.0788) (end 33.1546 77.1627) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.721 74.8563) (end 33.6981 74.9376) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9344 74.1197) (end 33.9115 74.201) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1368 77.2465) (end 33.1216 77.3278) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5635 75.4304) (end 33.5432 75.5117) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1876 76.9976) (end 33.1698 77.0788) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2054 76.9137) (end 33.1876 76.9976) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2587 76.6648) (end 33.2409 76.7486) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6321 75.184) (end 33.6092 75.2653) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8404 74.4474) (end 33.815 74.5287) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5432 75.5117) (end 33.5203 75.5929) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6524 75.1002) (end 33.6321 75.184) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0885 77.4954) (end 33.0733 77.5767) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2232 76.8299) (end 33.2054 76.9137) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5203 75.5929) (end 33.5 75.6768) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8193 79.3064) (end 32.8091 79.4004) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.832 79.2124) (end 32.8193 79.3064) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8422 79.1185) (end 32.832 79.2124) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3349 76.3346) (end 33.3171 76.4184) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4365 75.9231) (end 33.4162 76.0044) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8523 79.0245) (end 32.8422 79.1185) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1216 77.3278) (end 33.1038 77.4116) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8861 74.2823) (end 33.8632 74.3661) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9765 68.5089) (end 35.9156 68.6435) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7243 71.6255) (end 34.6786 71.7652) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.8757 66.6725) (end 36.8071 66.802) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1579 73.3882) (end 34.1325 73.4695) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1807 73.3069) (end 34.1579 73.3882) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4017 72.5983) (end 34.3585 72.7405) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2229 67.9806) (end 36.1619 68.1126) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.3499 67.7164) (end 36.2864 67.8485) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2061 73.2257) (end 34.1807 73.3069) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.008 73.8759) (end 33.9826 73.9572) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.4134 67.5869) (end 36.3499 67.7164) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0334 73.7946) (end 34.008 73.8759) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0563 73.7133) (end 34.0334 73.7946) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0817 73.6321) (end 34.0563 73.7133) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2348 70.2564) (end 35.1815 70.391) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3415 69.9846) (end 35.2882 70.1192) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2823 72.9818) (end 34.2569 73.0631) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7378 69.0423) (end 35.6819 69.1769) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.15 66.1568) (end 37.0814 66.2864) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2864 67.8485) (end 36.2229 67.9806) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2569 73.0631) (end 34.2315 73.1444) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.4794 67.4548) (end 36.4134 67.5869) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1282 70.5282) (end 35.0748 70.6653) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5363 72.1817) (end 34.4906 72.3214) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.0128 66.4159) (end 36.9443 66.5455) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9732 70.9371) (end 34.9224 71.0743) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4533 69.7128) (end 35.3974 69.85) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1619 68.1126) (end 36.0984 68.2447) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1071 73.5508) (end 34.0817 73.6321) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3077 72.9005) (end 34.2823 72.9818) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5092 69.5782) (end 35.4533 69.7128) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.0814 66.2864) (end 37.0128 66.4159) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6819 69.1769) (end 35.6235 69.3115) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4906 72.3214) (end 34.4474 72.4586) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6303 71.9023) (end 34.5821 72.042) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8716 71.2114) (end 34.8234 71.3511) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7726 71.4883) (end 34.7243 71.6255) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1325 73.4695) (end 34.1071 73.5508) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6235 69.3115) (end 35.565 69.4436) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3331 72.8193) (end 34.3077 72.9005) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5821 72.042) (end 34.5363 72.1817) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9224 71.0743) (end 34.8716 71.2114) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0748 70.6653) (end 35.024 70.8) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.675 67.0636) (end 36.609 67.1932) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.9443 66.5455) (end 36.8757 66.6725) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.8071 66.802) (end 36.7411 66.9341) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2315 73.1444) (end 34.2061 73.2257) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8571 68.7756) (end 35.7987 68.9077) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9156 68.6435) (end 35.8571 68.7756) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3585 72.7405) (end 34.3331 72.8193) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.565 69.4436) (end 35.5092 69.5782) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.609 67.1932) (end 36.5429 67.3227) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7987 68.9077) (end 35.7378 69.0423) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4474 72.4586) (end 34.4017 72.5983) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8234 71.3511) (end 34.7726 71.4883) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1815 70.391) (end 35.1282 70.5282) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2882 70.1192) (end 35.2348 70.2564) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0375 68.3768) (end 35.9765 68.5089) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6786 71.7652) (end 34.6303 71.9023) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3974 69.85) (end 35.3415 69.9846) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.024 70.8) (end 34.9732 70.9371) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0984 68.2447) (end 36.0375 68.3768) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.5429 67.3227) (end 36.4794 67.4548) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.7411 66.9341) (end 36.675 67.0636) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.7002 62.0497) (end 39.6417 62.1386) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.3641 64.0791) (end 38.3082 64.168) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.5663 60.8533) (end 40.5053 60.9371) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.1454 60.0989) (end 41.0819 60.1828) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.2922 65.9003) (end 37.2211 66.0298) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.8739 64.8843) (end 37.7977 65.0113) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.944 61.7068) (end 39.883 61.7906) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.0685 61.534) (end 40.005 61.6204) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.3634 65.7733) (end 37.2922 65.9003) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.4345 65.6463) (end 37.3634 65.7733) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.1294 61.4477) (end 40.0685 61.534) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.5793 65.3923) (end 37.5056 65.5193) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.6504 65.2653) (end 37.5793 65.3923) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.0819 60.1828) (end 41.0159 60.264) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.9331 63.1876) (end 38.8747 63.2765) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.0474 63.0123) (end 38.9915 63.0987) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.1 64.5084) (end 38.0238 64.6328) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.4614 62.3976) (end 39.4004 62.484) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.8228 60.5155) (end 40.7593 60.5993) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.005 61.6204) (end 39.944 61.7068) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.6461 63.6321) (end 38.5876 63.721) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.1904 61.3639) (end 40.1294 61.4477) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.8162 63.3654) (end 38.7604 63.4543) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.6933 60.6857) (end 40.6298 60.7695) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.0159 60.264) (end 40.9524 60.3479) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.9524 60.3479) (end 40.8863 60.4317) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.1642 62.8345) (end 39.1058 62.9234) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.883 61.7906) (end 39.8221 61.8769) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.2252 62.7482) (end 39.1642 62.8345) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.2115 60.0151) (end 41.1454 60.0989) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.7593 60.5993) (end 40.6933 60.6857) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.8863 60.4317) (end 40.8228 60.5155) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.4004 62.484) (end 39.342 62.5729) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.0238 64.6328) (end 37.9476 64.7598) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.2524 64.2569) (end 38.1762 64.3814) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.5318 63.8099) (end 38.4759 63.8988) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.42 63.9877) (end 38.3641 64.0791) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.2211 66.0298) (end 37.15 66.1568) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.342 62.5729) (end 39.2836 62.6593) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.724 65.1383) (end 37.6504 65.2653) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.1762 64.3814) (end 38.1 64.5084) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.5876 63.721) (end 38.5318 63.8099) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.7604 63.4543) (end 38.7019 63.5432) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.3783 61.1073) (end 40.3148 61.1937) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.6298 60.7695) (end 40.5663 60.8533) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.5053 60.9371) (end 40.4418 61.0235) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.5056 65.5193) (end 37.4345 65.6463) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.5808 62.2249) (end 39.5198 62.3113) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.6417 62.1386) (end 39.5808 62.2249) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.7977 65.0113) (end 37.724 65.1383) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.2836 62.6593) (end 39.2252 62.7482) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.3148 61.1937) (end 40.2539 61.2775) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.5198 62.3113) (end 39.4614 62.3976) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.9476 64.7598) (end 37.8739 64.8843) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.4759 63.8988) (end 38.42 63.9877) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.8747 63.2765) (end 38.8162 63.3654) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.9915 63.0987) (end 38.9331 63.1876) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.7611 61.9633) (end 39.7002 62.0497) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.3082 64.168) (end 38.2524 64.2569) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.1058 62.9234) (end 39.0474 63.0123) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.7019 63.5432) (end 38.6461 63.6321) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.8221 61.8769) (end 39.7611 61.9633) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.2539 61.2775) (end 40.1904 61.3639) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.4418 61.0235) (end 40.3783 61.1073) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.2104 57.6351) (end 43.1342 57.7215) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8266 54.803) (end 45.7454 54.8869) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0756 54.5567) (end 45.9917 54.637901) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.7515 57.0205) (end 43.6753 57.1094) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8564 55.814) (end 44.7751 55.8978) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.5965 57.1957) (end 43.5203 57.2821) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.5221 58.4302) (end 42.4459 58.5191) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9351 55.7276) (end 44.8564 55.814) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6176 56.0705) (end 44.5363 56.1543) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.6077 59.5198) (end 41.5417 59.6011) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.4096 59.7662) (end 41.3435 59.85) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5828 55.0545) (end 45.5015 55.138301) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.4756 59.6849) (end 41.4096 59.7662) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.5417 59.6011) (end 41.4756 59.6849) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.2935 58.6969) (end 42.2173 58.7883) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.6737 59.4385) (end 41.6077 59.5198) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.7423 59.3573) (end 41.6737 59.4385) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.5203 57.2821) (end 43.4416 57.371) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1764 55.4736) (end 45.0951 55.557401) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.8084 59.2734) (end 41.7423 59.3573) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.9455 59.1109) (end 41.8769 59.1922) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.8769 59.1922) (end 41.8084 59.2734) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.9031 57.9882) (end 42.8269 58.0771) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.1342 57.7215) (end 43.058 57.8104) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.3654 57.4599) (end 43.2892 57.5462) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7751 55.8978) (end 44.6963 55.9841) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.3001 56.4134) (end 44.2214 56.4998) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5015 55.138301) (end 45.4202 55.2221) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.4416 57.371) (end 43.3654 57.4599) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.9089 56.847701) (end 43.8302 56.934101) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0164 55.6438) (end 44.9351 55.7276) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.2214 56.4998) (end 44.1426 56.586101) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.5363 56.1543) (end 44.4576 56.2407) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7454 54.8869) (end 45.6641 54.9707) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9105 54.721801) (end 45.8266 54.803) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.339 55.306) (end 45.2577 55.3898) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.0116 59.0296) (end 41.9455 59.1109) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.8302 56.934101) (end 43.7515 57.0205) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.0801 58.9483) (end 42.0116 59.0296) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.1487 58.867) (end 42.0801 58.9483) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.4459 58.5191) (end 42.3697 58.608) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.5983 58.3413) (end 42.5221 58.4302) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6963 55.9841) (end 44.6176 56.0705) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4202 55.2221) (end 45.339 55.306) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.6745 58.2524) (end 42.5983 58.3413) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.1426 56.586101) (end 44.0639 56.6725) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9917 54.637901) (end 45.9105 54.721801) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.7507 58.166) (end 42.6745 58.2524) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.9818 57.8993) (end 42.9031 57.9882) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.3788 56.327) (end 44.3001 56.4134) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0951 55.557401) (end 45.0164 55.6438) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.0639 56.6725) (end 43.9851 56.7588) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.4576 56.2407) (end 44.3788 56.327) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.2173 58.7883) (end 42.1487 58.867) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.8269 58.0771) (end 42.7507 58.166) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.9851 56.7588) (end 43.9089 56.847701) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.2775 59.9313) (end 41.2115 60.0151) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.3435 59.85) (end 41.2775 59.9313) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.3697 58.608) (end 42.2935 58.6969) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.2892 57.5462) (end 43.2104 57.6351) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.6753 57.1094) (end 43.5965 57.1957) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6641 54.9707) (end 45.5828 55.0545) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.058 57.8104) (end 42.9818 57.8993) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2577 55.3898) (end 45.1764 55.4736) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.597 53.1266) (end 47.5742 53.147) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3684 53.3273) (end 47.3481 53.3476) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.9221 52.8549) (end 47.8993 52.8726) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1355 52.6847) (end 48.1126 52.7025) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.9163 53.7439) (end 46.8325 53.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1754 53.5051) (end 47.089 53.5864) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6885 53.0479) (end 47.6656 53.0682) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.7342 53.0098) (end 47.7113 53.0276) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5056 53.2079) (end 47.4827 53.2257) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3057 52.5551) (end 48.2803 52.5729) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.7596 52.9895) (end 47.7342 53.0098) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.0027 53.6651) (end 46.9163 53.7439) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2617 53.4264) (end 47.1754 53.5051) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1126 52.7025) (end 48.0898 52.7202) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3481 53.3476) (end 47.2617 53.4264) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3913 53.307) (end 47.3684 53.3273) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4599 53.246) (end 47.437 53.2663) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3311 52.5374) (end 48.3057 52.5551) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0161 52.7787) (end 47.9933 52.7964) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.7113 53.0276) (end 47.6885 53.0479) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4276 52.4637) (end 48.4047 52.4815) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.7824 52.9692) (end 47.7596 52.9895) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4141 53.2867) (end 47.3913 53.307) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.9704 52.8168) (end 47.945 52.8345) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0898 52.7202) (end 48.0644 52.7406) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0644 52.7406) (end 48.0415 52.7583) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.437 53.2663) (end 47.4141 53.2867) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6656 53.0682) (end 47.6427 53.0885) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4047 52.4815) (end 48.3793 52.4993) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1609 52.6644) (end 48.1355 52.6847) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.9933 52.7964) (end 47.9704 52.8168) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0415 52.7583) (end 48.0161 52.7787) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3539 52.5196) (end 48.3311 52.5374) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1594 54.4728) (end 46.0756 54.5567) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.8325 53.8251) (end 46.7461 53.9039) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1838 52.6466) (end 48.1609 52.6644) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.2407 54.3916) (end 46.1594 54.4728) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.3245 54.3103) (end 46.2407 54.3916) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.089 53.5864) (end 47.0027 53.6651) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5513 53.1673) (end 47.5284 53.1876) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5742 53.147) (end 47.5513 53.1673) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.851 52.9107) (end 47.8282 52.9311) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.8993 52.8726) (end 47.8764 52.893) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2092 52.6288) (end 48.1838 52.6466) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.945 52.8345) (end 47.9221 52.8549) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4784 52.4281) (end 48.453 52.4459) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.232 52.6085) (end 48.2092 52.6288) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2574 52.5907) (end 48.232 52.6085) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3793 52.4993) (end 48.3539 52.5196) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2803 52.5729) (end 48.2574 52.5907) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5013 52.4104) (end 48.4784 52.4281) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.8282 52.9311) (end 47.8053 52.9514) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5284 53.1876) (end 47.5056 53.2079) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.4083 54.229) (end 46.3245 54.3103) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.453 52.4459) (end 48.4276 52.4637) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4827 53.2257) (end 47.4599 53.246) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.4921 54.147701) (end 46.4083 54.229) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6199 53.1063) (end 47.597 53.1266) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.5785 54.066401) (end 46.4921 54.147701) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.6623 53.9852) (end 46.5785 54.066401) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.7461 53.9039) (end 46.6623 53.9852) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6427 53.0885) (end 47.6199 53.1063) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.8053 52.9514) (end 47.7824 52.9692) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.8764 52.893) (end 47.851 52.9107) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3903 51.6585) (end 49.3801 51.6763) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4258 51.6052) (end 49.4157 51.623) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.469 51.5315) (end 49.4588 51.5493) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2302 51.8617) (end 49.215 51.877) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4487 51.5671) (end 49.4385 51.5874) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.53 51.4147) (end 49.5198 51.435) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2455 51.8439) (end 49.2302 51.8617) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4385 51.5874) (end 49.4258 51.6052) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4588 51.5493) (end 49.4487 51.5671) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5267 52.3926) (end 48.5013 52.4104) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5521 52.3748) (end 48.5267 52.3926) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3547 51.7119) (end 49.342 51.7271) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5749 52.3596) (end 48.5521 52.3748) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6003 52.3418) (end 48.5749 52.3596) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6257 52.324) (end 48.6003 52.3418) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6511 52.3062) (end 48.6257 52.324) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9381 52.1132) (end 48.9178 52.1284) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2887 51.7957) (end 49.2734 51.8109) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4893 51.4934) (end 49.4792 51.5112) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7502 52.2376) (end 48.7248 52.2554) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4792 51.5112) (end 49.469 51.5315) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8264 52.1868) (end 48.801 52.2046) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8975 52.1411) (end 48.8772 52.1538) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5554 51.3537) (end 49.5477 51.374) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9178 52.1284) (end 48.8975 52.1411) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.215 51.877) (end 49.1998 51.8922) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.121 51.9684) (end 49.1032 51.9836) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.342 51.7271) (end 49.3293 51.7449) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0321 52.0421) (end 49.0143 52.0573) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1032 51.9836) (end 49.0855 51.9989) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2607 51.8287) (end 49.2455 51.8439) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1693 51.9227) (end 49.154 51.9379) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3801 51.6763) (end 49.3674 51.6941) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.403 51.6407) (end 49.3903 51.6585) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4995 51.4731) (end 49.4893 51.4934) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3166 51.7627) (end 49.3014 51.7779) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5477 51.374) (end 49.5376 51.3944) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0143 52.0573) (end 48.994 52.0725) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6765 52.2884) (end 48.6511 52.3062) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6994 52.2732) (end 48.6765 52.2884) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5096 51.4528) (end 49.4995 51.4731) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1998 51.8922) (end 49.1845 51.9074) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3293 51.7449) (end 49.3166 51.7627) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5655 51.3334) (end 49.5554 51.3537) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7248 52.2554) (end 48.6994 52.2732) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0855 51.9989) (end 49.0677 52.0141) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4157 51.623) (end 49.403 51.6407) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7756 52.2224) (end 48.7502 52.2376) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.801 52.2046) (end 48.7756 52.2224) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1363 51.9532) (end 49.121 51.9684) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2734 51.8109) (end 49.2607 51.8287) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0677 52.0141) (end 49.0499 52.0294) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.154 51.9379) (end 49.1363 51.9532) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8518 52.1716) (end 48.8264 52.1868) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5198 51.435) (end 49.5096 51.4528) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0499 52.0294) (end 49.0321 52.0421) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8772 52.1538) (end 48.8518 52.1716) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9559 52.1005) (end 48.9381 52.1132) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9762 52.0852) (end 48.9559 52.1005) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5376 51.3944) (end 49.53 51.4147) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.994 52.0725) (end 48.9762 52.0852) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3674 51.6941) (end 49.3547 51.7119) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1845 51.9074) (end 49.1693 51.9227) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3014 51.7779) (end 49.2887 51.7957) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4494 48.1711) (end 50.4266 48.2498) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9059 50.1396) (end 49.8856 50.2183) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6671 51.0286) (end 49.662 51.0515) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6933 47.3075) (end 50.6704 47.3862) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5155 47.9349) (end 50.4926 48.0136) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5587 47.7774) (end 50.5358 47.8561) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6247 47.5437) (end 50.6044 47.6225) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7586 50.6908) (end 49.7357 50.7695) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8856 50.2183) (end 49.8627 50.2971) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9491 49.9821) (end 49.9287 50.0609) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6722 51.0057) (end 49.6671 51.0286) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6951 50.927) (end 49.6722 51.0057) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2742 48.801) (end 50.2513 48.8798) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3377 48.5648) (end 50.3174 48.6435) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4926 48.0136) (end 50.4698 48.0924) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6704 47.3862) (end 50.6476 47.465) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5815 47.7012) (end 50.5587 47.7774) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7154 50.8483) (end 49.6951 50.927) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8424 50.3758) (end 49.8221 50.4546) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9287 50.0609) (end 49.9059 50.1396) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6476 47.465) (end 50.6247 47.5437) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7136 47.2288) (end 50.6933 47.3075) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0126 49.7459) (end 49.9922 49.8246) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0989 49.4309) (end 50.0786 49.5097) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1218 49.3522) (end 50.0989 49.4309) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1853 49.116) (end 50.165 49.1947) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4037 48.3286) (end 50.3834 48.4073) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2945 48.7223) (end 50.2742 48.801) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7365 47.15) (end 50.7136 47.2288) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3605 48.4861) (end 50.3377 48.5648) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4266 48.2498) (end 50.4037 48.3286) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3834 48.4073) (end 50.3605 48.4861) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2513 48.8798) (end 50.2285 48.9585) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7992 50.5333) (end 49.7789 50.612) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.596 51.2496) (end 49.5884 51.2724) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5358 47.8561) (end 50.5155 47.9349) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6112 51.2089) (end 49.6036 51.2293) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9922 49.8246) (end 49.9719 49.9034) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.165 49.1947) (end 50.1421 49.2735) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2081 49.0372) (end 50.1853 49.116) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6044 47.6225) (end 50.5815 47.7012) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5731 51.3131) (end 49.5655 51.3334) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9719 49.9034) (end 49.9491 49.9821) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2285 48.9585) (end 50.2081 49.0372) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0557 49.5884) (end 50.0354 49.6672) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6544 51.0743) (end 49.6468 51.0972) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6468 51.0972) (end 49.6417 51.12) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7789 50.612) (end 49.7586 50.6908) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5808 51.2928) (end 49.5731 51.3131) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5884 51.2724) (end 49.5808 51.2928) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6036 51.2293) (end 49.596 51.2496) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7357 50.7695) (end 49.7154 50.8483) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6189 51.1861) (end 49.6112 51.2089) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8221 50.4546) (end 49.7992 50.5333) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6417 51.12) (end 49.6341 51.1429) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8627 50.2971) (end 49.8424 50.3758) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0354 49.6672) (end 50.0126 49.7459) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0786 49.5097) (end 50.0557 49.5884) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3174 48.6435) (end 50.2945 48.7223) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4698 48.0924) (end 50.4494 48.1711) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1421 49.2735) (end 50.1218 49.3522) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6265 51.1632) (end 49.6189 51.1861) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6341 51.1429) (end 49.6265 51.1632) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.662 51.0515) (end 49.6544 51.0743) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5112 44.5745) (end 51.4985 44.6126) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7593 47.0713) (end 50.7365 47.15) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3969 44.9148) (end 51.3867 44.9504) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8939 46.6014) (end 50.8711 46.6801) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3613 45.0266) (end 51.3486 45.0647) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4604 44.7269) (end 51.4477 44.7624) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1657 45.6717) (end 51.153 45.7073) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0082 46.2102) (end 50.9854 46.2864) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0971 45.8978) (end 51.087 45.9359) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2902 45.2526) (end 51.28 45.2907) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3257 45.1409) (end 51.3156 45.179) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2572 45.3669) (end 51.2445 45.405) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9854 46.2864) (end 50.9625 46.3652) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0768 45.974) (end 51.054 46.0527) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3384 45.1028) (end 51.3257 45.1409) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.805 46.9138) (end 50.7822 46.9925) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.628 44.2392) (end 51.6153 44.2773) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2216 45.4812) (end 51.2114 45.5193) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8482 46.7589) (end 50.8279 46.8376) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9397 46.4439) (end 50.9168 46.5226) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5874 44.3509) (end 51.5747 44.389) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4096 44.8767) (end 51.3969 44.9148) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3029 45.2171) (end 51.2902 45.2526) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5366 44.5008) (end 51.5239 44.5389) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2343 45.4431) (end 51.2216 45.4812) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7822 46.9925) (end 50.7593 47.0713) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3867 44.9504) (end 51.374 44.9885) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8279 46.8376) (end 50.805 46.9138) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2673 45.3288) (end 51.2572 45.3669) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6407 44.2036) (end 51.628 44.2392) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8711 46.6801) (end 50.8482 46.7589) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9168 46.5226) (end 50.8939 46.6014) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9625 46.3652) (end 50.9397 46.4439) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0311 46.1315) (end 51.0082 46.2102) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1759 45.6336) (end 51.1657 45.6717) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3156 45.179) (end 51.3029 45.2171) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.054 46.0527) (end 51.0311 46.1315) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.087 45.9359) (end 51.0768 45.974) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4985 44.6126) (end 51.4858 44.6507) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1429 45.7454) (end 51.1327 45.7835) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2445 45.405) (end 51.2343 45.4431) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.374 44.9885) (end 51.3613 45.0266) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4223 44.8386) (end 51.4096 44.8767) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.562 44.4271) (end 51.5493 44.4627) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.153 45.7073) (end 51.1429 45.7454) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.435 44.8005) (end 51.4223 44.8386) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1098 45.8597) (end 51.0971 45.8978) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.12 45.8216) (end 51.1098 45.8597) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5747 44.389) (end 51.562 44.4271) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1327 45.7835) (end 51.12 45.8216) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1886 45.5955) (end 51.1759 45.6336) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.28 45.2907) (end 51.2673 45.3288) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4731 44.6888) (end 51.4604 44.7269) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4858 44.6507) (end 51.4731 44.6888) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5493 44.4627) (end 51.5366 44.5008) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1987 45.5574) (end 51.1886 45.5955) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6686 44.1274) (end 51.6559 44.1655) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2114 45.5193) (end 51.1987 45.5574) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4477 44.7624) (end 51.435 44.8005) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6559 44.1655) (end 51.6407 44.2036) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5239 44.5389) (end 51.5112 44.5745) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6001 44.3154) (end 51.5874 44.3509) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3486 45.0647) (end 51.3384 45.1028) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6153 44.2773) (end 51.6001 44.3154) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2374 116.4158) (end 45.2221 116.398) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.339 116.5301) (end 45.3237 116.5149) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5117 116.6851) (end 45.5066 116.6876) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.311 116.4971) (end 45.2958 116.4819) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5193 116.6825) (end 45.5117 116.6851) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4914 116.6927) (end 45.4837 116.6952) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9453 116.0856) (end 44.93 116.0704) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0037 116.1517) (end 44.9884 116.1364) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0316 116.1847) (end 45.0164 116.1694) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 116.6546) (end 45.5853 116.6571) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9605 116.1034) (end 44.9453 116.0856) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0469 116.2025) (end 45.0316 116.1847) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9732 116.1186) (end 44.9605 116.1034) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5549 116.6698) (end 45.5422 116.6749) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2958 116.4819) (end 45.2805 116.4641) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9884 116.1364) (end 44.9732 116.1186) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1789 116.3498) (end 45.1637 116.332) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2221 116.398) (end 45.2069 116.3828) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0164 116.1694) (end 45.0037 116.1517) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5066 116.6876) (end 45.499 116.6901) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4406 116.647) (end 45.4253 116.6292) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5853 116.6571) (end 45.5777 116.6597) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2805 116.4641) (end 45.2653 116.4488) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5269 116.68) (end 45.5193 116.6825) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4253 116.6292) (end 45.4126 116.6139) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2653 116.4488) (end 45.2526 116.4311) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4837 116.6952) (end 45.4685 116.68) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.3694 116.5631) (end 45.3542 116.5479) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5701 116.6622) (end 45.5625 116.6673) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.3542 116.5479) (end 45.339 116.5301) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.09 116.2507) (end 45.0748 116.2355) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1205 116.2837) (end 45.1053 116.2685) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1332 116.299) (end 45.1205 116.2837) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.499 116.6901) (end 45.4914 116.6927) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4126 116.6139) (end 45.3974 116.5962) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5777 116.6597) (end 45.5701 116.6622) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1916 116.365) (end 45.1789 116.3498) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1485 116.3168) (end 45.1332 116.299) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4558 116.6622) (end 45.4406 116.647) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5422 116.6749) (end 45.5269 116.68) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.3974 116.5962) (end 45.3821 116.5809) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4685 116.68) (end 45.4558 116.6622) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1637 116.332) (end 45.1485 116.3168) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.3821 116.5809) (end 45.3694 116.5631) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0621 116.2177) (end 45.0469 116.2025) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0748 116.2355) (end 45.0621 116.2177) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2526 116.4311) (end 45.2374 116.4158) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.3237 116.5149) (end 45.311 116.4971) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1053 116.2685) (end 45.09 116.2507) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2069 116.3828) (end 45.1916 116.365) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5625 116.6673) (end 45.5549 116.6698) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.8138) (end 45.598 115.8265) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.3269) (end 45.598 116.3422) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.7834) (end 45.598 115.7986) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.5631) (end 45.598 116.5784) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.5479) (end 45.598 116.5631) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.4311) (end 45.598 116.4463) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.9307) (end 45.598 115.9459) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.9002) (end 45.598 115.9154) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.5352) (end 45.598 116.5479) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.652) (end 45.5904 116.6546) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.8875) (end 45.598 115.9002) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.6368) (end 45.598 116.652) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.5047) (end 45.598 116.52) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.1796) (end 45.598 116.1948) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.1517) (end 45.598 116.1669) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.0932) (end 45.598 116.1085) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.0475) (end 45.598 116.0628) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.4895) (end 45.598 116.5047) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.7249) (end 45.598 115.7402) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.9154) (end 45.598 115.9307) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.3879) (end 45.598 116.4006) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.8723) (end 45.598 115.8875) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.2101) (end 45.598 116.2253) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.7986) (end 45.598 115.8138) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.6216) (end 45.598 116.6368) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.2533) (end 45.598 116.2685) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.1212) (end 45.598 116.1364) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.9459) (end 45.598 115.9612) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.6089) (end 45.598 116.6216) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.7402) (end 45.598 115.7529) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.1085) (end 45.598 116.1212) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.4742) (end 45.598 116.4895) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.4006) (end 45.598 116.4158) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.7529) (end 45.598 115.7681) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.3574) (end 45.598 116.3726) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.2837) (end 45.598 116.299) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.3142) (end 45.598 116.3269) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.5936) (end 45.598 116.6089) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.5784) (end 45.598 116.5936) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.52) (end 45.598 116.5352) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.4615) (end 45.598 116.4742) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.3726) (end 45.598 116.3879) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.2685) (end 45.598 116.2837) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.2253) (end 45.598 116.2406) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.4463) (end 45.598 116.4615) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.4158) (end 45.598 116.4311) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.0196) (end 45.598 116.0348) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.0043) (end 45.598 116.0196) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.8265) (end 45.598 115.8418) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.3422) (end 45.598 116.3574) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.299) (end 45.598 116.3142) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.8418) (end 45.598 115.857) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.0348) (end 45.598 116.0475) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.2406) (end 45.598 116.2533) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.1948) (end 45.598 116.2101) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.1669) (end 45.598 116.1796) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.1364) (end 45.598 116.1517) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.9739) (end 45.598 115.9891) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.078) (end 45.598 116.0932) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 116.0628) (end 45.598 116.078) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.7681) (end 45.598 115.7834) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.9891) (end 45.598 116.0043) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.9612) (end 45.598 115.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.857) (end 45.598 115.8723) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 110.7516) (end 45.5955 110.8431) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 111.3028) (end 45.593 111.3942) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.4966) (end 45.5904 112.588) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 114.239) (end 45.5955 114.333) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.6795) (end 45.5904 112.7709) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 111.9454) (end 45.5904 112.0369) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 114.1476) (end 45.5955 114.239) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.7709) (end 45.5904 112.8624) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.588) (end 45.5904 112.6795) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.7097) (end 45.598 115.7249) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.6183) (end 45.598 115.7097) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.4135) (end 45.593 113.505) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.3414) (end 45.598 115.4328) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 114.9756) (end 45.598 115.0671) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 110.3833) (end 45.598 110.4748) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6006 110.2004) (end 45.598 110.2919) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 114.8817) (end 45.598 114.9756) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 113.8733) (end 45.5955 113.9647) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.3112) (end 45.5904 112.4026) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 114.6073) (end 45.598 114.6988) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.4026) (end 45.5904 112.4966) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 114.333) (end 45.5955 114.4245) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 110.5662) (end 45.5955 110.6602) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 111.6686) (end 45.5904 111.76) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 114.0562) (end 45.5955 114.1476) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 110.8431) (end 45.593 110.9345) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.505) (end 45.593 113.5964) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6006 110.015) (end 45.6006 110.109) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.6879) (end 45.593 113.7818) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.2307) (end 45.593 113.3221) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6031 109.9236) (end 45.6006 110.015) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.0452) (end 45.593 113.1392) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.2197) (end 45.5904 112.3112) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 111.76) (end 45.5904 111.854) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 111.4857) (end 45.5904 111.5771) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 111.0259) (end 45.593 111.1174) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 111.2088) (end 45.593 111.3028) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.4328) (end 45.598 115.5268) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 114.4245) (end 45.5955 114.5159) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.5964) (end 45.593 113.6879) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.1283) (end 45.5904 112.2197) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 111.5771) (end 45.5904 111.6686) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 110.9345) (end 45.593 111.0259) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 110.6602) (end 45.5955 110.7516) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.5268) (end 45.598 115.6183) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.0671) (end 45.598 115.1585) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 112.9538) (end 45.593 113.0452) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.25) (end 45.598 115.3414) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 115.1585) (end 45.598 115.25) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 114.7902) (end 45.598 114.8817) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 113.9647) (end 45.5955 114.0562) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 114.6988) (end 45.598 114.7902) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5955 114.5159) (end 45.5955 114.6073) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.0369) (end 45.5904 112.1283) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 111.1174) (end 45.593 111.2088) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 110.4748) (end 45.5955 110.5662) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.598 110.2919) (end 45.598 110.3833) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.7818) (end 45.5955 113.8733) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 111.854) (end 45.5904 111.9454) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6006 110.109) (end 45.6006 110.2004) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.3221) (end 45.593 113.4135) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 113.1392) (end 45.593 113.2307) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5904 112.8624) (end 45.593 112.9538) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.593 111.3942) (end 45.5904 111.4857) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7352 104.2137) (end 45.7327 104.3102) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6031 109.8321) (end 45.6031 109.9236) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6438 107.7976) (end 45.6412 107.8941) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6641 106.9264) (end 45.6615 107.0229) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6057 109.7356) (end 45.6031 109.8321) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6209 108.7653) (end 45.6209 108.8644) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7454 103.825) (end 45.7428 103.9216) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.626 108.5723) (end 45.6234 108.6688) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7174 104.9884) (end 45.7149 105.0849) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6844 106.2482) (end 45.6819 106.3447) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6285 108.4758) (end 45.626 108.5723) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6057 109.6391) (end 45.6057 109.7356) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6082 109.5426) (end 45.6057 109.6391) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6615 107.0229) (end 45.659 107.1194) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7098 105.2779) (end 45.7073 105.3744) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6107 109.347) (end 45.6107 109.4435) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6234 108.6688) (end 45.6209 108.7653) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6869 106.1491) (end 45.6844 106.2482) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6514 107.409) (end 45.6488 107.508) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7479 103.7285) (end 45.7454 103.825) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6971 105.7631) (end 45.6946 105.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6285 108.3793) (end 45.6285 108.4758) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6488 107.6046) (end 45.6463 107.7011) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.659 107.1194) (end 45.6565 107.2159) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7301 104.5032) (end 45.7276 104.5997) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6565 107.2159) (end 45.6539 107.3125) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6209 108.8644) (end 45.6184 108.9609) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7428 103.9216) (end 45.7403 104.0181) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6946 105.8596) (end 45.692 105.9561) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6666 106.8299) (end 45.6641 106.9264) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6488 107.508) (end 45.6488 107.6046) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6539 107.3125) (end 45.6514 107.409) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6895 106.0526) (end 45.6869 106.1491) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6133 109.2505) (end 45.6107 109.347) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6361 108.0872) (end 45.6336 108.1862) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6692 106.7308) (end 45.6666 106.8299) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6412 107.8941) (end 45.6387 107.9906) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6463 107.7011) (end 45.6438 107.7976) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6717 106.6343) (end 45.6692 106.7308) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6742 106.5378) (end 45.6717 106.6343) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6768 106.4412) (end 45.6742 106.5378) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.72 104.8918) (end 45.7174 104.9884) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6819 106.3447) (end 45.6768 106.4412) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.692 105.9561) (end 45.6895 106.0526) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7022 105.57) (end 45.6996 105.6665) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7149 105.0849) (end 45.7123 105.1814) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7225 104.7928) (end 45.72 104.8918) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7301 104.4067) (end 45.7301 104.5032) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7327 104.3102) (end 45.7301 104.4067) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7047 105.471) (end 45.7022 105.57) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.725 104.6963) (end 45.7225 104.7928) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6336 108.1862) (end 45.6311 108.2827) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6107 109.4435) (end 45.6082 109.5426) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7073 105.3744) (end 45.7047 105.471) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6996 105.6665) (end 45.6971 105.7631) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7276 104.5997) (end 45.725 104.6963) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6158 109.0574) (end 45.6133 109.154) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7377 104.1146) (end 45.7352 104.2137) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6133 109.154) (end 45.6133 109.2505) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6184 108.9609) (end 45.6158 109.0574) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6311 108.2827) (end 45.6285 108.3793) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7123 105.1814) (end 45.7098 105.2779) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7403 104.0181) (end 45.7377 104.1146) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6387 107.9906) (end 45.6361 108.0872) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7936 100.5789) (end 45.7936 100.6475) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7606 103.0757) (end 45.7581 103.1443) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 100.4392) (end 45.7936 100.5078) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7708 102.4509) (end 45.7682 102.522) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 99.9541) (end 45.7987 100.0227) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 100.0912) (end 45.7987 100.1624) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.753 103.3526) (end 45.753 103.4237) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7555 103.284) (end 45.753 103.3526) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7885 101.0641) (end 45.7885 101.1326) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7758 101.9658) (end 45.7758 102.0343) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7581 103.1443) (end 45.7581 103.2154) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7606 103.0072) (end 45.7606 103.0757) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7606 102.936) (end 45.7606 103.0072) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7682 102.522) (end 45.7682 102.5906) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.786 101.2723) (end 45.786 101.3409) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7631 102.8675) (end 45.7606 102.936) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7631 102.7989) (end 45.7631 102.8675) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7784 101.8972) (end 45.7758 101.9658) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 100.1624) (end 45.7962 100.2309) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7657 102.7278) (end 45.7631 102.7989) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7809 101.6178) (end 45.7809 101.6889) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7657 102.6592) (end 45.7657 102.7278) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7682 102.5906) (end 45.7657 102.6592) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7936 100.5078) (end 45.7936 100.5789) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7911 100.7161) (end 45.7911 100.7872) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7708 102.3823) (end 45.7708 102.4509) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7708 102.3137) (end 45.7708 102.3823) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 99.4689) (end 45.8038 99.5375) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7809 101.6889) (end 45.7784 101.7575) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 100.2309) (end 45.7962 100.2995) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7733 102.2426) (end 45.7708 102.3137) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 99.5375) (end 45.8038 99.6061) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7784 101.8261) (end 45.7784 101.8972) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 100.2995) (end 45.7962 100.3706) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 99.2607) (end 45.8063 99.3292) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 99.8144) (end 45.8012 99.8855) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7733 102.174) (end 45.7733 102.2426) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 99.8855) (end 45.8012 99.9541) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7758 102.1055) (end 45.7733 102.174) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7758 102.0343) (end 45.7758 102.1055) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7784 101.7575) (end 45.7784 101.8261) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7885 100.9929) (end 45.7885 101.0641) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7835 101.5492) (end 45.7809 101.6178) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7835 101.4806) (end 45.7835 101.5492) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7835 101.4095) (end 45.7835 101.4806) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 99.6061) (end 45.8038 99.6772) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7911 100.9244) (end 45.7885 100.9929) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7885 101.1326) (end 45.786 101.2012) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7936 100.6475) (end 45.7911 100.7161) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7911 100.8558) (end 45.7911 100.9244) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 99.3978) (end 45.8063 99.4689) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 99.6772) (end 45.8012 99.7458) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 99.3292) (end 45.8063 99.3978) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.786 101.3409) (end 45.7835 101.4095) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7911 100.7872) (end 45.7911 100.8558) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 99.7458) (end 45.8012 99.8144) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7479 103.632) (end 45.7479 103.7285) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7504 103.5609) (end 45.7479 103.632) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7504 103.4923) (end 45.7504 103.5609) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 100.3706) (end 45.7962 100.4392) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 100.0227) (end 45.7987 100.0912) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.753 103.4237) (end 45.7504 103.4923) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.786 101.2012) (end 45.786 101.2723) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7581 103.2154) (end 45.7555 103.284) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.6528) (end 45.7962 97.6909) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.8789) (end 45.7962 97.917) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 98.3666) (end 45.8038 98.4021) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 98.4402) (end 45.8038 98.4783) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8114 97.0915) (end 45.8089 97.1296) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 98.1405) (end 45.7987 98.1786) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 99.0422) (end 45.8089 99.0778) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 98.4783) (end 45.8038 98.5164) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 98.4021) (end 45.8038 98.4402) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 99.154) (end 45.8089 99.1921) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 98.74) (end 45.8089 98.7781) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8241 96.9061) (end 45.8216 96.9442) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 99.1159) (end 45.8089 99.154) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 97.503) (end 45.7987 97.5411) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 97.4293) (end 45.7987 97.4674) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 97.2795) (end 45.8012 97.3176) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 97.1677) (end 45.8063 97.2058) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 98.9279) (end 45.8089 98.966) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 98.2904) (end 45.8012 98.3285) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 99.0041) (end 45.8089 99.0422) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 98.3285) (end 45.8012 98.3666) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.5792) (end 45.7962 97.6173) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8292 96.8324) (end 45.8266 96.868) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 98.0288) (end 45.7987 98.0669) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 98.8543) (end 45.8089 98.8924) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.6909) (end 45.7962 97.729) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 98.7781) (end 45.8089 98.8162) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 97.3531) (end 45.8012 97.3912) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 98.6663) (end 45.8063 98.7044) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 98.5901) (end 45.8063 98.6282) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 97.3176) (end 45.8012 97.3531) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 98.2523) (end 45.8012 98.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 98.0669) (end 45.7987 98.1024) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.9526) (end 45.7962 97.9907) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.8408) (end 45.7962 97.8789) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.7671) (end 45.7962 97.8027) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8139 97.0559) (end 45.8114 97.0915) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8266 96.868) (end 45.8241 96.9061) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 98.8162) (end 45.8089 98.8543) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 98.2167) (end 45.8012 98.2523) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.9907) (end 45.7987 98.0288) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.729) (end 45.7962 97.7671) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.6173) (end 45.7962 97.6528) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.819 96.9797) (end 45.8165 97.0178) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 99.1921) (end 45.8063 99.2607) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 98.5545) (end 45.8063 98.5901) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8216 96.9442) (end 45.819 96.9797) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 99.0778) (end 45.8089 99.1159) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 98.966) (end 45.8089 99.0041) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 98.8924) (end 45.8089 98.9279) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 98.7044) (end 45.8063 98.74) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 98.1786) (end 45.7987 98.2167) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8089 97.1296) (end 45.8089 97.1677) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.8027) (end 45.7962 97.8408) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 97.5411) (end 45.7962 97.5792) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 97.4674) (end 45.7987 97.503) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8165 97.0178) (end 45.8139 97.0559) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 98.6282) (end 45.8063 98.6663) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7987 98.1024) (end 45.7987 98.1405) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8012 97.3912) (end 45.7987 97.4293) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 97.2414) (end 45.8038 97.2795) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8038 98.5164) (end 45.8038 98.5545) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7962 97.917) (end 45.7962 97.9526) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 97.2058) (end 45.8063 97.2414) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.3423 95.7809) (end 46.3169 95.7961) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8495 96.6445) (end 45.847 96.6724) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1441 95.9282) (end 46.1264 95.9485) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8952 96.4108) (end 45.8876 96.4387) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0908 95.9891) (end 46.0756 96.0095) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.2483 95.8393) (end 46.2254 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.9112 95.6742) (end 46.868 95.6742) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8597 96.5835) (end 45.8546 96.614) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9359 96.2762) (end 45.9282 96.3016) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0044 96.1238) (end 45.9917 96.1466) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0451 96.0552) (end 46.0298 96.0755) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9689 96.1974) (end 45.9562 96.2228) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0603 96.0323) (end 46.0451 96.0552) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.609 95.6945) (end 46.5759 95.6996) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.0408 95.6818) (end 46.995 95.6793) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.8299 95.6742) (end 46.7893 95.6742) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.995 95.6793) (end 46.9519 95.6767) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.0865 95.6869) (end 47.0408 95.6818) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8317 96.7943) (end 45.8292 96.8324) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.5124 95.7148) (end 46.482 95.725) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.868 95.6742) (end 46.8299 95.6742) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1645 95.9104) (end 46.1441 95.9282) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0171 96.1009) (end 46.0044 96.1238) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.3956 95.7555) (end 46.3702 95.7682) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.946 96.2482) (end 45.9359 96.2762) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8368 96.7638) (end 45.8317 96.7943) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1264 95.9485) (end 46.1086 95.9688) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8393 96.7334) (end 45.8368 96.7638) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.979 96.172) (end 45.9689 96.1974) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.642 95.6869) (end 46.609 95.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8419 96.7029) (end 45.8393 96.7334) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.847 96.6724) (end 45.8419 96.7029) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8546 96.614) (end 45.8495 96.6445) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8647 96.5556) (end 45.8597 96.5835) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9028 96.3828) (end 45.8952 96.4108) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0298 96.0755) (end 46.0171 96.1009) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.9519 95.6767) (end 46.9112 95.6742) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.88 96.4692) (end 45.8749 96.4971) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.3169 95.7961) (end 46.294 95.8088) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9562 96.2228) (end 45.946 96.2482) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1086 95.9688) (end 46.0908 95.9891) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.7893 95.6742) (end 46.7512 95.6767) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1848 95.8901) (end 46.1645 95.9104) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.4515 95.7351) (end 46.4235 95.7453) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8876 96.4387) (end 45.88 96.4692) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.2051 95.8723) (end 46.1848 95.8901) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8698 96.5251) (end 45.8647 96.5556) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8749 96.4971) (end 45.8698 96.5251) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.482 95.725) (end 46.4515 95.7351) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9105 96.3549) (end 45.9028 96.3828) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.7512 95.6767) (end 46.7156 95.6793) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9917 96.1466) (end 45.979 96.172) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.2711 95.824) (end 46.2483 95.8393) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.294 95.8088) (end 46.2711 95.824) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.4235 95.7453) (end 46.3956 95.7555) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9181 96.3295) (end 45.9105 96.3549) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.7156 95.6793) (end 46.6775 95.6818) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9282 96.3016) (end 45.9181 96.3295) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.2254 95.8571) (end 46.2051 95.8723) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.6775 95.6818) (end 46.642 95.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.3702 95.7682) (end 46.3423 95.7809) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.5429 95.7072) (end 46.5124 95.7148) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0756 96.0095) (end 46.0603 96.0323) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.5759 95.6996) (end 46.5429 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4573 95.7072) (end 47.4497 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2592 95.7047) (end 47.249 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4802 95.7072) (end 47.4726 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5437 95.7047) (end 47.5361 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5996 95.7021) (end 47.5919 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.498 95.7047) (end 47.4878 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5208 95.7047) (end 47.5132 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2338 95.7047) (end 47.2262 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.249 95.7047) (end 47.2414 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2744 95.7047) (end 47.2668 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2668 95.7047) (end 47.2592 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2973 95.7072) (end 47.2897 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3938 95.7072) (end 47.3862 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4167 95.7072) (end 47.4091 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4726 95.7072) (end 47.4649 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5361 95.7047) (end 47.5284 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5056 95.7047) (end 47.498 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3303 95.7072) (end 47.3227 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3379 95.7072) (end 47.3303 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5284 95.7047) (end 47.5208 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5513 95.7047) (end 47.5437 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5767 95.7047) (end 47.5691 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3608 95.7072) (end 47.3532 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4014 95.7072) (end 47.3938 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4243 95.7072) (end 47.4167 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4319 95.7072) (end 47.4243 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4421 95.7072) (end 47.4319 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5615 95.7047) (end 47.5513 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5843 95.7021) (end 47.5767 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4497 95.7072) (end 47.4421 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5691 95.7047) (end 47.5615 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5919 95.7021) (end 47.5843 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3862 95.7072) (end 47.3786 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2186 95.7021) (end 47.2109 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1398 95.6945) (end 47.1322 95.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4878 95.7072) (end 47.4802 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2897 95.7072) (end 47.2821 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6072 95.7021) (end 47.5996 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3532 95.7072) (end 47.3456 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3684 95.7072) (end 47.3608 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5132 95.7047) (end 47.5056 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2821 95.7047) (end 47.2744 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3786 95.7072) (end 47.3684 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6224 95.7021) (end 47.6148 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3125 95.7072) (end 47.3049 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1474 95.6945) (end 47.1398 95.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6326 95.7021) (end 47.6224 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2109 95.7021) (end 47.2033 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1322 95.6945) (end 47.0865 95.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1551 95.697) (end 47.1474 95.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1627 95.697) (end 47.1551 95.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1957 95.6996) (end 47.1881 95.6996) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1703 95.697) (end 47.1627 95.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2262 95.7021) (end 47.2186 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2414 95.7047) (end 47.2338 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3049 95.7072) (end 47.2973 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6148 95.7021) (end 47.6072 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3227 95.7072) (end 47.3125 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4091 95.7072) (end 47.4014 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4649 95.7072) (end 47.4573 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3456 95.7072) (end 47.3379 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1805 95.6996) (end 47.1703 95.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1881 95.6996) (end 47.1805 95.6996) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2033 95.7021) (end 47.1957 95.6996) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4281 95.6081) (end 52.3214 95.6107) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6402 95.7021) (end 47.6326 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4705 95.6285) (end 51.3638 95.6285) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.342 95.6691) (end 49.2353 95.6716) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1505 95.6335) (end 51.0463 95.6361) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0039 95.6183) (end 51.8972 95.6183) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.2391 95.5802) (end 54.1324 95.5802) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1711 95.692) (end 48.0644 95.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7045 95.6818) (end 48.5978 95.6843) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5129 95.6462) (end 50.4063 95.6488) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.833 95.6386) (end 50.7263 95.6412) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1929 95.6513) (end 50.0862 95.6539) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0644 95.6945) (end 47.9577 95.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4911 95.6869) (end 48.3844 95.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9397 95.6386) (end 50.833 95.6386) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8754 95.6589) (end 49.7687 95.6615) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3857 95.5929) (end 53.279 95.5954) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.0258 95.5827) (end 53.9191 95.5853) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.851 95.697) (end 47.7469 95.6996) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0682 95.598) (end 52.9615 95.6005) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.1324 95.5802) (end 54.0258 95.5827) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5772 95.6259) (end 51.4705 95.6285) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6196 95.6437) (end 50.5129 95.6462) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6415 95.6056) (end 52.5348 95.6081) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9821 95.6564) (end 49.8754 95.6589) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.7469 95.6996) (end 47.6402 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3638 95.6285) (end 51.2572 95.631) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.9577 95.697) (end 47.851 95.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2996 95.6513) (end 50.1929 95.6513) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4924 95.5904) (end 53.3857 95.5929) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2777 95.6894) (end 48.1711 95.692) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3844 95.6869) (end 48.2777 95.6894) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5978 95.6843) (end 48.4911 95.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8111 95.6793) (end 48.7045 95.6818) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4487 95.6666) (end 49.342 95.6691) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7263 95.6412) (end 50.6196 95.6437) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.3458 95.5777) (end 54.2391 95.5802) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1286 95.6742) (end 49.022 95.6767) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3214 95.6107) (end 52.2147 95.6132) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0862 95.6539) (end 49.9821 95.6564) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2572 95.631) (end 51.1505 95.6335) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.9191 95.5853) (end 53.8124 95.5853) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6839 95.6234) (end 51.5772 95.6259) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8548 95.6031) (end 52.7481 95.6031) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2353 95.6716) (end 49.1286 95.6742) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7906 95.6208) (end 51.6839 95.6234) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9178 95.6767) (end 48.8111 95.6793) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.022 95.6767) (end 48.9178 95.6767) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9615 95.6005) (end 52.8548 95.6031) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5554 95.664) (end 49.4487 95.6666) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.8124 95.5853) (end 53.7057 95.5878) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4063 95.6488) (end 50.2996 95.6513) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1106 95.6158) (end 52.0039 95.6183) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2147 95.6132) (end 52.1106 95.6158) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7481 95.6031) (end 52.6415 95.6056) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.662 95.664) (end 49.5554 95.664) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7057 95.5878) (end 53.599 95.5904) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7687 95.6615) (end 49.662 95.664) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8972 95.6183) (end 51.7906 95.6208) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.599 95.5904) (end 53.4924 95.5904) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5348 95.6081) (end 52.4281 95.6081) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1749 95.5954) (end 53.0682 95.598) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0463 95.6361) (end 50.9397 95.6386) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.279 95.5954) (end 53.1749 95.5954) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9186 95.5192) (end 59.7941 95.5192) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8121 95.5472) (end 56.6877 95.5497) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.4456 95.5624) (end 55.3212 95.565) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.2876 95.5015) (end 61.1632 95.504) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.2919 95.5142) (end 60.1675 95.5167) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5409 95.5116) (end 60.4164 95.5116) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9142 95.5065) (end 60.7898 95.5091) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9435 95.5573) (end 55.819 95.5599) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6877 95.5497) (end 56.5632 95.5497) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0611 95.5446) (end 56.9366 95.5472) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.5701 95.5624) (end 55.4456 95.5624) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.9074 95.4938) (end 61.7829 95.4964) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.9254 95.5269) (end 58.800999 95.5294) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.2988 95.5243) (end 59.1743 95.5269) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.1675 95.5167) (end 60.043 95.5167) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.1632 95.504) (end 61.0387 95.5065) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.6653 95.5091) (end 60.5409 95.5116) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.6945 95.5599) (end 55.5701 95.5624) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1898 95.5548) (end 56.0654 95.5548) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4388 95.5523) (end 56.3143 95.5523) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0387 95.5065) (end 60.9142 95.5065) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9366 95.5472) (end 56.8121 95.5472) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.1563 95.4913) (end 62.0318 95.4913) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4344 95.5421) (end 57.31 95.5421) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.9297 95.537) (end 57.8078 95.5396) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0542 95.537) (end 57.9297 95.537) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.6696 95.5218) (end 59.5477 95.5218) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.4276 95.5319) (end 58.3031 95.5345) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.049899 95.5269) (end 58.9254 95.5269) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.4233 95.5243) (end 59.2988 95.5243) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.7941 95.5192) (end 59.6696 95.5218) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.5477 95.5218) (end 59.4233 95.5243) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.800999 95.5294) (end 58.6765 95.5294) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1855 95.5446) (end 57.0611 95.5446) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.31 95.5421) (end 57.1855 95.5446) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.4164 95.5116) (end 60.2919 95.5142) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.4121 95.5015) (end 61.2876 95.5015) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.0318 95.4913) (end 61.9074 95.4938) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3031 95.5345) (end 58.1787 95.5345) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.552 95.5319) (end 58.4276 95.5319) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7898 95.5091) (end 60.6653 95.5091) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6834 95.5396) (end 57.5589 95.5396) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.6765 95.5294) (end 58.552 95.5319) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.6585 95.4989) (end 61.534 95.4989) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.2808 95.4888) (end 62.1563 95.4913) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.0722 95.5675) (end 54.9478 95.57) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.7829 95.4964) (end 61.6585 95.4989) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0654 95.5548) (end 55.9435 95.5573) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.4499 95.5777) (end 54.3458 95.5777) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.5744 95.5751) (end 54.4499 95.5777) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.6989 95.5726) (end 54.5744 95.5751) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.819 95.5599) (end 55.6945 95.5599) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.8233 95.57) (end 54.6989 95.5726) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3143 95.5523) (end 56.1898 95.5548) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5632 95.5497) (end 56.4388 95.5523) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5589 95.5396) (end 57.4344 95.5421) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.534 95.4989) (end 61.4121 95.5015) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8078 95.5396) (end 57.6834 95.5396) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.1743 95.5269) (end 59.049899 95.5269) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.043 95.5167) (end 59.9186 95.5192) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.1787 95.5345) (end 58.0542 95.537) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.9478 95.57) (end 54.8233 95.57) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.1967 95.5675) (end 55.0722 95.5675) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3212 95.565) (end 55.1967 95.5675) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.4837 95.4049) (end 65.4075 95.4075) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.7024 95.4811) (end 62.6287 95.4837) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.8004 95.4278) (end 64.7242 95.4303) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.2993 95.4684) (end 63.2256 95.471) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.5744 95.4354) (end 64.4982 95.438) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1789 95.4151) (end 65.1027 95.4176) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7918 95.3643) (end 66.7131 95.3668) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.8523 95.4786) (end 62.7786 95.4811) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.6727 95.4608) (end 63.599 95.4608) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.1223 95.4481) (end 64.0486 95.4507) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.3483 95.4405) (end 64.2721 95.443) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.8987 95.4532) (end 63.8225 95.4557) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.4245 95.438) (end 64.3483 95.4405) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.172 95.3846) (end 66.0958 95.3872) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0255 95.3567) (end 66.9467 95.3592) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6343 95.3694) (end 66.5581 95.3719) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9467 95.3592) (end 66.868 95.3618) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1017 95.3541) (end 67.0255 95.3567) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.4052 95.4862) (end 62.2808 95.4888) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.9409 95.3922) (end 65.8647 95.3948) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7131 95.3668) (end 66.6343 95.3694) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.8766 95.4253) (end 64.8004 95.4278) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.1985 95.4456) (end 64.1223 95.4481) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.6361 95.3999) (end 65.5599 95.4024) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.7489 95.4583) (end 63.6727 95.4608) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.4789 95.4862) (end 62.4052 95.4862) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.7242 95.4303) (end 64.6506 95.4329) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.5551 95.4837) (end 62.4789 95.4862) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.9724 95.4532) (end 63.8987 95.4532) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.2482 95.3821) (end 66.172 95.3846) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.6287 95.4837) (end 62.5551 95.4837) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.7786 95.4811) (end 62.7024 95.4811) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.9259 95.4786) (end 62.8523 95.4786) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.0021 95.4761) (end 62.9259 95.4786) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.3755 95.4684) (end 63.2993 95.4684) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.2721 95.443) (end 64.1985 95.4456) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.868 95.3618) (end 66.7918 95.3643) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.1494 95.4735) (end 63.0758 95.4735) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.4075 95.4075) (end 65.3313 95.41) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.8225 95.4557) (end 63.7489 95.4583) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.6506 95.4329) (end 64.5744 95.4354) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5581 95.3719) (end 66.4794 95.3745) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.9503 95.4227) (end 64.8766 95.4253) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.7885 95.3948) (end 65.7123 95.3973) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.2256 95.471) (end 63.1494 95.4735) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.0265 95.4202) (end 64.9503 95.4227) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.0758 95.4735) (end 63.0021 95.4761) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.4492 95.4659) (end 63.3755 95.4684) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.8647 95.3948) (end 65.7885 95.3948) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.5228 95.4634) (end 63.4492 95.4659) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4794 95.3745) (end 66.4032 95.377) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.0486 95.4507) (end 63.9724 95.4532) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.2551 95.4126) (end 65.1789 95.4151) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.3313 95.41) (end 65.2551 95.4126) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.7123 95.3973) (end 65.6361 95.3999) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.599 95.4608) (end 63.5228 95.4634) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4032 95.377) (end 66.327 95.3795) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1027 95.4176) (end 65.0265 95.4202) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.327 95.3795) (end 66.2482 95.3821) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1804 95.3516) (end 67.1017 95.3541) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.5599 95.4024) (end 65.4837 95.4049) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.0171 95.3897) (end 65.9409 95.3922) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.4982 95.438) (end 64.4245 95.438) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.0958 95.3872) (end 66.0171 95.3897) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1424 90.8025) (end 27.1348 90.8126) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0103 91.0742) (end 27.0052 91.0844) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1576 90.7694) (end 27.1526 90.7796) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1983 90.6831) (end 27.1932 90.6932) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2186 90.6374) (end 27.2135 90.6501) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1678 90.7466) (end 27.1627 90.7593) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.183 90.7136) (end 27.178 90.7263) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0154 91.0615) (end 27.0103 91.0742) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0205 91.0514) (end 27.0154 91.0615) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0992 90.8888) (end 27.0941 90.899) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1145 90.8558) (end 27.1094 90.866) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1526 90.7796) (end 27.1475 90.7898) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1932 90.6932) (end 27.1881 90.7034) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2237 90.6272) (end 27.2186 90.6374) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2338 90.6043) (end 27.2288 90.617) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2542 90.5612) (end 27.2491 90.5713) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1729 90.7364) (end 27.1678 90.7466) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0383 91.0184) (end 27.0306 91.0311) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0586 90.9752) (end 27.0535 90.9853) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0637 90.965) (end 27.0586 90.9752) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1881 90.7034) (end 27.183 90.7136) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2034 90.6704) (end 27.1983 90.6831) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0789 90.932) (end 27.0738 90.9422) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1043 90.8787) (end 27.0992 90.8888) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1195 90.8456) (end 27.1145 90.8558) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1246 90.8355) (end 27.1195 90.8456) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1297 90.8228) (end 27.1246 90.8355) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.244 90.584) (end 27.2389 90.5942) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2084 90.6602) (end 27.2034 90.6704) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1348 90.8126) (end 27.1297 90.8228) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2491 90.5713) (end 27.244 90.584) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2135 90.6501) (end 27.2084 90.6602) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0941 90.899) (end 27.0891 90.9117) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9849 91.1276) (end 26.9798 91.1377) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.261 95.3491) (end 67.1804 95.3516) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1627 90.7593) (end 27.1576 90.7694) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 91.2266) (end 26.939599 91.2248) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0306 91.0311) (end 27.0256 91.0412) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0738 90.9422) (end 27.0687 90.9549) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.084 90.9218) (end 27.0789 90.932) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.178 90.7263) (end 27.1729 90.7364) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9443 91.2139) (end 26.9392 91.2266) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0256 91.0412) (end 27.0205 91.0514) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0891 90.9117) (end 27.084 90.9218) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0484 90.998) (end 27.0433 91.0082) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9494 91.2038) (end 26.9443 91.2139) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9544 91.1936) (end 26.9494 91.2038) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9798 91.1377) (end 26.9748 91.1504) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9595 91.1835) (end 26.9544 91.1936) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9646 91.1708) (end 26.9595 91.1835) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9697 91.1606) (end 26.9646 91.1708) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.99 91.1174) (end 26.9849 91.1276) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0002 91.0946) (end 26.9951 91.1073) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0433 91.0082) (end 27.0383 91.0184) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0535 90.9853) (end 27.0484 90.998) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0687 90.9549) (end 27.0637 90.965) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2288 90.617) (end 27.2237 90.6272) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1094 90.866) (end 27.1043 90.8787) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.1475 90.7898) (end 27.1424 90.8025) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2389 90.5942) (end 27.2338 90.6043) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.2592 90.551) (end 27.2542 90.5612) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9748 91.1504) (end 26.9697 91.1606) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9951 91.1073) (end 26.99 91.1174) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.0052 91.0844) (end 27.0002 91.0946) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2478 85.9587) (end 32.2656 85.9434) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2326 85.9739) (end 32.2478 85.9587) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1386 86.0704) (end 32.1538 86.0552) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9963 86.2152) (end 32.0116 86.2) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0751 86.1365) (end 32.0903 86.1187) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.5341 86.6978) (end 31.5874 86.6419) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.7746 87.4801) (end 30.8279 87.4243) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.75 86.4743) (end 31.8033 86.4159) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0997 87.1449) (end 31.1531 87.089) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.9372 87.3125) (end 30.9905 87.2566) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0116 86.2) (end 32.0268 86.1847) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.3715 86.8655) (end 31.4248 86.8096) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.5874 86.6419) (end 31.6407 86.5861) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.3156 86.9213) (end 31.3715 86.8655) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4248 86.8096) (end 31.4782 86.7537) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8813 87.3684) (end 30.9372 87.3125) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.9905 87.2566) (end 31.0464 87.2007) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1056 86.1035) (end 32.1233 86.0882) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0446 86.167) (end 32.0598 86.1517) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0268 86.1847) (end 32.0446 86.167) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.5562 87.7037) (end 30.611999 87.6478) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3443 85.8622) (end 32.3596 85.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0464 87.2007) (end 31.0997 87.1449) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9811 86.233) (end 31.9963 86.2152) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0903 86.1187) (end 32.1056 86.1035) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0598 86.1517) (end 32.0751 86.1365) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.6654 87.5919) (end 30.7187 87.536) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3265 85.8774) (end 32.3443 85.8622) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9659 86.2482) (end 31.9811 86.233) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4782 86.7537) (end 31.5341 86.6978) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1868 86.0222) (end 32.2021 86.0069) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1538 86.0552) (end 32.1691 86.04) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1233 86.0882) (end 32.1386 86.0704) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9125 86.3041) (end 31.9659 86.2482) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6407 86.5861) (end 31.6966 86.5302) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.8033 86.4159) (end 31.8566 86.36) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.1531 87.089) (end 31.2089 87.0331) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2089 87.0331) (end 31.2623 86.9772) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.7187 87.536) (end 30.7746 87.4801) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.8566 86.36) (end 31.9125 86.3041) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2021 86.0069) (end 32.2173 85.9917) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8279 87.4243) (end 30.8813 87.3684) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3113 85.8952) (end 32.3265 85.8774) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.611999 87.6478) (end 30.6654 87.5919) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2961 85.9104) (end 32.3113 85.8952) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2808 85.9257) (end 32.2961 85.9104) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6966 86.5302) (end 31.75 86.4743) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2623 86.9772) (end 31.3156 86.9213) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2656 85.9434) (end 32.2808 85.9257) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2173 85.9917) (end 32.2326 85.