Strings.0=Yes Strings.1=No Strings.2=Enter a box description, please Strings.3=Box exists Strings.4=Box already exists. Do yo want you use this record? Strings.5=Enter the case description, please Strings.6=Case exists Strings.7=Case already exists. Do you want to use this record? Strings.8=Delete Strings.9=Want you delete this record? Strings.10= Strings.11=Open link: Strings.12=Open File: Strings.13=Export finished. Strings.14=The picture is too big and cannot be stored in database!\r\nSize: %1\r\nMake the picture smaller? Strings.15=Picture size: Strings.16=Byte Strings.17=Order Strings.18=Want you set the articles as ordered? Strings.19=There are no open positions for the deliverer "Reichelt". Strings.20=The deliverer "Reichelt" could not be found in "Address"! Strings.21=Enter the address description, please Strings.22=Address existing Strings.23=Address already exists. Do you want to use this record? Strings.24=Enter the component description, please Strings.25=Components exists Strings.26=Component already exists. Do you want to use this record? Strings.27=Enter a designation, please Strings.28=open Strings.29=ordered Strings.30=delivered Strings.31=stored Strings.32=Delete Strings.33=Some components use this case.\r\nDo you really want to delete this case? Strings.34=Enter Password Strings.35=Enter the database password, please Strings.36=Ordering position already exists Strings.37=Component already exists in the order-list. Do you want to use this record? Strings.38=Enter the type description, please Strings.39=n. ordered Strings.40=Import data Strings.41=The import deletes all records from the selected tables and inserts the records from the file.\r\nDo you want to start the import? Strings.42=Stock/field exists Strings.43=Stock/field already exists. Do you want to rename the entry? Strings.44=Stock/Field Strings.45=Enter a new description, please Strings.46=Enter a project description, please Strings.47=Project Exists Strings.48=Project already exists. Do you want to use this record? Strings.49=Main picture Strings.50=Extra picture Strings.51= Strings.52= Strings.53= Strings.54=Topic selection Strings.55=Book project components Strings.56=The project has been produced and the components of the positions will be reduce from stock? Strings.57=Enter a designation, please frmMain.tabBauteil=Component - F2 frmMain.tabBBauteil=Component frmMain.edLagerManiHint=Stock with a plus / minus manipulate frmMain.btnLagerManiM=- frmMain.btnLagerManiMHint=Stock with a minus manipulate frmMain.btnLagerManiP=+ frmMain.btnLagerManiPHint=Stock with a plus manipulate frmMain.spGotoCaseHint=Goto case frmMain.spGotoKisteHint=Goto box frmMain.spGotoAdrLGHint=Goto Address frmMain.lbBauteilHandbuch1=Ha&ndbook frmMain.spHandbuch1Hint=Choice Manual (File) frmMain.spHandbuch1ExecHint=Open manual frmMain.spBNew1Hint=New entry frmMain.spBCopy1Hint=Copy data frmMain.spBSave1Hint=Save data frmMain.spBAbort1Hint=Abort change frmMain.spBDelete1Hint=Delete data frmMain.lbDatum11=Date: frmMain.spBPrint1Hint=Print frmMain.tabBLief=Deliverer frmMain.spBNew2Hint=New entry frmMain.spBCopy2Hint=Copy data frmMain.spBSave2Hint=Save data frmMain.spBAbort2Hint=Abort change frmMain.spBDelete2Hint=Delete data frmMain.lbDatum12=Date: frmMain.spBPrint2Hint=Print frmMain.lbBLiefCaseLag=Variant frmMain.lbBLiefAdr=&Address frmMain.lbBLiefBestNr=Order-&Nr frmMain.lbBLiefEPreis=&Price (PU) frmMain.spGotoAdrHint=Goto Address frmMain.spGotoLagerHint=Goto Store/Case frmMain.lbBauteilTyp=&Type frmMain.lbBauteilHandbuch=&Handbook frmMain.lbBauteilBez=&Description frmMain.spBauteilTypHint=Choice type frmMain.spHandbuchHint=Choice Manual (File) frmMain.spHandbuchExecHint=Open manual frmMain.spFilterTypHint=Set filter to selected type frmMain.lbBauteilLibrary=&Library frmMain.spBNewHint=New entry frmMain.spBCopyHint=Copy data frmMain.spBSaveHint=Save data frmMain.spBAbortHint=Abort change frmMain.spBDeleteHint=Delete data frmMain.lbDatum1=Date: frmMain.spBPrintHint=Print frmMain.edSchnellsucheHint=Quick Search frmMain.spBExpHint=Import/Export frmMain.tabProjekt=Project - F3 frmMain.lbProjektHandbuch=&Handbook frmMain.lbProjektBez=&Description frmMain.spHandbuch2Hint=Choice Manual (File) frmMain.spHandbuch2ExecHint=Open manual frmMain.lbProjektMengeFertig=&Quantity ready frmMain.lbProjektMengeOffen=Q&uantity Open frmMain.lbProjektTermin=&Termin frmMain.spProjektBuchHint=Stock accounting frmMain.spPNewHint=New entry frmMain.spPCopyHint=Copy data frmMain.spPSaveHint=Save data frmMain.spPAbortHint=Abort change frmMain.spPDeleteHint=Delete data frmMain.lbDatum7=Date: frmMain.spPPrintHint=Print frmMain.edSchnellsucheProjHint=Quick Search frmMain.spPExpHint=Import/Export frmMain.tabPUebers=Overview frmMain.tabPPos=Position frmMain.lbPPosSMD=S&MD frmMain.lbPPosMenge=Quantit&y frmMain.lbPPosBez=D&escription frmMain.lbPPosBauteil=&Component frmMain.spGotoBauteil1Hint=Goto Component frmMain.lbPPosLagCase=&Store/Case frmMain.spGotoBauteilLG1Hint=Goto Store/Case frmMain.lbPPosSymbol=Symb&ol frmMain.lbPPosWert=&Value frmMain.lbPPosCase=C&ase frmMain.lbPPosVariante=Va&riant frmMain.lbPPosTop=To&p frmMain.lbPPosPosX=Pos &X frmMain.lbPPosPosY=Pos Y frmMain.spFilterVarianteHint=Filter variant frmMain.spPNew1Hint=New entry frmMain.spPCopy1Hint=Copy data frmMain.spPSave1Hint=Save data frmMain.spPAbort1Hint=Abort change frmMain.spPDelete1Hint=Delete data frmMain.lbDatum13=Date: frmMain.spPPrint1Hint=Print frmMain.spPPExpHint=Import/Export frmMain.tabPHistorie=History frmMain.lbProjektHistHandbuch=Ha&ndbook frmMain.lbProjektHistProjBez=&Project frmMain.spHandbuch3Hint=Choice Manual (File) frmMain.spHandbuch3ExecHint=Open manual frmMain.lbProjektHistVersion=&Version frmMain.lbProjektHistAufwand=T&ime frmMain.lbProjektHistDatum=D&ate frmMain.lbProjektHistBez=D&escription frmMain.spHNew1Hint=New entry frmMain.spHCopy1Hint=Copy data frmMain.spHSave1Hint=Save data frmMain.spHAbort1Hint=Abort change frmMain.spHDelete1Hint=Delete data frmMain.lbDatum8=Date: frmMain.spHPrint1Hint=Print frmMain.tabBestell=Order - F4 frmMain.spONewHint=New entry frmMain.spOCopyHint=Copy data frmMain.spOSaveHint=Save data frmMain.spOAbortHint=Abort change frmMain.spODeleteHint=Delete data frmMain.lbDatum2=Date: frmMain.spOPrintHint=Print frmMain.spOExpHint=Import/Export frmMain.edSchnellsucheBestHint=Quick Search frmMain.lbBestBez=&Description frmMain.lbBestMenge=&Quantity (packing unit) frmMain.lbBestBauteil=Co&mponent frmMain.lbBestLagCase=&Store/Case frmMain.lbBestLiefLagCase=Suppl&ier/stock/case frmMain.lbBestStatus=Status frmMain.spBestelltFilterHint=Filter on current status frmMain.btnBestellLagerBuch=Book &in stock frmMain.spGotoBauteilHint=Goto Component frmMain.spGotoBauteilLGHint=Goto Store/Case frmMain.lbBestL1BestNr=&Order-Nr frmMain.lbBestL1EP=&Price frmMain.lbBestL1GP=Total Price frmMain.spGotoAdrL1Hint=Goto Address frmMain.lbBestL2GP=Total Price frmMain.spGotoAdrL2Hint=Goto Address frmMain.grpSum=Sum frmMain.lbBestSumOffen=Status "open" frmMain.tabSuche=Seek - F5 frmMain.lbSuchSuch=&Seek frmMain.spSPrintHint=Print frmMain.rbSuchBaut=in &components frmMain.rbSuchHist=in &history frmMain.rbSuchWissen=in &knowledge frmMain.tabCase=Case - F6 frmMain.spCNewHint=New entry frmMain.spCCopyHint=Copy data frmMain.spCSaveHint=Save data frmMain.spCAbortHint=Abort change frmMain.spCDeleteHint=Delete data frmMain.lbDatum3=Date: frmMain.spCPrintHint=Print frmMain.edSchnellsucheCaseHint=Quick Search frmMain.lbCaseBez=&Description frmMain.lbCasePin=&Pin frmMain.DBCheckBox2=&SMD frmMain.lbCaseRaster=&Raster frmMain.lbCasemm=mm frmMain.Panel37=Component with selected case frmMain.tabKiste=Box -F7 frmMain.spKNewHint=New entry frmMain.spKCopyHint=Copy data frmMain.spKSaveHint=Save data frmMain.spKAbortHint=Abort change frmMain.spKDeleteHint=Delete data frmMain.lbDatum4=Date: frmMain.spKPrintHint=Print frmMain.edSchnellsucheKisteHint=Quick Search frmMain.spKFachHint=Components in case / tray manage frmMain.lbKisteBez=&Description frmMain.lbKisteLagO=&Location frmMain.lbKisteSize=&Size frmMain.lbKisteNr=&Number frmMain.lbKistePX=Pos &X frmMain.lbKistePY=Pos &Y frmMain.tabTyp=Type - F8 frmMain.spTNewHint=New entry frmMain.spTCopyHint=New Sub entry frmMain.spTSaveHint=Save data frmMain.spTAbortHint=Abort change frmMain.spTDeleteHint=Delete data frmMain.lbDatum5=Date: frmMain.spTPrintHint=Print frmMain.rbTypAnsichtNur=&Only choiced type frmMain.rbTypAnsichtAlle=&With selected subtypes frmMain.lbTypAnsicht=View frmMain.tabAdr=Address - F9 frmMain.lbAdrBez=&Description frmMain.lbAdrFirma=&Company frmMain.lbAdrStr=&Street frmMain.lbAdrPlz=&PostCode/Loc. frmMain.lbAdrName=&Name frmMain.lbAdrTel=&Tel frmMain.lbAdrMobil=&Handy frmMain.lbAdrFax=F&ax frmMain.lbAdrINet=&Internet frmMain.lbAdrMail=&E-Mail frmMain.lbAdrKundNr=C&ustomer No frmMain.lbAdrUsId=&VAT-ID frmMain.spInternetHint=Open Web-Browser frmMain.lbAdrLand=C&ountry frmMain.spANewHint=New entry frmMain.spACopyHint=Copy data frmMain.spASaveHint=Save data frmMain.spAAbortHint=Abort change frmMain.spADeleteHint=Delete data frmMain.lbDatum6=Date: frmMain.spAPrintHint=Print frmMain.edSchnellsucheAdrHint=Quick Search frmMain.tabExtras=Extras - F10 frmMain.tabExtraCalc=Calculator frmMain.grpTimer=Timer frmMain.lbTimerStartZeit=Start &Time frmMain.lbTimerHMS=H:M:S frmMain.lbTimeAktuell=Current Time frmMain.btnCalculator=Calculator frmMain.btnCalendar=Calendar frmMain.grpSMDCode=SMD Code frmMain.lbSMDCode=Value frmMain.lbSMDCodeHalbl=Semiconductors frmMain.lbSMDCodeHalblDesc=This semiconductor table has been made available by http://www.elektronik-kompendium.de/. Thank you!\r\nIf a component could not be found, you can search it online: frmMain.btnSmdCodeElKo=To http://www.elektronik-kompendium.de/ frmMain.btnCalcR=Voltage divider frmMain.btnCalcLM317=LM317 / LM350 frmMain.tabExtraHistorie=History frmMain.lbHistExHandbuch=&Handbook frmMain.lbHistExProjBez=P&roject frmMain.spHandbuch4Hint=Choice Manual (File) frmMain.spHandbuch4ExecHint=Open manual frmMain.lbHistExVersion=&Version frmMain.lbHistExAufwand=&Time frmMain.lbProjektTermin2=&Date frmMain.lbHistExBez=D&escription frmMain.lbHistExProj=&Project frmMain.spGotoProjektHint=Goto project frmMain.spHNewHint=New entry frmMain.spHCopyHint=Copy data frmMain.spHSaveHint=Save data frmMain.spHAbortHint=Abort change frmMain.spHDeleteHint=Delete data frmMain.lbDatum9=Date: frmMain.spHPrintHint=Print frmMain.tabExtraWissen=Knowledge frmMain.lbWissenHandbuch=&Handbook frmMain.spHandbuch5Hint=Choice Manual (File) frmMain.spHandbuch5ExecHint=Open manual frmMain.lbWissenThema=&Topic frmMain.lbWissenBez=&Description frmMain.spWNewHint=New entry frmMain.spWCopyHint=Copy data frmMain.spWSaveHint=Save data frmMain.spWAbortHint=Abort change frmMain.spWDeleteHint=Delete data frmMain.lbDatum10=Date: frmMain.spWPrintHint=Print frmMain.tabExtraLog=Log frmMain.chkDebugPause=&Pause Log frmMain.btnDebugClear=&Clear frmMain.tabExtraDatabase=Database frmMain.lbDDB=Database manipulation with SQL command frmMain.spDPrintHint=Print frmMain.spDExpHint=Import/Export frmMain.spDSaveHint=Save data frmMain.spDAbortHint=Abort change frmMain.spDDeleteHint=Delete data frmMain.btnDebugSQL=&Execute frmMain.btnDebugOeffnen=Open &all frmMain.btnDebugOeffnenHint=This button turns all the tables (recognized tabs) are updated frmMain.chkDebErwIns=MultiInsert frmMain.chkDebErwInsHint=Several records with an INSERT command process frmMain.tabExtraInfo=Info frmMain.lbDInfo1=Electronics, warehouse management, order proposal list frmMain.lbDInfo2=This program may be freely used and copied, it's freeware frmMain.btnHelp=Help - F1 frmMain.grpLanguage=Translation frmMain.btnLangSave=&Save text frmMain.btnLangLoad=&Loading text frmMain.btnLangTranslate=&Translations frmMain.lbDInfoTranslatedBy= frmMain.qAdrfoto_ID=Foto_ID frmMain.qAdrBezeichnung=Designation frmMain.qAdrFirma=Company frmMain.qAdrStrasse=Street frmMain.qAdrPLZ=Postal Code frmMain.qAdrOrt=Location frmMain.qAdrName=Name frmMain.qAdrTelefon=Telephone frmMain.qAdrMobil=Handy frmMain.qAdrFax=Fax frmMain.qAdrEMail=EMail frmMain.qAdrInternet=Internet frmMain.qAdrUsSTID=VAT-ID frmMain.qAdrKundNr=CustomerID frmMain.qAdrBemerkung=Remark frmMain.qAdrLand=Country frmMain.qAdrAendDatum=ChangeDate frmMain.qKisteFoto_ID=Foto_ID frmMain.qKisteBezeichnung=Designation frmMain.qKisteLagerort=Location frmMain.qKisteNummer=Number frmMain.qKistePosX=PosX frmMain.qKistePosY=PosY frmMain.qKisteGroesse=Size frmMain.qKisteAendDatum=ChangeDate frmMain.qTypBezeichnung=Designation frmMain.qTypAendDatum=ChangeDate frmMain.qBauteilFoto_ID=Foto_ID frmMain.qBauteiltree_typ_ID=Type ID frmMain.qBauteilBezeichnung=Designation frmMain.qBauteilBeschreibung=Text frmMain.qBauteilHandbuch=Handbook frmMain.qBauteilLibrary=Library frmMain.qBauteilKennz=Flag frmMain.qBauteilAendDatum=ChangeDate frmMain.qBAdrBauteil_ID=Component frmMain.qBAdrAdr_ID=Address frmMain.qBAdrBestellNr=Order-Nr. frmMain.qBAdrEPreis=Price frmMain.qBAdrBemerkung=Remark frmMain.qBAdrAendDatum=ChangeDate frmMain.qSuchtree_typ_ID=Type frmMain.qSuchBezeichnung=Designation frmMain.qSuchCBez=CDesc. frmMain.qSuchSMD=SMD frmMain.qSuchSMD_Text=SMD_Text frmMain.qSuchKBez=BoxDesc. frmMain.qSuchLagerNr=Stock no frmMain.qSuchMenge=Quantity frmMain.qSuchHaltbar=Preserved frmMain.qSuchBarcode=Barcode frmMain.qSuchAdrBez=AddrDesc. frmMain.qSuchBestellNr=OrderNr frmMain.qSuchEPreis=Price frmMain.qSuchGPreis=Total Price frmMain.oDlg=Select Existing File frmMain.qFotoBezeichnung=Designation frmMain.qFotoTabelle=Table frmMain.qFotoBildTyp=Picture Type frmMain.qFotoBild=Picture frmMain.qFotoAendDatum=ChangeDate frmMain.oPic=Choice Picture frmMain.qBestellBezeichnung=Designation frmMain.qBestellMenge=Quantity frmMain.qBestellStatus=Status frmMain.qBestellBemerkung=Remark frmMain.qBestellBauteil_ID=Component frmMain.qBestellLief1_Adr_ID=Deliv1 Addr frmMain.qBestellLief1_BestellNr=Deliv1 OrderNo frmMain.qBestellLief1_EPreis=Deliv1 Price frmMain.qBestellLief1_GPreis=Deliv1 Total frmMain.qBestellLief2_Adr_ID=Deliv2 Addr frmMain.qBestellLief2_BestellNr=Deliv2 OrderNo frmMain.qBestellLief2_EPreis=Deliv2 Price frmMain.qBestellLief2_GPreis=Deliv2 Total frmMain.qBestellAendDatum=ChangeDate frmMain.mnBestMengeMin=Components with a minimum amount of undercut frmMain.mnExpReichelt=Reichelt Export frmMain.mnImpReichelt=Reichelt Import frmMain.sDlgCsv=Export frmMain.oDlgCsv=Import frmMain.mnDebugLogCopy=Copy line frmMain.mnDebugLogCopyAll=Copy all lines frmMain.mnDebugLogClear=Clear log frmMain.mnExpCSV=Export CSV-Format frmMain.mnExpXML=Export XML-Format frmMain.mnDBExport=Export/Import database frmMain.sDlgXml=Export frmMain.mnBExpCsv=Export CSV-Format frmMain.mnBExpXML=Export XML-Format frmMain.mnTypNeu=New entry frmMain.mnTypNeuU=New sub entry frmMain.mnTypEdit=Edit frmMain.mnTypDelete=Delete frmMain.qTypBLID=LID frmMain.qTypBBezeichnung=Designation frmMain.qTypBBeschreibung=Text frmMain.qTypBLBez=Stock Desc. frmMain.qTypBMenge=Quantity frmMain.qTypBKiste=Box frmMain.qTypBLagerNr=Stock no frmMain.qTypBBemerkung=Remark frmMain.qProjektFoto_ID=Foto_ID frmMain.qProjektBezeichnung=Designation frmMain.qProjektBeschreibung=Text frmMain.qProjektMengeFertig=Quantity finished frmMain.qProjektMengeOffen=Quantity Open frmMain.qProjektKennz=Flag frmMain.qProjektTermin=Termin frmMain.qProjektHandbuch=Handbook frmMain.qProjektAendDatum=ChangeDate frmMain.qPPosProjekt_ID=Project frmMain.qPPosBezeichnung=Designation frmMain.qPPosBemerkung=Remark frmMain.qPPosBauteil_ID=Component frmMain.qPPosSymbol=Symbol frmMain.qPPosWert=Value frmMain.qPPosMenge=Quantity frmMain.qPPosVariante=Variant frmMain.qPPosPosX=Pos X frmMain.qPPosPosY=Pos Y frmMain.qPPosTop=Top frmMain.qPPosSMD=SMD frmMain.qPPosKennz=Flag frmMain.qPPosAendDatum=ChangeDate frmMain.mnPPSchnell=Quick Entry frmMain.mnExpCSV1=Export CSV-Format frmMain.mnExpXML1=Export XML-Format frmMain.mnExpCSV2=Export CSV-Format frmMain.mnExpXML2=Export XML-Format frmMain.qHist1Projekt_ID=Project frmMain.qHist1Foto_ID=Foto_ID frmMain.qHist1Datum=Date frmMain.qHist1Projekt=Project Descr. frmMain.qHist1Bezeichnung=Designation frmMain.qHist1Beschreibung=Text frmMain.qHist1Version=Version frmMain.qHist1Kennz=Flag frmMain.qHist1Aufwand=Time frmMain.qHist1Handbuch=Handbook frmMain.qHist1AendDatum=ChangeDate frmMain.qHistProjekt_ID=Project frmMain.qHistFoto_ID=Foto_ID frmMain.qHistDatum=Date frmMain.qHistProjekt=Project Descr. frmMain.qHistBezeichnung=Designation frmMain.qHistBeschreibung=Text frmMain.qHistVersion=Version frmMain.qHistKennz=Flag frmMain.qHistAufwand=Time frmMain.qHistHandbuch=Handbook frmMain.qHistAendDatum=ChangeDate frmMain.qWissenFoto_ID=Foto_ID frmMain.qWissenBezeichnung=Designation frmMain.qWissenBeschreibung=Text frmMain.qWissenThema=Topic frmMain.qWissenKennz=Flag frmMain.qWissenHandbuch=Handbook frmMain.qWissenAendDatum=ChangeDate frmMain.qSuchHProjekt_ID=Project frmMain.qSuchHFoto_ID=Foto_ID frmMain.qSuchHDatum=Date frmMain.qSuchHProjekt=Project Descr. frmMain.qSuchHBezeichnung=Designation frmMain.qSuchHBeschreibung=Text frmMain.qSuchHVersion=Version frmMain.qSuchHKennz=Flag frmMain.qSuchHAufwand=Time frmMain.qSuchHHandbuch=Handbook frmMain.qSuchHAendDatum=ChangeDate frmMain.qSuchWFoto_ID=Foto_ID frmMain.qSuchWBezeichnung=Designation frmMain.qSuchWBeschreibung=Text frmMain.qSuchWThema=Topic frmMain.qSuchWKennz=Flag frmMain.qSuchWHandbuch=Handbook frmMain.qSuchWAendDatum=ChangeDate frmMain.mnProjMengeTest=Check for quantity production frmMain.mnProjMengeBuche=Beech quantity after production frmBestellMin=Below minimum reorder quantities frmBestellMin.btnClose=Close frmBestellMin.qryOID=OID frmBestellMin.qryBezeichnung=Designation frmBestellMin.qryMenge=Quantity frmBestellMin.qryMengeMin=Min Quantity frmBestellMin.qryStatus=Status frmBestellMin.qryKiste=Box frmBestellMin.qryLagerNr=Stock no frmBild=Picture View frmPPosTest=Check stock frmPPosTest.btnClose=Close frmPPosTest.qBID=BID frmPPosTest.qLID=LID frmPPosTest.qLagerMenge=Stocks frmPPosTest.qMengePos=Amount of position frmPPosTest.qMengeProjOffen=Project Quantity Open frmPPosTest.qLagerRest=Store rest frmPPosTest.qBezeichnung=Component description frmPPosTest.qLBez=Component Bearing Code