#include #include #include #include // #define DEBUG_DFPLAYER_COMMUNICATION #include "DFMiniMp3.h" #define EEPROM_CFG 1 #define EEPROM_FOLDER 2 #define EEPROM_TRACK 4 #define EEPROM_INIT_MAGIC 8 #define MAGIC_MARKER 0xCAFE #define BUTTON_TOLERANCE 25 #define LONG_KEY_PRESS_TIME_MS 2000L #define VOLUME_CHECK_INTERVAL_MS 200L #define PLAY_DELAY_MS 500L #define FADE_OUT_MS 3L * 1000L * 60L #define PIN_KEY A3 #define PIN_VOLUME A2 #define PIN_VOLUME_INTERNAL A1 // Uncomment to use button 11 as button "previous" // #define USE_PREVIOUS_BUTTON // Uncomment to make player pause playback on minimum volume // #define PAUSE_ON_MIN_VOLUME // Comment if compiler complains about too big binary #define INIT_CONFIG_ON_FIRST_START #define NO_FOLDERS 12 #ifdef USE_PREVIOUS_BUTTON #define NO_FOLDERS 11 #endif class Mp3Notify; void initDFPlayer(); void playFolderOrNextInFolder(int folder, boolean loop); void repeatCurrentOrPlayPreviousInCurFolder(); void writeTrackInfo(int16_t folder, int16_t track); void readFolderTrackCounts(); boolean isPlaying(); SoftwareSerial softSerial(0, 1); // RX, TX enum { MODE_NORMAL, MODE_SET_TIMER } mode = MODE_NORMAL; boolean continuousPlayWithinPlaylist = true; boolean loopPlaylist = false; boolean restartLastTrackOnStart = true; boolean repeat1 = false; boolean* config[] {&continuousPlayWithinPlaylist, &loopPlaylist, &restartLastTrackOnStart, &repeat1}; boolean paused = false; boolean volatile error = false; boolean sdAvailable = false; boolean usbAvailable = false; float volFade = 1.0; int vol = -1; int key = -1; unsigned long keyPressTimeMs = 0L; unsigned long volumeHandledLastMs = 0L; unsigned long sleepAtMs = 0L; unsigned long offAtMs = 0L; unsigned long trackPlaybackStartedAtMs = 0L; unsigned long nowMs; int16_t curFolder = -1; int16_t curTrack = -1; int16_t expectedGlobalTrackToFinish = -1; unsigned long startTrackAtMs = 0L; int maxTracks[NO_FOLDERS]; DFMiniMp3 player(softSerial); class Mp3Notify { public: static void OnError(uint16_t errorCode) { error = true; } static void OnPlayFinished(uint16_t globalTrack) { if (expectedGlobalTrackToFinish == globalTrack) { expectedGlobalTrackToFinish = -1; if (startTrackAtMs == 0 /* no user request pending */) { if (repeat1) { startTrackAtMs = millis() + PLAY_DELAY_MS; } else if (continuousPlayWithinPlaylist) { playFolderOrNextInFolder(curFolder, loopPlaylist); } } if (restartLastTrackOnStart && (curTrack == -1 || !continuousPlayWithinPlaylist)) { writeTrackInfo(-1, -1); } } } static void OnCardOnline(uint16_t code) { sdAvailable = true; } static void OnCardInserted(uint16_t code) { player.setPlaybackSource(DfMp3_PlaySource_Sd); readFolderTrackCounts(); } static void OnCardRemoved(uint16_t code) { if (!isPlaying()) { player.setPlaybackSource(DfMp3_PlaySource_Usb); readFolderTrackCounts(); } } static void OnUsbOnline(uint16_t code) { usbAvailable = true; } static void OnUsbInserted(uint16_t code) { player.setPlaybackSource(DfMp3_PlaySource_Usb); readFolderTrackCounts(); } static void OnUsbRemoved(uint16_t code) { if (!isPlaying()) { player.setPlaybackSource(DfMp3_PlaySource_Sd); readFolderTrackCounts(); } } }; void turnOff() { volFade = 0.0; player.setVolume(0); delay(50); player.stop(); delay(50); player.setPlaybackSource(DfMp3_PlaySource_Sleep); delay(50); player.disableDac(); delay(50); player.sleep(); delay(200); while (1) { set_sleep_mode(SLEEP_MODE_PWR_DOWN); sleep_mode(); delay(5000); } } void