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1691 86.04) (end 32.1868 86.0222) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0449 89.2785) (end 29.0982 89.22) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.8848 89.4486) (end 28.9382 89.3902) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.7782 89.5629) (end 28.8315 89.5045) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4988 89.8652) (end 28.514 89.8474) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4403 89.9312) (end 28.4556 89.9135) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.6181 89.7331) (end 28.6715 89.6772) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1736 90.3122) (end 28.1863 90.2945) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.4741 88.8263) (end 29.5275 88.7679) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3083 90.1065) (end 28.321 90.0887) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2448 90.1979) (end 28.2575 90.1802) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3116 88.994) (end 29.3674 88.938101) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3718 90.0176) (end 28.387 89.9998) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.9382 89.3902) (end 28.9915 89.3343) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2702 90.1598) (end 28.2829 90.1421) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.321 90.0887) (end 28.3337 90.0684) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.514 89.8474) (end 28.5673 89.7915) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.7248 89.6188) (end 28.7782 89.5629) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.231 88.0389) (end 30.2844 87.9831) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.1218 88.1507) (end 30.1777 88.094801) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.9059 88.3768) (end 29.9593 88.3183) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.5673 89.7915) (end 28.6181 89.7331) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.483499 89.8804) (end 28.4988 89.8652) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3464 90.0506) (end 28.3591 90.0328) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8526 88.4326) (end 29.9059 88.3768) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.69 88.6003) (end 29.7434 88.5444) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.4208 88.8822) (end 29.4741 88.8263) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.1515 89.1642) (end 29.2049 89.1083) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.2582 89.0499) (end 29.3116 88.994) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4708 89.8957) (end 28.483499 89.8804) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.2049 89.1083) (end 29.2582 89.0499) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0982 89.22) (end 29.1515 89.1642) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4556 89.9135) (end 28.4708 89.8957) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.5275 88.7679) (end 29.5808 88.712) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.1777 88.094801) (end 30.231 88.0389) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0151 88.2625) (end 30.0685 88.2066) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.8315 89.5045) (end 28.8848 89.4486) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4276 89.9465) (end 28.4403 89.9312) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3591 90.0328) (end 28.3718 90.0176) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.7434 88.5444) (end 29.7967 88.4885) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.6367 88.656201) (end 29.69 88.6003) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.6715 89.6772) (end 28.7248 89.6188) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.5808 88.712) (end 29.6367 88.656201) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3997 89.982) (end 28.4149 89.9643) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1965 90.2741) (end 28.2092 90.2564) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3337 90.0684) (end 28.3464 90.0506) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1863 90.2945) (end 28.1965 90.2741) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.387 89.9998) (end 28.3997 89.982) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2321 90.2183) (end 28.2448 90.1979) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.5028 87.7595) (end 30.5562 87.7037) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.4469 87.8154) (end 30.5028 87.7595) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.3936 87.8713) (end 30.4469 87.8154) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0685 88.2066) (end 30.1218 88.1507) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2575 90.1802) (end 28.2702 90.1598) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.9593 88.3183) (end 30.0151 88.2625) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.7967 88.4885) (end 29.8526 88.4326) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2092 90.2564) (end 28.2219 90.236) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4149 89.9643) (end 28.4276 89.9465) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3674 88.938101) (end 29.4208 88.8822) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.9915 89.3343) (end 29.0449 89.2785) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2219 90.236) (end 28.2321 90.2183) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2956 90.1243) (end 28.3083 90.1065) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2829 90.1421) (end 28.2956 90.1243) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.3403 87.927201) (end 30.3936 87.8713) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.2844 87.9831) (end 30.3403 87.927201) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7368 91.7753) (end 27.7342 91.7423) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1635 90.3326) (end 28.1736 90.3122) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9654 90.7136) (end 27.973 90.6932) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1508 90.3503) (end 28.1635 90.3326) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1406 90.3707) (end 28.1508 90.3503) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9171 90.8152) (end 27.9273 90.7948) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1178 90.4113) (end 28.1279 90.391) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0847 90.4697) (end 28.0949 90.4494) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0543 90.5307) (end 28.0644 90.5104) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0238 90.5916) (end 28.0339 90.5713) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0035 90.6323) (end 28.0136 90.612) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9933 90.6526) (end 28.0035 90.6323) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8053 91.0844) (end 27.8155 91.0641) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7368 91.3765) (end 27.7393 91.346) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7291 91.4349) (end 27.7317 91.4044) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7241 91.5543) (end 27.7241 91.5238) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7266 91.6483) (end 27.7266 91.6178) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7596 91.2368) (end 27.7672 91.2089) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1279 90.391) (end 28.1406 90.3707) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0441 90.551) (end 28.0543 90.5307) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8307 91.0234) (end 27.8384 91.0006) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9552 90.7339) (end 27.9654 90.7136) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7444 91.3181) (end 27.7495 91.2901) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8638 90.9396) (end 27.8739 90.9193) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1076 90.4291) (end 28.1178 90.4113) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0949 90.4494) (end 28.1076 90.4291) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.973 90.6932) (end 27.9831 90.6729) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7266 91.4933) (end 27.7291 91.4629) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0746 90.49) (end 28.0847 90.4697) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7977 91.1073) (end 27.8053 91.0844) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7241 91.5238) (end 27.7266 91.4933) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0644 90.5104) (end 28.0746 90.49) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0339 90.5713) (end 28.0441 90.551) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0136 90.612) (end 28.0238 90.5916) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9831 90.6729) (end 27.9933 90.6526) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.945 90.7542) (end 27.9552 90.7339) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9374 90.7745) (end 27.945 90.7542) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9273 90.7948) (end 27.9374 90.7745) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8917 90.8787) (end 27.8993 90.8583) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9095 90.8355) (end 27.9171 90.8152) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8993 90.8583) (end 27.9095 90.8355) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7672 91.2089) (end 27.7723 91.1835) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8485 90.9803) (end 27.8561 90.9599) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7495 91.2901) (end 27.7545 91.2622) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8815 90.899) (end 27.8917 90.8787) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8739 90.9193) (end 27.8815 90.899) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8384 91.0006) (end 27.8485 90.9803) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7317 91.7118) (end 27.7291 91.6788) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7342 91.7423) (end 27.7317 91.7118) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8561 90.9599) (end 27.8638 90.9396) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7723 91.1835) (end 27.7799 91.1581) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8231 91.0438) (end 27.8307 91.0234) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7291 91.6788) (end 27.7266 91.6483) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8155 91.0641) (end 27.8231 91.0438) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7799 91.1581) (end 27.7901 91.1327) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7393 91.346) (end 27.7444 91.3181) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7317 91.4044) (end 27.7368 91.3765) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7418 91.8058) (end 27.7368 91.7753) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7901 91.1327) (end 27.7977 91.1073) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7291 91.4629) (end 27.7291 91.4349) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7241 91.5848) (end 27.7241 91.5543) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7545 91.2622) (end 27.7596 91.2368) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7444 91.8388) (end 27.7418 91.8058) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7266 91.6178) (end 27.7241 91.5848) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.6461 93.0326) (end 28.6156 93.0148) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8434 92.2147) (end 27.8307 92.1842) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.707 93.0681) (end 28.6766 93.0504) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.973 92.4763) (end 27.9552 92.4484) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.9153 93.1951) (end 28.8848 93.1774) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.8544 93.1596) (end 28.8239 93.1418) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7622 91.9328) (end 27.7545 91.9023) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7698 91.9658) (end 27.7622 91.9328) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4378 92.9081) (end 28.4073 92.8903) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7749 91.9963) (end 27.7698 91.9658) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0847 92.6313) (end 28.0644 92.6059) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.785 92.0293) (end 27.7749 91.9963) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8003 92.0928) (end 27.7926 92.0598) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9552 92.4484) (end 27.94 92.4204) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3489 92.8548) (end 28.321 92.8395) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8104 92.1233) (end 27.8003 92.0928) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8307 92.1842) (end 27.8206 92.1537) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8942 92.3341) (end 27.8815 92.3061) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.8239 93.1418) (end 28.7959 93.124) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8688 92.2757) (end 27.8561 92.2452) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2194 92.7633) (end 28.194 92.743) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8815 92.3061) (end 27.8688 92.2757) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.94 92.4204) (end 27.9247 92.3925) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.6766 93.0504) (end 28.6461 93.0326) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.5877 92.997) (end 28.5572 92.9792) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9247 92.3925) (end 27.9095 92.3646) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9882 92.5043) (end 27.973 92.4763) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.1211 93.3221) (end 29.0931 93.3044) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.194 92.743) (end 28.1711 92.7227) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.7959 93.124) (end 28.7655 93.1037) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9095 92.3646) (end 27.8942 92.3341) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0931 93.3044) (end 29.0626 93.2866) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8561 92.2452) (end 27.8434 92.2147) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.7655 93.1037) (end 28.735 93.0859) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.006 92.5297) (end 27.9882 92.5043) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.9737 93.2307) (end 28.9433 93.2129) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0263 92.5551) (end 28.006 92.5297) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.9433 93.2129) (end 28.9153 93.1951) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0441 92.5805) (end 28.0263 92.5551) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.0644 92.6059) (end 28.0441 92.5805) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1279 92.677) (end 28.1051 92.6541) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4683 92.9259) (end 28.4378 92.9081) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1482 92.6998) (end 28.1279 92.677) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1711 92.7227) (end 28.1482 92.6998) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2702 92.8014) (end 28.2448 92.7837) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0626 93.2866) (end 29.0322 93.2688) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4988 92.9437) (end 28.4683 92.9259) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4073 92.8903) (end 28.3794 92.8726) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.6156 93.0148) (end 28.5877 92.997) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2956 92.8218) (end 28.2702 92.8014) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.5267 92.9615) (end 28.4988 92.9437) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.2448 92.7837) (end 28.2194 92.7633) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0322 93.2688) (end 29.0042 93.2485) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.321 92.8395) (end 28.2956 92.8218) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.5572 92.9792) (end 28.5267 92.9615) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0042 93.2485) (end 28.9737 93.2307) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7495 91.8693) (end 27.7444 91.8388) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7545 91.9023) (end 27.7495 91.8693) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.1051 92.6541) (end 28.0847 92.6313) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.735 93.0859) (end 28.707 93.0681) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.8848 93.1774) (end 28.8544 93.1596) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.7926 92.0598) (end 27.785 92.0293) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.3794 92.8726) (end 28.3489 92.8548) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.8206 92.1537) (end 27.8104 92.1233) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.6984 94.2797) (end 30.6628 94.2569) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8 94.3432) (end 30.767 94.3229) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.9372 94.4296) (end 30.9041 94.4093) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.071 93.9013) (end 30.0431 93.8835) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8686 94.3864) (end 30.8356 94.3661) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.1429 94.5591) (end 31.1073 94.5363) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8627 93.7743) (end 29.8348 93.7565) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.8356 94.3661) (end 30.8 94.3432) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.9041 94.4093) (end 30.8686 94.3864) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.1515 93.3399) (end 29.1211 93.3221) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.596 93.6117) (end 29.5656 93.5939) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.5943 94.2162) (end 30.5612 94.1934) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.182 93.3577) (end 29.1515 93.3399) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.21 93.3755) (end 29.182 93.3577) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.2989 93.4314) (end 29.2709 93.4136) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3878 93.4847) (end 29.3598 93.4669) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.4487 93.5228) (end 29.4182 93.5025) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.9516 93.8276) (end 29.9237 93.8098) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0057 94.4728) (end 30.9702 94.4499) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.9237 93.8098) (end 29.8932 93.792) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.9702 94.4499) (end 30.9372 94.4296) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.5071 93.5584) (end 29.4767 93.5406) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.5656 93.5939) (end 29.5376 93.5761) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.1625 93.9546) (end 30.132 93.9368) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.6545 93.6473) (end 29.6265 93.6295) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.4571 94.1299) (end 30.4241 94.1095) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.7154 93.6854) (end 29.6849 93.6676) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.5612 94.1934) (end 30.5257 94.173) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.9821 93.8454) (end 29.9516 93.8276) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.132 93.9368) (end 30.1015 93.919) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.2209 93.9902) (end 30.1904 93.9724) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.3885 94.0892) (end 30.3555 94.0689) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.6628 94.2569) (end 30.6298 94.2365) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.7314 94.3) (end 30.6984 94.2797) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0388 94.4931) (end 31.0057 94.4728) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.492699 94.1527) (end 30.4571 94.1299) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.3199 94.0486) (end 30.2869 94.0283) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.2709 93.4136) (end 29.2404 93.3933) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.5376 93.5761) (end 29.5071 93.5584) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0126 93.8657) (end 29.9821 93.8454) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0743 94.5159) (end 31.0388 94.4931) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.1904 93.9724) (end 30.1625 93.9546) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.4241 94.1095) (end 30.3885 94.0892) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.5257 94.173) (end 30.492699 94.1527) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.2404 93.3933) (end 29.21 93.3755) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.7459 93.7031) (end 29.7154 93.6854) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.767 94.3229) (end 30.7314 94.3) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3293 93.4491) (end 29.2989 93.4314) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.3598 93.4669) (end 29.3293 93.4491) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.4182 93.5025) (end 29.3878 93.4847) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.4767 93.5406) (end 29.4487 93.5228) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.6265 93.6295) (end 29.596 93.6117) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0431 93.8835) (end 30.0126 93.8657) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.3555 94.0689) (end 30.3199 94.0486) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.1073 94.5363) (end 31.0743 94.5159) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.6849 93.6676) (end 29.6545 93.6473) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.7738 93.7209) (end 29.7459 93.7031) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8043 93.7387) (end 29.7738 93.7209) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8348 93.7565) (end 29.8043 93.7387) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.1015 93.919) (end 30.071 93.9013) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.8932 93.792) (end 29.8627 93.7743) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.6298 94.2365) (end 30.5943 94.2162) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.2514 94.0079) (end 30.2209 93.9902) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.2869 94.0283) (end 30.2514 94.0079) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1919 95.1433) (end 32.1564 95.1255) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.3842 94.7064) (end 31.3486 94.6836) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7329 95.377) (end 32.6923 95.3567) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0733 95.5675) (end 33.0377 95.5446) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.1759 94.5794) (end 31.1429 94.5591) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2115 94.5998) (end 31.1759 94.5794) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3367 95.2068) (end 32.3011 95.1916) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4104 95.2373) (end 32.3723 95.2221) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2445 94.6226) (end 31.2115 94.5998) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4459 95.2525) (end 32.4104 95.2373) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.279 95.7123) (end 33.246 95.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.2801 94.6429) (end 31.2445 94.6226) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.7296 94.9071) (end 31.6966 94.8868) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0377 95.5446) (end 33.0022 95.5218) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.8008 94.9452) (end 31.7652 94.9249) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.943 95.0189) (end 31.9074 95.0011) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0497 95.0747) (end 32.0141 95.057) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.5569 94.808) (end 31.5214 94.7877) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8904 95.4583) (end 32.8523 95.438) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3723 95.2221) (end 32.3367 95.2068) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6611 94.8665) (end 31.6255 94.8487) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.484 95.2678) (end 32.4459 95.2525) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.8719 94.9833) (end 31.8363 94.963) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8142 95.4176) (end 32.7736 95.3973) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0022 95.5218) (end 32.9666 95.5015) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9666 95.5015) (end 32.9285 95.4786) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9074 95.0011) (end 31.8719 94.9833) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3011 95.1916) (end 32.2656 95.1763) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4365 95.8444) (end 33.406 95.8164) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1089 95.5904) (end 33.0733 95.5675) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8523 95.438) (end 32.8142 95.4176) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9285 95.4786) (end 32.8904 95.4583) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.3156 94.6633) (end 31.2801 94.6429) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.3486 94.6836) (end 31.3156 94.6633) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4858 94.7674) (end 31.4528 94.7471) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1444 95.6132) (end 33.1089 95.5904) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4172 94.7268) (end 31.3842 94.7064) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.4528 94.7471) (end 31.4172 94.7268) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.5214 94.7877) (end 31.4858 94.7674) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6255 94.8487) (end 31.5899 94.8284) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1208 95.1078) (end 32.0852 95.0925) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.611 95.3211) (end 32.5704 95.3033) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3451 95.7631) (end 33.3121 95.7377) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.18 95.6386) (end 33.1444 95.6132) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7736 95.3973) (end 32.7329 95.377) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6923 95.3567) (end 32.6517 95.3389) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.1564 95.1255) (end 32.1208 95.1078) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.246 95.6869) (end 33.213 95.6615) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.406 95.8164) (end 33.3756 95.791) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.213 95.6615) (end 33.18 95.6386) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3756 95.791) (end 33.3451 95.7631) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5704 95.3033) (end 32.5272 95.2856) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0852 95.0925) (end 32.0497 95.0747) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.5899 94.8284) (end 31.5569 94.808) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.6966 94.8868) (end 31.6611 94.8665) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.7652 94.9249) (end 31.7296 94.9071) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.8363 94.963) (end 31.8008 94.9452) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2275 95.1586) (end 32.1919 95.1433) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3121 95.7377) (end 33.279 95.7123) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.9786 95.0392) (end 31.943 95.0189) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0141 95.057) (end 31.9786 95.0392) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.2656 95.1763) (end 32.2275 95.1586) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5272 95.2856) (end 32.484 95.2678) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6517 95.3389) (end 32.611 95.3211) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8709 96.3244) (end 33.848 96.2914) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9191 96.3905) (end 33.8963 96.3574) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0741 96.6318) (end 34.0512 96.5962) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4449 97.4649) (end 34.4347 97.4369) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3281 97.1499) (end 34.3154 97.122) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0309 96.5606) (end 34.008 96.5251) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6956 96.1034) (end 33.6677 96.073) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3382 97.1804) (end 34.3281 97.1499) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2823 97.0432) (end 34.2646 97.0051) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5559 95.9536) (end 33.528 95.9256) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5033 97.6401) (end 34.4957 97.6122) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5838 95.9841) (end 33.5559 95.9536) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6118 96.012) (end 33.5838 95.9841) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4347 97.4369) (end 34.4246 97.409) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6677 96.073) (end 33.6397 96.0425) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.721 96.1339) (end 33.6956 96.1034) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.008 96.5251) (end 33.9877 96.4921) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3712 97.2642) (end 34.3611 97.2363) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3941 97.3226) (end 34.3839 97.2922) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8226 96.2584) (end 33.7972 96.2254) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5592 97.8154) (end 34.549 97.7875) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8963 96.3574) (end 33.8709 96.3244) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9877 96.4921) (end 33.9648 96.4565) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3154 97.122) (end 34.2976 97.0839) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4246 97.409) (end 34.4144 97.3785) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4144 97.3785) (end 34.4043 97.3506) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1909 96.8527) (end 34.1731 96.8146) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2087 96.8908) (end 34.1909 96.8527) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.549 97.7875) (end 34.5414 97.757) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.455099 97.4954) (end 34.4449 97.4649) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3509 97.2083) (end 34.3382 97.1804) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4043 97.3506) (end 34.3941 97.3226) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9648 96.4565) (end 33.942 96.4235) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1147 96.7029) (end 34.0944 96.6673) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2646 97.0051) (end 34.2468 96.967) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4652 97.5233) (end 34.455099 97.4954) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7464 96.1644) (end 33.721 96.1339) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0944 96.6673) (end 34.0741 96.6318) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7718 96.1949) (end 33.7464 96.1644) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.848 96.2914) (end 33.8226 96.2584) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1731 96.8146) (end 34.1528 96.7765) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2976 97.0839) (end 34.2823 97.0432) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5236 97.6986) (end 34.5135 97.6706) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4754 97.5538) (end 34.4652 97.5233) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.229 96.9289) (end 34.2087 96.8908) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.576999 97.8764) (end 34.5668 97.8459) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3611 97.2363) (end 34.3509 97.2083) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4957 97.6122) (end 34.4855 97.5817) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5414 97.757) (end 34.531299 97.729) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4855 97.5817) (end 34.4754 97.5538) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.531299 97.729) (end 34.5236 97.6986) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1528 96.7765) (end 34.1325 96.741) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2468 96.967) (end 34.229 96.9289) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7972 96.2254) (end 33.7718 96.1949) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5668 97.8459) (end 34.5592 97.8154) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1325 96.741) (end 34.1147 96.7029) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.467 95.8698) (end 33.4365 95.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4975 95.8977) (end 33.467 95.8698) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5135 97.6706) (end 34.5033 97.6401) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.942 96.4235) (end 33.9191 96.3905) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0512 96.5962) (end 34.0309 96.5606) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.528 95.9256) (end 33.4975 95.8977) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6397 96.0425) (end 33.6118 96.012) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3839 97.2922) (end 34.3712 97.2642) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1256 99.5909) (end 35.1028 99.5299) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1866 99.7687) (end 35.1663 99.7102) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2704 100.0074) (end 35.2501 99.9465) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.897 98.9355) (end 34.8869 98.9076) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2298 99.888) (end 35.2094 99.8296) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3974 100.3656) (end 35.3771 100.3046) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9046 98.966) (end 34.897 98.9355) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2094 99.8296) (end 35.1866 99.7687) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2501 99.9465) (end 35.2298 99.888) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5846 97.9043) (end 34.576999 97.8764) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5948 97.9348) (end 34.5846 97.9043) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0621 99.4105) (end 35.0418 99.3521) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6024 97.9627) (end 34.5948 97.9348) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6125 97.9932) (end 34.6024 97.9627) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6202 98.0237) (end 34.6125 97.9932) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6278 98.0516) (end 34.6202 98.0237) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.739499 98.4377) (end 34.7319 98.4072) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.958 99.1133) (end 34.9377 99.0524) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3136 100.1268) (end 35.2933 100.0658) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.671 98.1989) (end 34.6633 98.171) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2933 100.0658) (end 35.2704 100.0074) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6964 98.2878) (end 34.6887 98.2599) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.721799 98.3767) (end 34.7141 98.3488) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4609 100.5434) (end 35.4406 100.4824) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7319 98.4072) (end 34.721799 98.3767) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8869 98.9076) (end 34.8767 98.8771) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8284 98.7323) (end 34.8208 98.7019) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0418 99.3521) (end 35.0189 99.2911) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7827 98.585) (end 34.7751 98.5545) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8208 98.7019) (end 34.8107 98.6714) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9148 98.994) (end 34.9046 98.966) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8564 98.8187) (end 34.8488 98.7908) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1028 99.5299) (end 35.0824 99.4715) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1459 99.6493) (end 35.1256 99.5909) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3339 100.1852) (end 35.3136 100.1268) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9986 99.2327) (end 34.9783 99.1718) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4406 100.4824) (end 35.4177 100.424) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7751 98.5545) (end 34.7649 98.5241) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6379 98.0821) (end 34.6278 98.0516) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.645599 98.11) (end 34.6379 98.0821) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3542 100.2462) (end 35.3339 100.1852) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6557 98.1405) (end 34.645599 98.11) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8767 98.8771) (end 34.8665 98.8492) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0189 99.2911) (end 34.9986 99.2327) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6633 98.171) (end 34.6557 98.1405) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8107 98.6714) (end 34.8005 98.6434) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1663 99.7102) (end 35.1459 99.6493) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6811 98.2294) (end 34.671 98.1989) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6887 98.2599) (end 34.6811 98.2294) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8386 98.7603) (end 34.8284 98.7323) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9377 99.0524) (end 34.9148 98.994) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8005 98.6434) (end 34.7929 98.613) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8488 98.7908) (end 34.8386 98.7603) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7065 98.3183) (end 34.6964 98.2878) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3771 100.3046) (end 35.3542 100.2462) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7929 98.613) (end 34.7827 98.585) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7141 98.3488) (end 34.7065 98.3183) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7497 98.4656) (end 34.739499 98.4377) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7573 98.4961) (end 34.7497 98.4656) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4177 100.424) (end 35.3974 100.3656) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7649 98.5241) (end 34.7573 98.4961) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0824 99.4715) (end 35.0621 99.4105) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8665 98.8492) (end 34.8564 98.8187) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9783 99.1718) (end 34.958 99.1133) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.6809 105.8545) (end 37.6148 105.73) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5447 100.7821) (end 35.5244 100.7212) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.4388 103.1926) (end 36.3855 103.0605) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4812 100.6018) (end 35.4609 100.5434) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5041 100.6627) (end 35.4812 100.6018) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5244 100.7212) (end 35.5041 100.6627) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1289 102.3823) (end 36.1061 102.3239) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1746 102.5017) (end 36.1518 102.4433) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7606 101.3765) (end 35.7378 101.3155) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8038 101.4933) (end 35.7809 101.4349) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.195 102.5601) (end 36.1746 102.5017) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8902 101.7321) (end 35.8673 101.6711) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9537 101.9099) (end 35.9333 101.8489) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.8782 104.2238) (end 36.8198 104.0968) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.9951 104.4778) (end 36.9341 104.3508) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.2364 104.9833) (end 37.1729 104.8588) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.4218 105.3592) (end 37.3583 105.2347) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5676 100.8405) (end 35.5447 100.7821) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5879 100.899) (end 35.5676 100.8405) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1518 102.4433) (end 36.1289 102.3823) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7174 101.2571) (end 35.6946 101.1961) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2178 102.6211) (end 36.195 102.5601) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.7639 103.9673) (end 36.708 103.8403) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6514 101.0793) (end 35.6311 101.0183) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.5429 103.4517) (end 36.4896 103.3221) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8444 101.6127) (end 35.8241 101.5543) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1061 102.3239) (end 36.0857 102.2655) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.1144 104.7318) (end 37.0535 104.604801) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6108 100.9599) (end 35.5879 100.899) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8673 101.6711) (end 35.8444 101.6127) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.1729 104.8588) (end 37.1144 104.7318) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.5963 103.5812) (end 36.5429 103.4517) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6311 101.0183) (end 35.6108 100.9599) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6743 101.1377) (end 35.6514 101.0793) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6946 101.1961) (end 35.6743 101.1377) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7378 101.3155) (end 35.7174 101.2571) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7809 101.4349) (end 35.7606 101.3765) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8241 101.5543) (end 35.8038 101.4933) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9105 101.7905) (end 35.8902 101.7321) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9333 101.8489) (end 35.9105 101.7905) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9765 101.9683) (end 35.9537 101.9099) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9968 102.0267) (end 35.9765 101.9683) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2839 102.7963) (end 36.261 102.7379) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.708 103.8403) (end 36.6522 103.7107) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.4896 103.3221) (end 36.4388 103.1926) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.3855 103.0605) (end 36.3347 102.9284) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0197 102.0877) (end 35.9968 102.0267) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.5513 105.6081) (end 37.4853 105.4837) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.6148 105.73) (end 37.5513 105.6081) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0426 102.1461) (end 36.0197 102.0877) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0629 102.2045) (end 36.0426 102.1461) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.261 102.7379) (end 36.2407 102.6795) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.4853 105.4837) (end 37.4218 105.3592) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0857 102.2655) (end 36.0629 102.2045) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2407 102.6795) (end 36.2178 102.6211) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.8198 104.0968) (end 36.7639 103.9673) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.9341 104.3508) (end 36.8782 104.2238) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.7469 105.9764) (end 37.6809 105.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.3347 102.9284) (end 36.2839 102.7963) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.0535 104.604801) (end 36.9951 104.4778) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.2973 105.1103) (end 37.2364 104.9833) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.6522 103.7107) (end 36.5963 103.5812) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.8129 106.1009) (end 37.7469 105.9764) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.3583 105.2347) (end 37.2973 105.1103) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.2699 111.3714) (end 41.2089 111.2926) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.6511 107.5487) (end 38.58 107.4293) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.3893 111.5314) (end 41.3283 111.4501) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.3268 108.6104) (end 39.248 108.4936) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.8109 112.0877) (end 41.7499 112.0089) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.689 111.9302) (end 41.628 111.8489) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.0161 106.4666) (end 37.9476 106.3447) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.0847 106.5886) (end 38.0161 106.4666) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.8559 110.81) (end 40.7949 110.7288) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.1533 106.7079) (end 38.0847 106.5886) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.7916 109.3089) (end 39.7129 109.1921) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.2244 106.8299) (end 38.1533 106.7079) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.3641 107.0712) (end 38.293 106.9492) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.248 108.4936) (end 39.1744 108.3767) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.6781 110.5687) (end 40.5968 110.4544) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.4352 107.1905) (end 38.3641 107.0712) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.58 107.4293) (end 38.5064 107.3099) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.9483 108.0237) (end 38.8721 107.9043) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.628 111.8489) (end 41.5696 111.7702) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.7985 107.7874) (end 38.7248 107.6681) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.2717 109.9972) (end 40.1904 109.8829) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.8721 107.9043) (end 38.7985 107.7874) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.1744 108.3767) (end 39.0982 108.2599) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.3283 111.4501) (end 41.2699 111.3714) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.1505 111.2114) (end 41.0921 111.1301) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.0982 108.2599) (end 39.022 108.1405) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.403 108.7272) (end 39.3268 108.6104) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.2351 112.6414) (end 42.1741 112.5626) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.1904 109.8829) (end 40.1116 109.7686) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.5696 111.7702) (end 41.5086 111.6914) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.022 108.1405) (end 38.9483 108.0237) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.1741 112.5626) (end 42.1132 112.4839) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.7248 107.6681) (end 38.6511 107.5487) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.5086 111.6914) (end 41.4477 111.6101) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.4792 108.8441) (end 39.403 108.7272) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.9303 112.2451) (end 41.8693 112.1664) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.5579 108.9609) (end 39.4792 108.8441) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.8693 112.1664) (end 41.8109 112.0877) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.6367 109.0778) (end 39.5579 108.9609) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.7129 109.1921) (end 39.6367 109.0778) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.9516 109.54) (end 39.8703 109.4232) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.9143 110.8913) (end 40.8559 110.81) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.0304 109.6543) (end 39.9516 109.54) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.1116 109.7686) (end 40.0304 109.6543) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.4342 110.2258) (end 40.3529 110.1115) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.1132 112.4839) (end 42.0522 112.4052) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.9727 110.9701) (end 40.9143 110.8913) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.7949 110.7288) (end 40.7365 110.65) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.2089 111.2926) (end 41.1505 111.2114) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.5155 110.3401) (end 40.4342 110.2258) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.0311 111.0513) (end 40.9727 110.9701) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.3529 110.1115) (end 40.2717 109.9972) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.0522 112.4052) (end 41.9912 112.3264) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.5968 110.4544) (end 40.5155 110.3401) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.0921 111.1301) (end 41.0311 111.0513) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.9912 112.3264) (end 41.9303 112.2451) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.8815 106.2228) (end 37.8129 106.1009) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.9476 106.3447) (end 37.8815 106.2228) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.8703 109.4232) (end 39.7916 109.3089) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.4477 111.6101) (end 41.3893 111.5314) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.7499 112.0089) (end 41.689 111.9302) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.293 106.9492) (end 38.2244 106.8299) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.7365 110.65) (end 40.6781 110.5687) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.5064 107.3099) (end 38.4352 107.1905) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.5668 115.631) (end 44.5058 115.5522) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.5795 115.6462) (end 44.5668 115.631) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.8302 114.6861) (end 43.7692 114.6073) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.2155 113.9012) (end 43.152 113.8225) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.7057 114.5286) (end 43.6448 114.4499) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.1985 115.1585) (end 44.1375 115.0798) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.704 115.8011) (end 44.6887 115.7834) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.6448 114.4499) (end 43.5838 114.3737) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.7692 114.6073) (end 43.7057 114.5286) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8589 115.9866) (end 44.8437 115.9688) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9021 116.0374) (end 44.8868 116.0196) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8157 115.9358) (end 44.8005 115.9205) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.296 112.720101) (end 42.2351 112.6414) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.418 112.8776) (end 42.357 112.7989) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.6008 113.1138) (end 42.539899 113.0351) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.9082 113.5075) (end 42.8472 113.4288) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.93 116.0704) (end 44.9173 116.0526) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7725 115.885) (end 44.7598 115.8697) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.9521 114.8436) (end 43.8912 114.7648) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.7837 113.35) (end 42.722799 113.2713) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.8912 114.7648) (end 43.8302 114.6861) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.0301 113.665) (end 42.9691 113.5863) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8741 116.0018) (end 44.8589 115.9866) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.3814 115.3947) (end 44.3204 115.316) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7878 115.9027) (end 44.7725 115.885) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6481 115.7326) (end 44.6328 115.7173) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.152 113.8225) (end 43.0911 113.7437) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.3374 114.0587) (end 43.2765 113.98) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.831 115.9535) (end 44.8157 115.9358) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.4619 114.2162) (end 43.3984 114.1374) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.0131 114.9223) (end 43.9521 114.8436) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.3204 115.316) (end 44.2595 115.2373) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.5058 115.5522) (end 44.4449 115.4735) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6201 115.6995) (end 44.6074 115.6818) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7167 115.8189) (end 44.704 115.8011) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8868 116.0196) (end 44.8741 116.0018) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.5922 115.664) (end 44.5795 115.6462) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.539899 113.0351) (end 42.478899 112.9563) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.0911 113.7437) (end 43.0301 113.665) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.0766 115.001) (end 44.0131 114.9223) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8005 115.9205) (end 44.7878 115.9027) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.4449 115.4735) (end 44.3814 115.3947) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6328 115.7173) (end 44.6201 115.6995) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.676 115.7681) (end 44.6608 115.7503) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.357 112.7989) (end 42.296 112.720101) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6887 115.7834) (end 44.676 115.7681) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.5229 114.2949) (end 43.4619 114.2162) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.478899 112.9563) (end 42.418 112.8776) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.661799 113.1926) (end 42.6008 113.1138) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.8472 113.4288) (end 42.7837 113.35) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7319 115.8342) (end 44.7167 115.8189) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8437 115.9688) (end 44.831 115.9535) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9173 116.0526) (end 44.9021 116.0374) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.1375 115.0798) (end 44.0766 115.001) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6074 115.6818) (end 44.5922 115.664) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6608 115.7503) (end 44.6481 115.7326) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.722799 113.2713) (end 42.661799 113.1926) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.9691 113.5863) (end 42.9082 113.5075) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7446 115.8519) (end 44.7319 115.8342) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.2595 115.2373) (end 44.1985 115.1585) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7598 115.8697) (end 44.7446 115.8519) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.2765 113.98) (end 43.2155 113.9012) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.3984 114.1374) (end 43.3374 114.0587) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.5838 114.3737) (end 43.5229 114.2949) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3596 85.8444) (end 32.3748 85.8291) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6999 85.4583) (end 32.7152 85.4431) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8701 85.2246) (end 32.8803 85.2068) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.025 84.9224) (end 33.0327 84.9071) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.893 85.1891) (end 32.9031 85.1687) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7939 85.3364) (end 32.8066 85.3161) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0174 84.9401) (end 33.025 84.9224) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9031 85.1687) (end 32.9133 85.156) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8803 85.2068) (end 32.893 85.1891) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0708 84.7903) (end 33.0784 84.7725) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0657 84.8081) (end 33.0708 84.7903) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9615 85.0646) (end 32.9692 85.0494) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0606 84.8233) (end 33.0657 84.8081) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5577 85.631) (end 32.5729 85.6132) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5272 85.664) (end 32.5424 85.6463) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4662 85.7301) (end 32.4815 85.7148) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4205 85.7809) (end 32.4358 85.7631) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9971 84.9884) (end 33.0047 84.9706) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8447 85.2627) (end 32.8574 85.2449) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0504 84.8563) (end 33.0555 84.8411) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8574 85.2449) (end 32.8701 85.2246) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0327 84.9071) (end 33.0377 84.8893) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5882 85.598) (end 32.6009 85.5802) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7558 85.3897) (end 32.7685 85.3719) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0123 84.9554) (end 33.0174 84.9401) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6313 85.5447) (end 32.644 85.5294) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9692 85.0494) (end 32.9768 85.0341) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4967 85.6971) (end 32.512 85.6818) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9844 85.0189) (end 32.992 85.0036) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9463 85.0951) (end 32.9539 85.0798) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4815 85.7148) (end 32.4967 85.6971) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9285 85.1256) (end 32.9387 85.1103) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.832 85.2805) (end 32.8447 85.2627) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7685 85.3719) (end 32.7812 85.3542) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7279 85.4253) (end 32.7406 85.4075) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6593 85.5116) (end 32.672 85.4939) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6872 85.4761) (end 32.6999 85.4583) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0555 84.8411) (end 33.0606 84.8233) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0377 84.8893) (end 33.0428 84.8741) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9768 85.0341) (end 32.9844 85.0189) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8193 85.2983) (end 32.832 85.2805) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7406 85.4075) (end 32.7558 85.3897) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.644 85.5294) (end 32.6593 85.5116) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6009 85.5802) (end 32.6161 85.5624) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0428 84.8741) (end 33.0504 84.8563) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0047 84.9706) (end 33.0123 84.9554) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9209 85.1408) (end 32.9285 85.1256) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.39 85.8139) (end 32.4053 85.7961) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.3748 85.8291) (end 32.39 85.8139) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.992 85.0036) (end 32.9971 84.9884) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9539 85.0798) (end 32.9615 85.0646) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9387 85.1103) (end 32.9463 85.0951) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4053 85.7961) (end 32.4205 85.7809) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.8066 85.3161) (end 32.8193 85.2983) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.672 85.4939) (end 32.6872 85.4761) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5729 85.6132) (end 32.5882 85.598) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.5424 85.6463) (end 32.5577 85.631) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.9133 85.156) (end 32.9209 85.1408) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7812 85.3542) (end 32.7939 85.3364) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.512 85.6818) (end 32.5272 85.664) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.451 85.7479) (end 32.4662 85.7301) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.7152 85.4431) (end 32.7279 85.4253) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6161 85.5624) (end 32.6313 85.5447) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.4358 85.7631) (end 32.451 85.7479) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9701 49.0703) (end 50.9854 49.022) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2775 47.9577) (end 51.2876 47.912) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9447 49.1642) (end 50.9574 49.116) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8508 49.4894) (end 50.8635 49.4436) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8787 49.3979) (end 50.8914 49.3497) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2419 48.0949) (end 51.2521 48.0492) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7009 50.0024) (end 50.7136 49.9567) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0641 48.7426) (end 51.0768 48.6943) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2648 48.0035) (end 51.2775 47.9577) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6603 50.1421) (end 50.673 50.0964) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1022 48.6029) (end 51.1149 48.5546) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2521 48.0492) (end 51.2648 48.0035) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2165 48.1838) (end 51.2292 48.1381) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7974 49.6773) (end 50.8101 49.6316) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1657 48.3667) (end 51.1784 48.321) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8914 49.3497) (end 50.9041 49.3039) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2038 48.2295) (end 51.2165 48.1838) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1784 48.321) (end 51.1911 48.2752) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9574 49.116) (end 50.9701 49.0703) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9981 48.9763) (end 51.0108 48.9306) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.673 50.0964) (end 50.6882 50.0507) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7568 49.817) (end 50.7695 49.7713) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9168 49.2557) (end 50.932 49.21) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9041 49.3039) (end 50.9168 49.2557) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8101 49.6316) (end 50.8254 49.5833) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7695 49.7713) (end 50.7822 49.723) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7822 49.723) (end 50.7974 49.6773) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7136 49.9567) (end 50.7288 49.911) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1911 48.2752) (end 51.2038 48.2295) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.153 48.4149) (end 51.1657 48.3667) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8381 49.5376) (end 50.8508 49.4894) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1403 48.4607) (end 51.153 48.4149) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1276 48.5089) (end 51.1403 48.4607) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0489 48.7883) (end 51.0641 48.7426) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6882 50.0507) (end 50.7009 50.0024) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1149 48.5546) (end 51.1276 48.5089) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0768 48.6943) (end 51.0895 48.6486) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0362 48.8366) (end 51.0489 48.7883) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9854 49.022) (end 50.9981 48.9763) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0235 48.8823) (end 51.0362 48.8366) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7415 49.8627) (end 50.7568 49.817) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8254 49.5833) (end 50.8381 49.5376) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7288 49.911) (end 50.7415 49.8627) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.313 47.8206) (end 51.3232 47.7749) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0108 48.9306) (end 51.0235 48.8823) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3003 47.8663) (end 51.313 47.8206) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2292 48.1381) (end 51.2419 48.0949) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.932 49.21) (end 50.9447 49.1642) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8635 49.4436) (end 50.8787 49.3979) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2876 47.912) (end 51.3003 47.8663) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0895 48.6486) (end 51.1022 48.6029) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.264 51.4299) (end 50.2666 51.4096) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1421 51.9633) (end 50.1472 51.9455) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1218 52.0167) (end 50.1294 51.9989) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.297 51.3029) (end 50.3123 51.2572) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2513 51.4833) (end 50.2539 51.4655) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2589 51.4477) (end 50.264 51.4299) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4317 50.8864) (end 50.4444 50.8406) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4012 50.9803) (end 50.4164 50.9321) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2107 51.689) (end 50.2158 51.6712) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5333 50.5612) (end 50.546 50.5155) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2005 51.7449) (end 50.2056 51.7246) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1599 51.91) (end 50.165 51.8922) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.645 50.1904) (end 50.6603 50.1421) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6323 50.2361) (end 50.645 50.1904) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6044 50.3301) (end 50.6171 50.2818) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5739 50.4215) (end 50.5891 50.3758) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2361 51.5595) (end 50.2386 51.5391) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.358 51.1175) (end 50.3732 51.0718) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1853 51.8185) (end 50.1878 51.8008) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.546 50.5155) (end 50.5612 50.4698) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3732 51.0718) (end 50.3859 51.0261) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5028 50.6552) (end 50.518 50.6095) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4748 50.7467) (end 50.4901 50.7009) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2818 51.3563) (end 50.2869 51.3385) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3428 51.1632) (end 50.358 51.1175) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2056 51.7246) (end 50.2081 51.7068) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2259 51.6128) (end 50.2285 51.595) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.165 51.8922) (end 50.17 51.8744) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2716 51.3918) (end 50.2767 51.374) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2386 51.5391) (end 50.2437 51.5214) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2335 51.5772) (end 50.2361 51.5595) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2285 51.595) (end 50.2335 51.5772) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2158 51.6712) (end 50.2183 51.6509) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1472 51.9455) (end 50.1548 51.9278) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1345 51.9811) (end 50.1421 51.9633) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1751 51.8541) (end 50.1802 51.8363) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2869 51.3385) (end 50.292 51.3207) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2462 51.5036) (end 50.2513 51.4833) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6171 50.2818) (end 50.6323 50.2361) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5612 50.4698) (end 50.5739 50.4215) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3275 51.2115) (end 50.3428 51.1632) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2767 51.374) (end 50.2818 51.3563) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2081 51.7068) (end 50.2107 51.689) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.17 51.8744) (end 50.1751 51.8541) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5891 50.3758) (end 50.6044 50.3301) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4596 50.7949) (end 50.4748 50.7467) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1294 51.9989) (end 50.1345 51.9811) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1929 51.7804) (end 50.1954 51.7627) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.518 50.6095) (end 50.5333 50.5612) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4901 50.7009) (end 50.5028 50.6552) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2234 51.6331) (end 50.2259 51.6128) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2437 51.5214) (end 50.2462 51.5036) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2183 51.6509) (end 50.2234 51.6331) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3123 51.2572) (end 50.3275 51.2115) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1878 51.8008) (end 50.1929 51.7804) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4444 50.8406) (end 50.4596 50.7949) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4164 50.9321) (end 50.4317 50.8864) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1954 51.7627) (end 50.2005 51.7449) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3859 51.0261) (end 50.4012 50.9803) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.292 51.3207) (end 50.297 51.3029) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2539 51.4655) (end 50.2589 51.4477) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1548 51.9278) (end 50.1599 51.91) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2666 51.4096) (end 50.2716 51.3918) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1802 51.8363) (end 50.1853 51.8185) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7019 53.147) (end 48.7705 53.0936) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9338 52.291) (end 49.9491 52.2757) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.752 53.9242) (end 47.818 53.8683) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1703 54.4576) (end 47.2338 54.3966) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1065 52.0497) (end 50.1142 52.0344) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0278 52.1843) (end 50.0405 52.1665) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4225 53.3629) (end 48.4936 53.307) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2879 53.4721) (end 48.3565 53.4162) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0989 52.0675) (end 50.1065 52.0497) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0811 52.1005) (end 50.0888 52.0852) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2193 53.528) (end 48.2879 53.4721) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.071 52.1183) (end 50.0811 52.1005) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6392 52.4942) (end 49.7154 52.4485) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2338 54.3966) (end 47.2973 54.338201) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4919 52.5907) (end 49.5655 52.5424) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1998 52.7863) (end 49.2709 52.7355) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9839 52.9387) (end 49.055 52.8879) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9922 52.23) (end 50.0049 52.2148) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4903 54.1604) (end 47.5564 54.0995) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3565 53.4162) (end 48.4225 53.3629) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.85 52.3621) (end 49.8678 52.3469) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1507 53.5838) (end 48.2193 53.528) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7916 52.4002) (end 49.8119 52.3875) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6224 54.041) (end 47.6859 53.9826) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.2973 54.338201) (end 47.3633 54.2773) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.3633 54.2773) (end 47.4268 54.218801) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3445 52.6872) (end 49.4182 52.639) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4936 53.307) (end 48.5622 53.2536) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2709 52.7355) (end 49.3445 52.6872) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.1068 54.5186) (end 47.1703 54.4576) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5564 54.0995) (end 47.6224 54.041) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.4268 54.218801) (end 47.4903 54.1604) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0608 52.136) (end 50.071 52.1183) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0049 52.2148) (end 50.0176 52.1995) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9643 52.2605) (end 49.9795 52.2453) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8856 52.3342) (end 49.9033 52.3189) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9186 52.3062) (end 49.9338 52.291) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1142 52.0344) (end 50.1218 52.0167) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0888 52.0852) (end 50.0989 52.0675) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0507 52.1513) (end 50.0608 52.136) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9795 52.2453) (end 49.9922 52.23) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8678 52.3469) (end 49.8856 52.3342) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8119 52.3875) (end 49.8297 52.3748) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.9501 53.754) (end 48.0187 53.6956) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.6859 53.9826) (end 47.752 53.9242) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.818 53.8683) (end 47.884 53.8099) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0405 52.1665) (end 50.0507 52.1513) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8416 53.0428) (end 48.9127 52.9895) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7705 53.0936) (end 48.8416 53.0428) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0176 52.1995) (end 50.0278 52.1843) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9491 52.2757) (end 49.9643 52.2605) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0187 53.6956) (end 48.0847 53.6397) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9127 52.9895) (end 48.9839 52.9387) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9033 52.3189) (end 49.9186 52.3062) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8297 52.3748) (end 49.85 52.3621) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7154 52.4485) (end 49.7916 52.4002) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5655 52.5424) (end 49.6392 52.4942) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6308 53.2003) (end 48.7019 53.147) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4182 52.639) (end 49.4919 52.5907) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1261 52.8371) (end 49.1998 52.7863) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.055 52.8879) (end 49.1261 52.8371) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5622 53.2536) (end 48.6308 53.2003) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0847 53.6397) (end 48.1507 53.5838) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.884 53.8099) (end 47.9501 53.754) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.9851 57.8587) (end 44.0283 57.8079) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1002 56.576) (end 45.1459 56.5252) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.4228 56.2254) (end 45.471 56.1772) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.9798 54.640501) (end 47.0433 54.5795) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.8531 58.0161) (end 43.8962 57.9628) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.9163 54.7014) (end 46.9798 54.640501) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.8528 54.7624) (end 46.9163 54.7014) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9282 55.6971) (end 45.9892 55.633601) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1459 56.5252) (end 45.1916 56.476901) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0113 56.6776) (end 45.0545 56.626801) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.7918 54.8234) (end 46.8528 54.7624) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1111 55.5092) (end 46.1721 55.445701) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.3382 57.4446) (end 44.3814 57.3938) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.2061 57.5996) (end 44.2493 57.5488) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.8962 57.9628) (end 43.9394 57.912) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.7283 54.8843) (end 46.7918 54.8234) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.4794 55.133201) (end 46.5429 55.0697) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.4185 55.1942) (end 46.4794 55.133201) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2399 56.4261) (end 45.2856 56.3753) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6234 56.014601) (end 45.6844 55.9511) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.471 56.1772) (end 45.5168 56.1264) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.2856 56.3753) (end 45.3313 56.324501) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.0545 56.626801) (end 45.1002 56.576) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8741 56.83) (end 44.9199 56.779201) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6938 57.0332) (end 44.7395 56.9824) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6506 57.0865) (end 44.6938 57.0332) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.074 57.7571) (end 44.1172 57.7037) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.516 57.2389) (end 44.5617 57.1881) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.295 57.498) (end 44.3382 57.4446) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.1604 57.6529) (end 44.2061 57.5996) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.0283 57.8079) (end 44.074 57.7571) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.1172 57.7037) (end 44.1604 57.6529) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.3814 57.3938) (end 44.4271 57.343) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.3313 56.324501) (end 45.3771 56.276201) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.6674 54.945301) (end 46.7283 54.8843) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.8073 58.0669) (end 43.8531 58.0161) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.6039 55.0088) (end 46.6674 54.945301) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.5429 55.0697) (end 46.6039 55.0088) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.5617 57.1881) (end 44.6049 57.1373) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.4703 57.2897) (end 44.516 57.2389) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9199 56.779201) (end 44.9656 56.7284) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8673 55.7606) (end 45.9282 55.6971) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9656 56.7284) (end 45.0113 56.6776) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.4271 57.343) (end 44.4703 57.2897) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7852 56.931601) (end 44.8284 56.8808) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.294 55.3187) (end 46.3575 55.2577) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.8063 55.824101) (end 45.8673 55.7606) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.9892 55.633601) (end 46.0502 55.5701) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.565 56.0781) (end 45.6234 56.014601) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.233 55.3822) (end 46.294 55.3187) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.7454 55.8876) (end 45.8063 55.824101) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.3575 55.2577) (end 46.4185 55.1942) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.1721 55.445701) (end 46.233 55.3822) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.6844 55.9511) (end 45.7454 55.8876) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.3771 56.276201) (end 45.4228 56.2254) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.1916 56.476901) (end 45.2399 56.4261) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.8284 56.8808) (end 44.8741 56.83) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.7395 56.9824) (end 44.7852 56.931601) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.2493 57.5488) (end 44.295 57.498) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.9394 57.912) (end 43.9851 57.8587) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.6049 57.1373) (end 44.6506 57.0865) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.0433 54.5795) (end 47.1068 54.5186) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0502 55.5701) (end 46.1111 55.5092) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5168 56.1264) (end 45.565 56.0781) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.3936 62.2935) (end 40.452 62.2071) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.3222 58.6359) (end 43.3654 58.5851) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.9321 61.5315) (end 40.993 61.4477) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.0987 58.8924) (end 43.1444 58.8416) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.8726 59.149) (end 42.9183 59.0982) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.6298 61.9531) (end 40.6908 61.8693) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.2122 59.8983) (end 42.2808 59.8195) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.623699 59.4284) (end 42.692299 59.3496) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.6839 60.5409) (end 41.7499 60.4596) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.4934 60.7873) (end 41.5569 60.706) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.3029 61.0337) (end 41.3664 60.9498) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.1175 61.2826) (end 41.1784 61.1988) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.721 58.1711) (end 43.7642 58.1177) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.738 59.2988) (end 42.7837 59.2506) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.9183 59.0982) (end 42.9641 59.0448) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.5432 58.3768) (end 43.5864 58.326) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.1784 61.1988) (end 41.2419 61.1149) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.8795 60.2996) (end 41.9455 60.2183) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.5864 58.326) (end 43.6321 58.2752) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.4543 58.481) (end 43.5 58.4302) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.0098 58.994) (end 43.053 58.9432) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.8711 61.6153) (end 40.9321 61.5315) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.4299 60.8686) (end 41.4934 60.7873) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.2742 62.4637) (end 40.3326 62.3773) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.816 60.3783) (end 41.8795 60.2996) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.7642 58.1177) (end 43.8073 58.0669) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.993 61.4477) (end 41.054 61.3664) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.4111 58.5318) (end 43.4543 58.481) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.6204 60.6222) (end 41.6839 60.5409) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.6753 58.2219) (end 43.721 58.1711) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.3654 58.5851) (end 43.4111 58.5318) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.2765 58.6867) (end 43.3222 58.6359) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.2333 58.7375) (end 43.2765 58.6867) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.1876 58.7908) (end 43.2333 58.7375) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.1462 59.9796) (end 42.2122 59.8983) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.3664 60.9498) (end 41.4299 60.8686) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.1444 58.8416) (end 43.1876 58.7908) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.053 58.9432) (end 43.0987 58.8924) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.452 62.2071) (end 40.5104 62.1233) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.9641 59.0448) (end 43.0098 58.994) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.7499 60.4596) (end 41.816 60.3783) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.3468 59.7408) (end 42.4154 59.6621) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.8101 61.6991) (end 40.8711 61.6153) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.2808 59.8195) (end 42.3468 59.7408) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.054 61.3664) (end 41.1175 61.2826) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.7492 61.7855) (end 40.8101 61.6991) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.8294 59.1998) (end 42.8726 59.149) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.5526 59.5046) (end 42.623699 59.4284) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.692299 59.3496) (end 42.738 59.2988) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.0776 60.0583) (end 42.1462 59.9796) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.5569 60.706) (end 41.6204 60.6222) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.2419 61.1149) (end 41.3029 61.0337) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.5714 62.037) (end 40.6298 61.9531) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.5104 62.1233) (end 40.5714 62.037) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.2158 62.55) (end 40.2742 62.4637) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.4154 59.6621) (end 42.484 59.5833) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.484 59.5833) (end 42.5526 59.5046) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.0116 60.137) (end 42.0776 60.0583) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.9455 60.2183) (end 42.0116 60.137) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.6908 61.8693) (end 40.7492 61.7855) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.3326 62.3773) (end 40.3936 62.2935) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.7837 59.2506) (end 42.8294 59.1998) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.6321 58.2752) (end 43.6753 58.2219) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.5 58.4302) (end 43.5432 58.3768) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.9095 66.2305) (end 37.9679 66.1264) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.9062 68.2066) (end 36.957 68.0999) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.1574 62.6339) (end 40.2158 62.55) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.0989 62.7202) (end 40.1574 62.6339) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.4157 63.7591) (end 39.4716 63.6727) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.1381 65.8216) (end 38.1965 65.72) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.0078 67.9958) (end 37.0586 67.8917) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.0431 62.8066) (end 40.0989 62.7202) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.9846 62.8929) (end 40.0431 62.8066) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.8678 63.0657) (end 39.9262 62.9793) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.9661 64.4576) (end 39.022 64.3687) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.5274 63.5838) (end 39.5833 63.4975) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.801 64.7192) (end 38.8569 64.6328) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.4716 63.6727) (end 39.5274 63.5838) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.8569 64.6328) (end 38.9102 64.5439) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.5546 65.118) (end 38.6156 65.0164) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.4192 67.1576) (end 37.4726 67.0535) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.1068 67.785) (end 37.1602 67.6808) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.7375 64.8183) (end 38.801 64.7192) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.5793 66.8477) (end 37.6326 66.7436) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.0586 67.8917) (end 37.1068 67.785) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.9262 62.9793) (end 39.9846 62.8929) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.8119 63.152) (end 39.8678 63.0657) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.7977 66.4337) (end 37.8536 66.3321) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.3573 63.8454) (end 39.4157 63.7591) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.3743 65.4177) (end 38.4327 65.3186) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.957 68.0999) (end 37.0078 67.9958) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.9102 64.5439) (end 38.9661 64.4576) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.7535 63.2384) (end 39.8119 63.152) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.3659 67.2617) (end 37.4192 67.1576) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.6976 63.3247) (end 39.7535 63.2384) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.2455 64.0207) (end 39.3014 63.9318) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.8579 68.3133) (end 36.9062 68.2066) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.6417 63.4111) (end 39.6976 63.3247) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.5833 63.4975) (end 39.6417 63.4111) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.3014 63.9318) (end 39.3573 63.8454) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.1896 64.1071) (end 39.2455 64.0207) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.1337 64.1934) (end 39.1896 64.1071) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.9679 66.1264) (end 38.0238 66.0248) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.022 64.3687) (end 39.0779 64.2823) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.1602 67.6808) (end 37.211 67.5767) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.8096 68.4174) (end 36.8579 68.3133) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.3133 65.5193) (end 38.3743 65.4177) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.6885 66.6394) (end 37.7444 66.5378) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.2549 65.6184) (end 38.3133 65.5193) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.6623 68.7375) (end 36.7106 68.6308) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.0779 64.2823) (end 39.1337 64.1934) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.7106 68.6308) (end 36.7588 68.5241) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.6326 66.7436) (end 37.6885 66.6394) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.6156 65.0164) (end 38.6765 64.9173) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.211 67.5767) (end 37.2618 67.47) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.4327 65.3186) (end 38.4937 65.217) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.0796 65.9232) (end 38.1381 65.8216) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.0238 66.0248) (end 38.0796 65.9232) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.7444 66.5378) (end 37.7977 66.4337) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.6765 64.9173) (end 38.7375 64.8183) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.2618 67.47) (end 37.3151 67.3659) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.1965 65.72) (end 38.2549 65.6184) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.3151 67.3659) (end 37.3659 67.2617) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.7588 68.5241) (end 36.8096 68.4174) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.8536 66.3321) (end 37.9095 66.2305) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.5259 66.9493) (end 37.5793 66.8477) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.4937 65.217) (end 38.5546 65.118) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.4726 67.0535) (end 37.5259 66.9493) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.245 72.2605) (end 35.2653 72.202) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0172 70.2386) (end 36.0629 70.1319) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1866 72.4408) (end 35.2069 72.3798) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0316 72.9183) (end 35.0494 72.8599) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9554 73.1596) (end 34.9732 73.0987) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1459 72.5602) (end 35.1663 72.4992) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0875 72.738) (end 35.1078 72.6796) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.0629 70.1319) (end 36.1061 70.0227) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7726 73.7616) (end 34.7903 73.7006) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.9308 70.4545) (end 35.974 70.3478) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4126 71.7855) (end 35.433 71.7271) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.864 73.4593) (end 34.8818 73.4009) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3491 71.9633) (end 35.3695 71.9049) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2069 72.3798) (end 35.2247 72.3214) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7903 73.7006) (end 34.808099 73.6397) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0494 72.8599) (end 35.0697 72.7989) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1282 72.6186) (end 35.1459 72.5602) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.974 70.3478) (end 36.0172 70.2386) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7987 70.7796) (end 35.8419 70.673) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6285 71.214) (end 35.6717 71.1073) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0697 72.7989) (end 35.0875 72.738) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.0113 72.9793) (end 35.0316 72.9183) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8259 73.5813) (end 34.8462 73.5203) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5854 71.3232) (end 35.6285 71.214) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.499 71.5518) (end 35.5219 71.4908) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3923 71.8464) (end 35.4126 71.7855) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2856 72.1411) (end 35.3085 72.0827) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3288 72.0242) (end 35.3491 71.9633) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9935 73.0377) (end 35.0113 72.9793) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3085 72.0827) (end 35.3288 72.0242) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2653 72.202) (end 35.2856 72.1411) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9732 73.0987) (end 34.9935 73.0377) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.433 71.7271) (end 35.4558 71.6686) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8851 70.5637) (end 35.9308 70.4545) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.8419 70.673) (end 35.8851 70.5637) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1663 72.4992) (end 35.1866 72.4408) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9377 73.218) (end 34.9554 73.1596) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8462 73.5203) (end 34.864 73.4593) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5219 71.4908) (end 35.5447 71.4324) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4787 71.6102) (end 35.499 71.5518) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1078 72.6796) (end 35.1282 72.6186) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7124 70.9981) (end 35.7555 70.8889) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.4558 71.6686) (end 35.4787 71.6102) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8996 73.34) (end 34.9199 73.279) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.808099 73.6397) (end 34.8259 73.5813) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.6166 68.8442) (end 36.6623 68.7375) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.8818 73.4009) (end 34.8996 73.34) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.5683 68.9508) (end 36.6166 68.8442) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.5201 69.0575) (end 36.5683 68.9508) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.4744 69.1642) (end 36.5201 69.0575) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.4261 69.2709) (end 36.4744 69.1642) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.3804 69.3776) (end 36.4261 69.2709) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.3347 69.4842) (end 36.3804 69.3776) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1975 69.8068) (end 36.2432 69.7001) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1061 70.0227) (end 36.1518 69.916) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7555 70.8889) (end 35.7987 70.7796) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.9199 73.279) (end 34.9377 73.218) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.6717 71.1073) (end 35.7124 70.9981) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.3695 71.9049) (end 35.3923 71.8464) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.2247 72.3214) (end 35.245 72.2605) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.5447 71.4324) (end 35.5854 71.3232) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2889 69.5935) (end 36.3347 69.4842) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2432 69.7001) (end 36.2889 69.5935) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.1518 69.916) (end 36.1975 69.8068) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1198 75.9536) (end 34.1249 75.9333) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2798 75.3923) (end 34.2874 75.372) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1071 75.9968) (end 34.1147 75.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7192 73.9419) (end 34.737 73.8835) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6811 74.0639) (end 34.7014 74.0029) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5744 74.4245) (end 34.5922 74.3661) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4297 74.9071) (end 34.4474 74.8487) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3738 75.09) (end 34.3941 75.0291) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1604 75.8088) (end 34.1655 75.7885) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3179 75.2704) (end 34.3382 75.2094) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2442 75.5167) (end 34.2493 75.4964) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3001 75.3313) (end 34.3052 75.311) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7014 74.0029) (end 34.7192 73.9419) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6633 74.1248) (end 34.6811 74.0639) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1757 75.7453) (end 34.1833 75.725) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.6278 74.2442) (end 34.645599 74.1832) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3052 75.311) (end 34.3128 75.2907) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.483 74.7268) (end 34.5033 74.6684) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0868 76.0806) (end 34.0918 76.0578) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4652 74.7878) (end 34.483 74.7268) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2061 75.6412) (end 34.2138 75.6209) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2747 75.4151) (end 34.2798 75.3923) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.356 75.1484) (end 34.3738 75.09) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1147 75.9739) (end 34.1198 75.9536) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1299 75.913) (end 34.135 75.8927) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.61 74.3052) (end 34.6278 74.2442) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2874 75.372) (end 34.2925 75.3516) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4119 74.9681) (end 34.4297 74.9071) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2138 75.6209) (end 34.2188 75.6006) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0918 76.0578) (end 34.0969 76.0374) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5922 74.3661) (end 34.61 74.3052) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5567 74.4855) (end 34.5744 74.4245) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.538899 74.5465) (end 34.5567 74.4855) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0969 76.0374) (end 34.102 76.0171) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3382 75.2094) (end 34.356 75.1484) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2696 75.4355) (end 34.2747 75.4151) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.4474 74.8487) (end 34.4652 74.7878) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2925 75.3516) (end 34.3001 75.3313) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.262 75.4558) (end 34.2696 75.4355) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2569 75.4761) (end 34.262 75.4558) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2493 75.4964) (end 34.2569 75.4761) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1528 75.8292) (end 34.1604 75.8088) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2315 75.5599) (end 34.2366 75.5371) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2239 75.5802) (end 34.2315 75.5599) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2188 75.6006) (end 34.2239 75.5802) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.196 75.6844) (end 34.2011 75.6615) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1477 75.8495) (end 34.1528 75.8292) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1655 75.7885) (end 34.1706 75.7657) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1249 75.9333) (end 34.1299 75.913) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1884 75.7047) (end 34.196 75.6844) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1426 75.8698) (end 34.1477 75.8495) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3941 75.0291) (end 34.4119 74.9681) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.3128 75.2907) (end 34.3179 75.2704) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1833 75.725) (end 34.1884 75.