$MODV2 ; Define C166v2 core mode ; ;------------------------------------------------------------------------------ ; This file is part of the C166 Compiler package ; Copyright KEIL ELEKTRONIK GmbH 1993 - 2002 ; Version 4.04 ;------------------------------------------------------------------------------ ; START_V2.A66: This code is executed after processor reset and provides the ; startup sequence for the C166v2/Super10 architecture CPU's. ; (i.e. XC161, XC164 ect.) ; ; You may add this file to a uVision2 project - in this case it will be ; automatically assembled and linked. ; ; For manual translation of this file use A166 with the following invocation: ; ; A166 START_V2.A66 SET () ; ; determines the memory model and can be one of the following: ; TINY, SMALL, COMPACT, HCOMPACT, MEDIUM, LARGE or HLARGE ; ; Example: A166 START_V2.A66 SET (SMALL) ; ; For manual linkage of the modified START_V2.OBJ file to your application ; use the following L166 invocation: ; ; L166 , START_V2.OBJ ; ;------------------------------------------------------------------------------ ; Setup model-dependend Assembler controls $CASE $IF NOT TINY $SEGMENTED $ENDIF ; Settings for ADDRSEL calculation (do not change!) KB EQU 0x400 ; define KB constant for CS _SIZE calculation MB EQU 0x400*KB ; define MB as 1024KB ;------------------------------------------------------------------------------ ; ; Definitions for System and User Stack ; ===================================== ; ; STKSZ: Maximum System Stack Size selection ; Defines the system stack space that is used by CALL/RET and PUSH/POP ; instructions. The system stack space must be adjusted according the actual ; requirements of the application. SSTSZ EQU 0x200 ; set System Stack Size to 200H Bytes ; ; USTSZ: User Stack Size Definition ; Defines the user stack space available for automatics. This stack space is ; accessed by R0. The user stack space must be adjusted according the actual ; requirements of the application. USTSZ EQU 0x1000 ; set User Stack Size to 1000H Bytes. ; ; ; Definitions for Startup Code ; ============================ ; ; CLR_MEMORY: Disable Memory Zero Initialization of RAM area ; --- Set CLR_MEMORY = 0 to disable memory zero initilization $SET (CLR_MEMORY = 1) ; ; INIT_VARS: Disable Variable Initialization ; --- Set INIT_VARS = 0 to disable variable initilization $SET (INIT_VARS = 1) ; ; DPPUSE: Re-assign DPP registers ; --- Set DPPUSE = 0 to reduce the code size of the startup code, if you ; are not using the L166 DPPUSE directive. $SET (DPPUSE = 1) ; ; DPP3USE: Use DPP3 register during variable initilization ; --- Set DPP3USE = 0 to disable the usage of DPP3 during initilization of ; variables. This option might be required if you write ; program parts that are reloaded during application ; execution and increase code size of the startup code. $SET (DPP3USE = 1) ; ; ; Definitions for Cpu Configuration Register CPUCON1 ; ================================================== ; ; ZCJ: Zero Cycle Jump Function (CPUCON1.0): _ZCJ EQU 0 ; 0 = Disable Zero Cycle Jump Function ; 1 = Enable Zero Cycle Jump Function ; ; BP: Branch Prediction Unit (CPUCON1.1): _BP EQU 0 ; 0 = Disable Branch Prediction Unit ; 1 = Enable Branch Prediction Unit ; ; INTSCXT: Interruptability of Switch Context Instruction (CPUCON1.2): _INTSCXT EQU 0 ; 0 = Disable Interruption of SCXT instruction ; 1 = Enable Interruption of SCXT instruction ; ; SGTDIS: Disable Segmentation Control (CPUCON1.3): $IF TINY _SGTDIS EQU 1 ; disable segmented mode for TINY model $ELSE _SGTDIS EQU 0 ; enable segmented mode (Reset Value) $ENDIF ; ; WDTCTL: Watchdog Timer Control (CPUCON1.4): _WDTCTL EQU 0 ; 0 = DISWDT executable until end of EINIT ; 1 = DISWDT/ENWDT always executable ; ; VECSC: Vector Table Scaling Factor (CPUCON1.5 .. CPUCON1.6) _VECSC EQU 0 ; 0 = Space between two vectors is 2 words ; 1 = Space between two vectors is 4 words ; 2 = Space between two vectors is 8 words ; 3 = Space between two vectors is 16 words ; ; ; Definitions for CPU Configuration Register CPUCON2 ; ================================================== ; ; INIT_CPUCON2: Init CPUCON2 register ; --- Set INIT_CPUCON2 = 1 to initilize the SYSCON1 register $SET (INIT_CPUCON2 = 1) ; default: do not initilize CPUCON2 ; ; SL: Short Loop Mode (CPUCON2.0) _SL EQU 1 ; 0 = Short Loop mode disabled ; 1 = Short Loop mode enabled ; ; FASTPEC: Fast Pec Event Injection (CPUCON2.1) _FASTPEC EQU 1 ; 0 = Direct Injection of PEC Events disabled ; 1 = Direct Injection of PEC Events enabled ; ; FASTBL: Fast Block Transfer Injection (CPUCON2.2) _FASTBL EQU 0 ; 0 = Direct Injection for Block Transfers disabled ; 1 = Direct Injection for Block Transfers enabled ; ; RETST: Return Stack (CPUCON2.3) _RETST EQU 1 ; 0 = Return Stack disabled ; 1 = Return Stack enabled ; ; OVRUN: Pipeline Bubble Overrun (CPUCON2.4) _OVRUN EQU 1 ; 0 = Overrun of Pipeline Bubbles not allowed ; 1 = Overrun of Pipeline Bubbles allowed ; ; ZSC: Zero Cycle Jump Cache (CPUCON2.5) _ZSC EQU 1 ; 0 = Zero Cycle Jump Cache disabled ; 1 = Zero Cycle Jump Cache enabled ; ; STEN: Stall Instruction (CPUCON2.6) _STEN EQU 0 ; 0 = Stall instruction disabled ; 1 = Stall instruction enabled ; ; EIOIAEN: Early IO Injection Acknowledge _EIOIAEN EQU 1 ; 0 = Injection ack. by destructive read not guaranteed ; ; 1 = Injection ack. by destructive read guaranteed ; ; BYPF: Fetch Bypass Control (CPUCON2.8) _BYPF EQU 1 ; 0 = Bypass Path from Fetch to Decode disabled ; 1 = Bypass Path from Fetch to Decode enabled ; ; BYPPF: Prefecth Bypass Control (CPUCON2.9) _BYPPF EQU 1 ; 0 = Bypass Path from Prefetch to Decode disabled ; 1 = Bypass Path from Prefetch to Decode enabled ; ; FIFOFED: FIFO Fill Configuration (CPUCON2.10 .. CPUCON2.11) _FIFOFED EQU 3 ; 0 = FIFO disabled ; 1 = FIFO filled with up to 1 instruction per cycle ; 2 = FIFO filled with up to 2 instructions per cycle ; 3 = FIFO filled with up to 3 instructions per cycle ; ; FIFODEPTH: FIFO Depth Configuration (CPUCON2.12 .. CPUCON2.15) _FIFODEPTH EQU 8 ; 0 = No FIFO entries (No FIFO) ; 1 = 1 FIFO entry ; ... ; 8 = 8 FIFO entries ; 9 - 15 = reserved ; ; Definitions for System Configuration Register SYSCON1 ; ===================================================== ; ; INIT_SYSCON1: Init SYSCON1 register ; --- Set INIT_SYSCON1 = 1 to initilize the SYSCON1 register $SET (INIT_SYSCON1 = 1) ; ; SLEEPCON: Sleep Mode Configuration (SYSCON1.0 .. SYSCON1.1) _SLEEPCON EQU 0 ; 0 = Normal IDLE mode entered upone IDLE instruction ; 1 = SLEEP mode entered upone IDLE instruction ; 2 - 3 = reserved ; ; PDCFG: Port Driver Configuration (SYSCON1.2 .. SYSCON1.3) _PDCFG EQU 0 ; 0 = Port drivers are always ON (default) ; 1 = Port drivers are off in IDLE or Sleep mode ; 2 = Port drivers are off in Powerdown mode ; 3 = reserved ; ; PFCFG: Program Flash Configuration (SYSCON1.4 .. SYSCON1.5) _PFCFG EQU 0 ; 0 = Program Flash is always ON (default) ; 1 = Program Flash is off in IDLE or Sleep mode ; 2 - 3 = reserved ; ; CPSYS: Clock Prescaler for System (SYSCON1.8 .. SYSCON1.10) _CPSYS EQU 0 ; 0 = clock signal for CPU is PLL frequency ; 1 = clock signal for CPU is PLL frequency / 2 ; 2 - 7 = reserved ; ; ; Definitions for System Configuration Register SYSCON3 ; ===================================================== ; ; INIT_SYSCON3: Init SYSCON3 register ; --- Set INIT_SYSCON3 = 1 to initilize the SYSCON3 register $SET (INIT_SYSCON3 = 1) ; ; SYSCON3: Power Management (disable on-chip peripherals) ; ADCDIS EQU 0 ; 1 = disable Analog/Digital Converter (SYSCON3.0) ASC0DIS EQU 0 ; 1 = disable UART ASC0 (SYSCON3.1) SSC0DIS EQU 0 ; 1 = disable Synchronus Serial Cnl0 SSC0 (SYSCON3.2) GPTDIS EQU 0 ; 1 = disable Timer Block GPT (SYSCON3.3) ; reserved (SYSCON3.4) FMDIS EQU 0 ; 1 = disable on-chip Flash Memory Module (SYSCON3.5) CC1DIS EQU 0 ; 1 = disable CAPCOM Unit 1 (SYSCON3.6) CC2DIS EQU 0 ; 1 = disable CAPCOM Unit 2 (SYSCON3.7) CC6DIS EQU 0 ; 1 = disable CAPCOM Unit 6 (SYSCON3.8) ; reserved (SYSCON3.9) ASC1DIS EQU 0 ; 1 = disable UART ASC1 (SYSCON3.10) I2CDIS EQU 0 ; 1 = disable I2C Bus Module (SYSCON3.11) SDLMDIS EQU 0 ; 1 = disable SDLM (J1850) Module (SYSCON3.12) CANDIS EQU 0 ; 1 = disable on-chip CAN Module (SYSCON3.13) ; reserved (SYSCON3.14) SSC1DIS EQU 0 ; 1 = disable Synchronus Serial Cnl1 SSC1 (SYSCON3.15) ; ; ; ; Definitions for Reset Configuration Register RSTCON ; =================================================== ; ; INIT_RSTCON: Init RSTCON register ; --- Set INIT_RSTCON = 1 to initilize the RSTCON register $SET (INIT_RSTCON = 1) ; ; RSTLEN: Reset Length Control (RSTCON.0 .. RSTCON.2) _RSTLEN EQU 0 ; 0 = 2 t_CPU clocks (default) ; 1 = 4 t_CPU clocks ; 2 = 8 t_CPU clocks ; 3 = 16 t_CPU clocks ; 4 = 32 t_CPU clocks ; 5 = 64 t_CPU clocks ; 6 = 128 t_CPU clocks ; 7 = 256 t_CPU clocks ; ; RORMV: RSTOUT# Remove Control (RSTCON.4) _RORMV EQU 0 ; 0 = RSTOUT delievers RSTOUT# signal ; 1 = RSTOUT pin operates as GPIO ; ; ROCOFF: RSTOUT# Control Switch Off (RSTCON.5) _ROCOFF EQU 0 ; 0 = RSTOUT is deactivated by user software ; 1 = RSTOUT is deactiveted at end of reset ; ; ROCON: RSTOUT# Control Switch Off (RSTCON.6) _ROCON EQU 0 ; 0 = RSTOUT is activated upon any reset ; 1 = RSTOUT is only activated upon a hardware reset ; ; RODIS: RSTOUT# Disable Control (RSTCON.7) _RODIS EQU 0 ; 0 = RSTOUT is controlled by other mechanism ; 1 = RSTOUT is deactivated ; ; ; ; Definitions for PLL Control Register PLLCON ; =========================================== ; ; INIT_PLLCON: Init PLLCON register ; --- Set INIT_PLLCON = 1 to initilize the PLLCON register $SET (INIT_PLLCON = 1) ; ; PLLODIV: PLL Output Devider (PLLCON.0 .. PLLCON.3) _PLLODIV EQU 9 ; 0 .. 14 Fpll = Fvco / (PLLODIV+1) ; 15 = reserved ; ; PLLIDIV: PLL Input Devider (PLLCON.4 .. PLLCON.5) _PLLIDIV EQU 0 ; 0 .. 3 Fin = Fosc / (PLLIDIV+1) ; ; PLLVB: PLL VCO Band Select (PLLCON.6 .. PLLCON.7) _PLLVB EQU 2 ; ValueVCO output frequency Base frequency ; 0 = 100...150 MHz 20...80 MHz ; 1 = 150...200 MHz 40...130 MHz ; 2 = 200...250 MHz [def.] 60...180 MHz ; 3 = (250...300 MHz) Reserved ; ; PLLMUL: PLL Multiplication Factor (PLLCON.8 .. PLLCON.12) _PLLMUL EQU 24 ; 7 .. 31 Fvco = Fin * (PLLMUL+1) ; 0 .. 6 = reserved ; ; PLLCTRL: PLL Operation Control (PLLCON.13 .. PLLCON.14) _PLLCTRL EQU 3 ; 0 = Bypass PLL clock mult., the VCO is off ; 1 = Bypass PLL clock mult., the VCO is running ; 2 = VCO clock used, input clock switched off ; 3 = VCO clock used, input clock connected ; ; PLLWRI: PLLCON Write Ignore Flag (PLLCON.15) _PLLWRI EQU 0 ; 0 = Register PLLCON may be written ; 1 = Write cycles to register PLLCON are ignored ; ; ; Definitions for Watchdog Timer Control Register WDTCON ; ====================================================== ; ; --- Set WATCHDOG = 1 to enable the Hardware watchdog and initilize the WDTCON register $SET (WATCHDOG = 0) ; 0 = Disabled Hardware watchdog ; ; WDTIN: Watchdog Timer Input Frequency Select (WDTCON.0 .. WDTCON.1) _WDTIN EQU 1 ; 0 = frequency f_peripheral / 2 (CPU default) ; 1 = frequency f_peripheral / 128 (recommended for START_V2) ; 2 = frequency f_peripheral / 4 ; 3 = frequency f_peripheral / 256 ; ; WDTREL: Watchdog Timer Reload Value (WDTCON8 .. WDTCON15) _WDTREL EQU 0 ; high byte of WDT (counts up, overflow gives Watchdog reset) ; ; ; Definitions for Frequency Output Signal FOCON ; ============================================= ; ; INIT_FOCON: Init FOCON register ; --- Set INIT_FOCON = 1 to initilize the FOCON register $SET (INIT_FOCON = 1) ; ; CLKEN: CLKOUT Enable (FOCON.7) _CLKEN EQU 0 ; 0 = P3.15 is IO pin when _FOUT is 0 ; 1 = P3.15 outputs signal CLKOUT ; ; FORV: Frequency Output Reload Value (FOCON.8 .. FOCON.13) _FORV EQU 0 ; is copied to FOCNT upon each underflow of FOCNT ; ; FOSS: Frequency Output Signal Select (FOCON.14) _FOSS EQU 0 ; 0 = Output of the toggle latch; 0.5 duty cycle ; 1 = Output of reload counter; duty cycle depends on FORV ; ; FOEN: Frequency Output Enable (FOCON.15) _FOEN EQU 0 ; 0 = P3.15 is IO pin when _CLKEN is 0 ; 1 = P3.15 outputs f_OUT when _CLKEN is 0 ; ; ; ============= CONFIGURE EXTERNAL BUS (EBC) BEHAVIOUR ===================== ; ; --- Set CONFIG_EBC = 1 to initialize the EBCMOD0/EBCMOD1 registers $SET (CONFIG_EBC = 1) ; 0 = EBCMOD0/EBCMOD1 are set during reset according the ; of configuration bus (typical Port0) values. ; 1 = the following external bus configuration values ; are written to EBCMOD and BUSACT0 ; ; Definitions for EBC Mode 0 register EBCMOD0 ; =========================================== ; ; SAPEN: Segment Address Pins Enabled (EBCMOD0.0 .. EBCMOD0.3) _SAPEN EQU 8 ; 0 = No segment address pins enabled ; 1 = One (A16) segment address pin enabled ; : = : ; 8 = Eight (A16 .. A23) address pins enabled ; 9 - 15 = reserved ; ; CSPEN: CSx Pins Enabled (EBCMOD0.4 .. EBCMOD0.7) _CSPEN EQU 5 ; 0 = No CS pins enabled ; 1 = One CS (CS0) pin enabled ; : = : ; 8 = Eight CS (CS0 .. CS7) pins enabled ; 9 - 15 = reserved ; Note: the number of available CS pins depends on the chip used ; ; ARBEN: Bus Arbitration Pins Enabled (EBCMOD0.8) _ARBEN EQU 0 ; 0 = HOLD, HLDA and BREQ pins are tristate or act as GPIO ; 1 = HOLD, HLDA and BREQ pins act normally ; ; SLAVE: SLAVE mode enable (EBCMOD0.9) _SLAVE EQU 0 ; 0 = Bus arbiter acts in master mode ; 1 = Bus arbiter acts in slave mode ; ; EBCDIS: EBC pins disable (EBCMOD0.10) _EBCDIS EQU 0 ; 0 = EBC is using the pins for external bus ; 1 = EBC off (pins to be used as GPIO if implemented) ; ; WRCFG: Configuration for pins WR/WRL and BHE/WRH (EBCMOD0.11) _WRCFG EQU 0 ; 0 = Pins act as WR and BHE ; 1 = Pins act as WRL and WRH ; ; BYTDIS: BHE pin disable (EBCMOD0.12) _BYTDIS EQU 0 ; 0 = BHE enabled ; 1 = BHE disabled (GPIO function if implemented) ; ; ALEDIS: ALE pin disable (EBCMOD0.13) _ALEDIS EQU 0 ; 0 = ALE pin enabled ; 1 = ALE pin disabled (GPIO function if implemented) ; ; RDYDIS: READY pin disable (EBCMOD0.14) _RDYDIS EQU 0 ; 0 = READY enabled ; 1 = READY disabled (GPIO function if implemented) ; ; RDYPOL: READY pin polarity (EBCMOD0.15) _RDYPOL EQU 0 ; 0 = READY pin is active low ; 1 = READY pin is active high ; ; ; ; Definitions for EBC Mode 1 register EBCMOD1 ; =========================================== ; ; APDIS: Address Port Pins Disable (EBCMOD1.0 .. EBCMOD0.4) _APDIS EQU 0 ; 0 = Address port PORT1 used as address bus ; 1 - 30 = reserved ; 31 = Address bus disabled (PORT1 used as GPIO) ; ; DHPDIS: Data High Port Pins Disable (EBCMOD1.6) _DHPDIS EQU 0 ; 0 = Data bus pins 15-8 of PORT0 enabled ; 1 = Data bus pins 15-8 disabled (used as GPIO) ; ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS0 AREA =========== ; ; --- Set CONFIG_CS0 = 1 to initialize the FCONCS0/TCONCS0 registers $SET (CONFIG_CS0 = 1) ; ; Definitions for Function Configuration Register FCONCS0 ; ======================================================= ; ; ENCS0: Enable Chip Select (FCONCS0.0) _ENCS0 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN0: Ready Enable (FCONCS0.1) _RDYEN0 EQU 0 ; 0 = Access time controlled by TCONCS0.PHE0 ; 1 = Access time cont. by TCONCS0.PHE0 and READY signal ; ; RDYMOD0: Ready Mode (FCONCS0.2) _RDYMOD0 EQU 0 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP0: Bus Type Selection (FCONCS0.4 .. FCONCS0.5) _BTYP0 EQU 3 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS0: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA0: Phase A clock cycle (TCONCS0.0 .. TCONCS0.1) _PHA0 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB0: Phase B clock cycle (TCONCS0.2) _PHB0 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC0: Phase C clock cycle (TCONCS0.3 .. TCONCS0.4) _PHC0 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD0: Phase D clock cycle (TCONCS0.5) _PHD0 EQU 1 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE0: Phase E clock cycle (TCONCS0.6 .. TCONCS0.10) _PHE0 EQU 3 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF0: Phase F read clock cycle (TCONCS0.11 .. TCONCS0.12) _RDPHF0 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF0: Phase F write clock cycle (TCONCS0.13 .. TCONCS0.14) _WRPHF0 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS1 AREA =========== ; ; --- Set CONFIG_CS1 = 1 to initialize the ADDRSEL1/FCONCS1/TCONCS1 registers $SET (CONFIG_CS1 = 0) ; ; Definitions for Address Select register ADDRSEL1 ; ================================================ ; _ADDR1 EQU 0x400000 ; Set CS1# Start Address (default 100000H) ; _SIZE1 EQU 512*KB ; Set CS1# Size (default 1024*KB = 1*MB) ; possible values for _SIZE1 are: ; 4*KB (gives RGSZ1 = 0) ; 8*KB (gives RGSZ1 = 1) ; 16*KB (gives RGSZ1 = 2) ; 32*KB (gives RGSZ1 = 3) ; 64*KB (gives RGSZ1 = 4) ; 128*KB (gives RGSZ1 = 5) ; 256*KB (gives RGSZ1 = 6) ; 512*KB (gives RGSZ1 = 7) ; 1024*KB or 1*MB (gives RGSZ1 = 8) ; 2048*KB or 2*MB (gives RGSZ1 = 9) ; 4096*KB or 4*MB (gives RGSZ1 = 10) ; 8192*KB or 8*MB (gives RGSZ1 = 11) ; (RGSZ1 = 12 .. 15 reserved) ; ; Definitions for Function Configuration Register FCONCS1 ; ======================================================= ; ; ENCS1: Enable Chip Select (FCONCS1.0) _ENCS1 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN1: Ready Enable (FCONCS1.1) _RDYEN1 EQU 0 ; 0 = Access time controlled by TCONCS1.PHE1 ; 1 = Access time cont. by TCONCS1.PHE1 and READY signal ; ; RDYMOD1: Ready Mode (FCONCS1.2) _RDYMOD1 EQU 0 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP1: Bus Type Selection (FCONCS1.4 .. FCONCS1.5) _BTYP1 EQU 3 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS1: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA1: Phase A clock cycle (TCONCS1.0 .. TCONCS1.1) _PHA1 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB1: Phase B clock cycle (TCONCS1.2) _PHB1 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC1: Phase C clock cycle (TCONCS1.3 .. TCONCS1.4) _PHC1 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD1: Phase D clock cycle (TCONCS1.5) _PHD1 EQU 1 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE1: Phase