frmPPosTest.qCBez=Case frmDruckEtikett=EleLa - Printing Label frmDruckEtikett.lbAuswKiste=&Choice box frmDruckEtikett.rgrpAuswahl=Lab&el-Format frmDruckEtikett.rgrpAuswahlItem0=Individual frmDruckEtikett.rgrpAuswahlItem1=39,5 x 17,5 mm (Standard Sort Box) frmDruckEtikett.lbBreite=&Width frmDruckEtikett.lbMM1=mm frmDruckEtikett.lbMM2=mm frmDruckEtikett.lbHoch=&Height frmDruckEtikett.lbFontGr=Font height frmDruckEtikett.lbFont=&Font frmDruckEtikett.spDataHint=Display Components frmDruckEtikett.rGrpAusricht=Alignment frmDruckEtikett.rGrpAusrichtItem0=Left frmDruckEtikett.rGrpAusrichtItem1=Center frmDruckEtikett.chkGrpFelder=Selection fields frmDruckEtikett.chkGrpFelderItem0=Box frmDruckEtikett.chkGrpFelderItem1=Stock/Field frmDruckEtikett.chkGrpFelderItem2=Component description frmDruckEtikett.chkGrpFelderItem3=Stock/case description frmDruckEtikett.chkGrpFelderItem4=Case frmDruckEtikett.btnPrint=Print frmDruckEtikett.btnAbbruch=Cancel frmDruckEtikett.qDataLagerNr=Stock no frmDruckEtikett.qDataBezeichnung=Designation frmDruckEtikett.qDataLBezeichnung=Stock Description frmDruckEtikett.qDataGehuse=Case frmImportExport=Export/Import database frmImportExport.btnClose=Close frmImportExport.chkGrp=&Choice table frmImportExport.btnExport=&Export frmImportExport.lbFile=&File frmImportExport.btnImport=&Import frmKisteTausch=Stock/Field exchange frmKisteTausch.Panel3=box / stock Number/Field frmKisteTausch.Panel5=Contents of box / stock Number/Field frmKisteTausch.btnBauteilKisteEntf=Component from box to remove frmKisteTausch.btnBauteilInFach=Component in the storage compartment add frmKisteTausch.btnFachAdd=Add storage compartment frmKisteTausch.btnBauteilFachEntf=Remove from component storage compartment frmKisteTausch.btnFachRen=Compartment rename frmKisteTausch.btnFachMove=Content to box / stock-no move frmKisteTausch.btnClose=Close frmKisteTausch.Panel8=Component list frmKisteTausch.lbSuch=Quick Search frmKisteTausch.qInhaltBauteilBez=ComponentDescr. frmKisteTausch.qInhaltCBez=Case frmKisteTausch.qBauteilBID=BID frmKisteTausch.qBauteilBauteilBez=ComponentDescr. frmKisteTausch.qBauteilCBez=Case frmKisteTausch.qBauteilKiste=Box frmKisteTausch.qBauteilLagerNr=Stock no frmKisteTausch.mnTVRen=Compartment rename frmKisteTausch.mnTVAdd=Add storage compartment frmKisteTausch.mnInhaltEntfKiste=Component from box to remove frmKisteTausch.mnInhaltEntfFach=Remove from component storage compartment frmKisteTausch.mnBauteilInFach=Component in the storage compartment add frmKisteTausch.mnOpenKiste=Open treeview box frmStatus=Status frmStatus.Panel1=Status change during import frmStatus.rGrp= frmStatus.rGrpItem0=Not change frmStatus.rGrpItem1=Open frmStatus.rGrpItem2=Ordered frmStatus.rGrpItem3=delivered frmStatus.rGrpItem4=stored frmStatus.btnOK=OK frmTypAuswahl=Choice type frmTypAuswahl.btnOK=OK frmTypAuswahl.btnAbbruch=Cancel frmKisteTauschDlg=Move content frmKisteTauschDlg.lbKiste=&Box frmKisteTauschDlg.lbLagerNr=Stock no/Field frmKisteTauschDlg.btnOK=&OK frmKisteTauschDlg.btnAbbruch=&Cancel frmKisteTauschDlg.lbVonKiste=From Box frmCalcR=Resistor divider frmCalcR.lbCaption=Calculating resistance voltage divider frmCalcR.lbUges=&Uges frmCalcR.lbUfb=U&fb frmCalcR.lbV=V frmCalcR.lbV1=V frmCalcR.btnClose=&Close frmCalcLM317=LM317/LM350 Calculator frmCalcLM317.lbCaption=Voltage divider LM317/LM350 frmCalcLM317.btnClose=&Close frmSchnell=Components Quick Entry frmSchnell.lbBauteil=&Component frmSchnell.lbCase=Ca&se/variant frmSchnell.lbBez=Id&entifier frmSchnell.lbStart=Number &Start frmSchnell.lbEnd=&Number End frmSchnell.lbFormat=Number-&Format frmSchnell.btnErz=&Create >>> frmSchnell.btnDel=Delete frmSchnell.lbDemo=Demo frmSchnell.btnCancel=&Cancel frmSchnell.btnOK=&Add frmSchnell.btnClear=Clear frmSchnell.lbTyp=Type frmSchnell.spBauteilTypHint=Choice type frmSchnell.spFilterTypHint=Set filter to selected type frmMain.chkTypCase=Filter case frmMain.grpExtraExchange=Currency Converter frmMain.lbExtraExchKurs=&Course frmMain.lbExtraExchBetrag=&Value frmMain.lbExtraExchErg=Result frmMain.btnCalcLCD=LCD Display frmMain.qTypBGehause=Case frmCalcLCD=LCD Graphic Display frmCalcLCD.btnClose=&Close frmCalcLCD.Label1=Calculation font / size for graphics LCDs frmCalcLCD.lbLCDX=Display size X frmCalcLCD.lbLCDPixel1=Pixel frmCalcLCD.lbLCDFont=Font frmCalcLCD.lbLCDTestText=Test Text frmCalcLCD.lbLCDAnsicht=View frmCalcLCD.rbLCDNormal=Normal frmCalcLCD.rbLCDStretched=Stretched frmCalcLCD.lbLCDFontSize=Font size frmCalcLCD.lbLCDPixel2=Pixel frmCalcLCD.Label2=Contrast frmCalcLCD.chkBold=Bold frmCalcLCD.Label3=(0..255) frmCalcLCD.chkPixel=Pixilated frmCalcLCD.lbLCDFont1=Top offset frmCalcLCD.lbLCDPixel3=Pixel frmCalcLCD.chkPixGrau=Grayscale frmCalcLCD.chk8Bit=In 8-bit crushing frmBestellMin.qryGehause=Case frmCalcLCD.lbLCDY=Y Strings.58=Date reached frmMain.spTel1Hint=Dial phone number frmMain.spTel2Hint=Dial phone number frmMain.mnCpBautMit=Copy with store/case frmMain.mnTelKonfig=Configuration frmTelParam=Dial parameter frmTelParam.Label1=COM &port with modem frmTelParam.Label2=AT &init sequence frmTelParam.Label3=&Dial prefix frmTelParam.btnOK=&OK frmTelParam.btnCancel=&Cancel frmMain.spGotoLiefOnlineHint=Goto homepage from deliverer frmMain.lbPPosEPreis=Pr&ice frmMain.lbPPosGPreis=Total Price frmMain.lbPPosSum=Sum frmMain.lbAdrGebDatum=Bi&rthday frmMain.qAdrGebDatum=Birthday frmMain.mnExpBestNr=Export ordering number frmMain.qPPosEPreis=Price frmMain.qPPosGPreis=Total Price frmMain.mnAdrDruck=Print telephone list frmMain.spFilterBauteilHint=Filter on component frmMain.qTypFoto_ID=Foto_ID frmDruckEtikett.grpBarcode=Barcode frmDruckEtikett.lbBarcode=Code frmDruckEtikett.lbFontGr1=Height frmDruckEtikett.lbFontGr2=Width frmDruckEtikett.chkMitCodeText=With bar codes as text frmExpBestNr=Export order numbers frmExpBestNr.Lieferant=Supplier frmExpBestNr.Lieferant1=Separator frmExpBestNr.btnClose=&Close frmMain.lbAdrKundNr1=Lo&gin frmMain.qAdrLogin=Login frmMain.qAdrPasswort=Password Strings.59=There are more identical positions to which no component / stock has been linked.\r\nDo you want to set all the items to this component/stock/case? Strings.60=Select type frmMain.lbCaseBez1=&Type frmMain.spFilterCaseTypHint=Filter type frmMain.mnPPCopyItemVal=Copy Component/Stock/Case frmMain.mnCopySQL=Copy SQL-Script frmMain.spBLCaseHint=Choice case frmMain.spPPBauteilHint=Choice component frmAuswahl=Choice frmAuswahl.btnCancel=&Cancel frmAuswahl.btnOK=&OK frmAuswahl.lbSuche=Seek: frmAuswahl.qryBFID=FID frmAuswahl.qryBBezeichnung=Designation frmAuswahl.qryBBeschreibung=Text frmAuswahl.qryBGehause=Case frmAuswahl.qryBBemerkung=Remark frmAuswahl.qryCFoto_ID=Foto_ID frmAuswahl.qryCBezeichnung=Designation frmAuswahl.qryCTyp=Type frmAuswahl.qryCPins=Pin frmAuswahl.qryCRaster=Raster frmAuswahl.qryCText=Remark frmAuswahl.qryCSMD=SMD frmAuswahl.qryCAendDatum=ChangeDate frmMain.spBestelltFilterSuchHint=Filter on order frmMain.lbSuchSum=Sum: frmMain.spFilterAdrHint=Filter on address Strings.61=The configuration was changed.\r\nTo activate the new configuration you must close and restart EleLa. frmMain.btnKonfig=&Options frmKonfig=Configuration frmKonfig.btnSave=Save frmKonfig.btnClose=Close frmKonfig.tabLanguage=Language frmKonfig.rgrpLanguage= frmKonfig.rgrpLanguageItem0=German electronic store frmKonfig.rgrpLanguageItem1=German warehouse frmKonfig.rgrpLanguageItem2=English electronic store frmKonfig.lbTablefile1=Titel EXE frmKonfig.tabDatbase=Database frmKonfig.lbProtocol=Protocol frmKonfig.lbHost=Host frmKonfig.lbPort=Port frmKonfig.lbDatabase=Database frmKonfig.lbPasswort=Password frmKonfig.lbUser=User frmKonfig.tabDir=Directories frmKonfig.tabTel=Telephone frmKonfig.lbTPort=COM-Port frmKonfig.lbTStart=AT Init frmKonfig.lbTDial=Dial Prefix frmKonfig.tabExtra=Extras frmKonfig.lbTablefile=Table-File frmKonfig.chkTableSaveSort=Save table sortorder frmKonfig.lbStartCopy=Start Copy frmKonfig.lbStartRun=Start Run frmKonfig.tabFile=INI-File frmKonfig.oDB=Open databasefile frmKonfig.oDir=Select directory frmKonfig.btnTestDB=Test connection frmKonfig.tabLinux=Linux frmKonfig.lbLItem=Combo item height frmKonfig.lbLFont=Font size frmMain.qAdrBank=Bank frmMain.qAdrBLZ=BLZ frmMain.qAdrKonto=Account frmMain.qBAdrEPMenge=From quantity frmMain.mnBauteilMove=Move record frmMain.mnBauteilCopy=Copy record frmAuswahl.qryDtree_typ_ID=tree_typ_ID frmAuswahl.qryDFoto_ID=Foto_ID frmAuswahl.qryDBezeichnung=Designation frmAuswahl.qryDBeschreibung=Text frmAuswahl.qryDHandbuch=Handbook frmAuswahl.qryDLibrary=Library frmAuswahl.qryDKennz=Flag frmAuswahl.qryDAendDatum=ChangeDate frmKonfig.lbDirHandbuch=Components frmKonfig.lbDirProjekt=Projects frmMain.lbPPosStatus=Status frmMain.spPPStatusHint=Choice status frmMain.lbPPosSuchIn=(...) frmMain.spGotoBestL1OnlineHint=Goto homepage from deliverer frmMain.spGotoBestL2OnlineHint=Goto homepage from deliverer frmMain.spBestellBauteilHint=Choice component frmMain.spGeburtstagHint=Choice date frmMain.qPPosStatus=Status frmMain.mnPPImportCAD=Import CAD CSV frmMain.mnCpProjMit=Copy with position frmMain.mnPPBuchen=Stock accounting frmMain.mnPPSetLoesch=All: clear status frmMain.mnPPSetOffen=All: set status open frmMain.mnPPSetAktiv=All: set status activ frmMain.mnPPSetFertig=All: set status ready frmMain.mnPPSetPruef=All: set status test frmMain.mnPPSetNV=All: set status not used frmAuswahl.qryEFoto_ID=Foto_ID frmAuswahl.qryEBezeichnung=Designation frmAuswahl.qryEBeschreibung=Text frmAuswahl.qryEKennz=Flag frmAuswahl.qryEMengeFertig=Quantity finished frmAuswahl.qryEMengeOffen=Min Quantity frmAuswahl.qryETermin=Termin frmAuswahl.qryEHandbuch=Handbook frmAuswahl.qryEAendDatum=ChangeDate frmBauteil=inventory list frmBauteil.btnClose=Close frmBauteil.qryBezeichnung=Designation frmBauteil.qryMenge=Quantity frmMain.lbBLiefVPE=Packaging &unit frmMain.lbProjektBauteil=Component frmMain.spProjektBauteilHint=Choice component frmMain.spGotoBauteil2Hint=Goto Component frmMain.lbProjLagCase=Variant frmMain.spGotoBauteilLG2Hint=Goto Store/Case frmMain.spPPosNicht=D frmMain.spPPosNichtHint=defect frmMain.spPPosPruefen=T frmMain.spPPosPruefenHint=test frmMain.spPPosFertig=R frmMain.spPPosFertigHint=ready frmMain.spPPosAktiv=A frmMain.spPPosAktivHint=activ frmMain.spPPosOffen=O frmMain.spPPosOffenHint=open frmMain.spPPosKeinHint= frmMain.lbProjektHistSN=Serial numbe&r frmMain.lbProjektHistGN=Devi&ce number frmMain.lbProjektHistFDatum=Date read&y frmMain.lbProjektHistFVersion=Versi&on ready frmMain.spHist1FilterHint=Filter on current status frmMain.lbProjektHistStatus=Status frmMain.spHist1FilterBFHint=Filter on current B/F frmMain.spHist1BugF=R frmMain.spHist1BugFHint=Feature frmMain.spHist1Bug=B frmMain.spHist1BugHint=Bug frmMain.spHist1BugN=N frmMain.spHist1BugNHint=not used frmMain.lbHistStatus2=B/F frmMain.spHist1Hist=H frmMain.spHist1HistHint=History frmMain.spHist1Offen=O frmMain.spHist1OffenHint=open frmMain.spHist1Aktiv=A frmMain.spHist1AktivHint=activ frmMain.spHist1Fertig=R frmMain.spHist1FertigHint=ready frmMain.spHist1Nicht=N frmMain.spHist1NichtHint=not edit frmMain.spHist1Spaeter=L frmMain.spHist1SpaeterHint=later frmMain.lbBestSumBestellt=Status "ordered" frmMain.lbBestProjekt=Pro&ject frmMain.spGotoProjektBestellHint=Goto project frmMain.spBestOffen=O frmMain.spBestOffenHint=open frmMain.spBestBestellt=O frmMain.spBestBestelltHint=ordered frmMain.spBestGeliefert=D frmMain.spBestGeliefertHint=delivered frmMain.spBestEingelagert=S frmMain.spBestEingelagertHint=stored frmMain.lbHistExFVersion=Versi&on ready frmMain.lbHistExFDatum=Date read&y frmMain.lbHistExGN=Devi&ce number frmMain.lbHistExSN=&Serial number frmMain.spHistFilterHint=Filter on current status frmMain.lbHistStatus=Status frmMain.lbHistStatus1=B/F frmMain.spHistBug=B frmMain.spHistBugHint=Bug frmMain.spHistBugN=N frmMain.spHistBugNHint=not used frmMain.spHistBugF=R frmMain.spHistBugFHint=Feature frmMain.spHistFilterBFHint=Filter on current B/F frmMain.spHistHist=H frmMain.spHistHistHint=History frmMain.spHistOffen=O frmMain.spHistOffenHint=open frmMain.spHistAktiv=A frmMain.spHistAktivHint=activ frmMain.spHistFertig=R frmMain.spHistFertigHint=ready frmMain.spHistNicht=N frmMain.spHistNichtHint=not edit frmMain.spHistSpaeter=L frmMain.spHistSpaeterHint=later frmMain.qBAdrVPEMenge=Packaging unit frmMain.qBestellProjekt_ID=Project frmMain.qProjektBauteil_ID=Component frmMain.qHist1Status=Status frmMain.qHist1FStatus=B/F frmMain.qHist1SNr=Serial number frmMain.qHist1GNr=Device number frmMain.qHist1FDatum=Date ready frmMain.qHist1FVersion=Version ready frmMain.qHistStatus=Status frmMain.qHistFStatus=B/F frmMain.qHistSNr=Serial number frmMain.qHistGNr=Device number frmMain.qHistFDatum=Date ready frmMain.qHistFVersion=Version ready frmMain.spHist1FilterDatumFHint=Filter on date ready frmMain.spHist1FilterVersionFHint=Filter on version ready frmMain.mnHPrintEinzel=Print current record frmMain.btnCalcURIP=U R I P frmKonfig.lbDirVorlage=Template frmKonfig.lbDirTemp=Temp frmCalcURIP=U R I P frmCalcURIP.lbU=&U frmCalcURIP.lbV=V frmCalcURIP.lbCaption=Calculate U R I P frmCalcURIP.lbOhm=Ω frmCalcURIP.lbR=&R frmCalcURIP.lbI=&I frmCalcURIP.lbA=A frmCalcURIP.lbW=W frmCalcURIP.lbP=&P Strings.62=Do you really want to archive all the visible items? frmMain.spBEtikettHint=Printing Label frmMain.spBestellFilterDatumHint=Filter status date frmMain.dbBestArchiv=Archive frmMain.spKEtikettHint=Printing Label frmMain.qBestellSDatum=SDatum frmMain.qBestellArchiv=Archive frmMain.mnOArchivSicht=Archive Visible Strings.63=yes|yes-x|no|"not relevant" Strings.64=yes|no Strings.65=yes|no Strings.66=yes|no Strings.67=New|"2. Choice"|Used|Useless|Defect|"Not available"|Obsolete Strings.68=Cancel Strings.69=Do you really want to cancel the entry? frmMain.spBLBarFormatHint=Barcode frmMain.spBestSpaeter=L frmMain.spBestSpaeterHint=later frmMain.lbTypBarFormat=&Barcode Format frmMain.qTypBarFormat=BarFormat frmMain.qProjektOptA=OptA frmMain.qProjektOptB=OptB frmMain.qProjektOptC=OptC frmMain.qProjektAdr_ID=Address frmMain.qHist1Adr_ID=Address frmMain.qHistAdr_ID=Address frmMain.mnLGBarcGen=Create Barcode frmMain.mnLGBarcTest=Check Barcode frmKonfig.lbBarFormat=Barcode-Format frmMain.tabBBestell=Order frmMain.lbBBestellCaseLag=Store/&Case frmMain.spGotoLager1Hint=Goto Store/Case frmMain.lbBBestBez=D&escription frmMain.spGotoBestellHint=Goto order frmMain.qBBestellBezeichnung=Designation frmMain.qBBestellMenge=Quantity frmMain.qBBestellStatus=Status frmMain.qBBestellSDatum=SDatum frmMain.qBBestellArchiv=Archive frmMain.qBBestellBemerkung=Remark frmMain.qBBestellBauteil_ID=Component frmMain.qBBestellLief1_Adr_ID=Deliv1 Addr frmMain.qBBestellLief1_BestellNr=Deliv1 OrderNo frmMain.qBBestellLief1_EPreis=Deliv1 Price frmMain.qBBestellLief1_GPreis=Deliv1 Total frmMain.qBBestellLief2_Adr_ID=Deliv2 Addr frmMain.qBBestellLief2_BestellNr=Deliv2 OrderNo frmMain.qBBestellLief2_EPreis=Deliv2 Price frmMain.qBBestellLief2_GPreis=Deliv2 Total frmMain.qBBestellProjekt_ID=Project frmMain.qBBestellAendDatum=ChangeDate Strings.70=Sum components: Strings.71=Sum store/case: Strings.72=Quantity Components: Strings.73=Sum (quantity*price): Strings.74=Unit price update Strings.75=Do you really want to update all prices from components-table? frmMain.spHist1Testen=T frmMain.spHist1TestenHint=test frmMain.lbBestSumGeliefert=Status "delivered" frmMain.spBestellFilterProjektHint=Filter projekt frmMain.spCExpHint=Import/Export frmMain.lbCaseHerstellerBez=S&uplier desc. frmMain.Panel57=Import/Export Case frmMain.spMailHint=Send E-Mail frmMain.spHistTesten=T frmMain.spHistTestenHint=test frmMain.grpInfoStatistik=Statistics frmMain.tabExtraMP3=MP3 frmMain.grpFile=File properties frmMain.GroupBox3=File frmMain.spMNewHint=New entry frmMain.spMCopyHint=Copy data frmMain.spMSaveHint=Save data frmMain.spMAbortHint=Abort change frmMain.spMDeleteHint=Delete data frmMain.lbDatum14=Date: frmMain.spMPrintHint=Print frmMain.spMExpHint=Import/Export frmMain.qTypBEPreis=Price frmMain.qTypBHaltbar=Preserved frmMain.qTypBBWare=BWare frmMain.qTypBRoHS=RoHS frmMain.qTypBKennz=Flag frmMain.qTypBGewicht=Weight frmMain.qTypBBarcode=Barcode frmMain.qTypBSMD=SMD frmMain.mnPPEPreis=refresh Price frmMain.mnTblAll=All frmMain.qMP3Foto_ID=Foto_ID frmMain.qMP3FileSize=FileSize frmMain.qMP3IDV2Artist=IDV2Artist frmMain.qMP3IDV2Album=IDV2Album frmMain.qMP3IDV2Titel=IDV2Titel frmMain.qMP3IDV2Year=IDV2Year frmMain.qMP3IDV2Genre=IDV2Genre frmMain.qMP3IDV2Track=IDV2Track frmMain.qMP3IDV2Comment=Remark frmMain.qMP3IDV2Encoder=Encoder frmMain.qMP3IDV2Copyright=IDV2Copyright frmMain.qMP3IDV2Language=IDV2Language frmMain.qMP3IDV2Link=IDV2Link frmMain.qMP3Rating=Rating frmMain.qMP3AendDatum=ChangeDate frmMain.mnMP3ReadVerz=Read directory frmMain.mnMP3IDTagSave=save ID-Tag into MP3 File frmMain.mnCaseImpExport=Import/Export Case frmMain.oDlgDB=Select Database File frmPPosTest.qPrjMax=Max projects frmDruckEtikett.lbAnzahl=Count frmDruckEtikett.rGrpSort=Sorting frmDruckEtikett.rGrpSortItem0=Horizontal frmDruckEtikett.rGrpSortItem1=Vertikal frmDruckEtikett.rGrpSortItem2=Horizontal by number frmDruckEtikett.rGrpSortItem3=Vertikal number frmDruckEtikett.lbHeightAnzahl=Count frmMain.tabBProjekt=Projects frmMain.lbBProjektCaseLag=Store/&Case frmMain.spGotoLager2Hint=Goto Store/Case frmMain.lbBProjektBez=D&escription frmMain.spGotoProjekt1Hint=Goto project frmMain.spAdrBankDet=▼ frmMain.lbAdrBank=&Bank frmMain.lbAdrBLZ=B&LZ frmMain.lbAdrSWIFT=SWIFT frmMain.lbAdrIBAN=IBAN frmMain.lbAdrKonto=Account frmMain.qAdrSWIFT=SWIFT frmMain.qAdrIBAN=IBAN frmMain.qSuchEPMenge=From quantity frmMain.qSuchVPEMenge=Packaging unit frmMain.mnTypCut=Cut Type frmMain.mnTypInsert=Insert Type frmMain.qProjektVariante=Variant frmMain.qBProjektProjekt_ID=Project frmMain.qBProjektBezeichnung=Designation frmMain.qBProjektStatus=Status frmMain.qBProjektBemerkung=Remark frmMain.qBProjektBauteil_ID=Component frmMain.qBProjektSymbol=Symbol frmMain.qBProjektWert=Value frmMain.qBProjektMenge=Quantity frmMain.qBProjektEPreis=Price frmMain.qBProjektGPreis=Total Price frmMain.qBProjektVariante=Variant frmMain.qBProjektPosX=Pos X frmMain.qBProjektPosY=Pos Y frmMain.qBProjektTop=Top frmMain.qBProjektSMD=SMD frmMain.qBProjektKennz=Flag frmMain.qBProjektAendDatum=ChangeDate frmMain.mnBildEinfg=Insert picture frmMain.mnBildEinfZW=from Clipboard frmMain.mnBildEinfDatei=from File frmMain.mnBildEinfgUebZW=overwrite from clipboard frmMain.mnBildEinfgUebDatei=overwrite from file frmMain.mnBildCopy=Copy to clipboard frmMain.mnBildDel=Delete picture frmDruckEtikett.chkGrpFelderItem5=on label only one component frmMain.lbBLagerSumMenge=Sum quantity: frmKonfig.rgrpLanguageItem3=Polish electronic store Strings.76=n. in CSV import frmMain.spFilterProjektHint=Filter projekt frmMain.spFilterPPStatusHint=Filter on current status frmMain.lbBestSumAnz=Count Pos frmMain.lbBestTermin1=&Termin frmMain.lbBestTermin2=D&ate confirmed frmMain.edSchnellsucheCaseExpHint=Quick Search frmMain.spFilterCaseExpHint=Filter case frmMain.chkSchnellsucheCaseExpSMD=SMD frmMain.Panel39=Components from tray frmMain.qBestellTermin1=Termin frmMain.qBestellTermin2=Date ordered frmMain.mnBInventar=inventory list frmMain.qKisteBLID=LID frmMain.qKisteBBezeichnung=Designation frmMain.qKIsteBBeschreibung=Text frmMain.qKisteBLBez=Stock Desc. frmMain.qKisteBMenge=Quantity frmMain.qKisteBCBez=Case frmMain.qKisteBLagerNr=Stock no frmMain.qKisteBBemerkung=Remark frmMain.mnPopPrint=Print frmMain.mnPopRefresh=Update frmDruckEtikett.lbAuswFach=Choice box frmDruckEtikett.spDruckvHint=Printprewiew frmBauteil.spPrintHint=Print frmBauteil.qryBID=BID frmBauteil.qryBBez=Comp. Desc. frmBauteil.qryMengeV=Quantity used frmBauteil.qryMengeMin=Min Quantity frmBauteil.qryEPreis=Price frmBauteil.qryGPreis=Total Price frmBauteil.qryVPreis=VPrice frmBauteil.qryHaltbar=Preserved frmBauteil.qryKiste_ID=Box frmBauteil.qryLagernr=Stock no frmBauteil.qrySMD=SMD frmBauteil.qrySMD_Text=SMD_Text frmBauteil.qryBWare=BWare frmBauteil.qryRoHS=RoHS frmBauteil.qryBemerkung=Remark frmBauteil.qryHandbuch=Handbook frmBauteil.qryAdr_ID=Manufacturer frmBauteil.qryLibrary=Library frmBauteil.qryKennz=Flag frmBauteil.qryGewicht=Weight frmBauteil.qryBarcode=Barcode frmBauteil.qryAendDatum=ChangeDate frmMain.qSuchHStatus=Status frmMain.qSuchHFStatus=B/F frmMain.qSuchHSNr=Serial number frmMain.qSuchHGNr=Device number frmMain.qSuchHFDatum=Date ready frmMain.qSuchHFVersion=Version ready frmMain.qSuchHAdr_ID=Address frmMain.btnInfoVersion=Check version frmVersion=EleLa Downloads frmVersion.btnClose=Cancel frmSchnell.qMem_ID=ID frmSchnell.qMem_Symbol=Symbol frmSchnell.qMem_Bauteil=Component frmSchnell.qMem_Gehäuse=Case frmVersion.memVersion_Bezeichnung=Designation frmVersion.memVersion_Version=Version frmVersion.memVersion_Link=Link frmVersion.memVersion_Status=Status Strings.77=There are items without an order number or quantity available.