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2011 75.6615) (end 34.2061 75.6412) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.135 75.8927) (end 34.1426 75.8698) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.645599 74.1832) (end 34.6633 74.1248) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5211 74.6074) (end 34.538899 74.5465) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.2366 75.5371) (end 34.2442 75.5167) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.5033 74.6684) (end 34.5211 74.6074) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.102 76.0171) (end 34.1071 75.9968) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.737 73.8835) (end 34.7548 73.8226) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1706 75.7657) (end 34.1757 75.7453) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.7548 73.8226) (end 34.7726 73.7616) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.721 77.9221) (end 33.7286 77.8789) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7667 77.658) (end 33.7769 77.6148) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8759 77.0865) (end 33.8836 77.0433) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0715 76.1416) (end 34.0766 76.1213) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8912 77.0001) (end 33.8988 76.9569) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8251 77.3506) (end 33.8328 77.3074) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0156 76.3727) (end 34.0207 76.3524) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8988 76.9569) (end 33.909 76.9112) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8836 77.0433) (end 33.8912 77.0001) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0563 76.2051) (end 34.0614 76.1848) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0029 76.4362) (end 34.0055 76.4159) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9598 76.6496) (end 33.9674 76.6039) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0512 76.2254) (end 34.0563 76.2051) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0461 76.2457) (end 34.0512 76.2254) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.688 78.0974) (end 33.6956 78.0542) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6727 78.1863) (end 33.6804 78.1431) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.041 76.2686) (end 34.0461 76.2457) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9852 76.52) (end 33.9877 76.4997) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8582 77.1754) (end 33.8658 77.1322) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.036 76.2889) (end 34.041 76.2686) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8658 77.1322) (end 33.8759 77.0865) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0207 76.3524) (end 34.0258 76.3321) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7058 78.011) (end 33.7134 77.9653) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7997 77.4827) (end 33.8074 77.4395) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0055 76.4159) (end 34.0106 76.393) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7286 77.8789) (end 33.7362 77.8332) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9674 76.6039) (end 33.9725 76.5835) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6575 78.2752) (end 33.6651 78.2295) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.975 76.5632) (end 33.9801 76.5404) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.942 76.7359) (end 33.9496 76.6928) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6499 78.3184) (end 33.6575 78.2752) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9242 76.8248) (end 33.9344 76.7791) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8505 77.2185) (end 33.8582 77.1754) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8074 77.4395) (end 33.8175 77.3938) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7845 77.5716) (end 33.7921 77.5259) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7439 77.79) (end 33.7515 77.7469) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7591 77.7011) (end 33.7667 77.658) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0664 76.1619) (end 34.0715 76.1416) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0106 76.393) (end 34.0156 76.3727) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9725 76.5835) (end 33.975 76.5632) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8404 77.2643) (end 33.8505 77.2185) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7921 77.5259) (end 33.7997 77.4827) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7362 77.8332) (end 33.7439 77.79) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7134 77.9653) (end 33.721 77.9221) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0817 76.1009) (end 34.0868 76.0806) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0766 76.1213) (end 34.0817 76.1009) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9166 76.868) (end 33.9242 76.8248) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9928 76.4794) (end 33.9979 76.4565) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0614 76.1848) (end 34.0664 76.1619) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0309 76.3092) (end 34.036 76.2889) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.0258 76.3321) (end 34.0309 76.3092) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9979 76.4565) (end 34.0029 76.4362) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9877 76.4997) (end 33.9928 76.4794) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8328 77.3074) (end 33.8404 77.2643) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7515 77.7469) (end 33.7591 77.7011) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6956 78.0542) (end 33.7058 78.011) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6804 78.1431) (end 33.688 78.0974) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9801 76.5404) (end 33.9852 76.52) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.8175 77.3938) (end 33.8251 77.3506) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6651 78.2295) (end 33.6727 78.1863) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9496 76.6928) (end 33.9598 76.6496) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.9344 76.7791) (end 33.942 76.7359) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.909 76.9112) (end 33.9166 76.868) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.7769 77.6148) (end 33.7845 77.5716) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4975 79.2886) (end 33.5026 79.2429) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3375 80.7593) (end 33.34 80.7237) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4365 79.7357) (end 33.4416 79.7001) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4518 79.6315) (end 33.4543 79.596) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4086 79.9821) (end 33.4137 79.9465) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4162 79.9135) (end 33.4213 79.8779) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5635 78.8467) (end 33.5711 78.8035) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5508 78.9356) (end 33.5559 78.8899) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3705 80.3707) (end 33.373 80.3351) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.34 80.7237) (end 33.3451 80.6882) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5432 78.9788) (end 33.5508 78.9356) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3603 80.4774) (end 33.3654 80.4418) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5559 78.8899) (end 33.5635 78.8467) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4543 79.596) (end 33.4594 79.5604) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5356 79.0219) (end 33.5432 78.9788) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4848 79.375) (end 33.4899 79.3318) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3959 80.1243) (end 33.3984 80.0887) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4746 79.4563) (end 33.4772 79.4207) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4213 79.8779) (end 33.4264 79.8424) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4772 79.4207) (end 33.4848 79.375) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4645 79.5249) (end 33.4695 79.4893) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4594 79.5604) (end 33.4645 79.5249) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4416 79.7001) (end 33.4467 79.6671) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3349 80.7949) (end 33.3375 80.7593) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3654 80.4418) (end 33.3679 80.4062) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3476 80.6526) (end 33.3502 80.6196) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4695 79.4893) (end 33.4746 79.4563) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3832 80.231) (end 33.3883 80.1954) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4467 79.6671) (end 33.4518 79.6315) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4264 79.8424) (end 33.4289 79.8068) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3984 80.0887) (end 33.401 80.0532) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3883 80.1954) (end 33.3908 80.1599) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4289 79.8068) (end 33.434 79.7712) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3908 80.1599) (end 33.3959 80.1243) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.373 80.3351) (end 33.3781 80.2996) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6423 78.3615) (end 33.6499 78.3184) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6372 78.4073) (end 33.6423 78.3615) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.406 80.0176) (end 33.4086 79.9821) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6296 78.4504) (end 33.6372 78.4073) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6219 78.4936) (end 33.6296 78.4504) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6143 78.5393) (end 33.6219 78.4936) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6067 78.5825) (end 33.6143 78.5393) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5178 79.1566) (end 33.5229 79.1108) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3679 80.4062) (end 33.3705 80.3707) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4899 79.3318) (end 33.4975 79.2886) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5026 79.2429) (end 33.5102 79.1997) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5991 78.6257) (end 33.6067 78.5825) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3552 80.5485) (end 33.3578 80.5129) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5915 78.6714) (end 33.5991 78.6257) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5229 79.1108) (end 33.5305 79.0677) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3806 80.264) (end 33.3832 80.231) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.401 80.0532) (end 33.406 80.0176) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3781 80.2996) (end 33.3806 80.264) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3502 80.6196) (end 33.3527 80.584) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3527 80.584) (end 33.3552 80.5485) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5864 78.7146) (end 33.5915 78.6714) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5788 78.7578) (end 33.5864 78.7146) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3578 80.5129) (end 33.3603 80.4774) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.434 79.7712) (end 33.4365 79.7357) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3451 80.6882) (end 33.3476 80.6526) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.4137 79.9465) (end 33.4162 79.9135) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5711 78.8035) (end 33.5788 78.7578) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5305 79.0677) (end 33.5356 79.0219) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.5102 79.1997) (end 33.5178 79.1566) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2816 81.6458) (end 33.2816 81.6102) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.274 81.755) (end 33.2765 81.7169) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2714 81.8312) (end 33.274 81.7931) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2613 82.0572) (end 33.2638 82.0191) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2562 82.2071) (end 33.2587 82.169) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2663 81.9429) (end 33.2689 81.9048) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2409 82.9996) (end 33.2409 82.9615) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2968 81.3613) (end 33.2994 81.3257) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2486 82.583) (end 33.2486 82.5475) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.246 82.7735) (end 33.246 82.7354) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2917 81.468) (end 33.2917 81.4324) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2511 82.3951) (end 33.2536 82.357) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2765 81.7169) (end 33.279 81.6813) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.246 82.6973) (end 33.246 82.6592) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2486 82.5475) (end 33.2511 82.5094) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2638 82.0191) (end 33.2638 81.981) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2689 81.8693) (end 33.2714 81.8312) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3273 80.9015) (end 33.3298 80.866) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3248 80.9371) (end 33.3273 80.9015) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3146 81.0793) (end 33.3171 81.0438) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2638 81.981) (end 33.2663 81.9429) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2613 82.0953) (end 33.2613 82.0572) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2511 82.4713) (end 33.2511 82.4332) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3121 81.1149) (end 33.3146 81.0793) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.307 81.219) (end 33.307 81.1835) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2943 81.3968) (end 33.2968 81.3613) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2841 81.5746) (end 33.2867 81.5391) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2892 81.5035) (end 33.2917 81.468) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2587 82.1309) (end 33.2613 82.0953) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2867 81.5391) (end 33.2892 81.5035) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2816 81.6102) (end 33.2841 81.5746) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2587 82.169) (end 33.2587 82.1309) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2994 81.3257) (end 33.3019 81.2902) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3197 81.0082) (end 33.3222 80.9727) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.274 81.7931) (end 33.274 81.755) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2409 83.0351) (end 33.2409 82.9996) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2562 82.2452) (end 33.2562 82.2071) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2511 82.4332) (end 33.2511 82.3951) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.307 81.1835) (end 33.3095 81.1505) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3044 81.2546) (end 33.307 81.219) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2689 81.9048) (end 33.2689 81.8693) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3019 81.2902) (end 33.3044 81.2546) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2536 82.3214) (end 33.2562 82.2833) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2409 82.9234) (end 33.2435 82.8853) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2511 82.5094) (end 33.2511 82.4713) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2409 82.9615) (end 33.2409 82.9234) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2536 82.357) (end 33.2536 82.3214) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2435 82.8091) (end 33.246 82.7735) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3222 80.9727) (end 33.3248 80.9371) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3171 81.0438) (end 33.3197 81.0082) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2384 83.0732) (end 33.2409 83.0351) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3095 81.1505) (end 33.3121 81.1149) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.246 82.7354) (end 33.246 82.6973) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2917 81.4324) (end 33.2943 81.3968) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.279 81.6813) (end 33.2816 81.6458) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2435 82.8853) (end 33.2435 82.8472) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2562 82.2833) (end 33.2562 82.2452) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2486 82.6211) (end 33.2486 82.583) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2384 83.1113) (end 33.2384 83.0732) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2435 82.8472) (end 33.2435 82.8091) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2384 83.1494) (end 33.2384 83.1113) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.246 82.6592) (end 33.2486 82.6211) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3324 80.8304) (end 33.3349 80.7949) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.3298 80.866) (end 33.3324 80.8304) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1571 84.4245) (end 33.1597 84.4067) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0835 84.7573) (end 33.0885 84.7395) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.18 84.2645) (end 33.1825 84.2467) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2359 83.1875) (end 33.2384 83.1494) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2079 83.9394) (end 33.2105 83.9013) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1698 84.3534) (end 33.1724 84.3356) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0911 84.7217) (end 33.0962 84.7039) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2333 83.2993) (end 33.2359 83.2612) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2308 83.4136) (end 33.2308 83.3755) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2282 83.5254) (end 33.2282 83.4873) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2232 83.6371) (end 33.2232 83.6016) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1876 84.2112) (end 33.1876 84.1934) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2359 83.2231) (end 33.2359 83.1875) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2308 83.4492) (end 33.2308 83.4136) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2232 83.6016) (end 33.2257 83.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2155 83.7895) (end 33.2181 83.7514) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1266 84.582) (end 33.1317 84.5642) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1012 84.6861) (end 33.1063 84.6709) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1876 84.1934) (end 33.1901 84.1756) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1393 84.5287) (end 33.1419 84.5134) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0962 84.7039) (end 33.1012 84.6861) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1774 84.2823) (end 33.18 84.2645) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1952 84.1248) (end 33.1952 84.107) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.152 84.4601) (end 33.1546 84.4423) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2206 83.7133) (end 33.2206 83.6752) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1825 84.2467) (end 33.1851 84.2289) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0885 84.7395) (end 33.0911 84.7217) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2359 83.2612) (end 33.2359 83.2231) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2333 83.3374) (end 33.2333 83.2993) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1241 84.5998) (end 33.1266 84.582) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2308 83.3755) (end 33.2333 83.3374) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2282 83.4873) (end 33.2308 83.4492) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.0784 84.7725) (end 33.0835 84.7573) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2257 83.5635) (end 33.2282 83.5254) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2206 83.6752) (end 33.2232 83.6371) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2181 83.7514) (end 33.2206 83.7133) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.213 83.8251) (end 33.2155 83.7895) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2003 84.0511) (end 33.2028 84.013) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1597 84.4067) (end 33.1647 84.389) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.213 83.8632) (end 33.213 83.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1927 84.1578) (end 33.1927 84.14) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1063 84.6709) (end 33.1114 84.6531) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1774 84.3001) (end 33.1774 84.2823) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1444 84.4956) (end 33.1495 84.4779) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1851 84.2289) (end 33.1876 84.2112) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1749 84.3178) (end 33.1774 84.3001) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2054 83.9775) (end 33.2079 83.9394) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1901 84.1756) (end 33.1927 84.1578) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1419 84.5134) (end 33.1444 84.4956) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2028 84.013) (end 33.2054 83.9775) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1114 84.6531) (end 33.1139 84.6353) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1927 84.14) (end 33.1952 84.1248) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1673 84.3712) (end 33.1698 84.3534) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1647 84.389) (end 33.1673 84.3712) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1495 84.4779) (end 33.152 84.4601) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.2105 83.9013) (end 33.213 83.8632) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1139 84.6353) (end 33.119 84.6176) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1952 84.107) (end 33.1978 84.0892) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1724 84.3356) (end 33.1749 84.3178) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.119 84.6176) (end 33.1241 84.5998) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1546 84.4423) (end 33.1571 84.4245) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1343 84.5464) (end 33.1393 84.5287) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1978 84.0892) (end 33.2003 84.0511) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1317 84.5642) (end 33.1343 84.5464) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3084 43.0555) (end 75.3516 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.3788 43.0606) (end 74.422 43.0606) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.9571 43.0733) (end 74.0003 43.0733) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.295 43.0632) (end 74.3381 43.0632) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0976 43.053) (end 75.1408 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0138 43.053) (end 75.057 43.053) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.2543 43.0657) (end 74.295 43.0632) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8436 43.0555) (end 74.8868 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.184 43.0555) (end 75.2246 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7191 43.0555) (end 74.7598 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.93 43.0555) (end 74.9706 43.053) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.3381 43.0632) (end 74.3788 43.0606) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.2111 43.0657) (end 74.2543 43.0657) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.5355 43.0936) (end 73.5787 43.0911) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.7895 43.0809) (end 73.8301 43.0784) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.5787 43.0911) (end 73.6219 43.0886) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8868 43.0555) (end 74.93 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.6219 43.0886) (end 73.6625 43.086) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.422 43.0606) (end 74.4651 43.0606) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.8733 43.0784) (end 73.9165 43.0759) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.7057 43.086) (end 73.7463 43.0835) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6488 43.0606) (end 75.6894 43.0606) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3948 43.0555) (end 75.4354 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6056 43.0606) (end 75.6488 43.0606) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.8301 43.0784) (end 73.8733 43.0784) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.7463 43.0835) (end 73.7895 43.0809) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5624 43.0581) (end 75.6056 43.0606) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.6625 43.086) (end 73.7057 43.086) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3516 43.0555) (end 75.3948 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2246 43.0555) (end 75.2678 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5218 43.0581) (end 75.5624 43.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4786 43.0581) (end 75.5218 43.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6328 43.0581) (end 74.676 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5921 43.0581) (end 74.6328 43.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.0841 43.0708) (end 74.1273 43.0682) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.9165 43.0759) (end 73.9571 43.0733) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.0003 43.0733) (end 74.0435 43.0708) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.676 43.0555) (end 74.7191 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.1408 43.0555) (end 75.184 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.057 43.053) (end 75.0976 43.053) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.1273 43.0682) (end 74.168 43.0682) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9706 43.053) (end 75.0138 43.053) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.803 43.0555) (end 74.8436 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5058 43.0581) (end 74.549 43.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4354 43.0555) (end 75.4786 43.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2678 43.0555) (end 75.3084 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7598 43.0555) (end 74.803 43.0555) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.549 43.0581) (end 74.5921 43.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.4651 43.0606) (end 74.5058 43.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.168 43.0682) (end 74.2111 43.0657) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.0435 43.0708) (end 74.0841 43.0708) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.4992 43.1775) (end 72.5322 43.1749) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4044 43.3502) (end 71.4375 43.3451) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3054 43.3654) (end 71.3384 43.3603) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.4949 43.0962) (end 73.5355 43.0936) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.2655 43.2105) (end 72.2985 43.2054) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.3315 43.2003) (end 72.3646 43.1978) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.4517 43.0987) (end 73.4949 43.0962) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.7989 43.1444) (end 72.8319 43.1419) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8997 43.2664) (end 71.9328 43.2613) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.3247 43.1038) (end 73.3679 43.1013) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8007 43.2841) (end 71.8337 43.2791) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.5035 43.3324) (end 71.5365 43.3273) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.411 43.0987) (end 73.4517 43.0987) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.3679 43.1013) (end 73.411 43.0987) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.898 43.1343) (end 72.931 43.1317) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.2409 43.1089) (end 73.284 43.1063) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.1334 43.2308) (end 72.1664 43.2257) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.3646 43.1978) (end 72.3976 43.1927) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.6686 43.3045) (end 71.7016 43.2994) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.2002 43.114) (end 73.2409 43.1089) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.0732 43.1216) (end 73.1164 43.119) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.1164 43.119) (end 73.157 43.1165) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.6313 43.1622) (end 72.6643 43.1597) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.5322 43.1749) (end 72.5652 43.1698) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.4306 43.1876) (end 72.4636 43.1825) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8337 43.2791) (end 71.8667 43.274) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.0344 43.246) (end 72.0674 43.241) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.5365 43.3273) (end 71.5695 43.3222) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.3976 43.1927) (end 72.4306 43.1876) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.1664 43.2257) (end 72.1995 43.2206) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.1004 43.2359) (end 72.1334 43.2308) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.0674 43.241) (end 72.1004 43.2359) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.9328 43.2613) (end 71.9658 43.2562) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4375 43.3451) (end 71.4705 43.3375) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3714 43.3553) (end 71.4044 43.3502) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.6026 43.3172) (end 71.6356 43.3121) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.157 43.1165) (end 73.2002 43.114) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.2325 43.2156) (end 72.2655 43.2105) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.03 43.1241) (end 73.0732 43.1216) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.997 43.1267) (end 73.03 43.1241) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.964 43.1292) (end 72.997 43.1267) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.7633 43.147) (end 72.7989 43.1444) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8667 43.274) (end 71.8997 43.2664) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.5695 43.3222) (end 71.6026 43.3172) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.8319 43.1419) (end 72.8649 43.1368) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.7303 43.1521) (end 72.7633 43.147) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3384 43.3603) (end 71.3714 43.3553) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.7346 43.2943) (end 71.7677 43.2892) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.5982 43.1673) (end 72.6313 43.1622) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.6973 43.1546) (end 72.7303 43.1521) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.0013 43.2511) (end 72.0344 43.246) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.1995 43.2206) (end 72.2325 43.2156) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.9658 43.2562) (end 72.0013 43.2511) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.931 43.1317) (end 72.964 43.1292) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.7016 43.2994) (end 71.7346 43.2943) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.6643 43.1597) (end 72.6973 43.1546) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.284 43.1063) (end 73.3247 43.1038) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.7677 43.2892) (end 71.8007 43.2841) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.8649 43.1368) (end 72.898 43.1343) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.4636 43.1825) (end 72.4992 43.1775) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.2985 43.2054) (end 72.3315 43.2003) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4705 43.3375) (end 71.5035 43.3324) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.5652 43.1698) (end 72.5982 43.1673) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.6356 43.3121) (end 71.6686 43.3045) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.1558 43.7947) (end 68.2193 43.7871) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.7179 43.5839) (end 69.7814 43.5762) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.1377 43.3934) (end 71.1708 43.3883) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.9726 43.4188) (end 71.0057 43.4137) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.9704 43.8252) (end 68.0313 43.815) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.8459 43.8455) (end 67.9069 43.8353) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.6579 43.876) (end 67.7214 43.8658) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.1047 43.3984) (end 71.1377 43.3934) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.7814 43.5762) (end 69.8449 43.5686) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.5934 43.6016) (end 69.6569 43.594) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0717 43.4035) (end 71.1047 43.3984) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.3453 43.5051) (end 70.4062 43.4975) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6562 43.7236) (end 68.7171 43.7159) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.4682 43.749) (end 68.5292 43.7413) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.0313 43.815) (end 68.0948 43.8048) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.0938 43.5381) (end 70.1573 43.528) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.7824 43.8556) (end 67.8459 43.8455) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0387 43.4086) (end 71.0717 43.4035) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.2818 43.5127) (end 70.3453 43.5051) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.8431 43.4365) (end 70.9066 43.4264) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.4062 43.4975) (end 70.4697 43.4873) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.9058 43.561) (end 69.9693 43.5534) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.6569 43.594) (end 69.7179 43.5839) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.4055 43.6245) (end 69.469 43.6169) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1565 43.6575) (end 69.2175 43.6499) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.093 43.6651) (end 69.1565 43.6575) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.2802 43.7769) (end 68.3437 43.7667) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9051 43.6905) (end 68.9686 43.6804) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5927 43.7312) (end 68.6562 43.7236) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.4047 43.7591) (end 68.4682 43.749) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.2193 43.7871) (end 68.2802 43.7769) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.3437 43.7667) (end 68.4047 43.7591) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7171 43.7159) (end 68.7806 43.7058) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.9066 43.4264) (end 70.9396 43.4238) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.7186 43.4543) (end 70.7821 43.4442) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.9069 43.8353) (end 67.9704 43.8252) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.5307 43.4797) (end 70.5942 43.4721) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.469 43.6169) (end 69.5299 43.6093) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9686 43.6804) (end 69.0295 43.6728) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8416 43.6982) (end 68.9051 43.6905) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.7214 43.8658) (end 67.7824 43.8556) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.7821 43.4442) (end 70.8431 43.4365) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.5299 43.6093) (end 69.5934 43.6016) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7806 43.7058) (end 68.8416 43.6982) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.281 43.6397) (end 69.342 43.6321) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.2698 43.3705) (end 71.3054 43.3654) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.2368 43.3756) (end 71.2698 43.3705) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.2038 43.3832) (end 71.2368 43.3756) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.1708 43.3883) (end 71.2038 43.3832) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0057 43.4137) (end 71.0387 43.4086) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.9396 43.4238) (end 70.9726 43.4188) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.6577 43.4619) (end 70.7186 43.4543) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.4697 43.4873) (end 70.5307 43.4797) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.9693 43.5534) (end 70.0303 43.5458) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.1573 43.528) (end 70.2183 43.5204) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.8449 43.5686) (end 69.9058 43.561) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.342 43.6321) (end 69.4055 43.6245) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2175 43.6499) (end 69.281 43.6397) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5292 43.7413) (end 68.5927 43.7312) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.0948 43.8048) (end 68.1558 43.7947) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0295 43.6728) (end 69.093 43.6651) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.5942 43.4721) (end 70.6577 43.4619) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.2183 43.5204) (end 70.2818 43.5127) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.0303 43.5458) (end 70.0938 43.5381) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1992 43.782) (end 65.2322 43.8023) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.4725 43.909) (end 67.5335 43.8963) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.5015 43.9369) (end 65.537 43.9522) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2261 43.9547) (end 67.2871 43.942) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9163 44.0182) (end 66.9772 44.003) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.3313 43.8582) (end 65.3669 43.876) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.2381 44.0868) (end 66.2787 44.0868) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6953 44.0563) (end 66.7385 44.0512) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4819 44.0817) (end 66.5251 44.0766) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.8215 44.0385) (end 65.8571 44.0461) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.7123 44.0106) (end 65.7479 44.0207) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.6056 43.9776) (end 65.6412 43.9877) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7385 44.0512) (end 66.7816 44.0436) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5657 44.0741) (end 66.6089 44.069) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.8926 44.0538) (end 65.9307 44.0588) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.4116 43.9191) (end 67.4725 43.909) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.6412 43.9877) (end 65.6767 44.0004) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.045 44.0741) (end 66.0831 44.0792) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.3481 43.9318) (end 67.4116 43.9191) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8274 44.036) (end 66.8705 44.0258) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.0062 43.6499) (end 65.0367 43.6728) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.4685 43.9217) (end 65.5015 43.9369) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.7834 44.0284) (end 65.8215 44.0385) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1357 43.7413) (end 65.1662 43.7617) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.0069 44.069) (end 66.045 44.0741) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2871 43.942) (end 67.3481 43.9318) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.537 43.9522) (end 65.5701 43.9649) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1626 43.9674) (end 67.2261 43.9547) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1017 43.9801) (end 67.1626 43.9674) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0407 43.9903) (end 67.1017 43.9801) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9772 44.003) (end 67.0407 43.9903) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8705 44.0258) (end 66.9163 44.0182) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7816 44.0436) (end 66.8274 44.036) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6521 44.0639) (end 66.6953 44.0563) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.2 44.0868) (end 66.2381 44.0868) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.7479 44.0207) (end 65.7834 44.0284) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6089 44.069) (end 66.6521 44.0639) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.3194 44.0868) (end 66.36 44.0868) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.2322 43.8023) (end 65.2653 43.8226) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.2787 44.0868) (end 66.3194 44.0868) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.9688 44.0639) (end 66.0069 44.069) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.8571 44.0461) (end 65.8926 44.0538) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.4329 43.9064) (end 65.4685 43.9217) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.0697 43.6956) (end 65.1027 43.7185) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.5701 43.9649) (end 65.6056 43.9776) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.3999 43.8912) (end 65.4329 43.9064) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5251 44.0766) (end 66.5657 44.0741) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4413 44.0842) (end 66.4819 44.0817) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.0367 43.6728) (end 65.0697 43.6956) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.1593 44.0842) (end 66.2 44.0868) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.9307 44.0588) (end 65.9688 44.0639) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.6767 44.0004) (end 65.7123 44.0106) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.2983 43.8404) (end 65.3313 43.8582) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.2653 43.8226) (end 65.2983 43.8404) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1027 43.7185) (end 65.1357 43.7413) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.36 44.0868) (end 66.4006 44.0842) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4006 44.0842) (end 66.4413 44.0842) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.1212 44.0817) (end 66.1593 44.0842) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.0831 44.0792) (end 66.1212 44.0817) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.3669 43.876) (end 65.3999 43.8912) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1662 43.7617) (end 65.1992 43.782) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.9732 43.6245) (end 65.0062 43.6499) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.597 43.8861) (end 67.6579 43.876) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.5335 43.8963) (end 67.597 43.8861) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.2993 41.9862) (end 63.3501 42.0319) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.3036 41.1759) (end 62.357 41.214) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.9427 43.5991) (end 64.9732 43.6245) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.9097 43.5737) (end 64.9427 43.5991) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.7217 43.4035) (end 64.7547 43.434) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.6607 43.34) (end 64.6912 43.373) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.4009 42.0776) (end 63.4492 42.1234) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.3204 42.9793) (end 64.3661 43.0276) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.357 41.214) (end 62.4128 41.2547) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.1919 41.0972) (end 62.2477 41.1353) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.9945 41.7195) (end 63.0453 41.7627) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.6912 43.373) (end 64.7217 43.4035) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.837 41.59) (end 62.8904 41.6331) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.6303 43.3095) (end 64.6607 43.34) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.9394 42.5907) (end 63.9876 42.639) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.6262 41.4198) (end 62.6795 41.4604) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.7946 42.4485) (end 63.8429 42.4967) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.5 42.1691) (end 63.5508 42.2148) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.7862 41.5468) (end 62.837 41.59) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.4492 42.1234) (end 63.5 42.1691) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.8904 41.6331) (end 62.9412 41.6763) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.2721 42.9311) (end 64.3204 42.9793) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.1299 42.7838) (end 64.1781 42.832) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.2477 41.1353) (end 62.3036 41.1759) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.3501 42.0319) (end 63.4009 42.0776) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.4662 41.2953) (end 62.5195 41.336) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.9412 41.6763) (end 62.9945 41.7195) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.0242 40.9804) (end 62.0826 41.0185) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.8792 43.5458) (end 64.9097 43.5737) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.7463 42.4028) (end 63.7946 42.4485) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.8462 43.5178) (end 64.8792 43.5458) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.5515 43.2257) (end 64.5998 43.2765) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.2485 41.9405) (end 63.2993 41.9862) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.8157 43.4899) (end 64.8462 43.5178) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.7852 43.4619) (end 64.8157 43.4899) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.7547 43.434) (end 64.7852 43.4619) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.5998 43.2765) (end 64.6303 43.3095) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.5058 43.1775) (end 64.5515 43.2257) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.4601 43.1267) (end 64.5058 43.1775) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.5508 42.2148) (end 63.599 42.2605) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.0826 41.0185) (end 62.136 41.0566) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.1977 41.8948) (end 63.2485 41.9405) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.0359 42.6872) (end 64.0816 42.7355) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.136 41.0566) (end 62.1919 41.0972) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.3661 43.0276) (end 64.4118 43.0784) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.0453 41.7627) (end 63.0961 41.8059) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.4118 43.0784) (end 64.4601 43.1267) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.0961 41.8059) (end 63.1469 41.8516) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.9876 42.639) (end 64.0359 42.6872) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.2239 42.8828) (end 64.2721 42.9311) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.599 42.2605) (end 63.6473 42.3088) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.1781 42.832) (end 64.2239 42.8828) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.0816 42.7355) (end 64.1299 42.7838) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.5195 41.336) (end 62.5729 41.3791) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.6795 41.4604) (end 62.7329 41.5036) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.6981 42.3545) (end 63.7463 42.4028) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.6473 42.3088) (end 63.6981 42.3545) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.1469 41.8516) (end 63.1977 41.8948) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.4128 41.2547) (end 62.4662 41.2953) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.9683 40.9423) (end 62.0242 40.9804) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.8911 42.545) (end 63.9394 42.5907) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.8429 42.4967) (end 63.8911 42.545) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.7329 41.5036) (end 62.7862 41.5468) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.5729 41.3791) (end 62.6262 41.4198) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.1378 40.4495) (end 61.1581 40.4597) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0793 40.4216) (end 61.0997 40.4292) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0412 40.4038) (end 61.0616 40.4114) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9244 40.353) (end 60.9447 40.3606) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.8431 40.3225) (end 60.8634 40.3276) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9828 40.3758) (end 61.0031 40.386) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.4062 40.2285) (end 60.4291 40.2311) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.2317 40.4978) (end 61.2521 40.5079) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.6399 40.2615) (end 60.6602 40.2666) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5358 40.2412) (end 60.5561 40.2463) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0997 40.4292) (end 61.12 40.4393) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7415 40.2895) (end 60.7618 40.2946) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.6602 40.2666) (end 60.6806 40.2717) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5764 40.2488) (end 60.5967 40.2539) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.2132 40.2361) (end 60.2335 40.2336) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9447 40.3606) (end 60.9625 40.3682) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0235 40.3936) (end 61.0412 40.4038) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.2996 40.2285) (end 60.3199 40.2285) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.7982 40.8305) (end 61.8566 40.8686) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.7397 40.7949) (end 61.7982 40.8305) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9625 40.3682) (end 60.9828 40.3758) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9041 40.3428) (end 60.9244 40.353) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7009 40.2768) (end 60.7212 40.2819) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.567 40.6883) (end 61.6254 40.7238) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.2767 40.2311) (end 60.2996 40.2285) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.2698 40.5181) (end 61.3308 40.5511) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.1759 40.4673) (end 61.1936 40.4774) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.214 40.4876) (end 61.2317 40.4978) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.8838 40.3352) (end 60.9041 40.3428) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.1936 40.4774) (end 61.214 40.4876) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.1581 40.4597) (end 61.1759 40.4673) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.8634 40.3276) (end 60.8838 40.3352) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.3892 40.5841) (end 61.4476 40.6197) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.6254 40.7238) (end 61.6839 40.7594) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0616 40.4114) (end 61.0793 40.4216) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.3859 40.2285) (end 60.4062 40.2285) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.8228 40.3149) (end 60.8431 40.3225) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7212 40.2819) (end 60.7415 40.2895) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.5086 40.6527) (end 61.567 40.6883) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.4476 40.6197) (end 61.5086 40.6527) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0031 40.386) (end 61.0235 40.3936) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.2564 40.2311) (end 60.2767 40.2311) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7822 40.3022) (end 60.8025 40.3073) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.4494 40.2336) (end 60.4723 40.2336) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.6806 40.2717) (end 60.7009 40.2768) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.4291 40.2311) (end 60.4494 40.2336) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7618 40.2946) (end 60.7822 40.3022) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5129 40.2387) (end 60.5358 40.2412) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.8566 40.8686) (end 61.9125 40.9042) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.6839 40.7594) (end 61.7397 40.7949) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.3631 40.2285) (end 60.3859 40.2285) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5561 40.2463) (end 60.5764 40.2488) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.2335 40.2336) (end 60.2564 40.2311) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.2521 40.5079) (end 61.2698 40.5181) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.12 40.4393) (end 61.1378 40.4495) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.4723 40.2336) (end 60.4926 40.2361) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.8025 40.3073) (end 60.8228 40.3149) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.6196 40.2565) (end 60.6399 40.2615) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.3427 40.2285) (end 60.3631 40.2285) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.4926 40.2361) (end 60.5129 40.2387) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.3199 40.2285) (end 60.3427 40.2285) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5967 40.2539) (end 60.6196 40.2565) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.9125 40.9042) (end 61.9683 40.9423) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.3308 40.5511) (end 61.3892 40.5841) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.0354 40.2692) (end 60.0583 40.2641) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9668 40.292) (end 59.9897 40.2844) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.7382 40.3733) (end 59.788999 40.3555) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.2734 40.546) (end 59.3242 40.5257) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.065099 40.6222) (end 59.1185 40.6044) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.4283 40.4876) (end 59.4791 40.4698) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.9805 41.021) (end 58.0313 41.0032) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.549499 40.8127) (end 58.6003 40.7949) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.2904 40.9092) (end 58.3438 40.8889) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4116 41.2267) (end 57.4624 41.209) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2541 41.2801) (end 57.3074 41.2623) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.8086 40.7187) (end 58.859399 40.6984) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.6003 40.7949) (end 58.6536 40.7746) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3946 40.8711) (end 58.4454 40.8508) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5157 41.1886) (end 57.5665 41.1709) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.3242 40.5257) (end 59.375 40.5079) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.5299 40.4495) (end 59.583299 40.4317) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.7215 41.115) (end 57.7748 41.0972) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.944 40.2996) (end 59.9668 40.292) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.375 40.5079) (end 59.4283 40.4876) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.2201 40.5638) (end 59.2734 40.546) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.7044 40.7568) (end 58.755199 40.7365) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3582 41.2445) (end 57.4116 41.2267) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.1903 40.2387) (end 60.2132 40.2361) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6707 41.1353) (end 57.7215 41.115) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.1675 40.2412) (end 60.1903 40.2387) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9897 40.2844) (end 60.0125 40.2768) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.1472 40.2463) (end 60.1675 40.2412) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.1693 40.5841) (end 59.2201 40.5638) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.1243 40.2488) (end 60.1472 40.2463) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.0125 40.2768) (end 60.0354 40.2692) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.1185 40.6044) (end 59.1693 40.5841) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8932 40.3174) (end 59.944 40.2996) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8424 40.3377) (end 59.8932 40.3174) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.9297 41.0413) (end 57.9805 41.021) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3074 41.2623) (end 57.3582 41.2445) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.0143 40.6425) (end 59.065099 40.6222) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.755199 40.7365) (end 58.8086 40.7187) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.583299 40.4317) (end 59.6341 40.4114) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.4791 40.4698) (end 59.5299 40.4495) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.9102 40.6806) (end 58.9635 40.6603) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6173 41.1531) (end 57.6707 41.1353) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4624 41.209) (end 57.5157 41.1886) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0847 40.9854) (end 58.1355 40.9651) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.6536 40.7746) (end 58.7044 40.7568) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0313 41.0032) (end 58.0847 40.9854) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.859399 40.6984) (end 58.9102 40.6806) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.2396 40.927) (end 58.2904 40.9092) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.0786 40.259) (end 60.1014 40.2539) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.6874 40.3936) (end 59.7382 40.3733) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8764 41.0591) (end 57.9297 41.0413) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3438 40.8889) (end 58.3946 40.8711) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5665 41.1709) (end 57.6173 41.1531) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.6341 40.4114) (end 59.6874 40.3936) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.788999 40.3555) (end 59.8424 40.3377) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.1355 40.9651) (end 58.1888 40.9473) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.9635 40.6603) (end 59.0143 40.6425) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.4987 40.833) (end 58.549499 40.8127) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8256 41.0794) (end 57.8764 41.0591) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.1888 40.9473) (end 58.2396 40.927) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.7748 41.0972) (end 57.8256 41.0794) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.4454 40.8508) (end 58.4987 40.833) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.1014 40.2539) (end 60.1243 40.2488) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.0583 40.2641) (end 60.0786 40.259) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3593 41.9303) (end 55.4177 41.91) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.3026 42.385) (end 54.356 42.3596) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9417 41.3868) (end 56.995 41.369) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2033 41.2979) (end 57.2541 41.2801) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.15 41.3156) (end 57.2033 41.2979) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6826 41.4757) (end 56.7334 41.4579) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.4736 41.8871) (end 55.532 41.8668) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0992 41.3334) (end 57.15 41.3156) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.356 42.3596) (end 54.4118 42.3316) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.1934 42.4409) (end 54.2493 42.4129) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.0214 42.0624) (end 55.0773 42.0395) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.995 41.369) (end 57.0458 41.3512) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.8538 42.1335) (end 54.9097 42.1081) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8909 41.4045) (end 56.9417 41.3868) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.106 41.6662) (end 56.1644 41.6458) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.6303 42.23) (end 54.6862 42.2046) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9333 41.7246) (end 55.9917 41.7043) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.5879 41.8465) (end 55.6463 41.8262) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.7979 42.1564) (end 54.8538 42.1335) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.532 41.8668) (end 55.5879 41.8465) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.9097 42.1081) (end 54.9656 42.0853) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3397 41.5874) (end 56.3981 41.5696) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.4177 41.91) (end 55.4736 41.8871) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.2493 42.4129) (end 54.3026 42.385) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.9656 42.0853) (end 55.0214 42.0624) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.4652 42.3062) (end 54.5211 42.2808) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.0334 42.5247) (end 54.0867 42.4967) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.8226 42.6466) (end 53.8759 42.6161) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7692 42.6771) (end 53.8226 42.6466) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.8774 41.7449) (end 55.9333 41.7246) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0458 41.3512) (end 57.0992 41.3334) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8375 41.4223) (end 56.8909 41.4045) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3034 41.9532) (end 55.3593 41.9303) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7867 41.4401) (end 56.8375 41.4223) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7334 41.4579) (end 56.7867 41.4401) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6293 41.4934) (end 56.6826 41.4757) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5708 41.5112) (end 56.6293 41.4934) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5124 41.5315) (end 56.5708 41.5112) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.454 41.5493) (end 56.5124 41.5315) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.6463 41.8262) (end 55.7047 41.8059) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.0867 42.4967) (end 54.1401 42.4688) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.2475 41.9735) (end 55.3034 41.9532) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2229 41.6281) (end 56.2813 41.6077) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.1401 42.4688) (end 54.1934 42.4409) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.9267 42.5856) (end 53.98 42.5552) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.0773 42.0395) (end 55.1332 42.0192) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3981 41.5696) (end 56.454 41.5493) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.1332 42.0192) (end 55.1891 41.9964) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1644 41.6458) (end 56.2229 41.6281) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2813 41.6077) (end 56.3397 41.5874) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.7047 41.8059) (end 55.7606 41.7855) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0501 41.6865) (end 56.106 41.6662) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.819 41.7652) (end 55.8774 41.7449) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.5211 42.2808) (end 54.5769 42.2554) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.6862 42.2046) (end 54.742 42.1818) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.7606 41.7855) (end 55.819 41.7652) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.1891 41.9964) (end 55.2475 41.9735) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.8759 42.6161) (end 53.9267 42.5856) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.4118 42.3316) (end 54.4652 42.3062) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.98 42.5552) (end 54.0334 42.5247) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7184 42.7076) (end 53.7692 42.6771) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9917 41.7043) (end 56.0501 41.6865) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.742 42.1818) (end 54.7979 42.1564) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.5769 42.2554) (end 54.6303 42.23) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7329 43.4797) (end 52.738 43.4721) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8345 43.3603) (end 52.8421 43.3553) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8066 43.3908) (end 52.8116 43.3832) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.058 43.1724) (end 53.0656 43.1673) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8193 43.3756) (end 52.8269 43.368) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7659 43.434) (end 52.7735 43.4264) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9691 43.241) (end 52.9793 43.2359) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8269 43.368) (end 52.8345 43.3603) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8116 43.3832) (end 52.8193 43.3756) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3603 42.9438) (end 53.4111 42.9082) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9463 43.2613) (end 52.9539 43.2537) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8777 43.3197) (end 52.8853 43.3121) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2587 43.0174) (end 53.3095 42.9793) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2104 43.053) (end 53.2587 43.0174) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0809 43.1546) (end 53.0885 43.147) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1596 43.0911) (end 53.2104 43.053) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.025 43.1978) (end 53.0326 43.1902) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9158 43.2867) (end 52.9234 43.2791) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7939 43.4035) (end 52.7989 43.3959) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1114 43.1292) (end 53.1596 43.0911) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7989 43.3959) (end 52.8066 43.3908) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1037 43.1368) (end 53.1114 43.1292) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0656 43.1673) (end 53.0733 43.1597) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7481 43.4569) (end 52.7558 43.4492) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0326 43.1902) (end 53.0428 43.1851) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9539 43.2537) (end 52.9615 43.2486) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0021 43.2156) (end 53.0098 43.2105) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8853 43.3121) (end 52.8929 43.307) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0174 43.2029) (end 53.025 43.1978) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0098 43.2105) (end 53.0174 43.2029) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9793 43.2359) (end 52.9869 43.2283) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9005 43.2994) (end 52.9082 43.2943) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8624 43.3349) (end 52.8701 43.3273) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8472 43.3476) (end 52.8548 43.34) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7862 43.4111) (end 52.7939 43.4035) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.738 43.4721) (end 52.7431 43.4645) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7558 43.4492) (end 52.7608 43.4416) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0504 43.1775) (end 53.058 43.1724) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.5635 42.8066) (end 53.6143 42.7736) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.5127 42.8396) (end 53.5635 42.8066) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7786 43.4188) (end 52.7862 43.4111) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9615 43.2486) (end 52.9691 43.241) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8929 43.307) (end 52.9005 43.2994) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7431 43.4645) (end 52.7481 43.4569) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.6651 42.7406) (end 53.7184 42.7076) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.6143 42.7736) (end 53.6651 42.7406) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8421 43.3553) (end 52.8472 43.3476) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.931 43.274) (end 52.9386 43.2664) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4619 42.8752) (end 53.5127 42.8396) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4111 42.9082) (end 53.4619 42.8752) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9945 43.2232) (end 53.0021 43.2156) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0428 43.1851) (end 53.0504 43.1775) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9869 43.2283) (end 52.9945 43.2232) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9234 43.2791) (end 52.931 43.274) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7735 43.4264) (end 52.7786 43.4188) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3095 42.9793) (end 53.3603 42.9438) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0961 43.1419) (end 53.1037 43.1368) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9386 43.2664) (end 52.9463 43.2613) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0885 43.147) (end 53.0961 43.1419) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7608 43.4416) (end 52.7659 43.434) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0733 43.1597) (end 53.0809 43.1546) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8701 43.3273) (end 52.8777 43.3197) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9082 43.2943) (end 52.9158 43.2867) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8548 43.34) (end 52.8624 43.3349) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5246 43.9141) (end 52.5373 43.8836) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7253 43.4873) (end 52.7329 43.4797) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3494 44.3103) (end 52.3621 44.2824) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7202 43.495) (end 52.7253 43.4873) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7151 43.5026) (end 52.7202 43.495) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.71 43.5102) (end 52.7151 43.5026) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4738 44.0258) (end 52.4865 43.9979) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4484 44.0817) (end 52.4611 44.0538) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6796 43.5661) (end 52.6846 43.5585) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4357 44.1122) (end 52.4484 44.0817) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1741 44.7396) (end 52.1868 44.7116) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6643 43.6042) (end 52.677 43.5737) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6135 43.7159) (end 52.6262 43.688) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5754 43.7998) (end 52.5881 43.7718) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0573 45.0571) (end 52.0674 45.0291) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4611 44.0538) (end 52.4738 44.0258) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2325 44.5948) (end 52.2427 44.5668) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.423 44.1401) (end 52.4357 44.1122) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3011 44.4246) (end 52.3138 44.3941) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2427 44.5668) (end 52.2554 44.5389) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1081 44.9123) (end 52.1208 44.8843) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2554 44.5389) (end 52.2655 44.5084) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6872 43.5508) (end 52.6923 43.5432) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7024 43.5254) (end 52.705 43.5178) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3265 44.3662) (end 52.3392 44.3382) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2782 44.4805) (end 52.2909 44.4525) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6389 43.6601) (end 52.6516 43.6321) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4865 43.9979) (end 52.4992 43.9699) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1208 44.8843) (end 52.1309 44.8539) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6262 43.688) (end 52.6389 43.6601) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3138 44.3941) (end 52.3265 44.3662) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2909 44.4525) (end 52.3011 44.4246) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.705 43.5178) (end 52.71 43.5102) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2655 44.5084) (end 52.2782 44.4805) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6973 43.5331) (end 52.7024 43.5254) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2198 44.6253) (end 52.2325 44.5948) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6923 43.5432) (end 52.6973 43.5331) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6846 43.5585) (end 52.6872 43.5508) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.55 43.8556) (end 52.5627 43.8277) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5373 43.8836) (end 52.55 43.8556) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3875 44.2239) (end 52.4002 44.196) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3621 44.2824) (end 52.3748 44.2519) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1512 44.798) (end 52.1639 44.7675) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2097 44.6532) (end 52.2198 44.6253) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3392 44.3382) (end 52.3494 44.3103) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0877 44.9707) (end 52.0979 44.9428) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.197 44.6811) (end 52.2097 44.6532) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1868 44.7116) (end 52.197 44.6811) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1309 44.8539) (end 52.1411 44.8259) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1411 44.8259) (end 52.1512 44.798) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0776 44.9986) (end 52.0877 44.9707) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4002 44.196) (end 52.4103 44.1681) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5627 43.8277) (end 52.5754 43.7998) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0674 45.0291) (end 52.0776 44.9986) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0979 44.9428) (end 52.1081 44.9123) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.677 43.5737) (end 52.6796 43.5661) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6516 43.6321) (end 52.6643 43.6042) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5119 43.942) (end 52.5246 43.9141) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1639 44.7675) (end 52.1741 44.7396) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6008 43.7439) (end 52.6135 43.7159) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5881 43.7718) (end 52.6008 43.7439) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4992 43.9699) (end 52.5119 43.942) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4103 44.1681) (end 52.423 44.1401) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3748 44.2519) (end 52.3875 44.2239) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8236 45.8165) (end 51.8363 45.7708) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.788 45.9511) (end 51.7982 45.9054) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7626 46.0426) (end 51.7753 45.9969) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6915 46.3144) (end 51.7017 46.2686) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6432 46.4972) (end 51.6559 46.4515) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7271 46.1797) (end 51.7372 46.134) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4045 47.4548) (end 51.4172 47.4091) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0268 45.146) (end 52.0369 45.1155) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5289 46.9544) (end 51.5416 46.9087) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4731 47.183) (end 51.4832 47.1373) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0471 45.0875) (end 52.0573 45.0571) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5874 46.7258) (end 51.5975 46.6801) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7982 45.9054) (end 51.8109 45.8597) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4959 47.0916) (end 51.5061 47.0459) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5416 46.9087) (end 51.5518 46.863) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7017 46.2686) (end 51.7144 46.2229) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7499 46.0883) (end 51.7626 46.0426) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3461 47.6834) (end 51.3588 47.6377) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8871 45.5905) (end 51.9023 45.5447) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9785 45.2907) (end 51.9887 45.2628) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7144 46.2229) (end 51.7271 46.1797) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6788 46.3601) (end 51.6915 46.3144) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5645 46.8173) (end 51.5747 46.7716) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9506 45.3796) (end 51.9607 45.3492) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3359 47.7291) (end 51.3461 47.6834) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0369 45.1155) (end 52.0471 45.0875) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0166 45.1739) (end 52.0268 45.146) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0065 45.2044) (end 52.0166 45.1739) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6661 46.4058) (end 51.6788 46.3601) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9023 45.5447) (end 51.915 45.499) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8363 45.7708) (end 51.849 45.7251) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6559 46.4515) (end 51.6661 46.4058) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9963 45.2323) (end 52.0065 45.2044) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.915 45.499) (end 51.9277 45.4533) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7753 45.9969) (end 51.788 45.9511) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3943 47.5005) (end 51.4045 47.4548) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6331 46.543) (end 51.6432 46.4972) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5747 46.7716) (end 51.5874 46.7258) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9887 45.2628) (end 51.9963 45.2323) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9684 45.3212) (end 51.9785 45.2907) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7372 46.134) (end 51.7499 46.0883) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3232 47.7749) (end 51.3359 47.7291) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6102 46.6344) (end 51.6204 46.5887) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4273 47.3634) (end 51.44 47.3177) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5518 46.863) (end 51.5645 46.8173) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4172 47.4091) (end 51.4273 47.3634) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5975 46.6801) (end 51.6102 46.6344) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4604 47.2288) (end 51.4731 47.183) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9607 45.3492) (end 51.9684 45.3212) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9404 45.4101) (end 51.9506 45.3796) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3816 47.5463) (end 51.3943 47.5005) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9277 45.4533) (end 51.9404 45.4101) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4832 47.1373) (end 51.4959 47.0916) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8617 45.6794) (end 51.8744 45.6336) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8109 45.8597) (end 51.8236 45.8165) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.44 47.3177) (end 51.4502 47.2719) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6204 46.5887) (end 51.6331 46.543) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5188 47.0002) (end 51.5289 46.9544) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3715 47.592) (end 51.3816 47.5463) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4502 47.2719) (end 51.4604 47.2288) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3588 47.6377) (end 51.3715 47.592) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5061 47.0459) (end 51.5188 47.0002) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8744 45.6336) (end 51.8871 45.5905) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.849 45.7251) (end 51.8617 45.6794) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.0415 43.1216) (end 78.1151 43.1241) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.1954 43.241) (end 80.2716 43.2486) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.8916 43.1165) (end 77.9653 43.119) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.1217 43.2359) (end 80.1954 43.241) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.3709 43.1013) (end 77.4446 43.1038) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.5182 43.1063) (end 77.5944 43.1089) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.0481 43.2283) (end 80.1217 43.2359) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.5622 43.1419) (end 78.6358 43.1444) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.5505 43.0809) (end 76.6267 43.0835) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.6036 43.1978) (end 79.6772 43.2029) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.327 43.0759) (end 76.4032 43.0784) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6894 43.0606) (end 75.7326 43.0632) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.9744 43.2232) (end 80.0481 43.2283) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.9007 43.2181) (end 79.9744 43.2232) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.7857 43.1521) (end 78.8593 43.1546) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.8245 43.213) (end 79.9007 43.2181) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.0712 43.0936) (end 77.1474 43.0962) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.5944 43.1089) (end 77.6681 43.1089) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.0298 43.0682) (end 76.1034 43.0708) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.7509 43.2079) (end 79.8245 43.213) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.1565 43.1698) (end 79.2302 43.1749) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.6772 43.2029) (end 79.7509 43.2079) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.4537 43.1876) (end 79.5274 43.1927) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.9653 43.119) (end 78.0415 43.1216) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.1888 43.1267) (end 78.265 43.1292) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.4032 43.0784) (end 76.4768 43.0784) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.8502 43.0886) (end 76.9239 43.0911) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7326 43.0632) (end 75.8063 43.0632) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.2302 43.1749) (end 79.3064 43.18) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.6681 43.1089) (end 77.7417 43.1114) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.1474 43.0962) (end 77.221 43.0962) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.9239 43.0911) (end 76.9975 43.0911) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.7417 43.1114) (end 77.8179 43.114) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.9975 43.0911) (end 77.0712 43.0936) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.6267 43.0835) (end 76.7003 43.0835) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8799 43.0657) (end 75.9561 43.0682) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.38 43.1825) (end 79.4537 43.1876) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.2947 43.0987) (end 77.3709 43.1013) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.3064 43.18) (end 79.38 43.1825) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.0829 43.1673) (end 79.1565 43.1698) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.0092 43.1622) (end 79.0829 43.1673) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.4885 43.1394) (end 78.5622 43.1419) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.4768 43.0784) (end 76.5505 43.0809) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8063 43.0632) (end 75.8799 43.0657) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.933 43.1597) (end 79.0092 43.1622) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.6358 43.1444) (end 78.7095 43.1495) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.4123 43.1368) (end 78.4885 43.1394) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.1796 43.0733) (end 76.2533 43.0733) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.1151 43.1241) (end 78.1888 43.1267) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.3386 43.1317) (end 78.4123 43.1368) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.774 43.086) (end 76.8502 43.0886) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.221 43.0962) (end 77.2947 43.0987) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.7003 43.0835) (end 76.774 43.086) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.8593 43.1546) (end 78.933 43.1597) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.1034 43.0708) (end 76.1796 43.0733) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.265 43.1292) (end 78.3386 43.1317) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.3452 43.2537) (end 80.4189 43.2613) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.2533 43.0733) (end 76.327 43.0759) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.5274 43.1927) (end 79.6036 43.1978) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.8179 43.114) (end 77.8916 43.1165) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.4446 43.1038) (end 77.5182 43.1063) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.2716 43.2486) (end 80.3452 43.2537) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.7095 43.1495) (end 78.7857 43.1521) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.9561 43.0682) (end 76.0298 43.0682) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.5936 63.8251) (end 116.6495 63.8353) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.7391 64.102) (end 117.795 64.1147) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.5766 64.0588) (end 117.6324 64.074) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.4285 63.7896) (end 116.4844 63.7997) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.3396 63.7692) (end 116.3751 63.7769) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.6103 64.3306) (end 118.6637 64.3458) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.5011 64.3026) (end 118.5545 64.3179) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.176 64.2137) (end 118.2293 64.229) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.9042 64.1426) (end 117.9576 64.1579) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.0305 63.9242) (end 117.0863 63.9369) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.8679 63.8861) (end 116.9212 63.8988) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.4844 63.7997) (end 116.5402 63.8124) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.4478 64.2874) (end 118.5011 64.3026) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.0668 64.1858) (end 118.1201 64.201) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.9576 64.1579) (end 118.0134 64.1706) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.795 64.1147) (end 117.8483 64.1299) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.6858 64.0867) (end 117.7391 64.102) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.414 64.0182) (end 117.4673 64.0309) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.2489 63.9775) (end 117.3048 63.9902) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.9771 63.9115) (end 117.0305 63.9242) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.7028 63.848) (end 116.7587 63.8607) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.812 63.8734) (end 116.8679 63.8861) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.6495 63.8353) (end 116.7028 63.848) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.7587 63.8607) (end 116.812 63.8734) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.0863 63.9369) (end 117.1397 63.9521) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.4673 64.0309) (end 117.5232 64.0461) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.3751 63.7769) (end 116.4285 63.7896) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.6637 64.3458) (end 118.7196 64.3611) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.3048 63.9902) (end 117.3581 64.0055) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.1956 63.9648) (end 117.2489 63.9775) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.2852 64.2442) (end 118.3386 64.2595) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.0134 64.1706) (end 118.0668 64.1858) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.1397 63.9521) (end 117.1956 63.9648) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.8821 64.4042) (end 118.9355 64.4195) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.6324 64.074) (end 117.6858 64.0867) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.2293 64.229) (end 118.2852 64.2442) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.8262 64.3915) (end 118.8821 64.4042) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.7729 64.3763) (end 118.8262 64.3915) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.3386 64.2595) (end 118.3919 64.2722) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.7196 64.3611) (end 118.7729 64.3763) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.5232 64.0461) (end 117.5766 64.0588) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.5545 64.3179) (end 118.6103 64.3306) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.3919 64.2722) (end 118.4478 64.2874) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.9212 63.8988) (end 116.9771 63.9115) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.5402 63.8124) (end 116.5936 63.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.3581 64.0055) (end 117.414 64.0182) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.8483 64.1299) (end 117.9042 64.1426) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.1201 64.201) (end 118.176 64.2137) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2619 63.5635) (end 114.2974 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.9992 63.7057) (end 116.0322 63.7108) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5743 63.5686) (end 114.6098 63.5686) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8265 63.6778) (end 115.8621 63.6829) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6538 63.6524) (end 115.6893 63.6575) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4016 63.5635) (end 114.4371 63.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2728 63.6092) (end 115.3058 63.6143) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4811 63.6321) (end 115.5166 63.6372) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0975 63.5965) (end 115.1331 63.5991) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8892 63.5813) (end 114.9248 63.5838) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7851 63.5762) (end 114.8181 63.5787) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.681 63.5711) (end 114.714 63.5737) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6893 63.6575) (end 115.7224 63.6626) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5496 63.6397) (end 115.5852 63.6448) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9578 63.5864) (end 114.9934 63.5889) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.1694 63.7362) (end 116.205 63.7413) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.714 63.5737) (end 114.7495 63.5737) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.3066 63.7616) (end 116.3396 63.7692) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.205 63.7413) (end 116.238 63.7489) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.1008 63.7235) (end 116.1364 63.7286) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7579 63.6676) (end 115.7935 63.6727) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5413 63.566) (end 114.5743 63.5686) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8537 63.5787) (end 114.8892 63.5813) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1933 63.5635) (end 114.2288 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.2735 63.7565) (end 116.3066 63.7616) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.0678 63.7184) (end 116.1008 63.7235) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6098 63.5686) (end 114.6454 63.5711) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.0322 63.7108) (end 116.0678 63.7184) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.9637 63.7007) (end 115.9992 63.7057) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8951 63.688) (end 115.9306 63.693) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8621 63.6829) (end 115.8951 63.688) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7935 63.6727) (end 115.8265 63.6778) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7224 63.6626) (end 115.7579 63.6676) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2372 63.6067) (end 115.2728 63.6092) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.062 63.594) (end 115.0975 63.5965) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8181 63.5787) (end 114.8537 63.5787) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3414 63.6168) (end 115.3769 63.6219) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3058 63.6143) (end 115.3414 63.6168) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2974 63.5635) (end 114.333 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1331 63.5991) (end 115.1686 63.6016) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0289 63.5914) (end 115.062 63.594) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9248 63.5838) (end 114.9578 63.5864) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5057 63.566) (end 114.5413 63.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1425 63.566) (end 114.1577 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6454 63.5711) (end 114.681 63.5711) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4701 63.566) (end 114.5057 63.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4455 63.627) (end 115.4811 63.6321) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1686 63.6016) (end 115.2017 63.6041) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5166 63.6372) (end 115.5496 63.6397) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2017 63.6041) (end 115.2372 63.6067) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9934 63.5889) (end 115.0289 63.5914) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7495 63.5737) (end 114.7851 63.5762) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.366 63.5635) (end 114.4016 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.333 63.5635) (end 114.366 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1577 63.5635) (end 114.1933 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3769 63.6219) (end 115.4125 63.6245) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.9306 63.693) (end 115.9637 63.7007) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6182 63.6499) (end 115.6538 63.6524) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4125 63.6245) (end 115.4455 63.627) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4371 63.566) (end 114.4701 63.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2288 63.5635) (end 114.2619 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5852 63.6448) (end 115.6182 63.6499) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.238 63.7489) (end 116.2735 63.7565) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.1364 63.7286) (end 116.1694 63.7362) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.571 63.3451) (end 113.5786 63.3552) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8072 63.5178) (end 113.8174 63.5229) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5481 63.3146) (end 113.5557 63.3247) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4872 63.2231) (end 113.4948 63.2358) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4237 63.1088) (end 113.4643 63.1825) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5303 63.2943) (end 113.538 63.3044) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5075 63.2587) (end 113.5151 63.2714) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9291 63.5508) (end 113.9444 63.5508) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8174 63.5229) (end 113.8301 63.5254) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7843 63.5076) (end 113.7945 63.5127) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9164 63.5483) (end 113.9291 63.5508) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8783 63.5381) (end 113.891 63.5432) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.637 63.4162) (end 113.6472 63.4238) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6116 63.3908) (end 113.6192 63.4009) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5557 63.3247) (end 113.5634 63.3349) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4948 63.2358) (end 113.5024 63.246) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5227 63.2816) (end 113.5303 63.2943) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8402 63.5279) (end 113.8529 63.533) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7945 63.5127) (end 113.8072 63.5178) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7513 63.4949) (end 113.764 63.5) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5024 63.246) (end 113.5075 63.2587) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4795 63.2104) (end 113.4872 63.2231) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7107 63.4721) (end 113.7208 63.4771) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7031 63.4644) (end 113.7107 63.4721) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6726 63.4467) (end 113.6827 63.4517) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6294 63.4086) (end 113.637 63.4162) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5862 63.3654) (end 113.5964 63.373) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.604 63.3832) (end 113.6116 63.3908) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4719 63.1952) (end 113.4795 63.2104) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5964 63.373) (end 113.604 63.3832) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5786 63.3552) (end 113.5862 63.3654) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4643 63.1825) (end 113.4719 63.1952) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6472 63.4238) (end 113.6548 63.4314) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1247 63.566) (end 114.1425 63.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1069 63.5635) (end 114.1247 63.