E clock cycle (TCONCS1.6 .. TCONCS1.10) _PHE1 EQU 3 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF1: Phase F read clock cycle (TCONCS1.11 .. TCONCS1.12) _RDPHF1 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF1: Phase F write clock cycle (TCONCS1.13 .. TCONCS1.14) _WRPHF1 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS2 AREA =========== ; ; --- Set CONFIG_CS2 = 1 to initialize the ADDRSEL2/FCONCS2/TCONCS2 registers $SET (CONFIG_CS2 = 0) ; ; Definitions for Address Select register ADDRSEL2 ; ================================================ ; _ADDR2 EQU 0x200000 ; Set CS2# Start Address (default 200000H) ; _SIZE2 EQU 4*KB ; Set CS2# Size (default 1024*KB = 1*MB) ; possible values for _SIZE2 are: ; 4*KB (gives RGSZ1 = 0) ; 8*KB (gives RGSZ1 = 1) ; 16*KB (gives RGSZ1 = 2) ; 32*KB (gives RGSZ1 = 3) ; 64*KB (gives RGSZ1 = 4) ; 128*KB (gives RGSZ1 = 5) ; 256*KB (gives RGSZ1 = 6) ; 512*KB (gives RGSZ1 = 7) ; 1024*KB or 1*MB (gives RGSZ1 = 8) ; 2048*KB or 2*MB (gives RGSZ1 = 9) ; 4096*KB or 4*MB (gives RGSZ1 = 10) ; 8192*KB or 8*MB (gives RGSZ1 = 11) ; (RGSZ1 = 12 .. 15 reserved) ; ; Definitions for Function Configuration Register FCONCS2 ; ======================================================= ; ; ENCS2: Enable Chip Select (FCONCS2.0) _ENCS2 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN2: Ready Enable (FCONCS2.1) _RDYEN2 EQU 0 ; 0 = Access time controlled by TCONCS2.PHE2 ; 1 = Access time cont. by TCONCS2.PHE2 and READY signal ; ; RDYMOD2: Ready Mode (FCONCS2.2) _RDYMOD2 EQU 0 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP2: Bus Type Selection (FCONCS2.4 .. FCONCS2.5) _BTYP2 EQU 3 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS2: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA2: Phase A clock cycle (TCONCS2.0 .. TCONCS2.1) _PHA2 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB2: Phase B clock cycle (TCONCS2.2) _PHB2 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC2: Phase C clock cycle (TCONCS2.3 .. TCONCS2.4) _PHC2 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD2: Phase D clock cycle (TCONCS2.5) _PHD2 EQU 1 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE2: Phase E clock cycle (TCONCS2.6 .. TCONCS2.10) _PHE2 EQU 15 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF2: Phase F read clock cycle (TCONCS2.11 .. TCONCS2.12) _RDPHF2 EQU 2 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF2: Phase F write clock cycle (TCONCS2.13 .. TCONCS2.14) _WRPHF2 EQU 2 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS3 AREA =========== ; ; --- Set CONFIG_CS3 = 1 to initialize the ADDRSEL3/FCONCS3/TCONCS3 registers $SET (CONFIG_CS3 = 0) ; ; Definitions for Address Select register ADDRSEL3 ; ================================================ ; _ADDR3 EQU 0x300000 ; Set CS3# Start Address (default 300000H) ; _SIZE3 EQU 1*MB ; Set CS3# Size (default 1024*KB = 1*MB) ; possible values for _SIZE3 are: ; 4*KB (gives RGSZ1 = 0) ; 8*KB (gives RGSZ1 = 1) ; 16*KB (gives RGSZ1 = 2) ; 32*KB (gives RGSZ1 = 3) ; 64*KB (gives RGSZ1 = 4) ; 128*KB (gives RGSZ1 = 5) ; 256*KB (gives RGSZ1 = 6) ; 512*KB (gives RGSZ1 = 7) ; 1024*KB or 1*MB (gives RGSZ1 = 8) ; 2048*KB or 2*MB (gives RGSZ1 = 9) ; 4096*KB or 4*MB (gives RGSZ1 = 10) ; 8192*KB or 8*MB (gives RGSZ1 = 11) ; (RGSZ1 = 12 .. 15 reserved) ; ; Definitions for Function Configuration Register FCONCS3 ; ======================================================= ; ; ENCS3: Enable Chip Select (FCONCS3.0) _ENCS3 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN3: Ready Enable (FCONCS3.1) _RDYEN3 EQU 0 ; 0 = Access time controlled by TCONCS3.PHE3 ; 1 = Access time cont. by TCONCS3.PHE3 and READY signal ; ; RDYMOD3: Ready Mode (FCONCS3.2) _RDYMOD3 EQU 0 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP3: Bus Type Selection (FCONCS3.4 .. FCONCS3.5) _BTYP3 EQU 3 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS3: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA3: Phase A clock cycle (TCONCS3.0 .. TCONCS3.1) _PHA3 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB3: Phase B clock cycle (TCONCS3.2) _PHB3 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC3: Phase C clock cycle (TCONCS3.3 .. TCONCS3.4) _PHC3 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD3: Phase D clock cycle (TCONCS3.5) _PHD3 EQU 1 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE3: Phase E clock cycle (TCONCS3.6 .. TCONCS3.10) _PHE3 EQU 4 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF3: Phase F read clock cycle (TCONCS3.11 .. TCONCS3.12) _RDPHF3 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF3: Phase F write clock cycle (TCONCS3.13 .. TCONCS3.14) _WRPHF3 EQU 1 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS4 AREA =========== ; ; --- Set CONFIG_CS4 = 1 to initialize the ADDRSEL4/FCONCS4/TCONCS4 registers $SET (CONFIG_CS4 = 0) ; ; Definitions for Address Select register ADDRSEL4 ; ================================================ ; _ADDR4 EQU 0x400000 ; Set CS4# Start Address (default 400000H) ; _SIZE4 EQU 1*MB ; Set CS4# Size (default 1024*KB = 1*MB) ; possible values for _SIZE4 are: ; 4*KB (gives RGSZ1 = 0) ; 8*KB (gives RGSZ1 = 1) ; 16*KB (gives RGSZ1 = 2) ; 32*KB (gives RGSZ1 = 3) ; 64*KB (gives RGSZ1 = 4) ; 128*KB (gives RGSZ1 = 5) ; 256*KB (gives RGSZ1 = 6) ; 512*KB (gives RGSZ1 = 7) ; 1024*KB or 1*MB (gives RGSZ1 = 8) ; 2048*KB or 2*MB (gives RGSZ1 = 9) ; 4096*KB or 4*MB (gives RGSZ1 = 10) ; 8192*KB or 8*MB (gives RGSZ1 = 11) ; (RGSZ1 = 12 .. 