0 0.00004079 AVRootloader.ex IRP_MJ_CREATE Serial0 SUCCESS Options: Open 1 0.00000279 AVRootloader.ex IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS 2 0.00000196 AVRootloader.ex IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS 3 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS 4 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS 5 0.00000196 AVRootloader.ex IOCTL_SERIAL_GET_TIMEOUTS Serial0 SUCCESS 6 0.00000168 AVRootloader.ex IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:0 RM:0 RC:1000 WM:0 WC:1000 7 0.00000251 AVRootloader.ex IRP_MJ_FLUSH_BUFFERS Serial0 SUCCESS 8 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS 9 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS 10 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS 11 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS 12 0.00000726 AVRootloader.ex IOCTL_SERIAL_SET_BAUD_RATE Serial0 SUCCESS Rate: 115200 13 0.00000419 AVRootloader.ex IOCTL_SERIAL_CLR_RTS Serial0 SUCCESS 14 0.00000391 AVRootloader.ex IOCTL_SERIAL_CLR_DTR Serial0 SUCCESS 15 0.00000307 AVRootloader.ex IOCTL_SERIAL_SET_LINE_CONTROL Serial0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8 16 0.00000196 AVRootloader.ex IOCTL_SERIAL_SET_CHAR Serial0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:0 XOFF:0 17 0.00000754 AVRootloader.ex IOCTL_SERIAL_SET_HANDFLOW Serial0 SUCCESS Shake:0 Replace:0 XonLimit:0 XoffLimit:0 18 0.00000196 AVRootloader.ex IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:0 RM:0 RC:50 WM:0 WC:50 19 0.00000419 AVRootloader.ex IOCTL_SERIAL_SET_DTR Serial0 SUCCESS 20 0.00000279 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 21 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 22 0.00002347 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 23 0.00202875 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 24 0.04693585 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 25 0.00000419 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 26 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 27 0.00002430 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 28 0.00202707 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 29 0.04811561 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 30 0.00000419 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 31 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 32 0.00002375 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 33 0.00202763 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 34 0.04803963 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 35 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 36 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 37 0.00002235 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 38 0.00203462 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 39 0.04796448 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 40 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 41 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 42 0.00002291 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 43 0.00202903 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 44 0.04809326 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 45 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 46 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 47 0.00002235 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 48 0.00203434 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 49 0.04810304 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 50 0.00000475 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 51 0.00000251 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 52 0.00002207 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 53 0.00203238 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 54 0.04762225 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 55 0.00000419 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 56 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 57 0.00002375 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 58 0.00203238 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 59 0.04809466 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 60 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 61 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 62 0.00002291 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 63 0.00193963 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 64 0.04811338 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 65 0.00000475 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 66 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 67 0.00002263 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 68 0.00203266 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 69 0.04767254 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 70 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 71 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 72 0.00002235 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 73 0.00203685 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 74 0.04806952 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 75 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 76 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 77 0.00002430 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 78 0.00202651 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 79 0.04811533 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 80 0.00000419 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 81 0.00000251 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 82 0.00002430 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 83 0.00202707 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 84 0.04811142 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 85 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 86 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 87 0.00002263 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 88 0.00203238 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 89 0.04809298 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 90 0.00000419 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 91 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 92 0.00002458 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 93 0.00198210 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 94 0.04808432 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 95 0.00000419 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 