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.538 63.3044) (end 113.5481 63.3146) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0917 63.5635) (end 114.1069 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.764 63.5) (end 113.7742 63.5051) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6827 63.4517) (end 113.6929 63.4594) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.665 63.439) (end 113.6726 63.4467) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5151 63.2714) (end 113.5227 63.2816) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0764 63.5635) (end 114.0917 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7742 63.5051) (end 113.7843 63.5076) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6548 63.4314) (end 113.665 63.439) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.731 63.4822) (end 113.7412 63.4898) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.985 63.5584) (end 114.0002 63.5584) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0612 63.5635) (end 114.0764 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0002 63.5584) (end 114.0155 63.561) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0434 63.5635) (end 114.0612 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0282 63.561) (end 114.0434 63.5635) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0155 63.561) (end 114.0282 63.561) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9698 63.5559) (end 113.985 63.5584) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9571 63.5533) (end 113.9698 63.5559) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8529 63.533) (end 113.8656 63.5356) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.891 63.5432) (end 113.9037 63.5457) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8301 63.5254) (end 113.8402 63.5279) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7412 63.4898) (end 113.7513 63.4949) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7208 63.4771) (end 113.731 63.4822) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6192 63.4009) (end 113.6294 63.4086) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5634 63.3349) (end 113.571 63.3451) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6929 63.4594) (end 113.7031 63.4644) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9444 63.5508) (end 113.9571 63.5533) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9037 63.5457) (end 113.9164 63.5483) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8656 63.5356) (end 113.8783 63.5381) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1199 59.5706) (end 111.1732 59.6367) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3424 62.959) (end 113.383 63.0352) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.5822 60.1751) (end 111.6304 60.2437) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2179 62.738) (end 113.2586 62.8117) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0071 62.3697) (end 113.0503 62.4434) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3282 59.8373) (end 111.379 59.9059) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.527 61.5747) (end 112.5728 61.6458) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7912 62.0065) (end 112.8369 62.0801) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2984 61.2191) (end 112.3467 61.2902) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.019 60.7974) (end 112.0673 60.866) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.8743 60.5892) (end 111.9225 60.6577) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7295 60.3809) (end 111.7777 60.4495) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0503 62.4434) (end 113.0935 62.517) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.8801 62.1513) (end 112.9233 62.2249) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.113 60.9371) (end 112.1613 61.0083) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7777 60.4495) (end 111.826 60.518) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6373 58.9813) (end 110.6932 59.0474) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3017 62.8853) (end 113.3424 62.959) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2586 62.8117) (end 113.3017 62.8853) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1341 62.5907) (end 113.1773 62.6643) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.8024 59.1769) (end 110.8557 59.2404) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.5314 60.1091) (end 111.5822 60.1751) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9708 60.7263) (end 112.019 60.7974) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0157 59.4385) (end 111.0691 59.5046) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1773 62.6643) (end 113.2179 62.738) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0935 62.517) (end 113.1341 62.5907) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6304 60.2437) (end 111.6812 60.3123) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9639 62.2986) (end 113.0071 62.3697) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9233 62.2249) (end 112.9639 62.2986) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5814 58.9178) (end 110.6373 58.9813) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.8369 62.0801) (end 112.8801 62.1513) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.748 61.9354) (end 112.7912 62.0065) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6159 61.7195) (end 112.6617 61.7906) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4813 61.5036) (end 112.527 61.5747) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2527 61.148) (end 112.2984 61.2191) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9225 60.6577) (end 111.9708 60.7263) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5728 61.6458) (end 112.6159 61.7195) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3467 61.2902) (end 112.3924 61.3613) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1732 59.6367) (end 111.2266 59.7027) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.207 61.0768) (end 112.2527 61.148) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0673 60.866) (end 112.113 60.9371) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.3045 58.6054) (end 110.4138 58.7273) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4806 60.0405) (end 111.5314 60.1091) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9091 59.3065) (end 110.9624 59.3725) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6812 60.3123) (end 111.7295 60.3809) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4298 59.9719) (end 111.4806 60.0405) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4356 61.4324) (end 112.4813 61.5036) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3924 61.3613) (end 112.4356 61.4324) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.8557 59.2404) (end 110.9091 59.3065) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.1613 61.0083) (end 112.207 61.0768) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4138 58.7273) (end 110.4696 58.7908) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.826 60.518) (end 111.8743 60.5892) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2774 59.7713) (end 111.3282 59.8373) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2266 59.7027) (end 111.2774 59.7713) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9624 59.3725) (end 111.0157 59.4385) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6617 61.7906) (end 112.7048 61.8617) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4696 58.7908) (end 110.5255 58.8543) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7048 61.8617) (end 112.748 61.9354) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.379 59.9059) (end 111.4298 59.9719) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5255 58.8543) (end 110.5814 58.9178) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0691 59.5046) (end 111.1199 59.5706) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7465 59.1109) (end 110.8024 59.1769) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.383 63.0352) (end 113.4237 63.1088) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6932 59.0474) (end 110.7465 59.1109) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.303 56.4566) (end 108.4148 56.5709) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.7584 57.9984) (end 109.8677 58.1177) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6673 54.866501) (end 106.7866 54.9758) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1979 58.4835) (end 110.3045 58.6054) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.0886 58.3616) (end 110.1979 58.4835) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.9769 58.2397) (end 110.0886 58.3616) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8433 55.9943) (end 107.9576 56.1086) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6096 55.7632) (end 107.7264 55.8775) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.9995 51.882) (end 103.1341 51.976) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4953 55.6514) (end 107.6096 55.7632) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.8232 53.2638) (end 104.9502 53.3679) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.8677 58.1177) (end 109.9769 58.2397) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.6492 57.8764) (end 109.7584 57.9984) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.093 57.2795) (end 109.2047 57.3989) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.4008 52.1665) (end 103.5329 52.2656) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.7551 56.923901) (end 108.8694 57.0408) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.4506 53.7845) (end 105.5751 53.8912) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7264 55.8775) (end 107.8433 55.9943) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3785 55.5371) (end 107.4953 55.6514) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.5751 53.8912) (end 105.697 53.997901) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.0561 52.6567) (end 104.1857 52.7558) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.697 53.997901) (end 105.8214 54.104501) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.5375 57.7571) (end 109.6492 57.8764) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4285 54.645601) (end 106.5479 54.754801) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.1872 54.4271) (end 106.3066 54.5363) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.3165 57.5183) (end 109.4257 57.6377) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.2047 57.3989) (end 109.3165 57.5183) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9576 56.1086) (end 108.0719 56.2229) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.1857 52.7558) (end 104.3127 52.8574) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.6434 56.8071) (end 108.7551 56.923901) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.5291 56.6903) (end 108.6434 56.8071) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 56.5709) (end 108.5291 56.6903) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1422 55.311) (end 107.2591 55.4253) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.8214 54.104501) (end 105.9434 54.2112) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0254 55.1993) (end 107.1422 55.311) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.3261 53.6804) (end 105.4506 53.7845) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7866 54.9758) (end 106.906 55.0875) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5479 54.754801) (end 106.6673 54.866501) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.9434 54.2112) (end 106.0653 54.3204) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.2017 53.5737) (end 105.3261 53.6804) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.0772 53.4695) (end 105.2017 53.5737) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.8649 51.7881) (end 102.9995 51.882) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.5692 53.0581) (end 104.6962 53.1622) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.9502 53.3679) (end 105.0772 53.4695) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.4422 52.959) (end 104.5692 53.0581) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.7945 52.4586) (end 103.9266 52.5577) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.7303 51.6941) (end 102.8649 51.7881) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.3127 52.8574) (end 104.4422 52.959) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.1341 51.976) (end 103.2662 52.0725) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.665 52.3621) (end 103.7945 52.4586) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.6769 51.656) (end 102.7303 51.6941) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.3066 54.5363) (end 106.4285 54.645601) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.0653 54.3204) (end 106.1872 54.4271) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.5329 52.2656) (end 103.665 52.3621) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.9266 52.5577) (end 104.0561 52.6567) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4257 57.6377) (end 109.5375 57.7571) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.9812 57.1602) (end 109.093 57.2795) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1887 56.3397) (end 108.303 56.4566) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.6962 53.1622) (end 104.8232 53.2638) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.8694 57.0408) (end 108.9812 57.1602) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0719 56.2229) (end 108.1887 56.3397) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2591 55.4253) (end 107.3785 55.5371) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.2662 52.0725) (end 103.4008 52.1665) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.906 55.0875) (end 107.0254 55.1993) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.4714 49.5021) (end 99.5273 49.5376) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.413 49.469) (end 99.4714 49.5021) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.1496 49.9212) (end 100.2055 49.9567) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.9657 51.1607) (end 102.0191 51.1988) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.2614 49.9923) (end 100.3173 50.0278) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.8118 49.7078) (end 99.8677 49.7434) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.3637 50.739) (end 101.4196 50.7771) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.3173 50.0278) (end 100.3731 50.0659) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.2055 49.9567) (end 100.2614 49.9923) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.5652 51.5798) (end 102.621 51.6179) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.2012 50.6247) (end 101.2545 50.6628) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.7059 50.2869) (end 100.7618 50.3225) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.4026 51.4655) (end 102.4559 51.5036) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.2375 51.3512) (end 102.2934 51.3893) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.1842 51.3131) (end 102.2375 51.3512) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.1283 51.275) (end 102.1842 51.3131) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.7473 51.0083) (end 101.8006 51.0464) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.9802 50.4723) (end 101.0361 50.5104) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.0379 49.85) (end 100.0937 49.8856) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.8006 51.0464) (end 101.8565 51.0845) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.0937 49.8856) (end 100.1496 49.9212) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.6939 50.9676) (end 101.7473 51.0083) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.6381 50.9295) (end 101.6939 50.9676) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.6416 49.6037) (end 99.7 49.6392) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.2545 50.6628) (end 101.3104 50.7009) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.1031 49.2938) (end 99.1844 49.337) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.5847 50.8914) (end 101.6381 50.9295) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.7618 50.3225) (end 100.8151 50.3606) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.4196 50.7771) (end 101.4755 50.8152) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.871 50.3987) (end 100.9269 50.4368) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.5941 50.2133) (end 100.65 50.2488) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.4849 50.1371) (end 100.5408 50.1752) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.982 49.8145) (end 100.0379 49.85) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.7 49.6392) (end 99.7559 49.6722) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.5273 49.5376) (end 99.5857 49.5706) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.2403 49.37) (end 99.2987 49.403) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.3571 49.436) (end 99.413 49.469) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.9098 51.1226) (end 101.9657 51.1607) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.621 51.6179) (end 102.6769 51.656) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.3104 50.7009) (end 101.3637 50.739) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.9261 49.7789) (end 99.982 49.8145) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.8151 50.3606) (end 100.871 50.3987) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.1844 49.337) (end 99.2403 49.37) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.5857 49.5706) (end 99.6416 49.6037) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.5118 51.5417) (end 102.5652 51.5798) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.4559 51.5036) (end 102.5118 51.5417) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.429 50.1015) (end 100.4849 50.1371) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.092 50.5485) (end 101.1453 50.5866) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.3467 51.4274) (end 102.4026 51.4655) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.8565 51.0845) (end 101.9098 51.1226) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.5288 50.8533) (end 101.5847 50.8914) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.4755 50.8152) (end 101.5288 50.8533) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.0361 50.5104) (end 101.092 50.5485) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.8677 49.7434) (end 99.9261 49.7789) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.2987 49.403) (end 99.3571 49.436) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.2934 51.3893) (end 102.3467 51.4274) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.0749 51.2369) (end 102.1283 51.275) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.1453 50.5866) (end 101.2012 50.6247) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.0191 51.1988) (end 102.0749 51.2369) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.7559 49.6722) (end 99.8118 49.7078) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.9269 50.4368) (end 100.9802 50.4723) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.65 50.2488) (end 100.7059 50.2869) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.5408 50.1752) (end 100.5941 50.2133) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.3731 50.0659) (end 100.429 50.1015) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.8146 48.0822) (end 96.8959 48.1254) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.2373 47.3075) (end 95.3211 47.3481) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.5563 48.4607) (end 97.6376 48.5038) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.6993 49.0703) (end 98.778 49.1134) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.5367 48.9814) (end 98.618 49.0245) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.1448 48.2498) (end 97.2261 48.293) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.4049 47.3888) (end 95.4862 47.4294) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.4554 48.9382) (end 98.5367 48.9814) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.2929 48.8493) (end 98.3742 48.8925) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.0465 48.7197) (end 98.1278 48.7629) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.7369 47.0687) (end 94.8207 47.1094) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.8027 48.5902) (end 97.8839 48.6334) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.4854 46.9519) (end 94.5692 46.99) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.8839 48.6334) (end 97.9652 48.6766) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.3168 47.8358) (end 96.4006 47.8765) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.1501 46.7944) (end 94.234 46.8325) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.0704 47.7114) (end 96.1517 47.752) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.57 47.4701) (end 95.6538 47.5082) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.4016 46.9113) (end 94.4854 46.9519) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.4862 47.4294) (end 95.57 47.4701) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.5692 46.99) (end 94.6531 47.0306) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.4725 48.42) (end 97.5563 48.4607) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.2091 48.8061) (end 98.2929 48.8493) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.6495 48.0009) (end 96.7308 48.0416) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.6376 48.5038) (end 97.7188 48.547) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.9012 46.675) (end 93.985 46.7157) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.3211 47.3481) (end 95.4049 47.3888) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.6531 47.0306) (end 94.7369 47.0687) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.0219 49.2481) (end 99.1031 49.2938) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.9866 47.6707) (end 96.0704 47.7114) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.9406 49.2023) (end 99.0219 49.2481) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.8593 49.1592) (end 98.9406 49.2023) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.1534 47.2694) (end 95.2373 47.3075) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.778 49.1134) (end 98.8593 49.1592) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.618 49.0245) (end 98.6993 49.0703) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.1278 48.7629) (end 98.2091 48.8061) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.3742 48.8925) (end 98.4554 48.9382) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.9652 48.6766) (end 98.0465 48.7197) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.8959 48.1254) (end 96.9797 48.166) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.7188 48.547) (end 97.8027 48.5902) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.6538 47.5082) (end 95.7376 47.5488) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.0696 47.2288) (end 95.1534 47.2694) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.3912 48.3768) (end 97.4725 48.42) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.4844 47.9171) (end 96.5657 47.9577) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.3099 48.3337) (end 97.3912 48.3768) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.8207 47.1094) (end 94.9045 47.1475) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.2261 48.293) (end 97.3099 48.3337) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.9045 47.1475) (end 94.9858 47.1881) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.4006 47.8765) (end 96.4844 47.9171) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.061 48.2092) (end 97.1448 48.2498) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.7376 47.5488) (end 95.8189 47.5894) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.9797 48.166) (end 97.061 48.2092) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.5657 47.9577) (end 96.6495 48.0009) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.985 46.7157) (end 94.0663 46.7538) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.234 46.8325) (end 94.3178 46.8706) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.7308 48.0416) (end 96.8146 48.0822) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.8189 47.5894) (end 95.9027 47.6301) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.9027 47.6301) (end 95.9866 47.6707) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.9858 47.1881) (end 95.0696 47.2288) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.853 46.6547) (end 93.9012 46.675) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.2355 47.7952) (end 96.3168 47.8358) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.1517 47.752) (end 96.2355 47.7952) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.3178 46.8706) (end 94.4016 46.9113) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.0663 46.7538) (end 94.1501 46.7944) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.5652 46.1188) (end 92.613399 46.1366) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.4204 46.0654) (end 92.468699 46.0832) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.3213 46.0273) (end 92.3696 46.0451) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.0292 45.9232) (end 92.0775 45.941) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.8337 45.8546) (end 91.8819 45.8724) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.1766 45.9765) (end 92.2248 45.9943) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.8024 45.5117) (end 90.8507 45.5295) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.9513 46.2686) (end 92.999499 46.2864) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.3434 45.6895) (end 91.391699 45.7048) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.097099 45.6082) (end 91.1453 45.6235) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.806499 46.2102) (end 92.8547 46.2305) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.5898 45.7708) (end 91.6381 45.7886) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.468699 46.0832) (end 92.5169 46.101) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.1961 45.6413) (end 91.244399 45.6565) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.391699 45.7048) (end 91.4425 45.7225) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.0775 45.941) (end 92.1283 45.9588) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.273099 46.0121) (end 92.3213 46.0273) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.571 46.5252) (end 93.6193 46.548) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.5228 46.5049) (end 93.571 46.5252) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.3348 46.4236) (end 93.380499 46.4439) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.1283 45.9588) (end 92.1766 45.9765) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.981 45.9054) (end 92.0292 45.9232) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.4908 45.7378) (end 91.539 45.7556) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.2865 46.4033) (end 93.3348 46.4236) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.1443 46.3448) (end 93.189999 46.3652) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.903 46.2483) (end 92.9513 46.2686) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.6617 46.1543) (end 92.71 46.1747) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.7582 46.1924) (end 92.806499 46.2102) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.932699 45.8902) (end 91.981 45.9054) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.71 46.1747) (end 92.7582 46.1924) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.613399 46.1366) (end 92.6617 46.1543) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.8819 45.8724) (end 91.932699 45.8902) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.999499 46.2864) (end 93.0478 46.3067) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.4288 46.4642) (end 93.477 46.4845) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.3696 46.0451) (end 92.4204 46.0654) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.7389 45.4914) (end 90.8024 45.5117) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.7854 45.8394) (end 91.8337 45.8546) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.539 45.7556) (end 91.5898 45.7708) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.189999 46.3652) (end 93.2383 46.3855) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.096 46.3245) (end 93.1443 46.3448) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.2248 45.9943) (end 92.273099 46.0121) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.0478 46.3067) (end 93.096 46.3245) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.6863 45.8038) (end 91.7346 45.8216) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.901499 45.5447) (end 90.9497 45.56) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.4425 45.7225) (end 91.4908 45.7378) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.8507 45.5295) (end 90.901499 45.5447) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.6381 45.7886) (end 91.6863 45.8038) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.048799 45.593) (end 91.097099 45.6082) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.8072 46.6319) (end 93.853 46.6547) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.759 46.6115) (end 93.8072 46.6319) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.7133 46.5887) (end 93.759 46.6115) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.477 46.4845) (end 93.5228 46.5049) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.1453 45.6235) (end 91.1961 45.6413) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.380499 46.4439) (end 93.4288 46.4642) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.2383 46.3855) (end 93.2865 46.4033) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.9497 45.56) (end 90.998 45.5752) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.7346 45.8216) (end 91.7854 45.8394) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.8547 46.2305) (end 92.903 46.2483) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.5169 46.101) (end 92.5652 46.1188) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.998 45.5752) (end 91.048799 45.593) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.2952 45.6743) (end 91.3434 45.6895) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.244399 45.6565) (end 91.2952 45.6743) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.665 46.5684) (end 93.7133 46.5887) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.6193 46.548) (end 93.665 46.5684) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.7204 45.1714) (end 89.7839 45.1917) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.5934 45.1333) (end 89.6569 45.1536) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.4029 45.0748) (end 89.4664 45.0952) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.1463 44.9986) (end 89.2098 45.019) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.8263 44.9047) (end 88.8898 44.9224) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.5063 44.8107) (end 88.5698 44.831) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.8001 44.6126) (end 87.8636 44.6303) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.1862 44.7192) (end 88.2497 44.737) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.4776 44.5237) (end 87.5436 44.5414) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.0915 44.417) (end 87.1575 44.4348) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.8984 44.3662) (end 86.9619 44.3814) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.7054 44.3128) (end 86.7689 44.3306) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.5698 44.831) (end 88.6333 44.8488) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.3132 44.7573) (end 88.3767 44.7751) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.221 44.4525) (end 87.2845 44.4703) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.4664 45.0952) (end 89.5299 45.1129) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.7689 44.3306) (end 86.8349 44.3484) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.6754 45.4711) (end 90.7389 45.4914) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.6119 45.4508) (end 90.6754 45.4711) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.5299 45.1129) (end 89.5934 45.1333) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.3368 45.0571) (end 89.4029 45.0748) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.6993 44.8666) (end 88.7628 44.8869) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.028 44.3992) (end 87.0915 44.417) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.5484 45.4304) (end 90.6119 45.4508) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.4214 45.3898) (end 90.4849 45.4101) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.3579 45.3695) (end 90.4214 45.3898) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.2309 45.3314) (end 90.2944 45.3492) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.1674 45.3111) (end 90.2309 45.3314) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.2733 45.0367) (end 89.3368 45.0571) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.8474 45.212) (end 89.9134 45.2298) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.6569 45.1536) (end 89.7204 45.1714) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.2098 45.019) (end 89.2733 45.0367) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.0828 44.9809) (end 89.1463 44.9986) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.7341 44.5948) (end 87.8001 44.6126) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.4141 44.5059) (end 87.4776 44.5237) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.9619 44.3814) (end 87.028 44.3992) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.9533 44.9428) (end 89.0193 44.9605) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.7628 44.8869) (end 88.8263 44.9047) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.8898 44.9224) (end 88.9533 44.9428) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.6333 44.8488) (end 88.6993 44.8666) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.9271 44.6481) (end 87.9932 44.6659) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.3506 44.4881) (end 87.4141 44.5059) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.1575 44.4348) (end 87.221 44.4525) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.8636 44.6303) (end 87.9271 44.6481) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.6724 44.3052) (end 86.7054 44.3128) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.5436 44.5414) (end 87.6071 44.5592) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.1202 44.7015) (end 88.1862 44.7192) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.6071 44.5592) (end 87.6706 44.577) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.2944 45.3492) (end 90.3579 45.3695) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.2497 44.737) (end 88.3132 44.7573) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.6706 44.577) (end 87.7341 44.5948) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.2845 44.4703) (end 87.3506 44.4881) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.8349 44.3484) (end 86.8984 44.3662) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.4849 45.4101) (end 90.5484 45.4304) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.1039 45.2907) (end 90.1674 45.3111) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.9932 44.6659) (end 88.0567 44.6837) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.0193 44.9605) (end 89.0828 44.9809) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.0404 45.2704) (end 90.1039 45.2907) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.9769 45.2501) (end 90.0404 45.2704) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.0567 44.6837) (end 88.1202 44.7015) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.4428 44.7929) (end 88.5063 44.8107) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.3767 44.7751) (end 88.4428 44.7929) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.9134 45.2298) (end 89.9769 45.2501) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.7839 45.1917) (end 89.8474 45.212) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6538 44.0868) (end 85.6894 44.0919) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0036 43.975) (end 85.0392 43.9826) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.6038 44.2874) (end 86.6394 44.2951) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.6394 44.2951) (end 86.6724 44.3052) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.5708 44.2798) (end 86.6038 44.2874) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.4362 44.2468) (end 86.4692 44.2544) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7224 44.0995) (end 85.758 44.1046) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.5378 44.2697) (end 86.5708 44.2798) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0392 43.9826) (end 85.0722 43.9877) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.935 43.9649) (end 84.9706 43.9699) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4506 44.0512) (end 85.4837 44.0563) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.5047 44.262) (end 86.5378 44.2697) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3465 44.0334) (end 85.3821 44.0385) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.4692 44.2544) (end 86.5047 44.262) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0983 44.1706) (end 86.1314 44.1782) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2093 44.0106) (end 85.2449 44.0157) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9967 44.1503) (end 86.0298 44.1579) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.791 44.1122) (end 85.8266 44.1173) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3135 44.0258) (end 85.3465 44.0334) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.758 44.1046) (end 85.791 44.1122) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3821 44.0385) (end 85.4151 44.0436) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.233 44.2011) (end 86.2685 44.2062) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6894 44.0919) (end 85.7224 44.0995) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9706 43.9699) (end 85.0036 43.975) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4151 44.0436) (end 85.4506 44.0512) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1077 43.9928) (end 85.1408 43.9979) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8334 43.9471) (end 84.8664 43.9547) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6963 43.9268) (end 84.7293 43.9318) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6607 43.9191) (end 84.6963 43.9268) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9612 44.1427) (end 85.9967 44.1503) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.4031 44.2392) (end 86.4362 44.2468) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5591 43.9039) (end 84.5921 43.909) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6208 44.0792) (end 85.6538 44.0868) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.3701 44.229) (end 86.4031 44.2392) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.3346 44.2214) (end 86.3701 44.229) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.3015 44.2138) (end 86.3346 44.2214) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1669 44.1858) (end 86.1999 44.1935) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8266 44.1173) (end 85.8596 44.1249) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5921 43.909) (end 84.6277 43.9141) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5235 43.8963) (end 84.5591 43.9039) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8664 43.9547) (end 84.902 43.9598) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5878 44.0741) (end 85.6208 44.0792) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.902 43.9598) (end 84.935 43.9649) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.46 43.8861) (end 84.5235 43.8963) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7648 43.9369) (end 84.7979 43.942) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4837 44.0563) (end 85.5192 44.0614) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.2685 44.2062) (end 86.3015 44.2138) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5192 44.0614) (end 85.5522 44.069) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1314 44.1782) (end 86.1669 44.1858) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1999 44.1935) (end 86.233 44.2011) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8596 44.1249) (end 85.8951 44.13) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0653 44.163) (end 86.0983 44.1706) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9282 44.1376) (end 85.9612 44.1427) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1408 43.9979) (end 85.1763 44.003) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2449 44.0157) (end 85.2779 44.0207) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8951 44.13) (end 85.9282 44.1376) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5522 44.069) (end 85.5878 44.0741) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7293 43.9318) (end 84.7648 43.9369) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0722 43.9877) (end 85.1077 43.9928) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7979 43.942) (end 84.8334 43.9471) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6277 43.9141) (end 84.6607 43.9191) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0298 44.1579) (end 86.0653 44.163) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2779 44.0207) (end 85.3135 44.0258) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1763 44.003) (end 85.2093 44.0106) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.8903 43.6093) (end 82.9513 43.622) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.6998 43.5762) (end 82.7633 43.5889) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.5754 43.5559) (end 82.6389 43.5661) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.1969 43.4924) (end 82.2604 43.5026) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.9454 43.4518) (end 82.0089 43.4619) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.3874 43.5229) (end 82.4484 43.5331) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.6196 43.2791) (end 80.6831 43.2867) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.3932 43.6982) (end 83.4542 43.7109) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.3155 43.3603) (end 81.379 43.368) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.0006 43.3197) (end 81.0615 43.3273) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.2027 43.6651) (end 83.2662 43.6778) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.6305 43.4035) (end 81.694 43.4137) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.7633 43.5889) (end 82.8268 43.5991) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.125 43.3375) (end 81.1885 43.3451) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.379 43.368) (end 81.4425 43.3781) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.2604 43.5026) (end 82.3239 43.5127) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.5119 43.5458) (end 82.5754 43.5559) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.0841 43.8226) (end 84.1476 43.8328) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.0206 43.8099) (end 84.0841 43.8226) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.8962 43.7896) (end 83.9571 43.7998) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.3239 43.5127) (end 82.3874 43.5229) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.1334 43.4823) (end 82.1969 43.4924) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.5035 43.3857) (end 81.567 43.3959) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.8327 43.7769) (end 83.8962 43.7896) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.6447 43.7439) (end 83.7057 43.754) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.3297 43.688) (end 83.3932 43.6982) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.0148 43.6321) (end 83.0783 43.6423) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.1418 43.655) (end 83.2027 43.6651) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.0724 43.4721) (end 82.1334 43.4823) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.0783 43.6423) (end 83.1418 43.655) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.9513 43.622) (end 83.0148 43.6321) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.0089 43.4619) (end 82.0724 43.4721) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.4542 43.7109) (end 83.5177 43.721) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.7057 43.754) (end 83.7692 43.7667) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.6389 43.5661) (end 82.6998 43.5762) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.5561 43.274) (end 80.6196 43.2791) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.8819 43.4416) (end 81.9454 43.4518) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.567 43.3959) (end 81.6305 43.4035) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.5812 43.7337) (end 83.6447 43.7439) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.5177 43.721) (end 83.5812 43.7337) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.4484 43.5331) (end 82.5119 43.5458) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.7575 43.4238) (end 81.8184 43.434) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.694 43.4137) (end 81.7575 43.4238) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.7466 43.2918) (end 80.8101 43.2994) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.4425 43.3781) (end 81.5035 43.3857) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.6831 43.2867) (end 80.7466 43.2918) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.9371 43.3146) (end 81.0006 43.3197) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.4189 43.2613) (end 80.4926 43.2664) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3991 43.876) (end 84.46 43.8861) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3356 43.8658) (end 84.3991 43.876) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.4926 43.2664) (end 80.5561 43.274) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.2086 43.8429) (end 84.2721 43.8556) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.0615 43.3273) (end 81.125 43.3375) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.9571 43.7998) (end 84.0206 43.8099) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.7692 43.7667) (end 83.8327 43.7769) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.8101 43.2994) (end 80.8736 43.307) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.8184 43.434) (end 81.8819 43.4416) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.2662 43.6778) (end 83.3297 43.688) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.8268 43.5991) (end 82.8903 43.6093) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.8736 43.307) (end 80.9371 43.3146) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.252 43.3527) (end 81.3155 43.3603) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.1885 43.3451) (end 81.252 43.3527) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.2721 43.8556) (end 84.3356 43.8658) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.1476 43.8328) (end 84.2086 43.8429) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8633 65.4355) (end 120.8887 65.4685) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0785 64.7548) (end 120.1089 64.7725) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9819 64.7116) (end 120.015 64.7243) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5324 64.582) (end 119.5857 64.5973) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1514 64.4779) (end 119.2072 64.4931) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2606 64.5084) (end 119.3165 64.5236) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.13 65.8165) (end 121.1529 65.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.064 65.7098) (end 121.0868 65.7454) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5458 65.0926) (end 120.5763 65.1205) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9903 65.6057) (end 121.0157 65.6412) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4544 65.0113) (end 120.4849 65.0367) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1724 64.8081) (end 120.2055 64.8259) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9675 65.5701) (end 120.9903 65.6057) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9421 65.5371) (end 120.9675 65.5701) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7516 65.3034) (end 120.7795 65.3364) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3299 64.9122) (end 120.3629 64.9351) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9355 64.4195) (end 118.9888 64.4347) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7508 64.6405) (end 119.8041 64.6557) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 64.5236) (end 119.3698 64.5389) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8354 65.3999) (end 120.8633 65.4355) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8041 64.6557) (end 119.8575 64.6709) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7795 65.3364) (end 120.8074 65.3694) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7236 65.2729) (end 120.7516 65.3034) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6957 65.2399) (end 120.7236 65.2729) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6652 65.2094) (end 120.6957 65.2399) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4849 65.0367) (end 120.5153 65.0646) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5763 65.1205) (end 120.6068 65.151) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2055 64.8259) (end 120.2359 64.8462) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2664 64.8691) (end 120.2994 64.8894) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3698 64.5389) (end 119.4231 64.5541) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9888 64.4347) (end 119.0447 64.45) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1089 64.7725) (end 120.142 64.7878) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0454 64.7395) (end 120.0785 64.7548) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.921 64.6887) (end 119.9515 64.6989) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6949 64.6252) (end 119.7508 64.6405) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8905 64.6786) (end 119.921 64.6887) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4231 64.5541) (end 119.479 64.5668) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.098 64.4652) (end 119.1514 64.4779) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8575 64.6709) (end 119.8905 64.6786) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1732 65.8876) (end 121.1935 65.9232) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6416 64.6125) (end 119.6949 64.6252) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1529 65.852) (end 121.1732 65.8876) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5153 65.0646) (end 120.5458 65.0926) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2359 64.8462) (end 120.2664 64.8691) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1097 65.7809) (end 121.13 65.8165) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0868 65.7454) (end 121.1097 65.7809) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.015 64.7243) (end 120.0454 64.7395) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3934 64.9605) (end 120.4239 64.9859) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8074 65.3694) (end 120.8354 65.3999) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6373 65.1789) (end 120.6652 65.2094) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6068 65.151) (end 120.6373 65.1789) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0447 64.45) (end 119.098 64.4652) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3629 64.9351) (end 120.3934 64.9605) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9515 64.6989) (end 119.9819 64.7116) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5857 64.5973) (end 119.6416 64.6125) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0411 65.6742) (end 121.064 65.7098) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0157 65.6412) (end 121.0411 65.6742) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4239 64.9859) (end 120.4544 65.0113) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8887 65.4685) (end 120.9141 65.5015) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.479 64.5668) (end 119.5324 64.582) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2072 64.4931) (end 119.2606 64.5084) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.142 64.7878) (end 120.1724 64.8081) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9141 65.5015) (end 120.9421 65.5371) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2994 64.8894) (end 120.3299 64.9122) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9156 103.0732) (end 122.9258 103.1392) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8648 102.8141) (end 122.8801 102.8776) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.2654 101.5924) (end 122.306 101.6432) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.0597 101.3511) (end 122.1028 101.3968) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.9733 101.2647) (end 122.0165 101.3079) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6413 102.1944) (end 122.6693 102.2553) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.4864 101.9099) (end 122.5194 101.9658) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.9276 101.2215) (end 121.9733 101.2647) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7709 102.4992) (end 122.7912 102.5601) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6693 102.2553) (end 122.6972 102.3137) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5524 102.0216) (end 122.5829 102.0801) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9258 103.1392) (end 122.9334 103.2053) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9461 103.5406) (end 122.9436 103.6066) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9334 103.2053) (end 122.9385 103.2739) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.0165 101.3079) (end 122.0597 101.3511) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9055 103.0097) (end 122.9156 103.0732) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.8819 101.1809) (end 121.9276 101.2215) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7226 102.3747) (end 122.748 102.4357) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8953 103.98) (end 122.8877 104.0155) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9029 103.9444) (end 122.8953 103.98) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.1028 101.3968) (end 122.146 101.4451) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9131 103.8758) (end 122.9029 103.9444) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8928 102.9437) (end 122.9055 103.0097) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9309 103.7412) (end 122.9233 103.8098) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8801 102.8776) (end 122.8928 102.9437) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9436 103.3399) (end 122.9461 103.4059) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8496 102.7506) (end 122.8648 102.8141) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.2273 101.5416) (end 122.2654 101.5924) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.748 102.4357) (end 122.7709 102.4992) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9233 103.8098) (end 122.9131 103.8758) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9385 103.6752) (end 122.9309 103.7412) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8115 102.6236) (end 122.8318 102.6871) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7912 102.5601) (end 122.8115 102.6236) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6972 102.3137) (end 122.7226 102.3747) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.3441 101.694) (end 122.3797 101.7473) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.306 101.6432) (end 122.3441 101.694) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.4534 101.854) (end 122.4864 101.9099) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.146 101.4451) (end 122.1867 101.4933) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9436 103.6066) (end 122.9385 103.6752) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.1867 101.4933) (end 122.2273 101.5416) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5194 101.9658) (end 122.5524 102.0216) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.7904 101.0996) (end 121.8361 101.1403) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9461 103.472) (end 122.9461 103.5406) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.3797 101.7473) (end 122.4178 101.8007) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8318 102.6871) (end 122.8496 102.7506) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9461 103.4059) (end 122.9461 103.472) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.4178 101.8007) (end 122.4534 101.854) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6134 102.1359) (end 122.6413 102.1944) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5829 102.0801) (end 122.6134 102.1359) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.9385 103.2739) (end 122.9436 103.3399) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.8361 101.1403) (end 121.8819 101.1809) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5128 100.5332) (end 120.5331 100.5383) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.5999 100.9574) (end 121.6482 100.9904) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4696 100.523) (end 120.4899 100.5281) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.5517 100.9244) (end 121.5999 100.9574) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3147 100.4926) (end 120.3375 100.4976) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3604 100.5002) (end 120.3807 100.5053) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.5009 100.8939) (end 121.5517 100.9244) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4526 100.8634) (end 121.5009 100.8939) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0734 100.4468) (end 120.0962 100.4494) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4018 100.8329) (end 121.4526 100.8634) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9624 100.6475) (end 120.9852 100.6551) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0073 100.4341) (end 120.0302 100.4367) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3535 100.8075) (end 121.4018 100.8329) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7287 100.5815) (end 120.749 100.5891) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6423 100.5611) (end 120.6652 100.5662) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0995 100.6932) (end 121.1503 100.7135) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2283 100.4748) (end 120.2512 100.4799) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3027 100.7821) (end 121.3535 100.8075) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3807 100.5053) (end 120.4036 100.5103) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1503 100.7135) (end 121.2011 100.7339) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8354 100.6119) (end 120.8582 100.617) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2011 100.7339) (end 121.2519 100.7567) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2519 100.7567) (end 121.3027 100.7821) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4899 100.5281) (end 120.5128 100.5332) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.556 100.5408) (end 120.5763 100.5459) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0302 100.4367) (end 120.0531 100.4418) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8582 100.617) (end 120.8786 100.6221) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1623 100.4621) (end 120.1851 100.4672) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6652 100.5662) (end 120.6855 100.5713) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4036 100.5103) (end 120.4239 100.5129) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2512 100.4799) (end 120.2715 100.4824) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1851 100.4672) (end 120.2055 100.4722) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4239 100.5129) (end 120.4468 100.518) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2055 100.4722) (end 120.2283 100.4748) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0962 100.4494) (end 120.1191 100.4545) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0462 100.6754) (end 121.0995 100.6932) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0259 100.6678) (end 121.0462 100.6754) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2944 100.4875) (end 120.3147 100.4926) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0056 100.6602) (end 121.0259 100.6678) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9852 100.6551) (end 121.0056 100.6602) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9421 100.6424) (end 120.9624 100.6475) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9217 100.6348) (end 120.9421 100.6424) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8989 100.6297) (end 120.9217 100.6348) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0531 100.4418) (end 120.0734 100.4468) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8786 100.6221) (end 120.8989 100.6297) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7922 100.5992) (end 120.8151 100.6043) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.622 100.5561) (end 120.6423 100.5611) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7719 100.5942) (end 120.7922 100.5992) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5331 100.5383) (end 120.556 100.5408) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5992 100.551) (end 120.622 100.5561) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1394 100.4595) (end 120.1623 100.4621) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2715 100.4824) (end 120.2944 100.4875) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1191 100.4545) (end 120.1394 100.4595) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.749 100.5891) (end 120.7719 100.5942) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8151 100.6043) (end 120.8354 100.6119) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5763 100.5459) (end 120.5992 100.551) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7084 100.5764) (end 120.7287 100.5815) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.987 100.4291) (end 120.0073 100.4341) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6855 100.5713) (end 120.7084 100.5764) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4468 100.518) (end 120.4696 100.523) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3375 100.4976) (end 120.3604 100.5002) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.7447 101.0615) (end 121.7904 101.0996) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.6964 101.026) (end 121.7447 101.0615) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.6482 100.9904) (end 121.6964 101.026) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 100.0379) (end 119.3165 100.0481) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3266 100.0989) (end 119.3292 100.109) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6797 100.3681) (end 119.7025 100.3732) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9642 100.4265) (end 119.987 100.4291) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9438 100.4214) (end 119.9642 100.4265) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5476 100.3325) (end 119.5578 100.3351) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.921 100.4164) (end 119.9438 100.4214) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8981 100.4138) (end 119.921 100.4164) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8778 100.4087) (end 119.8981 100.4138) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8549 100.4037) (end 119.8778 100.4087) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8321 100.3986) (end 119.8549 100.4037) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8118 100.396) (end 119.8321 100.3986) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7889 100.391) (end 119.8118 100.396) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3952 100.236) (end 119.4028 100.2411) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3825 100.2208) (end 119.3901 100.2284) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3622 100.1903) (end 119.3673 100.1979) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3469 100.1649) (end 119.352 100.1725) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7686 100.3859) (end 119.7889 100.391) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5933 100.3478) (end 119.606 100.3503) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7457 100.3833) (end 119.7686 100.3859) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.606 100.3503) (end 119.6187 100.3554) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7229 100.3783) (end 119.7457 100.3833) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4104 100.2487) (end 119.4181 100.2563) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5146 100.3173) (end 119.5247 100.3224) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4333 100.269) (end 119.4409 100.2741) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 100.0481) (end 119.319 100.0582) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6441 100.3605) (end 119.6594 100.363) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3723 100.2055) (end 119.3774 100.2132) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6314 100.3579) (end 119.6441 100.3605) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5806 100.3427) (end 119.5933 100.3478) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3673 100.1979) (end 119.3723 100.2055) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5247 100.3224) (end 119.5349 100.3275) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4943 100.3071) (end 119.5044 100.3122) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4663 100.2919) (end 119.4765 100.297) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4485 100.2792) (end 119.4562 100.2868) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.319 100.0709) (end 119.3215 100.0811) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3241 100.0912) (end 119.3266 100.0989) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6187 100.3554) (end 119.6314 100.3579) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5705 100.3402) (end 119.5806 100.3427) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5044 100.3122) (end 119.5146 100.3173) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4409 100.2741) (end 119.4485 100.2792) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4181 100.2563) (end 119.4257 100.2614) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.319 100.0582) (end 119.319 100.0709) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 100.0277) (end 119.3165 100.0379) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7025 100.3732) (end 119.7229 100.3783) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6594 100.363) (end 119.6797 100.3681) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5578 100.3351) (end 119.5705 100.3402) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3393 100.1471) (end 119.3444 100.1547) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3368 100.137) (end 119.3393 100.1471) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5349 100.3275) (end 119.5476 100.3325) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4841 100.3021) (end 119.4943 100.3071) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4765 100.297) (end 119.4841 100.3021) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3444 100.1547) (end 119.3469 100.1649) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4562 100.2868) (end 119.4663 100.2919) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3215 100.0811) (end 119.3241 100.0912) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4028 100.2411) (end 119.4104 100.2487) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3901 100.2284) (end 119.3952 100.236) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3317 100.1192) (end 119.3342 100.1293) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4257 100.2614) (end 119.4333 100.269) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3774 100.2132) (end 119.3825 100.2208) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3571 100.1827) (end 119.3622 100.1903) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.352 100.1725) (end 119.3571 100.1827) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3292 100.109) (end 119.3317 100.1192) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3342 100.1293) (end 119.3368 100.137) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3596 99.761) (end 119.3393 99.8398) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 100.015) (end 119.3165 100.0277) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6416 98.6917) (end 119.6213 98.7679) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 100.0049) (end 119.3165 100.015) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 99.9922) (end 119.3165 100.0049) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 99.9795) (end 119.3165 99.9922) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4384 99.4562) (end 119.4181 99.5324) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.479 99.3038) (end 119.4587 99.38) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3165 99.9693) (end 119.3165 99.9795) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4993 99.2276) (end 119.479 99.3038) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9438 97.5462) (end 119.9235 97.6224) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.319 99.9566) (end 119.3165 99.9693) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3241 99.9185) (end 119.3215 99.9312) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1597 96.7029) (end 120.142 96.7816) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2359 96.3981) (end 120.2156 96.4743) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3317 99.8804) (end 119.3266 99.8931) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8448 97.9272) (end 119.8245 98.0034) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4587 99.38) (end 119.4384 99.4562) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5197 99.1514) (end 119.4993 99.2276) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8245 98.0034) (end 119.8041 98.0821) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0632 97.0864) (end 120.0429 97.1626) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8041 98.0821) (end 119.7838 98.1583) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6822 98.5393) (end 119.6619 98.6155) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7229 98.3869) (end 119.7025 98.4631) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3071 96.0907) (end 120.2893 96.1669) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.319 99.9439) (end 119.319 99.9566) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3215 99.9312) (end 119.319 99.9439) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4181 99.5324) (end 119.3977 99.6086) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0429 97.1626) (end 120.0251 97.2388) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3266 99.9058) (end 119.3241 99.9185) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3342 99.8652) (end 119.3317 99.8804) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3368 99.8525) (end 119.3342 99.8652) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3393 99.8398) (end 119.3368 99.8525) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7838 98.1583) (end 119.7635 98.2345) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2156 96.4743) (end 120.1978 96.5505) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8651 97.851) (end 119.8448 97.9272) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5603 98.9965) (end 119.54 99.0752) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5806 98.9203) (end 119.5603 98.9965) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6213 98.7679) (end 119.6009 98.8441) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6619 98.6155) (end 119.6416 98.6917) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7635 98.2345) (end 119.7432 98.3107) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8854 97.7748) (end 119.8651 97.851) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9845 97.3938) (end 119.9642 97.47) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9032 97.6986) (end 119.8854 97.7748) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9235 97.6224) (end 119.9032 97.6986) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1013 96.934) (end 120.0835 97.0102) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2537 96.3193) (end 120.2359 96.3981) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0048 97.3176) (end 119.9845 97.3938) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0251 97.2388) (end 120.0048 97.3176) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1216 96.8578) (end 120.1013 96.934) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2715 96.2431) (end 120.2537 96.3193) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7025 98.4631) (end 119.6822 98.5393) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7432 98.3107) (end 119.7229 98.3869) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.142 96.7816) (end 120.1216 96.8578) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0835 97.0102) (end 120.0632 97.0864) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2893 96.1669) (end 120.2715 96.2431) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.38 99.6848) (end 119.3596 99.761) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9642 97.47) (end 119.9438 97.5462) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1801 96.6267) (end 120.1597 96.7029) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1978 96.5505) (end 120.1801 96.6267) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3266 99.8931) (end 119.3266 99.9058) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3977 99.6086) (end 119.38 99.6848) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.54 99.0752) (end 119.5197 99.1514) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6009 98.8441) (end 119.5806 98.9203) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0513 91.6305) (end 121.0437 91.7016) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8328 93.3602) (end 120.8227 93.4314) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8659 93.1443) (end 120.8557 93.2155) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.462 95.3973) (end 120.4468 95.4735) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.495 95.2424) (end 120.4772 95.3186) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9649 92.423) (end 120.9548 92.4966) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3248 96.012) (end 120.3071 96.0907) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3426 95.9358) (end 120.3248 96.012) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.65 94.4347) (end 120.6373 94.5058) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3604 95.8596) (end 120.3426 95.9358) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6881 94.2213) (end 120.6754 94.2924) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7998 93.5761) (end 120.7871 93.6473) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4112 95.6285) (end 120.396 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.429 95.5523) (end 120.4112 95.6285) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4468 95.4735) (end 120.429 95.5523) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.556 94.9325) (end 120.5407 95.0112) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0233 91.9201) (end 121.0157 91.9912) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7389 93.9343) (end 120.7262 94.0054) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9268 92.7125) (end 120.9167 92.7837) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5407 95.0112) (end 120.5255 95.0874) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9167 92.7837) (end 120.909 92.8573) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5687 94.8614) (end 120.556 94.9325) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5839 94.7903) (end 120.5687 94.8614) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9903 92.2071) (end 120.9827 92.2807) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5966 94.7191) (end 120.5839 94.7903) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6754 94.2924) (end 120.6627 94.3635) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7871 93.6473) (end 120.7744 93.7184) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0691 91.4146) (end 121.064 91.4857) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6373 94.5058) (end 120.622 94.5769) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7643 93.792) (end 120.7516 93.8632) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8227 93.4314) (end 120.81 93.505) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8455 93.2891) (end 120.8328 93.3602) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8862 92.9996) (end 120.876 93.0732) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8989 92.9284) (end 120.8862 92.9996) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.937 92.6414) (end 120.9268 92.7125) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0081 92.0623) (end 120.9979 92.136) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9827 92.2807) (end 120.9725 92.3519) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5103 95.1662) (end 120.495 95.2424) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.909 92.8573) (end 120.8989 92.9284) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3782 95.7834) (end 120.3604 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9471 92.5678) (end 120.937 92.6414) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6627 94.3635) (end 120.65 94.4347) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7744 93.7184) (end 120.7643 93.792) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9979 92.136) (end 120.9903 92.2071) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5255 95.0874) (end 120.5103 95.1662) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7135 94.0765) (end 120.7008 94.1476) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8557 93.2155) (end 120.8455 93.2891) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.036 91.7753) (end 121.031 91.8464) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0437 91.7016) (end 121.036 91.7753) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6093 94.648) (end 120.5966 94.7191) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.622 94.5769) (end 120.6093 94.648) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7262 94.0054) (end 120.7135 94.0765) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.031 91.8464) (end 121.0233 91.9201) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.876 93.0732) (end 120.8659 93.1443) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9548 92.4966) (end 120.9471 92.5678) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.396 95.7047) (end 120.3782 95.7834) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7008 94.1476) (end 120.6881 94.2213) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0564 91.5568) (end 121.0513 91.6305) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4772 95.3186) (end 120.462 95.3973) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9725 92.3519) (end 120.9649 92.423) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7516 93.8632) (end 120.7389 93.9343) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.81 93.505) (end 120.7998 93.5761) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.064 91.4857) (end 121.0564 91.5568) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0157 91.9912) (end 121.0081 92.0623) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0919 86.614) (end 121.097 86.7308) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1148 90.6196) (end 121.1122 90.6907) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0868 86.3829) (end 121.0894 86.4997) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0792 91.2698) (end 121.0741 91.3409) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0589 85.5701) (end 121.064 85.6844) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0665 85.8012) (end 121.0716 85.918) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0843 91.1962) (end 121.0792 91.2698) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0894 91.125) (end 121.0843 91.1962) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0945 91.0514) (end 121.0894 91.125) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1021 90.9091) (end 121.0995 90.9803) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 89.0549) (end 121.1351 89.1692) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1072 90.8355) (end 121.1021 90.9091) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1122 90.6907) (end 121.1097 90.7644) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1224 87.7773) (end 121.1249 87.8916) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1122 87.3125) (end 121.1148 87.4268) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 89.6341) (end 121.1326 89.7509) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0437 85.1052) (end 121.0487 85.2195) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1199 90.4748) (end 121.1199 90.5459) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0716 85.918) (end 121.0741 86.0349) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1326 89.7509) (end 121.1326 89.8652) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.13 88.3564) (end 121.1326 88.4733) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1326 89.8652) (end 121.13 89.982) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1249 90.33) (end 121.1224 90.4037) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0894 86.4997) (end 121.0919 86.614) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0995 86.8477) (end 121.1021 86.9645) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1199 90.5459) (end 121.1148 90.6196) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.13 89.982) (end 121.13 90.0989) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.031 84.7547) (end 121.036 84.8716) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1326 88.4733) (end 121.1326 88.590101) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0741 86.0349) (end 121.0792 86.1492) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0487 85.2195) (end 121.0513 85.3364) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.036 84.8716) (end 121.0386 84.9884) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0792 86.1492) (end 121.0818 86.266) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0386 84.9884) (end 121.0437 85.1052) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1148 87.4268) (end 121.1173 87.5436) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 89.5172) (end 121.1351 89.6341) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1224 90.4037) (end 121.1199 90.4748) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0564 85.4532) (end 121.0589 85.5701) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.13 90.0989) (end 121.1275 90.2132) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 89.4029) (end 121.1351 89.5172) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 89.2861) (end 121.1351 89.4029) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 89.1692) (end 121.1351 89.2861) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 88.8213) (end 121.1351 88.938101) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 88.704401) (end 121.1351 88.8213) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1326 88.590101) (end 121.1351 88.704401) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1275 88.1253) (end 121.13 88.2421) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1097 87.1957) (end 121.1122 87.3125) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1249 88.0085) (end 121.1275 88.1253) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.097 86.7308) (end 121.0995 86.8477) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1072 87.0788) (end 121.1097 87.1957) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0259 84.6404) (end 121.031 84.7547) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0513 85.3364) (end 121.0564 85.4532) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1275 90.2132) (end 121.1249 90.33) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1249 87.8916) (end 121.1249 88.0085) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.13 88.2421) (end 121.13 88.3564) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1021 86.9645) (end 121.1072 87.0788) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1351 88.938101) (end 121.1351 89.0549) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1199 87.660501) (end 121.1224 87.7773) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1173 87.5436) (end 121.1199 87.660501) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0818 86.266) (end 121.0868 86.3829) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.064 85.6844) (end 121.0665 85.8012) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0741 91.3409) (end 121.0691 91.4146) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0995 90.9803) (end 121.0945 91.0514) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1097 90.7644) (end 121.1072 90.8355) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8989 82.1944) (end 120.9014 82.2198) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9167 82.3392) (end 120.9217 82.3646) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9624 82.7507) (end 120.9624 82.7761) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0233 84.5236) (end 121.0259 84.6404) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0183 84.4067) (end 121.0233 84.5236) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9395 82.5094) (end 120.9421 82.5322) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0157 84.2899) (end 121.0183 84.4067) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0106 84.1756) (end 121.0157 84.2899) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0056 84.0588) (end 121.0106 84.1756) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.003 83.9419) (end 121.0056 84.0588) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8405 81.7829) (end 120.8455 81.8083) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.97 82.898) (end 120.9725 83.0123) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9979 83.8251) (end 121.003 83.9419) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8836 82.0979) (end 120.8862 82.1233) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.876 82.0496) (end 120.8811 82.0725) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8633 81.9531) (end 120.8659 81.976) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9878 83.4771) (end 120.9903 83.5939) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9802 83.246) (end 120.9827 83.3628) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9497 82.6059) (end 120.9522 82.6313) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9751 83.1291) (end 120.9802 83.246) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9522 82.6313) (end 120.9548 82.6541) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9725 83.0123) (end 120.9751 83.1291) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8913 82.1461) (end 120.8938 82.1715) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9294 82.4357) (end 120.9344 82.4611) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9675 82.8497) (end 120.9675 82.8726) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9014 82.2198) (end 120.904 82.2427) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9649 82.7989) (end 120.9649 82.8243) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8709 82.0014) (end 120.8735 82.0242) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9573 82.7024) (end 120.9598 82.7278) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9573 82.6795) (end 120.9573 82.7024) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8659 81.976) (end 120.8709 82.0014) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9471 82.583) (end 120.9497 82.6059) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9344 82.4611) (end 120.937 82.484) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9243 82.3874) (end 120.9268 82.4128) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.909 82.2681) (end 120.9116 82.2909) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8532 81.8794) (end 120.8557 81.9048) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9141 82.3163) (end 120.9167 82.3392) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9548 82.6541) (end 120.9573 82.6795) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9446 82.5576) (end 120.9471 82.583) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9268 82.4128) (end 120.9294 82.4357) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.904 82.2427) (end 120.909 82.2681) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8938 82.1715) (end 120.8989 82.1944) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8354 81.7347) (end 120.8379 81.7601) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8506 81.8566) (end 120.8532 81.8794) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9954 83.7108) (end 120.9979 83.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9903 83.5939) (end 120.9954 83.7108) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9624 82.7761) (end 120.9649 82.7989) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8455 81.8083) (end 120.8481 81.8312) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9827 83.3628) (end 120.9878 83.4771) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8481 81.8312) (end 120.8506 81.8566) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8328 81.7118) (end 120.8354 81.7347) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9675 82.8726) (end 120.97 82.898) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9598 82.7278) (end 120.9624 82.7507) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9421 82.5322) (end 120.9446 82.5576) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9116 82.2909) (end 120.9141 82.3163) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8862 82.1233) (end 120.8913 82.1461) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8811 82.0725) (end 120.8836 82.0979) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.937 82.484) (end 120.9395 82.5094) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8379 81.7601) (end 120.8405 81.7829) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8735 82.0242) (end 120.876 82.0496) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8608 81.9277) (end 120.8633 81.9531) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9649 82.8243) (end 120.9675 82.8497) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9217 82.3646) (end 120.9243 82.3874) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8557 81.9048) (end 120.8608 81.9277) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7846 80.8863) (end 120.7897 80.9777) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3604 77.8942) (end 120.3782 77.9856) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3045 77.6275) (end 120.3223 77.7164) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8303 81.6864) (end 120.8328 81.7118) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7338 80.2462) (end 120.7414 80.3377) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7516 80.4291) (end 120.7592 80.5205) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8278 81.661) (end 120.8303 81.6864) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8252 81.6381) (end 120.8278 81.661) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6068 79.2455) (end 120.6195 79.3369) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8227 81.6127) (end 120.8252 81.6381) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5636 78.9737) (end 120.5788 79.0651) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4163 78.1634) (end 120.4341 78.2549) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8151 81.5162) (end 120.8176 81.5416) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.81 81.4451) (end 120.8125 81.468) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.81 81.4197) (end 120.81 81.4451) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7592 80.5205) (end 120.7668 80.612) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6931 79.8805) (end 120.7033 79.9719) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5001 78.613) (end 120.5179 78.7044) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1851 77.0915) (end 120.2055 77.1804) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8024 81.2546) (end 120.8049 81.346) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2055 77.1804) (end 120.2258 77.2693) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7897 80.9777) (end 120.7947 81.0692) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7719 80.7034) (end 120.7795 80.7949) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7668 80.612) (end 120.7719 80.7034) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7033 79.9719) (end 120.7135 80.0633) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5788 79.0651) (end 120.5915 79.154) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6576 79.6087) (end 120.6703 79.6976) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4341 78.2549) (end 120.4493 78.3438) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.683 79.789) (end 120.6931 79.8805) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6703 79.6976) (end 120.683 79.789) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6195 79.3369) (end 120.6322 79.4258) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3782 77.9856) (end 120.3985 78.0745) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3426 77.8053) (end 120.3604 77.8942) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2639 77.4471) (end 120.2842 77.536) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1623 77.0001) (end 120.1851 77.0915) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4671 78.4352) (end 120.4849 78.5241) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2461 77.3582) (end 120.2639 77.4471) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7236 80.1548) (end 120.7338 80.2462) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2258 77.2693) (end 120.2461 77.3582) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8201 81.5899) (end 120.8227 81.6127) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.142 76.9112) (end 120.1623 77.0001) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8176 81.5645) (end 120.8201 81.5899) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5915 79.154) (end 120.6068 79.2455) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4493 78.3438) (end 120.4671 78.4352) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8176 81.5416) (end 120.8176 81.5645) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8074 81.3943) (end 120.81 81.4197) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3223 77.7164) (end 120.3426 77.8053) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5331 78.7933) (end 120.5484 78.8848) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7998 81.1632) (end 120.8024 81.2546) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8074 81.3714) (end 120.8074 81.3943) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6449 79.5172) (end 120.6576 79.6087) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7135 80.0633) (end 120.7236 80.1548) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6322 79.4258) (end 120.6449 79.5172) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2842 77.536) (end 120.3045 77.6275) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5179 78.7044) (end 120.5331 78.7933) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8049 81.346) (end 120.8074 81.3714) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8125 81.4934) (end 120.8151 81.5162) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5484 78.8848) (end 120.5636 78.9737) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8125 81.468) (end 120.8125 81.4934) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7795 80.7949) (end 120.7846 80.8863) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7414 80.3377) (end 120.7516 80.4291) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3985 78.0745) (end 120.4163 78.1634) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7947 81.0692) (end 120.7998 81.1632) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4849 78.5241) (end 120.5001 78.613) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.606 74.836) (end 119.6187 74.8792) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4079 74.2315) (end 119.4206 74.2747) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1691 73.5432) (end 119.1844 73.5863) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1216 76.8223) (end 120.142 76.9112) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1013 76.7334) (end 120.1216 76.8223) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0353 76.4667) (end 120.0581 76.5556) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5501 74.6633) (end 119.5628 74.7065) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5222 74.5769) (end 119.5349 74.6201) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8372 75.6666) (end 119.86 75.7555) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7711 75.4024) (end 119.7813 75.4456) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.507 74.5338) (end 119.5222 74.5769) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2149 73.6727) (end 119.2301 73.7159) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7457 75.3135) (end 119.7584 75.3567) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6975 75.1408) (end 119.7102 75.184) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6594 75.0087) (end 119.6721 75.0519) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2606 73.8022) (end 119.2733 73.8454) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2301 73.7159) (end 119.2453 73.7591) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5349 74.6201) (end 119.5501 74.6633) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4943 74.4906) (end 119.507 74.5338) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2733 73.8454) (end 119.2885 73.8886) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2885 73.8886) (end 119.3038 73.9318) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1564 73.5) (end 119.1691 73.5432) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.794 75.4888) (end 119.8041 75.532) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3774 74.1451) (end 119.3927 74.1883) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3495 74.0588) (end 119.3622 74.102) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7229 75.2272) (end 119.733 75.2704) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1844 73.5863) (end 119.1996 73.6295) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5628 74.7065) (end 119.5781 74.7497) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0785 76.6445) (end 120.1013 76.7334) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0581 76.5556) (end 120.0785 76.6445) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7102 75.184) (end 119.7229 75.2272) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.015 76.3778) (end 120.0353 76.4667) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9921 76.2889) (end 120.015 76.3778) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3038 73.9318) (end 119.319 73.975) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9718 76.2) (end 119.9921 76.2889) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8829 75.8444) (end 119.9057 75.9333) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9261 76.0222) (end 119.9489 76.1111) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9489 76.1111) (end 119.9718 76.2) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9057 75.9333) (end 119.9261 76.0222) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.86 75.7555) (end 119.8829 75.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8041 75.532) (end 119.8143 75.5777) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4511 74.361) (end 119.4663 74.4042) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1412 73.4593) (end 119.1564 73.5) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3927 74.1883) (end 119.4079 74.2315) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1996 73.6295) (end 119.2149 73.6727) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4206 74.2747) (end 119.4358 74.3179) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8143 75.5777) (end 119.8372 75.6666) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6314 74.9224) (end 119.6441 74.9656) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6187 74.8792) (end 119.6314 74.9224) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.319 73.975) (end 119.3342 74.0181) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6441 74.9656) (end 119.6594 75.0087) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4663 74.4042) (end 119.479 74.4474) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2453 73.7591) (end 119.2606 73.8022) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3342 74.0181) (end 119.3495 74.0588) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3622 74.102) (end 119.3774 74.1451) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7813 75.4456) (end 119.794 75.4888) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7584 75.3567) (end 119.7711 75.4024) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5908 74.7928) (end 119.606 74.836) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.733 75.2704) (end 119.7457 75.3135) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6848 75.0951) (end 119.6975 75.1408) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6721 75.0519) (end 119.6848 75.0951) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5781 74.7497) (end 119.5908 74.7928) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.479 74.4474) (end 119.4943 74.4906) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4358 74.3179) (end 119.4511 74.361) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9101 72.7151) (end 118.9101 72.7253) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9431 72.5449) (end 118.9405 72.5526) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1793 72.1208) (end 119.1514 72.1716) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2072 72.07) (end 119.1793 72.1208) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.126 73.4162) (end 119.1412 73.4593) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0955 73.3298) (end 119.1107 73.373) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9126 72.7329) (end 118.9126 72.7431) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1107 73.373) (end 119.126 73.4162) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9405 72.5526) (end 118.938 72.5602) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9507 72.5297) (end 118.9482 72.5373) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9126 72.6592) (end 118.9126 72.6669) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0675 73.2434) (end 119.0828 73.2866) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9177 72.6313) (end 118.9151 72.6389) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.38 71.7626) (end 119.352 71.8134) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9532 72.898) (end 118.9659 72.9412) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9253 72.5957) (end 118.9228 72.6034) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9228 72.804) (end 118.9253 72.8116) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9126 72.7507) (end 118.9151 72.7608) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9202 72.6211) (end 118.9177 72.6313) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9126 72.7431) (end 118.9126 72.7507) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9151 72.6389) (end 118.9151 72.6491) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0396 73.1571) (end 119.0523 73.2003) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0091 73.0707) (end 119.0244 73.1139) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9482 72.5373) (end 118.9431 72.5449) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9101 72.7253) (end 118.9126 72.7329) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9329 72.5703) (end 118.9304 72.578) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9151 72.6491) (end 118.9126 72.6592) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0371 72.3773) (end 119.0091 72.4281) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9202 72.7964) (end 118.9228 72.804) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9101 72.705) (end 118.9101 72.7151) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2657 71.9658) (end 119.2377 72.0166) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4079 71.7118) (end 119.38 71.7626) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.352 71.8134) (end 119.3215 71.8642) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0523 73.2003) (end 119.0675 73.2434) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0244 73.1139) (end 119.0396 73.1571) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9812 72.9844) (end 118.9964 73.0275) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9151 72.7608) (end 118.9151 72.7685) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9101 72.6973) (end 118.9101 72.705) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2377 72.0166) (end 119.2072 72.07) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2936 71.915) (end 119.2657 71.9658) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0091 72.4281) (end 118.9812 72.4789) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9126 72.6669) (end 118.9126 72.677) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9812 72.4789) (end 118.9507 72.5297) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3215 71.8642) (end 119.2936 71.915) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0929 72.2732) (end 119.065 72.324) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1514 72.1716) (end 119.1234 72.2224) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0828 73.2866) (end 119.0955 73.3298) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9126 72.677) (end 118.9101 72.6872) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9659 72.9412) (end 118.9812 72.9844) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9964 73.0275) (end 119.0091 73.0707) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9151 72.7685) (end 118.9177 72.7786) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.938 72.8548) (end 118.9532 72.898) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9177 72.7862) (end 118.9202 72.7964) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9304 72.578) (end 118.9278 72.5856) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9228 72.6034) (end 118.9202 72.6135) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9177 72.7786) (end 118.9177 72.7862) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9101 72.6872) (end 118.9101 72.6973) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.938 72.5602) (end 118.9329 72.5703) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4384 71.6585) (end 119.4079 71.7118) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.065 72.324) (end 119.0371 72.3773) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9253 72.8116) (end 118.938 72.8548) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9202 72.6135) (end 118.9202 72.6211) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1234 72.2224) (end 119.0929 72.2732) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9278 72.5856) (end 118.9253 72.5957) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0945 68.6511) (end 121.0741 68.6918) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9261 70.7898) (end 119.8981 70.8406) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0404 70.5866) (end 120.0124 70.6374) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1851 70.3301) (end 120.1572 70.3809) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2994 70.1269) (end 120.2715 70.1777) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3274 70.0735) (end 120.2994 70.1269) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6423 69.5122) (end 120.6119 69.563) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4696 69.8195) (end 120.4417 69.8703) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.782 69.2556) (end 120.7541 69.3064) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9116 69.0143) (end 120.8913 69.055) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9751 68.895) (end 120.9548 68.9331) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4137 69.9211) (end 120.3858 69.9719) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8709 69.0956) (end 120.8481 69.1337) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9954 68.8543) (end 120.9751 68.895) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.13 68.5698) (end 121.1122 68.6105) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8981 70.8406) (end 119.8676 70.8939) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7813 71.0463) (end 119.7533 71.0971) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4943 71.5569) (end 119.4663 71.6077) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5247 71.5061) (end 119.4943 71.5569) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8676 70.8939) (end 119.8397 70.9447) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.954 70.739) (end 119.9261 70.7898) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.241 70.2285) (end 120.2131 70.2793) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9344 68.9737) (end 120.9116 69.0143) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5527 71.4553) (end 119.5247 71.5061) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5806 71.4045) (end 119.5527 71.4553) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7254 71.1479) (end 119.6949 71.1987) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0538 68.7324) (end 121.036 68.773) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9845 70.6882) (end 119.954 70.739) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0124 70.6374) (end 119.9845 70.6882) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0157 68.8137) (end 120.9954 68.8543) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0741 68.6918) (end 121.0538 68.7324) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.036 68.773) (end 121.0157 68.8137) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8118 70.9955) (end 119.7813 71.0463) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6703 69.4588) (end 120.6423 69.5122) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8049 69.215) (end 120.782 69.2556) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9548 68.9331) (end 120.9344 68.9737) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0708 70.5358) (end 120.0404 70.5866) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2131 70.2793) (end 120.1851 70.3301) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1267 70.4317) (end 120.0988 70.485) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1572 70.3809) (end 120.1267 70.4317) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2715 70.1777) (end 120.241 70.2285) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8278 69.1744) (end 120.8049 69.215) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8913 69.055) (end 120.8709 69.0956) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5839 69.6138) (end 120.556 69.6646) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6119 69.563) (end 120.5839 69.6138) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7541 69.3064) (end 120.7262 69.3572) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5001 69.7662) (end 120.4696 69.8195) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7262 69.3572) (end 120.6982 69.408) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4663 71.6077) (end 119.4384 71.6585) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6086 71.3537) (end 119.5806 71.4045) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6982 69.408) (end 120.6703 69.4588) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4417 69.8703) (end 120.4137 69.9211) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8481 69.1337) (end 120.8278 69.1744) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.639 71.3029) (end 119.6086 71.3537) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.667 71.2495) (end 119.639 71.3029) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.556 69.6646) (end 120.528 69.7154) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0988 70.485) (end 120.0708 70.5358) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6949 71.1987) (end 119.667 71.2495) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.528 69.7154) (end 120.5001 69.7662) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1122 68.6105) (end 121.0945 68.6511) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3553 70.0227) (end 120.3274 70.0735) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3858 69.9719) (end 120.3553 70.0227) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7533 71.0971) (end 119.7254 71.1479) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8397 70.9447) (end 119.8118 70.9955) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2824 68.2015) (end 121.2672 68.2422) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3383 68.0339) (end 121.3256 68.0745) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3561 66.2762) (end 121.3688 66.3092) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3993 67.8205) (end 121.3866 67.8637) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.445 67.6072) (end 121.4348 67.6504) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2824 66.101) (end 121.3002 66.1365) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4882 67.117) (end 121.4882 67.1627) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4755 67.3862) (end 121.4704 67.4319) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4805 66.8858) (end 121.4831 66.9341) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.445 66.6039) (end 121.4526 66.6521) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.417 66.4743) (end 121.4247 66.5074) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3916 66.3778) (end 121.4018 66.4108) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4348 67.6504) (end 121.4272 67.6935) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4653 67.4751) (end 121.4577 67.5183) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4602 66.6979) (end 121.4653 66.7461) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2672 68.2422) (end 121.2519 68.2828) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4018 66.4108) (end 121.4094 66.4413) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2189 68.3666) (end 121.2011 68.4073) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2519 68.2828) (end 121.2342 68.3235) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2977 68.1584) (end 121.2824 68.2015) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.417 67.7367) (end 121.4094 67.7799) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3434 66.2407) (end 121.3561 66.2762) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4348 66.5556) (end 121.445 66.6039) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3104 68.1177) (end 121.2977 68.1584) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3256 68.0745) (end 121.3104 68.1177) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.351 67.9907) (end 121.3383 68.0339) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3688 66.3092) (end 121.3789 66.3423) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2113 65.9587) (end 121.2316 65.9943) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3764 67.9069) (end 121.3637 67.9501) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3866 67.8637) (end 121.3764 67.9069) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4094 67.7799) (end 121.3993 67.8205) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4272 67.6935) (end 121.417 67.7367) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4882 67.2084) (end 121.4856 67.2516) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4882 67.0712) (end 121.4882 67.117) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.478 66.8401) (end 121.4805 66.8858) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4247 66.5074) (end 121.4348 66.5556) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4882 67.1627) (end 121.4882 67.2084) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2316 65.9943) (end 121.2494 66.0298) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4729 66.7944) (end 121.478 66.8401) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4526 66.6521) (end 121.4602 66.6979) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1935 65.9232) (end 121.2113 65.9587) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3281 66.2076) (end 121.3434 66.2407) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2494 66.0298) (end 121.2672 66.0654) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4831 66.9341) (end 121.4856 66.9798) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3789 66.3423) (end 121.3916 66.3778) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3154 66.1721) (end 121.3281 66.2076) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.478 67.343) (end 121.4755 67.3862) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4856 66.9798) (end 121.4882 67.0255) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1503 68.5292) (end 121.13 68.5698) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4704 67.4319) (end 121.4653 67.4751) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4882 67.0255) (end 121.4882 67.0712) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4653 66.7461) (end 121.4729 66.7944) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4094 66.4413) (end 121.417 66.4743) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2672 66.0654) (end 121.2824 66.101) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1681 68.4886) (end 121.1503 68.5292) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4856 67.2516) (end 121.4831 67.2973) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3637 67.9501) (end 121.351 67.9907) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1834 68.4479) (end 121.1681 68.4886) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4526 67.5615) (end 121.445 67.6072) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4831 67.2973) (end 121.478 67.343) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3002 66.1365) (end 121.3154 66.1721) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4577 67.5183) (end 121.4526 67.5615) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2011 68.4073) (end 121.1834 68.4479) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2342 68.3235) (end 121.2189 68.3666) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0033 107.3302) (end 108.0084 107.2845) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0008 107.3785) (end 108.0033 107.3302) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8865 109.1844) (end 107.889 109.1108) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9779 107.6198) (end 107.983 107.5715) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8687 109.5578) (end 107.8712 109.4816) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.955 107.9068) (end 107.9601 107.8586) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9398 108.1456) (end 107.9423 108.0973) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9195 108.5139) (end 107.922 108.4402) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9068 108.7374) (end 107.9119 108.6637) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8966 108.9609) (end 107.8992 108.8873) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9881 107.5233) (end 107.9906 107.475) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9271 108.364) (end 107.9322 108.