01:53:55 --------- 01:53:55 06.05.20 Start program V3.1.20504-64 (Unix) 01:53:55 IDE: Lazarus LCL 2.0.6.0, Free Pascal FPC 3.0.4, Zeos 7.2.7-rc 01:53:55 Compile: 14.Nov.2019 10:41:03, GTK 2 widget set SVN: 441M 01:53:55 DesignDPI: 96 / ActualDPI: 96 01:53:55 Use INI file: /home/mratix/EleLa/EleLa.ini 01:53:55 Parameter [DB] Protocol=sqlite-3 01:53:55 Parameter [DB] Database=/home/mratix/EleLa/EleLa.sq3 01:53:55 Parameter [Programm] VorlageDir=/home/mratix/EleLa/storage/templates/ 01:53:55 Parameter [Programm] TempDir=/home/mratix/EleLa/temp/ 01:53:55 Parameter [Programm] BildDir=/home/mratix/EleLa/storage/pictures 01:53:55 Parameter [Bauteil] DefHandbuchDir=/home/mratix/EleLa/storage 01:53:55 Parameter [Bauteil] DefLibDir=/home/mratix/EleLa/storage/library 01:53:55 Parameter [Projekt] DefHandbuchDir=/home/mratix/EleLa/storage/projects 01:53:55 Parameter [Projekt] GeraetDefHandbuchDir=/home/mratix/EleLa/storage/devices 01:53:55 Parameter [Projekt] DokuDefHandbuchDir=/home/mratix/EleLa/storage/doku 01:53:55 Parameter [Linux] ComboItemHeight=11 01:53:55 Parameter [Linux] FontHeight=11 01:54:04 Connect database... 01:54:05 DB.Version: SQLite-DLL: 3.11.0 01:54:05 Database Version: V3.1.18B30 01:54:05 Database connected. 01:56:27 ---- 01:56:27 Start create Database and tables 10.16.1.85.elela 01:56:27 Create Table "adr" 01:56:27 CreateIndex (adr,ID_ID_Bezeichnung) 01:56:27 CreateIndex (adr,ID_ID) 01:56:27 CreateIndex (adr,Foto_ID) 01:56:27 CreateUniqueIndex (adr,ID_ID,Bezeichnung) 01:56:27 Create Table "bauteil" 01:56:27 CreateUniqueIndex (bauteil,Bezeichnung) 01:56:27 CreateIndex (bauteil,tree_typ_ID) 01:56:27 Create Table "bauteiladr" 01:56:27 CreateIndex (bauteiladr,Bauteil_ID) 01:56:27 CreateIndex (bauteiladr,Adr_ID) 01:56:27 CreateIndex (bauteiladr,BauteilLager_ID) 01:56:27 CreateIndex (bauteiladr,BestellNr) 01:56:27 Create Table "bauteillager" 01:56:27 En: (btnKonfigClick|TfrmKonfig.btnErzeugeDBClick)/( $00000000008DE78C) 01:56:27 E: SQL Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'JSON, Geloescht INTEGER, AendDatum timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ' at line 36 01:56:59 ---- 01:56:59 Start create Database and tables 10.16.1.85.elela 01:56:59 Create Table "adr" 01:56:59 CreateIndex (adr,ID_ID_Bezeichnung) 01:56:59 CreateIndex (adr,ID_ID) 01:56:59 CreateIndex (adr,Foto_ID) 01:56:59 CreateUniqueIndex (adr,ID_ID,Bezeichnung) 01:56:59 Create Table "bauteil" 01:56:59 CreateUniqueIndex (bauteil,Bezeichnung) 01:56:59 CreateIndex (bauteil,tree_typ_ID) 01:56:59 Create Table "bauteiladr" 01:56:59 CreateIndex (bauteiladr,Bauteil_ID) 01:56:59 CreateIndex (bauteiladr,Adr_ID) 01:56:59 CreateIndex (bauteiladr,BauteilLager_ID) 01:56:59 CreateIndex (bauteiladr,BestellNr) 01:56:59 Create Table "bauteillager" 01:56:59 En: (TfrmKonfig.btnErzeugeDBClick)/( $00000000008DE78C) 01:56:59 E: SQL Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'JSON, Geloescht INTEGER, AendDatum timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ' at line 36