15 reserved) ; ; Definitions for Function Configuration Register FCONCS4 ; ======================================================= ; ; ENCS4: Enable Chip Select (FCONCS4.0) _ENCS4 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN4: Ready Enable (FCONCS4.1) _RDYEN4 EQU 0 ; 0 = Access time controlled by TCONCS4.PHE4 ; 1 = Access time cont. by TCONCS4.PHE4 and READY signal ; ; RDYMOD4: Ready Mode (FCONCS4.2) _RDYMOD4 EQU 0 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP4: Bus Type Selection (FCONCS4.4 .. FCONCS4.5) _BTYP4 EQU 2 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS4: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA4: Phase A clock cycle (TCONCS4.0 .. TCONCS4.1) _PHA4 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB4: Phase B clock cycle (TCONCS4.2) _PHB4 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC4: Phase C clock cycle (TCONCS4.3 .. TCONCS4.4) _PHC4 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD4: Phase D clock cycle (TCONCS4.5) _PHD4 EQU 0 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE4: Phase E clock cycle (TCONCS4.6 .. TCONCS4.10) _PHE4 EQU 9 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF4: Phase F read clock cycle (TCONCS4.11 .. TCONCS4.12) _RDPHF4 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF4: Phase F write clock cycle (TCONCS4.13 .. TCONCS4.14) _WRPHF4 EQU 3 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS5 AREA =========== ; ; --- Set CONFIG_CS5 = 1 to initialize the ADDRSEL5/FCONCS5/TCONCS5 registers $SET (CONFIG_CS5 = 0) ; ; Definitions for Address Select register ADDRSEL5 ; ================================================ ; _ADDR5 EQU 0x500000 ; Set CS5# Start Address (default 500000H) ; _SIZE5 EQU 1*MB ; Set CS5# Size (default 1024*KB = 1*MB) ; possible values for _SIZE5 are: ; 4*KB (gives RGSZ1 = 0) ; 8*KB (gives RGSZ1 = 1) ; 16*KB (gives RGSZ1 = 2) ; 32*KB (gives RGSZ1 = 3) ; 64*KB (gives RGSZ1 = 4) ; 128*KB (gives RGSZ1 = 5) ; 256*KB (gives RGSZ1 = 6) ; 512*KB (gives RGSZ1 = 7) ; 1024*KB or 1*MB (gives RGSZ1 = 8) ; 2048*KB or 2*MB (gives RGSZ1 = 9) ; 4096*KB or 4*MB (gives RGSZ1 = 10) ; 8192*KB or 8*MB (gives RGSZ1 = 11) ; (RGSZ1 = 12 .. 15 reserved) ; ; Definitions for Function Configuration Register FCONCS5 ; ======================================================= ; ; ENCS5: Enable Chip Select (FCONCS5.0) _ENCS5 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN5: Ready Enable (FCONCS5.1) _RDYEN5 EQU 0 ; 0 = Access time controlled by TCONCS5.PHE5 ; 1 = Access time cont. by TCONCS5.PHE5 and READY signal ; ; RDYMOD5: Ready Mode (FCONCS5.2) _RDYMOD5 EQU 0 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP5: Bus Type Selection (FCONCS5.4 .. FCONCS5.5) _BTYP5 EQU 2 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS5: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA5: Phase A clock cycle (TCONCS5.0 .. TCONCS5.1) _PHA5 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB5: Phase B clock cycle (TCONCS5.2) _PHB5 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC5: Phase C clock cycle (TCONCS5.3 .. TCONCS5.4) _PHC5 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD5: Phase D clock cycle (TCONCS5.5) _PHD5 EQU 0 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE5: Phase E clock cycle (TCONCS5.6 .. TCONCS5.10) _PHE5 EQU 9 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF5: Phase F read clock cycle (TCONCS5.11 .. TCONCS5.12) _RDPHF5 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF5: Phase F write clock cycle (TCONCS5.13 .. TCONCS5.14) _WRPHF5 EQU 3 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS6 AREA =========== ; ; --- Set CONFIG_CS6 = 1 to initialize the ADDRSEL6/FCONCS6/TCONCS6 registers $SET (CONFIG_CS6 = 0) ; ; Definitions for Address Select register ADDRSEL6 ; ================================================ ; _ADDR6 EQU 0x600000 ; Set CS6# Start Address (default 600000H) ; _SIZE6 EQU 1*MB ; Set CS6# Size (default 1024*KB = 1*MB) ; possible values for _SIZE6 are: ; 4*KB (gives RGSZ1 = 0) ; 8*KB (gives RGSZ1 = 1) ; 16*KB (gives RGSZ1 = 2) ; 32*KB (gives RGSZ1 = 3) ; 64*KB (gives RGSZ1 = 4) ; 128*KB (gives RGSZ1 = 5) ; 256*KB (gives RGSZ1 = 6) ; 512*KB (gives RGSZ1 = 7) ; 1024*KB or 1*MB (gives RGSZ1 = 8) ; 2048*KB or 2*MB (gives RGSZ1 = 9) ; 4096*KB or 4*MB (gives RGSZ1 = 10) ; 8192*KB or 8*MB (gives RGSZ1 = 11) ; (RGSZ1 = 12 .. 15 reserved) ; ; Definitions for Function Configuration Register FCONCS6 ; ======================================================= ; ; ENCS6: Enable Chip Select (FCONCS6.0) _ENCS6 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN6: Ready Enable (FCONCS6.1) _RDYEN6 EQU 0 ; 0 = Access time controlled by TCONCS6.PHE6 ; 1 = Access time cont. by TCONCS6.PHE6 and READY signal ; ; RDYMOD6: Ready Mode (FCONCS6.2) _RDYMOD6 EQU 0 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP6: Bus Type Selection (FCONCS6.4 .. FCONCS6.5) _BTYP6 EQU 2 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS6: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA6: Phase A clock cycle (TCONCS6.0 .. TCONCS6.1) _PHA6 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB6: Phase B clock cycle (TCONCS6.2) _PHB6 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC6: Phase C clock cycle (TCONCS6.3 .. TCONCS6.4) _PHC6 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD6: Phase D clock cycle (TCONCS6.5) _PHD6 EQU 0 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE6: Phase E clock cycle (TCONCS6.6 .. TCONCS6.10) _PHE6 EQU 9 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF6: Phase F read clock cycle (TCONCS6.11 .. TCONCS6.12) _RDPHF6 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF6: Phase F write clock cycle (TCONCS6.13 .. TCONCS6.14) _WRPHF6 EQU 3 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; ; ; ========== CONFIGURE EXTERNAL BUS BEHAVIOUR FOR CS7 AREA =========== ; ; --- Set CONFIG_CS7 = 1 to initialize the ADDRSEL7/FCONCS7/TCONCS7 registers ; --- Note: The CS7# chip default at reset allows to access the on-chip Twin-CAN $SET (CONFIG_CS7 = 1) ; ; Definitions for Address Select register ADDRSEL7 ; ================================================ ; _ADDR7 EQU 0x200000 ; Set CS7# Start Address (default 200000H) ; _SIZE7 EQU 4*KB ; Set CS7# Size (default 1024*KB = 1*MB) ; possible values for _SIZE7 are: ; 4*KB (gives RGSZ1 = 0) ; 8*KB (gives RGSZ1 = 1) ; 16*KB (gives RGSZ1 = 2) ; 32*KB (gives RGSZ1 = 3) ; 64*KB (gives RGSZ1 = 4) ; 128*KB (gives RGSZ1 = 5) ; 256*KB (gives RGSZ1 = 6) ; 512*KB (gives RGSZ1 = 7) ; 1024*KB or 1*MB (gives RGSZ1 = 8) ; 2048*KB or 2*MB (gives RGSZ1 = 9) ; 4096*KB or 4*MB (gives RGSZ1 = 10) ; 8192*KB or 8*MB (gives RGSZ1 = 11) ; (RGSZ1 = 12 .. 