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0363 106.995) (end 108.0414 106.9492) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8992 108.8873) (end 107.9042 108.8111) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0312 107.0432) (end 108.0363 106.995) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0262 107.0915) (end 108.0312 107.0432) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9144 108.5875) (end 107.9195 108.5139) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8814 109.2581) (end 107.8865 109.1844) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0135 107.2363) (end 108.0185 107.188) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0185 107.188) (end 108.0211 107.1397) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0084 107.2845) (end 108.0135 107.2363) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.889 109.1108) (end 107.8915 109.0346) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.856 109.855) (end 107.8585 109.7813) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.983 107.5715) (end 107.9881 107.5233) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9627 107.8103) (end 107.9677 107.762) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9601 107.8586) (end 107.9627 107.8103) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9525 107.9551) (end 107.955 107.9068) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9373 108.1938) (end 107.9398 108.1456) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9119 108.6637) (end 107.9144 108.5875) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8585 109.7813) (end 107.8611 109.7051) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9423 108.0973) (end 107.9449 108.0516) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9347 108.2421) (end 107.9373 108.1938) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.922 108.4402) (end 107.9271 108.364) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8788 109.3343) (end 107.8814 109.2581) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8611 109.7051) (end 107.8661 109.6315) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8915 109.0346) (end 107.8966 108.9609) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8763 109.408) (end 107.8788 109.3343) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9754 107.6655) (end 107.9779 107.6198) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9449 108.0516) (end 107.95 108.0033) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.95 108.0033) (end 107.9525 107.9551) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9322 108.2904) (end 107.9347 108.2421) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9042 108.8111) (end 107.9068 108.7374) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8661 109.6315) (end 107.8687 109.5578) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0465 106.901) (end 108.0516 106.8527) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9677 107.762) (end 107.9703 107.7138) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0414 106.9492) (end 108.0465 106.901) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9957 107.4268) (end 108.0008 107.3785) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9703 107.7138) (end 107.9754 107.6655) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8712 109.4816) (end 107.8763 109.408) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9906 107.475) (end 107.9957 107.4268) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0211 107.1397) (end 108.0262 107.0915) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7341 113.2484) (end 107.7366 113.1545) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7518 112.6871) (end 107.7544 112.6134) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6934 114.5667) (end 107.696 114.4727) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8357 110.302) (end 107.8407 110.2284) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8052 111.1225) (end 107.8077 111.0463) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7849 111.7168) (end 107.7874 111.6432) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7214 113.6244) (end 107.7239 113.5304) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7163 113.8123) (end 107.7188 113.7183) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7544 112.6134) (end 107.7569 112.5372) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7468 112.837) (end 107.7493 112.7608) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7137 113.9063) (end 107.7163 113.8123) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.828 110.5256) (end 107.8306 110.4519) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7772 111.9403) (end 107.7798 111.8667) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8103 110.9726) (end 107.8128 110.8989) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8077 111.0463) (end 107.8103 110.9726) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7671 112.2401) (end 107.7696 112.1639) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8026 111.1961) (end 107.8052 111.1225) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7823 111.793) (end 107.7849 111.7168) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7747 112.0165) (end 107.7772 111.9403) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7188 113.7183) (end 107.7214 113.6244) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7798 111.8667) (end 107.7823 111.793) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7112 114.0003) (end 107.7137 113.9063) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7493 112.7608) (end 107.7518 112.6871) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6883 114.7547) (end 107.6909 114.6607) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6833 114.9426) (end 107.6858 114.8486) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7595 112.4636) (end 107.762 112.3899) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7391 113.0605) (end 107.7417 112.9843) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7239 113.5304) (end 107.7264 113.4364) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8509 109.9287) (end 107.856 109.855) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8255 110.5992) (end 107.828 110.5256) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8484 110.0049) (end 107.8509 109.9287) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8458 110.0785) (end 107.8484 110.0049) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7976 111.346) (end 107.8001 111.2698) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8433 110.1522) (end 107.8458 110.0785) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8407 110.2284) (end 107.8433 110.1522) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8331 110.3757) (end 107.8357 110.302) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8306 110.4519) (end 107.8331 110.3757) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.823 110.6754) (end 107.8255 110.5992) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8128 110.8989) (end 107.8153 110.8227) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.795 111.4196) (end 107.7976 111.346) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7417 112.9843) (end 107.7442 112.910601) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7874 111.6432) (end 107.7899 111.5695) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7442 112.910601) (end 107.7468 112.837) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.701 114.2822) (end 107.7036 114.1882) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6909 114.6607) (end 107.6934 114.5667) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.696 114.4727) (end 107.6985 114.3787) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8179 110.7491) (end 107.823 110.6754) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7899 111.5695) (end 107.7925 111.4933) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7366 113.1545) (end 107.7391 113.0605) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8153 110.8227) (end 107.8179 110.7491) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7696 112.1639) (end 107.7722 112.0902) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7036 114.1882) (end 107.7087 114.0943) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.762 112.3899) (end 107.7645 112.3137) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6807 115.0366) (end 107.6833 114.9426) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6858 114.8486) (end 107.6883 114.7547) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8001 111.2698) (end 107.8026 111.1961) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7925 111.4933) (end 107.795 111.4196) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7315 113.3424) (end 107.7341 113.2484) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7722 112.0902) (end 107.7747 112.0165) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7569 112.5372) (end 107.7595 112.4636) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7645 112.3137) (end 107.7671 112.2401) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7264 113.4364) (end 107.7315 113.3424) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7087 114.0943) (end 107.7112 114.0003) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6985 114.3787) (end 107.701 114.2822) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.602 117.9576) (end 107.6045 117.8636) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6756 115.2246) (end 107.6782 115.1306) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5969 118.1456) (end 107.5994 118.0516) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6731 115.3185) (end 107.6756 115.2246) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5791 118.8034) (end 107.5817 118.7094) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5842 118.6155) (end 107.5867 118.5215) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.668 115.4125) (end 107.6731 115.3185) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6655 115.5065) (end 107.668 115.4125) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5969 119.159) (end 107.5918 119.1514) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6528 115.9789) (end 107.6553 115.885) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6096 119.1819) (end 107.6045 119.1743) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6655 119.2682) (end 107.6604 119.2606) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6629 115.603) (end 107.6655 115.5065) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6248 117.0153) (end 107.6274 116.9213) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6172 117.3912) (end 107.6198 117.2972) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6604 115.697) (end 107.6629 115.603) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.574 119.0981) (end 107.574 119.0879) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5867 118.5215) (end 107.5893 118.4275) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.635 119.22) (end 107.6274 119.2098) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6579 115.791) (end 107.6604 115.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6375 116.5428) (end 107.6401 116.4488) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6553 115.885) (end 107.6579 115.791) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6401 116.4488) (end 107.6426 116.3549) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5994 118.0516) (end 107.602 117.9576) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6071 117.7696) (end 107.6096 117.6731) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6045 119.1743) (end 107.602 119.1666) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5817 119.1311) (end 107.5791 119.1184) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6604 119.2606) (end 107.6553 119.2555) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6198 117.2972) (end 107.6223 117.2032) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5893 118.4275) (end 107.5918 118.3335) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.574 119.0879) (end 107.5766 118.9939) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5791 119.1184) (end 107.574 119.1082) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5918 118.3335) (end 107.5944 118.2395) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.574 119.1082) (end 107.574 119.0981) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5918 119.1514) (end 107.5893 119.1438) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6477 119.2428) (end 107.6426 119.2301) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6502 116.0729) (end 107.6528 115.9789) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5766 118.899901) (end 107.5791 118.8034) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6477 116.1669) (end 107.6502 116.0729) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6452 116.2609) (end 107.6477 116.1669) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6426 116.3549) (end 107.6452 116.2609) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.635 116.6368) (end 107.6375 116.5428) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.602 119.1666) (end 107.5969 119.159) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6553 119.2555) (end 107.6477 119.2428) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6325 116.7333) (end 107.635 116.6368) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6299 116.8273) (end 107.6325 116.7333) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6147 117.4852) (end 107.6172 117.3912) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6223 119.1997) (end 107.6172 119.192) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6045 117.8636) (end 107.6071 117.7696) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6121 117.5791) (end 107.6147 117.4852) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5867 119.1387) (end 107.5817 119.1311) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5766 118.9939) (end 107.5766 118.899901) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5893 119.1438) (end 107.5867 119.1387) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6274 116.9213) (end 107.6299 116.8273) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6274 119.2098) (end 107.6223 119.1997) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6096 117.6731) (end 107.6121 117.5791) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6248 117.1092) (end 107.6248 117.0153) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6172 119.192) (end 107.6096 119.1819) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6223 117.2032) (end 107.6248 117.1092) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5944 118.2395) (end 107.5969 118.1456) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5817 118.7094) (end 107.5842 118.6155) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.668 119.2733) (end 107.6655 119.2682) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6782 115.1306) (end 107.6807 115.0366) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6426 119.2301) (end 107.635 119.22) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8052 119.3241) (end 107.8001 119.3317) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7772 119.3724) (end 107.7722 119.3825) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6909 119.3089) (end 107.6858 119.3013) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6731 119.2809) (end 107.668 119.2733) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8687 119.2022) (end 107.8636 119.2098) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7417 119.3978) (end 107.7366 119.3876) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6807 119.2962) (end 107.6782 119.2886) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.701 119.3267) (end 107.696 119.319) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.922 119.1057) (end 107.9144 119.1158) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7036 119.3343) (end 107.701 119.3267) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7671 119.3902) (end 107.762 119.3978) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9423 119.0701) (end 107.9347 119.0803) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8204 119.2911) (end 107.8179 119.2987) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8306 119.2759) (end 107.8255 119.2835) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8458 119.2454) (end 107.8407 119.253) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.856 119.2225) (end 107.8534 119.2301) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8814 119.1743) (end 107.8788 119.1819) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7188 119.3597) (end 107.7137 119.3495) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9728 119.0244) (end 107.9652 119.0371) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7137 119.3495) (end 107.7087 119.3419) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7239 119.3673) (end 107.7188 119.3597) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7518 119.4156) (end 107.7468 119.4054) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8128 119.3063) (end 107.8077 119.314) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7569 119.4079) (end 107.7518 119.4156) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8001 119.3317) (end 107.795 119.3394) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9347 119.0803) (end 107.9296 119.093) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8382 119.2606) (end 107.8331 119.2682) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8941 119.1539) (end 107.889 119.1616) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7722 119.3825) (end 107.7671 119.3902) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8407 119.253) (end 107.8382 119.2606) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8788 119.1819) (end 107.8763 119.1895) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.889 119.1616) (end 107.8865 119.1692) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7899 119.347) (end 107.7874 119.3571) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8865 119.1692) (end 107.8814 119.1743) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9144 119.1158) (end 107.9068 119.1285) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9881 119.0041) (end 107.9804 119.0142) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7823 119.3648) (end 107.7772 119.3724) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8712 119.1946) (end 107.8687 119.2022) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7087 119.3419) (end 107.7036 119.3343) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.729 119.3775) (end 107.7239 119.3673) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.762 119.3978) (end 107.7569 119.4079) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.795 119.3394) (end 107.7899 119.347) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8077 119.314) (end 107.8052 119.3241) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9296 119.093) (end 107.922 119.1057) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6858 119.3013) (end 107.6807 119.2962) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.696 119.319) (end 107.6909 119.3089) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8636 119.2098) (end 107.8611 119.2174) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9576 119.0473) (end 107.95 119.0574) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7366 119.3876) (end 107.729 119.3775) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8611 119.2174) (end 107.856 119.2225) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8992 119.1412) (end 107.8941 119.1539) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8763 119.1895) (end 107.8712 119.1946) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9068 119.1285) (end 107.8992 119.1412) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7874 119.3571) (end 107.7823 119.3648) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9652 119.0371) (end 107.9576 119.0473) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8179 119.2987) (end 107.8128 119.3063) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8255 119.2835) (end 107.8204 119.2911) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.95 119.0574) (end 107.9423 119.0701) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7468 119.4054) (end 107.7417 119.3978) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8331 119.2682) (end 107.8306 119.2759) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8484 119.2378) (end 107.8458 119.2454) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6782 119.2886) (end 107.6731 119.2809) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8534 119.2301) (end 107.8484 119.2378) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9804 119.0142) (end 107.9728 119.0244) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.2664 116.426) (end 110.2182 116.4793) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.1615 117.6782) (end 109.1133 117.7315) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9294 115.6538) (end 110.8837 115.7097) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9982 118.9939) (end 107.9881 119.0041) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0058 118.9863) (end 107.9982 118.9939) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.8237 118.0592) (end 108.7755 118.1125) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4569 116.205) (end 110.4087 116.2609) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5509 116.0958) (end 110.5052 116.1517) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0541 118.930401) (end 108.0058 118.9863) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1024 118.8745) (end 108.0541 118.930401) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5992 116.0399) (end 110.5509 116.0958) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1481 118.8212) (end 108.1024 118.8745) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.065 117.7874) (end 109.0168 117.8408) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.6416 117.1346) (end 109.5933 117.1905) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.7381 117.0254) (end 109.6899 117.0813) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.9312 116.807) (end 109.8829 116.8629) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.0759 116.6444) (end 110.0277 116.6978) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1963 118.7653) (end 108.1481 118.8212) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.6307 118.2751) (end 108.5824 118.331) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5052 116.1517) (end 110.4569 116.205) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.5824 118.331) (end 108.5342 118.3843) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6474 115.9866) (end 110.5992 116.0399) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.5476 117.2439) (end 109.4994 117.2972) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.9685 117.8966) (end 108.9202 117.95) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2446 118.712) (end 108.1963 118.7653) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4028 117.4064) (end 109.3546 117.4623) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.8346 116.9162) (end 109.7864 116.9721) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4087 116.2609) (end 110.363 116.3168) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 118.6586) (end 108.2446 118.712) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4376 118.4935) (end 108.3894 118.5494) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.8829 116.8629) (end 109.8346 116.9162) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4859 118.4402) (end 108.4376 118.4935) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.6789 118.2218) (end 108.6307 118.2751) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.1133 117.7315) (end 109.065 117.7874) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.9202 117.95) (end 108.872 118.0033) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.3063 117.5156) (end 109.2581 117.569) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.2098 117.6249) (end 109.1615 117.6782) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3411 118.6028) (end 108.2929 118.6586) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.5342 118.3843) (end 108.4859 118.4402) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.7272 118.1684) (end 108.6789 118.2218) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.0168 117.8408) (end 108.9685 117.8966) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.3546 117.4623) (end 109.3063 117.5156) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4994 117.2972) (end 109.4511 117.3531) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7897 115.8215) (end 110.7414 115.8748) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9776 115.5979) (end 110.9294 115.6538) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.8837 115.7097) (end 110.8354 115.7656) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3894 118.5494) (end 108.3411 118.6028) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1699 116.5352) (end 110.1242 116.5885) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.2182 116.4793) (end 110.1699 116.5352) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.7755 118.1125) (end 108.7272 118.1684) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.872 118.0033) (end 108.8237 118.0592) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7414 115.8748) (end 110.6932 115.9307) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1242 116.5885) (end 110.0759 116.6444) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.2581 117.569) (end 109.2098 117.6249) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4511 117.3531) (end 109.4028 117.4064) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.5933 117.1905) (end 109.5476 117.2439) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.6899 117.0813) (end 109.6416 117.1346) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.3147 116.3701) (end 110.2664 116.426) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.7864 116.9721) (end 109.7381 117.0254) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.9794 116.7536) (end 109.9312 116.807) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.0277 116.6978) (end 109.9794 116.7536) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.363 116.3168) (end 110.3147 116.3701) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6932 115.9307) (end 110.6474 115.9866) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.8354 115.7656) (end 110.7897 115.8215) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9512 113.1164) (end 112.8979 113.19) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.985 111.6) (end 113.9367 111.6762) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0604 112.9665) (end 113.0046 113.0402) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.13 115.4176) (end 111.0716 115.4887) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1885 115.3465) (end 111.13 115.4176) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3246 112.5931) (end 113.2713 112.6693) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8859 111.7549) (end 113.8377 111.8311) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2469 115.2754) (end 111.1885 115.3465) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4221 115.0645) (end 111.3637 115.1357) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7727 114.6378) (end 111.7142 114.7089) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2746 111.1275) (end 114.2263 111.2063) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4806 114.9934) (end 111.4221 115.0645) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4143 110.8888) (end 114.366 110.9701) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4 113.8479) (end 112.3442 113.919) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6236 113.5558) (end 112.5677 113.6294) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.1156 114.2086) (end 112.0597 114.2797) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4821 112.3671) (end 113.4287 112.4433) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7869 111.9099) (end 113.7361 111.9861) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2713 112.6693) (end 113.2205 112.743) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8377 111.8311) (end 113.7869 111.9099) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.366 110.9701) (end 114.3203 111.0488) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3637 115.1357) (end 111.3053 115.2068) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3053 115.2068) (end 111.2469 115.2754) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0046 113.0402) (end 112.9512 113.1164) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.842 113.2637) (end 112.7887 113.3373) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0597 114.2797) (end 112.0013 114.3533) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9367 111.6762) (end 113.8859 111.7549) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3203 111.0488) (end 114.2746 111.1275) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2205 112.743) (end 113.1671 112.8166) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5329 112.2909) (end 113.4821 112.3671) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.539 114.9223) (end 111.4806 114.9934) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.5974 114.8512) (end 111.539 114.9223) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0333 111.5212) (end 113.985 111.6) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1671 112.8166) (end 113.1138 112.8928) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5677 113.6294) (end 112.5118 113.7031) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6558 114.7801) (end 111.5974 114.8512) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7142 114.7089) (end 111.6558 114.7801) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.8311 114.5667) (end 111.7727 114.6378) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.887 114.4956) (end 111.8311 114.5667) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9454 114.4245) (end 111.887 114.4956) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7361 111.9861) (end 113.6853 112.0623) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0815 111.4425) (end 114.0333 111.5212) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0013 114.3533) (end 111.9454 114.4245) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2299 114.0638) (end 112.174 114.1374) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2857 113.9927) (end 112.2299 114.0638) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2263 111.2063) (end 114.178 111.285) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6769 113.4821) (end 112.6236 113.5558) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.178 111.285) (end 114.1298 111.3638) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.8979 113.19) (end 112.842 113.2637) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7328 113.411) (end 112.6769 113.4821) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6853 112.0623) (end 113.6345 112.1385) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.174 114.1374) (end 112.1156 114.2086) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3442 113.919) (end 112.2857 113.9927) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4559 113.7742) (end 112.4 113.8479) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5118 113.7031) (end 112.4559 113.7742) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7887 113.3373) (end 112.7328 113.411) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6345 112.1385) (end 113.5837 112.2147) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1138 112.8928) (end 113.0604 112.9665) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5837 112.2147) (end 113.5329 112.2909) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1298 111.3638) (end 114.0815 111.4425) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3779 112.5169) (end 113.3246 112.5931) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0234 115.5421) (end 110.9776 115.5979) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0716 115.4887) (end 111.0234 115.5421) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4287 112.4433) (end 113.3779 112.5169) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3947 109.1819) (end 115.3668 109.2302) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0137 109.8372) (end 114.9858 109.8829) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.476 109.0422) (end 115.448 109.0905) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6944 108.6688) (end 115.6665 108.7171) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8036 108.4834) (end 115.7782 108.5291) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5319 108.9482) (end 115.5039 108.9965) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6131 108.8085) (end 115.5852 108.8568) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7724 110.2589) (end 114.7445 110.3071) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.078 108.016) (end 116.0526 108.0643) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1763 109.5553) (end 115.1483 109.6035) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2855 109.3699) (end 115.2575 109.4156) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.9408 108.2497) (end 115.9154 108.2954) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.448 109.0905) (end 115.4226 109.1362) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.1618 107.8763) (end 116.1338 107.9246) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.0526 108.0643) (end 116.0246 108.11) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6665 108.7171) (end 115.6411 108.7628) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5573 108.9025) (end 115.5319 108.9482) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.46 110.81) (end 114.4143 110.8888) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5057 110.7288) (end 114.46 110.81) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5311 110.683) (end 114.5057 110.7288) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6411 108.7628) (end 115.6131 108.8085) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7224 108.6231) (end 115.6944 108.6688) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.9967 108.1557) (end 115.9687 108.204) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7445 110.3071) (end 114.7191 110.3528) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6378 110.4951) (end 114.6098 110.5408) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7978 110.2131) (end 114.7724 110.2589) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8511 110.1192) (end 114.8257 110.1649) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.067 109.7432) (end 115.0416 109.7915) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7503 108.5774) (end 115.7224 108.6231) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2042 109.5096) (end 115.1763 109.5553) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3668 109.2302) (end 115.3388 109.2759) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7782 108.5291) (end 115.7503 108.5774) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1483 109.6035) (end 115.1229 109.6493) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8257 110.1649) (end 114.7978 110.2131) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.907 110.0252) (end 114.8791 110.0709) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5039 108.9965) (end 115.476 109.0422) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8316 108.4351) (end 115.8036 108.4834) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.9687 108.204) (end 115.9408 108.2497) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0416 109.7915) (end 115.0137 109.8372) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.095 109.6975) (end 115.067 109.7432) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5852 108.8568) (end 115.5573 108.9025) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9604 109.9312) (end 114.9324 109.9769) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1229 109.6493) (end 115.095 109.6975) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8875 108.3437) (end 115.8595 108.3894) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.0246 108.11) (end 115.9967 108.1557) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3134 109.3216) (end 115.2855 109.3699) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.9154 108.2954) (end 115.8875 108.3437) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5565 110.6348) (end 114.5311 110.683) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5844 110.5891) (end 114.5565 110.6348) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6098 110.5408) (end 114.5844 110.5891) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6632 110.4468) (end 114.6378 110.4951) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6911 110.4011) (end 114.6632 110.4468) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.1897 107.8306) (end 116.1618 107.8763) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7191 110.3528) (end 114.6911 110.4011) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8791 110.0709) (end 114.8511 110.1192) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2575 109.4156) (end 115.2296 109.4638) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8595 108.3894) (end 115.8316 108.4351) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2296 109.4638) (end 115.2042 109.5096) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3388 109.2759) (end 115.3134 109.3216) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4226 109.1362) (end 115.3947 109.1819) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.1059 107.9703) (end 116.078 108.016) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.1338 107.9246) (end 116.1059 107.9703) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9324 109.9769) (end 114.907 110.0252) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9858 109.8829) (end 114.9604 109.9312) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.304 107.6401) (end 116.2837 107.6731) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.8019 107.0077) (end 116.7765 107.0331) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.4775 106.5454) (end 117.4445 106.5606) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.5105 106.5301) (end 117.4775 106.5454) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.3218 107.6071) (end 116.304 107.6401) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.9339 106.8883) (end 116.9085 106.9111) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.3447 107.5766) (end 116.3218 107.6071) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.4488 107.4217) (end 116.4285 107.4522) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.5834 107.2464) (end 116.5606 107.2744) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.6545 107.1626) (end 116.6291 107.1905) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.7257 107.0839) (end 116.7028 107.1093) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.8687 106.4108) (end 117.8306 106.4209) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.365 107.5436) (end 116.3447 107.5766) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.7213 106.4539) (end 117.6858 106.4641) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.5377 107.3023) (end 116.5148 107.3328) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.4285 107.4522) (end 116.4056 107.4826) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.7028 107.1093) (end 116.6774 107.1372) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.4717 107.3912) (end 116.4488 107.4217) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.492 107.3607) (end 116.4717 107.3912) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.5606 107.2744) (end 116.5377 107.3023) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.221 106.68) (end 117.193 106.6978) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.8273 106.9823) (end 116.8019 107.0077) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.6063 107.2185) (end 116.5834 107.2464) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.1041 106.7562) (end 117.0736 106.7791) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.6291 107.1905) (end 116.6063 107.2185) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.7765 107.0331) (end 116.7511 107.0585) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.0457 106.7994) (end 117.0178 106.8197) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.3149 106.6241) (end 117.2845 106.6419) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.7511 107.0585) (end 116.7257 107.0839) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.5791 106.5022) (end 117.5461 106.5149) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.983 106.3854) (end 117.9449 106.393) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.7569 106.4412) (end 117.7213 106.4539) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.6858 106.4641) (end 117.6502 106.4768) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.8552 106.9569) (end 116.8273 106.9823) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.8806 106.934) (end 116.8552 106.9569) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.9898 106.8426) (end 116.9619 106.8654) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.0178 106.8197) (end 116.9898 106.8426) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.0736 106.7791) (end 117.0457 106.7994) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.5461 106.5149) (end 117.5105 106.5301) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.6147 106.4895) (end 117.5791 106.5022) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.2845 106.6419) (end 117.254 106.6597) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.1625 106.7181) (end 117.1321 106.7359) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.3784 106.5911) (end 117.348 106.6089) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.6502 106.4768) (end 117.6147 106.4895) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.4445 106.5606) (end 117.4115 106.5759) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.9068 106.4031) (end 117.8687 106.4108) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.2431 107.7366) (end 116.2151 107.7849) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.4056 107.4826) (end 116.3853 107.5131) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.193 106.6978) (end 117.1625 106.7181) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.2634 107.7036) (end 116.2431 107.7366) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.3853 107.5131) (end 116.365 107.5436) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.5148 107.3328) (end 116.492 107.3607) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.6774 107.1372) (end 116.6545 107.1626) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.9619 106.8654) (end 116.9339 106.8883) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.1321 106.7359) (end 117.1041 106.7562) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.2837 107.6731) (end 116.2634 107.7036) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.8306 106.4209) (end 117.7925 106.4311) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.9085 106.9111) (end 116.8806 106.934) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.7925 106.4311) (end 117.7569 106.4412) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.348 106.6089) (end 117.3149 106.6241) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.254 106.6597) (end 117.221 106.68) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.9449 106.393) (end 117.9068 106.4031) (layer Eco1.User) (width 0.5))
  (gr_line (start 117.4115 106.5759) (end 117.3784 106.5911) (layer Eco1.User) (width 0.5))
  (gr_line (start 116.2151 107.7849) (end 116.1897 107.8306) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.2827 106.332) (end 118.2598 106.3371) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.369 106.3168) (end 118.3462 106.3193) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.258 106.106) (end 119.2377 106.1136) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.4783 106.2939) (end 118.4554 106.299) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.5875 106.2711) (end 118.5646 106.2761) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3647 106.078) (end 119.3444 106.0831) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.8262 106.2152) (end 118.8059 106.2203) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.6967 106.2457) (end 118.6738 106.2507) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9355 106.1898) (end 118.9126 106.1949) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.065 106.1568) (end 119.0421 106.1644) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1285 106.1415) (end 119.1082 106.1466) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1945 106.1237) (end 119.1717 106.1288) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.5646 106.2761) (end 118.5443 106.2812) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.6535 106.2558) (end 118.6307 106.2609) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0218 106.1695) (end 118.999 106.1745) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.2598 106.3371) (end 118.237 106.3422) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1717 106.1288) (end 119.1514 106.1364) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.0236 106.3777) (end 117.983 106.3854) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.237 106.3422) (end 118.2166 106.3447) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.303 106.3295) (end 118.2827 106.332) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.5214 106.2838) (end 118.5011 106.2888) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2809 106.1009) (end 119.258 106.106) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0853 106.1517) (end 119.065 106.1568) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.0617 106.3727) (end 118.0236 106.3777) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.1277 106.36) (end 118.1074 106.365) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.1938 106.3498) (end 118.1735 106.3523) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2377 106.1136) (end 119.2149 106.1187) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.3259 106.3244) (end 118.303 106.3295) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.3462 106.3193) (end 118.3259 106.3244) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.3919 106.3117) (end 118.369 106.3168) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.4351 106.3041) (end 118.4122 106.3066) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.4554 106.299) (end 118.4351 106.3041) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.5011 106.2888) (end 118.4783 106.2939) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.8491 106.2101) (end 118.8262 106.2152) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9558 106.1847) (end 118.9355 106.1898) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1082 106.1466) (end 119.0853 106.1517) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.5443 106.2812) (end 118.5214 106.2838) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.7831 106.2253) (end 118.7602 106.2304) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.8059 106.2203) (end 118.7831 106.2253) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9786 106.1796) (end 118.9558 106.1847) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.0421 106.1644) (end 119.0218 106.1695) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3012 106.0958) (end 119.2809 106.1009) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4079 106.0679) (end 119.3876 106.0729) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.9126 106.1949) (end 118.8923 106.1999) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.2149 106.1187) (end 119.1945 106.1237) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3241 106.0907) (end 119.3012 106.0958) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.717 106.2406) (end 118.6967 106.2457) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.8923 106.1999) (end 118.8694 106.205) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.0846 106.3676) (end 118.0617 106.3727) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.6738 106.2507) (end 118.6535 106.2558) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.8694 106.205) (end 118.8491 106.2101) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.999 106.1745) (end 118.9786 106.1796) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.1514 106.1364) (end 119.1285 106.1415) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3876 106.0729) (end 119.3647 106.078) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.1074 106.365) (end 118.0846 106.3676) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.7602 106.2304) (end 118.7399 106.2355) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.4122 106.3066) (end 118.3919 106.3117) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.1506 106.3574) (end 118.1277 106.36) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.6103 106.266) (end 118.5875 106.2711) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.7399 106.2355) (end 118.717 106.2406) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.3444 106.0831) (end 119.3241 106.0907) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.6307 106.2609) (end 118.6103 106.266) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.1735 106.3523) (end 118.1506 106.3574) (layer Eco1.User) (width 0.5))
  (gr_line (start 118.2166 106.3447) (end 118.1938 106.3498) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0607 105.8824) (end 120.0302 105.8926) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6677 105.7046) (end 120.6373 105.7148) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4308 106.0602) (end 119.4079 106.0679) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4511 106.0552) (end 119.4308 106.0602) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.4841 106.045) (end 119.4511 106.0552) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6441 106.0018) (end 119.6111 106.0094) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9972 105.9028) (end 119.9642 105.9104) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2537 105.8291) (end 120.2207 105.8367) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6373 105.7148) (end 120.6042 105.725) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7338 105.6869) (end 120.7008 105.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1453 105.5573) (end 121.1148 105.5675) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7406 105.9739) (end 119.7076 105.984) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3502 105.8012) (end 120.3172 105.8088) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9337 105.9205) (end 119.9007 105.9282) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9642 105.9104) (end 119.9337 105.9205) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4772 105.7631) (end 120.4442 105.7707) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9878 105.6081) (end 120.9548 105.6157) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3172 105.8088) (end 120.2867 105.8189) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.3807 105.791) (end 120.3502 105.8012) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9548 105.6157) (end 120.9243 105.6259) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3358 105.4938) (end 121.3053 105.504) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.9243 105.6259) (end 120.8913 105.6361) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5171 106.0374) (end 119.4841 106.045) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7008 105.6945) (end 120.6677 105.7046) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7973 105.6665) (end 120.7643 105.6767) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5738 105.7351) (end 120.5407 105.7427) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0302 105.8926) (end 119.9972 105.9028) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2867 105.8189) (end 120.2537 105.8291) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3053 105.504) (end 121.2723 105.5167) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7737 105.9663) (end 119.7406 105.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5476 106.0272) (end 119.5171 106.0374) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.5806 106.0196) (end 119.5476 106.0272) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.0937 105.8748) (end 120.0607 105.8824) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8913 105.6361) (end 120.8608 105.6462) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6111 106.0094) (end 119.5806 106.0196) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0183 105.598) (end 120.9878 105.6081) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8702 105.9383) (end 119.8372 105.9485) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.9007 105.9282) (end 119.8702 105.9383) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1242 105.8647) (end 120.0937 105.8748) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1902 105.8469) (end 120.1572 105.857) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.2207 105.8367) (end 120.1902 105.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.7643 105.6767) (end 120.7338 105.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2088 105.537) (end 121.1783 105.5472) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0513 105.5878) (end 121.0183 105.598) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8608 105.6462) (end 120.8278 105.6564) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3993 105.4735) (end 121.3688 105.4837) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.0818 105.5776) (end 121.0513 105.5878) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1148 105.5675) (end 121.0818 105.5776) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2723 105.5167) (end 121.2418 105.5268) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.2418 105.5268) (end 121.2088 105.537) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4297 105.4633) (end 121.3993 105.4735) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4442 105.7707) (end 120.4137 105.7808) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5407 105.7427) (end 120.5103 105.7529) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.8278 105.6564) (end 120.7973 105.6665) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.3688 105.4837) (end 121.3358 105.4938) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8041 105.9561) (end 119.7737 105.9663) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.8372 105.9485) (end 119.8041 105.9561) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.1572 105.857) (end 120.1242 105.8647) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.1783 105.5472) (end 121.1453 105.5573) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.6042 105.725) (end 120.5738 105.7351) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.6771 105.9917) (end 119.6441 106.0018) (layer Eco1.User) (width 0.5))
  (gr_line (start 119.7076 105.984) (end 119.6771 105.9917) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.4137 105.7808) (end 120.3807 105.791) (layer Eco1.User) (width 0.5))
  (gr_line (start 120.5103 105.7529) (end 120.4772 105.7631) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.8819 105.2779) (end 121.8514 105.2932) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6743 104.5566) (end 122.6566 104.5845) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7226 104.4702) (end 122.7074 104.498101) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.0292 105.1966) (end 121.9987 105.2119) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.0851 105.1611) (end 122.0571 105.1789) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8521 104.1527) (end 122.842 104.188301) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4628 105.4532) (end 121.4297 105.4633) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.4932 105.443) (end 121.4628 105.4532) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.3695 104.9376) (end 122.3441 104.9579) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.5948 105.4049) (end 121.5618 105.4176) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.4381 104.8664) (end 122.4153 104.8918) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.621 104.6404) (end 122.6032 104.6658) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.6279 105.3922) (end 121.5948 105.4049) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.7574 105.3389) (end 121.7244 105.3541) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.8514 105.2932) (end 121.8184 105.3084) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.9987 105.2119) (end 121.9708 105.2297) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.1943 105.0849) (end 122.1663 105.1027) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5245 104.7699) (end 122.5042 104.795301) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8064 104.2848) (end 122.7937 104.3178) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.9403 105.2474) (end 121.9098 105.2627) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7937 104.3178) (end 122.781 104.3483) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.9708 105.2297) (end 121.9403 105.2474) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.1663 105.1027) (end 122.1409 105.123) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8801 104.0511) (end 122.8699 104.0867) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.2197 105.0646) (end 122.1943 105.0849) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.4153 104.8918) (end 122.3924 104.9147) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.2705 105.0239) (end 122.2451 105.0442) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6032 104.6658) (end 122.5854 104.6937) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.2451 105.0442) (end 122.2197 105.0646) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.3441 104.9579) (end 122.3213 104.9807) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5651 104.719101) (end 122.5448 104.7445) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6566 104.5845) (end 122.6388 104.612401) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6921 104.5286) (end 122.6743 104.5566) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7531 104.4092) (end 122.7378 104.4397) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8191 104.2518) (end 122.8064 104.2848) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7683 104.3788) (end 122.7531 104.4092) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8699 104.0867) (end 122.8623 104.1197) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.113 105.1408) (end 122.0851 105.1611) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.781 104.3483) (end 122.7683 104.3788) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.5288 105.4303) (end 121.4932 105.443) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8293 104.2213) (end 122.8191 104.2518) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8877 104.0155) (end 122.8801 104.0511) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.3924 104.9147) (end 122.3695 104.9376) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5854 104.6937) (end 122.5651 104.719101) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.6609 105.3795) (end 121.6279 105.3922) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.6939 105.3668) (end 121.6609 105.3795) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7074 104.498101) (end 122.6921 104.5286) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.4813 104.8207) (end 122.461 104.8436) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.7879 105.3236) (end 121.7574 105.3389) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.1409 105.123) (end 122.113 105.1408) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.2959 105.0011) (end 122.2705 105.0239) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.3213 104.9807) (end 122.2959 105.0011) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5042 104.795301) (end 122.4813 104.8207) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.7378 104.4397) (end 122.7226 104.4702) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.842 104.188301) (end 122.8293 104.2213) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.7244 105.3541) (end 121.6939 105.3668) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.5618 105.4176) (end 121.5288 105.4303) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.461 104.8436) (end 122.4381 104.8664) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.9098 105.2627) (end 121.8819 105.2779) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.8623 104.1197) (end 122.8521 104.1527) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.0571 105.1789) (end 122.0292 105.1966) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.6388 104.612401) (end 122.621 104.6404) (layer Eco1.User) (width 0.5))
  (gr_line (start 121.8184 105.3084) (end 121.7879 105.3236) (layer Eco1.User) (width 0.5))
  (gr_line (start 122.5448 104.7445) (end 122.5245 104.7699) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1151 106.1822) (end 108.1201 106.1339) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.176 105.4633) (end 108.1786 105.4151) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1709 105.5116) (end 108.176 105.4633) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0643 106.7079) (end 108.0693 106.6597) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1024 106.3244) (end 108.1074 106.2787) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0922 106.4209) (end 108.0973 106.3727) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0795 106.5657) (end 108.0846 106.5174) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2776 103.3729) (end 108.2802 103.3043) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2548 103.9216) (end 108.2573 103.853) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2446 104.1273) (end 108.2471 104.0587) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2675 103.5787) (end 108.27 103.5101) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1328 105.9891) (end 108.1379 105.9434) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1938 105.1535) (end 108.1989 105.0849) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1506 105.7986) (end 108.1532 105.7504) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1074 106.2787) (end 108.1125 106.2304) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0693 106.6597) (end 108.0744 106.614) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0871 106.4692) (end 108.0922 106.4209) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2598 103.7844) (end 108.2624 103.7158) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2471 104.0587) (end 108.2522 103.9901) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2421 104.1959) (end 108.2446 104.1273) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0744 106.614) (end 108.0795 106.5657) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0592 106.7562) (end 108.0643 106.7079) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2395 104.2645) (end 108.2421 104.1959) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.237 104.333) (end 108.2395 104.2645) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.209 104.8817) (end 108.2116 104.8131) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1989 105.0849) (end 108.2014 105.0163) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1913 105.222) (end 108.1938 105.1535) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1659 105.6056) (end 108.1684 105.5599) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0541 106.8045) (end 108.0592 106.7562) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1455 105.8469) (end 108.1506 105.7986) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1201 106.1339) (end 108.1252 106.0856) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0516 106.8527) (end 108.0541 106.8045) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1532 105.7504) (end 108.1582 105.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2294 104.4702) (end 108.2319 104.4016) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2217 104.6074) (end 108.2268 104.5388) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0973 106.3727) (end 108.1024 106.3244) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2116 104.8131) (end 108.2167 104.7445) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2065 104.9477) (end 108.209 104.8817) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1684 105.5599) (end 108.1709 105.5116) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1608 105.6538) (end 108.1659 105.6056) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0846 106.5174) (end 108.0871 106.4692) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2014 105.0163) (end 108.2065 104.9477) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1836 105.3186) (end 108.1887 105.2703) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1582 105.7021) (end 108.1608 105.6538) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1786 105.4151) (end 108.1811 105.3668) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1278 106.0374) (end 108.1328 105.9891) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2827 103.2358) (end 108.2852 103.1672) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2802 103.3043) (end 108.2827 103.2358) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2725 103.4415) (end 108.2776 103.3729) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.27 103.5101) (end 108.2725 103.4415) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2649 103.6472) (end 108.2675 103.5787) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2624 103.7158) (end 108.2649 103.6472) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2573 103.853) (end 108.2598 103.7844) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2522 103.9901) (end 108.2548 103.9216) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2319 104.4016) (end 108.237 104.333) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2268 104.5388) (end 108.2294 104.4702) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1379 105.9434) (end 108.1405 105.8951) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1887 105.2703) (end 108.1913 105.222) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1405 105.8951) (end 108.1455 105.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1125 106.2304) (end 108.1151 106.1822) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2192 104.6759) (end 108.2217 104.6074) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1252 106.0856) (end 108.1278 106.0374) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1811 105.3668) (end 108.1836 105.3186) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2167 104.7445) (end 108.2192 104.6759) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.1852 93.9368) (end 90.2538 93.9165) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.9109 94.0232) (end 89.9795 94.0029) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.7341 94.7141) (end 87.8001 94.6937) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.8448 94.046) (end 89.9109 94.0232) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.5045 94.1527) (end 89.5705 94.1324) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.0955 94.2823) (end 89.1641 94.2619) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.7552 94.3915) (end 88.8212 94.3686) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.3462 94.521) (end 88.4148 94.4982) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.1405 94.5845) (end 88.2091 94.5642) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.9373 94.6506) (end 88.0059 94.6277) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.6391 94.1095) (end 89.7077 94.0892) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.4809 94.4778) (end 88.5494 94.455) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.7262 93.7666) (end 90.792299 93.7463) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.0059 94.6277) (end 88.0745 94.6074) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.0615 93.6625) (end 91.127499 93.6422) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.9929 93.6828) (end 91.0615 93.6625) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.2777 94.5413) (end 88.3462 94.521) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.6655 94.7369) (end 87.7341 94.7141) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.048 93.98) (end 90.1166 93.9597) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.6602 93.7895) (end 90.7262 93.7666) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.591599 93.8098) (end 90.6602 93.7895) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.8001 94.6937) (end 87.8687 94.6709) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.9269 93.7057) (end 90.9929 93.6828) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.457 93.853) (end 90.525599 93.8301) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.3198 93.8936) (end 90.3884 93.8733) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.2538 93.9165) (end 90.3198 93.8936) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.027 94.3051) (end 89.0955 94.2823) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.6866 94.4118) (end 88.7552 94.3915) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.2091 94.5642) (end 88.2777 94.5413) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.1166 93.9597) (end 90.1852 93.9368) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.9795 94.0029) (end 90.048 93.98) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.2302 94.2391) (end 89.2987 94.2188) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.1641 94.2619) (end 89.2302 94.2391) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.618 94.4347) (end 88.6866 94.4118) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.4148 94.4982) (end 88.4809 94.4778) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.8687 94.6709) (end 87.9373 94.6506) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.8212 94.3686) (end 88.8898 94.3483) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.4359 94.1756) (end 89.5045 94.1527) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.8898 94.3483) (end 88.9584 94.3254) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.5705 94.1324) (end 89.6391 94.1095) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.9584 94.3254) (end 89.027 94.3051) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.0745 94.6074) (end 88.1405 94.5845) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.5494 94.455) (end 88.618 94.4347) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.860799 93.726) (end 90.9269 93.7057) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.2987 94.2188) (end 89.3673 94.1959) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.3884 93.8733) (end 90.457 93.853) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.792299 93.7463) (end 90.860799 93.726) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.3673 94.1959) (end 89.4359 94.1756) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.7763 94.0664) (end 89.8448 94.046) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.7077 94.0892) (end 89.7763 94.0664) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.525599 93.8301) (end 90.591599 93.8098) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0679 95.2398) (end 86.0882 95.2348) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3973 95.4303) (end 85.4176 95.4253) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.951 95.2754) (end 85.9713 95.2703) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.3937 94.8233) (end 87.4598 94.8004) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1085 95.2271) (end 86.1263 95.2221) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.852 95.3033) (end 85.8723 95.2983) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4379 95.4202) (end 85.4557 95.4151) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.5969 94.7572) (end 87.6655 94.7369) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.5284 94.7801) (end 87.5969 94.7572) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.4598 94.8004) (end 87.5284 94.7801) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.3252 94.8436) (end 87.3937 94.8233) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.2566 94.8665) (end 87.3252 94.8436) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.1194 94.9096) (end 87.188 94.8868) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.7105 95.0392) (end 86.7791 95.0163) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.5073 95.1027) (end 86.5759 95.0824) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1466 95.217) (end 86.1669 95.2094) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5954 95.377) (end 85.6157 95.3719) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.476 95.41) (end 85.4964 95.4049) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1263 95.2221) (end 86.1466 95.217) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6538 95.3592) (end 85.6742 95.3541) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4557 95.4151) (end 85.476 95.41) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9307 95.2805) (end 85.951 95.2754) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.9848 94.9528) (end 87.0508 94.93) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7326 95.3389) (end 85.7529 95.3313) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0882 95.2348) (end 86.1085 95.2271) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9713 95.2703) (end 85.9891 95.2627) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4176 95.4253) (end 85.4379 95.4202) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7732 95.3262) (end 85.7935 95.3211) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.4387 95.1255) (end 86.5073 95.1027) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5751 95.3821) (end 85.5954 95.377) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.188 94.8868) (end 87.2566 94.8665) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0501 95.2475) (end 86.0679 95.2398) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.377 95.4354) (end 85.3973 95.4303) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.0508 94.93) (end 87.1194 94.9096) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.8476 94.996) (end 86.9162 94.9731) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1669 95.2094) (end 86.2355 95.189) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0298 95.2525) (end 86.0501 95.2475) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7935 95.3211) (end 85.8139 95.316) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9104 95.2881) (end 85.9307 95.2805) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7529 95.3313) (end 85.7732 95.3262) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4964 95.4049) (end 85.5167 95.3973) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3592 95.443) (end 85.377 95.4354) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8139 95.316) (end 85.8316 95.311) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6945 95.3491) (end 85.7148 95.344) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.9162 94.9731) (end 86.9848 94.9528) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8926 95.2932) (end 85.9104 95.2881) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.7791 95.0163) (end 86.8476 94.996) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9891 95.2627) (end 86.0094 95.2576) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6742 95.3541) (end 85.6945 95.3491) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.2355 95.189) (end 86.3015 95.1662) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5167 95.3973) (end 85.537 95.3922) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.6444 95.0595) (end 86.7105 95.0392) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.3701 95.1459) (end 86.4387 95.1255) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8316 95.311) (end 85.852 95.3033) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7148 95.344) (end 85.7326 95.3389) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.3015 95.1662) (end 86.3701 95.1459) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.537 95.3922) (end 85.5548 95.3872) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0094 95.2576) (end 86.0298 95.2525) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5548 95.3872) (end 85.5751 95.3821) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3389 95.4481) (end 85.3592 95.443) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8723 95.2983) (end 85.8926 95.2932) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6361 95.3668) (end 85.6538 95.3592) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.5759 95.0824) (end 86.6444 95.0595) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6157 95.3719) (end 85.6361 95.3668) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4481 95.725) (end 85.4303 95.7224) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.062 95.6945) (end 85.0442 95.692) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.902 95.5675) (end 84.9223 95.5624) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3186 95.4532) (end 85.3389 95.4481) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2982 95.4583) (end 85.3186 95.4532) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9452 95.6843) (end 84.9274 95.6843) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2779 95.4634) (end 85.2982 95.4583) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2601 95.4684) (end 85.2779 95.4634) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2398 95.4735) (end 85.2601 95.4684) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2195 95.4811) (end 85.2398 95.4735) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1408 95.5015) (end 85.1611 95.4964) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0214 95.5345) (end 85.0417 95.5294) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.029 95.692) (end 85.0112 95.6894) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2297 95.7072) (end 85.2119 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2627 95.7097) (end 85.2449 95.7097) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3287 95.7148) (end 85.3135 95.7148) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3795 95.7199) (end 85.3643 95.7174) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1992 95.4862) (end 85.2195 95.4811) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9096 95.6539) (end 84.9071 95.6386) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1789 95.4913) (end 85.1992 95.4862) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9071 95.6386) (end 84.9071 95.6259) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1611 95.4964) (end 85.1789 95.4913) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1966 95.7047) (end 85.1789 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9934 95.6894) (end 84.9782 95.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0417 95.5294) (end 85.062 95.5243) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1458 95.6996) (end 85.1281 95.6996) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9807 95.5446) (end 85.0011 95.5396) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2957 95.7123) (end 85.2805 95.7123) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9426 95.5573) (end 84.963 95.5523) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9045 95.5954) (end 84.9045 95.5827) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3135 95.7148) (end 85.2957 95.7123) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9071 95.6107) (end 84.9045 95.5954) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9096 95.6691) (end 84.9096 95.6539) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0442 95.692) (end 85.029 95.692) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9782 95.6869) (end 84.9604 95.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1128 95.697) (end 85.095 95.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0773 95.6945) (end 85.062 95.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1204 95.5065) (end 85.1408 95.5015) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9071 95.6259) (end 84.9071 95.6107) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.062 95.5243) (end 85.0798 95.5192) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9122 95.6818) (end 84.9096 95.6691) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0112 95.6894) (end 84.9934 95.6894) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1281 95.6996) (end 85.1128 95.697) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1789 95.7021) (end 85.1611 95.7021) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1001 95.5116) (end 85.1204 95.5065) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0798 95.5192) (end 85.1001 95.5116) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9223 95.5624) (end 84.9426 95.5573) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4125 95.7224) (end 85.3973 95.7199) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4303 95.7224) (end 85.4125 95.7224) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0011 95.5396) (end 85.0214 95.5345) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.963 95.5523) (end 84.9807 95.5446) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9045 95.5827) (end 84.902 95.5675) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3973 95.7199) (end 85.3795 95.7199) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9274 95.6843) (end 84.9122 95.6818) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.095 95.697) (end 85.0773 95.6945) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2119 95.7072) (end 85.1966 95.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2449 95.7097) (end 85.2297 95.7072) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4633 95.725) (end 85.4481 95.725) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9604 95.6869) (end 84.9452 95.6843) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2805 95.7123) (end 85.2627 95.7097) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3465 95.7174) (end 85.3287 95.7148) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1611 95.7021) (end 85.1458 95.6996) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4811 95.7275) (end 85.4633 95.725) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3643 95.7174) (end 85.3465 95.7174) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.8027 95.7783) (end 87.6884 95.7758) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.2101 95.7555) (end 86.0983 95.7555) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.143 95.7809) (end 88.0313 95.7809) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.0549 95.7936) (end 88.9406 95.7936) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.5096 95.7986) (end 89.3953 95.7986) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.3716 95.7859) (end 88.2573 95.7834) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.712 95.7885) (end 88.6002 95.7885) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5472 95.7326) (end 85.5319 95.7301) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5319 95.7301) (end 85.5141 95.7301) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5649 95.7326) (end 85.5472 95.7326) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9332 95.7529) (end 85.9155 95.7504) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.348 95.7707) (end 87.2337 95.7707) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8494 95.7504) (end 85.8316 95.7478) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.8934 95.7656) (end 86.7791 95.7631) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.0313 95.7809) (end 87.917 95.7783) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.9406 95.7936) (end 88.8263 95.791) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.4859 95.7859) (end 88.3716 95.7859) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5802 95.7351) (end 85.5649 95.7326) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8164 95.7478) (end 85.7986 95.7478) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8316 95.7478) (end 85.8164 95.7478) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.8263 95.791) (end 88.712 95.7885) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.1667 95.7961) (end 89.0549 95.7936) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4964 95.7275) (end 85.4811 95.7275) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7148 95.7428) (end 85.6996 95.7428) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7478 95.7453) (end 85.7326 95.7428) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.631 95.7377) (end 85.6157 95.7377) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.664 95.7402) (end 85.6488 95.7402) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.4387 95.758) (end 86.3244 95.758) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.281 95.7961) (end 89.1667 95.7961) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.0077 95.7656) (end 86.8934 95.7656) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.6884 95.7758) (end 87.5766 95.7732) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.3953 95.7986) (end 89.281 95.7961) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.7791 95.7631) (end 86.6648 95.7631) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7986 95.7478) (end 85.7834 95.7453) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8672 95.7504) (end 85.8494 95.7504) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.2573 95.7834) (end 88.143 95.7809) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8824 95.7504) (end 85.8672 95.7504) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.6213 95.8012) (end 89.5096 95.7986) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.3244 95.758) (end 86.2101 95.7555) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.553 95.7605) (end 86.4387 95.758) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.6002 95.7885) (end 88.4859 95.7859) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9663 95.7529) (end 85.951 95.7529) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.6648 95.7631) (end 86.553 95.7605) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.8499 95.8037) (end 89.7356 95.8037) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6996 95.7428) (end 85.6818 95.7402) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.4623 95.7732) (end 87.348 95.7707) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7834 95.7453) (end 85.7656 95.7453) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9155 95.7504) (end 85.9002 95.7504) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0983 95.7555) (end 85.984 95.7529) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.9002 95.7504) (end 85.8824 95.7504) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.984 95.7529) (end 85.9663 95.7529) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6157 95.7377) (end 85.598 95.7351) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5141 95.7301) (end 85.4964 95.7275) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7656 95.7453) (end 85.7478 95.7453) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7326 95.7428) (end 85.7148 95.7428) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.2337 95.7707) (end 87.122 95.7682) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.7356 95.8037) (end 89.6213 95.8012) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.951 95.7529) (end 85.9332 95.7529) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.122 95.7682) (end 87.0077 95.7656) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.917 95.7783) (end 87.8027 95.7783) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.598 95.7351) (end 85.5802 95.7351) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.5766 95.7732) (end 87.4623 95.7732) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6488 95.7402) (end 85.631 95.7377) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6818 95.7402) (end 85.664 95.7402) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.0785 95.8063) (end 89.9642 95.8063) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.1903 95.8088) (end 90.0785 95.8063) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.902 95.8393) (end 94.6962 95.8393) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.6449 95.8139) (end 90.5332 95.8113) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.897199 95.824) (end 91.782899 95.824) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.9256 95.8418) (end 95.7224 95.8418) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.2309 95.852) (end 100.0252 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.2139 95.819) (end 91.1021 95.8164) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.466099 95.8291) (end 92.351799 95.8266) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.149399 95.8317) (end 93.035099 95.8317) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.6726 95.8342) (end 93.4669 95.8342) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.2873 95.8367) (end 94.0816 95.8367) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.5332 95.8113) (end 90.4189 95.8113) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.9878 95.8164) (end 90.8735 95.8164) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.920799 95.8317) (end 92.806499 95.8317) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.0816 95.8367) (end 93.8758 95.8342) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.5901 95.8494) (end 98.3869 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.822 95.852) (end 99.6162 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.3046 95.8088) (end 90.1903 95.8088) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.9754 95.8469) (end 97.7722 95.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.0252 95.852) (end 99.822 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.1077 95.8393) (end 94.902 95.8393) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.261099 95.8317) (end 93.149399 95.8317) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.1575 95.8469) (end 96.9518 95.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.4189 95.8113) (end 90.3046 95.8088) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.7592 95.8139) (end 90.6449 95.8139) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.6962 95.8393) (end 94.4905 95.8367) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.746 95.8444) (end 96.5403 95.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.1021 95.8164) (end 90.9878 95.8164) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.7958 95.8494) (end 98.5901 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.668599 95.8215) (end 91.5568 95.8215) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.782899 95.824) (end 91.668599 95.8215) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.011499 95.8266) (end 91.897199 95.824) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.351799 95.8266) (end 92.237499 95.8266) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.580399 95.8291) (end 92.466099 95.8291) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.4669 95.8342) (end 93.261099 95.8317) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.692199 95.8291) (end 92.580399 95.8291) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.5403 95.8444) (end 96.3371 95.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.035099 95.8317) (end 92.920799 95.8317) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.3109 95.8393) (end 95.1077 95.8393) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.9518 95.8444) (end 96.746 95.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.6162 95.852) (end 99.4105 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.3371 95.8444) (end 96.1313 95.8418) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.5664 95.8469) (end 97.3607 95.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.4905 95.8367) (end 94.2873 95.8367) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.5167 95.8418) (end 95.3109 95.8393) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.3282 95.819) (end 91.2139 95.819) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.237499 95.8266) (end 92.123199 95.8266) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.7722 95.8469) (end 97.5664 95.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.123199 95.8266) (end 92.011499 95.8266) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.4105 95.8494) (end 99.2047 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.806499 95.8317) (end 92.692199 95.8291) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.8758 95.8342) (end 93.6726 95.8342) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.1313 95.8418) (end 95.9256 95.8418) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.3607 95.8469) (end 97.1575 95.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.5568 95.8215) (end 91.4425 95.8215) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.2047 95.8494) (end 99.0015 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.8735 95.8164) (end 90.7592 95.8139) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.4425 95.8215) (end 91.3282 95.819) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.0015 95.8494) (end 98.7958 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.7224 95.8418) (end 95.5167 95.8418) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.1811 95.8469) (end 97.9754 95.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.9642 95.8063) (end 89.8499 95.8037) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.3869 95.8494) (end 98.1811 95.8469) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4793 95.8596) (end 106.459 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4006 95.8596) (end 106.3802 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7562 95.8545) (end 106.7358 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.4366 95.852) (end 100.2309 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.8717 95.8545) (end 101.666 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.3305 95.8571) (end 104.1247 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.558 95.8596) (end 106.5377 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5987 95.8596) (end 106.5784 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.9451 95.8571) (end 104.7419 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6165 95.8571) (end 106.5987 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0533 95.8494) (end 107.033 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.6398 95.852) (end 100.4366 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.8456 95.852) (end 100.6398 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.0513 95.852) (end 100.8456 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.4864 95.8545) (end 102.2807 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.3068 95.8571) (end 103.1011 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.9543 95.852) (end 106.934 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.2571 95.8545) (end 101.0513 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5784 95.8596) (end 106.558 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.934 95.852) (end 106.9136 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6368 95.8571) (end 106.6165 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.9136 95.852) (end 106.8933 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.7419 95.8571) (end 104.5362 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7968 95.8545) (end 106.7765 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8349 95.8545) (end 106.8146 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.9215 95.8571) (end 103.7158 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.5598 95.8596) (end 105.3566 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5377 95.8596) (end 106.5199 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.4603 95.8545) (end 101.2571 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.666 95.8545) (end 101.4603 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.0749 95.8545) (end 101.8717 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.2807 95.8545) (end 102.0749 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.6896 95.8545) (end 102.4864 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8933 95.852) (end 106.8755 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.8954 95.8545) (end 102.6896 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.9746 95.852) (end 106.9543 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.1011 95.8545) (end 102.8954 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.1509 95.8596) (end 104.9451 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.3566 95.8596) (end 105.1509 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.9713 95.8596) (end 105.7656 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.3802 95.8596) (end 106.177 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4412 95.8596) (end 106.4209 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6977 95.8571) (end 106.6774 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.9924 95.8494) (end 106.9746 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7765 95.8545) (end 106.7562 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7358 95.8571) (end 106.7155 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.459 95.8596) (end 106.4412 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.033 95.8494) (end 107.0127 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8755 95.852) (end 106.8552 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0127 95.8494) (end 106.9924 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.7158 95.8571) (end 103.51 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6774 95.8571) (end 106.6571 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4209 95.8596) (end 106.4006 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8552 95.852) (end 106.8349 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8146 95.8545) (end 106.7968 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.51 95.8571) (end 103.3068 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.1247 95.8571) (end 103.9215 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4996 95.8596) (end 106.4793 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.5362 95.8571) (end 104.3305 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.7656 95.8596) (end 105.5598 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.177 95.8596) (end 105.9713 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5199 95.8596) (end 106.4996 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6571 95.8571) (end 106.6368 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7155 95.8571) (end 106.6977 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5055 95.8571) (end 107.4851 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.049 96.0323) (end 108.0389 96.0222) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0846 96.0653) (end 108.0744 96.0552) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6045 95.8647) (end 107.5842 95.8621) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6426 95.8672) (end 107.6248 95.8647) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8204 95.9028) (end 107.8052 95.8977) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0711 95.8494) (end 107.0533 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8687 95.9206) (end 107.8534 95.9155) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0914 95.8494) (end 107.0711 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1118 95.8494) (end 107.0914 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8839 95.9282) (end 107.8687 95.9206) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0135 96.0018) (end 107.9982 95.9917) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1321 95.8494) (end 107.1118 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2692 95.8494) (end 107.2489 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.348 95.852) (end 107.3277 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1524 95.8494) (end 107.1321 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7188 95.8774) (end 107.6985 95.8748) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5842 95.8621) (end 107.5639 95.8621) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9449 95.9587) (end 107.9296 95.951) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1702 95.8494) (end 107.1524 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1379 96.1263) (end 108.1278 96.1136) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3277 95.8494) (end 107.3099 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4267 95.8545) (end 107.4064 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4851 95.8571) (end 107.4674 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8534 95.9155) (end 107.8382 95.9079) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5461 95.8596) (end 107.5258 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7696 95.8875) (end 107.7544 95.885) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9982 95.9917) (end 107.9855 95.9841) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5639 95.8621) (end 107.5461 95.8596) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6985 95.8748) (end 107.6807 95.8723) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7366 95.8799) (end 107.7188 95.8774) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7544 95.885) (end 107.7366 95.8799) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0389 96.0222) (end 108.0262 96.012) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1074 96.0882) (end 108.0947 96.078) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0617 96.0425) (end 108.049 96.0323) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9728 95.9739) (end 107.9576 95.9663) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1176 96.1009) (end 108.1074 96.0882) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6629 95.8698) (end 107.6426 95.8672) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1278 96.1136) (end 108.1176 96.1009) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1905 95.8494) (end 107.1702 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2108 95.8494) (end 107.1905 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2311 95.8494) (end 107.2108 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8382 95.9079) (end 107.8204 95.9028) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9855 95.9841) (end 107.9728 95.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2489 95.8494) (end 107.2311 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3683 95.852) (end 107.348 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0744 96.0552) (end 108.0617 96.0425) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9144 95.9434) (end 107.8992 95.9358) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.447 95.8545) (end 107.4267 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3886 95.852) (end 107.3683 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7874 95.8926) (end 107.7696 95.8875) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6807 95.8723) (end 107.6629 95.8698) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8052 95.8977) (end 107.7874 95.8926) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0947 96.078) (end 108.0846 96.0653) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9296 95.951) (end 107.9144 95.9434) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4064 95.852) (end 107.3886 95.852) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2896 95.8494) (end 107.2692 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8992 95.9358) (end 107.8839 95.9282) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3099 95.8494) (end 107.2896 95.8494) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5258 95.8596) (end 107.5055 95.8571) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6248 95.8647) (end 107.6045 95.8647) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0262 96.012) (end 108.0135 96.0018) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4674 95.8545) (end 107.447 95.