\r\nDo you want to cancel the order process? Strings.78=There are items without an order number or quantity available. frmMain.lbPPosSumM=Sum frmMain.panAdrBauteile=Components from deliverer frmMain.qBBestellTermin1=Termin1 frmMain.qBBestellTermin2=Termin2 frmMain.qKisteBEPreis=Price frmMain.qKisteBGPreis=Total Price frmMain.qAdrBLID=LID frmMain.qAdrBBezeichnung=Designation frmMain.qAdrBBeschreibung=Text frmMain.qAdrBLBez=Stock Desc. frmMain.qAdrBEPreis=Price frmMain.qAdrBCBez=CDesc. frmMain.qAdrBBemerkung=Remark frmVersion.btnOnline=WWW frmVersion.memVersion_MD5=MD5 Strings.79=yes|no Strings.80=yes|no Strings.81=yes|no frmMain.spProjTerminHint=Choice date frmMain.spHist1FDatumHint=Choice date frmMain.spBestTerm1Hint=Choice date frmMain.spBestTerm2Hint=Choice date frmMain.spTelMobHint=Dial phone number frmMain.lbAdrMail2=E-Mail 2 frmMain.spMail2Hint=Send E-Mail frmMain.lbAdrTel2=Telephone &2 frmMain.chkAdrLief=Supplier frmMain.chkAdrHerst=Manufacturer frmMain.chkAdrPrivat=Privat frmMain.chkAdrGesperrt=Blocked frmMain.tabAdrUeb=Overview frmMain.tabAdrKontakt=Contact frmMain.lbAdrKBez=Designation frmMain.lbAdrKStr=Street frmMain.lbAdrKPlz=PostCode/Loc. frmMain.lbAdrKName=Name frmMain.lbAdrKTel=Telephone frmMain.lbAdrKMobil=Handy frmMain.lbAdrKFax=Fax frmMain.lbAdrKINet=Internet frmMain.lbAdrKMail=E-Mail frmMain.lbAdrKKundNr=Customer nr frmMain.spInternetKHint=Open Web-Browser frmMain.lbAdrKLand=Country frmMain.spTelK1Hint=Dial phone number frmMain.spTelKMobHint=Dial phone number frmMain.lbAdrKGebDatum=Birthday frmMain.spGeburtstagKHint=Choice date frmMain.spMailKHint=Send E-Mail frmMain.lbAdrKMail2=E-Mail 2 frmMain.spMailK2Hint=Send E-Mail frmMain.lbAdrKTel2=Telephone 2 frmMain.spTelK2Hint=Dial phone number frmMain.chkAdrKPrivat=Privat frmMain.chkAdrKGesperrt=Blocked frmMain.spAKNewHint=New entry frmMain.spAKCopyHint=Copy data frmMain.spAKSaveHint=Save data frmMain.spAKAbortHint=Abort change frmMain.spAKDeleteHint=Delete data frmMain.lbDatum15=Date: frmMain.spAKPrintHint=Print frmMain.spHistFDatumHint=Choice date frmMain.lbWissenInfo=&Info frmMain.lbProjektHistStatus1=Status frmMain.spWissenStat0=0 frmMain.spWissenStat0Hint=0 frmMain.spWissenStat1=1 frmMain.spWissenStat1Hint=1 frmMain.spWissenStat2=2 frmMain.spWissenStat2Hint=2 frmMain.spWissenStat3=3 frmMain.spWissenStat3Hint=3 frmMain.spWissenStat4=4 frmMain.spWissenStat4Hint=4 frmMain.spWissenStat5=5 frmMain.spWissenStat5Hint=5 frmMain.spWissenStat6=6 frmMain.spWissenStat6Hint=6 frmMain.spWissenFilterSHint=Filter on current status frmMain.tabExtraTermin=Termin frmMain.lbTerminSuch=&Seek frmMain.spTerminPrintHint=Print frmMain.chkTerminProjekt=&Project frmMain.chkTerminBestellung=&Order frmMain.chkTerminAdresse=&Address frmMain.qAdrTelefon2=Telephone2 frmMain.qAdrEMail2=EMail2 frmMain.qAdrLieferant=Supplier frmMain.qAdrHersteller=Manufacturer frmMain.qAdrPrivat=Privat frmMain.qAdrGesperrt=Blocked frmMain.qGehauseFoto_ID=Foto_ID frmMain.qGehauseBezeichnung=Designation frmMain.qGehauseTyp=Type frmMain.qGehauseNormbez=standard name frmMain.qGehauseHerstellerbez=Manufacturer desc. frmMain.qGehauseLibrary=Library frmMain.qGehausePins=Pin frmMain.qGehauseRaster=Raster frmMain.qGehauseSMD=SMD frmMain.qGehauseBemerkung=Remark frmMain.qGehauseAendDatum=ChangeDate frmMain.qKisteBemerkung=Remark frmMain.qTypBemerkung=Remark frmMain.qBauteilInfo=Info frmMain.qBAdrFoto_ID=Foto_ID frmMain.qSuchBBeschr=Comp. Desc. frmMain.qBestellFoto_ID=Foto_ID frmMain.qGehauseBLID=LID frmMain.qGehauseBBezeichnung=Designation frmMain.qGehauseBBeschreibung=Text frmMain.qGehauseBLBez=Stock Desc. frmMain.qGehauseBMenge=Quantity frmMain.qGehauseBEPreis=Price frmMain.qGehauseBGPreis=Total Price frmMain.qGehauseBBemerkung=Remark frmMain.qPPosFoto_ID=Foto_ID frmMain.qPPosGehause=Case frmMain.qPPosBarcode=Barcode frmMain.qPPosInfo=Info frmMain.qWissenStatus=Status frmMain.qWissenOptA=OptA frmMain.qWissenOptB=OptB frmMain.qWissenOptC=OptC frmMain.qWissenInfo=Info frmMain.mnAdrNPDruck=Print phone list not private frmMain.mnAdrPDruck=Print phone list private frmMain.qBBestellFoto_ID=Foto_ID frmMain.qGehauseExpFoto_ID=Foto_ID frmMain.qGehauseExpBezeichnung=Designation frmMain.qGehauseExpTyp=Type frmMain.qGehauseExpNormbez=standard name frmMain.qGehauseExpHerstellerbez=Manufacturer desc. frmMain.qGehauseExpLibrary=Library frmMain.qGehauseExpPins=Pin frmMain.qGehauseExpRaster=Raster frmMain.qGehauseExpSMD=SMD frmMain.qGehauseExpBemerkung=Remark frmMain.qGehauseExpAendDatum=ChangeDate frmMain.qBProjektFoto_ID=Foto_ID frmMain.qBProjektGehause=Case frmMain.qBProjektBarcode=Barcode frmMain.qBProjektInfo=Info frmMain.qTerminTyp=Type frmMain.qTerminBereich=Range frmMain.qTerminBezeichnung=Designation frmMain.qTerminTermin1=Termin1 frmMain.qTerminTermin2=Termin2 frmMain.qAdrKfoto_ID=Foto_ID frmMain.qAdrKBezeichnung=Designation frmMain.qAdrKFirma=Company frmMain.qAdrKName=Name frmMain.qAdrKStrasse=Street frmMain.qAdrKPLZ=Postal Code frmMain.qAdrKOrt=Location frmMain.qAdrKTelefon=Telephone frmMain.qAdrKTelefon2=Telephone2 frmMain.qAdrKMobil=Handy frmMain.qAdrKFax=Fax frmMain.qAdrKEMail=EMail frmMain.qAdrKEMail2=EMail2 frmMain.qAdrKInternet=Internet frmMain.qAdrKUsSTID=VAT-ID frmMain.qAdrKKundNr=CustomerID frmMain.qAdrKLogin=Login frmMain.qAdrKPasswort=Password frmMain.qAdrKBemerkung=Remark frmMain.qAdrKLand=Country frmMain.qAdrKGebDatum=Birthday frmMain.qAdrKLieferant=Supplier frmMain.qAdrKHersteller=Manufacturer frmMain.qAdrKPrivat=Privat frmMain.qAdrKGesperrt=Blocked frmMain.qAdrKBank=Bank frmMain.qAdrKBLZ=BLZ frmMain.qAdrKKonto=Account frmMain.qAdrKSWIFT=SWIFT frmMain.qAdrKIBAN=IBAN frmMain.qAdrKAendDatum=ChangeDate frmAuswahl.qryFFoto_ID=Foto_ID frmAuswahl.qryFBezeichnung=Designation frmAuswahl.qryFFirma=Company frmAuswahl.qryFName=Name frmKonfig.btnErzeugeDB=Create new database frmBauteil.qryGehause_ID=Case frmMain.=Extern frmMain.lbBauteilInfo=Info frmMain.spHandbuch8ExecHint=Open manual frmMain.spHandbuch8Hint=Choice Manual (File) frmMain.lbPPosHandbuch=Ha&ndbook frmMain.spHandbuch9ExecHint=Open manual frmMain.spHandbuch9Hint=Choice Manual (File) frmMain.lbBestellHandbuch=&Handbook frmMain.lbBestellInfo=I&nfo frmMain.lbCaseLibrary=&Library frmMain.lbCaseNormbez=&Norm desc. frmMain.lbCaseHandbuch=&Handbook frmMain.spHandbuch6ExecHint=Open manual frmMain.spHandbuch6Hint=Choice Manual (File) frmMain.spHandbuch7ExecHint=Open manual frmMain.spHandbuch7Hint=Choice Manual (File) frmMain.lbKisteHandbuch=&Handbook frmMain.spHandbuch10ExecHint=Open manual frmMain.spHandbuch10Hint=Choice Manual (File) frmMain.lbAdrHandbuch=Handbook frmMain.spHandbuch11ExecHint=Open manual frmMain.spHandbuch11Hint=Choice Manual (File) frmMain.lbAdrKHandbuch=Handbook frmMain.qAdrHandbuch=Handbook frmMain.qAdrInfo=Info frmMain.qGehauseHandbuch=Handbook frmMain.qGehauseInfo=Info frmMain.qKisteHandbuch=Handbook frmMain.qSuchBInfo=CInfo frmMain.qFotoBildDatei=PicFile frmMain.qBestellHandbuch=Handbook frmMain.qBestellInfo=Info frmMain.qPPosHandbuch=Handbook frmMain.qBBestellHandbuch=Handbook frmMain.qBBestellInfo=Info frmMain.qGehauseExpHandbuch=Handbook frmMain.qGehauseExpInfo=Info frmMain.qBProjektHandbuch=Handbook frmMain.qAdrKHandbuch=Handbook frmMain.qAdrKInfo=Info Strings.82=Contact from: Strings.83=Start / end code for data not found! Strings.84=Component|"Working time"|"Small material" Strings.85=Please select type of component! frmMain.spHaltbarBisHint=Choice date frmMain.spProjektDet=▼ frmMain.lbProjektWartungNext=Next servicing frmMain.spProjWartungHint=Choice date frmMain.lbProjektWartungInv=Interval frmMain.spProjIntervallHint=Stock accounting frmMain.lbProjektAdr=Address frmMain.spGotoAdrPHint=Goto Address frmMain.lbPPosPosR=Rotation frmMain.lbPPosSNr=Serial number frmMain.lbProjektHistPPos=Position frmMain.spHist1Det=▼ frmMain.spH1GotoPPosHint=Goto project pos frmMain.lbProjektHistFehlerreport=Error report custo&mer frmMain.lbProjektHistRepReport=Repair Report frmMain.lbProjektHistRMA=RMA frmMain.spGetRMACodeHint=Generate RMA Code frmMain.spGetErrorCodeHint=Generate RMA Code frmMain.lbProjektHistFehlercode=Error code frmMain.lbProjektHistVorgehen=Proceedin&g frmMain.lbProjektHistKostenv=Quotation frmMain.spH1GotoKostHint=Goto quotation frmMain.tabPKost=Quotation frmMain.tabPKUeb=Overview frmMain.lbPKostAdrKont=&Address/Contact frmMain.lbPKostBez=D&escription frmMain.lbPKostLief=De&livery frmMain.lbPKostAngebot=&Offer frmMain.spGotoAdrPKHint=Goto Address frmMain.lbPKostStatus=Status frmMain.spPKSAngebot=A frmMain.spPKSAngebotHint=Offer frmMain.spPKSAngebotG=OS frmMain.spPKSAngebotGHint=Offer sended frmMain.spPKSBestellt=B frmMain.spPKSBestelltHint=ordered frmMain.spPKSFertig=R frmMain.spPKSFertigHint=ready frmMain.spPKSGeliefert=D frmMain.spPKSGeliefertHint=delivered frmMain.spPKSStorno=L frmMain.spPKSStornoHint=canceled frmMain.spPKFilterHint=Filter on current status frmMain.lbPKostAuftrag=&Commission no frmMain.spPKAngebotHint=Choice date frmMain.lbPKostGueltig=&Valid to frmMain.spPKGueltigHint=Choice date frmMain.spPKLiefHint=Choice date frmMain.lbPKostAbnahme=Acce&ptance frmMain.spPKAbnahmeHint=Choice date frmMain.lbPKostBestNr=Order-&Nr. frmMain.lbPKostGPreis=Total Price frmMain.lbPKostInfo=&Info frmMain.spGetKVCodeHint=Generate RMA Code frmMain.spPKNewHint=New entry frmMain.spPKCopyHint=Copy data frmMain.spPKSaveHint=Save data frmMain.spPKAbortHint=Abort change frmMain.spPKDeleteHint=Delete data frmMain.lbDatum17=Date: frmMain.spPKPrintHint=Print frmMain.spPKExpHint=Import/Export frmMain.tabPKPos=Position frmMain.lbPKostPBez=D&escription frmMain.lbPKostPLieferung=De&livery frmMain.lbPKostPStatus=Status frmMain.spPKPOffen=O frmMain.spPKPOffenHint=open frmMain.spPKPAktiv=A frmMain.spPKPAktivHint=activ frmMain.spPKPTest=T frmMain.spPKPTestHint=test frmMain.spPKPFertig=R frmMain.spPKPFertigHint=ready frmMain.spPKPNichtB=N frmMain.spPKPNichtBHint=not edit frmMain.spPKPStorno=L frmMain.spPKPStornoHint=canceled frmMain.spPKPFilterHint=Filter on current status frmMain.lbPKostPTermin=Te&rmin frmMain.spPKPTerminHint=Choice date frmMain.spPKPLiefHint=Choice date frmMain.lbPKostPArtikelNr=&Item no frmMain.lbPKostPVPreis=&VPrice frmMain.lbPKostPMenge=Qua&ntity frmMain.lbPKostPBauteil=&Component frmMain.lbPKostPLagCase=&Store/Case frmMain.spGotoBauteilLG3Hint=Goto Store/Case frmMain.spGotoBauteil3Hint=Goto Component frmMain.spPKPBauteilHint=Choice component frmMain.lbPKostPVSum=Total position frmMain.lbPKostPPPos=&Position frmMain.spPKPVPreisHint=Update price from component frmMain.lbPKostPInfo=In&fo frmMain.spPKPGotoProjPosHint=Goto project pos frmMain.spPKPNewHint=New entry frmMain.spPKPCopyHint=Copy data frmMain.spPKPSaveHint=Save data frmMain.spPKPAbortHint=Abort change frmMain.spPKPDeleteHint=Delete data frmMain.lbDatum18=Date: frmMain.spPKPPrintHint=Print frmMain.spPKPExpHint=Import/Export frmMain.tabPBestell=Order frmMain.lbPBestellBauteil=&Component frmMain.spGotoLager3Hint=Goto Store/Case frmMain.lbPBestBez=D&escription frmMain.spGotoBestell1Hint=Goto order frmMain.chkPBestellArchiv=With archived frmMain.spBestTeil=T frmMain.spBestTeilHint=partial delivery frmMain.lbBestAuftrag=&Commission no frmMain.spBestellFilterAuftragHint=Filter on current commission frmMain.spBestAuftragFctHint=commission function frmMain.spBestellCalcHint=Calculator quantity frmMain.spBestellResetStaffelHint=Update price from supplier frmMain.lbBestSumMenge=Count quantity frmMain.lbBestSumMengeVPE=Count quantity PU frmMain.btnBestellLiefBuch=Book as delivered frmMain.lbBestMengeLief=Q&uantity store (unit) frmMain.lbBestMengeLiefSum=Sum quantity deliver (unit) frmMain.spBestellDet=▲ frmMain.lbBestMengeLagSum=Sum quantity store (unit) frmMain.lbBestL1EP1=Quantity (Unit) frmMain.chkBestellLief1=Deliverer 1 frmMain.spGotoBauteilA1Hint=Goto Component-Deliverer frmMain.spBestellFilterLief1Hint=Filter supplier frmMain.spBestellLief1SetStaffelHint=Copy order nr/price into component > deliverer frmMain.chkBestellLief2=Deliverer 2 frmMain.spBestellLief2SetStaffelHint=Copy order nr/price into component > deliverer frmMain.spBestellFilterLief2Hint=Filter supplier frmMain.spGotoBauteilA2Hint=Goto Component-Deliverer frmMain.chkAdrProjekt=Project/History frmMain.qAdrProjekt=Project frmMain.qBestellAuftrag=commission frmMain.qBestellUseLief12=Supplier frmMain.qBestellLief_MengeVPE=Deliv. Qualtity Unit frmMain.qBestellLief_MengeVPESum=Deliv. Qualtity Unit Sum frmMain.qBestellLager_MengeVPESum=Storage Unit total amount frmMain.qBestellLief1_BauteilAdr_ID=Deliv1 supplier frmMain.qBestellLief1_MengeVPE=Deliv1 Qualtity Unit frmMain.qBestellLief2_BauteilAdr_ID=Deliv2 supplier frmMain.qBestellLief2_MengeVPE=Deliv2 Qualtity Unit frmMain.mnBBarcodeTest=Find double barcode frmMain.qProjektWartung=Service frmMain.qProjektSNr=SNr frmMain.qProjektVPreis=VPrice frmMain.qProjektArtikelNr=Store item no frmMain.qPPosArtikelNr=Item no frmMain.qPPosArt=Category frmMain.qPPosPosZ=Pos Z frmMain.qPPosPosR=Pos R frmMain.qPPosGBez=StoreCase frmMain.qPPosSNr=SNr frmMain.qHist1ProjektPos_ID=ProjectPos frmMain.qHist1Kosten_ID=Quotation frmMain.qHist1Vorgehen=Proceeding frmMain.qHist1KundeBes=Error report customer frmMain.qHist1RepNr=RMA frmMain.qHist1RepFehler=Error code frmMain.qHist1RepBes=Repair Report frmMain.qHistProjektPos_ID=ProjectPos frmMain.qHistKosten_ID=Quotation frmMain.qHistVorgehen=Proceeding frmMain.qHistKundeBes=Error report customer frmMain.qHistRepNr=RMA frmMain.qHistRepFehler=Error code frmMain.qHistRepBes=Repair Report frmMain.qBBestellAuftrag=commission frmMain.qBBestellUseLief12=Supplier frmMain.qBBestellLief_MengeVPE=Deliv. Qualtity Unit frmMain.qBBestellLief_MengeVPESum=Deliv. Qualtity Unit Sum frmMain.qBBestellLager_MengeVPESum=Storage Unit total amount frmMain.qBBestellLief1_BauteilAdr_ID=Deliv1 supplier frmMain.qBBestellLief1_MengeVPE=Deliv1 Qualtity Unit frmMain.qBBestellLief2_BauteilAdr_ID=Deliv2 supplier frmMain.qBBestellLief2_MengeVPE=Deliv2 Qualtity Unit frmMain.qBProjektArtikelNr=Item no frmMain.qBProjektArt=Category frmMain.qBProjektPosZ=Pos Z frmMain.qBProjektPosR=Pos R frmMain.mnPopBestellen=Order component frmMain.qAdrKProjekt=Project frmMain.qPBestellFoto_ID=Foto_ID frmMain.qPBestellBezeichnung=Designation frmMain.qPBestellMenge=Quantity frmMain.qPBestellAuftrag=commission frmMain.qPBestellStatus=Status frmMain.qPBestellSDatum=SDatum frmMain.qPBestellTermin1=Termin frmMain.qPBestellTermin2=Date ordered frmMain.qPBestellArchiv=Archive frmMain.qPBestellBemerkung=Remark frmMain.qPBestellBauteil_ID=Component frmMain.qPBestellHandbuch=Handbook frmMain.qPBestellInfo=Info frmMain.qPBestellUseLief12=Supplier frmMain.qPBestellLief_MengeVPE=Deliv. Qualtity Unit frmMain.qPBestellLief_MengeVPESum=Deliv. Qualtity Unit Sum frmMain.qPBestellLager_MengeVPESum=Storage Unit total amount frmMain.qPBestellLief1_Adr_ID=Deliv1 Addr frmMain.qPBestellLief1_BauteilAdr_ID=Deliv1 supplier frmMain.qPBestellLief1_BestellNr=Deliv1 OrderNo frmMain.qPBestellLief1_MengeVPE=Deliv1 Qualtity Unit frmMain.qPBestellLief1_EPreis=Deliv1 Price frmMain.qPBestellLief1_GPreis=Deliv1 Total frmMain.qPBestellLief2_Adr_ID=Deliv2 Addr frmMain.qPBestellLief2_BauteilAdr_ID=Deliv2 supplier frmMain.qPBestellLief2_BestellNr=Deliv2 OrderNo frmMain.qPBestellLief2_MengeVPE=Deliv2 Qualtity Unit frmMain.qPBestellLief2_EPreis=Deliv2 Price frmMain.qPBestellLief2_GPreis=Deliv2 Total frmMain.qPBestellProjekt_ID=Project frmMain.qPBestellAendDatum=ChangeDate frmMain.mnOAuftGlob=Global changes commission frmMain.mnOAuftAutoNum=Next commission number frmMain.mnBTypAend=Alter