15 reserved) ; ; Definitions for Function Configuration Register FCONCS7 ; ======================================================= ; ; ENCS7: Enable Chip Select (FCONCS7.0) _ENCS7 EQU 1 ; 0 = Chip Select 0 disabled ; 1 = Chip Select 0 enabled ; ; RDYEN7: Ready Enable (FCONCS7.1) _RDYEN7 EQU 1 ; 0 = Access time controlled by TCONCS7.PHE7 ; 1 = Access time cont. by TCONCS7.PHE7 and READY signal ; ; RDYMOD7: Ready Mode (FCONCS7.2) _RDYMOD7 EQU 1 ; 0 = Asynchronous READY ; 1 = Synchronous READY ; ; BTYP7: Bus Type Selection (FCONCS7.4 .. FCONCS7.5) _BTYP7 EQU 2 ; 0 = 8 bit Demultiplexed bus ; 1 = 8 bit Multiplexed bus ; 2 = 16 bit Demultiplexed bus ; 3 = 16 bit Multiplexed bus ; ; ; TCONCS7: Definitions for the Timing Configuration register ; ========================================================== ; ; PHA7: Phase A clock cycle (TCONCS7.0 .. TCONCS7.1) _PHA7 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHB7: Phase B clock cycle (TCONCS7.2) _PHB7 EQU 0 ; 0 = 1 clock cycle ; 1 = 2 clock cycles ; ; PHC7: Phase C clock cycle (TCONCS7.3 .. TCONCS7.4) _PHC7 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; PHD7: Phase D clock cycle (TCONCS7.5) _PHD7 EQU 0 ; 0 = 0 clock cycles ; 1 = 1 clock cycle ; ; PHE7: Phase E clock cycle (TCONCS7.6 .. TCONCS7.10) _PHE7 EQU 0 ; 0 = 1 clock cycle ; : = : ; 31 = 32 clock cycles ; ; RDPHF7: Phase F read clock cycle (TCONCS7.11 .. TCONCS7.12) _RDPHF7 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ; WRPHF7: Phase F write clock cycle (TCONCS7.13 .. TCONCS7.14) _WRPHF7 EQU 0 ; 0 = 0 clock cycles ; : = : ; 3 = 3 clock cycles ; ;------------------------------------------------------------------------------ $IF TINY $SET (DPPUSE = 0) $ENDIF $IF NOT TINY ASSUME DPP3:SYSTEM ASSUME DPP2:NDATA $ENDIF NAME ?C_STARTUP PUBLIC ?C_STARTUP PUBLIC ?L?VECSC ?L?VECSC EQU _VECSC ; Interrupt Vector Spacing for L166 $IF MEDIUM OR LARGE OR HLARGE Model LIT 'FAR' $ELSE Model LIT 'NEAR' $ENDIF EXTRN main:Model PUBLIC ?C_USRSTKBOT ?C_USERSTACK SECTION DATA PUBLIC 'NDATA' $IF NOT TINY NDATA DGROUP ?C_USERSTACK $ENDIF ?C_USRSTKBOT: DS USTSZ ; Size of User Stack ?C_USERSTKTOP: ?C_USERSTACK ENDS ?C_MAINREGISTERS REGDEF R0 - R15 ?C_SYSSTACK SECTION DATA PUBLIC 'IDATA' $IF NOT TINY SDATA DGROUP ?C_SYSSTACK $ENDIF _BOS: ; bottom of system stack DS SSTSZ ; Size of User Stack _TOS: ; top of system stack ?C_SYSSTACK ENDS PUBLIC ?C_SYSSTKBOT PUBLIC ?C_SYSSTKTOP ?C_SYSSTKBOT EQU _BOS ?C_SYSSTKTOP EQU _TOS SSKDEF 7 ; unlimited System stack size ?C_STARTUP_CODE SECTION CODE 'ICODE' ;------------------------------------------------------------------------------ ; Special Function Register Addresses ADDRSEL1 EQU 0EE1EH ADDRSEL2 EQU 0EE26H ADDRSEL3 EQU 0EE2EH ADDRSEL4 EQU 0EE36H ADDRSEL5 EQU 0EE3EH ADDRSEL6 EQU 0EE46H ADDRSEL7 EQU 0EE4EH CPUCON1 DEFR 0FE18H CPUCON2 DEFR 0FE1AH EBCMOD0 EQU 0EE00H EBCMOD1 EQU 0EE02H FOCON DEFR 0FFAAH FCONCS0 EQU 0EE12H FCONCS1 EQU 0EE1AH FCONCS2 EQU 0EE22H FCONCS3 EQU 0EE2AH FCONCS4 EQU 0EE32H FCONCS5 EQU 0EE3AH FCONCS6 EQU 0EE42H FCONCS7 EQU 0EE4AH RSTCON EQU 0F1E0H SP DEFR 0FE12H SPSEG DEFR 0FF0CH STKOV DEFR 0FE14H STKUN DEFR 0FE16H SYSCON1 DEFR 0F1DCH SYSCON3 DEFR 0F1D4H PLLCON DEFR 0F1D0H TCONCS0 EQU 0EE10H TCONCS1 EQU 0EE18H TCONCS2 EQU 0EE20H TCONCS3 EQU 0EE28H TCONCS4 EQU 0EE30H TCONCS5 EQU 0EE38H TCONCS6 EQU 0EE40H TCONCS7 EQU 0EE48H WDTCON DEFR 0FFAEH ; Macro for calculation of ADDRSEL values ------------- CALC_ADDRSEL MACRO sym, adr, size IF size <= (4*KB) sym EQU ((adr >> 8) AND 0xFFF0) OR 0 ELSEIF size <= (8*KB) sym EQU ((adr >> 8) AND 0xFFE0) OR 1 ELSEIF size <= (16*KB) sym EQU ((adr >> 8) AND 0xFFC0) OR 2 ELSEIF size <= (32*KB) sym EQU ((adr >> 8) AND 0xFF80) OR 3 ELSEIF size <= (64*KB) sym EQU ((adr >> 8) AND 0xFF00) OR 4 ELSEIF size <= (128*KB) sym EQU ((adr >> 8) AND 0xFE00) OR 5 ELSEIF size <= (256*KB) sym EQU ((adr >> 8) AND 0xFC00) OR 6 ELSEIF size <= (512*KB) sym EQU ((adr >> 8) AND 0xF800) OR 7 ELSEIF size <= (1*MB) sym EQU ((adr >> 8) AND 0xF000) OR 8 ELSEIF size <= (2*MB) sym EQU ((adr >> 8) AND 0xE000) OR 9 ELSEIF size <= (4*MB) sym EQU ((adr >> 8) AND 0xC000) OR 10 ELSEIF size <= (8*MB) sym EQU ((adr >> 8) AND 0x8000) OR 11 ENDIF ENDM ; ----------------------------------------------------- ?C_RESET PROC TASK C_STARTUP INTNO RESET = 0 ?C_STARTUP: LABEL Model $IF (WATCHDOG = 0) DISWDT ; Disable watchdog timer $ELSE _WDTCON SET (_WDTREL << 8) OR (_WDTIN) MOV WDTCON,#_WDTCON ; Set WDTCON register SRVWDT ; Enable watchdog $ENDIF ; Set CPUCON1 register _CPC1 SET (_VECSC<<5) OR (_WDTCTL<<4) OR (_SGTDIS<<3) _CPC1 SET _CPC1 OR (_INTSCXT<<2) OR (_BP<<1) OR (_ZCJ) MOV CPUCON1,#_CPC1 $IF (INIT_CPUCON2 = 1) ; Set CPUCON2 register _CPC2 SET (_RETST<<3) OR (_FASTBL<<2) OR (_FASTPEC<<1) OR (_SL) _CPC2 SET _CPC2 OR (_EIOIAEN<<7) OR (_STEN<<6) OR (_ZSC<<5) OR (_OVRUN<<4) _CPC2 SET _CPC2 OR (_BYPPF<<9) OR (_BYPF<<8) _CPC2 SET _CPC2 OR (_FIFODEPTH<<12) OR (_FIFOFED<<10) MOV CPUCON2,#_CPC2 $ENDIF $IF (INIT_SYSCON1 = 1) ; Set SYSCON1 register _SYSC1 SET (_CPSYS<<8) OR (_PFCFG<<4) OR (_PDCFG<<2) OR (_SLEEPCON) EXTR #01H ; Extended SFR access MOV SYSCON1,#_SYSC1 $ENDIF $IF (INIT_SYSCON3 = 1) ; Set SYSCON3 register _SYSC3 SET ADCDIS OR (ASC0DIS << 1) OR (SSC0DIS << 2) OR (GPTDIS << 3) _SYSC3 SET _SYSC3 OR (FMDIS << 5) OR (CC1DIS << 6) OR (CC2DIS << 7) _SYSC3 SET _SYSC3 OR (CC6DIS << 8) OR (ASC1DIS << 10) OR (I2CDIS << 11) _SYSC3 SET _SYSC3 OR (SDLMDIS << 12) OR (CANDIS << 13) OR (SSC1DIS<< 15) EXTR #01H MOV SYSCON3,#_SYSC3 $ENDIF $IF (CONFIG_EBC = 1) ; Set EBCMOD0 register _EBC0 SET (_SLAVE<<9) OR (_ARBEN<<8) OR (_CSPEN<<4) OR (_SAPEN) _EBC0 SET _EBC0 OR (_BYTDIS<<12) OR (_WRCFG<<11) OR (_EBCDIS<<10) _EBC0 SET _EBC0 OR (_RDYPOL<<15) OR (_RDYDIS<<14) OR (_ALEDIS<<13) MOV R0,#_EBC0 MOV EBCMOD0,R0 ; Set EBCMOD1 register _EBC1 SET (_DHPDIS<<6) OR (_APDIS) MOV R0,#_EBC1 MOV EBCMOD1,R0 $ENDIF $IF (CONFIG_CS0) ; Set TCONCS0 register _TCS0 SET (_PHD0<<5) OR (_PHC0<<3) OR (_PHB0<<2) OR (_PHA0) _TCS0 SET _TCS0 OR (_WRPHF0<<13) OR (_RDPHF0<<11) OR (_PHE0<<6) MOV R0,#_TCS0 MOV TCONCS0,R0 ; Set FCONCS0 register _FCS0 SET (_BTYP0<<4) OR (_RDYMOD0<<2) OR (_RDYEN0<<1) OR (_ENCS0) MOV R0,#_FCS0 MOV FCONCS0,R0 $ENDIF $IF (CONFIG_CS1) ; Set TCONCS1 register _TCS1 SET (_PHD1<<5) OR (_PHC1<<3) OR (_PHB1<<2) OR (_PHA1) _TCS1 SET _TCS1 OR (_WRPHF1<<13) OR (_RDPHF1<<11) OR (_PHE1<<6) MOV R0,#_TCS1 MOV TCONCS1,R0 ; Set ADDRSEL1 register CALC_ADDRSEL _ADDRSEL1, _ADDR1, _SIZE1 MOV R0,#_ADDRSEL1 MOV ADDRSEL1,R0 ; Set FCONCS1 register _FCS1 SET (_BTYP1<<4) OR (_RDYMOD1<<2) OR (_RDYEN1<<1) OR (_ENCS1) MOV R0,#_FCS1 MOV FCONCS1,R0 $ENDIF $IF (CONFIG_CS2) ; Set TCONCS2 register _TCS2 SET (_PHD2<<5) OR (_PHC2<<3) OR (_PHB2<<2) OR (_PHA2) _TCS2 SET _TCS2 OR (_WRPHF2<<13) OR (_RDPHF2<<11) OR (_PHE2<<6) MOV R0,#_TCS2 MOV TCONCS2,R0 ; Set ADDRSEL2 register CALC_ADDRSEL _ADDRSEL2, _ADDR2, _SIZE2 MOV R0,#_ADDRSEL2 MOV ADDRSEL2,R0 ; Set FCONCS2 register _FCS2 SET (_BTYP2<<4) OR (_RDYMOD2<<2) OR (_RDYEN2<<1) OR (_ENCS2) MOV R0,#_FCS2 MOV FCONCS2,R0 $ENDIF $IF (CONFIG_CS3) ; Set TCONCS3 register _TCS3 SET (_PHD3<<5) OR (_PHC3<<3) OR (_PHB3<<2) OR (_PHA3) _TCS3 SET _TCS3 OR (_WRPHF3<<13) OR (_RDPHF3<<11) OR (_PHE3<<6) MOV R0,#_TCS3 MOV TCONCS3,R0 ; Set ADDRSEL3 register CALC_ADDRSEL _ADDRSEL3, _ADDR3, _SIZE3 MOV R0,#_ADDRSEL3 MOV ADDRSEL3,R0 ; Set FCONCS3 register _FCS3 SET (_BTYP3<<4) OR (_RDYMOD3<<2) OR (_RDYEN3<<1) OR (_ENCS3) MOV R0,#_FCS3 MOV FCONCS3,R0 $ENDIF $IF (CONFIG_CS4) ; Set TCONCS4 register _TCS4 SET (_PHD4<<5) OR (_PHC4<<3) OR (_PHB4<<2) OR (_PHA4) _TCS4 SET _TCS4 OR (_WRPHF4<<13) OR (_RDPHF4<<11) OR (_PHE4<<6) MOV R0,#_TCS4 MOV TCONCS4,R0 ; Set ADDRSEL4 register CALC_ADDRSEL _ADDRSEL4, _ADDR4, _SIZE4 MOV R0,#_ADDRSEL4 MOV ADDRSEL4,R0 ; Set FCONCS4 register _FCS4 SET (_BTYP4<<4) OR (_RDYMOD4<<2) OR (_RDYEN4<<1) OR (_ENCS4) MOV R0,#_FCS4 MOV FCONCS4,R0 $ENDIF $IF (CONFIG_CS5) ; Set TCONCS5 register _TCS5 SET (_PHD5<<5) OR (_PHC5<<3) OR (_PHB5<<2) OR (_PHA5) _TCS5 SET _TCS5 OR (_WRPHF5<<13) OR (_RDPHF5<<11) OR (_PHE5<<6) MOV R0,#_TCS5 MOV TCONCS5,R0 ; Set ADDRSEL5 register CALC_ADDRSEL _ADDRSEL5, _ADDR5, _SIZE5 MOV R0,#_ADDRSEL5 MOV ADDRSEL5,R0 ; Set FCONCS5 register _FCS5 SET (_BTYP5<<4) OR (_RDYMOD5<<2) OR (_RDYEN5<<1) OR (_ENCS5) MOV R0,#_FCS5 MOV FCONCS5,R0 $ENDIF $IF (CONFIG_CS6) ; Set TCONCS6 register _TCS6 SET (_PHD6<<5) OR (_PHC6<<3) OR (_PHB6<<2) OR (_PHA6) _TCS6 SET _TCS6 OR (_WRPHF6<<13) OR (_RDPHF6<<11) OR (_PHE6<<6) MOV R0,#_TCS6 MOV TCONCS6,R0 ; Set ADDRSEL6 register CALC_ADDRSEL _ADDRSEL6, _ADDR6, _SIZE6 MOV R0,#_ADDRSEL6 MOV ADDRSEL6,R0 ; Set FCONCS6 register _FCS6 SET (_BTYP6<<4) OR (_RDYMOD6<<2) OR (_RDYEN6<<1) OR (_ENCS6) MOV R0,#_FCS6 MOV FCONCS6,R0 $ENDIF $IF (CONFIG_CS7) ; Set TCONCS7 register _TCS7 SET (_PHD7<<5) OR (_PHC7<<3) OR (_PHB7<<2) OR (_PHA7) _TCS7 SET _TCS7 OR (_WRPHF7<<13) OR (_RDPHF7<<11) OR (_PHE7<<6) MOV R0,#_TCS7 MOV TCONCS7,R0 ; Set ADDRSEL7 register CALC_ADDRSEL _ADDRSEL7, _ADDR7, _SIZE7 MOV R0,#_ADDRSEL7 MOV ADDRSEL7,R0 ; Set FCONCS7 register _FCS7 SET (_BTYP7<<4) OR (_RDYMOD7<<2) OR (_RDYEN7<<1) OR (_ENCS7) MOV R0,#_FCS7 MOV FCONCS7,R0 $ENDIF $IF (INIT_RSTCON = 1) ; Set RSTCON register _RSTCON SET (_ROCOFF<<5) OR (_RORMV<<4) OR (_RSTLEN) _RSTCON SET _RSTCON OR (_RODIS<<7) OR (_ROCON<<6) MOV R0,#_RSTCON MOV RSTCON,R0 $ENDIF $IF (INIT_PLLCON = 1) ; Set PLLCON register _PLLCON SET (_PLLVB<<6) OR (_PLLIDIV<<4) OR (_PLLODIV) _PLLCON SET _PLLCON OR (_PLLWRI<<15) OR (_PLLCTRL<<13) OR (_PLLMUL<<8) EXTR #01H ; Extended SFR access MOV PLLCON,#_PLLCON $ENDIF $IF (INIT_FOCON = 1) ; Set FOCON register _FOCON SET (_CLKEN<<7) OR (_FORV<<8) OR (_FOSS<<14) OR (_FOEN<<15) MOV FOCON,#_FOCON $ENDIF ; MOV STKUN,#SOF (_TOS) ; INITIALIZE STACK UNFL REGISTER MOV STKOV,#SOF (_BOS+6*2) ; INITIALIZE STACK OVFL REGISTER MOV SP,#SOF (_TOS) ; INITIALIZE STACK POINTER MOV SPSEG,#SEG (_TOS) ; INITIALIZE STACK POINTER SEGMENT $IF NOT TINY EXTRN ?C_PAGEDPP0 : DATA16 EXTRN ?C_PAGEDPP1 : DATA16 EXTRN ?C_PAGEDPP2 : DATA16 $IF (DPPUSE = 1) MOV DPP0,#?C_PAGEDPP0 ; INIT DPP0 VALUE $ENDIF MOV DPP1,#?C_PAGEDPP1 ; DEFAULT NEAR CONST PAGE MOV DPP2,#?C_PAGEDPP2 ; DEFAULT NEAR DATA PAGE $ENDIF MOV CP,#?C_MAINREGISTERS EINIT MOV R0,#?C_USERSTKTOP ;------------------------------------------------------------------------------ ; ; The following code is necessary to set RAM variables to 0 at start-up ; (RESET) of the C application program. ; $IF (CLR_MEMORY = 1) EXTRN ?C_CLRMEMSECSTART : WORD Clr_Memory: $IF TINY MOV R8,#?C_CLRMEMSECSTART JMPR cc_Z,EndClear RepeatClear: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF MOV R5,#0 MOV R2,[R8+] ; Count JMPR cc_Z,EndClear MOV R3,R2 MOV R4,[R8+] JBC R2.14,ClearNear ClearBit: MOV R3,R4 SHR R3,#3 BCLR R3.0 ADD R3,#0FD00H ; START OF BIT SPACE MOV R5,#1 SHL R5,R4 CPL R5 AND R5,[R3] MOV [R3],R5 ADD R4,#1 SUB R2,#1 JMPR cc_NZ,ClearBit JMPR cc_UC,RepeatClear ClearNear: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF MOVB [R4],RL5 ADD R4,#1 SUB R2,#1 JMPR cc_NN,ClearNear JMPR cc_UC,RepeatClear $ELSE MOV R9,#SEG (?C_CLRMEMSECSTART) MOV R8,#SOF (?C_CLRMEMSECSTART) MOV R1,R8 OR R1,R9 JMPR cc_Z,EndClear RepeatClear: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF MOV R5,#0 EXTS R9,#1 MOV R2,[R8+] ; Count JMPR cc_Z,EndClear MOV R3,R2 EXTS R9,#1 MOV R4,[R8+] JBC R2.14,ClearNear JBC R2.15,ClearFar ClearBit: MOV R3,R4 SHR R3,#3 BCLR R3.0 ADD R3,#0FD00H ; START OF BIT SPACE MOV R5,#1 SHL R5,R4 CPL R5 AND R5,[R3] MOV [R3],R5 ADD R4,#1 SUB R2,#1 JMPR cc_NZ,ClearBit JMPR cc_UC,RepeatClear ClearFar: EXTS R9,#1 MOV R3,[R8+] RepClearFar: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF EXTP R4,#1 MOVB [R3],RL5 ADD R3,#1 ADDC R4,#0 OR R3,#0C000H SUB R2,#1 JMPR cc_NN,RepClearFar JMPR cc_UC,RepeatClear ClearNear: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF MOVB [R4],RL5 