You should install WinAVR first.
This version of avrdude can acces a usb connected programmer and
replaces the older version of WinAVR-20100110 .
The file avrdude.conf is modified, the data for efuse of ATmega168,
Atmega168P, ATmega328, ATmega328P and ATmega88 are modified to byte access.
You find the avrdude files in the bin subdirectory.
In directory pn/tools you will find a expanded WinAVR.xml file,
which gives you access to the fuses setting of my TransistorTester Makefile.
If you unpack this zip archiv to the root directory of WinAVR, the files
should be at the right place.
For operating with the TransistorTester package, you should unpack the
Transistortester files and then start the Programmers Notepad of your
WinAVR package.
You should open the right Makefile of the TransistorTester
in either subdirectory default , mega8 or mega168_strip_grid .
Testers with the normal layout and either ATmega168 or ATmega328 should
take the default directory.
Edit your Makefile, so that you have selected the right processor and
options. You have also to configure the programmer interface "avrdude"
(PROGRAMMER=  and PORT=) .
If all selections are choosen, you should save the Makefile and
select the Tool "[WinAVR] Program" and if the fuses are not already set
correctly, you should select the Tool "[WinAVR] set fuses"  or the
Tool "[WinAVr] set fuses Crystal" if you have the 8 MHz Crystal installed.
You should never take the Crystal version, if you have no crystal connected to
your ATmega!