initDFPlayer() { delay(100); player.setEq(DfMp3_Eq_Normal); delay(100); if (usbAvailable) { player.setPlaybackSource(DfMp3_PlaySource_Usb); } else { player.setPlaybackSource(DfMp3_PlaySource_Sd); } delay(250); player.enableDac(); delay(250); } void readConfig() { uint8_t cfg = eeprom_read_byte((uint8_t*) EEPROM_CFG); loopPlaylist = cfg & 1; continuousPlayWithinPlaylist = cfg & 2; restartLastTrackOnStart = cfg & 4; repeat1 = cfg & 8; } void writeConfig() { uint8_t cfg = eeprom_read_byte((uint8_t*) EEPROM_CFG); cfg = (cfg & (0xff ^ 1)) | (loopPlaylist ? 1 : 0); cfg = (cfg & (0xff ^ 2)) | (continuousPlayWithinPlaylist ? 2 : 0); cfg = (cfg & (0xff ^ 4)) | (restartLastTrackOnStart ? 4 : 0); cfg = (cfg & (0xff ^ 8)) | (repeat1 ? 8 : 0); eeprom_update_byte((uint8_t*) EEPROM_CFG, cfg); } void readTrackInfo() { curFolder = (int16_t) eeprom_read_word((uint16_t*) EEPROM_FOLDER); if (curFolder < 1 || curFolder > NO_FOLDERS) { curFolder = -1; curTrack = -1; return; } curTrack = (int16_t) eeprom_read_word((uint16_t*) EEPROM_TRACK); if (curTrack < 1 || curTrack > maxTracks[curFolder - 1]) { curTrack = -1; curFolder = -1; } } void writeTrackInfo(int16_t folder, int16_t track) { eeprom_update_word((uint16_t*) EEPROM_FOLDER, (uint16_t) folder); eeprom_update_word((uint16_t*) EEPROM_TRACK, (uint16_t) track); } boolean isPlaying() { uint16_t state = 0; int retries = 3; error = true; while (retries > 0 && error) { --retries; error = false; state = player.getStatus(); if (error) { delay(100); } } error = false; return (state & 1) == 1; } void playOrAdvertise(int fileNo) { if (isPlaying()) { player.playAdvertisement(fileNo); } else { player.playMp3FolderTrack(fileNo); } } void playFolderOrNextInFolder(int folder, boolean loop = true) { startTrackAtMs = 0; if (curFolder != folder) { curFolder = folder; curTrack = 1; } else { if (curTrack == -1) { curTrack = 1; } else if (++curTrack > maxTracks[folder - 1]) { if (!loop) { curTrack = -1; return; } curTrack = 1; } } startTrackAtMs = millis() + PLAY_DELAY_MS; } void repeatCurrentOrPlayPreviousInCurFolder() { if (curFolder == -1 || curTrack == -1) { return; } startTrackAtMs = 0; if (trackPlaybackStartedAtMs == 0 || millis() < trackPlaybackStartedAtMs + 3000) { if (--curTrack <= 0) { curTrack = maxTracks[curFolder - 1]; } } trackPlaybackStartedAtMs = 0; startTrackAtMs = millis() + PLAY_DELAY_MS; } void readFolderTrackCounts() { delay(2000); for (int i = 0; i < NO_FOLDERS; ++i) { maxTracks[i] = player.getFolderTrackCount(i + 1); if (maxTracks[i] == -1) i--; } curFolder = -1; curTrack = -1; } #ifdef INIT_CONFIG_ON_FIRST_START void initConfigOnFirstStart() { uint16_t magic = eeprom_read_word((uint16_t*) EEPROM_INIT_MAGIC); if (magic != MAGIC_MARKER) { eeprom_update_word((uint16_t*) EEPROM_INIT_MAGIC, MAGIC_MARKER); writeConfig(); writeTrackInfo(-1, -1); } } #endif void setup() { player.begin(); pinMode(PIN_VOLUME, INPUT); pinMode(PIN_VOLUME_INTERNAL, INPUT); pinMode(PIN_KEY, INPUT_PULLUP); #ifdef INIT_CONFIG_ON_FIRST_START initConfigOnFirstStart(); #endif readConfig(); delay(1500); error = false; uint8_t storageDevices = player.queryStorageDevices(); if (error) { error = false; if (!sdAvailable && !usbAvailable) { player.reset(); for (int i = 0; i < 30; ++i) { player.loop(); delay(50); } } } else { usbAvailable = storageDevices & 0x01; sdAvailable = storageDevices & 