ADD R4,#1 SUB R2,#1 JMPR cc_NN,ClearNear JMPR cc_UC,RepeatClear $ENDIF EndClear: $ENDIF ;------------------------------------------------------------------------------ ; ; The following code is necessary, if the application program contains ; initialized variables at file level. ; $IF (INIT_VARS = 1) ; ********************************************************* EXTRN ?C_INITSECSTART : WORD Init_Vars: $IF TINY ; ******************************************************************** MOV R8,#?C_INITSECSTART RepeatInit: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF MOV R2,[R8+] JMPR cc_Z,EndInit JBC R2.15,InitBit MOV R4,R2 AND R2,#3FFFH JMPR cc_NZ,LenLoad MOV R4,#0 MOV R2,[R8+] LenLoad: MOV R3,[R8+] CopyInitVal: MOVB [R3],[R8+] $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF ADD R3,#1 SUB R2,#1 JMPR cc_NZ,CopyInitVal JNB R8.0,RepeatInit ADD R8,#1 JMPR cc_UC,RepeatInit InitBit: MOVBZ R3,RL2 SHL R3,#1 OR R3,#0FD00H ; START OF BIT SPACE MOV R4,#1 MOVB RL5,RH2 SHL R4,R5 ; CALCULATE BIT MASK JB R2.7,SetBit CPL R4 ; CLEAR BIT AND R4,[R3] JMPR cc_UC,StoreBit SetBit: OR R4,[R3] ; SET BIT StoreBit: MOV [R3],R4 JMPR cc_UC,RepeatInit EndInit: $ELSE ; $IF TINY ************************************************************** MOV R9,#SEG (?C_INITSECSTART) MOV R8,#SOF (?C_INITSECSTART) $IF (DPP3USE = 1) ; *********************************************************** RepeatInit: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF MOV DPP3,#3 EXTS R9,#1 MOV R2,[R8] JMPR cc_Z,EndInit ADD R8,#2 ADDC R9,#0 JBC R2.15,InitBit MOV R4,R2 AND R2,#3FFFH JMPR cc_NZ,LenLoad MOV R4,#0 EXTS R9,#1 MOV R2,[R8] ADD R8,#2 ADDC R9,#0 LenLoad: EXTS R9,#1 MOV R3,[R8] ADD R8,#2 ADDC R9,#0 JB R4.14,CopyInitVal MOV DPP3,R3 EXTS R9,#1 MOV R3,[R8] ADD R8,#2 ADDC R9,#0 CopyInitVal: EXTS R9,#1 MOVB RL5,[R8] ADD R8,#1 ADDC R9,#0 MOVB [R3],RL5 ADD R3,#1 JB R4.14,NoDPP3Adj JB R3.14,NoDPP3Adj ADD DPP3,#1 OR R3,#0C000H ; SET DPP3 Bits NoDPP3Adj: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF SUB R2,#1 JMPR cc_NZ,CopyInitVal JNB R8.0,RepeatInit ADD R8,#1 JMPR cc_UC,RepeatInit InitBit: MOVBZ R3,RL2 SHL R3,#1 OR R3,#0FD00H ; START OF BIT SPACE MOV R4,#1 MOVB RL5,RH2 SHL R4,R5 ; CALCULATE BIT MASK JB R2.7,SetBit CPL R4 ; CLEAR BIT AND R4,[R3] JMPR cc_UC,StoreBit SetBit: OR R4,[R3] ; SET BIT StoreBit: MOV [R3],R4 JMPR cc_UC,RepeatInit $ELSE ; block IF (DPP3USE = 1) ************************************************ RepeatInit: $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF EXTS R9,#1 MOV R2,[R8] JMPR cc_Z,EndInit ADD R8,#2 ADDC R9,#0 JBC R2.15,InitBit MOV R4,R2 AND R2,#3FFFH JMPR cc_NZ,LenLoad MOV R4,#0 EXTS R9,#1 MOV R2,[R8] ADD R8,#2 ADDC R9,#0 LenLoad: EXTS R9,#1 MOV R3,[R8] ADD R8,#2 ADDC R9,#0 JB R4.14,CopyNearVal MOV R6,R3 EXTS R9,#1 MOV R3,[R8] ADD R8,#2 ADDC R9,#0 CopyInitVal: EXTS R9,#1 MOVB RL5,[R8] ADD R8,#1 ADDC R9,#0 EXTP R6,#1 MOV [R3],RL5 ADD R3,#1 ADDC R6,#0 $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF SUB R2,#1 JMPR cc_NZ,CopyInitVal JMPR cc_UC,CopyInitDone CopyNearVal: EXTS R9,#1 MOVB RL5,[R8] ADD R8,#1 ADDC R9,#0 MOVB [R3],RL5 ADD R3,#1 $IF (WATCHDOG = 1) SRVWDT ; SERVICE WATCHDOG $ENDIF SUB R2,#1 JMPR cc_NZ,CopyNearVal CopyInitDone: JNB R8.0,RepeatInit ADD R8,#1 JMPR cc_UC,RepeatInit InitBit: MOVBZ R3,RL2 SHL R3,#1 OR R3,#0FD00H ; START OF BIT SPACE MOV R4,#1 MOVB RL5,RH2 SHL R4,R5 ; CALCULATE BIT MASK JB R2.7,SetBit CPL R4 ; CLEAR BIT AND R4,[R3] JMPR cc_UC,StoreBit SetBit: OR R4,[R3] ; SET BIT StoreBit: MOV [R3],R4 JMPR cc_UC,RepeatInit $ENDIF ; close block IF (DPP3USE = 1) **************************************** EndInit: $ENDIF ; close block $IF TINY ************************************************ $ENDIF ; close $IF (INIT_VARS = 1) ******************************************* ;------------------------------------------------------------------------------ $IF TINY JMP main $ELSE JMP FAR main $ENDIF ?C_RESET ENDP ?C_STARTUP_CODE ENDS $IF (INIT_VARS = 1) EXTERN ?C_ENDINIT:WORD $ENDIF ;****************************************************************************** ; * ; STRUCTURE OF THE INITIALIZATION INFORMATION * ; ------------------------------------------- * ; This section describes the initialization data generated by: * ; - C166 for explicit variable initializations (in ?C_INITSEC) * ; - L166 to clear memory regions (in ?C_CLRMEMSEC) * ; * ; Explicit variable initilizations at C source level are stored by C166 in * ; the section ?C_INITSEC. All partial sections are combined at linker level * ; to one section. The section end value DW 0 taken from the library module * ; ?C_ENDINIT. This module is included with the ?C_ENDINIT symbol definition. * ; * ; Structure of the ?C_INITSEC information: * ; ?C_INITSECSTART: [start address label] * ; + [WORD] ----+ repeated * ;
[WORD or DWORD] ----+ repeated * ; [BYTES according to length] ----+ repeated * ; 0x0000 [WORD] * ; Whereby: * ; := 0x4000: WORD near address field, * ; 0x0000: DWORD PAG/POF address field (POF part set to DPP3) * ; 0x8080: set bit * ; 0x8000: clear bit * ; := bytes to copy into memory specified by
* ; For bit initilizations ( = 0x80x0) the address is encoded in the * ; field and no further address information is generated. MSB of * ; is the bit pos. LSB of is the bit address. * ; * ; * ; Sections that start with ?xx0? are set to zero in the startup code. The * ; address information about these sections are stored by L166 in the section * ; ?C_CLRMEMSEC. * ; * ; Structure of the ?C_CLRMERSEC information: * ; ?C_CLRMEMSECSTART: [start address label] * ; + [WORD] ----+ repeated * ;
[WORD or DWORD] ----+ repeated * ; 0x0000 [WORD] * ; Whereby: * ; := 0x4000: WORD near address field, * ; 0x8000: DWORD PAG/POF address field (POF part set to DPP3) * ; 0x0000: bit area * ; For bit areas ( = 0x0000) the address is encoded as WORD with LSB * ; as byte offset to 0xFD00 and MSB as bit number in the addressed byte. * ; * ;****************************************************************************** END