96 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 97 0.00002263 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 98 0.00203098 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 99 0.04799018 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 100 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 101 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 102 0.00002486 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 103 0.00203238 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 104 0.04806700 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 105 0.00000419 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 106 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 107 0.00002179 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 9: 00 00 00 00 0D 42 4F 4F 54 108 0.00202931 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 9: 93 07 03 10 FF FF FF FF 3F 109 0.04806393 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 110 0.00000419 AVRootloader.ex IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS 111 0.00000196 AVRootloader.ex IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS 112 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS 113 0.00000196 AVRootloader.ex IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS 114 0.00000782 AVRootloader.ex IOCTL_SERIAL_SET_BAUD_RATE Serial0 SUCCESS Rate: 1200 115 0.00000391 AVRootloader.ex IOCTL_SERIAL_SET_RTS Serial0 SUCCESS 116 0.00000419 AVRootloader.ex IOCTL_SERIAL_SET_DTR Serial0 SUCCESS 117 0.00000307 AVRootloader.ex IOCTL_SERIAL_SET_LINE_CONTROL Serial0 SUCCESS StopBits: 1 Parity: NONE WordLength: 7 118 0.00000196 AVRootloader.ex IOCTL_SERIAL_SET_CHAR Serial0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13 119 0.00000754 AVRootloader.ex IOCTL_SERIAL_SET_HANDFLOW Serial0 SUCCESS Shake:1 Replace:40 XonLimit:2048 XoffLimit:512 120 0.00000196 AVRootloader.ex IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:0 RM:0 RC:0 WM:0 WC:0 121 0.00000251 AVRootloader.ex IRP_MJ_CLEANUP Serial0 SUCCESS 122 0.07615102 AVRootloader.ex IRP_MJ_CLOSE Serial0 SUCCESS 123 0.00004023 AVRootloader.ex IRP_MJ_CREATE Serial0 SUCCESS Options: Open 124 0.00000251 AVRootloader.ex IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS 125 0.00000196 AVRootloader.ex IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS 126 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS 127 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS 128 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_TIMEOUTS Serial0 SUCCESS 129 0.00000196 AVRootloader.ex IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:0 RM:0 RC:1000 WM:0 WC:1000 130 0.00000279 AVRootloader.ex IRP_MJ_FLUSH_BUFFERS Serial0 SUCCESS 131 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS 132 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS 133 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS 134 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS 135 0.00000754 AVRootloader.ex IOCTL_SERIAL_SET_BAUD_RATE Serial0 SUCCESS Rate: 115200 136 0.00000391 AVRootloader.ex IOCTL_SERIAL_CLR_RTS Serial0 SUCCESS 137 0.00000391 AVRootloader.ex IOCTL_SERIAL_CLR_DTR Serial0 SUCCESS 138 0.00000279 AVRootloader.ex IOCTL_SERIAL_SET_LINE_CONTROL Serial0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8 139 0.00000223 AVRootloader.ex IOCTL_SERIAL_SET_CHAR Serial0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:0 XOFF:0 140 0.00000726 AVRootloader.ex IOCTL_SERIAL_SET_HANDFLOW Serial0 SUCCESS Shake:0 Replace:0 XonLimit:0 XoffLimit:0 141 0.00000419 AVRootloader.ex IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:0 RM:0 RC:50 WM:0 WC:50 142 0.00000447 AVRootloader.ex IOCTL_SERIAL_SET_DTR Serial0 SUCCESS 143 0.00000279 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 144 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 145 0.00002403 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 10: 00 00 00 00 00 0D 42 4F 4F 54 146 0.04834218 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 9: 93 07 03 10 FF FF FF FF 3F 147 0.00000447 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 148 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 149 0.00002347 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 10: 00 00 00 00 00 0D 42 4F 4F 54 150 0.00167926 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: 93 151 0.00000279 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: 07 152 0.00000223 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: 03 153 0.00000223 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: 10 154 0.00000223 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: FF 155 0.00000223 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: FF 156 0.00000223 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: FF 157 0.00000223 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: FF 158 0.00035228 AVRootloader.ex IRP_MJ_READ Serial0 SUCCESS Length 1: 3F 159 0.04797900 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 160 0.00000559 AVRootloader.ex IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR 161 0.00000223 AVRootloader.ex IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS 162 0.00001481 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 2: 00 01 163 0.00009135 AVRootloader.ex IRP_MJ_WRITE Serial0 SUCCESS Length 2: C1 C0 164 0.04960966 AVRootloader.ex IRP_MJ_READ Serial0 TIMEOUT Length 0: 165 0.00000391 AVRootloader.ex IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS 166 0.00000196 AVRootloader.ex IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS 167 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS 168 0.00000168 AVRootloader.ex IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS 169 0.00000782 AVRootloader.ex IOCTL_SERIAL_SET_BAUD_RATE Serial0 SUCCESS Rate: 1200 170 0.00000419 AVRootloader.ex IOCTL_SERIAL_SET_RTS Serial0 SUCCESS 171 0.00000391 AVRootloader.ex IOCTL_SERIAL_SET_DTR Serial0 SUCCESS 172 0.00000279 AVRootloader.ex IOCTL_SERIAL_SET_LINE_CONTROL Serial0 SUCCESS StopBits: 1 Parity: NONE WordLength: 7 173 0.00000196 AVRootloader.ex IOCTL_SERIAL_SET_CHAR Serial0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13 174 0.00000754 AVRootloader.ex IOCTL_SERIAL_SET_HANDFLOW Serial0 SUCCESS Shake:1 Replace:40 XonLimit:2048 XoffLimit:512 175 0.00000196 AVRootloader.ex IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:0 RM:0 RC:0 WM:0 WC:0 176 0.00000251 AVRootloader.ex IRP_MJ_CLEANUP Serial0 SUCCESS 177 0.07734838 AVRootloader.ex IRP_MJ_CLOSE Serial0 SUCCESS