type frmMain.qPKostProjekt_ID=Project frmMain.qPKostAdr_ID=Address frmMain.qPKostAdrK_ID=Contact frmMain.qPKostFoto_ID=Foto_ID frmMain.qPKostBezeichnung=Designation frmMain.qPKostBeschreibung=Text frmMain.qPKostStatus=Status frmMain.qPKostGPreis=Total Price frmMain.qPKostAuftrag=commission no frmMain.qPKostBestellnr=Order-Nr. frmMain.qPKostDAngebot=Offer frmMain.qPKostDGueltig=Valid to frmMain.qPKostDLief=Delivery frmMain.qPKostDAbnahme=Acceptance frmMain.qPKostInfo=Info frmMain.qPKostAendDatum=ChangeDate frmMain.qPKostPosProjekt_ID=Project_ID frmMain.qPKostPosKosten_ID=Kosten_ID frmMain.qPKostPosProjektPos_ID=ProjectPos frmMain.qPKostPosBauteil_ID=Component frmMain.qPKostPosFoto_ID=Foto_ID frmMain.qPKostPosNr=No frmMain.qPKostPosBezeichnung=Designation frmMain.qPKostPosBeschreibung=Text frmMain.qPKostPosStatus=Status frmMain.qPKostPosMenge=Quantity frmMain.qPKostPosVPreis=VPrice frmMain.qPKostPosVPSum=VPSum frmMain.qPKostPosBarcode=Barcode frmMain.qPKostPosArtikelNr=Item no frmMain.qPKostPosTermin=Termin frmMain.qPKostPosDLief=DDeliver frmMain.qPKostPosInfo=Info frmMain.qPKostPosArt=Category frmMain.qPKostPosAendDatum=ChangeDate frmMain.mnHistRMA=Next RMA number frmMain.mnKVAuftrag=Next commission number frmPPosTest.lbAuftNr=commission no for order frmStatus.rGrpItem5=later frmStatus.chkAuftrag=Change Order frmStatus.chkArchiv=Archive frmStatus.chkAendArchiv=Archive frmExpBestNr.btnErzeuge=v v v v v frmExpBestNr.Lieferant2=Order-Nr frmExpBestNr.chkInfo2=With information project / order nr frmExpBestNr.chkAnfz=Text in "..." frmExpBestNr.chkInfo1=With information from Info line frmExpBestNr.btnCopy=Copy to clipboard frmAuswahl.qryBArtikelNr=Item no frmAuswahl.qryFSort=Sort frmKonfig.chkVersionCheck=Automatic test for new version frmKonfig.lbLogInDatei=Log in file frmKonfig.tabGlobal=Global Param frmKonfig.lbBestellFormat=Order commission format frmKonfig.lbISO9001=ISO9001 compliant frmKonfig.lbDateFormat=Date format frmKonfig.lbHistRMAFormat=History RMA Format frmKonfig.lbKVAuftragFormat=Quotation commission format frmBauteil.qryArtikelNr=Item no frmBauteil.qryArt=Category frmBauteil.qryInfo=Info frmBestellAenderung=commission global changes frmBestellAenderung.chkAendStatus=Status frmBestellAenderung.spBestSpaeter=L frmBestellAenderung.spBestSpaeterHint=later frmBestellAenderung.spBestEingelagert=S frmBestellAenderung.spBestEingelagertHint=stored frmBestellAenderung.spBestGeliefert=D frmBestellAenderung.spBestGeliefertHint=delivered frmBestellAenderung.spBestTeil=T frmBestellAenderung.spBestTeilHint=partial delivery frmBestellAenderung.spBestBestellt=B frmBestellAenderung.spBestBestelltHint=ordered frmBestellAenderung.spBestOffen=O frmBestellAenderung.spBestOffenHint=open frmBestellAenderung.chkAendArchiv=Archive frmBestellAenderung.chkArchiv=Archive frmBestellAenderung.chkAendAuftrag=commission no frmBestellAenderung.Label1=Make global changes for all filteres (visible)\r\nprositions from selected commission frmBestellAenderung.btnOK=&OK frmBestellAenderung.btnCancel=&Cancel frmBestellAenderung.chkAlleSichtbare=Alter all visible positions,\r\nnot only from selected commission frmBestellDruck=Print order frmBestellDruck.btnOK=&OK frmBestellDruck.btnCancel=&Cancel frmBestellDruck.lbFormular=Formular: frmBestellDruck.Lieferant=Supplier frmBestellDruck.Lieferant2=Order-Nr frmBestellDruck.chkSetTermin=Set termin frmBestellDruck.chkSetStatusB=Set status to "ordered" Strings.86="Single error"|"Customer Error"|"build error"|"soldering defects"|"Software Update"|"Firmware Update"|"Update document" Strings.87=Warranty|Goodwill|Paid Strings.88=For new contact write "EleLa" in the message an I accept the new conversation. Strings.89=File not found: Strings.90=Paper too small, cannot print the label. frmMain.spPPosDet=▲ frmMain.lbProjektHistAbrechnung=Invoice frmMain.lbHist1AdrKont=Addre&ss/Contact frmMain.spGotoAdrH1Hint=Goto Address frmMain.lbProjektHistPPos1=Position frmMain.spHGotoPPosHint=Goto project pos frmMain.spHistDet=▼ frmMain.lbHistExFehlerreport=Error report c&ustomer frmMain.lbHistExtRepReport=Repair Report frmMain.lbHistExRMA=R&MA frmMain.spGetRMACode1Hint=Generate RMA Code frmMain.spGetErrorCode1Hint=Generate RMA Code frmMain.lbHistExFehlercode=Error code frmMain.lbHistExVorgehen=Proceeding frmMain.lbHistExKostenv=&Quotation frmMain.spHGotoKostHint=Goto quotation frmMain.lbHistExAbrechnung=&Invoice frmMain.lbHistAdrKont=&Address/Contact frmMain.spGotoAdrHHint=Goto Address frmMain.qFotoPosX0=PosX0 frmMain.qFotoPosY0=PosY0 frmMain.qFotoPosXFak=PosXFak frmMain.qFotoPosYFak=PosYFak frmMain.qFotoPosTop=PosTop frmMain.qHist1Abrechnung=invoice frmMain.qHist1AdrK_ID=Contact frmMain.qHistAbrechnung=invoice frmMain.qHistAdrK_ID=Contact frmMain.qPKostPosLArtikelNr=Store item no frmMain.qPKostPosLBarcode=Store barcode frmMain.qPKostPosLArt=Store Art frmMain.mnPKPVPreis=refresh Price frmMain.mnPKPNr=Number reassigned frmMain.mnPIntvEinstell=Select interval frmMain.mnPIntvWart=Service done frmBild.lbTop=Layer: frmBild.lbX=X Pos: frmBild.lbMas1=Measure frmBild.lbXFak=Measure/Pixel: frmBild.lbY=Y Pos: frmBild.lbMas2=Measure frmBild.lbYFak=Measure/Pixel: frmBild.btnSave=Save frmBild.mnCopyClp=Copy pricture into clipboard frmBild.mnPos=Scale picture frmIntervall=Interval frmIntervall.btnOK=&OK frmIntervall.btnAbbruch=&Cancel frmIntervall.rbTag=Days frmIntervall.rbWoche=Weeks frmIntervall.rbMonat=Month frmIntervall.rbJahr=Year frmMain.lbBLiefStueck=D&enomination frmMain.lbProjektArtikelNr=Item no frmMain.lbProjektArtikelNr2=Item no 2 frmMain.lbProjektAuftrag=commission no frmMain.spProjAuftragFctHint=commission function frmMain.lbProjektHistGPreis1=Total Price frmMain.spFilterAdrChkHint=Filter on checkbox frmMain.lbProjektHistGPreis=Total Price frmMain.qBAdrDivMenge=denomination frmMain.qBAdrArtikelNr=Store item no frmMain.qBAdrArtikelNr2=Store item no2 frmMain.qBestellArtikelNr=Store item no frmMain.qBestellArtikelNr2=Store item no2 frmMain.qProjektAuftrag=commission frmMain.qProjektArtikelNr2=Store item no 2 frmMain.qPPosLMenge=Stocks frmMain.qPPosDruck=Print frmMain.qHist1GPreis=Total Price frmMain.qHistGPreis=Total Price frmMain.mnDruckAlle=All print frmMain.mnDruckKein=All not print frmMain.qPKostPosLArtikelNr2=Store item no 2 frmMain.mnProjAuftrag=Next commission number frmMain.mnCpBestell=Order again frmStatus.chkAuftragF=Filter on current commission frmKonfig.lbBarFormat1=Project commission format frmIntervall.btnDelete=&Delete frmMemoEdit=Memo-Edit frmMemoEdit.btnOK=OK frmMemoEdit.btnCancel=Cancel frmMain.spBLLEDHint=Send Box to COM Port frmMain.lbCaseInfo=&Info Strings.91=Reason for stock movement Strings.92=Please enter the reason for the stock movement: frmMain.tabBBeweg=Stock movement frmMain.lbBBewegCaseLag=Store/&Case frmMain.spGotoProjekt2Hint=Goto project frmMain.spGotoLager4Hint=Goto Store/Case frmMain.spGotoBestell2Hint=Goto order frmMain.qBBewBauteil_ID=Component frmMain.qBBewUserName=UserName frmMain.qBBewComputerName=ComputerName frmMain.qBBewGrund=Reason frmMain.qBBewPMMenge=P/M Quantity frmMain.qBBewMenge=Quantity frmMain.qBBewDatum=Date frmMain.qBBewBestellen_ID=Order frmMain.qBBewProjekt_ID=Project frmMain.qBBewProjektPos_ID=projekt frmMain.qBBewAendDatum=ChangeDate frmMain.mnBLagbew=Last stock movement frmBauteil.qryLBewBBez=Component frmBauteil.qryLBewLBez=Stock/case frmBauteil.qryLBewGBez=Case frmBauteil.qryLBewKBez=Box frmBauteil.qryLBewLagerNr=Stock no frmBauteil.qryLBewBestellen_ID=bestellen frmBauteil.qryLBewProjekt_ID=Project frmBauteil.qryLBewUserName=UserName frmBauteil.qryLBewComputerName=ComputerName frmBauteil.qryLBewGrund=Reason frmBauteil.qryLBewPMMenge=P/M Quantity frmBauteil.qryLBewMenge=Quantity frmBauteil.qryLBewDatum=Date frmBauteil.qryLBewAendDatum=ChangeDate frmBauteil.qryLBewArtikelNr=Item no frmBauteil.qryLBewArtikelNr2=Item no 2 frmBauteil.qryLBewBarcode=Barcode frmBauteil.qryLBewBauteil_ID=Component_ID frmMain.btnBestellBauteil2Hint=Take part in order proposal frmMain.btnBestellBauteil3Hint=Take part in order proposal frmMain.btnBestellBauteil1Hint=Take part in order proposal frmMain.btnBestellBauteil4Hint=Take part in order proposal frmMain.btnBestellBauteil5Hint=Take part in order proposal frmMain.spFilterWissenThemaHint=Filter variant frmMain.spFilterWissenHint=Filter on component frmMain.edSchnellsucheWissenHint=Quick Search frmBestellMin.btnBestellHint=Take part in order proposal frmPPosTest.btnBestellBauteilHint=Take part in order proposal frmPPosTest.btnBestellBauteilAll=All missing frmPPosTest.btnBestellBauteilAllHint=All open parts in order to take the proposal frmPPosTest.btnBestellBauteilAllPos=All positions frmPPosTest.btnBestellBauteilAllPosHint=All components in order proposal with the\r\n amount required to take frmMain.spBInfoEtikett1Hint=Printing Label frmMain.spBInfoEtikettHint=Printing Label frmMain.spHExp1Hint=Import/Export frmMain.spPKInfoEtikettHint=Printing Label frmMain.spPKPInfoEtikettHint=Printing Label frmMain.spOInfoEtikettHint=Printing Label frmMain.spCInfoEtikettHint=Printing Label frmMain.lbKisteInfo=&Info frmMain.spKInfoEtikettHint=Printing Label frmMain.lbAdrInfo=Info frmMain.spAInfoEtikettHint=Printing Label frmMain.spHExpHint=Import/Export frmMain.spWInfoEtikettHint=Printing Label frmMain.qKisteInfo=Info frmMain.qProjektInfo=Info frmMain.mnPPInfoEtikett=Printing Label "Info" frmMain.mnPInfoEtikett=Printing Label "Info" frmMain.qHist1Info=Info frmMain.qHistInfo=Info frmMain.mnHInfoEtikett=Printing Label "Info" frmPPosTest.spBestAuftragFctHint=Next commission number frmPPosTest.mnOAuftAutoNum=Next commission number frmMain.lbBestSumAll=Status frmMain.qAdrRabatt=Discount frmMain.qBAdrRabatt=Discount frmMain.qSuchArtikelNr=Item no frmMain.qSuchArtikelNr2=Item no 2 frmMain.qPPosRabatt=Discount frmMain.qPKostRabatt=Discount frmMain.qPKostPosRabatt=Discount frmMain.qBestellLief1_Rabatt=Deliv1 Discount frmMain.qBestellLief2_Rabatt=Deliv2 Discount frmMain.spBestelltArchivHint=Archive View frmKisteTausch.qInhaltArtikelNr=Item no frmKisteTausch.qInhaltArtikelNr2=Item no 2 frmKisteTausch.qBauteilArtikelNr=Item no frmKisteTausch.qBauteilArtikelNr2=Item no 2 Strings.93=yes|no Strings.94=yes|no Strings.95=yes|no frmMain.qBestellLagerMenge=Stocks frmMain.qBestellKennz=Flag frmMain.qBestellPrio=Priority frmMain.qBestellOptA=OptA frmMain.qBestellOptB=OptB frmMain.qBestellOptC=OptC frmKonfig.lbDirBilder=Pictures Strings.96=Day Strings.97=Days Strings.98=Month Strings.99=Months Strings.100=Create components Strings.101=Want you really create this new components? frmMain.panAdrBestellung=Order frmMain.lbWissenBez1=Remark frmMain.mnBGen=Create components frmMain.qWissenBemerkung=Remark frmMain.mnAdrAnsBaut=Show components from deliverer/manufactur frmMain.mnAdrAnsBest=Show orders frmMain.mnCpPKostMit=Copy with all positions frmMain.qAdrB1Foto_ID=Foto_ID frmMain.qAdrB1Bezeichnung=Designation frmMain.qAdrB1Menge=Quantity frmMain.qAdrB1Auftrag=commission frmMain.qAdrB1Status=Status frmMain.qAdrB1SDatum=SDatum frmMain.qAdrB1Termin1=Termin frmMain.qAdrB1Termin2=Date ordered frmMain.qAdrB1Archiv=Archive frmMain.qAdrB1Bemerkung=Remark frmMain.qAdrB1Bauteil_ID=Component frmMain.qAdrB1Handbuch=Handbook frmMain.qAdrB1Info=Info frmMain.qAdrB1UseLief12=Supplier frmMain.qAdrB1Lief_MengeVPE=Deliv. Qualtity Unit frmMain.qAdrB1Lief_MengeVPESum=Deliv. Qualtity Unit Sum frmMain.qAdrB1Lager_MengeVPESum=Storage Unit total amount frmMain.qAdrB1Lief1_Adr_ID=Deliv1 Addr frmMain.qAdrB1Lief1_BauteilAdr_ID=Deliv1 supplier frmMain.qAdrB1Lief1_BestellNr=Deliv1 OrderNo frmMain.qAdrB1Lief1_MengeVPE=Deliv1 Qualtity Unit frmMain.qAdrB1Lief1_EPreis=Deliv1 Price frmMain.qAdrB1Lief1_Rabatt=Deliv1 Discount frmMain.qAdrB1Lief1_GPreis=Deliv1 Total frmMain.qAdrB1Lief2_Adr_ID=Deliv2 Addr frmMain.qAdrB1Lief2_BauteilAdr_ID=Deliv2 supplier frmMain.qAdrB1Lief2_BestellNr=Deliv2 OrderNo frmMain.qAdrB1Lief2_MengeVPE=Deliv2 Qualtity Unit frmMain.qAdrB1Lief2_EPreis=Deliv2 Price frmMain.qAdrB1Lief2_Rabatt=Deliv2 Discount frmMain.qAdrB1Lief2_GPreis=Deliv2 Total frmMain.qAdrB1Projekt_ID=Project frmMain.qAdrB1Kennz=Flag frmMain.qAdrB1Prio=Priority frmMain.qAdrB1OptA=OptA frmMain.qAdrB1OptB=OptB frmMain.qAdrB1OptC=OptC frmMain.qAdrB1AendDatum=ChangeDate frmBauteilErzeuge=Generate components frmBauteilErzeuge.lbReihe=&Preferred number frmBauteilErzeuge.lbFaktor=&Factor frmBauteilErzeuge.lbEinheit=&Unit frmBauteilErzeuge.lbPrefix=P&refix frmBauteilErzeuge.lbCase=C&ase frmBauteilErzeuge.lbPrefix1=&Type frmBauteilErzeuge.spBauteilTypHint=Choice type frmBauteilErzeuge.btnAnlegen=Create frmBauteilErzeuge.btnCancel=&Close Strings.102=Delete picture Strings.103=Want you really delete this picture? frmBauteil.qryArtikelNr2=Item no 2 frmBauteil.qryInv_Menge=Inv_Quantity frmBauteil.qryInv_Wert=Inv_Value frmBauteil.qryInv_Datum=Inv_Date frmBauteil.qryInv_Name=Inv_Name frmMain.qTypBArtikelNr=Item no frmMain.qTypBArtikelNr2=Item no 2 frmMain.mnPopSQLCopy=Copy SQL command into clipboard frmPPosTest.btnAll=All frmPPosTest.Label1=Select the projects for testing frmPPosTest.btnKein=None frmPPosTest.qBarcode=Barcode frmPPosTest.qArtikelNr=Item no frmPPosTest.qArtikelNr2=Item no 2 frmPPosTest.qnBID=BID frmPPosTest.qnLID=LID frmPPosTest.qnLagerMenge=Stocks frmPPosTest.qnMengePos=Amount of position frmPPosTest.qnLagerRest=Store rest frmPPosTest.qnBezeichnung=Component description frmPPosTest.qnLBez=Component Bearing Code frmPPosTest.qnCBez=Case frmPPosTest.qnBarcode=Barcode frmPPosTest.qnArtikelNr=Item no frmPPosTest.qnArtikelNr2=Item no 2 frmAuswahl.qryBBarcode=Barcode frmAuswahl.qryBArtikelNr2=Item no 2 Strings.104=Playlist Strings.105=.mp3.wmv.m4a Strings.106=.avi.mpg frmMain.lbMP3Size=Size frmMain.lbMP3FileName=Name frmMain.spHandbuch12Hint=Choice Manual (File) frmMain.rbMP3Musik=Musik frmMain.rbMP3Video=Video frmMain.spMP3FilterTypHint=Filter type frmMain.grpMP3ID=Titel description frmMain.lbMP3Jahr=Year frmMain.lbMP3Titel=Title frmMain.lbMP3Album=Album frmMain.lbMP3Artist=Artist frmMain.lbMP3Track=Track frmMain.lbMP3Genre=Genre frmMain.lbMP3Comment=Remark frmMain.spMP3FilterArtistHint=Filter artist frmMain.spMP3FilterAlbumHint=Filter album frmMain.spMP3FilterGenreHint=Filter genre frmMain.lbMP3Comment1=Info frmMain.spMP3InfoEtikettHint=Printing Label frmMain.Panel29=Comment / Lyrics frmMain.lbMP3Duration=Timelength frmMain.lbMP3Bitrate=Bitrate frmMain.lbMP3Version=Version frmMain.btnMP3RatingM=- frmMain.btnMP3RatingMHint=Rating Minus frmMain.lbMp3Rating=Rating frmMain.btnMP3RatingP=+ frmMain.btnMP3RatingPHint=Rating Plus frmMain.tbMP3LautHint=Volume frmMain.tbMP3ZeitHint=Time frmMain.spFilterMP3Hint=Filter on component frmMain.edSchnellsucheMP3Hint=Quick Search frmMain.chkMP3AendInFile=Save changes automatically into MP3 file frmMain.qMP3FileTyp=Type frmMain.qMP3FileVersion=Version frmMain.qMP3FileBitrate=Bitrate frmMain.qMP3FileDuration=Timelength frmMain.qMP3Bemerkung=Remark frmMain.qMP3Handbuch=Handbook frmMain.qMP3Info=Info frmMain.qMP3Lagernr=Stock no frmMain.qMP3Kennz=Flag frmMain.qMP3Prio=Prio frmMain.qMP3OptA=OptA frmMain.qMP3OptB=OptB frmMain.qMP3OptC=OptC frmMain.mnMP3GlobAend=Global changes frmMain.mnMP3ID3TagRead=Read MP3 Tag-ID from file frmMain.oDirDlgMP3=Select Directory frmKonfig.lbProxy=Proxy parameter frmKonfig.lbProxyPort=Port frmMP3Aend=MP3 globale changes frmMP3Aend.chkArtist=Artist frmMP3Aend.chkAlbum=Album frmMP3Aend.chkJahr=IDV2Year frmMP3Aend.chkGenre=Genre frmMP3Aend.btnOK=OK frmMP3Aend.btnCancel=Cancel Strings.107=Rest Strings.108=yes|no Strings.109=yes|no Strings.110=yes|no Strings.111=Want you really book all visible positions (ordered/partial delivery/delivered) in stock? Strings.112=Action Strings.113=MP3 ID frmMain.qBauteiltree_typ=Type frmMain.qBAdrAdr=Address frmMain.qBestellBauteil=Component frmMain.qBestellLief1_Adr=Deliv1 Addr frmMain.qBestellLief1_BauteilAdr=Deliv1 supplier frmMain.qBestellLief2_Adr=Deliv2 Addr frmMain.qBestellLief2_BauteilAdr=Deliv2 supplier frmMain.qBestellProjekt=Project frmMain.mnBestBucheLager=Book visible in stock frmMain.qPPosBauteil=Component frmMain.mnAdrInfoEtikett=Printing Label "Info" frmMain.mnMP3Integrieren=Integrate new files frmMain.mnMP3Del=Delete row and file frmMP3Aend.chkComment=Clear MP3 remark (comment) Strings.114=This function will update all the MP3 files IDV2-tag, which are visible in the table.