(module ATWINC15x0_Module (layer F.Cu) (tedit 5FA5E782)
  (descr "WiFi Transmitter Module, 21.7x14.7x2.1, Pitch 1.016")
  (tags "funk, wifi, transmitter, module")
  (fp_text reference REF** (at 13.79 2.1) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value ATWINC15x0-MRx10P/Ux (at -2.1 -8.4 90) (layer F.Fab)
  (fp_line (start 0 0) (end 0 -21.72) (layer F.SilkS) (width 0.1))
  (fp_line (start 0 0) (end 14.73 0) (layer F.SilkS) (width 0.1))
  (fp_line (start 14.73 0) (end 14.73 -21.72) (layer F.SilkS) (width 0.1))
  (fp_line (start 0 -21.72) (end 14.73 -21.72) (layer F.SilkS) (width 0.1))
  (fp_line (start 1.1 -1.1) (end 1.1 -14.76) (layer F.SilkS) (width 0.1))
  (fp_line (start 1.1 -14.76) (end 13.66 -14.76) (layer F.SilkS) (width 0.1))
  (fp_line (start 13.66 -14.76) (end 13.66 -1.11) (layer F.SilkS) (width 0.1))
  (fp_line (start 13.66 -1.1) (end 1.1 -1.1) (layer F.SilkS) (width 0.1))
  (fp_circle (center 11.94 -19.08) (end 12.96 -19.07) (layer F.SilkS) (width 0.15))
  (fp_circle (center 11.94 -19.08) (end 12.11 -19.08) (layer F.SilkS) (width 0.2))
  (fp_line (start 19 -15.4) (end 19 -23) (layer Dwgs.User) (width 0.12))
  (fp_line (start 19 -23) (end -4 -23) (layer Dwgs.User) (width 0.12))
  (fp_line (start -4 -23) (end -4 -15.4) (layer Dwgs.User) (width 0.12))
  (fp_line (start -4 -15.4) (end 19 -15.4) (layer Dwgs.User) (width 0.12))
  (fp_line (start -1.1 1.1) (end 15.8 1.1) (layer F.CrtYd) (width 0.05))
  (fp_line (start 15.8 1.1) (end 15.8 -21.75) (layer F.CrtYd) (width 0.05))
  (fp_line (start 15.8 -21.75) (end -1.1 -21.75) (layer F.CrtYd) (width 0.05))
  (fp_line (start -1.1 -21.75) (end -1.1 1.1) (layer F.CrtYd) (width 0.05))
  (fp_line (start 13.65 -14.76) (end 13.65 -21.3) (layer F.SilkS) (width 0.15))
  (fp_line (start 13.65 -21.3) (end 9.6 -21.3) (layer F.SilkS) (width 0.15))
  (fp_line (start 9.6 -21.3) (end 9.6 -19.5) (layer F.SilkS) (width 0.15))
  (fp_line (start 9.6 -19.5) (end 7.3 -19.5) (layer F.SilkS) (width 0.15))
  (fp_line (start 7.3 -19.5) (end 7.3 -21.3) (layer F.SilkS) (width 0.15))
  (fp_line (start 7.3 -21.3) (end 5.3 -21.3) (layer F.SilkS) (width 0.15))
  (fp_line (start 5.3 -21.3) (end 5.3 -19.5) (layer F.SilkS) (width 0.15))
  (fp_line (start 5.3 -19.5) (end 3.2 -19.5) (layer F.SilkS) (width 0.15))
  (fp_line (start 3.2 -19.5) (end 3.2 -21.3) (layer F.SilkS) (width 0.15))
  (fp_line (start 3.2 -21.3) (end 0.6 -21.3) (layer F.SilkS) (width 0.15))
  (fp_line (start 0.6 -21.3) (end 0.6 -18.1) (layer F.SilkS) (width 0.15))
  (fp_line (start 11.94 -21.3) (end 11.94 -19.08) (layer F.SilkS) (width 0.15))
  (fp_text user Antenna (at 6.9 -17.1) (layer Dwgs.User)
  (fp_text user "Keep out area - Copper free" (at 7.5 -22.4) (layer Dwgs.User)
    (effects (font (size 1 1) (thickness 0.1)))
  (pad Pad smd rect (at 6.88 -6.27) (size 3.7 3.7) (layers F.Cu F.Paste))
  (pad 1 smd rect (at 14.73 -2.67) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 2 smd rect (at 14.73 -3.686) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 3 smd rect (at 14.73 -4.702) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 4 smd rect (at 14.73 -5.718) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 5 smd rect (at 14.73 -9.782) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 6 smd rect (at 14.73 -11.814) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 7 smd rect (at 14.73 -12.83) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 8 smd rect (at 14.73 -13.846) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 9 smd rect (at 14.73 -14.862) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 10 smd rect (at 0 -12.824) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 11 smd rect (at 0 -11.808) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 12 smd rect (at 0 -10.792) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 13 smd rect (at 0 -9.776) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 14 smd rect (at 0 -8.76) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 15 smd rect (at 0 -7.744) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 16 smd rect (at 0 -6.728) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 17 smd rect (at 0 -5.712) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 18 smd rect (at 0 -4.696) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 19 smd rect (at 0 -3.68) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 20 smd rect (at 1.9 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 21 smd rect (at 4.948 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 22 smd rect (at 5.964 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 23 smd rect (at 6.98 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 24 smd rect (at 7.996 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 25 smd rect (at 9.012 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 26 smd rect (at 10.028 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 27 smd rect (at 11.044 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
  (pad 28 smd rect (at 12.06 0 90) (size 1.9 0.8) (layers F.Cu F.Paste))
