clear % Bresenham fractional divider vs DDS % First Question: Does Jitter for DDS depend on % accumulator width? %Example: 11 MHz clock= 11 * 5^6 * 2^6 % 310kHz output = 31 * 5^4 *2^4 nn=2*31*11*100; %nn=100; % Signal references % add some phaseshifts to avoid 'exact' zero results fastsig= (real(exp(j*(2*pi*(0:nn-1)/(31 )+0.1234)))); slowsig= (real(exp(j*(2*pi*(0:nn-1)/(1100)+0.1234)))); fastref=sign(real(exp(j*(2*pi*(0:nn-1)/(31 )+0.1234)))); slowref=sign(real(exp(j*(2*pi*(0:nn-1)/(1100)+0.1234)))); spfastsig=fft(fastsig); spslowsig=fft(slowsig); spfastref=fft(fastref); spslowref=fft(slowref); plot(0:nn-1,fastsig,'b.-',.... 0:nn-1,fastref,'r.-'); plot(0:nn-1,20*log10(abs(spfastsig)),'b.-',.... 0:nn-1,20*log10(abs(spfastref)),'r.-'); plot(0:nn-1,20*log10(abs(spfastref)),'b.-',.... 0:nn-1,20*log10(abs(spslowref)),'r.-'); acc32 =uint64(0); phaseinc32=uint64(2^32/31); fastdds32=zeros(size(fastref)); for(k=1:nn) acc32=acc32+phaseinc32; acc32=bitand(acc32,2^32-1); % too dumb for overflow arith fastdds32(k)=2*(bitand(acc32,2^31)>0)-1; end; spfastdds32=fft(fastdds32); plot(0:nn-1,20*log10(abs(spfastref)),'b.-',.... 0:nn-1,20*log10(abs(spfastdds32)),'r.-'); % identical! nn too small to see any difference BITBIT=20; acc32 =uint64(0); phaseinc32=uint64((2^BITBIT)/31); fastdds16=zeros(size(fastref)); for(k=1:nn) acc32=acc32+phaseinc32; acc32=bitand(acc32,(2^BITBIT)-1); % too dumb for overflow arith fastdds16(k)=2*(bitand(acc32,2^(BITBIT-1))>0)-1; end; spfastdds16=fft(fastdds16); plot(0:nn-1,20*log10(abs(spfastdds16)),'b.-',.... 0:nn-1,20*log10(abs(spfastdds32)),'r.-'); plot(fastdds16-fastdds32,'.'); % answer question 1: yes, threshold effect, any width % broader 19 is ok. Then no difference betwenn fastdds16 and % fastdds32 %ph=exp(j*2*pi*(0:nn-1)/31)./exp(j*2*pi*(0:nn-1)/1100); ph=296*31; fracdiv=zeros(size(fastsig)); for(k=1:nn) ph= ph+1*31; fracdiv(k)=2*(ph<=((1100*31)/2))-1; if(ph>=1100*31) ph=ph-1100*31;end; end; spfracdiv=fft(fracdiv); plot(0:nn-1,20*log10(abs(spslowref)),'b.-',.... 0:nn-1,20*log10(abs(spfracdiv)),'r.-'); plot(1:3000,slowref(1:3000),'.-',1:3000,fracdiv(1:3000),'.-') sum(abs(fracdiv-slowref)) return bres1= (0:nn-1)*31 % Bresenham == fractional divider ? xxx=0:nn-1; ee=fix((nn/2+(0:nn-1)*deltay)/nn); return