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9576 95.9663) (end 107.9449 95.9587) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.0001) (end 108.2903 96.9874) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.713) (end 108.2929 96.7003) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1455 96.139) (end 108.1379 96.1263) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1557 96.1517) (end 108.1455 96.139) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1659 96.1669) (end 108.1557 96.1517) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1811 96.1949) (end 108.1735 96.1796) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1735 96.1796) (end 108.1659 96.1669) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2192 96.266) (end 108.2116 96.2508) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2776 96.4667) (end 108.2751 96.4489) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2827 96.5022) (end 108.2802 96.4844) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.5759) (end 108.2878 96.5556) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.6241) (end 108.2903 96.6114) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.6876) (end 108.2929 96.6749) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.8375) (end 108.2903 96.8248) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.8629) (end 108.2903 96.8502) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.9137) (end 108.2903 96.901) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.9518) (end 108.2903 96.9391) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1887 96.2076) (end 108.1811 96.1949) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1963 96.2228) (end 108.1887 96.2076) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.204 96.2381) (end 108.1963 96.2228) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2598 96.3803) (end 108.2548 96.3625) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.27 96.4311) (end 108.2675 96.4133) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.8121) (end 108.2903 96.7994) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.6622) (end 108.2903 96.6495) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2878 96.5378) (end 108.2852 96.52) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.7765) (end 108.2929 96.7638) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.8883) (end 108.2903 96.8756) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.0382) (end 108.2903 97.0255) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2268 96.2812) (end 108.2192 96.266) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2878 96.5556) (end 108.2878 96.5378) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.901) (end 108.2903 96.8883) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.237 96.3143) (end 108.2319 96.299) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2497 96.3473) (end 108.2446 96.3295) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.7003) (end 108.2929 96.6876) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.6495) (end 108.2903 96.6368) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.7511) (end 108.2929 96.7384) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.7257) (end 108.2929 96.713) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2116 96.2508) (end 108.204 96.2381) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2319 96.299) (end 108.2268 96.2812) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2548 96.3625) (end 108.2497 96.3473) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2675 96.4133) (end 108.2624 96.3955) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.6749) (end 108.2903 96.6622) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.7638) (end 108.2929 96.7511) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.7994) (end 108.2903 96.7892) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2446 96.3295) (end 108.237 96.3143) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2624 96.3955) (end 108.2598 96.3803) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2751 96.4489) (end 108.27 96.4311) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.9772) (end 108.2903 96.9645) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.9874) (end 108.2903 96.9772) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2802 96.4844) (end 108.2776 96.4667) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2852 96.52) (end 108.2827 96.5022) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.5937) (end 108.2903 96.5759) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.9645) (end 108.2903 96.9518) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.6114) (end 108.2903 96.5937) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 96.7384) (end 108.2929 96.7257) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.8248) (end 108.2903 96.8121) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.8502) (end 108.2903 96.8375) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.0128) (end 108.2903 97.0001) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.6368) (end 108.2903 96.6241) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.8756) (end 108.2903 96.8629) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.9264) (end 108.2903 96.9137) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.7892) (end 108.2903 96.7765) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.0255) (end 108.2903 97.0128) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 96.9391) (end 108.2903 96.9264) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3335 97.757) (end 108.331 97.7367) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.1753) (end 108.2903 97.1626) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3386 97.7976) (end 108.336 97.7773) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.0636) (end 108.2903 97.0509) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3538 97.9373) (end 108.3513 97.917) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3487 97.8967) (end 108.3462 97.8764) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.0763) (end 108.2903 97.0636) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.089) (end 108.2903 97.0763) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.1017) (end 108.2903 97.089) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.1271) (end 108.2903 97.1144) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2954 97.3633) (end 108.2954 97.3506) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.1398) (end 108.2903 97.1271) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.1626) (end 108.2903 97.1525) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3106 97.5538) (end 108.3081 97.5335) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3183 97.6351) (end 108.3183 97.6147) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 97.3023) (end 108.2929 97.2896) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.364 98.0186) (end 108.3614 97.9983) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.2007) (end 108.2903 97.188) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3462 97.8764) (end 108.3437 97.856) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 97.2896) (end 108.2929 97.2769) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.303 97.4547) (end 108.3005 97.4344) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 97.2769) (end 108.2929 97.2642) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.2261) (end 108.2903 97.2134) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.336 97.7773) (end 108.3335 97.757) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3284 97.7163) (end 108.3259 97.696) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.188) (end 108.2903 97.1753) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 97.2642) (end 108.2903 97.2515) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3716 98.0796) (end 108.3691 98.0592) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3005 97.4344) (end 108.2979 97.4141) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3437 97.856) (end 108.3411 97.8357) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3614 97.9983) (end 108.3589 97.978) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3691 98.0592) (end 108.3665 98.0389) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3411 97.8357) (end 108.3386 97.8154) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3665 98.0389) (end 108.364 98.0186) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3183 97.6147) (end 108.3157 97.5944) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 97.3125) (end 108.2929 97.3023) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.2134) (end 108.2903 97.2007) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3564 97.9576) (end 108.3538 97.9373) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.2515) (end 108.2903 97.2388) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 97.3252) (end 108.2929 97.3125) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2954 97.3379) (end 108.2929 97.3252) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2954 97.3506) (end 108.2954 97.3379) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2979 97.3887) (end 108.2954 97.376) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2979 97.4014) (end 108.2979 97.3887) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2979 97.4141) (end 108.2979 97.4014) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3056 97.4928) (end 108.303 97.475) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3208 97.6554) (end 108.3183 97.6351) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3081 97.5131) (end 108.3056 97.4928) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.331 97.7367) (end 108.3284 97.7163) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3233 97.6757) (end 108.3208 97.6554) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3741 98.0999) (end 108.3716 98.0796) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3589 97.978) (end 108.3564 97.9576) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.2388) (end 108.2903 97.2261) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3081 97.5335) (end 108.3081 97.5131) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.303 97.475) (end 108.303 97.4547) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3259 97.696) (end 108.3233 97.6757) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2954 97.376) (end 108.2954 97.3633) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3132 97.5741) (end 108.3106 97.5538) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3157 97.5944) (end 108.3132 97.5741) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3386 97.8154) (end 108.3386 97.7976) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3513 97.917) (end 108.3487 97.8967) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.0509) (end 108.2903 97.0382) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.1144) (end 108.2903 97.1017) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 97.1525) (end 108.2903 97.1398) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4072 99.6721) (end 108.4072 99.6366) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4199 98.9025) (end 108.4173 98.8695) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4122 98.5215) (end 108.4097 98.5012) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3767 98.1177) (end 108.3741 98.0999) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3792 98.138) (end 108.3767 98.1177) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.7374) (end 108.4173 98.7044) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4046 99.8042) (end 108.4046 99.7712) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3843 98.1989) (end 108.3818 98.1786) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3792 98.1583) (end 108.3792 98.138) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3818 98.1786) (end 108.3792 98.1583) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3868 98.2193) (end 108.3843 98.1989) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4046 98.4021) (end 108.4021 98.3818) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.8365) (end 108.4173 98.8035) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.2378) (end 108.4173 99.2048) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 99.3038) (end 108.4148 99.2708) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4122 99.4385) (end 108.4148 99.4054) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4097 99.5375) (end 108.4122 99.5045) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3945 98.3005) (end 108.3919 98.2802) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.6434) (end 108.4148 98.6231) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4021 99.8372) (end 108.4046 99.8042) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 98.6231) (end 108.4148 98.6028) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3995 98.3412) (end 108.397 98.3209) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.1718) (end 108.4173 99.1362) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.7704) (end 108.4173 98.7374) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4021 98.3818) (end 108.3995 98.3615) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.0702) (end 108.4173 99.0371) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 99.3699) (end 108.4148 99.3369) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4046 99.7712) (end 108.4046 99.7382) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4072 98.4402) (end 108.4046 98.4199) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4097 98.4809) (end 108.4072 98.4606) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 99.4054) (end 108.4148 99.3699) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 98.5622) (end 108.4122 98.5418) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 98.5825) (end 108.4148 98.5622) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.8695) (end 108.4173 98.8365) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.6638) (end 108.4173 98.6434) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.0041) (end 108.4173 98.9711) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.9381) (end 108.4199 98.9025) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3894 98.2396) (end 108.3868 98.2193) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 98.6028) (end 108.4148 98.5825) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3995 98.3615) (end 108.3995 98.3412) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.6841) (end 108.4173 98.6638) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.8035) (end 108.4173 98.7704) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.0371) (end 108.4173 99.0041) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.1362) (end 108.4173 99.1032) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3919 98.2599) (end 108.3894 98.2396) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3919 98.2802) (end 108.3919 98.2599) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4097 98.5012) (end 108.4097 98.4809) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4097 99.6036) (end 108.4097 99.5705) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4072 99.6366) (end 108.4097 99.6036) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.397 98.3209) (end 108.3945 98.3005) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4046 98.4199) (end 108.4046 98.4021) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4122 98.5418) (end 108.4122 98.5215) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4097 99.5705) (end 108.4097 99.5375) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.7044) (end 108.4173 98.6841) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 98.9711) (end 108.4173 98.9381) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.2048) (end 108.4173 99.1718) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 99.2708) (end 108.4173 99.2378) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4072 99.7052) (end 108.4072 99.6721) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4072 98.4606) (end 108.4072 98.4402) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4148 99.3369) (end 108.4148 99.3038) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4122 99.4715) (end 108.4122 99.4385) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4173 99.1032) (end 108.4173 99.0702) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4046 99.7382) (end 108.4072 99.7052) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4122 99.5045) (end 108.4122 99.4715) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.331 101.8667) (end 108.3335 101.7981) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3919 100.137) (end 108.3945 100.1039) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3259 102.0039) (end 108.3284 101.9353) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3132 102.3468) (end 108.3157 102.2782) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3081 102.4814) (end 108.3106 102.4128) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2852 103.1672) (end 108.2878 103.0986) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3995 99.9033) (end 108.4021 99.8703) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3995 99.9388) (end 108.3995 99.9033) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.397 100.0049) (end 108.3995 99.9719) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.397 100.0379) (end 108.397 100.0049) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3741 100.6373) (end 108.3767 100.6043) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3945 100.1039) (end 108.3945 100.0709) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3919 100.17) (end 108.3919 100.137) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3538 101.1809) (end 108.3564 101.1123) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3437 101.4552) (end 108.3462 101.3866) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3818 100.4722) (end 108.3818 100.4367) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3005 102.7557) (end 108.303 102.6871) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3894 100.2055) (end 108.3919 100.17) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3157 102.2782) (end 108.3183 102.2096) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3818 100.4367) (end 108.3843 100.4037) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3665 100.838) (end 108.3691 100.805) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3843 100.4037) (end 108.3843 100.3706) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3868 100.2716) (end 108.3894 100.2386) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3284 101.9353) (end 108.331 101.8667) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.336 101.7295) (end 108.3386 101.661) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3894 100.2386) (end 108.3894 100.2055) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3843 100.3706) (end 108.3843 100.3376) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2929 102.9614) (end 108.2954 102.8929) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3691 100.805) (end 108.3691 100.772) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3183 102.2096) (end 108.3208 102.141) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.303 102.6871) (end 108.303 102.6185) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2954 102.8929) (end 108.2979 102.8243) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3208 102.141) (end 108.3233 102.0724) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2979 102.8243) (end 108.3005 102.7557) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3462 101.3866) (end 108.3487 101.3181) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3792 100.5053) (end 108.3818 100.4722) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3868 100.3046) (end 108.3868 100.2716) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3056 102.55) (end 108.3081 102.4814) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3843 100.3376) (end 108.3868 100.3046) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3792 100.5383) (end 108.3792 100.5053) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3767 100.5713) (end 108.3792 100.5383) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3767 100.6043) (end 108.3767 100.5713) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3716 100.7034) (end 108.3741 100.6704) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3716 100.7389) (end 108.3716 100.7034) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3691 100.772) (end 108.3716 100.7389) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3614 100.9752) (end 108.364 100.9066) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3411 101.5238) (end 108.3437 101.4552) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3589 101.0437) (end 108.3614 100.9752) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3335 101.7981) (end 108.336 101.7295) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3411 101.5924) (end 108.3411 101.5238) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 103.03) (end 108.2929 102.9614) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.303 102.6185) (end 108.3056 102.55) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2878 103.0986) (end 108.2903 103.03) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3564 101.1123) (end 108.3589 101.0437) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.364 100.9066) (end 108.3665 100.838) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3386 101.661) (end 108.3411 101.5924) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3741 100.6704) (end 108.3741 100.6373) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3513 101.2495) (end 108.3538 101.1809) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3487 101.3181) (end 108.3513 101.2495) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3233 102.0724) (end 108.3259 102.0039) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3106 102.4128) (end 108.3132 102.3468) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4021 99.8703) (end 108.4021 99.8372) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3995 99.9719) (end 108.3995 99.9388) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3945 100.0709) (end 108.397 100.0379) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.5289 93.5177) (end 91.5949 93.4974) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.2027 92.9996) (end 93.268799 92.9792) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.5322 93.2053) (end 92.6007 93.185) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.466099 93.2282) (end 92.5322 93.2053) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.3282 93.5787) (end 91.394199 93.5584) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.1936 93.6219) (end 91.2622 93.6015) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.3084 92.3341) (end 95.3922 92.3087) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.9731 92.4408) (end 95.0569 92.4154) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.4067 92.6211) (end 94.4727 92.6008) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.0681 93.0402) (end 93.1341 93.0199) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.0714 92.7278) (end 94.1374 92.7075) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.7956 93.4339) (end 91.8641 93.4136) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.8707 92.7913) (end 93.9368 92.7684) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.0648 93.3526) (end 92.1308 93.3298) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.394199 93.5584) (end 91.4628 93.538) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.604 92.8751) (end 93.6701 92.8522) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.127499 93.6422) (end 91.1936 93.6219) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.476 92.2807) (end 95.5598 92.2553) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.3922 92.3087) (end 95.476 92.2807) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.2246 92.362) (end 95.3084 92.3341) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.1407 92.3874) (end 95.2246 92.362) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.0569 92.4154) (end 95.1407 92.3874) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.4727 92.6008) (end 94.5388 92.5805) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.1341 93.0199) (end 93.2027 92.9996) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.8893 92.4687) (end 94.9731 92.4408) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.6734 92.5373) (end 94.7394 92.517) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.206 92.6846) (end 94.2721 92.6643) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.8674 93.1037) (end 92.9335 93.0808) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.3381 92.644) (end 94.4067 92.6211) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.3315 93.2688) (end 92.3975 93.2485) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.5949 93.4974) (end 91.663499 93.4771) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.9962 93.3729) (end 92.0648 93.3526) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.1308 93.3298) (end 92.196899 93.3094) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.9368 92.7684) (end 94.0054 92.7481) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.3348 92.9564) (end 93.4034 92.9361) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.2622 93.6015) (end 91.3282 93.5787) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.2721 92.6643) (end 94.3381 92.644) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.1374 92.7075) (end 94.206 92.6846) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.3975 93.2485) (end 92.466099 93.2282) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.2655 93.2891) (end 92.3315 93.2688) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.9335 93.0808) (end 93.002099 93.0605) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.002099 93.0605) (end 93.0681 93.0402) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.732799 93.1443) (end 92.8014 93.124) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.196899 93.3094) (end 92.2655 93.2891) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.6007 93.185) (end 92.6668 93.1647) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.7295 93.4542) (end 91.7956 93.4339) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.808 92.4941) (end 94.8893 92.4687) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.7394 92.517) (end 94.808 92.4941) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.6073 92.5576) (end 94.6734 92.5373) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.5388 92.5805) (end 94.6073 92.5576) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.0054 92.7481) (end 94.0714 92.7278) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.8047 92.8116) (end 93.8707 92.7913) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.7361 92.8319) (end 93.8047 92.8116) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.6701 92.8522) (end 93.7361 92.8319) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.4694 92.9157) (end 93.535499 92.8954) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.4034 92.9361) (end 93.4694 92.9157) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.8641 93.4136) (end 91.930199 93.3933) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.8014 93.124) (end 92.8674 93.1037) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.930199 93.3933) (end 91.9962 93.3729) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.4628 93.538) (end 91.5289 93.5177) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.268799 92.9792) (end 93.3348 92.9564) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.663499 93.4771) (end 91.7295 93.4542) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.6668 93.1647) (end 92.732799 93.1443) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.535499 92.8954) (end 93.604 92.8751) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1831 75.9257) (end 114.1577 75.8774) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5921 76.7334) (end 114.5692 76.6851) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8029 77.2236) (end 114.7826 77.1728) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6352 76.8325) (end 114.6124 76.7817) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2339 76.0197) (end 114.2085 75.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.333 76.2102) (end 114.3076 76.1619) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6581 76.8807) (end 114.6352 76.8325) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4041 76.3524) (end 114.3812 76.3041) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0543 77.9831) (end 115.0416 77.9323) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1323 75.8317) (end 114.1069 75.7834) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2822 76.1136) (end 114.2568 76.0679) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3076 76.1619) (end 114.2822 76.1136) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6124 76.7817) (end 114.5921 76.7334) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9807 77.7265) (end 114.9654 77.6757) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6784 76.929) (end 114.6581 76.8807) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9654 77.6757) (end 114.9477 77.6249) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5692 76.6851) (end 114.5463 76.6394) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9477 77.6249) (end 114.9324 77.5741) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.841 77.3227) (end 114.8232 77.2719) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8791 77.4217) (end 114.8613 77.3709) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0561 75.6895) (end 114.0333 75.6437) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1069 75.7834) (end 114.0815 75.7377) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1577 75.8774) (end 114.1323 75.8317) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2085 75.9739) (end 114.1831 75.9257) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2568 76.0679) (end 114.2339 76.0197) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3558 76.2559) (end 114.333 76.2102) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4295 76.3981) (end 114.4041 76.3524) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9324 77.5741) (end 114.9146 77.5233) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9959 77.7773) (end 114.9807 77.7265) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4524 76.4464) (end 114.4295 76.3981) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4752 76.4946) (end 114.4524 76.4464) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7216 77.0255) (end 114.7013 76.9772) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7419 77.0763) (end 114.7216 77.0255) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0112 77.8281) (end 114.9959 77.7773) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0823 78.0872) (end 115.0696 78.0364) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8232 77.2719) (end 114.8029 77.2236) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7826 77.1728) (end 114.7622 77.1246) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9146 77.5233) (end 114.8969 77.4725) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0416 77.9323) (end 115.0264 77.8789) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0264 77.8789) (end 115.0112 77.8281) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0924 78.1406) (end 115.0823 78.0872) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5235 76.5912) (end 114.5006 76.5429) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8969 77.4725) (end 114.8791 77.4217) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8613 77.3709) (end 114.841 77.3227) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0815 75.7377) (end 114.0561 75.6895) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3812 76.3041) (end 114.3558 76.2559) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5006 76.5429) (end 114.4752 76.4946) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0696 78.0364) (end 115.0543 77.9831) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5463 76.6394) (end 114.5235 76.5912) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7013 76.9772) (end 114.6784 76.929) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7622 77.1246) (end 114.7419 77.0763) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2271 78.9305) (end 115.222 78.8949) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.128 78.3006) (end 115.1178 78.2472) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4658 80.0405) (end 115.4582 80.0075) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1737 78.5698) (end 115.1661 78.5139) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2398 78.9965) (end 115.2347 78.9635) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5014 80.2107) (end 115.4963 80.1751) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.316 79.3674) (end 115.3083 79.3344) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2728 79.1667) (end 115.2652 79.1312) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3541 79.535) (end 115.3464 79.502) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3998 79.7382) (end 115.3922 79.7052) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4226 79.8398) (end 115.415 79.8043) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4455 79.9389) (end 115.4379 79.9059) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.194 78.7248) (end 115.1915 78.6917) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2601 79.0981) (end 115.2525 79.0651) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3845 79.6696) (end 115.3769 79.6366) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1382 78.3539) (end 115.128 78.3006) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4379 79.9059) (end 115.4303 79.8728) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1483 78.4073) (end 115.1382 78.3539) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1559 78.4606) (end 115.1483 78.4073) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1661 78.5139) (end 115.1559 78.4606) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2347 78.9635) (end 115.2271 78.9305) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4734 80.0735) (end 115.4658 80.0405) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4074 79.7712) (end 115.3998 79.7382) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.542 80.4113) (end 115.5369 80.3783) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2169 78.8619) (end 115.2118 78.8289) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1915 78.6917) (end 115.1864 78.6587) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4582 80.0075) (end 115.4531 79.9744) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5293 80.3453) (end 115.5217 80.3097) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1991 78.7603) (end 115.194 78.7248) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2042 78.7933) (end 115.1991 78.7603) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2118 78.8289) (end 115.2042 78.7933) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3007 79.3013) (end 115.2931 79.2658) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3083 79.3344) (end 115.3007 79.3013) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3236 79.4004) (end 115.316 79.3674) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3617 79.5706) (end 115.3541 79.535) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.415 79.8043) (end 115.4074 79.7712) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3464 79.502) (end 115.3388 79.469) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5217 80.3097) (end 115.5166 80.2767) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3693 79.6036) (end 115.3617 79.5706) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3922 79.7052) (end 115.3845 79.6696) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5369 80.3783) (end 115.5293 80.3453) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4811 80.1091) (end 115.4734 80.0735) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5166 80.2767) (end 115.509 80.2437) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5547 80.4799) (end 115.5496 80.4469) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4531 79.9744) (end 115.4455 79.9389) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4887 80.1421) (end 115.4811 80.1091) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2804 79.1997) (end 115.2728 79.1667) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3388 79.469) (end 115.3312 79.436) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.222 78.8949) (end 115.2169 78.8619) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2652 79.1312) (end 115.2601 79.0981) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3312 79.436) (end 115.3236 79.4004) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3769 79.6366) (end 115.3693 79.6036) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4303 79.8728) (end 115.4226 79.8398) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.509 80.2437) (end 115.5014 80.2107) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5496 80.4469) (end 115.542 80.4113) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2931 79.2658) (end 115.288 79.2328) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1813 78.6232) (end 115.1737 78.5698) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1864 78.6587) (end 115.1813 78.6232) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2474 79.0296) (end 115.2398 78.9965) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.288 79.2328) (end 115.2804 79.1997) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4963 80.1751) (end 115.4887 80.1421) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2525 79.0651) (end 115.2474 79.0296) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1051 78.1939) (end 115.0924 78.1406) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1178 78.2472) (end 115.1051 78.1939) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6944 82.4306) (end 115.6944 82.3976) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.669 81.6051) (end 115.6665 81.5721) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6817 81.9353) (end 115.6792 81.9023) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6817 81.9683) (end 115.6817 81.9353) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6995 82.5297) (end 115.697 82.4967) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.702 82.5957) (end 115.6995 82.5627) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6182 80.9168) (end 115.6131 80.8838) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5598 80.5129) (end 115.5547 80.4799) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.636 81.1124) (end 115.6335 81.0793) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6716 81.6712) (end 115.669 81.6381) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6385 81.1454) (end 115.636 81.1124) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6919 82.2985) (end 115.6919 82.2655) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6487 81.2775) (end 115.6462 81.2444) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6868 82.1665) (end 115.6868 82.1334) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.697 82.4967) (end 115.697 82.4636) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6589 81.407) (end 115.6563 81.374) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5827 80.6501) (end 115.5776 80.6145) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6106 80.8507) (end 115.6055 80.8177) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5674 80.5485) (end 115.5598 80.5129) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5725 80.5815) (end 115.5674 80.5485) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6131 80.8838) (end 115.6106 80.8507) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5776 80.6145) (end 115.5725 80.5815) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5877 80.6831) (end 115.5827 80.6501) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.669 81.6381) (end 115.669 81.6051) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6055 80.8177) (end 115.6004 80.7847) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6208 80.9498) (end 115.6182 80.9168) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6284 81.0133) (end 115.6233 80.9828) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6741 81.7702) (end 115.6741 81.7372) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6309 81.0463) (end 115.6284 81.0133) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6843 82.0344) (end 115.6817 82.0014) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6944 82.3976) (end 115.6944 82.3646) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6893 82.1995) (end 115.6868 82.1665) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6868 82.1334) (end 115.6868 82.1004) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6462 81.2444) (end 115.6436 81.2114) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6639 81.5391) (end 115.6639 81.5061) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6995 82.5627) (end 115.6995 82.5297) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6335 81.0793) (end 115.6309 81.0463) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6411 81.1784) (end 115.6385 81.1454) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6817 82.0014) (end 115.6817 81.9683) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6843 82.0674) (end 115.6843 82.0344) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6741 81.7372) (end 115.6716 81.7042) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6716 81.7042) (end 115.6716 81.6712) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6766 81.8363) (end 115.6766 81.8032) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6868 82.1004) (end 115.6843 82.0674) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6792 81.9023) (end 115.6792 81.8693) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6919 82.3316) (end 115.6919 82.2985) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5928 80.7187) (end 115.5877 80.6831) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5979 80.7517) (end 115.5928 80.7187) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6004 80.7847) (end 115.5979 80.7517) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6233 80.9828) (end 115.6208 80.9498) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6436 81.2114) (end 115.6411 81.1784) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6512 81.3105) (end 115.6487 81.2775) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6538 81.341) (end 115.6512 81.3105) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6563 81.374) (end 115.6538 81.341) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6614 81.473) (end 115.6589 81.44) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6639 81.5061) (end 115.6614 81.473) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6919 82.2655) (end 115.6893 82.2325) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6766 81.8032) (end 115.6741 81.7702) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6893 82.2325) (end 115.6893 82.1995) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.697 82.4636) (end 115.6944 82.4306) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6665 81.5721) (end 115.6639 81.5391) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6944 82.3646) (end 115.6919 82.3316) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6792 81.8693) (end 115.6766 81.8363) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6589 81.44) (end 115.6589 81.407) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7478 83.4822) (end 115.7452 83.439) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7554 83.6066) (end 115.7528 83.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7605 83.693) (end 115.7579 83.6498) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7757 83.9445) (end 115.7732 83.9013) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7859 84.1121) (end 115.7833 84.0715) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7681 83.8175) (end 115.7655 83.7768) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8367 84.9986) (end 115.8341 84.9554) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8113 84.5337) (end 115.8087 84.4931) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.824 84.7446) (end 115.8214 84.7014) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8494 85.2068) (end 115.8468 85.1662) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7376 83.312) (end 115.7351 83.2714) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7986 84.3229) (end 115.796 84.2823) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7528 83.566) (end 115.7503 83.5228) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8189 84.6607) (end 115.8163 84.6176) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8087 84.4931) (end 115.8062 84.4499) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7732 83.9013) (end 115.7706 83.8606) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.763 83.7336) (end 115.7605 83.693) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7071 82.7278) (end 115.7046 82.6948) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7122 82.8269) (end 115.7097 82.7938) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7325 83.2282) (end 115.73 83.1875) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7706 83.8606) (end 115.7681 83.8175) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7782 83.9876) (end 115.7757 83.9445) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8036 84.4067) (end 115.8011 84.3661) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7046 82.6618) (end 115.702 82.6287) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7122 82.8599) (end 115.7122 82.8269) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7147 82.8929) (end 115.7122 82.8599) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7198 82.9767) (end 115.7173 82.9335) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7249 83.0605) (end 115.7224 83.0174) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7808 84.0283) (end 115.7782 83.9876) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7274 83.1012) (end 115.7249 83.0605) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7452 83.439) (end 115.7427 83.3958) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7833 84.0715) (end 115.7808 84.0283) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.73 83.1875) (end 115.7274 83.1444) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7351 83.2714) (end 115.7325 83.2282) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7579 83.6498) (end 115.7554 83.6066) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8392 85.0392) (end 115.8367 84.9986) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7884 84.1553) (end 115.7859 84.1121) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8011 84.3661) (end 115.7986 84.3229) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7401 83.3552) (end 115.7376 83.312) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7655 83.7768) (end 115.763 83.7336) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7935 84.2391) (end 115.7909 84.1985) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.796 84.2823) (end 115.7935 84.2391) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8062 84.4499) (end 115.8036 84.4067) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8341 84.9122) (end 115.8316 84.8716) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8341 84.9554) (end 115.8341 84.9122) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8468 85.1662) (end 115.8443 85.123) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8265 84.7877) (end 115.824 84.7446) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8443 85.123) (end 115.8417 85.0824) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.702 82.6287) (end 115.702 82.5957) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7046 82.6948) (end 115.7046 82.6618) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8417 85.0824) (end 115.8392 85.0392) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7071 82.7608) (end 115.7071 82.7278) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8214 84.7014) (end 115.8189 84.6607) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7097 82.7938) (end 115.7071 82.7608) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7224 83.0174) (end 115.7198 82.9767) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8316 84.8716) (end 115.829 84.8284) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7909 84.1985) (end 115.7884 84.1553) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7427 83.3958) (end 115.7401 83.3552) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7503 83.5228) (end 115.7478 83.4822) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.829 84.8284) (end 115.8265 84.7877) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8138 84.5769) (end 115.8113 84.5337) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8163 84.6176) (end 115.8138 84.5769) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7173 82.9335) (end 115.7147 82.8929) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7274 83.1444) (end 115.7274 83.1012) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8011 85.9561) (end 115.8062 85.9485) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6182 86.0044) (end 115.6309 86.0044) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8722 85.6666) (end 115.8697 85.6539) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8519 85.25) (end 115.8494 85.2068) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.857 85.377) (end 115.857 85.3338) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.7301) (end 115.8697 85.7174) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8138 85.9409) (end 115.8189 85.9333) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8621 85.4608) (end 115.8595 85.4177) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.5878) (end 115.8671 85.5447) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5903 85.9993) (end 115.603 86.0019) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.6132) (end 115.8697 85.6005) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.6259) (end 115.8697 85.6132) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7732 85.979) (end 115.7808 85.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7655 85.9841) (end 115.7732 85.979) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7325 85.9993) (end 115.7427 85.9942) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6919 86.0069) (end 115.702 86.0044) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8468 85.8723) (end 115.8494 85.8647) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.824 85.9257) (end 115.8265 85.918) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8646 85.5015) (end 115.8621 85.4608) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8544 85.8444) (end 115.857 85.8317) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8189 85.9333) (end 115.824 85.9257) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8722 85.6793) (end 115.8722 85.6666) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8646 85.8012) (end 115.8646 85.7885) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.603 86.0019) (end 115.6182 86.0044) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8544 85.2932) (end 115.8519 85.25) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.6539) (end 115.8697 85.6386) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8062 85.9485) (end 115.8138 85.9409) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8671 85.7758) (end 115.8671 85.7656) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.857 85.3338) (end 115.8544 85.2932) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8443 85.8825) (end 115.8468 85.8723) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8595 85.4177) (end 115.857 85.377) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8671 85.5447) (end 115.8646 85.5015) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.796 85.9612) (end 115.8011 85.9561) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7427 85.9942) (end 115.7503 85.9917) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6436 86.0069) (end 115.6563 86.0069) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.6386) (end 115.8697 85.6259) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.692) (end 115.8722 85.6793) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8671 85.7656) (end 115.8697 85.7529) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.7529) (end 115.8697 85.7402) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8646 85.7885) (end 115.8671 85.7758) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8265 85.918) (end 115.8316 85.9104) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7884 85.9688) (end 115.796 85.9612) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7579 85.9866) (end 115.7655 85.9841) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8595 85.8215) (end 115.8621 85.8114) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.7047) (end 115.8697 85.692) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7808 85.9739) (end 115.7884 85.9688) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.6005) (end 115.8697 85.5878) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.7174) (end 115.8697 85.7047) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.857 85.8317) (end 115.8595 85.8215) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8697 85.7402) (end 115.8697 85.7301) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8316 85.9104) (end 115.8367 85.9003) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8621 85.8114) (end 115.8646 85.8012) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7503 85.9917) (end 115.7579 85.9866) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8519 85.8545) (end 115.8544 85.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.702 86.0044) (end 115.7122 86.0044) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.669 86.0069) (end 115.6817 86.0069) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8367 85.9003) (end 115.8392 85.8926) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8494 85.8647) (end 115.8519 85.8545) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.8392 85.8926) (end 115.8443 85.8825) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6563 86.0069) (end 115.669 86.0069) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7224 86.0019) (end 115.7325 85.9993) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6309 86.0044) (end 115.6436 86.0069) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.7122 86.0044) (end 115.7224 86.0019) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.6817 86.0069) (end 115.6919 86.0069) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.968 86.1746) (end 114.9781 86.167) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1966 86.0222) (end 115.2067 86.0146) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4557 85.9561) (end 115.476 85.9638) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4379 85.946) (end 115.4557 85.9561) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.575 85.9942) (end 115.5903 85.9993) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2753 85.979) (end 115.2855 85.9739) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9299 86.2025) (end 114.94 86.1974) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9121 86.2178) (end 114.9223 86.2101) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5598 85.9917) (end 115.575 85.9942) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3871 85.9409) (end 115.3972 85.9409) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9019 86.2228) (end 114.9121 86.2178) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.349 85.9485) (end 115.3591 85.946) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2194 86.0095) (end 115.2296 86.0019) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0924 86.0806) (end 115.1026 86.0755) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0721 86.0933) (end 115.0823 86.0882) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.034 86.1212) (end 115.0442 86.1136) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0061 86.1441) (end 115.0137 86.1365) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5446 85.9866) (end 115.5598 85.9917) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3185 85.9587) (end 115.3287 85.9561) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9223 86.2101) (end 114.9299 86.2025) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3287 85.9561) (end 115.3388 85.9511) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8918 86.2305) (end 114.9019 86.2228) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1128 86.0704) (end 115.1229 86.0628) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2398 85.9968) (end 115.2525 85.9917) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4303 85.9434) (end 115.4379 85.946) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1432 86.0527) (end 115.1534 86.0476) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0518 86.1085) (end 115.062 86.1009) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.94 86.1974) (end 114.9502 86.1898) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4226 85.9409) (end 115.4303 85.9434) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3972 85.9409) (end 115.4049 85.9409) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0442 86.1136) (end 115.0518 86.1085) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3795 85.9409) (end 115.3871 85.9409) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3058 85.9638) (end 115.3185 85.9587) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2067 86.0146) (end 115.2194 86.0095) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2525 85.9917) (end 115.2626 85.9841) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1636 86.04) (end 115.1737 86.0349) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1864 86.0273) (end 115.1966 86.0222) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.415 85.9409) (end 115.4226 85.9409) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3388 85.9511) (end 115.349 85.9485) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4049 85.9409) (end 115.415 85.9409) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2956 85.9688) (end 115.3058 85.9638) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2296 86.0019) (end 115.2398 85.9968) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1534 86.0476) (end 115.1636 86.04) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1229 86.0628) (end 115.1331 86.0577) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5115 85.9765) (end 115.5268 85.9815) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.476 85.9638) (end 115.4938 85.9688) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.5268 85.9815) (end 115.5446 85.9866) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9858 86.1593) (end 114.9959 86.1517) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9781 86.167) (end 114.9858 86.1593) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.4938 85.9688) (end 115.5115 85.9765) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3693 85.9434) (end 115.3795 85.9409) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.3591 85.946) (end 115.3693 85.9434) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9959 86.1517) (end 115.0061 86.1441) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2855 85.9739) (end 115.2956 85.9688) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1737 86.0349) (end 115.1864 86.0273) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1026 86.0755) (end 115.1128 86.0704) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0823 86.0882) (end 115.0924 86.0806) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9578 86.1822) (end 114.968 86.1746) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.2626 85.9841) (end 115.2753 85.979) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.062 86.1009) (end 115.0721 86.0933) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0239 86.1289) (end 115.034 86.1212) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.1331 86.0577) (end 115.1432 86.0527) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.9502 86.1898) (end 114.9578 86.1822) (layer Eco1.User) (width 0.5))
  (gr_line (start 115.0137 86.1365) (end 115.0239 86.1289) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7513 86.5353) (end 113.7716 86.5302) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8334 86.2635) (end 114.8435 86.2584) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.051 86.4616) (end 114.0739 86.4565) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9444 86.487) (end 113.9647 86.4819) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9012 86.4972) (end 113.9215 86.4921) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6853 86.5505) (end 113.7081 86.5454) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.874 86.2432) (end 114.8842 86.2355) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6218 86.5683) (end 113.6446 86.5632) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8638 86.2482) (end 114.874 86.2432) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8435 86.2584) (end 114.8537 86.2533) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5463 86.3422) (end 114.5667 86.3371) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.813 86.2711) (end 114.8232 86.266) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.78 86.2787) (end 114.8029 86.2736) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3101 86.4006) (end 114.3304 86.3956) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2238 86.421) (end 114.2441 86.4159) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.653 86.3143) (end 114.6733 86.3092) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8148 86.52) (end 113.8377 86.5124) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6962 86.3016) (end 114.7165 86.2965) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9647 86.4819) (end 113.9875 86.4768) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6733 86.3092) (end 114.6962 86.3016) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4168 86.3727) (end 114.4397 86.3676) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1374 86.4413) (end 114.1603 86.4362) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7285 86.5403) (end 113.7513 86.5353) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0739 86.4565) (end 114.0942 86.4514) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6446 86.5632) (end 113.665 86.5581) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8232 86.266) (end 114.8334 86.2635) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8029 86.2736) (end 114.813 86.2711) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7597 86.2863) (end 114.78 86.2787) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4397 86.3676) (end 114.46 86.3625) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9875 86.4768) (end 114.0079 86.4718) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8377 86.5124) (end 113.858 86.5073) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7165 86.2965) (end 114.7394 86.2914) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0079 86.4718) (end 114.0307 86.4667) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7945 86.5251) (end 113.8148 86.52) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2441 86.4159) (end 114.2669 86.4108) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6327 86.3194) (end 114.653 86.3143) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.7394 86.2914) (end 114.7597 86.2863) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8783 86.5022) (end 113.9012 86.4972) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.6098 86.3244) (end 114.6327 86.3194) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5895 86.3321) (end 114.6098 86.3244) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7716 86.5302) (end 113.7945 86.5251) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5032 86.3524) (end 114.5235 86.3473) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.665 86.5581) (end 113.6853 86.5505) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5667 86.3371) (end 114.5895 86.3321) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.4828 86.3575) (end 114.5032 86.3524) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3736 86.3854) (end 114.3965 86.3803) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2009 86.426) (end 114.2238 86.421) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.46 86.3625) (end 114.4828 86.3575) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1171 86.4464) (end 114.1374 86.4413) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3533 86.3905) (end 114.3736 86.3854) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1806 86.4311) (end 114.2009 86.426) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.858 86.5073) (end 113.8783 86.5022) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7081 86.5454) (end 113.7285 86.5403) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3304 86.3956) (end 114.3533 86.3905) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.3965 86.3803) (end 114.4168 86.3727) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.1603 86.4362) (end 114.1806 86.4311) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.5235 86.3473) (end 114.5463 86.3422) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2873 86.4057) (end 114.3101 86.4006) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.2669 86.4108) (end 114.2873 86.4057) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0307 86.4667) (end 114.051 86.4616) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9215 86.4921) (end 113.9444 86.487) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8842 86.2355) (end 114.8918 86.2305) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.8537 86.2533) (end 114.8638 86.2482) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0942 86.4514) (end 114.1171 86.4464) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7836 86.8121) (end 112.842 86.7943) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6667 86.8451) (end 112.7252 86.8274) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4889 86.8985) (end 112.5474 86.8807) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3137 86.9493) (end 112.3721 86.9315) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0775 87.0179) (end 112.1359 87.0026) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4882 87.1931) (end 111.5491 87.1753) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.843 87.3887) (end 110.9014 87.3709) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1961 87.282) (end 111.2545 87.2642) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5484 87.4776) (end 110.6093 87.4598) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1979 87.584301) (end 110.2563 87.5665) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3729 86.6394) (end 113.4313 86.6216) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7828 87.1068) (end 111.8412 87.089) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.5491 87.1753) (end 111.6076 87.1576) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3129 87.2465) (end 111.3713 87.2287) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.3147 87.5487) (end 110.3731 87.5309) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3721 86.9315) (end 112.4305 86.9137) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6083 86.8629) (end 112.6667 86.8451) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6015 86.5734) (end 113.6218 86.5683) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5786 86.581) (end 113.6015 86.5734) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5583 86.5861) (end 113.5786 86.581) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4305 86.9137) (end 112.4889 86.8985) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2527 86.9671) (end 112.3137 86.9493) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.666 87.1423) (end 111.7244 87.1245) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.538 86.5911) (end 113.5583 86.5861) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4313 86.6216) (end 113.4516 86.6165) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2535 86.6724) (end 113.3144 86.6572) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1366 86.708) (end 113.1951 86.6902) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0782 86.7258) (end 113.1366 86.708) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.1943 86.9848) (end 112.2527 86.9671) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9004 86.7766) (end 112.9614 86.7588) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.842 86.7943) (end 112.9004 86.7766) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.1359 87.0026) (end 112.1943 86.9848) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7252 86.8274) (end 112.7836 86.8121) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5474 86.8807) (end 112.6083 86.8629) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7846 87.4065) (end 110.843 87.3887) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.49 87.4954) (end 110.5484 87.4776) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.019 87.0356) (end 112.0775 87.0179) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7244 87.1245) (end 111.7828 87.1068) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9022 87.0712) (end 111.9606 87.0534) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.8412 87.089) (end 111.9022 87.0712) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6076 87.1576) (end 111.666 87.1423) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4315 87.5132) (end 110.49 87.4954) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.2563 87.5665) (end 110.3147 87.5487) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9599 87.3531) (end 111.0183 87.3354) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9014 87.3709) (end 110.9599 87.3531) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6093 87.4598) (end 110.6678 87.442) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1377 87.2998) (end 111.1961 87.282) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6678 87.442) (end 110.7262 87.4243) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5151 86.5988) (end 113.538 86.5911) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4516 86.6165) (end 113.4745 86.6089) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7262 87.4243) (end 110.7846 87.4065) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2545 87.2642) (end 111.3129 87.2465) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.3731 87.5309) (end 110.4315 87.5132) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9614 86.7588) (end 113.0198 86.7435) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4948 86.6038) (end 113.5151 86.5988) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0183 87.3354) (end 111.0767 87.3176) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9606 87.0534) (end 112.019 87.0356) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4745 86.6089) (end 113.4948 86.6038) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3144 86.6572) (end 113.3729 86.6394) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0767 87.3176) (end 111.1377 87.2998) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4298 87.2109) (end 111.4882 87.1931) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3713 87.2287) (end 111.4298 87.2109) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1951 86.6902) (end 113.2535 86.6724) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0198 86.7435) (end 113.0782 86.7258) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8179 88.3412) (end 107.8839 88.3209) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5631 88.7501) (end 106.6292 88.727301) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.6695 87.7468) (end 109.728 87.7291) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1394 87.6021) (end 110.1979 87.584301) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.081 87.6198) (end 110.1394 87.6021) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.3393 87.851001) (end 109.4054 87.8307) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.95 88.298) (end 108.016 88.2777) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.0226 87.637601) (end 110.081 87.6198) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.9642 87.6579) (end 110.0226 87.637601) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.431 88.7933) (end 106.4971 88.770501) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.9058 87.675701) (end 109.9642 87.6579) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.8448 87.6935) (end 109.9058 87.675701) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5537 88.4276) (end 107.6198 88.404701) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4877 88.4479) (end 107.5537 88.4276) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2235 88.534201) (end 107.2896 88.513901) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.9594 88.6206) (end 107.0254 88.6003) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4783 88.1278) (end 108.5443 88.105) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.082 88.2548) (end 108.1481 88.2345) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.7864 87.7113) (end 109.8448 87.6935) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.6764 88.0618) (end 108.7424 88.041501) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.016 88.2777) (end 108.082 88.2548) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.6035 87.7697) (end 109.6695 87.7468) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.9431 87.978) (end 109.0091 87.9577) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4971 88.770501) (end 106.5631 88.7501) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.728 87.7291) (end 109.7864 87.7113) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.0752 87.9348) (end 109.1412 87.9145) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8839 88.3209) (end 107.95 88.298) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.2329 88.856801) (end 106.299 88.834) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.5375 87.790001) (end 109.6035 87.7697) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4122 88.1482) (end 108.4783 88.1278) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4714 87.8103) (end 109.5375 87.790001) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4054 87.8307) (end 109.4714 87.8103) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7518 88.361501) (end 107.8179 88.3412) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2896 88.513901) (end 107.3556 88.4911) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6952 88.707) (end 106.7612 88.6841) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.2073 87.8942) (end 109.2733 87.8738) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.1412 87.9145) (end 109.2073 87.8942) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.0091 87.9577) (end 109.0752 87.9348) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.811 88.0212) (end 108.8771 87.9983) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1481 88.2345) (end 108.2141 88.2117) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.299 88.834) (end 106.365 88.8136) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6858 88.384401) (end 107.7518 88.361501) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4216 88.4707) (end 107.4877 88.4479) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.365 88.8136) (end 106.431 88.7933) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.1008 88.900001) (end 106.1669 88.877101) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6198 88.404701) (end 107.6858 88.384401) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.2733 87.8738) (end 109.3393 87.851001) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.8771 87.9983) (end 108.9431 87.978) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.7424 88.041501) (end 108.811 88.0212) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.6104 88.0847) (end 108.6764 88.0618) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2141 88.2117) (end 108.2802 88.191301) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.5443 88.105) (end 108.6104 88.0847) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3556 88.4911) (end 107.4216 88.4707) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3462 88.1685) (end 108.4122 88.1482) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0254 88.6003) (end 107.0914 88.5774) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8273 88.6638) (end 106.8933 88.6435) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2802 88.191301) (end 108.3462 88.1685) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1575 88.557101) (end 107.2235 88.534201) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7612 88.6841) (end 106.8273 88.6638) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.1669 88.877101) (end 106.2329 88.856801) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0914 88.5774) (end 107.1575 88.557101) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6292 88.727301) (end 106.6952 88.707) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.0348 88.9203) (end 106.1008 88.900001) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8933 88.6435) (end 106.9594 88.6206) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.2266 90.4316) (end 101.3079 90.4037) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.1265 89.8373) (end 103.2103 89.8093) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.5311 89.3978) (end 104.6149 89.3724) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.8367 88.9838) (end 105.9027 88.9635) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.9688 88.9406) (end 106.0348 88.9203) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.7056 89.6569) (end 103.7869 89.629) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.8964 90.5332) (end 100.9777 90.5078) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.9027 88.9635) (end 105.9688 88.9406) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.7706 89.0041) (end 105.8367 88.9838) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.4404 89.1108) (end 105.5065 89.0905) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.1102 89.215) (end 105.1915 89.1896) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.6149 89.3724) (end 104.6962 89.3445) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.2916 89.7839) (end 103.3754 89.7585) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.301 90.0938) (end 102.3823 90.0684) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.1359 90.1446) (end 102.2172 90.1192) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.8057 90.2487) (end 101.887 90.2233) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.5568 90.3275) (end 101.6406 90.2995) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.7046 89.027) (end 105.7706 89.0041) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.0358 89.5528) (end 104.1171 89.5274) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.6386 89.0473) (end 105.7046 89.027) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.1171 89.5274) (end 104.2009 89.502) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.5065 89.0905) (end 105.5725 89.0676) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.4661 90.043) (end 102.5474 90.0176) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.4567 89.7331) (end 103.5405 89.7077) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.3566 89.1362) (end 105.4404 89.1108) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.7125 89.9643) (end 102.7963 89.9389) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.9708 90.1979) (end 102.0521 90.1725) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.9777 90.5078) (end 101.0615 90.4824) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.8613 89.2937) (end 104.9451 89.2683) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.366 89.4486) (end 104.4498 89.4232) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.887 90.2233) (end 101.9708 90.1979) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.2847 89.474) (end 104.366 89.4486) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.952 89.5782) (end 104.0358 89.5528) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.2103 89.8093) (end 103.2916 89.7839) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.5405 89.7077) (end 103.6218 89.6823) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.8801 89.9135) (end 102.9614 89.8881) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.0452 89.8627) (end 103.1265 89.8373) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.5725 89.0676) (end 105.6386 89.0473) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.2009 89.502) (end 104.2847 89.474) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.2753 89.1642) (end 105.3566 89.1362) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.8707 89.6036) (end 103.952 89.5782) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.3754 89.7585) (end 103.4567 89.7331) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.7963 89.9389) (end 102.8801 89.9135) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.5474 90.0176) (end 102.6312 89.9897) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.1915 89.1896) (end 105.2753 89.1642) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.0264 89.2404) (end 105.1102 89.215) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.9451 89.2683) (end 105.0264 89.2404) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.3917 90.3783) (end 101.4755 90.3529) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.3079 90.4037) (end 101.3917 90.3783) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.78 89.3191) (end 104.8613 89.2937) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.6962 89.3445) (end 104.78 89.3191) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.4498 89.4232) (end 104.5311 89.3978) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.4755 90.3529) (end 101.5568 90.3275) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.7869 89.629) (end 103.8707 89.6036) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.9614 89.8881) (end 103.0452 89.8627) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.3823 90.0684) (end 102.4661 90.043) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.2172 90.1192) (end 102.301 90.0938) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.1428 90.457) (end 101.2266 90.4316) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.6218 89.6823) (end 103.7056 89.6569) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.0521 90.1725) (end 102.1359 90.1446) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.7219 90.2741) (end 101.8057 90.2487) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.6312 89.9897) (end 102.7125 89.9643) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.0615 90.4824) (end 101.1428 90.457) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.6406 90.2995) (end 101.7219 90.2741) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.7275 92.1995) (end 95.8088 92.1741) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.0709 90.7974) (end 100.1522 90.7694) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.8959 91.8235) (end 96.9797 91.7956) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.8126 90.5612) (end 100.8964 90.5332) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.3117 92.0115) (end 96.3955 91.9836) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.4793 91.9582) (end 96.5606 91.9302) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.7313 90.5866) (end 100.8126 90.5612) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.6475 90.612) (end 100.7313 90.5866) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.5662 90.6399) (end 100.6475 90.612) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.4011 90.6907) (end 100.4824 90.6653) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.8161 91.1987) (end 98.8999 91.1733) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.3173 90.7186) (end 100.4011 90.6907) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.9032 90.8507) (end 99.9871 90.8228) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.8966 91.4959) (end 97.9805 91.4705) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.5639 91.6051) (end 97.6477 91.5772) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.2327 91.0641) (end 99.3165 91.0387) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.9764 92.1207) (end 96.0602 92.0928) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.7356 90.9041) (end 99.8194 90.8761) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.5606 91.9302) (end 96.6444 91.9048) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.3165 91.0387) (end 99.4003 91.0107) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.3157 91.3613) (end 98.3996 91.3333) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.4003 91.0107) (end 99.4841 90.9828) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.6437 92.2274) (end 95.7275 92.1995) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.9797 91.7956) (end 97.0635 91.7677) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.2286 91.7143) (end 97.3124 91.6864) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.1522 90.7694) (end 100.236 90.744) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.9871 90.8228) (end 100.0709 90.7974) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.8194 90.8761) (end 99.9032 90.8507) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.3996 91.3333) (end 98.4834 91.3079) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.6444 91.9048) (end 96.7282 91.8769) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.0602 92.0928) (end 96.144 92.0648) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.4841 90.9828) (end 99.568 90.9574) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.7282 91.8769) (end 96.8121 91.8489) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.8926 92.1461) (end 95.9764 92.1207) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.6477 91.5772) (end 97.7315 91.5518) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.1514 91.092) (end 99.2327 91.0641) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.6518 90.9295) (end 99.7356 90.9041) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.2279 92.0394) (end 96.3117 92.0115) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.568 90.9574) (end 99.6518 90.9295) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.0676 91.1174) (end 99.1514 91.092) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.8088 92.1741) (end 95.8926 92.1461) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.9838 91.1454) (end 99.0676 91.1174) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.6485 91.252) (end 98.7323 91.2266) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.8999 91.1733) (end 98.9838 91.1454) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.5647 91.28) (end 98.6485 91.252) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.1481 91.4146) (end 98.2319 91.3892) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.4801 91.633) (end 97.5639 91.6051) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.4834 91.3079) (end 98.5647 91.28) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.1473 91.7397) (end 97.2286 91.7143) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.0643 91.4425) (end 98.1481 91.4146) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.3963 91.6584) (end 97.4801 91.633) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.144 92.0648) (end 96.2279 92.0394) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.5598 92.2553) (end 95.6437 92.2274) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.9805 91.4705) (end 98.0643 91.4425) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.2319 91.3892) (end 98.3157 91.3613) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.3124 91.6864) (end 97.3963 91.6584) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.7323 91.2266) (end 98.8161 91.1987) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.8154 91.5238) (end 97.8966 91.4959) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.7315 91.5518) (end 97.8154 91.5238) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.8121 91.8489) (end 96.8959 91.8235) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.3955 91.9836) (end 96.4793 91.9582) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.4824 90.6653) (end 100.5662 90.6399) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.236 90.744) (end 100.3173 90.7186) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.0635 91.7677) (end 97.1473 91.7397) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5075 74.7141) (end 113.4872 74.676) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9317 75.4558) (end 113.9113 75.4177) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5735 74.8233) (end 113.5507 74.7878) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9157 73.7718) (end 112.8903 73.7362) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1468 74.1324) (end 113.1239 74.0943) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7869 75.1942) (end 113.7666 75.1561) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6083 73.3095) (end 112.5829 73.2739) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2154 74.2391) (end 113.1925 74.2036) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6794 73.4162) (end 112.654 73.3806) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2382 74.2772) (end 113.2154 74.2391) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3754 74.4931) (end 113.3525 74.4576) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4414 74.6049) (end 113.4186 74.5668) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7023 73.4517) (end 112.6794 73.4162) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7252 73.4873) (end 112.7023 73.4517) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7963 73.594) (end 112.7734 73.5584) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0071 73.9165) (end 112.9842 73.8784) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.891 75.3796) (end 113.8707 75.344) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.8445 73.6651) (end 112.8217 73.6295) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7031 75.0443) (end 113.6827 75.0087) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.8217 73.6295) (end 112.7963 73.594) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6827 75.0087) (end 113.6599 74.9706) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9385 73.8073) (end 112.9157 73.7718) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1011 74.0588) (end 113.0782 74.0232) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8504 75.3059) (end 113.8301 75.2678) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1925 74.2036) (end 113.1697 74.168) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9842 73.8784) (end 112.9614 73.8429) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0325 73.9521) (end 113.0071 73.9165) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4186 74.5668) (end 113.3957 74.5312) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4872 74.676) (end 113.4643 74.6404) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5303 74.7497) (end 113.5075 74.7141) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6167 74.897) (end 113.5964 74.8614) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6396 74.9351) (end 113.6167 74.897) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7234 75.0824) (end 113.7031 75.0443) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9113 75.4177) (end 113.891 75.3796) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8301 75.2678) (end 113.8072 75.2323) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0079 75.5955) (end 113.9825 75.5498) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9571 75.504) (end 113.9317 75.4558) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0554 73.9877) (end 113.0325 73.9521) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.6599 74.9706) (end 113.6396 74.9351) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1697 74.168) (end 113.1468 74.1324) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7462 75.1205) (end 113.7234 75.0824) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8707 75.344) (end 113.8504 75.3059) (layer Eco1.User) (width 0.5))
  (gr_line (start 114.0333 75.6437) (end 114.0079 75.5955) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.6312 73.345) (end 112.6083 73.3095) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.654 73.3806) (end 112.6312 73.345) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7506 73.5228) (end 112.7252 73.4873) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5507 74.7878) (end 113.5303 74.7497) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.284 74.3483) (end 113.2611 74.3128) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.9614 73.8429) (end 112.9385 73.8073) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.1239 74.0943) (end 113.1011 74.0588) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3068 74.3839) (end 113.284 74.3483) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3957 74.5312) (end 113.3754 74.4931) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.5964 74.8614) (end 113.5735 74.8233) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.7666 75.1561) (end 113.7462 75.1205) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.9825 75.5498) (end 113.9571 75.504) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.7734 73.5584) (end 112.7506 73.5228) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.2611 74.3128) (end 113.2382 74.2772) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3525 74.4576) (end 113.3297 74.422) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.8674 73.7006) (end 112.8445 73.6651) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.8072 75.2323) (end 113.7869 75.1942) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.8903 73.7362) (end 112.8674 73.7006) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.4643 74.6404) (end 113.4414 74.6049) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.0782 74.0232) (end 113.0554 73.9877) (layer Eco1.User) (width 0.5))
  (gr_line (start 113.3297 74.422) (end 113.3068 74.3839) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3897 83.9165) (end 75.377 83.9165) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6183 83.8683) (end 75.6056 83.8733) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7478 83.82) (end 75.7351 83.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6462 83.8581) (end 75.631 83.8632) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4176 83.914) (end 75.4049 83.9165) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4735 83.9064) (end 75.4608 83.9089) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6589 83.8556) (end 75.6462 83.8581) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5142 83.8987) (end 75.5015 83.9013) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.946 83.7438) (end 75.9333 83.7489) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4456 83.9114) (end 75.4329 83.9114) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4608 83.9089) (end 75.4456 83.9114) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6056 83.8733) (end 75.5929 83.8759) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.631 83.8632) (end 75.6183 83.8683) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8799 83.7667) (end 75.8647 83.7717) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6716 83.8505) (end 75.6589 83.8556) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8647 83.7717) (end 75.852 83.7768) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.1238 83.6854) (end 76.0857 83.6955) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.852 83.7768) (end 75.8393 83.7844) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7732 83.8098) (end 75.7605 83.8149) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8012 83.7997) (end 75.7859 83.8048) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.377 83.9165) (end 75.3618 83.9191) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4049 83.9165) (end 75.3897 83.9165) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.0857 83.6955) (end 76.0501 83.7082) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4329 83.9114) (end 75.4176 83.914) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.4862 83.9038) (end 75.4735 83.9064) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5269 83.8937) (end 75.5142 83.8987) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5396 83.8911) (end 75.5269 83.8937) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8393 83.7844) (end 75.8266 83.7895) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8926 83.7616) (end 75.8799 83.7667) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5548 83.8886) (end 75.5396 83.8911) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.697 83.8403) (end 75.6843 83.8454) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7097 83.8352) (end 75.697 83.8403) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7351 83.8251) (end 75.7224 83.8302) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.9053 83.7565) (end 75.8926 83.7616) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.9739 83.7336) (end 75.9612 83.7387) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7605 83.8149) (end 75.7478 83.82) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8266 83.7895) (end 75.8139 83.7946) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.9333 83.7489) (end 75.9206 83.7514) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.0501 83.7082) (end 76.012 83.7209) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.9206 83.7514) (end 75.9053 83.7565) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.012 83.7209) (end 75.9739 83.7336) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5802 83.881) (end 75.5675 83.8835) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.8139 83.7946) (end 75.8012 83.7997) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7859 83.8048) (end 75.7732 83.8098) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3618 83.9191) (end 75.3465 83.9191) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5015 83.9013) (end 75.4862 83.9038) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5675 83.8835) (end 75.5548 83.8886) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.9612 83.7387) (end 75.946 83.7438) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.5929 83.8759) (end 75.5802 83.881) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.6843 83.8454) (end 75.6716 83.8505) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.7224 83.8302) (end 75.7097 83.8352) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.7113 83.2129) (end 77.6732 83.2231) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.0135 83.124) (end 77.9754 83.1367) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.1253 83.091) (end 78.0897 83.1012) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.028 83.4085) (end 76.9899 83.4212) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.4065 83.2993) (end 77.3709 83.312) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.5698 82.9564) (end 78.5088 82.9742) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.1619 83.6727) (end 76.1238 83.6854) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.5208 83.2663) (end 77.4827 83.279) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.2 83.66) (end 76.1619 83.6727) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.5589 83.2561) (end 77.5208 83.2663) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.7849 83.1901) (end 77.7494 83.2028) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.8992 83.1571) (end 77.8611 83.1698) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.2355 83.6498) (end 76.2 83.66) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.2736 83.6371) (end 76.2355 83.6498) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.4616 83.5787) (end 76.426 83.5889) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.3117 83.6244) (end 76.2736 83.6371) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.1804 83.3653) (end 77.1423 83.3755) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.9162 83.4441) (end 76.8781 83.4542) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.3513 83.0224) (end 78.3158 83.0351) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.3498 83.6143) (end 76.3117 83.6244) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.3158 83.0351) (end 78.2777 83.0453) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.614 83.533) (end 76.5759 83.5431) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.3328 83.3222) (end 77.2947 83.3323) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.7257 83.5) (end 76.6876 83.5101) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.4827 83.279) (end 77.4446 83.2891) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.426 83.5889) (end 76.3879 83.6016) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.84 83.4644) (end 76.8019 83.4771) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.8611 83.1698) (end 77.823 83.1799) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.8781 83.4542) (end 76.84 83.4644) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.1423 83.3755) (end 77.1042 83.3882) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.2185 83.3552) (end 77.1804 83.3653) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.9754 83.1367) (end 77.9373 83.1469) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.0516 83.1139) (end 78.0135 83.124) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.2015 83.0682) (end 78.1634 83.0809) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.3894 83.0123) (end 78.3513 83.0224) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.3879 83.6016) (end 76.3498 83.6143) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.2396 83.058) (end 78.2015 83.0682) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.0661 83.3984) (end 77.028 83.4085) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.2777 83.0453) (end 78.2396 83.058) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.2566 83.345) (end 77.2185 83.3552) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.4504 82.9945) (end 78.3894 83.0123) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.4997 83.566) (end 76.4616 83.5787) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.4446 83.2891) (end 77.4065 83.2993) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.5378 83.5558) (end 76.4997 83.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.5759 83.5431) (end 76.5378 83.5558) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.6521 83.5203) (end 76.614 83.533) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.0897 83.1012) (end 78.0516 83.1139) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.6351 83.2358) (end 77.597 83.246) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.6876 83.5101) (end 76.6521 83.5203) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.1042 83.3882) (end 77.0661 83.3984) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.3709 83.312) (end 77.3328 83.3222) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.6732 83.2231) (end 77.6351 83.2358) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.823 83.1799) (end 77.7849 83.1901) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.1634 83.0809) (end 78.1253 83.091) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.5088 82.9742) (end 78.4504 82.9945) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.7638 83.4873) (end 76.7257 83.5) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.597 83.246) (end 77.5589 83.2561) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.7494 83.2028) (end 77.7113 83.2129) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.8019 83.4771) (end 76.7638 83.4873) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.6282 82.9386) (end 78.5698 82.9564) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.9899 83.4212) (end 76.9543 83.4314) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.9373 83.1469) (end 77.8992 83.1571) (layer Eco1.User) (width 0.5))
  (gr_line (start 76.9543 83.4314) (end 76.9162 83.4441) (layer Eco1.User) (width 0.5))
  (gr_line (start 77.2947 83.3323) (end 77.2566 83.345) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.9863 82.8294) (end 78.9279 82.8472) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.8489 81.9429) (end 81.788 81.9607) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.1776 82.4586) (end 80.1192 82.4763) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.9279 82.8472) (end 78.867 82.865) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.0473 82.8091) (end 78.9863 82.8294) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.2861 82.7354) (end 79.2251 82.7557) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.7295 81.9785) (end 81.6686 81.9963) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.5223 82.6618) (end 79.4639 82.6821) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.6417 82.6262) (end 79.5832 82.644) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.822 82.5703) (end 79.761 82.5881) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.9414 82.5322) (end 79.8804 82.5525) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.9998 82.5144) (end 79.9414 82.5322) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.4773 82.3671) (end 80.4164 82.3849) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.0877 81.8693) (end 82.0267 81.8871) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.4458 81.7601) (end 82.3645 81.7855) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.1461 81.8515) (end 82.0877 81.8693) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.252 82.1258) (end 81.1911 82.1436) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.6102 82.0166) (end 81.5492 82.0344) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.1057 82.7913) (end 79.0473 82.8091) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.0717 82.1817) (end 81.0133 82.1995) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.6686 81.9963) (end 81.6102 82.0166) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.2386 82.4408) (end 80.1776 82.4586) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.7026 82.6059) (end 79.6417 82.6262) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.8355 82.2554) (end 80.7745 82.2731) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.2251 82.7557) (end 79.1667 82.7735) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.1192 82.4763) (end 80.0608 82.4967) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.788 81.9607) (end 81.7295 81.9785) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.7161 82.2935) (end 80.6551 82.3112) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.3445 82.7176) (end 79.2861 82.7354) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.3104 82.108) (end 81.252 82.1258) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.4029 82.6999) (end 79.3445 82.7176) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.5832 82.644) (end 79.5223 82.6618) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.9073 81.9252) (end 81.8489 81.9429) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.761 82.5881) (end 79.7026 82.6059) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.3645 81.7855) (end 82.2858 81.8083) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.297 82.423) (end 80.2386 82.4408) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.5357 82.3468) (end 80.4773 82.3671) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.6551 82.3112) (end 80.5967 82.329) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.5967 82.329) (end 80.5357 82.3468) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.7745 82.2731) (end 80.7161 82.2935) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.5492 82.0344) (end 81.4908 82.0522) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.9683 81.9048) (end 81.9073 81.9252) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.2071 81.8337) (end 82.1461 81.8515) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.9523 82.2173) (end 80.8939 82.2376) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.0608 82.4967) (end 79.9998 82.5144) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.0267 81.8871) (end 81.9683 81.9048) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.3579 82.4027) (end 80.297 82.423) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.1667 82.7735) (end 79.1057 82.7913) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.0133 82.1995) (end 80.9523 82.2173) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.4639 82.6821) (end 79.4029 82.6999) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.4908 82.0522) (end 81.4298 82.0699) (layer Eco1.User) (width 0.5))
  (gr_line (start 79.8804 82.5525) (end 79.822 82.5703) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.2858 81.8083) (end 82.2071 81.8337) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.6892 82.9208) (end 78.6282 82.9386) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.8939 82.2376) (end 80.8355 82.2554) (layer Eco1.User) (width 0.5))
  (gr_line (start 80.4164 82.3849) (end 80.3579 82.4027) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.4298 82.0699) (end 81.3714 82.0903) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.7476 82.9031) (end 78.6892 82.9208) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.8085 82.8827) (end 78.7476 82.9031) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.3714 82.0903) (end 81.3104 82.108) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.1326 82.1639) (end 81.0717 82.1817) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.5246 81.7372) (end 82.4458 81.7601) (layer Eco1.User) (width 0.5))
  (gr_line (start 78.867 82.865) (end 78.8085 82.8827) (layer Eco1.User) (width 0.5))
  (gr_line (start 81.1911 82.1436) (end 81.1326 82.1639) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2347 80.9168) (end 85.1535 80.9422) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.1171 81.2546) (end 84.0384 81.2775) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.4735 80.8457) (end 85.3922 80.8685) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.111 80.6526) (end 86.0298 80.678) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.4285 80.5586) (end 86.3498 80.5815) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.6335 80.7974) (end 85.5522 80.8203) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.8723 80.7263) (end 85.791 80.7491) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5972 81.1098) (end 84.5159 81.1327) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.2261 80.3173) (end 87.1474 80.3427) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.5436 80.2208) (end 87.4852 80.2411) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9147 81.0133) (end 84.836 81.0362) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.8273 80.4367) (end 86.7486 80.4621) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3922 80.8685) (end 85.3135 80.8939) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.4242 80.2589) (end 87.3658 80.2767) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.1474 80.3427) (end 87.0661 80.3656) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.0298 80.678) (end 85.951 80.7009) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.7123 80.772) (end 85.6335 80.7974) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.6033 81.7118) (end 82.5246 81.7372) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.6846 81.6889) (end 82.6033 81.7118) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.7633 81.6635) (end 82.6846 81.6889) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.951 80.7009) (end 85.8723 80.7263) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.1898 80.6298) (end 86.111 80.6526) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.9873 80.391) (end 86.9086 80.4139) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.3221 81.4934) (end 83.2408 81.5188) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.0834 81.567) (end 83.0021 81.5899) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.4796 81.4451) (end 83.4009 81.4705) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.6396 81.3968) (end 83.5609 81.4222) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.2772 81.2063) (end 84.1984 81.2292) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.2711 80.6044) (end 86.1898 80.6298) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6759 81.0844) (end 84.5972 81.1098) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1535 80.9422) (end 85.0747 80.965) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.3498 80.5815) (end 86.2711 80.6044) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5159 81.1327) (end 84.4372 81.1581) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.5609 81.4222) (end 83.4796 81.4451) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.7996 81.3486) (end 83.7184 81.374) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.5522 80.8203) (end 85.4735 80.8457) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.5098 80.5332) (end 86.4285 80.5586) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.9086 80.4139) (end 86.8273 80.4367) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.1984 81.2292) (end 84.1171 81.2546) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3559 81.1809) (end 84.2772 81.2063) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.791 80.7491) (end 85.7123 80.772) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.9597 81.3003) (end 83.8784 81.3257) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4372 81.1581) (end 84.3559 81.1809) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.6673 80.485) (end 86.5886 80.5104) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.0661 80.3656) (end 86.9873 80.391) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9934 80.9879) (end 84.9147 81.0133) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.7486 80.4621) (end 86.6673 80.485) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.8421 81.6381) (end 82.7633 81.6635) (layer Eco1.User) (width 0.5))
  (gr_line (start 82.9233 81.6153) (end 82.8421 81.6381) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.0021 81.5899) (end 82.9233 81.6153) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.1621 81.5416) (end 83.0834 81.567) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.2408 81.5188) (end 83.1621 81.5416) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.4852 80.2411) (end 87.4242 80.2589) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.4009 81.4705) (end 83.3221 81.4934) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.7184 81.374) (end 83.6396 81.3968) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.836 81.0362) (end 84.7547 81.0616) (layer Eco1.User) (width 0.5))
  (gr_line (start 86.5886 80.5104) (end 86.5098 80.5332) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7547 81.0616) (end 84.6759 81.0844) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0747 80.965) (end 84.9934 80.9879) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.3135 80.8939) (end 85.2347 80.9168) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.3074 80.2945) (end 87.2261 80.3173) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.3658 80.2767) (end 87.3074 80.2945) (layer Eco1.User) (width 0.5))
  (gr_line (start 83.8784 81.3257) (end 83.7996 81.3486) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.0384 81.2775) (end 83.9597 81.3003) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.2258 79.4156) (end 90.1674 79.4334) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.317999 79.088) (end 91.2672 79.1032) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.8812 79.2201) (end 90.822699 79.2378) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.6899 79.5757) (end 89.6289 79.596) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.8093 79.5401) (end 89.7483 79.5579) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.4062 79.3623) (end 90.3452 79.3801) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.9017 80.1141) (end 87.8433 80.1319) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.584 79.309) (end 90.525599 79.3267) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.0211 80.0786) (end 87.9627 80.0964) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.6424 79.2912) (end 90.584 79.309) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.0005 79.182) (end 90.9421 79.1997) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.1707 79.1337) (end 91.1199 79.1464) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.6046 80.203) (end 87.5436 80.2208) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.663 80.1853) (end 87.6046 80.203) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.9152 79.8093) (end 88.8542 79.8271) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.7239 80.1675) (end 87.663 80.1853) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.048 79.469) (end 89.9871 79.4868) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.7824 80.1497) (end 87.7239 80.1675) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.6289 79.596) (end 89.5705 79.6138) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.8433 80.1319) (end 87.7824 80.1497) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.3793 79.9719) (end 88.3183 79.9897) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.154 79.7382) (end 89.093 79.756) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.2868 79.3979) (end 90.2258 79.4156) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.3318 79.6849) (end 89.2733 79.7027) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.525599 79.3267) (end 90.4646 79.3445) (layer Eco1.User) (width 0.5))
  (gr_line (start 87.9627 80.0964) (end 87.9017 80.1141) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.0795 80.0608) (end 88.0211 80.0786) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.1199 79.1464) (end 91.0615 79.1642) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.3183 79.9897) (end 88.2599 80.0075) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.5705 79.6138) (end 89.5121 79.6315) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.9871 79.4868) (end 89.9287 79.5045) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.5121 79.6315) (end 89.4511 79.6493) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.1065 79.4512) (end 90.048 79.469) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.2672 79.1032) (end 91.219 79.1185) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.8542 79.8271) (end 88.7958 79.8449) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.1405 80.043) (end 88.0795 80.0608) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.5571 79.916) (end 88.4986 79.9363) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.8677 79.5223) (end 89.8093 79.5401) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.1989 80.0252) (end 88.1405 80.043) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.2599 80.0075) (end 88.1989 80.0252) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.1674 79.4334) (end 90.1065 79.4512) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.4377 79.9541) (end 88.3793 79.9719) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.4646 79.3445) (end 90.4062 79.3623) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.4986 79.9363) (end 88.4377 79.9541) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.618 79.8982) (end 88.5571 79.916) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.6764 79.8805) (end 88.618 79.8982) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.9736 79.7916) (end 88.9152 79.8093) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.7618 79.2556) (end 90.7034 79.2734) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.2124 79.7204) (end 89.154 79.7382) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.0346 79.7738) (end 88.9736 79.7916) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.9287 79.5045) (end 89.8677 79.5223) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.3452 79.3801) (end 90.2868 79.3979) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.0615 79.1642) (end 91.0005 79.182) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.7349 79.8627) (end 88.6764 79.8805) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.822699 79.2378) (end 90.7618 79.2556) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.093 79.756) (end 89.0346 79.7738) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.7034 79.2734) (end 90.6424 79.2912) (layer Eco1.User) (width 0.5))
