---------------------------------------------------------------------------------- -- Engineer: Mike Field -- -- Module Name: i2s_data_interface - Behavioral -- Description: Send & Receive I2S data -- New_sample is asserted for one cycle when a new sample has been -- received (and one transmitted) ---------------------------------------------------------------------------------- -- Also: Die Daten werden über i2s_d_in eingelesen und die umgewandelten Daten stehen dann dem Programm über audio_l_out -- und audio_r_out als std_logic_vector(23 downto 0) zur Verfügung. -- Für die Ausgabe werden die Daten audio_l_in und audio_r_in (jeweils std_logic_vector) seriell über -- i2s_d_out ausgegeben. library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity i2s_data_interface is Port ( clk : in STD_LOGIC; audio_l_in : in STD_LOGIC_VECTOR (23 downto 0); audio_r_in : in STD_LOGIC_VECTOR (23 downto 0); audio_l_out : out STD_LOGIC_VECTOR (23 downto 0); audio_r_out : out STD_LOGIC_VECTOR (23 downto 0); new_sample : out STD_LOGIC; i2s_bclk : in STD_LOGIC; i2s_d_out : out STD_LOGIC; i2s_d_in : in STD_LOGIC; i2s_lr : in STD_LOGIC ); end i2s_data_interface; architecture Behavioral of i2s_data_interface is -- signal bit_counter : unsigned(5 downto 0) := (others => '0'); -- todo rausgenommen 22_07_2020 signal bclk_delay : std_logic_vector(9 downto 0) := (others => '0'); signal lr_delay : std_logic_vector(9 downto 0) := (others => '0'); signal sr_in : std_logic_vector(126 downto 0) := (others => '0'); signal sr_out : std_logic_vector(63 downto 0) := (others => '0'); signal i2s_lr_last : std_logic := '0'; signal i2s_d_in_last : std_logic := '0'; begin process(clk) begin -- Process to predict when the falling edge of i2s_bclk should be if rising_edge(clk) then new_sample <= '0'; if bclk_delay(bclk_delay'high-1 downto bclk_delay'high-2) = "10" then -- is there a rising edge two cycles ago? If so the data bit is validand we can capture a bit sr_in <= sr_in(sr_in'high-1 downto 0) & i2s_d_in_last; end if; if bclk_delay(1 downto 0) = "10" then -- Was there a rising edge on BCLK 9 cycles ago? If so, this should be about the falling edge so the output can change. i2s_d_out <= sr_out(sr_out'high); -- if we are starting a new frame, then load the samples into the shift register if i2s_lr = '1' and i2s_lr_last = '0' then audio_l_out <= sr_in(sr_in'high downto sr_in'high - 23); audio_r_out <= sr_in(sr_in'high - 32 downto sr_in'high - 23 - 32); sr_out <= audio_l_in & x"00" & audio_r_in & x"00"; new_sample <= '1'; else sr_out <= sr_out(sr_out'high-1 downto 0) & '0'; end if; i2s_lr_last <= i2s_lr; -- remember what lr was, for edge detection end if; bclk_delay <= i2s_bclk & bclk_delay(bclk_delay'high downto 1); i2s_d_in_last <= i2s_d_in; end if; end process; end Behavioral;