\r\nDo you really want to perform this function? frmMain.qGehauseGewicht=Weight frmMain.mnHandbOrdner=Open folder frmBestellMin.qryProjSum=Quantity Proj frmKisteTausch.qInhaltMenge=Quantity frmKisteTausch.qBauteilMenge=Quantity frmKonfig.edPortHint=3306 Strings.115=Please enter a quantity of the produced part: Strings.116=Input error: Quantity can not be booked. frmMain.mnProjMengeBucheX=Beech part quantity after production frmMain.spPLEDHint=Send Box to COM Port frmPPosTest.qMengeBestellt=Quantity ordered frmPPosTest.qnMengeBestellt=Quantity ordered frmDruckEtikett.chkRaster=Raster Strings.117=yes|no Strings.118=yes|no Strings.119=yes|no Strings.120=Unlock version for changes Strings.121=Do you really want to change the versioned project? Strings.122="Single module"|"Complete unit" Strings.123= Strings.124=yes|no Strings.125=yes|no Strings.126=yes|no Strings.127=Documentation exists Strings.128=Documentation already exists. Do you want to jump to the record? Strings.129=Unlock version for changes Strings.130=Do you really want to change the versioned documentation? frmMain.tabPProjekt=Projects frmMain.panPPosVers=Version frmMain.tabPPDoku=Documentation frmMain.spPPDNewHint=New entry frmMain.spPPDCopyHint=Copy data frmMain.spPPDSaveHint=Save data frmMain.spPPDAbortHint=Abort change frmMain.spPPDDeleteHint=Delete data frmMain.lbDatum21=Date: frmMain.spPPDPrintHint=Print frmMain.spPPDVersionHint=Import/Export frmMain.lbPPDokuBez=&Description frmMain.lbPPDokuStatus=Status frmMain.spPPDokuNichtFrg=NR frmMain.spPPDokuNichtFrgHint=not released frmMain.spPPDokuFrgAktiv=EA frmMain.spPPDokuFrgAktivHint=enable active frmMain.spPPDokuFreigabe=R frmMain.spPPDokuFreigabeHint=released frmMain.spPPDokuPrototyp=P frmMain.spPPDokuPrototypHint=Prototyp frmMain.spPPDokuStorno=C frmMain.spPPDokuStornoHint=canceled frmMain.spPPDokuGesperrt=B frmMain.spPPDokuGesperrtHint=Blocked frmMain.spPPDokuFilterHint=Filter on current status frmMain.spHandbuch17ExecHint=Open manual frmMain.spHandbuch17Hint=Choice Manual (File) frmMain.lbPPDokuHandbuch=&Handbook frmMain.lbPPDokuKurzBez=Short Description frmMain.lbPPDokuDatum=D&ate frmMain.spPPDokuInfoEtikettHint=Printing Label frmMain.lbPPDokuInfo=Info frmMain.spPPDokuDatumHint=Choice date frmMain.lbPPDokuVersion=&Version frmMain.spHandbuchPDF18ExecHint=Open manual frmMain.spHandbuchPDF18Hint=Choice Manual (File) frmMain.lbPPDokuHandbuchPDF=Handbook &PDF frmMain.spGotoBauteilLG6Hint=Goto Store/Case frmMain.spGotoBauteil6Hint=Goto Component frmMain.spPPDBauteilHint=Choice component frmMain.lbPPDokuBauteil=&Component frmMain.lbPPDokuLagCase=Ca&se/variant frmMain.spFilterPDokuThemaHint=Filter on Topic frmMain.lbPPDokuThema=&Topic frmMain.spGotoDoku1Hint=Go to the documentation frmMain.spPPDokuHint=Selection documentation frmMain.lbPPDoku=D&ocumentation frmMain.chkPPDokuQuelle=Source Doku frmMain.tabPVersion=Version frmMain.spPVNewHint=New entry frmMain.spPVCopyHint=Copy data frmMain.spPVSaveHint=Save data frmMain.spPVAbortHint=Abort change frmMain.spPVDeleteHint=Delete data frmMain.lbDatum19=Date: frmMain.spPVPrintHint=Print frmMain.spPVExpHint=Import/Export frmMain.lbPVersBez=&Description frmMain.lbPVersBauteil=&Component frmMain.lbPVersLagCase=Ca&se/variant frmMain.spPVersBauteilHint=Choice component frmMain.spGotoBauteil5Hint=Goto Component frmMain.lbPVersStatus=Status frmMain.spPVersNichtFrg=NR frmMain.spPVersNichtFrgHint=not released frmMain.spPVersFrgAktiv=EA frmMain.spPVersFrgAktivHint=enable active frmMain.spPVersFreigabe=R frmMain.spPVersFreigabeHint=released frmMain.spPVersPrototyp=P frmMain.spPVersPrototypHint=Prototyp frmMain.spPVersStorno=C frmMain.spPVersStornoHint=canceled frmMain.spPVersGesperrt=D frmMain.spPVersGesperrtHint=Blocked frmMain.spPVersFilterHint=Filter on current status frmMain.spGotoBauteilLG5Hint=Goto Store/Case frmMain.spHandbuch14ExecHint=Open manual frmMain.spHandbuch14Hint=Choice Manual (File) frmMain.lbPVersHandbuch=&Handbook frmMain.lbPVersVersion=&Version frmMain.lbPVersRevision=&Revision frmMain.lbPVersDatum=D&ate frmMain.spPVersInfoEtikettHint=Printing Label frmMain.lbPVersInfo=Info frmMain.spPVersDatumHint=Choice date frmMain.lbPVersTermin=&Termin frmMain.spPVersTerminHint=Choice date frmMain.lbPVersBearb=Editor frmMain.lbPVersPruerf=Inspector frmMain.spPVersPruefungHint=Choice date frmMain.lbPVersPruerfD=Inspektion frmMain.lbPVersFrg=Releaser frmMain.spPVersDFreigHint=Choice date frmMain.lbPVersFrgD=Enabled frmMain.panPVersBaut=Changed components frmMain.tabPGeraet=Devices frmMain.lbPGeraetHandbuch=&Handbook frmMain.lbPGeraetBez=&Description frmMain.spHandbuch13Hint=Choice Manual (File) frmMain.spHandbuch13ExecHint=Open manual frmMain.lbPGeraetMengeFertig=&Quantity ready frmMain.lbPGeraetMengeOffen=Q&uantity Open frmMain.lbPGeraetTermin=&Termin frmMain.spPGeraetBuchHint=Stock accounting frmMain.spPGeraetTerminHint=Choice date frmMain.spPGeraetDet=▼ frmMain.spPGNewHint=New entry frmMain.spPGCopyHint=Copy data frmMain.spPGSaveHint=Save data frmMain.spPGAbortHint=Abort change frmMain.spPGDeleteHint=Delete data frmMain.lbDatum16=Date: frmMain.spPGPrintHint=Print frmMain.edSchnellsuchePGeratHint=Quick Search frmMain.spPGExpHint=Import/Export frmMain.spFilterPGeratHint=Filter projekt frmMain.lbPGeraetBauteil=Component frmMain.spPGeraetBauteilHint=Choice component frmMain.spGotoBauteil4Hint=Goto Component frmMain.spGotoBauteilLG4Hint=Goto Store/Case frmMain.lbPGeraetLagCase=Variant frmMain.lbPGeraetWartungNext=Next servicing frmMain.spPGeraetWartungHint=Choice date frmMain.lbPGeraetWartungInv=Interval frmMain.spPGeraetIntervallHint=Stock accounting frmMain.lbPGeraetAdr=Address frmMain.spGotoAdrPGHint=Goto Address frmMain.lbPGeraetArtikelNr=Ite&m no frmMain.lbPGeraetArtikelNr2=Item no 2 frmMain.lbPGeraetAuftrag=&Commission no frmMain.spPGeraetAuftragFctHint=commission function frmMain.tabPGUebers=Overview frmMain.tabPDoku=Documentation frmMain.spPDNewHint=New entry frmMain.spPDCopyHint=Copy data frmMain.spPDSaveHint=Save data frmMain.spPDAbortHint=Abort change frmMain.spPDDeleteHint=Delete data frmMain.lbDatum20=Date: frmMain.spPDPrintHint=Print frmMain.dbPDokuArchiv=Archive frmMain.spPDokuArchivHint=Archive View frmMain.spPDokuVersionHint=Version history frmMain.lbPDokuBez=&Description frmMain.lbPDokuStatus=Status frmMain.spPDokuNichtFrg=NR frmMain.spPDokuNichtFrgHint=not released frmMain.spPDokuFrgAktiv=FA frmMain.spPDokuFrgAktivHint=enable active frmMain.spPDokuFreigabe=R frmMain.spPDokuFreigabeHint=released frmMain.spPDokuPrototyp=T frmMain.spPDokuPrototypHint=Prototyp frmMain.spPDokuStorno=L frmMain.spPDokuStornoHint=canceled frmMain.spPDokuGesperrt=D frmMain.spPDokuGesperrtHint=Blocked frmMain.spPDokuFilterHint=Filter on current status frmMain.spHandbuch15ExecHint=Open manual frmMain.spHandbuch15Hint=Choice Manual (File) frmMain.lbPDokuHandbuch=&Handbook frmMain.lbPDokuKurzBez=Short Description frmMain.lbPDokuDatum=D&ate frmMain.spPDokuInfoEtikettHint=Printing Label frmMain.lbPDokuInfo=Info frmMain.spPDokuDatumHint=Choice date frmMain.lbPDokuVersion=&Version frmMain.lbPDokuDirZiel=&Destination folder frmMain.spDirZielHint=Select destination folder frmMain.spDirZielExecHint=Open destination directory frmMain.lbPDokuNummer=&Number frmMain.spHandbuchPDF16ExecHint=Open manual frmMain.spHandbuchPDF16Hint=Choice Manual (File) frmMain.lbPDokuHandbuchPDF=Handbook &PDF frmMain.lbDokuThema=&Topic frmMain.spFilterDokuThemaHint=Filter on Topic frmMain.panPVersBaut1=Used in project frmMain.spHandbuch12ExecHint=Open manual frmMain.qKisteBarcode=Barcode frmMain.qBestellLEinheit=Unit frmMain.mnBVerz=Create directories frmMain.qTypBLEinheit=Unit frmMain.qGehauseBRoHS=RoHS frmMain.qGehauseBKennz=Flag frmMain.qGehauseBGewicht=Weight frmMain.qGehauseBBarcode=Barcode frmMain.qGehauseBArtikelNr=Item no frmMain.qGehauseBArtikelNr2=Item no 2 frmMain.qGehauseBSMD=SMD frmMain.qProjektID_ID_Version=ID_ID_Version frmMain.qProjektProjektVersion_ID=Version frmMain.qProjektTyp=Type frmMain.qProjektVersionTyp=VersionType frmMain.qPPosID_ID_Version=ID_ID_Version frmMain.qPPosProjektVersion_ID=Version frmMain.qPPosLEinheit=Unit frmMain.qPPosGeloescht=Deleted frmMain.mnPVerz=Create directories frmMain.mnPVersNew=Create version frmMain.mnPVersAend=Change version frmMain.mnPVersZeig=Show version frmMain.mnPVersZeigAktuell=Current frmMain.qKisteBLEinheit=Unit frmMain.qKisteBHaltbar=Preserved frmMain.qKisteBBWare=BWare frmMain.qKisteBRoHS=RoHS frmMain.qKisteBKennz=Flag frmMain.qKisteBGewicht=Weight frmMain.qKisteBBarcode=Barcode frmMain.qKisteBArtikelNr=Item no frmMain.qKisteBArtikelNr2=Item no 2 frmMain.qKisteBSMD=SMD frmMain.qPVersFoto_ID=Foto_ID frmMain.qPVersProjekt_ID=Project frmMain.qPVersDatum=Date frmMain.qPVersVersion=Version frmMain.qPVersRevision=Revision frmMain.qPVersStatus=Status frmMain.qPVersBezeichnung=Designation frmMain.qPVersBauteil=Component frmMain.qPVersBauteil_ID=Component frmMain.qPVersBeschreibung=Text frmMain.qPVersBearbeiter=Editor frmMain.qPVersTermin=Termin frmMain.qPVersPruefer=Inspector frmMain.qPVersPrueferD=Inspection date frmMain.qPVersFreigeber=Releaser frmMain.qPVersFreigeberD=Released date frmMain.qPVersMengeFertig=Quantity finished frmMain.qPVersMengeOffen=Quantity Open frmMain.qPVersVPreis=VPrice frmMain.qPVersHandbuch=Handbook frmMain.qPVersInfo=Info frmMain.qPVersAuftrag=commission frmMain.qPVersSNr=SNr frmMain.qPVersArtikelNr=Item no frmMain.qPVersArtikelNr2=Item no 2 frmMain.qPVersBarcode=Barcode frmMain.qPVersOptA=OptA frmMain.qPVersOptB=OptB frmMain.qPVersOptC=OptC frmMain.qPVersKennz=Flag frmMain.qPVersAendDatum=ChangeDate frmMain.qPVersBProjekt_ID=Project frmMain.qPVersBFoto_ID=Foto_ID frmMain.qPVersBID_ID_Version=ID_ID_Version frmMain.qPVersBProjektVersion_ID=Version frmMain.qPVersBBezeichnung=Designation frmMain.qPVersBArtikelNr=Item no frmMain.qPVersBStatus=Status frmMain.qPVersBBemerkung=Remark frmMain.qPVersBBauteil_ID=Component frmMain.qPVersBSymbol=Symbol frmMain.qPVersBWert=Value frmMain.qPVersBGehause=Case frmMain.qPVersBMenge=Quantity frmMain.qPVersBEPreis=Price frmMain.qPVersBRabatt=Discount frmMain.qPVersBGPreis=Total Price frmMain.qPVersBArt=Category frmMain.qPVersBVariante=Variant frmMain.qPVersBPosX=Pos X frmMain.qPVersBPosY=Pos Y frmMain.qPVersBPosZ=Pos Z frmMain.qPVersBPosR=Pos R frmMain.qPVersBTop=Top frmMain.qPVersBSMD=SMD frmMain.qPVersBBarcode=Barcode frmMain.qPVersBKennz=Flag frmMain.qPVersBHandbuch=Handbook frmMain.qPVersBInfo=Info frmMain.qPVersBSNr=SNr frmMain.qPVersBDruck=Print frmMain.qPVersBAendDatum=ChangeDate frmMain.qPVersBGeloescht=Deleted frmMain.qPPosVBProjekt_ID=Project frmMain.qPPosVBFoto_ID=Foto_ID frmMain.qPPosVBID_ID_Version=ID_ID_Version frmMain.qPPosVBProjektVersion_ID=Version frmMain.qPPosVBBezeichnung=Designation frmMain.qPPosVBArtikelNr=Item no frmMain.qPPosVBStatus=Status frmMain.qPPosVBBemerkung=Remark frmMain.qPPosVBBauteil_ID=Component frmMain.qPPosVBSymbol=Symbol frmMain.qPPosVBWert=Value frmMain.qPPosVBGehause=Case frmMain.qPPosVBMenge=Quantity frmMain.qPPosVBEPreis=Price frmMain.qPPosVBRabatt=Discount frmMain.qPPosVBGPreis=Total Price frmMain.qPPosVBArt=Category frmMain.qPPosVBVariante=Variant frmMain.qPPosVBPosX=Pos X frmMain.qPPosVBPosY=Pos Y frmMain.qPPosVBPosZ=Pos Z frmMain.qPPosVBPosR=Pos R frmMain.qPPosVBTop=Top frmMain.qPPosVBSMD=SMD frmMain.qPPosVBBarcode=Barcode frmMain.qPPosVBKennz=Flag frmMain.qPPosVBHandbuch=Handbook frmMain.qPPosVBInfo=Info frmMain.qPPosVBSNr=SNr frmMain.qPPosVBDruck=Print frmMain.qPPosVBAendDatum=ChangeDate frmMain.qPPosVBGeloescht=Deleted frmMain.qDokuID_ID_Version=ID_ID_Version frmMain.qDokuFoto_ID=Foto_ID frmMain.qDokuBezeichnung=Designation frmMain.qDokuKurzBez=ShortDesc frmMain.qDokuThema=Topic frmMain.qDokuStatus=Status frmMain.qDokuDatum=Date frmMain.qDokuVersion=Version frmMain.qDokuRevision=Revision frmMain.qDokuBearbeiter=Editor frmMain.qDokuHandbuch=Handbook frmMain.qDokuHandbuchPDF=HandbookPDF frmMain.qDokuDirZiel=DirDestination frmMain.qDokuBemerkung=Remark frmMain.qDokuInfo=Info frmMain.qDokuArchiv=Archive frmMain.qDokuNr=No frmMain.qDokuOptA=OptA frmMain.qDokuOptB=OptB frmMain.qDokuOptC=OptC frmMain.qDokuKennz=Flag frmMain.qDokuAendDatum=ChangeDate frmMain.oDir=Select Directory frmMain.qPDokuID_ID_Version=ID_ID_Version frmMain.qPDokuProjekt_ID=Project_ID frmMain.qPDokuDoku_ID=Documentation frmMain.qPDokuFoto_ID=Foto_ID frmMain.qPDokuBauteil=Component frmMain.qPDokuBauteil_ID=Component_ID frmMain.qPDokuBezeichnung=Designation frmMain.qPDokuKurzBez=ShortDesc frmMain.qPDokuThema=Topic frmMain.qPDokuStatus=Status frmMain.qPDokuDatum=Date frmMain.qPDokuVersion=Version frmMain.qPDokuRevision=Revision frmMain.qPDokuBearbeiter=Editor frmMain.qPDokuHandbuch=Handbook frmMain.qPDokuHandbuchPDF=HandbookPDF frmMain.qPDokuBemerkung=Remark frmMain.qPDokuInfo=Info frmMain.qPDokuQuelleDoku=SourceDoku frmMain.qPDokuKennz=Flag frmMain.qPDokuOptA=OptA frmMain.qPDokuOptB=OptB frmMain.qPDokuOptC=OptC frmMain.qPDokuAendDatum=ChangeDate frmMain.qPDokuDokuBez=DocuDescr frmMain.qPDokuDokuKurzBez=DocuShortDesc frmMain.qPDokuDokuStatus=DocuStatus frmMain.qPDokuDokuDatum=DocuDate frmMain.qPDokuDokuVersion=DocuVersion frmMain.qPDokuDokuThema=DocuTopic frmMain.qPDokuDokuHandbuch=DocuHandbook frmMain.qPDokuDokuHandbuchPDF=DocuHandbookPDF frmMain.qPDokuDokuBemerkung=DocuRemark frmMain.qPDokuDokuInfo=DocuInfo frmMain.qPDokuDokuArchiv=DocuArchiv frmMain.qPDokuDokuNr=DocuNr frmMain.qDokuBFoto_ID=Foto_ID frmMain.qDokuBID_ID_Version=ID_ID_Version frmMain.qDokuBProjektVersion_ID=Version frmMain.qDokuBTyp=Type frmMain.qDokuBVersionTyp=VersionType frmMain.qDokuBBezeichnung=Designation frmMain.qDokuBBeschreibung=Text frmMain.qDokuBMengeFertig=Quantity finished frmMain.qDokuBMengeOffen=Quantity Open frmMain.qDokuBKennz=Flag frmMain.qDokuBTermin=Termin frmMain.qDokuBHandbuch=Handbook frmMain.qDokuBInfo=Info frmMain.qDokuBBauteil_ID=Component frmMain.qDokuBOptA=OptA frmMain.qDokuBOptB=OptB frmMain.qDokuBOptC=OptC frmMain.qDokuBWartung=Service frmMain.qDokuBIntervall=Interval frmMain.qDokuBVariante=Variant frmMain.qDokuBAuftrag=commission frmMain.qDokuBAdr_ID=Address frmMain.qDokuBSNr=SNr frmMain.qDokuBVPreis=VPrice frmMain.qDokuBAendDatum=ChangeDate frmMain.qDokuBArtikelNr=Item no frmMain.qDokuBArtikelNr2=Item no 2 frmMain.mnPDVersNew=Create version frmMain.mnPDVersAend=Change version frmMain.mnPDVersZeig=Show version frmMain.mnPPDVersNew=Create version frmMain.mnPPDVersAend=Change version frmMain.mnPPDVersZeig=Show version frmPPosTest.chkProj=Projects frmPPosTest.chkGeraet=Devices frmAuswahl.qryGID_ID_Version=ID_ID_Version frmAuswahl.qryGFoto_ID=Foto_ID frmAuswahl.qryGBezeichnung=Designation frmAuswahl.qryGKurzBez=ShortDesc frmAuswahl.qryGThema=Topic frmAuswahl.qryGStatus=Status frmAuswahl.qryGDatum=Date frmAuswahl.qryGVersion=Version frmAuswahl.qryGHandbuch=Handbook frmAuswahl.qryGHandbuchPDF=HandbookPDF frmAuswahl.qryGBemerkung=Remark frmAuswahl.qryGInfo=Info frmAuswahl.qryGNr=No frmAuswahl.qryGKennz=Flag frmAuswahl.qryGOptA=OptA frmAuswahl.qryGOptB=OptB frmAuswahl.qryGOptC=OptC frmAuswahl.qryGAendDatum=ChangeDate frmKonfig.lbDirGeraet=Devices frmKonfig.lbDirDoku=Documents frmKonfig.tabFormat=Formats frmKonfig.tabGBauteil=Components frmKonfig.lbVerzBauteil=Create directories for components: frmKonfig.tabGProjekt=Projects frmKonfig.lbVerzProjekt=Create directories for projects: frmBauteil.qryDokuID_ID_Version=ID_ID_Version frmBauteil.qryDokuFoto_ID=Foto_ID frmBauteil.qryDokuBezeichnung=Designation frmBauteil.qryDokuKurzBez=ShortDesc frmBauteil.qryDokuThema=Topic frmBauteil.qryDokuStatus=Status frmBauteil.qryDokuDatum=Date frmBauteil.qryDokuVersion=Version frmBauteil.qryDokuRevision=Revision frmBauteil.qryDokuBearbeiter=Editor frmBauteil.qryDokuHandbuch=Handbook frmBauteil.qryDokuHandbuchPDF=HandbookPDF frmBauteil.qryDokuDirZiel=DirDestination frmBauteil.qryDokuBemerkung=Remark frmBauteil.qryDokuInfo=Info frmBauteil.qryDokuArchiv=Archive frmBauteil.qryDokuNr=No frmBauteil.qryDokuDirErzeugen=MakeDir frmBauteil.qryDokuOptA=OptA frmBauteil.qryDokuOptB=OptB frmBauteil.qryDokuOptC=OptC frmBauteil.qryDokuKennz=Flag frmBauteil.qryDokuAendDatum=ChangeDate frmMP3Integrieren=Integrate new files frmMP3Integrieren.lbDir=&Folder from the new files: frmMP3Integrieren.lbAktion=Action frmMP3Integrieren.spAkCopy=Copy frmMP3Integrieren.spAkCopyNo=not copy frmMP3Integrieren.grpAend=Change MP3-ID tag (new files) frmMP3Integrieren.lbMP3Artist=IDV2Artist frmMP3Integrieren.lbMP3Album=IDV2Album frmMP3Integrieren.lbMP3Titel=IDV2Titel frmMP3Integrieren.lbMP3Jahr=IDV2Year frmMP3Integrieren.lbMP3Track=IDV2Track frmMP3Integrieren.lbMP3Genre=IDV2Genre frmMP3Integrieren.spMP3FilterArtistHint=Filter artist frmMP3Integrieren.spMP3FilterAlbumHint=Filter album frmMP3Integrieren.btnGlobAend=Global changes frmMP3Integrieren.spAkOverwrite=Overwrite existing file frmMP3Integrieren.spMSaveHint=Save data frmMP3Integrieren.spMAbortHint=Abort change frmMP3Integrieren.spMDeleteHint=Delete data frmMP3Integrieren.btnStart=Start integration frmMP3Integrieren.spFilterMP3Hint=Filter on component frmMP3Integrieren.edSchnellsucheMP3Hint=Quick Search frmMP3Integrieren.qMP3Foto_ID=Foto_ID frmMP3Integrieren.qMP3FileTyp=Type frmMP3Integrieren.qMP3FileSize=FileSize frmMP3Integrieren.qMP3IDV2Artist=IDV2Artist frmMP3Integrieren.qMP3IDV2Album=IDV2Album frmMP3Integrieren.qMP3IDV2Titel=IDV2Titel frmMP3Integrieren.qMP3IDV2Year=IDV2Year frmMP3Integrieren.qMP3IDV2Track=IDV2Track frmMP3Integrieren.qMP3IDV2Genre=IDV2Genre frmMP3Integrieren.qMP3IDV2Comment=Remark frmMP3Integrieren.qMP3IDV2Encoder=Encoder frmMP3Integrieren.qMP3IDV2Copyright=IDV2Copyright frmMP3Integrieren.qMP3IDV2Language=Language frmMP3Integrieren.qMP3IDV2Link=IDV2Link frmMP3Integrieren.qMP3FileVersion=Version frmMP3Integrieren.qMP3FileBitrate=Bitrate frmMP3Integrieren.qMP3FileDuration=Timelength frmMP3Integrieren.qMP3Bemerkung=Remark frmMP3Integrieren.qMP3Rating=Rating frmMP3Integrieren.qMP3Handbuch=Handbook frmMP3Integrieren.qMP3Info=Info frmMP3Integrieren.qMP3Lagernr=Stock no frmMP3Integrieren.qMP3Kennz=Flag frmMP3Integrieren.qMP3Prio=Prio frmMP3Integrieren.qMP3OptA=OptA frmMP3Integrieren.qMP3OptB=OptB frmMP3Integrieren.qMP3OptC=OptC frmMP3Integrieren.qMP3AendDatum=ChangeDate frmMP3Integrieren.mnMP3Del=Delete row and file frmMP3Integrieren.qMemIDV2Artist=IDV2Artist frmMP3Integrieren.qMemIDV2Album=IDV2Album frmMP3Integrieren.qMemIDV2Titel=IDV2Titel frmMP3Integrieren.qMemIDV2Year=IDV2Year frmMP3Integrieren.qMemIDV2Track=IDV2Track frmMP3Integrieren.qMemIDV2Comment=Remark frmMP3Integrieren.qMemIDV2Genre=IDV2Genre frmMP3Integrieren.qMemFileBitrate=Bitrate frmMP3Integrieren.qMemFileDuration=Duration frmMP3Integrieren.qMemFileSize=FileSize frmMP3Integrieren.qMemAction=Action frmMP3Integrieren.qMemMP3_ID=MP3 ID frmMP3Integrieren.qMemHandbuch=Handbook frmVersNew=New version frmVersNew.btnOK=&OK frmVersNew.btnCancel=&Cancel frmVersNew.lbMsg=Create a new version frmVersNew.lbBezeichung=&Description frmVersNew.lbVersion=&Version frmVersNew.lbRevision=&Revision frmVersNew.lbBearbeiter=&Clerk frmVersNew.lbDatum=D&ate frmVersNew.lbVersionOld=Last version frmVersNew.lbRevisionOld=Last revision Strings.131=Database is newer than the EXE version and can not be imported! Strings.132=Support the EleLa project with your donation Strings.133=This function automatically generates a barcode for ALL the case / variant entries, if the entry does not have a barcode. Strings.134=It can also create duplicate barcodes or errors, so check the log afterwards and check for duplicate barcodes.