  (gr_line (start 90.9421 79.1997) (end 90.8812 79.2201) (layer Eco1.User) (width 0.5))
  (gr_line (start 88.7958 79.8449) (end 88.7349 79.8627) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.4511 79.6493) (end 89.3927 79.6671) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.7483 79.5579) (end 89.6899 79.5757) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.219 79.1185) (end 91.1707 79.1337) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.2733 79.7027) (end 89.2124 79.7204) (layer Eco1.User) (width 0.5))
  (gr_line (start 89.3927 79.6671) (end 89.3318 79.6849) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.4288 78.4606) (end 93.380499 78.4733) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.301 78.7959) (end 92.2502 78.8111) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.1171 78.2523) (end 94.0689 78.265) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.3663 79.0727) (end 91.317999 79.088) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.4146 79.06) (end 91.3663 79.0727) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.9556 78.8975) (end 91.9073 78.9127) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.6269 78.3996) (end 93.5761 78.4149) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.7234 78.3717) (end 93.6752 78.3844) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.4654 79.0448) (end 91.4146 79.06) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.5136 79.0296) (end 91.4654 79.0448) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.7742 78.3565) (end 93.7234 78.3717) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.5619 79.0143) (end 91.5136 79.0296) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.201999 78.8264) (end 92.1537 78.8391) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.7912 78.6511) (end 92.743 78.6638) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.8903 78.6206) (end 92.8395 78.6359) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.0859 78.5622) (end 93.037599 78.5774) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.2332 78.519) (end 93.184899 78.5317) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.7092 78.9711) (end 91.660899 78.9864) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.76 78.9559) (end 91.7092 78.9711) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.6752 78.3844) (end 93.6269 78.3996) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.1029 78.8543) (end 92.0546 78.8695) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.8225 78.3412) (end 93.7742 78.3565) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.692199 78.679) (end 92.6439 78.6943) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.2136 78.2218) (end 94.1654 78.2371) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.3152 78.1914) (end 94.2644 78.2066) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.544899 78.7222) (end 92.4966 78.7375) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.9868 78.5927) (end 92.9386 78.6054) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.5761 78.4149) (end 93.527799 78.4301) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.6127 79.0016) (end 91.5619 79.0143) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.660899 78.9864) (end 91.6127 79.0016) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.037599 78.5774) (end 92.9868 78.5927) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.8083 78.9432) (end 91.76 78.9559) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.2502 78.8111) (end 92.201999 78.8264) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.4676 78.1431) (end 94.4168 78.1583) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.0546 78.8695) (end 92.006399 78.8848) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.4483 78.7527) (end 92.3975 78.7679) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.349299 78.7806) (end 92.301 78.7959) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.859099 78.928) (end 91.8083 78.9432) (layer Eco1.User) (width 0.5))
  (gr_line (start 91.9073 78.9127) (end 91.859099 78.928) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.006399 78.8848) (end 91.9556 78.8975) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.1537 78.8391) (end 92.1029 78.8543) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.4966 78.7375) (end 92.4483 78.7527) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.6439 78.6943) (end 92.5957 78.7095) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.9698 78.2955) (end 93.9215 78.3107) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.1654 78.2371) (end 94.1171 78.2523) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.0689 78.265) (end 94.0181 78.2803) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.3975 78.7679) (end 92.349299 78.7806) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.3323 78.4885) (end 93.2815 78.5038) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.380499 78.4733) (end 93.3323 78.4885) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.4168 78.1583) (end 94.366 78.1761) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.5957 78.7095) (end 92.544899 78.7222) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.9215 78.3107) (end 93.8707 78.326) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.2815 78.5038) (end 93.2332 78.519) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.366 78.1761) (end 94.3152 78.1914) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.2644 78.2066) (end 94.2136 78.2218) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.743 78.6638) (end 92.692199 78.679) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.8395 78.6359) (end 92.7912 78.6511) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.4796 78.4454) (end 93.4288 78.4606) (layer Eco1.User) (width 0.5))
  (gr_line (start 92.9386 78.6054) (end 92.8903 78.6206) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.1341 78.547) (end 93.0859 78.5622) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.184899 78.5317) (end 93.1341 78.547) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.527799 78.4301) (end 93.4796 78.4454) (layer Eco1.User) (width 0.5))
  (gr_line (start 93.8707 78.326) (end 93.8225 78.3412) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.0181 78.2803) (end 93.9698 78.2955) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.2939 77.5716) (end 96.2431 77.5868) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.5852 77.7951) (end 95.5344 77.8104) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.4463 77.5233) (end 96.3955 77.5411) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.8527 77.3989) (end 96.8019 77.4141) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.0559 77.3354) (end 97.0051 77.3506) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.5479 77.4929) (end 96.4971 77.5081) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.7003 77.4446) (end 96.6495 77.4598) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.128 77.9374) (end 95.0772 77.9551) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.5741 77.1779) (end 97.5131 77.1957) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.89 77.6986) (end 95.8392 77.7164) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.0907 77.6351) (end 96.0424 77.6529) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.3099 77.2566) (end 97.2591 77.2719) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.3955 77.5411) (end 96.3447 77.5564) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.7519 77.122) (end 97.6909 77.1398) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.5131 77.1957) (end 97.4623 77.2109) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.8019 77.4141) (end 96.7511 77.4294) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.5987 77.4776) (end 96.5479 77.4929) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.5692 78.1126) (end 94.5184 78.1279) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.6708 78.0796) (end 94.62 78.0974) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.7216 78.0644) (end 94.6708 78.0796) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.7511 77.4294) (end 96.7003 77.4446) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.9035 77.3811) (end 96.8527 77.3989) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.4115 77.2262) (end 97.3607 77.2414) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.0772 77.9551) (end 95.0264 77.9704) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.9248 78.0009) (end 94.874 78.0186) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.1788 77.9221) (end 95.128 77.9374) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.2804 77.8916) (end 95.2296 77.9069) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.6868 77.7621) (end 95.636 77.7799) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.9543 77.3659) (end 96.9035 77.3811) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.9408 77.6834) (end 95.89 77.6986) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.2431 77.5868) (end 96.1923 77.6046) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.0051 77.3506) (end 96.9543 77.3659) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.8392 77.7164) (end 95.7884 77.7316) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.2296 77.9069) (end 95.1788 77.9221) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.382 77.8586) (end 95.3312 77.8739) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.4971 77.5081) (end 96.4463 77.5233) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.1067 77.3201) (end 97.0559 77.3354) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.3607 77.2414) (end 97.3099 77.2566) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.636 77.7799) (end 95.5852 77.7951) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.7376 77.7469) (end 95.6868 77.7621) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.6495 77.4598) (end 96.5987 77.4776) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.4836 77.8281) (end 95.4328 77.8434) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.7884 77.7316) (end 95.7376 77.7469) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.2083 77.2871) (end 97.1575 77.3024) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.4623 77.2109) (end 97.4115 77.2262) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.1415 77.6199) (end 96.0907 77.6351) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.2591 77.2719) (end 97.2083 77.2871) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.5184 78.1279) (end 94.4676 78.1431) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.62 78.0974) (end 94.5692 78.1126) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.7724 78.0491) (end 94.7216 78.0644) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.8232 78.0339) (end 94.7724 78.0491) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.874 78.0186) (end 94.8232 78.0339) (layer Eco1.User) (width 0.5))
  (gr_line (start 94.9756 77.9856) (end 94.9248 78.0009) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.0264 77.9704) (end 94.9756 77.9856) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.3312 77.8739) (end 95.2804 77.8916) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.0424 77.6529) (end 95.9916 77.6681) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.1575 77.3024) (end 97.1067 77.3201) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.9916 77.6681) (end 95.9408 77.6834) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.1923 77.6046) (end 96.1415 77.6199) (layer Eco1.User) (width 0.5))
  (gr_line (start 96.3447 77.5564) (end 96.2939 77.5716) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.6325 77.1576) (end 97.5741 77.1779) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.6909 77.1398) (end 97.6325 77.1576) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.4328 77.8434) (end 95.382 77.8586) (layer Eco1.User) (width 0.5))
  (gr_line (start 95.5344 77.8104) (end 95.4836 77.8281) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.11 77.0153) (end 98.049 77.0331) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.092 76.1314) (end 101.0335 76.1492) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.4206 76.6267) (end 99.3622 76.6445) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.1684 76.9976) (end 98.11 77.0153) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.2294 76.9798) (end 98.1684 76.9976) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.2878 76.962) (end 98.2294 76.9798) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.9726 76.167) (end 100.9142 76.1873) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.5266 76.8909) (end 98.4681 76.9087) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.7653 76.8223) (end 98.7069 76.8375) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.8847 76.7867) (end 98.8263 76.8045) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.065 76.7334) (end 99.0041 76.7512) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.2428 76.6801) (end 99.1844 76.6978) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.1844 76.6978) (end 99.1235 76.7156) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.7204 76.5404) (end 99.6594 76.5581) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.3307 76.0603) (end 101.2698 76.0781) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.3993 76.04) (end 101.3307 76.0603) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.4951 76.3092) (end 100.4366 76.327) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.8532 76.2051) (end 100.7948 76.2229) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.3488 76.9442) (end 98.2878 76.962) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.3173 76.3626) (end 100.2563 76.3803) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.9142 76.1873) (end 100.8532 76.2051) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.4816 76.6089) (end 99.4206 76.6267) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.9457 76.769) (end 98.8847 76.7867) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.0785 76.4337) (end 100.0175 76.4515) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.4681 76.9087) (end 98.4072 76.9264) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.3622 76.6445) (end 99.3038 76.6623) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.0335 76.1492) (end 100.9726 76.167) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.9591 76.4692) (end 99.8982 76.487) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.5875 76.8731) (end 98.5266 76.8909) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.556 76.294) (end 100.4951 76.3092) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.6459 76.8553) (end 98.5875 76.8731) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.8263 76.8045) (end 98.7653 76.8223) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.1504 76.1136) (end 101.092 76.1314) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.0041 76.7512) (end 98.9457 76.769) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.6076 75.9765) (end 101.5365 75.9968) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.54 76.5937) (end 99.4816 76.6089) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.7788 76.5226) (end 99.7204 76.5404) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.8982 76.487) (end 99.8397 76.5048) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.8397 76.5048) (end 99.7788 76.5226) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.0175 76.4515) (end 99.9591 76.4692) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.7948 76.2229) (end 100.7338 76.2406) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.2113 76.0959) (end 101.1504 76.1136) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.4679 76.0197) (end 101.3993 76.04) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.1979 76.3981) (end 100.1369 76.4159) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.3038 76.6623) (end 99.2428 76.6801) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.2698 76.0781) (end 101.2113 76.0959) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.601 76.5759) (end 99.54 76.5937) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.4072 76.9264) (end 98.3488 76.9442) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.2563 76.3803) (end 100.1979 76.3981) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.7069 76.8375) (end 98.6459 76.8553) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.7338 76.2406) (end 100.6754 76.2584) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.1235 76.7156) (end 99.065 76.7334) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.5365 75.9968) (end 101.4679 76.0197) (layer Eco1.User) (width 0.5))
  (gr_line (start 98.049 77.0331) (end 97.9906 77.0509) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.1369 76.4159) (end 100.0785 76.4337) (layer Eco1.User) (width 0.5))
  (gr_line (start 99.6594 76.5581) (end 99.601 76.5759) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.6754 76.2584) (end 100.6144 76.2762) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.8103 77.1042) (end 97.7519 77.122) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.9906 77.0509) (end 97.9297 77.0687) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.6144 76.2762) (end 100.556 76.294) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.8712 77.0865) (end 97.8103 77.1042) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.3757 76.3448) (end 100.3173 76.3626) (layer Eco1.User) (width 0.5))
  (gr_line (start 97.9297 77.0687) (end 97.8712 77.0865) (layer Eco1.User) (width 0.5))
  (gr_line (start 100.4366 76.327) (end 100.3757 76.3448) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.1255 74.8919) (end 105.0569 74.9122) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.538 75.3821) (end 103.4694 75.4024) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.367 75.7428) (end 102.2959 75.7657) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.6762 75.9562) (end 101.6076 75.9765) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.7447 75.9333) (end 101.6762 75.9562) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.0554 75.5294) (end 102.9868 75.5523) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.4023 74.8081) (end 105.3338 74.8284) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.542 74.7649) (end 105.4709 74.7878) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.8133 75.913) (end 101.7447 75.9333) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.8819 75.8927) (end 101.8133 75.913) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.6106 74.7446) (end 105.542 74.7649) (layer Eco1.User) (width 0.5))
  (gr_line (start 101.953 75.8723) (end 101.8819 75.8927) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.4008 75.4228) (end 103.3322 75.4456) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.2289 75.1688) (end 104.1603 75.1891) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.366 75.1256) (end 104.2974 75.1459) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.6429 75.0392) (end 104.5743 75.0621) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.8512 74.9757) (end 104.78 74.9986) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.0216 75.8495) (end 101.953 75.8723) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.7811 75.6158) (end 102.7099 75.6361) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.4709 74.7878) (end 105.4023 74.8081) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.7099 75.6361) (end 102.6414 75.659) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.6792 74.7243) (end 105.6106 74.7446) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.0917 75.2094) (end 104.0206 75.2323) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.2637 75.4659) (end 103.1951 75.4888) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.0902 75.8292) (end 102.0216 75.8495) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.8834 75.2754) (end 103.8148 75.2958) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.5057 75.0824) (end 104.4346 75.1027) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.3338 74.8284) (end 105.2652 74.8487) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.2273 75.786) (end 102.1588 75.8088) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.5042 75.7022) (end 102.4356 75.7225) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.5743 75.0621) (end 104.5057 75.0824) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.5728 75.6793) (end 102.5042 75.7022) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.8496 75.5955) (end 102.7811 75.6158) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.4694 75.4024) (end 103.4008 75.4228) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.1951 75.4888) (end 103.124 75.5091) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.7463 75.3161) (end 103.6777 75.3389) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.6091 75.3593) (end 103.538 75.3821) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.1588 75.8088) (end 102.0902 75.8292) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.6414 75.659) (end 102.5728 75.6793) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.2959 75.7657) (end 102.2273 75.786) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.9182 75.5726) (end 102.8496 75.5955) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.3322 75.4456) (end 103.2637 75.4659) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.8148 75.2958) (end 103.7463 75.3161) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.0206 75.2323) (end 103.952 75.2526) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.8418 74.676) (end 105.796 74.6887) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.9357 74.6481) (end 105.89 74.6608) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.4356 75.7225) (end 102.367 75.7428) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.9883 74.9351) (end 104.9197 74.9554) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.0569 74.9122) (end 104.9883 74.9351) (layer Eco1.User) (width 0.5))
  (gr_line (start 102.9868 75.5523) (end 102.9182 75.5726) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.124 75.5091) (end 103.0554 75.5294) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.796 74.6887) (end 105.7478 74.7039) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.9197 74.9554) (end 104.8512 74.9757) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.6777 75.3389) (end 103.6091 75.3593) (layer Eco1.User) (width 0.5))
  (gr_line (start 103.952 75.2526) (end 103.8834 75.2754) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.1603 75.1891) (end 104.0917 75.2094) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.2974 75.1459) (end 104.2289 75.1688) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.1966 74.8716) (end 105.1255 74.8919) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.4346 75.1027) (end 104.366 75.1256) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.7115 75.0189) (end 104.6429 75.0392) (layer Eco1.User) (width 0.5))
  (gr_line (start 104.78 74.9986) (end 104.7115 75.0189) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.2652 74.8487) (end 105.1966 74.8716) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.7478 74.7039) (end 105.6792 74.7243) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.89 74.6608) (end 105.8418 74.676) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.43 73.9369) (end 108.3843 73.9521) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7722 74.1274) (end 107.7264 74.1426) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.9101 73.787) (end 108.872 73.7997) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0084 74.0613) (end 107.9601 74.074) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1024 74.0334) (end 108.0541 74.0486) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.5723 73.8937) (end 108.524 73.9089) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.078 74.6074) (end 106.0297 74.6201) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.712 73.8505) (end 108.6637 73.8657) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.1237 74.5922) (end 106.078 74.6074) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.172 74.5795) (end 106.1237 74.5922) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6901 74.4322) (end 106.6419 74.4449) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.7577 73.8378) (end 108.712 73.8505) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.2177 74.5642) (end 106.172 74.5795) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.2659 74.5515) (end 106.2177 74.5642) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3962 74.234) (end 107.348 74.2467) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4539 74.4982) (end 106.4056 74.5109) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2903 73.98) (end 108.2421 73.9927) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.3599 74.5261) (end 106.3117 74.5388) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9601 74.074) (end 107.9144 74.0893) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4056 74.5109) (end 106.3599 74.5261) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.9721 74.3534) (end 106.9238 74.3661) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5842 74.1807) (end 107.5385 74.1959) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.4783 73.9216) (end 108.43 73.9369) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.7264 74.1426) (end 107.6782 74.1553) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.6637 73.8657) (end 108.618 73.881) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.3117 74.5388) (end 106.2659 74.5515) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.4996 74.4855) (end 106.4539 74.4982) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5479 74.4728) (end 106.4996 74.4855) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.9238 74.3661) (end 106.8781 74.3788) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.9144 74.0893) (end 107.8661 74.102) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.2421 73.9927) (end 108.1963 74.0054) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.5961 74.4576) (end 106.5479 74.4728) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8661 74.102) (end 107.8204 74.1147) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.336 73.9648) (end 108.2903 73.98) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.348 74.2467) (end 107.3023 74.262) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.6419 74.4449) (end 106.5961 74.4576) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.1143 74.3128) (end 107.066 74.3255) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1481 74.0207) (end 108.1024 74.0334) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7358 74.4195) (end 106.6901 74.4322) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.7841 74.4068) (end 106.7358 74.4195) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.3843 73.9521) (end 108.336 73.9648) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8298 74.3915) (end 106.7841 74.4068) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.618 73.881) (end 108.5723 73.8937) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.8781 74.3788) (end 106.8298 74.3915) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.0203 74.3407) (end 106.9721 74.3534) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.066 74.3255) (end 107.0203 74.3407) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4445 74.2213) (end 107.3962 74.234) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.8339 73.8124) (end 108.7958 73.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6325 74.168) (end 107.5842 74.1807) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.16 74.3001) (end 107.1143 74.3128) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.4902 74.2086) (end 107.4445 74.2213) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.1963 74.0054) (end 108.1481 74.0207) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.524 73.9089) (end 108.4783 73.9216) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.2083 74.2874) (end 107.16 74.3001) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.872 73.7997) (end 108.8339 73.8124) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.5385 74.1959) (end 107.4902 74.2086) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.254 74.2747) (end 107.2083 74.2874) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.7958 73.8251) (end 108.7577 73.8378) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.3023 74.262) (end 107.254 74.2747) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.8204 74.1147) (end 107.7722 74.1274) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.0541 74.0486) (end 108.0084 74.0613) (layer Eco1.User) (width 0.5))
  (gr_line (start 105.984 74.6328) (end 105.9357 74.6481) (layer Eco1.User) (width 0.5))
  (gr_line (start 106.0297 74.6201) (end 105.984 74.6328) (layer Eco1.User) (width 0.5))
  (gr_line (start 107.6782 74.1553) (end 107.6325 74.168) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4214 73.2536) (end 110.3833 73.2688) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7236 73.1495) (end 110.6881 73.1622) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.8379 73.1114) (end 110.7998 73.1241) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.7432 73.5) (end 109.7051 73.5127) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1191 73.3628) (end 110.0836 73.3755) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2012 72.9971) (end 111.1808 73.0047) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.9863 73.7641) (end 108.9482 73.7768) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.2334 73.3222) (end 110.1953 73.3349) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.1006 73.726) (end 109.0625 73.7387) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.2715 73.3095) (end 110.2334 73.3222) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4976 73.2282) (end 110.4595 73.2409) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6119 73.1901) (end 110.5738 73.2028) (layer Eco1.User) (width 0.5))
  (gr_line (start 108.9482 73.7768) (end 108.9101 73.787) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.0244 73.7514) (end 108.9863 73.7641) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.1768 73.7006) (end 109.1387 73.7133) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.0625 73.7387) (end 109.0244 73.7514) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.8931 73.4441) (end 109.8575 73.4593) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.6314 73.5406) (end 109.5933 73.5533) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0665 73.0402) (end 111.0284 73.0504) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.3292 73.6473) (end 109.2911 73.66) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.0284 73.0504) (end 110.9903 73.0631) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4409 73.6067) (end 109.4028 73.6219) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.0455 73.3908) (end 110.0074 73.4035) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2647 72.9793) (end 111.2443 72.9844) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1953 73.3349) (end 110.1572 73.3501) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.1387 73.7133) (end 109.1006 73.726) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.5552 73.566) (end 109.5171 73.5813) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5738 73.2028) (end 110.5357 73.2155) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.5933 73.5533) (end 109.5552 73.566) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.8575 73.4593) (end 109.8194 73.472) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.9312 73.4314) (end 109.8931 73.4441) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.6881 73.1622) (end 110.65 73.1749) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7617 73.1368) (end 110.7236 73.1495) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9141 73.0885) (end 110.876 73.0987) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1046 73.0275) (end 111.0665 73.0402) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9522 73.0758) (end 110.9141 73.0885) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2443 72.9844) (end 111.2215 72.992) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.7813 73.4847) (end 109.7432 73.5) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.9903 73.0631) (end 110.9522 73.0758) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.9693 73.4162) (end 109.9312 73.4314) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1427 73.0148) (end 111.1046 73.0275) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.2149 73.6854) (end 109.1768 73.7006) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.1572 73.3501) (end 110.1191 73.3628) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.253 73.6727) (end 109.2149 73.6854) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.2911 73.66) (end 109.253 73.6727) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.3673 73.6346) (end 109.3292 73.6473) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.7998 73.1241) (end 110.7617 73.1368) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.3477 73.2815) (end 110.3096 73.2942) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.4028 73.6219) (end 109.3673 73.6346) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.8194 73.472) (end 109.7813 73.4847) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.0836 73.3755) (end 110.0455 73.3908) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.3833 73.2688) (end 110.3477 73.2815) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.5357 73.2155) (end 110.4976 73.2282) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.876 73.0987) (end 110.8379 73.1114) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.1808 73.0047) (end 111.1427 73.0148) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.479 73.594) (end 109.4409 73.6067) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.3096 73.2942) (end 110.2715 73.3095) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.4595 73.2409) (end 110.4214 73.2536) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.5171 73.5813) (end 109.479 73.594) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.2215 72.992) (end 111.2012 72.9971) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.7051 73.5127) (end 109.667 73.5254) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.65 73.1749) (end 110.6119 73.1901) (layer Eco1.User) (width 0.5))
  (gr_line (start 109.667 73.5254) (end 109.6314 73.5406) (layer Eco1.User) (width 0.5))
  (gr_line (start 110.0074 73.4035) (end 109.9693 73.4162) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.8412 72.8218) (end 111.8209 72.8243) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3485 72.9513) (end 111.3256 72.9564) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.1333 72.8472) (end 112.113 72.8421) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.285 72.9717) (end 111.2647 72.9793) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3053 72.964) (end 111.285 72.9717) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3256 72.9564) (end 111.3053 72.964) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9276 72.8167) (end 111.9047 72.8193) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9682 72.8193) (end 111.9479 72.8167) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3688 72.9437) (end 111.3485 72.9513) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9911 72.8193) (end 111.9682 72.8193) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4204 73.0402) (end 112.4026 73.0225) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.3891 72.9361) (end 111.3688 72.9437) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.5618 72.8828) (end 111.539 72.8878) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.605 72.8701) (end 111.5822 72.8751) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6914 72.8472) (end 111.6685 72.8523) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7549 72.8345) (end 111.7346 72.8396) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3289 72.9539) (end 112.3111 72.9386) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9479 72.8167) (end 111.9276 72.8167) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0114 72.8218) (end 111.9911 72.8193) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3111 72.9386) (end 112.2908 72.9234) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5372 73.2028) (end 112.5118 73.1672) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2908 72.9234) (end 112.273 72.9107) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.5187 72.8955) (end 111.4958 72.9005) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.174 72.8624) (end 112.1537 72.8548) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2146 72.8802) (end 112.1943 72.8701) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4526 72.9158) (end 111.4323 72.9234) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6482 72.8574) (end 111.6253 72.865) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.9047 72.8193) (end 111.8844 72.8193) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5118 73.1672) (end 112.4889 73.1317) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.412 72.9285) (end 111.3891 72.9361) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6685 72.8523) (end 111.6482 72.8574) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4323 72.9234) (end 111.412 72.9285) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4755 72.9082) (end 111.4526 72.9158) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.273 72.9107) (end 112.2527 72.9005) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.4958 72.9005) (end 111.4755 72.9082) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3467 72.9691) (end 112.3289 72.9539) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.539 72.8878) (end 111.5187 72.8955) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.5822 72.8751) (end 111.5618 72.8828) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7777 72.832) (end 111.7549 72.8345) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7981 72.8269) (end 111.7777 72.832) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.8209 72.8243) (end 111.7981 72.8269) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0724 72.832) (end 112.0521 72.8269) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4534 73.0834) (end 112.4381 73.0606) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.367 72.9844) (end 112.3467 72.9691) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.1537 72.8548) (end 112.1333 72.8472) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.113 72.8421) (end 112.0927 72.8345) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2527 72.9005) (end 112.2324 72.8878) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4026 73.0225) (end 112.3848 73.0021) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4889 73.1317) (end 112.4712 73.1063) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.3848 73.0021) (end 112.367 72.9844) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4712 73.1063) (end 112.4534 73.0834) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0521 72.8269) (end 112.0317 72.8243) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.1943 72.8701) (end 112.174 72.8624) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.2324 72.8878) (end 112.2146 72.8802) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5601 73.2384) (end 112.5372 73.2028) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.6253 72.865) (end 111.605 72.8701) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.8641 72.8218) (end 111.8412 72.8218) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.4381 73.0606) (end 112.4204 73.0402) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.5829 73.2739) (end 112.5601 73.2384) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7117 72.8421) (end 111.6914 72.8472) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.7346 72.8396) (end 111.7117 72.8421) (layer Eco1.User) (width 0.5))
  (gr_line (start 111.8844 72.8193) (end 111.8641 72.8218) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0317 72.8243) (end 112.0114 72.8218) (layer Eco1.User) (width 0.5))
  (gr_line (start 112.0927 72.8345) (end 112.0724 72.832) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 87.9932) (end 26.9392 87.1855) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 61.3283) (end 26.9392 60.5206) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 89.6112) (end 26.9392 88.800901) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 71.8337) (end 26.9392 71.026) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.4312 38.3921) (end 124.1506 38.3921) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 58.9026) (end 26.9392 58.0949) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 69.4106) (end 26.9392 68.6029) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 82.3392) (end 26.9392 81.5315) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 79.9135) (end 26.9392 79.1058) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 59.7129) (end 26.9392 58.9026) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 62.136) (end 26.9392 61.3283) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 72.6415) (end 26.9392 71.8337) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 65.3694) (end 26.9392 64.5617) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 75.8749) (end 26.9392 75.0672) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 60.5206) (end 26.9392 59.7129) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 62.9437) (end 26.9392 62.136) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 64.5617) (end 26.9392 63.754) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 75.0672) (end 26.9392 74.2594) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 88.800901) (end 26.9392 87.9932) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 86.3778) (end 26.9392 85.5701) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 63.754) (end 26.9392 62.9437) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 66.1772) (end 26.9392 65.3694) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 66.9849) (end 26.9392 66.1772) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 73.4517) (end 26.9392 72.6415) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 67.7951) (end 26.9392 66.9849) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 68.6029) (end 26.9392 67.7951) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 70.2183) (end 26.9392 69.4106) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 71.026) (end 26.9392 70.2183) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 74.2594) (end 26.9392 73.4517) (layer Eco1.User) (width 0.5))
  (gr_line (start 124.1506 38.3921) (end 124.1506 120.9421) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 76.6826) (end 26.9392 75.8749) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 77.4903) (end 26.9392 76.6826) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.939599 91.2248) (end 26.9392 90.4189) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 83.1469) (end 26.9392 82.3392) (layer Eco1.User) (width 0.5))
  (gr_line (start 124.1506 120.9421) (end 26.4312 120.9421) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 78.298) (end 26.9392 77.4903) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 79.1058) (end 26.9392 78.298) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 83.9546) (end 26.9392 83.1469) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 87.1855) (end 26.9392 86.3778) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 81.5315) (end 26.9392 80.7237) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 84.7623) (end 26.9392 83.9546) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 54.0537) (end 26.9392 53.2435) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 54.8615) (end 26.9392 54.0537) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 55.6692) (end 26.9392 54.8615) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 85.5701) (end 26.9392 84.7623) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 56.4794) (end 26.9392 55.6692) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 57.2872) (end 26.9392 56.4794) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 58.0949) (end 26.9392 57.2872) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.4312 120.9421) (end 26.4312 38.3921) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 90.4189) (end 26.9392 89.6112) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 80.7237) (end 26.9392 79.9135) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8261 43.7236) (end 51.8109 43.7591) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6973 42.4282) (end 52.6669 42.4536) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6966 44.0538) (end 51.6813 44.0919) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7093 44.0182) (end 51.6966 44.0538) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7245 43.9801) (end 51.7093 44.0182) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7677 43.8709) (end 51.7525 43.9064) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1411 43.086) (end 52.1182 43.1216) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4916 42.6288) (end 52.4662 42.6568) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6669 42.4536) (end 52.6364 42.4815) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7608 42.3748) (end 52.7278 42.4002) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3316 42.8142) (end 52.3062 42.8473) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9201 43.4975) (end 51.9023 43.5381) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4103 42.7203) (end 52.3849 42.7507) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.976 43.3807) (end 51.9582 43.4188) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2097 42.9819) (end 52.1868 43.0149) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0979 43.1571) (end 52.075 43.1927) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1868 43.0149) (end 52.1639 43.0505) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2325 42.9463) (end 52.2097 42.9819) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4383 42.6872) (end 52.4103 42.7203) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1182 43.1216) (end 52.0979 43.1571) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3849 42.7507) (end 52.357 42.7812) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7398 43.9445) (end 51.7245 43.9801) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8566 43.6499) (end 51.8414 43.688) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7278 42.4002) (end 52.6973 42.4282) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.357 42.7812) (end 52.3316 42.8142) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6084 42.512) (end 52.578 42.5399) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8574 42.2961) (end 52.8243 42.3215) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9894 42.1996) (end 52.9564 42.2224) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.025 42.1742) (end 52.9894 42.1996) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0141 43.3045) (end 51.9963 43.3426) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9963 43.3426) (end 51.976 43.3807) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1317 42.1081) (end 53.0961 42.1284) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0344 43.2664) (end 52.0141 43.3045) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.55 42.5679) (end 52.5221 42.5983) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8109 43.7591) (end 51.7956 43.7972) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0547 43.2308) (end 52.0344 43.2664) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1639 43.0505) (end 52.1411 43.086) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8871 43.5762) (end 51.8718 43.6143) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0961 42.1284) (end 53.0606 42.1513) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1672 42.0853) (end 53.1317 42.1081) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8243 42.3215) (end 52.7913 42.3469) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.075 43.1927) (end 52.0547 43.2308) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7913 42.3469) (end 52.7608 42.3748) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2028 42.0649) (end 53.1672 42.0853) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9234 42.2453) (end 52.8904 42.2707) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3062 42.8473) (end 52.2833 42.8803) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2833 42.8803) (end 52.2579 42.9133) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5221 42.5983) (end 52.4916 42.6288) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9023 43.5381) (end 51.8871 43.5762) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7525 43.9064) (end 51.7398 43.9445) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7829 43.8328) (end 51.7677 43.8709) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4662 42.6568) (end 52.4383 42.6872) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7956 43.7972) (end 51.7829 43.8328) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.578 42.5399) (end 52.55 42.5679) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8718 43.6143) (end 51.8566 43.6499) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8414 43.688) (end 51.8261 43.7236) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2579 42.9133) (end 52.2325 42.9463) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9564 42.2224) (end 52.9234 42.2453) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6364 42.4815) (end 52.6084 42.512) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8904 42.2707) (end 52.8574 42.2961) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0606 42.1513) (end 53.025 42.1742) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9379 43.4594) (end 51.9201 43.4975) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6813 44.0919) (end 51.6686 44.1274) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9582 43.4188) (end 51.9379 43.4594) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7133 41.8236) (end 53.6702 41.8389) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7972 41.7906) (end 53.754 41.8059) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.0791 41.6916) (end 53.9851 41.7246) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.3636 41.59) (end 54.2696 41.623) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.2145 41.2852) (end 55.1205 41.3207) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3311 40.1574) (end 58.2371 40.193) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7258 40.7416) (end 56.6318 40.7746) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.6869 41.115) (end 55.5929 41.1505) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1594 40.9448) (end 56.0654 40.9804) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.7646 40.3631) (end 57.6707 40.3987) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0466 40.2615) (end 57.9526 40.2946) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4802 40.4673) (end 57.3862 40.5003) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.5929 41.1505) (end 55.499 41.1836) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9714 41.0134) (end 55.8774 41.0489) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.1431 40.226) (end 58.0466 40.2615) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.2696 41.623) (end 54.1756 41.6585) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.8911 41.7576) (end 53.7972 41.7906) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1982 40.5689) (end 57.1042 40.6044) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.836 41.4223) (end 54.742 41.4553) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.1756 41.6585) (end 54.0791 41.6916) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.4576 41.5569) (end 54.3636 41.59) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.405 41.2166) (end 55.3085 41.2521) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8586 40.3301) (end 57.7646 40.3631) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.0265 41.3537) (end 54.9325 41.3868) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2922 40.5359) (end 57.1982 40.5689) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.742 41.4553) (end 54.6481 41.4884) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.5076 41.9075) (end 53.4695 41.9252) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.5541 41.5214) (end 54.4576 41.5569) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5767 40.4317) (end 57.4802 40.4673) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4695 41.9252) (end 53.4289 41.943) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.5482 41.8897) (end 53.5076 41.9075) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.6481 41.4884) (end 54.5541 41.5214) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2409 42.0421) (end 53.2028 42.0649) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.754 41.8059) (end 53.7133 41.8236) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8198 40.706) (end 56.7258 40.7416) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.9526 40.2946) (end 57.8586 40.3301) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2765 42.0218) (end 53.2409 42.0421) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3085 41.2521) (end 55.2145 41.2852) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3146 42.0014) (end 53.2765 42.0218) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.9851 41.7246) (end 53.8911 41.7576) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3862 40.5003) (end 57.2922 40.5359) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3527 41.9811) (end 53.3146 42.0014) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5378 40.8102) (end 56.4438 40.8432) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.425 40.1244) (end 58.3311 40.1574) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.499 41.1836) (end 55.405 41.2166) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6318 40.7746) (end 56.5378 40.8102) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.1205 41.3207) (end 55.0265 41.3537) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2533 40.9118) (end 56.1594 40.9448) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3908 41.9633) (end 53.3527 41.9811) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4289 41.943) (end 53.3908 41.9633) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9137 40.673) (end 56.8198 40.706) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6707 40.3987) (end 57.5767 40.4317) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0654 40.9804) (end 55.9714 41.0134) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.5889 41.8719) (end 53.5482 41.8897) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.9325 41.3868) (end 54.836 41.4223) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4438 40.8432) (end 56.3473 40.8762) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.6295 41.8541) (end 53.5889 41.8719) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.7809 41.082) (end 55.6869 41.115) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0103 40.6375) (end 56.9137 40.673) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3473 40.8762) (end 56.2533 40.9118) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1042 40.6044) (end 57.0103 40.6375) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.8774 41.0489) (end 55.7809 41.082) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.6702 41.8389) (end 53.6295 41.8541) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.2371 40.193) (end 58.1431 40.226) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.849999 39.6037) (end 59.8398 39.6088) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.888099 39.5757) (end 59.8805 39.5834) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.903299 39.5605) (end 59.8957 39.5681) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8629 39.4945) (end 57.3786 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.4098 39.4945) (end 58.9254 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3473 39.4945) (end 56.8629 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.519 40.0888) (end 58.425 40.1244) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.613 40.0558) (end 58.519 40.0888) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2198 39.4945) (end 52.7354 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.706999 40.0202) (end 58.613 40.0558) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.8035 39.9872) (end 58.706999 40.0202) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.991499 39.9186) (end 58.897499 39.9517) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.179399 39.8501) (end 59.0854 39.8831) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.7979 39.4945) (end 55.3135 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.5579 39.7129) (end 59.4639 39.7459) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8398 39.6088) (end 59.7458 39.6418) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8805 39.5834) (end 59.8728 39.5884) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9516 39.5021) (end 59.944 39.5097) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3786 39.4945) (end 57.8942 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7354 39.4945) (end 53.2511 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.916 39.5427) (end 59.9084 39.5503) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.8292 39.4945) (end 56.3473 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.944 39.5097) (end 59.9363 39.5173) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.9254 39.4945) (end 59.441 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.186 39.4945) (end 51.7017 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7667 39.4945) (end 54.2823 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9084 39.5503) (end 59.903299 39.5605) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.2734 39.8145) (end 59.179399 39.8501) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.865199 39.5961) (end 59.8576 39.6011) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8728 39.5884) (end 59.865199 39.5961) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8942 39.4945) (end 58.4098 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2511 39.4945) (end 53.7667 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.3674 39.7815) (end 59.2734 39.8145) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9363 39.5173) (end 59.9287 39.5249) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.6519 39.6773) (end 59.5579 39.7129) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9287 39.5249) (end 59.9236 39.5351) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9567 39.4945) (end 59.9516 39.5021) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3135 39.4945) (end 55.8292 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.441 39.4945) (end 59.9567 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.897499 39.9517) (end 58.8035 39.9872) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.4639 39.7459) (end 59.3674 39.7815) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9236 39.5351) (end 59.916 39.5427) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.0854 39.8831) (end 58.991499 39.9186) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8576 39.6011) (end 59.849999 39.6037) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8957 39.5681) (end 59.888099 39.5757) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7017 39.4945) (end 52.2198 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.7458 39.6418) (end 59.6519 39.6773) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.2823 39.4945) (end 54.7979 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 28.4861 39.4945) (end 29.0017 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.3529 39.4945) (end 40.8686 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 48.3921) (end 26.9392 47.5844) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6079 39.4945) (end 49.1236 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.0923 39.4945) (end 48.6079 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.9648 39.4945) (end 44.4804 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 40.3047) (end 26.9392 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 41.9227) (end 26.9392 41.1124) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.5767 39.4945) (end 48.0923 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.5511 39.4945) (end 31.0667 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 42.7304) (end 26.9392 41.9227) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6704 39.4945) (end 51.186 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1548 39.4945) (end 50.6704 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.5429 39.4945) (end 47.0585 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.1942 39.4945) (end 35.7098 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.1604 39.4945) (end 34.676 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 46.0273 39.4945) (end 46.5429 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.4154 39.4945) (end 42.931 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 51.628) (end 26.9392 50.8178) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 41.1124) (end 26.9392 40.3047) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.2254 39.4945) (end 36.7411 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 43.5407) (end 26.9392 42.7304) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.0979 39.4945) (end 32.6136 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.7723 39.4945) (end 38.2879 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 50.0101) (end 26.9392 49.2023) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 53.2435) (end 26.9392 52.4358) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.1292 39.4945) (end 33.6448 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 39.4945) (end 27.4548 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 45.5117 39.4945) (end 46.0273 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 32.6136 39.4945) (end 33.1292 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 50.8178) (end 26.9392 50.0101) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 52.4358) (end 26.9392 51.628) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.0667 39.4945) (end 31.5823 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 42.931 39.4945) (end 43.4492 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.3842 39.4945) (end 41.8998 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.8035 39.4945) (end 39.3217 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.8373 39.4945) (end 40.3529 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6392 39.4945) (end 50.1548 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.9961 39.4945) (end 45.5117 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 41.8998 39.4945) (end 42.4154 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 38.2879 39.4945) (end 38.8035 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 31.5823 39.4945) (end 32.0979 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 36.7411 39.4945) (end 37.2567 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 45.9664) (end 26.9392 45.1561) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 49.2023) (end 26.9392 48.3921) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 47.5844) (end 26.9392 46.7741) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1236 39.4945) (end 49.6392 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.5173 39.4945) (end 30.0329 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 29.0017 39.4945) (end 29.5173 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 47.0585 39.4945) (end 47.5767 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 44.4804 39.4945) (end 44.9961 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 45.1561) (end 26.9392 44.3484) (layer Eco1.User) (width 0.5))
  (gr_line (start 30.0329 39.4945) (end 30.5511 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 43.4492 39.4945) (end 43.9648 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 39.3217 39.4945) (end 39.8373 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 35.7098 39.4945) (end 36.2254 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 34.676 39.4945) (end 35.1942 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.9704 39.4945) (end 28.4861 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 40.8686 39.4945) (end 41.3842 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 33.6448 39.4945) (end 34.1604 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 37.2567 39.4945) (end 37.7723 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 27.4548 39.4945) (end 27.9704 39.4945) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 44.3484) (end 26.9392 43.5407) (layer Eco1.User) (width 0.5))
  (gr_line (start 26.9392 46.7741) (end 26.9392 45.9664) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1101 60.7898) (end 48.1126 60.8) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1025 60.6628) (end 48.1025 60.6704) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1126 60.579) (end 48.1126 60.5866) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.645) (end 48.105 60.6527) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1126 60.8076) (end 48.1152 60.8178) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1126 60.8) (end 48.1126 60.8076) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.6374) (end 48.105 60.645) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.7339) (end 48.105 60.7441) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1838 60.3961) (end 48.1761 60.4114) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1101 60.7797) (end 48.1101 60.7898) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.7517) (end 48.1076 60.7619) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1025 60.6704) (end 48.1025 60.6806) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.6527) (end 48.1025 60.6628) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1482 60.4774) (end 48.1431 60.4926) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.6273) (end 48.105 60.6374) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1431 60.4926) (end 48.1355 60.5104) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2244 60.2996) (end 48.2168 60.3148) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1355 60.5104) (end 48.1304 60.5257) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1177 60.5638) (end 48.1152 60.5714) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1228 60.5485) (end 48.1203 60.5561) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1076 60.772) (end 48.1101 60.7797) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1076 60.7619) (end 48.1076 60.772) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2168 60.3148) (end 48.2092 60.3326) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.7263) (end 48.105 60.7339) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1025 60.7162) (end 48.105 60.7263) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1025 60.706) (end 48.1025 60.7162) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1025 60.6882) (end 48.1025 60.6984) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1304 60.5257) (end 48.1279 60.5333) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1558 60.4622) (end 48.1482 60.4774) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2447 60.2513) (end 48.2396 60.2666) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1076 60.612) (end 48.1076 60.6196) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1101 60.6019) (end 48.1076 60.612) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1126 60.5866) (end 48.1101 60.5942) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1634 60.4444) (end 48.1558 60.4622) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1965 60.3631) (end 48.1888 60.3809) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1152 60.5714) (end 48.1126 60.579) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1279 60.5333) (end 48.1253 60.5409) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1761 60.4114) (end 48.1685 60.4291) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2092 60.3326) (end 48.2041 60.3479) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1685 60.4291) (end 48.1634 60.4444) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2041 60.3479) (end 48.1965 60.3631) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1203 60.5561) (end 48.1177 60.5638) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1253 60.5409) (end 48.1228 60.5485) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.232 60.2818) (end 48.2244 60.2996) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.105 60.7441) (end 48.105 60.7517) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1025 60.6984) (end 48.1025 60.706) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1888 60.3809) (end 48.1838 60.3961) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2396 60.2666) (end 48.232 60.2818) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1025 60.6806) (end 48.1025 60.6882) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1076 60.6196) (end 48.105 60.6273) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1101 60.5942) (end 48.1101 60.6019) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.674 59.5452) (end 48.6638 59.5605) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8391 59.3547) (end 48.7857 59.4182) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3344 58.7781) (end 49.2785 58.8416) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3971 59.9491) (end 48.387 59.9643) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4149 59.9186) (end 48.4047 59.9338) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5063 59.7687) (end 48.4962 59.7814) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2523 60.2336) (end 48.2447 60.2513) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5368 59.7256) (end 48.5267 59.7383) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.26 60.2183) (end 48.2523 60.2336) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.547 59.7103) (end 48.5368 59.7256) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6079 59.6265) (end 48.5978 59.6392) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.641 59.5859) (end 48.6308 59.5986) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2676 60.2031) (end 48.26 60.2183) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2752 60.1853) (end 48.2676 60.2031) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2904 60.1548) (end 48.2828 60.1701) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4505 59.8576) (end 48.4403 59.8729) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6112 58.4581) (end 49.5554 58.5216) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.387 59.9643) (end 48.3793 59.9796) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1693 58.9712) (end 49.1159 59.0347) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3209 60.0888) (end 48.3133 60.1066) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1159 59.0347) (end 49.0601 59.0982) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3903 58.7146) (end 49.3344 58.7781) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4886 59.7967) (end 48.4784 59.8119) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3463 60.0431) (end 48.3387 60.0583) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5267 59.7383) (end 48.5165 59.7535) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2828 60.1701) (end 48.2752 60.1853) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3717 59.9948) (end 48.3616 60.01) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6308 59.5986) (end 48.6181 59.6138) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3793 59.9796) (end 48.3717 59.9948) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4403 59.8729) (end 48.4327 59.8881) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4581 59.8424) (end 48.4505 59.8576) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6638 59.5605) (end 48.6511 59.5732) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7299 59.4817) (end 48.674 59.5452) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9508 59.2277) (end 48.895 59.2912) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2252 58.9077) (end 49.1693 58.9712) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2981 60.137) (end 48.2904 60.1548) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0042 59.1642) (end 48.9508 59.2277) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4225 59.9034) (end 48.4149 59.9186) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0601 59.0982) (end 49.0042 59.1642) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4682 59.8272) (end 48.4581 59.8424) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2785 58.8416) (end 49.2252 58.9077) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5165 59.7535) (end 48.5063 59.7687) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4436 58.6511) (end 49.3903 58.7146) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3057 60.1218) (end 48.2981 60.137) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3133 60.1066) (end 48.3057 60.1218) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7857 59.4182) (end 48.7299 59.4817) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4995 58.5876) (end 49.4436 58.6511) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5673 59.6824) (end 48.5571 59.6951) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3311 60.0735) (end 48.3209 60.0888) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3387 60.0583) (end 48.3311 60.0735) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4327 59.8881) (end 48.4225 59.9034) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4962 59.7814) (end 48.4886 59.7967) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6181 59.6138) (end 48.6079 59.6265) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.895 59.2912) (end 48.8391 59.3547) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5775 59.6671) (end 48.5673 59.6824) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5571 59.6951) (end 48.547 59.7103) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5554 58.5216) (end 49.4995 58.5876) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5978 59.6392) (end 48.5876 59.6544) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3539 60.0253) (end 48.3463 60.0431) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3616 60.01) (end 48.3539 60.0253) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4047 59.9338) (end 48.3971 59.9491) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6511 59.5732) (end 48.641 59.5859) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4784 59.8119) (end 48.4682 59.8272) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5876 59.6544) (end 48.5775 59.6671) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.927 57.0382) (end 50.8685 57.0967) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1462 55.9943) (end 52.0776 56.0451) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7583 55.5777) (end 52.7075 55.6108) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8116 55.5422) (end 52.7583 55.5777) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6646 58.3946) (end 49.6112 58.4581) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7205 58.3311) (end 49.6646 58.3946) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8076 57.1551) (end 50.7492 57.216) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7763 58.2676) (end 49.7205 58.3311) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8322 58.2041) (end 49.7763 58.2676) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2859 55.895201) (end 52.2173 55.943501) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.8881 58.1406) (end 49.8322 58.2041) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3298 55.1917) (end 53.2765 55.2272) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1708 56.8046) (end 51.1098 56.863) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2343 56.7487) (end 51.1708 56.8046) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4858 56.5226) (end 51.4223 56.5785) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7448 56.3067) (end 51.6788 56.360101) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3402 57.6402) (end 50.2818 57.7037) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6882 57.2745) (end 50.6298 57.3354) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.944 58.0771) (end 49.8881 58.1406) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.17 57.8282) (end 50.1116 57.8891) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7492 57.216) (end 50.6882 57.2745) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2257 55.2628) (end 53.1749 55.2983) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9999 58.0161) (end 49.944 58.0771) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2173 55.943501) (end 52.1462 55.9943) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0557 57.9526) (end 49.9999 58.0161) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1116 57.8891) (end 50.0557 57.9526) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8685 57.0967) (end 50.8076 57.1551) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4992 55.750501) (end 52.4281 55.7962) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3986 57.5793) (end 50.3402 57.6402) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6298 57.3354) (end 50.5714 57.3964) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9879 56.9798) (end 50.927 57.0382) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9158 55.4736) (end 52.8624 55.5066) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1749 55.2983) (end 53.1215 55.331401) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4223 56.5785) (end 51.3588 56.6344) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0115 56.095901) (end 51.943 56.1467) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.0489 56.9214) (end 50.9879 56.9798) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1098 56.863) (end 51.0489 56.9214) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2953 56.6903) (end 51.2343 56.7487) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8624 55.5066) (end 52.8116 55.5422) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9666 55.438001) (end 52.9158 55.4736) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4281 55.7962) (end 52.357 55.8444) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.357 55.8444) (end 52.2859 55.895201) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6034 55.6819) (end 52.55 55.7149) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0174 55.402501) (end 52.9666 55.438001) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7075 55.6108) (end 52.6542 55.6463) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3806 55.1561) (end 53.3298 55.1917) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2259 57.7647) (end 50.17 57.8282) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1215 55.331401) (end 53.0707 55.366901) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2818 57.7037) (end 50.2259 57.7647) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.4545 57.5183) (end 50.3986 57.5793) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5714 57.3964) (end 50.5129 57.4573) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5129 57.4573) (end 50.4545 57.5183) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3588 56.6344) (end 51.2953 56.6903) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6788 56.360101) (end 51.6128 56.4134) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8769 56.200001) (end 51.8109 56.2534) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0707 55.366901) (end 53.0174 55.402501) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2765 55.2272) (end 53.2257 55.2628) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5493 56.4693) (end 51.4858 56.5226) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.943 56.1467) (end 51.8769 56.200001) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.55 55.7149) (end 52.4992 55.750501) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6128 56.4134) (end 51.5493 56.4693) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0776 56.0451) (end 52.0115 56.095901) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6542 55.6463) (end 52.6034 55.6819) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8109 56.2534) (end 51.7448 56.3067) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7413 54.909701) (end 53.6905 54.945301) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.947 54.7675) (end 53.8962 54.803) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.102 54.6608) (end 54.0486 54.6964) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.3077 54.5186) (end 54.2544 54.5541) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.5642 54.340801) (end 54.5134 54.376301) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.8208 54.163) (end 54.77 54.1985) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3872 53.7743) (end 55.3364 53.8099) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.0799 53.9852) (end 55.0265 54.0207) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.6463 53.5991) (end 55.5955 53.6346) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.852 53.4619) (end 55.8342 53.4746) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9003 53.4314) (end 55.885 53.4416) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9511 53.3984) (end 55.9333 53.4111) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.77 54.1985) (end 54.7192 54.2341) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.9757 54.0563) (end 54.9249 54.0918) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.819 53.4848) (end 55.8038 53.4949) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.0486 54.6964) (end 53.9978 54.7319) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9333 53.4111) (end 55.9181 53.4213) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4822 55.085) (end 53.4314 55.1205) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.8429 54.8386) (end 53.7921 54.874201) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.9978 54.7319) (end 53.947 54.7675) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.1528 54.6252) (end 54.102 54.6608) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.6658 54.2696) (end 54.615 54.3052) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.8673 53.4518) (end 55.852 53.4619) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0679 53.3273) (end 56.0501 53.3375) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.8962 54.803) (end 53.8429 54.8386) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.2036 54.5897) (end 54.1528 54.6252) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9841 53.3781) (end 55.9663 53.3883) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0349 53.3476) (end 56.0171 53.3578) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.2544 54.5541) (end 54.2036 54.5897) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.3585 54.483) (end 54.3077 54.5186) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.4601 54.411901) (end 54.4093 54.447401) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.5134 54.376301) (end 54.4601 54.411901) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.615 54.3052) (end 54.5642 54.340801) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.4405 53.7388) (end 55.3872 53.7743) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.6996 53.5661) (end 55.6463 53.5991) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.885 53.4416) (end 55.8673 53.4518) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.7192 54.2341) (end 54.6658 54.2696) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0171 53.3578) (end 55.9993 53.3679) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.2856 53.845501) (end 55.2323 53.881001) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.7504 53.5305) (end 55.6996 53.5661) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0501 53.3375) (end 56.0349 53.3476) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.8342 53.4746) (end 55.819 53.4848) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9993 53.3679) (end 55.9841 53.3781) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3364 53.8099) (end 55.2856 53.845501) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9663 53.3883) (end 55.9511 53.3984) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.5955 53.6346) (end 55.5447 53.6702) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.1307 53.952101) (end 55.0799 53.9852) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.5447 53.6702) (end 55.4913 53.7058) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4314 55.1205) (end 53.3806 55.1561) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.0265 54.0207) (end 54.9757 54.0563) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.4913 53.7058) (end 55.4405 53.7388) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.8038 53.4949) (end 55.7504 53.5305) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9181 53.4213) (end 55.9003 53.4314) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.5863 55.0164) (end 53.5355 55.0494) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0832 53.3171) (end 56.0679 53.3273) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.2323 53.881001) (end 55.1815 53.916601) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.4093 54.447401) (end 54.3585 54.483) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.6905 54.945301) (end 53.6371 54.980801) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.7921 54.874201) (end 53.7413 54.909701) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.1815 53.916601) (end 55.1307 53.952101) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.8716 54.1274) (end 54.8208 54.163) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.9249 54.0918) (end 54.8716 54.1274) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.5355 55.0494) (end 53.4822 55.085) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.6371 54.980801) (end 53.5863 55.0164) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6928 52.9946) (end 56.675 53.0022) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0484 52.8371) (end 57.0331 52.8396) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8706 52.9107) (end 56.8528 52.9184) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8883 52.9031) (end 56.8706 52.9107) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1009 53.307) (end 56.0832 53.3171) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1187 53.2968) (end 56.1009 53.307) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3245 53.1825) (end 56.3067 53.1901) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.134 53.2867) (end 56.1187 53.2968) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1848 53.2587) (end 56.1695 53.2689) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7258 52.9768) (end 56.708 52.9844) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1271 52.8091) (end 57.1144 52.8142) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0992 52.8168) (end 57.0865 52.8218) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4286 53.1266) (end 56.4108 53.1343) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4438 53.1165) (end 56.4286 53.1266) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.515 53.0809) (end 56.4972 53.0885) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5861 53.0454) (end 56.5683 53.053) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0204 52.8447) (end 57.0077 52.8498) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2889 53.2003) (end 56.2711 53.2105) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1517 53.279) (end 56.134 53.2867) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1144 52.8142) (end 57.0992 52.8168) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3067 53.1901) (end 56.2889 53.2003) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2025 53.2486) (end 56.1848 53.2587) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.708 52.9844) (end 56.6928 52.9946) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.995 52.8549) (end 56.9823 52.8625) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2711 53.2105) (end 56.2533 53.2206) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3397 53.1724) (end 56.3245 53.1825) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3753 53.1546) (end 56.3575 53.1622) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7791 52.9514) (end 56.7613 52.959) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.393 53.1444) (end 56.3753 53.1546) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4108 53.1343) (end 56.393 53.1444) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4972 53.0885) (end 56.4794 53.0987) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9188 52.8879) (end 56.9061 52.8955) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6572 53.0098) (end 56.6394 53.02) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0331 52.8396) (end 57.0204 52.8447) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9823 52.8625) (end 56.9696 52.8676) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0865 52.8218) (end 57.0738 52.8269) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0611 52.832) (end 57.0484 52.8371) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4616 53.1089) (end 56.4438 53.1165) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9061 52.8955) (end 56.8883 52.9031) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9315 52.8828) (end 56.9188 52.8879) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7613 52.959) (end 56.7436 52.9692) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0077 52.8498) (end 56.995 52.8549) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7436 52.9692) (end 56.7258 52.9768) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9442 52.8777) (end 56.9315 52.8828) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8172 52.9361) (end 56.7994 52.9438) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.8528 52.9184) (end 56.835 52.926) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.1695 53.2689) (end 56.1517 53.279) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2203 53.2384) (end 56.2025 53.2486) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2381 53.2282) (end 56.2203 53.2384) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2533 53.2206) (end 56.2381 53.2282) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3575 53.1622) (end 56.3397 53.1724) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4794 53.0987) (end 56.4616 53.1089) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5683 53.053) (end 56.5505 53.0631) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6216 53.0276) (end 56.6039 53.0377) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0738 52.8269) (end 57.0611 52.832) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9569 52.8726) (end 56.9442 52.8777) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5327 53.0708) (end 56.515 53.0809) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6394 53.02) (end 56.6216 53.0276) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7994 52.9438) (end 56.7791 52.9514) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9696 52.8676) (end 56.9569 52.8726) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5505 53.0631) (end 56.5327 53.0708) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.675 53.0022) (end 56.6572 53.0098) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.835 52.926) (end 56.8172 52.9361) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.6039 53.0377) (end 56.5861 53.0454) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3532 52.7787) (end 57.3405 52.7787) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5284 52.832) (end 57.5157 52.8244) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.138 53.8124) (end 58.1025 53.7515) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1398 52.8066) (end 57.1271 52.8091) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.155 52.8015) (end 57.1398 52.8066) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1677 52.799) (end 57.155 52.8015) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.404 52.7863) (end 57.3913 52.7837) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4294 52.7914) (end 57.4167 52.7888) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4421 52.7939) (end 57.4294 52.7914) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6859 52.9971) (end 57.6757 52.9819) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.2041 53.9369) (end 58.171 53.875901) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1804 52.7964) (end 57.1677 52.799) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.1931 52.7939) (end 57.1804 52.7964) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2084 52.7914) (end 57.1931 52.7939) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2617 52.7812) (end 57.249 52.7837) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3024 52.7787) (end 57.2871 52.7812) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6376 52.926) (end 57.6275 52.9133) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4167 52.7888) (end 57.404 52.7863) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4548 52.799) (end 57.4421 52.7939) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6275 52.9133) (end 57.6173 52.9031) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8662 53.3197) (end 57.8307 53.2587) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6173 52.9031) (end 57.6046 52.893) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2211 52.7888) (end 57.2084 52.7914) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5513 52.8447) (end 57.5386 52.8371) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5741 52.8625) (end 57.5614 52.8549) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2338 52.7863) (end 57.2211 52.7888) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3913 52.7837) (end 57.3786 52.7812) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.2726 54.0614) (end 58.2396 53.997901) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8307 53.2587) (end 57.7977 53.1978) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.249 52.7837) (end 57.2338 52.7863) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2744 52.7812) (end 57.2617 52.7812) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2871 52.7812) (end 57.2744 52.7812) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3151 52.7787) (end 57.3024 52.7787) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6046 52.893) (end 57.5945 52.8828) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3278 52.7787) (end 57.3151 52.7787) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6478 52.9387) (end 57.6376 52.926) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.9678 53.5051) (end 57.9348 53.4441) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3405 52.7787) (end 57.3278 52.7787) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3659 52.7812) (end 57.3532 52.7787) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4802 52.8066) (end 57.4675 52.8041) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4929 52.8117) (end 57.4802 52.8066) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5157 52.8244) (end 57.503 52.8193) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.7291 53.0733) (end 57.6961 53.0123) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.658 52.9514) (end 57.6478 52.9387) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5386 52.8371) (end 57.5284 52.832) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5614 52.8549) (end 57.5513 52.8447) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5945 52.8828) (end 57.5843 52.8726) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6757 52.9819) (end 57.6656 52.9666) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.7977 53.1978) (end 57.7621 53.1343) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6656 52.9666) (end 57.658 52.9514) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.7621 53.1343) (end 57.7291 53.0733) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.5843 52.8726) (end 57.5741 52.8625) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.2396 53.997901) (end 58.2041 53.9369) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8993 53.3806) (end 57.8662 53.3197) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.1025 53.7515) (end 58.0694 53.6905) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6961 53.0123) (end 57.6859 52.9971) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.9348 53.4441) (end 57.8993 53.3806) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.171 53.875901) (end 58.138 53.8124) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0364 53.627) (end 58.0009 53.5661) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0694 53.6905) (end 58.0364 53.627) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0009 53.5661) (end 57.9678 53.5051) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3786 52.7812) (end 57.3659 52.7812) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.4675 52.8041) (end 57.4548 52.799) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.503 52.8193) (end 57.4929 52.8117) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8601 56.9671) (end 59.8246 56.9036) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.0804 55.5447) (end 59.0473 55.483801) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.4197 59.7916) (end 61.3079 59.5909) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3057 54.1223) (end 58.2726 54.0614) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3412 54.183301) (end 58.3057 54.1223) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.8467 55.1129) (end 58.8111 55.0494) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.3046 57.7748) (end 60.1929 57.5716) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5282 58.1787) (end 60.4164 57.9755) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3742 54.2468) (end 58.3412 54.183301) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.2836 55.9156) (end 59.2505 55.8546) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.6399 58.3794) (end 60.5282 58.1787) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.215 55.7936) (end 59.181999 55.7301) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.0143 55.4228) (end 58.9813 55.3593) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.4182 56.1645) (end 59.3852 56.1035) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.4868 56.286401) (end 59.4512 56.2254) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.621399 56.5353) (end 59.5884 56.471801) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.723 56.7207) (end 59.69 56.657201) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.7121 54.864) (end 58.6765 54.803) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.2505 55.8546) (end 59.215 55.7936) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.4164 57.9755) (end 60.3046 57.7748) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.6765 54.803) (end 58.6435 54.7421) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7517 58.5826) (end 60.6399 58.3794) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.3521 56.04) (end 59.316599 55.979101) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.9457 55.2983) (end 58.912699 55.2374) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.6432 60.1955) (end 61.5315 59.9948) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.4073 54.3077) (end 58.3742 54.2468) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.5528 56.4109) (end 59.5198 56.3499) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.1929 57.5716) (end 60.0837 57.371) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.440299 54.3687) (end 58.4073 54.3077) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.5774 54.6176) (end 58.5419 54.5541) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.5884 56.471801) (end 59.5528 56.4109) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.610499 54.678601) (end 58.5774 54.6176) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.745099 54.9275) (end 58.7121 54.864) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.0473 55.483801) (end 59.0143 55.4228) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.912699 55.2374) (end 58.8797 55.173901) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.181999 55.7301) (end 59.1489 55.6692) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.1159 55.6082) (end 59.0804 55.5447) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.4758 54.4322) (end 58.440299 54.3687) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.6435 54.7421) (end 58.610499 54.678601) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.5089 54.493201) (end 58.4758 54.4322) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.778099 54.988501) (end 58.745099 54.9275) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.9813 55.3593) (end 58.9457 55.2983) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.5419 54.5541) (end 58.5089 54.493201) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0844 59.1871) (end 60.9752 58.9839) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.5315 59.9948) (end 61.4197 59.7916) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.3079 59.5909) (end 61.1962 59.3877) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.316599 55.979101) (end 59.2836 55.9156) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.7916 56.8427) (end 59.7585 56.781701) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8246 56.9036) (end 59.7916 56.8427) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.8111 55.0494) (end 58.778099 54.988501) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.8797 55.173901) (end 58.8467 55.1129) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9752 58.9839) (end 60.8634 58.7832) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.7585 56.781701) (end 59.723 56.7207) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.1489 55.6692) (end 59.1159 55.6082) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.755 60.3987) (end 61.6432 60.1955) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.3852 56.1035) (end 59.3521 56.04) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.4512 56.2254) (end 59.4182 56.1645) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9719 57.1678) (end 59.8601 56.9671) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.5198 56.3499) (end 59.4868 56.286401) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.6569 56.5963) (end 59.621399 56.5353) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.69 56.657201) (end 59.6569 56.5963) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.0837 57.371) (end 59.9719 57.1678) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.8634 58.7832) (end 60.7517 58.5826) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.1962 59.3877) (end 61.0844 59.1871) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1144 70.071) (end 67.0585 69.9745) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.6615 67.4599) (end 65.5497 67.2567) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.6579 71.0438) (end 67.6046 70.9447) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.2203 68.4657) (end 66.1085 68.265) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4438 68.8696) (end 66.3321 68.6689) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2769 70.3631) (end 67.2211 70.2666) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.0877 61.0032) (end 61.976 60.8025) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.4395 70.6552) (end 67.3862 70.5587) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.1995 61.2064) (end 62.0877 61.0032) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.3112 61.407) (end 62.1995 61.2064) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.091 62.8193) (end 62.9793 62.6186) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.4954 70.7517) (end 67.4395 70.6552) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.423 61.6077) (end 62.3112 61.407) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.5348 61.8109) (end 62.423 61.6077) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.7674 65.847) (end 64.6557 65.6438) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.6465 62.0116) (end 62.5348 61.8109) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8934 69.6747) (end 66.7816 69.4741) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.7583 62.2148) (end 62.6465 62.0116) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.1085 68.265) (end 65.9968 68.0644) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.7616 64.0309) (end 63.6498 63.8277) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.9323 71.5264) (end 67.8764 71.4299) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.2145 66.6521) (end 65.1027 66.4515) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1677 70.17) (end 67.1144 70.071) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.5497 67.2567) (end 65.438 67.056) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.3862 70.5587) (end 67.3303 70.4596) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.87 62.4154) (end 62.7583 62.2148) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.9793 62.6186) (end 62.87 62.4154) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.2028 63.0225) (end 63.091 62.8193) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.6498 63.8277) (end 63.5381 63.627) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.9968 68.0644) (end 65.885 67.8612) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7816 69.4741) (end 66.6699 69.2734) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.885 67.8612) (end 65.7733 67.6605) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0052 69.8779) (end 66.8934 69.6747) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.7672 71.2368) (end 67.7138 71.1403) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.6557 65.6438) (end 64.5439 65.4431) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.0969 64.6354) (end 63.9851 64.4347) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.823 71.3334) (end 67.7672 71.2368) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5556 69.0702) (end 66.4438 68.8696) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.8764 71.4299) (end 67.823 71.3334) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.3145 63.2231) (end 63.2028 63.0225) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0585 69.9745) (end 67.0052 69.8779) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.4263 63.4263) (end 63.3145 63.2231) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.3303 70.4596) (end 67.2769 70.3631) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.5381 63.627) (end 63.4263 63.4263) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.8733 64.2315) (end 63.7616 64.0309) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.9851 64.4347) (end 63.8733 64.2315) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.8792 66.0476) (end 64.7674 65.847) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.6046 70.9447) (end 67.5487 70.8482) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.3262 66.8553) (end 65.2145 66.6521) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.2086 64.836) (end 64.0969 64.6354) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.9909 66.2483) (end 64.8792 66.0476) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6699 69.2734) (end 66.5556 69.0702) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2211 70.2666) (end 67.1677 70.17) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.7138 71.1403) (end 67.6579 71.0438) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.3204 65.0392) (end 64.2086 64.836) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1027 66.4515) (end 64.9909 66.2483) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.4321 65.2399) (end 64.3204 65.0392) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.5487 70.8482) (end 67.4954 70.7517) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.5439 65.4431) (end 64.4321 65.2399) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.7733 67.6605) (end 65.6615 67.4599) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.3321 68.6689) (end 66.2203 68.4657) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.8667 60.5993) (end 61.755 60.3987) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.976 60.8025) (end 61.8667 60.5993) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.438 67.056) (end 65.3262 66.8553) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.8601 74.9122) (end 69.8068 74.8157) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5927 72.6872) (end 68.5368 72.5907) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.5637 76.1543) (end 70.5434 76.1136) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.2066 72.0115) (end 68.1507 71.915) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.3717 72.3011) (end 68.3158 72.2046) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.4834 72.4941) (end 68.4276 72.3976) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.0811 75.2983) (end 70.0252 75.2018) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.1903 75.4939) (end 70.137 75.3974) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9229 73.2688) (end 68.8695 73.1723) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.2462 75.5904) (end 70.1903 75.4939) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.8939 76.7486) (end 70.871 76.708) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8136 73.0758) (end 68.7578 72.9793) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1438 73.6549) (end 69.088 73.5584) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2556 73.848) (end 69.1997 73.7514) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.4766 74.2366) (end 69.4207 74.1375) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.6417 74.5261) (end 69.5858 74.4296) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.7847 76.5505) (end 70.7618 76.5099) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8695 73.1723) (end 68.8136 73.0758) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.137 75.3974) (end 70.0811 75.2983) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.7618 76.5099) (end 70.7415 76.4692) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.3021 75.6869) (end 70.2462 75.5904) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.7415 76.4692) (end 70.7186 76.4311) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0346 73.4619) (end 68.9787 73.3654) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.6094 76.233) (end 70.5866 76.1924) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.6526 76.3118) (end 70.6297 76.2711) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.9881 71.6229) (end 67.9323 71.5264) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.3648 74.041) (end 69.3089 73.9445) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.0252 75.2018) (end 69.9719 75.1053) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.0415 71.722) (end 67.9881 71.6229) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.0974 71.8185) (end 68.0415 71.722) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.4207 74.1375) (end 69.3648 74.041) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.3158 72.2046) (end 68.2625 72.1081) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5368 72.5907) (end 68.4834 72.4941) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.7186 76.4311) (end 70.6958 76.3905) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7578 72.9793) (end 68.7019 72.8828) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.8075 76.5886) (end 70.7847 76.5505) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6485 72.7862) (end 68.5927 72.6872) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.1507 71.915) (end 68.0974 71.8185) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.2625 72.1081) (end 68.2066 72.0115) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.4276 72.3976) (end 68.3717 72.3011) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9787 73.3654) (end 68.9229 73.2688) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.7509 74.7192) (end 69.695 74.6227) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.4646 75.9765) (end 70.4113 75.88) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.8279 76.6293) (end 70.8075 76.5886) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.5866 76.1924) (end 70.5637 76.1543) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.5434 76.1136) (end 70.5205 76.0755) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.8068 74.8157) (end 69.7509 74.7192) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.871 76.708) (end 70.8507 76.6699) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.6958 76.3905) (end 70.6755 76.3524) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.8507 76.6699) (end 70.8279 76.6293) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7019 72.8828) (end 68.6485 72.7862) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.4113 75.88) (end 70.3554 75.7834) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.695 74.6227) (end 69.6417 74.5261) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.6755 76.3524) (end 70.6526 76.3118) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.6297 76.2711) (end 70.6094 76.233) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.088 73.5584) (end 69.0346 73.4619) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1997 73.7514) (end 69.1438 73.6549) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.916 75.0087) (end 69.8601 74.9122) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.3089 73.9445) (end 69.2556 73.848) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.5299 74.3331) (end 69.4766 74.2366) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.5858 74.4296) (end 69.5299 74.3331) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.9719 75.1053) (end 69.916 75.0087) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.3554 75.7834) (end 70.3021 75.6869) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.5205 76.0755) (end 70.4646 75.9765) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.694 78.2244) (end 71.6711 78.1837) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.2782 79.2912) (end 72.2376 79.2175) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.9505 78.6968) (end 71.9099 78.6232) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4984 77.8637) (end 71.4781 77.8256) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.5416 77.945) (end 71.5213 77.9043) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.7575 78.3438) (end 71.7372 78.3031) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.4408 79.5884) (end 72.4001 79.5147) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8235 78.4631) (end 71.8007 78.4225) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.9142 76.7867) (end 70.8939 76.7486) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8464 78.5038) (end 71.8235 78.4631) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.0318 78.8467) (end 71.9912 78.7705) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.1537 79.0677) (end 72.1131 78.994) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.9371 76.8274) (end 70.9142 76.7867) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.9599 76.868) (end 70.9371 76.8274) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.219 77.3455) (end 71.1962 77.3049) (layer Eco1.User) (width 0.5))
