--- DFF ------------------------------ library ieee; use ieee.std_logic_1164.all; entity DFF is generic( P_DELAY : time := 1 ns; SETUP : time := 1 ns); port( D : in std_logic; CLK : in std_logic; EN : in std_logic; RESET : in std_logic; Q : out std_logic; Q_INV : out std_logic); end DFF; architecture rtl of DFF is -- Zusätzliche Signale begin -- Hier kommt die Beschreibung vom DFF rein. end; --- MUX2X1 ------------------------------ library ieee; use ieee.std_logic_1164.all; entity MUX2X1 is generic( P_DELAY : time := 2 ns); port( S : in std_logic; E1 : in std_logic; E2 : in std_logic; Y : out std_logic); end MUX2X1; architecture rtl of MUX2X1 is -- Zusätzliche Signale begin -- Hier kommt die Beschreibung vom MUX2X1 rein. end; ----- D_RIPPLE_REG ------------------------------ library ieee; use ieee.std_logic_1164.all; entity D_RIPPLE_REG is generic( P_DELAY : time := 8 ns; SETUP : time := 2 ns; SIZE : positive := 4); port( D : in std_logic_vector(SIZE-1 downto 0); CLK : in std_logic; EN : in std_logic; RESET : in std_logic; RIPPLE : in std_logic; INPUT : in std_logic; Q : out std_logic_vector(SIZE-1 downto 0); Q_INV : out std_logic_vector(SIZE-1 downto 0); OUTPUT : out std_logic); end D_RIPPLE_REG; architecture rtl of D_RIPPLE_REG is -- Hier werden verwendete Komponenten deklariert. -- Zusätzliche Signale begin -- Hier kommt die Beschreibung vom MUX2X1 rein. end; ----- Testbench -------------------------------------- -- Optional