\r\nThe function can not be undone. Strings.135=Do you really want to do this? Strings.136=New data translation Strings.137=Enter a designation, please: Strings.138=Edit data translation Strings.139=Enter a designation, please: Strings.140=Do you really want to change the versioned device? Strings.141=Book device component Strings.142=The devicet has been produced and the components of the positions will be reduce from stock? Strings.143=Enter a device description, please Strings.144=Device exists Strings.145=Device already exists. Do you want to use this record? Strings.146=other Strings.147=Change all visible statuses Strings.148=Do you really want to change all visible statuses? frmMain.spBauteilCalcHint=Calculator frmMain.spBChartHint=Price Chart frmMain.lbBLiefAbMenge=&From quantity frmMain.spBLiefWeb=Web query frmMain.spProjektCalcHint=Calculator frmMain.spProjektInfoEtikettHint=Printing Label frmMain.lbPPDokuInfo1=Info frmMain.spFilterPHistHint=Filter projekt frmMain.edSchnellsuchePHistHint=Quick Search frmMain.spPGeraetCalcHint=Calculator frmMain.tabPGPos=Position frmMain.tabPGPPos=Components and projects frmMain.lbPGPosMenge=Quantit&y frmMain.lbPGPosBez=D&escription frmMain.btnBestellBauteil6Hint=Take part in order proposal frmMain.lbPGPosBauteil=&Component frmMain.spGotoBauteil7Hint=Goto Component frmMain.lbPGPosLagCase=Variant frmMain.spGotoBauteilLG7Hint=Goto Store/Case frmMain.lbPGPosVariante=Va&riant frmMain.spPGFilterVarianteHint=Filter variant frmMain.spPGPBauteilHint=Choice component frmMain.lbPGPosStatus=Status frmMain.spPGPStatusHint=Choice status frmMain.spPGPosNicht=D frmMain.spPGPosNichtHint=defect frmMain.spPGPosPruefen=T frmMain.spPGPosPruefenHint=test frmMain.spPGPosFertig=R frmMain.spPGPosFertigHint=ready frmMain.spPGPosAktiv=A frmMain.spPGPosAktivHint=activ frmMain.spPGPosOffen=O frmMain.spPGPosOffenHint=open frmMain.spPGPosKeinHint= frmMain.spFilterPGPStatusHint=Filter on current status frmMain.lbPGPosSumM=Sum frmMain.spPGPosDet=▼ frmMain.spPGLEDHint=Send Box to COM Port frmMain.spPGSave1Hint=Save data frmMain.spPGAbort1Hint=Abort change frmMain.lbDatum22=Date: frmMain.spPGPrint1Hint=Print frmMain.spPGPExpHint=Import/Export frmMain.lbPGPosSuchIn=(...) frmMain.spPGNew1Hint=New entry frmMain.spPGCopy1Hint=Copy data frmMain.spPGDelete1Hint=Delete data frmMain.spHandbuch16ExecHint=Open manual frmMain.spHandbuch16Hint=Choice Manual (File) frmMain.lbPGPosHandbuch=&Handbook frmMain.lbPGPosCase=&Case frmMain.lbPGPosSNr=Serial number frmMain.lbPGPosWert=&Value frmMain.lbPPosSum1=Sum frmMain.lbPGPosEPreis=Pr&ice frmMain.lbPGPosGPreis=Total Price frmMain.panPGPosVers=Version frmMain.tabPGPPPos=Project position / place variant frmMain.tabPGHistorie=History frmMain.lbProjektGHistHandbuch=Ha&ndbook frmMain.lbProjektGHistProjBez=&Project frmMain.spHandbuch19Hint=Choice Manual (File) frmMain.spHandbuch19ExecHint=Open manual frmMain.lbProjektGHistVersion=&Version frmMain.lbProjektGHistAufwand=T&ime frmMain.lbProjektGHistDatum=D&ate frmMain.lbProjektGHistBez=D&escription frmMain.lbProjektGHistFDatum=Date read&y frmMain.lbProjektGHistFVersion=Versi&on ready frmMain.spHist2FilterHint=Filter on current status frmMain.lbProjektGHistStatus=Status frmMain.spHist2FilterBFHint=Filter on current B/F frmMain.spHist2BugF=R frmMain.spHist2BugFHint=Feature frmMain.spHist2Bug=B frmMain.spHist2BugHint=Bug frmMain.spHist2BugN=D frmMain.spHist2BugNHint=defect frmMain.lbHistStatus3=B/F frmMain.spHist2Hist=H frmMain.spHist2HistHint=History frmMain.spHist2Offen=O frmMain.spHist2OffenHint=open frmMain.spHist2Aktiv=A frmMain.spHist2AktivHint=activ frmMain.spHist2Fertig=R frmMain.spHist2FertigHint=ready frmMain.spHist2Nicht=D frmMain.spHist2NichtHint=not edit frmMain.spHist2Spaeter=L frmMain.spHist2SpaeterHint=later frmMain.spHist2FilterDatumFHint=Filter on date ready frmMain.spHist2FilterVersionFHint=Filter on version ready frmMain.spHist2Testen=T frmMain.spHist2TestenHint=test frmMain.spHist2FDatumHint=Choice date frmMain.lbProjektGHistPPos=Position frmMain.spHist2Det=▼ frmMain.spH2GotoPPosHint=Goto project pos frmMain.spHNew2Hint=New entry frmMain.spHCopy2Hint=Copy data frmMain.spHSave2Hint=Save data frmMain.spHAbort2Hint=Abort change frmMain.spHDelete2Hint=Delete data frmMain.lbDatum23=Date: frmMain.spHPrint2Hint=Print frmMain.spHExp2Hint=Import/Export frmMain.spFilterPGHistHint=Filter projekt frmMain.edSchnellsuchePGHistHint=Quick Search frmMain.lbProjektHistGFehlerreport=Error report custo&mer frmMain.lbProjektGHistRepReport=Repair Report frmMain.lbProjektGHistRMA=RMA frmMain.spGetRMACode2Hint=Generate RMA Code frmMain.spGetErrorCode2Hint=Generate RMA Code frmMain.lbProjektGHistFehlercode=Error code frmMain.lbProjektGHistVorgehen=Proceedin&g frmMain.lbProjektGHistKostenv=Quotation frmMain.spH2GotoKostHint=Goto quotation frmMain.lbProjektGHistGN=Devi&ce number frmMain.lbProjektGHistSN=Serial numbe&r frmMain.lbProjektGHistAbrechnung=Invoice frmMain.lbHist2AdrKont=&Address/Contact frmMain.spGotoAdrH2Hint=Goto Address frmMain.lbProjektGHistGPreis=Total Price frmMain.tabPGDoku=Documentation frmMain.spPGDNewHint=New entry frmMain.spPGDCopyHint=Copy data frmMain.spPGDSaveHint=Save data frmMain.spPGDAbortHint=Abort change frmMain.spPGDDeleteHint=Delete data frmMain.lbDatum24=Date: frmMain.spPGDPrintHint=Print frmMain.spPGDVersionHint=Import/Export frmMain.lbPGDokuBez=&Description frmMain.lbPGDokuStatus=Status frmMain.spPGDokuNichtFrg=NR frmMain.spPGDokuNichtFrgHint=not released frmMain.spPGDokuFrgAktiv=EA frmMain.spPGDokuFrgAktivHint=enable active frmMain.spPGDokuFreigabe=R frmMain.spPGDokuFreigabeHint=released frmMain.spPGDokuPrototyp=T frmMain.spPGDokuPrototypHint=Prototyp frmMain.spPGDokuStorno=L frmMain.spPGDokuStornoHint=canceled frmMain.spPGDokuGesperrt=D frmMain.spPGDokuGesperrtHint=Blocked frmMain.spPGDokuFilterHint=Filter on current status frmMain.spHandbuch20ExecHint=Open manual frmMain.spHandbuch20Hint=Choice Manual (File) frmMain.lbPGDokuHandbuch=&Handbook frmMain.lbPGDokuKurzBez=Short Description frmMain.lbPGDokuDatum=D&ate frmMain.spPGDokuInfoEtikettHint=Printing Label frmMain.lbPGDokuInfo=Info frmMain.spPGDokuDatumHint=Choice date frmMain.lbPGDokuVersion=&Version frmMain.spHandbuchPDF21ExecHint=Open manual frmMain.spHandbuchPDF21Hint=Choice Manual (File) frmMain.lbPGDokuHandbuchPDF=Handbook &PDF frmMain.spGotoBauteilLG8Hint=Goto Store/Case frmMain.spGotoBauteil8Hint=Goto Component frmMain.spPGDBauteilHint=Choice component frmMain.lbPGDokuBauteil=&Component frmMain.lbPGDokuLagCase=Ca&se/variant frmMain.spFilterPGDokuThemaHint=Filter on Topic frmMain.lbPGDokuThema=&Topic frmMain.spGotoDoku2Hint=Go to the documentation frmMain.spPGDokuHint=Selection documentation frmMain.lbPGDoku=D&ocumentation frmMain.chkPGDokuQuelle=Source Doku frmMain.tabPGVersion=Version frmMain.spPGVNewHint=New entry frmMain.spPGVCopyHint=Copy data frmMain.spPGVSaveHint=Save data frmMain.spPGVAbortHint=Abort change frmMain.spPGVDeleteHint=Delete data frmMain.lbDatum25=Date: frmMain.spPGVPrintHint=Print frmMain.spPGVExpHint=Import/Export frmMain.lbPGVersBez=&Description frmMain.lbPGVersBauteil=&Component frmMain.lbPGVersLagCase=&Store/Case frmMain.spPGVersBauteilHint=Choice component frmMain.spGotoBauteil9Hint=Goto Component frmMain.lbPGVersStatus=Status frmMain.spPGVersNichtFrg=NR frmMain.spPGVersNichtFrgHint=not released frmMain.spPGVersFrgAktiv=EA frmMain.spPGVersFrgAktivHint=enable active frmMain.spPGVersFreigabe=R frmMain.spPGVersFreigabeHint=released frmMain.spPGVersPrototyp=T frmMain.spPGVersPrototypHint=Prototyp frmMain.spPGVersStorno=L frmMain.spPGVersStornoHint=canceled frmMain.spPGVersGesperrt=D frmMain.spPGVersGesperrtHint=Blocked frmMain.spPGVersFilterHint=Filter on current status frmMain.spGotoBauteilLG9Hint=Goto Store/Case frmMain.spHandbuch22ExecHint=Open manual frmMain.spHandbuch22Hint=Choice Manual (File) frmMain.lbPGVersHandbuch=&Handbook frmMain.lbPGVersVersion=&Version frmMain.lbPGVersRevision=&Revision frmMain.lbPGVersDatum=D&ate frmMain.spPGVersInfoEtikettHint=Printing Label frmMain.lbPGVersInfo=Info frmMain.spPGVersDatumHint=Choice date frmMain.lbPGVersTermin=&Termin frmMain.spPGVersTerminHint=Choice date frmMain.lbPGVersBearb=Editor frmMain.lbPGVersPruerf=Inspector frmMain.spPGVersPruefungHint=Choice date frmMain.lbPGVersPruerfD=Inspektion frmMain.lbPGVersFrg=Releaser frmMain.spPGVersDFreigHint=Choice date frmMain.lbPGVersFrgD=Enabled frmMain.panPGVersBaut=Changed components frmMain.tabPGEinzelgeraet=Single device frmMain.spPGENew=NEW frmMain.spPGENewHint=New entry frmMain.spPGECopyHint=Copy data frmMain.spPGESaveHint=Save data frmMain.spPGEAbortHint=Abort change frmMain.spPGEDeleteHint=Delete data frmMain.lbDatum28=Date: frmMain.spPGEPrint=T frmMain.spPGEPrintHint=Print frmMain.lbPGKostBez1=&Description frmMain.lbPGKostAdrKont1=&Address/Contact frmMain.spGotoAdrPGK1Hint=Goto Address frmMain.lbPGEStatus=Status frmMain.spPGE1=A frmMain.spPGE1Hint=&Offer frmMain.spPGE2=OS frmMain.spPGE2Hint=Offer sended frmMain.spPGE3=B frmMain.spPGE3Hint=ordered frmMain.spPGE4=D frmMain.spPGE4Hint=delivered frmMain.spPGE5=R frmMain.spPGE5Hint=ready frmMain.spPGE6=L frmMain.spPGE6Hint=canceled frmMain.spPGEFilterHint=Filter on current status frmMain.lbPGEBearb=Edited frmMain.spPGEBearbHint=Choice date frmMain.lbPGEPruef=Inspektion frmMain.spPGKEPruefHint=Choice date frmMain.lbPGEService=Service frmMain.spPGEServiceHint=Choice date frmMain.spPGDokuInfoEtikett1=T frmMain.spPGDokuInfoEtikett1Hint=Printing Label frmMain.lbPGDokuInfo1=Info frmMain.spPGELiefHint=Choice date frmMain.lbPGELief=delivered frmMain.lbProjektGHistSN1=Serial numbe&r frmMain.lbProjektGHistGN1=Devi&ce number frmMain.lbPGEVersion=Version frmMain.tabPGKost=Quotation frmMain.tabPGKUeb=Overview frmMain.lbPGKostAdrKont=&Address/Contact frmMain.lbPGKostBez=&Description frmMain.lbPGKostLief=De&livery frmMain.lbPGKostAngebot=&Offer frmMain.spGotoAdrPGKHint=Goto Address frmMain.lbPGKostStatus=Status frmMain.spPGKSAngebot=A frmMain.spPGKSAngebotHint=&Offer frmMain.spPGKSAngebotG=OS frmMain.spPGKSAngebotGHint=Offer sended frmMain.spPGKSBestellt=B frmMain.spPGKSBestelltHint=ordered frmMain.spPGKSFertig=R frmMain.spPGKSFertigHint=ready frmMain.spPGKSGeliefert=D frmMain.spPGKSGeliefertHint=delivered frmMain.spPGKSStorno=L frmMain.spPGKSStornoHint=canceled frmMain.spPGKFilterHint=Filter on current status frmMain.lbPGKostAuftrag=&Commission no frmMain.spPGKAngebotHint=Choice date frmMain.lbPGKostGueltig=&Valid to frmMain.spPGKGueltigHint=Choice date frmMain.spPGKLiefHint=Choice date frmMain.lbPGKostAbnahme=Acce&ptance frmMain.spPGKAbnahmeHint=Choice date frmMain.lbPGKostBestNr=Order-Nr. frmMain.lbPGKostGPreis=Total Price frmMain.lbPGKostInfo=Info frmMain.spGetPGKVCodeHint=Generate RMA Code frmMain.spPGKInfoEtikettHint=Printing Label frmMain.spPGKNewHint=New entry frmMain.spPGKCopyHint=Copy data frmMain.spPGKSaveHint=Save data frmMain.spPGKAbortHint=Abort change frmMain.spPGKDeleteHint=Delete data frmMain.lbDatum26=Date: frmMain.spPGKPrintHint=Print frmMain.spPGKExpHint=Import/Export frmMain.tabPGKPos=Position frmMain.lbPGKostPBez=&Description frmMain.lbPGKostPLieferung=De&livery frmMain.lbPGKostPStatus=Status frmMain.spPGKPOffen=O frmMain.spPGKPOffenHint=open frmMain.spPGKPAktiv=A frmMain.spPGKPAktivHint=activ frmMain.spPGKPTest=T frmMain.spPGKPTestHint=test frmMain.spPGKPFertig=R frmMain.spPGKPFertigHint=ready frmMain.spPGKPNichtB=D frmMain.spPGKPNichtBHint=not edit frmMain.spPGKPStorno=L frmMain.spPGKPStornoHint=canceled frmMain.spPGKPFilterHint=Filter on current status frmMain.lbPGKostPTermin=Termin frmMain.spPGKPTerminHint=Choice date frmMain.spPGKPLiefHint=Choice date frmMain.lbPKostPArtikelNr1=Ite&m no frmMain.lbPGKostPVPreis=&VPrice frmMain.lbPGKostPMenge=Quantit&y frmMain.btnBestellBauteil7Hint=Take part in order proposal frmMain.lbPGKostPBauteil=&Component frmMain.lbPGKostPLagCase=&Store/Case frmMain.spGotoBauteilLG10Hint=Goto Store/Case frmMain.spGotoBauteil10Hint=Goto Component frmMain.spPGKPBauteilHint=Choice component frmMain.lbPGKostPVSum=Total position frmMain.lbPKostPPPos1=Position frmMain.spPGKPVPreisHint=Update price from component frmMain.lbPGKostPInfo=Info frmMain.spPGKPGotoProjPosHint=Goto project pos frmMain.spPGKPInfoEtikettHint=Printing Label frmMain.spPGKPNewHint=New entry frmMain.spPGKPCopyHint=Copy data frmMain.spPGKPSaveHint=Save data frmMain.spPGKPAbortHint=Abort change frmMain.spPGKPDeleteHint=Delete data frmMain.lbDatum27=Date: frmMain.spPGKPPrintHint=Print frmMain.spPGKPExpHint=Import/Export frmMain.tabPGBestell=Order frmMain.lbPGBestellBauteil=&Component frmMain.spGotoLager5Hint=Goto Store/Case frmMain.lbPGBestBez=D&escription frmMain.spGotoBestell3Hint=Goto order frmMain.chkPGBestellArchiv=With archived frmMain.spBestChartHint=Price Chart frmMain.chkSuchMitLieferant=with deliverer frmMain.spAdrCpyHint=Copy address in clipboard frmMain.chkAdrKunde=Customer frmMain.spAdrKCpyHint=Copy address in clipboard frmMain.chkAdrKLief=Supplier frmMain.chkAdrKHerst=Manufacturer frmMain.chkAdrKKunde=Customer frmMain.chkAdrKProjekt=Project/History frmMain.tabExtraTerminal=COM Terminal frmMain.spTermConnectHint=Connect / disconnect frmMain.lbTermVerbindungParam=Connection parameter: frmMain.spTermParamHint=Connection parameter frmMain.spTermSaveHint=Save protocol into a file frmMain.spTermSendFileHint=Send file frmMain.spTermClearHint=Clear log frmMain.rbTermAnsi=ANSI frmMain.rbTermHex=HEX frmMain.rbTermCustom=Userdefined: frmMain.chkTermZWms=New line after ms: frmMain.spTermDWHint=Parameter data translation frmMain.btnTermSend=Send frmMain.btnTermSendHint=Send text to COM Port frmMain.chkTermBreak=BREAK frmMain.chkTermCR=CR frmMain.chkTermLF=LF frmMain.spTermPause=Pause frmMain.spTermPauseHint=Pause log frmMain.lbRXCnt=RX cnt.: frmMain.lbTXCnt=TX cnt.: frmMain.btn2048=2048 frmMain.qAdrSkype=Skype frmMain.qAdrFacebook=Facebook frmMain.qAdrWLanSSID=WLanSSID frmMain.qAdrWLanPasswort=WLanPassword frmMain.qAdrKunde=Customer frmMain.qSuchBAendDatum=Component date frmMain.qBestellBarcode=Store barcode frmMain.mnBBarcodeErzeuge=generate barcode Case frmMain.mnBBarcodeWebcam=Read the barcode with a webcam frmMain.qTypBID=ID frmMain.qTypBSMD_Text=SMD_Text frmMain.qGehauseBID=ID frmMain.qProjektIntervall=Interval frmMain.qPPostree_typ=Type frmMain.qPPostree_typ_ID=Type ID frmMain.mnPPExpBOM=Export BOM frmMain.mnPExport=Export Project frmMain.mnMoveAdrKontakt=Move to contact frmMain.mnCpGeraetMit=Copy with position frmMain.qBProjektPVBezeichnung=Project version descr. frmMain.qBProjektPVVersion=Project version frmMain.qKisteBID=ID frmMain.mnGotoBautLgGeh=Goto Store/Case frmMain.qAdrBID=ID frmMain.qAdrKKontaktArt=KontaktType frmMain.qAdrKSkype=Skype frmMain.qAdrKFacebook=Facebook frmMain.qAdrKWLanSSID=WLanSSID frmMain.qAdrKWLanPasswort=WLanPassword frmMain.qAdrKKunde=Customer frmMain.qPGeraetFoto_ID=Foto_ID frmMain.qPGeraetID_ID_Version=ID_ID_Version frmMain.qPGeraetProjektVersion_ID=Version frmMain.qPGeraetTyp=Type frmMain.qPGeraetVersionTyp=VersionType frmMain.qPGeraetBezeichnung=Designation frmMain.qPGeraetBeschreibung=Text frmMain.qPGeraetMengeFertig=Quantity finished frmMain.qPGeraetMengeOffen=Quantity Open frmMain.qPGeraetKennz=Flag frmMain.qPGeraetTermin=Termin frmMain.qPGeraetHandbuch=Handbook frmMain.qPGeraetInfo=Info frmMain.qPGeraetBauteil_ID=Component frmMain.qPGeraetOptA=OptA frmMain.qPGeraetOptB=OptB frmMain.qPGeraetOptC=OptC frmMain.qPGeraetWartung=Service frmMain.qPGeraetIntervall=Interval frmMain.qPGeraetVariante=Variant frmMain.qPGeraetAuftrag=commission frmMain.qPGeraetAdr_ID=Address frmMain.qPGeraetSNr=SNr frmMain.qPGeraetVPreis=VPrice frmMain.qPGeraetAendDatum=ChangeDate frmMain.qPGeraetArtikelNr=Store item no frmMain.qPGeraetArtikelNr2=Store item no 2 frmMain.qDokuAutoNr=AutoNr frmMain.qPDokuAutoNr=AutoNr frmMain.qPDokuNr=No frmMain.mnPGExpCSV=Export CSV-Format frmMain.mnPGExpXML=Export XML-Format frmMain.mnPGInfoEtikett=Printing Label "Info" frmMain.mnPGVerz=Create directories frmMain.mnPGVersNew=Create version frmMain.mnPGVersAend=Change version frmMain.mnPGVersZeig=Show version frmMain.mnPGVersZeigAktuell=Current frmMain.qPGPosProjekt_ID=Project frmMain.qPGPosFoto_ID=Foto_ID frmMain.qPGPosID_ID_Version=ID_ID_Version frmMain.qPGPosProjektVersion_ID=Version frmMain.qPGPosBezeichnung=Designation frmMain.qPGPosArtikelNr=on label only one component frmMain.qPGPosStatus=Status frmMain.qPGPosBemerkung=Remark frmMain.qPGPosBauteil=Component frmMain.qPGPosBauteil_ID=Component frmMain.qPGPostree_typ=Type frmMain.qPGPostree_typ_ID=Type ID frmMain.qPGPosSymbol=Symbol frmMain.qPGPosWert=Value frmMain.qPGPosGehause=Case frmMain.qPGPosMenge=Quantity frmMain.qPGPosEPreis=Price frmMain.qPGPosRabatt=Discount frmMain.qPGPosGPreis=Total Price frmMain.qPGPosArt=Category frmMain.qPGPosVariante=Variant frmMain.qPGPosPosX=Pos X frmMain.qPGPosPosY=Pos Y frmMain.qPGPosPosZ=Pos Z frmMain.qPGPosPosR=Pos R frmMain.qPGPosTop=Top frmMain.qPGPosSMD=SMD frmMain.qPGPosBarcode=Barcode frmMain.qPGPosKennz=Flag frmMain.qPGPosHandbuch=Handbook frmMain.qPGPosInfo=Info frmMain.qPGPosLMenge=Stocks frmMain.qPGPosGBez=StoreCase frmMain.qPGPosSNr=SNr frmMain.qPGPosDruck=Print frmMain.qPGPosAendDatum=ChangeDate frmMain.qPGPosGeloescht=Deleted frmMain.qHist2Projekt_ID=Project frmMain.qHist2ProjektPos_ID=bestellen frmMain.qHist2Foto_ID=Foto_ID frmMain.qHist2Datum=Date frmMain.qHist2Status=Status frmMain.qHist2FStatus=B/F frmMain.qHist2Projekt=Project Descr. frmMain.qHist2Bezeichnung=Designation frmMain.qHist2Beschreibung=Text frmMain.qHist2Version=Version frmMain.qHist1SNr1=Serial number frmMain.qHist2GNr=Devi&ce number frmMain.qHist2FDatum=Date ready frmMain.qHist2FVersion=Version ready frmMain.qHist2Aufwand=Time frmMain.qHist2Kennz=Flag frmMain.qHist2Handbuch=Handbook frmMain.qHist2Info=Info frmMain.qHist2Kosten_ID=Quotation frmMain.qHist2Vorgehen=Proceedin&g frmMain.qHist2Abrechnung=Invoice frmMain.qHist2GPreis=Total Price frmMain.qHist2KundeBes=Error report custo&mer frmMain.qHist2RepNr=RMA frmMain.qHist2RepFehler=Error code frmMain.qHist2RepBes=Repair Report frmMain.qHist2Adr_ID=Address frmMain.qHist2AdrK_ID=Contact frmMain.qHist2AendDatum=ChangeDate frmMain.qPGDokuID_ID_Version=ID_ID_Version frmMain.qPGDokuProjekt_ID=Project_ID frmMain.qPGDokuDoku_ID=Documentation frmMain.qPGDokuFoto_ID=Foto_ID frmMain.qPGDokuBauteil=Component frmMain.qPGDokuBauteil_ID=Component_ID frmMain.qPGDokuBezeichnung=Designation frmMain.qPGDokuKurzBez=ShortDesc frmMain.qPGDokuThema=Topic frmMain.qPGDokuStatus=Status frmMain.qPGDokuDatum=Date frmMain.qPGDokuVersion=Version frmMain.qPGDokuRevision=Revision frmMain.qPGDokuBearbeiter=Editor frmMain.qPGDokuHandbuch=Handbook frmMain.qPGDokuHandbuchPDF=HandbookPDF