use work.all; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.Definitions.all; entity memory_manager is port( res_n : in std_logic; clk : in std_logic; clk_sdram : in std_logic; -- pins to ram device sdram_data_Dq : inout std_logic_vector(15 downto 0); o_sdram_addr : out std_logic_vector(12 downto 0); o_sdram_clk : out std_logic; o_sdram_cke : out std_logic; o_sdram_cs_l : out std_logic; o_sdram_ras_l : out std_logic; o_sdram_cas_l : out std_logic; o_sdram_we_l : out std_logic; o_sdram_ba : out std_logic_vector(1 downto 0); o_sdram_dqml : out std_logic; o_sdram_dqmh : out std_logic; -- pins for write interface write_req_1 : in std_logic; write_req_1_done : out std_logic; write_idx_1 : in std_logic_vector(15 downto 0); write_req_2 : in std_logic; write_req_2_done : out std_logic; write_idx_2 : in std_logic_vector(15 downto 0); data_i : in reg_array_t; -- pins for read interface read_req : in std_logic; read_req_done : out std_logic; read_idx : idx_t; data_o : out reg_array_t; -- pins for test write interface write_addr_test : in std_logic_vector(15 downto 0); write_data_test : in std_logic_vector(15 downto 0); write_req_test : in std_logic; debug_1 : out std_logic; debug_2 : out std_logic ); end memory_manager; architecture behav of memory_manager is type state_t is (idle, write_1, write_1_delay, write_1_wait, write_2, write_2_delay, write_2_wait, read_s, read_s_delay, read_s_wait, write_test, write_test_delay, write_test_wait); signal current_state : state_t; signal write_req_1_reg : std_logic; signal write_req_1_d : std_logic; signal write_idx_1_reg : idx_t; signal write_req_2_reg : std_logic; signal write_req_2_d : std_logic; signal write_idx_2_reg : idx_t; signal data_reg : reg_array_t; signal read_req_reg : std_logic; signal read_req_d : std_logic; signal read_idx_reg : idx_t; signal write_req_test_reg : std_logic; signal write_req_test_d : std_logic; signal c_idx : integer;-- range 0 to 8; signal i_sdram_data : std_logic_vector(15 downto 0); signal o_sdram_data : std_logic_vector(15 downto 0); signal o_sdram_buf_we : std_logic; signal i_ram_data : std_logic_vector(15 downto 0); signal o_ram_data : std_logic_vector(15 downto 0); signal i_ram_addr : std_logic_vector(23 downto 0); signal i_ram_len : std_logic_vector(9 downto 0); signal i_ram_read_req : std_logic; signal o_ram_read_valid : std_logic; signal i_ram_write_req : std_logic; signal o_ram_write_valid : std_logic; signal o_ready : std_logic; constant SDRAM_ROW_WIDTH_BIT : integer := 13; constant SDRAM_COL_WIDTH_BIT : integer := 9; constant SDRAM_BANK_WIDTH_BIT : integer := 2; constant SDRAM_DATA_WIDTH_BIT : integer := 16; constant SDRAM_CAS : integer := 3; component sdram_cntr port( -- interface for manager RAM i_clk : in std_logic; i_ram_data : in std_logic_vector(SDRAM_DATA_WIDTH_BIT-1 downto 0); o_ram_data : out std_logic_vector(SDRAM_DATA_WIDTH_BIT-1 downto 0); i_ram_addr : in std_logic_vector(SDRAM_ROW_WIDTH_BIT + SDRAM_COL_WIDTH_BIT + SDRAM_BANK_WIDTH_BIT-1 downto 0); i_ram_len : in std_logic_vector(SDRAM_COL_WIDTH_BIT downto 0); i_ram_read_req : in std_logic; o_ram_read_valid : out std_logic; i_ram_write_req : in std_logic; o_ram_write_valid : out std_logic; o_ready : out std_logic; -- interface for SDRAM i_sdram_data : in std_logic_vector(SDRAM_DATA_WIDTH_BIT-1 downto 