  (gr_line (start 70.9803 76.9061) (end 70.9599 76.868) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.628 78.105) (end 71.6076 78.0644) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0031 76.9468) (end 70.9803 76.9061) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4781 77.8256) (end 71.4552 77.785) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0234 76.9874) (end 71.0031 76.9468) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0463 77.028) (end 71.0234 76.9874) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3054 77.5056) (end 71.2825 77.4649) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.7143 78.265) (end 71.694 78.2244) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3689 77.6249) (end 71.3486 77.5843) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8007 78.4225) (end 71.7804 78.3844) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0666 77.0661) (end 71.0463 77.028) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.0895 77.1068) (end 71.0666 77.0661) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.1131 78.994) (end 72.0725 78.9203) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.1962 77.3049) (end 71.1758 77.2668) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4552 77.785) (end 71.4349 77.7443) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.6076 78.0644) (end 71.5848 78.0237) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4349 77.7443) (end 71.4121 77.7062) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.6508 78.1431) (end 71.628 78.105) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.2376 79.2175) (end 72.1969 79.1439) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.3188 79.3648) (end 72.2782 79.2912) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.4814 79.662) (end 72.4408 79.5884) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.1098 77.1474) (end 71.0895 77.1068) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.5645 77.9856) (end 71.5416 77.945) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.1327 77.1855) (end 71.1098 77.1474) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.2393 77.3862) (end 71.219 77.3455) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.6711 78.1837) (end 71.6508 78.1431) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.2622 77.4268) (end 71.2393 77.3862) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.7804 78.3844) (end 71.7575 78.3438) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8896 78.5825) (end 71.8667 78.5419) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.4001 79.5147) (end 72.3595 79.441) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.6033 79.8855) (end 72.5627 79.8119) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.3595 79.441) (end 72.3188 79.3648) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.5627 79.8119) (end 72.522 79.7382) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3257 77.5462) (end 71.3054 77.5056) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.5848 78.0237) (end 71.5645 77.9856) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.522 79.7382) (end 72.4814 79.662) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.7372 78.3031) (end 71.7143 78.265) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.0725 78.9203) (end 72.0318 78.8467) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.153 77.2262) (end 71.1327 77.1855) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.9099 78.6232) (end 71.8896 78.5825) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.2825 77.4649) (end 71.2622 77.4268) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.8667 78.5419) (end 71.8464 78.5038) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.9912 78.7705) (end 71.9505 78.6968) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.1758 77.2668) (end 71.153 77.2262) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.4121 77.7062) (end 71.3917 77.6656) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.5213 77.9043) (end 71.4984 77.8637) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.1969 79.1439) (end 72.1537 79.0677) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3486 77.5843) (end 71.3257 77.5462) (layer Eco1.User) (width 0.5))
  (gr_line (start 71.3917 77.6656) (end 71.3689 77.6249) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.394 83.1571) (end 74.3534 83.0809) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6175 83.5406) (end 74.6099 83.533) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.2561 81.0743) (end 73.2155 81.0006) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.644 79.9592) (end 72.6033 79.8855) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.6846 80.0354) (end 72.644 79.9592) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.8065 80.2564) (end 72.7659 80.1827) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.3127 83.0072) (end 74.2721 82.9335) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.8878 80.4062) (end 72.8472 80.3326) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.0097 80.6298) (end 72.9691 80.5536) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.091 80.7771) (end 73.0504 80.7034) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.1316 80.8507) (end 73.091 80.7771) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.4593 81.4451) (end 73.4187 81.3714) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5236 83.3907) (end 74.5159 83.3806) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5286 83.4009) (end 74.5236 83.3907) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.554 83.4441) (end 74.5464 83.4339) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5794 83.4847) (end 74.5718 83.4746) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.9876 82.4128) (end 73.947 82.3392) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.2315 82.8599) (end 74.1908 82.7837) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.9284 80.4799) (end 72.8878 80.4062) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.8657 82.1893) (end 73.8251 82.1157) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.2721 82.9335) (end 74.2315 82.8599) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.2967 81.1479) (end 73.2561 81.0743) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.7031 81.8921) (end 73.6625 81.8185) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6226 83.5508) (end 74.6175 83.5406) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.7252 80.1091) (end 72.6846 80.0354) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.2155 81.0006) (end 73.1723 80.9269) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.3534 83.0809) (end 74.3127 83.0072) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.6219 81.7448) (end 73.5812 81.6686) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.7659 80.1827) (end 72.7252 80.1091) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.0283 82.4865) (end 73.9876 82.4128) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.8472 80.3326) (end 72.8065 80.2564) (layer Eco1.User) (width 0.5))
  (gr_line (start 72.9691 80.5536) (end 72.9284 80.4799) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.4347 83.2307) (end 74.394 83.1571) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5464 83.4339) (end 74.5413 83.4238) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6048 83.5228) (end 74.5972 83.5127) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.3374 81.2241) (end 73.2967 81.1479) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.4999 81.5213) (end 73.4593 81.4451) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.5812 81.6686) (end 73.5406 81.595) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.5406 81.595) (end 73.4999 81.5213) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.6625 81.8185) (end 73.6219 81.7448) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.1908 82.7837) (end 74.1502 82.71) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.4753 83.3044) (end 74.4347 83.2307) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5337 83.4111) (end 74.5286 83.4009) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.7844 82.042) (end 73.7438 81.9658) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.1723 80.9269) (end 73.1316 80.8507) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5159 83.3806) (end 74.4753 83.3044) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.378 81.2978) (end 73.3374 81.2241) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.0504 80.7034) (end 73.0097 80.6298) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.8251 82.1157) (end 73.7844 82.042) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.4187 81.3714) (end 73.378 81.2978) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.1502 82.71) (end 74.1095 82.6364) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.7438 81.9658) (end 73.7031 81.8921) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5413 83.4238) (end 74.5337 83.4111) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.9063 82.263) (end 73.8657 82.1893) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5718 83.4746) (end 74.5667 83.4644) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5921 83.5025) (end 74.5845 83.4949) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.1095 82.6364) (end 74.0689 82.5602) (layer Eco1.User) (width 0.5))
  (gr_line (start 73.947 82.3392) (end 73.9063 82.263) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.0689 82.5602) (end 74.0283 82.4865) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5972 83.5127) (end 74.5921 83.5025) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5591 83.4542) (end 74.554 83.4441) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6099 83.533) (end 74.6048 83.5228) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5667 83.4644) (end 74.5591 83.4542) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.5845 83.4949) (end 74.5794 83.4847) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2729 83.914) (end 75.2576 83.914) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.742 83.6828) (end 74.7344 83.6752) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.775 83.7133) (end 74.7674 83.7057) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9249 83.8073) (end 74.9147 83.8022) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9731 83.8302) (end 74.9604 83.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8512 83.7667) (end 74.8411 83.759) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8919 83.7895) (end 74.8817 83.7844) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.1103 83.8835) (end 75.0925 83.8784) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.1941 83.9038) (end 75.1763 83.9013) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3313 83.9191) (end 75.3186 83.9191) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8309 83.754) (end 74.8207 83.7463) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0366 83.8556) (end 75.0214 83.8505) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0925 83.8784) (end 75.0773 83.8708) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.1611 83.8962) (end 75.1433 83.8911) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3033 83.9165) (end 75.2881 83.9165) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9147 83.8022) (end 74.902 83.7971) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6302 83.5609) (end 74.6226 83.5508) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6379 83.5685) (end 74.6302 83.5609) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6429 83.5787) (end 74.6379 83.5685) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6506 83.5863) (end 74.6429 83.5787) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.902 83.7971) (end 74.8919 83.7895) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9376 83.8149) (end 74.9249 83.8073) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.062 83.8657) (end 75.0493 83.8606) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6582 83.5939) (end 74.6506 83.5863) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6658 83.6041) (end 74.6582 83.5939) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6709 83.6117) (end 74.6658 83.6041) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6785 83.6193) (end 74.6709 83.6117) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.709 83.6524) (end 74.7014 83.6447) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9477 83.82) (end 74.9376 83.8149) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7496 83.6905) (end 74.742 83.6828) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.803 83.7336) (end 74.7928 83.726) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9604 83.8251) (end 74.9477 83.82) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7344 83.6752) (end 74.7242 83.6676) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6861 83.6295) (end 74.6785 83.6193) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7014 83.6447) (end 74.6937 83.6371) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7166 83.66) (end 74.709 83.6524) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.9833 83.8352) (end 74.9731 83.8302) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0493 83.8606) (end 75.0366 83.8556) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7242 83.6676) (end 74.7166 83.66) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7572 83.6981) (end 74.7496 83.6905) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8817 83.7844) (end 74.8715 83.7794) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8715 83.7794) (end 74.8614 83.7717) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0087 83.8454) (end 74.996 83.8403) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2576 83.914) (end 75.2424 83.9114) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0773 83.8708) (end 75.062 83.8657) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7852 83.7184) (end 74.775 83.7133) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.0214 83.8505) (end 75.0087 83.8454) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2094 83.9064) (end 75.1941 83.9038) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7674 83.7057) (end 74.7572 83.6981) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.7928 83.726) (end 74.7852 83.7184) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8207 83.7463) (end 74.8106 83.7387) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8411 83.759) (end 74.8309 83.754) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.1763 83.9013) (end 75.1611 83.8962) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8614 83.7717) (end 74.8512 83.7667) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.996 83.8403) (end 74.9833 83.8352) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2424 83.9114) (end 75.2246 83.9089) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.1281 83.8886) (end 75.1103 83.8835) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2246 83.9089) (end 75.2094 83.9064) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.2881 83.9165) (end 75.2729 83.914) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3465 83.9191) (end 75.3313 83.9191) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.1433 83.8911) (end 75.1281 83.8886) (layer Eco1.User) (width 0.5))
  (gr_line (start 75.3186 83.9191) (end 75.3033 83.9165) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.6937 83.6371) (end 74.6861 83.6295) (layer Eco1.User) (width 0.5))
  (gr_line (start 74.8106 83.7387) (end 74.803 83.7336) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7197 88.2066) (end 68.7247 88.199) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6663 88.265) (end 68.6714 88.2599) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.712 88.2117) (end 68.7197 88.2066) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.707 88.2193) (end 68.712 88.2117) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7019 88.2244) (end 68.707 88.2193) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6943 88.232001) (end 68.7019 88.2244) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6892 88.2396) (end 68.6943 88.232001) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6841 88.2447) (end 68.6892 88.2396) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.679 88.2523) (end 68.6841 88.2447) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6714 88.2599) (end 68.679 88.2523) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6612 88.2726) (end 68.6663 88.265) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5368 88.7146) (end 68.5393 88.6993) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6384 88.3031) (end 68.646 88.2929) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.58 88.4657) (end 68.5825 88.4504) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6562 88.2802) (end 68.6612 88.2726) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5901 88.425) (end 68.5927 88.4123) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5596 88.590101) (end 68.5622 88.574901) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6054 88.3742) (end 68.6104 88.361501) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6511 88.285301) (end 68.6562 88.2802) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5698 88.7222) (end 68.5622 88.7197) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.646 88.2929) (end 68.6511 88.285301) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6155 88.3488) (end 68.6206 88.3361) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5622 88.574901) (end 68.5647 88.5622) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5774 88.4784) (end 68.58 88.4657) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6333 88.3158) (end 68.6384 88.3031) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6257 88.326) (end 68.6333 88.3158) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6206 88.3361) (end 68.6257 88.326) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5393 88.6993) (end 68.5419 88.686601) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6104 88.361501) (end 68.6155 88.3488) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.552 88.6308) (end 68.5546 88.618101) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6003 88.3869) (end 68.6054 88.3742) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5977 88.399601) (end 68.6003 88.3869) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5927 88.4123) (end 68.5977 88.399601) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5876 88.437701) (end 68.5901 88.425) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5673 88.534201) (end 68.5698 88.519001) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5749 88.4911) (end 68.5774 88.4784) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5698 88.519001) (end 68.5723 88.5063) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5444 88.7146) (end 68.5368 88.7146) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5647 88.5622) (end 68.5647 88.5469) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5647 88.5469) (end 68.5673 88.534201) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.552 88.7171) (end 68.5444 88.7146) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5723 88.5063) (end 68.5749 88.4911) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5571 88.6028) (end 68.5596 88.590101) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5546 88.618101) (end 68.5571 88.6028) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5622 88.7197) (end 68.552 88.7171) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5469 88.6587) (end 68.5495 88.646) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5444 88.6739) (end 68.5469 88.6587) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5419 88.686601) (end 68.5444 88.6739) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5495 88.646) (end 68.552 88.6308) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7247 88.199) (end 68.7298 88.193901) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5825 88.4504) (end 68.5876 88.437701) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8746 88.818701) (end 68.867 88.8162) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1083 88.7755) (end 69.093 88.7832) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8975 88.823801) (end 68.8898 88.8213) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6587 88.7501) (end 68.6511 88.747601) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7451 88.780601) (end 68.7349 88.7781) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7679 88.7882) (end 68.7603 88.785701) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0372 88.8136) (end 69.0245 88.818701) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7781 88.7908) (end 68.7679 88.7882) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8263 88.806) (end 68.8187 88.803501) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8517 88.8136) (end 68.8441 88.8111) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1769 88.7222) (end 69.1667 88.732401) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1565 88.74) (end 69.1438 88.7501) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5927 88.7298) (end 68.585 88.727301) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0118 88.8213) (end 68.9991 88.823801) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6181 88.7374) (end 68.6104 88.7349) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6943 88.762801) (end 68.6841 88.7603) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0803 88.7908) (end 69.0651 88.7984) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6358 88.742501) (end 68.6257 88.74) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9584 88.8289) (end 68.9432 88.8289) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1667 88.732401) (end 69.1565 88.74) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9432 88.8289) (end 68.9279 88.8263) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6257 88.74) (end 68.6181 88.7374) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7273 88.773) (end 68.7197 88.770501) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0499 88.806) (end 69.0372 88.8136) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7603 88.785701) (end 68.7527 88.7832) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6841 88.7603) (end 68.6765 88.7578) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7019 88.765401) (end 68.6943 88.762801) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8441 88.8111) (end 68.834 88.808601) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.867 88.8162) (end 68.8594 88.8136) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8822 88.8213) (end 68.8746 88.818701) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9127 88.8263) (end 68.9051 88.823801) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9203 88.8263) (end 68.9127 88.8263) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9991 88.823801) (end 68.9838 88.8263) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.093 88.7832) (end 69.0803 88.7908) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9711 88.8289) (end 68.9584 88.8289) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1438 88.7501) (end 69.1311 88.7578) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.121 88.7679) (end 69.1083 88.7755) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6689 88.7527) (end 68.6587 88.7501) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9279 88.8263) (end 68.9203 88.8263) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7095 88.7679) (end 68.7019 88.765401) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9838 88.8263) (end 68.9711 88.8289) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0651 88.7984) (end 69.0499 88.806) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7527 88.7832) (end 68.7451 88.780601) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.5774 88.724701) (end 68.5698 88.7222) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.585 88.727301) (end 68.5774 88.724701) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6765 88.7578) (end 68.6689 88.7527) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8898 88.8213) (end 68.8822 88.8213) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7933 88.7959) (end 68.7857 88.7933) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.187 88.712) (end 69.1769 88.7222) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7349 88.7781) (end 68.7273 88.773) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0245 88.818701) (end 69.0118 88.8213) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8009 88.7984) (end 68.7933 88.7959) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.834 88.808601) (end 68.8263 88.806) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9051 88.823801) (end 68.8975 88.823801) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1311 88.7578) (end 69.121 88.7679) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6028 88.732401) (end 68.5927 88.7298) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7857 88.7933) (end 68.7781 88.7908) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8187 88.803501) (end 68.8111 88.800901) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6104 88.7349) (end 68.6028 88.732401) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6435 88.7451) (end 68.6358 88.742501) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.6511 88.747601) (end 68.6435 88.7451) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8594 88.8136) (end 68.8517 88.8136) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7197 88.770501) (end 68.7095 88.7679) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8111 88.800901) (end 68.8009 88.7984) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2861 88.519001) (end 69.2835 88.5317) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2785 88.3006) (end 69.281 88.3183) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1261 87.945) (end 69.1388 87.965301) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1972 88.7019) (end 69.187 88.712) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2073 88.6917) (end 69.1972 88.7019) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2937 88.460601) (end 69.2912 88.475801) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7293 89.1108) (end 84.7115 89.1134) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2937 88.4301) (end 69.2937 88.4453) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2302 88.6587) (end 69.2226 88.6689) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2937 88.4149) (end 69.2937 88.4301) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1718 88.0262) (end 69.1819 88.044) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2581 88.610401) (end 69.2505 88.6231) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2734 88.572301) (end 69.2683 88.585) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6937 89.1134) (end 84.6734 89.1159) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2937 88.4453) (end 69.2937 88.460601) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2175 88.1228) (end 69.2251 88.1405) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7852 89.1032) (end 84.7674 89.1057) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2912 88.399601) (end 69.2937 88.4149) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6175 89.121) (end 84.5972 89.121) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2251 88.1405) (end 69.2327 88.1583) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5972 89.121) (end 84.5769 89.1235) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2327 88.1583) (end 69.2404 88.1786) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2683 88.267501) (end 69.2734 88.2828) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7496 89.1083) (end 84.7293 89.1108) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2581 88.232001) (end 69.2658 88.2498) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2226 88.6689) (end 69.215 88.679) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2454 88.6358) (end 69.2378 88.646) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2912 88.475801) (end 69.2912 88.4885) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2505 88.6231) (end 69.2454 88.6358) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2759 88.5596) (end 69.2734 88.572301) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2404 88.1786) (end 69.248 88.1964) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1489 87.9856) (end 69.1616 88.0059) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1007 87.904301) (end 69.1134 87.9246) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6734 89.1159) (end 84.6556 89.1184) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6353 89.1184) (end 84.6175 89.121) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2099 88.1024) (end 69.2175 88.1228) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0884 87.882901) (end 69.1007 87.904301) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.281 88.5444) (end 69.2759 88.5596) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5769 89.1235) (end 84.5774 89.1219) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2835 88.5317) (end 69.281 88.5444) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6556 89.1184) (end 84.6353 89.1184) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7674 89.1057) (end 84.7496 89.1083) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2861 88.3514) (end 69.2886 88.366601) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1997 88.0847) (end 69.2099 88.1024) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2734 88.2828) (end 69.2785 88.3006) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.281 88.3183) (end 69.2835 88.3336) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1388 87.965301) (end 69.1489 87.9856) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1819 88.044) (end 69.1921 88.0643) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.248 88.1964) (end 69.2531 88.2142) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1921 88.0643) (end 69.1997 88.0847) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7115 89.1134) (end 84.6937 89.1134) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2886 88.366601) (end 69.2912 88.384401) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2531 88.2142) (end 69.2581 88.232001) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1134 87.9246) (end 69.1261 87.945) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2658 88.2498) (end 69.2683 88.267501) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.215 88.679) (end 69.2073 88.6917) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2378 88.646) (end 69.2302 88.6587) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2886 88.503801) (end 69.2861 88.519001) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.1616 88.0059) (end 69.1718 88.0262) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2632 88.5977) (end 69.2581 88.610401) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2683 88.585) (end 69.2632 88.5977) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2912 88.4885) (end 69.2886 88.503801) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2912 88.384401) (end 69.2912 88.399601) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.2835 88.3336) (end 69.2861 88.3514) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1281 88.9787) (end 85.1179 88.9864) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8182 89.0981) (end 84.8004 89.1007) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2322 88.8492) (end 85.2271 88.861901) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8004 89.1007) (end 84.7852 89.1032) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.836 89.093) (end 84.8182 89.0981) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8512 89.0905) (end 84.836 89.093) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1636 88.9457) (end 85.156 88.9559) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1814 88.9305) (end 85.1738 88.938101) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9147 89.0753) (end 84.8995 89.0803) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.189 88.9203) (end 85.1814 88.9305) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2601 88.656201) (end 85.2601 88.6689) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8842 89.0829) (end 84.869 89.088) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8995 89.0803) (end 84.8842 89.0829) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0011 89.0473) (end 84.9858 89.0524) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0519 89.027) (end 85.0392 89.0321) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0874 89.0067) (end 85.0747 89.0143) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2601 88.727301) (end 85.2601 88.74) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1738 88.938101) (end 85.1636 88.9457) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1966 88.9102) (end 85.189 88.9203) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2601 88.74) (end 85.2576 88.7552) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2449 88.6054) (end 85.2474 88.613001) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2576 88.7552) (end 85.2551 88.7679) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.869 89.088) (end 84.8512 89.0905) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2398 88.8289) (end 85.2347 88.839001) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2474 88.803501) (end 85.2449 88.8162) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9858 89.0524) (end 84.9731 89.0575) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0265 89.0372) (end 85.0138 89.0422) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.156 88.9559) (end 85.1458 88.9635) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2474 88.613001) (end 85.25 88.6206) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9299 89.0727) (end 84.9147 89.0753) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0392 89.0321) (end 85.0265 89.0372) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9452 89.0676) (end 84.9299 89.0727) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9579 89.0626) (end 84.9452 89.0676) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2551 88.7679) (end 85.2525 88.780601) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9731 89.0575) (end 84.9579 89.0626) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2601 88.712) (end 85.2601 88.727301) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2347 88.5825) (end 85.2398 88.590101) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0138 89.0422) (end 85.0011 89.0473) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0976 88.9991) (end 85.0874 89.0067) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1077 88.994) (end 85.0976 88.9991) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1179 88.9864) (end 85.1077 88.994) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2144 88.8822) (end 85.2093 88.8924) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2551 88.6358) (end 85.2576 88.6435) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2627 88.6993) (end 85.2601 88.712) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2347 88.839001) (end 85.2322 88.8492) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2271 88.861901) (end 85.222 88.8721) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2525 88.780601) (end 85.25 88.7933) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2601 88.6689) (end 85.2627 88.6841) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.25 88.6206) (end 85.2525 88.628201) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2627 88.6841) (end 85.2627 88.6993) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2525 88.628201) (end 85.2551 88.6358) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2093 88.8924) (end 85.2017 88.9025) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2449 88.8162) (end 85.2398 88.8289) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.25 88.7933) (end 85.2474 88.803501) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2424 88.5977) (end 85.2449 88.6054) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.062 89.0194) (end 85.0519 89.027) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1382 88.9711) (end 85.1281 88.9787) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2576 88.6435) (end 85.2601 88.656201) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2398 88.590101) (end 85.2424 88.5977) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0747 89.0143) (end 85.062 89.0194) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2322 88.574901) (end 85.2347 88.5825) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1458 88.9635) (end 85.1382 88.9711) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2017 88.9025) (end 85.1966 88.9102) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.222 88.8721) (end 85.2144 88.8822) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0569 88.3768) (end 85.0646 88.384401) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9096 88.2955) (end 84.9172 88.298) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9706 88.3209) (end 84.9782 88.323401) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1255 88.437701) (end 85.1331 88.4453) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1103 88.422501) (end 85.1179 88.4301) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0341 88.359) (end 85.0417 88.3641) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2271 88.5673) (end 85.2322 88.574901) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0087 88.343701) (end 85.0188 88.3488) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0011 88.3387) (end 85.0087 88.343701) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9553 88.3133) (end 84.963 88.3158) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7902 88.2904) (end 84.8029 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9325 88.3031) (end 84.9401 88.305601) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.222 88.5596) (end 85.2271 88.5673) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.217 88.552001) (end 85.222 88.5596) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2068 88.536801) (end 85.2119 88.5444) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0798 88.3971) (end 85.0874 88.4022) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8512 88.2904) (end 84.8639 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1865 88.5063) (end 85.1916 88.513901) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1331 88.4453) (end 85.1408 88.453) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8639 88.2904) (end 84.8741 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7166 88.298) (end 84.7293 88.298) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8741 88.2904) (end 84.8893 88.2929) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0493 88.3717) (end 85.0569 88.3768) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1662 88.4834) (end 85.1738 88.4911) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0188 88.3488) (end 85.0265 88.3539) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2119 88.5444) (end 85.217 88.552001) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1458 88.460601) (end 85.1535 88.4682) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9401 88.305601) (end 84.9477 88.308201) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7293 88.298) (end 84.742 88.2955) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1408 88.453) (end 85.1458 88.460601) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0874 88.4022) (end 85.095 88.4098) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0722 88.3895) (end 85.0798 88.3971) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9172 88.298) (end 84.9249 88.3006) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8893 88.2929) (end 84.902 88.2955) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.2017 88.5292) (end 85.2068 88.536801) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8385 88.2904) (end 84.8512 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1966 88.5215) (end 85.2017 88.5292) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1027 88.4174) (end 85.1103 88.422501) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1916 88.513901) (end 85.1966 88.5215) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1789 88.498701) (end 85.1865 88.5063) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0646 88.384401) (end 85.0722 88.3895) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0265 88.3539) (end 85.0341 88.359) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7648 88.2929) (end 84.7775 88.2929) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8283 88.2904) (end 84.8385 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.095 88.4098) (end 85.1027 88.4174) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9858 88.3285) (end 84.9934 88.3336) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.902 88.2955) (end 84.9096 88.2955) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8029 88.2904) (end 84.8156 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.742 88.2955) (end 84.7547 88.2929) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.8156 88.2904) (end 84.8283 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7547 88.2929) (end 84.7648 88.2929) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.0417 88.3641) (end 85.0493 88.3717) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9477 88.308201) (end 84.9553 88.3133) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9782 88.323401) (end 84.9858 88.3285) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7039 88.3006) (end 84.7166 88.298) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9934 88.3336) (end 85.0011 88.3387) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.963 88.3158) (end 84.9706 88.3209) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.7775 88.2929) (end 84.7902 88.2904) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6912 88.3031) (end 84.7039 88.3006) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1535 88.4682) (end 85.1611 88.475801) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1179 88.4301) (end 85.1255 88.437701) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.9249 88.3006) (end 84.9325 88.3031) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1738 88.4911) (end 85.1789 88.498701) (layer Eco1.User) (width 0.5))
  (gr_line (start 85.1611 88.475801) (end 85.1662 88.4834) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3407 88.5977) (end 84.3457 88.585) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.333 88.7171) (end 84.333 88.7019) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3381 88.762801) (end 84.3356 88.747601) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4702 88.3945) (end 84.4804 88.3895) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4524 88.4098) (end 84.46 88.4022) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3762 88.503801) (end 84.3838 88.4911) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3788 88.867) (end 84.3762 88.861901) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.361 88.536801) (end 84.3661 88.5241) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.681 88.305601) (end 84.6912 88.3031) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3559 88.5469) (end 84.361 88.536801) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3356 88.6257) (end 84.3381 88.613001) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.333 88.6689) (end 84.333 88.6536) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6683 88.308201) (end 84.681 88.305601) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3711 88.8543) (end 84.3686 88.846701) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6074 88.323401) (end 84.6201 88.3209) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6201 88.3209) (end 84.6328 88.3183) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4194 88.442801) (end 84.427 88.4352) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4804 88.3895) (end 84.488 88.381801) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3584 88.8263) (end 84.3559 88.818701) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5616 88.3412) (end 84.5743 88.3361) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3559 88.818701) (end 84.3534 88.8111) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5312 88.3564) (end 84.5413 88.3514) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3889 88.480901) (end 84.3965 88.4707) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3838 88.8746) (end 84.3788 88.867) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3661 88.5241) (end 84.3711 88.513901) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4981 88.3742) (end 84.5083 88.3691) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.488 88.381801) (end 84.4981 88.3742) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.333 88.6536) (end 84.3356 88.6409) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.427 88.4352) (end 84.4346 88.4276) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4118 88.453) (end 84.4194 88.442801) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.333 88.7019) (end 84.333 88.6841) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.333 88.732401) (end 84.333 88.7171) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3457 88.7908) (end 84.3407 88.7755) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3686 88.846701) (end 84.3661 88.839001) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.361 88.834) (end 84.3584 88.8263) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6556 88.3107) (end 84.6683 88.308201) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3508 88.806) (end 84.3457 88.7908) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4423 88.4174) (end 84.4524 88.4098) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3534 88.8111) (end 84.3508 88.806) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4042 88.4631) (end 84.4118 88.453) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3661 88.839001) (end 84.361 88.834) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6429 88.3133) (end 84.6556 88.3107) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3711 88.513901) (end 84.3762 88.503801) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.6328 88.3183) (end 84.6429 88.3133) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5972 88.3285) (end 84.6074 88.323401) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5845 88.3336) (end 84.5972 88.3285) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3356 88.747601) (end 84.333 88.732401) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3483 88.572301) (end 84.3508 88.5596) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5515 88.346301) (end 84.5616 88.3412) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4346 88.4276) (end 84.4423 88.4174) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3762 88.861901) (end 84.3711 88.8543) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3838 88.4911) (end 84.3889 88.480901) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3356 88.6409) (end 84.3356 88.6257) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3407 88.7755) (end 84.3381 88.762801) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3457 88.585) (end 84.3483 88.572301) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5743 88.3361) (end 84.5845 88.3336) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3508 88.5596) (end 84.3559 88.5469) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3381 88.613001) (end 84.3407 88.5977) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5413 88.3514) (end 84.5515 88.346301) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5083 88.3691) (end 84.5185 88.3641) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.46 88.4022) (end 84.4702 88.3945) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.333 88.6841) (end 84.333 88.6689) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5185 88.3641) (end 84.5312 88.3564) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3965 88.4707) (end 84.4042 88.4631) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5337 89.0676) (end 84.5235 89.0575) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3991 88.900001) (end 84.3965 88.894901) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1652 95.1814) (end 67.1779 95.2068) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3864 88.8822) (end 84.3838 88.8746) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3915 88.8873) (end 84.3864 88.8822) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.3965 88.894901) (end 84.3915 88.8873) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5642 89.1057) (end 84.5566 89.0956) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5774 89.1219) (end 84.5693 89.1134) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4042 88.9076) (end 84.3991 88.900001) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.427 88.9406) (end 84.4219 88.933001) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2592 95.3516) (end 67.261 95.3491) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4194 88.9279) (end 84.4143 88.9203) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4575 88.9762) (end 84.4524 88.9711) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4778 89.0016) (end 84.4727 88.994) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4956 89.0245) (end 84.4854 89.0118) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0712 95.0138) (end 67.0839 95.0392) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8985 94.7064) (end 66.9112 94.7293) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4092 88.915201) (end 84.4042 88.9076) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4219 88.933001) (end 84.4194 88.9279) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5693 89.1134) (end 84.5642 89.1057) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9366 94.7776) (end 66.9518 94.8004) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2465 95.3262) (end 67.2592 95.3516) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1372 95.1332) (end 67.1525 95.1586) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9899 94.8715) (end 67.0052 94.8944) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1118 95.0849) (end 67.1245 95.1103) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4677 88.9889) (end 84.4626 88.9838) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5566 89.0956) (end 84.5489 89.0854) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0179 94.9198) (end 67.0306 94.9427) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4524 88.9711) (end 84.4473 88.966) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8832 94.6836) (end 66.8985 94.7064) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4727 88.994) (end 84.4677 88.9889) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4143 88.9203) (end 84.4092 88.915201) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4321 88.9457) (end 84.427 88.9406) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4372 88.9533) (end 84.4321 88.9457) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4423 88.9584) (end 84.4372 88.9533) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4473 88.966) (end 84.4423 88.9584) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0585 94.9909) (end 67.0712 95.0138) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0306 94.9427) (end 67.0433 94.9681) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4626 88.9838) (end 84.4575 88.9762) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4804 89.0067) (end 84.4778 89.0016) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0052 94.8944) (end 67.0179 94.9198) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2058 95.2551) (end 67.2185 95.2779) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0433 94.9681) (end 67.0585 94.9909) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9645 94.8233) (end 66.9772 94.8487) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1525 95.1586) (end 67.1652 95.1814) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1779 95.2068) (end 67.1931 95.2297) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5159 89.0448) (end 84.5058 89.0346) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5235 89.0575) (end 84.5159 89.0448) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9518 94.8004) (end 66.9645 94.8233) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.4854 89.0118) (end 84.4804 89.0067) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5058 89.0346) (end 84.4956 89.0245) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2185 95.2779) (end 67.2338 95.3033) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1245 95.1103) (end 67.1372 95.1332) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0966 95.062) (end 67.1118 95.0849) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9772 94.8487) (end 66.9899 94.8715) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.0839 95.0392) (end 67.0966 95.062) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8578 94.6353) (end 66.8705 94.6582) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5413 89.0778) (end 84.5337 89.0676) (layer Eco1.User) (width 0.5))
  (gr_line (start 84.5489 89.0854) (end 84.5413 89.0778) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8705 94.6582) (end 66.8832 94.6836) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.2338 95.3033) (end 67.2465 95.3262) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9239 94.7522) (end 66.9366 94.7776) (layer Eco1.User) (width 0.5))
  (gr_line (start 67.1931 95.2297) (end 67.2058 95.2551) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.9112 94.7293) (end 66.9239 94.7522) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.8639 91.0463) (end 64.9554 91.2114) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.2305 93.5101) (end 66.3219 93.6727) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.139 93.345) (end 66.2305 93.5101) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.8606 89.2404) (end 63.9521 89.4055) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8451 94.6125) (end 66.8578 94.6353) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7918 94.5185) (end 66.8045 94.5413) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7131 94.3762) (end 66.7258 94.3991) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7004 94.3534) (end 66.7131 94.3762) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4921 93.9775) (end 66.5048 94.0003) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.4982 90.391) (end 64.5896 90.5535) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.9521 89.4055) (end 64.0435 89.5706) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.2272 91.7042) (end 65.3186 91.8667) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.647 94.2594) (end 66.6597 94.2823) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.6811 90.7186) (end 64.7725 90.8837) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.135 89.7331) (end 64.2239 89.8982) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5962 94.1654) (end 66.6089 94.1883) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8324 94.5871) (end 66.8451 94.6125) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8172 94.5642) (end 66.8324 94.5871) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.8045 94.5413) (end 66.8172 94.5642) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7791 94.4931) (end 66.7918 94.5185) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.41 92.0318) (end 65.5015 92.1969) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.7692 89.0778) (end 63.8606 89.2404) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7664 94.4702) (end 66.7791 94.4931) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5048 94.0003) (end 66.5175 94.0257) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7537 94.4474) (end 66.7664 94.4702) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7385 94.4245) (end 66.7537 94.4474) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.7258 94.3991) (end 66.7385 94.4245) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4514 93.9089) (end 66.4667 93.9317) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.6778 88.9127) (end 63.7692 89.0778) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6877 94.3305) (end 66.7004 94.3534) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.9554 91.2114) (end 65.0468 91.374) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.9587 93.0173) (end 66.0501 93.1799) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.5015 92.1969) (end 65.5929 92.3595) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6597 94.2823) (end 66.675 94.3051) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5429 94.0714) (end 66.5556 94.0943) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.675 94.3051) (end 66.6877 94.3305) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4794 93.9546) (end 66.4921 93.9775) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.0435 89.5706) (end 64.135 89.7331) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.0501 93.1799) (end 66.139 93.345) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.8672 92.8522) (end 65.9587 93.0173) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4667 93.9317) (end 66.4794 93.9546) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.426 93.8606) (end 66.4387 93.8835) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.7758 92.6871) (end 65.8672 92.8522) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.3153 90.0608) (end 64.4067 90.2259) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.3219 93.6727) (end 66.4133 93.8378) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.1357 91.5391) (end 65.2272 91.7042) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6343 94.2365) (end 66.647 94.2594) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.5929 92.3595) (end 65.6844 92.5246) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.2239 89.8982) (end 64.3153 90.0608) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6216 94.2111) (end 66.6343 94.2365) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.6089 94.1883) (end 66.6216 94.2111) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5835 94.1426) (end 66.5962 94.1654) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5683 94.1197) (end 66.5835 94.1426) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5556 94.0943) (end 66.5683 94.1197) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5302 94.0486) (end 66.5429 94.0714) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.6844 92.5246) (end 65.7758 92.6871) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.3186 91.8667) (end 65.41 92.0318) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4387 93.8835) (end 66.4514 93.9089) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.7725 90.8837) (end 64.8639 91.0463) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.4067 90.2259) (end 64.4982 90.391) (layer Eco1.User) (width 0.5))
  (gr_line (start 65.0468 91.374) (end 65.1357 91.5391) (layer Eco1.User) (width 0.5))
  (gr_line (start 64.5896 90.5535) (end 64.6811 90.7186) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.4133 93.8378) (end 66.426 93.8606) (layer Eco1.User) (width 0.5))
  (gr_line (start 66.5175 94.0257) (end 66.5302 94.0486) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.0402 87.7646) (end 63.1317 87.927201) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.5122 81.4197) (end 59.6315 81.6331) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.4479 79.5096) (end 58.5673 79.7204) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.6745 87.1068) (end 62.7659 87.2719) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.583 86.9442) (end 62.6745 87.1068) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.1284 86.1212) (end 62.2198 86.2863) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.5797 85.1383) (end 61.6712 85.3008) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.1251 84.3178) (end 61.214 84.4804) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.5764 83.3323) (end 60.6679 83.4974) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.2208 82.6948) (end 60.3402 82.9081) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.8678 82.0572) (end 59.9846 82.2706) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.8035 80.1472) (end 58.9229 80.358) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.3112 86.4514) (end 62.4001 86.614) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.7593 83.66) (end 60.8507 83.8251) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.9846 82.2706) (end 60.104 82.484) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.9229 80.358) (end 59.0397 80.5713) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.8586 78.4454) (end 57.9755 78.6587) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.1317 87.927201) (end 63.2231 88.0923) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.9488 87.599501) (end 63.0402 87.7646) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.8573 87.4344) (end 62.9488 87.599501) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.3953 81.2089) (end 59.5122 81.4197) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.3311 79.2963) (end 58.4479 79.5096) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.457 83.119) (end 60.5764 83.3323) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.15 77.1728) (end 57.2668 77.3836) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.7659 87.2719) (end 62.8573 87.4344) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.6315 81.6331) (end 59.7484 81.8464) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.5673 79.7204) (end 58.686699 79.9338) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.3862 77.597) (end 57.503 77.8104) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.0369 85.9587) (end 62.1284 86.1212) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.7626 85.4659) (end 61.854 85.631) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.6712 85.3008) (end 61.7626 85.4659) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.4883 84.9732) (end 61.5797 85.1383) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.214 84.4804) (end 61.3054 84.6455) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.0336 84.1527) (end 61.1251 84.3178) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.9422 83.9902) (end 61.0336 84.1527) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.3402 82.9081) (end 60.457 83.119) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.7392 78.2345) (end 57.8586 78.4454) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.503 77.8104) (end 57.6224 78.0212) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.6679 83.4974) (end 60.7593 83.66) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.2759 80.9955) (end 59.3953 81.2089) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.2668 77.3836) (end 57.3862 77.597) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.2117 79.0829) (end 58.3311 79.2963) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.6224 78.0212) (end 57.7392 78.2345) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.7484 81.8464) (end 59.8678 82.0572) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.686699 79.9338) (end 58.8035 80.1472) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.1591 80.7822) (end 59.2759 80.9955) (layer Eco1.User) (width 0.5))
  (gr_line (start 58.0948 78.8721) (end 58.2117 79.0829) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.3054 84.6455) (end 61.3968 84.8106) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.2198 86.2863) (end 62.3112 86.4514) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.3968 84.8106) (end 61.4883 84.9732) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.8507 83.8251) (end 60.9422 83.9902) (layer Eco1.User) (width 0.5))
  (gr_line (start 60.104 82.484) (end 60.2208 82.6948) (layer Eco1.User) (width 0.5))
  (gr_line (start 59.0397 80.5713) (end 59.1591 80.7822) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.312 88.2574) (end 63.4034 88.419901) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.0306 76.9595) (end 57.15 77.1728) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.854 85.631) (end 61.9455 85.7936) (layer Eco1.User) (width 0.5))
  (gr_line (start 57.9755 78.6587) (end 58.0948 78.8721) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.5863 88.747601) (end 63.6778 88.9127) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.4949 88.585) (end 63.5863 88.747601) (layer Eco1.User) (width 0.5))
  (gr_line (start 61.9455 85.7936) (end 62.0369 85.9587) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.4916 86.7791) (end 62.583 86.9442) (layer Eco1.User) (width 0.5))
  (gr_line (start 62.4001 86.614) (end 62.4916 86.7791) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.4034 88.419901) (end 63.4949 88.585) (layer Eco1.User) (width 0.5))
  (gr_line (start 63.2231 88.0923) (end 63.312 88.2574) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.054 66.2203) (end 51.1276 66.355) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.9361 69.6036) (end 53.0098 69.7382) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1817 68.2498) (end 52.2579 68.3844) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.1081 68.1152) (end 52.1817 68.2498) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.9112 76.7461) (end 57.0306 76.9595) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.7944 76.5353) (end 56.9112 76.7461) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.3745 73.9851) (end 55.4939 74.1985) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.675 76.3219) (end 56.7944 76.5353) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.7862 69.3318) (end 52.8599 69.4665) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.7517 65.6793) (end 50.8279 65.8139) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.6658 72.7126) (end 54.7852 72.9234) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.3537 66.7614) (end 51.4299 66.896) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.549 72.4992) (end 54.6658 72.7126) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.074 71.6509) (end 54.1934 71.8617) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9041 65.9486) (end 50.9778 66.0857) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.6016 70.8) (end 53.721 71.0133) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.3219 75.6844) (end 56.4388 75.8977) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.6107 74.4118) (end 55.7301 74.6227) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.5581 76.1111) (end 56.675 76.3219) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.4388 75.8977) (end 56.5581 76.1111) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.4939 74.1985) (end 55.6107 74.4118) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5061 67.0331) (end 51.5797 67.1678) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.2025 75.4736) (end 56.3219 75.6844) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.8599 69.4665) (end 52.9361 69.6036) (layer Eco1.User) (width 0.5))
  (gr_line (start 56.0857 75.2602) (end 56.2025 75.4736) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.9663 75.0468) (end 56.0857 75.2602) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.2577 73.7743) (end 55.3745 73.9851) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.5602 68.9254) (end 52.6338 69.0626) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.7301 74.6227) (end 55.8495 74.836) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.0214 73.3501) (end 55.1383 73.5609) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.1276 66.355) (end 51.2038 66.4896) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.9557 67.8434) (end 52.0319 67.978) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.5797 67.1678) (end 51.6559 67.3024) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.1934 71.8617) (end 54.3102 72.075) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.1291 69.9516) (end 53.2485 70.1624) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.9021 73.1368) (end 55.0214 73.3501) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.7852 72.9234) (end 54.9021 73.1368) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.4296 72.2859) (end 54.549 72.4992) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.0319 67.978) (end 52.1081 68.1152) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.882 67.7088) (end 51.9557 67.8434) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.6338 69.0626) (end 52.71 69.1972) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.71 69.1972) (end 52.7862 69.3318) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.4078 68.6562) (end 52.484 68.7908) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.8058 67.5742) (end 51.882 67.7088) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.2579 68.3844) (end 52.3341 68.5216) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.28 66.6267) (end 51.3537 66.7614) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.8495 74.836) (end 55.9663 75.0468) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.6559 67.3024) (end 51.7296 67.437) (layer Eco1.User) (width 0.5))
  (gr_line (start 55.1383 73.5609) (end 55.2577 73.7743) (layer Eco1.User) (width 0.5))
  (gr_line (start 54.3102 72.075) (end 54.4296 72.2859) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.9572 71.4375) (end 54.074 71.6509) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.8378 71.2241) (end 53.9572 71.4375) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.721 71.0133) (end 53.8378 71.2241) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.3654 70.3758) (end 53.4847 70.5891) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.2485 70.1624) (end 53.3654 70.3758) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.7296 67.437) (end 51.8058 67.5742) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.4299 66.896) (end 51.5061 67.0331) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.0098 69.7382) (end 53.1291 69.9516) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.484 68.7908) (end 52.5602 68.9254) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.9778 66.0857) (end 51.054 66.2203) (layer Eco1.User) (width 0.5))
  (gr_line (start 51.2038 66.4896) (end 51.28 66.6267) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.8279 65.8139) (end 50.9041 65.9486) (layer Eco1.User) (width 0.5))
  (gr_line (start 52.3341 68.5216) (end 52.4078 68.6562) (layer Eco1.User) (width 0.5))
  (gr_line (start 53.4847 70.5891) (end 53.6016 70.8) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1304 60.8914) (end 48.133 60.9016) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.5503 63.5127) (end 49.6265 63.6473) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.2506 62.9717) (end 49.3242 63.1063) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1744 62.8345) (end 49.2506 62.9717) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.9508 62.4281) (end 49.0245 62.5653) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.801 62.1589) (end 48.8746 62.2935) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.3514 61.3461) (end 48.4251 61.4807) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1888 61.0514) (end 48.1939 61.0591) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1685 61.0057) (end 48.1711 61.0133) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1228 60.8559) (end 48.1228 60.8635) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1584 60.9803) (end 48.1609 60.9879) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1406 60.927) (end 48.1431 60.9371) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1761 61.021) (end 48.1787 61.0286) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1253 60.8736) (end 48.1279 60.8813) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1152 60.8178) (end 48.1152 60.8279) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.678 65.5422) (end 50.7517 65.6793) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.6018 65.4075) (end 50.678 65.5422) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.5256 65.2729) (end 50.6018 65.4075) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.452 65.1383) (end 50.5256 65.2729) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.1523 64.5947) (end 50.2259 64.7319) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4004 63.2409) (end 49.4741 63.3781) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1457 60.9448) (end 48.1482 60.9549) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.166 60.9956) (end 48.1685 61.0057) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3758 65.0011) (end 50.452 65.1383) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.3021 64.8665) (end 50.3758 65.0011) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.0761 64.4601) (end 50.1523 64.5947) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9999 64.3255) (end 50.0761 64.4601) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.85 64.0537) (end 49.9262 64.1909) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7763 63.9191) (end 49.85 64.0537) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.7001 63.7845) (end 49.7763 63.9191) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.133 60.9016) (end 48.1355 60.9092) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.6265 63.6473) (end 49.7001 63.7845) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1482 60.9549) (end 48.1533 60.9625) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2752 61.2089) (end 48.3514 61.3461) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1863 61.0438) (end 48.1888 61.0514) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1609 60.9879) (end 48.166 60.9956) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.4741 63.3781) (end 49.5503 63.5127) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.3242 63.1063) (end 49.4004 63.2409) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.7248 62.0217) (end 48.801 62.1589) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5013 61.6153) (end 48.5749 61.7525) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.4251 61.4807) (end 48.5013 61.6153) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1838 61.0362) (end 48.1863 61.0438) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1711 61.0133) (end 48.1761 61.021) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1177 60.8355) (end 48.1203 60.8457) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1939 61.0591) (end 48.1965 61.0667) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.138 60.9194) (end 48.1406 60.927) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1965 61.0667) (end 48.2015 61.0743) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1533 60.9625) (end 48.1558 60.9702) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1152 60.8279) (end 48.1177 60.8355) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.1007 62.6999) (end 49.1744 62.8345) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.2015 61.0743) (end 48.2752 61.2089) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.8746 62.2935) (end 48.9508 62.4281) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1787 61.0286) (end 48.1838 61.0362) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.0245 62.5653) (end 49.1007 62.6999) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.5749 61.7525) (end 48.6511 61.8871) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1558 60.9702) (end 48.1584 60.9803) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1431 60.9371) (end 48.1457 60.9448) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.6511 61.8871) (end 48.7248 62.0217) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1279 60.8813) (end 48.1304 60.8914) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1203 60.8457) (end 48.1228 60.8559) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1355 60.9092) (end 48.138 60.9194) (layer Eco1.User) (width 0.5))
  (gr_line (start 48.1228 60.8635) (end 48.1253 60.8736) (layer Eco1.User) (width 0.5))
  (gr_line (start 50.2259 64.7319) (end 50.3021 64.8665) (layer Eco1.User) (width 0.5))
  (gr_line (start 49.9262 64.1909) (end 49.9999 64.3255) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0549 87.9119) (end 69.0626 87.904301) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0397 87.9246) (end 69.0473 87.9196) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0245 87.9373) (end 69.0321 87.9323) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9711 87.9831) (end 68.9787 87.978) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9406 88.0085) (end 68.9483 88.003401) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.994 87.965301) (end 69.0016 87.9577) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7882 88.1355) (end 68.7959 88.1304) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.867 88.0694) (end 68.8721 88.0643) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8314 88.0999) (end 68.8365 88.094801) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7552 88.1685) (end 68.7628 88.1609) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9787 87.978) (end 68.9864 87.9704) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9025 88.0389) (end 68.9102 88.0339) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8721 88.0643) (end 68.8797 88.056701) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8441 88.0872) (end 68.8517 88.0821) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7298 88.193901) (end 68.7374 88.1863) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9635 87.9907) (end 68.9711 87.9831) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8873 88.0516) (end 68.8949 88.0466) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9559 87.9958) (end 68.9635 87.9907) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0626 87.904301) (end 69.0727 87.8992) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9483 88.003401) (end 68.9559 87.9958) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0803 87.8916) (end 69.088 87.884) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9864 87.9704) (end 68.994 87.965301) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7832 88.1431) (end 68.7882 88.1355) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7501 88.1736) (end 68.7552 88.1685) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.933 88.0135) (end 68.9406 88.0085) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8949 88.0466) (end 68.9025 88.0389) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0092 87.9526) (end 69.0168 87.945) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9178 88.0262) (end 68.9254 88.0212) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9102 88.0339) (end 68.9178 88.0262) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7425 88.1812) (end 68.7501 88.1736) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8797 88.056701) (end 68.8873 88.0516) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8035 88.1253) (end 68.8086 88.117701) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7959 88.1304) (end 68.8035 88.1253) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7628 88.1609) (end 68.7679 88.155801) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8238 88.105) (end 68.8314 88.0999) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7679 88.155801) (end 68.7755 88.1482) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0016 87.9577) (end 69.0092 87.9526) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7755 88.1482) (end 68.7832 88.1431) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8365 88.094801) (end 68.8441 88.0872) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.7374 88.1863) (end 68.7425 88.1812) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0727 87.8992) (end 69.0803 87.8916) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0473 87.9196) (end 69.0549 87.9119) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8086 88.117701) (end 68.8162 88.1126) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.9254 88.0212) (end 68.933 88.0135) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0321 87.9323) (end 69.0397 87.9246) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.0168 87.945) (end 69.0245 87.9373) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8162 88.1126) (end 68.8238 88.105) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8594 88.0745) (end 68.867 88.0694) (layer Eco1.User) (width 0.5))
  (gr_line (start 68.8517 88.0821) (end 68.8594 88.0745) (layer Eco1.User) (width 0.5))
  (gr_line (start 69.088 87.884) (end 69.0884 87.882901) (layer Eco1.User) (width 0.5))
  (segment (start 75.9715 61.468) (end 75.9715 63.8285) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 75.9715 63.8285) (end 74.4 65.4) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 74.4 65.4) (end 70.2 65.4) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 70.2 65.4) (end 60.4 55.6) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 60.4 55.6) (end 54.639092 55.6) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 54.639092 55.6) (end 49.6 60.639092) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 49.366437 63.318945) (end 49.366437 73.833563) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 49.6 60.639092) (end 49.6 62.271839) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 49.6 62.271839) (end 49.366437 63.318945) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 49.366437 73.833563) (end 45.4 77.8) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 45.4 77.8) (end 45.4 75.8) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 42.002 72.402) (end 40.592 72.402) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 45.4 75.8) (end 42.002 72.402) (width 0.25) (layer F.Cu) (net 1))
  (segment (start 36.592 72.402) (end 36 72.994) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 37.592 72.402) (end 36.592 72.402) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 38.56 82.512) (end 38.56 83.312) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 36 79.952) (end 38.56 82.512) (width 0.25) (layer F.Cu) (net 2))
  (segment (start 36 72.994) (end 36 79.952) (width 0.25) (layer F.Cu) (net 2))
  (via (at 73 59.8) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 74.5915 59.8) (end 73 59.8) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 75.9715 58.42) (end 74.5915 59.8) (width 0.25) (layer F.Cu) (net 3))
  (via (at 67.4 59.8) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 73 59.8) (end 67.4 59.8) (width 0.25) (layer B.Cu) (net 3))
  (via (at 37.8 76.2) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 37.8 74.11) (end 37.592 73.902) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 37.8 76.2) (end 37.8 74.11) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 37.8 76.2) (end 41.8 76.2) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 54.452692 55.149989) (end 48.916426 60.686255) (width 0.25) (layer F.Cu) (net 3))
  (via (at 44.31266 73.68734) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 3))
  (segment (start 48.916426 72.083574) (end 47.31266 73.68734) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 41.8 76.2) (end 44.31266 73.68734) (width 0.25) (layer B.Cu) (net 3))
  (segment (start 44.878345 73.68734) (end 44.31266 73.68734) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 62.749989 55.149989) (end 54.452692 55.149989) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 47.31266 73.68734) (end 44.878345 73.68734) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 67.4 59.8) (end 62.749989 55.149989) (width 0.25) (layer F.Cu) (net 3))
  (segment (start 48.916426 60.686255) (end 48.916426 72.083574) (width 0.25) (layer F.Cu) (net 3))
  (via (at 39 80.2) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 40.592 78.608) (end 39 80.2) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 40.592 73.902) (end 40.592 78.608) (width 0.25) (layer F.Cu) (net 4))
  (via (at 34.2 81.4) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 4))
  (segment (start 37.8 81.4) (end 34.2 81.4) (width 0.25) (layer B.Cu) (net 4))
  (segment (start 39 80.2) (end 37.8 81.4) (width 0.25) (layer B.Cu) (net 4))
  (segment (start 34.56 84.812) (end 35.56 84.812) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 34.2 84.452) (end 34.56 84.812) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 34.2 81.4) (end 34.2 84.452) (width 0.25) (layer F.Cu) (net 4))
  (segment (start 51.93 56.8) (end 48 56.8) (width 0.25) (layer F.Cu) (net 5))
  (segment (start 54.64 54.09) (end 51.93 56.8) (width 0.25) (layer F.Cu) (net 5))
  (via (at 48 56.8) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 5))
  (segment (start 54.84 54.09) (end 54.64 54.09) (width 0.25) (layer F.Cu) (net 5))
  (segment (start 48 56.8) (end 41 56.8) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 41 56.8) (end 40 56.8) (width 0.25) (layer B.Cu) (net 5))
  (via (at 39.4 64) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 5))
  (segment (start 39.4 57.4) (end 39.4 64) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 40 56.8) (end 39.4 57.4) (width 0.25) (layer B.Cu) (net 5))
  (segment (start 42.664 64) (end 42.672 64.008) (width 0.25) (layer F.Cu) (net 5))
  (segment (start 39.4 64) (end 42.664 64) (width 0.25) (layer F.Cu) (net 5))
  (segment (start 45.672 61.708) (end 45.672 62.508) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 45.672 57.758) (end 45.672 61.708) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 50.84 52.59) (end 45.672 57.758) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 51.84 52.59) (end 50.84 52.59) (width 0.25) (layer F.Cu) (net 6))
  (segment (start 36.56 83.312) (end 37.4 84.152) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 35.56 83.312) (end 36.56 83.312) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 39.576 95.212) (end 39.576 96.012) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 37.4 93.036) (end 39.576 95.212) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 37.4 84.152) (end 37.4 93.036) (width 0.25) (layer F.Cu) (net 7))
  (segment (start 38.56 85.612) (end 38.56 84.812) (width 0.25) (layer F.Cu) (net 8))
  (segment (start 36.576 97.512) (end 36.776 97.512) (width 0.25) (layer F.Cu) (net 8))
  (segment (start 36.776 97.512) (end 38.064 98.8) (width 0.25) (layer F.Cu) (net 8))
  (segment (start 42.6 89.652) (end 38.56 85.612) (width 0.25) (layer F.Cu) (net 8))
  (segment (start 38.064 98.8) (end 42.6 98.8) (width 0.25) (layer F.Cu) (net 8))
  (segment (start 42.6 98.8) (end 42.6 89.652) (width 0.25) (layer F.Cu) (net 8))
  (segment (start 52.84 54.09) (end 53.4 53.53) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 51.84 54.09) (end 52.84 54.09) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 53.4 52.144998) (end 55.144998 50.4) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 53.4 53.53) (end 53.4 52.144998) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 55.144998 50.4) (end 58.4 50.4) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 67.048 50.534) (end 66.6 50.086) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 68.048 50.534) (end 67.048 50.534) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 58.799999 50.000001) (end 58.4 50.4) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 60.641001 48.158999) (end 58.799999 50.000001) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 66.058001 48.158999) (end 60.641001 48.158999) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 66.6 48.700998) (end 66.058001 48.158999) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 66.6 50.086) (end 66.6 48.700998) (width 0.25) (layer F.Cu) (net 9))
  (segment (start 65.048 49.034) (end 61.766 49.034) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 58.21 52.59) (end 54.84 52.59) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 61.766 49.034) (end 58.21 52.59) (width 0.25) (layer F.Cu) (net 10))
  (segment (start 70.921 61.468) (end 71.4 60.989) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 70.3835 61.468) (end 70.921 61.468) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 69.048 49.034) (end 68.048 49.034) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 71.4 51.386) (end 69.048 49.034) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 71.4 60.989) (end 71.4 51.386) (width 0.25) (layer F.Cu) (net 11))
  (segment (start 65.248 50.534) (end 65.048 50.534) (width 0.25) (layer F.Cu) (net 12))
  (segment (start 70.3835 55.6695) (end 65.248 50.534) (width 0.25) (layer F.Cu) (net 12))
  (segment (start 70.3835 58.42) (end 70.3835 55.6695) (width 0.25) (layer F.Cu) (net 12))
  (via (at 83 55.4) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 13))
  (segment (start 81.5595 56.8405) (end 83 55.4) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 81.5595 58.42) (end 81.5595 56.8405) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 83 55.4) (end 85 53.4) (width 0.25) (layer B.Cu) (net 13))
  (via (at 85 52.4) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 13))
  (segment (start 85 53.4) (end 85 52.4) (width 0.25) (layer B.Cu) (net 13))
  (segment (start 85 51.834315) (end 85.2 51.634315) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 85 52.4) (end 85 51.834315) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 85.2 51.634315) (end 85.2 49) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 86.041001 48.158999) (end 86.041001 47.958999) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 85.2 49) (end 86.041001 48.158999) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 90.44 49.034) (end 91.44 49.034) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 89.364999 47.958999) (end 90.44 49.034) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 86.041001 47.958999) (end 89.364999 47.958999) (width 0.25) (layer F.Cu) (net 13))
  (segment (start 99.568 55.614) (end 93.414 55.614) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 93.414 55.614) (end 90 52.2) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 89.44 49.034) (end 88.44 49.034) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 90 49.594) (end 89.44 49.034) (width 0.25) (layer F.Cu) (net 14))
  (segment (start 90 52.2) (end 90 49.594) (width 0.25) (layer F.Cu) (net 14))
  (via (at 83.8 56.6) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 15))
  (segment (start 84.365685 56.6) (end 85.8 55.165685) (width 0.25) (layer B.Cu) (net 15))
  (segment (start 83.8 56.6) (end 84.365685 56.6) (width 0.25) (layer B.Cu) (net 15))
  (via (at 85.8 54.6) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 15))
  (segment (start 85.8 55.165685) (end 85.8 54.6) (width 0.25) (layer B.Cu) (net 15))
  (segment (start 88.24 50.534) (end 88.44 50.534) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 85.8 52.974) (end 88.24 50.534) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 85.8 54.6) (end 85.8 52.974) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 82.674998 57.725002) (end 83.400001 56.999999) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 83.400001 56.999999) (end 83.8 56.6) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 81.5595 61.468) (end 82.674998 60.352502) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 82.674998 60.352502) (end 82.674998 57.725002) (width 0.25) (layer F.Cu) (net 15))
  (segment (start 91.44 50.64) (end 91.44 50.534) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 93 52.2) (end 91.44 50.64) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 99.654 52.2) (end 93 52.2) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 101.568 54.114) (end 99.654 52.2) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 102.568 54.114) (end 101.568 54.114) (width 0.25) (layer F.Cu) (net 16))
  (segment (start 119.38 86.12) (end 119.38 85.32) (width 0.25) (layer F.Cu) (net 17))
  (via (at 118.6 89.6) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 17))
  (segment (start 119.38 88.82) (end 118.6 89.6) (width 0.25) (layer F.Cu) (net 17))
  (segment (start 119.38 86.12) (end 119.38 88.82) (width 0.25) (layer F.Cu) (net 17))
  (segment (start 118.6 89.6) (end 117.8 90.4) (width 0.25) (layer B.Cu) (net 17))
  (via (at 112.2 96.8) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 17))
  (segment (start 117.8 91.2) (end 112.2 96.8) (width 0.25) (layer B.Cu) (net 17))
  (segment (start 117.8 90.4) (end 117.8 91.2) (width 0.25) (layer B.Cu) (net 17))
  (segment (start 113.324 97.778) (end 114.324 97.778) (width 0.25) (layer F.Cu) (net 17))
  (segment (start 112.612315 97.778) (end 113.324 97.778) (width 0.25) (layer F.Cu) (net 17))
  (segment (start 112.2 97.365685) (end 112.612315 97.778) (width 0.25) (layer F.Cu) (net 17))
  (segment (start 112.2 96.8) (end 112.2 97.365685) (width 0.25) (layer F.Cu) (net 17))
  (segment (start 117.38 83.82) (end 117.8 84.24) (width 0.25) (layer F.Cu) (net 18))
  (segment (start 116.38 83.82) (end 117.38 83.82) (width 0.25) (layer F.Cu) (net 18))
  (segment (start 117.324 95.478) (end 117.324 96.278) (width 0.25) (layer F.Cu) (net 18))
  (segment (start 117.8 95.002) (end 117.324 95.478) (width 0.25) (layer F.Cu) (net 18))
  (segment (start 117.8 84.24) (end 117.8 95.002) (width 0.25) (layer F.Cu) (net 18))
  (via (at 103.4 62.2) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 19))
  (segment (start 104.942 63.742) (end 103.4 62.2) (width 0.25) (layer F.Cu) (net 19))
  (segment (start 107.212 63.742) (end 104.942 63.742) (width 0.25) (layer F.Cu) (net 19))
  (via (at 103.047159 56.952841) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 19))
  (segment (start 103.4 57.305682) (end 103.047159 56.952841) (width 0.25) (layer B.Cu) (net 19))
  (segment (start 102.568 55.614) (end 102.568 56.473682) (width 0.25) (layer F.Cu) (net 19))
  (segment (start 102.568 56.473682) (end 102.64716 56.552842) (width 0.25) (layer F.Cu) (net 19))
  (segment (start 103.4 62.2) (end 103.4 57.305682) (width 0.25) (layer B.Cu) (net 19))
  (segment (start 102.64716 56.552842) (end 103.047159 56.952841) (width 0.25) (layer F.Cu) (net 19))
  (segment (start 110.212 61.442) (end 106.97 58.2) (width 0.25) (layer F.Cu) (net 20))
  (segment (start 110.212 62.242) (end 110.212 61.442) (width 0.25) (layer F.Cu) (net 20))
  (segment (start 106.97 58.2) (end 103.268998 58.2) (width 0.25) (layer F.Cu) (net 20))
  (segment (start 103.268998 58.2) (end 101.068998 56) (width 0.25) (layer F.Cu) (net 20))
  (segment (start 100.568 54.114) (end 99.568 54.114) (width 0.25) (layer F.Cu) (net 20))
  (segment (start 101.068998 54.614998) (end 100.568 54.114) (width 0.25) (layer F.Cu) (net 20))
  (segment (start 101.068998 56) (end 101.068998 54.614998) (width 0.25) (layer F.Cu) (net 20))
  (segment (start 114.816 70.37) (end 115.4 70.954) (width 0.25) (layer F.Cu) (net 21))
  (segment (start 113.816 70.37) (end 114.816 70.37) (width 0.25) (layer F.Cu) (net 21))
  (via (at 115.4 74.2) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 21))
  (segment (start 115.4 70.954) (end 115.4 74.2) (width 0.25) (layer F.Cu) (net 21))
  (via (at 118.2 76.6) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 21))
  (segment (start 117.8 76.6) (end 118.2 76.6) (width 0.25) (layer B.Cu) (net 21))
  (segment (start 115.4 74.2) (end 117.8 76.6) (width 0.25) (layer B.Cu) (net 21))
  (segment (start 119.18 83.82) (end 119.38 83.82) (width 0.25) (layer F.Cu) (net 21))
  (segment (start 118.2 82.84) (end 119.18 83.82) (width 0.25) (layer F.Cu) (net 21))
  (segment (start 118.2 76.6) (end 118.2 82.84) (width 0.25) (layer F.Cu) (net 21))
  (segment (start 115.304999 82.662547) (end 115.37488 82.22512) (width 0.25) (layer F.Cu) (net 22))
  (segment (start 115.304999 85.244999) (end 115.304999 82.662547) (width 0.25) (layer F.Cu) (net 22))
  (segment (start 115.38 85.32) (end 115.304999 85.244999) (width 0.25) (layer F.Cu) (net 22))
  (segment (start 116.38 85.32) (end 115.38 85.32) (width 0.25) (layer F.Cu) (net 22))
  (segment (start 116.816 80.784) (end 116.816 71.87) (width 0.25) (layer F.Cu) (net 22))
  (segment (start 115.37488 82.22512) (end 116.816 80.784) (width 0.25) (layer F.Cu) (net 22))
  (segment (start 106.8 73.2) (end 95.068 61.468) (width 0.25) (layer F.Cu) (net 23))
  (segment (start 113.286 73.2) (end 106.8 73.2) (width 0.25) (layer F.Cu) (net 23))
  (segment (start 113.816 72.67) (end 113.286 73.2) (width 0.25) (layer F.Cu) (net 23))
  (segment (start 95.068 61.468) (end 87.1475 61.468) (width 0.25) (layer F.Cu) (net 23))
  (segment (start 113.816 71.87) (end 113.816 72.67) (width 0.25) (layer F.Cu) (net 23))
  (via (at 116.2 68.4) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 24))
  (segment (start 116.816 69.016) (end 116.2 68.4) (width 0.25) (layer F.Cu) (net 24))
  (segment (start 116.816 70.37) (end 116.816 69.016) (width 0.25) (layer F.Cu) (net 24))
  (segment (start 116.2 68.4) (end 107.4 68.4) (width 0.25) (layer B.Cu) (net 24))
  (via (at 106.8 67.4) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 24))
  (segment (start 106.8 67.8) (end 106.8 67.4) (width 0.25) (layer B.Cu) (net 24))
  (segment (start 107.4 68.4) (end 106.8 67.8) (width 0.25) (layer B.Cu) (net 24))
  (segment (start 87.685 58.42) (end 87.1475 58.42) (width 0.25) (layer F.Cu) (net 24))
  (segment (start 106.8 67.4) (end 97.82 58.42) (width 0.25) (layer F.Cu) (net 24))
  (segment (start 97.82 58.42) (end 87.685 58.42) (width 0.25) (layer F.Cu) (net 24))
  (segment (start 114.709002 96.278) (end 114.324 96.278) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 116.209002 97.778) (end 114.709002 96.278) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 117.324 97.778) (end 116.209002 97.778) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 113.324 96.278) (end 111.6 94.554) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 114.324 96.278) (end 113.324 96.278) (width 0.25) (layer F.Cu) (net 25))
  (via (at 114.8 88) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 25))
  (segment (start 111.6 91.2) (end 114.8 88) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 111.6 94.554) (end 111.6 91.2) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 109.212 63.742) (end 109.07 63.6) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 110.212 63.742) (end 109.212 63.742) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 108.212 62.242) (end 107.212 62.242) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 109.07 63.1) (end 108.212 62.242) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 109.07 63.6) (end 109.07 63.1) (width 0.25) (layer F.Cu) (net 25))
  (via (at 111.4 72.47499) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 25))
  (segment (start 116 77.07499) (end 111.799999 72.874989) (width 0.25) (layer B.Cu) (net 25))
  (segment (start 110.212 63.742) (end 110.212 64.542) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 114.8 88) (end 116 86.8) (width 0.25) (layer B.Cu) (net 25))
  (segment (start 116 86.8) (end 116 77.07499) (width 0.25) (layer B.Cu) (net 25))
  (segment (start 110.212 64.542) (end 111.4 65.73) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 111.4 71.909305) (end 111.4 72.47499) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 111.799999 72.874989) (end 111.4 72.47499) (width 0.25) (layer B.Cu) (net 25))
  (segment (start 111.4 65.73) (end 111.4 71.909305) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 81.670372 52.206372) (end 80.772 51.308) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 100.583579 57.61999) (end 87.08399 57.61999) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 105.205589 62.242) (end 100.583579 57.61999) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 107.212 62.242) (end 105.205589 62.242) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 87.08399 57.61999) (end 81.670372 52.206372) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 80.772 49.972) (end 80.772 51.308) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 77 46.2) (end 80.772 49.972) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 38 57.4) (end 49.2 46.2) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 44.608 64.008) (end 43.108 62.508) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 38 61.2) (end 38 57.4) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 49.2 46.2) (end 77 46.2) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 45.672 64.008) (end 44.608 64.008) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 39.308 62.508) (end 38 61.2) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 43.108 62.508) (end 39.308 62.508) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 44.672 64.008) (end 39.88 68.8) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 45.672 64.008) (end 44.672 64.008) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 39.308998 68.8) (end 32.8 75.308998) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 39.88 68.8) (end 39.308998 68.8) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 32.8 75.308998) (end 32.8 91.436) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 36.576 95.212) (end 36.576 96.012) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 32.8 91.436) (end 36.576 95.212) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 39.190998 97.512) (end 39.576 97.512) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 37.690998 96.012) (end 39.190998 97.512) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 36.576 96.012) (end 37.690998 96.012) (width 0.25) (layer F.Cu) (net 25))
  (segment (start 78.272 56.7075) (end 79.9845 58.42) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 78.272 51.308) (end 78.272 56.7075) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 83.42 58.42) (end 83.4 58.4) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 85.5725 58.42) (end 83.42 58.42) (width 0.25) (layer F.Cu) (net 26))
  (via (at 83.4 58.4) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 26))
  (segment (start 78.272 53.272) (end 78.272 51.308) (width 0.25) (layer B.Cu) (net 26))
  (segment (start 83.4 58.4) (end 78.272 53.272) (width 0.25) (layer B.Cu) (net 26))
  (segment (start 78.272 57.363494) (end 75.835494 59.8) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 78.272 56.7075) (end 78.272 57.363494) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 75.835494 60.029006) (end 74.3965 61.468) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 75.835494 59.8) (end 75.835494 60.029006) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 68.8085 62.043) (end 70.3655 63.6) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 68.8085 61.468) (end 68.8085 62.043) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 72.2645 63.6) (end 74.3965 61.468) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 70.3655 63.6) (end 72.2645 63.6) (width 0.25) (layer F.Cu) (net 26))
  (segment (start 75.772 57.0445) (end 74.3965 58.42) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 75.772 51.308) (end 75.772 57.0445) (width 0.25) (layer F.Cu) (net 27))
  (via (at 78.2 59.8) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 27))
  (segment (start 79.868 61.468) (end 78.2 59.8) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 79.9845 61.468) (end 79.868 61.468) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 75.772 52.533) (end 75.772 51.308) (width 0.25) (layer B.Cu) (net 27))
  (segment (start 75.772 56.806315) (end 75.772 52.533) (width 0.25) (layer B.Cu) (net 27))
  (segment (start 78.2 59.234315) (end 75.772 56.806315) (width 0.25) (layer B.Cu) (net 27))
  (segment (start 78.2 59.8) (end 78.2 59.234315) (width 0.25) (layer B.Cu) (net 27))
  (segment (start 79.9845 61.468) (end 79.9845 62.3845) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 79.9845 62.3845) (end 80.8 63.2) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 83.8405 63.2) (end 85.5725 61.468) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 80.8 63.2) (end 83.8405 63.2) (width 0.25) (layer F.Cu) (net 27))
  (via (at 69.2 56.8) (size 0.8) (drill 0.4) (layers F.Cu B.Cu) (net 27))
  (segment (start 68.8085 57.1915) (end 69.2 56.8) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 68.8085 58.42) (end 68.8085 57.1915) (width 0.25) (layer F.Cu) (net 27))
  (segment (start 75.772 51.433) (end 75.772 51.308) (width 0.25) (layer B.Cu) (net 27))
  (segment (start 70.405 56.8) (end 75.772 51.433) (width 0.25) (layer B.Cu) (net 27))
  (segment (start 69.2 56.8) (end 70.405 56.8) (width 0.25) (layer B.Cu) (net 27))