frmMain.qPGDokuBemerkung=Remark frmMain.qPGDokuInfo=Info frmMain.qPGDokuQuelleDoku=SourceDoku frmMain.qPGDokuAutoNr=AutoNr frmMain.qPGDokuNr=No frmMain.qPGDokuKennz=Flag frmMain.qPGDokuOptA=OptA frmMain.qPGDokuOptB=OptB frmMain.qPGDokuOptC=OptC frmMain.qPGDokuAendDatum=ChangeDate frmMain.qPGDokuDokuBez=DocuDescr frmMain.qPGDokuDokuKurzBez=DocuShortDesc frmMain.qPGDokuDokuStatus=DocuStatus frmMain.qPFDokuDokuDatum=DocuDate frmMain.qPGDokuDokuVersion=DocuVersion frmMain.qPGDokuDokuThema=DocuTopic frmMain.qPGDokuDokuHandbuch=DocuHandbook frmMain.qPGDokuDokuHandbuchPDF=DocuHandbookPDF frmMain.qPGDokuDokuBemerkung=DocuRemark frmMain.qPGDokuDokuInfo=DocuInfo frmMain.qPGDokuDokuArchiv=DocuArchiv frmMain.qPGDokuDokuNr=DocuNr frmMain.qPGVersFoto_ID=Foto_ID frmMain.qPGVersProjekt_ID=Project frmMain.qPGVersDatum=Date frmMain.qPGVersVersion=Version frmMain.qPGVersRevision=Revision frmMain.qPGVersStatus=Status frmMain.qPGVersBezeichnung=Designation frmMain.qPGVersBauteil=Component frmMain.qPGVersBauteil_ID=Component frmMain.qPGVersBeschreibung=Text frmMain.qPGVersBearbeiter=Editor frmMain.qPGVersTermin=Termin frmMain.qPGVersPruefer=Inspector frmMain.qPGVersPrueferD=Inspection date frmMain.qPGVersFreigeber=Releaser frmMain.qPGVersFreigeberD=Released date frmMain.qPGVersMengeFertig=Quantity finished frmMain.qPGVersMengeOffen=Quantity Open frmMain.qPGVersVPreis=VPrice frmMain.qPGVersHandbuch=Handbook frmMain.qPGVersInfo=Info frmMain.qPGVersAuftrag=commission frmMain.qPGVersSNr=SNr frmMain.qPGVersArtikelNr=on label only one component frmMain.qPGVersArtikelNr2=Item no 2 frmMain.qPGVersBarcode=Barcode frmMain.qPGVersOptA=OptA frmMain.qPGVersOptB=OptB frmMain.qPGVersOptC=OptC frmMain.qPGVersKennz=Flag frmMain.qPGVersAendDatum=ChangeDate frmMain.qPGKostProjekt_ID=Project frmMain.qPGKostAdr_ID=Address frmMain.qPGKostAdrK_ID=Contact frmMain.qPGKostFoto_ID=Foto_ID frmMain.qPGKostBezeichnung=Designation frmMain.qPGKostBeschreibung=Text frmMain.qPGKostStatus=Status frmMain.qPGKostRabatt=Discount frmMain.qPGKostGPreis=Total Price frmMain.qPGKostAuftrag=commission no frmMain.qPGKostBestellnr=Order-Nr. frmMain.qPGKostDAngebot=&Offer frmMain.qPGKostDGueltig=&Valid to frmMain.qPGKostDLief=De&livery frmMain.qPGKostDAbnahme=Acce&ptance frmMain.qPGKostInfo=Info frmMain.qPGKostAendDatum=ChangeDate frmMain.qPGKostPosProjekt_ID=Project_ID frmMain.qPGKostPosKosten_ID=Kosten_ID frmMain.qPGKostPosProjektPos_ID=bestellen frmMain.qPGKostPosBauteil_ID=Component frmMain.qPGKostPosFoto_ID=Foto_ID frmMain.qPGKostPosNr=No frmMain.qPGKostPosBezeichnung=Designation frmMain.qPGKostPosBeschreibung=Text frmMain.qPGKostPosStatus=Status frmMain.qPGKostPosMenge=Quantity frmMain.qPGKostPosVPreis=VPrice frmMain.qPGKostPosRabatt=Discount frmMain.qPGKostPosVPSum=VPSum frmMain.qPGKostPosBarcode=Barcode frmMain.qPGKostPosArtikelNr=on label only one component frmMain.qPGKostPosTermin=Termin frmMain.qPGKostPosDLief=DDeliver frmMain.qPGKostPosInfo=Info frmMain.qPGKostPosArt=Category frmMain.qPGKostPosAendDatum=ChangeDate frmMain.qPGKostPosLArtikelNr=Store item no frmMain.qPGKostPosLBarcode=Store barcode frmMain.qPGKostPosLArt=Store Art frmMain.qPGKostPosLArtikelNr2=Store item no 2 frmMain.qPGBestellFoto_ID=Foto_ID frmMain.qPGBestellBezeichnung=Designation frmMain.qPGBestellMenge=Quantity frmMain.qPGBestellAuftrag=commission frmMain.qPGBestellStatus=Status frmMain.qPGBestellSDatum=SDatum frmMain.qPGBestellTermin1=Termin frmMain.qPGBestellTermin2=Date ordered frmMain.qPGBestellArchiv=Archive frmMain.qPGBestellBemerkung=Remark frmMain.qPGBestellBauteil_ID=Component frmMain.qPGBestellHandbuch=Handbook frmMain.qPGBestellInfo=Info frmMain.qPGBestellUseLief12=Supplier frmMain.qPGBestellLief_MengeVPE=Deliv. Qualtity Unit frmMain.qPGBestellLief_MengeVPESum=Deliv. Qualtity Unit Sum frmMain.qPGBestellLager_MengeVPESum=Storage Unit total amount frmMain.qPGBestellLief1_Adr_ID=Deliv1 Addr frmMain.qPGBestellLief1_BauteilAdr_ID=Deliv1 supplier frmMain.qPGBestellLief1_BestellNr=Deliv1 OrderNo frmMain.qPGBestellLief1_MengeVPE=Deliv1 Qualtity Unit frmMain.qPGBestellLief1_EPreis=Deliv1 Price frmMain.qPGBestellLief1_GPreis=Deliv1 Total frmMain.qPGBestellLief2_Adr_ID=Deliv2 Addr frmMain.qPGBestellLief2_BauteilAdr_ID=Deliv2 supplier frmMain.qPGBestellLief2_BestellNr=Deliv2 OrderNo frmMain.qPGBestellLief2_MengeVPE=Deliv2 Qualtity Unit frmMain.qPGBestellLief2_EPreis=Deliv2 Price frmMain.qPGBestellLief2_GPreis=Deliv2 Total frmMain.qPGBestellProjekt_ID=Project frmMain.qPGBestellAendDatum=ChangeDate frmMain.qPGVersBProjekt_ID=Project frmMain.qPGVersBFoto_ID=Foto_ID frmMain.qPGVersBID_ID_Version=ID_ID_Version frmMain.qPGVersBProjektVersion_ID=Version frmMain.qPGVersBBezeichnung=Designation frmMain.qPGVersBArtikelNr=on label only one component frmMain.qPGVersBStatus=Status frmMain.qPGVersBBemerkung=Remark frmMain.qPGVersBBauteil_ID=Component frmMain.qPGVersBSymbol=Symbol frmMain.qPGVersBWert=Value frmMain.qPGVersBGehause=Case frmMain.qPGVersBMenge=Quantity frmMain.qPGVersBEPreis=Price frmMain.qPGVersBRabatt=Discount frmMain.qPGVersBGPreis=Total Price frmMain.qPGVersBArt=Category frmMain.qPGVersBVariante=Variant frmMain.qPGVersBPosX=Pos X frmMain.qPGVersBPosY=Pos Y frmMain.qPGVersBPosZ=Pos Z frmMain.qPGVersBPosR=Pos R frmMain.qPGVersBTop=Top frmMain.qPGVersBSMD=SMD frmMain.qPGVersBBarcode=Barcode frmMain.qPGVersBKennz=Flag frmMain.qPGVersBHandbuch=Handbook frmMain.qPGVersBInfo=Info frmMain.qPGVersBSNr=SNr frmMain.qPGVersBDruck=Print frmMain.qPGVersBAendDatum=ChangeDate frmMain.qPGVersBGeloescht=Deleted frmMain.qPGPosVBProjekt_ID=Project frmMain.qPGPosVBFoto_ID=Foto_ID frmMain.qPGPosVBID_ID_Version=ID_ID_Version frmMain.qPGPosVBProjektVersion_ID=Version frmMain.qPGPosVBBezeichnung=Designation frmMain.qPGPosVBArtikelNr=on label only one component frmMain.qPGPosVBStatus=Status frmMain.qPGPosVBBemerkung=Remark frmMain.qPGPosVBBauteil_ID=Component frmMain.qPGPosVBSymbol=Symbol frmMain.qPGPosVBWert=Value frmMain.qPGPosVBGehause=Case frmMain.qPGPosVBMenge=Quantity frmMain.qPGPosVBEPreis=Price frmMain.qPGPosVBRabatt=Discount frmMain.qPGPosVBGPreis=Total Price frmMain.qPGPosVBArt=Category frmMain.qPGPosVBVariante=Variant frmMain.qPGPosVBPosX=Pos X frmMain.qPGPosVBPosY=Pos Y frmMain.qPGPosVBPosZ=Pos Z frmMain.qPGPosVBPosR=Pos R frmMain.qPGPosVBTop=Top frmMain.qPGPosVBSMD=SMD frmMain.qPGPosVBBarcode=Barcode frmMain.qPGPosVBKennz=Flag frmMain.qPGPosVBHandbuch=Handbook frmMain.qPGPosVBInfo=Info frmMain.qPGPosVBSNr=SNr frmMain.qPGPosVBDruck=Print frmMain.qPGPosVBAendDatum=ChangeDate frmMain.qPGPosVBGeloescht=Deleted frmMain.mnPGPEPreis=refresh Price frmMain.mnExpCSV3=Export CSV-Format frmMain.mnExpXML3=Export XML-Format frmMain.mnPGPInfoEtikett=Printing Label "Info" frmMain.mnPGDVersNew=Create version frmMain.mnPGDVersAend=Change version frmMain.mnPGDVersZeig=Show version frmMain.qPGEinzelProjekt_ID=Project_ID frmMain.qPGEinzelBauteil_ID=Component_ID frmMain.qPGEinzelAdr_ID=Adr_ID frmMain.qPGEinzelAdrK_ID=AdrK_ID frmMain.qPGEinzelKosten_ID=Kosten_ID frmMain.qPGEinzelKostenPos_ID=KostenPos_ID frmMain.qPGEinzelFoto_ID=Foto_ID frmMain.qPGEinzelStatus=Status frmMain.qPGEinzelBezeichnung=Designation frmMain.qPGEinzelBemerkung=Remark frmMain.qPGEinzelMenge=Quantity frmMain.qPGEinzelEPreis=Price frmMain.qPGEinzelRabatt=Discount frmMain.qPGEinzelGPreis=Total Price frmMain.qPGEinzelVariante=Variant frmMain.qPGEinzelArtikelNr=on label only one component frmMain.qPGEinzelBarcode=Barcode frmMain.qPGEinzelSNr=SNr frmMain.qPGEinzelGNr=GNr frmMain.qPGEinzelFDatum=RDate frmMain.qPGEinzelFVersion=RVersion frmMain.qPGEinzelBearbeiter=Editor frmMain.qPGEinzelBearbeiterD=EditorD frmMain.qPGEinzelPruefer=Inspector frmMain.qPGEinzelPrueferD=InspectorD frmMain.qPGEinzelDLief=De&livery frmMain.qPGEinzelService=Service frmMain.qPGEinzelServiceD=ServiceD frmMain.qPGEinzelHandbuch=Handbook frmMain.qPGEinzelInfo=Info frmMain.qPGEinzelKennz=Flag frmMain.qPGEinzelOptA=OptA frmMain.qPGEinzelOptB=OptB frmMain.qPGEinzelOptC=OptC frmMain.qPGEinzelAendDatum=ChangeDate frmBestellMin.spAll=All frmBestellMin.spNix=None frmBestellMin.qryID=ID frmBestellMin.qryMengeBest=QuantityOrdered frmBestellMin.qryPosBestell=bauteil frmBestellMin.qryMengeBestellen=OrderQuantity frmPPosTest.panVersion= frmPPosTest.lbVersion=Version: frmDruckEtikett.chkGrpFelderItem6=Every label only one component frmDruckEtikett.lbVersatz=Offset X/Y/Start frmDruckEtikett.lbMM3=mm frmDruckEtikett.lbVersatzAnzahl=Number frmDruckEtikett.qDataArtikelNr=on label only one component frmTelParam.tabModem=Modem / TAPI frmTelParam.tabEXE=External software frmTelParam.lbEXE=Program to be executed: frmTelParam.lbEXE1=Startparameter (%TELNR% / %TELNAME%): frmTelParam.rgrpAuswahl=Choice dial type frmTelParam.rgrpAuswahlItem0=Modem / TAPI frmTelParam.rgrpAuswahlItem1=External software frmKisteTausch.mnGotoBauteil2=Goto Store/Case frmKisteTausch.mnGotoBauteil=Goto Store/Case frmTypAuswahl.panWithSubItems= frmTypAuswahl.chkSubItems=View with subordinate elements frmKonfig.lbDirLib=Library frmKonfig.rgrpTAuswahl=Choice dial type frmKonfig.rgrpTAuswahlItem0=Modem / TAPI frmKonfig.rgrpTAuswahlItem1=External software frmKonfig.lbEXE=Program to be executed: frmKonfig.lbEXE1=Startparameter (%TELNR% is the phone number / %TELNAME%): frmKonfig.tabGDesign=Design frmKonfig.btnAdrkontakt=Edit address contract frmKonfig.btnInfoStatistik=Edit statistik frmKonfig.tabWeb=Web query frmKonfig.tabWebFarnell=Farnell frmKonfig.lbAdrFarnell=Address: frmKonfig.lbKeyFarnell=API-Key: frmKonfig.lbLandFarnell=Country: frmKonfig.lbRegisterFarnell=Where can I get an API key?\r\n1. Register as a partner: http://partner.element14.com/member/register\r\n2. Apply for API Key, it will be offered to you directly after registration\r\n3. It is the API Key at: "Product Search API (REST): Basic"\r\nThe API Key is only activated by Farnell -> "Status: active". frmKonfig.tabWebMouser=Mouser frmKonfig.lbAdrMouser=Address: frmKonfig.lbKeyMouser=API-Key: frmKonfig.lbLandMouser=Country: frmKonfig.lbRegisterMouser=Where can I get an API key?\r\n1. Create an account: https://www.mouser.de/MyMouser/MouserLogin.aspx\r\n2. Here: http://www.mouser.de/apihome/ "Sign Up" enter additional data\r\n3. An "API check code" will be sent by e-mail, which you enter in the web interface\r\n, then the API key will be shown. frmKonfig.lbWaehrungMouser=Currency: frmParAdrkontakt=Edit address contract frmParAdrkontakt.spNewHint=New entry frmParAdrkontakt.spSaveHint=Save data frmParAdrkontakt.spAbortHint=Abort change frmParAdrkontakt.spDeleteHint=Delete data frmParAdrkontakt.lbDatum=Date: frmParAdrkontakt.btnClose=Close frmParAdrkontakt.lbParameter=Parameter Nr / Name: frmParAdrkontakt.lbValText=Tab Name: frmParAdrkontakt.lbValInt=Sequence: frmParAdrkontakt.lbValFloat=ValFloat: frmParAdrkontakt.lbValMemo=Text: frmParAdrkontakt.qParamParNr=ParNr frmParAdrkontakt.qParamParName=ParName frmParAdrkontakt.qParamLand=Country frmParAdrkontakt.qParamValInt=Sequence frmParAdrkontakt.qParamValFloat=ValFloat frmParAdrkontakt.qParamValText=Tab Name frmParAdrkontakt.qParamValMemo=Text frmParAdrkontakt.qParamAendDatum=ChangeDate frmParStatistik=Edit statistik frmParStatistik.spNewHint=New entry frmParStatistik.spSaveHint=Save data frmParStatistik.spAbortHint=Abort change frmParStatistik.spDeleteHint=Delete data frmParStatistik.lbDatum=Date: frmParStatistik.btnClose=Close frmParStatistik.lbParameter=Parameter Nr / Name: frmParStatistik.lbValText=SQL-String alternative: frmParStatistik.lbValInt=Sequence: frmParStatistik.lbValFloat=ValFloat: frmParStatistik.lbValMemo=SQL-String: frmParStatistik.qParamParNr=ParNr frmParStatistik.qParamParName=ParName frmParStatistik.qParamLand=Country frmParStatistik.qParamValInt=Sequence frmParStatistik.qParamValFloat=ValFloat frmParStatistik.qParamValText=SQL-String alternative frmParStatistik.qParamValMemo=SQL-String frmParStatistik.qParamAendDatum=ChangeDate frmTermParam=Terminal Parameter frmTermParam.rgrpPort=COM Port frmTermParam.rgrpBaud=Baudrate frmTermParam.rgrpParity=Parity frmTermParam.rgrpParityItem0=None frmTermParam.rgrpParityItem1=Even frmTermParam.rgrpParityItem2=Odd frmTermParam.rgrpStopBits=Stopbits frmTermParam.lbBaud=Baudrate: frmTermParam.btnCancel=Cancel frmTermParam.btnOK=OK frmTermCustom=Terminal edit translation frmTermCustom.spNewHint=New data translation frmTermCustom.spCopyHint=Copy data translation frmTermCustom.spDeleteHint=Lösche datatranslation frmTermCustom.btnOK=OK frmTermCustom.btnCancel=Cancel frmTermCustom.mnVorlAnsi=ANSI frmTermCustom.mnVorlHex=HEX frmTermCustom.mnVorlDez=DEZ frmVersion.memVersion_Größe=Size frmPPosTest.qMengeBestelltO=Quantity ordered open frmPPosTest.qnMengeBestelltO=Quantity ordered open frmMain.qAdrIDGUID=IDGUID frmMain.qAdrIDGUIDT=IDGUIDT frmMain.qGehauseIDGUID=IDGUID frmMain.qGehauseIDGUIDT=IDGUIDT frmMain.qKisteIDGUID=IDGUID frmMain.qKisteIDGUIDT=IDGUIDT frmMain.qTypIDGUID=IDGUID frmMain.qTypIDGUIDT=IDGUIDT frmMain.qBauteilIDGUID=IDGUID frmMain.qBauteilIDGUIDT=IDGUIDT frmMain.qBAdrIDGUID=IDGUID frmMain.qBAdrIDGUIDT=IDGUIDT frmMain.qFotoIDGUID=IDGUID frmMain.qFotoIDGUIDT=IDGUIDT frmMain.qBestellIDGUID=IDGUID frmMain.qBestellIDGUIDT=IDGUIDT frmMain.qProjektIDGUID=IDGUID frmMain.qProjektIDGUIDT=IDGUIDT frmMain.qPPosIDGUID=IDGUID frmMain.qPPosIDGUIDT=IDGUIDT frmMain.qHist1IDGUID=IDGUID frmMain.qHist1IDGUIDT=IDGUIDT frmMain.qHistIDGUID=IDGUID frmMain.qHistIDGUIDT=IDGUIDT frmMain.qWissenIDGUID=IDGUID frmMain.qWissenIDGUIDT=IDGUIDT frmMain.qMP3IDGUID=IDGUID frmMain.qMP3IDGUIDT=IDGUIDT frmMain.qAdrKIDGUID=IDGUID frmMain.qAdrKIDGUIDT=IDGUIDT frmMain.qPKostIDGUID=IDGUID frmMain.qPKostIDGUIDT=IDGUIDT frmMain.qPKostPosIDGUID=IDGUID frmMain.qPKostPosIDGUIDT=IDGUIDT frmMain.qPGeraetIDGUID=IDGUID frmMain.qPGeraetIDGUIDT=IDGUIDT frmMain.qPVersIDGUID=IDGUID frmMain.qPVersIDGUIDT=IDGUIDT frmMain.qDokuIDGUID=IDGUID frmMain.qDokuIDGUIDT=IDGUIDT frmMain.qPDokuIDGUID=IDGUID frmMain.qPDokuIDGUIDT=IDGUIDT frmMain.qPGPosIDGUID=IDGUID frmMain.qPGPosIDGUIDT=IDGUIDT frmMain.qHist2IDGUID=IDGUID frmMain.qHist2IDGUIDT=IDGUIDT frmMain.qPGDokuIDGUID=IDGUID frmMain.qPGDokuIDGUIDT=IDGUIDT frmMain.qPGVersIDGUID=IDGUID frmMain.qPGVersIDGUIDT=IDGUIDT frmMain.qPGKostIDGUID=IDGUID frmMain.qPGKostIDGUIDT=IDGUIDT frmMain.qPGKostPosIDGUID=IDGUID frmMain.qPGKostPosIDGUIDT=IDGUIDT frmMain.qPGEinzelIDGUID=IDGUID frmMain.qPGEinzelIDGUIDT=IDGUIDT frmMain.spBLagerOctopartHint=Open Octopart frmMain.spBLagerArtOctopartHint=Open Octopart frmMain.spBLiefOctopartHint=Open Octopart frmMain.spBauteilOctopartHint=Open Octopart frmMain.spBestellOctopart1Hint=Open Octopart frmMain.spBestellOctopart2Hint=Open Octopart frmBauteil.qryBarcBID=BID frmBauteil.qryBarcBBez=Comp. Desc. frmBauteil.qryBarcBauteil_ID=Component_ID frmBauteil.qryBarcGehause_ID=Gehause_ID frmBauteil.qryBarcAdr_ID=Adr_ID frmBauteil.qryBarcFoto_ID=Foto_ID frmBauteil.qryBarcBezeichnung=Designation frmBauteil.qryBarcBarcode=Barcode frmBauteil.qryBarcArtikelNr=on label only one component frmBauteil.qryBarcArtikelNr2=Item no 2 frmBauteil.qryBarcSMD=SMD frmBauteil.qryBarcSMD_Text=SMD_Text frmBauteil.qryBarcMenge=Quantity frmBauteil.qryBarcMengeV=Quantity used frmBauteil.qryBarcMengeMin=Min Quantity frmBauteil.qryBarcMengeBestellen=QuantityOrdered frmBauteil.qryBarcEinheit=Unit frmBauteil.qryBarcEPreis=Price frmBauteil.qryBarcGPreis=Total Price frmBauteil.qryBarcVPreis=VPrice frmBauteil.qryBarcHaltbar=Preserved frmBauteil.qryBarcKiste_ID=Box frmBauteil.qryBarcLagernr=Stock no frmBauteil.qryBarcArt=Category frmBauteil.qryBarcBWare=BWare frmBauteil.qryBarcRoHS=RoHS frmBauteil.qryBarcBemerkung=Remark frmBauteil.qryBarcHandbuch=Handbook frmBauteil.qryBarcLibrary=Library frmBauteil.qryBarcKennz=Flag frmBauteil.qryBarcInfo=Info frmBauteil.qryBarcGewicht=Weight frmBauteil.qryBarcAendDatum=ChangeDate Strings.149=Enter position in history Strings.150=This component is already noted in the history. Should a new history entry be created for the component? Strings.151=Designation exists frmMain.lbBTecData=Tecnical data frmMain.chkBTecEdit=Change frmMain.spSTecDataHint=Tecnical data frmMain.spTypFTecDataHint=Tecnical data frmMain.btnSpendeHint=a donation can be made via PayPal to paypal@mmvisual.de. Thanks a lot! frmMain.mnPPTecData=Tecnical data frmMain.mnPPosToHist=Create history entry frmMain.mnGPTecData=Tecnical data frmMain.mnPGPosToHist=Create history entry frmCalcR.lbUges1=&Uges frmCalcR.lbUfb1=U&fb frmCalcR.lbV2=V frmCalcR.lbV3=V frmCalcR.lbV4=R frmCalcR.lbV5=R frmCalcR.chkFixUGes1=Fix frmCalcR.chkFixR1=Fix frmCalcR.chkFixR2=Fix frmCalcR.chkFixUFB1=Fix frmAuswahl.panTecData= frmKonfig.tabTechData=Tecnical data frmKonfig.lbTechData=List of parameters of the technical data. One parameter per line. frmKonfig.mnCheck=Check data integrity frmKonfig.mnMyDesigner=phpMyAdmin designer frmAdrInline_Lng.qAdrKTelefon2=Telephone 2 frmAdrInline_Lng.qAdrKTelefon=Telephone frmAdrInline_Lng.lbAdrKTel=Telephone frmAdrInline_Lng.qAdrKSWIFT=SWIFT frmAdrInline_Lng.qAdrKStrasse=Street frmAdrInline_Lng.lbAdrKStr=Street frmAdrInline_Lng.qAdrKSkype=Skype frmAdrInline_Lng.spMailK2Hint=Send E-Mail frmAdrInline_Lng.spMailKHint=Send E-Mail frmAdrInline_Lng.qAdrKPrivat=Privat frmAdrInline_Lng.chkAdrKPrivat=Privat frmAdrInline_Lng.qAdrKName=Name frmAdrInline_Lng.lbAdrKName=Name frmAdrInline_Lng.spAKNewHint=New entry frmAdrInline_Lng.qAdrKLogin=Login frmAdrInline_Lng.qAdrKKunde=Customer frmAdrInline_Lng.chkAdrKKunde=Customer frmAdrInline_Lng.qAdrKInternet=Internet frmAdrInline_Lng.lbAdrKINet=Internet frmAdrInline_Lng.qAdrKInfo=Info frmAdrInline_Lng.qAdrKIDGUIDT=IDGUIDT frmAdrInline_Lng.qAdrKIDGUID=IDGUID frmAdrInline_Lng.qAdrKIBAN=IBAN frmAdrInline_Lng.qAdrKHersteller=Manufactu&rer frmAdrInline_Lng.chkAdrKHerst=Manufactu&rer frmAdrInline_Lng.qAdrKGesperrt=Blocked frmAdrInline_Lng.chkAdrKGesperrt=Blocked frmAdrInline_Lng.lbAdrKGebDatum=Bi&rthday frmAdrInline_Lng.spAKDeleteHint=Delete data frmAdrInline_Lng.qAdrKfoto_ID=Foto_ID frmAdrInline_Lng.qAdrKFirma=Company frmAdrInline_Lng.qAdrKProjekt=P&roject frmAdrInline_Lng.qAdrKFax=Fax frmAdrInline_Lng.lbAdrKFax=Fax frmAdrInline_Lng.qAdrKFacebook=Facebook frmAdrInline_Lng.qAdrKEMail2=EMail2 frmAdrInline_Lng.lbAdrKMail=E-Mail frmAdrInline_Lng.qAdrKEMail=EMail frmAdrInline_Lng.spAKPrintHint=Print frmAdrInline_Lng.lbDatum15=Date: frmAdrInline_Lng.spAKCopyHint=Copy data frmAdrInline_Lng.qAdrKPLZ=Code frmAdrInline_Lng.qAdrKBank=Bank frmAdrInline_Lng.qAdrKBezeichnung=D&esignation frmAdrInline_Lng.lbAdrKBez=D&esignation frmAdrInline_Lng.spAKSaveHint=Save data frmAdrInline_Lng.spGeburtstagKHint=Choice date frmSuchTecDataInline_Lng.chkAktiv=activ frmAdrInline_Lng.spAKAbortHint=Abort change frmAdrInline_Lng.qAdrKLieferant=Deliverer frmAdrInline_Lng.chkAdrKLief=Deliverer frmAdrInline_Lng.spHandbuch11Hint=Choice Manual (File) frmAdrInline_Lng.oDlg=Select Existing File frmAdrInline_Lng.qAdrKWLanSSID=WLanSSID frmAdrInline_Lng.qAdrKWLanPasswort=WLanPassword frmSuchTecDataInline_Lng.spDelHint=Delete frmAdrInline_Lng.qAdrKUsSTID=VAT-ID frmSuchTecDataInline_Lng.rbText=test frmAdrInline_Lng.lbAdrKTel2=Telephone 2 frmAdrInline_Lng.qAdrKLand=Country frmAdrInline_Lng.lbAdrKLand=Country frmAdrInline_Lng.chkAdrKProjekt=Project/History frmAdrInline_Lng.spTelK2Hint=Dial phone number frmAdrInline_Lng.spTelKMobHint=Dial phone number frmAdrInline_Lng.spTelK1Hint=Dial phone number frmAdrInline_Lng.qAdrKHandbuch=Handbook frmAdrInline_Lng.lbAdrKHandbuch=Handbook frmAdrInline_Lng.spHandbuch11ExecHint=Open manual frmAdrInline_Lng.spInternetKHint=Open Web-Browser frmAdrInline_Lng.qAdrKKundNr=CustomerID frmAdrInline_Lng.lbAdrKKundNr=Customer nr frmAdrInline_Lng.qAdrKMobil=Handy frmAdrInline_Lng.lbAdrKMobil=Handy frmAdrInline_Lng.qAdrKOrt=Location frmSuchTecDataInline_Lng.rbZahl=Number frmAdrInline_Lng.spAdrKCpyHint=Copy address in clipboard frmAdrInline_Lng.qAdrKKonto=Account frmAdrInline_Lng.qAdrKKontaktArt=KontaktType frmAdrInline_Lng.qAdrKBemerkung=Remark frmAdrInline_Lng.qAdrKBLZ=BLZ frmAdrInline_Lng.lbAdrKPlz=Postal Code frmAdrInline_Lng.qAdrKPasswort=Pass&word frmAdrInline_Lng.lbAdrKMail2=E-Mail 2 frmAdrInline_Lng.qAdrKAendDatum=ChangeDate frmAdrInline_Lng.qAdrKGebDatum=Birthday frmTecDataShowInline_Lng.panTop=Tecnical data frmAdrInline_Lng.panAdrKontaktBild= frmAdrInline_Lng.panTopAdrK= frmAdrInline_Lng.panAdrDet1= frmAdrInline_Lng.panAdrKMain= Strings.152=Name already exists. Do you want to jump to the record? Strings.153=Do you really want to run the data integrity check?