0); o_sdram_data : out std_logic_vector(SDRAM_DATA_WIDTH_BIT-1 downto 0); o_sdram_addr : out std_logic_vector(SDRAM_ROW_WIDTH_BIT-1 downto 0); o_sdram_clk : out std_logic; o_sdram_cke : out std_logic; o_sdram_cs_l : out std_logic; o_sdram_ras_l : out std_logic; o_sdram_cas_l : out std_logic; o_sdram_we_l : out std_logic; o_sdram_buf_we : out std_logic; o_sdram_ba : out std_logic_vector(SDRAM_BANK_WIDTH_BIT-1 downto 0); o_sdram_dqml : out std_logic; o_sdram_dqmh : out std_logic ); end component; begin debug_1 <= i_ram_read_req; debug_2 <= i_ram_write_req; read_req_done <= read_req_d; write_req_1_done <= write_req_1_d; write_req_2_done <= write_req_2_d; reg_p: process(res_n, clk) is begin if res_n = '0' then elsif clk'event and clk = '1' then if write_req_1 = '1' then write_req_1_reg <= '1'; data_reg(0 to 3) <= data_i(0 to 3); write_idx_1_reg <= write_idx_1; end if; if write_req_2 = '1' then write_req_2_reg <= '1'; data_reg(4 to 7) <= data_i(4 to 7); write_idx_2_reg <= write_idx_2; end if; if write_req_1_d = '1' then write_req_1_reg <= '0'; end if; if write_req_2_d = '1' then write_req_2_reg <= '0'; end if; if read_req = '1' then read_req_reg <= '1'; read_idx_reg <= read_idx; end if; if read_req_d = '1' then read_req_reg <= '0'; end if; if write_req_test = '1' then write_req_test_reg <= '1'; end if; if write_req_test_d = '1' then write_req_test_reg <= '0'; end if; end if; end process; work_p: process(res_n, clk) is begin if res_n = '0' then elsif clk'event and clk ='1' then case current_state is when idle => c_idx <= 0; if write_req_1_reg = '1' and write_req_1_d = '0' then current_state <= write_1; end if; if write_req_2_reg = '1' and write_req_2_d = '0' then current_state <= write_2; end if; if read_req_reg = '1' and read_req_d = '0' then current_state <= read_s; end if; if write_req_test_reg = '1' and write_req_test_d = '0' then current_state <= write_test; end if; read_req_d <= '0'; write_req_1_d <= '0'; write_req_2_d <= '0'; i_ram_write_req <= '0'; i_ram_read_req <= '0'; write_req_test_d <= '0'; when write_1 => i_ram_data <= data_reg(c_idx); --i_ram_data <= std_logic_vector(to_unsigned(to_integer(unsigned(write_idx_1_reg)) + (30 * c_idx), i_ram_data'length)); i_ram_addr <= std_logic_vector(to_unsigned((N_cycles * 2 * c_idx) + to_integer(unsigned(write_idx_1_reg)), i_ram_addr'length)); i_ram_len <= std_logic_vector(to_unsigned(1, i_ram_len'length)); i_ram_read_req <= '0'; i_ram_write_req <= '1'; if o_ready = '1' then current_state <= write_1_delay; end if; when write_1_delay => i_ram_write_req <= '1'; if o_ram_write_valid = '1' then current_state <= write_1_wait; end if; when write_1_wait => i_ram_write_req <= '0'; if o_ready = '1' then if c_idx < 3 then c_idx <= c_idx + 1; current_state <= write_1; else current_state <= idle; write_req_1_d <= '1'; end if; end if; when write_2 => i_ram_data <= data_reg(c_idx); i_ram_addr <= std_logic_vector(to_unsigned((N_cycles * 2 * (c_idx + 4)) + to_integer(unsigned(write_idx_2_reg)), i_ram_addr'length)); i_ram_len <= std_logic_vector(to_unsigned(1, i_ram_len'length)); i_ram_read_req <= '0'; i_ram_write_req <= '1'; if o_ready = '1' then current_state <= write_2_delay; end if; when write_2_delay => i_ram_write_req <= '1'; if o_ram_write_valid = '1' then current_state <= write_2_wait; end if; when write_2_wait => i_ram_write_req <= '0'; if o_ready = '1' then if c_idx < 3 then c_idx <= c_idx + 1; current_state <= write_2; else current_state <= idle; write_req_2_d <= '1'; end if; end if; when read_s => i_ram_addr <= std_logic_vector(to_unsigned((N_cycles * 2 * c_idx) + to_integer(unsigned(read_idx_reg)), i_ram_addr'length)); i_ram_len <= std_logic_vector(to_unsigned(1, i_ram_len'length)); i_ram_read_req <= '1'; i_ram_write_req <= '0'; if o_ready = '1' then current_state <= read_s_delay; end if; when read_s_delay => i_ram_read_req <= '1'; if o_ram_read_valid = '1' then current_state <= read_s_wait; --data_o(c_idx) <= o_ram_data; end if; when read_s_wait => i_ram_read_req <= '0'; if o_ready = '1' then data_o(c_idx) <= o_ram_data; if c_idx < 7 then c_idx <= c_idx + 1; current_state <= read_s; else current_state <= idle; read_req_d <= '1'; end if; end if; when write_test => i_ram_data <= write_data_test; i_ram_addr <= X"00" & write_addr_test; i_ram_len <= std_logic_vector(to_unsigned(1, i_ram_len'length)); i_ram_read_req <= '0'; i_ram_write_req <= '1'; if o_ready = '1' then current_state <= write_test_delay; end if; when write_test_delay => i_ram_write_req <= '1'; if o_ram_write_valid = '1' then current_state <= write_test_wait; end if; when write_test_wait => i_ram_write_req <= '0'; if o_ready = '1' then current_state <= idle; write_req_test_d <= '1'; end if; end case; end if; end process; sdram_controller_e: entity SDRAM_Controller port map( res_n => res_n, clk => clk, clk_sdram => clk_sdram, -- application pins i_ram_data => i_ram_data, o_ram_data => o_ram_data, i_ram_addr => i_ram_addr, i_ram_len => i_ram_len, i_ram_read_req => i_ram_read_req, o_ram_read_valid => o_ram_read_valid, i_ram_write_req => i_ram_write_req, o_ram_write_valid => o_ram_write_valid, o_ready => o_ready, -- pins to ram device i_sdram_data => i_sdram_data, o_sdram_data => o_sdram_data, o_sdram_addr => o_sdram_addr, o_sdram_clk => o_sdram_clk, o_sdram_cke => o_sdram_cke, o_sdram_cs_l => o_sdram_cs_l, o_sdram_ras_l => o_sdram_ras_l, o_sdram_cas_l => o_sdram_cas_l, o_sdram_we_l => o_sdram_we_l, o_sdram_buf_we => o_sdram_buf_we, o_sdram_ba => o_sdram_ba, o_sdram_dqml => o_sdram_dqml, o_sdram_dqmh => o_sdram_dqmh ); -- ram_controller_e: sdram_cntr port map( -- -- application pins -- i_clk => clk_sdram, -- i_ram_data => i_ram_data, -- o_ram_data => o_ram_data, -- i_ram_addr => i_ram_addr, -- i_ram_len => i_ram_len, -- i_ram_read_req => i_ram_read_req, -- o_ram_read_valid => o_ram_read_valid, -- i_ram_write_req => i_ram_write_req, -- o_ram_write_valid => o_ram_write_valid, -- o_ready => o_ready, -- -- -- pins to ram device -- i_sdram_data => i_sdram_data, -- o_sdram_data => o_sdram_data, -- o_sdram_addr => o_sdram_addr, -- o_sdram_clk => o_sdram_clk, -- o_sdram_cke => o_sdram_cke, -- o_sdram_cs_l => o_sdram_cs_l, -- o_sdram_ras_l => o_sdram_ras_l, -- o_sdram_cas_l => o_sdram_cas_l, -- o_sdram_we_l => o_sdram_we_l, -- o_sdram_buf_we => o_sdram_buf_we, -- o_sdram_ba => o_sdram_ba, -- o_sdram_dqml => o_sdram_dqml, -- o_sdram_dqmh => o_sdram_dqmh -- ); data_switcher_p1: process(o_sdram_buf_we, o_sdram_data, sdram_data_Dq) is begin if o_sdram_buf_we = '1' then sdram_data_Dq <= o_sdram_data; else sdram_data_Dq <= (others => 'Z'); end if; end process; i_sdram_data <= sdram_data_Dq; end architecture;
