(module "8bit-museum:Relay_DPDT_Omron_G6K-2P(-Y)" (layer F.Cu) (tedit 5F31402C)
  (descr "Omron G6K-2P relay package http://omronfs.omron.com/en_US/ecb/products/pdf/en-g6k.pdf")
  (tags "Omron G6K-2P relay")
  (fp_text reference REF** (at 2.7 -2.4) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value "Relay_DPDT_Omron_G6K-2P(-Y)" (at 2.5 10.1) (layer F.Fab)
  (fp_text user %R (at 2.55 3.8) (layer F.Fab)
  (fp_line (start 6.18 9.05) (end -1.1 9.05) (layer F.CrtYd) (width 0.05))
  (fp_line (start 6.18 9.05) (end 6.18 -1.45) (layer F.CrtYd) (width 0.05))
  (fp_line (start -1.1 -1.45) (end -1.1 9.05) (layer F.CrtYd) (width 0.05))
  (fp_line (start -1.1 -1.45) (end 6.18 -1.45) (layer F.CrtYd) (width 0.05))
  (fp_line (start 0.3 -1.2) (end 5.8 -1.2) (layer F.Fab) (width 0.12))
  (fp_line (start 5.8 -1.2) (end 5.8 8.8) (layer F.Fab) (width 0.12))
  (fp_line (start 5.8 8.8) (end -0.7 8.8) (layer F.Fab) (width 0.12))
  (fp_line (start -0.7 8.8) (end -0.7 -0.2) (layer F.Fab) (width 0.12))
  (fp_line (start -0.7 -0.2) (end 0.3 -1.2) (layer F.Fab) (width 0.12))
  (fp_line (start -0.8 -1.3) (end 5.9 -1.3) (layer F.SilkS) (width 0.12))
  (fp_line (start 5.9 -1.3) (end 5.9 -0.8) (layer F.SilkS) (width 0.12))
  (fp_line (start 5.9 0.8) (end 5.9 1.7) (layer F.SilkS) (width 0.12))
  (fp_line (start 5.9 3.645) (end 5.9 4.445) (layer F.SilkS) (width 0.12))
  (fp_line (start 5.9 5.969) (end 5.9 6.869) (layer F.SilkS) (width 0.12))
  (fp_line (start 5.9 8.4) (end 5.9 8.9) (layer F.SilkS) (width 0.12))
  (fp_line (start 5.9 8.9) (end -0.8 8.9) (layer F.SilkS) (width 0.12))
  (fp_line (start -0.8 8.9) (end -0.8 8.4) (layer F.SilkS) (width 0.12))
  (fp_line (start -0.8 6.869) (end -0.8 5.969) (layer F.SilkS) (width 0.12))
  (fp_line (start -0.8 4.445) (end -0.8 3.645) (layer F.SilkS) (width 0.12))
  (fp_line (start -0.8 1.7) (end -0.8 1.1) (layer F.SilkS) (width 0.12))
  (fp_line (start -0.8 -1.3) (end -0.8 -1.1) (layer F.SilkS) (width 0.12))
  (fp_line (start -1.1 0) (end -1.1 -1.6) (layer F.SilkS) (width 0.12))
  (fp_line (start -1.1 -1.6) (end 0.5 -1.6) (layer F.SilkS) (width 0.12))
  (pad 1 thru_hole rect (at 0 0) (size 1.7 1.7) (drill 0.85) (layers *.Cu *.Mask))
  (pad 2 thru_hole oval (at 0 2.921) (size 1.7 2.1) (drill oval 0.85 1.55) (layers *.Cu *.Mask))
  (pad 3 thru_hole oval (at 0 5.207) (size 1.7 1.8) (drill oval 0.85 1.25) (layers *.Cu *.Mask))
  (pad 4 thru_hole circle (at 0 7.62) (size 1.7 1.7) (drill oval 0.85) (layers *.Cu *.Mask))
  (pad 5 thru_hole circle (at 5.08 7.62) (size 1.7 1.7) (drill 0.85) (layers *.Cu *.Mask))
  (pad 6 thru_hole oval (at 5.08 5.207) (size 1.7 1.8) (drill oval 0.85 1.25) (layers *.Cu *.Mask))
  (pad 7 thru_hole oval (at 5.08 2.921) (size 1.7 2.1) (drill oval 0.85 1.55) (layers *.Cu *.Mask))
  (pad 8 thru_hole circle (at 5.08 0) (size 1.7 1.7) (drill 0.85) (layers *.Cu *.Mask))
  (model ${KISYS3DMOD}/Relay_THT.3dshapes/Relay_DPDT_Omron_G6K-2P.wrl
    (at (xyz 0 0 0))
    (scale (xyz 1 1 1))
    (rotate (xyz 0 0 0))