\r\nThis check automatically corrects the database. Strings.154=Do you really want to integrate this part variant into another one?\r\nThen it is transferred crate/storage and the supplier to the selected part. Strings.155=In the freeware version up to 2 storage bins can be used.\r\nTo use more storage bins please order the Pro version. Strings.156=In the freeware version, related parts cannot be grouped together.\r\nThis function is only enabled with the Pro version. Strings.157=Component|"Working time"|"Small material"|"Measure point" Strings.158=This component is still used in projects and therefore cannot be deleted. frmMain.tabBGehause=Case/variant frmMain.lbBVariCase=&Case frmMain.dbBVariSMD=&SMD frmMain.edBLMengeHint= frmMain.lbBVarirBez=D&escription frmMain.lbBVariLib=L&ibrary frmMain.lbBVariHersteller=Manufactu&rer frmMain.lbBVariBarcode=B&arcode frmMain.lbBVariGewicht=&Weight frmMain.lbBVariEPreis=&Price frmMain.lbBVarirPinout=Pinout frmMain.lbBVariArtikelNr=Ite&m no frmMain.lbBVariInfo=Info frmMain.lbBVariMenge=&Quantity frmMain.lbBVariArtikelNr2=Item no 2 frmMain.lbBVariBWare=BWare frmMain.spBVerwandtHint=Replacement/related components frmMain.spBVarKisteHint=Variant box frmMain.tabBKiste=Box/storage frmMain.spBKNewHint=New entry frmMain.spBKCopyHint=Copy data frmMain.spBKSaveHint=Save data frmMain.spBKAbortHint=Abort change frmMain.spBKDeleteHint=Delete data frmMain.lbDatum29=Date: frmMain.spBKPrintHint=Print frmMain.spBKFachHint=Components in case / tray manage frmMain.lbBLSumMenge=Sum quantity: frmMain.spBauteilKisteCalcHint=Calculator frmMain.lbBKGehauseVariante=Variant frmMain.spGotoKisteLagerHint=Goto Store/Case frmMain.lbBKKiste=&Box frmMain.lbBKLagerNr=Stock/&Field frmMain.lbBKMenge=&Quantity frmMain.edKisteManiHint=Stock with a plus / minus manipulate frmMain.btnKisteManiM=- frmMain.btnKisteManiMHint=Stock with a minus manipulate frmMain.btnKisteManiP=+ frmMain.btnKisteManiPHint=Stock with a plus manipulate frmMain.btnBestellBauteil8Hint=Take part in order proposal frmMain.lbBKBezeichnung=D&escription frmMain.lbBKHaltbar=Best bef&ore frmMain.lbBKHaltbarRest=Time rest: frmMain.lbBKGewicht=&Weight frmMain.lbBKHandbuch=Ha&ndbook frmMain.spHandbuch18Hint=Choice Manual (File) frmMain.spHandbuch18ExecHint=Open manual frmMain.spBKInfoEtikettHint=Printing Label frmMain.lbBKInfo=Info frmMain.lbBKLagerPosX=Component description frmMain.lbBKLagerPosY=Y frmMain.lbBKLagerPosZ=Z frmMain.lbBKStatus=Status frmMain.spBKSFrei=R frmMain.spBKSFreiHint=Enabled frmMain.spBKSGesperrt=D frmMain.spBKSGesperrtHint=Blocked frmMain.spBKSLeeren=E frmMain.spBKSLeerenHint=Clear frmMain.spBKSProjekt=T frmMain.spBKSProjektHint=Project frmMain.spBKSNichtVerwenden=D frmMain.spBKSNichtVerwendenHint=Do not use frmMain.lbBKisteBWare=BWare frmMain.lbBLiefEPreisM=&E-Prices from quantity frmMain.lbBLiefMengeEP=Quantity per purchase price frmMain.spPPosKein=- frmMain.lbPPosVerwandt=Related frmMain.lbPPosVerwandtHint=Related parts may be used frmMain.spHist1BugO=OPL frmMain.spHist1BugOHint=Open items list frmMain.spPGPosKein=- frmMain.lbPPosVerwandt1=Related frmMain.lbPPosVerwandt1Hint=Related parts may be used frmMain.spHist2BugO=OPL frmMain.spHist2BugOHint=Open items list frmMain.spBestelltKisteHint=Box from component frmMain.lbBestInKiste= frmMain.lbAdrPwd=Pass&word frmMain.btnCalcAntenne= frmMain.spHistBugO=OPL frmMain.spHistBugOHint=Open items list frmMain.btnDebugSqlNew=+ SQL Tab frmMain.btnLiz=Pro licensing frmMain.qBVariBauteil_ID=Component frmMain.qBVariFoto_ID=Foto_ID frmMain.qBVariBezeichnung=Designation frmMain.qBVariArtikelNr=Item no frmMain.qBVariGehause=Case frmMain.qBVariGehause_ID=Case frmMain.qBVariMenge=Quantity frmMain.qBVariMengeMin=Min Quantity frmMain.qBVariMengeBestellen=QuantityOrdered frmMain.qBVariProjSum=Quantity Proj frmMain.qBVariEPreis=Price frmMain.qBVariVPreis=VPrice frmMain.qBVariSMD=SMD frmMain.qBVariSMD_Text=SMD_Text frmMain.qBVariPinout=Pinout frmMain.qBVariArt=Category frmMain.qBVariRoHS=RoHS frmMain.qBVariBemerkung=Remark frmMain.qBVariHandbuch=Handbook frmMain.qBVariAdr=Adr frmMain.qBVariAdr_ID=Manufacturer frmMain.qBVariLibrary=Library frmMain.qBVariBWare=BWare frmMain.qBVariKennz=Flag frmMain.qBVariGewicht=Weight frmMain.qBVariGehGewicht=Weight (case) frmMain.qBVariGehSMD=SMD (case) frmMain.qBVariBarcode=Barcode frmMain.qBVariArtikelNr2=Item no 2 frmMain.qBVariInfo=Info frmMain.qBVariVerwandt=Related frmMain.qBVariBauteilVerwandt_ID=ComponentRelated_ID frmMain.qBVariAendDatum=ChangeDate frmMain.qBVariIDGUID=IDGUID frmMain.qBVariIDGUIDT=IDGUIDT frmMain.qBVariTecData=Tecnical data frmMain.qBVariGeloescht=Deleted frmMain.qBVariEinheit=Unit frmMain.qBAdrBauteilVariante=Variant frmMain.qBAdrBauteilVariante_ID=Variant ID frmMain.qBAdrEPreisM=Price M frmMain.qBAdrMengeEP=Quantity Purchase Price frmMain.qSuchVID=LID frmMain.qSuchVBez=Variant Comment frmMain.qSuchVBemerk=Variant Comment frmMain.qSuchVInfo=VInfo frmMain.qSuchPinout=Pinout frmMain.qSuchEinheit=Unit frmMain.qSuchVAendDatum=Variant date frmMain.qBestellFracht=Cargo frmMain.qBestellBauteilVariante=Variant frmMain.qBestellBauteilVariante_ID=Variant ID frmMain.qBestellBauteilKiste_ID=BauteilKiste frmMain.qProjektBauteilVariante_ID=Variant frmMain.qProjektKiste_ID=Box frmMain.qPPosBauteilVariante=Variant frmMain.qPPosBauteilVariante_ID=Variant ID frmMain.qPPosVerwandt=Related frmMain.qPPosVArtikelNr=Related ArticleNo frmMain.qPPosVBarcode=Related barcode frmMain.qPPosVArtikelNr2=Related ArticleNo2 frmMain.qPPosVArt=Related type frmMain.qPPosVHersteller=VProducer frmMain.qPPosVPinout=VPinout frmMain.mnPPKisteBauteil=Box from component frmMain.mnBauteilZusammenfassen=Summarize variant frmMain.qBBestellBauteilVariante_ID=Variant frmMain.qBProjektBauteilVariante_ID=Variant frmMain.qKisteBLagerPosX=Stock pos X frmMain.qKisteBLagerPosY=Stock pos Y frmMain.qKisteBLagerPosZ=Stock pos Z frmMain.qPBestellBauteilVariante_ID=Stock/case frmMain.qPKostPosBauteilVariante_ID=Component variant frmMain.qBBewBauteilVariante_ID=Component variant frmMain.qBBewBauteilKiste_ID=BauteilKiste frmMain.qBBewFracht=Cargo frmMain.qBBewEPreis=Price frmMain.qBBewIDGUID=IDGUID frmMain.qBBewIDGUIDT=IDGUIDT frmMain.qBBewGeloescht=Deleted frmMain.qAdrB1BauteilVariante_ID=Variant frmMain.qPGeraetBauteilVariante_ID=Variant frmMain.qPGeraetKiste_ID=Box frmMain.qPVersBauteilVariante=Variant frmMain.qPVersBauteilVariante_ID=Variant ID frmMain.qPVersBBauteilVariante_ID=Variant frmMain.qPPosVBBauteilVariante_ID=Variant frmMain.qPDokuBauteilVariante=Variant frmMain.qPDokuBauteilVariante_ID=Variant ID frmMain.qDokuBBauteilVariante_ID=Variant frmMain.qPGPosBauteilVariante=Variant frmMain.qPGPosBauteilVariante_ID=Variant ID frmMain.qPGPosVEinheit=Unit frmMain.qPGPosVerwandt=Related frmMain.qPGPosVArtikelNr=Store item no frmMain.qPGPosVBarcode=Store barcode frmMain.qPGPosVArtikelNr2=Store item no2 frmMain.qPGPosVArt=StoreArt frmMain.qPGPosVHersteller=VProducer frmMain.qPGPosVPinout=VPinout frmMain.qPGDokuBauteilVariante=Variant frmMain.qPGDokuBauteilVariante_ID=Variant ID frmMain.qPGVersBauteilVariante=Variant frmMain.qPGVersBauteilVariante_ID=Variant ID frmMain.qPGKostPosBauteilVariante_ID=Component variant frmMain.qPGBestellBauteilVariante_ID=Variant frmMain.qPGVersBBauteilVariante_ID=Variant frmMain.qPGPosVBBauteilVariante_ID=Variant frmMain.mnPGPKisteBauteil=Box from component frmMain.qPGEinzelBauteilVariante_ID=ComponentVariant_ID frmMain.qBKisteBauteil_ID=Component_ID frmMain.qBKisteBauteilVariante_ID=ComponentVariant_ID frmMain.qBKisteKiste_ID=Box frmMain.qBKisteFoto_ID=Foto_ID frmMain.qBKisteProjekt_ID=Project frmMain.qBKisteBezeichnung=Designation frmMain.qBKisteStatus=Status frmMain.qBKisteMenge=Quantity frmMain.qBKisteMengeV=Quantity used frmMain.qBKisteMengeMin=Min Quantity frmMain.qBKisteMengeRes=Quantity rest frmMain.qBKisteReserviertD=ReservedD frmMain.qBKisteHaltbar=Preserved frmMain.qBKisteLagernr=Stock no frmMain.qBKisteLagerPosX=Stock pos X frmMain.qBKisteLagerPosY=Stock pos Y frmMain.qBKisteLagerPosZ=Stock pos Z frmMain.qBKisteBWare=BWare frmMain.qBKisteBemerkung=Remark frmMain.qBKisteHandbuch=Handbook frmMain.qBKisteKennz=Flag frmMain.qBKisteInfo=Info frmMain.qBKisteGewicht=Weight frmMain.qBKisteBarcode=Barcode frmMain.qBKisteGeloescht=Deleted frmMain.qBKisteAendDatum=ChangeDate frmMain.qBKisteIDGUID=IDGUID frmMain.qBKisteIDGUIDT=IDGUIDT frmBestellMin.qryVID=LID frmBestellMin.qryVBez=Variant Comment frmDruckEtikett.chkGrpFelderItem7=Case frmDruckEtikett.chkGrpFelderItem8=Item no frmDruckEtikett.chkGrpFelderItem9=Only one component per label frmDruckEtikett.chkGroupBy= frmDruckEtikett.chkGroupByItem0=Stock/Field frmDruckEtikett.chkGroupByItem1=Component description frmDruckEtikett.chkGroupByItem2=Stock/case description frmDruckEtikett.chkGroupByItem3=Case frmDruckEtikett.qDataLagerPosX=PosX frmDruckEtikett.qDataLagerPosY=PosY frmDruckEtikett.qDataLagerPosZ=PosZ frmKisteTausch.qInhaltVBez=Variant description frmKisteTausch.qBauteilVID=LID frmKisteTausch.qBauteilKID=KID frmKisteTausch.qBauteilVariBez=Variant Desc frmKisteTausch.qBauteilKBez=BoxDesc. frmKisteTausch.qBauteilLagerPosX=Stock pos X frmKisteTausch.qBauteilLagerPosY=Stock pos Y frmKisteTausch.qBauteilLagerPosZ=Stock pos Z frmKisteTauschDlg.lbLagerNr1=Stock pos &X frmKisteTauschDlg.lbLagerNr2=Stock pos &Y frmKisteTauschDlg.lbLagerNr3=Stock pos &Z frmCalcR.lbTest=Against test: frmSchnell.qMem_VID=LID frmCalcLambda= frmCalcLambda.lbFreq=Frequency frmCalcLambda.lbLambda1=Lambda (wavelength) frmCalcLambda.lbLambda2=Lambda 1/2 frmCalcLambda.lbLambda4=Lambda 1/4 frmCalcLambda.lbLambda8=Lambda 1/8 frmCalcLambda.lbLambda16=Lambda 1/16 frmCalcLambda.btnClose=Close frmAuswahl.panMiddleMain= frmAuswahl.panMiddleKiste= frmAuswahl.panKisteBild= frmAuswahl.lbAnzahl=Quantity to book: frmAuswahl.qryBVID=LID frmAuswahl.qryBVFID=VFID frmAuswahl.qryBVBez=Variant Comment frmAuswahl.qryHIDGUID=IDGUID frmAuswahl.qryHIDGUIDT=IDGUIDT frmAuswahl.qryHFoto_ID=Foto_ID frmAuswahl.qryHBezeichnung=Designation frmAuswahl.qryHNummer=Number frmAuswahl.qryHPosX=PosX frmAuswahl.qryHPosY=PosY frmAuswahl.qryHLagerort=Location frmAuswahl.qryHGroesse=Size frmAuswahl.qryHBemerkung=Remark frmAuswahl.qryHHandbuch=Handbook frmAuswahl.qryHInfo=Info frmAuswahl.qryHBarcode=Barcode frmAuswahl.qryHParEtikett=ParLabel frmAuswahl.qryHGeloescht=Deleted frmAuswahl.qryHAendDatum=ChangeDate frmAuswahl.qryLagerPosIDGUID=IDGUID frmAuswahl.qryLagerPosIDGUIDT=IDGUIDT frmAuswahl.qryLagerPosBauteil_ID=Component_ID frmAuswahl.qryLagerPosBauteilVariante_ID=ComponentVariant_ID frmAuswahl.qryLagerPosKiste_ID=Box_ID frmAuswahl.qryLagerPosFoto_ID=Foto_ID frmAuswahl.qryLagerPosProjekt_ID=Project_ID frmAuswahl.qryLagerPosKBez=BoxDesc. frmAuswahl.qryLagerPosBezeichnung=Designation frmAuswahl.qryLagerPosMenge=Quantity frmAuswahl.qryLagerPosMengeRes=Quantity rest frmAuswahl.qryLagerPosMengeV=Quantity used frmAuswahl.qryLagerPosMengeMin=Min Quantity frmAuswahl.qryLagerPosStatus=Status frmAuswahl.qryLagerPosReserviertD=ReservedD frmAuswahl.qryLagerPosHaltbar=Preserved frmAuswahl.qryLagerPosLagernr=Stock no frmAuswahl.qryLagerPosLagerPosX=Stock pos X frmAuswahl.qryLagerPosLagerPosY=Stock pos Y frmAuswahl.qryLagerPosLagerPosZ=Stock pos Z frmAuswahl.qryLagerPosBWare=BWare frmAuswahl.qryLagerPosBemerkung=Remark frmAuswahl.qryLagerPosHandbuch=Handbook frmAuswahl.qryLagerPosKennz=Flag frmAuswahl.qryLagerPosInfo=Info frmAuswahl.qryLagerPosGewicht=Weight frmAuswahl.qryLagerPosBarcode=Barcode frmAuswahl.qryLagerPosGeloescht=Deleted frmAuswahl.qryLagerPosAendDatum=ChangeDate frmAuswahl.qryIIDGUID=IDGUID frmAuswahl.qryIIDGUIDT=IDGUIDT frmAuswahl.qryIBauteil_ID=Component_ID frmAuswahl.qryIBauteilVariante_ID=ComponentVariant_ID frmAuswahl.qryIKiste_ID=Box_ID frmAuswahl.qryIFoto_ID=Foto_ID frmAuswahl.qryIProjekt_ID=Project_ID frmAuswahl.qryIKBez=Box frmAuswahl.qryILagernr=Stock no frmAuswahl.qryILagerPosX=Stock pos X frmAuswahl.qryILagerPosY=Stock pos Y frmAuswahl.qryILagerPosZ=Stock pos Z frmAuswahl.qryIMenge=Quantity frmAuswahl.qryIMengeRes=Quantity rest frmAuswahl.qryIMengeV=Quantity used frmAuswahl.qryIMengeMin=Min Quantity frmAuswahl.qryIStatus=Status frmAuswahl.qryIBezeichnung=Designation frmAuswahl.qryIReserviertD=ReservedD frmAuswahl.qryIHaltbar=Preserved frmAuswahl.qryIKNummer=Box number frmAuswahl.qryIKPosX=Box PosX frmAuswahl.qryIKPosY=Box PosY frmAuswahl.qryIKLagerort=Box Storage location frmAuswahl.qryIBWare=BWare frmAuswahl.qryIBemerkung=Remark frmAuswahl.qryIHandbuch=Handbook frmAuswahl.qryIKennz=Flag frmAuswahl.qryIInfo=Info frmAuswahl.qryIGewicht=Weight frmAuswahl.qryIBarcode=Barcode frmAuswahl.qryIGeloescht=Deleted frmAuswahl.qryIAendDatum=ChangeDate frmAuswahl.qryIKFoto_ID=KFoto_ID frmKonfig.lbScalForm=Scale form frmKonfig.lbScalForm1=100..150% frmKonfig.lbWebabfrage=The deliverer can show the status from teh component frmKonfig.mnForeignKey=Create Foreign Key's frmBauteil.qryLBewBauteilVariante_ID=ComponentVariant_ID frmKisteTauschFach=Stock/Field frmKisteTauschFach.lbKiste=Box frmKisteTauschFach.lbLagerNr=Stock/Field frmKisteTauschFach.lbLagerPosX=Component description frmKisteTauschFach.lbLagerPosY=Stock/case description frmKisteTauschFach.lbLagerPosZ=Case frmKisteTauschFach.btnOK=OK frmKisteTauschFach.btnCancel=Cancel frmLizenzierung=Licensing Pro version frmLizenzierung.tabLicAntrag=Apply for a licence frmLizenzierung.btnWeiter1=Next frmLizenzierung.btnCancel=Cancel frmLizenzierung.lbFirma=Company frmLizenzierung.lbName=Name * frmLizenzierung.lbOrt=Postal Code * frmLizenzierung.lbStrasse=Street * frmLizenzierung.lbEMail=E-Mail * frmLizenzierung.lbLand=Country * frmLizenzierung.lbUsStID=VAT-ID frmLizenzierung.tabLicSend=Request license frmLizenzierung.btnSpeichern=Save frmLizenzierung.btnCancel1=Cancel frmLizenzierung.btnZuruck=Back frmLizenzierung.lbInfo=Copy text and email to elela@mmvisual.de. frmLizenzierung.tabLicAktiv=Licensing active frmLizenzierung.lbFirma1=Company frmLizenzierung.lbName1=Name frmLizenzierung.lbOrt1=Postal Code frmLizenzierung.lbStrasse1=Street frmLizenzierung.lbEMail1=E-Mail frmLizenzierung.lbLand1=Country frmLizenzierung.lbEMail2=License number frmLizenzierung.lbUsStID1=VAT-ID frmLizenzierung.btnClose=Close frmLizenzierung.tabLic=Licenses frmLizenzierung.btnClose1=Close frmLizenzierung.btnLoad=Load lic frmLizenzierung.btnMake=Create frmLizenzierung.btnSaveLic=Save Lic frmLizenzierung.qParIDGUID=IDGUID frmLizenzierung.qParIDGUIDT=IDGUIDT frmLizenzierung.qParParNr=ParNr frmLizenzierung.qParParName=ParName frmLizenzierung.qParLand=Country frmLizenzierung.qParValFloat=ValFloat frmLizenzierung.qParGeloescht=Deleted frmLizenzierung.qParAendDatum=ChangeDate frmLizenzierung.SDlg=Save file as frmLizenzierung.qEleLaLicIDGUID=IDGUID frmLizenzierung.qEleLaLicIDGUIDT=IDGUIDT frmLizenzierung.qEleLaLicFirma=Company frmLizenzierung.qEleLaLicName=Name frmLizenzierung.qEleLaLicStrasse=Street frmLizenzierung.qEleLaLicOrt=Location frmLizenzierung.qEleLaLicLand=Country frmLizenzierung.qEleLaLicEMail=EMail frmLizenzierung.qEleLaLicUsStID=VAT-ID frmLizenzierung.qEleLaLicDB=DB frmLizenzierung.qEleLaLicKdNr=CustNr frmLizenzierung.qEleLaLicLizenz=License frmLizenzierung.qEleLaLicBemerkung=Remark frmLizenzierung.qEleLaLicStatus=Status frmLizenzierung.qEleLaLicInfo=Info frmLizenzierung.qEleLaLicKennz=Flag frmLizenzierung.qEleLaLicGeloescht=Deleted frmLizenzierung.qEleLaLicAendDatum=ChangeDate frmLizenzierung.ODlg=Open license file frmLizenzierung.SDlgL=Create license file Strings.159=This function automatically generates a barcode for ALL crate/warehouse entries if the entry does not already have a barcode. frmMain.spBKBarFormatHint=Barcode frmMain.lbBKBarcode=B&arcode frmMain.qSuchLBarcode=SBarcode frmMain.mnBKBarcodeErzeuge=generate barcode store frmMain.spPGESave=L frmMain.tabSQL1= frmAdrInline_Lng= frmSuchTecDataInline_Lng= frmTecDataShowInline_Lng= frmLizenzierung.qParValInt= frmLizenzierung.qParValText= frmLizenzierung.qParValMemo=