0x02; } initDFPlayer(); readFolderTrackCounts(); if (restartLastTrackOnStart) { readTrackInfo(); if (curFolder != -1 && curTrack != -1) { startTrackAtMs = millis() + PLAY_DELAY_MS; } } } inline void handleSleepTimer() { if (sleepAtMs != 0 && nowMs >= sleepAtMs) { volFade = 1.0 - (nowMs - sleepAtMs) / (float) (offAtMs - sleepAtMs); if (volFade <= 0.0) { turnOff(); } } } inline void handleVolume() { if (nowMs > volumeHandledLastMs + VOLUME_CHECK_INTERVAL_MS) { volumeHandledLastMs = nowMs; int volCurrent = analogRead(PIN_VOLUME); int volInternal = analogRead(PIN_VOLUME_INTERNAL); int volNew = (map(volCurrent, 0, 1023, 1, 31 - map(volInternal, 1023, 0, 1, 30))) * volFade; if (volNew != vol) { vol = volNew; player.setVolume(vol); #ifdef PAUSE_ON_MIN_VOLUME if (vol == 1 && !paused) { paused = true; player.pause(); } if (vol > 1 && paused) { paused = false; player.start(); } #endif } } } inline void handleKeyPress() { int keyCurrent = analogRead(PIN_KEY); if (keyCurrent > 958 && key > 0) { switch (mode) { case MODE_NORMAL: if (nowMs - keyPressTimeMs >= LONG_KEY_PRESS_TIME_MS && key == 11) { mode = MODE_SET_TIMER; playOrAdvertise(100); delay(1000); } else if (nowMs - keyPressTimeMs >= LONG_KEY_PRESS_TIME_MS && key >= 1 && key <= 4) { *config[key-1] = !*config[key-1]; playOrAdvertise(*config[key-1] ? (key + 1) * 100 : (key + 1) * 100 + 1); writeConfig(); if (key == 3) { writeTrackInfo(restartLastTrackOnStart ? curFolder : -1, restartLastTrackOnStart ? curTrack : -1); } delay(1000); } else { #ifdef USE_PREVIOUS_BUTTON if (key == 11) { repeatCurrentOrPlayPreviousInCurFolder(); } else #endif playFolderOrNextInFolder(key); } break; case MODE_SET_TIMER: playOrAdvertise(key); if (key == 1) { sleepAtMs = 0; offAtMs = 0; volFade = 1.0; } else { sleepAtMs = nowMs + (key - 1) * 1000L * 60L * 5L; offAtMs = sleepAtMs + FADE_OUT_MS; } delay(1000); mode = MODE_NORMAL; break; } key = -1; } else if (keyCurrent <= 958) { int keyOld = key; if (keyCurrent > 920 - BUTTON_TOLERANCE) { key = 12; } else if (keyCurrent > 870 - BUTTON_TOLERANCE) { key = 9; } else if (keyCurrent > 780 - BUTTON_TOLERANCE) { key = 6; } else if (keyCurrent > 690 - BUTTON_TOLERANCE) { key = 3; } else if (keyCurrent > 630 - BUTTON_TOLERANCE) { key = 2; } else if (keyCurrent > 560 - BUTTON_TOLERANCE) { key = 5; } else if (keyCurrent > 480 - BUTTON_TOLERANCE) { key = 8; } else if (keyCurrent > 380 - BUTTON_TOLERANCE) { key = 11; } else if (keyCurrent > 300 - BUTTON_TOLERANCE) { key = 10; } else if (keyCurrent > 180 - BUTTON_TOLERANCE) { key = 7; } else if (keyCurrent > 100 - BUTTON_TOLERANCE) { key = 4; } else if (keyCurrent > 0) { key = 1; } if (keyOld != key) { keyPressTimeMs = nowMs; } } } void loop() { nowMs = millis(); handleSleepTimer(); handleVolume(); if (!paused) { handleKeyPress(); } if (startTrackAtMs != 0 and nowMs >= startTrackAtMs) { startTrackAtMs = 0; trackPlaybackStartedAtMs = nowMs; player.playFolderTrack(curFolder, curTrack); if (restartLastTrackOnStart) { writeTrackInfo(curFolder, curTrack); } // Don't reduce the following delay. Otherwise player might not have started playing // the requested track, returning the file number of the previous file, thus breaking // continuous play list playing which relies on correct curTrackFileNumber. delay(500); expectedGlobalTrackToFinish = player.getCurrentTrack(); } player.loop(); if (softSerial.overflow()) { softSerial.flush(); } delay(50); }
