#include "ioaduc7060.h"
#include "intrinsics.h"
#include "stdio.h"
#include "string.h"
#include "Definitions.h"
void ADC0_Configuration(void){
        ADC1CON	= 0;
	ADCMSKI = BIT0;					                // Erzeugt Interrupt, wenn das ADCxRDY-Bit im ADCSTA-Register gesetzt ist/wird.
  /*______ADCFLT für f = 100 Hz______*/       
        //ADCFLT =  0x804F;					        // (0x4F)hex = (79)dez	--> fADC = 100Hz + CHOPEN 
        //ADCFLT =  0x4F;                                               // CHOP-OFF
  /*______ADCFLT für f = 50 Hz______*/     
         //ADCFLT =  0x807F;                                               // CHOP-ON, AF = 0, SF = 127 --> fADC = 50 Hz
       //ADCFLT =  0x7F;                                                 // CHOP-OFF, AF = 0, SF = 127 --> fADC = 50 Hz
  /*______ADCFLT für f = 10 Hz______*/         
        //ADCFLT =  0x961F;                                               // CHOP-ON, AF = 22, SF = 31 --> fADC = 10 Hz
      // ADCFLT =  0x161F;                                               // CHOP-OFF, AF = 22, SF = 31 --> fADC = 10 Hz
  /*______ADCFLT für f = 1000 Hz______*/          
        //ADCFLT =  0xC101;                                               // CHOP-ON, AF = 1, SF = 1 --> fADC = 1000 Hz
        ADCFLT =  0x4101;                                               // CHOP-OFF, AF = 1, SF = 1 --> fADC = 1000 Hz      
        ADC0CON	= BIT15;                                                // enable the Primary-ADC, Codierung Zweierkompliment
	ADCCFG =  0;							// alle deaktiviert
  /*______Offset-Calibration______*/
	ADCMDE =  BIT2 +   					        // ADC self-offset calibration , ADC normal mode
		  BIT7;							// ADCCLK = 4Mhz
	while((ADCSTA & BIT15) != BIT15){}  	                        // Solange ausführen, bis BIT15 gesetzt wird (Calibration vollendet)
  /*______Gain-Calibration______*/
	ADCMDE =  BIT0 + BIT2 + 			                // ADC self-gain calibration , ADC normal mode
  /*______Calibrierung fertig______*/       
        ADC0CON	= BIT4 +                                                // external REF (2.5V), GAIN = 1; Codierung Zweierkompliment
                  BIT12 +                                               // if External Reference for ADC0 exceeds 1.35V
	ADCMDE =  BIT0 + 						// ADC continuous conversion mode , ADC normal mode
