xilinx.com
xci
unknown
1.0
clk_wiz_0
false
100000000
false
100000000
false
100000000
false
100000000
100000000
0
0.000
100000000
0
0.000
LEVEL_HIGH
100000000
0
0.000
0
0
100000000
0
0.000
0
0
0
0
0
0
0
0
0
0
0
0
0
AXI4LITE
READ_WRITE
0
0
0
0
0
0
MMCM
cddcdone
cddcreq
0000
0000
clkfb_in_n
clkfb_in
clkfb_in_p
SINGLE
clkfb_out_n
clkfb_out
clkfb_out_p
clkfb_stopped
50.0
100.0
0000
0000
100.00000
0000
0000
8.19328
BUFG
50.0
false
100.00000
0.000
50.000
100.000
0.000
0000
100.000
BUFG
50.0
false
8.19328
0.000
50.000
8.192
0.000
0000
100.000
BUFG
50.000
false
100.000
0.000
50.000
100.000
0.000
0000
0000
100.000
BUFG
50.000
false
100.000
0.000
50.000
100.000
0.000
0000
0000
100.000
BUFG
50.000
false
100.000
0.000
50.000
100.000
0.000
0000
0000
100.000
BUFG
50.000
false
100.000
0.000
50.000
100.000
0.000
BUFG
50.000
false
100.000
0.000
50.000
100.000
0.000
VCO
clk_in_sel
clk_out1
clk_out2
clk_out3
clk_out4
clk_out5
clk_out6
clk_out7
CLK_VALID
NA
daddr
dclk
den
din
0000
1.0
1.0
1.0
1.0
1.0
dout
drdy
dwe
93.000
1.000
0
0
0
0
0
0
0
0
FDBK_AUTO
0000
0000
0
Input Clock Freq (MHz) Input Jitter (UI)
__primary_________200.000____________0.010
no_secondary_input_clock
input_clk_stopped
0
Units_MHz
No_Jitter
locked
0000
0000
0000
false
false
false
false
false
false
false
false
OPTIMIZED
4.875
0.000
FALSE
5.000
10.0
9.750
0.500
0.000
FALSE
119
0.500
0.000
FALSE
0.000
FALSE
0.000
FALSE
FALSE
0.000
FALSE
0.000
FALSE
0.000
FALSE
FALSE
ZHOLD
None
0.010
0.010
FALSE
64.000
2.000
Output Output Phase Duty Cycle Pk-to-Pk Phase
Clock Freq (MHz) (degrees) (%) Jitter (ps) Error (ps)
clk_out1__100.00000______0.000______50.0______108.072_____87.159
clk_out2___8.19328______0.000______50.0______178.770_____87.159
no_CLK_OUT3_output
no_CLK_OUT4_output
no_CLK_OUT5_output
no_CLK_OUT6_output
no_CLK_OUT7_output
0
0
128.000
1.000
WAVEFORM
UNKNOWN
false
false
false
false
false
OPTIMIZED
1.000
0.000
0.000
0.000
0.000
0.000
0.000
CLKFBOUT
SYSTEM_SYNCHRONOUS
No notes
0.010
power_down
0000
clk_in1
MMCM
AUTO
200.000
0.010
10.000
Differential_clock_capable_pin
psclk
psdone
psen
psincdec
100.0
0
reset
100.000
0.010
10.000
clk_in2
Single_ended_clock_capable_pin
CENTER_HIGH
4000
0.004
STATUS
100.0
100.0
100.0
100.0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1440.000
600.000
clk_wiz_0
MMCM
false
empty
cddcdone
cddcreq
clkfb_in_n
clkfb_in
clkfb_in_p
SINGLE
clkfb_out_n
clkfb_out
clkfb_out_p
clkfb_stopped
50.0
0.010
100.0
0.010
BUFG
108.072
false
87.159
50.000
100.000
0.000
true
BUFG
178.770
false
87.159
50.000
8.192
0.000
true
BUFG
0.0
false
0.0
50.000
100.000
0.000
false
BUFG
0.0
false
0.0
50.000
100.000
0.000
false
BUFG
0.0
false
0.0
50.000
100.000
0.000
false
BUFG
0.0
false
0.0
50.000
100.000
0.000
false
BUFG
0.0
false
0.0
50.000
100.000
0.000
false
600.000
Custom
Custom
clk_in_sel
clk_out1
false
clk_out2
false
clk_out3
false
clk_out4
false
clk_out5
false
clk_out6
false
clk_out7
false
CLK_VALID
auto
clk_wiz_0
daddr
dclk
den
Custom
Custom
din
dout
drdy
dwe
false
false
false
false
false
false
false
false
false
FDBK_AUTO
input_clk_stopped
frequency
Enable_AXI
Units_MHz
Units_UI
UI
No_Jitter
locked
OPTIMIZED
4.875
0.000
false
5.000
10.0
9.750
0.500
0.000
false
119
0.500
0.000
false
0.000
false
0.000
false
false
0.000
false
0.000
false
0.000
false
false
ZHOLD
None
0.010
0.010
false
false
false
WAVEFORM
false
UNKNOWN
OPTIMIZED
10.000
0.000
0.000
0.000
0.000
0.000
0.000
CLKFBOUT
SYSTEM_SYNCHRONOUS
None
0.010
power_down
clk_in1
MMCM
mmcm_adv
200.000
0.010
10.000
psclk
psdone
psen
psincdec
100.0
REL_PRIMARY
Custom
reset
ACTIVE_HIGH
100.000
0.010
10.000
clk_in2
CENTER_HIGH
250
0.004
STATUS
empty
100.0
100.0
100.0
100.0
false
false
false
false
false
false
false
true
false
false
true
false
false
false
true
false
true
false
false
false
kintex7
digilentinc.com:genesys2:part0:1.1
xc7k325t
ffg900
VHDL
VHDL
-2
TRUE
TRUE
IP_Flow
TRUE
2019.2
OUT_OF_CONTEXT
